Hi David,
Can you parallelly, help me out to solve this issue, it’s very helpful for me:
Actually I am trying to bring Up the display on custom carrier board(HDMI to HDMI)
[0000.062] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.067] I> t234-A01-1-Silicon (0x12347) Prod
[0000.071] I> Boot-mode : Coldboot
[0000.074] I> Entry timestamp: 0x00000000
[0000.078] I> last_boot_error: 0x0
[0000.081] I> BR-BCT: preprod_dev_sign: 0
[0000.085] I> rst_source: 0x0, rst_level: 0x0
[0000.089] I> Task: SE error check
[0000.092] I> Task: Bootchain select WAR set
[0000.096] I> Task: Enable SLCG
[0000.099] I> Task: CRC check
[0000.102] I> Task: Initialize MB2 params
[0000.106] I> MB2-params @ 0x40060000
[0000.110] I> Task: Crypto init
[0000.113] I> Task: Perform MB1 KAT tests
[0000.117] I> Task: NVRNG health check
[0000.120] I> NVRNG: Health check success
[0000.124] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.130] I> Task: Enabling and initialization of Bandwidth limiter
[0000.136] I> No request to configure MBWT settings for any PC!
[0000.142] I> Task: Secure debug controls
[0000.145] I> Task: strap war set
[0000.149] I> Task: Initialize SOC Therm
[0000.152] I> Task: Program NV master stream id
[0000.157] I> Task: Verify boot mode
[0000.162] I> Task: Alias fuses
[0000.166] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.173] I> Task: Print SKU type
[0000.176] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.181] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.186] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.190] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.194] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.198] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.203] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.207] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.212] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.216] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.220] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.224] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.228] I> FUSE_SKU_INFO_0 = 0xd0
[0000.232] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.236] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.239] I> SKU: Prod
[0000.241] I> Task: Boost clocks
[0000.244] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.250] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.255] I> BPMP NAFLL lock success.
[0000.258] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.263] I> Initializing PLLC2 for AXI_CBB.
[0000.267] I> AXI_CBB : src = 35, divisor = 0
[0000.271] I> Task: Voltage monitor
[0000.275] I> VMON: Vmon re-calibration and fine tuning done
[0000.280] I> Task: UPHY init
[0000.285] I> HSIO UPHY init done
[0000.288] W> Skipping GBE UPHY config
[0000.291] I> Task: Boot device init
[0000.295] I> Boot_device: QSPI_FLASH instance: 0
[0000.300] I> Qspi clock source : pllc_out0
[0000.304] I> QSPI Flash: Macronix 64MB
[0000.307] I> QSPI-0l initialized successfully
[0000.311] I> Task: TSC init
[0000.314] I> Task: Load membct
[0000.317] I> RAM_CODE 0x4000431
[0000.320] I> Loading MEMBCT
[0000.323] I> Slot: 0
[0000.325] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.330] I> Binary name: MEM-BCT-0
[0000.334] I> Size of crypto header is 8192
[0000.338] I> Size of crypto header is 8192
[0000.342] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.348] I> BCH of MEM-BCT-0 read from storage
[0000.352] I> BCH address is : 0x40050000
[0000.356] I> MEM-BCT-0 header integrity check is success
[0000.361] I> Binary magic in BCH component 0 is MEM0
[0000.366] I> component binary type is 0
[0000.370] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.377] I> MEM-BCT-0 binary is read from storage
[0000.381] I> MEM-BCT-0 binary integrity check is success
[0000.387] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.393] I> RAM_CODE 0x4000431
[0000.399] I> RAM_CODE 0x4000431
[0000.403] I> Task: Load Page retirement list
[0000.407] I> Task: SDRAM params override
[0000.410] I> Task: Save mem-bct info
[0000.414] I> Task: Carveout allocate
[0000.417] I> RCM blob carveout will not be allocated
[0000.422] I> Update CCPLEX IST carveout from MB1-BCT
[0000.427] I> ECC region[0]: Start:0x0, End:0x0
[0000.431] I> ECC region[1]: Start:0x0, End:0x0
[0000.435] I> ECC region[2]: Start:0x0, End:0x0
[0000.440] I> ECC region[3]: Start:0x0, End:0x0
[0000.444] I> ECC region[4]: Start:0x0, End:0x0
[0000.448] I> Non-ECC region[0]: Start:0x80000000, End:0x1080000000
[0000.454] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.459] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.464] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.468] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.479] I> allocated(CO:44) base:0x1049800000 size:0x36800000 align: 0x100000
[0000.486] I> allocated(CO:31) base:0x1040000000 size:0x8000000 align: 0x8000000
[0000.493] I> allocated(CO:43) base:0x103c000000 size:0x4000000 align: 0x200000
[0000.500] I> allocated(CO:39) base:0x1039e00000 size:0x2200000 align: 0x10000
[0000.507] I> allocated(CO:20) base:0x1036000000 size:0x2000000 align: 0x2000000
[0000.515] I> allocated(CO:24) base:0x1034000000 size:0x2000000 align: 0x2000000
[0000.522] I> allocated(CO:28) base:0x1032000000 size:0x2000000 align: 0x2000000
[0000.529] I> allocated(CO:29) base:0x1030000000 size:0x2000000 align: 0x2000000
[0000.536] I> allocated(CO:22) base:0x1048000000 size:0x1000000 align: 0x1000000
[0000.544] I> allocated(CO:35) base:0x1038e00000 size:0x1000000 align: 0x100000
[0000.551] I> allocated(CO:41) base:0x102f000000 size:0x1000000 align: 0x100000
[0000.558] I> allocated(CO:02) base:0x1049000000 size:0x800000 align: 0x800000
[0000.565] I> allocated(CO:03) base:0x1038000000 size:0x800000 align: 0x800000
[0000.572] I> allocated(CO:06) base:0x102e800000 size:0x800000 align: 0x800000
[0000.579] I> allocated(CO:56) base:0x102e000000 size:0x800000 align: 0x200000
[0000.586] I> allocated(CO:07) base:0x1038800000 size:0x400000 align: 0x400000
[0000.593] I> allocated(CO:33) base:0x102dc00000 size:0x400000 align: 0x200000
[0000.600] I> allocated(CO:19) base:0x102d980000 size:0x280000 align: 0x10000
[0000.607] I> allocated(CO:23) base:0x1038c00000 size:0x200000 align: 0x200000
[0000.614] I> allocated(CO:01) base:0x102d800000 size:0x100000 align: 0x100000
[0000.621] I> allocated(CO:05) base:0x102d700000 size:0x100000 align: 0x100000
[0000.628] I> allocated(CO:08) base:0x102d600000 size:0x100000 align: 0x100000
[0000.635] I> allocated(CO:09) base:0x102d500000 size:0x100000 align: 0x100000
[0000.642] I> allocated(CO:12) base:0x102d400000 size:0x100000 align: 0x100000
[0000.649] I> allocated(CO:15) base:0x102d300000 size:0x100000 align: 0x100000
[0000.656] I> allocated(CO:17) base:0x102d200000 size:0x100000 align: 0x100000
[0000.663] I> allocated(CO:27) base:0x102d100000 size:0x100000 align: 0x100000
[0000.670] I> allocated(CO:42) base:0x102d000000 size:0x100000 align: 0x100000
[0000.677] I> allocated(CO:54) base:0x102d900000 size:0x80000 align: 0x80000
[0000.684] I> allocated(CO:34) base:0x102cff0000 size:0x10000 align: 0x10000
[0000.691] I> allocated(CO:72) base:0x102cdf0000 size:0x200000 align: 0x10000
[0000.698] I> allocated(CO:47) base:0x102c800000 size:0x400000 align: 0x200000
[0000.705] I> allocated(CO:50) base:0x102c600000 size:0x200000 align: 0x100000
[0000.712] I> allocated(CO:52) base:0x102cdc0000 size:0x30000 align: 0x10000
[0000.719] I> allocated(CO:48) base:0x102cda0000 size:0x20000 align: 0x10000
[0000.726] I> allocated(CO:69) base:0x102cd80000 size:0x20000 align: 0x10000
[0000.733] I> allocated(CO:49) base:0x102cd70000 size:0x10000 align: 0x10000
[0000.739] I> NSDRAM base: 0x80000000, end: 0x102cdf0000, size: 0xfacdf0000
[0000.746] I> Task: Thermal check
[0000.749] I> Using min_chip_limit as min_tmon_limit
[0000.754] I> Using max_chip_limit as max_tmon_limit
[0000.759] I> BCT max_tmon_limit = 105
[0000.762] I> BCT min_tmon_limit = -28
[0000.766] I> BCT max_tmon_limit = 105
[0000.769] I> BCT min_tmon_limit = -28
[0000.773] I> SKU specific max_chip_limit = 105
[0000.777] I> SKU specific min_chip_limit = -28
[0000.781] I> BCT max_chip_limit = 105
[0000.785] I> BCT min_chip_limit = -28
[0000.788] I> enable_soctherm_polling = 0
[0000.792] I> max temp read = 29
[0000.795] I> min temp read = 29
[0000.798] I> Enabling thermtrip
[0000.801] I> Task: Update FSI SCR with thermal fuse data
[0000.806] I> Task: Enable WDT 5th expiry
[0000.810] I> Task: I2C register
[0000.813] I> Task: Set I2C bus freq
[0000.816] I> Task: Reset FSI
[0000.819] I> Task: Pinmux init
[0000.822] I> Task: Prod config init
[0000.826] I> Task: Pad voltage init
[0000.829] I> Task: Prod init
[0000.832] I> Task: Program rst req config reg
[0000.836] I> Task: Common rail init
[0000.840] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.851] I> DONE: Thermal config
[0000.855] I> DONE: SOC rail config
[0000.859] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.865] I> DONE: MEMIO rail config
[0000.869] I> DONE: GPU rail info
[0000.873] I> DONE: CV rail info
[0000.876] I> Task: Mem clock src
[0000.879] I> Task: Misc. board config
[0000.884] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.889] I> Task: SDRAM init
[0000.892] I> MemoryType: 4 MemBctRevision: 8
[0000.899] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0000.906] I> MSS CAR: Init PLLM
[0000.909] I> MSS CAR: Init PLLHUB
[0000.914] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.926] I> SDRAM initialized!
[0000.929] I> SDRAM Size in Total 0x1000000000
[0000.933] I> Task: Dram Ecc scrub
[0000.936] I> Task: DRAM alias check
[0000.952] I> Task: Program NSDRAM carveout
[0000.956] I> NSDRAM carveout encryption is enabled
[0000.961] I> Program NSDRAM carveout
[0000.965] I> Task: Register checker
[0000.968] I> Task: Enable clock-mon
[0000.982] I> FMON: Fmon re-programming done
[0000.986] I> Task: Mapper init
[0000.989] I> Task: SC7 Context Init
[0000.993] I> Task: CCPLEX IST init
[0000.996] I> Task: CPU WP0
[0001.000] I> Loading MCE
[0001.002] I> Slot: 0
[0001.004] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.010] I> Binary name: MCE
[0001.013] I> Size of crypto header is 8192
[0001.017] I> Size of crypto header is 8192
[0001.020] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.027] I> BCH of MCE read from storage
[0001.031] I> BCH address is : 0x4003e000
[0001.035] I> MCE header integrity check is success
[0001.039] I> Binary magic in BCH component 0 is MTSM
[0001.044] I> component binary type is 8
[0001.048] I> Size of crypto header is 8192
[0001.052] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.060] I> MCE binary is read from storage
[0001.064] I> MCE binary integrity check is success
[0001.069] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.075] I> Size of crypto header is 8192
[0001.086] I> Size of crypto header is 8192
[0001.090] I> Sending WP0 mailbox command to PSC
[0001.099] I> Task: XUSB Powergate
[0001.102] I> Skipping powergate XUSB.
[0001.106] I> Task: MB1 fixed firewalls
[0001.112] W> Firewall readback mismatch
[0001.117] I> Task: Load bpmp-fw
[0001.120] I> Slot: 0
[0001.122] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.128] I> Binary name: BPMP_FW
[0001.131] I> Size of crypto header is 8192
[0001.135] I> Size of crypto header is 8192
[0001.139] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.145] I> BCH of BPMP_FW read from storage
[0001.149] I> BCH address is : 0x807fe000
[0001.153] I> BPMP_FW header integrity check is success
[0001.158] I> Binary magic in BCH component 0 is BPMF
[0001.163] I> component binary type is 15
[0001.167] I> Size of crypto header is 8192
[0001.170] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.188] I> BPMP_FW binary is read from storage
[0001.194] I> BPMP_FW binary integrity check is success
[0001.199] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.206] I> Slot: 0
[0001.208] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.214] I> Binary name: BPMP_FW_DTB
[0001.217] I> Size of crypto header is 8192
[0001.221] I> Size of crypto header is 8192
[0001.225] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.231] I> BCH of BPMP_FW_DTB read from storage
[0001.236] I> BCH address is : 0x807fc000
[0001.240] I> BPMP_FW_DTB header integrity check is success
[0001.245] I> Binary magic in BCH component 0 is BPMD
[0001.250] I> component binary type is 16
[0001.253] I> Size of crypto header is 8192
[0001.257] I> strt_pg_num(13072) num_of_pgs(502) read_buf(0x807bd3f0)
[0001.266] I> BPMP_FW_DTB binary is read from storage
[0001.272] I> BPMP_FW_DTB binary integrity check is success
[0001.277] I> Binary BPMP_FW_DTB loaded successfully at 0x807bd3f0 (0x3eb00)
[0001.284] I> Task: BPMP fw ast config
[0001.287] I> Task: Load psc-fw
[0001.290] I> Slot: 0
[0001.292] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.298] I> Binary name: PSC_FW
[0001.301] I> Size of crypto header is 8192
[0001.305] I> Size of crypto header is 8192
[0001.309] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.315] I> BCH of PSC_FW read from storage
[0001.319] I> BCH address is : 0x80ffe000
[0001.323] I> PSC_FW header integrity check is success
[0001.328] I> Binary magic in BCH component 0 is PFWP
[0001.333] I> component binary type is 17
[0001.337] I> Size of crypto header is 8192
[0001.341] I> strt_pg_num(21264) num_of_pgs(591) read_buf(0x80fb4200)
[0001.350] I> PSC_FW binary is read from storage
[0001.355] I> PSC_FW binary integrity check is success
[0001.360] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.366] I> Task: Load nvdec-fw
[0001.369] I> Slot: 0
[0001.372] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.377] I> Binary name: NVDEC
[0001.380] I> Size of crypto header is 8192
[0001.384] I> Size of crypto header is 8192
[0001.388] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.394] I> BCH of NVDEC read from storage
[0001.398] I> BCH address is : 0x800fe000
[0001.402] I> NVDEC header integrity check is success
[0001.407] I> Binary magic in BCH component 0 is NDEC
[0001.411] I> component binary type is 7
[0001.415] I> Size of crypto header is 8192
[0001.419] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.428] I> NVDEC binary is read from storage
[0001.433] I> NVDEC binary integrity check is success
[0001.438] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.444] I> Size of crypto header is 8192
[0001.456] I> Task: Load tsec-fw
[0001.459] I> TSEC-FW load support not enabled
[0001.463] I> Task: GPIO interrupt map
[0001.467] I> Task: SC7 context save
[0001.470] I> Slot: 0
[0001.472] I> Binary[27] block-0 (partition size: 0x100000)
[0001.477] I> Binary name: BR_BCT
[0001.480] I> Size of crypto header is 8192
[0001.484] I> Size of crypto header is 8192
[0001.488] I> Size of crypto header is 8192
[0001.492] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.498] I> BR_BCT binary is read from storage
[0001.503] I> BR_BCT binary integrity check is success
[0001.508] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.514] I> Slot: 0
[0001.516] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.521] I> Binary name: SC7-FW
[0001.525] I> Size of crypto header is 8192
[0001.528] I> Size of crypto header is 8192
[0001.532] I> Size of crypto header is 8192
[0001.536] I> Size of crypto header is 8192
[0001.540] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.547] I> BCH of SC7-FW read from storage
[0001.551] I> BCH address is : 0xa0002000
[0001.554] I> SC7-FW header integrity check is success
[0001.559] I> Binary magic in BCH component 0 is WB0B
[0001.564] I> component binary type is 13
[0001.568] I> Size of crypto header is 8192
[0001.572] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[0001.580] I> SC7-FW binary is read from storage
[0001.585] I> SC7-FW binary integrity check is success
[0001.590] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[0001.596] I> Slot: 0
[0001.598] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.604] I> Binary name: PSC_RF
[0001.607] I> Size of crypto header is 8192
[0001.611] I> Size of crypto header is 8192
[0001.615] I> Size of crypto header is 8192
[0001.619] I> Size of crypto header is 8192
[0001.622] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002fa00)
[0001.629] I> BCH of PSC_RF read from storage
[0001.633] I> BCH address is : 0xa002fa00
[0001.637] I> PSC_RF header integrity check is success
[0001.642] I> Binary magic in BCH component 0 is PSCR
[0001.646] I> component binary type is 22
[0001.650] I> Size of crypto header is 8192
[0001.654] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031a00)
[0001.662] I> PSC_RF binary is read from storage
[0001.666] I> PSC_RF binary integrity check is success
[0001.671] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x1be60)
[0001.680] I> Task: Save WP0 payload to SC7 ctx
[0001.685] I> Task: Load MB2rf binary to SC7 ctx
[0001.689] I> Slot: 0
[0001.691] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.697] I> Binary name: MB2_RF
[0001.700] I> Size of crypto header is 8192
[0001.704] I> Size of crypto header is 8192
[0001.708] I> Size of crypto header is 8192
[0001.712] I> Size of crypto header is 8192
[0001.716] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.722] I> BCH of MB2_RF read from storage
[0001.726] I> BCH address is : 0xa00d5d10
[0001.730] I> MB2_RF header integrity check is success
[0001.735] I> Binary magic in BCH component 0 is MB2R
[0001.739] I> component binary type is 14
[0001.743] I> Size of crypto header is 8192
[0001.747] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.755] I> MB2_RF binary is read from storage
[0001.759] I> MB2_RF binary integrity check is success
[0001.764] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf60)
[0001.771] I> Task: Save fuse alias data to SC7 ctx
[0001.775] I> Task: Save PMIC data to SC7 ctx
[0001.779] I> Task: Save Pinmux data to SC7 ctx
[0001.784] I> Task: Save Pad Voltage data to SC7 ctx
[0001.788] I> Task: Save controller prod data to SC7 ctx
[0001.793] I> Task: Save prod cfg data to SC7 ctx
[0001.798] I> Task: Save I2C bus freq data to SC7 ctx
[0001.803] I> Task: Save SOCTherm data to SC7 ctx
[0001.807] I> Task: Save FMON data to SC7 ctx
[0001.811] I> Task: Save VMON data to SC7 ctx
[0001.815] I> Task: Save TZDRAM data to SC7 ctx
[0001.820] I> Task: Save GPIO int data to SC7 ctx
[0001.824] I> Task: Save clock data to SC7 ctx
[0001.828] I> Task: Save debug data to SC7 ctx
[0001.832] I> Task: Save MBWT data to SC7 ctx
[0001.840] I> SC7 context save done
[0001.844] I> Task: Load MB2/Applet/FSKP
[0001.847] I> Loading MB2
[0001.850] I> Slot: 0
[0001.852] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.857] I> Binary name: MB2
[0001.860] I> Size of crypto header is 8192
[0001.864] I> Size of crypto header is 8192
[0001.868] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.874] I> BCH of MB2 read from storage
[0001.878] I> BCH address is : 0x8007e000
[0001.882] I> MB2 header integrity check is success
[0001.886] I> Binary magic in BCH component 0 is MB2B
[0001.891] I> component binary type is 6
[0001.895] I> Size of crypto header is 8192
[0001.899] I> strt_pg_num(8464) num_of_pgs(846) read_buf(0x80000000)
[0001.910] I> MB2 binary is read from storage
[0001.915] I> MB2 binary integrity check is success
[0001.919] I> Binary MB2 loaded successfully at 0x80000000 (0x69a70)
[0001.926] I> Task: Map CCPLEX SHARED carveout
[0001.930] I> Task: Prepare MB2 params
[0001.934] I> Task: Dram ecc test
[0001.937] I> Task: Misc NV security settings
[0001.941] I> NVDEC sticky bits programming done
[0001.945] I> Successfully powergated NVDEC
[0001.949] I> Task: Disable/Reload WDT
[0001.953] I> Task: Program misc carveouts
[0001.957] I> Program IPC carveouts
[0001.960] I> Task: Disable SCPM/POD reset
[0001.964] I> SLCG Global override status := 0x0
[0001.968] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-22833a33)
I> Emulation:
I> Entry timestamp: 0x001e7d5e
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x102e000000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: TZDRAM heap init
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Secondary storage device: QSPI_FLASH instance: 0
I> Secondary storage device: SDMMC_USER instance: 3
I> sdmmc HS400 mode enabled
I> Task: Partition Manager Init
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x102e001000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x102e001000)
I> strt_pg_num(131039) num_of_pgs(32) read_buf(0x102e001200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
W> PARTITION_MANAGER: Failed to publish partition.
I> Found 15 partitions in SDMMC_USER (instance 3)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> strt_pg_num(55040) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(55056) num_of_pgs(512) read_buf(0x102d600000)
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> strt_pg_num(56192) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(56208) num_of_pgs(880) read_buf(0x102d200000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x102d600000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> strt_pg_num(44800) num_of_pgs(16) read_buf(0x40067a30)
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x102d200000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(44816) num_of_pgs(1) read_buf(0x102e1403d8)
I> strt_pg_num(44816) num_of_pgs(8) read_buf(0x102e1403d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(44824) num_of_pgs(512) read_buf(0x102e0003c0)
I> strt_pg_num(45336) num_of_pgs(512) read_buf(0x102e0403c0)
I> dce : will be decompressed at 0x1036000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(45848) num_of_pgs(512) read_buf(0x102e0803c0)
I> dce : decompressed to 12066512 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> strt_pg_num(58240) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(58256) num_of_pgs(800) read_buf(0x1038800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x1036000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> strt_pg_num(9472) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(9488) num_of_pgs(312) read_buf(0x102d700000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x1038800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: A_pva-fw
I> Binary@ device:3/0 block-62336 (partition size: 0x40000), name: A_pva-fw
I> strt_pg_num(62336) num_of_pgs(16) read_buf(0x40067a30)
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x102d700000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(62352) num_of_pgs(1) read_buf(0x102e1403d8)
I> strt_pg_num(62352) num_of_pgs(8) read_buf(0x102e1403d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(62360) num_of_pgs(512) read_buf(0x102e0003c0)
I> pva-fw : will be decompressed at 0x102d980000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x102d980000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Enable FSI-SE clock…
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x1032000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
I> Task: Revoke PKC fuse
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE…
I> Enabling combined UART
����spe: early_init
����vic initialized
����tsc initialized
����aon lic initialized
����spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
����spe: SafeRTOS v8.4
����spe: init
����scheduler initialized
����aon hsp initialized
����tag initialized
����tcu initialized
����bpmp ipc initialized
����spe: late init
����cpu_nic clock initialized
����apb clock initialized
����pm initialized
����bpmp hsp initialized
����top1 hsp initialized
����ccplex ipc initialized
����spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Start secure NOR provision
I> Skip Secure NOR provisioning
I> Task: Trigger load FSI keyblob
I> Skipping FSI key blob copy
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d t��
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is da583751bbfe2b7f6e204562d97ff39e
bpmp: combined binary md5 is 39f77b2baaf3f0522607569dd3ae9a48
bpmp: firmware tag is 39f77b2baaf3f0522607-da583751bbf
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
��o psc
I> Task: Unhalt FSI
I> FSI unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load HV/CPUBL
I> Task: Load TOS
I> Task: Trigger load TS��[ 2.578163] Camera-FW on t234-rce-safe started
��initialized avfs_clk_platform
initialized powergate
��TCU early console enabled.
��EC ley��initialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
��blob
I> Sending opcode 0x53535452 to psc
��I> Sent opcode to psc
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
��DCE Started
��I> strt_pg_num(24832) num_of_pgs(16) read_buf(0x40067a30)
I> cpubl : oem authentication of header done
I> strt_pg_num(24848) num_of_pgs(1) read_buf(0x102e143f98)
I> strt_pg_num(24848) num_of_pgs(8) read_buf(0x102e143f98)
��DCE_R5_Init
��I> cpubl : meta-blob integrity check is success.
I> strt_pg_num(��initialized emc
initialized emc_mrq
��24856) num_of_pgs(512) read_buf(0x102e003f80)
��MPU��initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
�� en��initialized uphy
��abled
DCE_SW_Init
��I> ��initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
��strt_pg_num(25368) num_of_pgs(512) read_buf(0x102e043f80)
I> cpubl : will��initialized clk_cal_late
initialized noc_late
initialized cvc
�� be decompressed at 0x102c800000
I> versio��initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable sdmmc4_axicif
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initializ��[ 2.780077] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.433 ms,��ed extras_post
bpmp: init compl�� total boot 215.420 ms)
��ete
��n 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> strt_pg_num(25880) num_of_pgs(512) read_buf(0x102e083f80)
I> strt_pg_num(26392) num_of_pgs(512) read_buf(0x102e0c3f80)
I> strt_pg_num(26904) num_of_pgs(512) read_buf(0x102e103f80)
I> strt_pg_num(27416) num_of_pgs(512) read_buf(0x102e003f80)
I> strt_pg_num(27928) num_of_pgs(512) read_buf(0x102e043f80)
I> strt_pg_num(28440) num_of_pgs(512) read_buf(0x102e083f80)
I> strt_pg_num(28952) num_of_pgs(512) read_buf(0x102e0c3f80)
I> strt_pg_num(29464) num_of_pgs(512) read_buf(0x102e103f80)
I> strt_pg_num(29976) num_of_pgs(512) read_buf(0x102e003f80)
��Admin Task Init
Admin Task Init complete
Print Task I��I> strt_pg_num(30488) num_of_pgs(512) read_buf(0x102e043f80)
��nit
RM Task Init
SHA Task Init
Admin Task Started
DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
SHA Task Started
DCE: FW Boot Complete
Admin Task Running
SHA Task Running
��I> strt_pg_num(31000) num_of_pgs(512) read_buf(0x102e083f80)
I> cpubl : decompressed to 3653760 bytes
I> cpubl: plain binary integrity check is success
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> strt_pg_num(32000) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(32016) num_of_pgs(3672) read_buf(0x103fd35000)
I> NSDRAM carveout base: 0x80000000, size: 0xfacdf0000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x102c800000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x103fd35000
I> Relocating OP-TEE dtb from: 0x103feff180 to 0x103c040020, size: 0x2754
I> [0] START: 0x80000000, SIZE: 0xfacdf0000
I> [1] START: 0x1032000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> strt_pg_num(44288) num_of_pgs(16) read_buf(0x40067a30)
I> strt_pg_num(44304) num_of_pgs(8) read_buf(0x103c020000)
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x103c020000
I> EKB detected (length: 0x410) @ VA:0x103c020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x103c040020
I> OEM sc7 context saved
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
I> Task: Storage device deinit
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Bootchain failure check
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
��NOTICE: BL31: v2.8(release):e12e3fa93
NOTICE: BL31: Built : 21:01:44, Sep 12 2024
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Sep 13 04:10:17 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: fTPM ID is not enabled.
I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is not supported.
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 36.4.0-gcid-37537400 built on 2024-09-13T04:02:39+00:00)
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
I/TC: WARNING: Test UEFI variable auth key is being used !
I/TC: WARNING: UEFI variable protection is not fully enabled !
��I/TC: WARNING: Test UEFI variable auth key is being used !
Jetson System firmware version 36.4.0-gcid-37537400 date 2024-09-13T04:02:39+00:
00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
��debugfs initialized
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.148-rt-tegra (root@root1) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU )
[ 0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x1027f3f198 TPMFinalLog=0x1018b00000 SMBIOS=0xffff0000 SMBIOS 3.0=0x1027930000 MEMATTR=0x1021a43018 ESRT=0x1021a4
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x0000001021a44f98 to 0x0000001021a44fd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000ff5000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x1022d177c0-0x1022d19fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000101899ffff]
[ 0.000000] node 0: [mem 0x00000010189a0000-0x0000001018b0ffff]
[ 0.000000] node 0: [mem 0x0000001018b10000-0x0000001018b1afff]
[ 0.000000] node 0: [mem 0x0000001018b1b000-0x0000001018b1bfff]
[ 0.000000] node 0: [mem 0x0000001018b1c000-0x0000001025ffffff]
[ 0.000000] node 0: [mem 0x0000001026000000-0x0000001027f3ffff]
[ 0.000000] node 0: [mem 0x0000001027f40000-0x000000102c5fffff]
[ 0.000000] node 0: [mem 0x000000102c600000-0x000000102c7fffff]
[ 0.000000] node 0: [mem 0x000000102c800000-0x000000102cd6ffff]
[ 0.000000] node 0: [mem 0x000000102d700000-0x000000102d7fffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] On node 0, zone Normal: 2448 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 18432 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 28 pages/cpu s77744 r8192 d28752 u114688
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
��[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
��[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16187760
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
��[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,
[ 0.000000] Unknown kernel command line parameters "mminit_loglevel=4 fbcon=map:0 bl_prof_dataptr=2031616@0x102C610000 bl_prof_ro_ptr=6553e
�� passed to user space.
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla1_core
��[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 63803188K/65780160K available (18944K kernel code, 4044K rwdata, 9864K rodata, 7488K init, 551K bss, 1452684K reserved)
[ ��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla1_falcon
�� 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_c��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_n
��pu_ids=12.
[ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_core
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.00000��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_core
��0] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_falcon
��[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter:��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_falcon
�� mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000409] Console: colour dummy device 80x25
[ 0.000418] printk: console [tty0] enabled
[ 0.000484] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000492] pid_max: default: 32768 minimum: 301
[ 0.000541] LSM: Security Framework initializing
[ 0.000563] Yama: becoming mindful.
[ 0.000579] SELinux: Initializing.
[ 0.000873] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001086] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.002882] rcu: Hierarchical SRCU implementation.
[ 0.005882] Tegra Revision: A01 SKU: 208 CPU Process: 0 SoC Process: 0
[ 0.006200] Remapping and enabling EFI services.
[ 0.007132] smp: Bringing up secondary CPUs …
[ 0.007692] Detected PIPT I-cache on CPU1
[ 0.007740] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.007781] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.008296] Detected PIPT I-cache on CPU2
[ 0.008308] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.008320] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.008834] Detected PIPT I-cache on CPU3
[ 0.008843] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.008856] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.011365] Detected PIPT I-cache on CPU4
[ 0.011391] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.011418] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.011943] Detected PIPT I-cache on CPU5
[ 0.011954] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.011968] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.012445] Detected PIPT I-cache on CPU6
[ 0.012456] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.012470] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.012966] Detected PIPT I-cache on CPU7
[ 0.012977] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.012990] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.015513] Detected PIPT I-cache on CPU8
[ 0.015540] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.015566] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.016084] Detected PIPT I-cache on CPU9
[ 0.016095] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.016109] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.016596] Detected PIPT I-cache on CPU10
[ 0.016608] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.016622] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.017102] Detected PIPT I-cache on CPU11
[ 0.017113] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.017127] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.017184] smp: Brought up 1 node, 12 CPUs
[ 0.017189] SMP: Total of 12 processors activated.
[ 0.017192] CPU features: detected: 32-bit EL0 Support
[ 0.017194] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.017196] CPU features: detected: Common not Private translations
[ 0.017197] CPU features: detected: CRC32 instructions
[ 0.017198] CPU features: detected: Data cache clean to Point of Persistence
[ 0.017200] CPU features: detected: Generic authentication (architected algorithm)
[ 0.017201] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.017201] CPU features: detected: LSE atomic instructions
[ 0.017202] CPU features: detected: Privileged Access Never
[ 0.017204] CPU features: detected: RAS Extension Support
[ 0.017205] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.031031] spectre-bhb mitigation disabled by command line option
[ 0.043856] CPU: All CPU(s) started at EL2
[ 0.047263] devtmpfs: initialized
[ 0.071910] KASLR enabled
[ 0.072167] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.072196] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.081907] pinctrl core: initialized pinctrl subsystem
[ 0.083110] SMBIOS 3.6.0 present.
[ 0.083121] DMI: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.4.0-gcid-37537400 09/13/2024
[ 0.083796] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.086597] DMA: preallocated 8192 KiB GFP_KERNEL pool for atomic allocations
[ 0.087279] DMA: preallocated 8192 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.087951] DMA: preallocated 8192 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.088055] audit: initializing netlink subsys (disabled)
[ 0.088233] audit: type=2000 audit(0.084:1): state=initialized audit_enabled=0 res=1
[ 0.090336] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.090340] thermal_sys: Registered thermal governor ‘user_space’
[ 0.090342] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.095906] cpuidle: using governor menu
[ 0.096279] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.096459] ASID allocator initialised with 32768 entries
[ 0.098807] Serial: AMBA PL011 UART driver
[ 0.111426] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 118, base_baud = 0) is a SBSA
[ 0.111471] printk: console [ttyAMA0] enabled
[ 0.126610] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.138301] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.138311] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.138312] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.138313] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.139547] cryptd: max_cpu_qlen set to 1000
[ 0.142205] ACPI: Interpreter disabled.
[ 0.144680] iommu: Default domain type: Translated
[ 0.144686] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.145120] SCSI subsystem initialized
[ 0.145338] vgaarb: loaded
[ 0.145545] usbcore: registered new interface driver usbfs
[ 0.145577] usbcore: registered new interface driver hub
[ 0.145596] usbcore: hub_wq
[ 0.145604] usbcore: registered new device driver usb
[ 0.146061] pps_core: LinuxPPS API ver. 1 registered
[ 0.146064] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.146077] PTP clock support registered
[ 0.146155] EDAC MC: Ver: 3.0.0
[ 0.147774] Registered efivars operations
[ 0.148537] FPGA manager framework
[ 0.148634] Advanced Linux Sound Architecture Driver Initialized.
[ 0.149456] Bluetooth: Core ver 2.22
[ 0.149493] NET: Registered PF_BLUETOOTH protocol family
[ 0.149498] Bluetooth: HCI device and connection manager initialized
[ 0.149510] Bluetooth: HCI socket layer initialized
[ 0.149516] Bluetooth: L2CAP socket layer initialized
[ 0.149574] Bluetooth: SCO socket layer initialized
[ 0.150095] clocksource: Switched to clocksource arch_sys_counter
[ 0.195365] VFS: Disk quotas dquot_6.6.0
[ 0.195454] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.195763] pnp: PnP ACPI: disabled
[ 0.200037] NET: Registered PF_INET protocol family
[ 0.201126] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.204011] tcp_listen_portaddr_hash hash table entries: 32768 (order: 8, 1310720 bytes, linear)
[ 0.205825] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.205878] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.206379] TCP bind hash table entries: 65536 (order: 9, 2621440 bytes, linear)
[ 0.209963] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.210372] UDP hash table entries: 32768 (order: 9, 3145728 bytes, linear)
[ 0.214740] UDP-Lite hash table entries: 32768 (order: 9, 3145728 bytes, linear)
[ 0.219394] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.220024] RPC: Registered named UNIX socket transport module.
[ 0.220029] RPC: Registered udp transport module.
[ 0.220029] RPC: Registered tcp transport module.
[ 0.220031] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.220053] PCI: CLS 0 bytes, default 64
[ 0.220349] Unpacking initramfs…
[ 0.234161] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.238394] Initialise system trusted keyrings
[ 0.238452] Key type blacklist registered
[ 0.238567] workingset: timestamp_bits=42 max_order=24 bucket_order=0
[ 0.244415] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.244995] NFS: Registering the id_resolver key type
[ 0.245033] Key type id_resolver registered
[ 0.245036] Key type id_legacy registered
[ 0.245121] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.245147] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.245171] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.245491] 9p: Installing v9fs 9p2000 file system support
[ 0.246352] integrity: Platform Keyring initialized
[ 0.257557] Key type asymmetric registered
[ 0.257562] Asymmetric key parser ‘x509’ registered
[ 0.257637] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.257647] io scheduler mq-deadline registered
[ 0.257653] io scheduler kyber registered
[ 0.273892] EINJ: ACPI disabled.
[ 0.287591] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.289597] SuperH (H)SCI(F) driver initialized
[ 0.289997] msm_serial: driver initialized
[ 0.290689] printk: console [ttyTCU0] enabled
[ 0.291735] arm-smmu 8000000.iommu: probing hardware configuration…
[ 0.291740] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.291749] arm-smmu 8000000.iommu: stage 1 translation
[ 0.291751] arm-smmu 8000000.iommu: stage 2 translation
[ 0.291753] arm-smmu 8000000.iommu: nested translation
[ 0.291758] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.291762] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.291774] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.291775] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.291776] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.292976] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.292980] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.292984] arm-smmu 10000000.iommu: stage 1 translation
[ 0.292986] arm-smmu 10000000.iommu: stage 2 translation
[ 0.292987] arm-smmu 10000000.iommu: nested translation
[ 0.293001] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.293004] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.293023] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.293024] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.293025] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.293485] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.293490] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.293491] arm-smmu 12000000.iommu: stage 1 translation
[ 0.293493] arm-smmu 12000000.iommu: stage 2 translation
[ 0.293495] arm-smmu 12000000.iommu: nested translation
[ 0.293499] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.293501] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.293513] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.293514] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.293515] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.310679] loop: module loaded
[ 0.312176] megasas: 07.717.02.00-rc1
[ 0.316999] tun: Universal TUN/TAP device driver, 1.6
[ 0.317623] thunder_xcv, ver 1.0
[ 0.317658] thunder_bgx, ver 1.0
[ 0.317693] nicpf, ver 1.0
[ 0.318713] hclge is initializing
[ 0.318745] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.318753] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.318807] e1000: Intel(R) PRO/1000 Network Driver
[ 0.318811] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.318842] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.318847] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.318875] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.318880] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.318895] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.318899] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.319136] sky2: driver version 1.30
[ 0.319919] VFIO - User Level meta-driver version: 0.3
[ 0.321603] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.321613] ehci-pci: EHCI PCI platform driver
[ 0.321642] ehci-platform: EHCI generic platform driver
[ 0.321735] ehci-orion: EHCI orion driver
[ 0.321827] ehci-exynos: EHCI Exynos driver
[ 0.321886] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.321970] ohci-pci: OHCI PCI platform driver
[ 0.322000] ohci-platform: OHCI generic platform driver
[ 0.322144] ohci-exynos: OHCI Exynos driver
[ 0.322628] usbcore: registered new interface driver usb-storage
[ 0.324577] i2c_dev: i2c /dev entries driver
[ 0.326006] pps pps0: new PPS source ktimer
[ 0.326015] pps pps0: ktimer PPS source registered
[ 0.326029] pps_ldisc: PPS line discipline registered
[ 0.328396] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.330769] sdhci: Secure Digital Host Controller Interface driver
[ 0.330774] sdhci: Copyright(c) Pierre Ossman
[ 0.331297] Synopsys Designware Multimedia Card Interface Driver
[ 0.332013] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.334164] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.334686] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.337653] tegra-bpmp bpmp: firmware: 39f77b2baaf3f0522607-da583751bbf
[ 0.480296] Freeing initrd memory: 15488K
[ 3.525911] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 3.525936] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 3.525940] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 3.526327] hid: raw HID events driver (C) Jiri Kosina
[ 3.526603] usbcore: registered new interface driver usbhid
[ 3.526606] usbhid: USB HID core driver
[ 3.531919] optee: probing for conduit method.
[ 3.531968] optee: revision 4.2 (d78bc5fa)
[ 3.592350] optee: dynamic shared memory is enabled
[ 3.592612] optee: initialized driver
[ 3.599570] usbcore: registered new interface driver snd-usb-audio
[ 3.601791] NET: Registered PF_PACKET protocol family
[ 3.602867] Bluetooth: RFCOMM TTY layer initialized
[ 3.602918] Bluetooth: RFCOMM socket layer initialized
[ 3.602948] Bluetooth: RFCOMM ver 1.11
[ 3.603294] 9pnet: Installing 9P2000 support
[ 3.603431] Key type dns_resolver registered
[ 3.604955] printk: console [tty0]: printing thread started
[ 3.605810] printk: console [ttyTCU0]: printing thread started
[ 3.606669] printk: console [ttyAMA0]: printing thread started
[ 3.606846] Loading compiled-in X.509 certificates
[ 3.611286] Loaded X.509 cert ‘Build time autogenerated kernel key: 30150819326974e6bfb7bb02b6d35d55ecfd3a14’
[ 3.708986] gpio-394 (camera-control-output-low): hogged as output/low
[ 3.709014] gpio-397 (camera-control-output-low): hogged as output/low
[ 3.709038] gpio-487 (camera-control-output-low): hogged as output/low
[ 3.709056] gpio-486 (camera-control-output-low): hogged as output/low
[ 3.749520] simple-framebuffer chosen:framebuffer: framebuffer at 0x1039e00000, 0x870000 bytes
[ 3.749529] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=1920x1080x32, linelength=8192
[ 3.751940] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[ 3.752843] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 3.756718] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 3.758037] serial-tegra 3100000.serial: RX in PIO mode
[ 3.758045] serial-tegra 3100000.serial: TX in PIO mode
[ 3.758145] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 3.759799] serial-tegra 3110000.serial: RX in PIO mode
[ 3.759804] serial-tegra 3110000.serial: TX in PIO mode
[ 3.759917] 3110000.serial: ttyTHS2 at MMIO 0x3110000 (irq = 206, base_baud = 0) is a TEGRA_UART
[ 3.763340] tegra_rtc c2a0000.rtc: registered as rtc1
[ 3.763352] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.763799] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 3.768526] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 3.771773] tegra-i2c 3190000.i2c: Adding to iommu group 1
[ 3.775185] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 3.780936] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[ 3.789964] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[ 3.798801] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 3.807772] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 3.845897] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[ 3.849627] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 3.852334] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[ 3.856494] tegra-xusb 3610000.usb: Adding to iommu group 3
[ 3.864115] mmc0: CQHCI version 5.10
[ 3.872804] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 3.872810] tegra-xusb 3610000.usb: xHCI Host Controller
[ 3.872821] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 3.873561] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[ 3.873809] tegra-xusb 3610000.usb: irq 127, io mem 0x03610000
[ 3.873953] tegra-xusb 3610000.usb: xHCI Host Controller
[ 3.873956] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 3.873959] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.874643] hub 1-0:1.0: USB hub found
[ 3.874667] hub 1-0:1.0: 4 ports detected
[ 3.876130] hub 2-0:1.0: USB hub found
[ 3.876144] hub 2-0:1.0: 4 ports detected
[ 3.878247] sdhci-tegra 3400000.mmc: Adding to iommu group 4
[ 3.878549] irq: IRQ240: trimming hierarchy from :bus@0:pmc@c360000
[ 3.878714] irq: IRQ241: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 3.879063] irq: IRQ242: trimming hierarchy from :bus@0:pmc@c360000
[ 3.879427] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.210086] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.278806] ALSA device list:
[ 4.278810] No soundcards found.
[ 4.281801] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 4.293566] mmc0: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[ 4.328645] irq: IRQ243: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 4.329235] mmc1: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 4.330872] Freeing unused kernel memory: 7488K
[ 4.331050] Run /init as init process
[ 4.344473] Checking overlayfs setting…
[ 4.356553] Overlayfs is disabled…
[ 4.363073] Root device found: mmcblk0p1
[ 4.375000] hub 1-2:1.0: USB hub found
[ 4.375461] hub 1-2:1.0: 7 ports detected
[ 4.400138] mmc0: Command Queue Engine enabled
[ 4.400146] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.400600] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 4.404348] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 4.407718] mmcblk0boot0: mmc0:0001 G1M15M 31.5 MiB
[ 4.408305] mmcblk0boot1: mmc0:0001 G1M15M 31.5 MiB
[ 4.408851] mmcblk0rpmb: mmc0:0001 G1M15M 4.00 MiB, chardev (511:0)
[ 4.498489] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[ 4.519893] Found dev node: /dev/mmcblk0p1
[ 4.528486] hub 2-1:1.0: USB hub found
[ 4.529714] hub 2-1:1.0: 5 ports detected
[ 4.654085] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 4.819001] hub 1-3:1.0: USB hub found
[ 4.819542] hub 1-3:1.0: 7 ports detected
[ 4.942489] usb 2-3: new SuperSpeed Plus Gen 2x1 USB device number 3 using tegra-xusb
[ 4.942948] EXT4-fs (mmcblk0p1): recovery complete
[ 4.943636] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 4.948644] Rootfs mounted over mmcblk0p1
[ 4.957607] Switching from initrd to actual rootfs
[ 4.972504] hub 2-3:1.0: USB hub found
[ 4.973713] hub 2-3:1.0: 5 ports detected
[ 5.042088] usb 1-2.7: new high-speed USB device number 4 using tegra-xusb
[ 5.088057] systemd[1]: System time before build time, advancing clock.
[ 5.153743] NET: Registered PF_INET6 protocol family
[ 5.154807] Segment Routing with IPv6
[ 5.154817] In-situ OAM (IOAM) with IPv6
[ 5.190519] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GN)
[ 5.190926] systemd[1]: Detected architecture arm64.
[ 5.238088] usb 1-3.7: new high-speed USB device number 5 using tegra-xusb
[ 5.294250] systemd[1]: Hostname set to <localhost.localdomain>.
[ 5.330244] systemd[1]: Using hardware watchdog ‘NVIDIA Tegra186 WDT’, version 0, device /dev/watchdog
[ 5.330261] systemd[1]: Set hardware watchdog to 2min.
[ 5.578594] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to jou.
[ 5.586160] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to .
[ 5.642583] systemd[1]: Queued start job for default target OEM Configuration.
[ 5.644354] systemd[1]: Created slice Slice /system/modprobe.
[ 5.684071] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 5.734487] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.799197] systemd[1]: Reached target Slice Units.
[ 5.855678] systemd[1]: Reached target Swaps.
[ 5.906018] systemd[1]: Reached target Local Verity Protected Volumes.
[ 5.979482] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 6.028206] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.078645] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.128149] systemd[1]: Listening on Journal Audit Socket.
[ 6.168485] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.214658] systemd[1]: Listening on Journal Socket.
[ 6.260753] systemd[1]: Listening on udev Control Socket.
[ 6.331456] systemd[1]: Listening on udev Kernel Socket.
[ 6.418198] systemd[1]: Mounting Huge Pages File System…
[ 6.474184] systemd[1]: Mounting POSIX Message Queue File System…
[ 6.516722] systemd[1]: Mounting Kernel Debug File System…
[ 6.517987] systemd[1]: Mounting Kernel Trace File System…
[ 6.521969] systemd[1]: Starting Journal Service…
[ 6.539116] systemd[1]: Starting Set the console keyboard layout…
[ 6.540434] systemd[1]: Starting Create List of Static Device Nodes…
[ 6.541890] systemd[1]: Starting Load Kernel Module configfs…
[ 6.543335] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 6.571359] systemd[1]: Starting Load Kernel Module fuse…
[ 6.572883] systemd[1]: Starting NVIDIA specific first-boot udev script…
[ 6.574583] systemd[1]: Started Nameserver information manager.
[ 6.589701] fuse: init (API version 7.34)
[ 6.598559] systemd[1]: Reached target Preparation for Network.
[ 6.598706] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 6.601122] systemd[1]: Starting Load Kernel Modules…
[ 6.602566] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 6.610839] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null). Quota mode: none.
[ 6.610874] nvsciipc: loading out-of-tree module taints kernel.
[ 6.610933] nvsciipc: module verification failed: signature and/or required key missing - tainting kernel
[ 6.612214] nvsciipc: loaded module
[ 6.633599] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 6.634297] nvmap_co_device_init: vpr :dma coherent mem declare 0x0000001049800000,914358272
[ 6.634304] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 6.634316] nvmap_page_pool_init: Total RAM pages: 16087613
[ 6.634317] nvmap_page_pool_init: nvmap page pool size: 2010951 pages (3759 MB)
[ 6.634388] nvmap_background_zero_thread: PP zeroing thread starting.
[ 6.634414] nvmap_heap_create: created heap vpr base 0x0000001049800000 size (892928KiB)
[ 6.634448] nvmap_heap_create: fsi :dma coherent mem declare 0x000000102f000000,16777216
[ 6.634450] nvmap_heap_create: created heap fsi base 0x000000102f000000 size (16384KiB)
[ 6.646150] systemd[1]: Starting Coldplug All udev Devices…
[ 6.660731] tegra-host1x 13e00000.host1x: Adding to iommu group 5
[ 6.663062] host1x-context host1x-ctx.0: Adding to iommu group 6
[ 6.663597] host1x-context host1x-ctx.1: Adding to iommu group 7
[ 6.664078] host1x-context host1x-ctx.2: Adding to iommu group 8
[ 6.664508] host1x-context host1x-ctx.3: Adding to iommu group 9
[ 6.664954] host1x-context host1x-ctx.4: Adding to iommu group 10
[ 6.665452] host1x-context host1x-ctx.5: Adding to iommu group 11
[ 6.665839] host1x-context host1x-ctx.6: Adding to iommu group 12
[ 6.666399] host1x-context host1x-ctx.7: Adding to iommu group 13
[ 6.666951] host1x-context host1x-ctx.8: Adding to iommu group 14
[ 6.667338] host1x-context host1x-ctx.9: Adding to iommu group 15
[ 6.667704] host1x-context host1x-ctx.10: Adding to iommu group 16
[ 6.668104] host1x-context host1x-ctx.11: Adding to iommu group 17
[ 6.668567] host1x-context host1x-ctx.12: Adding to iommu group 18
[ 6.668909] host1x-context host1x-ctx.13: Adding to iommu group 19
[ 6.669324] host1x-context host1x-ctx.14: Adding to iommu group 20
[ 6.669922] host1x-context host1x-ctx.15: Adding to iommu group 21
[ 6.723743] systemd[1]: Started Journal Service.
[ 6.867926] systemd-journald[368]: Received client request to flush runtime journal.
[ 6.915941] nvgpu: 17000000.gpu nvgpu_nvhost_syncpt_init:122 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 1000
[ 6.915941]
��TCU debug prints will be routed to traces.
��[ 7.255763] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[ 7.255765] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[ 7.255766] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[ 7.255767] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[ 7.255768] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[ 7.255769] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[ 7.255782] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 7.365399] (NULL device *): fops function table already registered
��Starting RmBootstrap
Registered event_type:[0] for dce_core_ipc_type:[1]
Registered event_type:[1] for dce_core_ipc_type:[3]
dce_ipc State Initialized
RmBootstrap completed successfully
��[ 10.400386] using random self ethernet address
[ 10.400393] using random host ethernet address
[ 10.641009] using random self ethernet address
[ 10.641016] using random host ethernet address
[ 11.317824] mdio_bus 6800000.ethernet: MDIO device at address 0 is missing.
[ 11.317847] nvethernet 6800000.ethernet: failed to connect PHY
[ 11.317851] net eno1: ether_open: Cannot attach to PHY (error: -19)
[ 12.149733] rt5640 8-001c: Device with ID register 0xffff0000 is not rt5640/39
[ 22.099579] nvidia-modeset: ERROR: GPU:0: The requested configuration of display devices (HP Inc. HP P24v G4 (HDMI-1), HP Inc. HP P24v G4 .
[ 22.101202] nvidia-modeset: ERROR: GPU:0: The requested configuration of display devices (HP Inc. HP P24v G4 (HDMI-1), HP Inc. HP P24v G4 .
[ 23.483885] Please complete system configuration setup on the serial port provided by Jetson’s USB device mode connection. e.g. /dev/ttyAC.
