Orin nano
Yesterday I booted my orin nano and after some browsing I noticed hdmi sound was off and nonselectable in settings.
I decided to reboot. Since then after the nvidia splash screen it only shows a black screen. I am not able to get into commandline by ctrl F2, 3 or 4 or holding shift.
I have tried to boot from SD card too and there is no difference.
The black screen does reboot after pressing ctrl alt delete.
Could you access the Orin Nano through the serial console?
I have not tried that yet, but the sd card is the exact image used to install to the internal storage. In fact last time it was IN the unit it was during the transfer.
Is there another way to make it boot from SD again?
If you don’t give out the log, then we might not be able to tell if you could boot from SD.
Another quick to that does not need your log is to flash your board again from x86 Ubuntu host with sdkmanager.
Is a x86 Ubuntu host needed to get the log?
You could even get a log from even Rasberry Pi device. Any device that could use USB-TTL cable might be able to capture log.
But you could only reflash your Jetson by using a x86 Ubuntu host.
ok, I will try with a pi400. I will make or buy a USB-TTL cable. What do I need to do next? I have not tried something like this before.
following the steps as this
Just a reminder. It still has chance that you may need to reflash your board if the log tells that it is not recoverable unless doing reflash.
I ordered a usb-ttl cable (one with DTS and one without) and will try as soon as it arrives. In Pi OS I noticed that the ctrl alt way of getting into minicom settings does not seem to work, but --setup does, are there any other differences?
ok, first a note to anyone trying to do this with a different usb-ttl cable where you also have to attach the cables to the pins to the adapter itself: Cross over the TXD and RXD cables.
The output of my booting nano (with the SD-card also inserted),
Size of partition: 262144
I> Binary@ device:3/0 block-72448 (partition size: 0x40000), name: B_xusb-fw
I> strt_pg_num(72448) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_xusb-fw]: sw (BCH): 0, hw (BCT): 0
I> strt_pg_num(72464) num_of_pgs(312) read_buf(0x272f00000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x27d800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: B_pva-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-125312 (partition size: 0x40000), name: B_pva-fw
I> strt_pg_num(125312) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_pva-fw]: sw (BCH): 0, hw (BCT): 0
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x272f00000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(125328) num_of_pgs(1) read_buf(0x2739400d8)
I> strt_pg_num(125328) num_of_pgs(8) read_buf(0x2739400d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(125336) num_of_pgs(512) read_buf(0x2738000c0)
I> pva-fw : will be decompressed at 0x273180000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x273180000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Check MC errors
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x276000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
I> Task: Revoke PKC fuse
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save
W> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE..
I> Enabling combined UART
����spe: early_init
����vic initialized
����tsc initialized
����aon lic initialized
����spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
����spe: SafeRTOS v8.4
����spe: init
����scheduler initialized
����aon hsp initialized
����tag initialized
����tcu initialized
����bpmp ipc initialized
����spe: late init
����cpu_nic clock initialized
����apb clock initialized
����pm initialized
����bpmp hsp initialized
����top1 hsp initialized
����ccplex ipc initialized
����spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Trigger load FSI keyblob
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d to psc
I> Task: Unhalt FSI
I> ��
��FSI unhalt skip��hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is 68f126a8abf720445275b10ce9dac080
bpmp: combined binary md5 is 030ffe301d1db1d01cb6fae98e5e988b
bpmp: firmware tag is 030ffe301d1db1d01cb6-68f126a8abf
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
��ped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load HV/CPUBL
I> Task: Load TOS
I> Task: Trigger load TS��[ 2.589566] Camera-FW on t234-rce-safe started
TCU early console enabled.
��EC leyblob
I> Sending opcode 0x53535452 to psc
I> Sent opcode to psc
��initialized avfs_clk_platform
initialized powergate
��I> Task: Load and authenticate registered FWs
��initialized dvs
��I> ��
��initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
��Partition name: B_cpu-bootloader
��DCE Started
��I> Size of partition: 3670016
I> Binary@ device:3/0 block-87808 (partition size: 0x380000), name: B_cpu-bootlr
I> strt_pg_num(87808) num_of_pgs(16) read_buf(0x40067ab0)
��DCE_R5_Init
��I> Ratchet: [B_cpu-bootloader]: sw (BCH): 0, hw (BCT): 0
I> cpubl : oem authentication of header done
I> strt_pg_num(87824) num_of_pgs(1) read_buf(0x273943c98)
��MPU enabled
DCE_SW_Init
��I> strt_pg_num(��initialized emc
initialized emc_mrq
��87824) num_of_pgs(8) read_buf(0x2739��initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
��43c98)
I> cpubl : meta-blob integr��initialized clk_cal_late
initialized noc_late
initialized cvc
��ity check is success.
I> strt_p��initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable sdmmc4_axicif
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
clk_check_max_rate: pex1_c6_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c7_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c8_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c9_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c10_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c0_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c1_core rate 500000000 > max 250000000
clk_check_ma��[ 2.807343] Camera-FW on t234-rce-safe ready SHA1=04ea8699 (c0
clk_check_max_rate: pex0_�� total boot 231.264 ms)
��c3_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c4_core rate 500000000 > max 250000000
clk_check_max_rate: pex1_c5_core rate 500000000 > max 250000000
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
��g_num(87832) num_of_pgs(512) read_buf(0x273803c80)
��Admin Task Init
Admin Task Init complete
Print Task Init
RM Task Init
Admin Task Started
DCE SC7 SHA Disabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
DCE: FW Boot Complete
Admin Task Running
��I> strt_pg_num(88344) num_of_pgs(512) read_buf(0x273843c80)
I> cpubl : will be decompressed at 0x272000000
I> strt_pg_num(88856) num_of_pgs(512) read_buf(0x273883c80)
I> strt_pg_num(89368) num_of_pgs(512) read_buf(0x2738c3c80)
I> strt_pg_num(89880) num_of_pgs(512) read_buf(0x273903c80)
I> strt_pg_num(90392) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(90904) num_of_pgs(512) read_buf(0x273843c80)
I> strt_pg_num(91416) num_of_pgs(512) read_buf(0x273883c80)
I> strt_pg_num(91928) num_of_pgs(512) read_buf(0x2738c3c80)
I> strt_pg_num(92440) num_of_pgs(512) read_buf(0x273903c80)
I> strt_pg_num(92952) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(93464) num_of_pgs(512) read_buf(0x273843c80)
I> strt_pg_num(93976) num_of_pgs(512) read_buf(0x273883c80)
I> cpubl : decompressed to 3481728 bytes
I> cpubl: plain binary integrity check is success
I> Partition name: B_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-94976 (partition size: 0x400000), name: B_secure-os
I> strt_pg_num(94976) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_secure-os]: sw (BCH): 0, hw (BCT): 0
I> strt_pg_num(94992) num_of_pgs(3760) read_buf(0xc1d2a000)
I> MB2-params @ 0x40060000
I> NSDRAM carveout base: 0x80000000, size: 0x1f25f0000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x272000000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0xc1d2a000
I> Relocating OP-TEE dtb from: 0xc1eff180 to 0xbe040020, size: 0x2836
I> [0] START: 0x80000000, SIZE: 0x1f25f0000
I> [1] START: 0x276000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: B_eks
I> Binary@ device:3/0 block-107264 (partition size: 0x40000), name: B_eks
I> strt_pg_num(107264) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_eks]: sw (BCH): 0, hw (BCT): 0
I> strt_pg_num(107280) num_of_pgs(8) read_buf(0xbe020000)
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0xbe020000
I> EKB detected (length: 0x410) @ VA:0xbe020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0xbe040020
I> NVRNG: Health check success
I> Task: OEM SC7 context save
I> OEM sc7 context saved
I> Task: Disable MSS perf stats
I> Task: Storage device deinit
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Bootchain failure check
I> Current Boot-Chain Slot: 1
I> BR-BCT Boot-Chain is 1, and status is 1. Set UPDATE_BRBCT bit to 0
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
��NOTICE: BL31: v2.8(release):3242bf5
NOTICE: BL31: Built : 19:24:15, Jan 15 2026
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Jan 14
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecturel
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: fTPM ID is not enabled.
I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is no.
I/TC: Primary CPU switching to normal world boot
t23x_general UEFI firmware (version 36.5.0-gcid-43688277 built on 2026-01-16T)
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
UpdatePeCoffPermissions: Mapping section 1 of image at 0x406FC000 with RW-XN pe0
GetDeviceTypeRegions: 1 qspi0 regions present
MmInstallProtocolInterface: 01458542-64B6-42D9-808C-544254D88FC6 40701420
MmInstallProtocolInterface: 40930D29-595C-4588-B692-16E74A5B3C75 407012D0
UpdatePeCoffPermissions: Mapping section 1 of image at 0x406F3000 with RW-XN pe0
NorFlashInitialise: Using ChipSelect 0
MmInstallProtocolInterface: C3FF8100-150D-4744-A68B-19A5435D5DAD 406EBE30
MmInstallProtocolInterface: 40930D29-595C-4588-B692-16E74A5B3C75 40701110
UpdatePeCoffPermissions: Mapping section 1 of image at 0x406E8000 with RW-XN pe0
GetDeviceTypeRegions: 1 scratch-t234 regions present
FVBNORInitialize:Using Reserved Partition 66781184 65536 for VarStore Integrity
FVBNORInitialize: VariableOffset 65536000 VariableSize 262144FTW Offset 65798140
MmInstallProtocolInterface: D326D041-BD31-4C01-B5A8-628BE87F0653 406EB860
MmInstallProtocolInterface: D326D041-BD31-4C01-B5A8-628BE87F0653 406EB8F8
MmInstallProtocolInterface: D326D041-BD31-4C01-B5A8-628BE87F0653 406EB990
MmInstallProtocolInterface: D1A86E3F-0707-4C35-83CD-DC2C29C891A3 0
UpdatePeCoffPermissions: Mapping section 1 of image at 0x40607000 with RW-XN pe0
UpdatePeCoffPermissions: Mapping section 1 of image at 0x405FE000 with RW-XN pe0
MmInstallProtocolInterface: 3868FC3B-7E45-43A7-906C-4BA47DE1754D 405B4020
UpdatePeCoffPermissions: Mapping section 1 of image at 0x405B1000 with RW-XN pe0
UpdatePeCoffPermissions: Mapping section 1 of image at 0x405A5000 with RW-XN pe0
UpdatePeCoffPermissions: Mapping section 1 of image at 0x4059A000 with RW-XN pe0
MmInstallProtocolInterface: 26EEB3DE-B689-492E-80F0-BE8BD7DA4BA7 4059A0B8
UpdatePeCoffPermissions: Mapping section 1 of image at 0x40568000 with RW-XN pe0
MmInstallProtocolInterface: ED32D533-99E6-4209-9CC0-2D72CDD998A7 405681E8
Var SecureBoot Doesn’t exist Not Found
Var PK Doesn’t exist Not Found
Var KEK Doesn’t exist Not Found
Var db Doesn’t exist Not Found
Var dbx Doesn’t exist Not Found
I/TC: WARNING: Test UEFI variable auth key is being used !
I/TC: WARNING: UEFI variable protection is not fully enabled !
MmFvbSmmVarReady: VarStore validation Succesful
MmInstallProtocolInterface: B0D8F3C1-B7DE-4C11-BC89-2FB562C8C411 40568958
UpdatePeCoffPermissions: Mapping section 1 of image at 0x40433000 with RW-XN pe0
3h
��MmInstallProtocolInterface: 24E70042-D5C5-4260-8C39-0AD3AA32E93D 0
3h
                               t23x_general System firmware
                              date 2026-01-16T03:26:46+00:00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
s to enter Shell.
Enter to continue boot.
…��MmInstallProtocolInterface: 7CE88FB3-4BD7-4679-87A8-A8D8DEE50D2B 0
��L4TLauncher: Attempting Recovery Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
��MmInstallProtocolInterface: 27ABF055-B1B8-4C26-8048-748F37BAA2DF 0
��debugfs initialized
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.148-tegra (buildbrain@mobile-u64-6262-d8000) )
[ 0.000000] Machine model: NVIDIA Jetson Orin Nano Engineering Reference Devr
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x26de2e698 TPMFinalLog=0x25e900000 SMBIOS=0xffff000
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x0000000268e95818 to 0x00000002.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000249000000, B
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id sharl
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000277fffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x27130c800-0x27130efff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000277ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000bdffffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000025d49ffff]
[ 0.000000] node 0: [mem 0x000000025d4a0000-0x000000025e0cffff]
[ 0.000000] node 0: [mem 0x000000025e0d0000-0x000000025e0fffff]
[ 0.000000] node 0: [mem 0x000000025e100000-0x000000025e10ffff]
[ 0.000000] node 0: [mem 0x000000025e110000-0x000000025e15ffff]
[ 0.000000] node 0: [mem 0x000000025e160000-0x000000025e31ffff]
[ 0.000000] node 0: [mem 0x000000025e320000-0x000000025e8fffff]
[ 0.000000] node 0: [mem 0x000000025e900000-0x000000025e90ffff]
[ 0.000000] node 0: [mem 0x000000025e910000-0x000000026beeffff]
[ 0.000000] node 0: [mem 0x000000026bef0000-0x000000026de2ffff]
[ 0.000000] node 0: [mem 0x000000026de30000-0x0000000271dfffff]
[ 0.000000] node 0: [mem 0x0000000271e00000-0x0000000271ffffff]
[ 0.000000] node 0: [mem 0x0000000272000000-0x000000027259ffff]
[ 0.000000] node 0: [mem 0x0000000276000000-0x0000000277ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000277ffffff]
[ 0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 14944 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algo)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectrinsmod /lib/modules/5.15.148-tegra0
0] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2000800
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_logleve
[ 0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@.
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 byt)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe00)
[ 0.000000] Memory: 7500016K/8132224K available (20160K kernel code, 4064K r)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 ji.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398s
[ 0.000393] Console: colour dummy device 80x25
[ 0.000465] Calibrating delay loop (skipped), value calculated using timer f)
[ 0.000473] pid_max: default: 32768 minimum: 301
[ 0.000518] LSM: Security Framework initializing
[ 0.000546] Yama: becoming mindful.
[ 0.000562] SELinux: Initializing.
[ 0.000647] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, l)
[ 0.000662] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 byt)
[ 0.001806] rcu: Hierarchical SRCU implementation.
[ 0.004113] Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[ 0.004386] Remapping and enabling EFI services.
[ 0.005441] smp: Bringing up secondary CPUs …
[ 0.005953] Detected PIPT I-cache on CPU1
[ 0.005997] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.006037] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.006524] Detected PIPT I-cache on CPU2
[ 0.006536] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006553] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006969] Detected PIPT I-cache on CPU3
[ 0.006979] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006993] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.009452] Detected PIPT I-cache on CPU4
[ 0.009480] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f50000
[ 0.009507] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.009997] Detected PIPT I-cache on CPU5
[ 0.010009] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f52000
[ 0.010025] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.010085] smp: Brought up 1 node, 6 CPUs
[ 0.010090] SMP: Total of 6 processors activated.
[ 0.010093] CPU features: detected: 32-bit EL0 Support
[ 0.010095] CPU features: detected: Data cache clean to the PoU not requirede
[ 0.010097] CPU features: detected: Common not Private translations
[ 0.010098] CPU features: detected: CRC32 instructions
[ 0.010100] CPU features: detected: Data cache clean to Point of Persistence
[ 0.010101] CPU features: detected: Generic authentication (architected algo)
[ 0.010103] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.010104] CPU features: detected: LSE atomic instructions
[ 0.010105] CPU features: detected: Privileged Access Never
[ 0.010106] CPU features: detected: RAS Extension Support
[ 0.010109] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.046207] CPU: All CPU(s) started at EL2
[ 0.049494] devtmpfs: initialized
[ 0.069490] KASLR enabled
[ 0.069717] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.069745] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.074714] pinctrl core: initialized pinctrl subsystem
[ 0.075767] SMBIOS 3.6.0 present.
[ 0.075783] DMI: NVIDIA NVIDIA Jetson Orin Nano Engineering Reference Develo6
[ 0.076383] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.078387] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.078526] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic als
[ 0.078628] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic s
[ 0.078739] audit: initializing netlink subsys (disabled)
[ 0.078919] audit: type=2000 audit(0.076:1): state=initialized audit_enabled1
[ 0.081216] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.081220] thermal_sys: Registered thermal governor ‘user_space’
[ 0.081221] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.085397] cpuidle: using governor menu
[ 0.085609] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.085721] ASID allocator initialised with 32768 entries
[ 0.087780] Serial: AMBA PL011 UART driver
[ 0.099750] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud A
[ 0.111516] platform bpmp: Fixing up cyclic dependency with 2c60000.externalr
[ 0.121343] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.121352] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.121355] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.121357] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.122467] cryptd: max_cpu_qlen set to 1000
[ 0.124557] ACPI: Interpreter disabled.
[ 0.125804] VDD_1V8_AO: supplied by VDD_5V0_SYS
[ 0.125964] VDD_3V3_AO: supplied by VDD_5V0_SYS
[ 0.126213] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[ 0.126658] iommu: Default domain type: Translated
[ 0.126663] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.127051] SCSI subsystem initialized
[ 0.127316] vgaarb: loaded
[ 0.127526] usbcore: registered new interface driver usbfs
[ 0.127548] usbcore: registered new interface driver hub
[ 0.127565] usbcore: registered new device driver usb
[ 0.127990] pps_core: LinuxPPS API ver. 1 registered
[ 0.127996] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[ 0.128005] PTP clock support registered
[ 0.128072] EDAC MC: Ver: 3.0.0
[ 0.129355] Registered efivars operations
[ 0.129992] FPGA manager framework
[ 0.130063] Advanced Linux Sound Architecture Driver Initialized.
[ 0.130605] Bluetooth: Core ver 2.22
[ 0.130634] NET: Registered PF_BLUETOOTH protocol family
[ 0.130639] Bluetooth: HCI device and connection manager initialized
[ 0.130648] Bluetooth: HCI socket layer initialized
[ 0.130652] Bluetooth: L2CAP socket layer initialized
[ 0.130666] Bluetooth: SCO socket layer initialized
[ 0.131228] clocksource: Switched to clocksource arch_sys_counter
[ 0.166458] VFS: Disk quotas dquot_6.6.0
[ 0.166530] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.166755] pnp: PnP ACPI: disabled
[ 0.169808] NET: Registered PF_INET protocol family
[ 0.170155] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, l)
[ 0.171781] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 655)
[ 0.171882] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes,)
[ 0.171909] TCP established hash table entries: 65536 (order: 7, 524288 byte)
[ 0.172156] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, lin)
[ 0.173552] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.173755] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.173855] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linea)
[ 0.174149] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.174594] RPC: Registered named UNIX socket transport module.
[ 0.174600] RPC: Registered udp transport module.
[ 0.174600] RPC: Registered tcp transport module.
[ 0.174602] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.174621] PCI: CLS 0 bytes, default 64
[ 0.174946] Unpacking initramfs…
[ 0.184212] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counte
[ 0.184491] kvm [1]: IPA Size Limit: 48 bits
[ 0.184529] kvm [1]: GICv3: no GICV resource entry
[ 0.184537] kvm [1]: disabling GICv2 emulation
[ 0.184558] kvm [1]: GIC system register CPU interface enabled
[ 0.184628] kvm [1]: vgic interrupt IRQ9
[ 0.184782] kvm [1]: VHE mode initialized successfully
[ 0.187862] Initialise system trusted keyrings
[ 0.187911] Key type blacklist registered
[ 0.188046] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[ 0.191941] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.192384] NFS: Registering the id_resolver key type
[ 0.192408] Key type id_resolver registered
[ 0.192413] Key type id_legacy registered
[ 0.192456] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.192474] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registerin.
[ 0.192499] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.192734] 9p: Installing v9fs 9p2000 file system support
[ 0.193375] integrity: Platform Keyring initialized
[ 0.206417] Key type asymmetric registered
[ 0.206426] Asymmetric key parser ‘x509’ registered
[ 0.206551] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[ 0.206558] io scheduler mq-deadline registered
[ 0.206565] io scheduler kyber registered
[ 0.217419] EINJ: ACPI disabled.
[ 0.230030] Serial: 8250/16550 driver, 4 ports, ins shmodng /lib/modules/5.d
gra[ 194u.k.23o 8] perHel/ (Hdrivers/phy/) der initialized
_serial: driver initialized
[ 0.232865] printk: console [ttyTins /lib/modledules/5.15.148-t.23egr0] erne.
[ 0a19.234.k387
arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.233884] arm-smmu 8000000.iommu: stage 1 translation
[ 0.233888] arm-smmu 8000000.iommu: stage 2 translation
[ 0.233891] arm-smmu 8000000.iommu: nested translation
[ 0.233902] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.233908] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.233922] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.233929] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.233931] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.234962] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.234966] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.234969] arm-smmu 10000000.iommu: stage 1 translation
[ 0.234970] arm-smmu 10000000.iommu: stage 2 translation
[ 0.234971] arm-smmu 10000000.iommu: nested translation
[ 0.234973] arm-smmu 10000000.iommu: stream matching with 128 regists
[ 0.234976] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 on)
[ 0.234982] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.234983] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.234985] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.235395] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.235397] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.235399] arm-smmu 12000000.iommu: stage 1 translation
[ 0.235401] arm-smmu 12000000.iommu: stage 2 translation
[ 0.235402] arm-smmu 12000000.iommu: nested translation
[ 0.235404] arm-smmu 12000000.iommu: stream matching with 128 regists
[ 0.235407] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 on)
[ 0.235411] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.235412] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.235413] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.242905] loop: module loaded
[ 0.244024] megasas: 07.717.02.00-rc1
[ 0.248379] tun: Universal TUN/TAP device driver, 1.6
[ 0.249008] thunder_xcv, ver 1.0
[ 0.249037] thunder_bgx, ver 1.0
[ 0.249055] nicpf, ver 1.0
[ 0.249907] hclge is initializing
[ 0.249939] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - versin
[ 0.249946] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.249983] e1000: Intel(R) PRO/1000 Network Driver
[ 0.249988] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.250013] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.250018] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.250045] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.250050] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.250072] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.250080] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.250289] sky2: driver version 1.30
[ 0.250987] VFIO - User Level meta-driver version: 0.3
[ 0.252687] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.252698] ehci-pci: EHCI PCI platform driver
[ 0.252731] ehci-platform: EHCI generic platform driver
[ 0.252814] ehci-orion: EHCI orion driver
[ 0.252908] ehci-exynos: EHCI Exynos driver
[ 0.252971] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.252997] ohci-pci: OHCI PCI platform driver
[ 0.253021] ohci-platform: OHCI generic platform driver
[ 0.253090] ohci-exynos: OHCI Exynos driver
[ 0.253546] usbcore: registered new interface driver usb-storage
[ 0.255456] i2c_dev: i2c /dev entries driver
[ 0.256829] pps pps0: new PPS source ktimer
[ 0.256842] pps pps0: ktimer PPS source registered
[ 0.256852] pps_ldisc: PPS line discipline registered
[ 0.259002] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-m
[ 0.261104] sdhci: Secure Digital Host Controller Interface driver
[ 0.261109] sdhci: Copyright(c) Pierre Ossman
[ 0.261589] Synopsys Designware Multimedia Card Interface Driver
[ 0.262206] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.263379] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.264401] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.264990] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.266430] tegra-bpmp bpmp: firmware: 030ffe301d1db1d01cb6-68f126a8abf
[ 0.539721] Freeing initrd memory: 20464K
[ 4.125088] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046s
[ 4.125107] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_is
[ 4.125112] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_s
[ 4.125478] hid: raw HID events driver (C) Jiri Kosina
[ 4.125892] usbcore: registered new interface driver usbhid
[ 4.125899] usbhid: USB HID core driver
[ 4.131827] optee: probing for conduit method.
[ 4.131885] optee: revision 4.2 (5ef90dab)
[ 4.190201] optee: dynamic shared memory is enabled
[ 4.190476] optee: initialized driver
[ 4.193155] usbcore: registered new interface driver snd-usb-audio
[ 4.194853] NET: Registered PF_PACKET protocol family
[ 4.195092] Bluetooth: RFCOMM TTY layer initialized
[ 4.195105] Bluetooth: RFCOMM socket layer initialized
[ 4.195124] Bluetooth: RFCOMM ver 1.11
[ 4.195357] 9pnet: Installing 9P2000 support
[ 4.195456] Key type dns_resolver registered
[ 4.195939] printk: console [ttyTCU0]: printing thread started
[ 4.196009] Loading compiled-in X.509 certificates
[ 4.199342] Loaded X.509 cert ‘Build time autogenerated kernel key: 7f1e7893’
[ 4.231258] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 4.233391] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 s
[ 4.235535] serial-tegra 3100000.serial: RX in PIO mode
[ 4.235540] serial-tegra 3100000.serial: TX in PIO mode
[ 4.235663] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud T
[ 4.236323] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud T
[ 4.239600] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.239611] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.240190] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 4.246417] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 4.250320] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 4.256689] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 4.263410] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[ 4.264226] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 4.295231] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequz
[ 4.299212] tegra-xusb 3610000.usb: Adding to iommu group 2
[ 4.313991] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 C
[ 4.313999] tegra-xusb 3610000.usb: xHCI Host Controller
[ 4.314011] tegra-xusb 3610000.usb: new USB bus registered, assigned bus num1
[ 4.314751] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 0
[ 4.314771] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[ 4.314880] tegra-xusb 3610000.usb: xHCI Host Controller
[ 4.314884] tegra-xusb 3610000.usb: new USB bus registered, assigned bus num2
[ 4.314887] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.315701] hub 1-0:1.0: USB hub found
[ 4.315720] hub 1-0:1.0: 4 ports detected
[ 4.316092] hub 2-0:1.0: USB hub found
[ 4.316108] hub 2-0:1.0: 4 ports detected
[ 4.317240] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 4.317578] irq: IRQ228: trimming hierarchy from :bus@0:pmc@c360000
[ 4.317643] irq: IRQ229: trimming hierarchy from :bus@0:interrupt-controller1
[ 4.317708] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.358485] ALSA device list:
[ 4.358489] No soundcards found.
[ 4.360754] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 4.405922] irq: IRQ230: trimming hierarchy from :bus@0:interrupt-controller1
[ 4.406206] mmc0: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 6t
[ 4.407411] Freeing unused kernel memory: 7680K
[ 4.407499] Run /init as init process
[ 4.424966] Root device found: initrd
[ 4.438959] r8168: loading out-of-tree module taints kernel.
[ 4.441130] Mount initrd as rootfs and enter recovery mode
[ 4.651565] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.803547] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 4.804368] mmcblk0: mmc0:aaaa SN128 119 GiB
[ 4.819557] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 4.822938] hub 1-2:1.0: USB hub found
[ 4.823973] hub 1-2:1.0: 4 ports detected
[ 4.940445] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tb
[ 4.988959] hub 2-1:1.0: USB hub found
[ 4.991220] hub 2-1:1.0: 4 ports detected
[ 5.095405] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 5.478472] tegra194-pcie 140a0000.pcie: Adding to iommu group 4
[ 5.588313] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ra:
[ 5.588338] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff0
[ 5.588345] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff0
[ 5.588348] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff0
[ 5.588835] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[ 5.588841] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, d
[ 5.695410] tegra194-pcie 140a0000.pcie: Link up
[ 5.698114] tegra194-pcie 140a0000.pcie: Link up
[ 5.698187] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 5.698191] pci_bus 0008:00: root bus resource [io 0x0000-0xfffff] (bus add)
[ 5.698195] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352ffffff)
[ 5.698198] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 5.698200] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527fffff]
[ 5.698248] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 5.698405] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 5.701882] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 5.702039] pci 0008:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 5.702042] pci 0008:01:00.0: reg 0x10: [io size 0x0100]
[ 5.702224] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 5.702342] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 5.703329] pci 0008:01:00.0: supports D1 D2
[ 5.703331] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 5.718071] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280ffff]
[ 5.718075] pci 0008:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 5.718079] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff]
[ 5.718173] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff]
[ 5.718265] pci 0008:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 5.718294] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 5.718296] pci 0008:00:00.0: bridge window [io 0x1000-0x1fff]
[ 5.718301] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 5.718396] pcieport 0008:00:00.0: Adding to iommu group 4
[ 5.718485] pcieport 0008:00:00.0: PME: Signaling with IRQ 189
[ 5.719043] pcieport 0008:00:00.0: AER: enabled with IRQ 189
[ 5.719271] r8168 0008:01:00.0: Adding to iommu group 4
[ 5.719333] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded
[ 5.719399] r8168 0008:01:00.0: enabling device (0000 → 0003)
[ 5.736455] r8168: This product is covered by one or more of the following p.
[ 5.738512] r8168 Copyright (C) 2024 Realtek NIC software team <nicfae@real
[ 5.738512] This program comes with ABSOLUTELY NO WARRANTY; for details, pl
[ 5.738512] This is free software, and you are welcome to redistribute it u
[ 5.738619] tegra194-pcie 14100000.pcie: Adding to iommu group 5
[ 5.739550] irq: IRQ232: trimming hierarchy from :bus@0:interrupt-controller1
[ 5.742238] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ra:
[ 5.742261] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff0
[ 5.742267] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff0
[ 5.742270] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff0
[ 5.742570] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[ 5.742573] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, d
[ 5.847417] tegra194-pcie 14100000.pcie: Link up
[ 5.849687] tegra194-pcie 14100000.pcie: Link up
[ 5.849763] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 5.849768] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus )
[ 5.849771] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20affffff)
[ 5.849774] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 5.849776] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7fffff]
[ 5.849821] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 5.849986] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 5.853271] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 5.853444] pci 0001:01:00.0: reg 0x10: [io 0x100000-0x1000ff]
[ 5.853646] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 5.854702] pci 0001:01:00.0: supports D1 D2
[ 5.854704] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 5.870091] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80ffff]
[ 5.870095] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
[ 5.870099] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff]
[ 5.870202] pci 0001:01:00.0: BAR 0: assigned [io 0x100000-0x1000ff]
[ 5.870234] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 5.870237] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
[ 5.870242] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 5.870327] pcieport 0001:00:00.0: Adding to iommu group 5
[ 5.870410] pcieport 0001:00:00.0: PME: Signaling with IRQ 191
[ 5.870957] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[ 5.871290] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 5.874201] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ra:
[ 5.874224] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff0
[ 5.874229] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff0
[ 5.874233] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff0
[ 5.874746] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[ 5.874750] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, d
[ 5.979410] tegra194-pcie 14160000.pcie: Link up
[ 5.980419] tegra194-pcie 14160000.pcie: Link up
[ 5.980483] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 5.980487] pci_bus 0004:00: root bus resource [io 0x200000-0x2fffff] (bus )
[ 5.980490] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242ffffff)
[ 5.980493] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 5.980495] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427fffff]
[ 5.980538] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 5.980692] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 5.983799] pci 0004:01:00.0: [1ed0:2283] type 00 class 0x010802
[ 5.983993] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 5.984293] pci 0004:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 5.985391] pci 0004:01:00.0: reg 0x164: [mem 0x00000000-0x00003fff 64bit]
[ 5.985394] pci 0004:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x0003ffff 6)
[ 5.998021] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280ffff]
[ 5.998027] pci 0004:01:00.0: BAR 6: assigned [mem 0x2428000000-0x242800ffff]
[ 5.998030] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428010000-0x2428013fff]
[ 5.998116] pci 0004:01:00.0: BAR 7: assigned [mem 0x2428014000-0x2428053fff]
[ 5.998155] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 5.998160] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 5.998245] pcieport 0004:00:00.0: Adding to iommu group 6
[ 5.998328] pcieport 0004:00:00.0: PME: Signaling with IRQ 193
[ 5.998953] pcieport 0004:00:00.0: AER: enabled with IRQ 193
[ 5.999260] tegra194-pcie 141e0000.pcie: Adding to iommu group 7
[ 6.002013] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ra:
[ 6.002037] tegra194-pcie 141e0000.pcie: MEM 0x3000000000..0x3227ffffff0
[ 6.002044] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff0
[ 6.002047] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff0
[ 6.002569] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[ 6.002573] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, d
[ 7.109494] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 8.111389] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 8.111461] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 8.111465] pci_bus 0007:00: root bus resource [io 0x300000-0x3fffff] (bus )
[ 8.111470] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322ffffff)
[ 8.111473] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 8.111475] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227fffff]
[ 8.111516] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 8.111669] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 8.117212] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 8.117310] pcieport 0007:00:00.0: Adding to iommu group 7
[ 8.117391] pcieport 0007:00:00.0: PME: Signaling with IRQ 195
[ 8.117941] pcieport 0007:00:00.0: AER: enabled with IRQ 195
[ 8.118192] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 8.118275] pci 0007:00:00.0: Removing from iommu group 7
[ 8.118285] pci_bus 0007:00: busn_res: [bus 00-ff] is released
insmod /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme-core.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme.ko
[ 8.136646] nvme 0004:01:00.0: Adding to iommu group 6
[ 8.137022] nvme nvme0: pci function 0004:01:00.0
[ 8.137258] nvme 0004:01:00.0: enabling device (0000 → 0002)
[ 8.164149] nvme nvme0: allocated 128 MiB host memory buffer.
[ 8.165901] nvme nvme0: 6/0/0 default/read/poll queues
[ 8.169023] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
insmod /lib/modules/5.15.148-tegra/kernel/drivers/thermal/tegra/tegra-bpmp-ther
insmod /lib/modules/5.15.148-tegra/kernel/drivers/pwm/pwm-tegra.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/hwmon/pwm-fan.ko
Checking whether device /dev/mmcblk?p1 exist
Looking for OTA work directory on the device(s): /dev/mmcblk0p1
[ 8.196601] Finding OTA work dir on external storage devices
[ 8.200386] mount /dev/mmcblk0p1 /mnt
[ 8.246173] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. .
[ 8.247942] is_boot_part_for_disk_enc /dev/mmcblk0p1 /mnt
[ 8.257676] OTA work directory /mnt/ota_work is not found on /dev/mmcblk0p1
Checking whether device /dev/sd?1 exist
Device /dev/sd?1 does not exist
Checking whether device /dev/nvme?n1p1 exist
Looking for OTA work directory on the device(s): /dev/nvme0n1p1
[ 8.275509] mount /dev/nvme0n1p1 /mnt
[ 8.285583] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. .
[ 8.287228] is_boot_part_for_disk_enc /dev/nvme0n1p1 /mnt
[ 8.296641] OTA work directory /mnt/ota_work is not found on /dev/nvme0n1p1
[ 8.305264] Finding OTA work dir on internal storage device
[ 8.306533] mount /dev/mmcblk0 /mnt
mount: /mnt: wrong fs type, bad option, bad superblock on /dev/mmcblk0, missing.
[ 8.371453] Failed to mount /dev/mmcblk0 on the /mnt
[ 8.372705] Failed to run “mount_ota_work_partition /dev/mmcblk0 /mnt”
[ 8.373975] OTA work directorycannot seounermd on il processrna grl aoupnd ee
e
bash: no job control in this shell
bash-5.1#
and this is the log without the SD-card (the device normally booted this way from the mmc)
I> Size of partition: 2097152
I> Binary@ device:3/0 block-121216 (partition size: 0x200000), name: B_adsp-fw
I> strt_pg_num(121216) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_adsp-fw]: sw (BCH): 0, hw (BCT): 0
I> strt_pg_num(121232) num_of_pgs(232) read_buf(0x27d800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x27a000000
I> Partition name: B_xusb-fw
I> Powergating APE
I> Powergate done
I> Unhalting SPE..
����spe: early_init
����vic initialized
����tsc initialized
����spe: init
����tag initialized
����tcu initialized
����spe: late init
����pm initialized
I> Task: Unhalt FSI
I> ��
��FSI unhalt skipped��hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
initialized vwdt
initialized fuse
initialized vfrel
initialized adc
initialized fmon
initialized mc
initialized reset
initialized pm
initialized io_dpd
initialized regime
initialized i2c
initialized vrmon
I> Unhalting RCE
I> Unhalting DCE
I> Task: Load TOS
I> Task: Trigger load TS��[ 2.589544] Camera-FW on t234-rce-safe started
��EC ��TCU early console enabled.
��leyblob
I> Sent opcode to ��initialized avfs_clk_platform
��psc
I> Task: Load and authenticate registered ��initialized dvs
��FWs��initialized clk_mach_config
initialized suspend
initialized strap
I> Partition name: B_cpu-bootloader
��DCE Started
��DCE_R5_Init
��MPU enabled
DCE_SW_Init
��I> strt_p��initialized emc
initialized emc_mrq
��g_num(87824) num_of_pgs(8) read_buf(��initialized clk_cal
initialized uphy_dt
initialized uphy
initialized pg_late
initialized bwmgr
initialized oc_mrq
initialized clk_mrq
initialized i2c_mrq
initialized tag_mrq
��0x273943c98)
I> cpubl : meta-blob ��initialized clk_cal_late
initialized cvc
��integrity check is success.
I> ��initialized avfs_clk_mach_post
initialized rm
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable dsi_lp
��[ 2.806950] Camer��c0_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c1_core rate 500000000 > max 0
clk_check_max_rate: pex0_c2_core rate 500000�� ready SHA1=04ea8699 ��000 > max 0
clk_check_max_rate: pex0_c3_core rate 500000000 > max 250��(crt 12.419 ms, tota)
��000000
initialized pg_post
initialized profile
initialized mrq
initialized cactmon
bpmp: init complete
��strt_pg_num(87832) num_of_pgs(512) read_buf(0x273803c80)
��Admin Task Init
Print Task Init
RM Task Init
Admin Tas��I> strt_pg_num(88344)��k Started
RM Task Started
RM Task Running
Print Task Started
Print Task Running
Admin Task Running
�� num_of_pgs(512) read_buf(0x273843c80)
I> Task: SMMU init
I> MB2 finished
I/TC:
3h
FvbWrite: Writing Measurement 0xFF
3h
ESC to enter Setup.
s to enter Shell.
[ 0.000000] esrt: Reserving ESRT space from 0x0000000267a81d98 to 0x00000002.
[ 0.000000] NUMA: NODE_DATA [mem 0x27130b800-0x27130dfff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000025d4bffff]
[ 0.000000] node 0: [mem 0x000000025d4c0000-0x000000025e0effff]
[ 0.000000] node 0: [mem 0x000000025e0f0000-0x000000025e11ffff]
[ 0.000000] node 0: [mem 0x000000025e120000-0x000000025e12ffff]
[ 0.000000] node 0: [mem 0x000000025e130000-0x000000025e17ffff]
[ 0.000000] node 0: [mem 0x000000025e180000-0x000000025e31ffff]
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] Built 1 zonelists, mobility grouping on. Totins /lal modes: 2000
egr[ a/upda.00000tesive0] Polrs//ethernet/rene:altek/rmar8168/.000000] r8168.kl
mmand line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,1152
[ 0.000000] Memory: 7500140K/8132224K available (20160K kernel code, 4064K r)
[ 0.000391] Console: colour dummy device 80x25
[ 0.000458] Calibrating delay loop (skipped), value calculated using timer f)
[ 0.000467] pid_max: default: 32768 minimum: 301
[ 0.000508] LSM: Security Framework initializing
[ 0.000535] Yama: becoming mindful.
[ 0.000552] SELinux: Initializing.
[ 0.000634] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, l)
[ 0.000649] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 byt)
[ 0.001777] rcu: Hierarchical SRCU implementation.
[ 0.004061] Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[ 0.004336] Remapping and enabling EFI services.
[ 0.005398] smp: Bringing up secondary CPUs …
[ 0.005903] Detected PIPT I-cache on CPU1
[ 0.005949] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.005987] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.006456] Detected PIPT I-cache on CPU2
[ 0.006471] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006486] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006899] Detected PIPT I-cache on CPU3
[ 0.006910] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006924] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.009380] Detected PIPT I-cache on CPU4
[ 0.009409] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f50000
[ 0.009436] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.009926] Detected PIPT I-cache on CPU5
[ 0.009939] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f52000
[ 0.009953] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.010011] smp: Brought up 1 node, 6 CPUs
[ 0.010016] SMP: Total of 6 processors activated.
[ 0.010019] CPU features: detected: 32-bit EL0 Support
[ 0.010021] CPU features: detected: Data cache clean to the PoU not requirede
[ 0.010023] CPU features: detected: Common not Private translations
[ 0.010024] CPU features: detected: CRC32 instructions
[ 0.010025] CPU features: detected: Data cache clean to Point of Persistence
[ 0.010027] CPU features: detected: Generic authentication (architected algo)
[ 0.010028] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.010030] CPU features: detected: LSE atomic instructions
[ 0.010031] CPU features: detected: Privileged Access Never
[ 0.010032] CPU features: detected: RAS Extension Support
[ 0.010035] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.052787] CPU: All CPU(s) started at EL2
[ 0.056061] devtmpfs: initialized
[ 0.075554] KASLR enabled
[ 0.075769] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.075795] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.080783] pinctrl core: initialized pinctrl subsystem
[ 0.081923] SMBIOS 3.6.0 present.
[ 0.081937] DMI: NVIDIA NVIDIA Jetson Orin Nano Engineering Reference Develo6
[ 0.082527] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.084304] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.084448] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic als
[ 0.084549] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic s
[ 0.084681] audit: initializing netlink subsys (disabled)
[ 0.084847] audit: type=2000 audit(0.084:1): state=initialized audit_enabled1
[ 0.087111] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.087117] thermal_sys: Registered thermal governor ‘user_space’
[ 0.087119] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.091037] cpuidle: using governor menu
[ 0.091368] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.091469] ASID allocator initialised with 32768 entries
[ 0.093595] Serial: AMBA PL011 UART driver
[ 0.104848] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud A
[ 0.116572] platform bpmp: Fixing up cyclic dependency with 2c60000.externalr
[ 0.126358] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.126364] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.126365] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.126366] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.127465] cryptd: max_cpu_qlen set to 1000
[ 0.129471] ACPI: Interpreter disabled.
[ 0.130994] VDD_1V8_AO: supplied by VDD_5V0_SYS
[ 0.131200] VDD_3V3_AO: supplied by VDD_5V0_SYS
[ 0.131484] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[ 0.132010] iommu: Default domain type: Translated
[ 0.132016] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.132556] SCSI subsystem initialized
[ 0.132892] vgaarb: loaded
[ 0.133101] usbcore: registered new interface driver usbfs
[ 0.133128] usbcore: registered new interface driver hub
[ 0.133142] usbcore: registered new device driver usb
[ 0.133591] pps_core: LinuxPPS API ver. 1 registered
[ 0.133596] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[ 0.133611] PTP clock support registered
[ 0.133687] EDAC MC: Ver: 3.0.0
[ 0.135174] Registered efivars operations
[ 0.135926] FPGA manager framework
[ 0.136000] Advanced Linux Sound Architecture Driver Initialized.
[ 0.136553] Bluetooth: Core ver 2.22
[ 0.136588] NET: Registered PF_BLUETOOTH protocol family
[ 0.136594] Bluetooth: HCI device and connection manager initialized
[ 0.136602] Bluetooth: HCI socket layer initialized
[ 0.136610] Bluetooth: L2CAP socket layer initialized
[ 0.136628] Bluetooth: SCO socket layer initialized
[ 0.137113] clocksource: Switched to clocksource arch_sys_counter
[ 0.171436] VFS: Disk quotas dquot_6.6.0
[ 0.171510] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.171750] pnp: PnP ACPI: disabled
[ 0.174997] NET: Registered PF_INET protocol family
[ 0.175322] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, l)
[ 0.176882] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 655)
[ 0.177018] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes,)
[ 0.177033] TCP established hash table entries: 65536 (order: 7, 524288 byte)
[ 0.177312] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, lin)
[ 0.178720] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.178924] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.179021] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linea)
[ 0.179310] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.179753] RPC: Registered named UNIX socket transport module.
[ 0.179759] RPC: Registered udp transport module.
[ 0.179762] RPC: Registered tcp transport module.
[ 0.179764] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.179779] PCI: CLS 0 bytes, default 64
[ 0.180058] Unpacking initramfs…
[ 0.186340] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counte
[ 0.186664] kvm [1]: IPA Size Limit: 48 bits
[ 0.186701] kvm [1]: GICv3: no GICV resource entry
[ 0.186710] kvm [1]: disabling GICv2 emulation
[ 0.186726] kvm [1]: GIC system register CPU interface enabled
[ 0.186796] kvm [1]: vgic interrupt IRQ9
[ 0.186943] kvm [1]: VHE mode initialized successfully
[ 0.190454] Initialise system trusted keyrings
[ 0.190504] Key type blacklist registered
[ 0.190667] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[ 0.193833] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.194289] NFS: Registering the id_resolver key type
[ 0.194319] Key type id_resolver registered
[ 0.194323] Key type id_legacy registered
[ 0.194379] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.194394] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registerin.
[ 0.194417] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.194677] 9p: Installing v9fs 9p2000 file system support
[ 0.195307] integrity: Platform Keyring initialized
[ 0.208309] Key type asymmetric registered
[ 0.208316] Asymmetric key parser ‘x509’ registered
[ 0.208386] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[ 0.208393] io scheduler mq-deadline registered
[ 0.208398] io scheduler kyber registered
[ 0.219079] EINJ: ACPI disabled.
[ 0.231975] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.233830] SuperH (H)SCI(F) driver initialized
[ 0.234185] msm_serial: driver initialized
[ 0.234919] printk: console [ttyTCU0] enabled
[ 0.235915] arm-smmu 8000000.iommu: probing hardware configuration…
[ 0.235923] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.235928] arm-smmu 8000000.iommu: stage 1 translation
[ 0.235930] arm-smmu 8000000.iommu: stage 2 translation
[ 0.235931] arm-smmu 8000000.iommu: nested translation
[ 0.235935] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.235939] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.235952] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.235955] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.235957] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.236982] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.236986] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.236989] arm-smmu 10000000.iommu: stage 1 translation
[ 0.236990] arm-smmu 10000000.iommu: stage 2 translation
[ 0.236991] arm-smmu 10000000.iommu: nested translation
[ 0.236994] arm-smmu 10000000.iommu: stream matching with 128 regists
[ 0.236998] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 on)
[ 0.237003] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.237004] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.237007] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.237438] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.237442] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.237444] arm-smmu 12000000.iommu: stage 1 translation
[ 0.237445] arm-smmu 12000000.iommu: stage 2 translation
[ 0.237445] arm-smmu 12000000.iommu: nested translation
[ 0.237448] arm-smmu 12000000.iommu: stream matching with 128 regists
[ 0.237450] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 on)
[ 0.237455] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.237456] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.237457] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.244882] loop: module loaded
[ 0.245949] megasas: 07.717.02.00-rc1
[ 0.250268] tun: Universal TUN/TAP device driver, 1.6
[ 0.250879] thunder_xcv, ver 1.0
[ 0.250913] thunder_bgx, ver 1.0
[ 0.250936] nicpf, ver 1.0
[ 0.251819] hclge is initializing
[ 0.251853] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - versin
[ 0.251861] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.251913] e1000: Intel(R) PRO/1000 Network Driver
[ 0.251918] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.251941] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.251944] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.251966] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.251970] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.251981] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.251986] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.252203] sky2: driver version 1.30
[ 0.252901] VFIO - User Level meta-driver version: 0.3
[ 0.254539] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.254549] ehci-pci: EHCI PCI platform driver
[ 0.254577] ehci-platform: EHCI generic platform driver
[ 0.254660] ehci-orion: EHCI orion driver
[ 0.254722] ehci-exynos: EHCI Exynos driver
[ 0.254781] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.254809] ohci-pci: OHCI PCI platform driver
[ 0.254834] ohci-platform: OHCI generic platform driver
[ 0.254903] ohci-exynos: OHCI Exynos driver
[ 0.255355] usbcore: registered new interface driver usb-storage
[ 0.257261] i2c_dev: i2c /dev entries driver
[ 0.258562] pps pps0: new PPS source ktimer
[ 0.258571] pps pps0: ktimer PPS source registered
[ 0.258581] pps_ldisc: PPS line discipline registered
[ 0.260746] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-m
[ 0.262852] sdhci: Secure Digital Host Controller Interface driver
[ 0.262859] sdhci: Copyright(c) Pierre Ossman
[ 0.263326] Synopsys Designware Multimedia Card Interface Driver
[ 0.263971] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.265169] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.266142] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.266691] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.268055] tegra-bpmp bpmp: firmware: 030ffe301d1db1d01cb6-68f126a8abf
[ 0.544527] Freeing initrd memory: 20464K
[ 3.368713] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046s
[ 3.368744] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_is
[ 3.368749] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_s
[ 3.369031] hid: raw HID events driver (C) Jiri Kosina
[ 3.369429] usbcore: registered new interface driver usbhid
[ 3.369436] usbhid: USB HID core driver
[ 3.374547] optee: probing for conduit method.
[ 3.374613] optee: revision 4.2 (5ef90dab)
[ 3.433928] optee: dynamic shared memory is enabled
[ 3.434210] optee: initialized driver
[ 3.437278] usbcore: registered new interface driver snd-usb-audio
[ 3.438720] NET: Registered PF_PACKET protocol family
[ 3.439472] Bluetooth: RFCOMM TTY layer initialized
[ 3.439512] Bluetooth: RFCOMM socket layer initialized
[ 3.439539] Bluetooth: RFCOMM ver 1.11
[ 3.439758] 9pnet: Installing 9P2000 support
[ 3.439864] Key type dns_resolver registered
[ 3.441314] printk: console [ttyTCU0]: printing thread started
[ 3.441382] Loading compiled-in X.509 certificates
[ 3.443688] Loaded X.509 cert ‘Build time autogenerated kernel key: 7f1e7893’
[ 3.476257] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 3.477767] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 s
[ 3.479184] serial-tegra 3100000.serial: RX in PIO mode
[ 3.479189] serial-tegra 3100000.serial: TX in PIO mode
[ 3.479250] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud T
[ 3.479820] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud T
[ 3.481623] tegra_rtc c2a0000.rtc: registered as rtc1
[ 3.481632] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.482070] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 3.485403] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 3.487136] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 3.488591] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 3.493948] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[ 3.494717] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 3.525088] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequz
[ 3.530031] tegra-xusb 3610000.usb: Adding to iommu group 2
[ 3.548540] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 C
[ 3.548550] tegra-xusb 3610000.usb: xHCI Host Controller
[ 3.548567] tegra-xusb 3610000.usb: new USB bus registered, assigned bus num1
[ 3.549315] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 0
[ 3.549338] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[ 3.549470] tegra-xusb 3610000.usb: xHCI Host Controller
[ 3.549474] tegra-xusb 3610000.usb: new USB bus registered, assigned bus num2
[ 3.549477] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.549979] hub 1-0:1.0: USB hub found
[ 3.549994] hub 1-0:1.0: 4 ports detected
[ 3.550266] hub 2-0:1.0: USB hub found
[ 3.550278] hub 2-0:1.0: 4 ports detected
[ 3.551495] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 3.551974] irq: IRQ228: trimming hierarchy from :bus@0:pmc@c360000
[ 3.552036] irq: IRQ229: trimming hierarchy from :bus@0:interrupt-controller1
[ 3.552107] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 3.557281] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 3.634117] ALSA device list:
[ 3.634121] No soundcards found.
[ 3.681101] irq: IRQ230: trimming hierarchy from :bus@0:interrupt-controller1
[ 3.681383] mmc0: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 6t
[ 3.682323] Freeing unused kernel memory: 7680K
[ 3.682402] Run /init as init process
[ 3.698219] Root device found: initrd
[ 3.713971] r8168: loading out-of-tree module taints kernel.
[ 3.716101] Mount initrd as rootfs and enter recovery mode
[ 3.889104] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.059528] hub 1-2:1.0: USB hub found
[ 4.060650] hub 1-2:1.0: 4 ports detected
[ 4.178634] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tb
[ 4.233220] hub 2-1:1.0: USB hub found
[ 4.235774] hub 2-1:1.0: 4 ports detected
[ 4.337293] usb 1-3: new full-speed USB device number 3 using tegra-xusb
insmod /lib/modules/5.15.148-tegra/kernel/drivers/phy/tegra/phy-tegra194-p2u.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/pci/controller/dwc/pcie-tegra
[ 13.743402] tegra194-pcie 140a0000.pcie: Adding to iommu group 4
[ 13.850900] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ra:
[ 13.850925] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff0
[ 13.850933] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff0
[ 13.850937] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff0
[ 13.851428] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[ 13.851431] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, d
[ 13.957116] tegra194-pcie 140a0000.pcie: Link up
[ 13.959919] tegra194-pcie 140a0000.pcie: Link up
[ 13.959986] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 13.959990] pci_bus 0008:00: root bus resource [io 0x0000-0xfffff] (bus add)
[ 13.959994] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352ffffff)
[ 13.959997] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 13.959999] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527fffff]
[ 13.960048] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 13.960202] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 13.963689] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 13.963846] pci 0008:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 13.963849] pci 0008:01:00.0: reg 0x10: [io size 0x0100]
[ 13.964031] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 13.964148] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 13.965139] pci 0008:01:00.0: supports D1 D2
[ 13.965141] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 13.979959] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280ffff]
[ 13.979962] pci 0008:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 13.979966] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff]
[ 13.980060] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff]
[ 13.980152] pci 0008:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 13.980180] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 13.980184] pci 0008:00:00.0: bridge window [io 0x1000-0x1fff]
[ 13.980188] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 13.980280] pcieport 0008:00:00.0: Adding to iommu group 4
[ 13.980369] pcieport 0008:00:00.0: PME: Signaling with IRQ 189
[ 13.980657] pcieport 0008:00:00.0: AER: enabled with IRQ 189
[ 13.980833] r8168 0008:01:00.0: Adding to iommu group 4
[ 13.980890] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded
[ 13.980957] r8168 0008:01:00.0: enabling device (0000 → 0003)
[ 13.998041] r8168: This product is covered by one or more of the following p.
[ 14.000102] r8168 Copyright (C) 2024 Realtek NIC software team <nicfae@real
[ 14.000102] This program comes with ABSOLUTELY NO WARRANTY; for details, pl
[ 14.000102] This is free software, and you are welcome to redistribute it u
[ 14.000216] tegra194-pcie 14100000.pcie: Adding to iommu group 5
[ 14.001194] irq: IRQ232: trimming hierarchy from :bus@0:interrupt-controller1
[ 14.003323] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ra:
[ 14.003347] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff0
[ 14.003353] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff0
[ 14.003358] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff0
[ 14.003840] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[ 14.003843] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, d
[ 14.109287] tegra194-pcie 14100000.pcie: Link up
[ 14.112058] tegra194-pcie 14100000.pcie: Link up
[ 14.112120] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 14.112124] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus )
[ 14.112127] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20affffff)
[ 14.112129] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 14.112131] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7fffff]
[ 14.112176] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 14.112340] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 14.115970] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 14.116145] pci 0001:01:00.0: reg 0x10: [io 0x100000-0x1000ff]
[ 14.116346] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 14.117432] pci 0001:01:00.0: supports D1 D2
[ 14.117435] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 14.132036] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80ffff]
[ 14.132040] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
[ 14.132043] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff]
[ 14.132146] pci 0001:01:00.0: BAR 0: assigned [io 0x100000-0x1000ff]
[ 14.132177] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 14.132180] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
[ 14.132184] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 14.132286] pcieport 0001:00:00.0: Adding to iommu group 5
[ 14.132381] pcieport 0001:00:00.0: PME: Signaling with IRQ 191
[ 14.133279] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[ 14.133629] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 14.137013] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ra:
[ 14.137034] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff0
[ 14.137041] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff0
[ 14.137045] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff0
[ 14.137566] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[ 14.137570] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, d
[ 14.245287] tegra194-pcie 14160000.pcie: Link up
[ 14.245951] tegra194-pcie 14160000.pcie: Link up
[ 14.246007] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 14.246012] pci_bus 0004:00: root bus resource [io 0x200000-0x2fffff] (bus )
[ 14.246015] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242ffffff)
[ 14.246017] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 14.246019] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427fffff]
[ 14.246059] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 14.246206] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 14.249350] pci 0004:01:00.0: [1ed0:2283] type 00 class 0x010802
[ 14.249543] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 14.249842] pci 0004:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 14.250939] pci 0004:01:00.0: reg 0x164: [mem 0x00000000-0x00003fff 64bit]
[ 14.250941] pci 0004:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x0003ffff 6)
[ 14.263964] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280ffff]
[ 14.263969] pci 0004:01:00.0: BAR 6: assigned [mem 0x2428000000-0x242800ffff]
[ 14.263972] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428010000-0x2428013fff]
[ 14.264058] pci 0004:01:00.0: BAR 7: assigned [mem 0x2428014000-0x2428053fff]
[ 14.264094] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 14.264099] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 14.264184] pcieport 0004:00:00.0: Adding to iommu group 6
[ 14.264266] pcieport 0004:00:00.0: PME: Signaling with IRQ 193
[ 14.265296] pcieport 0004:00:00.0: AER: enabled with IRQ 193
[ 14.265573] tegra194-pcie 141e0000.pcie: Adding to iommu group 7
[ 14.268655] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ra:
[ 14.268676] tegra194-pcie 141e0000.pcie: MEM 0x3000000000..0x3227ffffff0
[ 14.268682] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff0
[ 14.268686] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff0
[ 14.269008] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[ 14.269010] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, d
[ 15.378982] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 16.380865] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 16.380915] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 16.380919] pci_bus 0007:00: root bus resource [io 0x300000-0x3fffff] (bus )
[ 16.380922] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322ffffff)
[ 16.380925] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 16.380927] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227fffff]
[ 16.380969] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 16.381145] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 16.386791] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 16.386879] pcieport 0007:00:00.0: Adding to iommu group 7
[ 16.386959] pcieport 0007:00:00.0: PME: Signaling with IRQ 195
[ 16.387459] pcieport 0007:00:00.0: AER: enabled with IRQ 195
[ 16.387679] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 16.387761] pci 0007:00:00.0: Removing from iommu group 7
[ 16.387771] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 16.402361] nvme 0004:01:00.0: Adding to iommu group 6
[ 16.402557] nvme nvme0: pci function 0004:01:00.0
[ 16.402788] nvme 0004:01:00.0: enabling device (0000 → 0002)
[ 16.430927] nvme nvme0: allocated 128 MiB host memory buffer.
[ 16.432668] nvme nvme0: 6/0/0 default/read/poll queues
[ 16.434662] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[ 16.460205] Finding OTA work dir on external storage dDeveviice /dev/
mmcblk?p1 does not exist
[ 16.484503] mount /dev/nvme0n1p1 /mnt
[ 16.493279] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. .
[ 16.494946] is_boot_part_for_disk_enc /dev/nvme0n1p1 /mnt
[ 16.501819] OTA work directory /mnt/ota_work is not found on /dev/nvme0n1p1
[ 16.510679] Finding OTA work dir on internal mount: evit:
spe[ cial devi.51t
[ 16.521265] Failed to mount /dev/mmcblk0 on the /mnt
[ h: .52246 set tFaiermina tol p rurocn “mou grnt_ota_work_par Inappropria /dt”
e[ 16.52no jobOTA work dirntrectthi is not fhelounlnternal abasnd external sts
The boot is stuck in recovery image.
Check this page to recover it.
this works for booting from SD, but NOT for booting from NVME. I even retried the step making the nvme bootable from the SD->nvme transfer method…
I have removed the SD-card and checked that the device is NOT set to unbootable. this is the log for trying to boot from the SSD. It looped again!
[0001.250] I> Size of crypto header is 8192
[0001.254] I> Size of crypto header is 8192
[0001.258] I> strt_pg_num(76032) num_of_pgs(16) read_buf(0x807fc000)
[0001.264] I> BCH of BPMP_FW_DTB read from storage
[0001.269] I> BCH address is : 0x807fc000
[0001.272] I> BPMP_FW_DTB header integrity check is success
[0001.278] I> Binary magic in BCH component 0 is BPMD
[0001.283] I> component binary type is 16
[0001.286] I> Size of crypto header is 8192
[0001.290] I> strt_pg_num(76048) num_of_pgs(734) read_buf(0x807a03f0)
[0001.301] I> BPMP_FW_DTB binary is read from storage
[0001.306] I> BPMP_FW_DTB binary integrity check is success
[0001.311] I> Binary BPMP_FW_DTB loaded successfully at 0x807a03f0 (0x5bc00)
[0001.318] I> Task: BPMP fw ast config
[0001.322] I> Task: Load psc-fw
[0001.325] I> Slot: 1
[0001.327] I> Binary[17] block-84224 (partition size: 0xc0000)
[0001.332] I> Binary name: PSC_FW
[0001.335] I> Size of crypto header is 8192
[0001.339] I> Size of crypto header is 8192
[0001.343] I> strt_pg_num(84224) num_of_pgs(16) read_buf(0x80ffe000)
[0001.350] I> BCH of PSC_FW read from storage
[0001.354] I> BCH address is : 0x80ffe000
[0001.358] I> PSC_FW header integrity check is success
[0001.362] I> Binary magic in BCH component 0 is PFWP
[0001.367] I> component binary type is 17
[0001.371] I> Size of crypto header is 8192
[0001.375] I> strt_pg_num(84240) num_of_pgs(591) read_buf(0x80fb4200)
[0001.385] I> PSC_FW binary is read from storage
[0001.390] I> PSC_FW binary integrity check is success
[0001.394] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.401] I> Task: Load nvdec-fw
[0001.404] I> Slot: 1
[0001.406] I> Binary[7] block-69376 (partition size: 0x100000)
[0001.412] I> Binary name: NVDEC
[0001.414] I> Size of crypto header is 8192
[0001.418] I> Size of crypto header is 8192
[0001.422] I> strt_pg_num(69376) num_of_pgs(16) read_buf(0x800fe000)
[0001.429] I> BCH of NVDEC read from storage
[0001.433] I> BCH address is : 0x800fe000
[0001.436] I> NVDEC header integrity check is success
[0001.441] I> Binary magic in BCH component 0 is NDEC
[0001.446] I> component binary type is 7
[0001.450] I> Size of crypto header is 8192
[0001.454] I> strt_pg_num(69392) num_of_pgs(560) read_buf(0x80000000)
[0001.463] I> NVDEC binary is read from storage
[0001.468] I> NVDEC binary integrity check is success
[0001.473] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.479] I> Size of crypto header is 8192
[0001.490] I> Task: Load tsec-fw
[0001.493] I> TSEC-FW load support not enabled
[0001.498] I> Task: GPIO interrupt map
[0001.501] I> Task: SC7 context save
[0001.505] I> Slot: 1
[0001.507] I> Binary[27] block-0 (partition size: 0x100000)
[0001.512] I> Binary name: BR_BCT
[0001.515] I> Size of crypto header is 8192
[0001.519] I> Size of crypto header is 8192
[0001.523] I> Size of crypto header is 8192
[0001.527] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.533] I> BR_BCT binary is read from storage
[0001.537] I> BR_BCT binary integrity check is success
[0001.542] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.548] I> Slot: 1
[0001.550] I> Binary[13] block-86784 (partition size: 0x30000)
[0001.556] I> Binary name: SC7-FW
[0001.559] I> Size of crypto header is 8192
[0001.563] I> Size of crypto header is 8192
[0001.567] I> Size of crypto header is 8192
[0001.571] I> Size of crypto header is 8192
[0001.575] I> strt_pg_num(86784) num_of_pgs(16) read_buf(0xa0002000)
[0001.581] I> BCH of SC7-FW read from storage
[0001.585] I> BCH address is : 0xa0002000
[0001.589] I> SC7-FW header integrity check is success
[0001.594] I> Binary magic in BCH component 0 is WB0B
[0001.599] I> component binary type is 13
[0001.602] I> Size of crypto header is 8192
[0001.606] I> strt_pg_num(86800) num_of_pgs(350) read_buf(0xa0004000)
[0001.615] I> SC7-FW binary is read from storage
[0001.619] I> SC7-FW binary integrity check is success
[0001.624] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2bb20)
[0001.631] I> Slot: 1
[0001.633] I> Binary[22] block-87168 (partition size: 0x30000)
[0001.638] I> Binary name: PSC_RF
[0001.641] I> Size of crypto header is 8192
[0001.645] I> Size of crypto header is 8192
[0001.649] I> Size of crypto header is 8192
[0001.653] I> Size of crypto header is 8192
[0001.657] I> strt_pg_num(87168) num_of_pgs(16) read_buf(0xa002fb20)
[0001.663] I> BCH of PSC_RF read from storage
[0001.667] I> BCH address is : 0xa002fb20
[0001.671] I> PSC_RF header integrity check is success
[0001.676] I> Binary magic in BCH component 0 is PSCR
[0001.681] I> component binary type is 22
[0001.685] I> Size of crypto header is 8192
[0001.689] I> strt_pg_num(87184) num_of_pgs(256) read_buf(0xa0031b20)
[0001.696] I> PSC_RF binary is read from storage
[0001.701] I> PSC_RF binary integrity check is success
[0001.706] I> Binary PSC_RF loaded successfully at 0xa0031b20 (0x20000)
[0001.715] I> Task: Save WP0 payload to SC7 ctx
[0001.720] I> Task: Load MB2rf binary to SC7 ctx
[0001.724] I> Slot: 1
[0001.726] I> Binary[14] block-87552 (partition size: 0x20000)
[0001.732] I> Binary name: MB2_RF
[0001.735] I> Size of crypto header is 8192
[0001.739] I> Size of crypto header is 8192
[0001.742] I> Size of crypto header is 8192
[0001.746] I> Size of crypto header is 8192
[0001.750] I> strt_pg_num(87552) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.757] I> BCH of MB2_RF read from storage
[0001.761] I> BCH address is : 0xa00d5d10
[0001.765] I> MB2_RF header integrity check is success
[0001.769] I> Binary magic in BCH component 0 is MB2R
[0001.774] I> component binary type is 14
[0001.778] I> Size of crypto header is 8192
[0001.782] I> strt_pg_num(87568) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.789] I> MB2_RF binary is read from storage
[0001.794] I> MB2_RF binary integrity check is success
[0001.799] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf40)
[0001.805] I> Task: Save fuse alias data to SC7 ctx
[0001.810] I> Task: Save PMIC data to SC7 ctx
[0001.814] I> Task: Save Pinmux data to SC7 ctx
[0001.818] I> Task: Save Pad Voltage data to SC7 ctx
[0001.823] I> Task: Save controller prod data to SC7 ctx
[0001.828] I> Task: Save prod cfg data to SC7 ctx
[0001.833] I> Task: Save I2C bus freq data to SC7 ctx
[0001.837] I> Task: Save SOCTherm data to SC7 ctx
[0001.842] I> Task: Save FMON data to SC7 ctx
[0001.846] I> Task: Save VMON data to SC7 ctx
[0001.850] I> Task: Save TZDRAM data to SC7 ctx
[0001.854] I> Task: Save GPIO int data to SC7 ctx
[0001.859] I> Task: Save clock data to SC7 ctx
[0001.863] I> Task: Save debug data to SC7 ctx
[0001.867] I> Task: Save MBWT data to SC7 ctx
[0001.875] I> SC7 context save done
[0001.879] I> Task: Load MB2/Applet/FSKP
[0001.882] I> Loading MB2
[0001.885] I> Slot: 1
[0001.887] I> Binary[6] block-71424 (partition size: 0x80000)
[0001.892] I> Binary name: MB2
[0001.895] I> Size of crypto header is 8192
[0001.899] I> Size of crypto header is 8192
[0001.903] I> strt_pg_num(71424) num_of_pgs(16) read_buf(0x8007e000)
[0001.909] I> BCH of MB2 read from storage
[0001.913] I> BCH address is : 0x8007e000
[0001.917] I> MB2 header integrity check is success
[0001.921] I> Binary magic in BCH component 0 is MB2B
[0001.926] I> component binary type is 6
[0001.930] I> Size of crypto header is 8192
[0001.934] I> strt_pg_num(71440) num_of_pgs(846) read_buf(0x80000000)
[0001.945] I> MB2 binary is read from storage
[0001.950] I> MB2 binary integrity check is success
[0001.954] I> Binary MB2 loaded successfully at 0x80000000 (0x69a30)
[0001.961] I> Task: Map CCPLEX SHARED carveout
[0001.965] I> Task: Prepare MB2 params
[0001.969] I> Task: Dram ecc test
[0001.972] I> Task: Misc NV security settings
[0001.976] I> NVDEC sticky bits programming done
[0001.980] I> Successfully powergated NVDEC
[0001.984] I> Task: Disable/Reload WDT
[0001.988] I> Task: Program misc carveouts
[0001.992] I> Program IPC carveouts
[0001.995] I> Task: Disable SCPM/POD reset
[0001.999] I> SLCG Global override status := 0x0
[0002.003] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-6ee03b4e)
I> t234-A01-1-Silicon (0x12347)
I> Boot-mode : Coldboot
I> Emulation:
I> Entry timestamp: 0x001eef76
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x273800000, size:0x800000]
I> Task: SE error check
I> Task: Crypto init
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: SMMU external bypass disable
I> Task: Enable hot-plug capability
I> Task: TZDRAM heap init
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: I2C register
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Task: Boot device init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : pllc_out0
I> QSPI Flash: Macronix 64MB
I> QSPI-0l initialized successfully
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Partition Manager Init
I> strt_pg_num(130592) num_of_pgs(1) read_buf(0x273801000)
I> strt_pg_num(130560) num_of_pgs(32) read_buf(0x273801200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: B_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-118016 (partition size: 0x90000), name: B_spe-fw
I> strt_pg_num(118016) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_spe-fw]: sw (BCH): 0, hw (BCT): 0
I> strt_pg_num(118032) num_of_pgs(512) read_buf(0x272e00000)
I> Partition name: B_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-119168 (partition size: 0x100000), name: B_rce-fw
I> strt_pg_num(119168) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_rce-fw]: sw (BCH): 0, hw (BCT): 0
I> strt_pg_num(119184) num_of_pgs(880) read_buf(0x272a00000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x272e00000
I> Partition name: B_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-107776 (partition size: 0x500000), name: B_dce-fw
I> strt_pg_num(107776) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_dce-fw]: sw (BCH): 0, hw (BCT): 0
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x272a00000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(107792) num_of_pgs(1) read_buf(0x2739400d8)
I> strt_pg_num(107792) num_of_pgs(8) read_buf(0x2739400d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(107800) num_of_pgs(512) read_buf(0x2738000c0)
I> strt_pg_num(108312) num_of_pgs(512) read_buf(0x2738400c0)
I> dce : will be decompressed at 0x27a000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(108824) num_of_pgs(512) read_buf(0x2738800c0)
I> dce : decompressed to 12091520 bytes
I> dce: plain binary integrity check is success
I> Partition name: B_adsp-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-72448 (partition size: 0x40000), name: B_xusb-fw
I> strt_pg_num(72448) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_xusb-fw]: sw (BCH): 0, hw (BCT): 0
I> strt_pg_num(72464) num_of_pgs(312) read_buf(0x272f00000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x27d800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: B_pva-fw
I> Binary@ device:3/0 block-125312 (partition size: 0x40000), name: B_pva-fw
I> strt_pg_num(125312) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_pva-fw]: sw (BCH): 0, hw (BCT): 0
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x272f00000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(125328) num_of_pgs(1) read_buf(0x2739400d8)
I> strt_pg_num(125328) num_of_pgs(8) read_buf(0x2739400d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(125336) num_of_pgs(512) read_buf(0x2738000c0)
I> pva-fw : will be decompressed at 0x273180000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x273180000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x276000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
I> Task: Revoke PKC fuse
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save
W> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE..
I> Enabling combined UART
ÿýÿàspe: early_init
ÿ¸ÿàvic initialized
ÿ¸ÿàtsc initialized
ÿ¸ÿàaon lic initialized
ÿ¸ÿàspe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
ÿ¸ÿàspe: SafeRTOS v8.4
ÿ¸ÿàspe: init
ÿ¸ÿàscheduler initialized
ÿ¸ÿàaon hsp initialized
ÿ¸ÿàtag initialized
ÿ¸ÿàtcu initialized
ÿ¸ÿàbpmp ipc initialized
ÿ¸ÿàspe: late init
ÿ¸ÿàcpu_nic clock initialized
ÿ¸ÿàapb clock initialized
ÿ¸ÿàpm initialized
ÿ¸ÿàbpmp hsp initialized
ÿ¸ÿàtop1 hsp initialized
ÿ¸ÿàccplex ipc initialized
ÿ¸ÿàspe: start scheduler
ÿ¸ÿá
I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Trigger load FSI keyblob
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d to psc
I> Task: Unhalt FSI
I> ÿâ
ÿáFSI unhalt skipÿâhwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is 68f126a8abf720445275b10ce9dac080
bpmp: combined binary md5 is 030ffe301d1db1d01cb6fae98e5e988b
bpmp: firmware tag is 030ffe301d1db1d01cb6-68f126a8abf
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
ÿáped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load HV/CPUBL
I> Task: Load TOS
I> Task: Trigger load TSÿå[ 2.589812] Camera-FW on t234-rce-safe started
ÿáEC leyblob
I> Sending opcode 0x53535452 to psc
I> Sent opcode to pscÿâinitialized avfs_clk_platform
initialized powergate
ÿá
I> Task: Load and authenticate registered FWsÿâinitialized dvs
ÿè
ÿá
I> ÿâinitialized clk_mach_config
suspend progress: 0x80000000
initialized suspend
initialized strap
initialized mce_dbell
ÿèDCE Started
ÿáPartition name: B_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-87808 (partition size: 0x380000), name: B_cpu-bootloader
ÿèDCE_R5_Init
ÿáI> strt_pg_num(87808) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_cpu-bootloader]: sw (BCH): 0, hw (BCT): 0
I> cpubl : oem authentication of header done
I> strt_pg_num(87824) num_of_pgs(1) read_buf(0x273943c98)
ÿèMPU enabled
DCEÿâinitialized emc
initialized emc_mrq
ÿè_SW_Init
ÿáI> strt_pg_num(87824) nuÿâinitialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
ÿám_of_pgs(8) read_buf(0x273943c98)ÿâinitialized clk_cal_late
initialized noc_late
initialized cvc
ÿá
I> cpubl : meta-blob integrityÿâinitialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable sdmmc4_axicif
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
clk_check_max_rate: pex1_c6_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c7_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c8_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c9_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c10_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c0_core rate 500000000 > max 250000000ÿå[ 2.807434] Camerÿâ
clk_check_max_rate: pex0_c1_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c2_core rate 500000000 > max 250000000
clkÿåa-FW on t234-rce-safeÿâ_check_max_rate: pex0_c3_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c4_core rate 500000000 > max 250000000
clk_check_max_rate: pex1_c5_corÿå ready SHA1=04ea8699 (crt 12.418 ms, total boot 231.109 ms)
ÿâe rate 500000000 > max 250000000
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
ÿá check isÿèAdmin Task Init
Admin Task Init complete
Print Task Iÿá success.
ÿènit
RM ÿáI> strt_pg_num(87832) num_of_pgs(512) read_buf(0x273803c80)
ÿèTask Init
Admin Task Started
DCE SC7 SHA Disabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
DCE: FW Boot Complete
Admin Task Running
ÿáI> strt_pg_num(88344) num_of_pgs(512) read_buf(0x273843c80)
I> cpubl : will be decompressed at 0x272000000
I> strt_pg_num(88856) num_of_pgs(512) read_buf(0x273883c80)
I> strt_pg_num(89368) num_of_pgs(512) read_buf(0x2738c3c80)
I> strt_pg_num(89880) num_of_pgs(512) read_buf(0x273903c80)
I> strt_pg_num(90392) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(90904) num_of_pgs(512) read_buf(0x273843c80)
I> strt_pg_num(91416) num_of_pgs(512) read_buf(0x273883c80)
I> strt_pg_num(91928) num_of_pgs(512) read_buf(0x2738c3c80)
I> strt_pg_num(92440) num_of_pgs(512) read_buf(0x273903c80)
I> strt_pg_num(92952) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(93464) num_of_pgs(512) read_buf(0x273843c80)
I> strt_pg_num(93976) num_of_pgs(512) read_buf(0x273883c80)
I> cpubl : decompressed to 3481728 bytes
I> cpubl: plain binary integrity check is success
I> Partition name: B_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-94976 (partition size: 0x400000), name: B_secure-os
I> strt_pg_num(94976) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_secure-os]: sw (BCH): 0, hw (BCT): 0
I> strt_pg_num(94992) num_of_pgs(3760) read_buf(0xc1d2a000)
I> MB2-params @ 0x40060000
I> NSDRAM carveout base: 0x80000000, size: 0x1f25f0000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x272000000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0xc1d2a000
I> Relocating OP-TEE dtb from: 0xc1eff180 to 0xbe040020, size: 0x2836
I> [0] START: 0x80000000, SIZE: 0x1f25f0000
I> [1] START: 0x276000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: B_eks
I> Binary@ device:3/0 block-107264 (partition size: 0x40000), name: B_eks
I> strt_pg_num(107264) num_of_pgs(16) read_buf(0x40067ab0)
I> Ratchet: [B_eks]: sw (BCH): 0, hw (BCT): 0
I> strt_pg_num(107280) num_of_pgs(8) read_buf(0xbe020000)
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0xbe020000
I> EKB detected (length: 0x410) @ VA:0xbe020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0xbe040020
I> NVRNG: Health check success
I> OEM sc7 context saved
I> Task: Disable MSS perf stats
I> Task: Storage device deinit
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Bootchain failure check
I> Current Boot-Chain Slot: 1
I> BR-BCT Boot-Chain is 1, and status is 1. Set UPDATE_BRBCT bit to 0
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
ÿäNOTICE: BL31: v2.8(release):3242bf5
NOTICE: BL31: Built : 19:24:15, Jan 15 2026
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Jan 16 03:29:23 UTC 2026 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: fTPM ID is not enabled.
I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is not supported.
I/TC: Primary CPU switching to normal world boot
ÿá
t23x_general UEFI firmware (version 36.5.0-gcid-43688277 built on 2026-01-16T03:26:46+00:00)
ÿäI/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
UpdatePeCoffPermissions: Mapping section 1 of image at 0x406FC000 with RW-XN permissions and size 0x1000
GetDeviceTypeRegions: 1 qspi0 regions present
MmInstallProtocolInterface: 01458542-64B6-42D9-808C-544254D88FC6 40701420
MmInstallProtocolInterface: 40930D29-595C-4588-B692-16E74A5B3C75 407012D0
UpdatePeCoffPermissions: Mapping section 1 of image at 0x406F3000 with RW-XN permissions and size 0x1000
NorFlashInitialise: Using ChipSelect 0
MmInstallProtocolInterface: C3FF8100-150D-4744-A68B-19A5435D5DAD 406EBE30
MmInstallProtocolInterface: 40930D29-595C-4588-B692-16E74A5B3C75 40701110
UpdatePeCoffPermissions: Mapping section 1 of image at 0x406E8000 with RW-XN permissions and size 0x1000
GetDeviceTypeRegions: 1 scratch-t234 regions present
FVBNORInitialize:Using Reserved Partition 66781184 65536 for VarStore Integrity
FVBNORInitialize: VariableOffset 65536000 VariableSize 262144FTW Offset 65798144 FTW Size 524288MmInstallProtocol0
MmInstallProtocolInterface: D326D041-BD31-4C01-B5A8-628BE87F0653 406EB860
MmInstallProtocolInterface: D326D041-BD31-4C01-B5A8-628BE87F0653 406EB8F8
MmInstallProtocolInterface: D326D041-BD31-4C01-B5A8-628BE87F0653 406EB990
MmInstallProtocolInterface: D1A86E3F-0707-4C35-83CD-DC2C29C891A3 0
t23x_general System firmware
date 2026-01-16T03:26:46+00:00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
s to enter Shell.
Enter to continue boot.
…ÿäMmInstallProtocolInterface: 7CE88FB3-4BD7-4679-87A8-A8D8DEE50D2B 0
ÿáL4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
ÿäMmInstallProtocolInterface: 27ABF055-B1B8-4C26-8048-748F37BAA2DF 0
ÿâdebugfs initialized
ÿá[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.199-tegra (buildbrain@2028b486-7cd5-47d1-a7b1-8c0183b08dcf-1nn8-hxql4) (aarch64)
[ 0.000000] Machine model: NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x26de2e698 TPMFinalLog=0x25e900000 SMBIOS=0xffff0000 SMBIOS 3.0=0x26da50000 MEMATTR=0
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x0000000267a81d98 to 0x0000000267a81dd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000249000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000277ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x27130a800-0x27130cfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000277ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000bdffffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x000000025e320000-0x000000025e8fffff]
[ 0.000000] node 0: [mem 0x000000025e900000-0x000000025e90ffff]
[ 0.000000] node 0: [mem 0x000000025e910000-0x000000026beeffff]
[ 0.000000] node 0: [mem 0x000000026bef0000-0x000000026de2ffff]
[ 0.000000] node 0: [mem 0x000000026de30000-0x0000000271dfffff]
[ 0.000000] node 0: [mem 0x0000000271e00000-0x0000000271ffffff]
[ 0.000000] node 0: [mem 0x0000000272000000-0x000000027259ffff]
[ 0.000000] node 0: [mem 0x0000000276000000-0x0000000277ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000277ffffff]
[ 0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 14944 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 30 pages/cpu s83480 r8192 d31208 u122880
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2000800
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=tty
[ 0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0.
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 7505444K/8132224K available (20544K kernel code, 4088K rwdata, 10188K rodata, 7744K init, )
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590s
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000388] Console: colour dummy device 80x25
[ 0.000397] printk: console [tty0] enabled
[ 0.000458] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125)
[ 0.000466] pid_max: default: 32768 minimum: 301
[ 0.000637] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000652] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001804] rcu: Hierarchical SRCU implementation.
[ 0.004172] Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[ 0.004441] Remapping and enabling EFI services.
[ 0.005498] smp: Bringing up secondary CPUs …
[ 0.006006] Detected PIPT I-cache on CPU1
[ 0.006056] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.006098] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.006570] Detected PIPT I-cache on CPU2
[ 0.006583] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006596] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.007005] Detected PIPT I-cache on CPU3
[ 0.007015] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.007027] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.009479] Detected PIPT I-cache on CPU4
[ 0.009509] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[ 0.009536] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.010027] Detected PIPT I-cache on CPU5
[ 0.010040] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[ 0.010054] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.010113] smp: Brought up 1 node, 6 CPUs
[ 0.010118] SMP: Total of 6 processors activated.
[ 0.010121] CPU features: detected: 32-bit EL0 Support
[ 0.010122] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.010125] CPU features: detected: Common not Private translations
[ 0.010126] CPU features: detected: CRC32 instructions
[ 0.010127] CPU features: detected: Data cache clean to Point of Persistence
[ 0.010128] CPU features: detected: Generic authentication (architected algorithm)
[ 0.010129] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.010129] CPU features: detected: LSE atomic instructions
[ 0.010130] CPU features: detected: Privileged Access Never
[ 0.010131] CPU features: detected: RAS Extension Support
[ 0.010133] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.042571] CPU: All CPU(s) started at EL2
[ 0.046229] devtmpfs: initialized
[ 0.067790] KASLR enabled
[ 0.068010] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.068036] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.073012] pinctrl core: initialized pinctrl subsystem
[ 0.074082] SMBIOS 3.6.0 present.
[ 0.074095] DMI: NVIDIA NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super/Jetson, BIOS 36.5.0-6
[ 0.074705] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.076642] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.076793] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.076896] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.076976] audit: initializing netlink subsys (disabled)
[ 0.077121] audit: type=2000 audit(0.076:1): state=initialized audit_enabled=0 res=1
[ 0.079568] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.079574] thermal_sys: Registered thermal governor ‘user_space’
[ 0.079577] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.083622] cpuidle: using governor menu
[ 0.083833] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.083931] ASID allocator initialised with 32768 entries
[ 0.086103] Serial: AMBA PL011 UART driver
[ 0.098315] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[ 0.110459] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.120822] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.120832] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.120836] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.120839] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.121818] cryptd: max_cpu_qlen set to 1000
[ 0.123836] ACPI: Interpreter disabled.
[ 0.125301] VDD_1V8_AO: supplied by VDD_5V0_SYS
[ 0.125488] VDD_3V3_AO: supplied by VDD_5V0_SYS
[ 0.125766] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[ 0.126317] iommu: Default domain type: Translated
[ 0.126324] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.126733] SCSI subsystem initialized
[ 0.126987] vgaarb: loaded
[ 0.127224] usbcore: registered new interface driver usbfs
[ 0.127254] usbcore: registered new interface driver hub
[ 0.127272] usbcore: registered new device driver usb
[ 0.127727] pps_core: LinuxPPS API ver. 1 registered
[ 0.127732] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.127746] PTP clock support registered
[ 0.127840] EDAC MC: Ver: 3.0.0
[ 0.129274] Registered efivars operations
[ 0.130003] FPGA manager framework
[ 0.130141] Advanced Linux Sound Architecture Driver Initialized.
[ 0.130775] Bluetooth: Core ver 2.22
[ 0.130809] NET: Registered PF_BLUETOOTH protocol family
[ 0.130813] Bluetooth: HCI device and connection manager initialized
[ 0.130825] Bluetooth: HCI socket layer initialized
[ 0.130832] Bluetooth: L2CAP socket layer initialized
[ 0.130846] Bluetooth: SCO socket layer initialized
[ 0.131364] clocksource: Switched to clocksource arch_sys_counter
[ 0.167466] VFS: Disk quotas dquot_6.6.0
[ 0.167520] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.167751] pnp: PnP ACPI: disabled
[ 0.170951] NET: Registered PF_INET protocol family
[ 0.171270] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.172864] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.172965] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.172983] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.173247] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.174627] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.174852] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.174951] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.175264] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.175711] RPC: Registered named UNIX socket transport module.
[ 0.175715] RPC: Registered udp transport module.
[ 0.175717] RPC: Registered tcp transport module.
[ 0.175719] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.175738] PCI: CLS 0 bytes, default 64
[ 0.176041] Unpacking initramfs…
[ 0.184497] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.184822] kvm [1]: IPA Size Limit: 48 bits
[ 0.184862] kvm [1]: GICv3: no GICV resource entry
[ 0.184873] kvm [1]: disabling GICv2 emulation
[ 0.184903] kvm [1]: GIC system register CPU interface enabled
[ 0.184977] kvm [1]: vgic interrupt IRQ9
[ 0.185136] kvm [1]: VHE mode initialized successfully
[ 0.188935] Initialise system trusted keyrings
[ 0.188984] Key type blacklist registered
[ 0.189139] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[ 0.192806] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.193364] NFS: Registering the id_resolver key type
[ 0.193388] Key type id_resolver registered
[ 0.193390] Key type id_legacy registered
[ 0.193447] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.193463] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.193492] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.193770] 9p: Installing v9fs 9p2000 file system support
[ 0.194459] integrity: Platform Keyring initialized
[ 0.207275] Key type asymmetric registered
[ 0.207280] Asymmetric key parser ‘x509’ registered
[ 0.207363] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.207371] io scheduler mq-deadline registered
[ 0.207376] io scheduler kyber registered
[ 0.218155] EINJ: ACPI disabled.
[ 0.231155] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.232986] SuperH (H)SCI(F) driver initialized
[ 0.233360] msm_serial: driver initialized
[ 0.234140] printk: console [ttyTCU0] enabled
[ 0.235142] arm-smmu 8000000.iommu: probing hardware configuration…
[ 0.235149] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.235156] arm-smmu 8000000.iommu: stage 1 translation
[ 0.235160] arm-smmu 8000000.iommu: stage 2 translation
[ 0.235160] arm-smmu 8000000.iommu: nested translation
[ 0.235165] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.235169] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.235188] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.235192] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.235194] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.236239] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.236242] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.236244] arm-smmu 10000000.iommu: stage 1 translation
[ 0.236245] arm-smmu 10000000.iommu: stage 2 translation
[ 0.236246] arm-smmu 10000000.iommu: nested translation
[ 0.236249] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.236252] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.236262] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.236263] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.236265] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.236633] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.236637] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.236639] arm-smmu 12000000.iommu: stage 1 translation
[ 0.236640] arm-smmu 12000000.iommu: stage 2 translation
[ 0.236642] arm-smmu 12000000.iommu: nested translation
[ 0.236644] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.236646] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.236651] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.236652] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.236654] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.244347] loop: module loaded
[ 0.245294] megasas: 07.727.03.00-rc1
[ 0.249604] tun: Universal TUN/TAP device driver, 1.6
[ 0.250203] thunder_xcv, ver 1.0
[ 0.250237] thunder_bgx, ver 1.0
[ 0.250262] nicpf, ver 1.0
[ 0.251111] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.251119] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.251170] hclge is initializing
[ 0.251198] e1000: Intel(R) PRO/1000 Network Driver
[ 0.251204] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.251235] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.251240] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.251265] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.251272] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.251289] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.251294] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.251546] sky2: driver version 1.30
[ 0.252286] VFIO - User Level meta-driver version: 0.3
[ 0.253930] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.253941] ehci-pci: EHCI PCI platform driver
[ 0.253968] ehci-platform: EHCI generic platform driver
[ 0.254049] ehci-orion: EHCI orion driver
[ 0.254113] ehci-exynos: EHCI Exynos driver
[ 0.254165] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.254197] ohci-pci: OHCI PCI platform driver
[ 0.254222] ohci-platform: OHCI generic platform driver
[ 0.254289] ohci-exynos: OHCI Exynos driver
[ 0.254728] usbcore: registered new interface driver usb-storage
[ 0.256631] i2c_dev: i2c /dev entries driver
[ 0.257916] pps_ldisc: PPS line discipline registered
[ 0.260422] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.262680] sdhci: Secure Digital Host Controller Interface driver
[ 0.262683] sdhci: Copyright(c) Pierre Ossman
[ 0.263148] Synopsys Designware Multimedia Card Interface Driver
[ 0.263805] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.264964] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.266020] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.266567] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.267990] tegra-bpmp bpmp: firmware: 030ffe301d1db1d01cb6-68f126a8abf
[ 0.430430] Freeing initrd memory: 14556K
[ 3.459593] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 3.459621] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 3.459625] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 3.459908] hid: raw HID events driver (C) Jiri Kosina
[ 3.460272] usbcore: registered new interface driver usbhid
[ 3.460279] usbhid: USB HID core driver
[ 3.464904] optee: probing for conduit method.
[ 3.464960] optee: revision 4.2 (5ef90dab)
[ 3.524311] optee: dynamic shared memory is enabled
[ 3.524563] optee: initialized driver
[ 3.527571] usbcore: registered new interface driver snd-usb-audio
[ 3.528978] NET: Registered PF_PACKET protocol family
[ 3.529753] Bluetooth: RFCOMM TTY layer initialized
[ 3.529765] Bluetooth: RFCOMM socket layer initialized
[ 3.529782] Bluetooth: RFCOMM ver 1.11
[ 3.530000] 9pnet: Installing 9P2000 support
[ 3.530106] Key type dns_resolver registered
[ 3.531522] printk: console [tty0]: printing thread started
[ 3.532196] printk: console [ttyTCU0]: printing thread started
[ 3.532260] Loading compiled-in X.509 certificates
[ 3.535186] Loaded X.509 cert ‘Build time autogenerated kernel key: bf367bc16f73a35b387769f189c603859d364fad’
[ 3.566974] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 3.569160] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 3.571749] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 3.573424] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[ 3.579069] tegra_rtc c2a0000.rtc: registered as rtc1
[ 3.579089] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.579822] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 3.588761] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 3.596575] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 3.603533] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 3.611532] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[ 3.612770] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 3.646280] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1785000 KHz, changing to: 17z
[ 3.651180] tegra-xusb 3610000.usb: Adding to iommu group 2
[ 3.668533] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 3.668542] tegra-xusb 3610000.usb: xHCI Host Controller
[ 3.668564] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 3.669304] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[ 3.669327] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[ 3.669464] tegra-xusb 3610000.usb: xHCI Host Controller
[ 3.669468] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 3.669472] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.670165] hub 1-0:1.0: USB hub found
[ 3.670182] hub 1-0:1.0: 4 ports detected
[ 3.670512] hub 2-0:1.0: USB hub found
[ 3.670525] hub 2-0:1.0: 4 ports detected
[ 3.671806] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 3.672348] irq: IRQ228: trimming hierarchy from :bus@0:pmc@c360000
[ 3.672410] irq: IRQ229: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 3.672483] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 3.673237] clk: Disabling unused clocks
[ 3.674981] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 3.712073] ALSA device list:
[ 3.712077] No soundcards found.
[ 3.759429] irq: IRQ230: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 3.759557] mmc0: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 3.760703] Freeing unused kernel memory: 7744K
[ 3.760789] Run /init as init process
[ 3.771729] Checking overlayfs setting…
[ 3.792762] Overlayfs is disabled…
[ 3.799593] Root device found: nvme0n1p1
[ 4.003605] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.174742] hub 1-2:1.0: USB hub found
[ 4.175765] hub 1-2:1.0: 4 ports detected
[ 4.288185] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[ 4.337886] hub 2-1:1.0: USB hub found
[ 4.340065] hub 2-1:1.0: 4 ports detected
[ 4.443611] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 14.308193] ERROR: nvme0n1p1 not found
[ 14.309687] ttyTCU0: Press [ENTER] to start bash in 30 seconds…
[ 17.310141] ttyTCU0: Press [ENTER] to start bash in 27 seconds…
[ 20.310505] ttyTCU0: Press [ENTER] to start bash in 24 seconds…
[ 22.595978] Starting bash…
Want to clarify what is the target that you want to do now?
The original problem of this topic was that you could not boot from SD. And looks like it could boot now.
If you want to discuss another problem for NVMe, I would suggest you could file a new topic.
What you hit on NVMe is not same as previous problem on SD. From what I saw, it is missing PCIe driver problem.
Thus, new topic would be better for discussion.
the original problem was that my nano suddenly decided that my nvme was no longer bootable…which led to failed boots…which led to the unbootable flag…which even stopped my nano from booting from SD too, The latter was solved, but the root cause was not, nor was the bootability of the NVME solved.
If possible I would want to restore normal booting to the nvme and learn what went wrong. The other option is to wipe the NVME and do a fresh transfer from SD, but that might eventually lead to this problem reaccurring…
