Jetson Orin Nano Encrypted RootFs Black Screen
I’m using a Jetson Orin Nano Devkit with JetPack SDK 5.1.2 and BSP 35.4.1. A Ubuntu 20.04 Linux host. OpTee from https://developer.nvidia.com/embedded/l4t/r35_release_v1.0/sources/public_sources.tbz2. Samsung 960 Pro NVME.
I am trying to get disk encryption working with the default/test fuse keys with the OpTee image generated by example.sh on an NVME before I then get it working with custom keys with secure boot enabled. Everything appears to correctly flash, but I am left with a Jetson that boots to NVME with a blinking cursor followed by a black screen and then it restarts and repeats. I’ve copied the commands and the output below.
sudo -s echo -1 > /sys/module/usbcore/parameters/autosuspend
sudo systemctl stop udisks2
cd Linux_for_Tegra
cd ./source/public/optee/samples/hwkey-agent/host/tool/gen_ekb/
./example.sh
cd ../../../../../../../..
cp ./source/public/optee/samples/hwkey-agent/host/tool/gen_ekb/sym2_t234.key ./sym2_t234.key
rm ./bootloader/eks_t234.img
cp ./source/public/optee/samples/hwkey-agent/host/tool/gen_ekb/eks_t234.img ./bootloader/eks_t234.img
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 --no-flash --showlogs -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" jetson-orin-nano-devkit internal
log
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --no-flash --external-device nvme0n1p1 -i ./sym2_t234.key -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml --external-only --append --network usb0 jetson-orin-nano-devkit external
log
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --network usb0 --flash-only
log
My thoughts that I am unsure about are that I keep seeing “Assuming zero filled SBK key”, which I am unsure is what is expected. Should I be specifying an SBK key with -v somewhere?
I’m not sure I have flashed the OpTee image to the EKB partition either correctly or at all, is there a way to check?
Perhaps I have missed something else along the way, any help is appreciated, thanks.
hello chrisward9000,
could you please also share the UART logs from target side for checking.
Jetson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
**  WARNING: Test Key is used.  **
      L4TLauncher: Attempting Recovery Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
▒▒I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
▒▒[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.120-tegra (buildbrain@mobile-u64-6422-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Aug 1 12:32:50 PDT 2023
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: NVIDIA Orin Nano Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x266eb1f18 SMBIOS=0xffff0000 SMBIOS 3.0=0x247630000 MEMATTR=0x248453018 ESRT=0x24848ba98 RNG=0x24883f818 MEMRESERVE=0x248455f18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x000000024848ba98 to 0x000000024848bad0.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000025a800000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000273ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000024731cfff]
[    0.000000]   node   0: [mem 0x000000024731d000-0x0000000247573fff]
[    0.000000]   node   0: [mem 0x0000000247574000-0x000000024757ffff]
[    0.000000]   node   0: [mem 0x0000000247580000-0x000000024763ffff]
[    0.000000]   node   0: [mem 0x0000000247640000-0x00000002482fffff]
[    0.000000]   node   0: [mem 0x0000000248300000-0x000000024839ffff]
[    0.000000]   node   0: [mem 0x00000002483a0000-0x00000002483bffff]
[    0.000000]   node   0: [mem 0x00000002483c0000-0x00000002483dffff]
[    0.000000]   node   0: [mem 0x00000002483e0000-0x00000002483effff]
[    0.000000]   node   0: [mem 0x00000002483f0000-0x000000024841ffff]
[    0.000000]   node   0: [mem 0x0000000248420000-0x000000024845ffff]
[    0.000000]   node   0: [mem 0x0000000248460000-0x000000024847ffff]
[    0.000000]   node   0: [mem 0x0000000248480000-0x000000024858ffff]
[    0.000000]   node   0: [mem 0x0000000248590000-0x000000024876ffff]
[    0.000000]   node   0: [mem 0x0000000248770000-0x000000024882ffff]
[    0.000000]   node   0: [mem 0x0000000248830000-0x00000002488dffff]
[    0.000000]   node   0: [mem 0x00000002488e0000-0x000000024892ffff]
[    0.000000]   node   0: [mem 0x0000000248930000-0x0000000248b5ffff]
[    0.000000]   node   0: [mem 0x0000000248b60000-0x0000000248beffff]
[    0.000000]   node   0: [mem 0x0000000248bf0000-0x0000000248c3ffff]
[    0.000000]   node   0: [mem 0x0000000248c40000-0x0000000248c6ffff]
[    0.000000]   node   0: [mem 0x0000000248c70000-0x0000000248d0ffff]
[    0.000000]   node   0: [mem 0x0000000248d10000-0x0000000248d5ffff]
[    0.000000]   node   0: [mem 0x0000000248d60000-0x0000000248dfffff]
[    0.000000]   node   0: [mem 0x0000000248e00000-0x00000002492dffff]
[    0.000000]   node   0: [mem 0x00000002492e0000-0x00000002494bffff]
[    0.000000]   node   0: [mem 0x00000002494c0000-0x000000026ab2ffff]
[    0.000000]   node   0: [mem 0x000000026ab30000-0x000000026ab7ffff]
[    0.000000]   node   0: [mem 0x000000026ab80000-0x000000026ea0ffff]
[    0.000000]   node   0: [mem 0x000000026ea10000-0x000000026ea1ffff]
[    0.000000]   node   0: [mem 0x0000000272000000-0x0000000273ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000273ffffff]
[    0.000000] On node 0, zone Normal: 480 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2002208
[    0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[    0.000000] Memory: 7367956K/8136832K available (18560K kernel code, 3166K rwdata, 7196K rodata, 3968K init, 1416K bss, 506732K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000659] Console: colour dummy device 80x25
[    0.000704] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000712] pid_max: default: 32768 minimum: 301
[    0.000812] LSM: Security Framework initializing
[    0.000840] Yama: becoming mindful.
[    0.000860] SELinux:  Initializing.
[    0.000946] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.000962] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.001776] /cpus/cpu-map/cluster1: empty cluster
[    0.002103] rcu: Hierarchical SRCU implementation.
[    0.002198] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.002637] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0003-p3768-0000-a0.dts
[    0.002641] DTB Build time: Aug  1 2023 12:44:16
[    0.003934] Tegra Revision: A01 SKU: 0xd5 CPU Process: 0 SoC Process: 0
[    0.004098] Remapping and enabling EFI services.
[    0.004582] smp: Bringing up secondary CPUs ...
[    0.033299] Detected PIPT I-cache on CPU1
[    0.033336] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.033365] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.062031] Detected PIPT I-cache on CPU2
[    0.062041] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.062056] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.090678] Detected PIPT I-cache on CPU3
[    0.090687] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.090701] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.121372] Detected PIPT I-cache on CPU4
[    0.121395] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[    0.121425] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.150141] Detected PIPT I-cache on CPU5
[    0.150153] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[    0.150169] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.150233] smp: Brought up 1 node, 6 CPUs
[    0.150247] SMP: Total of 6 processors activated.
[    0.150251] CPU features: detected: Privileged Access Never
[    0.150253] CPU features: detected: LSE atomic instructions
[    0.150255] CPU features: detected: User Access Override
[    0.150257] CPU features: detected: 32-bit EL0 Support
[    0.150260] CPU features: detected: Common not Private translations
[    0.150261] CPU features: detected: RAS Extension Support
[    0.150263] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.150266] CPU features: detected: CRC32 instructions
[    0.150268] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.188248] CPU: All CPU(s) started at EL2
[    0.190044] devtmpfs: initialized
[    0.210044] Registered cp15_barrier emulation handler
[    0.210052] Registered setend emulation handler
[    0.210059] KASLR enabled
[    0.210196] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.210209] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.212311] pinctrl core: initialized pinctrl subsystem
[    0.212807] SMBIOS 3.0.0 present.
[    0.212816] DMI: Unknown NVIDIA Orin Nano Developer Kit/NVIDIA Orin Nano Developer Kit, BIOS 4.1-33958178 08/01/2023
[    0.213179] NET: Registered protocol family 16
[    0.214116] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.214180] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.214237] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.214270] audit: initializing netlink subsys (disabled)
[    0.214366] audit: type=2000 audit(0.212:1): state=initialized audit_enabled=0 res=1
[    0.214574] thermal_sys: Registered thermal governor 'step_wise'
[    0.214577] thermal_sys: Registered thermal governor 'power_allocator'
[    0.214581] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.215530] cpuidle: using governor menu
[    0.215641] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.215715] ASID allocator initialised with 32768 entries
[    0.215822] Serial: AMBA PL011 UART driver
[    0.217827] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.217855] Tegra reboot handler registered.
[    0.240240] mc: mapped MMIO address: 0xffff8000107b0000 -> 0x2c10000
[    0.240254] mc: mapped MMIO address: 0xffff8000107d0000 -> 0x2c20000
[    0.240262] mc: mapped MMIO address: 0xffff8000107f0000 -> 0x2c30000
[    0.240272] mc: mapped MMIO address: 0xffff800010810000 -> 0x2c40000
[    0.240279] mc: mapped MMIO address: 0xffff800010830000 -> 0x2c50000
[    0.240285] mc: mapped MMIO address: 0xffff800010850000 -> 0x2b80000
[    0.240292] mc: mapped MMIO address: 0xffff800010870000 -> 0x2b90000
[    0.240298] mc: mapped MMIO address: 0xffff800010890000 -> 0x2ba0000
[    0.240305] mc: mapped MMIO address: 0xffff8000108b0000 -> 0x2bb0000
[    0.240312] mc: mapped MMIO address: 0xffff8000108d0000 -> 0x1700000
[    0.240318] mc: mapped MMIO address: 0xffff8000108f0000 -> 0x1710000
[    0.240331] mc: mapped MMIO address: 0xffff800010910000 -> 0x1720000
[    0.240338] mc: mapped MMIO address: 0xffff800010930000 -> 0x1730000
[    0.240344] mc: mapped MMIO address: 0xffff800010950000 -> 0x1740000
[    0.240351] mc: mapped MMIO address: 0xffff800010970000 -> 0x1750000
[    0.240358] mc: mapped MMIO address: 0xffff800010990000 -> 0x1760000
[    0.240365] mc: mapped MMIO address: 0xffff8000109b0000 -> 0x1770000
[    0.240372] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.240417] mc-err: mcerr ops are set to t23x
[    0.241172] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[    0.245939] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.245945] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.245947] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.245949] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.248002] ACPI: Interpreter disabled.
[    0.248485] ddr-vddq: supplied by vdd-5v
[    0.248672] ddr-vdd2: supplied by vdd-5v
[    0.248807] vdd-AO-1v2: supplied by vdd-5v
[    0.248935] vdd-3v3: supplied by vdd-5v
[    0.249060] vdd-rtc: supplied by vdd-AO-1v2
[    0.249185] vdd-0v95-uphy: supplied by vdd-AO-1v2
[    0.249289] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[    0.249563] vdd-1v8: supplied by vdd-3v3-sys
[    0.249680] vdd-3v3-AO: supplied by vdd-5v-sys
[    0.249805] vdd-av10-hub: supplied by vdd-5v-sys
[    0.249898] vdd-vbus-a: supplied by vdd-5v-sys
[    0.250027] vdd-vbus-b: supplied by vdd-5v-sys
[    0.250124] vdd-3v3-dp: supplied by vdd-3v3-sys
[    0.250449] iommu: Default domain type: Translated
[    0.250492] eventlib_kernel: keventlib is initialized, test id: 0
[    0.250707] SCSI subsystem initialized
[    0.250795] usbcore: registered new interface driver usbfs
[    0.250824] usbcore: registered new interface driver hub
[    0.250837] usbcore: registered new device driver usb
[    0.251051] mc: Linux media interface: v0.10
[    0.251061] videodev: Linux video capture interface: v2.00
[    0.251231] pps_core: LinuxPPS API ver. 1 registered
[    0.251234] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.251240] PTP clock support registered
[    0.251516] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    0.251573] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    0.252954] Registered efivars operations
[    0.253111] FPGA manager framework
[    0.253155] Advanced Linux Sound Architecture Driver Initialized.
[    0.253455] Bluetooth: Core ver 2.22
[    0.253470] NET: Registered protocol family 31
[    0.253471] Bluetooth: HCI device and connection manager initialized
[    0.253478] Bluetooth: HCI socket layer initialized
[    0.253488] Bluetooth: L2CAP socket layer initialized
[    0.253495] Bluetooth: SCO socket layer initialized
[    0.254037] camchar: rtcpu character device driver loaded
[    0.254279] clocksource: Switched to clocksource arch_sys_counter
[    0.457185] VFS: Disk quotas dquot_6.6.0
[    0.457228] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.457580] pnp: PnP ACPI: disabled
[    0.460052] la/ptsa driver initialized.
[    0.460136] NET: Registered protocol family 2
[    0.460286] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.461800] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.461817] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.461894] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.462442] TCP: Hash tables configured (established 65536 bind 65536)
[    0.462513] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.462535] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.462624] NET: Registered protocol family 1
[    0.462872] RPC: Registered named UNIX socket transport module.
[    0.462876] RPC: Registered udp transport module.
[    0.462878] RPC: Registered tcp transport module.
[    0.462879] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.462888] PCI: CLS 0 bytes, default 64
[    0.463018] Trying to unpack rootfs image as initramfs...
[    0.747768] Freeing initrd memory: 16596K
[    0.749924] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.750088] kvm [1]: IPA Size Limit: 48 bits
[    0.750109] kvm [1]: GICv3: no GICV resource entry
[    0.750115] kvm [1]: disabling GICv2 emulation
[    0.750138] kvm [1]: GIC system register CPU interface enabled
[    0.750203] kvm [1]: vgic interrupt IRQ9
[    0.750327] kvm [1]: VHE mode initialized successfully
[    0.751071] Initialise system trusted keyrings
[    0.751164] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    0.753941] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.754351] NFS: Registering the id_resolver key type
[    0.754368] Key type id_resolver registered
[    0.754372] Key type id_legacy registered
[    0.754420] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.754430] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.754444] ntfs: driver 2.1.32 [Flags: R/W].
[    0.769657] NET: Registered protocol family 38
[    0.769663] Key type asymmetric registered
[    0.769666] Asymmetric key parser 'x509' registered
[    0.769688] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[    0.769753] io scheduler mq-deadline registered
[    0.769757] io scheduler kyber registered
[    0.774069] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.774098] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.774119] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    0.774135] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    0.776817] tegra_dc_assign_hw_data: no matching compatible node
[    0.776821] tegradccommon module_init failed
[    0.776824] tegradc module_init failed
[    0.777102] EINJ: ACPI disabled.
[    0.778886] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.778893] tegra-pmc: ### PMC reset source: SYS_RESET_N
[    0.778897] tegra-pmc: ### PMC reset level: L0
[    0.778899] tegra-pmc: ### PMC reset status reg: 0x0
[    0.780325] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.328064] printk: console [ttyTCU0] enabled
[    2.333224] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.338753] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.343281] arm-smmu 12000000.iommu:         stage 1 translation
[    2.348615] arm-smmu 12000000.iommu:         stage 2 translation
[    2.354129] arm-smmu 12000000.iommu:         nested translation
[    2.359469] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    2.366465] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    2.375666] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    2.379507] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.386066] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.393549] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.399106] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.403829] arm-smmu 10000000.iommu:         stage 1 translation
[    2.409340] arm-smmu 10000000.iommu:         stage 2 translation
[    2.414766] arm-smmu 10000000.iommu:         nested translation
[    2.420193] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    2.427367] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    2.436570] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    2.440580] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.447141] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.454199] arm-smmu 8000000.iommu: probing hardware configuration...
[    2.460269] arm-smmu 8000000.iommu: SMMUv2 with:
[    2.464990] arm-smmu 8000000.iommu:  stage 1 translation
[    2.470505] arm-smmu 8000000.iommu:  stage 2 translation
[    2.475928] arm-smmu 8000000.iommu:  nested translation
[    2.481093] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    2.488266] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    2.497497] arm-smmu 8000000.iommu:  Supported page sizes: 0x00001000
[    2.501480] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    2.508040] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    2.515335] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    2.523875] tegra_profiler: version: 1.151, samples/io: 51/30
[    2.528263] tegra_profiler: auth: init
[    2.532372] nvsciipc: loaded module
[    2.537535] tun: Universal TUN/TAP device driver, 1.6
[    2.541290] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.547948] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.553480] e1000e: Intel(R) PRO/1000 Network Driver
[    2.558271] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.564146] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.569554] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.575414] PPP generic driver version 2.4.2
[    2.579764] PPP BSD Compression module registered
[    2.584350] PPP Deflate Compression module registered
[    2.589606] PPP MPPE Compression module registered
[    2.594610] usbcore: registered new interface driver r8152
[    2.599931] usbcore: registered new interface driver asix
[    2.605264] usbcore: registered new interface driver ax88179_178a
[    2.611392] usbcore: registered new interface driver cdc_ether
[    2.617338] usbcore: registered new interface driver net1080
[    2.622941] usbcore: registered new interface driver cdc_subset
[    2.628975] usbcore: registered new interface driver zaurus
[    2.634669] usbcore: registered new interface driver cdc_ncm
[    2.640348] usbcore: registered new interface driver aqc111
[    2.645900] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.652079] ohci-pci: OHCI PCI platform driver
[    2.656372] ohci-platform: OHCI generic platform driver
[    2.661775] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    2.667804] usbcore: registered new interface driver uas
[    2.672661] usbcore: registered new interface driver usb-storage
[    2.678663] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    2.684394] mousedev: PS/2 mouse device common for all mice
[    2.689815] usbcore: registered new interface driver xpad
[    2.697110] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.700562] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:21 UTC (21)
[    2.708346] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.714642] i2c /dev entries driver
[    2.718164] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    2.723747] tegra-i2c c240000.i2c: Adding to iommu group 2
[    2.729161] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    2.734550] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    2.739880] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    2.745400] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    2.750821] tegra-i2c c250000.i2c: Adding to iommu group 2
[    2.756154] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    2.766118] device-mapper: uevent: version 1.0.3
[    2.766379] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    2.775744] sdhci: Secure Digital Host Controller Interface driver
[    2.780786] sdhci: Copyright(c) Pierre Ossman
[    2.785070] Synopsys Designware Multimedia Card Interface Driver
[    2.791194] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.797445] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[    2.797730] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    2.810141] tegra-bpmp bpmp: firmware: cedb24d07defeef07ea9-925eece486b
[    2.817968] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    2.822113] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[    2.833426] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    2.833631] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
▒▒debugfs initialized
▒▒[    3.950906] hid: raw HID events driver (C) Jiri Kosina
[    3.951595] usbcore: registered new interface driver usbhid
[    3.951761] usbhid: USB HID core driver
[    3.952330] tegra-dce d800000.dce: Adding to iommu group 4
[    3.953567] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]
[    3.954006] tegra234-aon c000000.aon: Adding to iommu group 5
[    3.955124] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    3.955416] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [0]. Ignored...
[    3.955672] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]
[    3.955999] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    3.956258] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...
[    3.956260] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    3.956277] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    3.956476] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]
[    3.956524]  c000000.aon:hsp: probed
[    3.962756] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    3.971503] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...
[    3.971506] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    3.979791] tegra234-aon c000000.aon: init done
[    3.980218] tegra23x-psc e860000.psc: Adding to iommu group 6
[    3.988389] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    3.988395] dce: dce_start_boot_flow:173  DCE_BOOT_DONE
[    3.993313] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[    4.018551] tegra23x-psc e860000.psc: init done
[    4.023436] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[    4.030562] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    4.043087] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    4.046528] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    4.057779] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    4.068633] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    4.079670] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320▒▒▒▒]=0▒▒I/▒▒xaf▒▒TC:▒▒00-▒▒ Re▒▒0xf▒▒ser▒▒f80▒▒ved▒▒
▒▒s b▒▒  ▒▒har▒▒  4▒▒ed ▒▒.09▒▒me▒▒141▒▒mor▒▒5] ▒▒y i▒▒teg▒▒s d▒▒ra-▒▒isa▒▒ivc▒▒ble▒▒-bu▒▒d
▒▒: v▒▒▒▒c00▒▒▒▒000▒▒I/▒▒.rt▒▒TC:▒▒cpu▒▒ Dy▒▒:iv▒▒nam▒▒c-b▒▒ic ▒▒us:▒▒sha▒▒ivc▒▒re▒▒cap▒▒d m▒▒tur▒▒emo▒▒e@4▒▒ry ▒▒: i▒▒is ▒▒vcc▒▒ena▒▒apt▒▒bl▒▒ure▒▒ed
       ▒▒er=▒▒▒▒0 g▒▒I/▒▒rp=▒▒TC:▒▒1 R▒▒ No▒▒X[5▒▒rma▒▒12x▒▒l ▒▒64]▒▒Wor▒▒=0x▒▒ld ▒▒ff8▒▒vir▒▒0-0▒▒tua▒▒x18▒▒liz▒▒000▒▒ati▒▒ TX▒▒on▒▒[51▒▒ su▒▒2x6▒▒ppo▒▒4]=▒▒rt ▒▒0x1▒▒is ▒▒800▒▒dis▒▒0-0▒▒ab▒▒x20▒▒led▒▒080▒▒
▒▒▒▒[  ▒▒I/▒▒  4▒▒TC:▒▒.10▒▒ As▒▒389▒▒ync▒▒5] ▒▒hr▒▒teg▒▒ono▒▒ra-▒▒us ▒▒ivc▒▒not▒▒-bu▒▒ifi▒▒s b▒▒cat▒▒c00▒▒io▒▒000▒▒ns ▒▒.rt▒▒are▒▒cpu▒▒ di▒▒:iv▒▒sab▒▒c-b▒▒led▒▒us:▒▒
▒▒dia▒▒▒▒g@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    4.116128] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (113)
[    4.121978] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    4.130571] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[    4.143121] t19x_cache tegra-cache: probed
[    4.145389] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    4.156105] optee: probing for conduit method.
[    4.156247] optee: revision 3.21 (d8269f24)
[    4.216882] optee: dynamic shared memory is enabled
[    4.217230] optee: initialized driver
[    4.230155] nvpmodel: initialized successfully
[    4.230390] tegra_hv: get_hvd: not initialized yet
[    4.230527] user_ivc_mempool: hypervisor not present
[    4.231493] usbcore: registered new interface driver snd-usb-audio
[    4.232592] u32 classifier
[    4.233359]     input device check on
[    4.237044]     Actions configured
[    4.240445] Initializing XFRM netlink socket
[    4.245175] NET: Registered protocol family 10
[    4.250638] Segment Routing with IPv6
[    4.252744] NET: Registered protocol family 17
[    4.257097] NET: Registered protocol family 15
[    4.261509] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.274965] Bluetooth: RFCOMM socket layer initialized
[    4.279761] Bluetooth: RFCOMM ver 1.11
[    4.283686] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.289540] Bluetooth: HIDP socket layer initialized
[    4.295124] 9pnet: Installing 9P2000 support
[    4.298965] Key type dns_resolver registered
[    4.303945] registered taskstats version 1
[    4.307401] Loading compiled-in X.509 certificates
[    4.322585] Loaded X.509 cert 'Build time autogenerated kernel key: d94b64a20d69a5a32183bad4f211c4cae67041a9'
[    4.323551] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[    4.335251] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    4.336516] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[    4.346902] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    4.347632] tegra194-pcie 141e0000.pcie: Adding to iommu group 10
[    4.358843] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    4.359449] tegra194-pcie 140a0000.pcie: Adding to iommu group 11
[    4.371422] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    4.398777] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[    4.401801] host1x 13e40000.host1x: Adding to iommu group 13
[    4.427118] host1x 13e40000.host1x: initialized
[    4.427653] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[    4.428121] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[    4.430049] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[    4.430475] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[    4.432403] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[    4.432800] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[    4.444271] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[    4.450354] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    4.462003] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[    4.468156] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    4.480040] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[    4.486167] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    4.498046] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[    4.504194] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    4.516065] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[    4.522217] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    4.534119] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[    4.540256] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[    4.552118] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[    4.558297] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[    4.570156] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[    4.576340] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[    4.588160] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[    4.594336] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[    4.606206] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[    4.612337] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[    4.624211] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[    4.630390] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[    4.642243] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[    4.648390] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[    4.660276] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[    4.666419] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[    4.678342] falcon 15340000.vic: Adding to iommu group 30
[    4.687344] falcon 15340000.vic: initialized
[    4.687847] falcon 15380000.nvjpg: Adding to iommu group 31
[    4.695136] falcon 15380000.nvjpg: initialized
[    4.696915] falcon 15540000.nvjpg1: Adding to iommu group 32
[    4.705791] falcon 15540000.nvjpg1: initialized
[    4.707332] falcon 15a50000.ofa: Adding to iommu group 33
[    4.716272] falcon 15a50000.ofa: initialized
[    4.717316] nvdec 15480000.nvdec: Adding to iommu group 34
[    4.728511] nvdec 15480000.nvdec: initialized
[    4.728778] tsec 15500000.tsec: Adding to iommu group 35
[    4.736577] tsec 15500000.tsec: initialized
[    4.739351] gic 2a41000.agic-controller: GIC IRQ controller registered
[    4.754374] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    4.763386] gpio-397 (camera-control-output-low): hogged as output/low
[    4.763600] gpio-486 (camera-control-output-low): hogged as output/low
[    4.764500] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    4.769849] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    4.776052] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    4.782405] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    4.788077] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    4.793368] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    4.801149] tegra194-isp5 14800000.isp: Adding to iommu group 36
[    4.806630] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    4.813929] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    4.819634] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    4.828723] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    4.838071] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[    4.845836] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[    4.852713] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[    4.861499] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    4.867843] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[    4.877673] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    4.883846] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    4.893653] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    4.899726] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[    4.906410] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    4.912713] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    4.919014] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    4.925776] serial-tegra 3100000.serial: Adding to iommu group 2
[    4.931927] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[    4.941213] serial-tegra 3130000.serial: Adding to iommu group 2
[    4.946571] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[    4.955955] serial-tegra 3140000.serial: Adding to iommu group 2
[    4.961392] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[    4.987464] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[    4.987722] tegra-xusb 3610000.xhci: xHCI Host Controller
[    4.987879] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    4.993381] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    5.002013] tegra-xusb 3610000.xhci: irq 219, io mem 0x03610000
[    5.008202] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    5.016229] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.023400] usb usb1: Product: xHCI Host Controller
[    5.028386] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[    5.034684] usb usb1: SerialNumber: 3610000.xhci
[    5.040056] hub 1-0:1.0: USB hub found
[    5.043209] hub 1-0:1.0: 4 ports detected
[    5.047460] tegra-xusb 3610000.xhci: xHCI Host Controller
[    5.052635] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    5.060249] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    5.067661] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    5.075823] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.083075] usb usb2: Product: xHCI Host Controller
[    5.088060] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[    5.094273] usb usb2: SerialNumber: 3610000.xhci
[    5.099528] hub 2-0:1.0: USB hub found
[    5.102696] hub 2-0:1.0: 4 ports detected
[    5.128032] i2c i2c-2: Added multiplexed i2c bus 9
[    5.128504] i2c i2c-2: Added multiplexed i2c bus 10
[    5.128630] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    5.129095] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[    5.144353] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1537000 KHz, changing to: 1510400 KHz
[    5.146843] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1495000 KHz, changing to: 1497600 KHz
[    5.154307] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[    5.161379] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    5.162226] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    5.167123] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    5.177150] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    5.178321] irq: IRQ283: trimming hierarchy from :interrupt-controller@f400000-1
[    5.185719] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    5.185724] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    5.193381] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 283
[    5.310279] tegra194-pcie 14100000.pcie: Link up
[    5.311660] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    5.311844] pci_bus 0001:00: root bus resource [bus 00-ff]
[    5.311994] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    5.312246] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    5.312527] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    5.312797] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    5.313144] pci 0001:00:00.0: PME# supported from D0 D3hot
[    5.314283] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    5.319084] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    5.319406] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    5.319762] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    5.321079] pci 0001:01:00.0: supports D1 D2
[    5.321192] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    5.326737] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    5.326934] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    5.327091] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    5.333165] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    5.339396] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    5.344613] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    5.350827] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    5.358187] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    5.366734] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    5.375375] pcieport 0001:00:00.0: Adding to iommu group 8
[    5.380610] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[    5.387042] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[    5.392746] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    5.400012] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    5.404908] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    5.413393] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    5.421875] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    5.483758] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489, bcdDevice= 1.40
[    5.483979] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.484161] usb 1-2: Product: 4-Port USB 2.0 Hub
[    5.484285] usb 1-2: Manufacturer: Generic
[    5.485975] hub 1-2:1.0: USB hub found
[    5.487216] hub 1-2:1.0: 4 ports detected
[    5.538589] tegra194-pcie 14160000.pcie: Link up
[    5.548817] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    5.549006] pci_bus 0004:00: root bus resource [bus 00-ff]
[    5.549145] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    5.549404] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    5.549680] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    5.549924] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    5.550231] pci 0004:00:00.0: PME# supported from D0 D3hot
[    5.555305] pci 0004:01:00.0: [144d:a804] type 00 class 0x010802
[    5.555637] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    5.561999] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    5.562191] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    5.562471] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    5.562603] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    5.562798] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.567272] pci 0004:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    5.575962] pcieport 0004:00:00.0: Adding to iommu group 9
[    5.581455] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[    5.587785] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[    5.593117] nvme 0004:01:00.0: Adding to iommu group 9
[    5.598500] nvme nvme0: pci function 0004:01:00.0
[    5.602820] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    5.603539] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    5.608439] usb 2-1: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[    5.616098] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[    5.625917] nvme nvme0: 6/0/0 default/read/poll queues
[    5.629083] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    5.642645] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    5.642962]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[    5.651298] tegra194-pcie 141e0000.pcie:      MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[    5.681882] usb 2-1: New USB device found, idVendor=0bda, idProduct=0489, bcdDevice= 1.40
[    5.682103] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.682542] usb 2-1: Product: 4-Port USB 3.0 Hub
[    5.687261] usb 2-1: Manufacturer: Generic
[    5.704424] hub 2-1:1.0: USB hub found
[    5.706807] hub 2-1:1.0: 4 ports detected
[    5.798279] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    5.950408] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[    5.950653] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.950859] usb 1-3: Product: Bluetooth Radio
[    5.950991] usb 1-3: Manufacturer: Realtek
[    5.951110] usb 1-3: SerialNumber: 00e04c000001
[    6.758613] tegra194-pcie 141e0000.pcie: Phy link never came up
[    6.758878] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    6.759075] pci_bus 0007:00: root bus resource [bus 00-ff]
[    6.759233] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[    6.759514] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[    6.759827] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[    6.760090] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    6.760400] pci 0007:00:00.0: PME# supported from D0 D3hot
[    6.769749] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    6.769897] pci 0007:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    6.770431] pcieport 0007:00:00.0: Adding to iommu group 10
[    6.770813] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[    6.771753] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[    6.772325] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[    6.772581] pci 0007:00:00.0: Removing from iommu group 10
[    6.772731] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[    6.774688] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    6.779730] vdd-3v3-sd: supplied by vdd-3v3
[    6.785018] tegra194-isp5 14800000.isp: initialized
[    6.790973] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[    6.794863] (NULL device *): fops function table already registered
[    6.802011] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[    6.807799] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    6.807914] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    6.813632] irq: IRQ291: trimming hierarchy from :interrupt-controller@f400000-1
[    6.830318] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 283
[    6.935380] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[    6.935604] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[    6.935854] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[    6.936110] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[    7.042441] tegra194-pcie 140a0000.pcie: Link up
[    7.044989] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[    7.045191] pci_bus 0008:00: root bus resource [bus 00-ff]
[    7.045342] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[    7.045616] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[    7.045900] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[    7.046152] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[    7.046471] pci 0008:00:00.0: PME# supported from D0 D3hot
[    7.051552] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[    7.051850] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    7.052181] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    7.052469] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    7.053671] pci 0008:01:00.0: supports D1 D2
[    7.053780] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    7.059049] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[    7.059236] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[    7.059410] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[    7.065302] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[    7.073175] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[    7.079674] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[    7.084898] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[    7.091287] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[    7.098646] pci 0008:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    7.107186] pci 0008:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    7.115883] pcieport 0008:00:00.0: Adding to iommu group 11
[    7.121547] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[    7.127871] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[    7.133885] irq: IRQ293: trimming hierarchy from :pmc@c360000
[    7.138529] irq: IRQ294: trimming hierarchy from :interrupt-controller@f400000-1
[    7.145939] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    7.153453] tegra-se-nvhost 15810000.se: Adding to iommu group 39
[    7.159291] tegra-se-nvhost 15810000.se: initialized
[    7.165567] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    7.170079] tegra-se-nvhost 15820000.se: Adding to iommu group 40
[    7.176361] tegra-se-nvhost 15820000.se: initialized
[    7.184265] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    7.187133] tegra-se-nvhost 15840000.se: Adding to iommu group 41
[    7.193597] tegra-se-nvhost 15840000.se: initialized
[    7.202233] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    7.205162] tegra_actmon d230000.actmon: in actmon_register()...
[    7.210648] tegra_actmon d230000.actmon: bwmgr_disable = 1
[    7.216189] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    7.224041] hvc_sysfs: hypervisor is not present
[    7.261662] ALSA device list:
[    7.261751]   No soundcards found.
[    7.262747] Freeing unused kernel memory: 3968K
[    7.266316] Run /init as init process
[    7.283452] Root device found: initrd
modprobe: FATAL: Module r8168 not found in directory /lib/modules/5.10.120-tegra
[    7.286084] Mount initrd as rootfs and enter recovery mode
Finding OTA work dir on external storage devices
Checking whether device /dev/mmcblk?p1 exist
Device /dev/mmcblk?p1 does not exist
Checking whether device /dev/sd?1 exist
Device /dev/sd?1 does not exist
Checking whether device /dev/nvme?n1p1 exist
Looking for OTA work directory on the device(s): /dev/nvme0n1p1
mount /dev/nvme0n1p1 /mnt
[    7.317765] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
is_boot_only_partition /mnt
The mounted /dev/nvme0n1p1 is boot partition, try locating rootfs partition and mount it...
mount_rootfs_partition /dev/nvme0n1p1 /mnt
Found encrypted rootfs partition /dev/nvme0n1p2 through UUID(9bb884da-dbae-41cb-ac00-e929df91badd)
umount /mnt
[    7.377826] random: crng init done
unlock_encrypted_partition /dev/nvme0n1p2 dm_crypt_ota dm_crypt
is_luks_partition /dev/nvme0n1p2
is_unlocked /dev/nvme0n1p2 unlocked_device_name
get_uuid_for_luks_partition /dev/nvme0n1p2 luks_uuid
[    7.874247] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
No key available with this passphrase.
Failed to unlock the LUKS partition /dev/nvme0n1p2(UUID=9bb884da-dbae-41cb-ac00-e929df91badd)
Failed to run "unlock_encrypted_partition /dev/nvme0n1p2 dm_crypt_ota dm_crypt"
Failed to run "moutn_rootfs_partition /dev/nvme0n1p1 /mnt"
Failed to run "mount_ota_work_partition /dev/nvme0n1p1 /mnt"
Finding OTA work dir on internal storage device
mount /dev/mmcblk0p1 /mnt
mount: /mnt: special device /dev/mmcblk0p1 does not exist.
Failed to mount /dev/mmcblk0p1 on the /mnt
Failed to run "mount_ota_work_partition /dev/mmcblk0p1 /mnt"
OTA work directory is not found on internal and external storage devices
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
I then have a shell I can work in.
This looks the most relevant, but I am unsure as to why this error should occur as I thought I was using the OpTee default img created by example.sh which uses the default key. My thoughts are that I haven’t flashed that image properly or I have done it incorrectly, please let me know your thoughts, thanks.
it looks you’ve not updating EKS image correctly, or, there’s something wrong to create an encrypted rootfs for image flashing.
please double check you had this utility installed. i.e. $ sudo apt-get install cryptsetup.
here’s see-also discussion thread, Topic 264454, comment #22, it gives brief steps to verify disk encryption with Orin NX.
I think my issue here was that I didn’t have the Jetson-Orin-Nano-Devkit plugged in while I was generating images.
let’s close this topic if there’s no further questions.
The solution is to not swap the eks_t234.img file when flashing an unfused device.
here’s an FYI,
EKB (Encrypted Binary Blob) stores two keys, one is the kernel encryption key (sym_key_file), and another one is the LUKS key (sym2_key_file) for disk encryption support.
LUKS disk encryption support with a specific key. it’s script file, gen_ekb.py to generate an EKS image, (i.e. eks_t234.img file). also, in the developer guide, [Tool for EKB Generation] in the OP-TEE section, that sym2.key is equivalent to ekb.key
here’s see-also topic that we’ve verified disk encryption (i.e. ROOTFS_ENC=1) on Orin NX.
for instance, Topic 264454.
