Hi
According to the spec " Manually Sync Bootloader A/B Slots with the Capsule Update", it can perform BL capsule update.
However, after update, slot 1 can not be bootable. From the serial log, it respin and boot to slot 0. After it enter system UI, I recheck ‘Capsule update status’. it seems to be ‘1 - Capsule update successfully’. But, slot1 become ‘unbootable’ as follows:
sudo nvbootctrl dump-slots-info
[sudo] password for test:
Current version: 35.2.1
Capsule update status: 1
Current bootloader slot: A
Active bootloader slot: A
num_slots: 2
slot: 0, status: normal
slot: 1, status: unbootable
Here is serial log when capsule updating:
> Update Progress - 100% **************************************************▒▒▒▒Shutdown state requested 1
> Rebooting system ...
> [0000.064] I> MB1 (version: 0.28.0.0-t234-54845784-ec016368)
> [0000.070] I> t234-A01-0-Silicon (0x12347) Prod
> [0000.074] I> Boot-mode : Coldboot
> [0000.077] I> Emulation:
> [0000.079] I> Entry timestamp: 0x00000000
> [0000.083] I> last_boot_error: 0x0
> [0000.086] I> BR-BCT: preprod_dev_sign: 0
> [0000.090] I> rst_source: 0xb, rst_level: 0x1
> [0000.094] I> Task: Bootchain select WAR set (0x5000c741)
> [0000.099] I> Active chain: 1
> [0000.102] I> Task: CRC check (0x5001dab5)
> [0000.106] I> Task: Initialize MB2 params (0x5000d78d)
> [0000.111] I> MB2-params @ 0x40060000
> [0000.115] I> Task: Crypto init (0x5001cb8d)
> [0000.119] I> Task: Secure debug controls (0x5000cd21)
> [0000.124] I> Task: strap war set (0x5000c70d)
> [0000.128] I> strap value(0x4000001) set to 0x4000001
> [0000.133] I> Task: Initialize SOC Therm (0x5001af85)
> [0000.138] I> Task: Program NV master stream id (0x5000ccd5)
> [0000.143] I> Task: Verify boot mode (0xd482021)
> [0000.149] I> Task: Alias fuses (0x500109cd)
> [0000.153] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
> [0000.160] I> Task: Print SKU type (0x5000fee1)
> [0000.165] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
> [0000.170] I> FUSE_OPT_GPC_DISABLE = 0x00000002
> [0000.174] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
> [0000.178] I> FUSE_OPT_DLA_DISABLE = 0x00000000
> [0000.183] I> FUSE_OPT_EMC_DISABLE = 0x00000000
> [0000.187] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
> [0000.191] I> FUSE_PSCROM_PATCH_VERSION = 0x7
> [0000.195] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
> [0000.199] I> FUSE_SKU_INFO_0 = 0xd3
> [0000.203] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
> [0000.207] I> FUSE_PACKAGE_INFO_0 = 0x2
> [0000.210] I> SKU: Prod
> [0000.213] I> Task: Boost clocks (0x5001462d)
> [0000.217] I> Initializing PLLC2 for AXI_CBB.
> [0000.221] I> AXI_CBB : src = 35, divisor = 0
> [0000.225] I> Task: Voltage monitor (0x50014639)
> [0000.229] I> VMON: Vmon re-calibration and fine tuning done
> [0000.235] I> Task: UPHY init (0x5000dced)
> [0000.239] W> UPHY: UPHY lane info table is empty in MB1 BCT.
> [0000.244] I> Task: Boot device init (0x50000b39)
> [0000.249] I> Boot_device: QSPI_FLASH instance: 0
> [0000.253] I> Qspi clock source : pllc_out0
> [0000.258] I> QSPI Flash: Macronix 64MB
> [0000.261] I> QSPI-0l initialized successfully
> [0000.265] I> Task: TSC init (0x5001fa6d)
> [0000.269] I> Task: Load membct (0x50011fb9)
> [0000.273] I> RAM_CODE 0x4000001
> [0000.276] I> Loading MEMBCT
> [0000.279] I> Active chain: 1
> [0000.282] I> Slot: 1
> [0000.284] I> Binary[0] block-0 (partition size: 0x40000)
> [0000.289] I> get_binary_info: Binary name: MEM-BCT-0
> [0000.294] I> Size of crypto header is 8192
> [0000.298] I> BCH load address is : 0x40050000
> [0000.302] I> Size of crypto header is 8192
> [0000.306] I> BCH of MEM-BCT-0 read from storage
> [0000.310] I> BCH address is : 0x40050000
> [0000.314] I> MEM-BCT-0 header integrity check is success
> [0000.320] I> Binary magic in BCH component 0 is MEM0
> [0000.324] I> component binary type is 0
> [0000.329] I> MEM-BCT-0 binary is read from storage
> [0000.334] I> MEM-BCT-0 binary integrity check is success
> [0000.339] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
> [0000.345] I> RAM_CODE 0x4000001
> [0000.351] I> RAM_CODE 0x4000001
> [0000.354] I> Task: Load Page retirement list (0x50011601)
> [0000.360] I> Task: SDRAM params override (0x50011f95)
> [0000.365] I> Task: Save mem-bct info (0x500147fd)
> [0000.369] I> Task: Carveout allocate (0x50014861)
> [0000.374] I> RCM blob carveout will not be allocated
> [0000.379] I> ECC region[0]: Start:0x0, End:0x0
> [0000.383] I> ECC region[1]: Start:0x0, End:0x0
> [0000.387] I> ECC region[2]: Start:0x0, End:0x0
> [0000.391] I> ECC region[3]: Start:0x0, End:0x0
> [0000.396] I> ECC region[4]: Start:0x0, End:0x0
> [0000.400] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
> [0000.406] I> Non-ECC region[1]: Start:0x0, End:0x0
> [0000.410] I> Non-ECC region[2]: Start:0x0, End:0x0
> [0000.415] I> Non-ECC region[3]: Start:0x0, End:0x0
> [0000.420] I> Non-ECC region[4]: Start:0x0, End:0x0
> [0000.429] I> allocated(CO:44) base:0x449800000 size:0x36800000 align: 0x100000
> [0000.436] I> allocated(CO:31) base:0x440000000 size:0x8000000 align: 0x8000000
> [0000.444] I> allocated(CO:43) base:0x43c000000 size:0x4000000 align: 0x200000
> [0000.451] I> allocated(CO:20) base:0x43a000000 size:0x2000000 align: 0x2000000
> [0000.458] I> allocated(CO:24) base:0x438000000 size:0x2000000 align: 0x2000000
> [0000.465] I> allocated(CO:28) base:0x436000000 size:0x2000000 align: 0x2000000
> [0000.472] I> allocated(CO:29) base:0x434000000 size:0x2000000 align: 0x2000000
> [0000.479] I> allocated(CO:22) base:0x448000000 size:0x1000000 align: 0x1000000
> [0000.486] I> allocated(CO:41) base:0x433000000 size:0x1000000 align: 0x100000
> [0000.493] I> allocated(CO:35) base:0x432200000 size:0xe00000 align: 0x10000
> [0000.500] I> allocated(CO:02) base:0x449000000 size:0x800000 align: 0x800000
> [0000.507] I> allocated(CO:03) base:0x431800000 size:0x800000 align: 0x800000
> [0000.514] I> allocated(CO:06) base:0x431000000 size:0x800000 align: 0x800000
> [0000.521] I> allocated(CO:10) base:0x430800000 size:0x800000 align: 0x800000
> [0000.528] I> allocated(CO:56) base:0x430000000 size:0x800000 align: 0x200000
> [0000.535] I> allocated(CO:07) base:0x42fc00000 size:0x400000 align: 0x400000
> [0000.541] I> allocated(CO:33) base:0x42f800000 size:0x400000 align: 0x200000
> [0000.548] I> allocated(CO:01) base:0x432100000 size:0x100000 align: 0x100000
> [0000.555] I> allocated(CO:04) base:0x432000000 size:0x100000 align: 0x100000
> [0000.562] I> allocated(CO:05) base:0x42f700000 size:0x100000 align: 0x100000
> [0000.569] I> allocated(CO:08) base:0x42f600000 size:0x100000 align: 0x100000
> [0000.576] I> allocated(CO:09) base:0x42f500000 size:0x100000 align: 0x100000
> [0000.583] I> allocated(CO:15) base:0x42f400000 size:0x100000 align: 0x100000
> [0000.590] I> allocated(CO:17) base:0x42f300000 size:0x100000 align: 0x100000
> [0000.597] I> allocated(CO:23) base:0x42f200000 size:0x100000 align: 0x100000
> [0000.604] I> allocated(CO:27) base:0x42f100000 size:0x100000 align: 0x100000
> [0000.611] I> allocated(CO:42) base:0x42f000000 size:0x100000 align: 0x100000
> [0000.618] I> allocated(CO:54) base:0x42ef80000 size:0x80000 align: 0x80000
> [0000.624] I> allocated(CO:34) base:0x42ef70000 size:0x10000 align: 0x10000
> [0000.631] I> allocated(CO:47) base:0x42ea00000 size:0x400000 align: 0x200000
> [0000.638] I> allocated(CO:72) base:0x42e800000 size:0x200000 align: 0x10000
> [0000.645] I> allocated(CO:48) base:0x42ef50000 size:0x20000 align: 0x10000
> [0000.652] I> allocated(CO:69) base:0x42ef30000 size:0x20000 align: 0x10000
> [0000.658] I> allocated(CO:49) base:0x42ef20000 size:0x10000 align: 0x10000
> [0000.665] I> allocated(CO:50) base:0x42ef10000 size:0x10000 align: 0x10000
> [0000.672] I> allocated(CO:52) base:0x42ef00000 size:0x10000 align: 0x10000
> [0000.679] I> NSDRAM base: 0x80000000, end: 0x42ef70000
> [0000.684] I> Task: Thermal check (0x500208f9)
> [0000.688] I> max_chip_limit = 105
> [0000.691] I> min_chip_limit = -28
> [0000.694] I> max temp read = 47
> [0000.697] I> min temp read = 45
> [0000.700] I> Task: Update FSI SCR with thermal fuse data (0x50020a05)
> [0000.706] I> Task: Enable WDT 5th expiry (0x50020699)
> [0000.711] I> Task: I2C register (0x50000ad9)
> [0000.715] I> Task: Reset FSI (0x50014635)
> [0000.719] I> Task: Pinmux init (0x500137bd)
> [0000.724] I> Task: Prod config init (0x50013c09)
> [0000.728] I> Task: Pad voltage init (0x50013859)
> [0000.732] I> Task: Prod init (0x50013c4d)
> [0000.736] I> Task: Common rail init (0x50014305)
> [0000.741] I> DONE: Thermal config
> [0000.745] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
> [0000.752] I> DONE: SOC rail config
> [0000.756] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
> [0000.762] I> DONE: MEMIO rail config
> [0000.766] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
> [0000.772] I> DONE: GPU rail info
> [0000.776] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
> [0000.782] I> DONE: CV rail info
> [0000.785] I> Task: Mem clock src (0x50011de5)
> [0000.789] I> Task: Misc. board config (0x500143ad)
> [0000.794] W> PMIC_CONFIG: Platform config not found in MB1 BCT.
> [0000.800] I> Task: SDRAM init (0x50011de9)
> [0000.806] I> SDRAM-params @ 0xd485000
> [0000.810] I> MSS code-drop: NvBootSdramInit
> [0000.814] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
> [0000.821] I> MSS CAR: Init PLLM
> [0000.824] I> MSS CAR: Init PLLHUB
> [0000.829] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
> [0000.840] I> mb1_sdram_init Done !
> [0000.844] I> SDRAM Size in Total 0x400000000
> [0000.848] I> Task: Dram Ecc scrub (0x50011729)
> [0000.852] I> Task: DRAM alias check (0x50011f8d)
> [0000.870] I> Task: Program NSDRAM carveout (0x50015171)
> [0000.876] I> NSDRAM carveout encryption is enabled
> [0000.881] I> Program NSDRAM carveout
> [0000.886] I> Task: Register checker (0x50011f91)
> [0000.893] I> Task: Enable clock-mon (0x5001fa5d)
> [0000.899] I> FMON: Fmon re-programming done
> [0000.904] I> Task: Mapper init (0x5001dfed)
> [0000.909] I> Task: SC7 Context Init (0x5001fd5d)
> [0000.915] I> Task: CCPLEX IST init (0x5000d561)
> [0000.921] I> Task: CPU WP0 (0x5000c7a9)
> [0000.926] I> Loading MCE
> [0000.929] I> Active chain: 1
> [0000.932] I> Slot: 1
> [0000.934] I> Binary[8] block-0 (partition size: 0x80000)
> [0000.940] I> get_binary_info: Binary name: MCE
> [0000.945] I> Size of crypto header is 8192
> [0000.950] I> BCH load address is : 0x4003e000
> [0000.955] I> Size of crypto header is 8192
> [0000.960] I> BCH of MCE read from storage
> [0000.964] I> BCH address is : 0x4003e000
> [0000.970] I> MCE header integrity check is success
> [0000.975] I> Binary magic in BCH component 0 is MTSM
> [0000.980] I> component binary type is 8
> [0000.984] I> Size of crypto header is 8192
> [0000.991] I> MCE binary is read from storage
> [0000.996] I> MCE binary integrity check is success
> [0001.001] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
> [0001.009] I> Size of crypto header is 8192
> [0001.024] I> Size of crypto header is 8192
> [0001.029] I> Sending WP0 mailbox command to PSC
> [0001.040] I> Task: XUSB Powergate (0x50000ae5)
> [0001.046] I> Skipping powergate XUSB.
> [0001.049] I> Task: MB1 fixed firewalls (0x5001f0d9)
> [0001.070] I> Task: Load bpmp-fw (0x5001f41d)
> [0001.075] I> Active chain: 1
> [0001.079] I> Slot: 1
> [0001.081] I> Binary[15] block-0 (partition size: 0x180000)
> [0001.087] I> get_binary_info: Binary name: BPMP_FW
> [0001.092] I> Size of crypto header is 8192
> [0001.097] I> BCH load address is : 0x807fe000
> [0001.102] I> Size of crypto header is 8192
> [0001.107] I> BCH of BPMP_FW read from storage
> [0001.112] I> BCH address is : 0x807fe000
> [0001.117] I> BPMP_FW header integrity check is success
> [0001.123] I> Binary magic in BCH component 0 is BPMF
> [0001.128] I> component binary type is 15
> [0001.132] I> Size of crypto header is 8192
> [0001.148] I> BPMP_FW binary is read from storage
> [0001.155] I> BPMP_FW binary integrity check is success
> [0001.160] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfdc40)
> [0001.169] I> Active chain: 1
> [0001.172] I> Slot: 1
> [0001.174] I> Binary[16] block-72976 (partition size: 0x400000)
> [0001.181] I> get_binary_info: Binary name: BPMP_FW_DTB
> [0001.187] I> Size of crypto header is 8192
> [0001.191] I> BCH load address is : 0x807fc000
> [0001.197] I> Size of crypto header is 8192
> [0001.202] I> BCH of BPMP_FW_DTB read from storage
> [0001.207] I> BCH address is : 0x807fc000
> [0001.212] I> BPMP_FW_DTB header integrity check is success
> [0001.218] I> Binary magic in BCH component 0 is BPMD
> [0001.223] I> component binary type is 16
> [0001.227] I> Size of crypto header is 8192
> [0001.234] I> BPMP_FW_DTB binary is read from storage
> [0001.240] I> BPMP_FW_DTB binary integrity check is success
> [0001.245] I> Binary BPMP_FW_DTB loaded successfully at 0x807dbff0 (0x1fe80)
> [0001.254] I> Task: Load psc-fw (0x5001f5a5)
> [0001.260] I> Active chain: 1
> [0001.263] I> Slot: 1
> [0001.265] I> Binary[17] block-0 (partition size: 0xc0000)
> [0001.271] I> get_binary_info: Binary name: PSC_FW
> [0001.277] I> Size of crypto header is 8192
> [0001.281] I> BCH load address is : 0x80ffe000
> [0001.287] I> Size of crypto header is 8192
> [0001.291] I> BCH of PSC_FW read from storage
> [0001.296] I> BCH address is : 0x80ffe000
> [0001.302] I> PSC_FW header integrity check is success
> [0001.307] I> Binary magic in BCH component 0 is PFWP
> [0001.312] I> component binary type is 17
> [0001.316] I> Size of crypto header is 8192
> [0001.325] I> PSC_FW binary is read from storage
> [0001.331] I> PSC_FW binary integrity check is success
> [0001.336] I> Binary PSC_FW loaded successfully at 0x80000000 (0x59980)
> [0001.345] I> Task: Load nvdec-fw (0x5001f619)
> [0001.350] I> Active chain: 1
> [0001.353] I> Slot: 1
> [0001.356] I> Binary[7] block-0 (partition size: 0x100000)
> [0001.362] I> get_binary_info: Binary name: NVDEC
> [0001.367] I> Size of crypto header is 8192
> [0001.372] I> BCH load address is : 0x800fe000
> [0001.377] I> Size of crypto header is 8192
> [0001.382] I> BCH of NVDEC read from storage
> [0001.386] I> BCH address is : 0x800fe000
> [0001.392] I> NVDEC header integrity check is success
> [0001.397] I> Binary magic in BCH component 0 is NDEC
> [0001.403] I> component binary type is 7
> [0001.407] I> Size of crypto header is 8192
> [0001.414] I> NVDEC binary is read from storage
> [0001.420] I> NVDEC binary integrity check is success
> [0001.425] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
> [0001.436] I> Task: Load tsec-fw (0x5001f9a5)
> [0001.441] I> TSEC-FW load support not enabled
> [0001.446] I> Task: GPIO interrupt map (0x50014541)
> [0001.452] I> Task: SC7 context save (0x5001fe9d)
> [0001.458] I> NV_SC7 Context addr: 0xa0000000
> [0001.464] I> Active chain: 1
> [0001.467] I> Slot: 1
> [0001.469] I> Binary[27] block-0 (partition size: 0x100000)
> [0001.475] I> get_binary_info: Binary name: BR_BCT
> [0001.480] I> Size of crypto header is 8192
> [0001.485] I> Size of crypto header is 8192
> [0001.490] I> BR_BCT binary is read from storage
> [0001.495] I> BR_BCT binary integrity check is success
> [0001.501] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
> [0001.508] I> Active chain: 1
> [0001.512] I> Slot: 1
> [0001.514] I> Binary[13] block-0 (partition size: 0x30000)
> [0001.520] I> get_binary_info: Binary name: SC7-FW
> [0001.525] I> Size of crypto header is 8192
> [0001.530] I> Size of crypto header is 8192
> [0001.534] I> BCH load address is : 0xa0002000
> [0001.540] I> Size of crypto header is 8192
> [0001.545] I> BCH of SC7-FW read from storage
> [0001.549] I> BCH address is : 0xa0002000
> [0001.555] I> SC7-FW header integrity check is success
> [0001.560] I> Binary magic in BCH component 0 is WB0B
> [0001.565] I> component binary type is 13
> [0001.569] I> Size of crypto header is 8192
> [0001.576] I> SC7-FW binary is read from storage
> [0001.581] I> SC7-FW binary integrity check is success
> [0001.587] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x26220)
> [0001.595] I> Active chain: 1
> [0001.598] I> Slot: 1
> [0001.600] I> Binary[22] block-0 (partition size: 0x30000)
> [0001.606] I> get_binary_info: Binary name: PSC_RF
> [0001.612] I> Size of crypto header is 8192
> [0001.616] I> Size of crypto header is 8192
> [0001.621] I> BCH load address is : 0xa002a220
> [0001.626] I> Size of crypto header is 8192
> [0001.631] I> BCH of PSC_RF read from storage
> [0001.636] I> BCH address is : 0xa002a220
> [0001.641] I> PSC_RF header integrity check is success
> [0001.647] I> Binary magic in BCH component 0 is PSCR
> [0001.652] I> component binary type is 22
> [0001.656] I> Size of crypto header is 8192
> [0001.662] I> PSC_RF binary is read from storage
> [0001.667] I> PSC_RF binary integrity check is success
> [0001.673] I> Binary PSC_RF loaded successfully at 0xa002c220 (0x1b000)
> [0001.695] I> Active chain: 1
> [0001.698] I> Slot: 1
> [0001.701] I> Binary[14] block-0 (partition size: 0x20000)
> [0001.707] I> get_binary_info: Binary name: MB2_RF
> [0001.712] I> Size of crypto header is 8192
> [0001.716] I> Size of crypto header is 8192
> [0001.721] I> BCH load address is : 0xa008ea48
> [0001.726] I> Size of crypto header is 8192
> [0001.731] I> BCH of MB2_RF read from storage
> [0001.736] I> BCH address is : 0xa008ea48
> [0001.741] I> MB2_RF header integrity check is success
> [0001.747] I> Binary magic in BCH component 0 is MB2R
> [0001.752] I> component binary type is 14
> [0001.756] I> Size of crypto header is 8192
> [0001.762] I> MB2_RF binary is read from storage
> [0001.768] I> MB2_RF binary integrity check is success
> [0001.773] I> Binary MB2_RF loaded successfully at 0xa0090a48 (0x1bfa0)
> [0001.782] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
> [0001.790] I> SC7 context fuse-bypass data is empty
> [0001.798] I> SC7 context save done
> [0001.802] I> Task: Load MB2/Applet/FSKP (0x5000d691)
> [0001.808] I> Loading MB2
> [0001.811] I> Active chain: 1
> [0001.814] I> Slot: 1
> [0001.816] I> Binary[6] block-0 (partition size: 0x80000)
> [0001.822] I> get_binary_info: Binary name: MB2
> [0001.827] I> Size of crypto header is 8192
> [0001.832] I> BCH load address is : 0x8007e000
> [0001.837] I> Size of crypto header is 8192
> [0001.842] I> BCH of MB2 read from storage
> [0001.847] I> BCH address is : 0x8007e000
> [0001.852] I> MB2 header integrity check is success
> [0001.857] I> Binary magic in BCH component 0 is MB2B
> [0001.862] I> component binary type is 6
> [0001.867] I> Size of crypto header is 8192
> [0001.876] I> MB2 binary is read from storage
> [0001.882] I> MB2 binary integrity check is success
> [0001.887] I> Binary MB2 loaded successfully at 0x80000000 (0x68e00)
> [0001.895] I> Task: Map CCPLEX SHARED carveout (0x5000d835)
> [0001.902] I> Task: Prepare MB2 params (0x5000d8f1)
> [0001.910] I> BR-BCT Boot Chain Fields
> [0001.914] I> u32_non_gpio_select_boot_chain : 1
> [0001.919] I> u32_num_boot_chains : 2
> [0001.924] I> bf_bl_gpio_select_boot_chain_1b : 0
> [0001.930] I> Task: Program misc carveouts (0x50014bcd)
> [0001.936] I> Program IPC carveouts
> [0001.944] I> Task: Dram ecc test (0x500117a5)
> [0001.949] I> Task: Misc NV security settings (0x5000d0f9)
> [0001.956] I> NVDEC sticky bits programming done
> [0001.961] I> Successfully powergated NVDEC
> [0001.965] I> Task: Disable/Reload WDT (0x500206e1)
> [0001.971] I> Programmed SLCG global override := 0x0
> [0001.976] I> MB1: MSS reconfig completed
> I> MB2 (version: 0.0.0.0-t234-54845784-a9c0116a)
> I> Emulation:
> I> Entry timestamp: 0x001eb94a
> I> Regular heap: [base:0x40040000, size:0x10000]
> I> DMA heap: [base:0x430000000, size:0x800000]
> I> Task: ARI update carveout TZDRAM (0x50001e80)
> I> Task: Enable hot-plug capability (0x50025b5c)
> I> Task: PSC mailbox init (0x50015c10)
> I> Task: Crypto init (0x5000573c)
> I> Task: Enable GP-SE clock (0x50001fe4)
> I> Task: DICE Identity init (0x50018fcc)
> I> DICE is not enabled.
> I> Task: OEM SC7 context save init (0x500186cc)
> I> Task: I2C register (0x50001e44)
> I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001e2c)
> I> Task: Boot device init (0x50001d74)
> E> Error in command_complete 18001 int_status
> E> Sending CMD_SD_SEND_IF_COND failed
> E> Error opening sdcard-0
> E> Failed to initialize device 6-0
> C> Storage init failed
> C> Task 0x0 failed (err: 0x39390706)
> E> Top caller module: SDMMC, error module: SDMMC, reason: 0x06, aux_info: 0x07
> I> Busy Spin
> Blockquote
