See the command outputs below. lsmod shows nothing.
wklaw@linux:~$ ls /lib/modules
5.10.104-tegra
wklaw@linux:~$ uname -a
Linux linux 5.10.104-rt63-tegra #1 SMP PREEMPT RT Mon Oct 10 09:19:22 PDT 2022 aarch64 aarch64 aarch64 GNU/Linux
wklaw@linux:~$ lsmod
Module Size Used by
wklaw@linux:~$ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.104-rt63-tegra (wklaw@ubuntu) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT RT Mon Oct 10 09:19:22 PDT 2022
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x805405a98 SMBIOS=0xffff0000 SMBIOS 3.0=0x8039b0000 MEMATTR=0x80476d018 ESRT=0x80395ff98 RNG=0x827905a18 MEMRESERVE=0x80476ef18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x000000080395ff98 to 0x000000080395ffd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000817800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000835ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000007ffffffff]
[ 0.000000] node 0: [mem 0x0000000800000000-0x00000008021bffff]
[ 0.000000] node 0: [mem 0x00000008021c0000-0x0000000803565fff]
[ 0.000000] node 0: [mem 0x0000000803566000-0x0000000803700fff]
[ 0.000000] node 0: [mem 0x0000000803701000-0x000000080399ffff]
[ 0.000000] node 0: [mem 0x00000008039a0000-0x00000008039bffff]
[ 0.000000] node 0: [mem 0x00000008039c0000-0x000000080453ffff]
[ 0.000000] node 0: [mem 0x0000000804540000-0x00000008046cffff]
[ 0.000000] node 0: [mem 0x00000008046d0000-0x000000080473ffff]
[ 0.000000] node 0: [mem 0x0000000804740000-0x000000080475ffff]
[ 0.000000] node 0: [mem 0x0000000804760000-0x000000080477ffff]
[ 0.000000] node 0: [mem 0x0000000804780000-0x000000080499ffff]
[ 0.000000] node 0: [mem 0x00000008049a0000-0x00000008049bffff]
[ 0.000000] node 0: [mem 0x00000008049c0000-0x0000000804a0ffff]
[ 0.000000] node 0: [mem 0x0000000804a10000-0x0000000804a9ffff]
[ 0.000000] node 0: [mem 0x0000000804aa0000-0x0000000804e4ffff]
[ 0.000000] node 0: [mem 0x0000000804e50000-0x0000000804e5ffff]
[ 0.000000] node 0: [mem 0x0000000804e60000-0x0000000804e6ffff]
[ 0.000000] node 0: [mem 0x0000000804e70000-0x0000000804e7ffff]
[ 0.000000] node 0: [mem 0x0000000804e80000-0x0000000804ebffff]
[ 0.000000] node 0: [mem 0x0000000804ec0000-0x000000080534ffff]
[ 0.000000] node 0: [mem 0x0000000805350000-0x000000080539ffff]
[ 0.000000] node 0: [mem 0x00000008053a0000-0x00000008053cffff]
[ 0.000000] node 0: [mem 0x00000008053d0000-0x00000008053effff]
[ 0.000000] node 0: [mem 0x00000008053f0000-0x000000080553ffff]
[ 0.000000] node 0: [mem 0x0000000805540000-0x00000008055dffff]
[ 0.000000] node 0: [mem 0x00000008055e0000-0x000000080568ffff]
[ 0.000000] node 0: [mem 0x0000000805690000-0x000000080572ffff]
[ 0.000000] node 0: [mem 0x0000000805730000-0x00000008057bffff]
[ 0.000000] node 0: [mem 0x00000008057c0000-0x000000080585ffff]
[ 0.000000] node 0: [mem 0x0000000805860000-0x000000080612ffff]
[ 0.000000] node 0: [mem 0x0000000806130000-0x000000080630ffff]
[ 0.000000] node 0: [mem 0x0000000806310000-0x00000008278bffff]
[ 0.000000] node 0: [mem 0x00000008278c0000-0x000000082790ffff]
[ 0.000000] node 0: [mem 0x0000000827910000-0x000000082b6affff]
[ 0.000000] node 0: [mem 0x000000082c400000-0x000000082c7fffff]
[ 0.000000] node 0: [mem 0x0000000834000000-0x0000000835ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000835ffffff]
[ 0.000000] On node 0 totalpages: 8051376
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 118144 pages used for memmap
[ 0.000000] Normal zone: 7527088 pages, LIFO batch:63
[ 0.000000] On node 0, zone Normal: 336 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 27 pages/cpu s72896 r8192 d29504 u110592
[ 0.000000] pcpu-alloc: s72896 r8192 d29504 u110592 alloc=27*4096
[ 0.000000] pcpu-alloc: [0] 00 [0] 01 [0] 02 [0] 03 [0] 04 [0] 05 [0] 06 [0] 07
[ 0.000000] pcpu-alloc: [0] 08 [0] 09 [0] 10 [0] 11
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7925040
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 30995040K/32205504K available (18176K kernel code, 3228K rwdata, 7064K rodata, 3904K init, 1124K bss, 948320K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x3b0 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000746] Console: colour dummy device 80x25
[ 0.000754] printk: console [tty0] enabled
[ 0.000793] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000799] pid_max: default: 32768 minimum: 301
[ 0.000861] LSM: Security Framework initializing
[ 0.000878] Yama: becoming mindful.
[ 0.000896] SELinux: Initializing.
[ 0.001046] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001150] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.003148] rcu: Hierarchical SRCU implementation.
[ 0.003338] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.004015] DTS File Name: /home/wklaw/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/public/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.004020] DTB Build time: Oct 10 2022 09:46:35
[ 0.005389] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.005501] EFI runtime services will be disabled.
[ 0.005768] smp: Bringing up secondary CPUs ...
[ 0.034493] Detected PIPT I-cache on CPU1
[ 0.034536] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.034570] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.063242] Detected PIPT I-cache on CPU2
[ 0.063252] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.063266] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.091895] Detected PIPT I-cache on CPU3
[ 0.091904] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.091918] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.122599] Detected PIPT I-cache on CPU4
[ 0.122624] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.122652] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.151357] Detected PIPT I-cache on CPU5
[ 0.151367] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.151382] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.180030] Detected PIPT I-cache on CPU6
[ 0.180040] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.180055] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.208718] Detected PIPT I-cache on CPU7
[ 0.208729] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.208743] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.239423] Detected PIPT I-cache on CPU8
[ 0.239449] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.239477] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.268178] Detected PIPT I-cache on CPU9
[ 0.268190] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.268206] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.297464] Detected PIPT I-cache on CPU10
[ 0.297475] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.297492] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.326764] Detected PIPT I-cache on CPU11
[ 0.326775] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.326791] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.326855] smp: Brought up 1 node, 12 CPUs
[ 0.326859] SMP: Total of 12 processors activated.
[ 0.326862] CPU features: detected: Privileged Access Never
[ 0.326863] CPU features: detected: LSE atomic instructions
[ 0.326864] CPU features: detected: User Access Override
[ 0.326865] CPU features: detected: 32-bit EL0 Support
[ 0.326867] CPU features: detected: Common not Private translations
[ 0.326868] CPU features: detected: RAS Extension Support
[ 0.326868] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.326869] CPU features: detected: CRC32 instructions
[ 0.326870] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.359307] CPU: All CPU(s) started at EL2
[ 0.361526] devtmpfs: initialized
[ 0.379869] Registered cp15_barrier emulation handler
[ 0.379878] Registered setend emulation handler
[ 0.379882] KASLR enabled
[ 0.379999] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.380014] futex hash table entries: 4096 (order: 7, 524288 bytes, linear)
[ 0.381671] pinctrl core: initialized pinctrl subsystem
[ 0.382173] SMBIOS 3.0.0 present.
[ 0.382177] DMI: /, BIOS 1.0-d7fb19b 08/10/2022
[ 0.382443] NET: Registered protocol family 16
[ 0.383222] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.383423] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.383615] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.383652] audit: initializing netlink subsys (disabled)
[ 0.383721] audit: type=2000 audit(0.380:1): state=initialized audit_enabled=0 res=1
[ 0.383903] thermal_sys: Registered thermal governor 'step_wise'
[ 0.383905] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.383906] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.386011] cpuidle: using governor menu
[ 0.386170] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.386307] ASID allocator initialised with 32768 entries
[ 0.386413] Serial: AMBA PL011 UART driver
[ 0.388255] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.388274] Tegra reboot handler registered.
[ 0.407447] mc: mapped MMIO address: 0xffff8000112c0000 -> 0x2c10000
[ 0.407457] mc: mapped MMIO address: 0xffff8000112e0000 -> 0x2c20000
[ 0.407462] mc: mapped MMIO address: 0xffff800011300000 -> 0x2c30000
[ 0.407467] mc: mapped MMIO address: 0xffff800011320000 -> 0x2c40000
[ 0.407472] mc: mapped MMIO address: 0xffff800011340000 -> 0x2c50000
[ 0.407477] mc: mapped MMIO address: 0xffff800011360000 -> 0x2b80000
[ 0.407482] mc: mapped MMIO address: 0xffff800011380000 -> 0x2b90000
[ 0.407487] mc: mapped MMIO address: 0xffff8000113a0000 -> 0x2ba0000
[ 0.407491] mc: mapped MMIO address: 0xffff8000113c0000 -> 0x2bb0000
[ 0.407496] mc: mapped MMIO address: 0xffff8000113e0000 -> 0x1700000
[ 0.407504] mc: mapped MMIO address: 0xffff800011400000 -> 0x1710000
[ 0.407509] mc: mapped MMIO address: 0xffff800011420000 -> 0x1720000
[ 0.407514] mc: mapped MMIO address: 0xffff800011440000 -> 0x1730000
[ 0.407519] mc: mapped MMIO address: 0xffff800011460000 -> 0x1740000
[ 0.407525] mc: mapped MMIO address: 0xffff800011480000 -> 0x1750000
[ 0.407529] mc: mapped MMIO address: 0xffff8000114a0000 -> 0x1760000
[ 0.407534] mc: mapped MMIO address: 0xffff8000114c0000 -> 0x1770000
[ 0.407542] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.407567] mc-err: mcerr ops are set to t23x
[ 0.407865] tegra234-cbb 13a00000.cbb-fabric: secure_irq = 21
[ 0.407956] tegra234-cbb c600000.aon-fabric: secure_irq = 22
[ 0.408028] tegra234-cbb d600000.bpmp-fabric: secure_irq = 23
[ 0.408108] tegra234-cbb de00000.dce-fabric: secure_irq = 24
[ 0.408188] tegra234-cbb be00000.rce-fabric: secure_irq = 25
[ 0.408265] tegra234-cbb b600000.sce-fabric: secure_irq = 26
[ 0.408551] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 66, base_baud = 0) is a SBSA
[ 0.408564] printk: console [ttyAMA0] enabled
[ 0.413453] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.413456] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.413457] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.413458] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.415172] ACPI: Interpreter disabled.
[ 0.416606] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 0.416800] vbusA-cvb: supplied by vdd-5v-sys
[ 0.416906] vbusB-cvb: supplied by vdd-5v-sys
[ 0.417048] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 0.417148] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 0.417490] iommu: Default domain type: Translated
[ 0.417530] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.417730] SCSI subsystem initialized
[ 0.417803] usbcore: registered new interface driver usbfs
[ 0.417817] usbcore: registered new interface driver hub
[ 0.417827] usbcore: registered new device driver usb
[ 0.418022] mc: Linux media interface: v0.10
[ 0.418035] videodev: Linux video capture interface: v2.00
[ 0.418186] pps_core: LinuxPPS API ver. 1 registered
[ 0.418188] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.418192] PTP clock support registered
[ 0.418428] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.418449] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 0.420277] FPGA manager framework
[ 0.420319] Advanced Linux Sound Architecture Driver Initialized.
[ 0.420612] Bluetooth: Core ver 2.22
[ 0.420627] NET: Registered protocol family 31
[ 0.420629] Bluetooth: HCI device and connection manager initialized
[ 0.420635] Bluetooth: HCI socket layer initialized
[ 0.420638] Bluetooth: L2CAP socket layer initialized
[ 0.420646] Bluetooth: SCO socket layer initialized
[ 0.421482] camchar: rtcpu character device driver loaded
[ 0.421783] clocksource: Switched to clocksource arch_sys_counter
[ 0.573086] VFS: Disk quotas dquot_6.6.0
[ 0.573118] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.573256] pnp: PnP ACPI: disabled
[ 0.575800] la/ptsa driver initialized.
[ 0.575849] NET: Registered protocol family 2
[ 0.576294] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.578555] tcp_listen_portaddr_hash hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[ 0.579009] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.579235] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes, linear)
[ 0.580833] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.580961] UDP hash table entries: 16384 (order: 9, 2097152 bytes, linear)
[ 0.581918] UDP-Lite hash table entries: 16384 (order: 9, 2097152 bytes, linear)
[ 0.582984] NET: Registered protocol family 1
[ 0.583229] RPC: Registered named UNIX socket transport module.
[ 0.583232] RPC: Registered udp transport module.
[ 0.583233] RPC: Registered tcp transport module.
[ 0.583236] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.583243] PCI: CLS 0 bytes, default 64
[ 0.583341] Trying to unpack rootfs image as initramfs...
[ 0.693668] Freeing initrd memory: 8196K
[ 0.695517] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.696169] Initialise system trusted keyrings
[ 0.696247] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.698767] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.699052] NFS: Registering the id_resolver key type
[ 0.699064] Key type id_resolver registered
[ 0.699065] Key type id_legacy registered
[ 0.699099] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.699106] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.699117] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.710847] NET: Registered protocol family 38
[ 0.710852] Key type asymmetric registered
[ 0.710854] Asymmetric key parser 'x509' registered
[ 0.710873] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.710938] io scheduler mq-deadline registered
[ 0.710940] io scheduler kyber registered
[ 0.716721] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.716745] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.716760] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 0.716775] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 0.719281] tegra_dc_assign_hw_data: no matching compatible node
[ 0.719283] tegradccommon module_init failed
[ 0.719285] tegradc module_init failed
[ 0.719549] EINJ: ACPI disabled.
[ 0.721050] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.721055] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 0.721057] tegra-pmc: ### PMC reset level: L0
[ 0.721059] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.722350] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.723329] printk: console [ttyTCU0] enabled
[ 0.723849] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.723852] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.723855] arm-smmu 12000000.iommu: stage 1 translation
[ 0.723856] arm-smmu 12000000.iommu: stage 2 translation
[ 0.723857] arm-smmu 12000000.iommu: nested translation
[ 0.723859] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.723862] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.726463] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 0.726465] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.726467] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.727347] arm-smmu 10000000.iommu: probing hardware configuration...
[ 0.727348] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.727350] arm-smmu 10000000.iommu: stage 1 translation
[ 0.727351] arm-smmu 10000000.iommu: stage 2 translation
[ 0.727352] arm-smmu 10000000.iommu: nested translation
[ 0.727353] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.727356] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.729863] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 0.729865] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.729866] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.730337] arm-smmu 8000000.iommu: probing hardware configuration...
[ 0.730339] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.730340] arm-smmu 8000000.iommu: stage 1 translation
[ 0.730341] arm-smmu 8000000.iommu: stage 2 translation
[ 0.730342] arm-smmu 8000000.iommu: nested translation
[ 0.730343] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.730345] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.732872] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 0.732873] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.732875] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.733651] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 0.736247] tegra_profiler: version: 1.147, samples/io: 49/28
[ 0.736373] tegra_profiler: auth: init
[ 0.736696] nvsciipc: loaded module
[ 0.737703] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[ 0.737920] tegra23x-qspi 3270000.spi: Node prod has invalid entries
[ 0.737923] tegra23x-qspi 3270000.spi: Node prod: Child has not proper setting
[ 0.737925] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[ 0.737927] tegra23x-qspi 3270000.spi: Prod settings list not found
[ 0.738053] tegra23x-qspi 3270000.spi: Failed to get reset control: -517
[ 0.738706] tun: Universal TUN/TAP device driver, 1.6
[ 0.739179] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.739182] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.739207] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.739209] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.739223] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.739225] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.739399] PPP generic driver version 2.4.2
[ 0.739444] PPP BSD Compression module registered
[ 0.739446] PPP Deflate Compression module registered
[ 0.739461] PPP MPPE Compression module registered
[ 0.739481] usbcore: registered new interface driver r8152
[ 0.739494] usbcore: registered new interface driver asix
[ 0.739505] usbcore: registered new interface driver ax88179_178a
[ 0.739515] usbcore: registered new interface driver cdc_ether
[ 0.739523] usbcore: registered new interface driver net1080
[ 0.739529] usbcore: registered new interface driver cdc_subset
[ 0.739535] usbcore: registered new interface driver zaurus
[ 0.739547] usbcore: registered new interface driver cdc_ncm
[ 0.739557] usbcore: registered new interface driver aqc111
[ 0.739683] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.739694] ohci-pci: OHCI PCI platform driver
[ 0.739709] ohci-platform: OHCI generic platform driver
[ 0.740000] tegra-xusb 3610000.xhci: Adding to iommu group 1
[ 0.740534] usbcore: registered new interface driver uas
[ 0.740551] usbcore: registered new interface driver usb-storage
[ 0.740700] tegra-xudc 3550000.xudc: Adding to iommu group 2
[ 0.741066] mousedev: PS/2 mouse device common for all mice
[ 0.741083] usbcore: registered new interface driver xpad
[ 0.742945] tegra_rtc c2a0000.rtc: registered as rtc1
[ 0.743221] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:25 UTC (25)
[ 0.743239] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 0.743423] i2c /dev entries driver
[ 0.743523] tegra-i2c 3160000.i2c: Adding to iommu group 3
[ 0.743737] tegra-i2c c240000.i2c: Adding to iommu group 3
[ 0.743799] tegra-i2c 3180000.i2c: Adding to iommu group 3
[ 0.743844] tegra-i2c 3190000.i2c: Adding to iommu group 3
[ 0.743890] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[ 0.743946] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[ 0.743993] tegra-i2c c250000.i2c: Adding to iommu group 3
[ 0.744037] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[ 0.746203] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 0.746207] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 0.747038] device-mapper: uevent: version 1.0.3
[ 0.747126] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 0.748314] sdhci: Secure Digital Host Controller Interface driver
[ 0.748316] sdhci: Copyright(c) Pierre Ossman
[ 0.748317] Synopsys Designware Multimedia Card Interface Driver
[ 0.748398] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.748540] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[ 0.749130] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[ 0.749299] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 0.750202] tegra-bpmp bpmp: firmware: 888a114dda6bea50b6c6-eac380526d6
[ 0.751137] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 0.751467] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[ 0.754246] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 0.754265] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[ 0.787398] random: fast init done
[ 2.017149] hid: raw HID events driver (C) Jiri Kosina
[ 2.017822] usbcore: registered new interface driver usbhid
[ 2.017825] usbhid: USB HID core driver
[ 2.018836] tegra-dce d800000.dce: Adding to iommu group 6
[ 2.020089] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
[ 2.020597] tegra234-aon c000000.aon: Adding to iommu group 7
[ 2.020884] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 2.020910] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [0]. Ignored...
[ 2.020995] dce: dce_admin_send_cmd_ver:413 version : [0x2] err : [0x0]
[ 2.021099] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 2.021104] dce: dce_admin_setup_clients_ipc:542 Channel Reset Complete for Type [1] ...
[ 2.021105] dce: dce_admin_setup_clients_ipc:518 Get queue info failed for [2]
[ 2.021107] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [1]. Ignored...
[ 2.021116] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [1]. Ignored...
[ 2.021205] dce: dce_admin_setup_clients_ipc:542 Channel Reset Complete for Type [3] ...
[ 2.021209] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [3]. Ignored...
[ 2.021218] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [3]. Ignored...
[ 2.021377] dce: dce_start_boot_flow:100 DCE_BOOT_DONE
[ 2.022211] c000000.aon:hsp: probed
[ 2.022416] tegra234-aon c000000.aon: init done
[ 2.022705] tegra23x-psc e860000.psc: Adding to iommu group 8
[ 2.023258] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 2.023263] tegra23x-psc e860000.psc: init done
[ 2.023419] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 9
[ 2.024276] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 2.027768] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 2.027818] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.027928] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 2.027988] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 2.028398] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 2.028438] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 2.028465] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 2.028743] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (117)
[ 2.028745] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.029116] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2.029120] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2.029125] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2.029126] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2.029126] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=7a10e4613e151d2bf1df37dd80d456800f5b94d0
[ 2.029127] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2.029135] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2.029136] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2.029138] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2.029139] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2.030908] t19x_cache tegra-cache: probed
[ 2.031328] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 2.039338] optee: probing for conduit method.
[ 2.039359] optee: revision 3.16 (65cc2218)
[ 2.039455] optee: dynamic shared memory is enabled
[ 2.039591] optee: initialized driver
[ 2.051340] nvpmodel: initialized successfully
[ 2.051435] tegra_hv: get_hvd: not initialized yet
[ 2.051447] user_ivc_mempool: hypervisor not present
[ 2.051732] usbcore: registered new interface driver snd-usb-audio
[ 2.052460] u32 classifier
[ 2.052463] input device check on
[ 2.052466] Actions configured
[ 2.052599] Initializing XFRM netlink socket
[ 2.052946] NET: Registered protocol family 10
[ 2.054767] Segment Routing with IPv6
[ 2.054811] NET: Registered protocol family 17
[ 2.054834] NET: Registered protocol family 15
[ 2.054880] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.055626] Bluetooth: RFCOMM socket layer initialized
[ 2.055657] Bluetooth: RFCOMM ver 1.11
[ 2.055669] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.055679] Bluetooth: HIDP socket layer initialized
[ 2.056437] 9pnet: Installing 9P2000 support
[ 2.056500] Key type dns_resolver registered
[ 2.058136] printk: console [tty0]: printing thread started
[ 2.058430] printk: console [ttyTCU0]: printing thread started
[ 2.058850] printk: console [ttyAMA0]: printing thread started
[ 2.058922] Loading compiled-in X.509 certificates
[ 2.062058] Loaded X.509 cert 'Build time autogenerated kernel key: 634bc10d821957800e15eb2703cb9aadd8717845'
[ 2.062381] tegra194-pcie 14100000.pcie: Adding to iommu group 10
[ 2.068286] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 2.068941] tegra194-pcie 14160000.pcie: Adding to iommu group 11
[ 2.074400] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 2.074828] tegra194-pcie 141a0000.pcie: Adding to iommu group 12
[ 2.079788] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 2.079832] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 2.110335] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 13
[ 2.113454] host1x 13e40000.host1x: Adding to iommu group 14
[ 3.124953] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 3.135071] host1x 13e40000.host1x: initialized
[ 3.135401] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 15
[ 3.135939] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 3.137305] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 16
[ 3.137582] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 3.138908] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 17
[ 3.139393] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 3.140691] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 18
[ 3.141218] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 3.142578] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 19
[ 3.143069] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 3.144372] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 20
[ 3.144854] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 3.146170] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 21
[ 3.146652] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 3.147953] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 22
[ 3.148668] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 3.150030] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 23
[ 3.150339] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 3.151640] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 24
[ 3.152152] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 3.153456] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 25
[ 3.153966] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 3.155245] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 26
[ 3.156080] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 3.157379] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 27
[ 3.158206] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 3.159491] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 28
[ 3.160031] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 3.161345] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 29
[ 3.161881] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 3.163186] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 30
[ 3.163894] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 3.165229] falcon 15340000.vic: Adding to iommu group 31
[ 3.170296] falcon 15340000.vic: initialized
[ 3.170644] falcon 15380000.nvjpg: Adding to iommu group 32
[ 3.173145] falcon 15380000.nvjpg: initialized
[ 3.173284] falcon 15540000.nvjpg1: Adding to iommu group 33
[ 3.175932] falcon 15540000.nvjpg1: initialized
[ 3.176058] falcon 154c0000.nvenc: Adding to iommu group 34
[ 3.180061] falcon 154c0000.nvenc: initialized
[ 3.180189] falcon 15a50000.ofa: Adding to iommu group 35
[ 3.182850] falcon 15a50000.ofa: initialized
[ 3.182980] nvdec 15480000.nvdec: Adding to iommu group 36
[ 3.187898] nvdec 15480000.nvdec: initialized
[ 3.188011] tsec 15500000.tsec: Adding to iommu group 37
[ 3.191926] tsec 15500000.tsec: initialized
[ 3.193672] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 3.202877] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 3.213746] gpio-394 (camera-control-output-low): hogged as output/low
[ 3.213788] gpio-397 (camera-control-output-low): hogged as output/low
[ 3.213826] gpio-487 (camera-control-output-low): hogged as output/low
[ 3.213857] gpio-486 (camera-control-output-low): hogged as output/low
[ 3.214819] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 3.215590] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 3.215746] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 3.216476] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 3.217143] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 3.217597] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 3.219792] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 3.219920] tegra194-isp5 14800000.isp: Adding to iommu group 38
[ 3.222895] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 3.223156] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 3.223342] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 39
[ 3.224055] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 40
[ 3.224626] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 3.224752] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 3.224836] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 3.224927] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 3.225005] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 3.225099] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 3.225198] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 41
[ 3.225487] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 3.225588] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 42
[ 3.225895] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 3.225986] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 43
[ 3.226226] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 3.226316] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 44
[ 3.226564] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 3.226654] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 45
[ 3.226917] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 3.227007] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 46
[ 3.227255] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 3.227341] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 47
[ 3.227610] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 3.227699] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 48
[ 3.227933] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 3.228032] pva 16000000.pva0: Adding to iommu group 49
[ 3.247120] pva 16000000.pva0: initialized
[ 3.250561] nvdla 15880000.nvdla0: Adding to iommu group 50
[ 3.258821] nvdla 15880000.nvdla0: initialized
[ 3.260525] nvdla 158c0000.nvdla1: Adding to iommu group 51
[ 3.268347] nvdla 158c0000.nvdla1: initialized
[ 3.270056] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[ 3.270949] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 3.271165] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 3.271169] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 3.271349] serial-tegra 3100000.serial: Adding to iommu group 3
[ 3.271700] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud = 0) is a TEGRA_UART
[ 3.272135] serial-tegra 3130000.serial: Adding to iommu group 3
[ 3.272475] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.272822] tegra23x-qspi 3270000.spi: Node prod has invalid entries
[ 3.272826] tegra23x-qspi 3270000.spi: Node prod: Child has not proper setting
[ 3.272827] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[ 3.272830] tegra23x-qspi 3270000.spi: Prod settings list not found
[ 3.296900] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 3.296911] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 3.296936] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 3.297751] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 3.298096] tegra-xusb 3610000.xhci: irq 235, io mem 0x03610000
[ 3.298464] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 3.298469] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.298470] usb usb1: Product: xHCI Host Controller
[ 3.298473] usb usb1: Manufacturer: Linux 5.10.104-rt63-tegra xhci-hcd
[ 3.298473] usb usb1: SerialNumber: 3610000.xhci
[ 3.299127] hub 1-0:1.0: USB hub found
[ 3.299156] hub 1-0:1.0: 4 ports detected
[ 3.299393] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 3.299406] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 3.299411] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.299484] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 3.299487] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.299490] usb usb2: Product: xHCI Host Controller
[ 3.299491] usb usb2: Manufacturer: Linux 5.10.104-rt63-tegra xhci-hcd
[ 3.299492] usb usb2: SerialNumber: 3610000.xhci
[ 3.299659] hub 2-0:1.0: USB hub found
[ 3.299675] hub 2-0:1.0: 4 ports detected
[ 3.331623] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 3.333905] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 3.336457] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2043000 KHz, changing to: 2112000 KHz
[ 3.337947] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 3.339154] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 3.342195] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 3.342204] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 3.342210] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 3.342212] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 3.344006] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.349391] mmc0: CQHCI version 5.10
[ 3.353500] irq: IRQ302: trimming hierarchy from :interrupt-controller@f400000-1
[ 3.353543] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 302
[ 3.377955] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 3.449915] tegra194-pcie 14100000.pcie: Link up
[ 3.450832] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 3.450835] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 3.450838] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 3.450840] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 3.450842] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 3.450891] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 3.451059] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 3.455397] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 3.455556] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 3.455755] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 3.456849] pci 0001:01:00.0: supports D1 D2
[ 3.456850] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 3.461120] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 3.461124] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 3.461127] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 3.461229] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 3.461260] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 3.461264] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 3.461268] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 3.461282] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 3.461356] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 3.461608] pcieport 0001:00:00.0: Adding to iommu group 10
[ 3.462033] pcieport 0001:00:00.0: PME: Signaling with IRQ 51
[ 3.462360] pcieport 0001:00:00.0: AER: enabled with IRQ 51
[ 3.463146] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 3.464942] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 3.464950] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 3.464956] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 3.464960] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 3.468109] mmc0: Command Queue Engine enabled
[ 3.468112] mmc0: periodic cache flush enabled
[ 3.468116] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 3.468470] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 3.468697] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (511:0)
[ 3.471976] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 3.553924] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 3.705895] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 3.705899] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.705901] usb 1-3: Product: Bluetooth Radio
[ 3.705902] usb 1-3: Manufacturer: Realtek
[ 3.705904] usb 1-3: SerialNumber: 00e04c000001
[ 3.830637] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 3.868364] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 3.868367] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.868368] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 3.868370] usb 2-3: Manufacturer: Generic
[ 3.878579] hub 2-3:1.0: USB hub found
[ 3.880792] hub 2-3:1.0: 4 ports detected
[ 3.985913] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 4.153615] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 4.153619] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.153621] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 4.153623] usb 1-4: Manufacturer: Generic
[ 4.155060] hub 1-4:1.0: USB hub found
[ 4.156557] hub 1-4:1.0: 4 ports detected
[ 4.571087] tegra194-pcie 14160000.pcie: Phy link never came up
[ 4.571154] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 4.571157] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 4.571160] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 4.571162] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 4.571164] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 4.571208] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 4.571373] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 4.578991] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 4.579013] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 4.579275] pcieport 0004:00:00.0: Adding to iommu group 11
[ 4.579671] pcieport 0004:00:00.0: PME: Signaling with IRQ 53
[ 4.580268] pcieport 0004:00:00.0: AER: enabled with IRQ 53
[ 4.580522] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 4.580611] pci 0004:00:00.0: Removing from iommu group 11
[ 4.580620] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 4.582064] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 4.582079] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 4.582174] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 4.582388] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 4.582481] vdd-dp: supplied by vdd-3v3-sys
[ 4.582651] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 4.583057] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 4.584968] tegra194-isp5 14800000.isp: initialized
[ 4.589072] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 4.589146] (NULL device *): fops function table already registered
[ 4.589967] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 4.590469] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 4.590904] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.601199] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 302
[ 4.652634] random: crng init done
[ 4.698340] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 4.698353] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 4.698359] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 4.698362] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[ 4.857773] usb 1-4.2: new high-speed USB device number 4 using tegra-xusb
[ 4.959858] usb 1-4.2: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 4.959862] usb 1-4.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.960757] hub 1-4.2:1.0: USB hub found
[ 4.961231] hub 1-4.2:1.0: 3 ports detected
[ 5.249771] usb 1-4.2.1: new high-speed USB device number 5 using tegra-xusb
[ 5.359854] usb 1-4.2.1: New USB device found, idVendor=0424, idProduct=2640, bcdDevice= 0.00
[ 5.359858] usb 1-4.2.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.360757] hub 1-4.2.1:1.0: USB hub found
[ 5.361230] hub 1-4.2.1:1.0: 3 ports detected
[ 5.445775] usb 1-4.2.2: new low-speed USB device number 6 using tegra-xusb
[ 5.559604] usb 1-4.2.2: New USB device found, idVendor=413c, idProduct=2005, bcdDevice= 1.05
[ 5.559607] usb 1-4.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.559608] usb 1-4.2.2: Product: DELL USB Keyboard
[ 5.559609] usb 1-4.2.2: Manufacturer: DELL
[ 5.565579] input: DELL DELL USB Keyboard as /devices/platform/3610000.xhci/usb1/1-4/1-4.2/1-4.2.2/1-4.2.2:1.0/0003:413C:2005.0001/input/input0
[ 5.622381] hid-generic 0003:413C:2005.0001: input,hidraw0: USB HID v1.10 Keyboard [DELL DELL USB Keyboard] on usb-3610000.xhci-4.2.2/input0
[ 5.649771] usb 1-4.2.1.1: new high-speed USB device number 7 using tegra-xusb
[ 5.661854] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 5.794108] usb 1-4.2.1.1: New USB device found, idVendor=0424, idProduct=4060, bcdDevice= 1.82
[ 5.794112] usb 1-4.2.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.794114] usb 1-4.2.1.1: Product: Ultra Fast Media Reader
[ 5.794115] usb 1-4.2.1.1: Manufacturer: Generic
[ 5.794116] usb 1-4.2.1.1: SerialNumber: \xe2\x83\xb1??000264001
[ 5.795145] usb-storage 1-4.2.1.1:1.0: USB Mass Storage device detected
[ 5.796201] scsi host0: usb-storage 1-4.2.1.1:1.0
[ 5.806266] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 5.806320] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 5.806322] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 5.806325] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 5.806327] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 5.806328] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 5.806370] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 5.806530] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 5.814183] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 5.814204] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.814456] pcieport 0005:00:00.0: Adding to iommu group 12
[ 5.814848] pcieport 0005:00:00.0: PME: Signaling with IRQ 55
[ 5.815187] pcieport 0005:00:00.0: AER: enabled with IRQ 55
[ 5.815426] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 5.815512] pci 0005:00:00.0: Removing from iommu group 12
[ 5.815522] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 5.817261] nvethernet 6810000.ethernet: Adding to iommu group 52
[ 5.817852] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 5.817856] nvethernet 6810000.ethernet: failed to read MDIO address
[ 5.817859] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 5.817867] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 5.837801] usb 1-4.2.3: new low-speed USB device number 8 using tegra-xusb
[ 5.959655] usb 1-4.2.3: New USB device found, idVendor=046d, idProduct=c063, bcdDevice=57.00
[ 5.959658] usb 1-4.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.959659] usb 1-4.2.3: Product: DELL USB Laser Mouse
[ 5.959661] usb 1-4.2.3: Manufacturer: DELL
[ 5.966260] input: DELL DELL USB Laser Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.2/1-4.2.3/1-4.2.3:1.0/0003:046D:C063.0002/input/input1
[ 5.967053] hid-generic 0003:046D:C063.0002: input,hidraw1: USB HID v1.10 Mouse [DELL DELL USB Laser Mouse] on usb-3610000.xhci-4.2.3/input0
[ 6.210237] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:69:4e:1e
[ 6.210311] -->macsec_probe()
[ 6.210329] -->macsec_get_platform_res()
[ 6.210353] <--macsec_get_platform_res()
[ 6.210354] -->macsec_enable_car()
[ 6.210567] <--macsec_enable_car()
[ 6.210589] <--macsec_probe()
[ 6.210590] nvethernet 6810000.ethernet: Macsec not enabled
[ 6.210591] nvethernet 6810000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 6.212589] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 6.213378] irq: IRQ304: trimming hierarchy from :pmc@c360000
[ 6.213828] irq: IRQ305: trimming hierarchy from :interrupt-controller@f400000-1
[ 6.214272] irq: IRQ306: trimming hierarchy from :pmc@c360000
[ 6.214578] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[ 6.215026] tegra-se-nvhost 15810000.se: Adding to iommu group 53
[ 6.215637] tegra-se-nvhost 15810000.se: initialized
[ 6.225726] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 6.225865] tegra-se-nvhost 15820000.se: Adding to iommu group 54
[ 6.226301] tegra-se-nvhost 15820000.se: initialized
[ 6.228483] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 6.228568] tegra-se-nvhost 15840000.se: Adding to iommu group 55
[ 6.228958] tegra-se-nvhost 15840000.se: initialized
[ 6.233577] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 6.234323] tegra_actmon d230000.actmon: in actmon_register()...
[ 6.234592] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 6.234973] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 6.235156] hvc_sysfs: hypervisor is not present
[ 6.366156] ALSA device list:
[ 6.366160] No soundcards found.
[ 6.375664] Freeing unused kernel memory: 3904K
[ 6.375747] Run /init as init process
[ 6.375749] with arguments:
[ 6.375749] /init
[ 6.375750] with environment:
[ 6.375750] HOME=/
[ 6.375751] TERM=linux
[ 6.375751] mminit_loglevel=4
[ 6.395493] Root device found: mmcblk0p1
[ 6.395974] Found dev node: /dev/mmcblk0p1
[ 6.650298] EXT4-fs (mmcblk0p1): 1 orphan inode deleted
[ 6.650303] EXT4-fs (mmcblk0p1): recovery complete
[ 6.654187] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.655684] Rootfs mounted over mmcblk0p1
[ 6.667164] Switching from initrd to actual rootfs
[ 6.813757] systemd[1]: System time before build time, advancing clock.
[ 6.829174] scsi 0:0:0:0: Direct-Access Generic Ultra HS-SD/MMC 1.82 PQ: 0 ANSI: 0
[ 6.871463] systemd[1]: systemd 245.4-4ubuntu3.17 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 6.871943] systemd[1]: Detected architecture arm64.
[ 6.889922] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 7.045864] systemd[1]: Set hostname to <linux>.
[ 7.256267] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 7.256273] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 7.257179] systemd[1]: Created slice system-modprobe.slice.
[ 7.307819] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.357482] systemd[1]: Created slice User and Session Slice.
[ 7.390960] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.457134] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.515377] systemd[1]: Reached target User and Group Name Lookups.
[ 7.531501] systemd[1]: Reached target Slices.
[ 7.531550] systemd[1]: Reached target Swap.
[ 7.531829] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 7.531987] systemd[1]: Listening on Syslog Socket.
[ 7.532141] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 7.532242] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 7.532493] systemd[1]: Listening on Journal Audit Socket.
[ 7.532629] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.532801] systemd[1]: Listening on Journal Socket.
[ 7.532963] systemd[1]: Listening on udev Control Socket.
[ 7.533081] systemd[1]: Listening on udev Kernel Socket.
[ 7.534360] systemd[1]: Mounting Huge Pages File System...
[ 7.582251] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.611047] systemd[1]: Mounting RPC Pipe File System...
[ 7.612320] systemd[1]: Mounting Kernel Debug File System...
[ 7.613891] systemd[1]: Mounting Kernel Trace File System...
[ 7.632517] systemd[1]: Starting Journal Service...
[ 7.633999] systemd[1]: Starting Set the console keyboard layout...
[ 7.645601] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[ 7.645647] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 7.646786] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 7.674602] systemd[1]: Started Nameserver information manager.
[ 7.674873] systemd[1]: Reached target Network (Pre).
[ 7.681909] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 7.681980] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 7.685051] systemd[1]: Starting Load Kernel Modules...
[ 7.714596] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.716662] systemd[1]: Starting udev Coldplug all Devices...
[ 7.718534] systemd[1]: Mounted Huge Pages File System.
[ 7.729486] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.742826] systemd[1]: Started Journal Service.
[ 7.773394] systemd-journald[524]: Received client request to flush runtime journal.
[ 11.595635] using random self ethernet address
[ 11.595642] using random host ethernet address
[ 13.650673] hwmon hwmon1: temp1_input not attached to any thermal zone
[ 14.338295] Aquantia AQR113C 6810000.ethernet:00: No AQR phy_mode setting in DT
[ 18.434356] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 18.436318] nvethernet 6810000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 20.977539] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[ 37.853802] vdd-12v-sys: disabling
[ 37.853812] vdd-1v8-sys: disabling
[ 37.853814] vdd-3v3-ftdi: disabling
