Device can not boot up:ASSERT [FvbNorFlashStandaloneMm] FvbNorFlashStandaloneMm.c(978): ((BOOLEAN)(0==1))
英伟达团队,你们好。
我们在使用orin nx 16GB核心板,搭配自制的载板,并使用jetpack5.1.5刷机。此前都可以正常运行,在昨天上电启动过程中,出现启动不了的现象,接口串口读取日志如下 :
[Tue Aug 19 10:44:09.848 2025] [0000.065] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[Tue Aug 19 10:44:09.848 2025] [0000.070] I> t234-A01-1-Silicon (0x12347) Prod
[Tue Aug 19 10:44:09.848 2025] [0000.074] I> Boot-mode : Coldboot
[Tue Aug 19 10:44:09.848 2025] [0000.078] I> Entry timestamp: 0x00000000
[Tue Aug 19 10:44:09.848 2025] [0000.081] I> last_boot_error: 0x0
[Tue Aug 19 10:44:09.848 2025] [0000.084] I> BR-BCT: preprod_dev_sign: 0
[Tue Aug 19 10:44:09.848 2025] [0000.088] I> rst_source: 0x0, rst_level: 0x0
[Tue Aug 19 10:44:09.848 2025] [0000.092] I> Task: SE error check
[Tue Aug 19 10:44:09.848 2025] [0000.095] I> Task: Bootchain select WAR set
[Tue Aug 19 10:44:09.848 2025] [0000.099] I> Task: Enable SLCG
[Tue Aug 19 10:44:09.848 2025] [0000.102] I> Task: CRC check
[Tue Aug 19 10:44:09.848 2025] [0000.105] I> Task: Initialize MB2 params
[Tue Aug 19 10:44:09.848 2025] [0000.109] I> MB2-params @ 0x40060000
[Tue Aug 19 10:44:09.848 2025] [0000.113] I> Task: Crypto init
[Tue Aug 19 10:44:09.848 2025] [0000.116] I> Task: Perform MB1 KAT tests
[Tue Aug 19 10:44:09.848 2025] [0000.120] I> Task: NVRNG health check
[Tue Aug 19 10:44:09.848 2025] [0000.123] I> NVRNG: Health check success
[Tue Aug 19 10:44:09.848 2025] [0000.127] I> Task: MSS Bandwidth limiter settings for iGPU clients
[Tue Aug 19 10:44:09.848 2025] [0000.133] I> Task: Enabling and initialization of Bandwidth limiter
[Tue Aug 19 10:44:09.848 2025] [0000.139] I> No request to configure MBWT settings for any PC!
[Tue Aug 19 10:44:09.848 2025] [0000.145] I> Task: Secure debug controls
[Tue Aug 19 10:44:09.848 2025] [0000.149] I> Task: strap war set
[Tue Aug 19 10:44:09.848 2025] [0000.152] I> Task: Initialize SOC Therm
[Tue Aug 19 10:44:09.880 2025] [0000.155] I> Task: Program NV master stream id
[Tue Aug 19 10:44:09.880 2025] [0000.160] I> Task: Verify boot mode
[Tue Aug 19 10:44:09.880 2025] [0000.165] I> Task: Alias fuses
[Tue Aug 19 10:44:09.880 2025] [0000.169] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[Tue Aug 19 10:44:09.880 2025] [0000.176] I> Task: Print SKU type
[Tue Aug 19 10:44:09.880 2025] [0000.179] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[Tue Aug 19 10:44:09.880 2025] [0000.185] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[Tue Aug 19 10:44:09.880 2025] [0000.189] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[Tue Aug 19 10:44:09.880 2025] [0000.193] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[Tue Aug 19 10:44:09.880 2025] [0000.197] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[Tue Aug 19 10:44:09.880 2025] [0000.202] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[Tue Aug 19 10:44:09.880 2025] [0000.206] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[Tue Aug 19 10:44:09.880 2025] [0000.211] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[Tue Aug 19 10:44:09.880 2025] [0000.215] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[Tue Aug 19 10:44:09.880 2025] [0000.219] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[Tue Aug 19 10:44:09.880 2025] [0000.223] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[Tue Aug 19 10:44:09.880 2025] [0000.227] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[Tue Aug 19 10:44:09.880 2025] [0000.232] I> FUSE_SKU_INFO_0 = 0xd3
[Tue Aug 19 10:44:09.880 2025] [0000.235] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[Tue Aug 19 10:44:09.880 2025] [0000.239] I> FUSE_PACKAGE_INFO_0 = 0x2
[Tue Aug 19 10:44:09.880 2025] [0000.243] I> SKU: Prod
[Tue Aug 19 10:44:09.880 2025] [0000.245] I> Task: Boost clocks
[Tue Aug 19 10:44:09.913 2025] [0000.248] I> Initializing PLLC2 for AXI_CBB.
[Tue Aug 19 10:44:09.913 2025] [0000.252] I> AXI_CBB : src = 35, divisor = 0
[Tue Aug 19 10:44:09.913 2025] [0000.256] I> Task: Voltage monitor
[Tue Aug 19 10:44:09.913 2025] [0000.259] I> VMON: Vmon re-calibration and fine tuning done
[Tue Aug 19 10:44:09.913 2025] [0000.265] I> Task: UPHY init
[Tue Aug 19 10:44:09.913 2025] [0000.270] I> HSIO UPHY init done
[Tue Aug 19 10:44:09.913 2025] [0000.273] W> Skipping GBE UPHY config
[Tue Aug 19 10:44:09.913 2025] [0000.276] I> Task: Boot device init
[Tue Aug 19 10:44:09.913 2025] [0000.280] I> Boot_device: QSPI_FLASH instance: 0
[Tue Aug 19 10:44:09.913 2025] [0000.284] I> Qspi clock source : pllc_out0
[Tue Aug 19 10:44:09.913 2025] [0000.288] I> QSPI Flash: Macronix 64MB
[Tue Aug 19 10:44:09.913 2025] [0000.292] I> QSPI-0l initialized successfully
[Tue Aug 19 10:44:09.913 2025] [0000.296] I> Task: TSC init
[Tue Aug 19 10:44:09.913 2025] [0000.299] I> Task: Load membct
[Tue Aug 19 10:44:09.913 2025] [0000.302] I> RAM_CODE 0x4000411
[Tue Aug 19 10:44:09.913 2025] [0000.305] I> Loading MEMBCT
[Tue Aug 19 10:44:09.913 2025] [0000.308] I> Slot: 0
[Tue Aug 19 10:44:09.913 2025] [0000.310] I> Binary[0] block-3840 (partition size: 0x40000)
[Tue Aug 19 10:44:09.913 2025] [0000.315] I> Binary name: MEM-BCT-0
[Tue Aug 19 10:44:09.913 2025] [0000.319] I> Size of crypto header is 8192
[Tue Aug 19 10:44:09.913 2025] [0000.323] I> Size of crypto header is 8192
[Tue Aug 19 10:44:09.913 2025] [0000.326] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[Tue Aug 19 10:44:09.913 2025] [0000.333] I> BCH of MEM-BCT-0 read from storage
[Tue Aug 19 10:44:09.913 2025] [0000.337] I> BCH address is : 0x40050000
[Tue Aug 19 10:44:09.928 2025] [0000.341] I> MEM-BCT-0 header integrity check is success
[Tue Aug 19 10:44:09.928 2025] [0000.346] I> Binary magic in BCH component 0 is MEM0
[Tue Aug 19 10:44:09.928 2025] [0000.351] I> component binary type is 0
[Tue Aug 19 10:44:09.928 2025] [0000.355] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[Tue Aug 19 10:44:09.928 2025] [0000.361] I> MEM-BCT-0 binary is read from storage
[Tue Aug 19 10:44:09.928 2025] [0000.366] I> MEM-BCT-0 binary integrity check is success
[Tue Aug 19 10:44:09.928 2025] [0000.371] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[Tue Aug 19 10:44:09.928 2025] [0000.378] I> RAM_CODE 0x4000411
[Tue Aug 19 10:44:09.928 2025] [0000.383] I> RAM_CODE 0x4000411
[Tue Aug 19 10:44:09.928 2025] [0000.387] I> Task: Load Page retirement list
[Tue Aug 19 10:44:09.928 2025] [0000.391] I> Task: SDRAM params override
[Tue Aug 19 10:44:09.928 2025] [0000.395] I> Task: Save mem-bct info
[Tue Aug 19 10:44:09.928 2025] [0000.399] I> Task: Carveout allocate
[Tue Aug 19 10:44:09.928 2025] [0000.402] I> RCM blob carveout will not be allocated
[Tue Aug 19 10:44:09.928 2025] [0000.407] I> Update CCPLEX IST carveout from MB1-BCT
[Tue Aug 19 10:44:09.928 2025] [0000.412] I> ECC region[0]: Start:0x0, End:0x0
[Tue Aug 19 10:44:09.928 2025] [0000.416] I> ECC region[1]: Start:0x0, End:0x0
[Tue Aug 19 10:44:09.928 2025] [0000.420] I> ECC region[2]: Start:0x0, End:0x0
[Tue Aug 19 10:44:10.201 2025] [0000.425] I> ECC region[3]: Start:0x0, End:0x0
[Tue Aug 19 10:44:10.201 2025] [0000.429] I> ECC region[4]: Start:0x0, End:0x0
[Tue Aug 19 10:44:10.201 2025] [0000.433] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[Tue Aug 19 10:44:10.201 2025] [0000.439] I> Non-ECC region[1]: Start:0x0, End:0x0
[Tue Aug 19 10:44:10.201 2025] [0000.444] I> Non-ECC region[2]: Start:0x0, End:0x0
[Tue Aug 19 10:44:10.201 2025] [0000.448] I> Non-ECC region[3]: Start:0x0, End:0x0
[Tue Aug 19 10:44:10.201 2025] [0000.453] I> Non-ECC region[4]: Start:0x0, End:0x0
[Tue Aug 19 10:44:10.201 2025] [0000.464] I> allocated(CO:43) base:0x47c000000 size:0x4000000 align: 0x200000
[Tue Aug 19 10:44:10.201 2025] [0000.471] I> allocated(CO:39) base:0x479e00000 size:0x2200000 align: 0x10000
[Tue Aug 19 10:44:10.201 2025] [0000.478] I> allocated(CO:20) base:0x476000000 size:0x2000000 align: 0x2000000
[Tue Aug 19 10:44:10.201 2025] [0000.485] I> allocated(CO:24) base:0x474000000 size:0x2000000 align: 0x2000000
[Tue Aug 19 10:44:10.201 2025] [0000.492] I> allocated(CO:28) base:0x472000000 size:0x2000000 align: 0x2000000
[Tue Aug 19 10:44:10.201 2025] [0000.499] I> allocated(CO:22) base:0x478000000 size:0x1000000 align: 0x1000000
[Tue Aug 19 10:44:10.201 2025] [0000.506] I> allocated(CO:35) base:0x479000000 size:0xe00000 align: 0x10000
[Tue Aug 19 10:44:10.201 2025] [0000.513] I> allocated(CO:02) base:0x471800000 size:0x800000 align: 0x800000
[Tue Aug 19 10:44:10.232 2025] [0000.520] I> allocated(CO:03) base:0x471000000 size:0x800000 align: 0x800000
[Tue Aug 19 10:44:10.232 2025] [0000.527] I> allocated(CO:06) base:0x470800000 size:0x800000 align: 0x800000
[Tue Aug 19 10:44:10.232 2025] [0000.534] I> allocated(CO:56) base:0x470000000 size:0x800000 align: 0x200000
[Tue Aug 19 10:44:10.232 2025] [0000.541] I> allocated(CO:07) base:0x46fc00000 size:0x400000 align: 0x400000
[Tue Aug 19 10:44:10.232 2025] [0000.548] I> allocated(CO:33) base:0x46f800000 size:0x400000 align: 0x200000
[Tue Aug 19 10:44:10.232 2025] [0000.555] I> allocated(CO:23) base:0x46f600000 size:0x200000 align: 0x200000
[Tue Aug 19 10:44:10.232 2025] [0000.562] I> allocated(CO:01) base:0x46f500000 size:0x100000 align: 0x100000
[Tue Aug 19 10:44:10.232 2025] [0000.569] I> allocated(CO:05) base:0x46f400000 size:0x100000 align: 0x100000
[Tue Aug 19 10:44:10.232 2025] [0000.575] I> allocated(CO:08) base:0x46f300000 size:0x100000 align: 0x100000
[Tue Aug 19 10:44:10.232 2025] [0000.582] I> allocated(CO:09) base:0x46f200000 size:0x100000 align: 0x100000
[Tue Aug 19 10:44:10.232 2025] [0000.589] I> allocated(CO:15) base:0x46f100000 size:0x100000 align: 0x100000
[Tue Aug 19 10:44:10.232 2025] [0000.596] I> allocated(CO:17) base:0x46f000000 size:0x100000 align: 0x100000
[Tue Aug 19 10:44:10.232 2025] [0000.603] I> allocated(CO:27) base:0x46ef00000 size:0x100000 align: 0x100000
[Tue Aug 19 10:44:10.264 2025] [0000.610] I> allocated(CO:42) base:0x46ee00000 size:0x100000 align: 0x100000
[Tue Aug 19 10:44:10.264 2025] [0000.617] I> allocated(CO:54) base:0x46ed80000 size:0x80000 align: 0x80000
[Tue Aug 19 10:44:10.264 2025] [0000.624] I> allocated(CO:34) base:0x46ed70000 size:0x10000 align: 0x10000
[Tue Aug 19 10:44:10.264 2025] [0000.631] I> allocated(CO:72) base:0x46eb70000 size:0x200000 align: 0x10000
[Tue Aug 19 10:44:10.264 2025] [0000.637] I> allocated(CO:47) base:0x46e600000 size:0x400000 align: 0x200000
[Tue Aug 19 10:44:10.264 2025] [0000.644] I> allocated(CO:48) base:0x46eb50000 size:0x20000 align: 0x10000
[Tue Aug 19 10:44:10.264 2025] [0000.651] I> allocated(CO:69) base:0x46eb30000 size:0x20000 align: 0x10000
[Tue Aug 19 10:44:10.264 2025] [0000.658] I> allocated(CO:49) base:0x46eb20000 size:0x10000 align: 0x10000
[Tue Aug 19 10:44:10.264 2025] [0000.665] I> allocated(CO:50) base:0x46eb10000 size:0x10000 align: 0x10000
[Tue Aug 19 10:44:10.264 2025] [0000.671] I> NSDRAM base: 0x80000000, end: 0x46eb70000, size: 0x3eeb70000
[Tue Aug 19 10:44:10.264 2025] [0000.678] I> Task: Thermal check
[Tue Aug 19 10:44:10.264 2025] [0000.681] I> Using min_chip_limit as min_tmon_limit
[Tue Aug 19 10:44:10.264 2025] [0000.686] I> Using max_chip_limit as max_tmon_limit
[Tue Aug 19 10:44:10.264 2025] [0000.691] I> BCT max_tmon_limit = 105
[Tue Aug 19 10:44:10.264 2025] [0000.694] I> BCT min_tmon_limit = -28
[Tue Aug 19 10:44:10.291 2025] [0000.698] I> BCT max_tmon_limit = 105
[Tue Aug 19 10:44:10.291 2025] [0000.701] I> BCT min_tmon_limit = -28
[Tue Aug 19 10:44:10.291 2025] [0000.705] I> SKU specific max_chip_limit = 105
[Tue Aug 19 10:44:10.291 2025] [0000.709] I> SKU specific min_chip_limit = -28
[Tue Aug 19 10:44:10.291 2025] [0000.713] I> BCT max_chip_limit = 105
[Tue Aug 19 10:44:10.291 2025] [0000.717] I> BCT min_chip_limit = -28
[Tue Aug 19 10:44:10.291 2025] [0000.720] I> enable_soctherm_polling = 0
[Tue Aug 19 10:44:10.291 2025] [0000.724] I> max temp read = 33
[Tue Aug 19 10:44:10.291 2025] [0000.727] I> min temp read = 32
[Tue Aug 19 10:44:10.291 2025] [0000.730] I> Enabling thermtrip
[Tue Aug 19 10:44:10.291 2025] [0000.733] I> Task: Update FSI SCR with thermal fuse data
[Tue Aug 19 10:44:10.291 2025] [0000.738] I> Task: Enable WDT 5th expiry
[Tue Aug 19 10:44:10.291 2025] [0000.742] I> Task: I2C register
[Tue Aug 19 10:44:10.291 2025] [0000.745] I> Task: Set I2C bus freq
[Tue Aug 19 10:44:10.291 2025] [0000.748] I> Task: Reset FSI
[Tue Aug 19 10:44:10.291 2025] [0000.751] I> Task: Pinmux init
[Tue Aug 19 10:44:10.291 2025] [0000.754] I> skipped mmio_addr = 0x9240008
[Tue Aug 19 10:44:10.291 2025] [0000.758] I> skipped mmio_addr = 0x9240000
[Tue Aug 19 10:44:10.291 2025] [0000.762] I> skipped mmio_addr = 0x9240010
[Tue Aug 19 10:44:10.291 2025] [0000.766] I> skipped mmio_addr = 0x9240018
[Tue Aug 19 10:44:10.291 2025] [0000.770] I> skipped mmio_addr = 0x9240020
[Tue Aug 19 10:44:10.291 2025] [0000.774] I> skipped mmio_addr = 0x9240030
[Tue Aug 19 10:44:10.601 2025] [0000.778] I> skipped mmio_addr = 0x9240028
[Tue Aug 19 10:44:10.601 2025] [0000.782] I> skipped mmio_addr = 0x9240038
[Tue Aug 19 10:44:10.601 2025] [0000.786] I> skipped mmio_addr = 0x9240040
[Tue Aug 19 10:44:10.601 2025] [0000.790] I> skipped mmio_addr = 0x9240048
[Tue Aug 19 10:44:10.601 2025] [0000.793] I> skipped mmio_addr = 0x9241000
[Tue Aug 19 10:44:10.601 2025] [0000.797] I> skipped mmio_addr = 0x9241008
[Tue Aug 19 10:44:10.601 2025] [0000.801] I> skipped mmio_addr = 0x9241010
[Tue Aug 19 10:44:10.601 2025] [0000.805] I> skipped mmio_addr = 0x9241018
[Tue Aug 19 10:44:10.601 2025] [0000.809] I> skipped mmio_addr = 0x9241020
[Tue Aug 19 10:44:10.601 2025] [0000.813] I> skipped mmio_addr = 0x9241028
[Tue Aug 19 10:44:10.601 2025] [0000.817] I> skipped mmio_addr = 0x9241030
[Tue Aug 19 10:44:10.601 2025] [0000.821] I> skipped mmio_addr = 0x9241038
[Tue Aug 19 10:44:10.601 2025] [0000.825] I> skipped mmio_addr = 0x9241040
[Tue Aug 19 10:44:10.601 2025] [0000.829] I> skipped mmio_addr = 0x9242000
[Tue Aug 19 10:44:10.601 2025] [0000.833] I> skipped mmio_addr = 0x9242008
[Tue Aug 19 10:44:10.601 2025] [0000.837] I> Task: Prod config init
[Tue Aug 19 10:44:10.601 2025] [0000.840] I> Task: Pad voltage init
[Tue Aug 19 10:44:10.601 2025] [0000.843] I> Task: Prod init
[Tue Aug 19 10:44:10.601 2025] [0000.846] I> Task: Program rst req config reg
[Tue Aug 19 10:44:10.601 2025] [0000.850] I> Task: Common rail init
[Tue Aug 19 10:44:10.601 2025] [0000.854] I> DONE: Thermal config
[Tue Aug 19 10:44:10.601 2025] [0000.858] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[Tue Aug 19 10:44:10.601 2025] [0000.866] I> DONE: SOC rail config
[Tue Aug 19 10:44:10.635 2025] [0000.870] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[Tue Aug 19 10:44:10.635 2025] [0000.877] I> DONE: MEMIO rail config
[Tue Aug 19 10:44:10.635 2025] [0000.881] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[Tue Aug 19 10:44:10.635 2025] [0000.887] I> DONE: GPU rail info
[Tue Aug 19 10:44:10.635 2025] [0000.891] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[Tue Aug 19 10:44:10.635 2025] [0000.897] I> DONE: CV rail info
[Tue Aug 19 10:44:10.635 2025] [0000.900] I> Task: Mem clock src
[Tue Aug 19 10:44:10.635 2025] [0000.903] I> Task: Misc. board config
[Tue Aug 19 10:44:10.635 2025] [0000.907] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[Tue Aug 19 10:44:10.635 2025] [0000.913] I> Task: SDRAM init
[Tue Aug 19 10:44:10.635 2025] [0000.915] I> MemoryType: 4 MemBctRevision: 2
[Tue Aug 19 10:44:10.635 2025] [0000.922] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 2
[Tue Aug 19 10:44:10.635 2025] [0000.929] I> MSS CAR: Init PLLM
[Tue Aug 19 10:44:10.635 2025] [0000.933] I> MSS CAR: Init PLLHUB
[Tue Aug 19 10:44:10.635 2025] [0000.937] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[Tue Aug 19 10:44:10.635 2025] [0000.949] I> SDRAM initialized!
[Tue Aug 19 10:44:10.635 2025] [0000.952] I> SDRAM Size in Total 0x400000000
[Tue Aug 19 10:44:10.635 2025] [0000.956] I> Task: Dram Ecc scrub
[Tue Aug 19 10:44:10.635 2025] [0000.959] I> Task: DRAM alias check
[Tue Aug 19 10:44:10.635 2025] [0000.966] I> Task: Program NSDRAM carveout
[Tue Aug 19 10:44:10.635 2025] [0000.969] I> NSDRAM carveout encryption is enabled
[Tue Aug 19 10:44:10.665 2025] [0000.974] I> Program NSDRAM carveout
[Tue Aug 19 10:44:10.665 2025] [0000.978] I> Task: Register checker
[Tue Aug 19 10:44:10.665 2025] [0000.981] I> Task: Enable clock-mon
[Tue Aug 19 10:44:10.665 2025] [0000.985] I> FMON: Fmon re-programming done
[Tue Aug 19 10:44:10.665 2025] [0000.989] I> Task: Mapper init
[Tue Aug 19 10:44:10.665 2025] [0000.992] I> Task: SC7 Context Init
[Tue Aug 19 10:44:10.665 2025] [0000.995] I> Task: CCPLEX IST init
[Tue Aug 19 10:44:10.665 2025] [0000.999] I> Task: CPU WP0
[Tue Aug 19 10:44:10.665 2025] [0001.001] I> Loading MCE
[Tue Aug 19 10:44:10.665 2025] [0001.004] I> Slot: 0
[Tue Aug 19 10:44:10.665 2025] [0001.006] I> Binary[8] block-22784 (partition size: 0x80000)
[Tue Aug 19 10:44:10.665 2025] [0001.011] I> Binary name: MCE
[Tue Aug 19 10:44:10.665 2025] [0001.014] I> Size of crypto header is 8192
[Tue Aug 19 10:44:10.665 2025] [0001.018] I> Size of crypto header is 8192
[Tue Aug 19 10:44:10.665 2025] [0001.022] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[Tue Aug 19 10:44:10.665 2025] [0001.028] I> BCH of MCE read from storage
[Tue Aug 19 10:44:10.665 2025] [0001.032] I> BCH address is : 0x4003e000
[Tue Aug 19 10:44:10.665 2025] [0001.036] I> MCE header integrity check is success
[Tue Aug 19 10:44:10.665 2025] [0001.041] I> Binary magic in BCH component 0 is MTSM
[Tue Aug 19 10:44:10.665 2025] [0001.045] I> component binary type is 8
[Tue Aug 19 10:44:10.665 2025] [0001.049] I> Size of crypto header is 8192
[Tue Aug 19 10:44:10.665 2025] [0001.053] I> strt_pg_num(22800) num_of_pgs(357) read_buf(0x40000000)
[Tue Aug 19 10:44:10.665 2025] [0001.061] I> MCE binary is read from storage
[Tue Aug 19 10:44:10.665 2025] [0001.066] I> MCE binary integrity check is success
[Tue Aug 19 10:44:10.698 2025] [0001.070] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[Tue Aug 19 10:44:10.698 2025] [0001.077] I> Size of crypto header is 8192
[Tue Aug 19 10:44:10.698 2025] [0001.088] I> Size of crypto header is 8192
[Tue Aug 19 10:44:10.698 2025] [0001.092] I> Sending WP0 mailbox command to PSC
[Tue Aug 19 10:44:10.698 2025] [0001.101] I> Task: XUSB Powergate
[Tue Aug 19 10:44:10.698 2025] [0001.104] I> Skipping powergate XUSB.
[Tue Aug 19 10:44:10.698 2025] [0001.107] I> Task: MB1 fixed firewalls
[Tue Aug 19 10:44:10.698 2025] [0001.114] W> Firewall readback mismatch
[Tue Aug 19 10:44:10.698 2025] [0001.119] I> Task: Load bpmp-fw
[Tue Aug 19 10:44:10.698 2025] [0001.122] I> Slot: 0
[Tue Aug 19 10:44:10.698 2025] [0001.124] I> Binary[15] block-9984 (partition size: 0x180000)
[Tue Aug 19 10:44:10.698 2025] [0001.129] I> Binary name: BPMP_FW
[Tue Aug 19 10:44:10.698 2025] [0001.133] I> Size of crypto header is 8192
[Tue Aug 19 10:44:10.698 2025] [0001.136] I> Size of crypto header is 8192
[Tue Aug 19 10:44:10.698 2025] [0001.140] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[Tue Aug 19 10:44:10.698 2025] [0001.147] I> BCH of BPMP_FW read from storage
[Tue Aug 19 10:44:10.698 2025] [0001.151] I> BCH address is : 0x807fe000
[Tue Aug 19 10:44:10.698 2025] [0001.155] I> BPMP_FW header integrity check is success
[Tue Aug 19 10:44:10.698 2025] [0001.160] I> Binary magic in BCH component 0 is BPMF
[Tue Aug 19 10:44:10.698 2025] [0001.164] I> component binary type is 15
[Tue Aug 19 10:44:10.698 2025] [0001.168] I> Size of crypto header is 8192
[Tue Aug 19 10:44:10.715 2025] [0001.172] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[Tue Aug 19 10:44:10.715 2025] [0001.190] I> BPMP_FW binary is read from storage
[Tue Aug 19 10:44:10.984 2025] [0001.196] I> BPMP_FW binary integrity check is success
[Tue Aug 19 10:44:10.984 2025] [0001.201] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[Tue Aug 19 10:44:10.984 2025] [0001.208] I> Slot: 0
[Tue Aug 19 10:44:10.984 2025] [0001.210] I> Binary[16] block-13056 (partition size: 0x400000)
[Tue Aug 19 10:44:10.984 2025] [0001.215] I> Binary name: BPMP_FW_DTB
[Tue Aug 19 10:44:10.984 2025] [0001.219] I> Size of crypto header is 8192
[Tue Aug 19 10:44:10.984 2025] [0001.223] I> Size of crypto header is 8192
[Tue Aug 19 10:44:10.984 2025] [0001.227] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[Tue Aug 19 10:44:10.984 2025] [0001.233] I> BCH of BPMP_FW_DTB read from storage
[Tue Aug 19 10:44:10.984 2025] [0001.237] I> BCH address is : 0x807fc000
[Tue Aug 19 10:44:10.984 2025] [0001.241] I> BPMP_FW_DTB header integrity check is success
[Tue Aug 19 10:44:10.984 2025] [0001.247] I> Binary magic in BCH component 0 is BPMD
[Tue Aug 19 10:44:10.984 2025] [0001.251] I> component binary type is 16
[Tue Aug 19 10:44:10.984 2025] [0001.255] I> Size of crypto header is 8192
[Tue Aug 19 10:44:10.984 2025] [0001.259] I> strt_pg_num(13072) num_of_pgs(724) read_buf(0x807a17f0)
[Tue Aug 19 10:44:10.984 2025] [0001.269] I> BPMP_FW_DTB binary is read from storage
[Tue Aug 19 10:44:10.984 2025] [0001.275] I> BPMP_FW_DTB binary integrity check is success
[Tue Aug 19 10:44:10.984 2025] [0001.280] I> Binary BPMP_FW_DTB loaded successfully at 0x807a17f0 (0x5a680)
[Tue Aug 19 10:44:11.016 2025] [0001.287] I> Task: BPMP fw ast config
[Tue Aug 19 10:44:11.016 2025] [0001.291] I> Task: Load psc-fw
[Tue Aug 19 10:44:11.016 2025] [0001.294] I> Slot: 0
[Tue Aug 19 10:44:11.016 2025] [0001.296] I> Binary[17] block-21248 (partition size: 0xc0000)
[Tue Aug 19 10:44:11.016 2025] [0001.301] I> Binary name: PSC_FW
[Tue Aug 19 10:44:11.016 2025] [0001.304] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.016 2025] [0001.308] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.016 2025] [0001.312] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[Tue Aug 19 10:44:11.016 2025] [0001.318] I> BCH of PSC_FW read from storage
[Tue Aug 19 10:44:11.016 2025] [0001.322] I> BCH address is : 0x80ffe000
[Tue Aug 19 10:44:11.016 2025] [0001.326] I> PSC_FW header integrity check is success
[Tue Aug 19 10:44:11.016 2025] [0001.331] I> Binary magic in BCH component 0 is PFWP
[Tue Aug 19 10:44:11.016 2025] [0001.336] I> component binary type is 17
[Tue Aug 19 10:44:11.016 2025] [0001.340] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.016 2025] [0001.344] I> strt_pg_num(21264) num_of_pgs(717) read_buf(0x80fa4600)
[Tue Aug 19 10:44:11.016 2025] [0001.354] I> PSC_FW binary is read from storage
[Tue Aug 19 10:44:11.016 2025] [0001.359] I> PSC_FW binary integrity check is success
[Tue Aug 19 10:44:11.016 2025] [0001.364] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[Tue Aug 19 10:44:11.016 2025] [0001.370] I> Task: Load nvdec-fw
[Tue Aug 19 10:44:11.016 2025] [0001.373] I> Slot: 0
[Tue Aug 19 10:44:11.016 2025] [0001.375] I> Binary[7] block-6400 (partition size: 0x100000)
[Tue Aug 19 10:44:11.048 2025] [0001.381] I> Binary name: NVDEC
[Tue Aug 19 10:44:11.048 2025] [0001.384] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.048 2025] [0001.388] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.048 2025] [0001.392] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[Tue Aug 19 10:44:11.048 2025] [0001.398] I> BCH of NVDEC read from storage
[Tue Aug 19 10:44:11.048 2025] [0001.402] I> BCH address is : 0x800fe000
[Tue Aug 19 10:44:11.048 2025] [0001.406] I> NVDEC header integrity check is success
[Tue Aug 19 10:44:11.048 2025] [0001.411] I> Binary magic in BCH component 0 is NDEC
[Tue Aug 19 10:44:11.048 2025] [0001.415] I> component binary type is 7
[Tue Aug 19 10:44:11.048 2025] [0001.419] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.048 2025] [0001.423] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[Tue Aug 19 10:44:11.048 2025] [0001.432] I> NVDEC binary is read from storage
[Tue Aug 19 10:44:11.048 2025] [0001.437] I> NVDEC binary integrity check is success
[Tue Aug 19 10:44:11.048 2025] [0001.442] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[Tue Aug 19 10:44:11.048 2025] [0001.448] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.048 2025] [0001.460] I> Task: Load tsec-fw
[Tue Aug 19 10:44:11.048 2025] [0001.463] I> TSEC-FW load support not enabled
[Tue Aug 19 10:44:11.048 2025] [0001.467] I> Task: GPIO interrupt map
[Tue Aug 19 10:44:11.048 2025] [0001.471] I> Task: SC7 context save
[Tue Aug 19 10:44:11.048 2025] [0001.474] I> Slot: 0
[Tue Aug 19 10:44:11.048 2025] [0001.476] I> Binary[27] block-0 (partition size: 0x100000)
[Tue Aug 19 10:44:11.066 2025] [0001.481] I> Binary name: BR_BCT
[Tue Aug 19 10:44:11.066 2025] [0001.484] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.066 2025] [0001.488] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.066 2025] [0001.492] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.066 2025] [0001.496] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[Tue Aug 19 10:44:11.066 2025] [0001.502] I> BR_BCT binary is read from storage
[Tue Aug 19 10:44:11.066 2025] [0001.507] I> BR_BCT binary integrity check is success
[Tue Aug 19 10:44:11.066 2025] [0001.512] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[Tue Aug 19 10:44:11.066 2025] [0001.518] I> Slot: 0
[Tue Aug 19 10:44:11.066 2025] [0001.520] I> Binary[13] block-23808 (partition size: 0x30000)
[Tue Aug 19 10:44:11.066 2025] [0001.525] I> Binary name: SC7-FW
[Tue Aug 19 10:44:11.066 2025] [0001.529] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.066 2025] [0001.532] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.066 2025] [0001.536] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.066 2025] [0001.540] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.066 2025] [0001.544] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[Tue Aug 19 10:44:11.066 2025] [0001.551] I> BCH of SC7-FW read from storage
[Tue Aug 19 10:44:11.066 2025] [0001.555] I> BCH address is : 0xa0002000
[Tue Aug 19 10:44:11.066 2025] [0001.558] I> SC7-FW header integrity check is success
[Tue Aug 19 10:44:11.356 2025] [0001.563] I> Binary magic in BCH component 0 is WB0B
[Tue Aug 19 10:44:11.356 2025] [0001.568] I> component binary type is 13
[Tue Aug 19 10:44:11.356 2025] [0001.572] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.356 2025] [0001.576] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[Tue Aug 19 10:44:11.356 2025] [0001.584] I> SC7-FW binary is read from storage
[Tue Aug 19 10:44:11.356 2025] [0001.589] I> SC7-FW binary integrity check is success
[Tue Aug 19 10:44:11.356 2025] [0001.594] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[Tue Aug 19 10:44:11.356 2025] [0001.600] I> Slot: 0
[Tue Aug 19 10:44:11.356 2025] [0001.602] I> Binary[22] block-24192 (partition size: 0x30000)
[Tue Aug 19 10:44:11.356 2025] [0001.608] I> Binary name: PSC_RF
[Tue Aug 19 10:44:11.356 2025] [0001.611] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.356 2025] [0001.615] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.356 2025] [0001.619] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.356 2025] [0001.623] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.356 2025] [0001.626] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002fa00)
[Tue Aug 19 10:44:11.356 2025] [0001.633] I> BCH of PSC_RF read from storage
[Tue Aug 19 10:44:11.356 2025] [0001.637] I> BCH address is : 0xa002fa00
[Tue Aug 19 10:44:11.356 2025] [0001.641] I> PSC_RF header integrity check is success
[Tue Aug 19 10:44:11.356 2025] [0001.646] I> Binary magic in BCH component 0 is PSCR
[Tue Aug 19 10:44:11.356 2025] [0001.650] I> component binary type is 22
[Tue Aug 19 10:44:11.383 2025] [0001.654] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.383 2025] [0001.658] I> strt_pg_num(24208) num_of_pgs(256) read_buf(0xa0031a00)
[Tue Aug 19 10:44:11.383 2025] [0001.666] I> PSC_RF binary is read from storage
[Tue Aug 19 10:44:11.383 2025] [0001.670] I> PSC_RF binary integrity check is success
[Tue Aug 19 10:44:11.383 2025] [0001.675] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x20000)
[Tue Aug 19 10:44:11.383 2025] [0001.685] I> Task: Save WP0 payload to SC7 ctx
[Tue Aug 19 10:44:11.383 2025] [0001.689] I> Task: Load MB2rf binary to SC7 ctx
[Tue Aug 19 10:44:11.383 2025] [0001.693] I> Slot: 0
[Tue Aug 19 10:44:11.383 2025] [0001.695] I> Binary[14] block-24576 (partition size: 0x20000)
[Tue Aug 19 10:44:11.383 2025] [0001.701] I> Binary name: MB2_RF
[Tue Aug 19 10:44:11.383 2025] [0001.704] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.383 2025] [0001.708] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.383 2025] [0001.712] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.383 2025] [0001.716] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.383 2025] [0001.720] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d6aa0)
[Tue Aug 19 10:44:11.383 2025] [0001.726] I> BCH of MB2_RF read from storage
[Tue Aug 19 10:44:11.383 2025] [0001.730] I> BCH address is : 0xa00d6aa0
[Tue Aug 19 10:44:11.383 2025] [0001.734] I> MB2_RF header integrity check is success
[Tue Aug 19 10:44:11.383 2025] [0001.739] I> Binary magic in BCH component 0 is MB2R
[Tue Aug 19 10:44:11.383 2025] [0001.744] I> component binary type is 14
[Tue Aug 19 10:44:11.415 2025] [0001.747] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.415 2025] [0001.751] I> strt_pg_num(24592) num_of_pgs(223) read_buf(0xa00d8aa0)
[Tue Aug 19 10:44:11.415 2025] [0001.759] I> MB2_RF binary is read from storage
[Tue Aug 19 10:44:11.415 2025] [0001.764] I> MB2_RF binary integrity check is success
[Tue Aug 19 10:44:11.415 2025] [0001.768] I> Binary MB2_RF loaded successfully at 0xa00d8aa0 (0x1bcc0)
[Tue Aug 19 10:44:11.415 2025] [0001.775] I> Task: Save fuse alias data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.779] I> Task: Save PMIC data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.784] I> Task: Save Pinmux data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.788] I> Task: Save Pad Voltage data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.793] I> Task: Save controller prod data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.798] I> Task: Save prod cfg data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.802] I> Task: Save I2C bus freq data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.807] I> Task: Save SOCTherm data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.811] I> Task: Save FMON data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.815] I> Task: Save VMON data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.820] I> Task: Save TZDRAM data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.824] I> Task: Save GPIO int data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.828] I> Task: Save clock data to SC7 ctx
[Tue Aug 19 10:44:11.415 2025] [0001.832] I> Task: Save debug data to SC7 ctx
[Tue Aug 19 10:44:11.447 2025] [0001.837] I> Task: Save MBWT data to SC7 ctx
[Tue Aug 19 10:44:11.447 2025] [0001.845] I> SC7 context save done
[Tue Aug 19 10:44:11.447 2025] [0001.848] I> Task: Load MB2/Applet/FSKP
[Tue Aug 19 10:44:11.447 2025] [0001.852] I> Loading MB2
[Tue Aug 19 10:44:11.447 2025] [0001.854] I> Slot: 0
[Tue Aug 19 10:44:11.447 2025] [0001.856] I> Binary[6] block-8448 (partition size: 0x80000)
[Tue Aug 19 10:44:11.447 2025] [0001.862] I> Binary name: MB2
[Tue Aug 19 10:44:11.447 2025] [0001.864] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.447 2025] [0001.868] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.447 2025] [0001.872] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[Tue Aug 19 10:44:11.447 2025] [0001.878] I> BCH of MB2 read from storage
[Tue Aug 19 10:44:11.447 2025] [0001.882] I> BCH address is : 0x8007e000
[Tue Aug 19 10:44:11.447 2025] [0001.886] I> MB2 header integrity check is success
[Tue Aug 19 10:44:11.447 2025] [0001.891] I> Binary magic in BCH component 0 is MB2B
[Tue Aug 19 10:44:11.447 2025] [0001.895] I> component binary type is 6
[Tue Aug 19 10:44:11.447 2025] [0001.899] I> Size of crypto header is 8192
[Tue Aug 19 10:44:11.447 2025] [0001.903] I> strt_pg_num(8464) num_of_pgs(839) read_buf(0x80000000)
[Tue Aug 19 10:44:11.447 2025] [0001.914] I> MB2 binary is read from storage
[Tue Aug 19 10:44:11.447 2025] [0001.919] I> MB2 binary integrity check is success
[Tue Aug 19 10:44:11.447 2025] [0001.924] I> Binary MB2 loaded successfully at 0x80000000 (0x68c10)
[Tue Aug 19 10:44:11.447 2025] [0001.930] I> Task: Map CCPLEX SHARED carveout
[Tue Aug 19 10:44:11.447 2025] [0001.934] I> Task: Prepare MB2 params
[Tue Aug 19 10:44:11.447 2025] [0001.938] I> Task: Dram ecc test
[Tue Aug 19 10:44:11.447 2025] [0001.941] I> Task: Misc NV security settings
[Tue Aug 19 10:44:11.447 2025] [0001.945] I> NVDEC sticky bits programming done
[Tue Aug 19 10:44:11.447 2025] [0001.949] I> Successfully powergated NVDEC
[Tue Aug 19 10:44:11.447 2025] [0001.953] I> Task: Disable/Reload WDT
[Tue Aug 19 10:44:11.447 2025] [0001.957] I> Task: Program misc carveouts
[Tue Aug 19 10:44:11.447 2025] [0001.961] I> Program IPC carveouts
[Tue Aug 19 10:44:11.447 2025] [0001.964] I> Task: Disable SCPM/POD reset
[Tue Aug 19 10:44:11.447 2025] [0001.968] I> SLCG Global override status := 0x0
[Tue Aug 19 10:44:11.447 2025] [0001.973] I> MB1: MSS reconfig completed
[Tue Aug 19 10:44:11.688 2025] I> MB2 (version: 0.0.0.0-t234-54845784-7f6f63a6)
[Tue Aug 19 10:44:11.688 2025] I> t234-A01-1-Silicon (0x12347)
[Tue Aug 19 10:44:11.688 2025] I> Boot-mode : Coldboot
[Tue Aug 19 10:44:11.688 2025] I> Emulation:
[Tue Aug 19 10:44:11.688 2025] I> Entry timestamp: 0x001e7884
[Tue Aug 19 10:44:11.688 2025] I> Regular heap: [base:0x40040000, size:0x10000]
[Tue Aug 19 10:44:11.688 2025] I> DMA heap: [base:0x470000000, size:0x800000]
[Tue Aug 19 10:44:11.688 2025] I> Task: ARI update carveout TZDRAM (0x50002050)
[Tue Aug 19 10:44:11.688 2025] I> Task: Check MC errors (0x5000204c)
[Tue Aug 19 10:44:11.688 2025] I> Task: SMMU external bypass disable (0x500184fc)
[Tue Aug 19 10:44:11.688 2025] I> Task: Enable hot-plug capability (0x50028dec)
[Tue Aug 19 10:44:11.688 2025] I> Task: TZDRAM heap init (0x50019de0)
[Tue Aug 19 10:44:11.688 2025] I> Task: PSC mailbox init (0x50018548)
[Tue Aug 19 10:44:11.688 2025] I> Task: Crypto init (0x50006888)
[Tue Aug 19 10:44:11.688 2025] I> Task: Enable GP-SE clock (0x500021b4)
[Tue Aug 19 10:44:11.688 2025] I> Task: Measured Boot init (0x5001bd30)
[Tue Aug 19 10:44:11.688 2025] I> Task: fTPM silicon identity init (0x5001bedc)
[Tue Aug 19 10:44:11.688 2025] I> fTPM is not enabled.
[Tue Aug 19 10:44:11.688 2025] I> Task: OEM SC7 context save init (0x5001b27c)
[Tue Aug 19 10:44:11.688 2025] I> Task: I2C register (0x50002010)
[Tue Aug 19 10:44:11.688 2025] I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001ff8)
[Tue Aug 19 10:44:11.688 2025] I> Task: Program CBB PCIE AMAP regions (0x5001b9dc)
[Tue Aug 19 10:44:11.688 2025] I> Task: Boot device init (0x50001f40)
[Tue Aug 19 10:44:11.688 2025] I> Boot_device: QSPI_FLASH instance: 0
[Tue Aug 19 10:44:11.688 2025] I> Qspi clock source : pllc_out0
[Tue Aug 19 10:44:11.721 2025] I> QSPI-0l initialized successfully
[Tue Aug 19 10:44:11.721 2025] I> Task: Partition Manager Init (0x50001f20)
[Tue Aug 19 10:44:11.721 2025] I> Active chain: 0
[Tue Aug 19 10:44:11.721 2025] I> Found 57 partitions in QSPI_FLASH (instance 0)
[Tue Aug 19 10:44:11.721 2025] I> Task: Load and authenticate registered FWs (0x5001ed44)
[Tue Aug 19 10:44:11.721 2025] I> Task: Load AUXP FWs (0x50028970)
[Tue Aug 19 10:44:11.721 2025] I> Successfully register SPE FW load task with MB2 loader
[Tue Aug 19 10:44:11.721 2025] I> Skipping SCE FW load
[Tue Aug 19 10:44:11.721 2025] I> Successfully register RCE FW load task with MB2 loader
[Tue Aug 19 10:44:11.721 2025] I> Successfully register DCE FW load task with MB2 loader
[Tue Aug 19 10:44:11.721 2025] I> Unpowergating APE
[Tue Aug 19 10:44:11.721 2025] I> Unpowergate done
[Tue Aug 19 10:44:11.721 2025] I> Successfully register APE FW load task with MB2 loader
[Tue Aug 19 10:44:11.721 2025] I> Skipping FSI FW load
[Tue Aug 19 10:44:11.721 2025] I> Successfully register XUSB FW load task with MB2 loader
[Tue Aug 19 10:44:11.721 2025] I> Partition name: A_spe-fw
[Tue Aug 19 10:44:11.721 2025] I> Size of partition: 589824
[Tue Aug 19 10:44:11.721 2025] I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
[Tue Aug 19 10:44:11.721 2025] I> Partition name: A_rce-fw
[Tue Aug 19 10:44:11.721 2025] I> Size of partition: 1048576
[Tue Aug 19 10:44:11.721 2025] I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
[Tue Aug 19 10:44:11.721 2025] I> spe: Authentication Finalize Done
[Tue Aug 19 10:44:11.721 2025] I> Binary spe loaded successfully at 0x46f300000
[Tue Aug 19 10:44:11.735 2025] I> Active chain: 0
[Tue Aug 19 10:44:11.735 2025] I> Partition name: A_dce-fw
[Tue Aug 19 10:44:11.735 2025] I> Size of partition: 5242880
[Tue Aug 19 10:44:11.735 2025] I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
[Tue Aug 19 10:44:11.735 2025] I> rce: Authentication Finalize Done
[Tue Aug 19 10:44:11.735 2025] I> Binary rce loaded successfully at 0x46f000000
[Tue Aug 19 10:44:11.735 2025] I> Successfully register RCE FW context save task with MB2 loader
[Tue Aug 19 10:44:11.735 2025] I> dce : oem authentication of header done
[Tue Aug 19 10:44:11.735 2025] I> dce : meta-blob integrity check is success.
[Tue Aug 19 10:44:11.735 2025] I> dce : will be decompressed at 0x476000000
[Tue Aug 19 10:44:11.735 2025] I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
[Tue Aug 19 10:44:11.735 2025] I> Reserved10 0 BlockMaxSize 5 Reserved11 0
[Tue Aug 19 10:44:11.735 2025] I> dce : decompressed to 9449600 bytes
[Tue Aug 19 10:44:11.847 2025] I> dce: plain binary integrity check is success
[Tue Aug 19 10:44:11.847 2025] I> Active chain: 0
[Tue Aug 19 10:44:11.847 2025] I> Partition name: A_adsp-fw
[Tue Aug 19 10:44:11.847 2025] I> Size of partition: 2097152
[Tue Aug 19 10:44:11.847 2025] I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
[Tue Aug 19 10:44:11.847 2025] I> dce: Authentication Finalize Done
[Tue Aug 19 10:44:11.847 2025] I> Binary dce loaded successfully at 0x476000000
[Tue Aug 19 10:44:11.847 2025] I> Partition name: A_xusb-fw
[Tue Aug 19 10:44:11.847 2025] I> Size of partition: 262144
[Tue Aug 19 10:44:11.847 2025] I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
[Tue Aug 19 10:44:11.847 2025] I> ape: Authentication Finalize Done
[Tue Aug 19 10:44:11.847 2025] I> Binary ape loaded successfully at 0x46fc00000
[Tue Aug 19 10:44:11.847 2025] I> Successfully register APE FW context save task with MB2 loader
[Tue Aug 19 10:44:11.847 2025] I> xusb: Authentication Finalize Done
[Tue Aug 19 10:44:11.847 2025] I> Binary xusb loaded successfully at 0x46f400000
[Tue Aug 19 10:44:11.847 2025] I> Successfully register XUSB FW context save task with MB2 loader
[Tue Aug 19 10:44:11.847 2025] I> Task: Check MC errors (0x5000204c)
[Tue Aug 19 10:44:11.847 2025] I> Task: Carveout setup (0x500214d0)
[Tue Aug 19 10:44:11.847 2025] I> Program remaining OEM carveouts
[Tue Aug 19 10:44:11.847 2025] I> Task: Enable FSITHERM (0x500183cc)
[Tue Aug 19 10:44:11.847 2025] I> Task: Enable FSI VMON (0x50017ec8)
[Tue Aug 19 10:44:11.847 2025] I> Task: Validate FSI Therm readings (0x50017fac)
[Tue Aug 19 10:44:11.847 2025] I> Task: Restore XUSB sec (0x50001ef4)
[Tue Aug 19 10:44:11.859 2025] I> Task: Enable FSI SE clock (0x500189a4)
[Tue Aug 19 10:44:11.859 2025] I> Task: Initialize SBSA UART CAR (0x50002118)
[Tue Aug 19 10:44:11.859 2025] I> Task: Initialize CPUBL Params (0x50019990)
[Tue Aug 19 10:44:11.859 2025] I> CPUBL-params @ 0x472000000
[Tue Aug 19 10:44:11.859 2025] I> Task: Ratchet update (0x50029e88)
[Tue Aug 19 10:44:11.859 2025] W> Skip ratchet update - OPTIN fuse not set
[Tue Aug 19 10:44:11.859 2025] I> Task: Prepare eeprom data (0x5001975c)
[Tue Aug 19 10:44:11.863 2025] I> Task: Revoke PKC fuse (0x50001d40)
[Tue Aug 19 10:44:11.895 2025] I> PKC revoke fuse burn not requested
[Tue Aug 19 10:44:11.895 2025] I> Task: FSI padctl context save (0x5001b558)
[Tue Aug 19 10:44:11.895 2025] W> Skipping FSI padctl config save: fsi not enabled
[Tue Aug 19 10:44:11.895 2025] I> Task: Unpowergate APE (0x5001910c)
[Tue Aug 19 10:44:11.895 2025] W> mb2_unpowergate_ape: skip! APE is in unpowergated state
[Tue Aug 19 10:44:11.895 2025] I> Task: OEM firewalls (0x500259e4)
[Tue Aug 19 10:44:12.262 2025] I> OEM firewalls configured
[Tue Aug 19 10:44:12.262 2025] I> Task: Powergate APE (0x50019280)
[Tue Aug 19 10:44:12.262 2025] I> Powergating APE
[Tue Aug 19 10:44:12.262 2025] I> Powergate done
[Tue Aug 19 10:44:12.262 2025] I> Task: OEM firewall restore saved settings (0x50025e38)
[Tue Aug 19 10:44:12.262 2025] I> Task: Unhalt AUXPs (0x50028bf4)
[Tue Aug 19 10:44:12.262 2025] I> Unhalting SPE..
[Tue Aug 19 10:44:12.262 2025] I> Enabling combined UART
[Tue Aug 19 10:44:12.262 2025]     spe: early_init
[Tue Aug 19 10:44:12.262 2025]     vic initialized
[Tue Aug 19 10:44:12.262 2025]     tsc initialized
[Tue Aug 19 10:44:12.262 2025]     aon lic initialized
[Tue Aug 19 10:44:12.262 2025]     spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
[Tue Aug 19 10:44:12.262 2025]     spe: SafeRTOS v8.4
[Tue Aug 19 10:44:12.262 2025]     spe: init
[Tue Aug 19 10:44:12.262 2025]     scheduler initialized
[Tue Aug 19 10:44:12.262 2025]     aon hsp initialized
[Tue Aug 19 10:44:12.262 2025]     tag initialized
[Tue Aug 19 10:44:12.262 2025]     tcu initialized
[Tue Aug 19 10:44:12.262 2025]     bpmp ipc initialized
[Tue Aug 19 10:44:12.262 2025]     spe: late init
[Tue Aug 19 10:44:12.262 2025]     cpu_nic clock initialized
[Tue Aug 19 10:44:12.262 2025]     apb clock initialized
[Tue Aug 19 10:44:12.262 2025]     pm initialized
[Tue Aug 19 10:44:12.262 2025]     bpmp hsp initialized
[Tue Aug 19 10:44:12.262 2025]     top1 hsp initialized
[Tue Aug 19 10:44:12.262 2025]     ccplex ipc initialized
[Tue Aug 19 10:44:12.262 2025]     spe: start scheduler
[Tue Aug 19 10:44:12.262 2025] I> Task: Trigger mailbox for PSC-BL1 exit (0x500185c8)
[Tue Aug 19 10:44:12.262 2025] I> Sending opcode 0x4d420802 to psc
[Tue Aug 19 10:44:12.262 2025]   INFO: Entering psc_monitor_init!
[Tue Aug 19 10:44:12.262 2025] INFO: GSC22 BOM:0x478002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
[Tue Aug 19 10:44:12.262 2025] INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
[Tue Aug 19 10:44:12.262 2025] INFO: mstatus:0xa00000808
[Tue Aug 19 10:44:12.293 2025] INFO: Supervisor entry_point:c108c00
[Tue Aug 19 10:44:12.293 2025]   I> Received ACK from psc
[Tue Aug 19 10:44:12.293 2025] I> Tas  INFO: MONITOR: user task addr:0x478022000, blob offset:0x00020000
[Tue Aug 19 10:44:12.293 2025] INFO: MONITOR: populated user images:13
[Tue Aug 19 10:44:12.293 2025] INFO: mret to Supervisor!
[Tue Aug 19 10:44:12.293 2025] INFO: psc supervisor init.
[Tue Aug 19 10:44:12.293 2025] INFO: psc_irq_init...
[Tue Aug 19 10:44:12.293 2025] INFO: enter idle task.
[Tue Aug 19 10:44:12.293 2025] hwwdt_init: WDT boot cfg 0x710010 sts 0x10
[Tue Aug 19 10:44:12.293 2025] bpmp: socket 0
[Tue Aug 19 10:44:12.293 2025] bpmp: base binary md5 is da583751bbfe2b7f6e204562d97ff39e
[Tue Aug 19 10:44:12.293 2025] bpmp: combined binary md5 is dc3fd3cac60f9b918e11d435834d12a3
[Tue Aug 19 10:44:12.293 2025] bpmp: firmware tag is dc3fd3cac60f9b918e11-da583751bbf
[Tue Aug 19 10:44:12.293 2025] Control register check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
[Tue Aug 19 10:44:12.293 2025] Write control check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 0f18000b != actual value: 00000000 address: 13a159c8
[Tue Aug 19 10:44:12.293 2025] initialized vwdt
[Tue Aug 19 10:44:12.293 2025] initialized mail_early
[Tue Aug 19 10:44:12.293 2025] initialized fuse
[Tue Aug 19 10:44:12.325 2025] initialized vfrel
[Tue Aug 19 10:44:12.325 2025] initialized adc
[Tue Aug 19 10:44:12.325 2025] fmon_populate_monitors: found 199 monitors
[Tue Aug 19 10:44:12.325 2025] initialized fmon
[Tue Aug 19 10:44:12.325 2025] initialized mc
[Tue Aug 19 10:44:12.325 2025] initialized reset
[Tue Aug 19 10:44:12.325 2025] initialized uphy_early
[Tue Aug 19 10:44:12.325 2025] initialized emc_early
[Tue Aug 19 10:44:12.325 2025] initialized pm
[Tue Aug 19 10:44:12.325 2025] 465 clocks registered
[Tue Aug 19 10:44:12.325 2025] initialized clk_mach
[Tue Aug 19 10:44:12.325 2025] initialized clk_cal_early
[Tue Aug 19 10:44:12.325 2025] initialized clk_mach_early_config
[Tue Aug 19 10:44:12.325 2025] initialized io_dpd
[Tue Aug 19 10:44:12.325 2025] initialized soctherm
[Tue Aug 19 10:44:12.325 2025] initialized regime
[Tue Aug 19 10:44:12.325 2025] initialized i2c
[Tue Aug 19 10:44:12.325 2025] vrmon_dt_init: vrmon node not found
[Tue Aug 19 10:44:12.325 2025] vrmon_chk_boot_state: found 0 rail monitors
[Tue Aug 19 10:44:12.325 2025] initialized vrmon
[Tue Aug 19 10:44:12.325 2025] initialized regulator
[Tue Aug 19 10:44:12.325 2025]   k: Start secure NOR provisi  initialized avfs_clk_platform
[Tue Aug 19 10:44:12.325 2025] initialized powergate
[Tue Aug 19 10:44:12.325 2025]   on (0x5001b7f4)
[Tue Aug 19 10:44:12.325 2025] I>   initialized dvs
[Tue Aug 19 10:44:12.325 2025] initialized clk_mach_config
[Tue Aug 19 10:44:12.325 2025] initialized suspend
[Tue Aug 19 10:44:12.325 2025] initialized strap
[Tue Aug 19 10:44:12.325 2025] initialized mce_dbell
[Tue Aug 19 10:44:12.325 2025]   Task: Load FSI keyblob (0x500189ec)
[Tue Aug 19 10:44:12.325 2025] I> Task: Unhalt AUXPs (0x50028bfc)
[Tue Aug 19 10:44:12.325 2025] I> SCE unhalt skipped
[Tue Aug 19 10:44:12.325 2025] I> Unhalting RCE
[Tue Aug 19 10:44:12.325 2025] I> RCE unhalt successful
[Tue Aug 19 10:44:12.325 2025] I> DCE unhalt successful
[Tue Aug 19 10:44:12.325 2025] I> APE unhalt skipped
[Tue Aug 19 10:44:12.325 2025] I> FSI unhalt skipped
[Tue Aug 19 10:44:12.325 2025] I> Task: Load CPUBL (0x50019ab4)
[Tue Aug 19 10:44:12.325 2025] I> Task: Load TOS (0x5001a244)
[Tue Aug 19 10:44:12.325 2025] I> Task: Load and authenticate registered FWs (0x5001e  [     2.436801] Camera-FW on t234-rce-safe start  initialized emc
[Tue Aug 19 10:44:12.341 2025] initialized emc_mrq
[Tue Aug 19 10:44:12.341 2025]   ed
[Tue Aug 19 10:44:12.341 2025]   initializ  TCU early console ena  ed clk_cal
[Tue Aug 19 10:44:12.341 2025] initializ  bled.
[Tue Aug 19 10:44:12.341 2025]   ed uphy_dt
[Tue Aug 19 10:44:12.341 2025] initialized uphy_mrq
[Tue Aug 19 10:44:12.341 2025] HSIO UPHY reset has been de-asserted 0x0
[Tue Aug 19 10:44:12.341 2025] initialized pg_late
[Tue Aug 19 10:44:12.341 2025] initialized pg_mrq_init
[Tue Aug 19 10:44:12.341 2025] swdtimer_init: reg polling start w period 47 ms
[Tue Aug 19 10:44:12.341 2025] initialized swdtimer
[Tue Aug 19 10:44:12.341 2025] initialized hwwdt_late
[Tue Aug 19 10:44:12.341 2025] initialized bwmgr
[Tue Aug 19 10:44:12.341 2025] initialized thermal_host_trip
[Tue Aug 19 10:44:12.341 2025] initialized thermal_mrq
[Tue Aug 19 10:44:12.341 2025] initialized oc_mrq
[Tue Aug 19 10:44:12.341 2025] initialized reset_mrq
[Tue Aug 19 10:44:12.341 2025] initialized mail_mrq
[Tue Aug 19 10:44:12.341 2025] initialized fmon_mrq
[Tue Aug 19 10:44:12.341 2025] initialized clk_mrq
[Tue Aug 19 10:44:12.341 2025] initialized avfs_mrq
[Tue Aug 19 10:44:12.341 2025] initialized i2c_mrq
[Tue Aug 19 10:44:12.341 2025] initialized tag_mrq
[Tue Aug 19 10:44:12.341 2025] initialized bwmgr_mrq
[Tue Aug 19 10:44:12.341 2025] initialized console_mrq
[Tue Aug 19 10:44:12.341 2025] missing prod DT calibration data for 199 fmons
[Tue Aug 19 10:44:12.341 2025] initialized clk_sync_fmon_post
[Tue Aug 19 10:44:12.341 2025]   d44)
[Tue Aug 19 10:44:12.341 2025] I> Active chain: 0
[Tue Aug 19 10:44:12.341 2025] I> Partition name: A_cpu-bootloader
[Tue Aug 19 10:44:12.341 2025] I> Size of partition: 36700  initialized clk_cal_late
[Tue Aug 19 10:44:12.629 2025] initialized noc_late
[Tue Aug 19 10:44:12.629 2025] initialized cvc
[Tue Aug 19 10:44:12.629 2025]   16
[Tue Aug 19 10:44:12.629 2025] I> Binary@ device:3/0 block  initialized avfs_clk_mach_post
[Tue Aug 19 10:44:12.629 2025] initialized avfs_clk_platform_post
[Tue Aug 19 10:44:12.629 2025] initialized cvc_late
[Tue Aug 19 10:44:12.629 2025] WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
[Tue Aug 19 10:44:12.629 2025] WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
[Tue Aug 19 10:44:12.629 2025] WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
[Tue Aug 19 10:44:12.629 2025] WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
[Tue Aug 19 10:44:12.629 2025] WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
[Tue Aug 19 10:44:12.629 2025] WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
[Tue Aug 19 10:44:12.629 2025] WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
[Tue Aug 19 10:44:12.629 2025] WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
[Tue Aug 19 10:44:12.629 2025] WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
[Tue Aug 19 10:44:12.629 2025] WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
[Tue Aug 19 10:44:12.661 2025] initialized rm
[Tue Aug 19 10:44:12.661 2025] initialized console_late
[Tue Aug 19 10:44:12.661 2025] handling unreferenced clks
[Tue Aug 19 10:44:12.661 2025] enable can1_core
[Tue Aug 19 10:44:12.661 2025] enable can1_host
[Tue Aug 19 10:44:12.661 2025] enable can2_core
[Tue Aug 19 10:44:12.661 2025] enable can2_host
[Tue Aug 19 10:44:12.661 2025] enable pwm3
[Tue Aug 19 10:44:12.661 2025] enable sdmmc4_axicif
[Tue Aug 19 10:44:12.661 2025] enable mss_encr  [     2.618892] Camer  ypt
[Tue Aug 19 10:44:12.661 2025] enable maud
[Tue Aug 19 10:44:12.661 2025] enable pllg_ref
[Tue Aug 19 10:44:12.661 2025] enable dsi_core
[Tue Aug 19 10:44:12.661 2025] ena  a-FW on t234-rce-safe  ble aza_2xbit
[Tue Aug 19 10:44:12.661 2025] enable xusb_ss
[Tue Aug 19 10:44:12.661 2025] enable xusb_fs
[Tue Aug 19 10:44:12.661 2025] enable xusb_falcon
[Tue Aug 19 10:44:12.661 2025] enable xusb_core_mux
[Tue Aug 19 10:44:12.661 2025] enable dsi_lp
[Tue Aug 19 10:44:12.661 2025] initialized clk_mach_post
[Tue Aug 19 10:44:12.661 2025] initialized pg_post
[Tue Aug 19 10:44:12.661 2025] initia   ready SHA1=07158d6a (crt 17.528 ms, total boot 200.680 ms)
[Tue Aug 19 10:44:12.661 2025]   lized regulator_post
[Tue Aug 19 10:44:12.661 2025] initialized profile
[Tue Aug 19 10:44:12.661 2025] initialized mrq
[Tue Aug 19 10:44:12.661 2025] initialized patrol_scrubber
[Tue Aug 19 10:44:12.661 2025] initialized cactmon
[Tue Aug 19 10:44:12.661 2025] initialized extras_post
[Tue Aug 19 10:44:12.661 2025] bpmp: init complete
[Tue Aug 19 10:44:12.661 2025] DCE: FW Boot Done
[Tue Aug 19 10:44:12.661 2025]   -24832 (partition size: 0x380000), name: A_cpu-bootloader
[Tue Aug 19 10:44:12.661 2025] I> cpubl : oem authentication of header done
[Tue Aug 19 10:44:12.661 2025] I> cpubl : meta-blob integrity check is success.
[Tue Aug 19 10:44:12.661 2025] I> cpubl : will be decompressed at 0x46e600000
[Tue Aug 19 10:44:12.661 2025] I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
[Tue Aug 19 10:44:12.680 2025] I> Reserved10 0 BlockMaxSize 5 Reserved11 0
[Tue Aug 19 10:44:12.680 2025] I> cpubl : decompressed to 3244160 bytes
[Tue Aug 19 10:44:12.680 2025] I> cpubl: plain binary integrity check is success
[Tue Aug 19 10:44:12.680 2025] I> Active chain: 0
[Tue Aug 19 10:44:12.680 2025] I> Partition name: A_secure-os
[Tue Aug 19 10:44:12.680 2025] I> Size of partition: 4194304
[Tue Aug 19 10:44:12.680 2025] I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
[Tue Aug 19 10:44:12.680 2025] I> MB2-params @ 0x40060000
[Tue Aug 19 10:44:12.680 2025] I> cpubl_params: nsdram: carveout: 1, encryption: 1
[Tue Aug 19 10:44:12.680 2025] I> NSDRAM carveout base: 0x80000000, size: 0x3eeb70000
[Tue Aug 19 10:44:12.680 2025] I> cpubl: Authentication Finalize Done
[Tue Aug 19 10:44:12.680 2025] I> Binary cpubl loaded successfully at 0x46e600000
[Tue Aug 19 10:44:12.680 2025] I> tos: Authentication Finalize Done
[Tue Aug 19 10:44:12.680 2025] I> Binary tos loaded successfully at 0x47fdc7000
[Tue Aug 19 10:44:12.680 2025] I> Relocating OP-TEE dtb from: 0x47fefec50 to 0x47c000860, size: 0x2886
[Tue Aug 19 10:44:12.680 2025] I> [0] START: 0x80000000, SIZE: 0x3eeb70000
[Tue Aug 19 10:44:12.680 2025] I> [1] START: 0x472000000, SIZE: 0x2000000
[Tue Aug 19 10:44:12.680 2025] I> Setting NS memory ranges to OP-TEE dtb finished.
[Tue Aug 19 10:44:12.680 2025] I> Partition name: A_eks
[Tue Aug 19 10:44:12.680 2025] I> Size of partition: 262144
[Tue Aug 19 10:44:12.680 2025] I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
[Tue Aug 19 10:44:12.680 2025] I> eks: Authentication Finalize Done
[Tue Aug 19 10:44:12.693 2025] I> Binary eks loaded successfully at 0x470000200
[Tue Aug 19 10:44:12.693 2025] I> EKB detected (length: 0x410) @ VA:0x470000200
[Tue Aug 19 10:44:12.693 2025] I> Task: Prepare TOS params (0x5001a1bc)
[Tue Aug 19 10:44:12.693 2025] I> Setting EKB blob info to OPTEE dtb finished.
[Tue Aug 19 10:44:12.693 2025] I> Setting OPTEE arg3: 0x47c000860
[Tue Aug 19 10:44:12.693 2025] I> Task: OEM SC7 context save (0x5001b654)
[Tue Aug 19 10:44:12.693 2025] I> OEM sc7 context saved
[Tue Aug 19 10:44:12.693 2025] I> Task: Disable MSS perf stats (0x50028c88)
[Tue Aug 19 10:44:12.693 2025] I> Task: Program display sticky bits (0x50028c04)
[Tue Aug 19 10:44:12.693 2025] I> Task: Storage device deinit (0x500020bc)
[Tue Aug 19 10:44:12.693 2025] I> Task: SMMU init (0x500183f8)
[Tue Aug 19 10:44:12.693 2025] I> Task: Program GICv3 registers (0x50028d28)
[Tue Aug 19 10:44:12.693 2025] I> Task: Audit firewall settings (0x50025c38)
[Tue Aug 19 10:44:12.693 2025] I> Task: Bootchain failure check (0x500025dc)
[Tue Aug 19 10:44:12.693 2025] I> Current Boot-Chain Slot: 0
[Tue Aug 19 10:44:12.693 2025] I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
[Tue Aug 19 10:44:12.693 2025] I> MB2 finished
[Tue Aug 19 10:44:12.693 2025]   NOTICE:  BL31: v2.6(release):5e1f8b33d
[Tue Aug 19 10:44:12.693 2025] NOTICE:  BL31: Built : 01:34:51, Mar  4 2025
[Tue Aug 19 10:44:12.693 2025] I/TC: Physical secure memory base 0x47c040000 size 0x3fc0000
[Tue Aug 19 10:44:12.725 2025] I/TC:
[Tue Aug 19 10:44:12.789 2025] I/TC: Non-secure external DT found
[Tue Aug 19 10:44:12.956 2025] I/TC: OP-TEE version: 3.22 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Mar  4 09:47:00 UTC 2025 aarch64
[Tue Aug 19 10:44:12.990 2025] I/TC: WARNING: This OP-TEE configuration might be insecure!
[Tue Aug 19 10:44:13.021 2025] I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
[Tue Aug 19 10:44:13.046 2025] I/TC: Primary CPU initializing
[Tue Aug 19 10:44:13.317 2025] I/TC: Test OEM keys are being used. This is insecure for shipping products!
[Tue Aug 19 10:44:13.405 2025] I/TC: Primary CPU switching to normal world boot
[Tue Aug 19 10:44:13.443 2025]
[Tue Aug 19 10:44:13.443 2025] Jetson UEFI firmware (version 6.1-39721438 built on 2025-03-04T09:36:16+00:00)
[Tue Aug 19 10:44:13.464 2025]
[Tue Aug 19 10:44:13.686 2025]
[Tue Aug 19 10:44:13.716 2025]
[Tue Aug 19 10:44:13.732 2025]
[Tue Aug 19 10:44:13.795 2025]
[Tue Aug 19 10:44:13.811 2025]
[Tue Aug 19 10:44:13.830 2025]
[Tue Aug 19 10:44:13.843 2025]
[Tue Aug 19 10:44:13.863 2025]
[Tue Aug 19 10:44:13.876 2025]
[Tue Aug 19 10:44:13.891 2025]
[Tue Aug 19 10:44:13.907 2025]
[Tue Aug 19 10:44:13.924 2025]
[Tue Aug 19 10:44:13.940 2025]
[Tue Aug 19 10:44:13.956 2025]
[Tue Aug 19 10:44:13.971 2025]
[Tue Aug 19 10:44:13.990 2025]
[Tue Aug 19 10:44:14.003 2025]
[Tue Aug 19 10:44:14.022 2025]
[Tue Aug 19 10:44:14.035 2025]
[Tue Aug 19 10:44:14.054 2025]
[Tue Aug 19 10:44:14.070 2025]
[Tue Aug 19 10:44:14.086 2025]
[Tue Aug 19 10:44:14.099 2025]
[Tue Aug 19 10:44:14.116 2025]
[Tue Aug 19 10:44:14.131 2025]
[Tue Aug 19 10:44:14.146 2025]
[Tue Aug 19 10:44:14.163 2025]
[Tue Aug 19 10:44:14.180 2025]
[Tue Aug 19 10:44:14.194 2025]
[Tue Aug 19 10:44:14.214 2025]
[Tue Aug 19 10:44:14.214 2025]   I/TC: Reserved shared memory is disabled
[Tue Aug 19 10:44:14.226 2025] I/TC: Dynamic shared memory is enabled
[Tue Aug 19 10:44:14.242 2025] I/TC: Normal World virtualization support is disabled
[Tue Aug 19 10:44:14.259 2025] I/TC: Asynchronous notifications are disabled
[Tue Aug 19 10:44:14.593 2025] I/TC: WARNING: Test UEFI variable auth key is being used !
[Tue Aug 19 10:44:14.611 2025] I/TC: WARNING: UEFI variable protection is not fully enabled !
[Tue Aug 19 10:44:14.928 2025]
[Tue Aug 19 10:44:14.928 2025] ASSERT [FvbNorFlashStandaloneMm] /dvs/git/dirty/git-master_linux/out/nvidia/optee.t234-uefi/StandaloneMmOptee_RELEASE/edk2-nvidia/Silicon/NVIDIA/Drivers/FvbNorFlashDxe/FvbNorFlashStandaloneMm.c(978): ((BOOLEAN)(0==1))
麻烦看一下是什么原因
启动串口.log (294.1 KB)
Based on the provided context, I will provide a comprehensive answer to the question.
The question seems to be asking about the Jetson Orin NX 16GB module, specifically with JetPack 5.1.5 installed, and a log size of 2941 KB.
From the context, we can gather the following information about the Jetson Orin NX 16GB module:
  • It is part of the NVIDIA Jetson Orin NX series, which includes the Jetson Orin NX 16GB (P3767-0000) and Jetson Orin NX 16GB (P3767-0001) modules.
  • The module has a maximum operating frequency of up to 614 MHz and supports up to 40 TOPS (tera-operations per second) for sparse INT8 operations.
  • It has 2x NVDLA (Deep Learning Accelerator) cores.
  • The module is compatible with the Jetson Orin NX reference carrier board (P3768-0000).
Regarding the log size of 2941 KB, it is not clear what specific information is being logged or what the log is related to. However, based on the context, it appears that the log may be related to the thermal performance or power consumption of the module.
From the provided context, we can see that there are several discussions and documents related to the thermal performance and power consumption of the Jetson Orin NX module, including:
  • “Understanding Orin NX OC and Throttling Limits” (February 7, 2025)
  • “Jetson NX Orin 16GB PCB Flex demand” (February 5, 2025)
  • “Seeking Thermal Clarification” (January 8, 2025)
  • “Flashing Orin NX module without a heatsink” (December 20, 2024)
  • “Jetson Orin NX Direct Sinking Solutions” (November 20, 2024)
These documents and discussions may provide more information about the thermal performance and power consumption of the Jetson Orin NX 16GB module, which could be related to the log size of 2941 KB.
In comparison to other Jetson modules, the Jetson Orin NX 16GB module has a higher maximum operating frequency and supports more TOPS for sparse INT8 operations compared to the Jetson Orin NX 8GB module. However, the log size of 2941 KB is not directly comparable to other modules without more context.
In summary, the Jetson Orin NX 16GB module is a powerful module with advanced features, and the log size of 2941 KB may be related to its thermal performance or power consumption. Further investigation and analysis of the log and related documents would be necessary to provide more specific information.
你的回答没有解决我的问题。我需要通过日志定位无法启动的原因,麻烦查看一下
@WayneWWW
please refer to
