After the system is powered on, the system is stuck after the following information is printed.
[0000.062] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0000.068] I> t234-A01-0-Silicon (0x12347) Prod
[0000.072] I> Boot-mode : Coldboot
[0000.075] I> Entry timestamp: 0x00000000
[0000.079] I> last_boot_error: 0x0
[0000.082] I> BR-BCT: preprod_dev_sign: 0
[0000.086] I> rst_source: 0x0, rst_level: 0x0
[0000.090] I> Task: SE error check
[0000.093] I> Task: Bootchain select WAR set
[0000.097] I> Task: Enable SLCG
[0000.100] I> Task: CRC check
[0000.103] I> Task: Initialize MB2 params
[0000.107] I> MB2-params @ 0x40060000
[0000.111] I> Task: Crypto init
[0000.113] I> Task: Perform MB1 KAT tests
[0000.117] I> Task: NVRNG health check
[0000.121] I> NVRNG: Health check success
[0000.125] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.131] I> Task: Enabling and initialization of Bandwidth limiter
[0000.137] I> No request to configure MBWT settings for any PC!
[0000.142] I> Task: Secure debug controls
[0000.146] I> Task: strap war set
[0000.149] I> Task: Initialize SOC Therm
[0000.153] I> Task: Program NV master stream id
[0000.157] I> Task: Verify boot mode
[0000.163] I> Task: Alias fuses
[0000.167] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.174] I> Task: Print SKU type
[0000.177] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.182] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.186] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.191] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0000.195] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.199] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.204] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.208] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.212] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.217] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.221] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.225] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.229] I> FUSE_SKU_INFO_0 = 0xd4
[0000.232] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.236] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.240] I> SKU: Prod
[0000.242] I> Task: Boost clocks
[0000.245] I> Initializing PLLC2 for AXI_CBB.
[0000.249] I> AXI_CBB : src = 35, divisor = 0
[0000.254] I> Task: Voltage monitor
[0000.257] I> VMON: Vmon re-calibration and fine tuning done
[0000.262] I> Task: UPHY init
[0000.267] E> UPHY: Failed to calibrate resistor for HSIO PLL 2.
[0000.273] E> UPHY initialization failed for instance 0
[0000.278] C> Task 0x19 failed (err: 0x43431106)
[0000.282] E> Top caller module: UPHY, error module: UPHY, reason: 0x06, aux_info: 0x11
[0000.290] C> Boot Info Table status dump :
0111111100111000111111111
Is it on your custom board? Which release in use? What did you change?
You should tell more about the environment but not just give out a log and ask for help…
HI WayneWWW,
Thank you for reminding me, I apologize for my carelessness.
Environment: The hardware platform we use is custom board + Orin nx 8G, and JETSON LINUX VERSION is 35.4.1.
Case: The Orin nx has been running on a custom board for about three weeks, and yesterday it automatically shut down and couldn’t be turned on again, and printed the above log. Using another Orin nx core board to run on the custom board for about an hour, it also became like this.
I have noticed that an error appeared in the log: “E> UPHY: Failed to calibrate resistor for HSIO PLL 2”, I didn’t find the post about it.
Can you give me some advice? I would appreciate your help.
Do you have NV devkit there to validate whether this module can still work fine or not?
Yes, using NV devkit won’t work either. The printed logs are the same.
Are you able to reflash sdkmanager for it on devkit and see if it can work?
If it cannot get flashed, share me the log.
Hi WayneWWW,
Trying to reflash, it failed. Orin NX log and SDK Manager log are as follows:
[0004.471] I> Boot-mode : BPMP Diagnostic
[0004.475] I> Entry timestamp: 0x00000000
[0004.479] I> last_boot_error: 0x0
[0004.482] I> BR-BCT: preprod_dev_sign: 0
[0004.486] I> rst_source: 0xb, rst_level: 0x1
[0004.490] I> Task: Initialize MB2 params
[0004.494] I> MB2-params @ 0x40060000
[0004.498] I> Task: Crypto init
[0004.501] I> Task: Perform MB1 KAT tests
[0004.505] I> Task: NVRNG health check
[0004.508] I> NVRNG: Health check success
[0004.512] I> Task: Secure debug controls
[0004.516] I> Task: strap war set
[0004.519] I> Task: Program NV master stream id
[0004.523] I> Task: Verify boot mode
[0004.529] I> Task: Alias fuses
[0004.532] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0004.539] I> Task: Print SKU type
[0004.542] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0004.547] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0004.551] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0004.556] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0004.560] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0004.564] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0004.569] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0004.573] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0004.577] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0004.582] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0004.586] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0004.590] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0004.594] I> FUSE_SKU_INFO_0 = 0xd4
[0004.597] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0004.602] I> FUSE_PACKAGE_INFO_0 = 0x2
[0004.605] I> SKU: Prod
[0004.607] I> Task: Boost clocks
[0004.610] I> Initializing PLLC2 for AXI_CBB.
[0004.615] I> AXI_CBB : src = 35, divisor = 0
[0004.619] I> Task: Voltage monitor
[0004.622] I> VMON: Vmon re-calibration and fine tuning done
[0004.628] I> Task: UPHY init
[0004.631] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0004.636] I> Task: Boot device init
[0004.640] I> Boot_device: RCM
[0004.643] I> USB configuration success
[0004.646] I> Task: TSC init
[0004.649] I> Task: Enable WDT 5th expiry
[0004.653] I> Task: I2C register
[0004.656] I> Task: Set I2C bus freq
[0004.659] I> Task: Reset FSI
[0004.662] I> Task: Enable clock-mon
[0004.666] I> FMON: Fmon re-programming done
[0004.670] I> Task: Mapper init
[0004.673] I> Task: MB1 fixed firewalls
[0004.680] W> Firewall readback mismatch
[0004.685] I> Task: Load MB2/Applet/FSKP
[0004.688] I> Loading MB2 Applet
[0004.691] I> Slot: 0
[0004.693] I> Binary[21] block-352321536 (partition size: 0x50000)
[0004.699] I> Binary name: MB2-Applet
[0004.703] I> Size of crypto header is 8192
[0004.707] I> Size of crypto header is 8192
[0004.711] I> BCH of MB2-Applet read from storage
[0004.715] I> BCH address is : 0x4004e000
[0004.719] I> MB2-Applet header integrity check is success
[0004.725] I> Binary magic in BCH component 0 is MB2A
[0004.729] I> component binary type is 21
[0004.733] I> Size of crypto header is 8192
[0004.745] I> MB2-Applet binary is read from storage
[0004.750] I> MB2-Applet binary integrity check is success
[0004.755] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x41b40)
[0004.762] I> Task: Prepare MB2 params
[0004.766] I> BR-BCT Boot Chain Fields
[0004.769] I> u32_non_gpio_select_boot_chain : 0
[0004.774] I> u32_num_boot_chains : 0
[0004.779] I> bf_bl_gpio_select_boot_chain_1b : 0
[0004.783] I> Task: Misc NV security settings
[0004.787] I> NVDEC sticky bits programming done
[0004.792] I> Successfully powergated NVDEC
[0004.796] I> Task: Disable/Reload WDT
[0004.799] I> Task: Program misc carveouts
[0004.803] I> SLCG Global override status := 0x0
[0004.808] I> MB1: MSS reconfig completed
[0004.812] W> Firewall readback mismatch
[0004.815] W> Firewall readback mismatch
[0004.819] W> Firewall readback mismatch
[0004.823] W> Firewall readback mismatch
[0004.826] W> Firewall readback mismatch
[0004.830] W> Firewall readback mismatch
[0004.834] W> Firewall readback mismatch
[0004.837] W> Firewall readback mismatch
[0004.841] W> Firewall readback mismatch
[0004.845] W> Firewall readback mismatch
I> Applet (version: 0.0.0.0-t234-54845784-8d394889)
I> Emulation:
I> Entry timestamp: 0xffffffff
I> Task: Pinmux init (0x4000062d)
I> Task: Boot device init (0x40001321)
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
I> QSPI-0l initialized successfully
E> Error in command_complete 18001 int_status
E> OCR failed, error = 39390706
E> Failed to open sdmmc-3, err = 39390706
W> Ignoring init failure for device 0-3
E> Error in command_complete 18000 int_status
W> Ignoring init failure for device 1-3
E> Unknown device 7
E> Unknown device 8
I> Task: Partition Manager Init (0x40002d61)
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: I2C register (0x400006a5)
I> Task: Register exit handlers (0x400005f5)
I> Task: Enter 3p server (0x40001925)
I> Populate chip info
I> RAM_CODE 0x4000021
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> dump bct
I> Rebooting : reboot-recovery
[0021.744] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0021.749] I> t234-A01-0-Silicon (0x12347) Prod
[0021.753] I> Boot-mode : BPMP Diagnostic
[0021.757] I> Entry timestamp: 0x00000000
[0021.761] I> last_boot_error: 0x0
[0021.764] I> BR-BCT: preprod_dev_sign: 0
[0021.768] I> rst_source: 0xb, rst_level: 0x1
[0021.772] I> Task: Initialize MB2 params
[0021.776] I> MB2-params @ 0x40060000
[0021.780] I> Task: Crypto init
[0021.782] I> Task: Perform MB1 KAT tests
[0021.786] I> Task: NVRNG health check
[0021.790] I> NVRNG: Health check success
[0021.794] I> Task: Secure debug controls
[0021.798] I> Task: strap war set
[0021.801] I> Task: Program NV master stream id
[0021.805] I> Task: Verify boot mode
[0021.811] I> Task: Alias fuses
[0021.814] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0021.822] I> Task: Print SKU type
[0021.825] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0021.830] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0021.834] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0021.839] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0021.843] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0021.847] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0021.852] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0021.856] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0021.860] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0021.865] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0021.869] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0021.873] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0021.877] I> FUSE_SKU_INFO_0 = 0xd4
[0021.880] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0021.884] I> FUSE_PACKAGE_INFO_0 = 0x2
[0021.888] I> SKU: Prod
[0021.890] I> Task: Boost clocks
[0021.893] I> Initializing PLLC2 for AXI_CBB.
[0021.897] I> AXI_CBB : src = 35, divisor = 0
[0021.902] I> Task: Voltage monitor
[0021.905] I> VMON: Vmon re-calibration and fine tuning done
[0021.910] I> Task: UPHY init
[0021.914] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0021.919] I> Task: Boot device init
[0021.922] I> Boot_device: RCM
[0021.925] I> USB configuration success
[0021.929] I> Task: TSC init
[0021.932] I> Task: Enable WDT 5th expiry
[0021.936] I> Task: I2C register
[0021.939] I> Task: Set I2C bus freq
[0021.942] I> Task: Reset FSI
[0021.945] I> Task: Enable clock-mon
[0021.949] I> FMON: Fmon re-programming done
[0021.953] I> Task: Mapper init
[0021.956] I> Task: MB1 fixed firewalls
[0021.962] W> Firewall readback mismatch
[0021.967] I> Task: Load MB2/Applet/FSKP
[0021.971] I> Loading MB2 Applet
[0021.974] I> Slot: 0
[0021.976] I> Binary[21] block-352321536 (partition size: 0x50000)
[0021.982] I> Binary name: MB2-Applet
[0021.985] I> Size of crypto header is 8192
[0021.989] I> Size of crypto header is 8192
[0021.994] I> BCH of MB2-Applet read from storage
[0021.998] I> BCH address is : 0x4004e000
[0022.002] I> MB2-Applet header integrity check is success
[0022.007] I> Binary magic in BCH component 0 is MB2A
[0022.012] I> component binary type is 21
[0022.016] I> Size of crypto header is 8192
[0022.027] I> MB2-Applet binary is read from storage
[0022.033] I> MB2-Applet binary integrity check is success
[0022.038] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x41b40)
[0022.045] I> Task: Prepare MB2 params
[0022.049] I> BR-BCT Boot Chain Fields
[0022.052] I> u32_non_gpio_select_boot_chain : 0
[0022.057] I> u32_num_boot_chains : 0
[0022.061] I> bf_bl_gpio_select_boot_chain_1b : 0
[0022.066] I> Task: Misc NV security settings
[0022.070] I> NVDEC sticky bits programming done
[0022.075] I> Successfully powergated NVDEC
[0022.079] I> Task: Disable/Reload WDT
[0022.082] I> Task: Program misc carveouts
[0022.086] I> SLCG Global override status := 0x0
[0022.091] I> MB1: MSS reconfig completed
[0022.095] W> Firewall readback mismatch
[0022.098] W> Firewall readback mismatch
[0022.102] W> Firewall readback mismatch
[0022.106] W> Firewall readback mismatch
[0022.109] W> Firewall readback mismatch
[0022.113] W> Firewall readback mismatch
[0022.117] W> Firewall readback mismatch
[0022.120] W> Firewall readback mismatch
[0022.124] W> Firewall readback mismatch
[0022.128] W> Firewall readback mismatch
I> Emulation:
E> Unknown device 7
E> Unknown device 8
I> dump bct
[0513.225] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0513.230] I> t234-A01-0-Silicon (0x12347) Prod
[0513.234] I> Boot-mode : BPMP Diagnostic
[0513.238] I> Entry timestamp: 0x00000000
[0513.242] I> last_boot_error: 0x0
[0513.245] I> BR-BCT: preprod_dev_sign: 0
[0513.249] I> rst_source: 0xb, rst_level: 0x1
[0513.253] I> Task: Initialize MB2 params
[0513.257] I> MB2-params @ 0x40060000
[0513.261] I> Task: Crypto init
[0513.264] I> Task: Perform MB1 KAT tests
[0513.268] I> Task: NVRNG health check
[0513.271] I> NVRNG: Health check success
[0513.275] I> Task: Secure debug controls
[0513.279] I> Task: strap war set
[0513.282] I> Task: Program NV master stream id
[0513.286] I> Task: Verify boot mode
[0513.292] I> Task: Alias fuses
[0513.295] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0513.302] I> Task: Print SKU type
[0513.305] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0513.310] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0513.314] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0513.319] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0513.323] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0513.327] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0513.332] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0513.336] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0513.341] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0513.345] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0513.349] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0513.353] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0513.357] I> FUSE_SKU_INFO_0 = 0xd4
[0513.361] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0513.365] I> FUSE_PACKAGE_INFO_0 = 0x2
[0513.368] I> SKU: Prod
[0513.371] I> Task: Boost clocks
[0513.374] I> Initializing PLLC2 for AXI_CBB.
[0513.378] I> AXI_CBB : src = 35, divisor = 0
[0513.382] I> Task: Voltage monitor
[0513.385] I> VMON: Vmon re-calibration and fine tuning done
[0513.391] I> Task: UPHY init
[0513.394] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0513.400] I> Task: Boot device init
[0513.403] I> Boot_device: RCM
[0513.406] I> USB configuration success
[0513.410] I> Task: TSC init
[0513.413] I> Task: Enable WDT 5th expiry
[0513.416] I> Task: I2C register
[0513.419] I> Task: Set I2C bus freq
[0513.423] I> Task: Reset FSI
[0513.425] I> Task: Enable clock-mon
[0513.429] I> FMON: Fmon re-programming done
[0513.434] I> Task: Mapper init
[0513.436] I> Task: MB1 fixed firewalls
[0513.443] W> Firewall readback mismatch
[0513.448] I> Task: Load MB2/Applet/FSKP
[0513.452] I> Loading MB2 Applet
[0513.455] I> Slot: 0
[0513.457] I> Binary[21] block-352321536 (partition size: 0x50000)
[0513.463] I> Binary name: MB2-Applet
[0513.466] I> Size of crypto header is 8192
[0513.470] I> Size of crypto header is 8192
[0513.474] I> BCH of MB2-Applet read from storage
[0513.479] I> BCH address is : 0x4004e000
[0513.483] I> MB2-Applet header integrity check is success
[0513.488] I> Binary magic in BCH component 0 is MB2A
[0513.493] I> component binary type is 21
[0513.496] I> Size of crypto header is 8192
[0513.509] I> MB2-Applet binary is read from storage
[0513.514] I> MB2-Applet binary integrity check is success
[0513.520] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x41b40)
[0513.526] I> Task: Prepare MB2 params
[0513.530] I> BR-BCT Boot Chain Fields
[0513.534] I> u32_non_gpio_select_boot_chain : 0
[0513.538] I> u32_num_boot_chains : 0
[0513.543] I> bf_bl_gpio_select_boot_chain_1b : 0
[0513.548] I> Task: Misc NV security settings
[0513.552] I> NVDEC sticky bits programming done
[0513.556] I> Successfully powergated NVDEC
[0513.560] I> Task: Disable/Reload WDT
[0513.564] I> Task: Program misc carveouts
[0513.568] I> SLCG Global override status := 0x0
[0513.572] I> MB1: MSS reconfig completed
[0513.576] W> Firewall readback mismatch
[0513.580] W> Firewall readback mismatch
[0513.583] W> Firewall readback mismatch
[0513.587] W> Firewall readback mismatch
[0513.591] W> Firewall readback mismatch
[0513.595] W> Firewall readback mismatch
[0513.598] W> Firewall readback mismatch
[0513.602] W> Firewall readback mismatch
[0513.606] W> Firewall readback mismatch
[0513.609] W> Firewall readback mismatch
I> Emulation:
E> Unknown device 7
E> Unknown device 8
I> dump bct
[0033.414] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0033.419] I> t234-A01-0-Silicon (0x12347) Prod
[0033.423] I> Boot-mode : Coldboot
[0033.426] I> Entry timestamp: 0x00000000
[0033.430] I> last_boot_error: 0x0
[0033.433] I> BR-BCT: preprod_dev_sign: 0
[0033.437] I> rst_source: 0xb, rst_level: 0x1
[0033.441] I> Task: SE error check
[0033.444] I> Task: Bootchain select WAR set
[0033.448] I> Task: Enable SLCG
[0033.451] I> Task: CRC check
[0033.454] I> Task: Initialize MB2 params
[0033.458] I> MB2-params @ 0x40060000
[0033.462] I> Task: Crypto init
[0033.465] I> Task: Perform MB1 KAT tests
[0033.469] I> Task: NVRNG health check
[0033.472] I> NVRNG: Health check success
[0033.476] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0033.482] I> Task: Enabling and initialization of Bandwidth limiter
[0033.488] I> No request to configure MBWT settings for any PC!
[0033.494] I> Task: Secure debug controls
[0033.498] I> Task: strap war set
[0033.501] I> Task: Initialize SOC Therm
[0033.504] I> Task: Program NV master stream id
[0033.509] I> Task: Verify boot mode
[0033.514] I> Task: Alias fuses
[0033.518] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0033.525] I> Task: Print SKU type
[0033.528] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0033.534] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0033.538] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0033.542] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0033.547] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0033.551] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0033.555] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0033.560] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0033.564] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0033.568] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0033.573] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0033.577] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0033.581] I> FUSE_SKU_INFO_0 = 0xd4
[0033.584] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0033.588] I> FUSE_PACKAGE_INFO_0 = 0x2
[0033.592] I> SKU: Prod
[0033.594] I> Task: Boost clocks
[0033.597] I> Initializing PLLC2 for AXI_CBB.
[0033.601] I> AXI_CBB : src = 35, divisor = 0
[0033.605] I> Task: Voltage monitor
[0033.609] I> VMON: Vmon re-calibration and fine tuning done
[0033.614] I> Task: UPHY init
[0033.619] E> UPHY: Failed to calibrate resistor for HSIO PLL 2.
[0033.625] E> UPHY initialization failed for instance 0
[0033.630] C> Task 0x19 failed (err: 0x43431106)
[0033.634] E> Top caller module: UPHY, error module: UPHY, reason: 0x06, aux_info: 0x11
[0033.642] C> Boot Info Table status dump :
[0000.065] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0000.070] I> t234-A01-0-Silicon (0x12347) Prod
[0000.075] I> Boot-mode : Coldboot
[0000.078] I> Entry timestamp: 0x00000000
[0000.082] I> last_boot_error: 0x43431106
[0000.085] I> BR-BCT: preprod_dev_sign: 0
[0000.089] I> rst_source: 0x17, rst_level: 0x1
[0000.093] I> Task: SE error check
[0000.096] I> Task: Bootchain select WAR set
[0000.101] I> Task: Enable SLCG
[0000.103] I> Task: CRC check
[0000.106] I> Task: Initialize MB2 params
[0000.111] I> MB2-params @ 0x40060000
[0000.114] I> Task: Crypto init
[0000.117] I> Task: Perform MB1 KAT tests
[0000.121] I> Task: NVRNG health check
[0000.124] I> NVRNG: Health check success
[0000.128] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.134] I> Task: Enabling and initialization of Bandwidth limiter
[0000.140] I> No request to configure MBWT settings for any PC!
[0000.146] I> Task: Secure debug controls
[0000.150] I> Task: strap war set
[0000.153] I> Task: Initialize SOC Therm
[0000.156] I> Task: Program NV master stream id
[0000.161] I> Task: Verify boot mode
[0000.166] I> Task: Alias fuses
[0000.170] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.177] I> Task: Print SKU type
[0000.180] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.186] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0000.190] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0000.194] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0000.199] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.203] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.207] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.212] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.216] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.220] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.224] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.229] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.233] I> FUSE_SKU_INFO_0 = 0xd4
[0000.236] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.240] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.244] I> SKU: Prod
[0000.246] I> Task: Boost clocks
[0000.249] I> Initializing PLLC2 for AXI_CBB.
[0000.253] I> AXI_CBB : src = 35, divisor = 0
[0000.257] I> Task: Voltage monitor
[0000.261] I> VMON: Vmon re-calibration and fine tuning done
[0000.266] I> Task: UPHY init
[0000.271] E> UPHY: Failed to calibrate resistor for HSIO PLL 2.
[0000.276] E> UPHY initialization failed for instance 0
[0000.281] C> Task 0x19 failed (err: 0x43431106)
[0000.286] E> Top caller module: UPHY, error module: UPHY, reason: 0x06, aux_info: 0x11
[0000.293] C> Boot Info Table status dump :
[0000.066] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0000.071] I> t234-A01-0-Silicon (0x12347) Prod
[0000.076] I> Boot-mode : Coldboot
[0000.079] I> Entry timestamp: 0x00000000
[0000.083] I> last_boot_error: 0x43431106
[0000.086] I> BR-BCT: preprod_dev_sign: 0
[0000.090] I> rst_source: 0x3, rst_level: 0x1
[0000.094] I> Task: SE error check
[0000.097] I> Task: Bootchain select WAR set
[0000.104] I> Task: CRC check
[0000.107] I> Task: Initialize MB2 params
[0000.112] I> MB2-params @ 0x40060000
[0000.115] I> Task: Crypto init
[0000.118] I> Task: Perform MB1 KAT tests
[0000.122] I> Task: NVRNG health check
[0000.125] I> NVRNG: Health check success
[0000.129] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.135] I> Task: Enabling and initialization of Bandwidth limiter
[0000.141] I> No request to configure MBWT settings for any PC!
[0000.147] I> Task: Secure debug controls
[0000.151] I> Task: strap war set
[0000.154] I> Task: Initialize SOC Therm
[0000.157] I> Task: Program NV master stream id
[0000.162] I> Task: Verify boot mode
[0000.167] I> Task: Alias fuses
[0000.171] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.178] I> Task: Print SKU type
[0000.181] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.187] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0000.191] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0000.195] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0000.204] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.208] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.213] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.217] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.221] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.225] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.234] I> FUSE_SKU_INFO_0 = 0xd4
[0000.237] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.241] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.245] I> SKU: Prod
[0000.247] I> Task: Boost clocks
[0000.250] I> Initializing PLLC2 for AXI_CBB.
[0000.254] I> AXI_CBB : src = 35, divisor = 0
[0000.258] I> Task: Voltage monitor
[0000.267] I> Task: UPHY init
[0000.277] E> UPHY initialization failed for instance 0
[0000.282] C> Task 0x19 failed (err: 0x43431106)
[0000.287] E> Top caller module: UPHY, error module: UPHY, reason: 0x06, aux_info: 0x11
[0000.294] C> Boot Info Table status dump :
sdkm-2024-02-20-11-31-41.log (712.0 KB)
This looks like hardware defect. Please RMA this module.
Hi WayneWWW,
This seems to be a problem caused by the customized carrier board and should not be able to RMA.
In addition, according to the error message, can you give troubleshooting suggestions? Whether I can skip the HSIO initialization and not use the exception part.
Don’t you say you see the same issue on NV devkit?
I mean below.
Hi WayneWWW,
[0004.5…
Yes, but this was used on the custom carrier before it appeared, and it was normal at first. Can RMA be applied even if the problem is caused by custom carrier board.
And I bought it from a third-party store.
Your concept is not correct. Each reflash is a independent event. Whether it is on custom board before does not matter.
If it is not able to get flashed on NV devkit now, then this module is defective.
Your description indicates this is hardware defect too.
There is no need to dig into this and make this module to just work in some partial situation. For example, use some tricks to make it barely work.
Disabling UPHY means PCIe and USB on your carrier board won’t work anymore. I don’t think such board should be in use anymore.
Hi WayneWWW,
OK,I will try to RMA.
I have two Orin nx core boards, both of which have this problem due to running on this custom board. So how to troubleshoot the problem of customized carrier board is more important.
Just to clarify. I want you to flash the board on devkit but not “boot” from devkit.
Could you confirm you are doing flash but not boot?
Also, could you use the “export logs” button on sdkmanager but not current log? Your current sdkmanager log has more than one flash logs.
Hi WayneWWW,
Yes, I confirm I am doing flash. The following logs are generated by using the Export Log button, The previous log “sdkm-2024-02-20-11-31-41.log” was one of them.
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_Orin_NX_modules_2024-02-20_11-37-34.zip (235.1 KB)
Are you sure the previous uart log matches to the sdkmanager log you just shared?
Could you try to use manual flash instead of sdkmanager? And share us the uart + host side log again?
I am not sure why your flash log has two parts.
First part is using Orin AGX config to flash but later it is using Orin NX/Nano config.
The AGX config part shall not appear.
Hi WayneWWW,
These are the logs I burned using the “sudo./ flash.sh-r jetson-orin-nano-devkit-nvme internal” command.
HOST_flash_02-21 11.40.log (91.4 KB)
TARGET_flash_02-21 11.41.log (11.3 KB)
