hello:
I use custom board orin NX 16G, software version R36.4.4, in rec recovery boot uart print as fllow:
[0004.249] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0004.254] I> t234-A01-1-Silicon (0x12347) Prod
[0004.259] I> Boot-mode : BPMP Diagnostic
[0004.263] I> Entry timestamp: 0x00000000
[0004.266] I> last_boot_error: 0x0
[0004.269] I> BR-BCT: preprod_dev_sign: 0
[0004.273] I> rst_source: 0x0, rst_level: 0x0
[0004.277] I> Task: Initialize MB2 params
[0004.282] I> MB2-params @ 0x40060000
[0004.285] I> Task: Crypto init
[0004.288] I> Task: Perform MB1 KAT tests
[0004.292] I> Task: NVRNG health check
[0004.295] I> NVRNG: Health check success
[0004.299] I> Task: Secure debug controls
[0004.303] I> Task: strap war set
[0004.306] I> Task: Program NV master stream id
[0004.310] I> Task: Verify boot mode
[0004.316] I> Task: Alias fuses
[0004.319] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0004.327] I> Task: Print SKU type
[0004.330] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0004.335] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0004.339] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0004.343] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0004.348] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0004.352] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0004.356] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0004.361] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0004.365] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0004.369] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0004.374] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0004.378] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0004.382] I> FUSE_SKU_INFO_0 = 0xd3
[0004.385] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0004.389] I> FUSE_PACKAGE_INFO_0 = 0x2
[0004.393] I> SKU: Prod
[0004.395] I> Task: Boost clocks
[0004.398] I> Initializing NAFLL for BPMP_CPU_NIC.
[0004.403] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0004.409] I> BPMP NAFLL lock success.
[0004.412] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0004.417] I> Initializing PLLC2 for AXI_CBB.
[0004.421] I> AXI_CBB : src = 35, divisor = 0
[0004.425] I> Task: Voltage monitor
[0004.428] I> VMON: Vmon re-calibration and fine tuning done
[0004.434] I> Task: UPHY init
[0004.437] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0004.442] I> Task: Boot device init
[0004.445] I> Boot_device: RCM
[0004.448] I> USB configuration success
[0004.452] I> Task: TSC init
[0004.455] I> Task: Enable WDT 5th expiry
[0004.459] I> Task: I2C register
[0004.462] I> Task: Set I2C bus freq
[0004.465] I> Task: Reset FSI
[0004.468] I> Task: Enable clock-mon
[0004.472] I> FMON: Fmon re-programming done
[0004.476] I> Task: Mapper init
[0004.479] I> Task: MB1 fixed firewalls
[0004.485] W> Firewall readback mismatch
[0004.490] I> Task: Load MB2/Applet/FSKP
[0004.494] I> Loading MB2 Applet
[0004.497] I> Slot: 0
[0004.499] I> Binary[21] block-352321536 (partition size: 0x50000)
[0004.505] I> Binary name: MB2-Applet
[0004.508] I> Size of crypto header is 8192
[0004.512] I> Size of crypto header is 8192
[0004.516] I> BCH of MB2-Applet read from storage
[0004.521] I> BCH address is : 0x4004e000
[0004.525] I> MB2-Applet header integrity check is success
[0004.530] I> Binary magic in BCH component 0 is MB2A
[0004.535] I> component binary type is 21
[0004.539] I> Size of crypto header is 8192
[0004.551] I> MB2-Applet binary is read from storage
[0004.557] I> MB2-Applet binary integrity check is success
[0004.562] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x42500)
[0004.569] I> Task: Prepare MB2 params
[0004.573] I> Task: Misc NV security settings
[0004.577] I> NVDEC sticky bits programming done
[0004.581] I> Successfully powergated NVDEC
[0004.585] I> Task: Disable/Reload WDT
[0004.589] I> Task: Program misc carveouts
[0004.593] I> Task: Disable SCPM/POD reset
[0004.596] I> SLCG Global override status := 0x0
[0004.601] I> MB1: MSS reconfig completed
[0004.605] W> Firewall readback mismatch
[0004.608] W> Firewall readback mismatch
[0004.612] W> Firewall readback mismatch
[0004.616] W> Firewall readback mismatch
[0004.619] W> Firewall readback mismatch
[0004.623] W> Firewall readback mismatch
[0004.627] W> Firewall readback mismatch
[0004.630] W> Firewall readback mismatch
[0004.634] W> Firewall readback mismatch
[0004.638] W> Firewall readback mismatch
I> Applet (version: 0.0.0.0-t234-54845784-9fa9acb5)
I> Emulation:
I> Task: Pinmux init
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
I> QSPI Flash: Macronix 64MB
I> QSPI-0l initialized successfully
I> Secondary storage device: SDMMC_BOOT instance: 3
E> Error in command_complete 18000 int_status
E> OCR failed, error = 39390706
E> STORAGE: Failed to open SDMMC: 3.
W> Ignoring init failure for device 0-3
I> Secondary storage device: SDMMC_USER instance: 3
W> Ignoring init failure for device 1-3
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Register exit handlers
I> Task: Enter 3p server
I> Reading fuses
I> Read fuse successfully
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Populate chip info
I> RAM_CODE 0x4000011
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> dump bct
I> strt_pg_num(0) num_of_pgs(16) read_buf(0x40071738)
I> BRBCT integrity check is success
I> Validation passed for 1 copy of BRBCT @ 0
I> Rebooting : reboot-recovery
[0010.750] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0010.755] I> t234-A01-1-Silicon (0x12347) Prod
[0010.760] I> Boot-mode : Coldboot
[0010.763] I> Entry timestamp: 0x00000000
[0010.766] I> last_boot_error: 0x0
[0010.770] I> BR-BCT: preprod_dev_sign: 0
[0010.773] I> rst_source: 0xb, rst_level: 0x1
[0010.777] I> Task: SE error check
[0010.781] I> Task: Bootchain select WAR set
[0010.785] I> Task: Enable SLCG
[0010.788] I> Task: CRC check
[0010.791] I> Task: Initialize MB2 params
[0010.795] I> MB2-params @ 0x40060000
[0010.798] I> Task: Crypto init
[0010.801] I> Task: Perform MB1 KAT tests
[0010.805] I> Task: NVRNG health check
[0010.809] I> NVRNG: Health check success
[0010.812] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0010.818] I> Task: Enabling and initialization of Bandwidth limiter
[0010.825] I> No request to configure MBWT settings for any PC!
[0010.830] I> Task: Secure debug controls
[0010.834] I> Task: strap war set
[0010.837] I> Task: Initialize SOC Therm
[0010.841] I> Task: Program NV master stream id
[0010.845] I> Task: Verify boot mode
[0010.851] I> Task: Alias fuses
[0010.854] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0010.861] I> Task: Print SKU type
[0010.864] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0010.869] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0010.874] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0010.878] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0010.882] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0010.887] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0010.891] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0010.895] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0010.900] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0010.904] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0010.908] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0010.912] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0010.916] I> FUSE_SKU_INFO_0 = 0xd3
[0010.920] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0010.924] I> FUSE_PACKAGE_INFO_0 = 0x2
[0010.928] I> SKU: Prod
[0010.930] I> Task: Boost clocks
[0010.933] I> Initializing NAFLL for BPMP_CPU_NIC.
[0010.938] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0010.943] I> BPMP NAFLL lock success.
[0010.947] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0010.951] I> Initializing PLLC2 for AXI_CBB.
[0010.956] I> AXI_CBB : src = 35, divisor = 0
[0010.960] I> Task: Voltage monitor
[0010.963] I> VMON: Vmon re-calibration and fine tuning done
[0010.968] I> Task: UPHY init
[0010.973] I> HSIO UPHY init done
[0010.976] W> Skipping GBE UPHY config
[0010.980] I> Task: Boot device init
[0010.983] I> Boot_device: RCM
[0010.986] I> USB configuration success
[0010.990] I> Task: TSC init
[0010.993] I> Task: Load membct
[0010.996] I> RAM_CODE 0x4000011
[0010.999] I> Loading MEMBCT
[0011.001] I> Slot: 0
[0011.003] I> Binary[0] block-0 (partition size: 0x40000)
[0011.009] I> Binary name: MEM-BCT-0
[0011.012] I> Size of crypto header is 8192
[0011.016] I> Size of crypto header is 8192
[0011.020] I> BCH of MEM-BCT-0 read from storage
[0011.024] I> BCH address is : 0x40050000
[0011.028] I> MEM-BCT-0 header integrity check is success
[0011.033] I> Binary magic in BCH component 0 is MEM0
[0011.038] I> component binary type is 0
[0011.044] I> MEM-BCT-0 binary is read from storage
[0011.049] I> MEM-BCT-0 binary integrity check is success
[0011.054] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0011.061] I> RAM_CODE 0x4000011
[0011.066] I> RAM_CODE 0x4000011
[0011.070] I> Task: Load Page retirement list
[0011.074] I> Task: SDRAM params override
[0011.078] I> Task: Save mem-bct info
[0011.081] I> Task: Carveout allocate
[0011.085] I> Update CCPLEX IST carveout from MB1-BCT
[0011.090] I> ECC region[0]: Start:0x0, End:0x0
[0011.094] I> ECC region[1]: Start:0x0, End:0x0
[0011.098] I> ECC region[2]: Start:0x0, End:0x0
[0011.102] I> ECC region[3]: Start:0x0, End:0x0
[0011.107] I> ECC region[4]: Start:0x0, End:0x0
[0011.111] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0011.117] I> Non-ECC region[1]: Start:0x0, End:0x0
[0011.122] I> Non-ECC region[2]: Start:0x0, End:0x0
[0011.126] I> Non-ECC region[3]: Start:0x0, End:0x0
[0011.131] I> Non-ECC region[4]: Start:0x0, End:0x0
[0011.142] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0011.149] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0011.155] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0011.163] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000
[0011.170] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0011.177] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0011.184] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0011.191] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0011.198] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0011.205] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0011.212] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0011.219] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0011.226] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0011.233] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0011.240] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0011.246] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0011.253] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0011.260] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0011.267] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0011.274] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0011.281] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0011.288] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0011.295] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0011.302] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0011.309] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0011.316] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0011.323] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0011.329] I> allocated(CO:46) base:0x440000000 size:0x20000000 align: 0x20000000
[0011.337] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0011.344] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0011.351] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0011.357] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0011.364] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0011.371] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0011.378] I> Task: Thermal check
[0011.381] I> Using min_chip_limit as min_tmon_limit
[0011.385] I> Using max_chip_limit as max_tmon_limit
[0011.390] I> BCT max_tmon_limit = 105
[0011.394] I> BCT min_tmon_limit = -28
[0011.397] I> BCT max_tmon_limit = 105
[0011.401] I> BCT min_tmon_limit = -28
[0011.404] I> SKU specific max_chip_limit = 105
[0011.408] I> SKU specific min_chip_limit = -28
[0011.413] I> BCT max_chip_limit = 105
[0011.416] I> BCT min_chip_limit = -28
[0011.420] I> enable_soctherm_polling = 0
[0011.423] I> max temp read = 30
[0011.426] I> min temp read = 30
[0011.429] I> Enabling thermtrip
[0011.432] I> Task: Update FSI SCR with thermal fuse data
[0011.437] I> Task: Enable WDT 5th expiry
[0011.441] I> Task: I2C register
[0011.444] I> Task: Set I2C bus freq
[0011.448] I> Task: Reset FSI
[0011.450] I> Task: Pinmux init
[0011.453] I> skipped mmio_addr = 0x9240008
[0011.457] I> skipped mmio_addr = 0x9240000
[0011.461] I> skipped mmio_addr = 0x9240010
[0011.465] I> skipped mmio_addr = 0x9240018
[0011.469] I> skipped mmio_addr = 0x9240020
[0011.473] I> skipped mmio_addr = 0x9240030
[0011.477] I> skipped mmio_addr = 0x9240028
[0011.481] I> skipped mmio_addr = 0x9240038
[0011.485] I> skipped mmio_addr = 0x9240040
[0011.489] I> skipped mmio_addr = 0x9240048
[0011.493] I> skipped mmio_addr = 0x9241000
[0011.497] I> skipped mmio_addr = 0x9241008
[0011.501] I> skipped mmio_addr = 0x9241010
[0011.505] I> skipped mmio_addr = 0x9241018
[0011.509] I> skipped mmio_addr = 0x9241020
[0011.513] I> skipped mmio_addr = 0x9241028
[0011.517] I> skipped mmio_addr = 0x9241030
[0011.520] I> skipped mmio_addr = 0x9241038
[0011.524] I> skipped mmio_addr = 0x9241040
[0011.528] I> skipped mmio_addr = 0x9242000
[0011.532] I> skipped mmio_addr = 0x9242008
[0011.536] I> Task: Prod config init
[0011.540] I> Task: Pad voltage init
[0011.543] I> Task: Prod init
[0011.546] I> Task: Program rst req config reg
[0011.550] I> Task: Common rail init
[0011.553] I> DONE: Thermal config
[0011.557] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0011.565] I> DONE: SOC rail config
[0011.569] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0011.576] I> DONE: MEMIO rail config
[0011.580] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0011.586] I> DONE: GPU rail info
[0011.589] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0011.595] I> DONE: CV rail info
[0011.598] I> Task: Mem clock src
[0011.601] I> Task: Misc. board config
[0011.605] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0011.611] I> Task: SDRAM init
[0011.614] I> MemoryType: 4 MemBctRevision: 2
[0011.620] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 2
[0011.628] I> MSS CAR: Init PLLM
[0011.631] I> MSS CAR: Init PLLHUB
[0011.636] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0011.647] I> SDRAM initialized!
[0011.650] I> SDRAM Size in Total 0x400000000
[0011.654] I> Task: Dram Ecc scrub
[0011.657] I> Task: DRAM alias check
[0011.664] I> Task: Program NSDRAM carveout
[0011.668] I> NSDRAM carveout encryption is enabled
[0011.672] I> Program NSDRAM carveout
[0011.676] I> Task: Register checker
[0011.679] I> Task: Enable clock-mon
[0011.683] I> FMON: Fmon re-programming done
[0011.687] I> Task: Mapper init
[0011.690] I> Task: SC7 Context Init
[0011.694] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0011.699] I> Task: CCPLEX IST init
[0011.703] I> Task: CPU WP0
[0011.705] I> Loading MCE
[0011.708] I> Slot: 0
[0011.710] I> Binary[8] block-134217728 (partition size: 0x80000)
[0011.716] I> Binary name: MCE
[0011.718] I> Size of crypto header is 8192
[0011.722] I> Size of crypto header is 8192
[0000.063] I> MB1 (version: 1.4.0.7-t234-54845784-56c609fa)
[0000.069] I> t234-A01-1-Silicon (0x12347) Prod
[0000.073] I> Boot-mode : Coldboot
[0000.076] I> Entry timestamp: 0x00000000
[0000.080] I> last_boot_error: 0x0
[0000.083] I> BR-BCT: preprod_dev_sign: 0
[0000.087] I> rst_source: 0x17, rst_level: 0x1
[0000.091] I> Task: SE error check
[0000.094] I> Task: Bootchain select WAR set
[0000.098] I> Task: Enable SLCG
[0000.101] I> Task: CRC check
[0000.104] I> Task: Initialize MB2 params
[0000.108] I> MB2-params @ 0x40060000
[0000.112] I> Task: Crypto init
[0000.115] I> Task: Perform MB1 KAT tests
[0000.119] I> Task: NVRNG health check
[0000.122] I> NVRNG: Health check success
[0000.126] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.132] I> Task: Enabling and initialization of Bandwidth limiter
[0000.138] I> No request to configure MBWT settings for any PC!
[0000.144] I> Task: Secure debug controls
[0000.148] I> Task: strap war set
[0000.151] I> Task: Initialize SOC Therm
[0000.154] I> Task: Program NV master stream id
[0000.159] I> Task: Verify boot mode
[0000.164] I> Task: Alias fuses
[0000.168] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.175] I> Task: Print SKU type
[0000.178] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.183] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.188] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.192] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.196] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.200] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.205] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.209] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.214] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.218] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.222] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.226] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.230] I> FUSE_SKU_INFO_0 = 0xd3
[0000.234] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.238] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.241] I> SKU: Prod
[0000.244] I> Task: Boost clocks
[0000.247] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.252] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.257] I> BPMP NAFLL lock success.
[0000.261] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.265] I> Initializing PLLC2 for AXI_CBB.
[0000.269] I> AXI_CBB : src = 35, divisor = 0
[0000.273] I> Task: Voltage monitor
[0000.277] I> VMON: Vmon re-calibration and fine tuning done
[0000.282] I> Task: UPHY init
[0000.287] I> HSIO UPHY init done
[0000.290] W> Skipping GBE UPHY config
[0000.294] I> Task: Boot device init
[0000.297] I> Boot_device: QSPI_FLASH instance: 0
[0000.302] I> Qspi clock source : pllc_out0
[0000.306] I> QSPI Flash: Macronix 64MB
[0000.309] I> QSPI-0l initialized successfully
[0000.314] I> Task: TSC init
[0000.316] I> Task: Load membct
[0000.319] I> RAM_CODE 0x4000011
[0000.322] I> Loading MEMBCT
[0000.325] I> Slot: 0
[0000.327] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.333] I> Binary name: MEM-BCT-0
[0000.336] I> Size of crypto header is 8192
[0000.340] I> Size of crypto header is 8192
[0000.344] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.350] I> BCH of MEM-BCT-0 read from storage
[0000.354] I> BCH address is : 0x40050000
[0000.358] I> MEM-BCT-0 header integrity check is success
[0000.363] I> Binary magic in BCH component 0 is MEM0
[0000.368] I> component binary type is 0
[0000.372] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.379] I> MEM-BCT-0 binary is read from storage
[0000.384] I> MEM-BCT-0 binary integrity check is success
[0000.389] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.395] I> RAM_CODE 0x4000011
[0000.401] I> RAM_CODE 0x4000011
[0000.405] I> Task: Load Page retirement list
[0000.409] I> Task: SDRAM params override
[0000.413] I> Task: Save mem-bct info
[0000.416] I> Task: Carveout allocate
[0000.419] I> RCM blob carveout will not be allocated
[0000.424] I> Update CCPLEX IST carveout from MB1-BCT
[0000.429] I> ECC region[0]: Start:0x0, End:0x0
[0000.433] I> ECC region[1]: Start:0x0, End:0x0
[0000.438] I> ECC region[2]: Start:0x0, End:0x0
[0000.442] I> ECC region[3]: Start:0x0, End:0x0
[0000.446] I> ECC region[4]: Start:0x0, End:0x0
[0000.450] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.456] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.461] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.466] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.470] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.481] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.488] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0000.495] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0000.502] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000
[0000.509] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0000.516] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0000.523] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0000.530] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0000.537] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0000.544] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0000.551] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0000.558] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0000.565] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0000.572] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0000.579] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0000.586] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0000.593] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0000.600] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0000.607] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0000.613] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0000.620] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0000.627] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0000.634] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0000.641] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0000.648] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0000.655] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0000.662] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0000.669] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0000.676] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0000.682] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0000.689] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0000.696] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0000.703] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0000.709] I> Task: Thermal check
[0000.712] I> Using min_chip_limit as min_tmon_limit
[0000.717] I> Using max_chip_limit as max_tmon_limit
[0000.722] I> BCT max_tmon_limit = 105
[0000.725] I> BCT min_tmon_limit = -28
[0000.729] I> BCT max_tmon_limit = 105
[0000.732] I> BCT min_tmon_limit = -28
[0000.736] I> SKU specific max_chip_limit = 105
[0000.740] I> SKU specific min_chip_limit = -28
[0000.744] I> BCT max_chip_limit = 105
[0000.748] I> BCT min_chip_limit = -28
[0000.751] I> enable_soctherm_polling = 0
[0000.755] I> max temp read = 32
[0000.758] I> min temp read = 32
[0000.761] I> Enabling thermtrip
[0000.764] I> Task: Update FSI SCR with thermal fuse data
[0000.769] I> Task: Enable WDT 5th expiry
[0000.773] I> Task: I2C register
[0000.776] I> Task: Set I2C bus freq
[0000.779] I> Task: Reset FSI
[0000.782] I> Task: Pinmux init
[0000.785] I> skipped mmio_addr = 0x9240008
[0000.789] I> skipped mmio_addr = 0x9240000
[0000.793] I> skipped mmio_addr = 0x9240010
[0000.797] I> skipped mmio_ 8
[0001.087] I> Size of crypto header is 8192
[0001.090] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.099] I> MCE binary is read from storage
[0001.103] I> MCE binary integrity check is success
[0001.108] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.114] I> Size of crypto header is 8192
[0001.125] I> Size of crypto header is 8192
[0001.129] I> Sending WP0 mailbox command to PSC
[0001.138] I> Task: XUSB Powergate
[0001.141] I> Skipping powergate XUSB.
[0001.145] I> Task: MB1 fixed firewalls
[0001.151] W> Firewall readback mismatch
[0001.156] I> Task: Load bpmp-fw
[0001.159] I> Slot: 0
[0001.161] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.167] I> Binary name: BPMP_FW
[0001.170] I> Size of crypto header is 8192
[0001.174] I> Size of crypto header is 8192
[0001.178] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.184] I> BCH of BPMP_FW read from storage
[0001.188] I> BCH address is : 0x807fe000
[0001.192] I> BPMP_FW header integrity check is success
[0001.197] I> Binary magic in BCH component 0 is BPMF
[0001.202] I> component binary type is 15
[0001.205] I> Size of crypto header is 8192
[0001.209] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.227] I> BPMP_FW binary is read from storage
[0001.233] I> BPMP_FW binary integrity check is success
[0001.238] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8c00)
[0001.245] I> Slot: 0
[0001.247] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.253] I> Binary name: BPMP_FW_DTB
[0001.256] I> Size of crypto header is 8192
[0001.260] I> Size of crypto header is 8192
[0001.264] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.270] I> BCH of BPMP_FW_DTB read from storage
[0001.275] I> BCH address is : 0x807fc000
[0001.279] I> BPMP_FW_DTB header integrity check is success
[0001.284] I> Binary magic in BCH component 0 is BPMD
[0001.289] I> component binary type is 16
[0001.292] I> Size of crypto header is 8192
[0001.296] I> strt_pg_num(13072) num_of_pgs(733) read_buf(0x807a05f0)
[0001.307] I> BPMP_FW_DTB binary is read from storage
[0001.312] I> BPMP_FW_DTB binary integrity check is success
[0001.318] I> Binary BPMP_FW_DTB loaded successfully at 0x807a05f0 (0x5b940)
[0001.324] I> Task: BPMP fw ast config
[0001.328] I> Task: Load psc-fw
[0001.331] I> Slot: 0
[0001.333] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.339] I> Binary name: PSC_FW
[0001.342] I> Size of crypto header is 8192
[0001.346] I> Size of crypto header is 8192
[0001.349] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.356] I> BCH of PSC_FW read from storage
[0001.360] I> BCH address is : 0x80ffe000
[0001.364] I> PSC_FW header integrity check is success
[0001.369] I> Binary magic in BCH component 0 is PFWP
[0001.373] I> component binary type is 17
[0001.377] I> Size of crypto header is 8192
[0001.381] I> strt_pg_num(21264) num_of_pgs(591) read_buf(0x80fb4200)
[0001.391] I> PSC_FW binary is read from storage
[0001.396] I> PSC_FW binary integrity check is success
[0001.400] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.407] I> Task: Load nvdec-fw
[0001.410] I> Slot: 0
[0001.412] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.418] I> Binary name: NVDEC
[0001.420] I> Size of crypto header is 8192
[0001.424] I> Size of crypto header is 8192
[0001.428] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.435] I> BCH of NVDEC read from storage
[0001.439] I> BCH address is : 0x800fe000
[0001.442] I> NVDEC header integrity check is success
[0001.447] I> Binary magic in BCH component 0 is NDEC
[0001.452] I> component binary type is 7
[0001.456] I> Size of crypto header is 8192
[0001.460] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.469] I> NVDEC binary is read from storage
[0001.474] I> NVDEC binary integrity check is success
[0001.479] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.485] I> Size of crypto header is 8192
[0001.496] I> Task: Load tsec-fw
[0001.499] I> TSEC-FW load support not enabled
[0001.504] I> Task: GPIO interrupt map
[0001.507] I> Task: SC7 context save
[0001.511] I> Slot: 0
[0001.513] I> Binary[27] block-0 (partition size: 0x100000)
[0001.518] I> Binary name: BR_BCT
[0001.521] I> Size of crypto header is 8192
[0001.525] I> Size of crypto header is 8192
[0001.529] I> Size of crypto header is 8192
[0001.533] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.539] I> BR_BCT binary is read from storage
[0001.543] I> BR_BCT binary integrity check is success
[0001.548] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.554] I> Slot: 0
[0001.556] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.562] I> Binary name: SC7-FW
[0001.565] I> Size of crypto header is 8192
[0001.569] I> Size of crypto header is 8192
[0001.573] I> Size of crypto header is 8192
[0001.577] I> Size of crypto header is 8192
[0001.581] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.587] I> BCH of SC7-FW read from storage
[0001.591] I> BCH address is : 0xa0002000
[0001.595] I> SC7-FW header integrity check is success
[0001.600] I> Binary magic in BCH component 0 is WB0B
[0001.605] I> component binary type is 13
[0001.608] I> Size of crypto header is 8192
[0001.612] I> strt_pg_num(23824) num_of_pgs(350) read_buf(0xa0004000)
[0001.621] I> SC7-FW binary is read from storage
[0001.625] I> SC7-FW binary integrity check is success
[0001.630] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2bb20)
[0001.637] I> Slot: 0
[0001.639] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.644] I> Binary name: PSC_RF
[0001.647] I> Size of crypto header is 8192
[0001.651] I> Size of crypto header is 8192
[0001.655] I> Size of crypto header is 8192
[0001.659] I> Size of crypto header is 8192
[0001.663] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002fb20)
[0001.669] I> BCH of PSC_RF read from storage
[0001.673] I> BCH address is : 0xa002fb20
[0001.677] I> PSC_RF header integrity check is success
[0001.682] I> Binary magic in BCH component 0 is PSCR
[0001.687] I> component binary type is 22
[0001.691] I> Size of crypto header is 8192
[0001.695] I> strt_pg_num(24208) num_of_pgs(256) read_buf(0xa0031b20)
[0001.702] I> PSC_RF binary is read from storage
[0001.707] I> PSC_RF binary integrity check is success
[0001.712] I> Binary PSC_RF loaded successfully at 0xa0031b20 (0x20000)
[0001.721] I> Task: Save WP0 payload to SC7 ctx
[0001.726] I> Task: Load MB2rf binary to SC7 ctx
[0001.730] I> Slot: 0
[0001.732] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.738] I> Binary name: MB2_RF
[0001.741] I> Size of crypto header is 8192
[0001.745] I> Size of crypto header is 8192
[0001.749] I> Size of crypto header is 8192
[0001.752] I> Size of crypto header is 8192
[0001.756] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.763] I> BCH of MB2_RF read from storage
[0001.767] I> BCH address is : 0xa00d5d10
[0001.771] I> MB2_RF header integrity check is success
[0001.776] I> Binary magic in BCH component 0 is MB2R
[0001.780] I> component binary type is 14
[0001.784] I> Size of crypto header is 8192
[0001.788] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.796] I> MB2_RF binary is read from storage
[0001.800] I> MB2_RF binary integrity check is success
[0001.805] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf40)
[0001.811] I> Task: Save fuse alias data to SC7 ctx
[0001.816] I> Task: Save PMIC data to SC7 ctx
[0001.820] I> Task: Save Pinmux data to SC7 ctx
[0001.824] I> Task: Save Pad Voltage data to SC7 ctx
[0001.830] E> SC7_CONTEXT_SAVE: pad voltage config table is empty in MB1 BCT.
[0001.837] E> Top caller module: SC7_CONTEXT_SAVE, error module: SC7_CONTEXT_SAVE, reason: 0x28, aux_info: 0x08
[0001.847] I> Task: Save controller prod data to SC7 ctx
[0001.852] I> Task: Save prod cfg data to SC7 ctx
[0001.856] I> Task: Save I2C bus freq data to SC7 ctx
[0001.861] I> Task: Save SOCTherm data to SC7 ctx
[0001.865] I> Task: Save FMON data to SC7 ctx
[0001.870] I> Task: Save VMON data to SC7 ctx
[0001.874] I> Task: Save TZDRAM data to SC7 ctx
[0001.878] I> Task: Save GPIO int data to SC7 ctx
[0001.882] I> Task: Save clock data to SC7 ctx
[0001.887] I> Task: Save debug data to SC7 ctx
[0001.891] I> Task: Save MBWT data to SC7 ctx
[0001.895] E> SC7_CONTEXT_SAVE: Fatal error SC7 context save failed.
[0001.902] C> Task 0x45 failed (err: 0x37371039)
[0001.906] E> Top caller module: SC7_CONTEXT_SAVE, error module: SC7_CONTEXT_SAVE, reason: 0x39, aux_info: 0x10
[0001.916] C> Boot Info Table status dump :
01111111001110001111111111111111111111111111101110111111011111111101
I have change filetegra234-mb2-bct-misc-p3767-0000.dts in cvb_eeprom_read_size = <0x0>;,
but I use reComputer J4012 board (remove eeprom)is ok,What matters do I need to pay attention to?The core board and hard drive boot normally on both the self-developed board and J4012 board, only the USB flash of the rec boot reports an error on the self-developed board,Can you help me identify possible issues there? J4012 board ok uart print as fllow:
[0000.870] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.875] I> t234-A01-1-Silicon (0x12347) Prod
[0000.879] I> Boot-mode : BPMP Diagnostic
[0000.883] I> Entry timestamp: 0x00000000
[0000.887] I> last_boot_error: 0x0
[0000.890] I> BR-BCT: preprod_dev_sign: 0
[0000.894] I> rst_source: 0x0, rst_level: 0x0
[0000.898] I> Task: Initialize MB2 params
[0000.902] I> MB2-params @ 0x40060000
[0000.906] I> Task: Crypto init
[0000.909] I> Task: Perform MB1 KAT tests
[0000.912] I> Task: NVRNG health check
[0000.916] I> NVRNG: Health check success
[0000.920] I> Task: Secure debug controls
[0000.924] I> Task: strap war set
[0000.927] I> Task: Program NV master stream id
[0000.931] I> Task: Verify boot mode
[0000.937] I> Task: Alias fuses
[0000.940] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.947] I> Task: Print SKU type
[0000.950] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.955] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.959] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.964] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.968] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.972] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.977] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.981] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.985] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.990] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.994] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.998] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0001.002] I> FUSE_SKU_INFO_0 = 0xd3
[0001.005] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0001.010] I> FUSE_PACKAGE_INFO_0 = 0x2
[0001.013] I> SKU: Prod
[0001.015] I> Task: Boost clocks
[0001.018] I> Initializing NAFLL for BPMP_CPU_NIC.
[0001.023] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0001.029] I> BPMP NAFLL lock success.
[0001.032] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0001.037] I> Initializing PLLC2 for AXI_CBB.
[0001.041] I> AXI_CBB : src = 35, divisor = 0
[0001.045] I> Task: Voltage monitor
[0001.048] I> VMON: Vmon re-calibration and fine tuning done
[0001.054] I> Task: UPHY init
[0001.057] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0001.062] I> Task: Boot device init
[0001.066] I> Boot_device: RCM
[0001.069] I> USB configuration success
[0001.072] I> Task: TSC init
[0001.075] I> Task: Enable WDT 5th expiry
[0001.079] I> Task: I2C register
[0001.082] I> Task: Set I2C bus freq
[0001.085] I> Task: Reset FSI
[0001.088] I> Task: Enable clock-mon
[0001.092] I> FMON: Fmon re-programming done
[0001.096] I> Task: Mapper init
[0001.099] I> Task: MB1 fixed firewalls
[0001.105] W> Firewall readback mismatch
[0001.110] I> Task: Load MB2/Applet/FSKP
[0001.114] I> Loading MB2 Applet
[0001.117] I> Slot: 0
[0001.119] I> Binary[21] block-352321536 (partition size: 0x50000)
[0001.125] I> Binary name: MB2-Applet
[0001.128] I> Size of crypto header is 8192
[0001.132] I> Size of crypto header is 8192
[0001.137] I> BCH of MB2-Applet read from storage
[0001.141] I> BCH address is : 0x4004e000
[0001.145] I> MB2-Applet header integrity check is success
[0001.150] I> Binary magic in BCH component 0 is MB2A
[0001.155] I> component binary type is 21
[0001.159] I> Size of crypto header is 8192
[0001.172] I> MB2-Applet binary is read from storage
[0001.177] I> MB2-Applet binary integrity check is success
[0001.182] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x42500)
[0001.189] I> Task: Prepare MB2 params
[0001.193] I> Task: Misc NV security settings
[0001.197] I> NVDEC sticky bits programming done
[0001.202] I> Successfully powergated NVDEC
[0001.205] I> Task: Disable/Reload WDT
[0001.209] I> Task: Program misc carveouts
[0001.213] I> Task: Disable SCPM/POD reset
[0001.217] I> SLCG Global override status := 0x0
[0001.221] I> MB1: MSS reconfig completed
[0001.225] W> Firewall readback mismatch
[0001.229] W> Firewall readback mismatch
[0001.232] W> Firewall readback mismatch
[0001.236] W> Firewall readback mismatch
[0001.240] W> Firewall readback mismatch
[0001.243] W> Firewall readback mismatch
[0001.247] W> Firewall readback mismatch
[0001.251] W> Firewall readback mismatch
[0001.254] W> Firewall readback mismatch
[0001.258] W> Firewall readback mismatch
I> Emulation:
E> Error in command_complete 18001 int_status
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> dump bct
[0010.754] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0010.759] I> t234-A01-1-Silicon (0x12347) Prod
[0010.763] I> Boot-mode : Coldboot
[0010.767] I> Entry timestamp: 0x00000000
[0010.770] I> last_boot_error: 0x0
[0010.773] I> BR-BCT: preprod_dev_sign: 0
[0010.777] I> rst_source: 0xb, rst_level: 0x1
[0010.781] I> Task: SE error check
[0010.784] I> Task: Bootchain select WAR set
[0010.788] I> Task: Enable SLCG
[0010.791] I> Task: CRC check
[0010.794] I> Task: Initialize MB2 params
[0010.799] I> MB2-params @ 0x40060000
[0010.802] I> Task: Crypto init
[0010.805] I> Task: Perform MB1 KAT tests
[0010.809] I> Task: NVRNG health check
[0010.812] I> NVRNG: Health check success
[0010.816] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0010.822] I> Task: Enabling and initialization of Bandwidth limiter
[0010.828] I> No request to configure MBWT settings for any PC!
[0010.834] I> Task: Secure debug controls
[0010.838] I> Task: strap war set
[0010.841] I> Task: Initialize SOC Therm
[0010.845] I> Task: Program NV master stream id
[0010.849] I> Task: Verify boot mode
[0010.855] I> Task: Alias fuses
[0010.858] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0010.865] I> Task: Print SKU type
[0010.869] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0010.874] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0010.878] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0010.882] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0010.887] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0010.891] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0010.895] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0010.900] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0010.904] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0010.908] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0010.913] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0010.917] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0010.921] I> FUSE_SKU_INFO_0 = 0xd3
[0010.924] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0010.928] I> FUSE_PACKAGE_INFO_0 = 0x2
[0010.932] I> SKU: Prod
[0010.934] I> Task: Boost clocks
[0010.937] I> Initializing NAFLL for BPMP_CPU_NIC.
[0010.942] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0010.948] I> BPMP NAFLL lock success.
[0010.951] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0010.956] I> Initializing PLLC2 for AXI_CBB.
[0010.960] I> AXI_CBB : src = 35, divisor = 0
[0010.964] I> Task: Voltage monitor
[0010.967] I> VMON: Vmon re-calibration and fine tuning done
[0010.973] I> Task: UPHY init
[0010.978] I> HSIO UPHY init done
[0010.981] W> Skipping GBE UPHY config
[0010.984] I> Task: Boot device init
[0010.987] I> Boot_device: RCM
[0010.990] I> USB configuration success
[0010.994] I> Task: TSC init
[0010.997] I> Task: Load membct
[0011.000] I> RAM_CODE 0x4000011
[0011.003] I> Loading MEMBCT
[0011.006] I> Slot: 0
[0011.008] I> Binary[0] block-0 (partition size: 0x40000)
[0011.013] I> Binary name: MEM-BCT-0
[0011.020] I> Size of crypto header is 8192
[0011.024] I> BCH of MEM-BCT-0 read from storage
[0011.029] I> BCH address is : 0x40050000
[0011.033] I> MEM-BCT-0 header integrity check is success
[0011.038] I> Binary magic in BCH component 0 is MEM0
[0011.043] I> component binary type is 0
[0011.048] I> MEM-BCT-0 binary is read from storage
[0011.053] I> MEM-BCT-0 binary integrity check is success
[0011.058] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0011.065] I> RAM_CODE 0x4000011
[0011.070] I> RAM_CODE 0x4000011
[0011.074] I> Task: Load Page retirement list
[0011.078] I> Task: SDRAM params override
[0011.082] I> Task: Save mem-bct info
[0011.086] I> Task: Carveout allocate
[0011.089] I> Update CCPLEX IST carveout from MB1-BCT
[0011.094] I> ECC region[0]: Start:0x0, End:0x0
[0011.098] I> ECC region[1]: Start:0x0, End:0x0
[0011.103] I> ECC region[2]: Start:0x0, End:0x0
[0011.107] I> ECC region[3]: Start:0x0, End:0x0
[0011.111] I> ECC region[4]: Start:0x0, End:0x0
[0011.115] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0011.121] I> Non-ECC region[1]: Start:0x0, End:0x0
[0011.126] I> Non-ECC region[2]: Start:0x0, End:0x0
[0011.131] I> Non-ECC region[3]: Start:0x0, End:0x0
[0011.135] I> Non-ECC region[4]: Start:0x0, End:0x0
[0011.146] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0011.153] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0011.160] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0011.167] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000
[0011.174] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0011.181] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0011.188] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0011.195] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0011.202] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0011.209] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0011.216] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0011.223] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0011.230] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0011.237] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0011.244] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0011.251] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0011.258] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0011.265] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0011.272] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0011.279] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0011.285] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0011.292] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0011.299] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0011.306] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0011.313] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0011.320] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0011.327] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0011.334] I> allocated(CO:46) base:0x440000000 size:0x20000000 align: 0x20000000
[0011.341] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0011.348] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0011.355] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0011.362] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0011.368] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0011.375] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0011.382] I> Task: Thermal check
[0011.385] I> Using min_chip_limit as min_tmon_limit
[0011.390] I> Using max_chip_limit as max_tmon_limit
[0011.394] I> BCT max_tmon_limit = 105
[0011.398] I> BCT min_tmon_limit = -28
[0011.401] I> BCT max_tmon_limit = 105
[0011.405] I> BCT min_tmon_limit = -28
[0011.408] I> SKU specific max_chip_limit = 105
[0011.413] I> SKU specific min_chip_limit = -28
[0011.417] I> BCT max_chip_limit = 105
[0011.420] I> BCT min_chip_limit = -28
[0011.424] I> enable_soctherm_polling = 0
[0011.428] I> max temp read = 36
[0011.431] I> min temp read = 36
[0011.434] I> Enabling thermtrip
[0011.437] I> Task: Update FSI SCR with thermal fuse data
[0011.442] I> Task: Enable WDT 5th expiry
[0011.445] I> Task: I2C register
[0011.448] I> Task: Set I2C bus freq
[0011.452] I> Task: Reset FSI
[0011.455] I> Task: Pinmux init
[0011.458] I> skipped mmio_addr = 0x9240008
[0011.462] I> skipped mmio_addr = 0x9240000
[0011.466] I> skipped mmio_addr = 0x9240010
[0011.470] I> skipped mmio_addr = 0x9240018
[0011.474] I> skipped mmio_addr = 0x9240020
[0011.477] I> skipped mmio_addr = 0x9240030
[0011.481] I> skipped mmio_addr = 0x9240028
[0011.485] I> skipped mmio_addr = 0x9240038
[0011.489] I> skipped mmio_addr = 0x9240040
[0011.493] I> skipped mmio_addr = 0x9240048
[0011.497] I> skipped mmio_addr = 0x9241000
[0011.501] I> skipped mmio_addr = 0x9241008
[0011.505] I> skipped mmio_addr = 0x9241010
[0011.509] I> skipped mmio_addr = 0x9241018
[0011.513] I> skipped mmio_addr = 0x9241020
[0011.517] I> skipped mmio_addr = 0x9241028
[0011.521] I> skipped mmio_addr = 0x9241030
[0011.525] I> skipped mmio_addr = 0x9241038
[0011.529] I> skipped mmio_addr = 0x9241040
[0011.533] I> skipped mmio_addr = 0x9242000
[0011.537] I> skipped mmio_addr = 0x9242008
[0011.541] I> Task: Prod config init
[0011.544] I> Task: Pad voltage init
[0011.547] I> Task: Prod init
[0011.550] I> Task: Program rst req config reg
[0011.554] I> Task: Common rail init
[0011.558] I> DONE: Thermal config
[0011.561] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0011.570] I> DONE: SOC rail config
[0011.573] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0011.580] I> DONE: MEMIO rail config
[0011.584] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0011.590] I> DONE: GPU rail info
[0011.594] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0011.600] I> DONE: CV rail info
[0011.603] I> Task: Mem clock src
[0011.606] I> Task: Misc. board config
[0011.610] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0011.616] I> Task: SDRAM init
[0011.619] I> MemoryType: 4 MemBctRevision: 2
[0011.625] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 2
[0011.633] I> MSS CAR: Init PLLM
[0011.636] I> MSS CAR: Init PLLHUB
[0011.641] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0011.652] I> SDRAM initialized!
[0011.655] I> SDRAM Size in Total 0x400000000
[0011.659] I> Task: Dram Ecc scrub
[0011.662] I> Task: DRAM alias check
[0011.669] I> Task: Program NSDRAM carveout
[0011.673] I> NSDRAM carveout encryption is enabled
[0011.678] I> Program NSDRAM carveout
[0011.681] I> Task: Register checker
[0011.685] I> Task: Enable clock-mon
[0011.689] I> FMON: Fmon re-programming done
[0011.693] I> Task: Mapper init
[0011.696] I> Task: SC7 Context Init
[0011.699] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0011.705] I> Task: CCPLEX IST init
[0011.708] I> Task: CPU WP0
[0011.711] I> Loading MCE
[0011.713] I> Slot: 0
[0011.715] I> Binary[8] block-134217728 (partition size: 0x80000)
[0011.721] I> Binary name: MCE
[0011.724] I> Size of crypto header is 8192
[0011.728] I> Size of crypto header is 8192
[0014.492] I> BCH of MCE read from storage
[0014.496] I> BCH address is : 0x4003e000
[0014.499] I> MCE header integrity check is success
[0014.504] I> Binary magic in BCH component 0 is MTSM
[0014.509] I> component binary type is 8
[0014.513] I> Size of crypto header is 8192
[0014.520] I> MCE binary is read from storage
[0014.524] I> MCE binary integrity check is success
[0014.529] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0014.535] I> Size of crypto header is 8192
[0014.539] I> Sending WP0 mailbox command to PSC
[0014.548] I> Task: XUSB Powergate
[0014.551] I> Skipping powergate XUSB.
[0014.555] I> Task: MB1 fixed firewalls
[0014.561] W> Firewall readback mismatch
[0014.566] I> Task: Load bpmp-fw
[0014.569] I> Slot: 0
[0014.571] I> Binary[15] block-251658240 (partition size: 0x180000)
[0014.577] I> Binary name: BPMP_FW
[0014.580] I> Size of crypto header is 8192
[0014.584] I> Size of crypto header is 8192
[0014.589] I> BCH of BPMP_FW read from storage
[0014.593] I> BCH address is : 0x807fe000
[0014.597] I> BPMP_FW header integrity check is success
[0014.602] I> Binary magic in BCH component 0 is BPMF
[0014.606] I> component binary type is 15
[0014.610] I> Size of crypto header is 8192
[0014.632] I> BPMP_FW binary is read from storage
[0014.638] I> BPMP_FW binary integrity check is success
[0014.643] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0014.650] I> Slot: 0
[0014.652] I> Binary[16] block-268435456 (partition size: 0x400000)
[0014.658] I> Binary name: BPMP_FW_DTB
[0014.661] I> Size of crypto header is 8192
[0014.665] I> Size of crypto header is 8192
[0014.669] I> BCH of BPMP_FW_DTB read from storage
[0014.674] I> BCH address is : 0x807fc000
[0014.678] I> BPMP_FW_DTB header integrity check is success
[0014.683] I> Binary magic in BCH component 0 is BPMD
[0014.688] I> component binary type is 16
[0014.692] I> Size of crypto header is 8192
[0014.702] I> BPMP_FW_DTB binary is read from storage
[0014.708] I> BPMP_FW_DTB binary integrity check is success
[0014.713] I> Binary BPMP_FW_DTB loaded successfully at 0x807a06b0 (0x5b940)
[0014.720] I> Task: BPMP fw ast config
[0014.723] I> Task: Load psc-fw
[0014.726] I> Slot: 0
[0014.728] I> Binary[17] block-285212672 (partition size: 0xc0000)
[0014.734] I> Binary name: PSC_FW
[0014.737] I> Size of crypto header is 8192
[0014.741] I> Size of crypto header is 8192
[0014.745] I> BCH of PSC_FW read from storage
[0014.749] I> BCH address is : 0x80ffe000
[0014.753] I> PSC_FW header integrity check is success
[0014.758] I> Binary magic in BCH component 0 is PFWP
[0014.763] I> component binary type is 17
[0014.767] I> Size of crypto header is 8192
[0014.776] I> PSC_FW binary is read from storage
[0014.781] I> PSC_FW binary integrity check is success
[0014.786] I> Binary PSC_FW loaded successfully at 0x80fb4210 (0x49df0)
[0014.792] I> Task: Load nvdec-fw
[0014.795] I> Slot: 0
[0014.797] I> Binary[7] block-117440512 (partition size: 0x100000)
[0014.803] I> Binary name: NVDEC
[0014.806] I> Size of crypto header is 8192
[0014.810] I> Size of crypto header is 8192
[0014.814] I> BCH of NVDEC read from storage
[0014.818] I> BCH address is : 0x800fe000
[0014.822] I> NVDEC header integrity check is success
[0014.827] I> Binary magic in BCH component 0 is NDEC
[0014.832] I> component binary type is 7
[0014.835] I> Size of crypto header is 8192
[0014.844] I> NVDEC binary is read from storage
[0014.849] I> NVDEC binary integrity check is success
[0014.854] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0014.863] I> Task: Load tsec-fw
[0014.866] I> TSEC-FW load support not enabled
[0014.870] I> Task: GPIO interrupt map
[0014.874] I> Task: SC7 context save
[0014.877] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0014.883] I> Task: Load MB2/Applet/FSKP
[0014.887] I> Loading MB2
[0014.889] I> Slot: 0
[0014.891] I> Binary[6] block-100663296 (partition size: 0x80000)
[0014.897] I> Binary name: MB2
[0014.900] I> Size of crypto header is 8192
[0014.904] I> Size of crypto header is 8192
[0014.908] I> BCH of MB2 read from storage
[0014.912] I> BCH address is : 0x8007e000
[0014.915] I> MB2 header integrity check is success
[0014.920] I> Binary magic in BCH component 0 is MB2B
[0014.925] I> component binary type is 6
[0014.929] I> Size of crypto header is 8192
[0014.940] I> MB2 binary is read from storage
[0014.945] I> MB2 binary integrity check is success
[0014.950] I> Binary MB2 loaded successfully at 0x80000000 (0x69a70)
[0014.956] I> Task: Map CCPLEX SHARED carveout
[0014.960] I> Task: Prepare MB2 params
[0014.964] I> Task: Dram ecc test
[0014.967] I> Task: Misc NV security settings
[0014.971] I> NVDEC sticky bits programming done
[0014.975] I> Successfully powergated NVDEC
[0014.979] I> Task: Disable/Reload WDT
[0014.983] I> Task: Program misc carveouts
[0014.987] I> Program IPC carveouts
[0014.990] I> Task: Disable SCPM/POD reset
[0014.994] I> SLCG Global override status := 0x0
[0014.999] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-0fbce5b9)
I> Boot-mode : RCM BOOT
I> Emulation:
I> Entry timestamp: 0x00e55333
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x473800000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: Set blob address
I> Task: TZDRAM heap init
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x472e00000
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x472a00000
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x47a000000
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x47d800000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x472f00000
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x473180000
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSI VMON
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x476000000
I> Task: Prepare eeprom data
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE..
I> Enabling combined UART
????spe: early_init
????vic initialized
????tsc initialized
????aon lic initialized
????spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
????spe: SafeRTOS v8.4
????spe: init
????scheduler initialized
????aon hsp initialized
????tag initialized
????tcu initialized
????bpmp ipc initialized
????spe: late init
????cpu_nic clock initialized
????apb clock initialized
????pm initialized
????bpmp hsp initialized
????top1 hsp initialized
????ccplex ipc initialized
????spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Start secure NOR provision
I> Skip Secure NOR provisioning
I> Task: Trigger load FSI keyblob
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d to psc
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is da583751bbfe2b7f6e204562d97ff39e
bpmp: combined binary md5 is dc3fd3cac60f9b918e11d435834d12a3
bpmp: firmware tag is dc3fd3cac60f9b918e11-da583751bbf
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
??I> Received ACK from psc
I> Task: Unhalt FSI
I> FSI unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Loa??initialized avfs_clk_platform
initialized powergate
??[ 4.512794] Camera-FW on t234-rce-safe started
??initialized dvs
initialized clk_mach_config
suspend progress: 0x0
initialized suspend
initialized str??TCU early console enabled.
??ap
initialized mce_dbell
??d HV/CPUBL
I> Task: Load TOS
I> Task: Trigger load TSEC leyblob
I> Sending opcode 0x53535452 to psc
I> Sent opcode to psc
??I> MB2-params @ 0x40060000
I> NSDRAM carveout base: 0x80000000, size: 0x3f25f0000
I> ??initialized emc
initialized emc_mrq
??DCE Started
??cpubl_params: nsdram:??initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
?? carveout: 1, encryption??initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
??DCE_R5_Init
MPU enabled
DCE_SW_Init
??: 1
I> cpubl: Authentication Finalize Done
I> Binary??initialized clk_cal_late
initialized noc_late
initialized cvc
?? cpubl loaded successfully at 0x4??initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable sdmmc4_axicif
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable usb2_trk
enable xusb_??[ 4.739195] Camer??ss_dev
enable xusb_fs_dev
enable xusb_falcon
enable dsi_lp
enable xusb_cor??a-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.423 ms, total boot 239.895 m??e_mux
enable xusb_core_dev
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initializ??s)
??ed mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
??Admin Task Init
Admin Task Init complete
Pri??72000000
??nt Task Init
RM Task Init
SHA Task Init
Admin Task Started
DCE??I> tos: Authenticatio?? SC7 SHA Enabled
RM Task Started
RM Task Running
Pri??n Finalize Done
I> Binary tos loaded successfully at 0xc1d83810
??nt Task Started
Print Task Running
SHA Task Started
DCE: FW Boot Complete
Admin Task R??I> Relocating OP-TEE ??unning
SHA Task Running
??dtb from: 0xc1eff530 to 0xbe040020, size: 0x2754
I> [0] START: 0x80000000, SIZE: 0x3f25f0000
I> [1] START: 0x476000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0xbe020000
I> EKB detected (length: 0x410) @ VA:0xbe020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0xbe040020
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Clear dec source key
I> MB2 finished
??NOTICE: BL31: v2.8(release):l4t-r36.4.4
NOTICE: BL31: Built : 2025-06-16 15:14:01
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 15.2.0 (GCC)) #1 Mon Jun 16 15:53:22 UTC 2025 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
JetsonMinimal UEFI firmware (version v36.4.4 built on 2024-10-01T15:28:28+00:00)
??I/TC: WARNING (insecure configuration): Failed to get monotonic counter for REE FS, using 0
E/TC:?? 00 get_rpc_alloc_res:644 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD: init_elf:493 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:?? 00 ldelf_init_with_ldelf:152 ldelf failed with res: 0xffff000c
??[ 6.605911] Camera-FW on t234-rce-safe started
??[ 6.653372] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 0.906 ms, total boot 48.418 ms)
L4TLauncher: Attempting RCM Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
??debugfs initialized
??I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
??[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.148-l4t-r36.4.4-1012.12+gc8a82765359e (oe-user@oe-host) (aarch64-oe4t-linux-gcc (GCC) 15.2.0, GNU ld (GNU Binutils) 2.45.0.20250908) #1 SMP PREEMPT Tue Jul 1 10:48:42 UTC 2025 ()
[ 0.000000] Machine model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit Super
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: SMBIOS=0xffff0000 SMBIOS 3.0=0x43dda0000 MEMATTR=0x43a47b018 RNG=0x42a6d0018 MEMRESERVE=0x42c559f18
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000461000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000477ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x4602fb800-0x4602fdfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000477ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000bdffffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000042ee49fff]
[ 0.000000] node 0: [mem 0x000000042ee4a000-0x000000042eeabfff]
[ 0.000000] node 0: [mem 0x000000042eeac000-0x000000043c38ffff]
[ 0.000000] node 0: [mem 0x000000043c390000-0x000000043e2cffff]
[ 0.000000] node 0: [mem 0x000000043e2d0000-0x0000000471dfffff]
[ 0.000000] node 0: [mem 0x0000000471e00000-0x0000000471ffffff]
[ 0.000000] node 0: [mem 0x0000000472000000-0x000000047259ffff]
[ 0.000000] node 0: [mem 0x0000000472f00000-0x0000000472ffffff]
[ 0.000000] node 0: [mem 0x0000000476000000-0x0000000477ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000477ffffff]
[ 0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Emod /lib/module
.15 08-l0004t-r36CPU.4. fe012.12res8a8276cted: 9e/dwaker/drdirrs/ty bit/ga maemedge
t/libc.00omp000osite.0] feko atures: detected: insmod /lctrib/e-vmods/5.15[ .148-l4t-.000] r36CPU4-1 fe012res: dete8a8d: Spe9e/e-BnelHB
[ 0/drivers/000usb/gaCPUdgeunc fetioatun/usb_ernf_mel e tass_ste isolatige.on for
ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4065440
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000
[ 0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12 /l677ib/module6 bs, .15ear.148-l 0r36.4.0004-1Ino012.12+gc8a8he h tabl276e e9e/updntr: 1048ate576ers/thrdeermr: 83the08 bytripes, lient.konea
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 1573mod271ib/2K/165s/5218.158-l56K4t-ailr36abl.4.e (19392K.12 ke+gcrne276l c535, 4updK raterivers/nvta,pmo 10072/nvK rpmodeloda 7616K-cl init,ap. 52
ins /l, 527000K reserved, 262144K cma-reserved)
ib/[ .00ule000s/5.14SLU8-lB: HWa4-10124, Order=+gc8a82765359e/bjeate=0,s/dUs=ers/thermNod1
al/[ tegra2.0034-0] trace eveoc-nt evestrnt.ingko rifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
/l[ 0ib/.00ule0000] s/5.15rcu.14: 8-l4t- rer36icting4-1.12+gc8a8 CPUs fro2769e/R_CPUSate=25s/ders6 t/pwm/pr_cidstegra-
0tac0000] eter.k Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
mod[ .00ib/mod000 Traciules/5.15ian8-l4t-t or36f T.4.ask4-1.12+gcs R8a8enabled.
ker[ .00000/drivers/rcuphy/tegra/phCU y-tegrcalated v4-palue of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_ /lcpuib/mods=8
.15.148-l 04t-.00r360004-1012NR_IRQS: +gc64,276 nr_ir9e/qs:/dr 64ivereapwmllo/pwcated irqo s: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
r36.4.4-1012.12+gc8a8276.005359e/0000] nelclors/cks/controllch_er/dwc/pcie-_cotegra1unter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000375] Console: colour dummy device 80x25
[ 0.000440] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000448] pid_max: default: 32768 minimum: 301
[ 0.000481] LSM: Security Framework initializing
[ 0.000502] Yama: becoming mindful.
[ 0.000517] SELinux: Initializing.
[ 0.000604] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000633] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.001787] rcu: Hierarchical SRCU implementation.
[ 0.004016] Tegra Revision: A01 SKU: 211 CPU Process: 0 SoC Process: 0
[ 0.004276] Remapping and enabling EFI services.
[ 0.005099] smp: Bringing up secondary CPUs ...
[ 0.005590] Detected PIPT I-cache on CPU1
[ 0.005629] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.005656] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.006100] Detected PIPT I-cache on CPU2
[ 0.006112] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006127] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006539] Detected PIPT I-cache on CPU3
[ 0.006548] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006562] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.009026] Detected PIPT I-cache on CPU4
[ 0.009049] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.009075] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.009550] Detected PIPT I-cache on CPU5
[ 0.009560] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.009574] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.010004] Detected PIPT I-cache on CPU6
[ 0.010014] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.010029] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.010470] Detected PIPT I-cache on CPU7
[ 0.010482] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.010494] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.010547] smp: Brought up 1 node, 8 CPUs
[ 0.010552] SMP: Total of 8 processors activated.
[ 0.010554] CPU features: detected: 32-bit EL0 Support
[ 0.010556] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.010558] CPU features: detected: Common not Private translations
[ 0.010559] CPU features: detected: CRC32 instructions
[ 0.010561] CPU features: detected: Data cache clean to Point of Persistence
[ 0.010563] CPU features: detected: Generic authentication (architected algorithm)
[ 0.010564] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.010565] CPU features: detected: LSE atomic instructions
[ 0.010567] CPU features: detected: Privileged Access Never
[ 0.010568] CPU features: detected: RAS Extension Support
[ 0.010571] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.025333] spectre-bhb mitigation disabled by command line option
[ 0.039068] CPU: All CPU(s) started at EL2
[ 0.040774] devtmpfs: initialized
[ 0.051427] KASLR enabled
[ 0.051521] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.051536] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.053614] pinctrl core: initialized pinctrl subsystem
[ 0.054118] SMBIOS 3.6.0 present.
[ 0.054126] DMI: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit Super/Jetson, BIOS v36.4.4 10/01/2024
[ 0.054402] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.055511] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.055623] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.055720] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.055746] audit: initializing netlink subsys (disabled)
[ 0.055826] audit: type=2000 audit(0.052:1): state=initialized audit_enabled=0 res=1
[ 0.056696] thermal_sys: Registered thermal governor 'step_wise'
[ 0.056700] thermal_sys: Registered thermal governor 'user_space'
[ 0.056701] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.058596] cpuidle: using governor menu
[ 0.058690] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.058769] ASID allocator initialised with 32768 entries
[ 0.059793] Serial: AMBA PL011 UART driver
[ 0.067297] tegra-mc 2c00000.memory-controller: unknown: write @0x00000000500604c0: Security violation (TrustZone violation)
[ 0.067833] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[ 0.075541] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.082126] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.082131] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.082132] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.082133] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.082769] cryptd: max_cpu_qlen set to 1000
[ 0.083959] ACPI: Interpreter disabled.
[ 0.084806] VDD_1V8_AO: supplied by VDD_5V0_SYS
[ 0.084896] VDD_3V3_AO: supplied by VDD_5V0_SYS
[ 0.085031] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[ 0.085331] iommu: Default domain type: Translated
[ 0.085334] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.085487] SCSI subsystem initialized
[ 0.085592] vgaarb: loaded
[ 0.085685] usbcore: registered new interface driver usbfs
[ 0.085700] usbcore: registered new interface driver hub
[ 0.085710] usbcore: registered new device driver usb
[ 0.086020] pps_core: LinuxPPS API ver. 1 registered
[ 0.086022] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.086027] PTP clock support registered
[ 0.086075] EDAC MC: Ver: 3.0.0
[ 0.086671] Registered efivars operations
[ 0.087005] FPGA manager framework
[ 0.087047] Advanced Linux Sound Architecture Driver Initialized.
[ 0.087318] Bluetooth: Core ver 2.22
[ 0.087346] NET: Registered PF_BLUETOOTH protocol family
[ 0.087349] Bluetooth: HCI device and connection manager initialized
[ 0.087354] Bluetooth: HCI socket layer initialized
[ 0.087358] Bluetooth: L2CAP socket layer initialized
[ 0.087366] Bluetooth: SCO socket layer initialized
[ 0.087593] clocksource: Switched to clocksource arch_sys_counter
[ 0.106064] VFS: Disk quotas dquot_6.6.0
[ 0.106098] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.106205] pnp: PnP ACPI: disabled
[ 0.108353] NET: Registered PF_INET protocol family
[ 0.108566] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.110632] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.110704] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.110713] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.110816] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.111388] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.111472] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.111511] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.111670] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.111892] RPC: Registered named UNIX socket transport module.
[ 0.111895] RPC: Registered udp transport module.
[ 0.111895] RPC: Registered tcp transport module.
[ 0.111896] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.111904] PCI: CLS 0 bytes, default 64
[ 0.111995] Unpacking initramfs...
[ 0.120032] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.120174] kvm [1]: IPA Size Limit: 48 bits
[ 0.120192] kvm [1]: GICv3: no GICV resource entry
[ 0.120195] kvm [1]: disabling GICv2 emulation
[ 0.120209] kvm [1]: GIC system register CPU interface enabled
[ 0.120280] kvm [1]: vgic interrupt IRQ9
[ 0.120396] kvm [1]: VHE mode initialized successfully
[ 0.122332] Initialise system trusted keyrings
[ 0.122350] Key type blacklist registered
[ 0.122409] workingset: timestamp_bits=42 max_order=22 bucket_order=0
[ 0.124709] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.124939] NFS: Registering the id_resolver key type
[ 0.124952] Key type id_resolver registered
[ 0.124952] Key type id_legacy registered
[ 0.124979] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.124985] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.124996] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.125122] 9p: Installing v9fs 9p2000 file system support
[ 0.125414] integrity: Platform Keyring initialized
[ 0.136553] Key type asymmetric registered
[ 0.136556] Asymmetric key parser 'x509' registered
[ 0.136596] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.136600] io scheduler mq-deadline registered
[ 0.136602] io scheduler kyber registered
[ 0.143217] EINJ: ACPI disabled.
[ 0.151066] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.152119] SuperH (H)SCI(F) driver initialized
[ 0.152348] msm_serial: driver initialized
[ 0.152774] printk: console [ttyTCU0] enabled
[ 0.153396] arm-smmu 8000000.iommu: probing hardware configuration...
[ 0.153399] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.153402] arm-smmu 8000000.iommu: stage 1 translation
[ 0.153403] arm-smmu 8000000.iommu: stage 2 translation
[ 0.153404] arm-smmu 8000000.iommu: nested translation
[ 0.153406] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.153409] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.153420] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.153422] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.153424] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.154173] arm-smmu 10000000.iommu: probing hardware configuration...
[ 0.154175] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.154176] arm-smmu 10000000.iommu: stage 1 translation
[ 0.154177] arm-smmu 10000000.iommu: stage 2 translation
[ 0.154178] arm-smmu 10000000.iommu: nested translation
[ 0.154179] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.154182] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.154185] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.154187] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.154188] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.154472] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.154473] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.154475] arm-smmu 12000000.iommu: stage 1 translation
[ 0.154477] arm-smmu 12000000.iommu: stage 2 translation
[ 0.154478] arm-smmu 12000000.iommu: nested translation
[ 0.154480] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.154481] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.154484] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.154485] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.154486] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit P
thanks you!
