NX烧录QSPI后启动不了
烧录命令是:./flash.sh -c bootloader/generic/cfg/flash_t234_qspi.xml $BOARD nvme0n1p1
烧录完成后设备启动不了,在一直重启
我这里有4个核心板:NX 16GB,NX 8GB,Nano 8GB,Nano 4GB,只有NX 8GB启动不了
请问是什么原因?
下面是启动日志:
[0000.063] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0000.068] I> t234-A01-0-Silicon (0x12347) Prod
[0000.072] I> Boot-mode : Coldboot
[0000.075] I> Entry timestamp: 0x00000000
[0000.079] I> last_boot_error: 0x0
[0000.082] I> BR-BCT: preprod_dev_sign: 0
[0000.086] I> rst_source: 0x0, rst_level: 0x0
[0000.090] I> Task: SE error check
[0000.093] I> Task: Bootchain select WAR set
[0000.097] I> Task: Enable SLCG
[0000.100] I> Task: CRC check
[0000.103] I> Task: Initialize MB2 params
[0000.107] I> MB2-params @ 0x40060000
[0000.111] I> Task: Crypto init
[0000.114] I> Task: Perform MB1 KAT tests
[0000.118] I> Task: NVRNG health check
[0000.121] I> NVRNG: Health check success
[0000.125] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.131] I> Task: Enabling and initialization of Bandwidth limiter
[0000.137] I> No request to configure MBWT settings for any PC!
[0000.143] I> Task: Secure debug controls
[0000.147] I> Task: strap war set
[0000.150] I> Task: Initialize SOC Therm
[0000.153] I> Task: Program NV master stream id
[0000.158] I> Task: Verify boot mode
[0000.163] I> Task: Alias fuses
[0000.167] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.174] I> Task: Print SKU type
[0000.177] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.182] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0000.187] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0000.191] I> FUSE_OPT_DLA_DISABLE = 0x00000001
[0000.195] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.199] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.204] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.208] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.213] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.217] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.221] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.225] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.229] I> FUSE_SKU_INFO_0 = 0xd4
[0000.233] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.237] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.240] I> SKU: Prod
[0000.243] I> Task: Boost clocks
[0000.246] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.251] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.256] I> BPMP NAFLL lock success.
[0000.260] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.264] I> Initializing PLLC2 for AXI_CBB.
[0000.268] I> AXI_CBB : src = 35, divisor = 0
[0000.272] I> Task: Voltage monitor
[0000.276] I> VMON: Vmon re-calibration and fine tuning done
[0000.281] I> Task: UPHY init
[0000.286] I> HSIO UPHY init done
[0000.289] W> Skipping GBE UPHY config
[0000.293] I> Task: Boot device init
[0000.296] I> Boot_device: QSPI_FLASH instance: 0
[0000.301] I> Qspi clock source : pllc_out0
[0000.305] I> QSPI Flash: Macronix 64MB
[0000.308] I> QSPI-0l initialized successfully
[0000.312] I> Task: TSC init
[0000.315] I> Task: Load membct
[0000.318] I> RAM_CODE 0x4000421
[0000.321] I> Loading MEMBCT
[0000.324] I> Slot: 0
[0000.326] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.331] I> Binary name: MEM-BCT-0
[0000.335] I> Size of crypto header is 8192
[0000.339] I> Size of crypto header is 8192
[0000.343] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.349] I> BCH of MEM-BCT-0 read from storage
[0000.353] I> BCH address is : 0x40050000
[0000.357] I> MEM-BCT-0 header integrity check is success
[0000.362] I> Binary magic in BCH component 0 is MEM0
[0000.367] I> component binary type is 0
[0000.371] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.378] I> MEM-BCT-0 binary is read from storage
[0000.382] I> MEM-BCT-0 binary integrity check is success
[0000.388] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.394] I> RAM_CODE 0x4000421
[0000.400] I> RAM_CODE 0x4000421
[0000.404] I> Task: Load Page retirement list
[0000.408] I> Task: SDRAM params override
[0000.411] I> Task: Save mem-bct info
[0000.415] I> Task: Carveout allocate
[0000.418] I> RCM blob carveout will not be allocated
[0000.423] I> Update CCPLEX IST carveout from MB1-BCT
[0000.428] I> ECC region[0]: Start:0x0, End:0x0
[0000.432] I> ECC region[1]: Start:0x0, End:0x0
[0000.436] I> ECC region[2]: Start:0x0, End:0x0
[0000.441] I> ECC region[3]: Start:0x0, End:0x0
[0000.445] I> ECC region[4]: Start:0x0, End:0x0
[0000.449] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000
[0000.455] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.460] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.465] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.469] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.480] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.487] I> allocated(CO:39) base:0x27de00000 size:0x2200000 align: 0x10000
[0000.494] I> allocated(CO:20) base:0x27a000000 size:0x2000000 align: 0x2000000
[0000.501] I> allocated(CO:24) base:0x278000000 size:0x2000000 align: 0x2000000
[0000.508] I> allocated(CO:28) base:0x276000000 size:0x2000000 align: 0x2000000
[0000.515] I> allocated(CO:22) base:0x27c000000 size:0x1000000 align: 0x1000000
[0000.522] I> allocated(CO:35) base:0x275000000 size:0x1000000 align: 0x100000
[0000.529] I> allocated(CO:02) base:0x27d000000 size:0x800000 align: 0x800000
[0000.536] I> allocated(CO:03) base:0x274800000 size:0x800000 align: 0x800000
[0000.543] I> allocated(CO:06) base:0x274000000 size:0x800000 align: 0x800000
[0000.550] I> allocated(CO:56) base:0x273800000 size:0x800000 align: 0x200000
[0000.557] I> allocated(CO:07) base:0x27d800000 size:0x400000 align: 0x400000
[0000.564] I> allocated(CO:33) base:0x273400000 size:0x400000 align: 0x200000
[0000.571] I> allocated(CO:19) base:0x273180000 size:0x280000 align: 0x10000
[0000.578] I> allocated(CO:23) base:0x27dc00000 size:0x200000 align: 0x200000
[0000.585] I> allocated(CO:01) base:0x273000000 size:0x100000 align: 0x100000
[0000.592] I> allocated(CO:05) base:0x272f00000 size:0x100000 align: 0x100000
[0000.598] I> allocated(CO:08) base:0x272e00000 size:0x100000 align: 0x100000
[0000.605] I> allocated(CO:09) base:0x272d00000 size:0x100000 align: 0x100000
[0000.612] I> allocated(CO:12) base:0x272c00000 size:0x100000 align: 0x100000
[0000.619] I> allocated(CO:15) base:0x272b00000 size:0x100000 align: 0x100000
[0000.626] I> allocated(CO:17) base:0x272a00000 size:0x100000 align: 0x100000
[0000.633] I> allocated(CO:27) base:0x272900000 size:0x100000 align: 0x100000
[0000.640] I> allocated(CO:42) base:0x272800000 size:0x100000 align: 0x100000
[0000.647] I> allocated(CO:54) base:0x273100000 size:0x80000 align: 0x80000
[0000.654] I> allocated(CO:34) base:0x2727f0000 size:0x10000 align: 0x10000
[0000.661] I> allocated(CO:72) base:0x2725f0000 size:0x200000 align: 0x10000
[0000.667] I> allocated(CO:47) base:0x272000000 size:0x400000 align: 0x200000
[0000.674] I> allocated(CO:50) base:0x271e00000 size:0x200000 align: 0x100000
[0000.681] I> allocated(CO:48) base:0x2725d0000 size:0x20000 align: 0x10000
[0000.688] I> allocated(CO:69) base:0x2725b0000 size:0x20000 align: 0x10000
[0000.695] I> allocated(CO:49) base:0x2725a0000 size:0x10000 align: 0x10000
[0000.702] I> NSDRAM base: 0x80000000, end: 0x2725f0000, size: 0x1f25f0000
[0000.708] I> Task: Thermal check
[0000.711] I> Using min_chip_limit as min_tmon_limit
[0000.716] I> Using max_chip_limit as max_tmon_limit
[0000.721] I> BCT max_tmon_limit = 105
[0000.724] I> BCT min_tmon_limit = -28
[0000.728] I> BCT max_tmon_limit = 105
[0000.731] I> BCT min_tmon_limit = -28
[0000.735] I> SKU specific max_chip_limit = 105
[0000.739] I> SKU specific min_chip_limit = -28
[0000.743] I> BCT max_chip_limit = 105
[0000.747] I> BCT min_chip_limit = -28
[0000.750] I> enable_soctherm_polling = 0
[0000.754] I> max temp read = 55
[0000.757] I> min temp read = 54
[0000.760] I> Enabling thermtrip
[0000.763] I> Task: Update FSI SCR with thermal fuse data
[0000.768] I> Task: Enable WDT 5th expiry
[0000.772] I> Task: I2C register
[0000.775] I> Task: Set I2C bus freq
[0000.778] I> Task: Reset FSI
[0000.781] I> Task: Pinmux init
[0000.784] I> skipped mmio_addr = 0x9240008
[0000.788] I> skipped mmio_addr = 0x9240000
[0000.792] I> skipped mmio_addr = 0x9240010
[0000.796] I> skipped mmio_addr = 0x9240018
[0000.800] I> skipped mmio_addr = 0x9240020
[0000.804] I> skipped mmio_addr = 0x9240030
[0000.808] I> skipped mmio_addr = 0x9240028
[0000.812] I> skipped mmio_addr = 0x9240038
[0000.816] I> skipped mmio_addr = 0x9240040
[0000.820] I> skipped mmio_addr = 0x9240048
[0000.824] I> skipped mmio_addr = 0x9241000
[0000.828] I> skipped mmio_addr = 0x9241008
[0000.831] I> skipped mmio_addr = 0x9241010
[0000.835] I> skipped mmio_addr = 0x9241018
[0000.839] I> skipped mmio_addr = 0x9241020
[0000.843] I> skipped mmio_addr = 0x9241028
[0000.847] I> skipped mmio_addr = 0x9241030
[0000.851] I> skipped mmio_addr = 0x9241038
[0000.855] I> skipped mmio_addr = 0x9241040
[0000.859] I> skipped mmio_addr = 0x9242000
[0000.863] I> skipped mmio_addr = 0x9242008
[0000.867] I> Task: Prod config init
[0000.870] I> Task: Pad voltage init
[0000.874] I> Task: Prod init
[0000.876] I> Task: Program rst req config reg
[0000.881] I> Task: Common rail init
[0000.884] I> DONE: Thermal config
[0000.888] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.896] I> DONE: SOC rail config
[0000.900] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.906] I> DONE: MEMIO rail config
[0000.910] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.916] I> DONE: GPU rail info
[0000.919] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.925] I> DONE: CV rail info
[0000.928] I> Task: Mem clock src
[0000.931] I> Task: Misc. board config
[0000.935] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.941] I> Task: SDRAM init
[0000.944] I> MemoryType: 4 MemBctRevision: 1
[0000.950] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.958] I> MSS CAR: Init PLLM
[0000.961] I> MSS CAR: Init PLLHUB
[0000.966] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0000.977] I> SDRAM initialized!
[0000.980] I> SDRAM Size in Total 0x200000000
[0000.984] I> Task: Dram Ecc scrub
[0000.987] I> Task: DRAM alias check
[0000.994] I> Task: Program NSDRAM carveout
[0000.998] I> NSDRAM carveout encryption is enabled
[0001.002] I> Program NSDRAM carveout
[0001.006] I> Task: Register checker
[0001.009] I> Task: Enable clock-mon
[0001.013] I> FMON: Fmon re-programming done
[0001.017] I> Task: Mapper init
[0001.020] I> Task: SC7 Context Init
[0001.024] I> Task: CCPLEX IST init
[0001.027] I> Task: CPU WP0
[0001.030] I> Loading MCE
[0001.032] I> Slot: 0
[0001.034] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.040] I> Binary name: MCE
[0001.042] I> Size of crypto header is 8192
[0001.046] I> Size of crypto header is 8192
[0001.050] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.057] I> BCH of MCE read from storage
[0001.060] I> BCH address is : 0x4003e000
[0001.064] I> MCE header integrity check is success
[0001.069] I> Binary magic in BCH component 0 is MTSM
[0001.074] I> component binary type is 8
[0001.077] I> Size of crypto header is 8192
[0001.081] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.090] I> MCE binary is read from storage
[0001.094] I> MCE binary integrity check is success
[0001.099] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.105] I> Size of crypto header is 8192
[0001.116] I> Size of crypto header is 8192
[0001.120] I> Sending WP0 mailbox command to PSC
[0001.129] I> Task: XUSB Powergate
[0001.132] I> Skipping powergate XUSB.
[0001.136] I> Task: MB1 fixed firewalls
[0001.142] W> Firewall readback mismatch
[0001.147] I> Task: Load bpmp-fw
[0001.150] I> Slot: 0
[0001.152] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.158] I> Binary name: BPMP_FW
[0001.161] I> Size of crypto header is 8192
[0001.165] I> Size of crypto header is 8192
[0001.169] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.175] I> BCH of BPMP_FW read from storage
[0001.179] I> BCH address is : 0x807fe000
[0001.183] I> BPMP_FW header integrity check is success
[0001.188] I> Binary magic in BCH component 0 is BPMF
[0001.193] I> component binary type is 15
[0001.196] I> Size of crypto header is 8192
[0001.200] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.218] I> BPMP_FW binary is read from storage
[0001.224] I> BPMP_FW binary integrity check is success
[0001.229] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.236] I> Slot: 0
[0001.238] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.243] I> Binary name: BPMP_FW_DTB
[0001.247] I> Size of crypto header is 8192
[0001.251] I> Size of crypto header is 8192
[0001.255] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.261] I> BCH of BPMP_FW_DTB read from storage
[0001.266] I> BCH address is : 0x807fc000
[0001.269] I> BPMP_FW_DTB header integrity check is success
[0001.275] I> Binary magic in BCH component 0 is BPMD
[0001.280] I> component binary type is 16
[0001.283] I> Size of crypto header is 8192
[0001.287] I> strt_pg_num(13072) num_of_pgs(499) read_buf(0x807bd9f0)
[0001.296] I> BPMP_FW_DTB binary is read from storage
[0001.302] I> BPMP_FW_DTB binary integrity check is success
[0001.307] I> Binary BPMP_FW_DTB loaded successfully at 0x807bd9f0 (0x3e500)
[0001.314] I> Task: BPMP fw ast config
[0001.317] I> Task: Load psc-fw
[0001.320] I> Slot: 0
[0001.322] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.328] I> Binary name: PSC_FW
[0001.331] I> Size of crypto header is 8192
[0001.335] I> Size of crypto header is 8192
[0001.339] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.345] I> BCH of PSC_FW read from storage
[0001.349] I> BCH address is : 0x80ffe000
[0001.353] I> PSC_FW header integrity check is success
[0001.358] I> Binary magic in BCH component 0 is PFWP
[0001.363] I> component binary type is 17
[0001.366] I> Size of crypto header is 8192
[0001.370] I> strt_pg_num(21264) num_of_pgs(591) read_buf(0x80fb4200)
[0001.380] I> PSC_FW binary is read from storage
[0001.385] I> PSC_FW binary integrity check is success
[0001.390] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.396] I> Task: Load nvdec-fw
[0001.399] I> Slot: 0
[0001.401] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.407] I> Binary name: NVDEC
[0001.410] I> Size of crypto header is 8192
[0001.414] I> Size of crypto header is 8192
[0001.418] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.424] I> BCH of NVDEC read from storage
[0001.428] I> BCH address is : 0x800fe000
[0001.432] I> NVDEC header integrity check is success
[0001.436] I> Binary magic in BCH component 0 is NDEC
[0001.441] I> component binary type is 7
[0001.445] I> Size of crypto header is 8192
[0001.449] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.458] I> NVDEC binary is read from storage
[0001.463] I> NVDEC binary integrity check is success
[0001.468] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.474] I> Size of crypto header is 8192
[0001.486] I> Task: Load tsec-fw
[0001.489] I> TSEC-FW load support not enabled
[0001.493] I> Task: GPIO interrupt map
[0001.496] I> Task: SC7 context save
[0001.500] I> Slot: 0
[0001.502] I> Binary[27] block-0 (partition size: 0x100000)
[0001.507] I> Binary name: BR_BCT
[0001.510] I> Size of crypto header is 8192
[0001.514] I> Size of crypto header is 8192
[0001.518] I> Size of crypto header is 8192
[0001.522] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.528] I> BR_BCT binary is read from storage
[0001.532] I> BR_BCT binary integrity check is success
[0001.537] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.544] I> Slot: 0
[0001.546] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.551] I> Binary name: SC7-FW
[0001.554] I> Size of crypto header is 8192
[0001.558] I> Size of crypto header is 8192
[0001.562] I> Size of crypto header is 8192
[0001.566] I> Size of crypto header is 8192
[0001.570] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.576] I> BCH of SC7-FW read from storage
[0001.580] I> BCH address is : 0xa0002000
[0001.584] I> SC7-FW header integrity check is success
[0001.589] I> Binary magic in BCH component 0 is WB0B
[0001.594] I> component binary type is 13
[0001.598] I> Size of crypto header is 8192
[0001.602] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[0001.610] I> SC7-FW binary is read from storage
[0001.615] I> SC7-FW binary integrity check is success
[0001.619] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b920)
[0001.626] I> Slot: 0
[0001.628] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.633] I> Binary name: PSC_RF
[0001.636] I> Size of crypto header is 8192
[0001.640] I> Size of crypto header is 8192
[0001.644] I> Size of crypto header is 8192
[0001.648] I> Size of crypto header is 8192
[0001.652] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f920)
[0001.658] I> BCH of PSC_RF read from storage
[0001.663] I> BCH address is : 0xa002f920
[0001.666] I> PSC_RF header integrity check is success
[0001.671] I> Binary magic in BCH component 0 is PSCR
[0001.676] I> component binary type is 22
[0001.680] I> Size of crypto header is 8192
[0001.684] I> strt_pg_num(24208) num_of_pgs(224) read_buf(0xa0031920)
[0001.691] I> PSC_RF binary is read from storage
[0001.696] I> PSC_RF binary integrity check is success
[0001.701] I> Binary PSC_RF loaded successfully at 0xa0031920 (0x1be60)
[0001.710] I> Task: Save WP0 payload to SC7 ctx
[0001.715] I> Task: Load MB2rf binary to SC7 ctx
[0001.719] I> Slot: 0
[0001.721] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.726] I> Binary name: MB2_RF
[0001.730] I> Size of crypto header is 8192
[0001.733] I> Size of crypto header is 8192
[0001.737] I> Size of crypto header is 8192
[0001.741] I> Size of crypto header is 8192
[0001.745] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.752] I> BCH of MB2_RF read from storage
[0001.756] I> BCH address is : 0xa00d5d10
[0001.760] I> MB2_RF header integrity check is success
[0001.764] I> Binary magic in BCH component 0 is MB2R
[0001.769] I> component binary type is 14
[0001.773] I> Size of crypto header is 8192
[0001.777] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.784] I> MB2_RF binary is read from storage
[0001.789] I> MB2_RF binary integrity check is success
[0001.794] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf30)
[0001.800] I> Task: Save fuse alias data to SC7 ctx
[0001.805] I> Task: Save PMIC data to SC7 ctx
[0001.809] I> Task: Save Pinmux data to SC7 ctx
[0001.813] I> Task: Save Pad Voltage data to SC7 ctx
[0001.818] I> Task: Save controller prod data to SC7 ctx
[0001.823] I> Task: Save prod cfg data to SC7 ctx
[0001.828] I> Task: Save I2C bus freq data to SC7 ctx
[0001.832] I> Task: Save SOCTherm data to SC7 ctx
[0001.837] I> Task: Save FMON data to SC7 ctx
[0001.841] I> Task: Save VMON data to SC7 ctx
[0001.845] I> Task: Save TZDRAM data to SC7 ctx
[0001.849] I> Task: Save GPIO int data to SC7 ctx
[0001.854] I> Task: Save clock data to SC7 ctx
[0001.858] I> Task: Save debug data to SC7 ctx
[0001.862] I> Task: Save MBWT data to SC7 ctx
[0001.870] I> SC7 context save done
[0001.874] I> Task: Load MB2/Applet/FSKP
[0001.877] I> Loading MB2
[0001.880] I> Slot: 0
[0001.882] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.887] I> Binary name: MB2
[0001.890] I> Size of crypto header is 8192
[0001.894] I> Size of crypto header is 8192
[0001.898] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.904] I> BCH of MB2 read from storage
[0001.908] I> BCH address is : 0x8007e000
[0001.912] I> MB2 header integrity check is success
[0001.916] I> Binary magic in BCH component 0 is MB2B
[0001.921] I> component binary type is 6
[0001.925] I> Size of crypto header is 8192
[0001.929] I> strt_pg_num(8464) num_of_pgs(844) read_buf(0x80000000)
[0001.940] I> MB2 binary is read from storage
[0001.944] I> MB2 binary integrity check is success
[0001.949] I> Binary MB2 loaded successfully at 0x80000000 (0x696a0)
[0001.955] I> Task: Map CCPLEX SHARED carveout
[0001.960] I> Task: Prepare MB2 params
[0001.963] I> Task: Dram ecc test
[0001.966] I> Task: Misc NV security settings
[0001.971] I> NVDEC sticky bits programming done
[0001.975] I> Successfully powergated NVDEC
[0001.979] I> Task: Disable/Reload WDT
[0001.982] I> Task: Program misc carveouts
[0001.986] I> Program IPC carveouts
[0001.990] I> Task: Disable SCPM/POD reset
[0001.994] I> SLCG Global override status := 0x0
[0001.998] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-af79ed0a)
I> Emulation:
I> Entry timestamp: 0x001ee360
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x273800000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: Enable hot-plug capability
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Partition Manager Init
I> strt_pg_num(1) num_of_pgs(1) read_buf(0x273801000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0x273801000)
I> strt_pg_num(131039) num_of_pgs(32) read_buf(0x273801200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> strt_pg_num(55040) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(55056) num_of_pgs(512) read_buf(0x272e00000)
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> strt_pg_num(56192) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(56208) num_of_pgs(880) read_buf(0x272a00000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x272e00000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> strt_pg_num(44800) num_of_pgs(16) read_buf(0x40066880)
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x272a00000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(44816) num_of_pgs(1) read_buf(0x2739400d8)
I> strt_pg_num(44816) num_of_pgs(8) read_buf(0x2739400d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(44824) num_of_pgs(512) read_buf(0x2738000c0)
I> strt_pg_num(45336) num_of_pgs(512) read_buf(0x2738400c0)
I> dce : will be decompressed at 0x27a000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(45848) num_of_pgs(512) read_buf(0x2738800c0)
I> dce : decompressed to 11853952 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> strt_pg_num(58240) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(58256) num_of_pgs(800) read_buf(0x27d800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x27a000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> strt_pg_num(9472) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(9488) num_of_pgs(312) read_buf(0x272f00000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x27d800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: A_pva-fw
I> Binary@ device:3/0 block-62336 (partition size: 0x40000), name: A_pva-fw
I> strt_pg_num(62336) num_of_pgs(16) read_buf(0x40066880)
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x272f00000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(62352) num_of_pgs(1) read_buf(0x2739400d8)
I> strt_pg_num(62352) num_of_pgs(8) read_buf(0x2739400d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(62360) num_of_pgs(512) read_buf(0x2738000c0)
I> pva-fw : will be decompressed at 0x273180000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x273180000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x276000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
I> Task: FSI padctl context save
W> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE..
I> Enabling combined UART
???pe: early_init
??ic initialized
??sc initialized
??on lic initialized
??pe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
??pe: SafeRTOS v8.4
??pe: init
??cheduler initialized
??on hsp initialized
??ag initialized
??cu initialized
??pmp ipc initialized
??pe: late init
??pu_nic clock initialized
??pb clock initialized
??m initialized
??pmp hsp initialized
??op1 hsp initialized
??cplex ipc initialized
??pe: start scheduler
   ?> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Start secure NOR provision
I> Skip Secure NOR provisioning
I> Task: Trigger load FSI keyblob
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d to psc
 ?wwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is 3b0e1a33cf85c7f62a7e8b93c2af97ed
bpmp: combined binary md5 is 6432e47ee22b94f945d6c4e54b6b9344
bpmp: firmware tag is 6432e47ee22b94f945d6-3b0e1a33cf8
Write control check for CBB_CENTRAL_CBB_FIREWALL_PWM7_BLF failed, expected value: 00100008 != actual value: 0010000a address: 13a178a8
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
?> Received ACK from psc
I> Task: ?nitialized avfs_clk_platform
initialized powergate
?nhalt FSI
I> FSI unhal?nitialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
? skipped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load HV/CPUBL
I> Task: Load TOS
I> Task: Trigger load TSEC leyblob
I> Sending opcode 0x53535452 to psc
I> Sent opcode to psc
I> Tas?     2.566585] Camera-FW on t234-rce-safe started
TCU early console enabled.
?nitialized emc
initialized emc_mrq
?: Load a?nitialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
 ??d aut?nitialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
?enticate registered FWs
?CE Started
DCE_R5_Init
MPU enabled
DCE_SW_Init
BUG: /?nitialized clk_cal_late
initialized noc_late
initialized cvc
?vs/git/d?> Partition name: A_?nitialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable sdmmc4_axicif
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
?     2.748471] Camer?nable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initia?-FW on t234-rce-safe ready SHA1=e2238c99 (crt 15.721 ms, total boot 198.680 m?ized cactmon
initialized extras_post
bpmp: init complete
?rty/git-?pu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
?aster_linux/display/dce/init/dce-init.c:185  dce_dt_init failed, rc = 0x4000003c"
Abort: reason:0x30?> strt_pg_num(24832) num_of_pgs(16) read_buf(0x40066880)
? Err:0x0 [(NULL)]
?> cpubl : oem authentication of header done
I> strt_pg_num(24848) num_of_pgs(1) read_buf(0x273943c98)
I> strt_pg_num(24848) num_of_pgs(8) read_buf(0x273943c98)
I> cpubl : meta-blob integrity check is success.
I> strt_pg_num(24856) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(25368) num_of_pgs(512) read_buf(0x273843c80)
I> cpubl : will be decompressed at 0x272000000
I> strt_pg_num(25880) num_of_pgs(512) read_buf(0x273883c80)
I> strt_pg_num(26392) num_of_pgs(512) read_buf(0x2738c3c80)
I> strt_pg_num(26904) num_of_pgs(512) read_buf(0x273903c80)
I> strt_pg_num(27416) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(27928) num_of_pgs(512) read_buf(0x273843c80)
I> strt_pg_num(28440) num_of_pgs(512) read_buf(0x273883c80)
I> strt_pg_num(28952) num_of_pgs(512) read_buf(0x2738c3c80)
I> strt_pg_num(29464) num_of_pgs(512) read_buf(0x273903c80)
I> strt_pg_num(29976) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(30488) num_of_pgs(512) read_buf(0x273843c80)
I> strt_pg_num(31000) num_of_pgs(512) read_buf(0x273883c80)
I> cpubl : decompressed to 3317888 bytes
I> cpubl: plain binary integrity check is success
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> strt_pg_num(32000) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(32016) num_of_pgs(3176) read_buf(0xc1d73000)
I> NSDRAM carveout base: 0x80000000, size: 0x1f25f0000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x272000000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0xc1d73000
I> Relocating OP-TEE dtb from: 0xc1eff0f0 to 0xbe040020, size: 0x2889
I> [0] START: 0x80000000, SIZE: 0x1f25f0000
I> [1] START: 0x276000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> strt_pg_num(44288) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(44304) num_of_pgs(8) read_buf(0xbe020000)
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0xbe020000
I> EKB detected (length: 0x410) @ VA:0xbe020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0xbe040020
I> OEM sc7 context saved
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
I> Task: Storage device deinit
I> Task: SMMU external bypass disable
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Bootchain failure check
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
?OTICE:  BL31: v2.8(release):e12e3fa93
NOTICE:  BL31: Built : 19:36:31, Apr 24 2024
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Thu Apr 25 02:48:28 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
?hutdown state requested 1
Rebooting system ...
[0000.061] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0000.067] I> t234-A01-0-Silicon (0x12347) Prod
[0000.071] I> Boot-mode : Coldboot
[0000.074] I> Entry timestamp: 0x00000000
[0000.078] I> last_boot_error: 0x0
[0000.081] I> BR-BCT: preprod_dev_sign: 0
[0000.085] I> rst_source: 0xb, rst_level: 0x1
[0000.089] I> Task: SE error check
[0000.092] I> Task: Bootchain select WAR set
[0000.096] I> Task: Enable SLCG
[0000.099] I> Task: CRC check
[0000.102] I> Task: Initialize MB2 params
[0000.106] I> MB2-params @ 0x40060000
[0000.110] I> Task: Crypto init
[0000.113] I> Task: Perform MB1 KAT tests
[0000.116] I> Task: NVRNG health check
[0000.120] I> NVRNG: Health check success
[0000.124] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.130] I> Task: Enabling and initialization of Bandwidth limiter
[0000.136] I> No request to configure MBWT settings for any PC!
[0000.141] I> Task: Secure debug controls
[0000.145] I> Task: strap war set
[0000.148] I> Task: Initialize SOC Therm
[0000.152] I> Task: Program NV master stream id
[0000.156] I> Task: Verify boot mode
[0000.162] I> Task: Alias fuses
[0000.166] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.173] I> Task: Print SKU type
[0000.176] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.181] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0000.185] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0000.190] I> FUSE_OPT_DLA_DISABLE = 0x00000001
[0000.194] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.198] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.203] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.207] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.211] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.216] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.220] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.224] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.228] I> FUSE_SKU_INFO_0 = 0xd4
[0000.231] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.236] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.239] I> SKU: Prod
[0000.241] I> Task: Boost clocks
[0000.244] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.249] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.255] I> BPMP NAFLL lock success.
[0000.258] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.263] I> Initializing PLLC2 for AXI_CBB.
[0000.267] I> AXI_CBB : src = 35, divisor = 0
[0000.271] I> Task: Voltage monitor
[0000.274] I> VMON: Vmon re-calibration and fine tuning done
[0000.280] I> Task: UPHY init
[0000.285] I> HSIO UPHY init done
[0000.288] W> Skipping GBE UPHY config
[0000.291] I> Task: Boot device init
[0000.295] I> Boot_device: QSPI_FLASH instance: 0
[0000.299] I> Qspi clock source : pllc_out0
[0000.303] I> QSPI Flash: Macronix 64MB
[0000.307] I> QSPI-0l initialized successfully
[0000.311] I> Task: TSC init
[0000.314] I> Task: Load membct
[0000.317] I> RAM_CODE 0x4000421
[0000.320] I> Loading MEMBCT
[0000.323] I> Slot: 1
[0000.325] I> Binary[0] block-66816 (partition size: 0x40000)
[0000.330] I> Binary name: MEM-BCT-0
[0000.334] I> Size of crypto header is 8192
[0000.338] I> Size of crypto header is 8192
[0000.342] I> strt_pg_num(66816) num_of_pgs(16) read_buf(0x40050000)
[0000.348] I> BCH of MEM-BCT-0 read from storage
[0000.352] I> BCH address is : 0x40050000
[0000.356] I> MEM-BCT-0 header integrity check is success
[0000.361] I> Binary magic in BCH component 0 is MEM0
[0000.366] I> component binary type is 0
[0000.370] I> strt_pg_num(66832) num_of_pgs(115) read_buf(0x40040000)
[0000.377] I> MEM-BCT-0 binary is read from storage
[0000.381] I> MEM-BCT-0 binary integrity check is success
[0000.387] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.393] I> RAM_CODE 0x4000421
[0000.399] I> RAM_CODE 0x4000421
[0000.403] I> Task: Load Page retirement list
[0000.407] I> Task: SDRAM params override
[0000.410] I> Task: Save mem-bct info
[0000.414] I> Task: Carveout allocate
[0000.417] I> RCM blob carveout will not be allocated
[0000.422] I> Update CCPLEX IST carveout from MB1-BCT
[0000.427] I> ECC region[0]: Start:0x0, End:0x0
[0000.431] I> ECC region[1]: Start:0x0, End:0x0
[0000.440] I> ECC region[3]: Start:0x0, End:0x0
[0000.444] I> ECC region[4]: Start:0x0, End:0x0
[0000.448] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000
[0000.454] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.459] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.464] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.468] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.479] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.486] I> allocated(CO:39) base:0x27de00000 size:0x2200000 align: 0x10000
[0000.493] I> allocated(CO:20) base:0x27a000000 size:0x2000000 align: 0x2000000
[0000.500] I> allocated(CO:24) base:0x278000000 size:0x2000000 align: 0x2000000
[0000.507] I> allocated(CO:28) base:0x276000000 size:0x2000000 align: 0x2000000
[0000.514] I> allocated(CO:22) base:0x27c000000 size:0x1000000 align: 0x1000000
[0000.521] I> allocated(CO:35) base:0x275000000 size:0x1000000 align: 0x100000
[0000.528] I> allocated(CO:02) base:0x27d000000 size:0x800000 align: 0x800000
[0000.535] I> allocated(CO:03) base:0x274800000 size:0x800000 align: 0x800000
[0000.542] I> allocated(CO:06) base:0x274000000 size:0x800000 align: 0x800000
[0000.549] I> allocated(CO:56) base:0x273800000 size:0x800000 align: 0x200000
[0000.556] I> allocated(CO:07) base:0x27d800000 size:0x400000 align: 0x400000
[0000.563] I> allocated(CO:33) base:0x273400000 size:0x400000 align: 0x200000
[0000.570] I> allocated(CO:19) base:0x273180000 size:0x280000 align: 0x10000
[0000.577] I> allocated(CO:23) base:0x27dc00000 size:0x200000 align: 0x200000
[0000.584] I> allocated(CO:01) base:0x273000000 size:0x100000 align: 0x100000
[0000.591] I> allocated(CO:05) base:0x272f00000 size:0x100000 align: 0x100000
[0000.604] I> allocated(CO:09) base:0x272d00000 size:0x100000 align: 0x100000
[0000.611] I> allocated(CO:12) base:0x272c00000 size:0x100000 align: 0x100000
[0000.618] I> allocated(CO:15) base:0x272b00000 size:0x100000 align: 0x100000
[0000.625] I> allocated(CO:17) base:0x272a00000 size:0x100000 align: 0x100000
[0000.632] I> allocated(CO:27) base:0x272900000 size:0x100000 align: 0x100000
[0000.639] I> allocated(CO:42) base:0x272800000 size:0x100000 align: 0x100000
[0000.646] I> allocated(CO:54) base:0x273100000 size:0x80000 align: 0x80000
[0000.653] I> allocated(CO:34) base:0x2727f0000 size:0x10000 align: 0x10000
[0000.660] I> allocated(CO:72) base:0x2725f0000 size:0x200000 align: 0x10000
[0000.673] I> allocated(CO:50) base:0x271e00000 size:0x200000 align: 0x100000
[0000.680] I> allocated(CO:48) base:0x2725d0000 size:0x20000 align: 0x10000
[0000.687] I> allocated(CO:69) base:0x2725b0000 size:0x20000 align: 0x10000
[0000.694] I> allocated(CO:49) base:0x2725a0000 size:0x10000 align: 0x10000
[0000.701] I> NSDRAM base: 0x80000000, end: 0x2725f0000, size: 0x1f25f0000
[0000.707] I> Task: Thermal check
[0000.710] I> Using min_chip_limit as min_tmon_limit
[0000.715] I> Using max_chip_limit as max_tmon_limit
[0000.720] I> BCT max_tmon_limit = 105
[0000.723] I> BCT min_tmon_limit = -28
[0000.727] I> BCT max_tmon_limit = 105
[0000.730] I> BCT min_tmon_limit = -28
[0000.734] I> SKU specific max_chip_limit = 105
[0000.738] I> SKU specific min_chip_limit = -28
[0000.742] I> BCT max_chip_limit = 105
[0000.746] I> BCT min_chip_limit = -28
[0000.749] I> enable_soctherm_polling = 0
[0000.753] I> max temp read = 57
[0000.756] I> min temp read = 56
[0000.759] I> Enabling thermtrip
[0000.762] I> Task: Update FSI SCR with thermal fuse data
[0000.767] I> Task: Enable WDT 5th expiry
[0000.771] I> Task: I2C register
[0000.774] I> Task: Set I2C bus freq
[0000.777] I> Task: Reset FSI
[0000.780] I> Task: Pinmux init
[0000.783] I> skipped mmio_addr = 0x9240008
[0000.787] I> skipped mmio_addr = 0x9240000
[0000.791] I> skipped mmio_addr = 0x9240010
[0000.795] I> skipped mmio_addr = 0x9240018
[0000.799] I> skipped mmio_addr = 0x9240020
[0000.803] I> skipped mmio_addr = 0x9240030
[0000.807] I> skipped mmio_addr = 0x9240028
[0000.811] I> skipped mmio_addr = 0x9240038
[0000.815] I> skipped mmio_addr = 0x9240040
[0000.819] I> skipped mmio_addr = 0x9240048
[0000.823] I> skipped mmio_addr = 0x9241000
[0000.827] I> skipped mmio_addr = 0x9241008
[0000.834] I> skipped mmio_addr = 0x9241018
[0000.838] I> skipped mmio_addr = 0x9241020
[0000.842] I> skipped mmio_addr = 0x9241028
[0000.846] I> skipped mmio_addr = 0x9241030
[0000.850] I> skipped mmio_addr = 0x9241038
[0000.854] I> skipped mmio_addr = 0x9241040
[0000.858] I> skipped mmio_addr = 0x9242000
[0000.862] I> skipped mmio_addr = 0x9242008
[0000.866] I> Task: Prod config init
[0000.869] I> Task: Pad voltage init
[0000.873] I> Task: Prod init
[0000.875] I> Task: Program rst req config reg
[0000.880] I> Task: Common rail init
[0000.883] I> DONE: Thermal config
[0000.887] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.899] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.940] I> Task: SDRAM init
[0000.943] I> MemoryType: 4 MemBctRevision: 1
[0000.957] I> MSS CAR: Init PLLM
[0000.960] I> MSS CAR: Init PLLHUB
[0000.965] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0000.976] I> SDRAM initialized!
[0000.979] I> SDRAM Size in Total 0x200000000
[0000.983] I> Task: Dram Ecc scrub
[0000.993] I> Task: Program NSDRAM carveout
[0000.997] I> NSDRAM carveout encryption is enabled
[0001.005] I> Task: Register checker
[0001.023] I> Task: CCPLEX IST init
[0001.026] I> Task: CPU WP0
[0001.029] I> Loading MCE
[0001.031] I> Slot: 1
[0001.034] I> Binary[8] block-85760 (partition size: 0x80000)
[0001.039] I> Binary name: MCE
[0001.050] I> strt_pg_num(85760) num_of_pgs(16) read_buf(0x4003e000)
[0001.056] I> BCH of MCE read from storage
[0001.068] I> Binary magic in BCH component 0 is MTSM
[0001.073] I> component binary type is 8
[0001.081] I> strt_pg_num(85776) num_of_pgs(350) read_buf(0x40000000)
[0001.089] I> MCE binary is read from storage
[0001.098] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.104] I> Size of crypto header is 8192
[0001.115] I> Size of crypto header is 8192
[0001.119] I> Sending WP0 mailbox command to PSC
[0001.128] I> Task: XUSB Powergate
[0001.135] I> Task: MB1 fixed firewalls
[0001.141] W> Firewall readback mismatch
[0001.146] I> Task: Load bpmp-fw
[0001.149] I> Slot: 1
[0001.151] I> Binary[15] block-72960 (partition size: 0x180000)
[0001.157] I> Binary name: BPMP_FW
[0001.160] I> Size of crypto header is 8192
[0001.164] I> Size of crypto header is 8192
[0001.168] I> strt_pg_num(72960) num_of_pgs(16) read_buf(0x807fe000)
[0001.174] I> BCH of BPMP_FW read from storage
[0001.182] I> BPMP_FW header integrity check is success
[0001.187] I> Binary magic in BCH component 0 is BPMF
[0001.192] I> component binary type is 15
[0001.200] I> strt_pg_num(72976) num_of_pgs(1990) read_buf(0x80000000)
[0001.217] I> BPMP_FW binary is read from storage
[0001.235] I> Slot: 1
[0001.237] I> Binary[16] block-76032 (partition size: 0x400000)
[0001.246] I> Size of crypto header is 8192
[0001.250] I> Size of crypto header is 8192
[0001.254] I> strt_pg_num(76032) num_of_pgs(16) read_buf(0x807fc000)
[0001.265] I> BCH address is : 0x807fc000
[0001.274] I> Binary magic in BCH component 0 is BPMD
[0001.279] I> component binary type is 16
[0001.287] I> strt_pg_num(76048) num_of_pgs(499) read_buf(0x807bd9f0)
[0001.301] I> BPMP_FW_DTB binary integrity check is success
[0001.306] I> Binary BPMP_FW_DTB loaded successfully at 0x807bd9f0 (0x3e500)
[0001.313] I> Task: BPMP fw ast config
[0001.320] I> Slot: 1
[0001.322] I> Binary[17] block-84224 (partition size: 0xc0000)
[0001.327] I> Binary name: PSC_FW
[0001.330] I> Size of crypto header is 8192
[0001.334] I> Size of crypto header is 8192
[0001.338] I> strt_pg_num(84224) num_of_pgs(16) read_buf(0x80ffe000)
[0001.357] I> Binary magic in BCH component 0 is PFWP
[0001.362] I> component binary type is 17
[0001.370] I> strt_pg_num(84240) num_of_pgs(591) read_buf(0x80fb4200)
[0001.384] I> PSC_FW binary integrity check is success
[0001.389] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.399] I> Slot: 1
[0001.401] I> Binary[7] block-69376 (partition size: 0x100000)
[0001.406] I> Binary name: NVDEC
[0001.409] I> Size of crypto header is 8192
[0001.413] I> Size of crypto header is 8192
[0001.417] I> strt_pg_num(69376) num_of_pgs(16) read_buf(0x800fe000)
[0001.431] I> NVDEC header integrity check is success
[0001.449] I> strt_pg_num(69392) num_of_pgs(560) read_buf(0x80000000)
[0001.485] I> Task: Load tsec-fw
[0001.488] I> TSEC-FW load support not enabled
[0001.500] I> Slot: 1
[0001.543] I> Slot: 1
[0001.545] I> Binary[13] block-86784 (partition size: 0x30000)
[0001.570] I> strt_pg_num(86784) num_of_pgs(16) read_buf(0xa0002000)
[0001.597] I> Size of crypto header is 8192
[0001.601] I> strt_pg_num(86800) num_of_pgs(349) read_buf(0xa0004000)
[0001.614] I> SC7-FW binary integrity check is success
[0001.626] I> Slot: 1
[0001.628] I> Binary[22] block-87168 (partition size: 0x30000)
[0001.652] I> strt_pg_num(87168) num_of_pgs(16) read_buf(0xa002f920)
[0001.662] I> BCH address is : 0xa002f920
[0001.684] I> strt_pg_num(87184) num_of_pgs(224) read_buf(0xa0031920)
[0001.714] I> Task: Load MB2rf binary to SC7 ctx
[0001.719] I> Slot: 1
[0001.721] I> Binary[14] block-87552 (partition size: 0x20000)
[0001.729] I> Size of crypto header is 8192
[0001.745] I> strt_pg_num(87552) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.751] I> BCH of MB2_RF read from storage
[0001.759] I> MB2_RF header integrity check is success
[0001.777] I> strt_pg_num(87568) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.827] I> Task: Save I2C bus freq data to SC7 ctx
[0001.873] I> Task: Load MB2/Applet/FSKP
[0001.879] I> Slot: 1
[0001.881] I> Binary[6] block-71424 (partition size: 0x80000)
[0001.898] I> strt_pg_num(71424) num_of_pgs(16) read_buf(0x8007e000)
[0001.929] I> strt_pg_num(71440) num_of_pgs(844) read_buf(0x80000000)
[0001.945] I> MB2 binary integrity check is success
[0001.983] I> Task: Program misc carveouts
I> Emulation:
I> Entry timestamp: 0x001eec97
I> strt_pg_num(130592) num_of_pgs(1) read_buf(0x273801000)
I> strt_pg_num(130560) num_of_pgs(32) read_buf(0x273801200)
I> Unpowergate done
I> Partition name: B_spe-fw
I> Binary@ device:3/0 block-118016 (partition size: 0x90000), name: B_spe-fw
I> strt_pg_num(118016) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(118032) num_of_pgs(512) read_buf(0x272e00000)
I> Partition name: B_rce-fw
I> Binary@ device:3/0 block-119168 (partition size: 0x100000), name: B_rce-fw
I> strt_pg_num(119168) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(119184) num_of_pgs(880) read_buf(0x272a00000)
I> Partition name: B_dce-fw
I> Binary@ device:3/0 block-107776 (partition size: 0x500000), name: B_dce-fw
I> strt_pg_num(107776) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(107792) num_of_pgs(1) read_buf(0x2739400d8)
I> strt_pg_num(107792) num_of_pgs(8) read_buf(0x2739400d8)
I> strt_pg_num(107800) num_of_pgs(512) read_buf(0x2738000c0)
I> strt_pg_num(108312) num_of_pgs(512) read_buf(0x2738400c0)
I> strt_pg_num(108824) num_of_pgs(512) read_buf(0x2738800c0)
I> Partition name: B_adsp-fw
I> Binary@ device:3/0 block-121216 (partition size: 0x200000), name: B_adsp-fw
I> strt_pg_num(121216) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(121232) num_of_pgs(800) read_buf(0x27d800000)
I> Partition name: B_xusb-fw
I> Binary@ device:3/0 block-72448 (partition size: 0x40000), name: B_xusb-fw
I> strt_pg_num(72448) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(72464) num_of_pgs(312) read_buf(0x272f00000)
I> Partition name: B_pva-fw
I> Binary@ device:3/0 block-125312 (partition size: 0x40000), name: B_pva-fw
I> strt_pg_num(125312) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(125328) num_of_pgs(1) read_buf(0x2739400d8)
I> strt_pg_num(125328) num_of_pgs(8) read_buf(0x2739400d8)
I> strt_pg_num(125336) num_of_pgs(512) read_buf(0x2738000c0)
I> Powergating APE
I> Powergate done
I> Unhalting SPE..
???pe: early_init
??ic initialized
??sc initialized
??pe: init
??ag initialized
??cu initialized
??pe: late init
??m initialized
bpmp: socket 0
initialized vwdt
initialized fuse
initialized vfrel
initialized adc
initialized fmon
initialized mc
initialized reset
initialized pm
initialized io_dpd
initialized regime
initialized i2c
initialized vrmon
?nhalt FSI
I> FSI un?nitialized dvs
suspend progress: 0x80000000
initialized suspend
initialized strap
?alt skipped
I> Unhalting RCE
I> Unhalting DCE
I> Task: Load TOS
I> Sending opcode 0x53535452 to psc?     2.567574] Camera-FW on t234-rce-safe started
TCU early console ena?nitialized emc
initialized emc_mrq
?led.
I> Sen?nitialized clk_cal
initialized uphy_dt
initialized uphy
? opcode ?nitialized pg_late
initialized bwmgr
initialized oc_mrq
initialized clk_mrq
initialized i2c_mrq
initialized tag_mrq
?o psc
 ?CE Started
DCE_R5_Init
?> ?nitialized clk_cal_late
initialized cvc
?artit?PU enabled
DCE_SW_In?nitialized avfs_clk_mach_post
initialized rm
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
?     2.749320] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 15.811 ms,?nable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable dsi_lp
initialized pg_post
initialized pro?total boot 198.629 m?ile
initialized mrq
ini?)
?ialized cactmon
bpmp: init complete
?on na?t
BUG: /dvs/git/dirty/git-master_linux/display/dce/init/dce-init.c:185  dce_dt_init failed, rc = 0x?e: B_cpu-bootloader
I> Binary@ device:3/0 block-87808 (partition size: 0x380000), name: B_cpu-bootloader
?000003c"
Abort: reason:0x301 Err:0x0 [(NULL)]
?> strt_pg_num(87808) num_of_pgs(16) read_buf(0x40066880)
I> cpubl : oem authentication of header done
I> strt_pg_num(87824) num_of_pgs(1) read_buf(0x273943c98)
I> strt_pg_num(87824) num_of_pgs(8) read_buf(0x273943c98)
I> strt_pg_num(87832) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(88344) num_of_pgs(512) read_buf(0x273843c80)
I> strt_pg_num(88856) num_of_pgs(512) read_buf(0x273883c80)
I> strt_pg_num(89368) num_of_pgs(512) read_buf(0x2738c3c80)
I> strt_pg_num(89880) num_of_pgs(512) read_buf(0x273903c80)
I> strt_pg_num(90392) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(90904) num_of_pgs(512) read_buf(0x273843c80)
I> strt_pg_num(91416) num_of_pgs(512) read_buf(0x273883c80)
I> strt_pg_num(91928) num_of_pgs(512) read_buf(0x2738c3c80)
I> strt_pg_num(92440) num_of_pgs(512) read_buf(0x273903c80)
I> strt_pg_num(92952) num_of_pgs(512) read_buf(0x273803c80)
I> strt_pg_num(93464) num_of_pgs(512) read_buf(0x273843c80)
I> strt_pg_num(93976) num_of_pgs(512) read_buf(0x273883c80)
I> Partition name: B_secure-os
I> Binary@ device:3/0 block-94976 (partition size: 0x400000), name: B_secure-os
I> strt_pg_num(94976) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(94992) num_of_pgs(3176) read_buf(0xc1d73000)
I> Partition name: B_eks
I> Binary@ device:3/0 block-107264 (partition size: 0x40000), name: B_eks
I> strt_pg_num(107264) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(107280) num_of_pgs(8) read_buf(0xbe020000)
I> Task: SMMU init
I> Current Boot-Chain Slot: 1
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 1
I> MB2 finished
I/TC:
已经找到原因了,是设备树配置错误
