您好,我使用ORIN NX16g,定制化载板,无法烧录36.3的镜像,总是会卡在Waiting for target to boot-up…,但是烧录35.3.1是正常的,烧录信息如下:
donnie@donnie:~/36.3/Linux_for_Tegra$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 --flash-only -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
/home/donnie/36.3/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 2-1 --device-instance 0 --flash-only --external-device nvme0n1p1 -c "tools/kernel_flash/flash_l4t_t234_nvme.xml" --network usb0 jetson-orin-nano-devkit internal
# Entry added by NVIDIA initrd flash tool
/home/donnie/36.3/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
Export list for localhost:
* Step 1: Build the flashing environment *
Create flash environment 0
/home/donnie/36.3/Linux_for_Tegra/bootloader /home/donnie/36.3/Linux_for_Tegra
Finish creating flash environment 0.
* Step 2: Boot the device with flash initrd image *
/home/donnie/36.3/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/donnie/36.3/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3768-0000+p3767-0000-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3768-0000+p3767-0000-nv.dtb" --bct_backup --instance 2-1
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0515 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0515 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0515 ] rcm boot with presigned binaries
[ 0.0520 ] tegrarcm_v2 --instance 2-1 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0523 ] BR_CID: 0x80012344705DD2420C000000100000C0
[ 0.0663 ] Sending bct_br
[ 0.0767 ] Sending mb1
[ 0.0776 ] Sending psc_bl1
[ 0.0986 ] Sending bct_mb1
[ 0.1107 ] Generating blob for T23x
[ 0.1121 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.1124 ] The number of images in blob is 19
[ 0.1132 ] blobsize is 96568973
[ 0.1136 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3563584
[ 0.1689 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[ 0.1704 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[ 0.1715 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[ 0.1723 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[ 0.1732 ] Not supported type: mb2_applet
[ 0.1736 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 439968
[ 0.1750 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.1759 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[ 0.1782 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12065168
[ 0.1901 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.1937 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1027008
[ 0.1977 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 383232
[ 0.1992 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[ 0.2014 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 414976
[ 0.2023 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.2026 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1633344
[ 0.2036 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.2053 ] Added binary blob_boot0.img of size 72480768
[ 0.2727 ] Added binary blob_tegra234-p3768-0000+p3767-0000-nv.dtb of size 244109
[ 0.3779 ] tegrarcm_v2 --instance 2-1 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.3784 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[ 0.3953 ] Sending bct_mem
[ 0.4052 ] Sending blob
[ 7.9195 ] RCM-boot started
* Step 3: Start the flashing process *
Waiting for target to boot-up...
Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Cleaning up...
