New Orin NX devkit flash problem
Stuck here when flashing new Orin NX devkit, R35.5.0 and R35.6.0 are the same:
[  10.8432 ] Sending membct and RCM blob
[  10.8447 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[  10.8457 ] BL: version 1.4.0.1-t234-54845784-08e631ca last_boot_error: 0
[  11.0043 ] Sending bct_mem
[  11.1797 ] Sending blob
[  12.3059 ] completed
[  12.3059 ] Retrieving storage infomation
[  12.3076 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails storage storage_info.bin
Below is the complete log file:
R35.5.0_flash_log.txt (78.8 KB)
R35.6.0_flash_log.txt (71.8 KB)
  1. Customized customer baseboard, no problem with flash Xavier NX/Nano.
  2. PC “lsusb” command:
    Bus 001 Device 086: ID 0955:7323 NVidia Corp.
  3. flash command:
sudo ./flash.sh  jetson-orin-nano-devkit internal
sudo ./flash.sh   jetson-orin-nano-devkit mmcblk0p1
I checked a lot of similar articles but didn’t get any help. due to time constraints, we urgently need your help.
flash command is wrong. Please refer to:
https://docs.nvidia.com/jetson/archives/r35.6.0/DeveloperGuide/IN/QuickStart.html
And please also capture the uart log during flash failure.
I referred here. Since there is no program in Orin NX, the initrd flash cannot be used.
The uart log:
0023.940] I> MB1 (version: 1.4.0.1-t234-54845784-08e631ca)
[0023.945] I> t234-A01-1-Silicon (0x12347) Prod
[0023.950] I> Boot-mode : BPMP Diagnostic
[0023.953] I> Entry timestamp: 0x00000000
[0023.957] I> last_boot_error: 0x0
[0023.960] I> BR-BCT: preprod_dev_sign: 0
[0023.964] I> rst_source: 0x0, rst_level: 0x0
[0023.968] I> Task: Initialize MB2 params
[0023.973] I> MB2-params @ 0x40060000
[0023.976] I> Task: Crypto init
[0023.979] I> Task: Perform MB1 KAT tests
[0023.983] I> Task: NVRNG health check
[0023.986] I> NVRNG: Health check success
[0023.990] I> Task: Secure debug controls
[0023.994] I> Task: strap war set
[0023.997] I> Task: Program NV master stream id
[0024.001] I> Task: Verify boot mode
[0024.007] I> Task: Alias fuses
[0024.010] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0024.017] I> Task: Print SKU type
[0024.020] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0024.026] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0024.030] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0024.034] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0024.039] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0024.043] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0024.047] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0024.052] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0024.056] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0024.060] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0024.065] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0024.069] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0024.073] I> FUSE_SKU_INFO_0 = 0xd3
[0024.076] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0024.080] I> FUSE_PACKAGE_INFO_0 = 0x2
[0024.084] I> SKU: Prod
[0024.086] I> Task: Boost clocks
[0024.089] I> Initializing PLLC2 for AXI_CBB.
[0024.093] I> AXI_CBB : src = 35, divisor = 0
[0024.097] I> Task: Voltage monitor
[0024.101] I> VMON: Vmon re-calibration and fine tuning done
[0024.106] I> Task: UPHY init
[0024.109] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0024.115] I> Task: Boot device init
[0024.118] I> Boot_device: RCM
[0024.121] I> USB configuration success
[0024.125] I> Task: TSC init
[0024.128] I> Task: Enable WDT 5th expiry
[0024.131] I> Task: I2C register
[0024.134] I> Task: Set I2C bus freq
[0024.138] I> Task: Reset FSI
[0024.140] I> Task: Enable clock-mon
[0024.144] I> FMON: Fmon re-programming done
[0024.148] I> Task: Mapper init
[0024.151] I> Task: MB1 fixed firewalls
[0024.158] W> Firewall readback mismatch
[0024.163] I> Task: Load MB2/Applet/FSKP
[0024.166] I> Loading MB2 Applet
[0024.169] I> Slot: 0
[0024.171] I> Binary[21] block-352321536 (partition size: 0x50000)
[0024.177] I> Binary name: MB2-Applet
[0024.181] I> Size of crypto header is 8192
[0024.185] I> Size of crypto header is 8192
[0024.305] I> BCH of MB2-Applet read from storage
[0024.309] I> BCH address is : 0x4004e000
[0024.313] I> MB2-Applet header integrity check is success
[0024.319] I> Binary magic in BCH component 0 is MB2A
[0024.323] I> component binary type is 21
[0024.327] I> Size of crypto header is 8192
[0024.338] I> MB2-Applet binary is read from storage
[0024.344] I> MB2-Applet binary integrity check is success
[0024.349] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x41b40)
[0024.356] I> Task: Prepare MB2 params
[0024.360] I> Task: Misc NV security settings
[0024.364] I> NVDEC sticky bits programming done
[0024.368] I> Successfully powergated NVDEC
[0024.372] I> Task: Disable/Reload WDT
[0024.376] I> Task: Program misc carveouts
[0024.380] I> Task: Disable SCPM/POD reset
[0024.384] I> SLCG Global override status := 0x0
[0024.388] I> MB1: MSS reconfig completed
[0024.392] W> Firewall readback mismatch
[0024.395] W> Firewall readback mismatch
[0024.399] W> Firewall readback mismatch
[0024.403] W> Firewall readback mismatch
[0024.407] W> Firewall readback mismatch
[0024.410] W> Firewall readback mismatch
[0024.414] W> Firewall readback mismatch
[0024.418] W> Firewall readback mismatch
[0024.421] W> Firewall readback mismatch
[0024.425] W> Firewall readback mismatch
I> Applet (version: 0.0.0.0-t234-54845784-d30edb11)
I> Emulation:
I> Entry timestamp: 0xffffffff
I> Task: Pinmux init (0x4000062d)
I> Task: Boot device init (0x40001321)
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
I> QSPI-0l initialized successfully
E> Error in command_complete 18000 int_status
E> OCR failed, error = 39390706
E> Failed to open sdmmc-3, err = 39390706
W> Ignoring init failure for device 0-3
W> Ignoring init failure for device 1-3
E> Unknown device 7
E> Unknown device 8
I> Task: Partition Manager Init (0x40002d61)
W> Cannot find any partition table for 00030000
 > PARTITION_MANAGER: Failed to publish partition.
I> Task: I2C register (0x400006a5)
I> Task: Register exit handlers (0x400005f5)
I> Task: Enter 3p server (0x40001925)
I> Populate chip info
I> RAM_CODE 0x4000001
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> dump bct
I> Rebooting : reboot-recovery
�0025.310] I> MB1 (version: 1.4.0.1-t234-54845784-08e631ca)
[0025.316] I> t234-A01-1-Silicon (0x12347) Prod
[0025.320] I> Boot-mode : Coldboot
[0025.323] I> Entry timestamp: 0x00000000
[0025.327] I> last_boot_error: 0x0
[0025.330] I> BR-BCT: preprod_dev_sign: 0
[0025.334] I> rst_source: 0xb, rst_level: 0x1
[0025.338] I> Task: SE error check
[0025.341] I> Task: Bootchain select WAR set
[0025.345] I> Task: Enable SLCG
[0025.348] I> Task: CRC check
[0025.351] I> Task: Initialize MB2 params
[0025.355] I> MB2-params @ 0x40060000
[0025.358] I> Task: Crypto init
[0025.361] I> Task: Perform MB1 KAT tests
[0025.365] I> Task: NVRNG health check
[0025.369] I> NVRNG: Health check success
[0025.372] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0025.378] I> Task: Enabling and initialization of Bandwidth limiter
[0025.385] I> No request to configure MBWT settings for any PC!
[0025.390] I> Task: Secure debug controls
[0025.394] I> Task: strap war set
[0025.397] I> Task: Initialize SOC Therm
[0025.401] I> Task: Program NV master stream id
[0025.405] I> Task: Verify boot mode
[0025.411] I> Task: Alias fuses
[0025.414] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0025.421] I> Task: Print SKU type
[0025.424] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0025.430] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0025.434] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0025.438] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0025.442] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0025.447] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0025.451] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0025.456] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0025.460] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0025.464] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0025.468] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0025.473] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0025.477] I> FUSE_SKU_INFO_0 = 0xd3
[0025.480] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0025.484] I> FUSE_PACKAGE_INFO_0 = 0x2
[0025.488] I> SKU: Prod
[0025.490] I> Task: Boost clocks
[0025.493] I> Initializing PLLC2 for AXI_CBB.
[0025.497] I> AXI_CBB : src = 35, divisor = 0
[0025.501] I> Task: Voltage monitor
[0025.505] I> VMON: Vmon re-calibration and fine tuning done
[0025.510] I> Task: UPHY init
[0025.515] I> HSIO UPHY init done
[0025.518] W> Skipping GBE UPHY config
[0025.521] I> Task: Boot device init
[0025.525] I> Boot_device: RCM
[0025.528] I> USB configuration success
[0026.612] I> Task: TSC init
[0026.615] I> Task: Load membct
[0026.618] I> RAM_CODE 0x4000001
[0026.621] I> Loading MEMBCT
[0026.624] I> Slot: 0
[0026.626] I> Binary[0] block-0 (partition size: 0x40000)
[0026.631] I> Binary name: MEM-BCT-0
[0026.634] I> Size of crypto header is 8192
[0026.638] I> Size of crypto header is 8192
[0026.793] I> BCH of MEM-BCT-0 read from storage
[0026.797] I> BCH address is : 0x40050000
[0026.801] I> MEM-BCT-0 header integrity check is success
[0026.806] I> Binary magic in BCH component 0 is MEM0
[0026.811] I> component binary type is 0
[0026.816] I> MEM-BCT-0 binary is read from storage
[0026.821] I> MEM-BCT-0 binary integrity check is success
[0026.826] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0026.833] I> RAM_CODE 0x4000001
[0026.838] I> RAM_CODE 0x4000001
[0026.842] I> Task: Load Page retirement list
[0026.846] I> Task: SDRAM params override
[0026.850] I> Task: Save mem-bct info
[0026.853] I> Task: Carveout allocate
[0026.857] I> Update CCPLEX IST carveout from MB1-BCT
[0026.862] I> ECC region[0]: Start:0x0, End:0x0
[0026.866] I> ECC region[1]: Start:0x0, End:0x0
[0026.870] I> ECC region[2]: Start:0x0, End:0x0
[0026.874] I> ECC region[3]: Start:0x0, End:0x0
[0026.879] I> ECC region[4]: Start:0x0, End:0x0
[0026.883] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0026.889] I> Non-ECC region[1]: Start:0x0, End:0x0
[0026.894] I> Non-ECC region[2]: Start:0x0, End:0x0
[0026.898] I> Non-ECC region[3]: Start:0x0, End:0x0
[0026.903] I> Non-ECC region[4]: Start:0x0, End:0x0
[0026.914] I> allocated(CO:43) base:0x47c000000 size:0x4000000 align: 0x200000
[0026.921] I> allocated(CO:39) base:0x479e00000 size:0x2200000 align: 0x10000
[0026.928] I> allocated(CO:20) base:0x476000000 size:0x2000000 align: 0x2000000
[0026.935] I> allocated(CO:24) base:0x474000000 size:0x2000000 align: 0x2000000
[0026.942] I> allocated(CO:28) base:0x472000000 size:0x2000000 align: 0x2000000
[0026.949] I> allocated(CO:22) base:0x478000000 size:0x1000000 align: 0x1000000
[0026.956] I> allocated(CO:35) base:0x479000000 size:0xe00000 align: 0x10000
[0026.963] I> allocated(CO:02) base:0x471800000 size:0x800000 align: 0x800000
[0026.970] I> allocated(CO:03) base:0x471000000 size:0x800000 align: 0x800000
[0026.977] I> allocated(CO:06) base:0x470800000 size:0x800000 align: 0x800000
[0026.984] I> allocated(CO:56) base:0x470000000 size:0x800000 align: 0x200000
[0026.991] I> allocated(CO:07) base:0x46fc00000 size:0x400000 align: 0x400000
[0026.998] I> allocated(CO:33) base:0x46f800000 size:0x400000 align: 0x200000
[0027.005] I> allocated(CO:23) base:0x46f600000 size:0x200000 align: 0x200000
[0027.012] I> allocated(CO:01) base:0x46f500000 size:0x100000 align: 0x100000
[0027.018] I> allocated(CO:05) base:0x46f400000 size:0x100000 align: 0x100000
[0027.025] I> allocated(CO:08) base:0x46f300000 size:0x100000 align: 0x100000
[0027.032] I> allocated(CO:09) base:0x46f200000 size:0x100000 align: 0x100000
[0027.039] I> allocated(CO:15) base:0x46f100000 size:0x100000 align: 0x100000
[0027.046] I> allocated(CO:17) base:0x46f000000 size:0x100000 align: 0x100000
[0027.053] I> allocated(CO:27) base:0x46ef00000 size:0x100000 align: 0x100000
[0027.060] I> allocated(CO:42) base:0x46ee00000 size:0x100000 align: 0x100000
[0027.067] I> allocated(CO:54) base:0x46ed80000 size:0x80000 align: 0x80000
[0027.074] I> allocated(CO:34) base:0x46ed70000 size:0x10000 align: 0x10000
[0027.081] I> allocated(CO:72) base:0x46eb70000 size:0x200000 align: 0x10000
[0027.087] I> allocated(CO:46) base:0x440000000 size:0x20000000 align: 0x20000000
[0027.095] I> allocated(CO:47) base:0x46e600000 size:0x400000 align: 0x200000
[0027.102] I> allocated(CO:48) base:0x46eb50000 size:0x20000 align: 0x10000
[0027.108] I> allocated(CO:69) base:0x46eb30000 size:0x20000 align: 0x10000
[0027.115] I> allocated(CO:49) base:0x46eb20000 size:0x10000 align: 0x10000
[0027.122] I> allocated(CO:50) base:0x46eb10000 size:0x10000 align: 0x10000
[0027.129] I> NSDRAM base: 0x80000000, end: 0x46eb70000, size: 0x3eeb70000
[0027.135] I> Task: Thermal check
[0027.139] I> max_chip_limit = 105
[0027.142] I> min_chip_limit = -28
[0027.145] I> max temp read = 44
[0027.148] I> min temp read = 38
[0027.151] I> Task: Update FSI SCR with thermal fuse data
[0027.156] I> Task: Enable WDT 5th expiry
[0027.160] I> Task: I2C register
[0027.163] I> Task: Set I2C bus freq
[0027.166] I> Task: Reset FSI
[0027.169] I> Task: Pinmux init
[0027.172] I> skipped mmio_addr = 0x9240008
[0027.176] I> skipped mmio_addr = 0x9240000
[0027.180] I> skipped mmio_addr = 0x9240010
[0027.184] I> skipped mmio_addr = 0x9240018
[0027.188] I> skipped mmio_addr = 0x9240020
[0027.192] I> skipped mmio_addr = 0x9240030
[0027.196] I> skipped mmio_addr = 0x9240028
[0027.200] I> skipped mmio_addr = 0x9240038
[0027.204] I> skipped mmio_addr = 0x9240040
[0027.207] I> skipped mmio_addr = 0x9240048
[0027.211] I> skipped mmio_addr = 0x9241000
[0027.215] I> skipped mmio_addr = 0x9241008
[0027.219] I> skipped mmio_addr = 0x9241010
[0027.223] I> skipped mmio_addr = 0x9241018
[0027.227] I> skipped mmio_addr = 0x9241020
[0027.231] I> skipped mmio_addr = 0x9241028
[0027.235] I> skipped mmio_addr = 0x9241030
[0027.239] I> skipped mmio_addr = 0x9241038
[0027.243] I> skipped mmio_addr = 0x9241040
[0027.247] I> skipped mmio_addr = 0x9242000
[0027.251] I> skipped mmio_addr = 0x9242008
[0027.255] I> Task: Prod config init
[0027.258] I> Task: Pad voltage init
[0027.261] I> Task: Prod init
[0027.264] I> Task: Program rst req config reg
[0027.268] I> Task: Common rail init
[0027.272] I> DONE: Thermal config
[0027.276] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0027.284] I> DONE: SOC rail config
[0027.288] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0027.295] I> DONE: MEMIO rail config
[0027.299] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0027.305] I> DONE: GPU rail info
[0027.308] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0027.314] I> DONE: CV rail info
[0027.317] I> Task: Mem clock src
[0027.320] I> Task: Misc. board config
[0027.324] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0027.330] I> Task: SDRAM init
[0027.333] I> MemoryType: 4 MemBctRevision: 1
[0027.340] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0027.347] I> MSS CAR: Init PLLM
[0027.350] I> MSS CAR: Init PLLHUB
[0027.355] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0027.366] I> SDRAM initialized!
[0027.369] I> SDRAM Size in Total 0x400000000
[0027.373] I> Task: Dram Ecc scrub
[0027.377] I> Task: DRAM alias check
[0027.386] I> Task: Program NSDRAM carveout
[0027.390] I> NSDRAM carveout encryption is enabled
[0027.395] I> Program NSDRAM carveout
[0027.398] I> Task: Register checker
[0027.402] I> Task: Enable clock-mon
[0027.406] I> FMON: Fmon re-programming done
[0027.410] I> Task: Mapper init
[0027.413] I> Task: SC7 Context Init
[0027.417] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0027.422] I> Task: CCPLEX IST init
[0027.426] I> Task: CPU WP0
[0027.428] I> Loading MCE
[0027.431] I> Slot: 0
[0027.433] I> Binary[8] block-134217728 (partition size: 0x80000)
[0027.439] I> Binary name: MCE
[0027.441] I> Size of crypto header is 8192
[0027.445] I> Size of crypto header is 8192
[0027.963] I> BCH of MCE read from storage
[0027.967] I> BCH address is : 0x4003e000
[0027.971] I> MCE header integrity check is success
[0027.975] I> Binary magic in BCH component 0 is MTSM
[0027.980] I> component binary type is 8
[0027.984] I> Size of crypto header is 8192
[0027.991] I> MCE binary is read from storage
[0027.996] I> MCE binary integrity check is success
[0028.001] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0028.007] I> Size of crypto header is 8192
[0028.011] I> Sending WP0 mailbox command to PSC
[0028.020] I> Task: XUSB Powergate
[0028.023] I> Skipping powergate XUSB.
[0028.026] I> Task: MB1 fixed firewalls
[0028.033] W> Firewall readback mismatch
[0028.038] I> Task: Load bpmp-fw
[0028.041] I> Slot: 0
[0028.043] I> Binary[15] block-251658240 (partition size: 0x180000)
[0028.049] I> Binary name: BPMP_FW
[0028.052] I> Size of crypto header is 8192
[0028.056] I> Size of crypto header is 8192
[0028.060] I> BCH of BPMP_FW read from storage
[0028.064] I> BCH address is : 0x807fe000
[0028.068] I> BPMP_FW header integrity check is success
[0028.073] I> Binary magic in BCH component 0 is BPMF
[0028.078] I> component binary type is 15
[0028.082] I> Size of crypto header is 8192
[0028.103] I> BPMP_FW binary is read from storage
[0028.109] I> BPMP_FW binary integrity check is success
[0028.114] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0028.120] I> Slot: 0
[0028.123] I> Binary[16] block-268435456 (partition size: 0x400000)
[0028.129] I> Binary name: BPMP_FW_DTB
[0028.132] I> Size of crypto header is 8192
[0028.136] I> Size of crypto header is 8192
[0028.140] I> BCH of BPMP_FW_DTB read from storage
[0028.145] I> BCH address is : 0x807fc000
[0028.148] I> BPMP_FW_DTB header integrity check is success
[0028.154] I> Binary magic in BCH component 0 is BPMD
[0028.159] I> component binary type is 16
[0028.162] I> Size of crypto header is 8192
[0028.171] I> BPMP_FW_DTB binary is read from storage
[0028.176] I> BPMP_FW_DTB binary integrity check is success
[0028.181] I> Binary BPMP_FW_DTB loaded successfully at 0x807bed30 (0x3d2c0)
[0028.188] I> Task: BPMP fw ast config
[0028.192] I> Task: Load psc-fw
[0028.195] I> Slot: 0
[0028.197] I> Binary[17] block-285212672 (partition size: 0xc0000)
[0028.203] I> Binary name: PSC_FW
[0028.206] I> Size of crypto header is 8192
[0028.210] I> Size of crypto header is 8192
[0028.214] I> BCH of PSC_FW read from storage
[0028.218] I> BCH address is : 0x80ffe000
[0028.222] I> PSC_FW header integrity check is success
[0028.226] I> Binary magic in BCH component 0 is PFWP
[0028.231] I> component binary type is 17
[0028.235] I> Size of crypto header is 8192
[0028.245] I> PSC_FW binary is read from storage
[0028.250] I> PSC_FW binary integrity check is success
[0028.255] I> Binary PSC_FW loaded successfully at 0x80fa4680 (0x59980)
[0028.262] I> Task: Load nvdec-fw
[0028.265] I> Slot: 0
[0028.267] I> Binary[7] block-117440512 (partition size: 0x100000)
[0028.273] I> Binary name: NVDEC
[0028.276] I> Size of crypto header is 8192
[0028.280] I> Size of crypto header is 8192
[0028.284] I> BCH of NVDEC read from storage
[0028.288] I> BCH address is : 0x800fe000
[0028.291] I> NVDEC header integrity check is success
[0028.296] I> Binary magic in BCH component 0 is NDEC
[0028.301] I> component binary type is 7
[0028.305] I> Size of crypto header is 8192
[0028.314] I> NVDEC binary is read from storage
[0028.318] I> NVDEC binary integrity check is success
[0028.323] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0028.332] I> Task: Load tsec-fw
[0028.335] I> TSEC-FW load support not enabled
[0028.339] I> Task: GPIO interrupt map
[0028.343] I> Task: SC7 context save
[0028.347] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0028.352] I> Task: Load MB2/Applet/FSKP
[0028.356] I> Loading MB2
[0028.358] I> Slot: 0
[0028.360] I> Binary[6] block-100663296 (partition size: 0x80000)
[0028.366] I> Binary name: MB2
[0028.369] I> Size of crypto header is 8192
[0028.373] I> Size of crypto header is 8192
[0028.377] I> BCH of MB2 read from storage
[0028.381] I> BCH address is : 0x8007e000
[0028.385] I> MB2 header integrity check is success
[0028.389] I> Binary magic in BCH component 0 is MB2B
[0028.394] I> component binary type is 6
[0028.398] I> Size of crypto header is 8192
[0028.409] I> MB2 binary is read from storage
[0028.414] I> MB2 binary integrity check is success
[0028.419] I> Binary MB2 loaded successfully at 0x80000000 (0x68b10)
[0028.425] I> Task: Map CCPLEX SHARED carveout
[0028.429] I> Task: Prepare MB2 params
[0028.433] I> Task: Dram ecc test
[0028.436] I> Task: Misc NV security settings
[0028.440] I> NVDEC sticky bits programming done
[0028.444] I> Successfully powergated NVDEC
[0028.448] I> Task: Disable/Reload WDT
[0028.452] I> Task: Program misc carveouts
[0028.456] I> Program IPC carveouts
[0028.459] I> Task: Disable SCPM/POD reset
[0028.463] I> SLCG Global override status := 0x0
[0028.468] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-934581f8)
I> Boot-mode : RCM Flash
I> Emulation:
I> Entry timestamp: 0x01b2d384
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x470000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002050)
I> Task: Check MC errors (0x5000204c)
I> Task: PSC mailbox init (0x50018864)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001ff8)
I> Task: Program CBB PCIE AMAP regions (0x5001bcf8)
I> Task: Boot device init (0x50001f40)
I> Qspi clock source : pllc_out0
E> Sending CMD_SD_SEND_IF_COND failed
E> Error opening sdcard-0
E> Failed to initialize device 6-0
C> Storage init failed
C> Task 0x0 failed (err: 0x39390706)
E> Top caller module: SDMMC, error module: SDMMC, reason: 0x06, aux_info: 0x07
I> Busy Spin
我直接用中文問好了… 請問你到底在講什麼?
燒錄的時候本來就不用管板子上之前有沒有燒東西.
我的意思只能用这两个命令进行烧录:
sudo ./flash.sh -r jetson-orin-nano-devkit internal
sudo ./flash.sh -r jetson-orin-nano-devkit mmcblk0p1
请帮忙分析下串口log,谢谢了
能請你先解釋一下為什麼只能用這兩個command燒錄嗎? 你現在的問題就是這兩個command來的啊
Orin NX/Nano沒有emmc. 本來就是得用initrd flash燒錄…
哦,好的
下午,我也用initrd flash命令烧录过,一直卡在Waiting boot up:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p "-c ./bootloader/t186ref/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs usb0 jetson-orin-nano-devkit nvme0n1p1
如果加上–network,立马就返回错误:
/mnt/ubuntu20/code/nvidia/Orin_nx/R35.5.0/SOMB-JETSON-V1.1-ORIN-NX-R35.5.0-General/out/SOMB-JETSON-V1.1-ORIN-NX-R35.5.0-NVIDIA-20241014_111420/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device nvme0n1p1 -p -c ./bootloader/t186ref/cfg/flash_t234_qspi.xml -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit nvme0n1p1
exportfs: /mnt/ubuntu20/code/nvidia/Orin_nx/R35.5.0/SOMB-JETSON-V1.1-ORIN-NX-R35.5.0-General/out/SOMB-JETSON-V1.1-ORIN-NX-R35.5.0-NVIDIA-20241014_111420/rootfs does not support NFS export
Cleaning up...
我再实验下这种init flash方式,并且查看uart log
一直卡在這的時候就得看UART log了.
串口上面打印这些信息:
�0111.047] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0111.052] I> t234-A01-1-Silicon (0x12347) Prod
[0111.057] I> Boot-mode : Coldboot
[0111.060] I> Entry timestamp: 0x00000000
[0111.064] I> last_boot_error: 0x0
[0111.067] I> BR-BCT: preprod_dev_sign: 0
[0111.071] I> rst_source: 0xb, rst_level: 0x1
[0111.075] I> Task: SE error check
[0111.078] I> Task: Bootchain select WAR set
[0111.082] I> Task: Enable SLCG
[0111.085] I> Task: CRC check
[0111.088] I> Task: Initialize MB2 params
[0111.092] I> MB2-params @ 0x40060000
[0111.095] I> Task: Crypto init
[0111.098] I> Task: Perform MB1 KAT tests
[0111.102] I> Task: NVRNG health check
[0111.106] I> NVRNG: Health check success
[0111.110] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0111.116] I> Task: Enabling and initialization of Bandwidth limiter
[0111.122] I> No request to configure MBWT settings for any PC!
[0111.127] I> Task: Secure debug controls
[0111.131] I> Task: strap war set
[0111.134] I> Task: Initialize SOC Therm
[0111.138] I> Task: Program NV master stream id
[0111.142] I> Task: Verify boot mode
[0111.148] I> Task: Alias fuses
[0111.151] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0111.158] I> Task: Print SKU type
[0111.162] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0111.167] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0111.171] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0111.175] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0111.180] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0111.184] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0111.188] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0111.193] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0111.197] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0111.201] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0111.206] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0111.210] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0111.214] I> FUSE_SKU_INFO_0 = 0xd3
[0111.217] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0111.221] I> FUSE_PACKAGE_INFO_0 = 0x2
[0111.225] I> SKU: Prod
[0111.227] I> Task: Boost clocks
[0111.230] I> Initializing PLLC2 for AXI_CBB.
[0111.234] I> AXI_CBB : src = 35, divisor = 0
[0111.238] I> Task: Voltage monitor
[0111.242] I> VMON: Vmon re-calibration and fine tuning done
[0111.247] I> Task: UPHY init
[0111.252] I> HSIO UPHY init done
[0111.255] W> Skipping GBE UPHY config
[0111.259] I> Task: Boot device init
[0111.262] I> Boot_device: RCM
[0111.265] I> USB configuration success
[0111.321] I> Task: TSC init
[0111.324] I> Task: Load membct
[0111.327] I> RAM_CODE 0x4000001
[0111.330] I> Loading MEMBCT
[0111.333] I> Slot: 0
[0111.335] I> Binary[0] block-0 (partition size: 0x40000)
[0111.340] I> Binary name: MEM-BCT-0
[0111.343] I> Size of crypto header is 8192
[0111.347] I> Size of crypto header is 8192
[0111.351] I> BCH of MEM-BCT-0 read from storage
[0111.356] I> BCH address is : 0x40050000
[0111.360] I> MEM-BCT-0 header integrity check is success
[0111.365] I> Binary magic in BCH component 0 is MEM0
[0111.370] I> component binary type is 0
[0111.375] I> MEM-BCT-0 binary is read from storage
[0111.380] I> MEM-BCT-0 binary integrity check is success
[0111.385] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0111.392] I> RAM_CODE 0x4000001
[0111.397] I> RAM_CODE 0x4000001
[0111.401] I> Task: Load Page retirement list
[0111.405] I> Task: SDRAM params override
[0111.409] I> Task: Save mem-bct info
[0111.412] I> Task: Carveout allocate
[0111.415] I> Update CCPLEX IST carveout from MB1-BCT
[0111.420] I> ECC region[0]: Start:0x0, End:0x0
[0111.425] I> ECC region[1]: Start:0x0, End:0x0
[0111.429] I> ECC region[2]: Start:0x0, End:0x0
[0111.433] I> ECC region[3]: Start:0x0, End:0x0
[0111.437] I> ECC region[4]: Start:0x0, End:0x0
[0111.442] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0111.448] I> Non-ECC region[1]: Start:0x0, End:0x0
[0111.452] I> Non-ECC region[2]: Start:0x0, End:0x0
[0111.457] I> Non-ECC region[3]: Start:0x0, End:0x0
[0111.462] I> Non-ECC region[4]: Start:0x0, End:0x0
[0111.472] I> allocated(CO:43) base:0x47c000000 size:0x4000000 align: 0x200000
[0111.479] I> allocated(CO:39) base:0x479e00000 size:0x2200000 align: 0x10000
[0111.486] I> allocated(CO:20) base:0x476000000 size:0x2000000 align: 0x2000000
[0111.493] I> allocated(CO:24) base:0x474000000 size:0x2000000 align: 0x2000000
[0111.500] I> allocated(CO:28) base:0x472000000 size:0x2000000 align: 0x2000000
[0111.508] I> allocated(CO:22) base:0x478000000 size:0x1000000 align: 0x1000000
[0111.515] I> allocated(CO:35) base:0x479000000 size:0xe00000 align: 0x10000
[0111.522] I> allocated(CO:02) base:0x471800000 size:0x800000 align: 0x800000
[0111.529] I> allocated(CO:03) base:0x471000000 size:0x800000 align: 0x800000
[0111.535] I> allocated(CO:06) base:0x470800000 size:0x800000 align: 0x800000
[0111.542] I> allocated(CO:56) base:0x470000000 size:0x800000 align: 0x200000
[0111.549] I> allocated(CO:07) base:0x46fc00000 size:0x400000 align: 0x400000
[0111.556] I> allocated(CO:33) base:0x46f800000 size:0x400000 align: 0x200000
[0111.563] I> allocated(CO:23) base:0x46f600000 size:0x200000 align: 0x200000
[0111.570] I> allocated(CO:01) base:0x46f500000 size:0x100000 align: 0x100000
[0111.577] I> allocated(CO:05) base:0x46f400000 size:0x100000 align: 0x100000
[0111.584] I> allocated(CO:08) base:0x46f300000 size:0x100000 align: 0x100000
[0111.591] I> allocated(CO:09) base:0x46f200000 size:0x100000 align: 0x100000
[0111.598] I> allocated(CO:15) base:0x46f100000 size:0x100000 align: 0x100000
[0111.605] I> allocated(CO:17) base:0x46f000000 size:0x100000 align: 0x100000
[0111.612] I> allocated(CO:27) base:0x46ef00000 size:0x100000 align: 0x100000
[0111.619] I> allocated(CO:42) base:0x46ee00000 size:0x100000 align: 0x100000
[0111.626] I> allocated(CO:54) base:0x46ed80000 size:0x80000 align: 0x80000
[0111.633] I> allocated(CO:34) base:0x46ed70000 size:0x10000 align: 0x10000
[0111.639] I> allocated(CO:72) base:0x46eb70000 size:0x200000 align: 0x10000
[0111.646] I> allocated(CO:46) base:0x440000000 size:0x20000000 align: 0x20000000
[0111.654] I> allocated(CO:47) base:0x46e600000 size:0x400000 align: 0x200000
[0111.660] I> allocated(CO:48) base:0x46eb50000 size:0x20000 align: 0x10000
[0111.667] I> allocated(CO:69) base:0x46eb30000 size:0x20000 align: 0x10000
[0111.674] I> allocated(CO:49) base:0x46eb20000 size:0x10000 align: 0x10000
[0111.681] I> allocated(CO:50) base:0x46eb10000 size:0x10000 align: 0x10000
[0111.688] I> NSDRAM base: 0x80000000, end: 0x46eb70000, size: 0x3eeb70000
[0111.694] I> Task: Thermal check
[0111.697] I> Using min_chip_limit as min_tmon_limit
[0111.702] I> Using max_chip_limit as max_tmon_limit
[0111.707] I> BCT max_tmon_limit = 105
[0111.710] I> BCT min_tmon_limit = -28
[0111.714] I> BCT max_tmon_limit = 105
[0111.717] I> BCT min_tmon_limit = -28
[0111.721] I> SKU specific max_chip_limit = 105
[0111.725] I> SKU specific min_chip_limit = -28
[0111.729] I> BCT max_chip_limit = 105
[0111.733] I> BCT min_chip_limit = -28
[0111.736] I> enable_soctherm_polling = 0
[0111.740] I> max temp read = 45
[0111.743] I> min temp read = 39
[0111.746] I> Enabling thermtrip
[0111.749] I> Task: Update FSI SCR with thermal fuse data
[0111.754] I> Task: Enable WDT 5th expiry
[0111.758] I> Task: I2C register
[0111.761] I> Task: Set I2C bus freq
[0111.764] I> Task: Reset FSI
[0111.767] I> Task: Pinmux init
[0111.770] I> skipped mmio_addr = 0x9240008
[0111.774] I> skipped mmio_addr = 0x9240000
[0111.778] I> skipped mmio_addr = 0x9240010
[0111.782] I> skipped mmio_addr = 0x9240018
[0111.786] I> skipped mmio_addr = 0x9240020
[0111.790] I> skipped mmio_addr = 0x9240030
[0111.794] I> skipped mmio_addr = 0x9240028
[0111.798] I> skipped mmio_addr = 0x9240038
[0111.802] I> skipped mmio_addr = 0x9240040
[0111.806] I> skipped mmio_addr = 0x9240048
[0111.810] I> skipped mmio_addr = 0x9241000
[0111.814] I> skipped mmio_addr = 0x9241008
[0111.818] I> skipped mmio_addr = 0x9241010
[0111.821] I> skipped mmio_addr = 0x9241018
[0111.825] I> skipped mmio_addr = 0x9241020
[0111.829] I> skipped mmio_addr = 0x9241028
[0111.833] I> skipped mmio_addr = 0x9241030
[0111.837] I> skipped mmio_addr = 0x9241038
[0111.841] I> skipped mmio_addr = 0x9241040
[0111.845] I> skipped mmio_addr = 0x9242000
[0111.849] I> skipped mmio_addr = 0x9242008
[0111.853] I> Task: Prod config init
[0111.856] I> Task: Pad voltage init
[0111.860] I> Task: Prod init
[0111.863] I> Task: Program rst req config reg
[0111.867] I> Task: Common rail init
[0111.870] I> DONE: Thermal config
[0111.874] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0111.883] I> DONE: SOC rail config
[0111.886] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0111.893] I> DONE: MEMIO rail config
[0111.897] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0111.903] I> DONE: GPU rail info
[0111.907] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0111.913] I> DONE: CV rail info
[0111.916] I> Task: Mem clock src
[0111.919] I> Task: Misc. board config
[0111.923] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0111.929] I> Task: SDRAM init
[0111.932] I> MemoryType: 4 MemBctRevision: 1
[0111.938] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0111.946] I> MSS CAR: Init PLLM
[0111.949] I> MSS CAR: Init PLLHUB
[0111.953] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0111.965] I> SDRAM initialized!
[0111.968] I> SDRAM Size in Total 0x400000000
[0111.972] I> Task: Dram Ecc scrub
[0111.975] I> Task: DRAM alias check
[0111.985] I> Task: Program NSDRAM carveout
[0111.989] I> NSDRAM carveout encryption is enabled
[0111.994] I> Program NSDRAM carveout
[0111.997] I> Task: Register checker
[0112.001] I> Task: Enable clock-mon
[0112.005] I> FMON: Fmon re-programming done
[0112.009] I> Task: Mapper init
[0112.011] I> Task: SC7 Context Init
[0112.015] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0112.021] I> Task: CCPLEX IST init
[0112.024] I> Task: CPU WP0
[0112.027] I> Loading MCE
[0112.029] I> Slot: 0
[0112.031] I> Binary[8] block-134217728 (partition size: 0x80000)
[0112.037] I> Binary name: MCE
[0112.040] I> Size of crypto header is 8192
[0112.044] I> Size of crypto header is 8192
[0114.483] I> BCH of MCE read from storage
[0114.486] I> BCH address is : 0x4003e000
[0114.490] I> MCE header integrity check is success
[0114.495] I> Binary magic in BCH component 0 is MTSM
[0114.500] I> component binary type is 8
[0114.503] I> Size of crypto header is 8192
[0114.511] I> MCE binary is read from storage
[0114.516] I> MCE binary integrity check is success
[0114.520] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0114.526] I> Size of crypto header is 8192
[0114.530] I> Sending WP0 mailbox command to PSC
[0114.539] I> Task: XUSB Powergate
[0114.543] I> Skipping powergate XUSB.
[0114.546] I> Task: MB1 fixed firewalls
[0114.552] W> Firewall readback mismatch
[0114.557] I> Task: Load bpmp-fw
[0114.561] I> Slot: 0
[0114.563] I> Binary[15] block-251658240 (partition size: 0x180000)
[0114.569] I> Binary name: BPMP_FW
[0114.572] I> Size of crypto header is 8192
[0114.576] I> Size of crypto header is 8192
[0114.580] I> BCH of BPMP_FW read from storage
[0114.584] I> BCH address is : 0x807fe000
[0114.588] I> BPMP_FW header integrity check is success
[0114.593] I> Binary magic in BCH component 0 is BPMF
[0114.598] I> component binary type is 15
[0114.601] I> Size of crypto header is 8192
[0114.623] I> BPMP_FW binary is read from storage
[0114.629] I> BPMP_FW binary integrity check is success
[0114.634] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0114.640] I> Slot: 0
[0114.642] I> Binary[16] block-268435456 (partition size: 0x400000)
[0114.648] I> Binary name: BPMP_FW_DTB
[0114.652] I> Size of crypto header is 8192
[0114.656] I> Size of crypto header is 8192
[0114.660] I> BCH of BPMP_FW_DTB read from storage
[0114.664] I> BCH address is : 0x807fc000
[0114.668] I> BPMP_FW_DTB header integrity check is success
[0114.674] I> Binary magic in BCH component 0 is BPMD
[0114.678] I> component binary type is 16
[0114.682] I> Size of crypto header is 8192
[0114.692] I> BPMP_FW_DTB binary is read from storage
[0114.698] I> BPMP_FW_DTB binary integrity check is success
[0114.703] I> Binary BPMP_FW_DTB loaded successfully at 0x807a1970 (0x5a680)
[0114.710] I> Task: BPMP fw ast config
[0114.714] I> Task: Load psc-fw
[0114.717] I> Slot: 0
[0114.719] I> Binary[17] block-285212672 (partition size: 0xc0000)
[0114.725] I> Binary name: PSC_FW
[0114.728] I> Size of crypto header is 8192
[0114.732] I> Size of crypto header is 8192
[0114.736] I> BCH of PSC_FW read from storage
[0114.740] I> BCH address is : 0x80ffe000
[0114.744] I> PSC_FW header integrity check is success
[0114.749] I> Binary magic in BCH component 0 is PFWP
[0114.753] I> component binary type is 17
[0114.757] I> Size of crypto header is 8192
[0114.767] I> PSC_FW binary is read from storage
[0114.772] I> PSC_FW binary integrity check is success
[0114.777] I> Binary PSC_FW loaded successfully at 0x80fa4680 (0x59980)
[0114.784] I> Task: Load nvdec-fw
[0114.787] I> Slot: 0
[0114.789] I> Binary[7] block-117440512 (partition size: 0x100000)
[0114.795] I> Binary name: NVDEC
[0114.798] I> Size of crypto header is 8192
[0114.802] I> Size of crypto header is 8192
[0114.806] I> BCH of NVDEC read from storage
[0114.810] I> BCH address is : 0x800fe000
[0114.814] I> NVDEC header integrity check is success
[0114.818] I> Binary magic in BCH component 0 is NDEC
[0114.823] I> component binary type is 7
[0114.827] I> Size of crypto header is 8192
[0114.836] I> NVDEC binary is read from storage
[0114.841] I> NVDEC binary integrity check is success
[0114.845] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0114.854] I> Task: Load tsec-fw
[0114.857] I> TSEC-FW load support not enabled
[0114.861] I> Task: GPIO interrupt map
[0114.865] I> Task: SC7 context save
[0114.869] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0114.875] I> Task: Load MB2/Applet/FSKP
[0114.878] I> Loading MB2
[0114.881] I> Slot: 0
[0114.883] I> Binary[6] block-100663296 (partition size: 0x80000)
[0114.889] I> Binary name: MB2
[0114.891] I> Size of crypto header is 8192
[0114.895] I> Size of crypto header is 8192
[0114.899] I> BCH of MB2 read from storage
[0114.903] I> BCH address is : 0x8007e000
[0114.907] I> MB2 header integrity check is success
[0114.912] I> Binary magic in BCH component 0 is MB2B
[0114.917] I> component binary type is 6
[0114.920] I> Size of crypto header is 8192
[0114.931] I> MB2 binary is read from storage
[0114.936] I> MB2 binary integrity check is success
[0114.941] I> Binary MB2 loaded successfully at 0x80000000 (0x68c10)
[0114.947] I> Task: Map CCPLEX SHARED carveout
[0114.951] I> Task: Prepare MB2 params
[0114.955] I> Task: Dram ecc test
[0114.958] I> Task: Misc NV security settings
[0114.962] I> NVDEC sticky bits programming done
[0114.967] I> Successfully powergated NVDEC
[0114.971] I> Task: Disable/Reload WDT
[0114.974] I> Task: Program misc carveouts
[0114.978] I> Program IPC carveouts
[0114.982] I> Task: Disable SCPM/POD reset
[0114.986] I> SLCG Global override status := 0x0
[0114.990] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-7f6f63a6)
I> Boot-mode : RCM BOOT
I> Emulation:
I> Entry timestamp: 0x06db0558
I> Task: SMMU external bypass disable (0x500184fc)
I> Task: Enable hot-plug capability (0x50028dec)
I> Task: Set blob address (0x50002024)
I> Task: TZDRAM heap init (0x50019de0)
I> Task: PSC mailbox init (0x50018548)
I> Task: Crypto init (0x50006888)
I> Task: Enable GP-SE clock (0x500021b4)
I> Task: Measured Boot init (0x5001bd30)
I> Task: fTPM silicon identity init (0x5001bedc)
I> fTPM is not enabled.
I> Task: I2C register (0x50002010)
I> Task: Program CBB PCIE AMAP regions (0x5001b9dc)
I> Task: Load and authenticate registered FWs (0x5001ed44)
I> Task: Load AUXP FWs (0x50028970)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x46f300000
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x46f000000
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x476000000
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x46fc00000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x46f400000
I> Task: Carveout setup (0x500214d0)
I> Program remaining OEM carveouts
I> Task: Enable FSI VMON (0x50017ec8)
I> Task: Restore XUSB sec (0x50001ef4)
I> Task: Enable FSI SE clock (0x500189a4)
I> Task: Initialize SBSA UART CAR (0x50002118)
I> Task: Initialize CPUBL Params (0x50019990)
I> CPUBL-params @ 0x472000000
I> Task: Prepare eeprom data (0x5001975c)
E> I2C: slave not found in slaves.
E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
E> I2C_DEV: Failed to send register address 0x00000000.
E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
E> eeprom: Failed to read I2C slave device
C> Task 0x0 failed (err: 0x1f1e050d)
E> Top caller module: I2C_DEV, error module: I2C, reason: 0x0d, aux_info: 0x05
I> Busy Spin
我将bootloader/tegra234-mb2-bct-common.dtsi的eeprom的size改成0了,也是一样问题:
           eeprom {
               cvm_eeprom_i2c_instance = <0>;
               cvm_eeprom_i2c_slave_address = <0xa0>;
               cvm_eeprom_read_size = <0>;
               cvb_eeprom_i2c_instance = <0x0>;
               cvb_eeprom_i2c_slave_address = <0xac>;
               cvb_eeprom_read_size = <0>;
这个默认地址是0xac,我修改这三个文件的eeprom_read_size为0,再实验下:
bootloader/tegra234-mb2-bct-misc-p3767-0000.dts
bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3767-0000.dts
bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3701-0002-p3711-0000.dts
修改了这三个文件后,uart log 运行到kernel了,但是还是qspi报错,下面是uart log:
Jetson UEFI firmware (version 6.0-37391689 built on 2024-08-28T08:47:11+00:00)
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
......EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
�C: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
�  0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.216-tegra (arm1@arm1-wxz) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Fri Oct 11 14:58:05 CST 2024
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: NVIDIA Orin NX Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: MEMATTR=0x4363bf018 RNG=0x428a40018 MEMRESERVE=0x42a8aaf18
[    0.000000] random: crng init done
[    0.000000] Reserved memory: created CMA memory pool at 0x000000045e800000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000473ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000042ca6afff]
[    0.000000]   node   0: [mem 0x000000042ca6b000-0x000000042cd1bfff]
[    0.000000]   node   0: [mem 0x000000042cd1c000-0x000000043a1fffff]
[    0.000000]   node   0: [mem 0x000000043a200000-0x000000043c13ffff]
[    0.000000]   node   0: [mem 0x000000043c140000-0x000000046eb0ffff]
[    0.000000]   node   0: [mem 0x000000046eb10000-0x000000046eb1ffff]
[    0.000000]   node   0: [mem 0x0000000472000000-0x0000000473ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000473ffffff]
[    0.000000] On node 0, zone Normal: 224 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90392 r8192 d32488 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4066848
[    0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 kernel.hung_task_panic=0
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effff000-0x00000000fffff000] (256MB)
[    0.000000] Memory: 15577796K/16526464K available (18560K kernel code, 3170K rwdata, 7212K rodata, 3968K init, 1415K bss, 686524K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000655] Console: colour dummy device 80x25
[    0.000694] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000700] pid_max: default: 32768 minimum: 301
[    0.000754] LSM: Security Framework initializing
[    0.000774] Yama: becoming mindful.
[    0.000792] SELinux:  Initializing.
[    0.000856] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.000880] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.001921] rcu: Hierarchical SRCU implementation.
[    0.001995] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.002404] DTS File Name: /mnt/ubuntu20/code/nvidia/Orin_nx/SOMB-JETSON-V1.1-ORIN-NX-R35.6.0-General/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0000-p3768-0000-a0.dts
[    0.002410] DTB Build time: Oct 11 2024 15:25:59
[    0.003641] Tegra Revision: A01 SKU: 0xd3 CPU Process: 0 SoC Process: 0
[    0.003797] Remapping and enabling EFI services.
[    0.004677] smp: Bringing up secondary CPUs ...
[    0.033363] Detected PIPT I-cache on CPU1
[    0.033395] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.033421] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.062052] Detected PIPT I-cache on CPU2
[    0.062062] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.062078] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.090675] Detected PIPT I-cache on CPU3
[    0.090684] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.090699] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.121357] Detected PIPT I-cache on CPU4
[    0.121376] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.121402] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.150058] Detected PIPT I-cache on CPU5
[    0.150067] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.150081] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.178703] Detected PIPT I-cache on CPU6
[    0.178713] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.178727] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.207353] Detected PIPT I-cache on CPU7
[    0.207363] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.207378] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.207432] smp: Brought up 1 node, 8 CPUs
[    0.207445] SMP: Total of 8 processors activated.
[    0.207449] CPU features: detected: Privileged Access Never
[    0.207450] CPU features: detected: LSE atomic instructions
[    0.207452] CPU features: detected: User Access Override
[    0.207453] CPU features: detected: 32-bit EL0 Support
[    0.207455] CPU features: detected: Common not Private translations
[    0.207457] CPU features: detected: RAS Extension Support
[    0.207458] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.207460] CPU features: detected: CRC32 instructions
[    0.207461] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.240754] CPU: All CPU(s) started at EL2
[    0.242661] devtmpfs: initialized
[    0.257377] KASLR enabled
[    0.257491] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.257502] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.258993] pinctrl core: initialized pinctrl subsystem
[    0.259423] DMI not present or invalid.
[    0.259681] NET: Registered protocol family 16
[    0.260374] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.260482] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.260581] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.260608] audit: initializing netlink subsys (disabled)
[    0.260682] audit: type=2000 audit(0.260:1): state=initialized audit_enabled=0 res=1
[    0.260871] thermal_sys: Registered thermal governor 'step_wise'
[    0.260873] thermal_sys: Registered thermal governor 'power_allocator'
[    0.260876] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.261711] cpuidle: using governor menu
[    0.261797] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.261876] ASID allocator initialised with 32768 entries
[    0.261953] Serial: AMBA PL011 UART driver
[    0.263740] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.263760] Tegra reboot handler registered.
[    0.281630] mc: mapped MMIO address: 0xffff800010b20000 -> 0x2c10000
[    0.281638] mc: mapped MMIO address: 0xffff800010b40000 -> 0x2c20000
[    0.281643] mc: mapped MMIO address: 0xffff800010b60000 -> 0x2c30000
[    0.281648] mc: mapped MMIO address: 0xffff800010b80000 -> 0x2c40000
[    0.281654] mc: mapped MMIO address: 0xffff800010ba0000 -> 0x2c50000
[    0.281659] mc: mapped MMIO address: 0xffff800010bc0000 -> 0x2b80000
[    0.281663] mc: mapped MMIO address: 0xffff800010be0000 -> 0x2b90000
[    0.281671] mc: mapped MMIO address: 0xffff800010c00000 -> 0x2ba0000
[    0.281676] mc: mapped MMIO address: 0xffff800010c20000 -> 0x2bb0000
[    0.281681] mc: mapped MMIO address: 0xffff800010c40000 -> 0x1700000
[    0.281686] mc: mapped MMIO address: 0xffff800010c60000 -> 0x1710000
[    0.281693] mc: mapped MMIO address: 0xffff800010c80000 -> 0x1720000
[    0.281698] mc: mapped MMIO address: 0xffff800010ca0000 -> 0x1730000
[    0.281705] mc: mapped MMIO address: 0xffff800010cc0000 -> 0x1740000
[    0.281710] mc: mapped MMIO address: 0xffff800010ce0000 -> 0x1750000
[    0.281715] mc: mapped MMIO address: 0xffff800010d00000 -> 0x1760000
[    0.281719] mc: mapped MMIO address: 0xffff800010d20000 -> 0x1770000
[    0.281728] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.281759] mc-err: mcerr ops are set to t23x
[    0.282390] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[    0.286196] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.286200] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.286202] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.286203] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.287888] ACPI: Interpreter disabled.
[    0.288285] ddr-vddq: supplied by vdd-5v
[    0.288452] ddr-vdd2: supplied by vdd-5v
[    0.288556] vdd-AO-1v2: supplied by vdd-5v
[    0.288658] vdd-3v3: supplied by vdd-5v
[    0.288754] vdd-rtc: supplied by vdd-AO-1v2
[    0.288850] vdd-0v95-uphy: supplied by vdd-AO-1v2
[    0.288931] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[    0.289146] vdd-1v8: supplied by vdd-3v3-sys
[    0.289231] vdd-3v3-AO: supplied by vdd-5v-sys
[    0.289313] vdd-av10-hub: supplied by vdd-5v-sys
[    0.289412] vdd-vbus-a: supplied by vdd-5v-sys
[    0.289488] vdd-vbus-b: supplied by vdd-5v-sys
[    0.289568] vdd-3v3-dp: supplied by vdd-3v3-sys
[    0.289858] iommu: Default domain type: Translated
[    0.289906] eventlib_kernel: keventlib is initialized, test id: 0
[    0.290074] SCSI subsystem initialized
[    0.290146] usbcore: registered new interface driver usbfs
[    0.290162] usbcore: registered new interface driver hub
[    0.290174] usbcore: registered new device driver usb
[    0.290345] mc: Linux media interface: v0.10
[    0.290356] videodev: Linux video capture interface: v2.00
[    0.290497] pps_core: LinuxPPS API ver. 1 registered
[    0.290500] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.290507] PTP clock support registered
[    0.290731] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    0.290769] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    0.292092] Registered efivars operations
[    0.292294] FPGA manager framework
[    0.292335] Advanced Linux Sound Architecture Driver Initialized.
[    0.292618] Bluetooth: Core ver 2.22
[    0.292632] NET: Registered protocol family 31
[    0.292633] Bluetooth: HCI device and connection manager initialized
[    0.292639] Bluetooth: HCI socket layer initialized
[    0.292642] Bluetooth: L2CAP socket layer initialized
[    0.292648] Bluetooth: SCO socket layer initialized
[    0.293382] camchar: rtcpu character device driver loaded
[    0.293614] clocksource: Switched to clocksource arch_sys_counter
[    0.442274] VFS: Disk quotas dquot_6.6.0
[    0.442315] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.442601] pnp: PnP ACPI: disabled
[    0.444460] la/ptsa driver initialized.
[    0.444517] NET: Registered protocol family 2
[    0.444730] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.446948] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.446974] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.447087] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.447580] TCP: Hash tables configured (established 131072 bind 65536)
[    0.447653] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.447685] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.447793] NET: Registered protocol family 1
[    0.448048] RPC: Registered named UNIX socket transport module.
[    0.448051] RPC: Registered udp transport module.
[    0.448053] RPC: Registered tcp transport module.
[    0.448054] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.448065] PCI: CLS 0 bytes, default 64
[    0.448182] Trying to unpack rootfs image as initramfs...
[    0.810008] Freeing initrd memory: 31008K
[    0.811708] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.811843] kvm [1]: IPA Size Limit: 48 bits
[    0.811863] kvm [1]: GICv3: no GICV resource entry
[    0.811868] kvm [1]: disabling GICv2 emulation
[    0.811886] kvm [1]: GIC system register CPU interface enabled
[    0.811957] kvm [1]: vgic interrupt IRQ9
[    0.812067] kvm [1]: VHE mode initialized successfully
[    0.812712] Initialise system trusted keyrings
[    0.812799] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[    0.815083] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.815348] NFS: Registering the id_resolver key type
[    0.815363] Key type id_resolver registered
[    0.815366] Key type id_legacy registered
[    0.815396] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.815404] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.815416] ntfs: driver 2.1.32 [Flags: R/W].
[    0.827443] NET: Registered protocol family 38
[    0.827449] Key type asymmetric registered
[    0.827453] Asymmetric key parser 'x509' registered
[    0.827471] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[    0.827530] io scheduler mq-deadline registered
[    0.827533] io scheduler kyber registered
[    0.831103] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.831128] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.831142] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    0.831156] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    0.833469] tegra_dc_assign_hw_data: no matching compatible node
[    0.833474] tegradccommon module_init failed
[    0.833478] tegradc module_init failed
[    0.833726] EINJ: ACPI disabled.
[    0.835152] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.835158] tegra-pmc: ### PMC reset source: MAINSWRST
[    0.835161] tegra-pmc: ### PMC reset level: L1
[    0.835162] tegra-pmc: ### PMC reset status reg: 0x2d
[    0.836347] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.221357] printk: console [ttyTCU0] enabled
[    2.226146] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.232025] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.236574] arm-smmu 12000000.iommu:         stage 1 translation
[    2.241929] arm-smmu 12000000.iommu:         stage 2 translation
[    2.247426] arm-smmu 12000000.iommu:         nested translation
[    2.252762] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    2.259763] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    2.268464] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    2.272887] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.279448] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.286667] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.292310] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.297035] arm-smmu 10000000.iommu:         stage 1 translation
[    2.302548] arm-smmu 10000000.iommu:         stage 2 translation
[    2.307972] arm-smmu 10000000.iommu:         nested translation
[    2.313401] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    2.320573] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    2.329363] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    2.333787] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.340346] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.347337] arm-smmu 8000000.iommu: probing hardware configuration...
[    2.353474] arm-smmu 8000000.iommu: SMMUv2 with:
[    2.358200] arm-smmu 8000000.iommu:  stage 1 translation
[    2.363711] arm-smmu 8000000.iommu:  stage 2 translation
[    2.369137] arm-smmu 8000000.iommu:  nested translation
[    2.374299] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    2.381473] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    2.390259] arm-smmu 8000000.iommu:  Supported page sizes: 0x00001000
[    2.394687] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    2.401247] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    2.408492] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    2.417196] tegra_profiler: version: 1.151, samples/io: 51/30
[    2.421466] tegra_profiler: auth: init
[    2.425500] nvsciipc: loaded module
[    2.429876] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[    2.434938] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure has invalid entries
[    2.442200] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure: Child has not proper setting
[    2.450422] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[    2.457861] tegra23x-qspi 3270000.spi: Prod settings list not found
[    2.464688] tun: Universal TUN/TAP device driver, 1.6
[    2.469655] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.476499] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.482036] e1000e: Intel(R) PRO/1000 Network Driver
[    2.486998] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.492875] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.498197] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.503942] PPP generic driver version 2.4.2
[    2.508151] PPP BSD Compression module registered
[    2.512817] PPP Deflate Compression module registered
[    2.517984] PPP MPPE Compression module registered
[    2.522982] usbcore: registered new interface driver r8152
[    2.528309] usbcore: registered new interface driver asix
[    2.533823] usbcore: registered new interface driver ax88179_178a
[    2.539946] usbcore: registered new interface driver cdc_ether
[    2.545893] usbcore: registered new interface driver net1080
[    2.551491] usbcore: registered new interface driver cdc_subset
[    2.557531] usbcore: registered new interface driver zaurus
[    2.563223] usbcore: registered new interface driver cdc_ncm
[    2.568905] usbcore: registered new interface driver aqc111
[    2.574431] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.580631] ohci-pci: OHCI PCI platform driver
[    2.584928] ohci-platform: OHCI generic platform driver
[    2.590256] tegra-xusb 3610000.xhci: Adding to iommu group 1
[    2.596237] usbcore: registered new interface driver uas
[    2.601210] usbcore: registered new interface driver usb-storage
[    2.607196] tegra-xudc 3550000.xudc: Adding to iommu group 2
[    2.612924] mousedev: PS/2 mouse device common for all mice
[    2.618376] usbcore: registered new interface driver xpad
[    2.625733] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.629108] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:01:25 UTC (85)
[    2.636927] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.643158] i2c /dev entries driver
[    2.646719] tegra-i2c 3160000.i2c: Adding to iommu group 3
[    2.652270] tegra-i2c c240000.i2c: Adding to iommu group 3
[    2.657713] tegra-i2c 3180000.i2c: Adding to iommu group 3
[    2.663106] tegra-i2c 3190000.i2c: Adding to iommu group 3
[    2.668438] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[    2.673964] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[    2.679374] tegra-i2c c250000.i2c: Adding to iommu group 3
[    2.684711] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[    2.692727] pps pps0: new PPS source ktimer
[    2.694296] pps pps0: ktimer PPS source registered
[    2.699105] pps_ldisc: PPS line discipline registered
[    2.705050] device-mapper: uevent: version 1.0.3
[    2.708906] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    2.718333] sdhci: Secure Digital Host Controller Interface driver
[    2.723604] sdhci: Copyright(c) Pierre Ossman
[    2.728066] Synopsys Designware Multimedia Card Interface Driver
[    2.734173] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.740190] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    2.747129] tegra-bpmp bpmp: firmware: dc3fd3cac60f9b918e11-da583751bbf
[    2.755245] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    2.758827] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[    2.763814] nvvrs_pseq 4-003c: CAUTION: interrupt status reg:0x10 set to 0x2
[    2.770158] nvvrs_pseq 4-003c: Clearing interrupts
[    2.782159] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    2.782340] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
�ugfs initialized
�  3.924808] hid: raw HID events driver (C) Jiri Kosina
[    3.925451] usbcore: registered new interface driver usbhid
[    3.925617] usbhid: USB HID core driver
[    3.926127] tegra-dce d800000.dce: Adding to iommu group 4
[    3.927683] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]
[    3.928266] tegra234-aon c000000.aon: Adding to iommu group 5
[    3.929402] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    3.929841] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]
[    3.930144] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    3.930393] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...
[    3.930608] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]
[    3.930859]  c000000.aon:hsp: probed
[    3.930982] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    3.931233] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...
[    3.931613] tegra234-aon c000000.aon: init done
[    3.932720] dce: dce_start_boot_flow:173  DCE_BOOT_DONE
[    3.937977] tegra23x-psc e860000.psc: Adding to iommu group 6
[    3.943855] tegra23x-psc e860000.psc: ext_cfg base:00000000de4818b7
[    3.949780] tegra23x-psc e860000.psc: init done
[    3.954661] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[    3.961574] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    3.972476] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    3.977732] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    3.988888] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    3.999532] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    4.010663] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    4.022439] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    4.034931] tegra-ivc-bu� b���������������������������� R��������������������������x20�00����������������������������������� R����������us���������������������bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    4.061359] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    4.061366] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=23d74756c4720b2703c3fdde572be7d2b5d3d3ab
[    4.067539] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    4.087697] t19x_cache tegra-cache: probed
[    4.090116] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    4.103626] optee: probing for conduit method.
[    4.103760] optee: revision 3.22 (eb8130c7)
[    4.164377] optee: dynamic shared memory is enabled
[    4.164727] optee: initialized driver
[    4.177483] nvpmodel: initialized successfully
[    4.177723] tegra_hv: get_hvd: not initialized yet
[    4.177855] user_ivc_mempool: hypervisor not present
[    4.179048] usbcore: registered new interface driver snd-usb-audio
[    4.180092] u32 classifier
[    4.180172]     input device check on
[    4.181197]     Actions configured
[    4.184772] Initializing XFRM netlink socket
[    4.189357] NET: Registered protocol family 10
[    4.194492] Segment Routing with IPv6
[    4.197080] NET: Registered protocol family 17
[    4.201441] NET: Registered protocol family 15
[    4.205845] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.220006] Bluetooth: RFCOMM socket layer initialized
[    4.224138] Bluetooth: RFCOMM ver 1.11
[    4.228031] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.233887] Bluetooth: HIDP socket layer initialized
[    4.240240] 9pnet: Installing 9P2000 support
[    4.243321] Key type dns_resolver registered
[    4.248862] registered taskstats version 1
[    4.251751] Loading compiled-in X.509 certificates
[    4.269399] Loaded X.509 cert 'Build time autogenerated kernel key: c5276c1f43b0ad87622b4ab053e3c38d4edcc71c'
[    4.270261] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[    4.279132] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    4.280243] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[    4.291065] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    4.291649] tegra194-pcie 141e0000.pcie: Adding to iommu group 10
[    4.302839] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    4.303634] tegra194-pcie 140a0000.pcie: Adding to iommu group 11
[    4.315373] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    4.342491] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[    4.345474] host1x 13e40000.host1x: Adding to iommu group 13
[    4.368126] host1x 13e40000.host1x: initialized
[    4.368702] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[    4.369187] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[    4.369796] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[    4.370188] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[    4.370747] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[    4.376619] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[    4.387220] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[    4.394653] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    4.404987] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[    4.412499] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    4.422986] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[    4.430539] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    4.441045] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[    4.448558] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    4.459035] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[    4.466559] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    4.477110] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[    4.484633] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[    4.495109] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[    4.502622] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[    4.513140] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[    4.520678] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[    4.531134] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[    4.538658] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[    4.549162] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[    4.556735] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[    4.567222] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[    4.574694] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[    4.585217] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[    4.592742] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[    4.603250] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[    4.610774] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[    4.621304] falcon 15340000.vic: Adding to iommu group 30
[    4.631709] falcon 15340000.vic: initialized
[    4.632185] falcon 15380000.nvjpg: Adding to iommu group 31
[    4.640327] falcon 15380000.nvjpg: initialized
[    4.641226] falcon 15540000.nvjpg1: Adding to iommu group 32
[    4.650236] falcon 15540000.nvjpg1: initialized
[    4.651654] falcon 154c0000.nvenc: Adding to iommu group 33
[    4.662111] falcon 154c0000.nvenc: initialized
[    4.662376] falcon 15a50000.ofa: Adding to iommu group 34
[    4.670576] falcon 15a50000.ofa: initialized
[    4.671779] nvdec 15480000.nvdec: Adding to iommu group 35
[    4.684121] nvdec 15480000.nvdec: initialized
[    4.684389] tsec 15500000.tsec: Adding to iommu group 36
[    4.692591] tsec 15500000.tsec: initialized
[    4.695525] gic 2a41000.agic-controller: GIC IRQ controller registered
[    4.707351] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    4.720318] gpio-397 (camera-control-output-low): hogged as output/low
[    4.720540] gpio-486 (camera-control-output-low): hogged as output/low
[    4.721494] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    4.723965] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    4.730445] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    4.737614] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    4.743563] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    4.748865] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    4.755659] tegra194-isp5 14800000.isp: Adding to iommu group 37
[    4.762281] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    4.767927] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    4.774029] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    4.783126] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    4.792457] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[    4.800321] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[    4.807182] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: Adding to iommu group 38
[    4.814661] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    4.820910] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: Adding to iommu group 39
[    4.828578] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    4.835327] scare-pigeon 13e40000.host1x:isp-thi@14b00000: Adding to iommu group 37
[    4.843264] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    4.849513] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[    4.857802] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[    4.868528] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[    4.877065] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[    4.887774] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[    4.896107] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[    4.907019] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[    4.915340] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[    4.926092] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[    4.934580] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[    4.945347] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[    4.953847] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[    4.964591] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[    4.973113] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[    4.983857] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[    4.992345] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[    5.003095] pva 16000000.pva0: Adding to iommu group 48
[    5.013845] pva 16000000.pva0: initialized
[    5.020179] nvdla 15880000.nvdla0: Adding to iommu group 49
[    5.025737] nvdla 15880000.nvdla0: initialized
[    5.026546] nvdla 158c0000.nvdla1: Adding to iommu group 50
[    5.033741] nvdla 158c0000.nvdla1: initialized
[    5.034533] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[    5.039679] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    5.045984] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    5.052267] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    5.058890] serial-tegra 3100000.serial: Adding to iommu group 3
[    5.065092] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[    5.074440] serial-tegra 3130000.serial: Adding to iommu group 3
[    5.079889] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[    5.089018] serial-tegra 3140000.serial: Adding to iommu group 3
[    5.094717] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[    5.103814] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure has invalid entries
[    5.110720] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure: Child has not proper setting
[    5.119032] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[    5.126469] tegra23x-qspi 3270000.spi: Prod settings list not found
[    5.158091] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[    5.158354] tegra-xusb 3610000.xhci: xHCI Host Controller
[    5.158536] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    5.159566] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    5.164740] tegra-xusb 3610000.xhci: irq 230, io mem 0x03610000
[    5.170808] tegra-xusb 3610000.xhci: xHCI Host Controller
[    5.176081] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    5.183520] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    5.190929] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    5.199001] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.206355] usb usb1: Product: xHCI Host Controller
[    5.211163] usb usb1: Manufacturer: Linux 5.10.216-tegra xhci-hcd
[    5.217375] usb usb1: SerialNumber: 3610000.xhci
[    5.222832] hub 1-0:1.0: USB hub found
[    5.226066] hub 1-0:1.0: 4 ports detected
[    5.230538] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    5.238466] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.245729] usb usb2: Product: xHCI Host Controller
[    5.250711] usb usb2: Manufacturer: Linux 5.10.216-tegra xhci-hcd
[    5.256933] usb usb2: SerialNumber: 3610000.xhci
[    5.262419] hub 2-0:1.0: USB hub found
[    5.265517] hub 2-0:1.0: 4 ports detected
[    5.291673] i2c i2c-2: Added multiplexed i2c bus 9
[    5.292072] i2c i2c-2: Added multiplexed i2c bus 10
[    5.292218] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    5.292655] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[    5.307630] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2004000 KHz, changing to: 1984000 KHz
[    5.309352] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2003000 KHz, changing to: 1984000 KHz
[    5.316710] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[    5.322997] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    5.329147] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    5.334986] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    5.343468] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    5.352042] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    5.465774] tegra194-pcie 14100000.pcie: Link up
[    5.466981] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    5.467169] pci_bus 0001:00: root bus resource [bus 00-ff]
[    5.467320] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    5.467584] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    5.467862] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    5.468132] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    5.468458] pci 0001:00:00.0: PME# supported from D0 D3hot
[    5.472723] pci 0001:01:00.0: [10ec:8168] type 00 class 0x020000
[    5.473033] pci 0001:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    5.473216] pci 0001:01:00.0: reg 0x10: [io  size 0x0100]
[    5.473550] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    5.473863] pci 0001:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    5.475114] pci 0001:01:00.0: supports D1 D2
[    5.475226] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    5.479510] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    5.480843] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    5.486974] pci 0001:01:00.0: BAR 4: assigned [mem 0x20a8000000-0x20a8003fff 64bit]
[    5.489619] usb 1-3: new high-speed USB device number 2 using tegra-xusb
[    5.494948] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8004000-0x20a8004fff 64bit]
[    5.509648] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    5.515787] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    5.521010] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    5.527312] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    5.534497] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    5.543042] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    5.551794] pcieport 0001:00:00.0: Adding to iommu group 8
[    5.557173] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[    5.562687] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[    5.569003] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    5.575384] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    5.581480] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    5.589966] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    5.598447] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    5.652770] usb 1-3: New USB device found, idVendor=1a40, idProduct=0201, bcdDevice= 1.00
[    5.652982] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    5.653165] usb 1-3: Product: USB 2.0 Hub [MTT]
[    5.654165] hub 1-3:1.0: USB hub found
[    5.654640] hub 1-3:1.0: 7 ports detected
[    5.713621] tegra194-pcie 14160000.pcie: Link up
[    5.715991] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    5.716173] pci_bus 0004:00: root bus resource [bus 00-ff]
[    5.716320] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    5.716586] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    5.716866] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    5.717107] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    5.717405] pci 0004:00:00.0: PME# supported from D0 D3hot
[    5.721303] pci 0004:01:00.0: [1987:5019] type 00 class 0x010802
[    5.721648] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    5.727007] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    5.727188] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    5.727472] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    5.727608] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    5.731108] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.739648] pci 0004:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    5.748317] pcieport 0004:00:00.0: Adding to iommu group 9
[    5.753776] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[    5.759475] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[    5.765422] nvme 0004:01:00.0: Adding to iommu group 9
[    5.770797] nvme nvme0: pci function 0004:01:00.0
[    5.775174] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    5.775807] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    5.787903] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[    5.789662] nvme nvme0: missing or invalid SUBNQN field.
[    5.794019] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    5.807842] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    5.815027] nvme nvme0: allocated 64 MiB host memory buffer.
[    5.816326] tegra194-pcie 141e0000.pcie:      MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[    5.855690] nvme nvme0: 8/0/0 default/read/poll queues
[    5.857275]  nvme0n1: p1
[    5.949618] usb 1-3.6: new high-speed USB device number 3 using tegra-xusb
[    6.055267] usb 1-3.6: New USB device found, idVendor=0bda, idProduct=b720, bcdDevice= 2.00
[    6.055510] usb 1-3.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.055737] usb 1-3.6: Product: 802.11n WLAN Adapter
[    6.055875] usb 1-3.6: Manufacturer: Realtek
[    6.056013] usb 1-3.6: SerialNumber: 00e04c000001
[    6.939369] tegra194-pcie 141e0000.pcie: Phy link never came up
[    6.939613] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    6.939822] pci_bus 0007:00: root bus resource [bus 00-ff]
[    6.939977] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[    6.940262] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[    6.940581] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[    6.940859] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    6.941172] pci 0007:00:00.0: PME# supported from D0 D3hot
[    6.948205] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    6.948361] pci 0007:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    6.948848] pcieport 0007:00:00.0: Adding to iommu group 10
[    6.949180] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[    6.949644] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[    6.949999] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[    6.950234] pci 0007:00:00.0: Removing from iommu group 10
[    6.950378] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[    6.955477] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    6.960470] vdd-3v3-sd: supplied by vdd-3v3
[    6.966072] tegra194-isp5 14800000.isp: initialized
[    6.971519] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[    6.975621] (NULL device *): fops function table already registered
[    6.983794] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[    6.988591] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    6.994360] irq: IRQ303: trimming hierarchy from :interrupt-controller@f400000-1
[    7.111361] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[    7.111565] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[    7.111808] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[    7.112063] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[    7.217845] tegra194-pcie 140a0000.pcie: Link up
[    7.221301] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[    7.221505] pci_bus 0008:00: root bus resource [bus 00-ff]
[    7.221655] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[    7.221934] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[    7.222240] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[    7.222497] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[    7.222800] pci 0008:00:00.0: PME# supported from D0 D3hot
[    7.226853] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[    7.227148] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    7.227467] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    7.227755] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    7.228937] pci 0008:01:00.0: supports D1 D2
[    7.229045] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    7.233261] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[    7.233435] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[    7.233604] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[    7.240718] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[    7.248588] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[    7.255091] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[    7.260314] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[    7.266703] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[    7.274062] pci 0008:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    7.282603] pci 0008:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    7.291271] pcieport 0008:00:00.0: Adding to iommu group 11
[    7.296909] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[    7.302763] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[    7.309242] irq: IRQ305: trimming hierarchy from :pmc@c360000
[    7.313936] irq: IRQ306: trimming hierarchy from :interrupt-controller@f400000-1
[    7.321316] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    7.329164] tegra-se-nvhost 15810000.se: Adding to iommu group 51
[    7.334668] tegra-se-nvhost 15810000.se: initialized
[    7.347889] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    7.348147] tegra-se-nvhost 15820000.se: Adding to iommu group 52
[    7.351765] tegra-se-nvhost 15820000.se: initialized
[    7.358817] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    7.362516] tegra-se-nvhost 15840000.se: Adding to iommu group 53
[    7.368967] tegra-se-nvhost 15840000.se: initialized
[    7.376244] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    7.380376] tegra_actmon d230000.actmon: in actmon_register()...
[    7.386046] tegra_actmon d230000.actmon: bwmgr_disable = 1
[    7.391595] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    7.399399] hvc_sysfs: hypervisor is not present
[    7.403841] clk: Disabling unused clocks
[    7.443640] ALSA device list:
[    7.443722]   No soundcards found.
[    7.444483] Freeing unused kernel memory: 3968K
[    7.444672] Run /init as init process
[    7.457410] Root device found: initrd
insmod /lib/modules/5.10.216-tegra/kernel/drivers/net/ethernet/realtek/r8168/r8168.ko
[    7.521188] r8168 0001:01:00.0: Adding to iommu group 8
[    7.521571] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded
[    7.521835] r8168 0001:01:00.0: enabling device (0000 -> 0003)
[    7.539182] r8168 0001:01:00.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
[    7.539454] r8168 0001:01:00.0 (unnamed net_device) (uninitialized): Random ether addr f2:bf:16:7a:82:6e
[    7.539976] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    7.542340] r8168  Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
[    7.542340]  This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[    7.542340]  This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    7.543385] r8168 0008:01:00.0: Adding to iommu group 11
[    7.543726] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded
[    7.543950] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[    7.561441] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    7.563766] r8168  Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
[    7.563766]  This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[    7.563766]  This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    7.572174] Mount initrd as rootfs and enter recovery mode
enable_remote_access
enable remote access
insmod /lib/modules/5.10.216-tegra/kernel/drivers/mtd/mtd.ko
insmod /lib/modules/5.10.216-tegra/kernel/drivers/mtd/devices/qspi_mtd.ko
[    7.604628] qspi_mtd spi6.0: MX25U51279G (65536 Kbytes)
[    7.604761] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[    7.610042] ------------[ cut here ]------------
[    7.614692] WARNING: CPU: 7 PID: 237 at drivers/mtd/devices/qspi_mtd.c:514 read_sr1_reg.isra.0+0x130/0x180 [qspi_mtd]
[    7.625449] Modules linked in: qspi_mtd(+) mtd r8168
[    7.630437] CPU: 7 PID: 237 Comm: modprobe Not tainted 5.10.216-tegra #1
[    7.637260] Hardware name: NVIDIA Orin NX Developer Kit (DT)
[    7.643037] pstate: 00400009 (nzcv daif +PAN -UAO -TCO BTYPE=--)
[    7.648898] pc : read_sr1_reg.isra.0+0x130/0x180 [qspi_mtd]
[    7.654498] lr : read_sr1_reg.isra.0+0xe4/0x180 [qspi_mtd]
[    7.659921] sp : ffff8000138db650
[    7.663334] x29: ffff8000138db650 x28: ffffcd4e3a697798
[    7.668847] x27: ffffcd4e3a697618 x26: ffffcd4e3a6968b0
[    7.674360] x25: 0000000000000000 x24: ffff7602cf3dbdf8
[    7.679873] x23: 0000000000000001 x22: ffff8000138db896
[    7.685298] x21: ffff7602cf3db880 x20: ffff7602ce628ec0
[    7.690810] x19: ffff8000138db6a8 x18: 0000000000000010
[    7.696235] x17: 000000000000020e x16: ffffcd4e7f274bd0
[    7.701748] x15: ffff7602ce629430 x14: 2e202942694d3436
[    7.707172] x13: 2820303030303030 x12: 30307830203d2065
[    7.712597] x11: 0000000000000018 x10: 0000000000000ab0
[    7.718111] x9 : 0000000464005a97 x8 : 0000000000001400
[    7.723447] x7 : 00001190016a5c00 x6 : 0000000000000003
[    7.728960] x5 : 0000000000000000 x4 : 0000000000000000
[    7.734385] x3 : ffff7602ce628ec0 x2 : 0000000000000000
[    7.739721] x1 : ffff7602ce628ec0 x0 : 0000000000000044
[    7.745061] Call trace:
[    7.747512]  read_sr1_reg.isra.0+0x130/0x180 [qspi_mtd]
[    7.752585]  qspi_init+0x78/0x290 [qspi_mtd]
[    7.756874]  qspi_probe+0x400/0x4b0 [qspi_mtd]
[    7.761340]  spi_drv_probe+0x8c/0xf0
[    7.764839]  really_probe+0xf8/0x3f0
[    7.768334]  driver_probe_device+0x60/0x100
[    7.772362]  device_driver_attach+0x78/0x80
[    7.776561]  __driver_attach+0x74/0x100
[    7.780327]  bus_for_each_dev+0x84/0xe0
[    7.784086]  driver_attach+0x34/0x40
[    7.787760]  bus_add_driver+0x154/0x200
[    7.791523]  driver_register+0x68/0x120
[    7.795286]  __spi_register_driver+0x60/0x70
[    7.799574]  qspi_mtd_driver_init+0x2c/0x1000 [qspi_mtd]
[    7.804915]  do_one_initcall+0x50/0x300
[    7.808852]  do_init_module+0x50/0x200
[    7.812434]  load_module+0x1f74/0x2380
[    7.816372]  __do_sys_finit_module+0xb4/0x100
[    7.820835]  __arm64_sys_finit_module+0x2c/0x40
[    7.825388]  el0_svc_common.constprop.0+0x80/0x1d0
[    7.830286]  do_el0_svc+0x38/0xc0
[    7.833614]  el0_svc+0x1c/0x30
[    7.836760]  el0_sync_handler+0xa8/0xb0
[    7.840698]  el0_sync+0x16c/0x180
[    7.844112] ---[ end trace 24f105cc74aa2e78 ]---
[    7.848804] qspi_mtd spi6.0: block protection enabled 68
[    7.854371] qspi_mtd spi6.0: clearing block protect
[    7.859533] ------------[ cut here ]------------
[    7.863632] WARNING: CPU: 7 PID: 237 at drivers/mtd/devices/qspi_mtd.c:514 read_sr1_reg.isra.0+0x130/0x180 [qspi_mtd]
[    7.874036] Modules linked in: qspi_mtd(+) mtd r8168
[    7.878763] CPU: 7 PID: 237 Comm: modprobe Tainted: G        W         5.10.216-tegra #1
[    7.886636] Hardware name: NVIDIA Orin NX Developer Kit (DT)
[    7.892235] pstate: 00400009 (nzcv daif +PAN -UAO -TCO BTYPE=--)
[    7.898098] pc : read_sr1_reg.isra.0+0x130/0x180 [qspi_mtd]
[    7.903699] lr : read_sr1_reg.isra.0+0xe4/0x180 [qspi_mtd]
[    7.909034] sp : ffff8000138db380
[    7.912448] x29: ffff8000138db380 x28: ffff8000138db5e8
[    7.917873] x27: ffff7602ce628ec0 x26: 0000000000000000
[    7.923209] x25: 0000000000000000 x24: ffff7602cf3dbdf8
[    7.928547] x23: 0000000000000001 x22: ffff8000138db5e7
[    7.934060] x21: ffff7602cf3db880 x20: ffff7602ce628ec0
[    7.939484] x19: ffff8000138db3d8 x18: 0000000000000010
[    7.944997] x17: 0000000000000000 x16: 0000000000000000
[    7.950511] x15: 0000000000000000 x14: ffff7602c022d880
[    7.956022] x13: ffffa8b7ae717000 x12: 000000003464d91d
[    7.961446] x11: 0000000000000000 x10: 0000000000000ab0
[    7.966959] x9 : ffff8000138db030 x8 : ffff7602ce6299d0
[    7.972297] x7 : 00000035b5503510 x6 : 0000000000000003
[    7.977810] x5 : 0000000000000000 x4 : 0000000000000000
[    7.983234] x3 : ffff7602ce628ec0 x2 : 0000000000000000
[    7.988571] x1 : ffff7602ce628ec0 x0 : 0000000000000046
[    7.993910] Call trace:
[    7.996362]  read_sr1_reg.isra.0+0x130/0x180 [qspi_mtd]
[    8.001435]  qspi_write_en.constprop.0+0x78/0x1e0 [qspi_mtd]
[    8.007035]  qspi_write_status_cfgr_reg+0x68/0x1d0 [qspi_mtd]
[    8.012636]  qspi_init+0x258/0x290 [qspi_mtd]
[    8.016923]  qspi_probe+0x400/0x4b0 [qspi_mtd]
[    8.021214]  spi_drv_probe+0x8c/0xf0
[    8.024886]  really_probe+0xf8/0x3f0
[    8.028385]  driver_probe_device+0x60/0x100
[    8.032410]  device_driver_attach+0x78/0x80
[    8.036610]  __driver_attach+0x74/0x100
[    8.040373]  bus_for_each_dev+0x84/0xe0
[    8.044134]  driver_attach+0x34/0x40
[    8.047811]  bus_add_driver+0x154/0x200
[    8.051573]  driver_register+0x68/0x120
[    8.055336]  __spi_register_driver+0x60/0x70
[    8.059623]  qspi_mtd_driver_init+0x2c/0x1000 [qspi_mtd]
[    8.064963]  do_one_initcall+0x50/0x300
[    8.068901]  do_init_module+0x50/0x200
[    8.072749]  load_module+0x1f74/0x2380
[    8.076685]  __do_sys_finit_module+0xb4/0x100
[    8.081149]  __arm64_sys_finit_module+0x2c/0x40
[    8.085787]  el0_svc_common.constprop.0+0x80/0x1d0
[    8.090685]  do_el0_svc+0x38/0xc0
[    8.094014]  el0_svc+0x1c/0x30
[    8.097161]  el0_sync_handler+0xa8/0xb0
[    8.101098]  el0_sync+0x16c/0x180
[    8.104511] ---[ end trace 24f105cc74aa2e79 ]---
[    8.109160] qspi_mtd spi6.0: block protection enabled 70
[    8.115043] ------------[ cut here ]------------
[    8.119131] WARNING: CPU: 7 PID: 237 at drivers/mtd/devices/qspi_mtd.c:514 read_sr1_reg.isra.0+0x130/0x180 [qspi_mtd]
[    8.129625] Modules linked in: qspi_mtd(+) mtd r8168
[    8.134438] CPU: 7 PID: 237 Comm: modprobe Tainted: G        W         5.10.216-tegra #1
[    8.142134] Hardware name: NVIDIA Orin NX Developer Kit (DT)
[    8.147822] pstate: 00400009 (nzcv daif +PAN -UAO -TCO BTYPE=--)
[    8.153686] pc : read_sr1_reg.isra.0+0x130/0x180 [qspi_mtd]
[    8.159198] lr : read_sr1_reg.isra.0+0xe4/0x180 [qspi_mtd]
[    8.164621] sp : ffff8000138db600
[    8.167948] x29: ffff8000138db600 x28: ffffcd4e3a697798
[    8.173372] x27: ffffcd4e3a697618 x26: ffffcd4e3a6968b0
[    8.178797] x25: 0000000000000000 x24: ffff7602cf3dbdf8
[    8.184046] x23: 0000000000000001 x22: ffff8000138db837
[    8.189559] x21: ffff7602cf3db880 x20: ffff7602ce628ec0
[    8.194984] x19: ffff8000138db658 x18: 0000000000000010
[    8.200498] x17: 0000000000000000 x16: 0000000000000000
[    8.206010] x15: 0000000000000000 x14: ffff7602c022d880
[    8.211522] x13: ffffa8b7ae717000 x12: 000000003464d91d
[    8.216947] x11: 0000000000000000 x10: 0000000000000ab0
[    8.222458] x9 : ffff8000138db2b0 x8 : ffff7602ce6299d0
[    8.227796] x7 : 00000035b5503510 x6 : 0000000000000003
[    8.233310] x5 : 0000000000000000 x4 : 0000000000000000
[    8.238735] x3 : ffff7602ce628ec0 x2 : 0000000000000000
[    8.244073] x1 : ffff7602ce628ec0 x0 : 0000000000000047
[    8.249411] Call trace:
[    8.251862]  read_sr1_reg.isra.0+0x130/0x180 [qspi_mtd]
[    8.256937]  wait_till_ready+0x64/0x100 [qspi_mtd]
[    8.261749]  qspi_init+0x264/0x290 [qspi_mtd]
[    8.266035]  qspi_probe+0x400/0x4b0 [qspi_mtd]
[    8.270502]  spi_drv_probe+0x8c/0xf0
[    8.273999]  really_probe+0xf8/0x3f0
[    8.277498]  driver_probe_device+0x60/0x100
[    8.281698]  device_driver_attach+0x78/0x80
[    8.285723]  __driver_attach+0x74/0x100
[    8.289488]  bus_for_each_dev+0x84/0xe0
[    8.293247]  driver_attach+0x34/0x40
[    8.296923]  bus_add_driver+0x154/0x200
[    8.300685]  driver_register+0x68/0x120
[    8.304448]  __spi_register_driver+0x60/0x70
[    8.308736]  qspi_mtd_driver_init+0x2c/0x1000 [qspi_mtd]
[    8.314077]  do_one_initcall+0x50/0x300
[    8.317839]  do_init_module+0x50/0x200
[    8.321774]  load_module+0x1f74/0x2380
[    8.325710]  __do_sys_finit_module+0xb4/0x100
[    8.329997]  __arm64_sys_finit_module+0x2c/0x40
[    8.334638]  el0_svc_common.constprop.0+0x80/0x1d0
[    8.339536]  do_el0_svc+0x38/0xc0
[    8.342864]  el0_svc+0x1c/0x30
[    8.346012]  el0_sync_handler+0xa8/0xb0
[    8.349948]  el0_sync+0x16c/0x180
[    8.353362] ---[ end trace 24f105cc74aa2e7a ]---
[    8.358017] qspi_mtd spi6.0: block protection enabled 71
[    8.372194] 1 fixed-partitions partitions found on MTD device spi6.0
[    8.372362] Creating 1 MTD partitions on "spi6.0":
[    8.374547] 0x000000000000-0x000004000000 : "Whole_flash0"
insmod /lib/modules/5.10.216-tegra/kernel/drivers/spi/spi-tegra210-qspi.ko
insmod /lib/modules/5.10.216-tegra/kernel/drivers/hwmon/pwm-fan.ko
[   10.357623] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[   10.357926] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[   10.358212] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[   10.358501] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
Connection timeout: device /dev/sda is still not ready.
[   18.417981] using random self ethernet address
[   18.418126] using random host ethernet address
[   18.420968] Mass Storage Function, version: 2009/09/11
[   18.421114] LUN: removable file: (no medium)
[   18.422323] LUN: removable file: (no medium)
[   18.423485] LUN: removable file: (no medium)
[   18.424644] LUN: removable file: (no medium)
[   18.427236] rndis0: HOST MAC 42:20:c7:97:79:f5
[   18.427359] rndis0: MAC 32:13:aa:df:78:64
[   18.428570] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.0# [   18.954151] tegra-xudc 3550000.xudc: EP 5 (type: intr, dir: in) enabled
[   18.954371] tegra-xudc 3550000.xudc: EP 3 (type: bulk, dir: in) enabled
[   18.954575] tegra-xudc 3550000.xudc: EP 2 (type: bulk, dir: out) enabled
[   18.954839] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[   18.954989] tegra-xudc 3550000.xudc: EP 7 (type: bulk, dir: in) enabled
[   18.955240] tegra-xudc 3550000.xudc: EP 4 (type: bulk, dir: out) enabled
PC端log:
[   0.1372 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 437264
[   0.1377 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   0.1381 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[   0.1473 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.1516 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1027008
[   0.1521 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 378496
[   0.1551 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[   0.1568 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 540000
[   0.1571 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 401008
[   0.1573 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.1575 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1288096
[   0.1577 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.1580 ] Added binary blob_boot0.img of size 65611776
[   0.2240 ] Added binary blob_tegra234-p3767-0000-p3768-0000-a0.dtb of size 346351
[   0.3571 ] tegrarcm_v2 --instance 1-4 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   0.3580 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   0.3619 ] Sending bct_mem
[   0.3658 ] Sending blob
[   3.4717 ] RCM-boot started
/mnt/ubuntu20/code/nvidia/Orin_nx/SOMB-JETSON-V1.1-ORIN-NX-R35.6.0-General/out/SOMB-JETSON-V1.1-ORIN-NX-R35.6.0-General-20241011_155024
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Run command: if [ -f /qspi/l4t_flash_from_kernel.sh ]; then USER=root /qspi/l4t_flash_from_kernel.sh --no-reboot --qspi-only ; fi on root@fe80::1%enp0s20f0u4
blockdev: 打不开 /dev/sdf: 找不到介质
[ 0]: l4t_flash_from_kernel: Warning: serial number sysfs node doesn't exist.
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/ubuntu20/code/nvidia/Orin_nx/SOMB-JETSON-V1.1-ORIN-NX-R35.6.0-General/out/SOMB-JETSON-V1.1-ORIN-NX-R35.6.0-General-20241011_155024/tools/kernel_flash/images/internal/flash.idx
Number of lines is 58
max_index=57
[ 1]: l4t_flash_from_kernel: Successfully create gpt for emmc
Run command: partprobe /dev/mmcblk0 on root@fe80::1%enp0s20f0u4
SSH ready
Error: Could not stat device /dev/mmcblk0 - No such file or directory.
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
Flash index file is /qspi/internal/flash.idx
max_index=57
[ 0]: l4t_flash_from_kernel: Starting to flash to qspi
QSPI storage size: 67108864 bytes.
Erased 67108864 bytes from address 0x00000000 in flash
max_index=57
Writing br_bct_BR.bct (parittion: BCT) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/br_bct_BR.bct
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:0
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00000000 in flash
[ 189]: l4t_flash_from_kernel: QSPI erase block size is 65536
[ 189]: l4t_flash_from_kernel: Writing 16 copies of /qspi/internal/br_bct_BR.bct
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:65536
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00010000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:131072
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00020000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:196608
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00030000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:262144
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00040000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:327680
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00050000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:393216
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00060000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:458752
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00070000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:524288
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00080000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:589824
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x00090000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:655360
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x000a0000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:720896
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x000b0000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:786432
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x000c0000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:851968
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x000d0000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:917504
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x000e0000 in flash
Writing /qspi/internal/br_bct_BR.bct (8192 bytes) into  /dev/mtd0:983040
Copied 8192 bytes from /qspi/internal/br_bct_BR.bct to address 0x000f0000 in flash
Writing mb1_t234_prod_aligned_sigheader.bin.encrypt (parittion: A_mb1) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt
Writing /qspi/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt (282768 bytes) into  /dev/mtd0:1048576
Copied 282768 bytes from /qspi/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt to address 0x00100000 in flash
Writing psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (parittion: A_psc_bl1) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt
Writing /qspi/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (123008 bytes) into  /dev/mtd0:1572864
Copied 123008 bytes from /qspi/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt to address 0x00180000 in flash
Writing mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (parittion: A_MB1_BCT) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
Writing /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (17600 bytes) into  /dev/mtd0:1835008
Copied 17600 bytes from /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt to address 0x001c0000 in flash
Writing mem_coldboot_sigheader.bct.encrypt (parittion: A_MEM_BCT) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mem_coldboot_sigheader.bct.encrypt
Writing /qspi/internal/mem_coldboot_sigheader.bct.encrypt (243712 bytes) into  /dev/mtd0:1966080
Copied 243712 bytes from /qspi/internal/mem_coldboot_sigheader.bct.encrypt to address 0x001e0000 in flash
[ 190]: l4t_flash_from_kernel: Warning: skip writing A_tsec-fw partition as no image is specified
Writing nvdec_t234_prod_sigheader.fw.encrypt (parittion: A_nvdec) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/nvdec_t234_prod_sigheader.fw.encrypt
Writing /qspi/internal/nvdec_t234_prod_sigheader.fw.encrypt (294912 bytes) into  /dev/mtd0:3276800
Copied 294912 bytes from /qspi/internal/nvdec_t234_prod_sigheader.fw.encrypt to address 0x00320000 in flash
Writing mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (parittion: A_mb2) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt
Writing /qspi/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (437264 bytes) into  /dev/mtd0:4325376
Copied 437264 bytes from /qspi/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt to address 0x00420000 in flash
Writing xusb_t234_prod_sigheader.bin.encrypt (parittion: A_xusb-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/xusb_t234_prod_sigheader.bin.encrypt
Writing /qspi/internal/xusb_t234_prod_sigheader.bin.encrypt (164864 bytes) into  /dev/mtd0:4849664
Copied 164864 bytes from /qspi/internal/xusb_t234_prod_sigheader.bin.encrypt to address 0x004a0000 in flash
Writing bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt (parittion: A_bpmp-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt
Writing /qspi/internal/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt (1027008 bytes) into  /dev/mtd0:5111808
Copied 1027008 bytes from /qspi/internal/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt to address 0x004e0000 in flash
Writing tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt (parittion: A_bpmp-fw-dtb) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt
Writing /qspi/internal/tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt (378496 bytes) into  /dev/mtd0:6684672
Copied 378496 bytes from /qspi/internal/tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt to address 0x00660000 in flash
Writing pscfw_t234_prod_sigheader.bin.encrypt (parittion: A_psc-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/pscfw_t234_prod_sigheader.bin.encrypt
Writing /qspi/internal/pscfw_t234_prod_sigheader.bin.encrypt (375168 bytes) into  /dev/mtd0:10878976
Copied 375168 bytes from /qspi/internal/pscfw_t234_prod_sigheader.bin.encrypt to address 0x00a60000 in flash
Writing mce_flash_o10_cr_prod_sigheader.bin.encrypt (parittion: A_mts-mce) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt
Writing /qspi/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt (190592 bytes) into  /dev/mtd0:11665408
Copied 190592 bytes from /qspi/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt to address 0x00b20000 in flash
Writing sc7_t234_prod_sigheader.bin.encrypt (parittion: A_sc7) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/sc7_t234_prod_sigheader.bin.encrypt
Writing /qspi/internal/sc7_t234_prod_sigheader.bin.encrypt (186880 bytes) into  /dev/mtd0:12189696
Copied 186880 bytes from /qspi/internal/sc7_t234_prod_sigheader.bin.encrypt to address 0x00ba0000 in flash
Writing psc_rf_t234_prod_sigheader.bin.encrypt (parittion: A_pscrf) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/psc_rf_t234_prod_sigheader.bin.encrypt
Writing /qspi/internal/psc_rf_t234_prod_sigheader.bin.encrypt (122464 bytes) into  /dev/mtd0:12386304
Copied 122464 bytes from /qspi/internal/psc_rf_t234_prod_sigheader.bin.encrypt to address 0x00bd0000 in flash
Writing mb2rf_t234_sigheader.bin.encrypt (parittion: A_mb2rf) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/mb2rf_t234_sigheader.bin.encrypt
Writing /qspi/internal/mb2rf_t234_sigheader.bin.encrypt (122048 bytes) into  /dev/mtd0:12582912
Copied 122048 bytes from /qspi/internal/mb2rf_t234_sigheader.bin.encrypt to address 0x00c00000 in flash
Writing uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt (parittion: A_cpu-bootloader) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt
Writing /qspi/internal/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt (2912912 bytes) into  /dev/mtd0:12713984
Copied 2912912 bytes from /qspi/internal/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt to address 0x00c20000 in flash
Writing tos-optee_t234_sigheader.img.encrypt (parittion: A_secure-os) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/tos-optee_t234_sigheader.img.encrypt
Writing /qspi/internal/tos-optee_t234_sigheader.img.encrypt (1288096 bytes) into  /dev/mtd0:16384000
Copied 1288096 bytes from /qspi/internal/tos-optee_t234_sigheader.img.encrypt to address 0x00fa0000 in flash
[ 203]: l4t_flash_from_kernel: Warning: skip writing A_smm-fw partition as no image is specified
Writing eks_t234_sigheader.img.encrypt (parittion: A_eks) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/eks_t234_sigheader.img.encrypt
Writing /qspi/internal/eks_t234_sigheader.img.encrypt (9232 bytes) into  /dev/mtd0:22675456
Copied 9232 bytes from /qspi/internal/eks_t234_sigheader.img.encrypt to address 0x015a0000 in flash
Writing display-t234-dce_with_tegra234-p3767-0000-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt (parittion: A_dce-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/display-t234-dce_with_tegra234-p3767-0000-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt
Writing /qspi/internal/display-t234-dce_with_tegra234-p3767-0000-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt (738048 bytes) into  /dev/mtd0:22937600
Copied 738048 bytes from /qspi/internal/display-t234-dce_with_tegra234-p3767-0000-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt to address 0x015e0000 in flash
Writing spe_t234_sigheader.bin.encrypt (parittion: A_spe-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/spe_t234_sigheader.bin.encrypt
Writing /qspi/internal/spe_t234_sigheader.bin.encrypt (270336 bytes) into  /dev/mtd0:28180480
Copied 270336 bytes from /qspi/internal/spe_t234_sigheader.bin.encrypt to address 0x01ae0000 in flash
Writing camera-rtcpu-t234-rce_sigheader.img.encrypt (parittion: A_rce-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt
Writing /qspi/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt (540000 bytes) into  /dev/mtd0:28770304
Copied 540000 bytes from /qspi/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt to address 0x01b70000 in flash
Writing adsp-fw_sigheader.bin.encrypt (parittion: A_adsp-fw) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/adsp-fw_sigheader.bin.encrypt
Writing /qspi/internal/adsp-fw_sigheader.bin.encrypt (401008 bytes) into  /dev/mtd0:29818880
Copied 401008 bytes from /qspi/internal/adsp-fw_sigheader.bin.encrypt to address 0x01c70000 in flash
[ 207]: l4t_flash_from_kernel: Warning: skip writing A_reserved_on_boot partition as no image is specified
Writing mb1_t234_prod_aligned_sigheader.bin.encrypt (parittion: B_mb1) into /dev/mtd0
Writing /qspi/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt (282768 bytes) into  /dev/mtd0:33292288
Copied 282768 bytes from /qspi/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt to address 0x01fc0000 in flash
Writing psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (parittion: B_psc_bl1) into /dev/mtd0
Writing /qspi/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (123008 bytes) into  /dev/mtd0:33816576
Copied 123008 bytes from /qspi/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt to address 0x02040000 in flash
Writing mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (parittion: B_MB1_BCT) into /dev/mtd0
Writing /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (17600 bytes) into  /dev/mtd0:34078720
Copied 17600 bytes from /qspi/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt to address 0x02080000 in flash
Writing mem_coldboot_sigheader.bct.encrypt (parittion: B_MEM_BCT) into /dev/mtd0
Writing /qspi/internal/mem_coldboot_sigheader.bct.encrypt (243712 bytes) into  /dev/mtd0:34209792
Copied 243712 bytes from /qspi/internal/mem_coldboot_sigheader.bct.encrypt to address 0x020a0000 in flash
[ 208]: l4t_flash_from_kernel: Warning: skip writing B_tsec-fw partition as no image is specified
Writing nvdec_t234_prod_sigheader.fw.encrypt (parittion: B_nvdec) into /dev/mtd0
Writing /qspi/internal/nvdec_t234_prod_sigheader.fw.encrypt (294912 bytes) into  /dev/mtd0:35520512
Copied 294912 bytes from /qspi/internal/nvdec_t234_prod_sigheader.fw.encrypt to address 0x021e0000 in flash
Writing mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (parittion: B_mb2) into /dev/mtd0
Writing /qspi/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (437264 bytes) into  /dev/mtd0:36569088
Copied 437264 bytes from /qspi/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt to address 0x022e0000 in flash
Writing xusb_t234_prod_sigheader.bin.encrypt (parittion: B_xusb-fw) into /dev/mtd0
Writing /qspi/internal/xusb_t234_prod_sigheader.bin.encrypt (164864 bytes) into  /dev/mtd0:37093376
Copied 164864 bytes from /qspi/internal/xusb_t234_prod_sigheader.bin.encrypt to address 0x02360000 in flash
Writing bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt (parittion: B_bpmp-fw) into /dev/mtd0
Writing /qspi/internal/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt (1027008 bytes) into  /dev/mtd0:37355520
Copied 1027008 bytes from /qspi/internal/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt to address 0x023a0000 in flash
Writing tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt (parittion: B_bpmp-fw-dtb) into /dev/mtd0
Writing /qspi/internal/tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt (378496 bytes) into  /dev/mtd0:38928384
Copied 378496 bytes from /qspi/internal/tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt to address 0x02520000 in flash
Writing pscfw_t234_prod_sigheader.bin.encrypt (parittion: B_psc-fw) into /dev/mtd0
Writing /qspi/internal/pscfw_t234_prod_sigheader.bin.encrypt (375168 bytes) into  /dev/mtd0:43122688
Copied 375168 bytes from /qspi/internal/pscfw_t234_prod_sigheader.bin.encrypt to address 0x02920000 in flash
Writing mce_flash_o10_cr_prod_sigheader.bin.encrypt (parittion: B_mts-mce) into /dev/mtd0
Writing /qspi/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt (190592 bytes) into  /dev/mtd0:43909120
Copied 190592 bytes from /qspi/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt to address 0x029e0000 in flash
Writing sc7_t234_prod_sigheader.bin.encrypt (parittion: B_sc7) into /dev/mtd0
Writing /qspi/internal/sc7_t234_prod_sigheader.bin.encrypt (186880 bytes) into  /dev/mtd0:44433408
Copied 186880 bytes from /qspi/internal/sc7_t234_prod_sigheader.bin.encrypt to address 0x02a60000 in flash
Writing psc_rf_t234_prod_sigheader.bin.encrypt (parittion: B_pscrf) into /dev/mtd0
Writing /qspi/internal/psc_rf_t234_prod_sigheader.bin.encrypt (122464 bytes) into  /dev/mtd0:44630016
Copied 122464 bytes from /qspi/internal/psc_rf_t234_prod_sigheader.bin.encrypt to address 0x02a90000 in flash
Writing mb2rf_t234_sigheader.bin.encrypt (parittion: B_mb2rf) into /dev/mtd0
Writing /qspi/internal/mb2rf_t234_sigheader.bin.encrypt (122048 bytes) into  /dev/mtd0:44826624
Copied 122048 bytes from /qspi/internal/mb2rf_t234_sigheader.bin.encrypt to address 0x02ac0000 in flash
Writing uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt (parittion: B_cpu-bootloader) into /dev/mtd0
Writing /qspi/internal/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt (2912912 bytes) into  /dev/mtd0:44957696
Copied 2912912 bytes from /qspi/internal/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt to address 0x02ae0000 in flash
Writing tos-optee_t234_sigheader.img.encrypt (parittion: B_secure-os) into /dev/mtd0
Writing /qspi/internal/tos-optee_t234_sigheader.img.encrypt (1288096 bytes) into  /dev/mtd0:48627712
Copied 1288096 bytes from /qspi/internal/tos-optee_t234_sigheader.img.encrypt to address 0x02e60000 in flash
[ 221]: l4t_flash_from_kernel: Warning: skip writing B_smm-fw partition as no image is specified
Writing eks_t234_sigheader.img.encrypt (parittion: B_eks) into /dev/mtd0
Writing /qspi/internal/eks_t234_sigheader.img.encrypt (9232 bytes) into  /dev/mtd0:54919168
Copied 9232 bytes from /qspi/internal/eks_t234_sigheader.img.encrypt to address 0x03460000 in flash
Writing display-t234-dce_with_tegra234-p3767-0000-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt (parittion: B_dce-fw) into /dev/mtd0
Writing /qspi/internal/display-t234-dce_with_tegra234-p3767-0000-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt (738048 bytes) into  /dev/mtd0:55181312
Copied 738048 bytes from /qspi/internal/display-t234-dce_with_tegra234-p3767-0000-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt to address 0x034a0000 in flash
Writing spe_t234_sigheader.bin.encrypt (parittion: B_spe-fw) into /dev/mtd0
Writing /qspi/internal/spe_t234_sigheader.bin.encrypt (270336 bytes) into  /dev/mtd0:60424192
Copied 270336 bytes from /qspi/internal/spe_t234_sigheader.bin.encrypt to address 0x039a0000 in flash
Writing camera-rtcpu-t234-rce_sigheader.img.encrypt (parittion: B_rce-fw) into /dev/mtd0
Writing /qspi/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt (540000 bytes) into  /dev/mtd0:61014016
Copied 540000 bytes from /qspi/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt to address 0x03a30000 in flash
Writing adsp-fw_sigheader.bin.encrypt (parittion: B_adsp-fw) into /dev/mtd0
Writing /qspi/internal/adsp-fw_sigheader.bin.encrypt (401008 bytes) into  /dev/mtd0:62062592
Copied 401008 bytes from /qspi/internal/adsp-fw_sigheader.bin.encrypt to address 0x03b30000 in flash
[ 225]: l4t_flash_from_kernel: Warning: skip writing B_reserved_on_boot partition as no image is specified
[ 225]: l4t_flash_from_kernel: Warning: skip writing uefi_variables partition as no image is specified
[ 225]: l4t_flash_from_kernel: Warning: skip writing uefi_ftw partition as no image is specified
[ 225]: l4t_flash_from_kernel: Warning: skip writing worm partition as no image is specified
Writing bct_backup.img (parittion: BCT-boot-chain_backup) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/bct_backup.img
Writing /qspi/internal/bct_backup.img (32768 bytes) into  /dev/mtd0:66715648
Copied 32768 bytes from /qspi/internal/bct_backup.img to address 0x03fa0000 in flash
[ 225]: l4t_flash_from_kernel: Warning: skip writing reserved_partition partition as no image is specified
Writing gpt_backup_secondary_3_0.bin (parittion: secondary_gpt_backup) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/gpt_backup_secondary_3_0.bin
Writing /qspi/internal/gpt_backup_secondary_3_0.bin (16896 bytes) into  /dev/mtd0:66846720
Copied 16896 bytes from /qspi/internal/gpt_backup_secondary_3_0.bin to address 0x03fc0000 in flash
Writing qspi_bootblob_ver.txt (parittion: B_VER) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/qspi_bootblob_ver.txt
Writing /qspi/internal/qspi_bootblob_ver.txt (109 bytes) into  /dev/mtd0:66912256
Copied 109 bytes from /qspi/internal/qspi_bootblob_ver.txt to address 0x03fd0000 in flash
Writing qspi_bootblob_ver.txt (parittion: A_VER) into /dev/mtd0
Writing /qspi/internal/qspi_bootblob_ver.txt (109 bytes) into  /dev/mtd0:66977792
Copied 109 bytes from /qspi/internal/qspi_bootblob_ver.txt to address 0x03fe0000 in flash
Writing gpt_secondary_3_0.bin (parittion: secondary_gpt) into /dev/mtd0
Sha1 checksum matched for /qspi/internal/gpt_secondary_3_0.bin
Writing /qspi/internal/gpt_secondary_3_0.bin (16896 bytes) into  /dev/mtd0:67091968
Copied 16896 bytes from /qspi/internal/gpt_secondary_3_0.bin to address 0x03ffbe00 in flash
[ 225]: l4t_flash_from_kernel: Successfully flash the qspi
[ 225]: l4t_flash_from_kernel: Flashing success
Error flashing non-qspi storage
Cleaning up...
請問你現在燒錄的command是使用怎樣的參數?
这个参数:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device sda1 -p "-c ./bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs usb0 jetson-orin-nano-devkit sda1
  1. 那請問你usb drive有接嗎…? 我從log沒有看到
  2. 請問為什麼要自己加上 --no-systemimg…
  3. 請問你到目前為止到底有沒有成功先用文件上的command成功燒錄一次?
有接USB设备
因为之前有生成bootloader/system.img文件,为了节省时间
没有成功过
從你的log來看你反而nvme有偵測到. USB硬碟則沒有. 你要不要先試試看燒進去nvme?
这条烧录命令能识别qspi,但是nvme报错
sudo ./flash.sh  -r  jetson-orin-nano-devkit-nvme internal
uart log :
�0027.322] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0027.328] I> t234-A01-1-Silicon (0x12347) Prod
[0027.332] I> Boot-mode : Coldboot
[0027.335] I> Entry timestamp: 0x00000000
[0027.339] I> last_boot_error: 0x0
[0027.342] I> BR-BCT: preprod_dev_sign: 0
[0027.346] I> rst_source: 0xb, rst_level: 0x1
[0027.350] I> Task: SE error check
[0027.353] I> Task: Bootchain select WAR set
[0027.357] I> Task: Enable SLCG
[0027.360] I> Task: CRC check
[0027.363] I> Task: Initialize MB2 params
[0027.367] I> MB2-params @ 0x40060000
[0027.370] I> Task: Crypto init
[0027.373] I> Task: Perform MB1 KAT tests
[0027.377] I> Task: NVRNG health check
[0027.381] I> NVRNG: Health check success
[0027.385] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0027.391] I> Task: Enabling and initialization of Bandwidth limiter
[0027.397] I> No request to configure MBWT settings for any PC!
[0027.402] I> Task: Secure debug controls
[0027.406] I> Task: strap war set
[0027.409] I> Task: Initialize SOC Therm
[0027.413] I> Task: Program NV master stream id
[0027.417] I> Task: Verify boot mode
[0027.423] I> Task: Alias fuses
[0027.426] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0027.433] I> Task: Print SKU type
[0027.437] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0027.442] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0027.446] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0027.450] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0027.455] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0027.459] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0027.463] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0027.468] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0027.472] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0027.476] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0027.481] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0027.485] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0027.489] I> FUSE_SKU_INFO_0 = 0xd3
[0027.492] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0027.496] I> FUSE_PACKAGE_INFO_0 = 0x2
[0027.500] I> SKU: Prod
[0027.502] I> Task: Boost clocks
[0027.505] I> Initializing PLLC2 for AXI_CBB.
[0027.509] I> AXI_CBB : src = 35, divisor = 0
[0027.513] I> Task: Voltage monitor
[0027.517] I> VMON: Vmon re-calibration and fine tuning done
[0027.522] I> Task: UPHY init
[0027.527] I> HSIO UPHY init done
[0027.530] W> Skipping GBE UPHY config
[0027.534] I> Task: Boot device init
[0027.537] I> Boot_device: RCM
[0027.540] I> USB configuration success
[0028.960] I> Task: TSC init
[0028.963] I> Task: Load membct
[0028.966] I> RAM_CODE 0x4000001
[0028.969] I> Loading MEMBCT
[0028.972] I> Slot: 0
[0028.974] I> Binary[0] block-0 (partition size: 0x40000)
[0028.979] I> Binary name: MEM-BCT-0
[0028.982] I> Size of crypto header is 8192
[0028.986] I> Size of crypto header is 8192
[0029.141] I> BCH of MEM-BCT-0 read from storage
[0029.145] I> BCH address is : 0x40050000
[0029.149] I> MEM-BCT-0 header integrity check is success
[0029.154] I> Binary magic in BCH component 0 is MEM0
[0029.159] I> component binary type is 0
[0029.164] I> MEM-BCT-0 binary is read from storage
[0029.169] I> MEM-BCT-0 binary integrity check is success
[0029.174] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0029.181] I> RAM_CODE 0x4000001
[0029.186] I> RAM_CODE 0x4000001
[0029.190] I> Task: Load Page retirement list
[0029.194] I> Task: SDRAM params override
[0029.198] I> Task: Save mem-bct info
[0029.201] I> Task: Carveout allocate
[0029.205] I> Update CCPLEX IST carveout from MB1-BCT
[0029.210] I> ECC region[0]: Start:0x0, End:0x0
[0029.214] I> ECC region[1]: Start:0x0, End:0x0
[0029.218] I> ECC region[2]: Start:0x0, End:0x0
[0029.222] I> ECC region[3]: Start:0x0, End:0x0
[0029.227] I> ECC region[4]: Start:0x0, End:0x0
[0029.231] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0029.237] I> Non-ECC region[1]: Start:0x0, End:0x0
[0029.242] I> Non-ECC region[2]: Start:0x0, End:0x0
[0029.246] I> Non-ECC region[3]: Start:0x0, End:0x0
[0029.251] I> Non-ECC region[4]: Start:0x0, End:0x0
[0029.262] I> allocated(CO:43) base:0x47c000000 size:0x4000000 align: 0x200000
[0029.269] I> allocated(CO:39) base:0x479e00000 size:0x2200000 align: 0x10000
[0029.276] I> allocated(CO:20) base:0x476000000 size:0x2000000 align: 0x2000000
[0029.283] I> allocated(CO:24) base:0x474000000 size:0x2000000 align: 0x2000000
[0029.290] I> allocated(CO:28) base:0x472000000 size:0x2000000 align: 0x2000000
[0029.297] I> allocated(CO:22) base:0x478000000 size:0x1000000 align: 0x1000000
[0029.304] I> allocated(CO:35) base:0x479000000 size:0xe00000 align: 0x10000
[0029.311] I> allocated(CO:02) base:0x471800000 size:0x800000 align: 0x800000
[0029.318] I> allocated(CO:03) base:0x471000000 size:0x800000 align: 0x800000
[0029.325] I> allocated(CO:06) base:0x470800000 size:0x800000 align: 0x800000
[0029.332] I> allocated(CO:56) base:0x470000000 size:0x800000 align: 0x200000
[0029.339] I> allocated(CO:07) base:0x46fc00000 size:0x400000 align: 0x400000
[0029.346] I> allocated(CO:33) base:0x46f800000 size:0x400000 align: 0x200000
[0029.353] I> allocated(CO:23) base:0x46f600000 size:0x200000 align: 0x200000
[0029.360] I> allocated(CO:01) base:0x46f500000 size:0x100000 align: 0x100000
[0029.366] I> allocated(CO:05) base:0x46f400000 size:0x100000 align: 0x100000
[0029.373] I> allocated(CO:08) base:0x46f300000 size:0x100000 align: 0x100000
[0029.380] I> allocated(CO:09) base:0x46f200000 size:0x100000 align: 0x100000
[0029.387] I> allocated(CO:15) base:0x46f100000 size:0x100000 align: 0x100000
[0029.394] I> allocated(CO:17) base:0x46f000000 size:0x100000 align: 0x100000
[0029.401] I> allocated(CO:27) base:0x46ef00000 size:0x100000 align: 0x100000
[0029.408] I> allocated(CO:42) base:0x46ee00000 size:0x100000 align: 0x100000
[0029.415] I> allocated(CO:54) base:0x46ed80000 size:0x80000 align: 0x80000
[0029.422] I> allocated(CO:34) base:0x46ed70000 size:0x10000 align: 0x10000
[0029.429] I> allocated(CO:72) base:0x46eb70000 size:0x200000 align: 0x10000
[0029.436] I> allocated(CO:46) base:0x440000000 size:0x20000000 align: 0x20000000
[0029.443] I> allocated(CO:47) base:0x46e600000 size:0x400000 align: 0x200000
[0029.450] I> allocated(CO:48) base:0x46eb50000 size:0x20000 align: 0x10000
[0029.457] I> allocated(CO:69) base:0x46eb30000 size:0x20000 align: 0x10000
[0029.463] I> allocated(CO:49) base:0x46eb20000 size:0x10000 align: 0x10000
[0029.470] I> allocated(CO:50) base:0x46eb10000 size:0x10000 align: 0x10000
[0029.477] I> NSDRAM base: 0x80000000, end: 0x46eb70000, size: 0x3eeb70000
[0029.483] I> Task: Thermal check
[0029.487] I> Using min_chip_limit as min_tmon_limit
[0029.491] I> Using max_chip_limit as max_tmon_limit
[0029.496] I> BCT max_tmon_limit = 105
[0029.500] I> BCT min_tmon_limit = -28
[0029.503] I> BCT max_tmon_limit = 105
[0029.506] I> BCT min_tmon_limit = -28
[0029.510] I> SKU specific max_chip_limit = 105
[0029.514] I> SKU specific min_chip_limit = -28
[0029.519] I> BCT max_chip_limit = 105
[0029.522] I> BCT min_chip_limit = -28
[0029.526] I> enable_soctherm_polling = 0
[0029.529] I> max temp read = 49
[0029.532] I> min temp read = 43
[0029.535] I> Enabling thermtrip
[0029.538] I> Task: Update FSI SCR with thermal fuse data
[0029.543] I> Task: Enable WDT 5th expiry
[0029.547] I> Task: I2C register
[0029.550] I> Task: Set I2C bus freq
[0029.553] I> Task: Reset FSI
[0029.556] I> Task: Pinmux init
[0029.559] I> skipped mmio_addr = 0x9240008
[0029.563] I> skipped mmio_addr = 0x9240000
[0029.567] I> skipped mmio_addr = 0x9240010
[0029.571] I> skipped mmio_addr = 0x9240018
[0029.575] I> skipped mmio_addr = 0x9240020
[0029.579] I> skipped mmio_addr = 0x9240030
[0029.583] I> skipped mmio_addr = 0x9240028
[0029.587] I> skipped mmio_addr = 0x9240038
[0029.591] I> skipped mmio_addr = 0x9240040
[0029.595] I> skipped mmio_addr = 0x9240048
[0029.599] I> skipped mmio_addr = 0x9241000
[0029.603] I> skipped mmio_addr = 0x9241008
[0029.607] I> skipped mmio_addr = 0x9241010
[0029.611] I> skipped mmio_addr = 0x9241018
[0029.615] I> skipped mmio_addr = 0x9241020
[0029.619] I> skipped mmio_addr = 0x9241028
[0029.623] I> skipped mmio_addr = 0x9241030
[0029.626] I> skipped mmio_addr = 0x9241038
[0029.630] I> skipped mmio_addr = 0x9241040
[0029.634] I> skipped mmio_addr = 0x9242000
[0029.638] I> skipped mmio_addr = 0x9242008
[0029.642] I> Task: Prod config init
[0029.646] I> Task: Pad voltage init
[0029.649] I> Task: Prod init
[0029.652] I> Task: Program rst req config reg
[0029.656] I> Task: Common rail init
[0029.659] I> DONE: Thermal config
[0029.663] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0029.671] I> DONE: SOC rail config
[0029.675] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0029.682] I> DONE: MEMIO rail config
[0029.686] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0029.692] I> DONE: GPU rail info
[0029.695] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0029.701] I> DONE: CV rail info
[0029.704] I> Task: Mem clock src
[0029.707] I> Task: Misc. board config
[0029.711] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0029.717] I> Task: SDRAM init
[0029.720] I> MemoryType: 4 MemBctRevision: 1
[0029.726] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0029.734] I> MSS CAR: Init PLLM
[0029.737] I> MSS CAR: Init PLLHUB
[0029.742] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0029.753] I> SDRAM initialized!
[0029.756] I> SDRAM Size in Total 0x400000000
[0029.760] I> Task: Dram Ecc scrub
[0029.763] I> Task: DRAM alias check
[0029.773] I> Task: Program NSDRAM carveout
[0029.777] I> NSDRAM carveout encryption is enabled
[0029.782] I> Program NSDRAM carveout
[0029.785] I> Task: Register checker
[0029.789] I> Task: Enable clock-mon
[0029.793] I> FMON: Fmon re-programming done
[0029.797] I> Task: Mapper init
[0029.800] I> Task: SC7 Context Init
[0029.803] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0029.809] I> Task: CCPLEX IST init
[0029.812] I> Task: CPU WP0
[0029.815] I> Loading MCE
[0029.817] I> Slot: 0
[0029.819] I> Binary[8] block-134217728 (partition size: 0x80000)
[0029.825] I> Binary name: MCE
[0029.828] I> Size of crypto header is 8192
[0029.832] I> Size of crypto header is 8192
[0030.350] I> BCH of MCE read from storage
[0030.353] I> BCH address is : 0x4003e000
[0030.357] I> MCE header integrity check is success
[0030.362] I> Binary magic in BCH component 0 is MTSM
[0030.367] I> component binary type is 8
[0030.370] I> Size of crypto header is 8192
[0030.378] I> MCE binary is read from storage
[0030.382] I> MCE binary integrity check is success
[0030.387] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0030.393] I> Size of crypto header is 8192
[0030.397] I> Sending WP0 mailbox command to PSC
[0030.406] I> Task: XUSB Powergate
[0030.410] I> Skipping powergate XUSB.
[0030.413] I> Task: MB1 fixed firewalls
[0030.419] W> Firewall readback mismatch
[0030.424] I> Task: Load bpmp-fw
[0030.427] I> Slot: 0
[0030.429] I> Binary[15] block-251658240 (partition size: 0x180000)
[0030.435] I> Binary name: BPMP_FW
[0030.439] I> Size of crypto header is 8192
[0030.443] I> Size of crypto header is 8192
[0030.447] I> BCH of BPMP_FW read from storage
[0030.451] I> BCH address is : 0x807fe000
[0030.455] I> BPMP_FW header integrity check is success
[0030.460] I> Binary magic in BCH component 0 is BPMF
[0030.464] I> component binary type is 15
[0030.468] I> Size of crypto header is 8192
[0030.489] I> BPMP_FW binary is read from storage
[0030.496] I> BPMP_FW binary integrity check is success
[0030.501] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0030.507] I> Slot: 0
[0030.509] I> Binary[16] block-268435456 (partition size: 0x400000)
[0030.515] I> Binary name: BPMP_FW_DTB
[0030.519] I> Size of crypto header is 8192
[0030.523] I> Size of crypto header is 8192
[0030.527] I> BCH of BPMP_FW_DTB read from storage
[0030.531] I> BCH address is : 0x807fc000
[0030.535] I> BPMP_FW_DTB header integrity check is success
[0030.540] I> Binary magic in BCH component 0 is BPMD
[0030.545] I> component binary type is 16
[0030.549] I> Size of crypto header is 8192
[0030.559] I> BPMP_FW_DTB binary is read from storage
[0030.565] I> BPMP_FW_DTB binary integrity check is success
[0030.570] I> Binary BPMP_FW_DTB loaded successfully at 0x807a1970 (0x5a680)
[0030.577] I> Task: BPMP fw ast config
[0030.580] I> Task: Load psc-fw
[0030.583] I> Slot: 0
[0030.585] I> Binary[17] block-285212672 (partition size: 0xc0000)
[0030.591] I> Binary name: PSC_FW
[0030.594] I> Size of crypto header is 8192
[0030.598] I> Size of crypto header is 8192
[0030.602] I> BCH of PSC_FW read from storage
[0030.606] I> BCH address is : 0x80ffe000
[0030.610] I> PSC_FW header integrity check is success
[0030.615] I> Binary magic in BCH component 0 is PFWP
[0030.620] I> component binary type is 17
[0030.624] I> Size of crypto header is 8192
[0030.634] I> PSC_FW binary is read from storage
[0030.639] I> PSC_FW binary integrity check is success
[0030.644] I> Binary PSC_FW loaded successfully at 0x80fa4680 (0x59980)
[0030.650] I> Task: Load nvdec-fw
[0030.653] I> Slot: 0
[0030.655] I> Binary[7] block-117440512 (partition size: 0x100000)
[0030.661] I> Binary name: NVDEC
[0030.664] I> Size of crypto header is 8192
[0030.668] I> Size of crypto header is 8192
[0030.672] I> BCH of NVDEC read from storage
[0030.676] I> BCH address is : 0x800fe000
[0030.680] I> NVDEC header integrity check is success
[0030.685] I> Binary magic in BCH component 0 is NDEC
[0030.690] I> component binary type is 7
[0030.694] I> Size of crypto header is 8192
[0030.702] I> NVDEC binary is read from storage
[0030.707] I> NVDEC binary integrity check is success
[0030.712] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0030.721] I> Task: Load tsec-fw
[0030.724] I> TSEC-FW load support not enabled
[0030.728] I> Task: GPIO interrupt map
[0030.732] I> Task: SC7 context save
[0030.735] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0030.741] I> Task: Load MB2/Applet/FSKP
[0030.745] I> Loading MB2
[0030.747] I> Slot: 0
[0030.749] I> Binary[6] block-100663296 (partition size: 0x80000)
[0030.755] I> Binary name: MB2
[0030.758] I> Size of crypto header is 8192
[0030.762] I> Size of crypto header is 8192
[0030.766] I> BCH of MB2 read from storage
[0030.769] I> BCH address is : 0x8007e000
[0030.773] I> MB2 header integrity check is success
[0030.778] I> Binary magic in BCH component 0 is MB2B
[0030.783] I> component binary type is 6
[0030.786] I> Size of crypto header is 8192
[0030.798] I> MB2 binary is read from storage
[0030.803] I> MB2 binary integrity check is success
[0030.807] I> Binary MB2 loaded successfully at 0x80000000 (0x68c10)
[0030.813] I> Task: Map CCPLEX SHARED carveout
[0030.818] I> Task: Prepare MB2 params
[0030.821] I> Task: Dram ecc test
[0030.824] I> Task: Misc NV security settings
[0030.829] I> NVDEC sticky bits programming done
[0030.833] I> Successfully powergated NVDEC
[0030.837] I> Task: Disable/Reload WDT
[0030.840] I> Task: Program misc carveouts
[0030.844] I> Program IPC carveouts
[0030.848] I> Task: Disable SCPM/POD reset
[0030.852] I> SLCG Global override status := 0x0
[0030.856] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-7f6f63a6)
I> Boot-mode : RCM Flash
I> Emulation:
I> Entry timestamp: 0x01d747a8
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x470000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002050)
I> Task: Check MC errors (0x5000204c)
I> Task: SMMU external bypass disable (0x500184fc)
I> Task: PSC mailbox init (0x50018548)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001ff8)
I> Task: Program CBB PCIE AMAP regions (0x5001b9dc)
I> Task: Boot device init (0x50001f40)
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : pllc_out0
I> QSPI-0l initialized successfully
I> Initializing nvme device instance 4
I> Initializing nvme controller
I> tegrabl_pcie_soc_preinit: (4):
I> Unpowergate
I> PCIE unpowergating successful
I> tegrabl_pcie_soc_init: (4):
I> APPL initialization ...
I> PCIe controller-4 link is up
I> tegra_pcie_info[4].cfg0_base = 0x36000000
I> tegra_pcie_info[4].cfg1_base = 0x36020000
I> tegra_pcie_info[4].atu_dma_base = 0x36040000
I> tegra_pcie_bus[4].mem = 0x36200000
I> Scanning busnr: 0 devfn: 0
I> PCIe IDs: 0x229c10de
I> PCIe RID_CC: 0x60400a1
I> Scanning busnr: 1 devfn: 0
I> PCIe IDs: 0x50191987
I> PCIe RID_CC: 0x1080201
I> PCI Config: I/O=0x36100000, Memory=0x36200000
I> MEM64 bar_num=0 bar=0x36200000
I> Number of PCIe devices detected: 2
I> NVME page size: 4096
I> NVMe serial number: CD8E07290D9E92652224
I> NVMe model number: Phison CFESR512GMTCT-E9C-2
I> NVMe firmware revision: EJFM31.2
I> block_count: 1000215216
I> supported_lba: 0
I> block_size_log2: 0x9
I> tegrabl_create_io_queue_cmd: queue size: 2
I> nvme device id 000c0004
I> Task: Partition Manager Init (0x50001f20)
I> Active chain: 0
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Active chain: 0
W> Cannot find any partition table for 000c0004
 > PARTITION_MANAGER: Failed to publish partition.
I> Task: Trigger mailbox for PSC-BL1 exit (0x500185c8)
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Enter 3p server (0x500020e8)
I> Populate storage info
I> Erasing device 3: 0
I> QSPI: Erasing entire device
I> Writing device 3: 0.
I> Active chain: 0
I> Erasing device 12: 4
PC log:
[  10.8414 ] partition type rce_fw, magic id = RCEF
[  10.8444 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-t234-rce_aligned.img
[  10.8466 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-t234-rce_aligned.img zerosbk
[  10.8477 ] adding BCH for blob_camera-rtcpu-t234-rce_aligned.img
[  10.8695 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  10.8697 ] Assuming zero filled SBK key
[  10.8750 ] Warning: pub_key.key is not found
[  10.8755 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt blob_camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[  10.8798 ] Get magic id
[  10.8811 ] tegraparser_v2 --get_magic ape_fw
[  10.8822 ] APEF
[  10.8822 ]
[  10.8822 ] partition type ape_fw, magic id = APEF
[  10.8846 ] tegrahost_v2 --chip 0x23 0 --align blob_adsp-fw_aligned.bin
[  10.8876 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_adsp-fw_aligned.bin zerosbk
[  10.8895 ] adding BCH for blob_adsp-fw_aligned.bin
[  10.9068 ] tegrasign_v3.py --key None --list blob_adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  10.9072 ] Assuming zero filled SBK key
[  10.9111 ] Warning: pub_key.key is not found
[  10.9113 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_adsp-fw_aligned_sigheader.bin.encrypt blob_adsp-fw_aligned_sigheader.bin.hash zerosbk
[  10.9150 ] Get magic id
[  10.9164 ] tegraparser_v2 --get_magic spe_fw
[  10.9178 ] SPEF
[  10.9179 ]
[  10.9179 ] partition type spe_fw, magic id = SPEF
[  10.9210 ] tegrahost_v2 --chip 0x23 0 --align blob_spe_t234_aligned.bin
[  10.9235 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t234_aligned.bin zerosbk
[  10.9246 ] adding BCH for blob_spe_t234_aligned.bin
[  10.9364 ] tegrasign_v3.py --key None --list blob_spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  10.9367 ] Assuming zero filled SBK key
[  10.9405 ] Warning: pub_key.key is not found
[  10.9415 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_spe_t234_aligned_sigheader.bin.encrypt blob_spe_t234_aligned_sigheader.bin.hash zerosbk
[  10.9447 ] Get magic id
[  10.9460 ] tegraparser_v2 --get_magic tos
[  10.9472 ] TOSB
[  10.9472 ]
[  10.9472 ] partition type tos, magic id = TOSB
[  10.9543 ] tegrahost_v2 --chip 0x23 0 --align blob_tos-optee_t234_aligned.img
[  10.9584 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t234_aligned.img zerosbk
[  10.9598 ] adding BCH for blob_tos-optee_t234_aligned.img
[  11.0084 ] tegrasign_v3.py --key None --list blob_tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  11.0087 ] Assuming zero filled SBK key
[  11.0145 ] Warning: pub_key.key is not found
[  11.0149 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-optee_t234_aligned_sigheader.img.encrypt blob_tos-optee_t234_aligned_sigheader.img.hash zerosbk
[  11.0231 ] Get magic id
[  11.0249 ] tegraparser_v2 --get_magic eks
[  11.0264 ] EKSB
[  11.0266 ] partition type eks, magic id = EKSB
[  11.0279 ] tegrahost_v2 --chip 0x23 0 --align blob_eks_t234_aligned.img
[  11.0302 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t234_aligned.img zerosbk
[  11.0312 ] adding BCH for blob_eks_t234_aligned.img
[  11.0332 ] tegrasign_v3.py --key None --list blob_eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  11.0335 ] Assuming zero filled SBK key
[  11.0357 ] Warning: pub_key.key is not found
[  11.0357 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_t234_aligned_sigheader.img.encrypt blob_eks_t234_aligned_sigheader.img.hash zerosbk
[  11.0388 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[  11.0398 ] The number of images in blob is 16
[  11.0401 ] blobsize is 18452016
[  11.0402 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3186752
[  11.0494 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[  11.0500 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[  11.0503 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[  11.0506 ] Not supported type: mb2_applet
[  11.0507 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 437264
[  11.0510 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[  11.0513 ] Added binary blob_display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_sigheader.bin.encrypt of size 9443568
[  11.0572 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[  11.0596 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1027008
[  11.0602 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 378496
[  11.0606 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[  11.0609 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 540000
[  11.0613 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 401008
[  11.0616 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[  11.0619 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1288096
[  11.0622 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[  11.0819 ] Sending membct and RCM blob
[  11.0833 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[  11.0844 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[  11.2430 ] Sending bct_mem
[  11.4222 ] Sending blob
[  12.6344 ] completed
[  12.6345 ] Retrieving storage infomation
[  12.6395 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails storage storage_info.bin
[  12.6410 ] MB2 version 01.00.0000
[  13.5157 ] Saved platform info in storage_info.bin
[  14.5254 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[  14.6966 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[  14.7006 ] MB2 version 01.00.0000
[  14.8778 ] Flashing the device
[  14.8828 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[  14.8867 ] gpt_secondary_3_0.bin:
[  14.8888 ] partition_id	partition_name			      StartingLba	EndingLba
[  14.8899 ]            1	BCT                                 	       0	    2047
[  14.8910 ]            2	A_mb1                               	    2048	    3071
[  14.8920 ]            3	A_psc_bl1                           	    3072	    3583
[  14.8932 ]            4	A_MB1_BCT                           	    3584	    3839
[  14.8943 ]            5	A_MEM_BCT                           	    3840	    4351
[  14.8954 ]            6	A_tsec-fw                           	    4352	    6399
[  14.8965 ]            7	A_nvdec                             	    6400	    8447
[  14.8975 ]            8	A_mb2                               	    8448	    9471
[  14.8986 ]            9	A_xusb-fw                           	    9472	    9983
[  14.8996 ]           10	A_bpmp-fw                           	    9984	   13055
[  14.9007 ]           11	A_bpmp-fw-dtb                       	   13056	   21247
[  14.9014 ]           12	A_psc-fw                            	   21248	   22783
[  14.9015 ]           13	A_mts-mce                           	   22784	   23807
[  14.9015 ]           14	A_sc7                               	   23808	   24191
[  14.9015 ]           15	A_pscrf                             	   24192	   24575
[  14.9015 ]           16	A_mb2rf                             	   24576	   24831
[  14.9015 ]           17	A_cpu-bootloader                    	   24832	   31999
[  14.9015 ]           18	A_secure-os                         	   32000	   40191
[  14.9016 ]           19	A_smm-fw                            	   40192	   44287
[  14.9016 ]           20	A_eks                               	   44288	   44799
[  14.9016 ]           21	A_dce-fw                            	   44800	   55039
[  14.9016 ]           22	A_spe-fw                            	   55040	   56191
[  14.9016 ]           23	A_rce-fw                            	   56192	   58239
[  14.9017 ]           24	A_adsp-fw                           	   58240	   62335
[  14.9017 ]           25	A_reserved_on_boot                  	   62336	   65023
[  14.9017 ]           26	B_mb1                               	   65024	   66047
[  14.9017 ]           27	B_psc_bl1                           	   66048	   66559
[  14.9017 ]           28	B_MB1_BCT                           	   66560	   66815
[  14.9017 ]           29	B_MEM_BCT                           	   66816	   67327
[  14.9017 ]           30	B_tsec-fw                           	   67328	   69375
[  14.9017 ]           31	B_nvdec                             	   69376	   71423
[  14.9018 ]           32	B_mb2                               	   71424	   72447
[  14.9018 ]           33	B_xusb-fw                           	   72448	   72959
[  14.9018 ]           34	B_bpmp-fw                           	   72960	   76031
[  14.9018 ]           35	B_bpmp-fw-dtb                       	   76032	   84223
[  14.9018 ]           36	B_psc-fw                            	   84224	   85759
[  14.9018 ]           37	B_mts-mce                           	   85760	   86783
[  14.9018 ]           38	B_sc7                               	   86784	   87167
[  14.9019 ]           39	B_pscrf                             	   87168	   87551
[  14.9019 ]           40	B_mb2rf                             	   87552	   87807
[  14.9019 ]           41	B_cpu-bootloader                    	   87808	   94975
[  14.9019 ]           42	B_secure-os                         	   94976	  103167
[  14.9019 ]           43	B_smm-fw                            	  103168	  107263
[  14.9019 ]           44	B_eks                               	  107264	  107775
[  14.9019 ]           45	B_dce-fw                            	  107776	  118015
[  14.9020 ]           46	B_spe-fw                            	  118016	  119167
[  14.9020 ]           47	B_rce-fw                            	  119168	  121215
[  14.9020 ]           48	B_adsp-fw                           	  121216	  125311
[  14.9020 ]           49	B_reserved_on_boot                  	  125312	  127999
[  14.9020 ]           50	uefi_variables                      	  128000	  128511
[  14.9020 ]           51	uefi_ftw                            	  128512	  129535
[  14.9021 ]           52	worm                                	  129920	  130303
[  14.9021 ]           53	BCT-boot-chain_backup               	  130304	  130431
[  14.9021 ]           54	reserved_partition                  	  130432	  130559
[  14.9021 ]           55	secondary_gpt_backup                	  130560	  130687
[  14.9021 ]           56	B_VER                               	  130688	  130815
[  14.9021 ]           57	A_VER                               	  130816	  130943
[  14.9021 ] gpt_primary_12_4.bin:
[  14.9022 ] partition_id	partition_name			      StartingLba	EndingLba
[  14.9022 ]            1	APP                                 	 3050048	1000215175
[  14.9022 ]            2	A_kernel                            	      40	  262183
[  14.9022 ]            3	A_kernel-dtb                        	  262184	  263719
[  14.9022 ]            4	A_reserved_on_user                  	  263720	  328487
[  14.9022 ]            5	B_kernel                            	  328488	  590631
[  14.9023 ]            6	B_kernel-dtb                        	  590632	  592167
[  14.9023 ]            7	B_reserved_on_user                  	  592168	  656935
[  14.9023 ]            8	recovery                            	  656936	  820775
[  14.9023 ]            9	recovery-dtb                        	  820776	  821799
[  14.9023 ]           10	esp                                 	  821800	  952871
[  14.9023 ]           11	recovery_alt                        	  952872	 1116711
[  14.9023 ]           12	recovery-dtb_alt                    	 1116712	 1117735
[  14.9024 ]           13	esp_alt                             	 1117736	 1248807
[  14.9024 ]           14	UDA                                 	 1248832	 2068031
[  14.9024 ]           15	reserved                            	 2068032	 3050047
[  14.9024 ] gpt_secondary_12_4.bin:
[  14.9024 ] partition_id	partition_name			      StartingLba	EndingLba
[  14.9024 ]            1	APP                                 	 3050048	1000215175
[  14.9024 ]            2	A_kernel                            	      40	  262183
[  14.9025 ]            3	A_kernel-dtb                        	  262184	  263719
[  14.9025 ]            4	A_reserved_on_user                  	  263720	  328487
[  14.9025 ]            5	B_kernel                            	  328488	  590631
[  14.9025 ]            6	B_kernel-dtb                        	  590632	  592167
[  14.9025 ]            7	B_reserved_on_user                  	  592168	  656935
[  14.9025 ]            8	recovery                            	  656936	  820775
[  14.9026 ]            9	recovery-dtb                        	  820776	  821799
[  14.9026 ]           10	esp                                 	  821800	  952871
[  14.9026 ]           11	recovery_alt                        	  952872	 1116711
[  14.9026 ]           12	recovery-dtb_alt                    	 1116712	 1117735
[  14.9026 ]           13	esp_alt                             	 1117736	 1248807
[  14.9026 ]           14	UDA                                 	 1248832	 2068031
[  14.9026 ]           15	reserved                            	 2068032	 3050047
[  14.9027 ]
[  14.9028 ] Start flashing
[  14.9064 ] tegradevflash_v2 --pt flash.xml.bin --create
[  14.9096 ] Bootloader version 01.00.0000
[  15.0753 ] Erasing spi: 0 ......... [Done]
[ 202.0935 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin [ 16896 bytes ]
[ 202.0946 ] [................................................] 100%
[ 202.3135 ] Erasing nvme: 4 .........
[Failed]
Error: Return value 8
Command tegradevflash_v2 --pt flash.xml.bin --create
Failed flashing t186ref.
我再试试用这个command烧录nvme:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p "-c ./bootloader/t186ref/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit nvme0n1p1
你真的可以不用再試flash.sh了… 那個不會成功的
flash.sh沒有辦法燒除了mmcblk0p1之外的東西. 單燒QSPI可以. 但是nvme/ usb drive 這種沒有辦法.
请问,我用这条去掉–network的command烧录有影响么?
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p "-c ./bootloader/t186ref/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs  usb0 jetson-orin-nano-devkit nvme0n1p1
能請你就直接copy Quickstart guide上的command一字不漏不改然後燒錄嗎
network usb0拔了你也會不能燒. 真的有問題請你提供完整log給我 我會幫你確認.
先讓板子起碼能燒過一次. 之後你想改什麼再說
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 jetson-orin-nano-devkit internal
就是一字不漏的这条命令会报这个错误:
[sudo] ubuntu20 的密码:
/mnt/ubuntu20/code/nvidia/Orin_nx/SOMB-JETSON-V1.1-ORIN-NX-R35.6.0-General/out/SOMB-JETSON-V1.1-ORIN-NX-R35.6.0-General-20241011_155024/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p -c bootloader/t186ref/cfg/flash_t234_qspi.xml --showlogs --network usb0 jetson-orin-nano-devkit internal
exportfs: /mnt/ubuntu20/code/nvidia/Orin_nx/SOMB-JETSON-V1.1-ORIN-NX-R35.6.0-General/out/SOMB-JETSON-V1.1-ORIN-NX-R35.6.0-General-20241011_155024/rootfs does not support NFS export
Cleaning up...
