烧录QSPI报错:Alias_checker: Read/write mis-match
我执行这条命令时报错:./flash.sh -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit nvme0n1p1
[  11.0888 ] tegrasign_v3.py --key None --list blob_tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  11.0890 ] Assuming zero filled SBK key
[  11.0934 ] Warning: pub_key.key is not found
[  11.0933 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-optee_t234_aligned_sigheader.img.encrypt blob_tos-optee_t234_aligned_sigheader.img.hash zerosbk
[  11.0986 ] Get magic id
[  11.0991 ] tegraparser_v2 --get_magic eks
[  11.0996 ] EKSB
[  11.0998 ] partition type eks, magic id = EKSB
[  11.1004 ] tegrahost_v2 --chip 0x23 0 --align blob_eks_t234_aligned.img
[  11.1016 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t234_aligned.img zerosbk
[  11.1020 ] adding BCH for blob_eks_t234_aligned.img
[  11.1038 ] tegrasign_v3.py --key None --list blob_eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  11.1040 ] Assuming zero filled SBK key
[  11.1061 ] Warning: pub_key.key is not found
[  11.1058 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_t234_aligned_sigheader.img.encrypt blob_eks_t234_aligned_sigheader.img.hash zerosbk
[  11.1076 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[  11.1079 ] The number of images in blob is 17
[  11.1086 ] blobsize is 23886768
[  11.1088 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3567680
[  11.1243 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[  11.1268 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[  11.1276 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[  11.1282 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[  11.1287 ] Not supported type: mb2_applet
[  11.1290 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 439968
[  11.1300 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[  11.1307 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[  11.1316 ] Added binary blob_display-t234-dce_with_tegra234-p3768-0000+p3767-0000-nv_with_odm_overlay.dtb_sigheader.bin.encrypt of size 12103744
[  11.1398 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[  11.1412 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1027008
[  11.1425 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 383232
[  11.1443 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[  11.1457 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 414976
[  11.1469 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[  11.1480 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1633344
[  11.1493 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[  11.1638 ] Sending membct and RCM blob
[  11.1645 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[  11.1650 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[  11.1943 ] Sending bct_mem
[  11.2384 ] Sending blob
[  11.3052 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Failed flashing generic.
下面是串口日志:
[0032.019] I> Using min_chip_limit as min_tmon_limit
[0032.024] I> Using max_chip_limit as max_tmon_limit
[0032.029] I> BCT max_tmon_limit = 105
[0032.032] I> BCT min_tmon_limit = -28
[0032.036] I> BCT max_tmon_limit = 105
[0032.039] I> BCT min_tmon_limit = -28
[0032.043] I> SKU specific max_chip_limit = 105
[0032.047] I> SKU specific min_chip_limit = -28
[0032.051] I> BCT max_chip_limit = 105
[0032.055] I> BCT min_chip_limit = -28
[0032.058] I> enable_soctherm_polling = 0
[0032.062] I> max temp read = 59
[0032.065] I> min temp read = 58
[0032.068] I> Enabling thermtrip
[0032.071] I> Task: Update FSI SCR with thermal fuse data
[0032.076] I> Task: Enable WDT 5th expiry
[0032.080] I> Task: I2C register
[0032.083] I> Task: Set I2C bus freq
[0032.086] I> Task: Reset FSI
[0032.089] I> Task: Pinmux init
[0032.092] I> skipped mmio_addr = 0x9240008
[0032.096] I> skipped mmio_addr = 0x9240000
[0032.100] I> skipped mmio_addr = 0x9240010
[0032.104] I> skipped mmio_addr = 0x9240018
[0032.108] I> skipped mmio_addr = 0x9240020
[0032.112] I> skipped mmio_addr = 0x9240030
[0032.116] I> skipped mmio_addr = 0x9240028
[0032.120] I> skipped mmio_addr = 0x9240038
[0032.124] I> skipped mmio_addr = 0x9240040
[0032.128] I> skipped mmio_addr = 0x9240048
[0032.132] I> skipped mmio_addr = 0x9241000
[0032.136] I> skipped mmio_addr = 0x9241008
[0032.139] I> skipped mmio_addr = 0x9241010
[0032.143] I> skipped mmio_addr = 0x9241018
[0032.147] I> skipped mmio_addr = 0x9241020
[0032.151] I> skipped mmio_addr = 0x9241028
[0032.155] I> skipped mmio_addr = 0x9241030
[0032.159] I> skipped mmio_addr = 0x9241038
[0032.163] I> skipped mmio_addr = 0x9241040
[0032.167] I> skipped mmio_addr = 0x9242000
[0032.171] I> skipped mmio_addr = 0x9242008
[0032.175] I> Task: Prod config init
[0032.178] I> Task: Pad voltage init
[0032.182] I> Task: Prod init
[0032.184] I> Task: Program rst req config reg
[0032.189] I> Task: Common rail init
[0032.192] I> DONE: Thermal config
[0032.196] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0032.205] I> DONE: SOC rail config
[0032.208] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0032.214] I> DONE: MEMIO rail config
[0032.218] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0032.224] I> DONE: GPU rail info
[0032.228] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0032.234] I> DONE: CV rail info
[0032.237] I> Task: Mem clock src
[0032.241] I> Task: Misc. board config
[0032.245] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0032.250] I> Task: SDRAM init
[0032.253] I> MemoryType: 4 MemBctRevision: 1
[0032.260] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0032.267] I> MSS CAR: Init PLLM
[0032.270] I> MSS CAR: Init PLLHUB
[0032.275] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0032.286] I> SDRAM initialized!
[0032.289] I> SDRAM Size in Total 0x400000000
[0032.293] I> Task: Dram Ecc scrub
[0032.297] I> Task: DRAM alias check
[0032.301] E> Alias_checker: Read/write mis-match
[0032.306] C> Task 0x32 failed (err: 0x1c)
[0032.310] E> Top caller module: NONE, error module: NONE, reason: 0x1c, aux_info: 0x00
[0032.318] C> Boot Info Table status dump :
0111111100111000111111111111111111111111111110111
我看到好像提示是Alias不匹配,Alias是什么?
我使用这个命令烧录QSPI也不行:./tools/kernel_flash/l4t_initrd_flash.sh -p "--no-systemimg -c bootloader/generic/cfg/flash_t234_qspi.xml" --network usb0 jetson-orin-nano-devkit nvme0n1p1
Waiting for target to boot-up...
Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Cleaning up...
串口日志是:
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
....EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
ÿᣥbugfs initialized
ÿ㇯TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
ÿ٠   0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.136-tegra (root@ubuntu) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #4 SMP PREEMPT Thu May 23 14:11:11 CST 2024 ()
[    0.000000] Machine model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: SMBIOS=0xffff0000 SMBIOS 3.0=0x43b3c0000 MEMATTR=0x43530d018 RNG=0x427320018 MEMRESERVE=0x429b64f18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000461000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000477ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x4602ef800-0x4602f1fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000477ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000bdffffff]
[    0.000000]   node   0: [mem 0x00000000c2000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000042c3a4fff]
[    0.000000]   node   0: [mem 0x000000042c3a5000-0x000000042c60bfff]
[    0.000000]   node   0: [mem 0x000000042c60c000-0x0000000439aeffff]
[    0.000000]   node   0: [mem 0x0000000439af0000-0x000000043ba2ffff]
[    0.000000]   node   0: [mem 0x000000043ba30000-0x0000000471dfffff]
[    0.000000]   node   0: [mem 0x0000000471e00000-0x0000000471ffffff]
[    0.000000]   node   0: [mem 0x0000000472000000-0x000000047259ffff]
[    0.000000]   node   0: [mem 0x0000000472f00000-0x0000000472ffffff]
[    0.000000]   node   0: [mem 0x0000000476000000-0x0000000477ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000477ffffff]
[    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU feinsmod: dib/modules/5.15.13ctr6-t4
68.a/u[    0tes/dr0] CPUivenetatu/et: dnetcted: altek/ctrr81HB
   ko   0
0000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernble_remotcodccess  0.00000bleBuimot1 ze accelisss mobility grouping on.  Total pages: 40654mod /lib/mod  0.00ules/5Pol.15icyne:6-tegra/kernel/driver  0.00teg000ra/0] -tegranel194 cou.ko line:
t=/dev/initrd rw rootwait mminit_loglevel=4 console=ttmodU0,ib/modules/5.15.136-trmwareegrernassdrivers/p/etci/trollec/fware fwc/pcie-tn=map:0 n4.kifno ames=0 bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000
[    0.000000] Unknown kernel command line parameters "mminit_loglevel=4 fbcon=map:0 bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 15721308K/16521856K available (18880K kernel code, 4048K rwdata, 9936K rodata, 7616K init, 521K bss, 538404K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000000] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000312] Console: colour dummy device 80x25
[    0.000354] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000359] pid_max: default: 32768 minimum: 301
[    0.000381] LSM: Security Framework initializing
[    0.000396] Yama: becoming mindful.
[    0.000405] SELinux:  Initializing.
[    0.000457] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.000474] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.001274] rcu: Hierarchical SRCU implementation.
[    0.003306] Tegra Revision: A01 SKU: 211 CPU Process: 0 SoC Process: 0
[    0.003558] Remapping and enabling EFI services.
[    0.004309] smp: Bringing up secondary CPUs ...
[    0.004653] Detected PIPT I-cache on CPU1
[    0.004678] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.004696] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.005027] Detected PIPT I-cache on CPU2
[    0.005037] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.005049] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.005355] Detected PIPT I-cache on CPU3
[    0.005364] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.005375] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.007656] Detected PIPT I-cache on CPU4
[    0.007678] GICv3: CPU4: found redistributor 20000 region 0:0x000000000f540000
[    0.007699] CPU4: Booted secondary processor 0x0000020000 [0x410fd421]
[    0.008047] Detected PIPT I-cache on CPU5
[    0.008057] GICv3: CPU5: found redistributor 20100 region 0:0x000000000f560000
[    0.008069] CPU5: Booted secondary processor 0x0000020100 [0x410fd421]
[    0.008386] Detected PIPT I-cache on CPU6
[    0.008396] GICv3: CPU6: found redistributor 20200 region 0:0x000000000f580000
[    0.008407] CPU6: Booted secondary processor 0x0000020200 [0x410fd421]
[    0.008727] Detected PIPT I-cache on CPU7
[    0.008737] GICv3: CPU7: found redistributor 20300 region 0:0x000000000f5a0000
[    0.008748] CPU7: Booted secondary processor 0x0000020300 [0x410fd421]
[    0.008791] smp: Brought up 1 node, 8 CPUs
[    0.008793] SMP: Total of 8 processors activated.
[    0.008795] CPU features: detected: 32-bit EL0 Support
[    0.008796] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.008798] CPU features: detected: Common not Private translations
[    0.008799] CPU features: detected: CRC32 instructions
[    0.008799] CPU features: detected: Data cache clean to Point of Persistence
[    0.008801] CPU features: detected: Generic authentication (architected algorithm)
[    0.008802] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.008802] CPU features: detected: LSE atomic instructions
[    0.008803] CPU features: detected: Privileged Access Never
[    0.008804] CPU features: detected: RAS Extension Support
[    0.008805] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.034166] CPU: All CPU(s) started at EL2
[    0.035841] devtmpfs: initialized
[    0.046736] KASLR enabled
[    0.046829] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.046841] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.048896] pinctrl core: initialized pinctrl subsystem
[    0.049418] SMBIOS 3.6.0 present.
[    0.049425] DMI: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.3.0-gcid-36106755 04/25/2024
[    0.049699] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.050791] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.050898] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.050994] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.051021] audit: initializing netlink subsys (disabled)
[    0.051101] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[    0.051918] thermal_sys: Registered thermal governor 'step_wise'
[    0.051920] thermal_sys: Registered thermal governor 'user_space'
[    0.051921] thermal_sys: Registered thermal governor 'power_allocator'
[    0.053793] cpuidle: using governor menu
[    0.053901] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.053981] ASID allocator initialised with 32768 entries
[    0.054987] Serial: AMBA PL011 UART driver
[    0.062503] tegra-mc 2c00000.memory-controller: unknown: write @0x0000000050060590: Security violation (TrustZone violation)
[    0.063041] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[    0.070504] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.076798] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.076802] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.076803] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.076804] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.077341] cryptd: max_cpu_qlen set to 1000
[    0.078394] ACPI: Interpreter disabled.
[    0.079226] VDD_1V8_AO: supplied by VDD_5V0_SYS
[    0.079324] VDD_3V3_AO: supplied by VDD_5V0_SYS
[    0.079500] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[    0.079732] iommu: Default domain type: Translated
[    0.079735] iommu: DMA domain TLB invalidation policy: strict mode
ore.ko   00068] usbcore: registered new interface driver usbfs
[    0.080081] usbmode: registib/modew ule.15erf.136-tegra/kernr hub
s/nvme/host/nvme.k0091]
usbcore: registered new device driver usb
[    0.080404] pps_core: LinuxPPS API ver. 1 registered
[    0.080406] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.080412] PTP clock support registered
[    0.080465] EDAC MC: Ver: 3.0.0
[    0.081057] Registered efivars operations
[    0.081426] FPGA manager framework
[    0.081480] Advanced Linux Sound Architecture Driver Initialized.
[    0.081972] clocksource: Switched to clocksource arch_sys_counter
[    0.107566] VFS: Disk quotas dquot_6.6.0
[    0.107633] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.107881] pnp: PnP ACPI: disabled
[    0.111275] NET: Registered PF_INET protocol family
[    0.111827] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.114227] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.114255] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.114276] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.114450] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.115772] TCP: Hash tables configured (established 131072 bind 65536)
[    0.115971] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.116016] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.116213] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.116661] RPC: Registered named UNIX socket transport module.
[    0.116666] RPC: Registered udp transport module.
[    0.116667] RPC: Registered tcp transport module.
[    0.116669] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.116686] PCI: Cmod /lib/s, mods/5.15aul4
6-t  0.11ern6942] vers/tackher initr/teamfgra/te.
gra-bpmp-the.12rma7205] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.12insmodkvm /l [1]: uleIPA.15ze .13egrit: 48ern biel/driver
        s/ppwm[  -tegra.ko   0.127596] kvm [1]: GICv3: no GICV resource entry
[    0.127603] kvm [1ins]:  /lablib/module GI ems/5ula.15tio.13[  6-t762a/kkvmern [1vers/h]: GICn/pstewm-.ko m rste
r CPU interface enabled
[    0.127718] kvm [1]: vgic inteinspt IRQ /l[    0mod789ule2] s/5.13 [16-tegra/k moernel/drivers/usb/ed gadceslly
[  bcomposit1003] o tia
e system trusted keyrings
[    0.131122] workingset: timestampmodts=ib/modulemaxder.15 bu.13t_orde6-tr=0
egrern  0drivers/u.13sb/493typsquec/typfs: veko rsi
on 4.0 (2009/01/31) Phillip Lougher
a/k  0.13536modNFSib/egimodules/5rinhe id_.15res.13key6-tegrpe
   el/  0.135392] Keyec/ucsi/typepe resolver c_uistcsi d
[    0.135397] Key type id_legacy reins /lterib/ule
                                                   [  .15.13.136-t5455] egrnfsa/klelerndriut_inis/usb/typec/ucsv4 i/ue Layocsig.kDrivero  Registering...
[    0.135473] nfs4flexfilelaymod /lit:ib/uleSv4s/5 Flile La.13you6-tegrt Dernel/er verRegs/uerisb/gadng./udc/t
        a-x[  .ko 549
ntfs: driver 2.1.32 [Flags: R/O].
[    0.135682] 9p: Installing ins /ls 9mod00 ules/5.15em 6-tport
egrern  0el//ip755v6/Keyipv6.ko  tyasy
mmetric registered
[    0.147561] Asymmetric key parser 'x509' registered
[    0.147640] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.147652] io scheduler mq-deadline registered
[    0.147659] io scheduler kyber registered
[    0.158171] EINJ: ACPI disabled.
[    0.170383] modialib/mod: 8ules/5 driver, 6-tegra/uIRQpdaarites/drng bleive[    0.17ps/3] nvpps.ko erH
 /lib/mod) driver initializinsed
         ule  0.17.136-t9] egra/u_seriapdatesver/drrs/net/et innetali/nva/nvether  0net.17ern1] ko ntk: console [ttyTCU0] enabled
[    0.174110] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.174116] arm-smmu 8000000.iommu: SMMUv2 with:
[    0mod /lib/modules/5.15800.13egr000a/kommel/	stagedris/usb/typnslec/stuatisb1on
60x   0
 /l6] arm-smmu 8000000.iommu: 	stage 2 trainsmodon
   [  ules/5.17.158] .13armmu egr8000000.itesu: /drivers/	neplarm/d tra/ranmce/tegration
[  -mc  0.17
6] arm-smmu 8000000.iommu: 	stream matching with 12 /lib/stemods/5.15.13rou6-tegr
        a/updates.17414ivearmrs/spi/spi-t-smegra21800uad0.iommu:  8 context banks (0 stage-2 only)
[    0.174162] arm-smmu 8000000.iommu: 	Supported page sizes: 0x61311000
[    0.174164] arm-smmu 8000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.174165] arm-smmu 8000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.175176] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.175178] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.175180] arm-smmu 10000000.iommu: 	stage 1 translation
[    0.175183] arm-smmu 10000000.iommu: 	stage 2 translation
[    0.175183] arm-smmu 10000000.iommu: 	nested translation
[    0.175187] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    0.175189] arm-smmu 10000000.iommu: 	128 context banks (0 stage-2 only)
[    0.175198] arm-smmu 10000000.iommu: 	Supported page sizes: 0x61311000
[    0.175199] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.175200] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.175564] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.175567] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.175569] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.175570] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.175571] arm-smmu 12000000.iommu: 	nested translation
[    0.175574] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    0.175576] arm-smmu 12000000.iommu: 	128 context banks (0 stage-2 only)
[    0.175581] arm-smmu 12000000.iommu: 	Supported page sizes: 0x61311000
[    0.175583] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.175584] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.184148] loop: module loaded
[    0.185006] megasas: 07.717.02.00-rc1
[    0.189120] tun: Universal TUN/TAP device driver, 1.6
[    0.189708] thunder_xcv, ver 1.0
[    0.189743] thunder_bgx, ver 1.0
[    0.189765] nicpf, ver 1.0
[    0.190640] hclge is initializing
[    0.190680] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.190688] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.190732] e1000: Intel(R) PRO/1000 Network Driver
[    0.190739] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.190762] e1000e: Intel(R) PRO/1000 Network Driver
[    0.190767] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.190786] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.190791] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.190815] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.190822] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.191021] sky2: driver version 1.30
[    0.191697] VFIO - User Level meta-driver version: 0.3
[    0.193183] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.193193] ehci-pci: EHCI PCI platform driver
[    0.193219] ehci-platform: EHCI generic platform driver
[    0.193280] ehci-orion: EHCI orion driver
[    0.193358] ehci-exynos: EHCI Exynos driver
[    0.193417] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.193444] ohci-pci: OHCI PCI platform driver
[    0.193467] ohci-platform: OHCI generic platform driver
[    0.193530] ohci-exynos: OHCI Exynos driver
[    0.193935] usbcore: registered new interface driver usb-storage
[    0.195741] rtc-efi rtc-efi.0: registered as rtc0
[    0.195786] rtc-efi rtc-efi.0: setting system clock to 1970-01-01T00:02:46 UTC (166)
[    0.196246] i2c_dev: i2c /dev entries driver
[    0.197500] pps pps0: new PPS source ktimer
[    0.197509] pps pps0: ktimer PPS source registered
[    0.197517] pps_ldisc: PPS line discipline registered
[    0.199629] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.201649] sdhci: Secure Digital Host Controller Interface driver
[    0.201656] sdhci: Copyright(c) Pierre Ossman
[    0.202116] Synopsys Designware Multimedia Card Interface Driver
[    0.202708] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.203789] ledtrig-cpu: registered to indicate activity on CPUs
[    0.204731] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.205241] tegra-bpmp bpmp: Adding to iommu group 0
[    0.206691] tegra-bpmp bpmp: firmware: 6432e47ee22b94f945d6-3b0e1a33cf8
[    0.737404] Freeing initrd memory: 41108K
[    1.632673] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    1.632702] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    1.632707] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    1.632975] hid: raw HID events driver (C) Jiri Kosina
[    1.633179] usbcore: registered new interface driver usbhid
[    1.633183] usbhid: USB HID core driver
[    1.637087] optee: probing for conduit method.
[    1.637139] optee: revision 3.22 (e7b5ff3f)
[    1.696502] optee: dynamic shared memory is enabled
[    1.696741] optee: initialized driver
[    1.699389] usbcore: registered new interface driver snd-usb-audio
[    1.700934] NET: Registered PF_PACKET protocol family
[    1.701196] 9pnet: Installing 9P2000 support
[    1.701294] Key type dns_resolver registered
[    1.702386] printk: console [ttyTCU0]: printing thread started
[    1.702473] Loading compiled-in X.509 certificates
[    1.717105] Loaded X.509 cert 'Build time autogenerated kernel key: 641353b003ab53aae4a543f44339cbad41a07a52'
[    1.744499] gpio-394 (camera-control-output-low): hogged as output/low
[    1.749655] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    1.751748] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    1.754397] serial-tegra 3100000.serial: RX in PIO mode
[    1.754402] serial-tegra 3100000.serial: TX in PIO mode
[    1.754531] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    1.756543] serial-tegra 3140000.serial: RX in PIO mode
[    1.756548] serial-tegra 3140000.serial: TX in PIO mode
[    1.756675] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[    1.759913] tegra_rtc c2a0000.rtc: registered as rtc1
[    1.759925] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    1.760415] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    1.764034] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    1.767358] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    1.770192] tegra-i2c c240000.i2c: Adding to iommu group 1
[    1.772337] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[    1.773170] tegra-i2c c250000.i2c: Adding to iommu group 1
[    1.778128] i2c i2c-2: Added multiplexed i2c bus 9
[    1.778871] i2c i2c-2: Added multiplexed i2c bus 10
[    1.778876] i2c-mux-gpio bus@0:cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    1.796217] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2006000 KHz, changing to: 1984000 KHz
[    1.797754] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2001000 KHz, changing to: 1984000 KHz
[    1.800210] tegra-xusb 3610000.usb: Adding to iommu group 2
[    1.816080] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[    1.816088] tegra-xusb 3610000.usb: xHCI Host Controller
[    1.816101] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[    1.816840] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[    1.816860] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[    1.816970] tegra-xusb 3610000.usb: xHCI Host Controller
[    1.816974] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[    1.816977] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    1.817373] hub 1-0:1.0: USB hub found
[    1.817387] hub 1-0:1.0: 4 ports detected
[    1.817640] hub 2-0:1.0: USB hub found
[    1.817651] hub 2-0:1.0: 4 ports detected
[    1.819613] irq: IRQ222: trimming hierarchy from :bus@0:pmc@c360000
[    1.819666] irq: IRQ223: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    1.819711] irq: IRQ224: trimming hierarchy from :bus@0:pmc@c360000
[    1.819763] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    1.861440] ALSA device list:
[    1.861443]   No soundcards found.
[    1.869256] Freeing unused kernel memory: 7616K
[    1.869324] Run /init as init process
[    1.887275] Root device found: initrd
[    1.910456] r8168: loading out-of-tree module taints kernel.
[    1.912416] Mount initrd as rootfs and enter recovery mode
[    1.947642] tegra194-pcie 140a0000.pcie: Adding to iommu group 3
[    2.055210] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ranges:
[    2.055235] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[    2.055245] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[    2.055250] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[    2.055754] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[    2.055759] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    2.149974] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    2.162147] tegra194-pcie 140a0000.pcie: Link up
[    2.164879] tegra194-pcie 140a0000.pcie: Link up
[    2.164938] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[    2.164942] pci_bus 0008:00: root bus resource [io  0x0000-0xfffff] (bus address [0x2a100000-0x2a1fffff])
[    2.164946] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[    2.164949] pci_bus 0008:00: root bus resource [bus 00-ff]
[    2.164951] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[    2.165000] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[    2.165154] pci 0008:00:00.0: PME# supported from D0 D3hot
[    2.168364] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[    2.168519] pci 0008:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    2.168521] pci 0008:01:00.0: reg 0x10: [io  size 0x0100]
[    2.168702] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    2.168818] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    2.169796] pci 0008:01:00.0: supports D1 D2
[    2.169797] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.184620] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[    2.184623] pci 0008:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    2.184628] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[    2.184721] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[    2.184812] pci 0008:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    2.184841] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[    2.184844] pci 0008:00:00.0:   bridge window [io  0x1000-0x1fff]
[    2.184848] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[    2.184937] pcieport 0008:00:00.0: Adding to iommu group 3
[    2.185023] pcieport 0008:00:00.0: PME: Signaling with IRQ 190
[    2.185555] pcieport 0008:00:00.0: AER: enabled with IRQ 190
[    2.185730] r8168 0008:01:00.0: Adding to iommu group 3
[    2.185786] r8168 Gigabit Ethernet driver 8.051.02.10m_pll-NAPI loaded
[    2.185844] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[    2.202909] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    2.204957] r8168  Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
[    2.204957]  This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[    2.204957]  This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    2.205058] tegra194-pcie 14100000.pcie: Adding to iommu group 4
[    2.208634] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    2.208656] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    2.208662] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    2.208665] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    2.209129] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    2.209132] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    2.310009] hub 1-2:1.0: USB hub found
[    2.310613] hub 1-2:1.0: 4 ports detected
[    2.314144] tegra194-pcie 14100000.pcie: Link up
[    2.316894] tegra194-pcie 14100000.pcie: Link up
[    2.316949] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    2.316953] pci_bus 0001:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[    2.316956] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    2.316958] pci_bus 0001:00: root bus resource [bus 00-ff]
[    2.316960] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    2.317005] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    2.317165] pci 0001:00:00.0: PME# supported from D0 D3hot
[    2.320248] pci 0001:01:00.0: [10ec:b852] type 00 class 0x028000
[    2.320420] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    2.320621] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x000fffff 64bit]
[    2.321677] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[    2.336585] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    2.336588] pci 0001:00:00.0: BAR 13: assigned [io  0x100000-0x100fff]
[    2.336591] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a80fffff 64bit]
[    2.336693] pci 0001:01:00.0: BAR 0: assigned [io  0x100000-0x1000ff]
[    2.336724] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    2.336727] pci 0001:00:00.0:   bridge window [io  0x100000-0x100fff]
[    2.336731] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    2.336820] pcieport 0001:00:00.0: Adding to iommu group 4
[    2.336902] pcieport 0001:00:00.0: PME: Signaling with IRQ 192
[    2.337426] pcieport 0001:00:00.0: AER: enabled with IRQ 192
[    2.337692] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[    2.341251] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    2.341272] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    2.341278] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    2.341282] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    2.341777] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    2.341781] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    2.441976] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[    2.450146] tegra194-pcie 14160000.pcie: Link up
[    2.452783] tegra194-pcie 14160000.pcie: Link up
[    2.452841] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    2.452844] pci_bus 0004:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x36100000-0x361fffff])
[    2.452847] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    2.452849] pci_bus 0004:00: root bus resource [bus 00-ff]
[    2.452851] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    2.452892] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    2.453037] pci 0004:00:00.0: PME# supported from D0 D3hot
[    2.456001] pci 0004:01:00.0: h: [1dnot97:t termtypina0 clasrocessx01 group (-[    2.45 In2] appriate  00tl for00. deereg
10:bash: em no 0x0000ntr0-0x00003ol thi 64hel]
l  2
6490] bas.1# 00 01:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[    2.468521] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    2.468524] pci 0004:01:00.0: BAR 6: assigned [mem 0x2428000000-0x242801ffff pref]
[    2.468527] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428020000-0x2428023fff 64bit]
[    2.468610] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    2.468615] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    2.468704] pcieport 0004:00:00.0: Adding to iommu group 5
[    2.468780] pcieport 0004:00:00.0: PME: Signaling with IRQ 194
[    2.469313] pcieport 0004:00:00.0: AER: enabled with IRQ 194
[    2.469549] tegra194-pcie 141e0000.pcie: Adding to iommu group 6
[    2.472855] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[    2.472876] tegra194-pcie 141e0000.pcie:      MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[    2.472882] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    2.472885] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    2.473393] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[    2.473397] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    2.578144] tegra194-pcie 141e0000.pcie: Link up
[    2.580730] tegra194-pcie 141e0000.pcie: Link up
[    2.580789] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    2.580793] pci_bus 0007:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x3e100000-0x3e1fffff])
[    2.580796] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[    2.580798] pci_bus 0007:00: root bus resource [bus 00-ff]
[    2.580800] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff pref]
[    2.580841] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    2.580990] pci 0007:00:00.0: PME# supported from D0 D3hot
[    2.583950] pci 0007:01:00.0: [10ec:8168] type 00 class 0x020000
[    2.584103] pci 0007:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    2.584280] pci 0007:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    2.584395] pci 0007:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    2.585330] pci 0007:01:00.0: supports D1 D2
[    2.585331] pci 0007:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.600597] pci 0007:00:00.0: BAR 14: assigned [mem 0x3228000000-0x32280fffff]
[    2.600600] pci 0007:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[    2.600602] pci 0007:01:00.0: BAR 4: assigned [mem 0x3228000000-0x3228003fff 64bit]
[    2.600693] pci 0007:01:00.0: BAR 2: assigned [mem 0x3228004000-0x3228004fff 64bit]
[    2.600783] pci 0007:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[    2.600810] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    2.600813] pci 0007:00:00.0:   bridge window [io  0x300000-0x300fff]
[    2.600816] pci 0007:00:00.0:   bridge window [mem 0x3228000000-0x32280fffff]
[    2.600901] pcieport 0007:00:00.0: Adding to iommu group 6
[    2.600977] pcieport 0007:00:00.0: PME: Signaling with IRQ 196
[    2.601564] pcieport 0007:00:00.0: AER: enabled with IRQ 196
[    2.601732] r8168 0007:01:00.0: Adding to iommu group 6
[    2.601787] r8168 Gigabit Ethernet driver 8.051.02.10m_pll-NAPI loaded
[    2.601842] r8168 0007:01:00.0: enabling device (0000 -> 0003)
[    2.602015] hub 1-3:1.0: USB hub found
[    2.602619] hub 1-3:1.0: 4 ports detected
[    2.618352] r8168 0007:01:00.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
[    2.618357] r8168 0007:01:00.0 (unnamed net_device) (uninitialized): Random ether addr c2:25:1d:62:88:e6
[    2.618569] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    2.620602] r8168  Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
[    2.620602]  This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[    2.620602]  This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    2.646982] nvme 0004:01:00.0: Adding to iommu group 5
[    2.647345] nvme nvme0: pci function 0004:01:00.0
[    2.647573] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    2.651317] nvme nvme0: Shutdown timeout set to 8 seconds
[    2.662412] nvme nvme0: allocated 64 MiB host memory buffer.
[    2.789686] nvme nvme0: 8/0/0 default/read/poll queues
[    2.791923]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[    2.905976] usb 1-3.1: new high-speed USB device number 4 using tegra-xusb
[    2.906913] tegra-xudc 3550000.usb: Adding to iommu group 7
[    2.940818] NET: Registered PF_INET6 protocol family
[    2.941254] Segment Routing with IPv6
[    2.941261] In-situ OAM (IOAM) with IPv6
[    3.013798] tegra-qspi 3270000.spi: Adding to iommu group 8
[    3.014323] tegra-qspi 3270000.spi: Prod config not found for QSPI: -19
[    3.020886] spi-nor spi0.0: mx25u51279g (65536 Kbytes)
[    3.129977] usb 1-3.2: new full-speed USB device number 5 using tegra-xusb
[    4.038274] using random self ethernet address
[    4.038278] using random host ethernet address
[    4.367153] usb0: HOST MAC ce:87:ac:a4:57:39
[    4.367157] usb0: MAC 2a:6e:41:e9:09:0f
[    4.368317] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
bash-5.1# ifconfig
usb0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet6 fe80::1  prefixlen 128  scopeid 0x20<link>
        inet6 fc00:1:1::2  prefixlen 64  scopeid 0x0<global>
        ether 2a:6e:41:e9:09:0f  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
bash-5.1#
我看到设备进入recovery模式,有usb0网口,但是主机上没有对应的网口,是这个原因吗,怎么处理?
root@ubuntu:/home/user/EC5000# ifconfig -a
enp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.5.30.4  netmask 255.255.255.0  broadcast 10.5.30.255
        inet6 fe80::8224:599a:d407:9d98  prefixlen 64  scopeid 0x20<link>
        ether 98:29:a6:12:a0:97  txqueuelen 1000  (Ethernet)
        RX packets 47181892  bytes 5680651948 (5.6 GB)
        RX errors 0  dropped 1472721  overruns 0  frame 0
        TX packets 56729344  bytes 72333970973 (72.3 GB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 5807  bytes 690293 (690.2 KB)
        TX packets 5807  bytes 690293 (690.2 KB)
wlp3s0: flags=4098<BROADCAST,MULTICAST>  mtu 1500
        ether 60:14:b3:7e:42:33  txqueuelen 1000  (Ethernet)
你是用custom board?
插到DevKit上試一下 還有整機重燒是不是也是一樣的情況
如果都是的話就是你的module掛了
在DevKit上试了可以烧录QSPI,custom board不能烧录是不是因为我接了USB HUB芯片的原因?
那麻煩先照document調整你USB的內容
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/HR/JetsonModuleAdaptationAndBringUp/JetsonOrinNxNanoSeries.html#porting-universal-serial-bus
我现在使用DevKit烧录也会有问题,有时可以成功,有时会失败
失败时串口日志:
[0073.418] I> skipped mmio_addr = 0x9241030
[0073.422] I> skipped mmio_addr = 0x9241038
[0073.426] I> skipped mmio_addr = 0x9241040
[0073.430] I> skipped mmio_addr = 0x9242000
[0073.433] I> skipped mmio_addr = 0x9242008
[0073.437] I> Task: Prod config init
[0073.441] I> Task: Pad voltage init
[0073.444] I> Task: Prod init
[0073.447] I> Task: Program rst req config reg
[0073.451] I> Task: Common rail init
[0073.455] I> DONE: Thermal config
[0073.458] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0073.466] I> DONE: SOC rail config
[0073.470] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0073.476] I> DONE: MEMIO rail config
[0073.480] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0073.486] I> DONE: GPU rail info
[0073.490] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0073.496] I> DONE: CV rail info
[0073.499] I> Task: Mem clock src
[0073.502] I> Task: Misc. board config
[0073.506] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0073.512] I> Task: SDRAM init
[0073.515] I> MemoryType: 4 MemBctRevision: 1
[0073.521] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0073.529] I> MSS CAR: Init PLLM
[0073.532] I> MSS CAR: Init PLLHUB
[0073.536] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0073.548] I> SDRAM initialized!
[0073.551] I> SDRAM Size in Total 0x400000000
[0073.555] I> Task: Dram Ecc scrub
[0073.558] I> Task: DRAM alias check
[0073.563] E> Alias_checker: Read/write mis-match
[0073.567] C> Task 0x32 failed (err: 0x1c)
[0073.571] E> Top caller module: NONE, error module: NONE, reason: 0x1c, aux_info: 0x00
[0073.579] C> Boot Info Table status dump :
DevKit也燒不過的話大概就是你的module壞了
