Unable to flash SSD on Jetson AGX Orin Dev Kit
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_AGX_Orin_modules_2024-07-31_17-51-45.zip (315.4 KB)
Hello, I’ve tried flashing our Nvidia Jetson AGX Orin Dev Kit to Jetpack 6.0 I am able to flash the EEPROM, but not the NVME SSD for some reason.
Let me know if you require more logs.
  Jetson System firmware version 36.3.0-gcid-36191598 date 2024-05-06T16:58:59+00:
00
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
......EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
��debugfs initialized
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.136-tegra (buildbrain@mobile-u64-6367-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon May 6 09)
[    0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: SMBIOS=0xffff0000 SMBIOS 3.0=0x7fb350000 MEMATTR=0x7f4cbd018 RNG=0x7e7e80018 MEMRESERVE=0x7e9b27f18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] Reserved memory: created CMA memory pool at 0x000000081c000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000833ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x818c7a800-0x818c7cfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000833ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000007ec467fff]
[    0.000000]   node   0: [mem 0x00000007ec468000-0x00000007ec59bfff]
[    0.000000]   node   0: [mem 0x00000007ec59c000-0x00000007f9a7ffff]
[    0.000000]   node   0: [mem 0x00000007f9a80000-0x00000007fb9bffff]
[    0.000000]   node   0: [mem 0x00000007fb9c0000-0x000000082c5fffff]
[    0.000000]   node   0: [mem 0x000000082c600000-0x000000082c7fffff]
[    0.000000]   node   0: [mem 0x000000082c800000-0x000000082cd6ffff]
[    0.000000]   node   0: [mem 0x000000082d700000-0x000000082d7fffff]
[    0.000000]   node   0: [mem 0x0000000832000000-0x0000000833ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000833ffffff]
[    0.000000] On node 0, zone Normal: 2448 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 18432 pages in unavailable ranges
[  ��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
��  0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.00��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
��0000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU fe��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
��atures: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 7930224
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 bl_prof_dataptr=2031616@0x82C610000 b
[    0.000000] Unknown kernel com��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla1_core
��mand line parameters "bl_prof_dataptr=2031616@0x82C610000 bl_prof_ro_ptr=65536@0x82C600000", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla1_core
��777216 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 31135400K/32225728K available (19712K kernel code, 4056K rwdata, 9968K ro��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla1_falcon
��data, 7680K init, 529K bss, 828184K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     ��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla1_falcon
��RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[  ��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_core
��  0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_core
��[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: fo��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_falcon
��und redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000002] sched_clock: 56 bits at 31M��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_falcon
��Hz, resolution 32ns, wraps every 4398046511088ns
[    0.000554] Console: colour dummy device 80x25
[    0.000686] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000702] pid_max: default: 32768 minimum: 301
[    0.000769] LSM: Security Framework initializing
[    0.000818] Yama: becoming mindful.
[    0.000852] SELinux:  Initializing.
[    0.001101] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.001252] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.004144] rcu: Hierarchical SRCU implementation.
[    0.008129] Tegra Revision: A01 SKU: 208 CPU Process: 0 SoC Pro��WARNING @ [platform/drivers/clk/clk-fwk/clk.c]: clk_disable_ungated_and_locked_recursive called with refcount 0 for pll_c4
��cess: 0
[    0.008516] Remapping and enabling EFI services.
[    0.009773] smp: Bringing up secondary CPUs ...
[    0.010636] Detected PIPT I-cache on CPU1
[    0.010734] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.010795] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.011536] Detected PIPT I-cache on CPU2
[    0.011550] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.011570] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.012201] Detected PIPT I-cache on CPU3
[    0.012213] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.012232] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.014960] Detected PIPT I-cache on CPU4
[    0.014987] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.015021] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.015725] Detected PIPT I-cache on CPU5
[    0.015738] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.015757] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.016421] Detected PIPT I-cache on CPU6
[    0.016438] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.016459] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.017131] Detected PIPT I-cache on CPU7
[    0.017144] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.017163] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.019875] Detected PIPT I-cache on CPU8
[    0.019904] GICv3: CPU8: found redisinsbutmodib/200mod00 ion 0:0x0.13000egr540pda
tes/dr[  ive.01rs/993/et6] CPUnetBooted se/realtcony pek/r8168.rocko essor 0x0000020000 [0x410fd421]
[    0.020667] Detected PIPT I-cache on CPU9
[  ena.02068mot0] e_acceGICssv3: CPU9:ble fo redistri remot201cceregion 0:0x000000000f560000
[    0.020703]  /lib/Bootedmodules/5.15darroc6-tegressa/kor ern000el/020dri [00fdver421hy/ra/phy[  -te  0gra.021384] -p2ecto ed
T I-cache on CPU10
[    0.021397] GICv3: CPU10: found redistributorinsmod /l200ib/mod ren 0s/5.150006-tegrf58000ern0
el/[    0dris/pci/.02141conlle8] CPU10: Bootewc/d secoe-tndaa19ry o cessor 0x0000020200 [0x410fd421]
[    0.022101] Detected PIPT I-cache on CPU11
[    0.022115] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[    0.022137] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[    0.022209] smp: Brought up 1 node, 12 CPUs
[    0.022217] SMP: Total of 12 processors activated.
[    0.022222] CPU features: detected: 32-bit EL0 Support
[    0.022224] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.022228] CPU features: detected: Common not Private translations
[    0.022230] CPU features: detected: CRC32 instructions
[    0.022233] CPU features: detected: Data cache clean to Point of Persistence
[    0.022235] CPU features: detected: Generic authentication (architected algorithm)
[    0.022239] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.022239] CPU features: detected: LSE atomic instructions
[    0.022241] CPU features: detected: Privileged Access Never
[    0.022243] CPU features: detected: RAS Extension Support
[    0.022250] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.074127] CPU: All CPU(s) started at EL2
[    0.079590] devtmpfs: initialized
[    0.102949] KASLR enabled
[    0.103145] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.103177] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.108203] pinctrl core: initialized pinctrl subsystem
[    0.109202] SMBIOS 3.6.0 present.
[    0.109216] DMI: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[    0.109815] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.111961] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.112334] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.112674] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.112726] audit: initializing netlink subsys (disabled)
[    0.112868] audit: type=2000 audit(0.112:1): state=initialized audit_enabled=0 res=1
[    0.114695] thermal_sys: Registered thermal governor 'step_wise'
[    0.114699] thermal_sys: Registered thermal governor 'user_space'
[    0.114700] thermal_sys: Registered thermal governor 'power_allocator'
[    0.119794] cpuidle: using governor menu
[    0.119963] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.120109] ASID allocator initialised with 32768 entries
[    0.122262] Serial: AMBA PL011 UART driver
[    0.132995] tegra-mc 2c00000.memory-controller: unknown: write @0x0000000050060500: Security violation (TrustZone violation)
[    0.133922] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 118, base_baud = 0) is a SBSA
[    0.145772] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.155192] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.155199] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.155204] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.155206] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.156213] cryptd: max_cpu_qlen set to 1000
[    0.157941] ACPI: Interpreter disabled.
[    0.159850] iommu: Default domain type: Translated
[    0.159856] iommu: DMA domain TLB invalidation policy: strict mode
[    0.160170] SCSI subsystem initialized
[    0.160353] vgaarb: loaded
[    0.160515] usbcore: registered new interface driver usbfs
[    0.160539] usbcore: registered new interface driver hub
[    0.160565] usbcore: registered new device driver usb
[    0.161001] pps_core: LinuxPPS API ver. 1 registered
[    0.161006] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.161022] PTP clock support registered
[    0.161089] EDAC MC: Ver: 3.0.0
[    0.162284] Registered efivars operations
[    0.162837] FPGA manager framework
[    0.162917] Advanced Linux Sound Architecture Driver Initialized.
[    0.163753] clocksource: Switched to clocksource arch_sys_counter
[    0.199128] VFS: Disk quotas dquot_6.6.0
[    0.199216] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.199469] pnp: PnP ACPI: disabled
[    0.202808] NET: Registered PF_INET protocol family
[    0.203352] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.205687] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.205726] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.205760] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.205988] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.207381] TCP: Hash tables configured (established 262144 bind 65536)
[    0.207588] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.207662] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.207949] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.208418] RPC: Registered named UNIX socket transport module.
[    0.208422] RPC: Registered udp transport module.
[    0.208424] RPC: Registered tcp transport module.
[    0.208424] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.208444] PCI: CLS 0 bytes, default 64
[    0.208720] Unpacking initramfs...
[    0.220990] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.221365] kvm [1]: IPA Size Limit: 48 bits
[    0.221402] kvm [1]: GICv3: no GICV resource entry
[    0.221409] kvm [1]: disabling GICv2 emulation
[    0.221447] kvm [1]: GIC system register CPU interface enabled
[    0.221574] kvm [1]: vgic interrupt IRQ9
[    0.221794] kvm [1]: VHE mode initialized successfully
[    0.224939] Initialise system trusted keyrings
[    0.225057] workingset: timestamp_bits=42 max_order=23 bucket_order=0
[    0.228872] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.229367] NFS: Registering the id_resolver key type
[    0.229407] Key type id_resolver registered
[    0.229409] Key type id_legacy registered
[    0.229463] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.229478] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.229507] ntfs: driver 2.1.32 [Flags: R/O].
[    0.229731] 9p: Installing v9fs 9p2000 file system support
[    0.241567] Key type asymmetric registered
[    0.241576] Asymmetric key parser 'x509' registered
[    0.241654] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.241665] io scheduler mq-deadline registered
[    0.241675] io scheduler kyber registered
[    0.252566] EINJ: ACPI disabled.
[    0.264392] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.266242] SuperH (H)SCI(F) driver initialized
[    0.266588] msm_serial: driver initialized
[    0.267189] printk: console [ttyTCU0] enabled
[    0.268087] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.268094] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.268102] arm-smmu 8000000.iommu:  stage 1 translation
[    0.268107] arm-smmu 8000000.iommu:  stage 2 translation
[    0.268111] arm-smmu 8000000.iommu:  nested translation
[    0.268117] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    0.268124] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    0.268138] arm-smmu 8000000.iommu:  Supported page sizes: 0x61311000
[    0.268142] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    0.268146] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    0.269136] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.269141] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.269144] arm-smmu 10000000.iommu:         stage 1 translation
[    0.269146] arm-smmu 10000000.iommu:         stage 2 translation
[    0.269148] arm-smmu 10000000.iommu:         nested translation
[    0.269151] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    0.269153] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    0.269160] arm-smmu 10000000.iommu:         Supported page sizes: 0x61311000
[    0.269161] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.269164] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.269521] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.269524] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.269526] arm-smmu 12000000.iommu:         stage 1 translation
[    0.269526] arm-smmu 12000000.iommu:         stage 2 translation
[    0.269527] arm-smmu 12000000.iommu:         nested translation
[    0.269531] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    0.269533] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    0.269537] arm-smmu 12000000.iommu:         Supported page sizes: 0x61311000
[    0.269538] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.269539] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.279861] loop: module loaded
[    0.280773] megasas: 07.717.02.00-rc1
[    0.285032] tun: Universal TUN/TAP device driver, 1.6
[    0.285632] thunder_xcv, ver 1.0
[    0.285659] thunder_bgx, ver 1.0
[    0.285689] nicpf, ver 1.0
[    0.286508] hclge is initializing
[    0.286542] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.286550] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.286594] e1000: Intel(R) PRO/1000 Network Driver
[    0.286600] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.286628] e1000e: Intel(R) PRO/1000 Network Driver
[    0.286634] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.286653] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.286660] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.286678] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.286684] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.286893] sky2: driver version 1.30
[    0.287563] VFIO - User Level meta-driver version: 0.3
[    0.289030] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.289043] ehci-pci: EHCI PCI platform driver
[    0.289069] ehci-platform: EHCI generic platform driver
[    0.289141] ehci-orion: EHCI orion driver
[    0.289204] ehci-exynos: EHCI Exynos driver
[    0.289265] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.289288] ohci-pci: OHCI PCI platform driver
[    0.289311] ohci-platform: OHCI generic platform driver
[    0.289400] ohci-exynos: OHCI Exynos driver
[    0.289839] usbcore: registered new interface driver usb-storage
[    0.291676] rtc-efi rtc-efi.0: registered as rtc0
[    0.291718] rtc-efi rtc-efi.0: setting system clock to 1970-01-01T00:05:57 UTC (357)
[    0.292170] i2c_dev: i2c /dev entries driver
[    0.293488] pps pps0: new PPS source ktimer
[    0.293499] pps pps0: ktimer PPS source registered
[    0.293510] pps_ldisc: PPS line discipline registered
[    0.295655] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.297767] sdhci: Secure Digital Host Controller Interface driver
[    0.297773] sdhci: Copyright(c) Pierre Ossman
[    0.298202] Synopsys Designware Multimedia Card Interface Driver
[    0.298779] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.299951] ledtrig-cpu: registered to indicate activity on CPUs
[    0.300805] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.301315] tegra-bpmp bpmp: Adding to iommu group 0
[    0.302682] tegra-bpmp bpmp: firmware: 2aafe334513692db071c-3b0e1a33cf8
[    0.603598] Freeing initrd memory: 29244K
[    3.864969] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    3.864989] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    3.864992] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    3.865179] hid: raw HID events driver (C) Jiri Kosina
[    3.865541] usbcore: registered new interface driver usbhid
[    3.865549] usbhid: USB HID core driver
[    3.870468] optee: probing for conduit method.
[    3.870520] optee: revision 3.22 (e7b5ff3f)
[    3.929881] optee: dynamic shared memory is enabled
[    3.930138] optee: initialized driver
[    3.932752] usbcore: registered new interface driver snd-usb-audio
[    3.934431] NET: Registered PF_PACKET protocol family
[    3.934648] 9pnet: Installing 9P2000 support
[    3.934758] Key type dns_resolver registered
[    3.936112] printk: console [ttyTCU0]: printing thread started
[    3.936175] Loading compiled-in X.509 certificates
[    3.947235] Loaded X.509 cert 'Build time autogenerated kernel key: dbaa37291f9eb1704a33bc5cf19ca9266fdea8e6'
[    3.976743] gpio-394 (camera-control-output-low): hogged as output/low
[    3.976771] gpio-397 (camera-control-output-low): hogged as output/low
[    3.976790] gpio-487 (camera-control-output-low): hogged as output/low
[    3.976806] gpio-486 (camera-control-output-low): hogged as output/low
[    3.982428] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    3.984947] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    3.987578] serial-tegra 3100000.serial: RX in PIO mode
[    3.987583] serial-tegra 3100000.serial: TX in PIO mode
[    3.987711] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    3.989539] serial-tegra 3110000.serial: RX in PIO mode
[    3.989544] serial-tegra 3110000.serial: TX in PIO mode
[    3.989645] 3110000.serial: ttyTHS2 at MMIO 0x3110000 (irq = 208, base_baud = 0) is a TEGRA_UART
[    3.993850] tegra_rtc c2a0000.rtc: registered as rtc1
[    3.993871] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.994494] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    4.002780] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    4.008590] tegra-i2c 3190000.i2c: Adding to iommu group 1
[    4.014738] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    4.020275] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[    4.026363] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[    4.033861] tegra-i2c c240000.i2c: Adding to iommu group 1
[    4.039270] tegra-i2c c250000.i2c: Adding to iommu group 1
[    4.070394] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[    4.073728] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2007000 KHz, changing to: 2035200 KHz
[    4.076927] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[    4.079903] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[    4.080985] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[    4.082195] irq: IRQ235: trimming hierarchy from :bus@0:pmc@c360000
[    4.082254] irq: IRQ236: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    4.082299] irq: IRQ237: trimming hierarchy from :bus@0:pmc@c360000
[    4.082352] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    4.571538] ALSA device list:
[    4.571542]   No soundcards found.
[    4.575645] sdhci-tegra 3400000.mmc: Got CD GPIO
[    4.582350] mmc0: CQHCI version 5.10
[    4.617569] mmc0: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[    4.622696] irq: IRQ238: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    4.623188] mmc1: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[    4.624102] Freeing unused kernel memory: 7680K
[    4.624207] Run /init as init process
[    4.640079] Root device found: initrd
[    4.654608] r8168: loading out-of-tree module taints kernel.
[    4.656993] Mount initrd as rootfs and enter recovery mode
[    4.697279] tegra194-pcie 14100000.pcie: Adding to iommu group 4
[    4.699712] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    4.699727] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    4.699732] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    4.699735] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    4.700029] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    4.700031] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    4.727997] mmc0: Command Queue Engine enabled
[    4.728006] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    4.728239] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[    4.732507]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    4.732934] mmcblk0boot0: mmc0:0001 G1M15M 31.5 MiB
[    4.733342] mmcblk0boot1: mmc0:0001 G1M15M 31.5 MiB
[    4.733723] mmcblk0rpmb: mmc0:0001 G1M15M 4.00 MiB, chardev (511:0)
[    4.807761] tegra194-pcie 14100000.pcie: Link up
[    4.811532] tegra194-pcie 14100000.pcie: Link up
[    4.811585] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    4.811589] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    4.811592] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    4.811595] pci_bus 0001:00: root bus resource [bus 00-ff]
[    4.811596] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    4.811647] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    4.811821] pci 0001:00:00.0: PME# supported from D0 D3hot
[    4.815418] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    4.815589] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    4.815798] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    4.816850] pci 0001:01:00.0: supports D1 D2
[    4.816852] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    4.830690] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    4.830693] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    4.830696] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    4.830798] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    4.830828] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    4.830832] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    4.830836] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    4.830921] pcieport 0001:00:00.0: Adding to iommu group 4
[    4.831012] pcieport 0001:00:00.0: PME: Signaling with IRQ 202
[    4.831577] pcieport 0001:00:00.0: AER: enabled with IRQ 202
[    4.831895] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[    4.835710] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    4.835727] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    4.835733] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    4.835736] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    4.836416] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    4.836419] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    4.943983] tegra194-pcie 14160000.pcie: Link up
[    4.954286] tegra194-pcie 14160000.pcie: Link up
[    4.954328] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    4.954331] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    4.954334] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    4.954336] pci_bus 0004:00: root bus resource [bus 00-ff]
[    4.954337] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    4.954375] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    4.954513] pci 0004:00:00.0: PME# supported from D0 D3hot
[    4.957677] pci 0004:01:00.0: [144d:a80c] type 00 class 0x010802
[    4.957857] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    4.974564] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    4.974568] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    4.974647] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    4.974651] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    4.974723] pcieport 0004:00:00.0: Adding to iommu group 5
[    4.974791] pcieport 0004:00:00.0: PME: Signaling with IRQ 204
[    4.975810] pcieport 0004:00:00.0: AER: enabled with IRQ 204
[    4.976055] tegra194-pcie 141a0000.pcie: Adding to iommu group 6
[    5.085303] tegra194-pcie 141a0000.pcie: host bridge /bus@0/pcie@141a0000 ranges:
[    5.085322] tegra194-pcie 141a0000.pcie:      MEM 0x2800000000..0x2b27ffffff -> 0x2800000000
[    5.085329] tegra194-pcie 141a0000.pcie:      MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[    5.085334] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    5.085867] tegra194-pcie 141a0000.pcie: iATU unroll: enabled
[    5.085871] tegra194-pcie 141a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    6.193354] tegra194-pcie 141a0000.pcie: Phy link never came up
[    7.194646] tegra194-pcie 141a0000.pcie: Phy link never came up
[    7.194687] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[    7.194690] pci_bus 0005:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[    7.194692] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[    7.194694] pci_bus 0005:00: root bus resource [bus 00-ff]
[    7.194695] pci_bus 0005:00: root bus resource [mem 0x2800000000-0x2b27ffffff pref]
[    7.194737] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[    7.194890] pci 0005:00:00.0: PME# supported from D0 D3hot
[    7.200546] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    7.200624] pcieport 0005:00:00.0: Adding to iommu group 6
[    7.200696] pcieport 0005:00:00.0: PME: Signaling with IRQ 206
[    7.201113] pcieport 0005:00:00.0: AER: enabled with IRQ 206
[    7.201327] pci_bus 0005:01: busn_res: [bus 01-ff] is released
     7.201394] pci 0005:00:00.0: Removing from iommu ginsroup 6ib/mod  7s/51401] pci.136-t005a/k:00: busndrivers: s/nvme/ho0-ff] is released
insmod /lib/modules/5.15.136-tegra/kernel/drivers/nvme/host/nvme.ko
[    7.211404] nvme 0004:01:00.0: Adding to iommu group 5
[    7.211692] nvme nvme0: pci function 0004:01:00.0
[    7.211746] nvme 0mod004ib/:01:00.0:.15abl.13ing6-tegrvice (ernel/0 -ver002s/t)
hermal[  .21gra507gra7] e nmp-0: rmaShuwn o timeout set to 10 seconds
[    7.217065] nvme nvme0: 12/0/0 default/read/poll queue /lib/  7ules/5.15.21.136-t8810] egra/kern nvme0el/n1:drivers/pwm/pwm-tegra.ko
insmod /lib/modules/5.15.136-tegra/kernel/drivers/hwmon/pwm-fan.ko
insmod /lib/modules/5.15.136-tegra/kernel/drivers/usb/gadget/libcomposite.ko
insmod /lib/modules/5.15.136-tegra/kernel/drivers/usb/typec/typec.ko
insmod /lib/modules/5.15.136-tegra/kernel/drivers/usb/typec/ucsi/typec_ucsi.ko
insmod /lib/modules/5.15.136-tegra/kernel/drivers/usb/typec/ucsi/ucsi_ccg.ko
[    7.280055] irq: IRQ252: trimming hierarchy from :bus@0:pmc@c360000
insmod /lib/modules/5.15.136-tegra/kernel/drivers/usb/gadget/udc/tegra-xudc.ko
[    7.315188] tegra-xusb 3610000.usb: Adding to iommu group 7
insmod /lib/modules/5.15.136-tegra/kernel/net/ipv6/ipv6.ko
[    7.317125] tegra-xudc 3550000.usb: Adding to iommu group 8
insmod /lib/modules/5.15.136-tegra/updates/drivers/nvpps/nvpps.ko
[    7.327783] NET: Registered PF_INET6 protocol family
[    7.328275] Seginsment Routing with IPv6
[    7pdates/drivesitu O/ethernet with idi6
vethernet/nv  7ern0422] teg
ra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[    7.330430] tegra-xusb 3610000.usb: xHCI Host Controller
[    7.330442] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[    7.331163] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[    7.331183] tegra-xusb 3610000.usb: irq 128, io mem 0x03610000
[    7.331297] tegra-xusb 3610000.usb: xHCI Host Controller
[    7.331300] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[    7.331303] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    7.331521] hub 1-0:1.0: USB hub found
[    7.331534] hub 1-0:1.0: 4 ports detected
[    7.331767] nvpps c6a0000.nvpps: nvpps_probe
[    7.331826] nvpps c6a0000.nvpps: primary-emac found ethernet@6800000
[    7.331833] hub 2-0:1.0: USB hub found
[    7.331836] nvpps c6a0000.nvpps: primary emac base address 0x6810000
[    7.331839] nvpps c6a0000.nvpps: using ptp notifier method on emac ethernet@6800000
[    7.331840] nvpps c6a0000.nvpps: tsc_res_ns(32)
[    7.331844] hub 2-0:1.0: 4 ports detected
[    7.331848] nvpps c6a0000.nvpps: PPS GPIO not provided in DT, only Timer mode available
[    7.331890] nvpps c6a0000.nvpps: nvpps cdev(507:0)
[    7.331909] nvpps c6a0000.nvpps: TSC config ptx 0x113
[    7.336926] nvethernet 6800000.ethernet: Adding to iommu group 9
[    7.337188] nvethernet 6800000.ethernet: failed to read skip mac reset flag, default 0
[    7.337192] nvethernet 6800000.ethernet: setting to default DMA bit mask
[    7.337199] nvethernet 6800000.ethernet: failed to read UPHY GBE mode- default to 10G
[    7.663884] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[    7.720815] nvethernet 6800000.ethernet: Ethernet MAC address: 48:b0:2d:93:bf:bf
[    7.721549] nvethernet 6800000.ethernet: Macsec not enabled
[    7.721550] nvethernet 6800000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[    7.723031] nvethernet 6800000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
insmod /lib/modules/5.15.136-tegra/kernel/drivers/usb/typec/stusb160x.ko
insmod /lib/modules/5.15.136-tegra/updates/drivers/platform/tegra/mce/tegra-mce.ko
insmod /lib/modules/5.15.136-tegra/updates/drivers/spi/spi-tegra210-quad.ko
[    7.733870] tegra-qspi 3270000.spi: Adding to iommu group 10
[    7.735549] spi-nor spi0.0: mx25u51279g (65536 Kbytes)
[    7.944737] usb 2-3: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[    7.992739] hub 2-3:1.0: USB hub found
[    7.994983] hub 2-3:1.0: 4 ports detected
[    8.099745] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[    8.269026] hub 1-4:1.0: USB hub found
[    8.270221] hub 1-4:1.0: 4 ports detected
[    8.752191] using random self ethernet address
[    8.752197] using random host ethernet address
[    8.780184] usb0: HOST MAC 3e:cf:c8:34:e9:57
[    8.780190] usb0: MAC 1a:2a:de:fb:fd:15
[    8.780202] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.1# [    9.307188] tegra-xudc 3550000.usb: EP 5 (type: intr, dir: in) enabled
[    9.307208] tegra-xudc 3550000.usb: EP 3 (type: bulk, dir: in) enabled
[    9.307220] tegra-xudc 3550000.usb: EP 2 (type: bulk, dir: out) enabled
[    9.307309] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[   22.439306] tegra-xudc 3550000.usb: ep 3 disabled
[   22.439331] tegra-xudc 3550000.usb: ep 2 disabled
[   22.439344] tegra-xudc 3550000.usb: ep 5 disabled
[   22.666427] tegra-xudc 3550000.usb: EP 5 (type: intr, dir: in) enabled
[   22.666444] tegra-xudc 3550000.usb: EP 3 (type: bulk, dir: in) enabled
[   22.666455] tegra-xudc 3550000.usb: EP 2 (type: bulk, dir: out) enabled
[  203.744066] nfs: server fc00:1:1:0::1 not responding, still trying
[  203.744234] nfs: server fc00:1:1:0::1 not responding, still trying
[  263.136059] nfs: server fc00:1:1:0::1 not responding, timed out
[  443.360054] nfs: server fc00:1:1:0::1 not responding, timed out
[  448.480082] nfs: server fc00:1:1:0::1 not responding, timed out
Edit: So I was able to install it on the NVME SSD by plugging the ssd into the motherboard of the host computer and running the following command: sudo BOARDID=3701 BOARDSKU=0000 FAB=TS4 ./tools/kernel_flash/l4t_initrd_flash.sh -c tools/kernel_flash/flash_l4t_external.xml --external-device nvme0n1 --direct nvme0n1 jetson-agx-orin-devkit external
We are able to flash by below command.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml \
  --showlogs --network usb0 jetson-agx-orin-devkit external
What is causing it to fail when I try to flash it using the SDK manager?
