After applying latest version(5.0.2), type-c device mode is not working now. ( I used sdk-manager several times to update it.)
I tested it with 5.0.1-DP(5.0.0~5.0.1) again.
type-c device mode is normal working with 5.0.1-DP.
I need to use the features of the following port as mandatory.
Also I have to use the latest version(5.0.2) due to some bugs.
Do you have any solutions?
Up-stream Facing Port (UFP)
USB Type-C port next to 40-pin can act as UFP (Up-stream Facing Port) so NVIDIA Jetson AGX Orin Developer Kit act as a USB device when attached to a host PC.
You use this port as UFP when;
- Flashing NVIDIA Jetson AGX Orin Developer Kit from a host PC
- Using USB Device mode on L4T, which offers;
- Virtual Ethernet connection (Jetson being
192.168.55.1) over USB - Virtual UART connection (to complete OEM-config headless)
- USB Mass Storage class device mounted on host PC
