ORIN NANO 4GB版,常温开机失败,只有加热后才能正常开机
您好,我们产品使用 ORIN NANO 4GB版核芯板,目前已生产100台,其中有三台遇到了常温下核芯板开机失败问题,稳定复现:
1、当核芯板关机静置十分钟以上,等其温度降至室温(约 20 摄氏度),开机必无法启动,卡在加载CPU-Bootloader;
2、如果使用热风机对其进行吹风加热,使其温度在 50 摄氏度以上,必能开机(或者第一次开机失败时,等其30秒,使它因通电加热,然后再断电重启,也能开机);
3、目前出问题的核芯版 SN 为:1423524325869,1422724321104,1422724321263
软件使用 JetPack 5.1.4, 开机失败的串口日志如下:
[16:16:43:459] [0000.067] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[16:16:43:459] [0000.072] I> t234-A01-1-Silicon (0x12347) Prod
[16:16:43:459] [0000.077] I> Boot-mode : Coldboot
[16:16:43:470] [0000.080] I> Entry timestamp: 0x00000000
[16:16:43:470] [0000.083] I> last_boot_error: 0x0
[16:16:43:470] [0000.087] I> BR-BCT: preprod_dev_sign: 0
[16:16:43:476] [0000.090] I> rst_source: 0x0, rst_level: 0x0
[16:16:43:487] [0000.094] I> Task: SE error check
[16:16:43:487] [0000.098] I> Task: Bootchain select WAR set
[16:16:43:487] [0000.102] I> Task: Enable SLCG
[16:16:43:487] [0000.105] I> Task: CRC check
[16:16:43:493] [0000.108] I> Task: Initialize MB2 params
[16:16:43:505] [0000.112] I> MB2-params @ 0x40060000
[16:16:43:505] [0000.115] I> Task: Crypto init
[16:16:43:505] [0000.118] I> Task: Perform MB1 KAT tests
[16:16:43:505] [0000.122] I> Task: NVRNG health check
[16:16:43:516] [0000.126] I> NVRNG: Health check success
[16:16:43:516] [0000.129] I> Task: MSS Bandwidth limiter settings for iGPU clients
[16:16:43:527] [0000.135] I> Task: Enabling and initialization of Bandwidth limiter
[16:16:43:527] [0000.141] I> No request to configure MBWT settings for any PC!
[16:16:43:539] [0000.147] I> Task: Secure debug controls
[16:16:43:539] [0000.151] I> Task: strap war set
[16:16:43:539] [0000.154] I> Task: Initialize SOC Therm
[16:16:43:547] [0000.158] I> Task: Program NV master stream id
[16:16:43:547] [0000.162] I> Task: Verify boot mode
[16:16:43:561] [0000.168] I> Task: Alias fuses
[16:16:43:561] [0000.171] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[16:16:43:561] [0000.178] I> Task: Print SKU type
[16:16:43:574] [0000.181] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000078
[16:16:43:574] [0000.186] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[16:16:43:590] [0000.191] I> FUSE_OPT_TPC_DISABLE = 0x000000fc
[16:16:43:590] [0000.195] I> FUSE_OPT_DLA_DISABLE = 0x00000003
[16:16:43:590] [0000.199] I> FUSE_OPT_PVA_DISABLE = 0x00000001
[16:16:43:605] [0000.203] I> FUSE_OPT_NVENC_DISABLE = 0x00000001
[16:16:43:605] [0000.208] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[16:16:43:605] [0000.212] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[16:16:43:622] [0000.217] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[16:16:43:622] [0000.221] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[16:16:43:622] [0000.225] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[16:16:43:622] [0000.229] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[16:16:43:622] [0000.233] I> FUSE_SKU_INFO_0 = 0xd6
[16:16:43:639] [0000.237] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[16:16:43:639] [0000.241] I> FUSE_PACKAGE_INFO_0 = 0x2
[16:16:43:639] [0000.244] I> SKU: Prod
[16:16:43:657] [0000.247] I> Task: Boost clocks
[16:16:43:657] [0000.250] I> Initializing PLLC2 for AXI_CBB.
[16:16:43:657] [0000.254] I> AXI_CBB : src = 35, divisor = 0
[16:16:43:657] [0000.258] I> Task: Voltage monitor
[16:16:43:657] [0000.261] I> VMON: Vmon re-calibration and fine tuning done
[16:16:43:657] [0000.267] I> Task: UPHY init
[16:16:43:673] [0000.272] I> HSIO UPHY init done
[16:16:43:673] [0000.275] W> Skipping GBE UPHY config
[16:16:43:673] [0000.278] I> Task: Boot device init
[16:16:43:673] [0000.281] I> Boot_device: QSPI_FLASH instance: 0
[16:16:43:689] [0000.286] I> Qspi clock source : pllc_out0
[16:16:43:689] [0000.290] I> QSPI Flash: Macronix 64MB
[16:16:43:689] [0000.294] I> QSPI-0l initialized successfully
[16:16:43:689] [0000.298] I> Task: TSC init
[16:16:43:689] [0000.301] I> Task: Load membct
[16:16:43:689] [0000.304] I> RAM_CODE 0x4000441
[16:16:43:705] [0000.307] I> Loading MEMBCT
[16:16:43:705] [0000.310] I> Slot: 0
[16:16:43:705] [0000.312] I> Binary[1] block-3840 (partition size: 0x40000)
[16:16:43:705] [0000.317] I> Binary name: MEM-BCT-1
[16:16:43:723] [0000.320] I> Size of crypto header is 8192
[16:16:43:723] [0000.324] I> Size of crypto header is 8192
[16:16:43:723] [0000.328] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[16:16:43:723] [0000.334] I> BCH of MEM-BCT-1 read from storage
[16:16:43:723] [0000.339] I> BCH address is : 0x40050000
[16:16:43:739] [0000.343] I> MEM-BCT-1 header integrity check is success
[16:16:43:739] [0000.348] I> Binary magic in BCH component 1 is MEM1
[16:16:43:755] [0000.353] I> component binary type is 1
[16:16:43:755] [0000.356] I> strt_pg_num(3971) num_of_pgs(115) read_buf(0x40040000)
[16:16:43:772] [0000.363] I> MEM-BCT-1 binary is read from storage
[16:16:43:772] [0000.368] I> MEM-BCT-1 binary integrity check is success
[16:16:43:772] [0000.373] I> Binary MEM-BCT-1 loaded successfully at 0x40040000 (0xe580)
[16:16:43:772] [0000.380] I> RAM_CODE 0x4000441
[16:16:43:772] [0000.385] I> RAM_CODE 0x4000441
[16:16:43:789] [0000.389] I> Task: Load Page retirement list
[16:16:43:789] [0000.393] I> Task: SDRAM params override
[16:16:43:789] [0000.397] I> Task: Save mem-bct info
[16:16:43:806] [0000.400] I> Task: Carveout allocate
[16:16:43:806] [0000.404] I> RCM blob carveout will not be allocated
[16:16:43:806] [0000.408] I> Update CCPLEX IST carveout from MB1-BCT
[16:16:43:806] [0000.413] I> ECC region[0]: Start:0x0, End:0x0
[16:16:43:806] [0000.418] I> ECC region[1]: Start:0x0, End:0x0
[16:16:43:806] [0000.422] I> ECC region[2]: Start:0x0, End:0x0
[16:16:43:818] [0000.426] I> ECC region[3]: Start:0x0, End:0x0
[16:16:43:818] [0000.430] I> ECC region[4]: Start:0x0, End:0x0
[16:16:43:827] [0000.435] I> Non-ECC region[0]: Start:0x80000000, End:0x180000000
[16:16:43:827] [0000.441] I> Non-ECC region[1]: Start:0x0, End:0x0
[16:16:43:838] [0000.445] I> Non-ECC region[2]: Start:0x0, End:0x0
[16:16:43:838] [0000.450] I> Non-ECC region[3]: Start:0x0, End:0x0
[16:16:43:838] [0000.455] I> Non-ECC region[4]: Start:0x0, End:0x0
[16:16:43:858] [0000.465] I> allocated(CO:43) base:0x17c000000 size:0x4000000 align: 0x200000
[16:16:43:858] [0000.472] I> allocated(CO:39) base:0x179e00000 size:0x2200000 align: 0x10000
[16:16:43:869] [0000.479] I> allocated(CO:20) base:0x176000000 size:0x2000000 align: 0x2000000
[16:16:43:869] [0000.486] I> allocated(CO:24) base:0x174000000 size:0x2000000 align: 0x2000000
[16:16:43:881] [0000.493] I> allocated(CO:28) base:0x172000000 size:0x2000000 align: 0x2000000
[16:16:43:892] [0000.501] I> allocated(CO:22) base:0x178000000 size:0x1000000 align: 0x1000000
[16:16:43:892] [0000.508] I> allocated(CO:35) base:0x179000000 size:0xe00000 align: 0x10000
[16:16:43:903] [0000.515] I> allocated(CO:02) base:0x171800000 size:0x800000 align: 0x800000
[16:16:43:914] [0000.521] I> allocated(CO:03) base:0x171000000 size:0x800000 align: 0x800000
[16:16:43:914] [0000.528] I> allocated(CO:06) base:0x170800000 size:0x800000 align: 0x800000
[16:16:43:935] [0000.535] I> allocated(CO:56) base:0x170000000 size:0x800000 align: 0x200000
[16:16:43:935] [0000.542] I> allocated(CO:07) base:0x16fc00000 size:0x400000 align: 0x400000
[16:16:43:946] [0000.549] I> allocated(CO:33) base:0x16f800000 size:0x400000 align: 0x200000
[16:16:43:957] [0000.556] I> allocated(CO:23) base:0x16f600000 size:0x200000 align: 0x200000
[16:16:43:957] [0000.563] I> allocated(CO:01) base:0x16f500000 size:0x100000 align: 0x100000
[16:16:43:969] [0000.570] I> allocated(CO:05) base:0x16f400000 size:0x100000 align: 0x100000
[16:16:43:969] [0000.577] I> allocated(CO:08) base:0x16f300000 size:0x100000 align: 0x100000
[16:16:43:979] [0000.584] I> allocated(CO:09) base:0x16f200000 size:0x100000 align: 0x100000
[16:16:43:988] [0000.591] I> allocated(CO:15) base:0x16f100000 size:0x100000 align: 0x100000
[16:16:43:988] [0000.598] I> allocated(CO:17) base:0x16f000000 size:0x100000 align: 0x100000
[16:16:43:998] [0000.605] I> allocated(CO:27) base:0x16ef00000 size:0x100000 align: 0x100000
[16:16:44:009] [0000.612] I> allocated(CO:42) base:0x16ee00000 size:0x100000 align: 0x100000
[16:16:44:009] [0000.619] I> allocated(CO:54) base:0x16ed80000 size:0x80000 align: 0x80000
[16:16:44:019] [0000.625] I> allocated(CO:34) base:0x16ed70000 size:0x10000 align: 0x10000
[16:16:44:019] [0000.632] I> allocated(CO:72) base:0x16eb70000 size:0x200000 align: 0x10000
[16:16:44:032] [0000.639] I> allocated(CO:47) base:0x16e600000 size:0x400000 align: 0x200000
[16:16:44:042] [0000.646] I> allocated(CO:48) base:0x16eb50000 size:0x20000 align: 0x10000
[16:16:44:042] [0000.653] I> allocated(CO:69) base:0x16eb30000 size:0x20000 align: 0x10000
[16:16:44:051] [0000.659] I> allocated(CO:49) base:0x16eb20000 size:0x10000 align: 0x10000
[16:16:44:051] [0000.666] I> allocated(CO:50) base:0x16eb10000 size:0x10000 align: 0x10000
[16:16:44:060] [0000.673] I> NSDRAM base: 0x80000000, end: 0x16eb70000, size: 0xeeb70000
[16:16:44:072] [0000.680] I> Task: Thermal check
[16:16:44:072] [0000.683] I> Using min_chip_limit as min_tmon_limit
[16:16:44:072] [0000.687] I> Using max_chip_limit as max_tmon_limit
[16:16:44:083] [0000.692] I> BCT max_tmon_limit = 105
[16:16:44:083] [0000.696] I> BCT min_tmon_limit = -28
[16:16:44:083] [0000.699] I> BCT max_tmon_limit = 105
[16:16:44:094] [0000.703] I> BCT min_tmon_limit = -28
[16:16:44:094] [0000.706] I> SKU specific max_chip_limit = 105
[16:16:44:094] [0000.710] I> SKU specific min_chip_limit = -28
[16:16:44:105] [0000.715] I> BCT max_chip_limit = 105
[16:16:44:105] [0000.718] I> BCT min_chip_limit = -28
[16:16:44:105] [0000.722] I> enable_soctherm_polling = 0
[16:16:44:116] [0000.725] I> max temp read = 28
[16:16:44:116] [0000.728] I> min temp read = 27
[16:16:44:116] [0000.731] I> Enabling thermtrip
[16:16:44:116] [0000.734] I> Task: Update FSI SCR with thermal fuse data
[16:16:44:128] [0000.739] I> Task: Enable WDT 5th expiry
[16:16:44:128] [0000.743] I> Task: I2C register
[16:16:44:137] [0000.746] I> Task: Set I2C bus freq
[16:16:44:137] [0000.750] I> Task: Reset FSI
[16:16:44:137] [0000.752] I> Task: Pinmux init
[16:16:44:148] [0000.755] I> skipped mmio_addr = 0x9240008
[16:16:44:148] [0000.759] I> skipped mmio_addr = 0x9240000
[16:16:44:148] [0000.763] I> skipped mmio_addr = 0x9240010
[16:16:44:159] [0000.767] I> skipped mmio_addr = 0x9240018
[16:16:44:159] [0000.771] I> skipped mmio_addr = 0x9240020
[16:16:44:159] [0000.775] I> skipped mmio_addr = 0x9240030
[16:16:44:171] [0000.779] I> skipped mmio_addr = 0x9240028
[16:16:44:171] [0000.783] I> skipped mmio_addr = 0x9240038
[16:16:44:171] [0000.787] I> skipped mmio_addr = 0x9240040
[16:16:44:182] [0000.791] I> skipped mmio_addr = 0x9240048
[16:16:44:182] [0000.795] I> skipped mmio_addr = 0x9241000
[16:16:44:182] [0000.799] I> skipped mmio_addr = 0x9241008
[16:16:44:193] [0000.803] I> skipped mmio_addr = 0x9241010
[16:16:44:193] [0000.807] I> skipped mmio_addr = 0x9241018
[16:16:44:193] [0000.811] I> skipped mmio_addr = 0x9241020
[16:16:44:204] [0000.815] I> skipped mmio_addr = 0x9241028
[16:16:44:204] [0000.818] I> skipped mmio_addr = 0x9241030
[16:16:44:204] [0000.822] I> skipped mmio_addr = 0x9241038
[16:16:44:215] [0000.826] I> skipped mmio_addr = 0x9241040
[16:16:44:215] [0000.830] I> skipped mmio_addr = 0x9242000
[16:16:44:227] [0000.834] I> skipped mmio_addr = 0x9242008
[16:16:44:227] [0000.838] I> Task: Prod config init
[16:16:44:227] [0000.842] I> Task: Pad voltage init
[16:16:44:227] [0000.845] I> Task: Prod init
[16:16:44:238] [0000.848] I> Task: Program rst req config reg
[16:16:44:238] [0000.852] I> Task: Common rail init
[16:16:44:238] [0000.855] I> DONE: Thermal config
[16:16:44:248] [0000.859] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[16:16:44:256] [0000.867] I> DONE: SOC rail config
[16:16:44:265] [0000.871] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[16:16:44:265] [0000.877] I> DONE: MEMIO rail config
[16:16:44:275] [0000.881] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[16:16:44:275] [0000.887] I> DONE: GPU rail info
[16:16:44:284] [0000.891] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[16:16:44:284] [0000.897] I> DONE: CV rail info
[16:16:44:284] [0000.900] I> Task: Mem clock src
[16:16:44:295] [0000.903] I> Task: Misc. board config
[16:16:44:295] [0000.907] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[16:16:44:295] [0000.913] I> Task: SDRAM init
[16:16:44:305] [0000.915] I> MemoryType: 4 MemBctRevision: 2
[16:16:44:315] [0000.922] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 2
[16:16:44:315] [0000.929] I> MSS CAR: Init PLLM
[16:16:44:315] [0000.932] I> MSS CAR: Init PLLHUB
[16:16:44:332] [0000.937] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[16:16:44:341] [0000.948] I> SDRAM initialized!
[16:16:44:341] [0000.951] I> SDRAM Size in Total 0x100000000
[16:16:44:341] [0000.955] I> Task: Dram Ecc scrub
[16:16:44:341] [0000.959] I> Task: DRAM alias check
[16:16:44:356] [0000.963] I> Task: Program NSDRAM carveout
[16:16:44:356] [0000.967] I> NSDRAM carveout encryption is enabled
[16:16:44:356] [0000.972] I> Program NSDRAM carveout
[16:16:44:365] [0000.975] I> Task: Register checker
[16:16:44:365] [0000.979] I> Task: Enable clock-mon
[16:16:44:376] [0000.983] I> FMON: Fmon re-programming done
[16:16:44:376] [0000.987] I> Task: Mapper init
[16:16:44:376] [0000.990] I> Task: SC7 Context Init
[16:16:44:376] [0000.993] I> Task: CCPLEX IST init
[16:16:44:387] [0000.996] I> Task: CPU WP0
[16:16:44:387] [0000.999] I> Loading MCE
[16:16:44:387] [0001.001] I> Slot: 0
[16:16:44:387] [0001.003] I> Binary[8] block-22784 (partition size: 0x80000)
[16:16:44:398] [0001.009] I> Binary name: MCE
[16:16:44:398] [0001.012] I> Size of crypto header is 8192
[16:16:44:398] [0001.016] I> Size of crypto header is 8192
[16:16:44:410] [0001.020] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[16:16:44:410] [0001.026] I> BCH of MCE read from storage
[16:16:44:421] [0001.030] I> BCH address is : 0x4003e000
[16:16:44:421] [0001.034] I> MCE header integrity check is success
[16:16:44:421] [0001.038] I> Binary magic in BCH component 0 is MTSM
[16:16:44:432] [0001.043] I> component binary type is 8
[16:16:44:432] [0001.047] I> Size of crypto header is 8192
[16:16:44:441] [0001.051] I> strt_pg_num(22800) num_of_pgs(357) read_buf(0x40000000)
[16:16:44:450] [0001.059] I> MCE binary is read from storage
[16:16:44:458] [0001.063] I> MCE binary integrity check is success
[16:16:44:458] [0001.068] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[16:16:44:458] [0001.074] I> Size of crypto header is 8192
[16:16:44:476] [0001.085] I> Size of crypto header is 8192
[16:16:44:476] [0001.089] I> Sending WP0 mailbox command to PSC
[16:16:44:491] [0001.098] I> Task: XUSB Powergate
[16:16:44:491] [0001.102] I> Skipping powergate XUSB.
[16:16:44:491] [0001.105] I> Task: MB1 fixed firewalls
[16:16:44:498] [0001.111] W> Firewall readback mismatch
[16:16:44:509] [0001.116] I> Task: Load bpmp-fw
[16:16:44:509] [0001.119] I> Slot: 0
[16:16:44:509] [0001.121] I> Binary[15] block-9984 (partition size: 0x180000)
[16:16:44:509] [0001.127] I> Binary name: BPMP_FW
[16:16:44:520] [0001.130] I> Size of crypto header is 8192
[16:16:44:520] [0001.134] I> Size of crypto header is 8192
[16:16:44:520] [0001.138] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[16:16:44:532] [0001.144] I> BCH of BPMP_FW read from storage
[16:16:44:532] [0001.148] I> BCH address is : 0x807fe000
[16:16:44:543] [0001.152] I> BPMP_FW header integrity check is success
[16:16:44:543] [0001.157] I> Binary magic in BCH component 0 is BPMF
[16:16:44:554] [0001.162] I> component binary type is 15
[16:16:44:554] [0001.166] I> Size of crypto header is 8192
[16:16:44:554] [0001.170] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[16:16:44:575] [0001.187] I> BPMP_FW binary is read from storage
[16:16:44:586] [0001.194] I> BPMP_FW binary integrity check is success
[16:16:44:586] [0001.199] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[16:16:44:598] [0001.205] I> Slot: 0
[16:16:44:598] [0001.207] I> Binary[16] block-13056 (partition size: 0x400000)
[16:16:44:598] [0001.213] I> Binary name: BPMP_FW_DTB
[16:16:44:609] [0001.216] I> Size of crypto header is 8192
[16:16:44:609] [0001.220] I> Size of crypto header is 8192
[16:16:44:609] [0001.224] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[16:16:44:620] [0001.231] I> BCH of BPMP_FW_DTB read from storage
[16:16:44:620] [0001.235] I> BCH address is : 0x807fc000
[16:16:44:632] [0001.239] I> BPMP_FW_DTB header integrity check is success
[16:16:44:632] [0001.244] I> Binary magic in BCH component 0 is BPMD
[16:16:44:632] [0001.249] I> component binary type is 16
[16:16:44:643] [0001.253] I> Size of crypto header is 8192
[16:16:44:643] [0001.257] I> strt_pg_num(13072) num_of_pgs(375) read_buf(0x807cd1f0)
[16:16:44:653] [0001.265] I> BPMP_FW_DTB binary is read from storage
[16:16:44:664] [0001.270] I> BPMP_FW_DTB binary integrity check is success
[16:16:44:664] [0001.276] I> Binary BPMP_FW_DTB loaded successfully at 0x807cd1f0 (0x2ed00)
[16:16:44:674] [0001.282] I> Task: BPMP fw ast config
[16:16:44:674] [0001.286] I> Task: Load psc-fw
[16:16:44:674] [0001.289] I> Slot: 0
[16:16:44:674] [0001.291] I> Binary[17] block-21248 (partition size: 0xc0000)
[16:16:44:686] [0001.297] I> Binary name: PSC_FW
[16:16:44:686] [0001.300] I> Size of crypto header is 8192
[16:16:44:686] [0001.304] I> Size of crypto header is 8192
[16:16:44:697] [0001.307] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[16:16:44:697] [0001.314] I> BCH of PSC_FW read from storage
[16:16:44:708] [0001.318] I> BCH address is : 0x80ffe000
[16:16:44:708] [0001.322] I> PSC_FW header integrity check is success
[16:16:44:719] [0001.327] I> Binary magic in BCH component 0 is PFWP
[16:16:44:719] [0001.331] I> component binary type is 17
[16:16:44:719] [0001.335] I> Size of crypto header is 8192
[16:16:44:728] [0001.339] I> strt_pg_num(21264) num_of_pgs(717) read_buf(0x80fa4600)
[16:16:44:736] [0001.349] I> PSC_FW binary is read from storage
[16:16:44:747] [0001.354] I> PSC_FW binary integrity check is success
[16:16:44:747] [0001.359] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[16:16:44:758] [0001.366] I> Task: Load nvdec-fw
[16:16:44:758] [0001.369] I> Slot: 0
[16:16:44:758] [0001.371] I> Binary[7] block-6400 (partition size: 0x100000)
[16:16:44:758] [0001.376] I> Binary name: NVDEC
[16:16:44:770] [0001.379] I> Size of crypto header is 8192
[16:16:44:770] [0001.383] I> Size of crypto header is 8192
[16:16:44:770] [0001.387] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[16:16:44:781] [0001.393] I> BCH of NVDEC read from storage
[16:16:44:781] [0001.397] I> BCH address is : 0x800fe000
[16:16:44:792] [0001.401] I> NVDEC header integrity check is success
[16:16:44:792] [0001.406] I> Binary magic in BCH component 0 is NDEC
[16:16:44:803] [0001.411] I> component binary type is 7
[16:16:44:803] [0001.414] I> Size of crypto header is 8192
[16:16:44:803] [0001.418] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[16:16:44:823] [0001.428] I> NVDEC binary is read from storage
[16:16:44:831] [0001.433] I> NVDEC binary integrity check is success
[16:16:44:831] [0001.437] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[16:16:44:831] [0001.444] I> Size of crypto header is 8192
[16:16:44:848] [0001.455] I> Task: Load tsec-fw
[16:16:44:848] [0001.458] I> TSEC-FW load support not enabled
[16:16:44:848] [0001.462] I> Task: GPIO interrupt map
[16:16:44:848] [0001.466] I> Task: SC7 context save
[16:16:44:859] [0001.469] I> Slot: 0
[16:16:44:859] [0001.471] I> Binary[27] block-0 (partition size: 0x100000)
[16:16:44:859] [0001.477] I> Binary name: BR_BCT
[16:16:44:870] [0001.480] I> Size of crypto header is 8192
[16:16:44:870] [0001.484] I> Size of crypto header is 8192
[16:16:44:870] [0001.488] I> Size of crypto header is 8192
[16:16:44:882] [0001.491] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[16:16:44:882] [0001.497] I> BR_BCT binary is read from storage
[16:16:44:893] [0001.502] I> BR_BCT binary integrity check is success
[16:16:44:893] [0001.507] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[16:16:44:904] [0001.513] I> Slot: 0
[16:16:44:904] [0001.515] I> Binary[13] block-23808 (partition size: 0x30000)
[16:16:44:904] [0001.521] I> Binary name: SC7-FW
[16:16:44:915] [0001.524] I> Size of crypto header is 8192
[16:16:44:915] [0001.528] I> Size of crypto header is 8192
[16:16:44:915] [0001.532] I> Size of crypto header is 8192
[16:16:44:925] [0001.535] I> Size of crypto header is 8192
[16:16:44:936] [0001.539] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[16:16:44:936] [0001.546] I> BCH of SC7-FW read from storage
[16:16:44:936] [0001.550] I> BCH address is : 0xa0002000
[16:16:44:946] [0001.554] I> SC7-FW header integrity check is success
[16:16:44:946] [0001.559] I> Binary magic in BCH component 0 is WB0B
[16:16:44:956] [0001.563] I> component binary type is 13
[16:16:44:956] [0001.567] I> Size of crypto header is 8192
[16:16:44:956] [0001.571] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[16:16:44:966] [0001.579] I> SC7-FW binary is read from storage
[16:16:44:977] [0001.584] I> SC7-FW binary integrity check is success
[16:16:44:977] [0001.589] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[16:16:44:988] [0001.595] I> Slot: 0
[16:16:44:988] [0001.597] I> Binary[22] block-24192 (partition size: 0x30000)
[16:16:44:988] [0001.603] I> Binary name: PSC_RF
[16:16:44:988] [0001.606] I> Size of crypto header is 8192
[16:16:44:999] [0001.610] I> Size of crypto header is 8192
[16:16:44:999] [0001.614] I> Size of crypto header is 8192
[16:16:45:010] [0001.618] I> Size of crypto header is 8192
[16:16:45:010] [0001.622] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002fa00)
[16:16:45:010] [0001.628] I> BCH of PSC_RF read from storage
[16:16:45:022] [0001.632] I> BCH address is : 0xa002fa00
[16:16:45:022] [0001.636] I> PSC_RF header integrity check is success
[16:16:45:033] [0001.641] I> Binary magic in BCH component 0 is PSCR
[16:16:45:033] [0001.646] I> component binary type is 22
[16:16:45:033] [0001.649] I> Size of crypto header is 8192
[16:16:45:042] [0001.653] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031a00)
[16:16:45:054] [0001.661] I> PSC_RF binary is read from storage
[16:16:45:054] [0001.665] I> PSC_RF binary integrity check is success
[16:16:45:054] [0001.670] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x1be60)
[16:16:45:072] [0001.680] I> Task: Save WP0 payload to SC7 ctx
[16:16:45:072] [0001.684] I> Task: Load MB2rf binary to SC7 ctx
[16:16:45:072] [0001.688] I> Slot: 0
[16:16:45:072] [0001.690] I> Binary[14] block-24576 (partition size: 0x20000)
[16:16:45:084] [0001.696] I> Binary name: MB2_RF
[16:16:45:084] [0001.699] I> Size of crypto header is 8192
[16:16:45:095] [0001.703] I> Size of crypto header is 8192
[16:16:45:095] [0001.707] I> Size of crypto header is 8192
[16:16:45:095] [0001.711] I> Size of crypto header is 8192
[16:16:45:106] [0001.715] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d6aa0)
[16:16:45:106] [0001.721] I> BCH of MB2_RF read from storage
[16:16:45:117] [0001.725] I> BCH address is : 0xa00d6aa0
[16:16:45:117] [0001.729] I> MB2_RF header integrity check is success
[16:16:45:117] [0001.734] I> Binary magic in BCH component 0 is MB2R
[16:16:45:129] [0001.739] I> component binary type is 14
[16:16:45:129] [0001.742] I> Size of crypto header is 8192
[16:16:45:129] [0001.746] I> strt_pg_num(24592) num_of_pgs(223) read_buf(0xa00d8aa0)
[16:16:45:148] [0001.754] I> MB2_RF binary is read from storage
[16:16:45:148] [0001.759] I> MB2_RF binary integrity check is success
[16:16:45:148] [0001.763] I> Binary MB2_RF loaded successfully at 0xa00d8aa0 (0x1bcc0)
[16:16:45:158] [0001.770] I> Task: Save fuse alias data to SC7 ctx
[16:16:45:158] [0001.774] I> Task: Save PMIC data to SC7 ctx
[16:16:45:169] [0001.779] I> Task: Save Pinmux data to SC7 ctx
[16:16:45:169] [0001.783] I> Task: Save Pad Voltage data to SC7 ctx
[16:16:45:169] [0001.788] I> Task: Save controller prod data to SC7 ctx
[16:16:45:181] [0001.793] I> Task: Save prod cfg data to SC7 ctx
[16:16:45:181] [0001.797] I> Task: Save I2C bus freq data to SC7 ctx
[16:16:45:192] [0001.802] I> Task: Save SOCTherm data to SC7 ctx
[16:16:45:192] [0001.806] I> Task: Save FMON data to SC7 ctx
[16:16:45:203] [0001.810] I> Task: Save VMON data to SC7 ctx
[16:16:45:203] [0001.815] I> Task: Save TZDRAM data to SC7 ctx
[16:16:45:203] [0001.819] I> Task: Save GPIO int data to SC7 ctx
[16:16:45:214] [0001.823] I> Task: Save clock data to SC7 ctx
[16:16:45:214] [0001.827] I> Task: Save debug data to SC7 ctx
[16:16:45:214] [0001.832] I> Task: Save MBWT data to SC7 ctx
[16:16:45:234] [0001.840] I> SC7 context save done
[16:16:45:234] [0001.843] I> Task: Load MB2/Applet/FSKP
[16:16:45:234] [0001.847] I> Loading MB2
[16:16:45:234] [0001.849] I> Slot: 0
[16:16:45:244] [0001.851] I> Binary[6] block-8448 (partition size: 0x80000)
[16:16:45:244] [0001.856] I> Binary name: MB2
[16:16:45:244] [0001.859] I> Size of crypto header is 8192
[16:16:45:255] [0001.863] I> Size of crypto header is 8192
[16:16:45:255] [0001.867] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[16:16:45:255] [0001.873] I> BCH of MB2 read from storage
[16:16:45:266] [0001.877] I> BCH address is : 0x8007e000
[16:16:45:266] [0001.881] I> MB2 header integrity check is success
[16:16:45:278] [0001.886] I> Binary magic in BCH component 0 is MB2B
[16:16:45:278] [0001.890] I> component binary type is 6
[16:16:45:278] [0001.894] I> Size of crypto header is 8192
[16:16:45:286] [0001.898] I> strt_pg_num(8464) num_of_pgs(839) read_buf(0x80000000)
[16:16:45:295] [0001.909] I> MB2 binary is read from storage
[16:16:45:307] [0001.914] I> MB2 binary integrity check is success
[16:16:45:307] [0001.919] I> Binary MB2 loaded successfully at 0x80000000 (0x68c10)
[16:16:45:307] [0001.925] I> Task: Map CCPLEX SHARED carveout
[16:16:45:316] [0001.929] I> Task: Prepare MB2 params
[16:16:45:326] [0001.933] I> Task: Dram ecc test
[16:16:45:326] [0001.936] I> Task: Misc NV security settings
[16:16:45:326] [0001.940] I> NVDEC sticky bits programming done
[16:16:45:337] [0001.944] I> Successfully powergated NVDEC
[16:16:45:337] [0001.948] I> Task: Disable/Reload WDT
[16:16:45:337] [0001.952] I> Task: Program misc carveouts
[16:16:45:348] [0001.956] I> Program IPC carveouts
[16:16:45:348] [0001.959] I> Task: Disable SCPM/POD reset
[16:16:45:348] [0001.963] I> SLCG Global override status := 0x0
[16:16:45:358] [0001.967] I> MB1: MSS reconfig completed
[16:16:45:393] I> MB2 (version: 0.0.0.0-t234-54845784-7f6f63a6)
[16:16:45:393] I> t234-A01-1-Silicon (0x12347)
[16:16:45:393] I> Boot-mode : Coldboot
[16:16:45:393] I> Emulation:
[16:16:45:393] I> Entry timestamp: 0x001e6cda
[16:16:45:404] I> Regular heap: [base:0x40040000, size:0x10000]
[16:16:45:404] I> DMA heap: [base:0x170000000, size:0x800000]
[16:16:45:404] I> Task: ARI update carveout TZDRAM (0x50002050)
[16:16:45:415] I> Task: Check MC errors (0x5000204c)
[16:16:45:415] I> Task: SMMU external bypass disable (0x500184fc)
[16:16:45:425] I> Task: Enable hot-plug capability (0x50028dec)
[16:16:45:425] I> Task: TZDRAM heap init (0x50019de0)
[16:16:45:436] I> Task: PSC mailbox init (0x50018548)
[16:16:45:436] I> Task: Crypto init (0x50006888)
[16:16:45:436] I> Task: Enable GP-SE clock (0x500021b4)
[16:16:45:436] I> Task: Measured Boot init (0x5001bd30)
[16:16:45:447] I> Task: fTPM silicon identity init (0x5001bedc)
[16:16:45:447] I> fTPM is not enabled.
[16:16:45:447] I> Task: OEM SC7 context save init (0x5001b27c)
[16:16:45:459] I> Task: I2C register (0x50002010)
[16:16:45:459] I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001ff8)
[16:16:45:470] I> Task: Program CBB PCIE AMAP regions (0x5001b9dc)
[16:16:45:470] I> Task: Boot device init (0x50001f40)
[16:16:45:470] I> Boot_device: QSPI_FLASH instance: 0
[16:16:45:481] I> Qspi clock source : pllc_out0
[16:16:45:481] I> QSPI-0l initialized successfully
[16:16:45:481] I> Task: Partition Manager Init (0x50001f20)
[16:16:45:481] I> Active chain: 0
[16:16:45:500] I> Found 57 partitions in QSPI_FLASH (instance 0)
[16:16:45:500] I> Task: Load and authenticate registered FWs (0x5001ed44)
[16:16:45:500] I> Task: Load AUXP FWs (0x50028970)
[16:16:45:508] I> Successfully register SPE FW load task with MB2 loader
[16:16:45:508] I> Skipping SCE FW load
[16:16:45:508] I> Successfully register RCE FW load task with MB2 loader
[16:16:45:516] I> Successfully register DCE FW load task with MB2 loader
[16:16:45:516] I> Unpowergating APE
[16:16:45:516] I> Unpowergate done
[16:16:45:528] I> Successfully register APE FW load task with MB2 loader
[16:16:45:528] I> Skipping FSI FW load
[16:16:45:528] I> Successfully register XUSB FW load task with MB2 loader
[16:16:45:539] I> Active chain: 0
[16:16:45:539] I> Partition name: A_spe-fw
[16:16:45:539] I> Size of partition: 589824
[16:16:45:539] I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
[16:16:45:557] I> Active chain: 0
[16:16:45:557] I> Partition name: A_rce-fw
[16:16:45:557] I> Size of partition: 1048576
[16:16:45:557] I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
[16:16:45:568] I> spe: Authentication Finalize Done
[16:16:45:568] I> Binary spe loaded successfully at 0x16f300000
[16:16:45:582] I> Active chain: 0
[16:16:45:582] I> Partition name: A_dce-fw
[16:16:45:582] I> Size of partition: 5242880
[16:16:45:582] I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
[16:16:45:601] I> rce: Authentication Finalize Done
[16:16:45:601] I> Binary rce loaded successfully at 0x16f000000
[16:16:45:601] I> Successfully register RCE FW context save task with MB2 loader
[16:16:45:611] I> dce : oem authentication of header done
[16:16:45:611] I> dce : meta-blob integrity check is success.
[16:16:45:622] I> dce : will be decompressed at 0x176000000
[16:16:45:622] I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
[16:16:45:622] I> Reserved10 0 BlockMaxSize 5 Reserved11 0
[16:16:45:656] I> dce : decompressed to 9449600 bytes
[16:16:45:684] I> dce: plain binary integrity check is success
[16:16:45:684] I> Active chain: 0
[16:16:45:684] I> Partition name: A_adsp-fw
[16:16:45:684] I> Size of partition: 2097152
[16:16:45:694] I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
[16:16:45:705] I> dce: Authentication Finalize Done
[16:16:45:705] I> Binary dce loaded successfully at 0x176000000
[16:16:45:716] I> Active chain: 0
[16:16:45:716] I> Partition name: A_xusb-fw
[16:16:45:716] I> Size of partition: 262144
[16:16:45:716] I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
[16:16:45:726] I> ape: Authentication Finalize Done
[16:16:45:726] I> Binary ape loaded successfully at 0x16fc00000
[16:16:45:726] I> Successfully register APE FW context save task with MB2 loader
[16:16:45:743] I> xusb: Authentication Finalize Done
[16:16:45:743] I> Binary xusb loaded successfully at 0x16f400000
[16:16:45:743] I> Successfully register XUSB FW context save task with MB2 loader
[16:16:45:753] I> Task: Check MC errors (0x5000204c)
[16:16:45:753] I> Task: Carveout setup (0x500214d0)
[16:16:45:753] I> Program remaining OEM carveouts
[16:16:45:762] I> Task: Enable FSITHERM (0x500183cc)
[16:16:45:762] I> Task: Enable FSI VMON (0x50017ec8)
[16:16:45:762] I> Task: Validate FSI Therm readings (0x50017fac)
[16:16:45:773] I> Task: Restore XUSB sec (0x50001ef4)
[16:16:45:773] I> Task: Enable FSI SE clock (0x500189a4)
[16:16:45:773] I> Task: Initialize SBSA UART CAR (0x50002118)
[16:16:45:784] I> Task: Initialize CPUBL Params (0x50019990)
[16:16:45:784] I> CPUBL-params @ 0x172000000
[16:16:45:784] I> Task: Ratchet update (0x50029e88)
[16:16:45:793] W> Skip ratchet update - OPTIN fuse not set
[16:16:45:793] I> Task: Prepare eeprom data (0x5001975c)
[16:16:45:852] I> Task: Revoke PKC fuse (0x50001d40)
[16:16:45:852] I> PKC revoke fuse burn not requested
[16:16:45:852] I> Task: FSI padctl context save (0x5001b558)
[16:16:45:852] W> Skipping FSI padctl config save: fsi not enabled
[16:16:45:863] I> Task: Unpowergate APE (0x5001910c)
[16:16:45:863] W> mb2_unpowergate_ape: skip! APE is in unpowergated state
[16:16:45:872] I> Task: OEM firewalls (0x500259e4)
[16:16:45:900] I> OEM firewalls configured
[16:16:45:900] I> Task: Powergate APE (0x50019280)
[16:16:45:900] I> Powergating APE
[16:16:45:900] I> Powergate done
[16:16:45:900] I> Task: OEM firewall restore saved settings (0x50025e38)
[16:16:45:911] I> Task: Unhalt AUXPs (0x50028bf4)
[16:16:45:911] I> Unhalting SPE..
[16:16:45:911] I> Enabling combined UART
[16:16:45:927] <break>
[16:16:45:927] <0xff><0xfd><0xff><0xe0>spe: early_init
[16:16:45:927] <0xff><0xb8><0xff><0xe0>vic initialized
[16:16:45:927] <0xff><0xb8><0xff><0xe0>tsc initialized
[16:16:45:927] <0xff><0xb8><0xff><0xe0>aon lic initialized
[16:16:45:927] <0xff><0xb8><0xff><0xe0>spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
[16:16:45:938] <0xff><0xb8><0xff><0xe0>spe: SafeRTOS v8.4
[16:16:45:938] <0xff><0xb8><0xff><0xe0>spe: init
[16:16:45:938] <0xff><0xb8><0xff><0xe0>scheduler initialized
[16:16:45:938] <0xff><0xb8><0xff><0xe0>aon hsp initialized
[16:16:45:938] <0xff><0xb8><0xff><0xe0>tag initialized
[16:16:45:938] <0xff><0xb8><0xff><0xe0>tcu initialized
[16:16:45:949] <0xff><0xb8><0xff><0xe0>bpmp ipc initialized
[16:16:45:949] <0xff><0xb8><0xff><0xe0>spe: late init
[16:16:45:949] <0xff><0xb8><0xff><0xe0>cpu_nic clock initialized
[16:16:45:949] <0xff><0xb8><0xff><0xe0>apb clock initialized
[16:16:45:949] <0xff><0xb8><0xff><0xe0>pm initialized
[16:16:45:960] <0xff><0xb8><0xff><0xe0>bpmp hsp initialized
[16:16:45:960] <0xff><0xb8><0xff><0xe0>top1 hsp initialized
[16:16:45:960] <0xff><0xb8><0xff><0xe0>ccplex ipc initialized
[16:16:45:960] <0xff><0xb8><0xff><0xe0>spe: start scheduler
[16:16:45:960] <0xff><0xb8><0xff><0xe1>
[16:16:45:960] I> Task: Trigger mailbox for PSC-BL1 exit (0x500185c8)
[16:16:45:972] I> Sending opcode 0x4d420802 to psc
[16:16:45:972] <0xff><0xe7>INFO: Entering psc_monitor_init!
[16:16:45:972] INFO: GSC22 BOM:0x178002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
[16:16:45:983] INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
[16:16:45:983] INFO: mstatus:0xa00000808
[16:16:45:994] INFO: Supervisor entry_point:c108c00
[16:16:45:994] <0xff><0xe1>I> Received ACK from psc
[16:16:45:994] I> Tas<0xff><0xe7>INFO: MONITOR: user task addr:0x178022000, blob offset:0x00020000
[16:16:46:005] INFO: MONITOR: populated user images:13
[16:16:46:005] INFO: mret to Supervisor!
[16:16:46:005] INFO: psc supervisor init.
[16:16:46:016] INFO: psc_irq_init...
[16:16:46:016] INFO: enter idle task.
[16:16:46:016] <0xff><0xe2>
[16:16:46:016] hwwdt_init: WDT boot cfg 0x710010 sts 0x10
[16:16:46:016] bpmp: socket 0
[16:16:46:016] bpmp: base binary md5 is da583751bbfe2b7f6e204562d97ff39e
[16:16:46:028] bpmp: combined binary md5 is e941463f35523d12ee540d9bc33bc02f
[16:16:46:028] bpmp: firmware tag is e941463f35523d12ee54-da583751bbf
[16:16:46:039] Control register check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
[16:16:46:050] Write control check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 0f18000b != actual value: 00000000 address: 13a159c8
[16:16:46:061] Control register check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
[16:16:46:072] initialized vwdt
[16:16:46:072] initialized mail_early
[16:16:46:072] initialized fuse
[16:16:46:072] initialized vfrel
[16:16:46:084] initialized adc
[16:16:46:084] fmon_populate_monitors: found 199 monitors
[16:16:46:084] initialized fmon
[16:16:46:084] initialized mc
[16:16:46:084] initialized reset
[16:16:46:095] initialized uphy_early
[16:16:46:095] initialized emc_early
[16:16:46:095] initialized pm
[16:16:46:095] 465 clocks registered
[16:16:46:095] initialized clk_mach
[16:16:46:095] initialized clk_cal_early
[16:16:46:106] initialized clk_mach_early_config
[16:16:46:106] initialized io_dpd
[16:16:46:106] initialized soctherm
[16:16:46:106] initialized regime
[16:16:46:106] initialized i2c
[16:16:46:106] vrmon_dt_init: vrmon node not found
[16:16:46:117] vrmon_chk_boot_state: found 0 rail monitors
[16:16:46:117] initialized vrmon
[16:16:46:117] initialized regulator
[16:16:46:117] initialized avfs_clk_platform
[16:16:46:128] initialized powergate
[16:16:46:128] initialized dvs
[16:16:46:128] initialized clk_mach_config
[16:16:46:128] initialized suspend
[16:16:46:128] initialized strap
[16:16:46:140] initialized mce_dbell
[16:16:46:140] <0xff><0xe1>k: Start secure NOR provision (0x5001b7f4)<0xff><0xe2>initialized emc
[16:16:46:140] initialized emc_mrq
[16:16:46:140] I> Task: Load FSI keyblob (0x5<0xff><0xe2>initialized clk_cal
[16:16:46:151] initialized uphy_dt
[16:16:46:151] initialized uphy_mrq
[16:16:46:151] HSIO UPHY reset has been de-asserted 0x0
[16:16:46:162] initialized pg_late
[16:16:46:162] initialized pg_mrq_init
[16:16:46:162] swdtimer_init: reg polling start w period 47 ms
[16:16:46:162] initialized swdtimer
[16:16:46:173] initialized hwwdt_late
[16:16:46:173] initialized bwmgr
[16:16:46:173] initialized thermal_host_trip
[16:16:46:173] initialized thermal_mrq
[16:16:46:173] initialized oc_mrq
[16:16:46:173] initialized reset_mrq
[16:16:46:184] initialized mail_mrq
[16:16:46:184] initialized fmon_mrq
[16:16:46:184] initialized clk_mrq
[16:16:46:184] initialized avfs_mrq
[16:16:46:184] initialized i2c_mrq
[16:16:46:184] initialized tag_mrq
[16:16:46:196] initialized bwmgr_mrq
[16:16:46:196] initialized console_mrq
[16:16:46:196] missing prod DT calibration data for 199 fmons
[16:16:46:196] initialized clk_sync_fmon_post
[16:16:46:207] <0xff><0xe1>00189ec)
[16:16:46:207] I> Task: Unh<0xff><0xe2>initialized clk_cal_late
[16:16:46:207] initialized noc_late
[16:16:46:207] initialized cvc
[16:16:46:207] <0xff><0xe1>alt AUXPs (0x50028bfc)
[16:16:46:218] I> SCE<0xff><0xe2>initialized avfs_clk_mach_post
[16:16:46:218] initialized avfs_clk_platform_post
[16:16:46:218] initialized cvc_late
[16:16:46:218] WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
[16:16:46:229] WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
[16:16:46:240] WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
[16:16:46:240] WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
[16:16:46:252] WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
[16:16:46:263] WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
[16:16:46:263] WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
[16:16:46:274] WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
[16:16:46:285] WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
[16:16:46:296] WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
[16:16:46:296] initialized rm
[16:16:46:296] initialized console_late
[16:16:46:308] handling unreferenced clks
[16:16:46:308] enable can1_core
[16:16:46:308] enable can1_host
[16:16:46:308] enable can2_core
[16:16:46:308] enable can2_host
[16:16:46:308] enable pwm3
[16:16:46:308] enable sdmmc4_axicif
[16:16:46:319] enable mss_encrypt
[16:16:46:319] enable maud
[16:16:46:319] enable pllg_ref
[16:16:46:319] enable dsi_core
[16:16:46:319] enable aza_2xbit
[16:16:46:319] enable xusb_ss
[16:16:46:319] enable xusb_fs
[16:16:46:319] enable xusb_falcon
[16:16:46:330] enable xusb_core_mux
[16:16:46:330] enable dsi_lp
[16:16:46:330] clk_check_max_rate: pex1_c6_core rate 500000000 > max 250000000
[16:16:46:330] clk_check_max_rate: pex2_c7_core rate 500000000 > max 250000000
[16:16:46:341] clk_check_max_rate: pex2_c8_core rate 500000000 > max 250000000
[16:16:46:341] clk_check_max_rate: pex2_c9_core rate 500000000 > max 250000000
[16:16:46:352] clk_check_max_rate: pex2_c10_core rate 500000000 > max 250000000
[16:16:46:352] clk_check_max_rate: pex0_c0_core rate 500000000 > max 250000000
[16:16:46:364] clk_check_max_rate: pex0_c1_core rate 500000000 > max 250000000
[16:16:46:364] clk_check_max_rate: pex0_c2_core rate 500000000 > max 250000000
[16:16:46:375] clk_check_max_rate: pex0_c3_core rate 500000000 > max 250000000
[16:16:46:386] clk_check_max_rate: pex0_c4_core rate 500000000 > max 250000000
[16:16:46:386] clk_check_max_rate: pex1_c5_core rate 500000000 > max 250000000
[16:16:46:397] initialized clk_mach_post
[16:16:46:397] initialized pg_post
[16:16:46:397] initialized regulator_post
[16:16:46:397] initialized profile
[16:16:46:397] initialized mrq
[16:16:46:397] initialized patrol_scrubber
[16:16:46:408] initialized cactmon
[16:16:46:408] initialized extras_post
[16:16:46:408] bpmp: init complete
[16:16:46:408] <0xff><0xe1> unhalt skipped
[16:16:46:408] I> Unhalting RCE
[16:16:46:408] I> RCE unhalt success<0xff><0xe5>[     2.701533] Camera-FW on t234-rce-safe started
[16:16:46:420] TCU early console enabled.
[16:16:46:420] <0xff><0xe1>ful
[16:16:46:420] I> DCE unhalt successful
[16:16:46:431] I> APE unhalt skipped
[16:16:46:431] I> FSI unhalt skipped
[16:16:46:431] I> Task: Load CPUBL (0x50019ab4)
[16:16:46:431] I> Task: Load TOS (0x5001a244)
[16:16:46:431] <0xff><0xe8>
[16:16:46:431] <0xff><0xe1>I> Task: Load and authenticate registered FWs (0x5001ed44)
[16:16:46:442] I> Active chain: 0
[16:16:46:442] I> Partition name: A_cpu-bootloader
[16:16:46:442] I> Size of partition: 3670016
[16:16:46:453] I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
[16:16:46:453] I> cpubl : oem authentication of header done
[16:16:46:463] I> cpubl : meta-blob integrity check is success.
[16:16:46:463] E> LOADER: Page<break>
[16:16:46:538] <break>
[16:16:46:538] <0xff><0xe2>
[16:16:46:538] [0000.066] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[16:16:46:538] [0000.071] I> t234-A01-1-Silicon (0x12347) Prod
[16:16:46:538] [0000.076] I> Boot-mode : Coldboot
[16:16:46:549] [0000.079] I> Entry timestamp: 0x00000000
[16:16:46:549] [0000.082] I> last_boot_error: 0x0
[16:16:46:549] [0000.086] I> BR-BCT: preprod_dev_sign: 0
[16:16:46:558] [0000.089] I> rst_source: 0xb, rst_level: 0x1
[16:16:46:568] [0000.093] I> Task: SE error check
[16:16:46:568] [0000.097] I> Task: Bootchain select WAR set
[16:16:46:568] [0000.101] I> Task: Enable SLCG
[16:16:46:568] [0000.104] I> Task: CRC check
[16:16:46:577] [0000.107] I> Task: Initialize MB2 params
[16:16:46:585] [0000.111] I> MB2-params @ 0x40060000
[16:16:46:585] [0000.114] I> Task: Crypto init
[16:16:46:585] [0000.117] I> Task: Perform MB1 KAT tests
[16:16:46:585] [0000.121] I> Task: NVRNG health check
[16:16:46:597] [0000.125] I> NVRNG: Health check success
[16:16:46:597] [0000.128] I> Task: MSS Bandwidth limiter settings for iGPU clients
[16:16:46:606] [0000.134] I> Task: Enabling and initialization of Bandwidth limiter
[16:16:46:606] [0000.141] I> No request to configure MBWT settings for any PC!
[16:16:46:617] [0000.146] I> Task: Secure debug controls
[16:16:46:617] [0000.150] I> Task: strap war set
[16:16:46:617] [0000.153] I> Task: Initialize SOC Therm
[16:16:46:626] [0000.157] I> Task: Program NV master stream id
[16:16:46:626] [0000.161] I> Task: Verify boot mode
[16:16:46:639] [0000.167] I> Task: Alias fuses
[16:16:46:639] [0000.170] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[16:16:46:639] [0000.177] I> Task: Print SKU type
[16:16:46:650] [0000.180] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000078
[16:16:46:650] [0000.185] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[16:16:46:662] [0000.190] I> FUSE_OPT_TPC_DISABLE = 0x000000fc
[16:16:46:662] [0000.194] I> FUSE_OPT_DLA_DISABLE = 0x00000003
[16:16:46:662] [0000.198] I> FUSE_OPT_PVA_DISABLE = 0x00000001
[16:16:46:673] [0000.203] I> FUSE_OPT_NVENC_DISABLE = 0x00000001
[16:16:46:673] [0000.207] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[16:16:46:673] [0000.211] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[16:16:46:684] [0000.216] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[16:16:46:684] [0000.220] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[16:16:46:695] [0000.224] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[16:16:46:695] [0000.228] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[16:16:46:695] [0000.232] I> FUSE_SKU_INFO_0 = 0xd6
[16:16:46:706] [0000.236] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[16:16:46:706] [0000.240] I> FUSE_PACKAGE_INFO_0 = 0x2
[16:16:46:706] [0000.243] I> SKU: Prod
[16:16:46:717] [0000.246] I> Task: Boost clocks
[16:16:46:717] [0000.249] I> Initializing PLLC2 for AXI_CBB.
[16:16:46:717] [0000.253] I> AXI_CBB : src = 35, divisor = 0
[16:16:46:729] [0000.257] I> Task: Voltage monitor
[16:16:46:729] [0000.260] I> VMON: Vmon re-calibration and fine tuning done
[16:16:46:729] [0000.266] I> Task: UPHY init
[16:16:46:751] [0000.271] I> HSIO UPHY init done
[16:16:46:751] [0000.274] W> Skipping GBE UPHY config
[16:16:46:751] [0000.277] I> Task: Boot device init
[16:16:46:751] [0000.280] I> Boot_device: QSPI_FLASH instance: 0
[16:16:46:759] [0000.285] I> Qspi clock source : pllc_out0
[16:16:46:759] [0000.289] I> QSPI Flash: Macronix 64MB
[16:16:46:759] [0000.293] I> QSPI-0l initialized successfully
[16:16:46:766] [0000.297] I> Task: TSC init
[16:16:46:766] [0000.300] I> Task: Load membct
[16:16:46:766] [0000.303] I> RAM_CODE 0x4000441
[16:16:46:777] [0000.306] I> Loading MEMBCT
[16:16:46:777] [0000.309] I> Slot: 1
[16:16:46:777] [0000.311] I> Binary[1] block-66816 (partition size: 0x40000)
[16:16:46:788] [0000.316] I> Binary name: MEM-BCT-1
[16:16:46:788] [0000.319] I> Size of crypto header is 8192
[16:16:46:788] [0000.323] I> Size of crypto header is 8192
[16:16:46:800] [0000.327] I> strt_pg_num(66816) num_of_pgs(16) read_buf(0x40050000)
[16:16:46:800] [0000.334] I> BCH of MEM-BCT-1 read from storage
[16:16:46:800] [0000.338] I> BCH address is : 0x40050000
[16:16:46:811] [0000.342] I> MEM-BCT-1 header integrity check is success
[16:16:46:811] [0000.347] I> Binary magic in BCH component 1 is MEM1
[16:16:46:822] [0000.352] I> component binary type is 1
[16:16:46:822] [0000.356] I> strt_pg_num(66947) num_of_pgs(115) read_buf(0x40040000)
[16:16:46:840] [0000.363] I> MEM-BCT-1 binary is read from storage
[16:16:46:840] [0000.367] I> MEM-BCT-1 binary integrity check is success
[16:16:46:840] [0000.372] I> Binary MEM-BCT-1 loaded successfully at 0x40040000 (0xe580)
[16:16:46:849] [0000.379] I> RAM_CODE 0x4000441
[16:16:46:849] [0000.384] I> RAM_CODE 0x4000441
[16:16:46:860] [0000.388] I> Task: Load Page retirement list
[16:16:46:860] [0000.392] I> Task: SDRAM params override
[16:16:46:860] [0000.396] I> Task: Save mem-bct info
[16:16:46:872] [0000.400] I> Task: Carveout allocate
[16:16:46:872] [0000.403] I> RCM blob carveout will not be allocated
[16:16:46:872] [0000.408] I> Update CCPLEX IST carveout from MB1-BCT
[16:16:46:883] [0000.413] I> ECC region[0]: Start:0x0, End:0x0
[16:16:46:883] [0000.417] I> ECC region[1]: Start:0x0, End:0x0
[16:16:46:883] [0000.421] I> ECC region[2]: Start:0x0, End:0x0
[16:16:46:894] [0000.425] I> ECC region[3]: Start:0x0, End:0x0
[16:16:46:894] [0000.430] I> ECC region[4]: Start:0x0, End:0x0
[16:16:46:905] [0000.434] I> Non-ECC region[0]: Start:0x80000000, End:0x180000000
[16:16:46:905] [0000.440] I> Non-ECC region[1]: Start:0x0, End:0x0
[16:16:46:916] [0000.445] I> Non-ECC region[2]: Start:0x0, End:0x0
[16:16:46:916] [0000.449] I> Non-ECC region[3]: Start:0x0, End:0x0
[16:16:46:916] [0000.454] I> Non-ECC region[4]: Start:0x0, End:0x0
[16:16:46:937] [0000.464] I> allocated(CO:43) base:0x17c000000 size:0x4000000 align: 0x200000
[16:16:46:937] [0000.472] I> allocated(CO:39) base:0x179e00000 size:0x2200000 align: 0x10000
[16:16:46:948] [0000.478] I> allocated(CO:20) base:0x176000000 size:0x2000000 align: 0x2000000
[16:16:46:948] [0000.486] I> allocated(CO:24) base:0x174000000 size:0x2000000 align: 0x2000000
[16:16:46:959] [0000.493] I> allocated(CO:28) base:0x172000000 size:0x2000000 align: 0x2000000
[16:16:46:970] [0000.500] I> allocated(CO:22) base:0x178000000 size:0x1000000 align: 0x1000000
[16:16:46:970] [0000.507] I> allocated(CO:35) base:0x179000000 size:0xe00000 align: 0x10000
[16:16:46:983] [0000.514] I> allocated(CO:02) base:0x171800000 size:0x800000 align: 0x800000
[16:16:46:993] [0000.521] I> allocated(CO:03) base:0x171000000 size:0x800000 align: 0x800000
[16:16:46:993] [0000.528] I> allocated(CO:06) base:0x170800000 size:0x800000 align: 0x800000
[16:16:47:004] [0000.535] I> allocated(CO:56) base:0x170000000 size:0x800000 align: 0x200000
[16:16:47:004] [0000.542] I> allocated(CO:07) base:0x16fc00000 size:0x400000 align: 0x400000
[16:16:47:015] [0000.549] I> allocated(CO:33) base:0x16f800000 size:0x400000 align: 0x200000
[16:16:47:027] [0000.555] I> allocated(CO:23) base:0x16f600000 size:0x200000 align: 0x200000
[16:16:47:027] [0000.562] I> allocated(CO:01) base:0x16f500000 size:0x100000 align: 0x100000
[16:16:47:038] [0000.569] I> allocated(CO:05) base:0x16f400000 size:0x100000 align: 0x100000
[16:16:47:038] [0000.576] I> allocated(CO:08) base:0x16f300000 size:0x100000 align: 0x100000
[16:16:47:049] [0000.583] I> allocated(CO:09) base:0x16f200000 size:0x100000 align: 0x100000
[16:16:47:060] [0000.590] I> allocated(CO:15) base:0x16f100000 size:0x100000 align: 0x100000
[16:16:47:060] [0000.597] I> allocated(CO:17) base:0x16f000000 size:0x100000 align: 0x100000
[16:16:47:072] [0000.604] I> allocated(CO:27) base:0x16ef00000 size:0x100000 align: 0x100000
[16:16:47:084] [0000.611] I> allocated(CO:42) base:0x16ee00000 size:0x100000 align: 0x100000
[16:16:47:084] [0000.618] I> allocated(CO:54) base:0x16ed80000 size:0x80000 align: 0x80000
[16:16:47:094] [0000.625] I> allocated(CO:34) base:0x16ed70000 size:0x10000 align: 0x10000
[16:16:47:094] [0000.631] I> allocated(CO:72) base:0x16eb70000 size:0x200000 align: 0x10000
[16:16:47:105] [0000.638] I> allocated(CO:47) base:0x16e600000 size:0x400000 align: 0x200000
[16:16:47:117] [0000.645] I> allocated(CO:48) base:0x16eb50000 size:0x20000 align: 0x10000
[16:16:47:117] [0000.652] I> allocated(CO:69) base:0x16eb30000 size:0x20000 align: 0x10000
[16:16:47:128] [0000.659] I> allocated(CO:49) base:0x16eb20000 size:0x10000 align: 0x10000
[16:16:47:128] [0000.666] I> allocated(CO:50) base:0x16eb10000 size:0x10000 align: 0x10000
[16:16:47:139] [0000.672] I> NSDRAM base: 0x80000000, end: 0x16eb70000, size: 0xeeb70000
[16:16:47:150] [0000.679] I> Task: Thermal check
[16:16:47:150] [0000.682] I> Using min_chip_limit as min_tmon_limit
[16:16:47:150] [0000.687] I> Using max_chip_limit as max_tmon_limit
[16:16:47:161] [0000.691] I> BCT max_tmon_limit = 105
[16:16:47:161] [0000.695] I> BCT min_tmon_limit = -28
[16:16:47:161] [0000.698] I> BCT max_tmon_limit = 105
[16:16:47:173] [0000.702] I> BCT min_tmon_limit = -28
[16:16:47:173] [0000.705] I> SKU specific max_chip_limit = 105
[16:16:47:173] [0000.710] I> SKU specific min_chip_limit = -28
[16:16:47:184] [0000.714] I> BCT max_chip_limit = 105
[16:16:47:184] [0000.717] I> BCT min_chip_limit = -28
[16:16:47:184] [0000.721] I> enable_soctherm_polling = 0
[16:16:47:195] [0000.725] I> max temp read = 29
[16:16:47:195] [0000.728] I> min temp read = 28
[16:16:47:195] [0000.731] I> Enabling thermtrip
[16:16:47:195] [0000.734] I> Task: Update FSI SCR with thermal fuse data
[16:16:47:206] [0000.739] I> Task: Enable WDT 5th expiry
[16:16:47:206] [0000.743] I> Task: I2C register
[16:16:47:216] [0000.745] I> Task: Set I2C bus freq
[16:16:47:216] [0000.749] I> Task: Reset FSI
[16:16:47:216] [0000.752] I> Task: Pinmux init
[16:16:47:227] [0000.755] I> skipped mmio_addr = 0x9240008
[16:16:47:227] [0000.759] I> skipped mmio_addr = 0x9240000
[16:16:47:227] [0000.763] I> skipped mmio_addr = 0x9240010
[16:16:47:238] [0000.767] I> skipped mmio_addr = 0x9240018
[16:16:47:238] [0000.771] I> skipped mmio_addr = 0x9240020
[16:16:47:238] [0000.774] I> skipped mmio_addr = 0x9240030
[16:16:47:249] [0000.778] I> skipped mmio_addr = 0x9240028
[16:16:47:249] [0000.782] I> skipped mmio_addr = 0x9240038
[16:16:47:249] [0000.786] I> skipped mmio_addr = 0x9240040
[16:16:47:261] [0000.790] I> skipped mmio_addr = 0x9240048
[16:16:47:261] [0000.794] I> skipped mmio_addr = 0x9241000
[16:16:47:261] [0000.798] I> skipped mmio_addr = 0x9241008
[16:16:47:272] [0000.802] I> skipped mmio_addr = 0x9241010
[16:16:47:272] [0000.806] I> skipped mmio_addr = 0x9241018
[16:16:47:272] [0000.810] I> skipped mmio_addr = 0x9241020
[16:16:47:283] [0000.814] I> skipped mmio_addr = 0x9241028
[16:16:47:283] [0000.818] I> skipped mmio_addr = 0x9241030
[16:16:47:283] [0000.822] I> skipped mmio_addr = 0x9241038
[16:16:47:294] [0000.826] I> skipped mmio_addr = 0x9241040
[16:16:47:294] [0000.830] I> skipped mmio_addr = 0x9242000
[16:16:47:305] [0000.834] I> skipped mmio_addr = 0x9242008
[16:16:47:305] [0000.838] I> Task: Prod config init
[16:16:47:305] [0000.841] I> Task: Pad voltage init
[16:16:47:305] [0000.844] I> Task: Prod init
[16:16:47:317] [0000.847] I> Task: Program rst req config reg
[16:16:47:317] [0000.851] I> Task: Common rail init
[16:16:47:317] [0000.855] I> DONE: Thermal config
[16:16:47:335] [0000.858] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[16:16:47:335] [0000.867] I> DONE: SOC rail config
[16:16:47:342] [0000.870] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[16:16:47:342] [0000.877] I> DONE: MEMIO rail config
[16:16:47:353] [0000.880] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[16:16:47:353] [0000.887] I> DONE: GPU rail info
[16:16:47:353] [0000.890] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[16:16:47:364] [0000.896] I> DONE: CV rail info
[16:16:47:364] [0000.899] I> Task: Mem clock src
[16:16:47:364] [0000.902] I> Task: Misc. board config
[16:16:47:383] [0000.906] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[16:16:47:383] [0000.912] I> Task: SDRAM init
[16:16:47:383] [0000.914] I> MemoryType: 4 MemBctRevision: 2
[16:16:47:393] [0000.921] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 2
[16:16:47:393] [0000.929] I> MSS CAR: Init PLLM
[16:16:47:393] [0000.932] I> MSS CAR: Init PLLHUB
[16:16:47:410] [0000.936] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[16:16:47:420] [0000.948] I> SDRAM initialized!
[16:16:47:420] [0000.950] I> SDRAM Size in Total 0x100000000
[16:16:47:420] [0000.955] I> Task: Dram Ecc scrub
[16:16:47:420] [0000.958] I> Task: DRAM alias check
[16:16:47:435] [0000.962] I> Task: Program NSDRAM carveout
[16:16:47:435] [0000.966] I> NSDRAM carveout encryption is enabled
[16:16:47:435] [0000.971] I> Program NSDRAM carveout
[16:16:47:444] [0000.974] I> Task: Register checker
[16:16:47:444] [0000.978] I> Task: Enable clock-mon
[16:16:47:454] [0000.982] I> FMON: Fmon re-programming done
[16:16:47:454] [0000.986] I> Task: Mapper init
[16:16:47:454] [0000.989] I> Task: SC7 Context Init
[16:16:47:454] [0000.992] I> Task: CCPLEX IST init
[16:16:47:466] [0000.995] I> Task: CPU WP0
[16:16:47:466] [0000.998] I> Loading MCE
[16:16:47:466] [0001.001] I> Slot: 1
[16:16:47:466] [0001.003] I> Binary[8] block-85760 (partition size: 0x80000)
[16:16:47:477] [0001.008] I> Binary name: MCE
[16:16:47:477] [0001.011] I> Size of crypto header is 8192
[16:16:47:477] [0001.015] I> Size of crypto header is 8192
[16:16:47:488] [0001.019] I> strt_pg_num(85760) num_of_pgs(16) read_buf(0x4003e000)
[16:16:47:488] [0001.025] I> BCH of MCE read from storage
[16:16:47:499] [0001.029] I> BCH address is : 0x4003e000
[16:16:47:499] [0001.033] I> MCE header integrity check is success
[16:16:47:499] [0001.037] I> Binary magic in BCH component 0 is MTSM
[16:16:47:511] [0001.042] I> component binary type is 8
[16:16:47:511] [0001.046] I> Size of crypto header is 8192
[16:16:47:518] [0001.050] I> strt_pg_num(85776) num_of_pgs(357) read_buf(0x40000000)
[16:16:47:529] [0001.058] I> MCE binary is read from storage
[16:16:47:537] [0001.063] I> MCE binary integrity check is success
[16:16:47:537] [0001.067] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[16:16:47:537] [0001.073] I> Size of crypto header is 8192
[16:16:47:555] [0001.085] I> Size of crypto header is 8192
[16:16:47:555] [0001.089] I> Sending WP0 mailbox command to PSC
[16:16:47:569] [0001.098] I> Task: XUSB Powergate
[16:16:47:569] [0001.101] I> Skipping powergate XUSB.
[16:16:47:569] [0001.104] I> Task: MB1 fixed firewalls
[16:16:47:578] [0001.111] W> Firewall readback mismatch
[16:16:47:588] [0001.116] I> Task: Load bpmp-fw
[16:16:47:588] [0001.119] I> Slot: 1
[16:16:47:588] [0001.121] I> Binary[15] block-72960 (partition size: 0x180000)
[16:16:47:588] [0001.126] I> Binary name: BPMP_FW
[16:16:47:599] [0001.129] I> Size of crypto header is 8192
[16:16:47:599] [0001.133] I> Size of crypto header is 8192
[16:16:47:599] [0001.137] I> strt_pg_num(72960) num_of_pgs(16) read_buf(0x807fe000)
[16:16:47:610] [0001.144] I> BCH of BPMP_FW read from storage
[16:16:47:610] [0001.148] I> BCH address is : 0x807fe000
[16:16:47:622] [0001.152] I> BPMP_FW header integrity check is success
[16:16:47:622] [0001.157] I> Binary magic in BCH component 0 is BPMF
[16:16:47:633] [0001.161] I> component binary type is 15
[16:16:47:633] [0001.165] I> Size of crypto header is 8192
[16:16:47:633] [0001.169] I> strt_pg_num(72976) num_of_pgs(1990) read_buf(0x80000000)
[16:16:47:653] [0001.187] I> BPMP_FW binary is read from storage
[16:16:47:665] [0001.193] I> BPMP_FW binary integrity check is success
[16:16:47:665] [0001.198] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[16:16:47:676] [0001.205] I> Slot: 1
[16:16:47:676] [0001.207] I> Binary[16] block-76032 (partition size: 0x400000)
[16:16:47:676] [0001.212] I> Binary name: BPMP_FW_DTB
[16:16:47:688] [0001.216] I> Size of crypto header is 8192
[16:16:47:688] [0001.220] I> Size of crypto header is 8192
[16:16:47:688] [0001.224] I> strt_pg_num(76032) num_of_pgs(16) read_buf(0x807fc000)
[16:16:47:699] [0001.230] I> BCH of BPMP_FW_DTB read from storage
[16:16:47:699] [0001.234] I> BCH address is : 0x807fc000
[16:16:47:710] [0001.238] I> BPMP_FW_DTB header integrity check is success
[16:16:47:710] [0001.244] I> Binary magic in BCH component 0 is BPMD
[16:16:47:710] [0001.248] I> component binary type is 16
[16:16:47:721] [0001.252] I> Size of crypto header is 8192
[16:16:47:721] [0001.256] I> strt_pg_num(76048) num_of_pgs(375) read_buf(0x807cd1f0)
[16:16:47:739] [0001.264] I> BPMP_FW_DTB binary is read from storage
[16:16:47:747] [0001.270] I> BPMP_FW_DTB binary integrity check is success
[16:16:47:747] [0001.275] I> Binary BPMP_FW_DTB loaded successfully at 0x807cd1f0 (0x2ed00)
[16:16:47:756] [0001.282] I> Task: BPMP fw ast config
[16:16:47:756] [0001.285] I> Task: Load psc-fw
[16:16:47:756] [0001.288] I> Slot: 1
[16:16:47:756] [0001.290] I> Binary[17] block-84224 (partition size: 0xc0000)
[16:16:47:764] [0001.296] I> Binary name: PSC_FW
[16:16:47:764] [0001.299] I> Size of crypto header is 8192
[16:16:47:764] [0001.303] I> Size of crypto header is 8192
[16:16:47:776] [0001.307] I> strt_pg_num(84224) num_of_pgs(16) read_buf(0x80ffe000)
[16:16:47:776] [0001.313] I> BCH of PSC_FW read from storage
[16:16:47:787] [0001.317] I> BCH address is : 0x80ffe000
[16:16:47:787] [0001.321] I> PSC_FW header integrity check is success
[16:16:47:798] [0001.326] I> Binary magic in BCH component 0 is PFWP
[16:16:47:798] [0001.331] I> component binary type is 17
[16:16:47:798] [0001.334] I> Size of crypto header is 8192
[16:16:47:808] [0001.338] I> strt_pg_num(84240) num_of_pgs(717) read_buf(0x80fa4600)
[16:16:47:816] [0001.349] I> PSC_FW binary is read from storage
[16:16:47:826] [0001.354] I> PSC_FW binary integrity check is success
[16:16:47:826] [0001.359] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[16:16:47:837] [0001.365] I> Task: Load nvdec-fw
[16:16:47:837] [0001.368] I> Slot: 1
[16:16:47:837] [0001.370] I> Binary[7] block-69376 (partition size: 0x100000)
[16:16:47:837] [0001.376] I> Binary name: NVDEC
[16:16:47:848] [0001.379] I> Size of crypto header is 8192
[16:16:47:848] [0001.383] I> Size of crypto header is 8192
[16:16:47:848] [0001.387] I> strt_pg_num(69376) num_of_pgs(16) read_buf(0x800fe000)
[16:16:47:860] [0001.393] I> BCH of NVDEC read from storage
[16:16:47:860] [0001.397] I> BCH address is : 0x800fe000
[16:16:47:871] [0001.401] I> NVDEC header integrity check is success
[16:16:47:871] [0001.406] I> Binary magic in BCH component 0 is NDEC
[16:16:47:882] [0001.410] I> component binary type is 7
[16:16:47:882] [0001.414] I> Size of crypto header is 8192
[16:16:47:882] [0001.418] I> strt_pg_num(69392) num_of_pgs(560) read_buf(0x80000000)
[16:16:47:899] [0001.427] I> NVDEC binary is read from storage
[16:16:47:907] [0001.432] I> NVDEC binary integrity check is success
[16:16:47:907] [0001.437] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[16:16:47:907] [0001.443] I> Size of crypto header is 8192
[16:16:47:927] [0001.455] I> Task: Load tsec-fw
[16:16:47:927] [0001.458] I> TSEC-FW load support not enabled
[16:16:47:927] [0001.462] I> Task: GPIO interrupt map
[16:16:47:927] [0001.465] I> Task: SC7 context save
[16:16:47:938] [0001.469] I> Slot: 1
[16:16:47:938] [0001.471] I> Binary[27] block-0 (partition size: 0x100000)
[16:16:47:938] [0001.476] I> Binary name: BR_BCT
[16:16:47:949] [0001.479] I> Size of crypto header is 8192
[16:16:47:949] [0001.483] I> Size of crypto header is 8192
[16:16:47:949] [0001.487] I> Size of crypto header is 8192
[16:16:47:961] [0001.491] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[16:16:47:961] [0001.497] I> BR_BCT binary is read from storage
[16:16:47:972] [0001.501] I> BR_BCT binary integrity check is success
[16:16:47:972] [0001.506] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[16:16:47:983] [0001.513] I> Slot: 1
[16:16:47:983] [0001.515] I> Binary[13] block-86784 (partition size: 0x30000)
[16:16:47:983] [0001.520] I> Binary name: SC7-FW
[16:16:47:994] [0001.523] I> Size of crypto header is 8192
[16:16:47:994] [0001.527] I> Size of crypto header is 8192
[16:16:47:994] [0001.531] I> Size of crypto header is 8192
[16:16:48:003] [0001.535] I> Size of crypto header is 8192
[16:16:48:013] [0001.539] I> strt_pg_num(86784) num_of_pgs(16) read_buf(0xa0002000)
[16:16:48:013] [0001.545] I> BCH of SC7-FW read from storage
[16:16:48:013] [0001.549] I> BCH address is : 0xa0002000
[16:16:48:023] [0001.553] I> SC7-FW header integrity check is success
[16:16:48:023] [0001.558] I> Binary magic in BCH component 0 is WB0B
[16:16:48:034] [0001.563] I> component binary type is 13
[16:16:48:034] [0001.567] I> Size of crypto header is 8192
[16:16:48:034] [0001.571] I> strt_pg_num(86800) num_of_pgs(349) read_buf(0xa0004000)
[16:16:48:051] [0001.579] I> SC7-FW binary is read from storage
[16:16:48:059] [0001.584] I> SC7-FW binary integrity check is success
[16:16:48:059] [0001.588] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[16:16:48:069] [0001.595] I> Slot: 1
[16:16:48:069] [0001.597] I> Binary[22] block-87168 (partition size: 0x30000)
[16:16:48:069] [0001.602] I> Binary name: PSC_RF
[16:16:48:069] [0001.606] I> Size of crypto header is 8192
[16:16:48:079] [0001.609] I> Size of crypto header is 8192
[16:16:48:079] [0001.613] I> Size of crypto header is 8192
[16:16:48:089] [0001.617] I> Size of crypto header is 8192
[16:16:48:089] [0001.621] I> strt_pg_num(87168) num_of_pgs(16) read_buf(0xa002fa00)
[16:16:48:089] [0001.628] I> BCH of PSC_RF read from storage
[16:16:48:101] [0001.632] I> BCH address is : 0xa002fa00
[16:16:48:101] [0001.635] I> PSC_RF header integrity check is success
[16:16:48:112] [0001.640] I> Binary magic in BCH component 0 is PSCR
[16:16:48:112] [0001.645] I> component binary type is 22
[16:16:48:112] [0001.649] I> Size of crypto header is 8192
[16:16:48:121] [0001.653] I> strt_pg_num(87184) num_of_pgs(224) read_buf(0xa0031a00)
[16:16:48:133] [0001.660] I> PSC_RF binary is read from storage
[16:16:48:133] [0001.665] I> PSC_RF binary integrity check is success
[16:16:48:133] [0001.670] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x1be60)
[16:16:48:151] [0001.679] I> Task: Save WP0 payload to SC7 ctx
[16:16:48:151] [0001.684] I> Task: Load MB2rf binary to SC7 ctx
[16:16:48:151] [0001.688] I> Slot: 1
[16:16:48:151] [0001.690] I> Binary[14] block-87552 (partition size: 0x20000)
[16:16:48:163] [0001.696] I> Binary name: MB2_RF
[16:16:48:163] [0001.699] I> Size of crypto header is 8192
[16:16:48:174] [0001.703] I> Size of crypto header is 8192
[16:16:48:174] [0001.706] I> Size of crypto header is 8192
[16:16:48:174] [0001.710] I> Size of crypto header is 8192
[16:16:48:185] [0001.714] I> strt_pg_num(87552) num_of_pgs(16) read_buf(0xa00d6aa0)
[16:16:48:185] [0001.721] I> BCH of MB2_RF read from storage
[16:16:48:196] [0001.725] I> BCH address is : 0xa00d6aa0
[16:16:48:196] [0001.729] I> MB2_RF header integrity check is success
[16:16:48:196] [0001.733] I> Binary magic in BCH component 0 is MB2R
[16:16:48:208] [0001.738] I> component binary type is 14
[16:16:48:208] [0001.742] I> Size of crypto header is 8192
[16:16:48:208] [0001.746] I> strt_pg_num(87568) num_of_pgs(223) read_buf(0xa00d8aa0)
[16:16:48:226] [0001.753] I> MB2_RF binary is read from storage
[16:16:48:226] [0001.758] I> MB2_RF binary integrity check is success
[16:16:48:226] [0001.763] I> Binary MB2_RF loaded successfully at 0xa00d8aa0 (0x1bcc0)
[16:16:48:237] [0001.769] I> Task: Save fuse alias data to SC7 ctx
[16:16:48:237] [0001.774] I> Task: Save PMIC data to SC7 ctx
[16:16:48:248] [0001.778] I> Task: Save Pinmux data to SC7 ctx
[16:16:48:248] [0001.782] I> Task: Save Pad Voltage data to SC7 ctx
[16:16:48:248] [0001.787] I> Task: Save controller prod data to SC7 ctx
[16:16:48:259] [0001.792] I> Task: Save prod cfg data to SC7 ctx
[16:16:48:259] [0001.797] I> Task: Save I2C bus freq data to SC7 ctx
[16:16:48:271] [0001.801] I> Task: Save SOCTherm data to SC7 ctx
[16:16:48:271] [0001.806] I> Task: Save FMON data to SC7 ctx
[16:16:48:282] [0001.810] I> Task: Save VMON data to SC7 ctx
[16:16:48:282] [0001.814] I> Task: Save TZDRAM data to SC7 ctx
[16:16:48:282] [0001.818] I> Task: Save GPIO int data to SC7 ctx
[16:16:48:293] [0001.823] I> Task: Save clock data to SC7 ctx
[16:16:48:293] [0001.827] I> Task: Save debug data to SC7 ctx
[16:16:48:293] [0001.831] I> Task: Save MBWT data to SC7 ctx
[16:16:48:312] [0001.839] I> SC7 context save done
[16:16:48:312] [0001.843] I> Task: Load MB2/Applet/FSKP
[16:16:48:312] [0001.846] I> Loading MB2
[16:16:48:312] [0001.849] I> Slot: 1
[16:16:48:323] [0001.851] I> Binary[6] block-71424 (partition size: 0x80000)
[16:16:48:323] [0001.856] I> Binary name: MB2
[16:16:48:323] [0001.859] I> Size of crypto header is 8192
[16:16:48:334] [0001.863] I> Size of crypto header is 8192
[16:16:48:334] [0001.867] I> strt_pg_num(71424) num_of_pgs(16) read_buf(0x8007e000)
[16:16:48:345] [0001.873] I> BCH of MB2 read from storage
[16:16:48:345] [0001.877] I> BCH address is : 0x8007e000
[16:16:48:345] [0001.881] I> MB2 header integrity check is success
[16:16:48:356] [0001.885] I> Binary magic in BCH component 0 is MB2B
[16:16:48:356] [0001.890] I> component binary type is 6
[16:16:48:356] [0001.894] I> Size of crypto header is 8192
[16:16:48:366] [0001.898] I> strt_pg_num(71440) num_of_pgs(839) read_buf(0x80000000)
[16:16:48:375] [0001.909] I> MB2 binary is read from storage
[16:16:48:386] [0001.914] I> MB2 binary integrity check is success
[16:16:48:386] [0001.918] I> Binary MB2 loaded successfully at 0x80000000 (0x68c10)
[16:16:48:386] [0001.925] I> Task: Map CCPLEX SHARED carveout
[16:16:48:394] [0001.929] I> Task: Prepare MB2 params
[16:16:48:394] [0001.933] I> Task: Dram ecc test
[16:16:48:405] [0001.936] I> Task: Misc NV security settings
[16:16:48:405] [0001.940] I> NVDEC sticky bits programming done
[16:16:48:416] [0001.944] I> Successfully powergated NVDEC
[16:16:48:416] [0001.948] I> Task: Disable/Reload WDT
[16:16:48:416] [0001.952] I> Task: Program misc carveouts
[16:16:48:428] [0001.956] I> Program IPC carveouts
[16:16:48:428] [0001.959] I> Task: Disable SCPM/POD reset
[16:16:48:428] [0001.963] I> SLCG Global override status := 0x0
[16:16:48:437] [0001.967] I> MB1: MSS reconfig completed
[16:16:48:474] I> MB2 (version: 0.0.0.0-t234-54845784-7f6f63a6)
[16:16:48:474] I> t234-A01-1-Silicon (0x12347)
[16:16:48:474] I> Boot-mode : Coldboot
[16:16:48:474] I> Emulation:
[16:16:48:474] I> Entry timestamp: 0x001e7430
[16:16:48:485] I> Regular heap: [base:0x40040000, size:0x10000]
[16:16:48:485] I> DMA heap: [base:0x170000000, size:0x800000]
[16:16:48:485] I> Task: ARI update carveout TZDRAM (0x50002050)
[16:16:48:497] I> Task: Check MC errors (0x5000204c)
[16:16:48:497] I> Task: SMMU external bypass disable (0x500184fc)
[16:16:48:506] I> Task: Enable hot-plug capability (0x50028dec)
[16:16:48:506] I> Task: TZDRAM heap init (0x50019de0)
[16:16:48:517] I> Task: PSC mailbox init (0x50018548)
[16:16:48:517] I> Task: Crypto init (0x50006888)
[16:16:48:517] I> Task: Enable GP-SE clock (0x500021b4)
[16:16:48:517] I> Task: Measured Boot init (0x5001bd30)
[16:16:48:529] I> Task: fTPM silicon identity init (0x5001bedc)
[16:16:48:529] I> fTPM is not enabled.
[16:16:48:529] I> Task: OEM SC7 context save init (0x5001b27c)
[16:16:48:540] I> Task: I2C register (0x50002010)
[16:16:48:540] I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001ff8)
[16:16:48:551] I> Task: Program CBB PCIE AMAP regions (0x5001b9dc)
[16:16:48:551] I> Task: Boot device init (0x50001f40)
[16:16:48:551] I> Boot_device: QSPI_FLASH instance: 0
[16:16:48:562] I> Qspi clock source : pllc_out0
[16:16:48:562] I> QSPI-0l initialized successfully
[16:16:48:562] I> Task: Partition Manager Init (0x50001f20)
[16:16:48:562] I> Active chain: 1
[16:16:48:580] I> Found 57 partitions in QSPI_FLASH (instance 0)
[16:16:48:580] I> Task: Load and authenticate registered FWs (0x5001ed44)
[16:16:48:580] I> Task: Load AUXP FWs (0x50028970)
[16:16:48:589] I> Successfully register SPE FW load task with MB2 loader
[16:16:48:589] I> Skipping SCE FW load
[16:16:48:589] I> Successfully register RCE FW load task with MB2 loader
[16:16:48:598] I> Successfully register DCE FW load task with MB2 loader
[16:16:48:598] I> Unpowergating APE
[16:16:48:598] I> Unpowergate done
[16:16:48:609] I> Successfully register APE FW load task with MB2 loader
[16:16:48:609] I> Skipping FSI FW load
[16:16:48:609] I> Successfully register XUSB FW load task with MB2 loader
[16:16:48:620] I> Active chain: 1
[16:16:48:620] I> Partition name: B_spe-fw
[16:16:48:620] I> Size of partition: 589824
[16:16:48:620] I> Binary@ device:3/0 block-118016 (partition size: 0x90000), name: B_spe-fw
[16:16:48:639] I> Active chain: 1
[16:16:48:639] I> Partition name: B_rce-fw
[16:16:48:639] I> Size of partition: 1048576
[16:16:48:639] I> Binary@ device:3/0 block-119168 (partition size: 0x100000), name: B_rce-fw
[16:16:48:650] I> spe: Authentication Finalize Done
[16:16:48:650] I> Binary spe loaded successfully at 0x16f300000
[16:16:48:663] I> Active chain: 1
[16:16:48:663] I> Partition name: B_dce-fw
[16:16:48:663] I> Size of partition: 5242880
[16:16:48:663] I> Binary@ device:3/0 block-107776 (partition size: 0x500000), name: B_dce-fw
[16:16:48:681] I> rce: Authentication Finalize Done
[16:16:48:681] I> Binary rce loaded successfully at 0x16f000000
[16:16:48:681] I> Successfully register RCE FW context save task with MB2 loader
[16:16:48:690] I> dce : oem authentication of header done
[16:16:48:690] I> dce : meta-blob integrity check is success.
[16:16:48:703] I> dce : will be decompressed at 0x176000000
[16:16:48:703] I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
[16:16:48:703] I> Reserved10 0 BlockMaxSize 5 Reserved11 0
[16:16:48:737] I> dce : decompressed to 9449600 bytes
[16:16:48:765] I> dce: plain binary integrity check is success
[16:16:48:765] I> Active chain: 1
[16:16:48:765] I> Partition name: B_adsp-fw
[16:16:48:765] I> Size of partition: 2097152
[16:16:48:775] I> Binary@ device:3/0 block-121216 (partition size: 0x200000), name: B_adsp-fw
[16:16:48:785] I> dce: Authentication Finalize Done
[16:16:48:785] I> Binary dce loaded successfully at 0x176000000
[16:16:48:796] I> Active chain: 1
[16:16:48:796] I> Partition name: B_xusb-fw
[16:16:48:796] I> Size of partition: 262144
[16:16:48:796] I> Binary@ device:3/0 block-72448 (partition size: 0x40000), name: B_xusb-fw
[16:16:48:804] I> ape: Authentication Finalize Done
[16:16:48:804] I> Binary ape loaded successfully at 0x16fc00000
[16:16:48:804] I> Successfully register APE FW context save task with MB2 loader
[16:16:48:821] I> xusb: Authentication Finalize Done
[16:16:48:821] I> Binary xusb loaded successfully at 0x16f400000
[16:16:48:821] I> Successfully register XUSB FW context save task with MB2 loader
[16:16:48:832] I> Task: Check MC errors (0x5000204c)
[16:16:48:832] I> Task: Carveout setup (0x500214d0)
[16:16:48:832] I> Program remaining OEM carveouts
[16:16:48:843] I> Task: Enable FSITHERM (0x500183cc)
[16:16:48:843] I> Task: Enable FSI VMON (0x50017ec8)
[16:16:48:843] I> Task: Validate FSI Therm readings (0x50017fac)
[16:16:48:855] I> Task: Restore XUSB sec (0x50001ef4)
[16:16:48:855] I> Task: Enable FSI SE clock (0x500189a4)
[16:16:48:855] I> Task: Initialize SBSA UART CAR (0x50002118)
[16:16:48:866] I> Task: Initialize CPUBL Params (0x50019990)
[16:16:48:866] I> CPUBL-params @ 0x172000000
[16:16:48:866] I> Task: Ratchet update (0x50029e88)
[16:16:48:875] W> Skip ratchet update - OPTIN fuse not set
[16:16:48:875] I> Task: Prepare eeprom data (0x5001975c)
[16:16:48:933] I> Task: Revoke PKC fuse (0x50001d40)
[16:16:48:933] I> PKC revoke fuse burn not requested
[16:16:48:933] I> Task: FSI padctl context save (0x5001b558)
[16:16:48:933] W> Skipping FSI padctl config save: fsi not enabled
[16:16:48:944] I> Task: Unpowergate APE (0x5001910c)
[16:16:48:944] W> mb2_unpowergate_ape: skip! APE is in unpowergated state
[16:16:48:953] I> Task: OEM firewalls (0x500259e4)
[16:16:48:981] I> OEM firewalls configured
[16:16:48:981] I> Task: Powergate APE (0x50019280)
[16:16:48:981] I> Powergating APE
[16:16:48:981] I> Powergate done
[16:16:48:981] I> Task: OEM firewall restore saved settings (0x50025e38)
[16:16:48:992] I> Task: Unhalt AUXPs (0x50028bf4)
[16:16:48:992] I> Unhalting SPE..
[16:16:48:992] I> Enabling combined UART
[16:16:49:008] <break>
[16:16:49:008] <0xff><0xfd><0xff><0xe0>spe: early_init
[16:16:49:008] <0xff><0xb8><0xff><0xe0>vic initialized
[16:16:49:008] <0xff><0xb8><0xff><0xe0>tsc initialized
[16:16:49:008] <0xff><0xb8><0xff><0xe0>aon lic initialized
[16:16:49:008] <0xff><0xb8><0xff><0xe0>spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
[16:16:49:019] <0xff><0xb8><0xff><0xe0>spe: SafeRTOS v8.4
[16:16:49:019] <0xff><0xb8><0xff><0xe0>spe: init
[16:16:49:019] <0xff><0xb8><0xff><0xe0>scheduler initialized
[16:16:49:019] <0xff><0xb8><0xff><0xe0>aon hsp initialized
[16:16:49:019] <0xff><0xb8><0xff><0xe0>tag initialized
[16:16:49:019] <0xff><0xb8><0xff><0xe0>tcu initialized
[16:16:49:030] <0xff><0xb8><0xff><0xe0>bpmp ipc initialized
[16:16:49:030] <0xff><0xb8><0xff><0xe0>spe: late init
[16:16:49:030] <0xff><0xb8><0xff><0xe0>cpu_nic clock initialized
[16:16:49:030] <0xff><0xb8><0xff><0xe0>apb clock initialized
[16:16:49:030] <0xff><0xb8><0xff><0xe0>pm initialized
[16:16:49:042] <0xff><0xb8><0xff><0xe0>bpmp hsp initialized
[16:16:49:042] <0xff><0xb8><0xff><0xe0>top1 hsp initialized
[16:16:49:042] <0xff><0xb8><0xff><0xe0>ccplex ipc initialized
[16:16:49:042] <0xff><0xb8><0xff><0xe0>spe: start scheduler
[16:16:49:042] <0xff><0xb8><0xff><0xe1>
[16:16:49:042] I> Task: Trigger mailbox for PSC-BL1 exit (0x500185c8)
[16:16:49:053] I> Sending opcode 0x4d420802 to psc
[16:16:49:053] <0xff><0xe7>INFO: Entering psc_monitor_init!
[16:16:49:053] INFO: GSC22 BOM:0x178002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
[16:16:49:064] INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
[16:16:49:064] INFO: mstatus:0xa00000808
[16:16:49:075] INFO: Supervisor entry_point:c108c00
[16:16:49:075] <0xff><0xe1>I> Received ACK from psc
[16:16:49:075] I> Tas<0xff><0xe7>INFO: MONITOR: user task addr:0x178022000, blob offset:0x00020000
[16:16:49:087] INFO: MONITOR: populated user images:13
[16:16:49:087] INFO: mret to Supervisor!
[16:16:49:087] INFO: psc supervisor init.
[16:16:49:098] INFO: psc_irq_init...
[16:16:49:098] INFO: enter idle task.
[16:16:49:098] <0xff><0xe2>
[16:16:49:098] hwwdt_init: WDT boot cfg 0x710010 sts 0x10
[16:16:49:098] bpmp: socket 0
[16:16:49:098] bpmp: base binary md5 is da583751bbfe2b7f6e204562d97ff39e
[16:16:49:109] bpmp: combined binary md5 is e941463f35523d12ee540d9bc33bc02f
[16:16:49:109] bpmp: firmware tag is e941463f35523d12ee54-da583751bbf
[16:16:49:120] Control register check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
[16:16:49:131] Write control check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 0f18000b != actual value: 00000000 address: 13a159c8
[16:16:49:143] Control register check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
[16:16:49:154] initialized vwdt
[16:16:49:154] initialized mail_early
[16:16:49:154] initialized fuse
[16:16:49:154] initialized vfrel
[16:16:49:165] initialized adc
[16:16:49:165] fmon_populate_monitors: found 199 monitors
[16:16:49:165] initialized fmon
[16:16:49:165] initialized mc
[16:16:49:165] initialized reset
[16:16:49:176] initialized uphy_early
[16:16:49:176] initialized emc_early
[16:16:49:176] initialized pm
[16:16:49:176] 465 clocks registered
[16:16:49:176] initialized clk_mach
[16:16:49:176] initialized clk_cal_early
[16:16:49:187] initialized clk_mach_early_config
[16:16:49:187] initialized io_dpd
[16:16:49:187] initialized soctherm
[16:16:49:187] initialized regime
[16:16:49:187] initialized i2c
[16:16:49:187] vrmon_dt_init: vrmon node not found
[16:16:49:199] vrmon_chk_boot_state: found 0 rail monitors
[16:16:49:199] initialized vrmon
[16:16:49:199] initialized regulator
[16:16:49:199] initialized avfs_clk_platform
[16:16:49:210] initialized powergate
[16:16:49:210] initialized dvs
[16:16:49:210] initialized clk_mach_config
[16:16:49:210] suspend progress: 0x80000000
[16:16:49:210] initialized suspend
[16:16:49:221] initialized strap
[16:16:49:221] initialized mce_dbell
[16:16:49:221] <0xff><0xe1>k: Start sec<0xff><0xe2>initialized emc
[16:16:49:221] initialized emc_mrq
[16:16:49:221] <0xff><0xe1>ure NOR provision (0x5001b7f4)
[16:16:49:232] <0xff><0xe2>initialized clk_cal
[16:16:49:232] initialized uphy_dt
[16:16:49:232] initialized uphy_mrq
[16:16:49:232] HSIO UPHY reset has been de-asserted 0x0
[16:16:49:243] initialized pg_late
[16:16:49:243] initialized pg_mrq_init
[16:16:49:243] swdtimer_init: reg polling start w period 47 ms
[16:16:49:243] initialized swdtimer
[16:16:49:255] initialized hwwdt_late
[16:16:49:255] initialized bwmgr
[16:16:49:255] initialized thermal_host_trip
[16:16:49:255] initialized thermal_mrq
[16:16:49:255] initialized oc_mrq
[16:16:49:255] initialized reset_mrq
[16:16:49:266] initialized mail_mrq
[16:16:49:266] initialized fmon_mrq
[16:16:49:266] initialized clk_mrq
[16:16:49:266] initialized avfs_mrq
[16:16:49:266] initialized i2c_mrq
[16:16:49:266] initialized tag_mrq
[16:16:49:277] initialized bwmgr_mrq
[16:16:49:277] initialized console_mrq
[16:16:49:277] missing prod DT calibration data for 199 fmons
[16:16:49:277] initialized clk_sync_fmon_post
[16:16:49:288] <0xff><0xe1>I> Task: Load FSI keyblo<0xff><0xe2>initialized clk_cal_late
[16:16:49:288] initialized noc_late
[16:16:49:288] initialized cvc
[16:16:49:288] <0xff><0xe1>b (0x500189ec)
[16:16:49:299] I> Task: Unhalt<0xff><0xe2>initialized avfs_clk_mach_post
[16:16:49:299] initialized avfs_clk_platform_post
[16:16:49:299] initialized cvc_late
[16:16:49:299] WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
[16:16:49:311] WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
[16:16:49:322] WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
[16:16:49:322] WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
[16:16:49:333] WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
[16:16:49:344] WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
[16:16:49:344] WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
[16:16:49:355] WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
[16:16:49:367] WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
[16:16:49:378] WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
[16:16:49:378] initialized rm
[16:16:49:378] initialized console_late
[16:16:49:389] handling unreferenced clks
[16:16:49:389] enable can1_core
[16:16:49:389] enable can1_host
[16:16:49:389] enable can2_core
[16:16:49:389] enable can2_host
[16:16:49:389] enable pwm3
[16:16:49:389] enable sdmmc4_axicif
[16:16:49:400] enable mss_encrypt
[16:16:49:400] enable maud
[16:16:49:400] enable pllg_ref
[16:16:49:400] enable dsi_core
[16:16:49:400] enable aza_2xbit
[16:16:49:400] enable xusb_ss
[16:16:49:400] enable xusb_fs
[16:16:49:411] enable xusb_falcon
[16:16:49:411] enable xusb_core_mux
[16:16:49:411] enable dsi_lp
[16:16:49:411] clk_check_max_rate: pex1_c6_core rate 500000000 > max 250000000
[16:16:49:411] clk_check_max_rate: pex2_c7_core rate 500000000 > max 250000000
[16:16:49:423] clk_check_max_rate: pex2_c8_core rate 500000000 > max 250000000
[16:16:49:423] clk_check_max_rate: pex2_c9_core rate 500000000 > max 250000000
[16:16:49:434] clk_check_max_rate: pex2_c10_core rate 500000000 > max 250000000
[16:16:49:445] clk_check_max_rate: pex0_c0_core rate 500000000 > max 250000000
[16:16:49:445] clk_check_max_rate: pex0_c1_core rate 500000000 > max 250000000
[16:16:49:456] clk_check_max_rate: pex0_c2_core rate 500000000 > max 250000000
[16:16:49:456] clk_check_max_rate: pex0_c3_core rate 500000000 > max 250000000
[16:16:49:467] clk_check_max_rate: pex0_c4_core rate 500000000 > max 250000000
[16:16:49:467] clk_check_max_rate: pex1_c5_core rate 500000000 > max 250000000
[16:16:49:479] initialized clk_mach_post
[16:16:49:479] initialized pg_post
[16:16:49:479] initialized regulator_post
[16:16:49:479] initialized profile
[16:16:49:479] initialized mrq
[16:16:49:479] initialized patrol_scrubber
[16:16:49:490] initialized cactmon
[16:16:49:490] initialized extras_post
[16:16:49:490] bpmp: init complete
[16:16:49:490] <0xff><0xe1> AUXPs (0x50028bfc)
[16:16:49:490] I> SCE unhalt skipped
[16:16:49:501] I> Unhalting RCE
[16:16:49:501] I> RCE unhalt success<0xff><0xe5>[     2.707275] Camera-FW on t234-rce-safe started
[16:16:49:501] TCU early console enabled.
[16:16:49:501] <0xff><0xe1>ful
[16:16:49:512] I> DCE unhalt successful
[16:16:49:512] I> APE unhalt skipped
[16:16:49:512] I> FSI unhalt skipped
[16:16:49:512] I> Task: Load CPUB<0xff><0xe8>
[16:16:49:512] <0xff><0xe1>L (0x50019ab4)
[16:16:49:512] I> Task: Load TOS (0x5001a244)
[16:16:49:523] I> Task: Load and authenticate registered FWs (0x5001ed44)
[16:16:49:523] I> Active chain: 1
[16:16:49:523] I> Partition name: B_cpu-bootloader
[16:16:49:535] I> Size of partition: 3670016
[16:16:49:535] I> Binary@ device:3/0 block-87808 (partition size: 0x380000), name: B_cpu-bootloader
[16:16:49:535] I> cpubl : oem authentication of header done
[16:16:49:545] I> cpubl : meta-blob integrity check is success.
[16:16:49:545] E> LOADER: Page<break>
Is same module able to reproduce this issue when it is on NV devkit?
是的,我们在NV devkit上复现了此问题
please RMA the module.
好的, 我们有办法在来料检测时挑出这种核芯板么?做成产品后再发现问题返工的代价有点太高了
You may define the test case at your product QA section.
我们使用温箱对这三片核芯板进行测试:将核芯板放入温箱设置固定温度等待十分钟后尝试开机,每次升温 1 度。
核芯板 1423524325869:0~15℃ 正常,16~27℃ 异常,28~43℃ 正常,44~45℃异常,46~50℃正常
核芯板 1422724321104和1422724321263:0~17℃ 正常,18~23℃异常,24~50℃正常
您那边有更多的case协助我们预检出此类核芯板么?
Sorry that we don’t have the reference test case to verify that problem.
But as your finding, only these 3 modules got this problem, and please RMA it.
这三片核芯板已通过代理 RMA。
基于我们的测试结论,您认为可能是什么原因导致的?
感谢!
Not possible to know with just such test result. Our internal team will handle that.
好的,非常感谢!
辛苦您有最新消息时及时通知我们。
再次对您表示感谢!
