22d148
December 14, 2024, 8:17pm
1
Host Os: Ubuntu 20.04
Device: Jetson Nano Dev Kit
BackStory :
I was trying to downgrade my Jetson from Jetpack 6 to Jetpack 5 with cmd on sd card following the forums since i was having error with sdk based on this
https://docs.nvidia.com/jetson/archives/r35.5.0/DeveloperGuide/IN/QuickStart.html#jetson-modules-and-configurations
Problem:
While trying to debug my issues ,I accidentally ran this command from this forum
**sudo ./flash.sh -c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg p3509-a02+p3767-0000 nvme0n1p1**
Your log was not completed in the first comment. Now it has the full one.
E> OCR failed, error = 39390706
E> Failed to open sdmmc-3, err = 39390706
W> Ignoring init failure for device 0-3
E> Error in command_complete 18000 int_status
W> Ignoring init failure for device 1-3
E> Unknown device 7
E> Unknown device 8
I> Task: Partition Manager Init (0x40002d25)
W> Cannot find any partition table for 00030000
P…
The command ran fully and said “successfully flashed” etc , Later I realized that this command is for Nvme and not sd card . I think it changed some bootloader configurations and I am not able to start flashing from SDK , earlier i just had some small error at the end , now it doesnt even starts flashing.Now it doesnt even give output from DP to access BIOS.
Thank you for your assistance.
Just to clarify.
“Jetson Nano” is the old TX1 SoC that was released 5 years ago and “Jetson Orin Nano” is the new Orin SoC released last year.
These two are different thing. What is the exact board you are using? It looks like a Orin one but you filed in wrong forum.
22d148
December 15, 2024, 9:05am
3
It is Orin Nano Developer Kit , Apologize for the confusing them. , I changed the topic to the correct one.
please dump the serial console log. Boot up the board in this situation and then capture the log.
system
Closed
January 16, 2025, 7:39am
7
