RT Patch for Jetpack 6 GA
Hi everyone, I am using Orin Developer Kit with Orin NX 16 GB module. I would like to use real-time kernel. I have followed the developer guide. I did respectively the below steps ;
  1. Download kernel source on Jetpack Archive
  2. Extract the kernel source on Linux_for_tegra/source
  3. I did steps on below the Building The Kerneling The Kernel Title
  4. I did steps on below the Building the NVIDIA Out-of-Tree Modules
  5. I did steps on below the Building the DTBs
  6. After that I create a user with that command
    $ sudo tools/l4t_create_default_user.sh -u nvidia -p nvidia -a -n nvidia-desktop --accept-license
    8.Finally I flashed the module
    $ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
    But the system didn’t open properly. It stucked after the first nvidia logo.
    What should I do now?
    Thanks for your answers.
Please get uart log of the Orin NX developer kit. See where it gets stuck from the log.
And please try default kernel and see if the system is booted successfully.
Hi Danelll,
Firstly, thanks for your answer.
After your message, i have tried kernel compile again without rt patch steps. It seems system is booted succesfully.
but when rt patch was applied, system didn’t boot up properly.
I attached the system log.
orinnxlog.txt (61.0 KB)
We don’t hit the issue on Orin NX developer kit(Orin NX module + Orin Nano carrier board). Attach the log for reference:
MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0000.070] I> t234-A01-0-Silicon (0x12347) Prod
[0000.075] I> Boot-mode : Coldboot
[0000.078] I> Entry timestamp: 0x00000000
[0000.082] I> last_boot_error: 0x0
[0000.085] I> BR-BCT: preprod_dev_sign: 0
[0000.089] I> rst_source: 0x0, rst_level: 0x0
[0000.093] I> Task: SE error check
[0000.096] I> Task: Bootchain select WAR set
[0000.100] I> Task: Enable SLCG
[0000.103] I> Task: CRC check
[0000.106] I> Task: Initialize MB2 params
[0000.110] I> MB2-params @ 0x40060000
[0000.113] I> Task: Crypto init
[0000.116] I> Task: Perform MB1 KAT tests
[0000.120] I> Task: NVRNG health check
[0000.124] I> NVRNG: Health check success
[0000.127] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.133] I> Task: Enabling and initialization of Bandwidth limiter
[0000.139] I> No request to configure MBWT settings for any PC!
[0000.145] I> Task: Secure debug controls
[0000.149] I> Task: strap war set
[0000.152] I> Task: Initialize SOC Therm
[0000.156] I> Task: Program NV master stream id
[0000.160] I> Task: Verify boot mode
[0000.166] I> Task: Alias fuses
[0000.169] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.176] I> Task: Print SKU type
[0000.179] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.184] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.189] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.193] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.197] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.201] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.206] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.210] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.215] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.219] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.223] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.227] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.231] I> FUSE_SKU_INFO_0 = 0xd3
[0000.235] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.239] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.242] I> SKU: Prod
[0000.245] I> Task: Boost clocks
[0000.248] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.253] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.258] I> BPMP NAFLL lock success.
[0000.262] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.266] I> Initializing PLLC2 for AXI_CBB.
[0000.270] I> AXI_CBB : src = 35, divisor = 0
[0000.274] I> Task: Voltage monitor
[0000.278] I> VMON: Vmon re-calibration and fine tuning done
[0000.283] I> Task: UPHY init
[0000.288] I> HSIO UPHY init done
[0000.291] W> Skipping GBE UPHY config
[0000.295] I> Task: Boot device init
[0000.298] I> Boot_device: QSPI_FLASH instance: 0
[0000.303] I> Qspi clock source : pllc_out0
[0000.307] I> QSPI Flash: Macronix 64MB
[0000.310] I> QSPI-0l initialized successfully
[0000.314] I> Task: TSC init
[0000.317] I> Task: Load membct
[0000.320] I> RAM_CODE 0x4000401
[0000.323] I> Loading MEMBCT
[0000.326] I> Slot: 0
[0000.328] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.333] I> Binary name: MEM-BCT-0
[0000.337] I> Size of crypto header is 8192
[0000.341] I> Size of crypto header is 8192
[0000.345] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.351] I> BCH of MEM-BCT-0 read from storage
[0000.355] I> BCH address is : 0x40050000
[0000.359] I> MEM-BCT-0 header integrity check is success
[0000.364] I> Binary magic in BCH component 0 is MEM0
[0000.369] I> component binary type is 0
[0000.373] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.380] I> MEM-BCT-0 binary is read from storage
[0000.384] I> MEM-BCT-0 binary integrity check is success
[0000.390] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.396] I> RAM_CODE 0x4000401
[0000.402] I> RAM_CODE 0x4000401
[0000.405] I> Task: Load Page retirement list
[0000.409] I> Task: SDRAM params override
[0000.413] I> Task: Save mem-bct info
[0000.417] I> Task: Carveout allocate
[0000.420] I> RCM blob carveout will not be allocated
[0000.425] I> Update CCPLEX IST carveout from MB1-BCT
[0000.430] I> ECC region[0]: Start:0x0, End:0x0
[0000.434] I> ECC region[1]: Start:0x0, End:0x0
[0000.438] I> ECC region[2]: Start:0x0, End:0x0
[0000.443] I> ECC region[3]: Start:0x0, End:0x0
[0000.447] I> ECC region[4]: Start:0x0, End:0x0
[0000.451] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.457] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.462] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.466] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.471] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.482] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.489] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0000.495] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0000.503] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000
[0000.510] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0000.517] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0000.524] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0000.531] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0000.538] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0000.545] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0000.552] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0000.559] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0000.566] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0000.573] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0000.579] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0000.586] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0000.593] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0000.600] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0000.607] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0000.614] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0000.621] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0000.628] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0000.635] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0000.642] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0000.649] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0000.656] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0000.662] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0000.669] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0000.676] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0000.683] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0000.690] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0000.697] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0000.703] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0000.710] I> Task: Thermal check
[0000.713] I> Using min_chip_limit as min_tmon_limit
[0000.718] I> Using max_chip_limit as max_tmon_limit
[0000.723] I> BCT max_tmon_limit = 105
[0000.726] I> BCT min_tmon_limit = -28
[0000.730] I> BCT max_tmon_limit = 105
[0000.733] I> BCT min_tmon_limit = -28
[0000.737] I> SKU specific max_chip_limit = 105
[0000.741] I> SKU specific min_chip_limit = -28
[0000.745] I> BCT max_chip_limit = 105
[0000.749] I> BCT min_chip_limit = -28
[0000.752] I> enable_soctherm_polling = 0
[0000.756] I> max temp read = 29
[0000.759] I> min temp read = 29
[0000.762] I> Enabling thermtrip
[0000.765] I> Task: Update FSI SCR with thermal fuse data
[0000.770] I> Task: Enable WDT 5th expiry
[0000.774] I> Task: I2C register
[0000.777] I> Task: Set I2C bus freq
[0000.780] I> Task: Reset FSI
[0000.783] I> Task: Pinmux init
[0000.786] I> skipped mmio_addr = 0x9240008
[0000.790] I> skipped mmio_addr = 0x9240000
[0000.794] I> skipped mmio_addr = 0x9240010
[0000.798] I> skipped mmio_addr = 0x9240018
[0000.802] I> skipped mmio_addr = 0x9240020
[0000.806] I> skipped mmio_addr = 0x9240030
[0000.810] I> skipped mmio_addr = 0x9240028
[0000.814] I> skipped mmio_addr = 0x9240038
[0000.818] I> skipped mmio_addr = 0x9240040
[0000.821] I> skipped mmio_addr = 0x9240048
[0000.825] I> skipped mmio_addr = 0x9241000
[0000.829] I> skipped mmio_addr = 0x9241008
[0000.833] I> skipped mmio_addr = 0x9241010
[0000.837] I> skipped mmio_addr = 0x9241018
[0000.841] I> skipped mmio_addr = 0x9241020
[0000.845] I> skipped mmio_addr = 0x9241028
[0000.849] I> skipped mmio_addr = 0x9241030
[0000.853] I> skipped mmio_addr = 0x9241038
[0000.857] I> skipped mmio_addr = 0x9241040
[0000.861] I> skipped mmio_addr = 0x9242000
[0000.865] I> skipped mmio_addr = 0x9242008
[0000.869] I> Task: Prod config init
[0000.872] I> Task: Pad voltage init
[0000.875] I> Task: Prod init
[0000.878] I> Task: Program rst req config reg
[0000.882] I> Task: Common rail init
[0000.886] I> DONE: Thermal config
[0000.890] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.898] I> DONE: SOC rail config
[0000.902] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.908] I> DONE: MEMIO rail config
[0000.912] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.918] I> DONE: GPU rail info
[0000.922] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.928] I> DONE: CV rail info
[0000.931] I> Task: Mem clock src
[0000.934] I> Task: Misc. board config
[0000.938] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.943] I> Task: SDRAM init
[0000.946] I> MemoryType: 4 MemBctRevision: 1
[0000.953] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision
: 1
[0000.960] I> MSS CAR: Init PLLM
[0000.963] I> MSS CAR: Init PLLHUB
[0000.968] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0000.980] I> SDRAM initialized!
[0000.983] I> SDRAM Size in Total 0x400000000
[0000.987] I> Task: Dram Ecc scrub
[0000.990] I> Task: DRAM alias check
[0001.000] I> Task: Program NSDRAM carveout
[0001.004] I> NSDRAM carveout encryption is enabled
[0001.008] I> Program NSDRAM carveout
[0001.012] I> Task: Register checker
[0001.015] I> Task: Enable clock-mon
[0001.019] I> FMON: Fmon re-programming done
[0001.023] I> Task: Mapper init
[0001.026] I> Task: SC7 Context Init
[0001.029] I> Task: CCPLEX IST init
[0001.033] I> Task: CPU WP0
[0001.035] I> Loading MCE
[0001.038] I> Slot: 0
[0001.040] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.045] I> Binary name: MCE
[0001.048] I> Size of crypto header is 8192
[0001.052] I> Size of crypto header is 8192
[0001.056] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.062] I> BCH of MCE read from storage
[0001.066] I> BCH address is : 0x4003e000
[0001.070] I> MCE header integrity check is success
[0001.075] I> Binary magic in BCH component 0 is MTSM
[0001.079] I> component binary type is 8
[0001.083] I> Size of crypto header is 8192
[0001.087] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.095] I> MCE binary is read from storage
[0001.100] I> MCE binary integrity check is success
[0001.104] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.111] I> Size of crypto header is 8192
[0001.122] I> Size of crypto header is 8192
[0001.126] I> Sending WP0 mailbox command to PSC
[0001.135] I> Task: XUSB Powergate
[0001.138] I> Skipping powergate XUSB.
[0001.141] I> Task: MB1 fixed firewalls
[0001.148] W> Firewall readback mismatch
[0001.153] I> Task: Load bpmp-fw
[0001.156] I> Slot: 0
[0001.158] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.163] I> Binary name: BPMP_FW
[0001.166] I> Size of crypto header is 8192
[0001.170] I> Size of crypto header is 8192
[0001.174] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.180] I> BCH of BPMP_FW read from storage
[0001.185] I> BCH address is : 0x807fe000
[0001.189] I> BPMP_FW header integrity check is success
[0001.193] I> Binary magic in BCH component 0 is BPMF
[0001.198] I> component binary type is 15
[0001.202] I> Size of crypto header is 8192
[0001.206] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.224] I> BPMP_FW binary is read from storage
[0001.230] I> BPMP_FW binary integrity check is success
[0001.235] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.241] I> Slot: 0
[0001.243] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.249] I> Binary name: BPMP_FW_DTB
[0001.253] I> Size of crypto header is 8192
[0001.257] I> Size of crypto header is 8192
[0001.260] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.267] I> BCH of BPMP_FW_DTB read from storage
[0001.271] I> BCH address is : 0x807fc000
[0001.275] I> BPMP_FW_DTB header integrity check is success
[0001.280] I> Binary magic in BCH component 0 is BPMD
[0001.285] I> component binary type is 16
[0001.289] I> Size of crypto header is 8192
[0001.293] I> strt_pg_num(13072) num_of_pgs(733) read_buf(0x807a05f0)
[0001.303] I> BPMP_FW_DTB binary is read from storage
[0001.309] I> BPMP_FW_DTB binary integrity check is success
[0001.314] I> Binary BPMP_FW_DTB loaded successfully at 0x807a05f0 (0x5b900)
[0001.321] I> Task: BPMP fw ast config
[0001.325] I> Task: Load psc-fw
[0001.327] I> Slot: 0
[0001.329] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.335] I> Binary name: PSC_FW
[0001.338] I> Size of crypto header is 8192
[0001.342] I> Size of crypto header is 8192
[0001.346] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.352] I> BCH of PSC_FW read from storage
[0001.356] I> BCH address is : 0x80ffe000
[0001.360] I> PSC_FW header integrity check is success
[0001.365] I> Binary magic in BCH component 0 is PFWP
[0001.370] I> component binary type is 17
[0001.374] I> Size of crypto header is 8192
[0001.378] I> strt_pg_num(21264) num_of_pgs(591) read_buf(0x80fb4200)
[0001.387] I> PSC_FW binary is read from storage
[0001.392] I> PSC_FW binary integrity check is success
[0001.397] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.403] I> Task: Load nvdec-fw
[0001.407] I> Slot: 0
[0001.409] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.414] I> Binary name: NVDEC
[0001.417] I> Size of crypto header is 8192
[0001.421] I> Size of crypto header is 8192
[0001.425] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.431] I> BCH of NVDEC read from storage
[0001.435] I> BCH address is : 0x800fe000
[0001.439] I> NVDEC header integrity check is success
[0001.444] I> Binary magic in BCH component 0 is NDEC
[0001.449] I> component binary type is 7
[0001.452] I> Size of crypto header is 8192
[0001.456] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.465] I> NVDEC binary is read from storage
[0001.470] I> NVDEC binary integrity check is success
[0001.475] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.481] I> Size of crypto header is 8192
[0001.493] I> Task: Load tsec-fw
[0001.496] I> TSEC-FW load support not enabled
[0001.500] I> Task: GPIO interrupt map
[0001.504] I> Task: SC7 context save
[0001.507] I> Slot: 0
[0001.509] I> Binary[27] block-0 (partition size: 0x100000)
[0001.514] I> Binary name: BR_BCT
[0001.517] I> Size of crypto header is 8192
[0001.521] I> Size of crypto header is 8192
[0001.525] I> Size of crypto header is 8192
[0001.529] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.535] I> BR_BCT binary is read from storage
[0001.540] I> BR_BCT binary integrity check is success
[0001.544] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.551] I> Slot: 0
[0001.553] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.558] I> Binary name: SC7-FW
[0001.561] I> Size of crypto header is 8192
[0001.565] I> Size of crypto header is 8192
[0001.569] I> Size of crypto header is 8192
[0001.573] I> Size of crypto header is 8192
[0001.577] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.583] I> BCH of SC7-FW read from storage
[0001.588] I> BCH address is : 0xa0002000
[0001.591] I> SC7-FW header integrity check is success
[0001.596] I> Binary magic in BCH component 0 is WB0B
[0001.601] I> component binary type is 13
[0001.605] I> Size of crypto header is 8192
[0001.609] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[0001.617] I> SC7-FW binary is read from storage
[0001.622] I> SC7-FW binary integrity check is success
[0001.627] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b920)
[0001.633] I> Slot: 0
[0001.635] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.641] I> Binary name: PSC_RF
[0001.644] I> Size of crypto header is 8192
[0001.648] I> Size of crypto header is 8192
[0001.652] I> Size of crypto header is 8192
[0001.655] I> Size of crypto header is 8192
[0001.659] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f920)
[0001.666] I> BCH of PSC_RF read from storage
[0001.670] I> BCH address is : 0xa002f920
[0001.674] I> PSC_RF header integrity check is success
[0001.678] I> Binary magic in BCH component 0 is PSCR
[0001.683] I> component binary type is 22
[0001.687] I> Size of crypto header is 8192
[0001.691] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031920)
[0001.699] I> PSC_RF binary is read from storage
[0001.703] I> PSC_RF binary integrity check is success
[0001.708] I> Binary PSC_RF loaded successfully at 0xa0031920 (0x1be60)
[0001.717] I> Task: Save WP0 payload to SC7 ctx
[0001.722] I> Task: Load MB2rf binary to SC7 ctx
[0001.726] I> Slot: 0
[0001.728] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.734] I> Binary name: MB2_RF
[0001.737] I> Size of crypto header is 8192
[0001.741] I> Size of crypto header is 8192
[0001.745] I> Size of crypto header is 8192
[0001.749] I> Size of crypto header is 8192
[0001.752] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.759] I> BCH of MB2_RF read from storage
[0001.763] I> BCH address is : 0xa00d5d10
[0001.767] I> MB2_RF header integrity check is success
[0001.772] I> Binary magic in BCH component 0 is MB2R
[0001.776] I> component binary type is 14
[0001.780] I> Size of crypto header is 8192
[0001.784] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.792] I> MB2_RF binary is read from storage
[0001.796] I> MB2_RF binary integrity check is success
[0001.801] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf30)
[0001.808] I> Task: Save fuse alias data to SC7 ctx
[0001.812] I> Task: Save PMIC data to SC7 ctx
[0001.816] I> Task: Save Pinmux data to SC7 ctx
[0001.821] I> Task: Save Pad Voltage data to SC7 ctx
[0001.825] I> Task: Save controller prod data to SC7 ctx
[0001.830] I> Task: Save prod cfg data to SC7 ctx
[0001.835] I> Task: Save I2C bus freq data to SC7 ctx
[0001.840] I> Task: Save SOCTherm data to SC7 ctx
[0001.844] I> Task: Save FMON data to SC7 ctx
[0001.848] I> Task: Save VMON data to SC7 ctx
[0001.852] I> Task: Save TZDRAM data to SC7 ctx
[0001.857] I> Task: Save GPIO int data to SC7 ctx
[0001.861] I> Task: Save clock data to SC7 ctx
[0001.865] I> Task: Save debug data to SC7 ctx
[0001.869] I> Task: Save MBWT data to SC7 ctx
[0001.877] I> SC7 context save done
[0001.881] I> Task: Load MB2/Applet/FSKP
[0001.884] I> Loading MB2
[0001.887] I> Slot: 0
[0001.889] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.894] I> Binary name: MB2
[0001.897] I> Size of crypto header is 8192
[0001.901] I> Size of crypto header is 8192
[0001.905] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.911] I> BCH of MB2 read from storage
[0001.915] I> BCH address is : 0x8007e000
[0001.919] I> MB2 header integrity check is success
[0001.923] I> Binary magic in BCH component 0 is MB2B
[0001.928] I> component binary type is 6
[0001.932] I> Size of crypto header is 8192
[0001.936] I> strt_pg_num(8464) num_of_pgs(844) read_buf(0x80000000)
[0001.947] I> MB2 binary is read from storage
[0001.952] I> MB2 binary integrity check is success
[0001.956] I> Binary MB2 loaded successfully at 0x80000000 (0x696a0)
[0001.962] I> Task: Map CCPLEX SHARED carveout
[0001.967] I> Task: Prepare MB2 params
[0001.971] I> Task: Dram ecc test
[0001.974] I> Task: Misc NV security settings
[0001.978] I> NVDEC sticky bits programming done
[0001.982] I> Successfully powergated NVDEC
[0001.986] I> Task: Disable/Reload WDT
[0001.990] I> Task: Program misc carveouts
[0001.993] I> Program IPC carveouts
[0001.997] I> Task: Disable SCPM/POD reset
[0002.001] I> SLCG Global override status := 0x0
[0002.005] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-af79ed0a)
I> Emulation:
I> Entry timestamp: 0x001f0513
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x473800000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: Enable hot-plug capability
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Partition Manager Init
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x473801000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x473801000)
I> strt_pg_num(131039) num_of_pgs(32) read_buf(0x473801200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> strt_pg_num(55040) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(55056) num_of_pgs(512) read_buf(0x472e00000)
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> strt_pg_num(56192) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(56208) num_of_pgs(880) read_buf(0x472a00000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x472e00000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> strt_pg_num(44800) num_of_pgs(16) read_buf(0x40066880)
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x472a00000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(44816) num_of_pgs(1) read_buf(0x4739400d8)
I> strt_pg_num(44816) num_of_pgs(8) read_buf(0x4739400d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(44824) num_of_pgs(512) read_buf(0x4738000c0)
I> strt_pg_num(45336) num_of_pgs(512) read_buf(0x4738400c0)
I> dce : will be decompressed at 0x47a000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(45848) num_of_pgs(512) read_buf(0x4738800c0)
I> dce : decompressed to 12091520 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> strt_pg_num(58240) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(58256) num_of_pgs(800) read_buf(0x47d800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x47a000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> strt_pg_num(9472) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(9488) num_of_pgs(312) read_buf(0x472f00000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x47d800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: A_pva-fw
I> Binary@ device:3/0 block-62336 (partition size: 0x40000), name: A_pva-fw
I> strt_pg_num(62336) num_of_pgs(16) read_buf(0x40066880)
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x472f00000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(62352) num_of_pgs(1) read_buf(0x4739400d8)
I> strt_pg_num(62352) num_of_pgs(8) read_buf(0x4739400d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(62360) num_of_pgs(512) read_buf(0x4738000c0)
I> pva-fw : will be decompressed at 0x473180000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x473180000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x476000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
I> Task: FSI padctl context save
W> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE..
I> Enabling combined UART
spe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
spe: SafeRTOS v8.4
spe: init
scheduler initialized
aon hsp initialized
tag initialized
tcu initialized
bpmp ipc initialized
spe: late init
cpu_nic clock initialized
apb clock initialized
pm initialized
bpmp hsp initialized
top1 hsp initialized
ccplex ipc initialized
spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Start secure NOR provision
I> Skip Secure NOR provisioning
I> Task: Trigger load FSI keyblob
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d to psc
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is 3b0e1a33cf85c7f62a7e8b93c2af97ed
bpmp: combined binary md5 is 6432e47ee22b94f945d6c4e54b6b9344
bpmp: firmware tag is 6432e47ee22b94f945d6-3b0e1a33cf8
Write control check for CBB_CENTRAL_CBB_FIREWALL_PWM7_BLF failed, expected value
: 00100008 != actual value: 0010000a address: 13a178a8
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
I> Task: Unhalt FSI
I> FSI unhalt skipped
I> Task: Unhaltinitialized avfs_clk_platform
initialized powergate
 AUXPs
I> Unhaltinginitialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
 RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load HV/CPUBL
I> Task: Load TOS
I> Task: Trigger load TSEC leyblob
I> Sending opcode 0x53535452 to psc
I> Sent opcode to psc
I> [     2.599525] Camera-FW on t234-rce-safe started
TCU early console enabled.
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000)initialized emc
initialized emc_mrq
, name: A_cpu-bootloader
I> strinitialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
t_pg_num(24832) nuinitialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
DCE Started
DCE_R5_Init
MPU enabled
DCE_SW_Init
I> cpuinitialized clk_cal_late
initialized noc_late
initialized cvc
bl : oem authentication of headerinitialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0
/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone li
st sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0
/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1
/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone li
st sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1
/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone li
st sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2
/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone li
st sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2
/1
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pw[     2.798498] Camerm3
enable sdmmc4_axicif
enable mss_encrypt
enable maa-FW on t234-rce-safeud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable ready SHA1=e2238c99 (crt 19.169 ms, total boot 219.215 ms)
 xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
 done
I> strt_pg_num(24848) num_of_pgs(1) read_buf(0x473943c98)
Admin Task Init
Admin Task Init complete
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
SHA Task Started
DCE: FI> strt_pg_num(24848) num_of_pgs(8) read_buf(0x473943c98)
W Boot Complete
I> cpubl : meta-blob integrity check is success.
I> strt_pg_num(24856) num_of_pgs(512) read_buf(0x473803c80)
Admin Task Running
SHA Task Running
I> strt_pg_num(25368) num_of_pgs(512) read_buf(0x473843c80)
I> cpubl : will be decompressed at 0x472000000
I> strt_pg_num(25880) num_of_pgs(512) read_buf(0x473883c80)
I> strt_pg_num(26392) num_of_pgs(512) read_buf(0x4738c3c80)
I> strt_pg_num(26904) num_of_pgs(512) read_buf(0x473903c80)
I> strt_pg_num(27416) num_of_pgs(512) read_buf(0x473803c80)
I> strt_pg_num(27928) num_of_pgs(512) read_buf(0x473843c80)
I> strt_pg_num(28440) num_of_pgs(512) read_buf(0x473883c80)
I> strt_pg_num(28952) num_of_pgs(512) read_buf(0x4738c3c80)
I> strt_pg_num(29464) num_of_pgs(512) read_buf(0x473903c80)
I> strt_pg_num(29976) num_of_pgs(512) read_buf(0x473803c80)
I> strt_pg_num(30488) num_of_pgs(512) read_buf(0x473843c80)
I> strt_pg_num(31000) num_of_pgs(512) read_buf(0x473883c80)
I> cpubl : decompressed to 3555456 bytes
I> cpubl: plain binary integrity check is success
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> strt_pg_num(32000) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(32016) num_of_pgs(3176) read_buf(0xc1d73000)
I> NSDRAM carveout base: 0x80000000, size: 0x3f25f0000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x472000000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0xc1d73000
I> Relocating OP-TEE dtb from: 0xc1eff0f0 to 0xbe040020, size: 0x2889
I> [0] START: 0x80000000, SIZE: 0x3f25f0000
I> [1] START: 0x476000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> strt_pg_num(44288) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(44304) num_of_pgs(8) read_buf(0xbe020000)
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0xbe020000
I> EKB detected (length: 0x410) @ VA:0xbe020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0xbe040020
I> OEM sc7 context saved
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
I> Task: Storage device deinit
I> Task: SMMU external bypass disable
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Bootchain failure check
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
NOTICE:  BL31: v2.8(release):e12e3fa93
NOTICE:  BL31: Built : 09:56:21, May  6 2024
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Mon May
6 17:07:49 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/
porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 36.3.0-gcid-36191598 built on 2024-05-06T16:58:59+
00:00)
I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
I/TC: WARNING: Test UEFI variable auth key is being used !
I/TC: WARNING: UEFI variable protection is not fully enabled !
[     5.788699] Camera-FW on t234-rce-safe started
E/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure worl[     5.8
35883] Camera-FW on t234-rcd e-safe ready SHA1=e2238c99 (crt 0.891 ms, total boo
t 48.126 ms)
result: ret=0xffff0000 ret_origin=0
E/LD:   init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
Jetson System firmware version 36.3.0-gcid-36191598 date 2024-05-06T16:58:59+00:
00
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
debugfs initialized
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.136-rt-tegra (danel@danel-HP-Compaq-6200-Pro-M
T-PC) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU l
d (GNU Binutils) 2.38) #1 SMP PREEMPT_RT Thu Sep 19 09:48:56 CST 2024 ()
[    0.000000] Machine model: NVIDIA Jetson Orin NX Engineering Reference Develo
per Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x46d82f198 SMBIOS=0xffff0000 SMBIOS 3.0=0x46d200000
MEMATTR=0x4677ba018 ESRT=0x4677bd118 RNG=0x45ade0018 MEMRESERVE=0x45ba79c18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] esrt: Reserving ESRT space from 0x00000004677bd118 to 0x000000046
77bd150.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000044a000000, s
ize 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id share
d-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000477ffffff
[    0.000000] NUMA: NODE_DATA [mem 0x4702f07c0-0x4702f2fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000477ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000bdffffff]
[    0.000000]   node   0: [mem 0x00000000c2000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000045e239fff]
[    0.000000]   node   0: [mem 0x000000045e23a000-0x000000045e40bfff]
[    0.000000]   node   0: [mem 0x000000045e40c000-0x000000046b8effff]
[    0.000000]   node   0: [mem 0x000000046b8f0000-0x000000046d82ffff]
[    0.000000]   node   0: [mem 0x000000046d830000-0x0000000471dfffff]
[    0.000000]   node   0: [mem 0x0000000471e00000-0x0000000471ffffff]
[    0.000000]   node   0: [mem 0x0000000472000000-0x000000047259ffff]
[    0.000000]   node   0: [mem 0x0000000472f00000-0x0000000472ffffff]
[    0.000000]   node   0: [mem 0x0000000476000000-0x0000000477ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000477ffffff]
[    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 28 pages/cpu s77744 r8192 d28752 u114688
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algor
ithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4065440
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=PARTUUID=e2e2f973-9262-4c94-bc9f-96cef0
989b80 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firm
ware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efif
b:off console=tty0 bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x47
1E00000
[    0.000000] Unknown kernel command line parameters "mminit_loglevel=4 fbcon=m
ap:0 bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000", will
 be passed to user space.
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 byt
es, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes
, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe000
0] (64MB)
[    0.000000] Memory: 15750760K/16521856K available (18560K kernel code, 4036K
rwdata, 9772K rodata, 7488K init, 552K bss, 508952K reserved, 262144K cma-reserv
ed)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
[    0.000000]  No expedited grace period (rcu_normal_after_boot).
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif
fies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:
 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000000] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 43980
46511088ns
[    0.000330] Console: colour dummy device 80x25
[    0.000336] printk: console [tty0] enabled
[    0.000378] Calibrating delay loop (skipped), value calculated using timer fr
equency.. 62.50 BogoMIPS (lpj=125000)
[    0.000383] pid_max: default: 32768 minimum: 301
[    0.000416] LSM: Security Framework initializing
[    0.000431] Yama: becoming mindful.
[    0.000442] SELinux:  Initializing.
[    0.000532] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, li
near)
[    0.000569] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 byte
s, linear)
[    0.001485] rcu: Hierarchical SRCU implementation.
[    0.003679] Tegra Revision: A01 SKU: 211 CPU Process: 0 SoC Process: 0
[    0.003959] Remapping and enabling EFI services.
[    0.004721] smp: Bringing up secondary CPUs ...
[    0.005130] Detected PIPT I-cache on CPU1
[    0.005159] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.005181] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.005566] Detected PIPT I-cache on CPU2
[    0.005575] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.005588] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.005947] Detected PIPT I-cache on CPU3
[    0.005956] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.005967] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.008288] Detected PIPT I-cache on CPU4
[    0.008309] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c000
0
[    0.008330] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.008739] Detected PIPT I-cache on CPU5
[    0.008749] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e000
0
[    0.008760] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.009129] Detected PIPT I-cache on CPU6
[    0.009138] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f50000
0
[    0.009149] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.009530] Detected PIPT I-cache on CPU7
[    0.009539] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f52000
0
[    0.009550] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.009601] smp: Brought up 1 node, 8 CPUs
[    0.009604] SMP: Total of 8 processors activated.
[    0.009606] CPU features: detected: 32-bit EL0 Support
[    0.009608] CPU features: detected: Data cache clean to the PoU not required
for I/D coherence
[    0.009609] CPU features: detected: Common not Private translations
[    0.009610] CPU features: detected: CRC32 instructions
[    0.009612] CPU features: detected: Data cache clean to Point of Persistence
[    0.009613] CPU features: detected: Generic authentication (architected algor
ithm)
[    0.009615] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.009616] CPU features: detected: LSE atomic instructions
[    0.009617] CPU features: detected: Privileged Access Never
[    0.009618] CPU features: detected: RAS Extension Support
[    0.009619] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.022392] spectre-bhb mitigation disabled by command line option
[    0.034261] CPU: All CPU(s) started at EL2
[    0.035900] devtmpfs: initialized
[    0.052358] KASLR enabled
[    0.052468] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma
x_idle_ns: 7645041785100000 ns
[    0.052480] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.054589] pinctrl core: initialized pinctrl subsystem
[    0.055237] SMBIOS 3.6.0 present.
[    0.055245] DMI: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer
 Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[    0.055557] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.057101] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.057218] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic all
ocations
[    0.057321] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic a
llocations
[    0.057359] audit: initializing netlink subsys (disabled)
[    0.057459] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=
0 res=1
[    0.058624] thermal_sys: Registered thermal governor 'step_wise'
[    0.058627] thermal_sys: Registered thermal governor 'user_space'
[    0.058629] thermal_sys: Registered thermal governor 'power_allocator'
[    0.060542] cpuidle: using governor menu
[    0.060694] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.060782] ASID allocator initialised with 32768 entries
[    0.061893] Serial: AMBA PL011 UART driver
[    0.071321] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud =
 0) is a SBSA
[    0.082138] platform bpmp: Fixing up cyclic dependency with 2c60000.external-
memory-controller
[    0.090863] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.090868] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.090870] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.090872] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.091456] cryptd: max_cpu_qlen set to 1000
[    0.092760] ACPI: Interpreter disabled.
[    0.093799] VDD_1V8_AO: supplied by VDD_5V0_SYS
[    0.093904] VDD_3V3_AO: supplied by VDD_5V0_SYS
[    0.094136] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[    0.094448] iommu: Default domain type: Translated
[    0.094450] iommu: DMA domain TLB invalidation policy: strict mode
[    0.094700] SCSI subsystem initialized
[    0.094834] vgaarb: loaded
[    0.094948] usbcore: registered new interface driver usbfs
[    0.094963] usbcore: registered new interface driver hub
[    0.094977] usbcore: registered new device driver usb
[    0.095343] pps_core: LinuxPPS API ver. 1 registered
[    0.095345] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
tti <giometti@linux.it>
[    0.095352] PTP clock support registered
[    0.095409] EDAC MC: Ver: 3.0.0
[    0.096133] Registered efivars operations
[    0.096637] FPGA manager framework
[    0.096685] Advanced Linux Sound Architecture Driver Initialized.
[    0.097230] clocksource: Switched to clocksource arch_sys_counter
[    0.120590] VFS: Disk quotas dquot_6.6.0
[    0.120628] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.120758] pnp: PnP ACPI: disabled
[    0.123599] NET: Registered PF_INET protocol family
[    0.124101] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, li
near)
[    0.126470] tcp_listen_portaddr_hash hash table entries: 8192 (order: 6, 3932
16 bytes, linear)
[    0.126683] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes,
linear)
[    0.126695] TCP established hash table entries: 131072 (order: 8, 1048576 byt
es, linear)
[    0.126850] TCP bind hash table entries: 65536 (order: 9, 2621440 bytes, line
ar)
[    0.128206] TCP: Hash tables configured (established 131072 bind 65536)
[    0.128342] UDP hash table entries: 8192 (order: 7, 786432 bytes, linear)
[    0.128778] UDP-Lite hash table entries: 8192 (order: 7, 786432 bytes, linear
[    0.129683] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.130283] RPC: Registered named UNIX socket transport module.
[    0.130288] RPC: Registered udp transport module.
[    0.130290] RPC: Registered tcp transport module.
[    0.130292] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.130309] PCI: CLS 0 bytes, default 64
[    0.130602] Unpacking initramfs...
[    0.141385] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counte
rs available
[    0.145270] Initialise system trusted keyrings
[    0.145487] workingset: timestamp_bits=42 max_order=22 bucket_order=0
[    0.151413] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.152020] NFS: Registering the id_resolver key type
[    0.152056] Key type id_resolver registered
[    0.152060] Key type id_legacy registered
[    0.152135] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.152156] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering
[    0.152182] ntfs: driver 2.1.32 [Flags: R/O].
[    0.152547] 9p: Installing v9fs 9p2000 file system support
[    0.165585] Key type asymmetric registered
[    0.165592] Asymmetric key parser 'x509' registered
[    0.165672] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
45)
[    0.165681] io scheduler mq-deadline registered
[    0.165688] io scheduler kyber registered
[    0.180489] EINJ: ACPI disabled.
[    0.195313] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.197438] SuperH (H)SCI(F) driver initialized
[    0.197846] msm_serial: driver initialized
[    0.198634] printk: console [ttyTCU0] enabled
[    0.199688] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.199695] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.199703] arm-smmu 8000000.iommu:  stage 1 translation
[    0.199705] arm-smmu 8000000.iommu:  stage 2 translation
[    0.199710] arm-smmu 8000000.iommu:  nested translation
[    0.199716] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    0.199722] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    0.199744] arm-smmu 8000000.iommu:  Supported page sizes: 0x61311000
[    0.199746] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    0.199750] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    0.201098] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.201105] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.201109] arm-smmu 10000000.iommu:         stage 1 translation
[    0.201111] arm-smmu 10000000.iommu:         stage 2 translation
[    0.201112] arm-smmu 10000000.iommu:         nested translation
[    0.201119] arm-smmu 10000000.iommu:         stream matching with 128 registe
r groups
[    0.201124] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 onl
y)
[    0.201134] arm-smmu 10000000.iommu:         Supported page sizes: 0x61311000
[    0.201135] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.201136] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.201690] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.201694] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.201696] arm-smmu 12000000.iommu:         stage 1 translation
[    0.201697] arm-smmu 12000000.iommu:         stage 2 translation
[    0.201697] arm-smmu 12000000.iommu:         nested translation
[    0.201702] arm-smmu 12000000.iommu:         stream matching with 128 registe
r groups
[    0.201704] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 onl
y)
[    0.201720] arm-smmu 12000000.iommu:         Supported page sizes: 0x61311000
[    0.201722] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.201723] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.215051] loop: module loaded
[    0.216144] megasas: 07.717.02.00-rc1
[    0.220928] tun: Universal TUN/TAP device driver, 1.6
[    0.221634] thunder_xcv, ver 1.0
[    0.221669] thunder_bgx, ver 1.0
[    0.221697] nicpf, ver 1.0
[    0.222630] hclge is initializing
[    0.222670] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - versio
n
[    0.222677] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.222729] e1000: Intel(R) PRO/1000 Network Driver
[    0.222736] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.222775] e1000e: Intel(R) PRO/1000 Network Driver
[    0.222779] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.222805] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.222811] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.222827] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.222835] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.223069] sky2: driver version 1.30
[    0.223835] VFIO - User Level meta-driver version: 0.3
[    0.225688] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.225697] ehci-pci: EHCI PCI platform driver
[    0.225725] ehci-platform: EHCI generic platform driver
[    0.225812] ehci-orion: EHCI orion driver
[    0.225883] ehci-exynos: EHCI Exynos driver
[    0.225945] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.225979] ohci-pci: OHCI PCI platform driver
[    0.226016] ohci-platform: OHCI generic platform driver
[    0.226108] ohci-exynos: OHCI Exynos driver
[    0.226601] usbcore: registered new interface driver usb-storage
[    0.228710] i2c_dev: i2c /dev entries driver
[    0.230242] pps pps0: new PPS source ktimer
[    0.230249] pps pps0: ktimer PPS source registered
[    0.230263] pps_ldisc: PPS line discipline registered
[    0.232663] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-d
evel@redhat.com
[    0.235196] sdhci: Secure Digital Host Controller Interface driver
[    0.235202] sdhci: Copyright(c) Pierre Ossman
[    0.235715] Synopsys Designware Multimedia Card Interface Driver
[    0.236406] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.238583] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.239129] tegra-bpmp bpmp: Adding to iommu group 0
[    0.240975] tegra-bpmp bpmp: firmware: 6432e47ee22b94f945d6-3b0e1a33cf8
[    0.356090] Freeing initrd memory: 12792K
[    3.245980] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046,
[    3.246017] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_id
le_ns: 49772407460 ns
[    3.246021] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_i
dle_ns: 1911260446275 ns
[    3.246420] hid: raw HID events driver (C) Jiri Kosina
[    3.246663] usbcore: registered new interface driver usbhid
[    3.246669] usbhid: USB HID core driver
[    3.252520] optee: probing for conduit method.
[    3.252569] optee: revision 3.22 (e7b5ff3f)
[    3.313203] optee: dynamic shared memory is enabled
[    3.313487] optee: initialized driver
[    3.320964] usbcore: registered new interface driver snd-usb-audio
[    3.323196] NET: Registered PF_PACKET protocol family
[    3.323501] 9pnet: Installing 9P2000 support
[    3.323643] Key type dns_resolver registered
[    3.325193] printk: console [tty0]: printing thread started
[    3.325836] printk: console [ttyTCU0]: printing thread started
[    3.326001] Loading compiled-in X.509 certificates
[    3.340104] Loaded X.509 cert 'Build time autogenerated kernel key: e2d53db66
e5b7c1a15f9a5da68c5cee4f329d8da'
[    3.374376] gpio-394 (camera-control-output-low): hogged as output/low
[    3.388951] simple-framebuffer chosen:framebuffer: framebuffer at 0x47de0000
, 0x870000 bytes
[    3.388966] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=1920
x1080x32, linelength=8192
[    3.392836] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[    3.393756] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    3.397153] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 c
hannels
[    3.398780] serial-tegra 3100000.serial: RX in PIO mode
[    3.398786] serial-tegra 3100000.serial: TX in PIO mode
[    3.398874] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud =
 0) is a TEGRA_UART
[    3.400317] serial-tegra 3140000.serial: RX in PIO mode
[    3.400326] serial-tegra 3140000.serial: TX in PIO mode
[    3.400455] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud =
 0) is a TEGRA_UART
[    3.405325] tegra_rtc c2a0000.rtc: registered as rtc1
[    3.405343] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.406143] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    3.419954] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    3.429666] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    3.442069] tegra-i2c c240000.i2c: Adding to iommu group 1
[    3.454262] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[    3.455160] tegra-i2c c250000.i2c: Adding to iommu group 1
[    3.469372] i2c i2c-2: Added multiplexed i2c bus 9
[    3.471144] i2c i2c-2: Added multiplexed i2c bus 10
[    3.471164] i2c-mux-gpio bus@0:cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    3.492596] cpufreq: cpufreq_online: CPU0: Running at unlisted initial freque
ncy: 1980000 KHz, changing to: 1984000 KHz
[    3.495427] cpufreq: cpufreq_online: CPU4: Running at unlisted initial freque
ncy: 1982000 KHz, changing to: 1984000 KHz
[    3.501120] tegra-xusb 3610000.usb: Adding to iommu group 2
[    3.519541] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 U
TC
[    3.519551] tegra-xusb 3610000.usb: xHCI Host Controller
[    3.519572] tegra-xusb 3610000.usb: new USB bus registered, assigned bus numb
er 1
[    3.520335] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 q
uirks 0x0000000000010810
[    3.521393] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[    3.521562] tegra-xusb 3610000.usb: xHCI Host Controller
[    3.521569] tegra-xusb 3610000.usb: new USB bus registered, assigned bus numb
er 2
[    3.521575] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    3.522349] hub 1-0:1.0: USB hub found
[    3.522367] hub 1-0:1.0: 4 ports detected
[    3.522757] hub 2-0:1.0: USB hub found
[    3.522771] hub 2-0:1.0: 4 ports detected
[    3.524869] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[    3.525444] irq: IRQ222: trimming hierarchy from :bus@0:pmc@c360000
[    3.525594] irq: IRQ223: trimming hierarchy from :bus@0:interrupt-controller@
f400000-1
[    3.526311] irq: IRQ224: trimming hierarchy from :bus@0:pmc@c360000
[    3.526772] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.560888] ALSA device list:
[    3.560892]   No soundcards found.
[    3.561234] sdhci-tegra 3400000.mmc: Got CD GPIO
[    3.609071] irq: IRQ225: trimming hierarchy from :bus@0:interrupt-controller@
f400000-1
[    3.609754] mmc0: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64
-bit
[    3.611516] Freeing unused kernel memory: 7488K
[    3.611586] Run /init as init process
[    3.622900] Checking overlayfs setting...
[    3.646861] Overlayfs is disabled...
[    3.652685] Root device found: PARTUUID=e2e2f973-9262-4c94-bc9f-96cef0989b80
[    3.857488] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    4.029893] hub 1-2:1.0: USB hub found
[    4.031251] hub 1-2:1.0: 4 ports detected
[    4.142235] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using te
gra-xusb
[    4.196299] hub 2-1:1.0: USB hub found
[    4.198665] hub 2-1:1.0: 4 ports detected
[    4.301480] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    6.888218] tegra194-pcie 14100000.pcie: Adding to iommu group 4
[    6.893021] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ran
ges:
[    6.893049] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff
-> 0x2080000000
[    6.893058] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff
-> 0x0040000000
[    6.893063] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff
-> 0x0030100000
[    6.893761] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    6.893766] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2
 inbound
[    6.923573] tegra-xudc 3550000.usb: Adding to iommu group 5
[    7.001484] tegra194-pcie 14100000.pcie: Link up
[    7.002962] tegra194-pcie 14100000.pcie: Link up
[    7.003034] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    7.003039] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus addr
ess [0x30100000-0x301fffff])
[    7.003042] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff
] (bus address [0x40000000-0x47ffffff])
[    7.003045] pci_bus 0001:00: root bus resource [bus 00-ff]
[    7.003047] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff
 pref]
[    7.003097] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    7.003265] pci 0001:00:00.0: PME# supported from D0 D3hot
[    7.006500] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    7.006672] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    7.006873] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    7.007928] pci 0001:01:00.0: supports D1 D2
[    7.007929] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    7.020209] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff
[    7.020216] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    7.020220] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff
64bit]
[    7.020323] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    7.020353] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    7.020357] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    7.020361] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    7.020499] pcieport 0001:00:00.0: Adding to iommu group 4
[    7.021160] pcieport 0001:00:00.0: PME: Signaling with IRQ 192
[    7.022794] pcieport 0001:00:00.0: AER: enabled with IRQ 192
[    7.023709] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[    7.028745] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ran
ges:
[    7.028765] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff
-> 0x2140000000
[    7.028771] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff
-> 0x0040000000
[    7.028775] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff
-> 0x0036100000
[    7.029360] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    7.029365] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound,2
 inbound
[    8.141055] tegra194-pcie 14160000.pcie: Phy link never came up
[    9.143759] tegra194-pcie 14160000.pcie: Phy link never came up
[    9.143876] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    9.143880] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus a
ddress [0x36100000-0x361fffff])
[    9.143884] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff
[    9.143887] pci_bus 0004:00: root bus resource [bus 00-ff]
[    9.143889] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff
 pref]
[    9.143942] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    9.144113] pci 0004:00:00.0: PME# supported from D0 D3hot
[    9.149814] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    9.149952] pcieport 0004:00:00.0: Adding to iommu group 6
[    9.150301] pcieport 0004:00:00.0: PME: Signaling with IRQ 194
[    9.150877] pcieport 0004:00:00.0: AER: enabled with IRQ 194
[    9.151371] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    9.151454] pci 0004:00:00.0: Removing from iommu group 6
[    9.151464] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    9.153022] tegra194-pcie 141e0000.pcie: Adding to iommu group 7
[    9.155293] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ran
ges:
[    9.155305] tegra194-pcie 141e0000.pcie:      MEM 0x3000000000..0x3227ffffff
-> 0x3000000000
[    9.155310] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff
-> 0x0040000000
[    9.155314] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff
-> 0x003e100000
[    9.155633] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[    9.155635] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2
 inbound
[    9.261238] tegra194-pcie 141e0000.pcie: Link up
[    9.261986] tegra194-pcie 141e0000.pcie: Link up
[    9.262042] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    9.262046] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus a
ddress [0x3e100000-0x3e1fffff])
[    9.262049] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff
[    9.262052] pci_bus 0007:00: root bus resource [bus 00-ff]
[    9.262053] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff
 pref]
[    9.262091] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    9.262214] pci 0007:00:00.0: PME# supported from D0 D3hot
[    9.265348] pci 0007:01:00.0: [1b4b:1322] type 00 class 0x010802
[    9.265505] pci 0007:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    9.266595] pci 0007:01:00.0: PME# supported from D0 D3hot
[    9.280145] pci 0007:00:00.0: BAR 14: assigned [mem 0x3228000000-0x32280fffff
[    9.280153] pci 0007:01:00.0: BAR 0: assigned [mem 0x3228000000-0x3228003fff
64bit]
[    9.280224] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    9.280228] pci 0007:00:00.0:   bridge window [mem 0x3228000000-0x32280fffff]
[    9.280341] pcieport 0007:00:00.0: Adding to iommu group 7
[    9.280696] pcieport 0007:00:00.0: PME: Signaling with IRQ 196
[    9.281399] pcieport 0007:00:00.0: AER: enabled with IRQ 196
[    9.281584] nvme 0007:01:00.0: Adding to iommu group 7
[    9.281968] nvme nvme0: pci function 0007:01:00.0
[    9.282183] nvme 0007:01:00.0: enabling device (0000 -> 0002)
[    9.282602] tegra194-pcie 140a0000.pcie: Adding to iommu group 8
[    9.289513] nvme nvme0: 8/0/0 default/read/poll queues
[    9.295345]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    9.390503] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ran
ges:
[    9.390529] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff
-> 0x3240000000
[    9.390536] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff
-> 0x0040000000
[    9.390539] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff
-> 0x002a100000
[    9.390847] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[    9.390849] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2
 inbound
[    9.497477] tegra194-pcie 140a0000.pcie: Link up
[    9.498992] tegra194-pcie 140a0000.pcie: Link up
[    9.499081] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[    9.499086] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus a
ddress [0x2a100000-0x2a1fffff])
[    9.499089] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff
[    9.499093] pci_bus 0008:00: root bus resource [bus 00-ff]
[    9.499094] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff
 pref]
[    9.499140] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[    9.499292] pci 0008:00:00.0: PME# supported from D0 D3hot
[    9.502543] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[    9.502700] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    9.502882] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    9.502998] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    9.503984] pci 0008:01:00.0: supports D1 D2
[    9.503985] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    9.515938] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff
[    9.515944] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[    9.515949] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff
64bit]
[    9.516042] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff
64bit]
[    9.516135] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[    9.516163] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[    9.516166] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[    9.516170] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[    9.516304] pcieport 0008:00:00.0: Adding to iommu group 8
[    9.516689] pcieport 0008:00:00.0: PME: Signaling with IRQ 190
[    9.517526] pcieport 0008:00:00.0: AER: enabled with IRQ 190
[    9.684231] EXT4-fs (nvme0n1p1): recovery complete
[    9.684284] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. O
pts: (null). Quota mode: none.
[    9.689269] Rootfs mounted over PARTUUID=e2e2f973-9262-4c94-bc9f-96cef0989b80
[    9.697053] Switching from initrd to actual rootfs
[    9.771735] systemd[1]: System time before build time, advancing clock.
[    9.823105] NET: Registered PF_INET6 protocol family
[    9.823966] Segment Routing with IPv6
[    9.823974] In-situ OAM (IOAM) with IPv6
[    9.838973] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+P
AM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL
+BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +P
CRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +
SYSVINIT default-hierarchy=unified)
[    9.839353] systemd[1]: Detected architecture arm64.
[    9.840015] systemd[1]: Hostname set to <tegra-ubuntu>.
[    9.869435] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', versio
n 0, device /dev/watchdog
[    9.869453] systemd[1]: Set hardware watchdog to 2min.
[   10.052179] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard
output type syslog is obsolete, automatically updating to journal. Please update
 your unit file, and consider removing the setting altogether.
[   10.058584] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standa
rd output type syslog is obsolete, automatically updating to journal. Please upd
ate your unit file, and consider removing the setting altogether.
[   10.093835] systemd[1]: Queued start job for default target Graphical Interfa
ce.
[   10.095429] systemd[1]: Created slice Slice /system/modprobe.
[   10.096074] systemd[1]: Created slice Slice /system/serial-getty.
[   10.096602] systemd[1]: Created slice User and Session Slice.
[   10.096788] systemd[1]: Started Forward Password Requests to Wall Directory W
atch.
[   10.097200] systemd[1]: Set up automount Arbitrary Executable File Formats Fi
le System Automount Point.
[   10.097404] systemd[1]: Reached target Slice Units.
[   10.097471] systemd[1]: Reached target Mounting snaps.
[   10.099457] systemd[1]: Reached target Mounted snaps.
[   10.101502] systemd[1]: Reached target Swaps.
[   10.101569] systemd[1]: Reached target Local Verity Protected Volumes.
[   10.108512] systemd[1]: Listening on RPCbind Server Activation Socket.
[   10.108961] systemd[1]: Listening on Syslog Socket.
[   10.109216] systemd[1]: Listening on fsck to fsckd communication Socket.
[   10.109412] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   10.110963] systemd[1]: Listening on Journal Audit Socket.
[   10.111202] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.111460] systemd[1]: Listening on Journal Socket.
[   10.111786] systemd[1]: Listening on udev Control Socket.
[   10.111973] systemd[1]: Listening on udev Kernel Socket.
[   10.113211] systemd[1]: Mounting Huge Pages File System...
[   10.114565] systemd[1]: Mounting POSIX Message Queue File System...
[   10.139411] systemd[1]: Mounting Kernel Debug File System...
[   10.140797] systemd[1]: Mounting Kernel Trace File System...
[   10.144200] systemd[1]: Starting Journal Service...
[   10.156224] systemd[1]: Starting Set the console keyboard layout...
[   10.157825] systemd[1]: Starting Create List of Static Device Nodes...
[   10.169015] systemd[1]: Starting Load Kernel Module configfs...
[   10.174964] systemd[1]: Starting Load Kernel Module drm...
[   10.176457] systemd[1]: Starting Load Kernel Module efi_pstore...
[   10.178156] systemd[1]: Starting Load Kernel Module fuse...
[   10.190728] fuse: init (API version 7.34)
[   10.196898] systemd[1]: Starting NVIDIA specific first-boot udev script...
[   10.198808] systemd[1]: Started Nameserver information manager.
[   10.208359] systemd[1]: Reached target Preparation for Network.
[   10.208620] systemd[1]: Condition check resulted in File System Check on Root
 Device being skipped.
[   10.211048] systemd[1]: Starting Load Kernel Modules...
[   10.219505] nvsciipc: loading out-of-tree module taints kernel.
[   10.220541] nvsciipc: loaded module
[   10.232170] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   10.232730] nvmap_page_pool_init: Total RAM pages: 4008296
[   10.232732] nvmap_page_pool_init: nvmap page pool size: 501037 pages (1957 MB
[   10.232801] nvmap_background_zero_thread: PP zeroing thread starting.
[   10.245623] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.248040] tegra-host1x 13e00000.host1x: Adding to iommu group 9
[   10.249410] host1x-context host1x-ctx.0: Adding to iommu group 10
[   10.249653] host1x-context host1x-ctx.1: Adding to iommu group 11
[   10.249853] host1x-context host1x-ctx.2: Adding to iommu group 12
[   10.250114] host1x-context host1x-ctx.3: Adding to iommu group 13
[   10.250335] host1x-context host1x-ctx.4: Adding to iommu group 14
[   10.250581] host1x-context host1x-ctx.5: Adding to iommu group 15
[   10.250794] host1x-context host1x-ctx.6: Adding to iommu group 16
[   10.251006] host1x-context host1x-ctx.7: Adding to iommu group 17
[   10.251226] host1x-context host1x-ctx.8: Adding to iommu group 18
[   10.251439] host1x-context host1x-ctx.9: Adding to iommu group 19
[   10.251639] host1x-context host1x-ctx.10: Adding to iommu group 20
[   10.251852] host1x-context host1x-ctx.11: Adding to iommu group 21
[   10.252052] host1x-context host1x-ctx.12: Adding to iommu group 22
[   10.252244] host1x-context host1x-ctx.13: Adding to iommu group 23
[   10.252443] host1x-context host1x-ctx.14: Adding to iommu group 24
[   10.252637] host1x-context host1x-ctx.15: Adding to iommu group 25
[   10.253841] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null). Quota mode: none.
[   10.261313] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic depende
ncy with 10-0010
[   10.261335] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic depende
ncy with 9-0010
[   10.261357] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic depende
ncy with tegra-capture-vi
[   10.284734] systemd[1]: Starting Coldplug All udev Devices...
[   10.341170] systemd[1]: Started Journal Service.
[   10.381733] nvgpu: 17000000.gpu          nvgpu_nvhost_syncpt_init:122  [INFO]
  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   10.381733]
[   10.454523] systemd-journald[411]: Received client request to flush runtime j
ournal.
TCU debug prints will be routed to traces.
[   10.846110] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver mi
ssing
[   10.846111] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver mis
sing
[   10.846112] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver mis
sing
[   10.846113] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel dri
ver missing
[   10.846114] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel dri
ver missing
[   10.846115] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver mi
ssing
[   10.846118] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.846123] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.846128] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.846131] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.846132] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.846134] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.846140] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.846141] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.846143] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.846144] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.890459] (NULL device *): fops function table already registered
[   11.239095] using random self ethernet address
[   11.239104] using random host ethernet address
[   11.557091] imx219 9-0010: imx219_board_setup: error during i2c read probe (-
121)
[   11.562224] imx219 9-0010: board setup failed
[   11.562302] imx219: probe of 9-0010 failed with error -121
[   11.576704] imx219 10-0010: imx219_board_setup: error during i2c read probe (
-121)
[   11.581843] imx219 10-0010: board setup failed
[   11.581919] imx219: probe of 10-0010 failed with error -121
Starting RmBootstrap
Registered event_type:[0] for dce_core_ipc_type:[1]
Registered event_type:[1] for dce_core_ipc_type:[3]
dce_ipc State Initialized
RmBootstrap completed successfully
[   11.712005] using random self ethernet address
[   11.712010] using random host ethernet address
[   11.722465] cfg80211: Loading compiled-in X.509 certificates for regulatory d
atabase
[   11.728361] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   15.101684] IRQ226: set affinity failed(-22).
[   15.101721] IRQ249: set affinity failed(-22).
[   15.101725] IRQ252: set affinity failed(-22).
[   15.185930] IRQ226: set affinity failed(-22).
[   15.185962] IRQ249: set affinity failed(-22).
[   15.185965] IRQ252: set affinity failed(-22).
[   15.261537] IRQ226: set affinity failed(-22).
[   15.261566] IRQ249: set affinity failed(-22).
[   15.261569] IRQ252: set affinity failed(-22).
[   15.327237] IRQ226: set affinity failed(-22).
Ubuntu 22.04.4 LTS tegra-ubuntu ttyTCU0
tegra-ubuntu login:
Please check again if you follow the steps in developer guide one by one.
By default the source code is extracted to Linux_for_Tegra/source. This path needs root permission. Please run the commands with sudo like:
Can't receive file via Bluetooth on Jetson AGX Orin with JetPack 6 - #29 by DaneLLL
Or you may extract to the other non-root path for building kernel.
