Orin NX - Flashing Problems
Hi All
I’ve tried everything I can think of to flash an Orin NX module using a Seeed Studio reComputer 401 carrier board although I’m having no luck. Based on the instructions provided, this should follow the standard command line flashing process for the Orin NX.
I’m fairly confident it’s not the storage device as the flashing process isn’t getting that far. It seems to stop at the point of booting into the initrd for flashing. I’ve tried through the SDK Manager too with the same result.
I have tried different cables although I’m using the same cable as I did for the Orin AGX DevKit, official Nvidia cable, which worked just fine. I have tried other USB ports and computers with the exact same results suggesting it is most likely board/module related.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 p3509-a02+p3767-0000 internal
*  Step 2: Boot the device with flash initrd image *
/home/wj88/recomputer/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/wj88/recomputer/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --bldtb tegra234-p3767-0000-p3509-a02.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3767-0000-p3509-a02.dtb"    --secondary_gpt_backup  --bct_backup  --boot_chain A  --instance 1-1
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
 Entering RCM boot
[   0.0388 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0388 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0388 ] rcm boot with presigned binaries
[   0.0393 ] tegrarcm_v2 --instance 1-1 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0399 ] BR_CID: 0x80012344705DD1438800000009FF8280
[   0.0415 ] Sending bct_br
[   0.0417 ] Sending mb1
[   0.0424 ] Sending psc_bl1
[   0.0554 ] Sending bct_mb1
[   0.0631 ] Generating blob for T23x
[   0.0646 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0651 ] The number of images in blob is 18
[   0.0653 ] blobsize is 73437437
[   0.0654 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3182656
[   0.0787 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[   0.0791 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[   0.0794 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[   0.0796 ] Not supported type: mb2_applet
[   0.0797 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 437984
[   0.0800 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164352
[   0.0803 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[   0.0839 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.0844 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1048000
[   0.0851 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 138880
[   0.0855 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[   0.0858 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[   0.0862 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[   0.0865 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.0867 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1064752
[   0.0870 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.0874 ] Added binary blob_boot0.img of size 55435264
[   0.1101 ] Added binary blob_tegra234-p3767-0000-p3509-a02.dtb of size 344461
[   0.1742 ] tegrarcm_v2 --instance 1-1 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   0.1749 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[   0.2928 ] Sending bct_mem
[   0.2930 ] Sending blob
[   0.3973 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --instance 1-1 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Cleaning up...
[0112.380] I> MB1 (version: 0.32.0.0-t234-54845784-57325615)
[0112.385] I> t234-A01-0-Silicon (0x12347) Prod
[0112.389] I> Boot-mode : Coldboot
[0112.392] I> Emulation:
[0112.395] I> Entry timestamp: 0x00000000
[0112.398] I> last_boot_error: 0x0
[0112.402] I> BR-BCT: preprod_dev_sign: 0
[0112.405] I> rst_source: 0xb, rst_level: 0x1
[0112.409] I> Task: Bootchain select WAR set (0x5000ba65)
[0112.415] I> Task: Enable SLCG (0x5000bab1)
[0112.419] I> Task: CRC check (0x5001ea19)
[0112.423] I> Task: Initialize MB2 params (0x5000cb51)
[0112.428] I> MB2-params @ 0x40060000
[0112.431] I> Task: Crypto init (0x5001d981)
[0112.436] I> Task: Secure debug controls (0x5000c0a9)
[0112.441] I> Task: strap war set (0x5000ba2d)
[0112.445] I> Task: Initialize SOC Therm (0x5001bd35)
[0112.450] I> Task: Program NV master stream id (0x5000c05d)
[0112.455] I> Task: Verify boot mode (0xd4820f1)
[0112.461] I> Task: Alias fuses (0x5001095d)
[0112.465] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0112.472] I> Task: Print SKU type (0x5000f5f1)
[0112.477] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0112.482] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0112.486] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0112.491] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0112.495] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0112.499] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0112.504] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0112.508] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0112.512] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0112.517] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0112.521] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0112.525] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0112.529] I> FUSE_SKU_INFO_0 = 0xd3
[0112.532] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0112.536] I> FUSE_PACKAGE_INFO_0 = 0x2
[0112.540] I> SKU: Prod
[0112.542] I> Task: Boost clocks (0x500148a1)
[0112.546] I> Initializing PLLC2 for AXI_CBB.
[0112.551] I> AXI_CBB : src = 35, divisor = 0
[0112.555] I> Task: Voltage monitor (0x50014b49)
[0112.559] I> VMON: Vmon re-calibration and fine tuning done
[0112.564] I> Task: UPHY init (0x5000d065)
[0112.570] I> HSIO UPHY init done
[0112.574] E> Skipping GBE UPHY config
[0112.577] I> Task: Boot device init (0x50000be9)
[0112.582] I> Boot_device: RCM
[0112.585] I> USB configuration success
[0112.588] I> Task: TSC init (0x50020a4d)
[0112.592] I> Task: Load membct (0x50011fe9)
[0112.596] I> RAM_CODE 0x4000001
[0112.599] I> Loading MEMBCT
[0112.602] I> Slot: 0
[0112.604] I> Binary[0] block-0 (partition size: 0x40000)
[0112.609] I>  get_binary_info: Binary name: MEM-BCT-0
[0112.614] I> Size of crypto header is 8192
[0112.618] I> BCH load address is : 0x40050000
[0112.622] I> Size of crypto header is 8192
[0112.626] I> BCH of MEM-BCT-0 read from storage
[0112.631] I> BCH address is : 0x40050000
[0112.635] I> MEM-BCT-0 header integrity check is success
[0112.640] I> Binary magic in BCH component 0 is MEM0
[0112.645] I> component binary type is 0
[0112.656] I> MEM-BCT-0 binary is read from storage
[0112.661] I> MEM-BCT-0 binary integrity check is success
[0112.666] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0112.672] I> RAM_CODE 0x4000001
[0112.678] I> RAM_CODE 0x4000001
[0112.681] I> Task: Load Page retirement list (0x500115b1)
[0112.687] I> Task: SDRAM params override (0x50011fc5)
[0112.692] I> Task: Save mem-bct info (0x50014fa1)
[0112.696] I> Task: Carveout allocate (0x50015005)
[0112.701] I> ECC region[0]: Start:0x0, End:0x0
[0112.705] I> ECC region[1]: Start:0x0, End:0x0
[0112.709] I> ECC region[2]: Start:0x0, End:0x0
[0112.714] I> ECC region[3]: Start:0x0, End:0x0
[0112.718] I> ECC region[4]: Start:0x0, End:0x0
[0112.722] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0112.728] I> Non-ECC region[1]: Start:0x0, End:0x0
[0112.733] I> Non-ECC region[2]: Start:0x0, End:0x0
[0112.737] I> Non-ECC region[3]: Start:0x0, End:0x0
[0112.742] I> Non-ECC region[4]: Start:0x0, End:0x0
[0112.752] I> allocated(CO:31) base:0x478000000 size:0x8000000 align: 0x8000000
[0112.759] I> allocated(CO:43) base:0x474000000 size:0x4000000 align: 0x200000
[0112.766] I> allocated(CO:20) base:0x472000000 size:0x2000000 align: 0x2000000
[0112.773] I> allocated(CO:24) base:0x470000000 size:0x2000000 align: 0x2000000
[0112.780] I> allocated(CO:28) base:0x46e000000 size:0x2000000 align: 0x2000000
[0112.787] I> allocated(CO:22) base:0x46d000000 size:0x1000000 align: 0x1000000
[0112.794] I> allocated(CO:35) base:0x46c200000 size:0xe00000 align: 0x10000
[0112.801] I> allocated(CO:02) base:0x46b800000 size:0x800000 align: 0x800000
[0112.808] I> allocated(CO:03) base:0x46b000000 size:0x800000 align: 0x800000
[0112.815] I> allocated(CO:06) base:0x46a800000 size:0x800000 align: 0x800000
[0112.822] I> allocated(CO:10) base:0x46a000000 size:0x800000 align: 0x800000
[0112.829] I> allocated(CO:56) base:0x469800000 size:0x800000 align: 0x200000
[0112.836] I> allocated(CO:07) base:0x469400000 size:0x400000 align: 0x400000
[0112.843] I> allocated(CO:33) base:0x469000000 size:0x400000 align: 0x200000
[0112.850] I> allocated(CO:23) base:0x46c000000 size:0x200000 align: 0x200000
[0112.856] I> allocated(CO:01) base:0x468f00000 size:0x100000 align: 0x100000
[0112.863] I> allocated(CO:04) base:0x468e00000 size:0x100000 align: 0x100000
[0112.870] I> allocated(CO:05) base:0x468d00000 size:0x100000 align: 0x100000
[0112.877] I> allocated(CO:08) base:0x468c00000 size:0x100000 align: 0x100000
[0112.884] I> allocated(CO:09) base:0x468b00000 size:0x100000 align: 0x100000
[0112.891] I> allocated(CO:15) base:0x468a00000 size:0x100000 align: 0x100000
[0112.898] I> allocated(CO:17) base:0x468900000 size:0x100000 align: 0x100000
[0112.905] I> allocated(CO:27) base:0x468800000 size:0x100000 align: 0x100000
[0112.912] I> allocated(CO:42) base:0x468700000 size:0x100000 align: 0x100000
[0112.919] I> allocated(CO:54) base:0x468680000 size:0x80000 align: 0x80000
[0112.926] I> allocated(CO:34) base:0x468670000 size:0x10000 align: 0x10000
[0112.932] I> allocated(CO:46) base:0x440000000 size:0x20000000 align: 0x20000000
[0112.940] I> allocated(CO:47) base:0x468200000 size:0x400000 align: 0x200000
[0112.947] I> allocated(CO:72) base:0x468000000 size:0x200000 align: 0x10000
[0112.953] I> allocated(CO:48) base:0x468650000 size:0x20000 align: 0x10000
[0112.960] I> allocated(CO:69) base:0x468630000 size:0x20000 align: 0x10000
[0112.967] I> allocated(CO:49) base:0x468620000 size:0x10000 align: 0x10000
[0112.974] I> allocated(CO:50) base:0x468610000 size:0x10000 align: 0x10000
[0112.980] I> NSDRAM base: 0x80000000, end: 0x468670000
[0112.985] I> Task: Thermal check (0x50021d55)
[0112.990] I> max_chip_limit = 105
[0112.993] I> min_chip_limit = -28
[0112.996] I> max temp read = 47
[0112.999] I> min temp read = 46
[0113.002] I> Task: Update FSI SCR with thermal fuse data (0x50021e61)
[0113.008] I> Task: Enable WDT 5th expiry (0x50021a41)
[0113.013] I> Task: I2C register (0x50000b85)
[0113.017] I> Task: Reset FSI (0x500148b1)
[0113.021] I> Task: Pinmux init (0x5001397d)
[0113.025] I> skipped mmio_addr = 0x9240008
[0113.029] I> skipped mmio_addr = 0x9240000
[0113.033] I> skipped mmio_addr = 0x9240010
[0113.037] I> skipped mmio_addr = 0x9240018
[0113.041] I> skipped mmio_addr = 0x9240020
[0113.045] I> skipped mmio_addr = 0x9240030
[0113.049] I> skipped mmio_addr = 0x9240028
[0113.053] I> skipped mmio_addr = 0x9240038
[0113.057] I> skipped mmio_addr = 0x9240040
[0113.061] I> skipped mmio_addr = 0x9240048
[0113.065] I> skipped mmio_addr = 0x9241000
[0113.069] I> skipped mmio_addr = 0x9241008
[0113.073] I> skipped mmio_addr = 0x9241010
[0113.077] I> skipped mmio_addr = 0x9241018
[0113.080] I> skipped mmio_addr = 0x9241020
[0113.084] I> skipped mmio_addr = 0x9241028
[0113.088] I> skipped mmio_addr = 0x9241030
[0113.092] I> skipped mmio_addr = 0x9241038
[0113.096] I> skipped mmio_addr = 0x9241040
[0113.100] I> skipped mmio_addr = 0x9242000
[0113.104] I> skipped mmio_addr = 0x9242008
[0113.108] I> Task: Prod config init (0x50013ddd)
[0113.112] I> Task: Pad voltage init (0x50013a2d)
[0113.117] I> Task: Prod init (0x50013e21)
[0113.121] I> Task: Common rail init (0x50014575)
[0113.125] I> DONE: Thermal config
[0113.129] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0113.137] I> DONE: SOC rail config
[0113.141] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0113.147] I> DONE: MEMIO rail config
[0113.151] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0113.157] I> DONE: GPU rail info
[0113.161] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0113.167] I> DONE: CV rail info
[0113.170] I> Task: Mem clock src (0x50011de9)
[0113.174] I> Task: Misc. board config (0x5001461d)
[0113.180] W> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0113.185] I> Task: SDRAM init (0x50011ded)
[0113.189] I> SDRAM-params @ 0xd485000
[0113.193] I> MemoryType: 4 MemBctRevision: 1
[0113.199] I> MSS code-drop: NvBootSdramInit
[0113.204] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0113.211] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0113.218] I> MSS CAR: Init PLLM
[0113.221] I> MSS CAR: Init PLLHUB
[0113.226] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
Interestingly the serial output ends at the Encryption line. I’ve seen other outputs on this forum that continue to “mb1_sdram_init Done !” but mine doesn’t. No sure if this is a clue.
Booting the board without recovery produces no output on either HDMI or serial.
Any help would be appreciated.
Please dump the serial console log when your flash got failure.
Your current serial console log looks more like a boot log but not flash log.
I had the same issue solved by replacing all mmcblk0 references with nvme0n1 in all files in Linux_for_Tegra
It actually depends on which boot drive you want to use to boot up.
This is the exact serial output produced when executing the command identified in the post. There is no further output from the serial console.
I’ll give this a try…
Is this Orin NX 16GB module or 8GB module?
Orin NX 16GB.
Do you have other modules or NV devkit that can do the cross validation here?
Afraid not, I have an Orin AGX devkit that I’ve been using to prototype with but we were hoping to switch to the Orin NX.
I cannot tell if this is module problem or if there is really some kind of weird trick to modify nvme0n1 to mmcblk0 in config file.
It actually does not make any sense to me. However, since I don’t know the detail about a custom board. Maybe there is something else that make that trick to work.
The best way to validate this is put your module to Orin Nano devkit or xavier nx devkit and do flash. If that fails too, then please RMA this module.
Ok. I’ll look at procuring the devkit.
The main difference between the two carrier boards seems to be a lack of SD slot on the reComputer J401. I have now attempted a find/replace on all instances of mmcblk0 to nvme0n1, as suggested by @yaniv.nahum but it hasn’t changed the outcome.
Yes, actually no need to do that and no one has ever did that before to make something work…
Just wonder, could you put your serial console on again and just power on the board and see what got printed?
Actually the serial console shall print log in almost every situation. Even boot failure case would get log printed in the beginning. Your previous comment said there was nothing sounds a little weird.
Just a reminder that you have to enable the console before you power on the board.
I’ve just tried again.
Literally nothing prints via the serial console when powering on with or without being in recovery. The only time content is printed is when l4t_initrd_flash.sh is running.
For completeness, I’m attaching the logs from both executing the command and the serial console.
command.log (244.8 KB)
console.log (34.4 KB)
Your log was not completed in the first comment. Now it has the full one.
E> OCR failed, error = 39390706
E> Failed to open sdmmc-3, err = 39390706
W> Ignoring init failure for device 0-3
E> Error in command_complete 18000 int_status
W> Ignoring init failure for device 1-3
E> Unknown device 7
E> Unknown device 8
I> Task: Partition Manager Init (0x40002d25)
W> Cannot find any partition table for 00030000
PARTITION_MANAGER: Failed to publish partition.
I> Task: I2C register (0x400006a5)
I> Task: Register exit handlers (0x400005f5)
I> Task: Enter 3p server (0x400018e9)
I> Populate chip info
I> RAM_CODE 0x4000401
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> dump bct
I> Rebooting : reboot-recovery
And then it looks like your board reboot after above line. The flash process only ran until Rebooting : reboot-recovery got printed.
Could you try below command by using flash.sh instead of initrd flash tool and see what got printed in serial console?
sudo ./flash.sh -c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg p3509-a02+p3767-0000 nvme0n1p1
Also, remember to put board into recovery mode before doing this.
That was the output when generating the flash packages. I assume this is to read data from the module to inform the package generation? This also occurs in the --no-flash scenario.
After the packages are created, and you reach the Step 2: Boot the device with flash initrd image, this is when the serial output I originally provided occurs. It is reproduced with the --flash-only argument.
As suggestion, I’ve trying the flash.sh command. Same error with the complete output below.
Command:
wj88@ubuntu-home:~/recomputer/Linux_for_Tegra$ sudo ./flash.sh -c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg p3509-a02+p3767-0000 nvme0n1p1
[sudo] password for wj88:
# L4T BSP Information:
# R35 , REVISION: 3.1
# User release: 0.0
# Target Board Information:
# Name: p3509-a02+p3767-0000, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/wj88/recomputer/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
version 1.0.0
[   0.0284 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0296 ] File rcm_state open failed
[   0.0301 ] ERROR: failed to read rcm_state
[   0.0301 ]
[   0.0327 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0329 ] Assuming zero filled SBK key
[   0.0305 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.0440 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.0595 ] Parsing partition layout
[   0.0614 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0645 ] Kernel DTB used: None
[   0.0646 ] WARNING: dce base dtb is not provided
[   0.0646 ] Parsing partition layout
[   0.0661 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0683 ] Creating list of images to be signed
[   0.0702 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0713 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0737 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0740 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0806 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0811 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0877 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0882 ] adding BCH for mb2_t234_aligned.bin
[   0.0918 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1062 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.1067 ] adding BCH for mb2_t234_aligned.bin
[   0.1232 ] Filling MB1 storage info
[   0.1233 ] Parsing dev params for multi chains
[   0.1311 ] Generating br-bct
[   0.1331 ] Updating dev and MSS params in BR BCT
[   0.1333 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1363 ] Updating bl info
[   0.1380 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.1392 ] WARNING: boot chain is not completed. set to 0
[   0.1402 ] Generating signatures
[   0.1428 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1431 ] Assuming zero filled SBK key
[   0.1646 ] Warning: pub_key.key is not found
[   0.1624 ] Parsing dev params for multi chains
[   0.1624 ] Generating br-bct
[   0.1637 ] Updating dev and MSS params in BR BCT
[   0.1639 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1659 ] Updating bl info
[   0.1674 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.1687 ] WARNING: boot chain is not completed. set to 0
[   0.1708 ] Get Signed section of bct
[   0.1723 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.1737 ] Signing BCT
[   0.1764 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1766 ] Assuming zero filled SBK key
[   0.1809 ] Sha saved in br_bct_BR.sha
[   0.1813 ] Warning: pub_key.key is not found
[   0.1788 ] Updating BCT with signature
[   0.1800 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.1815 ] Offset :4608 Len :3584
[   0.1820 ] Generating SHA2 Hash
[   0.1846 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.1848 ] Assuming zero filled SBK key
[   0.1849 ] Assuming zero filled SBK key
[   0.1884 ] Sha saved in br_bct_BR.sha
[   0.1863 ] Updating BCT with SHA2 Hash
[   0.1876 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.1885 ] Offset :4608 Len :3584
[   0.1888 ] Offset :68 Len :8124
[   0.1891 ] Generating coldboot mb1-bct
[   0.1901 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1910 ] MB1-BCT version: 0.10
[   0.1912 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.1918 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.1921 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.1924 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.1928 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.1931 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.1933 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   0.1933 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   0.1933 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   0.1933 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   0.1933 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   0.1933 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   0.1933 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   0.1933 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   0.1933 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   0.1933 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   0.1934 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   0.1934 ]
[   0.1934 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1934 ] Added Platform Config 9 data with size :- 100
[   0.1934 ]
[   0.1934 ] Updating mb1-bct with firmware information
[   0.1945 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1976 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.1997 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.2006 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.2042 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2044 ] Assuming zero filled SBK key
[   0.2063 ] Warning: pub_key.key is not found
[   0.2051 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.2067 ] Generating recovery mb1-bct
[   0.2077 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.2086 ] MB1-BCT version: 0.10
[   0.2087 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.2092 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.2095 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.2099 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.2102 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.2106 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.2106 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   0.2106 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   0.2106 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   0.2106 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   0.2106 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   0.2106 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   0.2106 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   0.2106 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   0.2106 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   0.2106 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   0.2106 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   0.2106 ]
[   0.2106 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.2106 ] Added Platform Config 9 data with size :- 100
[   0.2107 ]
[   0.2107 ] Updating mb1-bct with firmware information
[   0.2117 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.2154 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.2186 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.2201 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.2239 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2243 ] Assuming zero filled SBK key
[   0.2268 ] Warning: pub_key.key is not found
[   0.2257 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.2276 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.2277 ] Copying signatures
[   0.2288 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.2359 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.2362 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.2362 ] Boot Rom communication
[   0.2377 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.2388 ] BR_CID: 0x80012344705DD1438800000009FF8280
[   0.2398 ] Sending bct_br
[   0.2400 ] Sending mb1
[   0.2402 ] Sending psc_bl1
[   0.2504 ] Sending bct_mb1
[   0.2560 ] Boot Rom communication completed
[   0.2594 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.2625 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.2638 ] adding BCH for applet_t234_aligned.bin
[   0.2818 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2822 ] Assuming zero filled SBK key
[   0.2874 ] Warning: pub_key.key is not found
[   0.2870 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.2894 ] Sending mb2_applet...
[   0.2907 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.2919 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[   0.4671 ] Sending applet
[   0.5784 ] completed
[   0.5805 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.5821 ] MB2 Applet version 01.00.0000
[   0.7934 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.7949 ] MB2 Applet version 01.00.0000
[   0.7993 ] Retrieving board information
[   0.8012 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   0.8031 ] MB2 Applet version 01.00.0000
[   0.8053 ] Saved platform info in chip_info.bin
[   0.8106 ] Chip minor revision: 1
[   0.8107 ] Bootrom revision: 0x7
[   0.8108 ] Ram code: 0x0
[   0.8109 ] Chip sku: 0xd3
[   0.8110 ] Chip Sample: prod
[   0.8117 ] Retrieving EEPROM data
[   0.8117 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/wj88/recomputer/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   0.8129 ] MB2 Applet version 01.00.0000
[   0.8152 ] Saved platform info in /home/wj88/recomputer/Linux_for_Tegra/bootloader/cvm.bin
[   0.8500 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.8519 ] MB2 Applet version 01.00.0000
[   0.8558 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.8569 ] MB2 Applet version 01.00.0000
[   0.8590 ] Dumping customer Info
[   0.8604 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   0.8616 ] MB2 Applet version 01.00.0000
[   0.8638 ] Saved bct in tmp.bct
[   0.8736 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/wj88/recomputer/Linux_for_Tegra/bootloader/custinfo_out.bin
[   0.8752 ] C[   0.8757 ] ustomer data saved in /home/wj88/recomputer/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[   0.8759 ] Rebooting to recovery mode
[   0.8775 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   0.8834 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.8854 ] MB2 Applet version 01.00.0000
[   0.8880 ] Booting to recovery mode
[   0.8897 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[   0.8908 ] MB2 Applet version 01.00.0000
Board ID(3767) version(300) sku(0000) revision(J.1)
Chip SKU(00:00:00:D3) ramcode(00:00:00:00) fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
Copy /home/wj88/recomputer/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3509-a02.dtb to /home/wj88/recomputer/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3509-a02.dtb.rec
copying bctfile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0000-sdram-l4t.dts)... done.
copying minratchet_config(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
copying pinmux_config(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi)... done.
copying gpioint_config(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3767-hdmi-a03.dtsi)... done.
copying deviceprod_config(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0000-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
Existing uphylane_config(/home/wj88/recomputer/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/wj88/recomputer/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing mb2applet(/home/wj88/recomputer/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/wj88/recomputer/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/wj88/recomputer/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/wj88/recomputer/Linux_for_Tegra/bootloader/ramdisk_tmp /home/wj88/recomputer/Linux_for_Tegra/bootloader /home/wj88/recomputer/Linux_for_Tegra
39726 blocks
gzip: /home/wj88/recomputer/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.104-tegra
56174 blocks
Making Recovery image...
copying recdtbfile(/home/wj88/recomputer/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3509-a02.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000165565 s, 121 kB/s
Existing sosfile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/wj88/recomputer/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/wj88/recomputer/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing dcefile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/wj88/recomputer/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/wj88/recomputer/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/wj88/recomputer/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
copying bpfdtbfile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3767-0000-a02-3509-a02.dtb)... done.
Existing scefile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/wj88/recomputer/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/wj88/recomputer/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/wj88/recomputer/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3509-a02.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.437006 s, 154 MB/s
	Sync'ing esp.img ... done.
copying tbcdtbfile(/home/wj88/recomputer/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3509-a02.dtb)... done.
copying cfgfile(/home/wj88/recomputer/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi.xml) to flash.xml... done.
Existing flashapp(/home/wj88/recomputer/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/wj88/recomputer/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/wj88/recomputer/Linux_for_Tegra/kernel/dtb/tegra234-p3767-overlay.dtbo)... done.
./tegraflash.py  --bl uefi_jetson_with_dtb.bin  --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0  --overlay_dtb L4TConfiguration.dtbo,tegra234-p3767-overlay.dtbo,  --bldtb tegra234-p3767-0000-p3509-a02.dtb --applet mb1_t234_prod.bin --cmd "flash; reboot"  --cfg flash.xml --chip 0x23 --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-hdmi-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0000-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts  --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02.dtb; sce_fw camera-rtcpu-sce.img; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img"  --sdram_config tegra234-p3767-0000-sdram-l4t.dts  --cust_info custinfo_out.bin  --secondary_gpt_backup  --bct_backup  --boot_chain A
saving flash command in /home/wj88/recomputer/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/wj88/recomputer/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[   0.0289 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0290 ] Assuming zero filled SBK key
[   0.0273 ] Parsing partition layout
[   0.0286 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0369 ] Change tegra234-bpmp-3767-0000-a02-3509-a02.dtb to tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb
[   0.0679 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_tmp.dtb
[   0.5323 ] Concatenating L4TConfiguration.dtbo,tegra234-p3767-overlay.dtbo to tegra234-p3767-0000-p3509-a02_with_odm_overlay.dtb
[   0.5324 ] Concatenating bl dtb to cpubl binary
[   0.5352 ] MB2 binary: mb2_t234.bin
[   0.5353 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[   0.5520 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[   1.0926 ] Generating coldboot mb2-bct
[   1.0927 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   1.0952 ] WARNING: unknown property 'tfc_version'
[   1.0983 ] WARNING: unknown property 'addr_header_version'
[   1.1122 ] Updating mb2-bct with storage information
[   1.1144 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   1.1162 ] Concatenating mb2-bct to mb2 binary
[   1.1162 ] mb2_bin_file = mb2_t234.bin
[   1.1162 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   1.1217 ] DCE binary: display-t234-dce.bin
[   1.1218 ] Kernel DTB used: tegra234-p3767-0000-p3509-a02_with_odm_overlay.dtb
[   1.1218 ] Concatenating kernel-dtb to dce-fw binary
[   1.1218 ] dce_bin = display-t234-dce.bin
[   1.1219 ] kernel_dtb = tegra234-p3767-0000-p3509-a02_with_odm_overlay.dtb
[   1.1219 ] dce_with_dtb = display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay.bin
[   1.1298 ] Update display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay.bin to dce_fw partitions
[   1.1318 ] Parsing partition layout
[   1.1336 ] tegraparser_v2 --pt flash.xml.tmp
[   1.1363 ] Creating list of images to be signed
[   1.1374 ] Generating ratchet blob
[   1.1374 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[   1.1467 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   1.1557 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[   1.1641 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[   1.1739 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   1.1868 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi
[   1.2049 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3767-hdmi-a03.dtsi
[   1.2150 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[   1.2240 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[   1.2329 ] Pre-processing config: tegra234-p3767-0000-sdram-l4t.dts
[   2.8672 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   2.8776 ] Pre-processing config: tegra234-p3767-0000-wb0sdram-l4t.dts
[   4.5104 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[   4.5216 ] Generating coldboot mb1-bct
[   4.5230 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-hdmi-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-hdmi-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   4.5245 ] MB1-BCT version: 0.10
[   4.5249 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   4.5257 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   4.5263 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   4.5268 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   4.5272 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   4.5276 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   4.5280 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   4.5282 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   4.5286 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   4.5289 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   4.5292 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   4.5295 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   4.5299 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   4.5304 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   4.5306 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   4.5309 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   4.5312 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   4.5317 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-hdmi-a03_cpp.dtb
[   4.5322 ] Added Platform Config 0 data with size :- 2424
[   4.5328 ]
[   4.5328 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-hdmi-a03_cpp.dtb
[   4.5328 ] WARNING: unknown node 'g2'
[   4.5329 ] WARNING: unknown node 'g2'
[   4.5329 ] WARNING: unknown node 'g9'
[   4.5329 ] Added Platform Config 2 data with size :- 24
[   4.5329 ]
[   4.5329 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   4.5329 ] Added Platform Config 4 data with size :- 288
[   4.5329 ]
[   4.5329 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   4.5329 ] Added Platform Config 3 data with size :- 52
[   4.5329 ]
[   4.5329 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   4.5329 ] WARNING: unknown property 'major'
[   4.5329 ] WARNING: unknown property 'minor'
[   4.5329 ] Added Platform Config 5 data with size :- 500
[   4.5329 ]
[   4.5330 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   4.5330 ] WARNING: unknown property 'major'
[   4.5330 ] WARNING: unknown property 'minor'
[   4.5330 ] Added Platform Config 7 data with size :- 380
[   4.5330 ]
[   4.5330 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   4.5330 ] Added Platform Config 8 data with size :- 24
[   4.5330 ]
[   4.5330 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   4.5330 ] Added Platform Config 9 data with size :- 100
[   4.5330 ]
[   4.5330 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   4.5330 ] ModuleCount 0 NumProdNames 0
[   4.5330 ] Added Platform Config 6 data with size :- 16
[   4.5330 ]
[   4.5331 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   4.5331 ]
[   4.5331 ] Updating mb1-bct with firmware information
[   4.5342 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   4.5366 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   4.5388 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   4.5396 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   4.5424 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.5426 ] Assuming zero filled SBK key
[   4.5443 ] Warning: pub_key.key is not found
[   4.5436 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   4.5454 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   4.5464 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   4.5477 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   4.5481 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   4.5543 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   4.5550 ] Header already present for nvdec_t234_prod_aligned.fw
[   4.5572 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   4.5654 ] adding BCH for xusb_t234_prod_aligned.bin
[   4.5865 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[   4.5946 ] adding BCH for tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[   4.6130 ] Header already present for pscfw_t234_prod_aligned.bin
[   4.6182 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   4.6251 ] Header already present for sc7_t234_prod.bin
[   4.6283 ] Header already present for psc_rf_t234_prod_aligned.bin
[   4.6316 ] adding BCH for mb2rf_t234_aligned.bin
[   4.6339 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[   4.6444 ] adding BCH for tos-optee_t234_aligned.img
[   4.7576 ] adding BCH for eks_t234_aligned.img
[   4.7961 ] INFO: compressing display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned.bin
[   4.9737 ] INFO: complete compression, display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned.bin, ratio = 7%
[   4.9939 ] adding BCH for display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned_blob_w_bin_aligned.bin
[   5.0119 ] adding BCH for spe_t234_aligned.bin
[   5.0254 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   5.0362 ] adding BCH for adsp-fw_aligned.bin
[   5.0553 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   5.0701 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   5.0706 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   5.0750 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   5.0754 ] Header already present for nvdec_t234_prod_aligned.fw
[   5.0777 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   5.0843 ] adding BCH for xusb_t234_prod_aligned.bin
[   5.1000 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[   5.1079 ] adding BCH for tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[   5.1271 ] Header already present for pscfw_t234_prod_aligned.bin
[   5.1332 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   5.1400 ] Header already present for sc7_t234_prod.bin
[   5.1433 ] Header already present for psc_rf_t234_prod_aligned.bin
[   5.1472 ] adding BCH for mb2rf_t234_aligned.bin
[   5.1492 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[   5.1609 ] adding BCH for tos-optee_t234_aligned.img
[   5.2674 ] adding BCH for eks_t234_aligned.img
[   5.3013 ] INFO: compressing display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned.bin
[   5.4659 ] INFO: complete compression, display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned.bin, ratio = 7%
[   5.4847 ] adding BCH for display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned_blob_w_bin_aligned.bin
[   5.5024 ] adding BCH for spe_t234_aligned.bin
[   5.5153 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   5.5249 ] adding BCH for adsp-fw_aligned.bin
[   5.5560 ] Filling MB1 storage info
[   5.5561 ] Parsing dev params for multi chains
[   5.5676 ] Generating br-bct
[   5.5689 ] Updating dev and MSS params in BR BCT
[   5.5691 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   5.6836 ] Updating bl info
[   5.6852 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   5.6977 ] Generating br-bct
[   5.6991 ] Updating dev and MSS params in BR BCT
[   5.6992 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   5.8139 ] Updating bl info
[   5.8160 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   5.8186 ] Generating BCT backup image
[   5.8187 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   5.8203 ] 32768+0 records in
[   5.8878 ] 32768+0 records out
[   5.8878 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0670046 s, 489 kB/s
[   5.8878 ]
[   5.8879 ] Concatenating BCT for chain A to bct_backup.img
[   5.8879 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   5.8900 ] 8192+0 records in
[   5.9064 ] 8192+0 records out
[   5.9064 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0155174 s, 528 kB/s
[   5.9064 ]
[   5.9065 ] Concatenating BCT for chain B to bct_backup.img
[   5.9065 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   5.9089 ] 8192+0 records in
[   5.9264 ] 8192+0 records out
[   5.9264 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.016593 s, 494 kB/s
[   5.9264 ]
[   5.9265 ] Generating signatures
[   5.9284 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.9288 ] Assuming zero filled SBK key
[   6.0613 ] Warning: pub_key.key is not found
[   6.0621 ] Parsing dev params for multi chains
[   6.0622 ] Generating br-bct
[   6.0635 ] Updating dev and MSS params in BR BCT
[   6.0636 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   6.1887 ] Updating customer data section
[   6.1904 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   6.1921 ] Updating bl info
[   6.1936 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   6.1959 ] Get Signed section of bct
[   6.1980 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   6.2000 ] Signing BCT
[   6.2020 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.2026 ] Assuming zero filled SBK key
[   6.2085 ] Sha saved in br_bct_BR.sha
[   6.2090 ] Warning: pub_key.key is not found
[   6.2071 ] Updating BCT with signature
[   6.2083 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   6.2095 ] Offset :4608 Len :3584
[   6.2100 ] Generating SHA2 Hash
[   6.2119 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   6.2121 ] Assuming zero filled SBK key
[   6.2122 ] Assuming zero filled SBK key
[   6.2159 ] Sha saved in br_bct_BR.sha
[   6.2145 ] Updating BCT with SHA2 Hash
[   6.2157 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   6.2168 ] Offset :4608 Len :3584
[   6.2171 ] Offset :68 Len :8124
[   6.2174 ] Generating br-bct
[   6.2186 ] Updating dev and MSS params in BR BCT
[   6.2188 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   6.3421 ] Updating customer data section
[   6.3440 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   6.3467 ] Updating bl info
[   6.3487 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   6.3516 ] Get Signed section of bct
[   6.3529 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   6.3548 ] Signing BCT
[   6.3567 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.3570 ] Assuming zero filled SBK key
[   6.3612 ] Sha saved in br_bct_BR.sha
[   6.3617 ] Warning: pub_key.key is not found
[   6.3599 ] Updating BCT with signature
[   6.3612 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   6.3626 ] Offset :4608 Len :3584
[   6.3633 ] Generating SHA2 Hash
[   6.3652 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   6.3656 ] Assuming zero filled SBK key
[   6.3701 ] Sha saved in br_bct_BR.sha
[   6.3688 ] Updating BCT with SHA2 Hash
[   6.3700 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   6.3711 ] Offset :4608 Len :3584
[   6.3714 ] Offset :68 Len :8124
[   6.3717 ] Generating BCT backup image
[   6.3717 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   6.3729 ] 32768+0 records in
[   6.4384 ] 32768+0 records out
[   6.4384 ] 32768 bytes (33 kB, 32 KiB) copied, 0.064836 s, 505 kB/s
[   6.4384 ]
[   6.4385 ] Concatenating BCT for chain A to bct_backup.img
[   6.4385 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   6.4399 ] 8192+0 records in
[   6.4517 ] 8192+0 records out
[   6.4517 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0113434 s, 722 kB/s
[   6.4517 ]
[   6.4518 ] Concatenating BCT for chain B to bct_backup.img
[   6.4518 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   6.4532 ] 8192+0 records in
[   6.4650 ] 8192+0 records out
[   6.4651 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0113885 s, 719 kB/s
[   6.4651 ]
[   6.4651 ] Generating coldboot mb1-bct
[   6.4667 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-hdmi-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-hdmi-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   6.4681 ] MB1-BCT version: 0.10
[   6.4683 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   6.4688 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   6.4693 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   6.4698 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   6.4704 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   6.4708 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   6.4713 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   6.4716 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   6.4720 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   6.4723 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   6.4723 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   6.4723 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   6.4724 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   6.4724 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   6.4724 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   6.4724 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   6.4724 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   6.4724 ]
[   6.4724 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-hdmi-a03_cpp.dtb
[   6.4724 ] Added Platform Config 0 data with size :- 2424
[   6.4724 ]
[   6.4724 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-hdmi-a03_cpp.dtb
[   6.4724 ] WARNING: unknown node 'g2'
[   6.4724 ] WARNING: unknown node 'g9'
[   6.4724 ] Added Platform Config 2 data with size :- 24
[   6.4724 ]
[   6.4724 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   6.4724 ] Added Platform Config 4 data with size :- 288
[   6.4724 ]
[   6.4724 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   6.4724 ] Added Platform Config 3 data with size :- 52
[   6.4724 ]
[   6.4724 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   6.4725 ] WARNING: unknown property 'major'
[   6.4725 ] WARNING: unknown property 'minor'
[   6.4725 ] Added Platform Config 5 data with size :- 500
[   6.4725 ]
[   6.4725 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   6.4725 ] Added Platform Config 7 data with size :- 380
[   6.4725 ]
[   6.4725 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   6.4725 ] Added Platform Config 8 data with size :- 24
[   6.4725 ]
[   6.4725 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   6.4725 ] Added Platform Config 9 data with size :- 100
[   6.4725 ]
[   6.4725 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   6.4725 ] ModuleCount 0 NumProdNames 0
[   6.4725 ] Added Platform Config 6 data with size :- 16
[   6.4725 ]
[   6.4725 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   6.4725 ]
[   6.4726 ] Updating mb1-bct with firmware information
[   6.4739 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   6.4769 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   6.4793 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   6.4802 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   6.4831 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.4833 ] Assuming zero filled SBK key
[   6.4854 ] Warning: pub_key.key is not found
[   6.4847 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   6.4863 ] Generating recovery mb1-bct
[   6.4877 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-hdmi-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-hdmi-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   6.4891 ] MB1-BCT version: 0.10
[   6.4894 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   6.4902 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   6.4905 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   6.4908 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   6.4912 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   6.4916 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   6.4920 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   6.4922 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   6.4925 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   6.4929 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   6.4931 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   6.4935 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   6.4938 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   6.4942 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   6.4945 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   6.4947 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   6.4950 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   6.4953 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-hdmi-a03_cpp.dtb
[   6.4956 ] Added Platform Config 0 data with size :- 2424
[   6.4960 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-hdmi-a03_cpp.dtb
[   6.4963 ] WARNING: unknown node 'g2'
[   6.4964 ] WARNING: unknown node 'g2'
[   6.4966 ] WARNING: unknown node 'g9'
[   6.4966 ] Added Platform Config 2 data with size :- 24
[   6.4966 ]
[   6.4966 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   6.4966 ] Added Platform Config 4 data with size :- 288
[   6.4966 ]
[   6.4966 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   6.4966 ] Added Platform Config 3 data with size :- 52
[   6.4966 ]
[   6.4966 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   6.4966 ] WARNING: unknown property 'major'
[   6.4966 ] WARNING: unknown property 'minor'
[   6.4966 ] Added Platform Config 5 data with size :- 500
[   6.4966 ]
[   6.4966 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   6.4966 ] Added Platform Config 7 data with size :- 380
[   6.4966 ]
[   6.4966 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   6.4967 ] Added Platform Config 8 data with size :- 24
[   6.4967 ]
[   6.4967 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   6.4967 ] Added Platform Config 9 data with size :- 100
[   6.4967 ]
[   6.4967 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   6.4967 ] ModuleCount 0 NumProdNames 0
[   6.4967 ] Added Platform Config 6 data with size :- 16
[   6.4967 ]
[   6.4967 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   6.4967 ]
[   6.4967 ] Updating mb1-bct with firmware information
[   6.4979 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   6.5012 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   6.5039 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   6.5050 ] adding BCH for mb1_bct_MB1_aligned.bct
[   6.5081 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.5083 ] Assuming zero filled SBK key
[   6.5107 ] Warning: pub_key.key is not found
[   6.5102 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   6.5121 ] Generating coldboot mem-bct
[   6.5133 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0000-sdram-l4t_cpp_1.bct tegra234-p3767-0000-sdram-l4t_cpp_2.bct tegra234-p3767-0000-sdram-l4t_cpp_3.bct tegra234-p3767-0000-sdram-l4t_cpp_4.bct
[   6.5146 ]  packing sdram params with Wb0 file tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb
[   6.6307 ] Packing sdram param for instance[0]
[   6.6311 ] Packing sdram param for instance[1]
[   6.6314 ] Packing sdram param for instance[2]
[   6.6317 ] Packing sdram param for instance[3]
[   6.6320 ] Packing sdram param for instance[4]
[   6.6323 ] Packing sdram param for instance[5]
[   6.6326 ] Packing sdram param for instance[6]
[   6.6329 ] Packing sdram param for instance[7]
[   6.6332 ] Packing sdram param for instance[8]
[   6.6335 ] Packing sdram param for instance[9]
[   6.6338 ] Packing sdram param for instance[10]
[   6.6342 ] Packing sdram param for instance[11]
[   6.6345 ] Packing sdram param for instance[12]
[   6.6348 ] Packing sdram param for instance[13]
[   6.6352 ] Packing sdram param for instance[14]
[   6.6355 ] Packing sdram param for instance[15]
[   6.7456 ] Getting sector size from pt
[   6.7476 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   6.7498 ] BlockSize read from layout is 0x200
[   6.7514 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0000-sdram-l4t_cpp_1.bct tegra234-p3767-0000-sdram-l4t_cpp_2.bct tegra234-p3767-0000-sdram-l4t_cpp_3.bct tegra234-p3767-0000-sdram-l4t_cpp_4.bct
[   6.7528 ] Binary 0 length is 58752
[   6.7531 ] Binary 0 align length is 58880
[   6.7558 ] Binary 1 length is 58752
[   6.7559 ] Binary 1 align length is 58880
[   6.7585 ] Binary 2 length is 58752
[   6.7587 ] Binary 2 align length is 58880
[   6.7611 ] Binary 3 length is 58752
[   6.7613 ] Binary 3 align length is 58880
[   6.7638 ] Buffer length is 235520
[   6.7642 ] adding BCH for tegra234-p3767-0000-sdram-l4t_cpp_1.bct
[   6.7648 ] new length is 243712
[   6.7682 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[   6.7711 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   6.7724 ] Header already present for mem_coldboot_aligned.bct
[   6.7758 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.7760 ] Assuming zero filled SBK key
[   6.7790 ] Warning: pub_key.key is not found
[   6.7787 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   6.7824 ] Generating recovery mem-bct
[   6.7839 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0000-sdram-l4t_cpp_1.bct tegra234-p3767-0000-sdram-l4t_cpp_2.bct tegra234-p3767-0000-sdram-l4t_cpp_3.bct tegra234-p3767-0000-sdram-l4t_cpp_4.bct
[   6.7854 ]  packing sdram params with Wb0 file tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb
[   6.9013 ] Packing sdram param for instance[0]
[   6.9016 ] Packing sdram param for instance[1]
[   6.9019 ] Packing sdram param for instance[2]
[   6.9023 ] Packing sdram param for instance[3]
[   6.9028 ] Packing sdram param for instance[4]
[   6.9031 ] Packing sdram param for instance[5]
[   6.9033 ] Packing sdram param for instance[6]
[   6.9034 ] Packing sdram param for instance[7]
[   6.9036 ] Packing sdram param for instance[8]
[   6.9038 ] Packing sdram param for instance[9]
[   6.9040 ] Packing sdram param for instance[10]
[   6.9042 ] Packing sdram param for instance[11]
[   6.9044 ] Packing sdram param for instance[12]
[   6.9046 ] Packing sdram param for instance[13]
[   6.9048 ] Packing sdram param for instance[14]
[   6.9050 ] Packing sdram param for instance[15]
[   7.0115 ] Reading ramcode from backup chip_info.bin file
[   7.0116 ] RAMCODE Read from Device: 0
[   7.0116 ] Using ramcode 0
[   7.0117 ] Disabled BPMP dtb trim, using default dtb
[   7.0117 ]
[   7.0148 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[   7.0197 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   7.0210 ] adding BCH for mem_rcm_aligned.bct
[   7.0271 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.0274 ] Assuming zero filled SBK key
[   7.0298 ] Warning: pub_key.key is not found
[   7.0294 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   7.0318 ] Copying signatures
[   7.0333 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   7.0977 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   7.0989 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   7.0989 ] Boot Rom communication
[   7.1008 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   7.1025 ] BR_CID: 0x80012344705DD1438800000009FF8280
[   7.1034 ] Sending bct_br
[   7.1036 ] Sending mb1
[   7.1038 ] Sending psc_bl1
[   7.1136 ] Sending bct_mb1
[   7.1198 ] Boot Rom communication completed
[   7.1199 ] Generating blob for T23x
[   7.1266 ] tegrahost_v2 --chip 0x23 0 --align blob_uefi_jetson_with_dtb_aligned.bin
[   7.1302 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_uefi_jetson_with_dtb_aligned.bin zerosbk
[   7.1318 ] adding BCH for blob_uefi_jetson_with_dtb_aligned.bin
[   7.2533 ] tegrasign_v3.py --key None --list blob_uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.2537 ] Assuming zero filled SBK key
[   7.2646 ] Warning: pub_key.key is not found
[   7.2641 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt blob_uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[   7.2725 ] Get magic id
[   7.2738 ] tegraparser_v2 --get_magic psc_fw
[   7.2750 ] PFWP
[   7.2750 ]
[   7.2750 ] partition type psc_fw, magic id = PFWP
[   7.2768 ] tegrahost_v2 --chip 0x23 0 --align blob_pscfw_t234_prod_aligned.bin
[   7.2795 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader blob_pscfw_t234_prod_aligned.bin zerosbk
[   7.2810 ] Header already present for blob_pscfw_t234_prod_aligned.bin
[   7.2904 ] tegrasign_v3.py --key None --list blob_pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.2907 ] Assuming zero filled SBK key
[   7.2943 ] Warning: pub_key.key is not found
[   7.2944 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_pscfw_t234_prod_aligned_sigheader.bin.encrypt blob_pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[   7.2970 ] Get magic id
[   7.2980 ] tegraparser_v2 --get_magic mts_mce
[   7.2992 ] MTSM
[   7.2994 ] partition type mts_mce, magic id = MTSM
[   7.3010 ] tegrahost_v2 --chip 0x23 0 --align blob_mce_flash_o10_cr_prod_aligned.bin
[   7.3036 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader blob_mce_flash_o10_cr_prod_aligned.bin zerosbk
[   7.3048 ] Header already present for blob_mce_flash_o10_cr_prod_aligned.bin
[   7.3118 ] tegrasign_v3.py --key None --list blob_mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.3120 ] Assuming zero filled SBK key
[   7.3145 ] Warning: pub_key.key is not found
[   7.3139 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[   7.3164 ] Get magic id
[   7.3176 ] tegraparser_v2 --get_magic mb2_applet
[   7.3188 ] MB2A
[   7.3190 ] partition type mb2_applet, magic id = MB2A
[   7.3208 ] tegrahost_v2 --chip 0x23 0 --align blob_applet_t234_aligned.bin
[   7.3232 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader blob_applet_t234_aligned.bin zerosbk
[   7.3243 ] adding BCH for blob_applet_t234_aligned.bin
[   7.3388 ] tegrasign_v3.py --key None --list blob_applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.3392 ] Assuming zero filled SBK key
[   7.3428 ] Warning: pub_key.key is not found
[   7.3427 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_applet_t234_aligned_sigheader.bin.encrypt blob_applet_t234_aligned_sigheader.bin.hash zerosbk
[   7.3467 ] Generating recovery mb2-bct
[   7.3468 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   7.3484 ] WARNING: unknown property 'tfc_version'
[   7.3506 ] WARNING: unknown property 'addr_header_version'
[   7.3654 ] Updating mb2-bct with storage information
[   7.3676 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   7.3710 ] Concatenating mb2-bct to mb2 binary
[   7.3710 ] mb2_bin_file = mb2_t234.bin
[   7.3710 ] mb2_bct_file = mb2_bct_MB2.bct
[   7.3724 ] Get magic id
[   7.3742 ] tegraparser_v2 --get_magic mb2_bootloader
[   7.3755 ] MB2B
[   7.3757 ] partition type mb2_bootloader, magic id = MB2B
[   7.3774 ] tegrahost_v2 --chip 0x23 0 --align blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[   7.3803 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[   7.3815 ] adding BCH for blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[   7.4016 ] tegrasign_v3.py --key None --list blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.4021 ] Assuming zero filled SBK key
[   7.4074 ] Warning: pub_key.key is not found
[   7.4077 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[   7.4116 ] Get magic id
[   7.4129 ] tegraparser_v2 --get_magic xusb_fw
[   7.4146 ] XUSB
[   7.4149 ] partition type xusb_fw, magic id = XUSB
[   7.4171 ] tegrahost_v2 --chip 0x23 0 --align blob_xusb_t234_prod_aligned.bin
[   7.4202 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_xusb_t234_prod_aligned.bin zerosbk
[   7.4214 ] adding BCH for blob_xusb_t234_prod_aligned.bin
[   7.4317 ] tegrasign_v3.py --key None --list blob_xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.4321 ] Assuming zero filled SBK key
[   7.4360 ] Warning: pub_key.key is not found
[   7.4361 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_xusb_t234_prod_aligned_sigheader.bin.encrypt blob_xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[   7.4389 ] Kernel DTB used: tegra234-p3767-0000-p3509-a02_with_odm_overlay.dtb
[   7.4389 ] Concatenating kernel-dtb to dce-fw binary
[   7.4390 ] dce_bin = display-t234-dce.bin
[   7.4390 ] kernel_dtb = tegra234-p3767-0000-p3509-a02_with_odm_overlay.dtb
[   7.4390 ] dce_with_dtb = display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay.bin
[   7.4484 ] Get magic id
[   7.4503 ] tegraparser_v2 --get_magic dce_fw
[   7.4518 ] DCEF
[   7.4520 ] partition type dce_fw, magic id = DCEF
[   7.4608 ] tegrahost_v2 --chip 0x23 0 --align blob_display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned.bin
[   7.4643 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned.bin zerosbk
[   7.4668 ] adding BCH for blob_display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned.bin
[   7.8069 ] tegrasign_v3.py --key None --list blob_display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.8072 ] Assuming zero filled SBK key
[   7.8350 ] Warning: pub_key.key is not found
[   7.8353 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned_sigheader.bin.encrypt blob_display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned_sigheader.bin.hash zerosbk
[   7.8673 ] Get magic id
[   7.8693 ] tegraparser_v2 --get_magic nvdec
[   7.8710 ] NDEC
[   7.8713 ] partition type nvdec, magic id = NDEC
[   7.8730 ] tegrahost_v2 --chip 0x23 0 --align blob_nvdec_t234_prod_aligned.fw
[   7.8757 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvdec_t234_prod_aligned.fw zerosbk
[   7.8770 ] Header already present for blob_nvdec_t234_prod_aligned.fw
[   7.8877 ] tegrasign_v3.py --key None --list blob_nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.8880 ] Assuming zero filled SBK key
[   7.8919 ] Warning: pub_key.key is not found
[   7.8918 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvdec_t234_prod_aligned_sigheader.fw.encrypt blob_nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[   7.8953 ] Get magic id
[   7.8965 ] tegraparser_v2 --get_magic bpmp_fw
[   7.8977 ] BPMF
[   7.8978 ] partition type bpmp_fw, magic id = BPMF
[   7.9003 ] tegrahost_v2 --chip 0x23 0 --align blob_bpmp_t234-TE990M-A1_prod_aligned.bin
[   7.9037 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t234-TE990M-A1_prod_aligned.bin zerosbk
[   7.9053 ] Header already present for blob_bpmp_t234-TE990M-A1_prod_aligned.bin
[   7.9304 ] tegrasign_v3.py --key None --list blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.9308 ] Assuming zero filled SBK key
[   7.9397 ] Warning: pub_key.key is not found
[   7.9398 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.encrypt blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.hash zerosbk
[   7.9452 ] Using bpmp-dtb concatenated with odmdata in blob
[   7.9453 ] Get magic id
[   7.9467 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[   7.9481 ] BPMD
[   7.9482 ] partition type bpmp_fw_dtb, magic id = BPMD
[   7.9502 ] tegrahost_v2 --chip 0x23 0 --align blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[   7.9537 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb zerosbk
[   7.9554 ] adding BCH for blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[   7.9645 ] tegrasign_v3.py --key None --list blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.9648 ] Assuming zero filled SBK key
[   7.9690 ] Warning: pub_key.key is not found
[   7.9709 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned_sigheader.dtb.encrypt blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned_sigheader.dtb.hash zerosbk
[   7.9739 ] Get magic id
[   7.9754 ] tegraparser_v2 --get_magic sce_fw
[   7.9768 ] SCEF
[   7.9770 ] partition type sce_fw, magic id = SCEF
[   7.9787 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-sce_aligned.img
[   7.9817 ] tegrahost_v2 --chip 0x23 0 --magicid SCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-sce_aligned.img zerosbk
[   7.9830 ] adding BCH for blob_camera-rtcpu-sce_aligned.img
[   7.9933 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-sce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.9937 ] Assuming zero filled SBK key
[   7.9975 ] Warning: pub_key.key is not found
[   7.9983 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-sce_aligned_sigheader.img.encrypt blob_camera-rtcpu-sce_aligned_sigheader.img.hash zerosbk
[   8.0032 ] Get magic id
[   8.0054 ] tegraparser_v2 --get_magic rce_fw
[   8.0070 ] RCEF
[   8.0072 ] partition type rce_fw, magic id = RCEF
[   8.0094 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-t234-rce_aligned.img
[   8.0125 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-t234-rce_aligned.img zerosbk
[   8.0140 ] adding BCH for blob_camera-rtcpu-t234-rce_aligned.img
[   8.0412 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.0417 ] Assuming zero filled SBK key
[   8.0465 ] Warning: pub_key.key is not found
[   8.0462 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt blob_camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[   8.0511 ] Get magic id
[   8.0528 ] tegraparser_v2 --get_magic ape_fw
[   8.0544 ] APEF
[   8.0546 ] partition type ape_fw, magic id = APEF
[   8.0564 ] tegrahost_v2 --chip 0x23 0 --align blob_adsp-fw_aligned.bin
[   8.0591 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_adsp-fw_aligned.bin zerosbk
[   8.0603 ] adding BCH for blob_adsp-fw_aligned.bin
[   8.0795 ] tegrasign_v3.py --key None --list blob_adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.0800 ] Assuming zero filled SBK key
[   8.0864 ] Warning: pub_key.key is not found
[   8.0875 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_adsp-fw_aligned_sigheader.bin.encrypt blob_adsp-fw_aligned_sigheader.bin.hash zerosbk
[   8.0905 ] Get magic id
[   8.0920 ] tegraparser_v2 --get_magic spe_fw
[   8.0934 ] SPEF
[   8.0936 ] partition type spe_fw, magic id = SPEF
[   8.0955 ] tegrahost_v2 --chip 0x23 0 --align blob_spe_t234_aligned.bin
[   8.0985 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t234_aligned.bin zerosbk
[   8.0999 ] adding BCH for blob_spe_t234_aligned.bin
[   8.1145 ] tegrasign_v3.py --key None --list blob_spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.1150 ] Assuming zero filled SBK key
[   8.1201 ] Warning: pub_key.key is not found
[   8.1212 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_spe_t234_aligned_sigheader.bin.encrypt blob_spe_t234_aligned_sigheader.bin.hash zerosbk
[   8.1244 ] Get magic id
[   8.1258 ] tegraparser_v2 --get_magic tos
[   8.1270 ] TOSB
[   8.1272 ] partition type tos, magic id = TOSB
[   8.1295 ] tegrahost_v2 --chip 0x23 0 --align blob_tos-optee_t234_aligned.img
[   8.1325 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t234_aligned.img zerosbk
[   8.1338 ] adding BCH for blob_tos-optee_t234_aligned.img
[   8.1773 ] tegrasign_v3.py --key None --list blob_tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.1780 ] Assuming zero filled SBK key
[   8.1870 ] Warning: pub_key.key is not found
[   8.1876 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-optee_t234_aligned_sigheader.img.encrypt blob_tos-optee_t234_aligned_sigheader.img.hash zerosbk
[   8.1925 ] Get magic id
[   8.1937 ] tegraparser_v2 --get_magic eks
[   8.1949 ] EKSB
[   8.1951 ] partition type eks, magic id = EKSB
[   8.1966 ] tegrahost_v2 --chip 0x23 0 --align blob_eks_t234_aligned.img
[   8.1997 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t234_aligned.img zerosbk
[   8.2010 ] adding BCH for blob_eks_t234_aligned.img
[   8.2040 ] tegrasign_v3.py --key None --list blob_eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   8.2044 ] Assuming zero filled SBK key
[   8.2077 ] Warning: pub_key.key is not found
[   8.2077 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_t234_aligned_sigheader.img.encrypt blob_eks_t234_aligned_sigheader.img.hash zerosbk
[   8.2128 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   8.2145 ] The number of images in blob is 16
[   8.2149 ] blobsize is 18014128
[   8.2151 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3182656
[   8.2295 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[   8.2304 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[   8.2314 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[   8.2323 ] Not supported type: mb2_applet
[   8.2327 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 437984
[   8.2338 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164352
[   8.2347 ] Added binary blob_display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_sigheader.bin.encrypt of size 9453632
[   8.2380 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   8.2399 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1048000
[   8.2408 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 138880
[   8.2416 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[   8.2421 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[   8.2426 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[   8.2430 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   8.2434 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1064752
[   8.2439 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   8.2544 ] Sending membct and RCM blob
[   8.2567 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   8.2586 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[   8.2598 ] Sending bct_mem
[   8.2601 ] Sending blob
[   8.3380 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Failed flashing t186ref.
Serial:
[0040.843] I> MB1 (version: 0.32.0.0-t234-54845784-57325615)
[0040.849] I> t234-A01-0-Silicon (0x12347) Prod
[0040.853] I> Boot-mode : BPMP Diagnostic
[0040.857] I> Emulation:
[0040.859] I> Entry timestamp: 0x00000000
[0040.863] I> last_boot_error: 0x0
[0040.866] I> BR-BCT: preprod_dev_sign: 0
[0040.870] I> rst_source: 0x0, rst_level: 0x0
[0040.874] I> Task: Initialize MB2 params (0x5000cb51)
[0040.879] I> MB2-params @ 0x40060000
[0040.883] I> Task: Crypto init (0x5001d981)
[0040.887] I> Task: Secure debug controls (0x5000c0a9)
[0040.892] I> Task: strap war set (0x5000ba2d)
[0040.896] I> Task: Program NV master stream id (0x5000c05d)
[0040.901] I> Task: Verify boot mode (0xd4820f1)
[0040.907] I> Task: Alias fuses (0x5001095d)
[0040.912] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0040.919] I> Task: Print SKU type (0x5000f5f1)
[0040.924] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0040.929] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0040.933] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0040.937] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0040.942] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0040.946] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0040.950] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0040.955] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0040.959] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0040.963] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0040.968] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0040.972] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0040.976] I> FUSE_SKU_INFO_0 = 0xd3
[0040.979] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0040.983] I> FUSE_PACKAGE_INFO_0 = 0x2
[0040.987] I> SKU: Prod
[0040.989] I> Task: Boost clocks (0x500148a1)
[0040.993] I> Initializing PLLC2 for AXI_CBB.
[0040.997] I> AXI_CBB : src = 35, divisor = 0
[0041.001] I> Task: Voltage monitor (0x50014b49)
[0041.006] I> VMON: Vmon re-calibration and fine tuning done
[0041.011] I> Task: UPHY init (0x5000d065)
[0041.016] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0041.021] I> Task: Boot device init (0x50000be9)
[0041.026] I> Boot_device: RCM
[0041.029] I> USB configuration success
[0041.032] I> Task: TSC init (0x50020a4d)
[0041.036] I> Task: Enable WDT 5th expiry (0x50021a41)
[0041.041] I> Task: I2C register (0x50000b85)
[0041.045] I> Task: Reset FSI (0x500148b1)
[0041.049] I> Task: Enable clock-mon (0x50020a35)
[0041.054] I> FMON: Fmon re-programming done
[0041.059] I> Task: MB1 fixed firewalls (0x5002006d)
[0041.065] W> Firewall readback mismatch
[0041.068] W> Firewall readback mismatch
[0041.073] W> Firewall readback mismatch
[0041.078] I> Task: Load MB2/Applet/FSKP (0x5000ca55)
[0041.083] I> Loading MB2 Applet
[0041.086] I> Slot: 0
[0041.088] I> Binary[21] block-0 (partition size: 0x50000)
[0041.094] I>  get_binary_info: Binary name: MB2-Applet
[0041.098] I> Size of crypto header is 8192
[0041.102] I> BCH load address is : 0x4004e000
[0041.107] I> Size of crypto header is 8192
[0041.111] I> BCH of MB2-Applet read from storage
[0041.115] I> BCH address is : 0x4004e000
[0041.119] I> MB2-Applet header integrity check is success
[0041.124] I> Binary magic in BCH component 0 is MB2A
[0041.129] I> component binary type is 21
[0041.133] I> Size of crypto header is 8192
[0041.144] I> MB2-Applet binary is read from storage
[0041.150] I> MB2-Applet binary integrity check is success
[0041.155] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x41b40)
[0041.162] I> Task: Map CCPLEX SHARED carveout (0x5000cbf9)
[0041.167] I> Task: Prepare MB2 params (0x5000cca9)
[0041.172] I> BR-BCT Boot Chain Fields
[0041.176] I>    u32_non_gpio_select_boot_chain  : 0
[0041.180] I>    u32_num_boot_chains             : 0
[0041.185] I>    bf_bl_gpio_select_boot_chain_1b : 0
[0041.189] I> Task: Misc NV security settings (0x5000c529)
[0041.195] I> NVDEC sticky bits programming done
[0041.199] I> Successfully powergated NVDEC
[0041.203] I> Task: Disable/Reload WDT (0x50021a99)
[0041.208] I> Task: Program misc carveouts (0x50015381)
[0041.213] I> SLCG Global override status := 0x0
[0041.217] I> MB1: MSS reconfig completed
[0041.221] W> Firewall readback mismatch
[0041.225] W> Firewall readback mismatch
[0041.228] W> Firewall readback mismatch
[0041.232] W> Firewall readback mismatch
[0041.236] W> Firewall readback mismatch
[0041.239] W> Firewall readback mismatch
[0041.243] W> Firewall readback mismatch
[0041.247] W> Firewall readback mismatch
[0041.250] W> Firewall readback mismatch
[0041.254] W> Firewall readback mismatch
I> Applet (version: 0.0.0.0-t234-54845784-f44287d2)
I> Emulation:
I> Entry timestamp: 0xffffffff
I> Task: Pinmux init (0x4000062d)
I> Task: Boot device init (0x400012e5)
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
I> QSPI-0l initialized successfully
E> Error in command_complete 18001 int_status
E> OCR failed, error = 39390706
E> Failed to open sdmmc-3, err = 39390706
W> Ignoring init failure for device 0-3
W> Ignoring init failure for device 1-3
E> Unknown device 7
E> Unknown device 8
I> Task: Partition Manager Init (0x40002d25)
W> Cannot find any partition table for 00030000
 > PARTITION_MANAGER: Failed to publish partition.
I> Task: I2C register (0x400006a5)
I> Task: Register exit handlers (0x400005f5)
I> Task: Enter 3p server (0x400018e9)
I> Populate chip info
I> RAM_CODE 0x4000001
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> dump bct
I> Rebooting : reboot-recovery
[0022.377] I> MB1 (version: 0.32.0.0-t234-54845784-57325615)
[0022.383] I> t234-A01-0-Silicon (0x12347) Prod
[0022.387] I> Boot-mode : Coldboot
[0022.390] I> Emulation:
[0022.393] I> Entry timestamp: 0x00000000
[0022.396] I> last_boot_error: 0x0
[0022.400] I> BR-BCT: preprod_dev_sign: 0
[0022.403] I> rst_source: 0xb, rst_level: 0x1
[0022.407] I> Task: Bootchain select WAR set (0x5000ba65)
[0022.413] I> Task: Enable SLCG (0x5000bab1)
[0022.417] I> Task: CRC check (0x5001ea19)
[0022.421] I> Task: Initialize MB2 params (0x5000cb51)
[0022.426] I> MB2-params @ 0x40060000
[0022.429] I> Task: Crypto init (0x5001d981)
[0022.433] I> Task: Secure debug controls (0x5000c0a9)
[0022.438] I> Task: strap war set (0x5000ba2d)
[0022.443] I> Task: Initialize SOC Therm (0x5001bd35)
[0022.447] I> Task: Program NV master stream id (0x5000c05d)
[0022.453] I> Task: Verify boot mode (0xd4820f1)
[0022.459] I> Task: Alias fuses (0x5001095d)
[0022.463] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0022.470] I> Task: Print SKU type (0x5000f5f1)
[0022.475] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0022.480] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0022.484] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0022.488] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0022.493] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0022.497] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0022.501] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0022.506] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0022.510] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0022.514] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0022.519] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0022.523] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0022.527] I> FUSE_SKU_INFO_0 = 0xd3
[0022.530] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0022.534] I> FUSE_PACKAGE_INFO_0 = 0x2
[0022.538] I> SKU: Prod
[0022.540] I> Task: Boost clocks (0x500148a1)
[0022.544] I> Initializing PLLC2 for AXI_CBB.
[0022.548] I> AXI_CBB : src = 35, divisor = 0
[0022.552] I> Task: Voltage monitor (0x50014b49)
[0022.557] I> VMON: Vmon re-calibration and fine tuning done
[0022.562] I> Task: UPHY init (0x5000d065)
[0022.568] I> HSIO UPHY init done
[0022.571] E> Skipping GBE UPHY config
[0022.575] I> Task: Boot device init (0x50000be9)
[0022.579] I> Boot_device: RCM
[0022.582] I> USB configuration success
[0023.496] I> Task: TSC init (0x50020a4d)
[0023.500] I> Task: Load membct (0x50011fe9)
[0023.504] I> RAM_CODE 0x4000001
[0023.507] I> Loading MEMBCT
[0023.510] I> Slot: 0
[0023.512] I> Binary[0] block-0 (partition size: 0x40000)
[0023.517] I>  get_binary_info: Binary name: MEM-BCT-0
[0023.522] I> Size of crypto header is 8192
[0023.526] I> BCH load address is : 0x40050000
[0023.530] I> Size of crypto header is 8192
[0023.534] I> BCH of MEM-BCT-0 read from storage
[0023.538] I> BCH address is : 0x40050000
[0023.542] I> MEM-BCT-0 header integrity check is success
[0023.547] I> Binary magic in BCH component 0 is MEM0
[0023.552] I> component binary type is 0
[0023.558] I> MEM-BCT-0 binary is read from storage
[0023.562] I> MEM-BCT-0 binary integrity check is success
[0023.568] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0023.574] I> RAM_CODE 0x4000001
[0023.580] I> RAM_CODE 0x4000001
[0023.583] I> Task: Load Page retirement list (0x500115b1)
[0023.589] I> Task: SDRAM params override (0x50011fc5)
[0023.593] I> Task: Save mem-bct info (0x50014fa1)
[0023.598] I> Task: Carveout allocate (0x50015005)
[0023.603] I> ECC region[0]: Start:0x0, End:0x0
[0023.607] I> ECC region[1]: Start:0x0, End:0x0
[0023.611] I> ECC region[2]: Start:0x0, End:0x0
[0023.615] I> ECC region[3]: Start:0x0, End:0x0
[0023.620] I> ECC region[4]: Start:0x0, End:0x0
[0023.624] I> Non-ECC region[0]: Start:0x80000000, End:0x480000000
[0023.630] I> Non-ECC region[1]: Start:0x0, End:0x0
[0023.635] I> Non-ECC region[2]: Start:0x0, End:0x0
[0023.639] I> Non-ECC region[3]: Start:0x0, End:0x0
[0023.644] I> Non-ECC region[4]: Start:0x0, End:0x0
[0023.653] I> allocated(CO:31) base:0x478000000 size:0x8000000 align: 0x8000000
[0023.661] I> allocated(CO:43) base:0x474000000 size:0x4000000 align: 0x200000
[0023.668] I> allocated(CO:20) base:0x472000000 size:0x2000000 align: 0x2000000
[0023.675] I> allocated(CO:24) base:0x470000000 size:0x2000000 align: 0x2000000
[0023.682] I> allocated(CO:28) base:0x46e000000 size:0x2000000 align: 0x2000000
[0023.689] I> allocated(CO:22) base:0x46d000000 size:0x1000000 align: 0x1000000
[0023.696] I> allocated(CO:35) base:0x46c200000 size:0xe00000 align: 0x10000
[0023.703] I> allocated(CO:02) base:0x46b800000 size:0x800000 align: 0x800000
[0023.710] I> allocated(CO:03) base:0x46b000000 size:0x800000 align: 0x800000
[0023.717] I> allocated(CO:06) base:0x46a800000 size:0x800000 align: 0x800000
[0023.724] I> allocated(CO:10) base:0x46a000000 size:0x800000 align: 0x800000
[0023.731] I> allocated(CO:56) base:0x469800000 size:0x800000 align: 0x200000
[0023.738] I> allocated(CO:07) base:0x469400000 size:0x400000 align: 0x400000
[0023.744] I> allocated(CO:33) base:0x469000000 size:0x400000 align: 0x200000
[0023.751] I> allocated(CO:23) base:0x46c000000 size:0x200000 align: 0x200000
[0023.758] I> allocated(CO:01) base:0x468f00000 size:0x100000 align: 0x100000
[0023.765] I> allocated(CO:04) base:0x468e00000 size:0x100000 align: 0x100000
[0023.772] I> allocated(CO:05) base:0x468d00000 size:0x100000 align: 0x100000
[0023.779] I> allocated(CO:08) base:0x468c00000 size:0x100000 align: 0x100000
[0023.786] I> allocated(CO:09) base:0x468b00000 size:0x100000 align: 0x100000
[0023.793] I> allocated(CO:15) base:0x468a00000 size:0x100000 align: 0x100000
[0023.800] I> allocated(CO:17) base:0x468900000 size:0x100000 align: 0x100000
[0023.807] I> allocated(CO:27) base:0x468800000 size:0x100000 align: 0x100000
[0023.814] I> allocated(CO:42) base:0x468700000 size:0x100000 align: 0x100000
[0023.821] I> allocated(CO:54) base:0x468680000 size:0x80000 align: 0x80000
[0023.827] I> allocated(CO:34) base:0x468670000 size:0x10000 align: 0x10000
[0023.834] I> allocated(CO:46) base:0x440000000 size:0x20000000 align: 0x2000000
[0023.841] I> allocated(CO:47) base:0x468200000 size:0x400000 align: 0x200000
[0023.848] I> allocated(CO:72) base:0x468000000 size:0x200000 align: 0x10000
[0023.855] I> allocated(CO:48) base:0x468650000 size:0x20000 align: 0x10000
[0023.862] I> allocated(CO:69) base:0x468630000 size:0x20000 align: 0x10000
[0023.869] I> allocated(CO:49) base:0x468620000 size:0x10000 align: 0x10000
[0023.875] I> allocated(CO:50) base:0x468610000 size:0x10000 align: 0x10000
[0023.882] I> NSDRAM base: 0x80000000, end: 0x468670000
[0023.887] I> Task: Thermal check (0x50021d55)
[0023.891] I> max_chip_limit = 105
[0023.894] I> min_chip_limit = -28
[0023.898] I> max temp read = 55
[0023.901] I> min temp read = 51
[0023.904] I> Task: Update FSI SCR with thermal fuse data (0x50021e61)
[0023.910] I> Task: Enable WDT 5th expiry (0x50021a41)
[0023.915] I> Task: I2C register (0x50000b85)
[0023.919] I> Task: Reset FSI (0x500148b1)
[0023.923] I> Task: Pinmux init (0x5001397d)
[0023.927] I> skipped mmio_addr = 0x9240008
[0023.931] I> skipped mmio_addr = 0x9240000
[0023.935] I> skipped mmio_addr = 0x9240010
[0023.939] I> skipped mmio_addr = 0x9240018
[0023.943] I> skipped mmio_addr = 0x9240020
[0023.947] I> skipped mmio_addr = 0x9240030
[0023.951] I> skipped mmio_addr = 0x9240028
[0023.955] I> skipped mmio_addr = 0x9240038
[0023.959] I> skipped mmio_addr = 0x9240040
[0023.963] I> skipped mmio_addr = 0x9240048
[0023.966] I> skipped mmio_addr = 0x9241000
[0023.970] I> skipped mmio_addr = 0x9241008
[0023.974] I> skipped mmio_addr = 0x9241010
[0023.978] I> skipped mmio_addr = 0x9241018
[0023.982] I> skipped mmio_addr = 0x9241020
[0023.986] I> skipped mmio_addr = 0x9241028
[0023.990] I> skipped mmio_addr = 0x9241030
[0023.994] I> skipped mmio_addr = 0x9241038
[0023.998] I> skipped mmio_addr = 0x9241040
[0024.002] I> skipped mmio_addr = 0x9242000
[0024.006] I> skipped mmio_addr = 0x9242008
[0024.010] I> Task: Prod config init (0x50013ddd)
[0024.014] I> Task: Pad voltage init (0x50013a2d)
[0024.019] I> Task: Prod init (0x50013e21)
[0024.023] I> Task: Common rail init (0x50014575)
[0024.027] I> DONE: Thermal config
[0024.032] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0024.040] I> DONE: SOC rail config
[0024.043] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0024.050] I> DONE: MEMIO rail config
[0024.054] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0024.060] I> DONE: GPU rail info
[0024.064] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0024.070] I> DONE: CV rail info
[0024.073] I> Task: Mem clock src (0x50011de9)
[0024.077] I> Task: Misc. board config (0x5001461d)
[0024.082] W> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0024.088] I> Task: SDRAM init (0x50011ded)
[0024.092] I> SDRAM-params @ 0xd485000
[0024.096] I> MemoryType: 4 MemBctRevision: 1
[0024.102] I> MSS code-drop: NvBootSdramInit
[0024.106] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevisio1
[0024.114] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevisio1
[0024.121] I> MSS CAR: Init PLLM
[0024.124] I> MSS CAR: Init PLLHUB
[0024.129] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
Could you try to run initrd flash with --no-flash command and see if it just output the same thing as this serial console log?
