I have an orin NX which cannot boot up. I checked the serial printing, and I found it never reach to I> Task: Disable/Reload WDT
Followings are the MB1 printing. According to I> rst_source: 0x13, rst_level: 0x0, I think it might be reset by WDT.
Could you help to find the root cause of this problem? Thank you.
[0000.066] I> MB1 (version: 1.4.0.7-t234-54845784-56c609fa)
[0000.071] I> t234-A01-1-Silicon (0x12347) Prod
[0000.075] I> Boot-mode : Coldboot
[0000.079] I> Entry timestamp: 0x00000000
[0000.082] I> last_boot_error: 0x0
[0000.085] I> BR-BCT: preprod_dev_sign: 0
[0000.089] I> rst_source: 0x13, rst_level: 0x0
[0000.093] I> Task: SE error check
[0000.097] I> Task: Bootchain select WAR set
[0000.101] I> Task: Enable SLCG
[0000.104] I> Task: CRC check
[0000.106] I> Task: Initialize MB2 params
[0000.111] I> MB2-params @ 0x40060000
[0000.114] I> Task: Crypto init
[0000.117] I> Task: Perform MB1 KAT tests
[0000.121] I> Task: NVRNG health check
[0000.124] I> NVRNG: Health check success
[0000.128] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.134] I> Task: Enabling and initialization of Bandwidth limiter
[0000.140] I> No request to configure MBWT settings for any PC!
[0000.146] I> Task: Secure debug controls
[0000.150] I> Task: strap war set
[0000.153] I> Task: Initialize SOC Therm
[0000.157] I> Task: Program NV master stream id
[0000.161] I> Task: Verify boot mode
[0000.167] I> Task: Alias fuses
[0000.170] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.178] I> Task: Print SKU type
[0000.181] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.186] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.190] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.194] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.199] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.203] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.207] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.212] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.216] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.220] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.225] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.229] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.233] I> FUSE_SKU_INFO_0 = 0xd3
[0000.236] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.240] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.244] I> SKU: Prod
[0000.246] I> Task: Boost clocks
[0000.249] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.254] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.260] I> BPMP NAFLL lock success.
[0000.263] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.268] I> Initializing PLLC2 for AXI_CBB.
[0000.272] I> AXI_CBB : src = 35, divisor = 0
[0000.276] I> Task: Voltage monitor
[0000.279] I> VMON: Vmon re-calibration and fine tuning done
[0000.285] I> Task: UPHY init
[0000.290] I> HSIO UPHY init done
[0000.293] W> Skipping GBE UPHY config
[0000.296] I> Task: Boot device init
[0000.300] I> Boot_device: QSPI_FLASH instance: 0
[0000.304] I> Qspi clock source : pllc_out0
[0000.308] I> QSPI Flash: Macronix 64MB
[0000.312] I> QSPI-0l initialized successfully
[0000.316] I> Task: TSC init
[0000.319] I> Task: Load membct
[0000.322] I> RAM_CODE 0x4000411
[0000.325] I> Loading MEMBCT
[0000.328] I> Slot: 0
[0000.330] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.335] I> Binary name: MEM-BCT-0
[0000.338] I> Size of crypto header is 8192
[0000.342] I> Size of crypto header is 8192
[0000.346] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.353] I> BCH of MEM-BCT-0 read from storage
[0000.357] I> BCH address is : 0x40050000
[0000.361] I> MEM-BCT-0 header integrity check is success
[0000.366] I> Binary magic in BCH component 0 is MEM0
[0000.371] I> component binary type is 0
[0000.374] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.381] I> MEM-BCT-0 binary is read from storage
[0000.386] I> MEM-BCT-0 binary integrity check is success
[0000.391] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.398] I> RAM_CODE 0x4000411
[0000.403] I> RAM_CODE 0x4000411
[0000.407] I> Task: Load Page retirement list
[0000.411] I> Task: SDRAM params override
[0000.415] I> Task: Save mem-bct info
[0000.419] I> Task: Carveout allocate
[0000.422] I> RCM blob carveout will not be allocated
[0000.427] I> Update CCPLEX IST carveout from MB1-BCT
[0000.432] I> ECC region[0]: Start:0x0, End:0x0
[0000.436] I> ECC region[1]: Start:0x0, End:0x0
[0000.440] I> ECC region[2]: Start:0x0, End:0x0
[0000.444] I> ECC region[3]: Start:0x0, End:0x0
[0000.449] I> ECC region[4]: Start:0x0, End:0x0
[0000.453] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0000.459] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.464] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.468] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.473] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.483] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.490] I> allocated(CO:39) base:0x47de00000 size:0x2200000 align: 0x10000
[0000.497] I> allocated(CO:20) base:0x47a000000 size:0x2000000 align: 0x2000000
[0000.505] I> allocated(CO:24) base:0x478000000 size:0x2000000 align: 0x2000000
[0000.512] I> allocated(CO:28) base:0x476000000 size:0x2000000 align: 0x2000000
[0000.519] I> allocated(CO:22) base:0x47c000000 size:0x1000000 align: 0x1000000
[0000.526] I> allocated(CO:35) base:0x475000000 size:0x1000000 align: 0x100000
[0000.533] I> allocated(CO:02) base:0x47d000000 size:0x800000 align: 0x800000
[0000.540] I> allocated(CO:03) base:0x474800000 size:0x800000 align: 0x800000
[0000.547] I> allocated(CO:06) base:0x474000000 size:0x800000 align: 0x800000
[0000.554] I> allocated(CO:56) base:0x473800000 size:0x800000 align: 0x200000
[0000.561] I> allocated(CO:07) base:0x47d800000 size:0x400000 align: 0x400000
[0000.568] I> allocated(CO:33) base:0x473400000 size:0x400000 align: 0x200000
[0000.575] I> allocated(CO:19) base:0x473180000 size:0x280000 align: 0x10000
[0000.581] I> allocated(CO:23) base:0x47dc00000 size:0x200000 align: 0x200000
[0000.588] I> allocated(CO:01) base:0x473000000 size:0x100000 align: 0x100000
[0000.595] I> allocated(CO:05) base:0x472f00000 size:0x100000 align: 0x100000
[0000.602] I> allocated(CO:08) base:0x472e00000 size:0x100000 align: 0x100000
[0000.609] I> allocated(CO:09) base:0x472d00000 size:0x100000 align: 0x100000
[0000.616] I> allocated(CO:12) base:0x472c00000 size:0x100000 align: 0x100000
[0000.623] I> allocated(CO:15) base:0x472b00000 size:0x100000 align: 0x100000
[0000.630] I> allocated(CO:17) base:0x472a00000 size:0x100000 align: 0x100000
[0000.637] I> allocated(CO:27) base:0x472900000 size:0x100000 align: 0x100000
[0000.644] I> allocated(CO:42) base:0x472800000 size:0x100000 align: 0x100000
[0000.651] I> allocated(CO:54) base:0x473100000 size:0x80000 align: 0x80000
[0000.658] I> allocated(CO:34) base:0x4727f0000 size:0x10000 align: 0x10000
[0000.664] I> allocated(CO:72) base:0x4725f0000 size:0x200000 align: 0x10000
[0000.671] I> allocated(CO:47) base:0x472000000 size:0x400000 align: 0x200000
[0000.678] I> allocated(CO:50) base:0x471e00000 size:0x200000 align: 0x100000
[0000.685] I> allocated(CO:48) base:0x4725d0000 size:0x20000 align: 0x10000
[0000.692] I> allocated(CO:69) base:0x4725b0000 size:0x20000 align: 0x10000
[0000.699] I> allocated(CO:49) base:0x4725a0000 size:0x10000 align: 0x10000
[0000.705] I> NSDRAM base: 0x80000000, end: 0x4725f0000, size: 0x3f25f0000
[0000.712] I> Task: Thermal check
[0000.715] I> Using min_chip_limit as min_tmon_limit
[0000.720] I> Using max_chip_limit as max_tmon_limit
[0000.725] I> BCT max_tmon_limit = 105
[0000.728] I> BCT min_tmon_limit = -28
[0000.732] I> BCT max_tmon_limit = 105
[0000.735] I> BCT min_tmon_limit = -28
[0000.738] I> SKU specific max_chip_limit = 105
[0000.743] I> SKU specific min_chip_limit = -28
[0000.747] I> BCT max_chip_limit = 105
[0000.751] I> BCT min_chip_limit = -28
[0000.754] I> enable_soctherm_polling = 0
[0000.758] I> max temp read = 37
[0000.761] I> min temp read = 36
[0000.764] I> Enabling thermtrip
[0000.767] I> Task: Update FSI SCR with thermal fuse data
[0000.772] I> Task: Enable WDT 5th expiry
[0000.776] I> Task: I2C register
[0000.779] I> Task: Set I2C bus freq
[0000.782] I> Task: Reset FSI
[0000.785] I> Task: Pinmux init
[0000.788] I> skipped mmio_addr = 0x9240008
[0000.792] I> skipped mmio_addr = 0x9240000
[0000.796] I> skipped mmio_addr = 0x9240010
[0000.800] I> skipped mmio_addr = 0x9240018
[0000.804] I> skipped mmio_addr = 0x9240020
[0000.808] I> skipped mmio_addr = 0x9240030
[0000.812] I> skipped mmio_addr = 0x9240028
[0000.815] I> skipped mmio_addr = 0x9240038
[0000.819] I> skipped mmio_addr = 0x9240040
[0000.823] I> skipped mmio_addr = 0x9240048
[0000.827] I> skipped mmio_addr = 0x9241000
[0000.831] I> skipped mmio_addr = 0x9241008
[0000.835] I> skipped mmio_addr = 0x9241010
[0000.839] I> skipped mmio_addr = 0x9241018
[0000.843] I> skipped mmio_addr = 0x9241020
[0000.847] I> skipped mmio_addr = 0x9241028
[0000.851] I> skipped mmio_addr = 0x9241030
[0000.855] I> skipped mmio_addr = 0x9241038
[0000.859] I> skipped mmio_addr = 0x9241040
[0000.863] I> skipped mmio_addr = 0x9242000
[0000.867] I> skipped mmio_addr = 0x9242008
[0000.871] I> Task: Prod config init
[0000.874] I> Task: Pad voltage init
[0000.877] I> Task: Prod init
[0000.880] I> Task: Program rst req config reg
[0000.884] I> Task: Common rail init
[0000.888] I> DONE: Thermal config
[0000.892] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.900] I> DONE: SOC rail config
[0000.904] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.910] I> DONE: MEMIO rail config
[0000.914] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.920] I> DONE: GPU rail info
[0000.923] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.929] I> DONE: CV rail info
[0000.932] I> Task: Mem clock src
[0000.935] I> Task: Misc. board config
[0000.939] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.945] I> Task: SDRAM init
[0000.948] I> MemoryType: 4 MemBctRevision: 2
[0000.954] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 2
[0000.962] I> MSS CAR: Init PLLM
[0000.965] I> MSS CAR: Init PLLHUB
[0000.969] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.981] I> SDRAM initialized!
[0000.984] I> SDRAM Size in Total 0x400000000
[0000.988] I> Task: Dram Ecc scrub
[0000.991] I> Task: DRAM alias check
[0000.998] I> Task: Program NSDRAM carveout
[0001.002] I> NSDRAM carveout encryption is enabled
[0001.006] I> Program NSDRAM carveout
[0001.010] I> Task: Register checker
[0001.013] I> Task: Enable clock-mon
[0001.017] I> FMON: Fmon re-programming done
[0001.021] I> Task: Mapper init
[0001.024] I> Task: SC7 Context Init
[0001.028] I> Task: CCPLEX IST init
[0001.031] I> Task: CPU WP0
[0001.033] I> Loading MCE
[0001.036] I> Slot: 0
[0001.038] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.043] I> Binary name: MCE
[0001.046] I> Size of crypto header is 8192
[0001.050] I> Size of crypto header is 8192
[0001.054] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.060] I> BCH of MCE read from storage
[0001.064] I> BCH address is : 0x4003e000
[0001.068] I> MCE header integrity check is success
[0001.073] I> Binary magic in BCH component 0 is MTSM
[0001.078] I> component binary type is 8
[0001.081] I> Size of crypto header is 8192
[0001.085] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.093] I> MCE binary is read from storage
[0001.098] I> MCE binary integrity check is success
[0001.103] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.109] I> Size of crypto header is 8192
[0001.120] I> Size of crypto header is 8192
[0001.124] I> Sending WP0 mailbox command to PSC
[0001.133] I> Task: XUSB Powergate
[0001.136] I> Skipping powergate XUSB.
[0001.139] I> Task: MB1 fixed firewalls
[0001.146] W> Firewall readback mismatch
[0001.151] I> Task: Load bpmp-fw
[0001.154] I> Slot: 0
[0001.156] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.161] I> Binary name: BPMP_FW
[0001.164] I> Size of crypto header is 8192
[0001.168] I> Size of crypto header is 8192
[0001.172] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.179] I> BCH of BPMP_FW read from storage
[0001.183] I> BCH address is : 0x807fe000
[0001.187] I> BPMP_FW header integrity check is success
[0001.192] I> Binary magic in BCH component 0 is BPMF
[0001.196] I> component binary type is 15
[0001.200] I> Size of crypto header is 8192
[0001.204] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.222] I> BPMP_FW binary is read from storage
[0001.228] I> BPMP_FW binary integrity check is success
[0001.233] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8c00)
[0001.239] I> Slot: 0
[0001.241] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.247] I> Binary name: BPMP_FW_DTB
[0001.251] I> Size of crypto header is 8192
[0001.255] I> Size of crypto header is 8192
[0001.259] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.265] I> BCH of BPMP_FW_DTB read from storage
[0001.269] I> BCH address is : 0x807fc000
[0001.273] I> BPMP_FW_DTB header integrity check is success
[0001.278] I> Binary magic in BCH component 0 is BPMD
[0001.283] I> component binary type is 16
[0001.287] I> Size of crypto header is 8192
[0001.291] I> strt_pg_num(13072) num_of_pgs(733) read_buf(0x807a05f0)
[0001.301] I> BPMP_FW_DTB binary is read from storage
[0001.307] I> BPMP_FW_DTB binary integrity check is success
[0001.312] I> Binary BPMP_FW_DTB loaded successfully at 0x807a05f0 (0x5b940)
[0001.319] I> Task: BPMP fw ast config
[0001.323] I> Task: Load psc-fw
[0001.326] I> Slot: 0
[0001.328] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.333] I> Binary name: PSC_FW
[0001.336] I> Size of crypto header is 8192
[0001.340] I> Size of crypto header is 8192
[0001.344] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.350] I> BCH of PSC_FW read from storage
[0001.354] I> BCH address is : 0x80ffe000
[0001.358] I> PSC_FW header integrity check is success
[0001.363] I> Binary magic in BCH component 0 is PFWP
[0001.368] I> component binary type is 17
[0001.372] I> Size of crypto header is 8192
[0001.376] I> strt_pg_num(21264) num_of_pgs(591) read_buf(0x80fb4200)
[0001.385] I> PSC_FW binary is read from storage
[0001.390] I> PSC_FW binary integrity check is success
[0001.395] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.402] I> Task: Load nvdec-fw
[0001.405] I> Slot: 0
[0001.407] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.412] I> Binary name: NVDEC
[0001.415] I> Size of crypto header is 8192
[0001.419] I> Size of crypto header is 8192
[0001.423] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.429] I> BCH of NVDEC read from storage
[0001.433] I> BCH address is : 0x800fe000
[0001.437] I> NVDEC header integrity check is success
[0001.442] I> Binary magic in BCH component 0 is NDEC
[0001.447] I> component binary type is 7
[0001.450] I> Size of crypto header is 8192
[0001.454] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.464] I> NVDEC binary is read from storage
[0001.468] I> NVDEC binary integrity check is success
[0001.473] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.480] I> Size of crypto header is 8192
[0001.491] I> Task: Load tsec-fw
[0001.494] I> TSEC-FW load support not enabled
[0001.498] I> Task: GPIO interrupt map
[0001.502] I> Task: SC7 context save
[0001.505] I> Slot: 0
[0001.507] I> Binary[27] block-0 (partition size: 0x100000)
[0001.513] I> Binary name: BR_BCT
[0001.516] I> Size of crypto header is 8192
[0001.520] I> Size of crypto header is 8192
[0001.524] I> Size of crypto header is 8192
[0001.527] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.533] I> BR_BCT binary is read from storage
[0001.538] I> BR_BCT binary integrity check is success
[0001.543] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.549] I> Slot: 0
[0001.551] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.557] I> Binary name: SC7-FW
[0001.560] I> Size of crypto header is 8192
[0001.564] I> Size of crypto header is 8192
[0001.568] I> Size of crypto header is 8192
[0001.571] I> Size of crypto header is 8192
[0001.575] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.582] I> BCH of SC7-FW read from storage
[0001.586] I> BCH address is : 0xa0002000
[0001.590] I> SC7-FW header integrity check is success
[0001.595] I> Binary magic in BCH component 0 is WB0B
[0001.599] I> component binary type is 13
[0001.603] I> Size of crypto header is 8192
[0001.607] I> strt_pg_num(23824) num_of_pgs(350) read_buf(0xa0004000)
[0001.615] I> SC7-FW binary is read from storage
[0001.620] I> SC7-FW binary integrity check is success
[0001.625] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2bb20)
[0001.631] I> Slot: 0
[0001.633] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.639] I> Binary name: PSC_RF
[0001.642] I> Size of crypto header is 8192
[0001.646] I> Size of crypto header is 8192
[0001.650] I> Size of crypto header is 8192
[0001.654] I> Size of crypto header is 8192
[0001.658] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002fb20)
[0001.664] I> BCH of PSC_RF read from storage
[0001.668] I> BCH address is : 0xa002fb20
[0001.672] I> PSC_RF header integrity check is success
[0001.677] I> Binary magic in BCH component 0 is PSCR
[0001.682] I> component binary type is 22
[0001.685] I> Size of crypto header is 8192
[0001.689] I> strt_pg_num(24208) num_of_pgs(256) read_buf(0xa0031b20)
[0001.697] I> PSC_RF binary is read from storage
[0001.702] I> PSC_RF binary integrity check is success
[0001.706] I> Binary PSC_RF loaded successfully at 0xa0031b20 (0x20000)
[0001.716] I> Task: Save WP0 payload to SC7 ctx
[0001.720] I> Task: Load MB2rf binary to SC7 ctx
[0001.725] I> Slot: 0
[0001.727] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.732] I> Binary name: MB2_RF
[0001.735] I> Size of crypto header is 8192
[0001.739] I> Size of crypto header is 8192
[0001.743] I> Size of crypto header is 8192
[0001.747] I> Size of crypto header is 8192
[0001.751] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.757] I> BCH of MB2_RF read from storage
[0001.761] I> BCH address is : 0xa00d5d10
[0001.765] I> MB2_RF header integrity check is success
[0001.770] I> Binary magic in BCH component 0 is MB2R
[0001.775] I> component binary type is 14
[0001.779] I> Size of crypto header is 8192
[0001.783] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.790] I> MB2_RF binary is read from storage
[0001.795] I> MB2_RF binary integrity check is success
[0001.800] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf40)
[0001.806] I> Task: Save fuse alias data to SC7 ctx
[0001.811] I> Task: Save PMIC data to SC7 ctx
[0001.815] I> Task: Save Pinmux data to SC7 ctx
[0001.819] I> Task: Save Pad Voltage data to SC7 ctx
[0001.824] I> Task: Save controller prod data to SC7 ctx
[0001.829] I> Task: Save prod cfg data to SC7 ctx
[0001.833] I> Task: Save I2C bus freq data to SC7 ctx
[0001.838] I> Task: Save SOCTherm data to SC7 ctx
[0001.843] I> Task: Save FMON data to SC7 ctx
[0001.847] I> Task: Save VMON data to SC7 ctx
[0001.851] I> Task: Save TZDRAM data to SC7 ctx
[0001.855] I> Task: Save GPIO int data to SC7 ctx
[0001.859] I> Task: Save clock data to SC7 ctx
[0001.864] I> Task: Save debug data to SC7 ctx
[0001.868] I> Task: Save MBWT data to SC7 ctx
[0001.876] I> SC7 context save done
[0001.879] I> Task: Load MB2/Applet/FSKP
[0001.883] I> Loading MB2
[0001.885] I> Slot: 0
[0001.887] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.893] I> Binary name: MB2
[0001.896] I> Size of crypto header is 8192
[0001.899] I> Size of crypto header is 8192
[0001.903] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.910] I> BCH of MB2 read from storage
[0001.913] I> BCH address is : 0x8007e000
[0001.917] I> MB2 header integrity check is success
[0001.922] I> Binary magic in BCH component 0 is MB2B
[0001.927] I> component binary type is 6
[0001.930] I> Size of crypto header is 8192
[0001.934] I> strt_pg_num(8464) num_of_pgs(846) read_buf(0x80000000)
[0001.945] I> MB2 binary is read from storage
[0001.950] I> MB2 binary integrity check is success
[0001.955] I> Binary MB2 loaded successfully at 0x80000000 (0x69a30)
[0001.961] I> Task: Map CCPLEX SHARED carveout
[0001.965] I> Task: Prepare MB2 params
[0001.969] I> Task: Dram ecc test
[0001.972] I> Task: Misc NV security settings
[0001.976] I> NVDEC sticky bits programming done
[0001.981] I> Successfully powergated NVDEC
[0000.067] I> MB1 (version: 1.4.0.7-t234-54845784-56c609fa)
[0000.072] I> t234-A01-1-Silicon (0x12347) Prod
[0000.076] I> Boot-mode : Coldboot
[0000.083] I> last_boot_error: 0x0
[0000.086] I> BR-BCT: preprod_dev_sign: 0
[0000.090] I> rst_source: 0x13, rst_level: 0x0
[0000.094] I> Task: SE error check
[0000.107] I> Task: Initialize MB2 params
[0000.115] I> Task: Crypto init
[0000.118] I> Task: Perform MB1 KAT tests
