I have connected a serial console to the development kit and captured output as per below. The connected monitor blanks out after initial boot screen.
I created a 64GB SD card with latest download and system is trying to boot from it.
L4TLauncher: Attempting Recovery Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
��I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
��Failed to create /rm/vdd_cpu
debugfs initialized
��[ 0.000000] Booting Linux on physical CPU 0x0000010200 [0x410fd421]
[ 0.000000] Linux version 5.15.136-tegra (buildbrain@mobile-u64-6269-d7000) (aarch64-buildroot-lin)
[ 0.000000] Machine model: NVIDIA Jetson Orin Nano Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x20b5bd598 SMBIOS=0xffff0000 SMBIOS 3.0=0x20a530000 MEMATTR=0x20a9b8018 E
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x000000020a9b9418 to 0x000000020a9b9450.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000021d000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000237ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x230d63800-0x230d65fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000237ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000207e7afff]
[ 0.000000] node 0: [mem 0x0000000207e7b000-0x000000020a1bffff]
[ 0.000000] node 0: [mem 0x000000020a1c0000-0x000000020a51ffff]
[ 0.000000] node 0: [mem 0x000000020a520000-0x000000020a53ffff]
[ 0.000000] node 0: [mem 0x000000020a540000-0x000000020a77ffff]
[ 0.000000] node 0: [mem 0x000000020a780000-0x000000020a7cffff]
[ 0.000000] node 0: [mem 0x000000020a7d0000-0x000000020a8bffff]
[ 0.000000] node 0: [mem 0x000000020a8c0000-0x000000020a90ffff]
[ 0.000000] node 0: [mem 0x000000020a910000-0x000000020a95ffff]
[ 0.000000] node 0: [mem 0x000000020a960000-0x000000020a9affff]
[ 0.000000] node 0: [mem 0x000000020a9b0000-0x000000020aaeffff]
[ 0.000000] node 0: [mem 0x000000020aaf0000-0x000000020afeffff]
[ 0.000000] node 0: [mem 0x000000020aff0000-0x000000020b57ffff]
[ 0.000000] node 0: [mem 0x000000020b580000-0x000000020b58ffff]
[ 0.000000] node 0: [mem 0x000000020b590000-0x000000020b6affff]
[ 0.000000] node 0: [mem 0x000000020b6b0000-0x000000020b74ffff]
[ 0.000000] node 0: [mem 0x000000020b750000-0x000000020b84ffff]
[ 0.000000] node 0: [mem 0x000000020b850000-0x000000020b8effff]
[ 0.000000] node 0: [mem 0x000000020b8f0000-0x000000020b9effff]
[ 0.000000] node 0: [mem 0x000000020b9f0000-0x000000020ba8ffff]
[ 0.000000] node 0: [mem 0x000000020ba90000-0x000000020c35ffff]
[ 0.000000] node 0: [mem 0x000000020c360000-0x000000020c53ffff]
[ 0.000000] node 0: [mem 0x000000020c540000-0x000000022dceffff]
[ 0.000000] node 0: [mem 0x000000022dcf0000-0x000000022dd3ffff]
[ 0.000000] node 0: [mem 0x000000022dd40000-0x00000002317fffff]
[ 0.000000] node 0: [mem 0x0000000231a00000-0x0000000231e0ffff]
[ 0.000000] node 0: [mem 0x0000000236000000-0x0000000237ffffff]
[ 0.000000] Initmem sins /lib/odeule[mem 0x00000.136-t000egr800a/u000pda00-tes/dr000000237/etherff0
0] On node 0, zone Normal: 512 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16880 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1756688
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,11
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 6531916K/7139392K available (19712K kernel code, 4056K rwdata, 9968K rodata, 7)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 10200 region 0:0x000000000f500000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idls
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000347] Console: colour dummy device 80x25
[ 0.000410] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoM)
[ 0.000417] pid_max: default: 32768 minimum: 301
[ 0.000455] LSM: Security Framework initializing
[ 0.000480] Yama: becoming mindful.
[ 0.000497] SELinux: Initializing.
[ 0.000576] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000590] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001240] /cpus/cpu-map: empty cluster
[ 0.001564] rcu: Hierarchical SRCU implementation.
[ 0.003574] Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[ 0.003820] Remapping and enabling EFI services.
[ 0.005005] smp: Bringing up secondary CPUs …
[ 0.033713] Detected PIPT I-cache on CPU1
[ 0.033758] GICv3: CPU1: found redistributor 10300 region 0:0x000000000f520000
[ 0.033785] CPU1: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.064511] Detected PIPT I-cache on CPU2
[ 0.064542] GICv3: CPU2: found redistributor 20000 region 0:0x000000000f540000
[ 0.064572] CPU2: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.093283] Detected PIPT I-cache on CPU3
[ 0.093297] GICv3: CPU3: found redistributor 20100 region 0:0x000000000f560000
[ 0.093313] CPU3: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.122603] Detected PIPT I-cache on CPU4
[ 0.122617] GICv3: CPU4: found redistributor 20200 region 0:0x000000000f580000
[ 0.122632] CPU4: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.151921] Detected PIPT I-cache on CPU5
[ 0.151935] GICv3: CPU5: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.151951] CPU5: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.152013] smp: Brought up 1 node, 6 CPUs
[ 0.152018] SMP: Total of 6 processors activated.
[ 0.152022] CPU features: detected: 32-bit EL0 Support
[ 0.152023] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.152026] CPU features: detected: Common not Private translations
[ 0.152027] CPU features: detected: CRC32 instructions
[ 0.152028] CPU features: detected: Data cache clean to Point of Persistence
[ 0.152030] CPU features: detected: Generic authentication (architected algorithm)
[ 0.152031] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.152032] CPU features: detected: LSE atomic instructions
[ 0.152033] CPU features: detected: Privileged Access Never
[ 0.152034] CPU features: detected: RAS Extension Support
[ 0.152037] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.182228] CPU: All CPU(s) started at EL2
[ 0.183616] devtmpfs: initialized
[ 0.195083] KASLR enabled
[ 0.195168] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785s
[ 0.195182] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.197344] pinctrl core: initialized pinctrl subsystem
[ 0.197901] SMBIOS 3.0.0 present.
[ 0.197910] DMI: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 3.0-326163
[ 0.198194] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.199453] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.199529] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.199586] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.199614] audit: initializing netlink subsys (disabled)
[ 0.199690] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1
[ 0.200654] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.200657] thermal_sys: Registered thermal governor ‘user_space’
[ 0.200658] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.202592] cpuidle: using governor menu
[ 0.202704] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.202781] ASID allocator initialised with 32768 entries
[ 0.203902] Serial: AMBA PL011 UART driver
[ 0.212864] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[ 0.222200] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.229868] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.229872] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.229873] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.229875] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.230495] cryptd: max_cpu_qlen set to 1000
[ 0.231710] ACPI: Interpreter disabled.
[ 0.232682] VDD_1V8_AO: supplied by VDD_5V0_SYS
[ 0.232785] VDD_3V3_AO: supplied by VDD_5V0_SYS
[ 0.233005] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[ 0.233289] iommu: Default domain type: Translated
[ 0.233292] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.233485] SCSI subsystem initialized
[ 0.233621] vgaarb: loaded
[ 0.233720] usbcore: registered new interface driver usbfs
[ 0.233736] usbcore: registered new interface driver hub
[ 0.233747] usbcore: registered new device driver usb
[ 0.234104] pps_core: LinuxPPS API ver. 1 registered
[ 0.234107] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.i
[ 0.234112] PTP clock support registered
[ 0.234166] EDAC MC: Ver: 3.0.0
[ 0.234767] Registered efivars operations
[ 0.235217] FPGA manager framework
[ 0.235269] Advanced Linux Sound Architecture Driver Initialized.
[ 0.235767] clocksource: Switched to clocksource arch_sys_counter
[ 0.255176] VFS: Disk quotas dquot_6.6.0
[ 0.255213] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.255319] pnp: PnP ACPI: disabled
[ 0.257490] NET: Registered PF_INET protocol family
[ 0.257617] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.259099] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.259129] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.259136] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.259207] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.259715] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.259812] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.259837] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.259938] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.260155] RPC: Registered named UNIX socket transport module.
[ 0.260158] RPC: Registered udp transport module.
[ 0.260159] RPC: Registered tcp transport module.
[ 0.260160] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.260166] PCI: CLS 0 bytes, default 64
[ 0.260322] Unpacking initramfs…
[ 0.260839] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.260969] kvm [1]: IPA Size Limit: 48 bits
[ 0.260987] kvm [1]: GICv3: no GICV resource entry
[ 0.260991] kvm [1]: disabling GICv2 emulation
[ 0.261004] kvm [1]: GIC system register CPU interface enabled
[ 0.261073] kvm [1]: vgic interrupt IRQ9
[ 0.261177] kvm [1]: VHE mode initialized successfully
[ 0.263200] Initialise system trusted keyrings
[ 0.263289] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[ 0.265600] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.265851] NFS: Registering the id_resolver key type
[ 0.265868] Key type id_resolver registered
[ 0.265870] Key type id_legacy registered
[ 0.265898] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.265906] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.265921] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.266053] 9p: Installing v9fs 9p2000 file system support
[ 0.281257] Key type asymmetric registered
[ 0.281260] Asymmetric key parser ‘x509’ registered
[ 0.281297] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.281301] io scheduler mq-deadline registered
[ 0.281305] io scheduler kyber registered
[ 0.288839] EINJ: ACPI disabled.
[ 0.297681] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.298851] SuperH (H)SCI(F) driver initialized
[ 0.299125] msm_serial: driver initialized
[ 0.299552] printk: console [ttyTCU0] enabled
[ 0.300286] arm-smmu 8000000.iommu: probing hardware configuration…
[ 0.300290] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.300294] arm-smmu 8000000.iommu: stage 1 translation
[ 0.300296] arm-smmu 8000000.iommu: stage 2 translation
[ 0.300297] arm-smmu 8000000.iommu: nested translation
[ 0.300300] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.300303] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.300315] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.300317] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.300319] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.301119] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.301121] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.301124] arm-smmu 10000000.iommu: stage 1 translation
[ 0.301124] arm-smmu 10000000.iommu: stage 2 translation
[ 0.301125] arm-smmu 10000000.iommu: nested translation
[ 0.301127] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.301129] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.301132] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.301134] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.301135] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.301492] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.301494] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.301495] arm-smmu 12000000.iommu: stage 1 translation
[ 0.301496] arm-smmu 12000000.iommu: stage 2 translation
[ 0.301497] arm-smmu 12000000.iommu: nested translation
[ 0.301499] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.301501] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.301504] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.301505] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.301507] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.305913] loop: module loaded
[ 0.306411] megasas: 07.717.02.00-rc1
[ 0.309289] tun: Universal TUN/TAP device driver, 1.6
[ 0.309738] thunder_xcv, ver 1.0
[ 0.309754] thunder_bgx, ver 1.0
[ 0.309767] nicpf, ver 1.0
[ 0.310402] hclge is initializing
[ 0.310416] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.310419] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.310440] e1000: Intel(R) PRO/1000 Network Driver
[ 0.310443] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.310457] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.310459] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.310474] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.310477] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.310487] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.310490] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.310648] sky2: driver version 1.30
[ 0.311187] VFIO - User Level meta-driver version: 0.3
[ 0.312275] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.312280] ehci-pci: EHCI PCI platform driver
[ 0.312297] ehci-platform: EHCI generic platform driver
[ 0.312356] ehci-orion: EHCI orion driver
[ 0.312411] ehci-exynos: EHCI Exynos driver
[ 0.312453] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.312463] ohci-pci: OHCI PCI platform driver
[ 0.312478] ohci-platform: OHCI generic platform driver
[ 0.312539] ohci-exynos: OHCI Exynos driver
[ 0.312879] usbcore: registered new interface driver usb-storage
[ 0.314270] i2c_dev: i2c /dev entries driver
[ 0.315321] pps pps0: new PPS source ktimer
[ 0.315327] pps pps0: ktimer PPS source registered
[ 0.315331] pps_ldisc: PPS line discipline registered
[ 0.316975] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.318073] sdhci: Secure Digital Host Controller Interface driver
[ 0.318076] sdhci: Copyright(c) Pierre Ossman
[ 0.318448] Synopsys Designware Multimedia Card Interface Driver
[ 0.318948] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.319881] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.320473] efifb: probing for efifb
[ 0.320514] efifb: framebuffer at 0x208000000, using 34560k, total 34560k
[ 0.320518] efifb: mode is 3840x2160x32, linelength=16384, pages=1
[ 0.320520] efifb: scrolling: redraw
[ 0.320521] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.335130] Console: switching to colour frame buffer device 480x135
[ 0.349468] fb0: EFI VGA frame buffer device
[ 0.349852] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 0.350115] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.350919] tegra-bpmp bpmp: firmware: f0fadc45ec6216cb5b0b-1377b684fe5
[ 0.551350] Freeing initrd memory: 16428K
[ 1.423312] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 8815904s
[ 1.423327] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 1.423331] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275s
[ 1.423433] hid: raw HID events driver (C) Jiri Kosina
[ 1.423656] usbcore: registered new interface driver usbhid
[ 1.423659] usbhid: USB HID core driver
[ 1.425306] tegra186-emc 2c60000.external-memory-controller: MRQ_BWMGR_INT not present
[ 1.427845] usbcore: registered new interface driver snd-usb-audio
[ 1.428530] NET: Registered PF_PACKET protocol family
[ 1.428647] 9pnet: Installing 9P2000 support
[ 1.428695] Key type dns_resolver registered
[ 1.429260] printk: console [ttyTCU0]: printing thread started
[ 1.429329] Loading compiled-in X.509 certificates
[ 1.436976] Loaded X.509 cert ‘Build time autogenerated kernel key: f3d26e9f064832ca792e15e33f60cd’
[ 1.453663] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 1.454603] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 1.455412] serial-tegra 3100000.serial: RX in PIO mode
[ 1.455415] serial-tegra 3100000.serial: TX in PIO mode
[ 1.455448] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 1.455789] serial-tegra 3140000.serial: RX in PIO mode
[ 1.455792] serial-tegra 3140000.serial: TX in PIO mode
[ 1.455814] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[ 1.456915] tegra_rtc c2a0000.rtc: registered as rtc1
[ 1.456921] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.457207] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 1.459670] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 1.461533] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 1.463635] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 1.468047] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[ 1.468481] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 1.476637] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1544000 KHz, chaz
[ 1.479327] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1540000 KHz, chaz
[ 1.485059] tegra-xusb 3610000.usb: Adding to iommu group 2
[ 1.503239] tegra-xusb 3610000.usb: Firmware timestamp: 2021-12-01 05:27:10 UTC
[ 1.503256] tegra-xusb 3610000.usb: xHCI Host Controller
[ 1.503285] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 1.504052] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x00000000000100
[ 1.504088] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[ 1.504251] tegra-xusb 3610000.usb: xHCI Host Controller
[ 1.504257] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 1.504262] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.504865] hub 1-0:1.0: USB hub found
[ 1.504886] hub 1-0:1.0: 4 ports detected
[ 1.505223] hub 2-0:1.0: USB hub found
[ 1.505236] hub 2-0:1.0: 4 ports detected
[ 1.506593] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 1.507339] irq: IRQ222: trimming hierarchy from :bus@0:pmc@c360000
[ 1.507421] irq: IRQ223: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 1.507485] irq: IRQ224: trimming hierarchy from :bus@0:pmc@c360000
[ 1.507579] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 1.508528] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 1.569513] ALSA device list:
[ 1.569519] No soundcards found.
[ 1.615282] irq: IRQ225: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 1.616304] mmc0: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 1.617892] Freeing unused kernel memory: 7680K
[ 1.617989] Run /init as init process
[ 1.643284] Root device found: initrd
[ 1.659292] r8168: loading out-of-tree module taints kernel.
[ 1.661800] Mount initrd as rootfs and enter recovery mode
[ 1.955811] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.206660] hub 1-2:1.0: USB hub found
[ 2.208060] hub 1-2:1.0: 4 ports detected
[ 3.984910] mmc0: Skipping voltage switch
[ 4.179713] mmc0: new high speed SDXC card at address 59b4
[ 4.180459] mmcblk0: mmc0:59b4 SD64G 59.4 GiB
[ 4.186827] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 25.195758] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 25.195764] rcu: 1-…!: (0 ticks this GP) idle=f9c/0/0x0 softirq=60/60 fqs=0 (false positive)
[ 25.195769] rcu: 2-…!: (330 ticks this GP) idle=832/0/0x0 softirq=88/90 fqs=0 (false positi)
[ 25.195773] rcu: 3-…!: (14 ticks this GP) idle=066/0/0x0 softirq=126/127 fqs=0 (false posit)
[ 25.195776] rcu: 4-…!: (1 GPs behind) idle=734/0/0x0 softirq=61/63 fqs=0 (false positive?)
[ 25.195779] rcu: 5-…!: (1 GPs behind) idle=48a/0/0x0 softirq=49/51 fqs=0 (false positive?)
[ 25.195782] (detected by 0, t=5252 jiffies, g=-987, q=7)
[ 25.195786] Task dump for CPU 1:
[ 25.195790] task:swapper/1 state:R running task stack: 0 pid: 0 ppid: 1 flags8
[ 25.195800] Call trace:
[ 25.195802] __switch_to+0x104/0x160
[ 25.195823] cpuidle_enter_state+0x1d0/0x3e0
[ 25.195838] cpuidle_enter+0x44/0x70
[ 25.195842] do_idle+0x228/0x2b0
[ 25.195849] cpu_startup_entry+0x30/0x70
[ 25.195852] secondary_start_kernel+0x14c/0x1a0
[ 25.195858] __secondary_switched+0x90/0x94
[ 25.195868] Task dump for CPU 2:
[ 25.195870] task:swapper/2 state:R running task stack: 0 pid: 0 ppid: 1 flags8
[ 25.195874] Call trace:
[ 25.195874] __switch_to+0x104/0x160
[ 25.195878] cpuidle_enter_state+0x1d0/0x3e0
[ 25.195881] cpuidle_enter+0x44/0x70
[ 25.195883] do_idle+0x228/0x2b0
[ 25.195886] cpu_startup_entry+0x34/0x70
[ 25.195889] secondary_start_kernel+0x14c/0x1a0
[ 25.195893] __secondary_switched+0x90/0x94
[ 25.195896] Task dump for CPU 3:
[ 25.195898] task:swapper/3 state:R running task stack: 0 pid: 0 ppid: 1 flags8
[ 25.195901] Call trace:
[ 25.195902] __switch_to+0x104/0x160
[ 25.195906] cpuidle_enter_state+0x1d0/0x3e0
[ 25.195909] cpuidle_enter+0x44/0x70
[ 25.195912] do_idle+0x228/0x2b0
[ 25.195915] cpu_startup_entry+0x34/0x70
[ 25.195917] secondary_start_kernel+0x14c/0x1a0
[ 25.195920] __secondary_switched+0x90/0x94
[ 25.195924] Task dump for CPU 4:
[ 25.195925] task:swapper/4 state:R running task stack: 0 pid: 0 ppid: 1 flags8
[ 25.195928] Call trace:
[ 25.195929] __switch_to+0x104/0x160
[ 25.195933] cpuidle_enter_state+0x1d0/0x3e0
[ 25.195936] cpuidle_enter+0x44/0x70
[ 25.195939] do_idle+0x228/0x2b0
[ 25.195941] cpu_startup_entry+0x34/0x70
[ 25.195944] secondary_start_kernel+0x14c/0x1a0
[ 25.195947] __secondary_switched+0x90/0x94
[ 25.195950] Task dump for CPU 5:
[ 25.195952] task:swapper/5 state:R running task stack: 0 pid: 0 ppid: 1 flags8
[ 25.195955] Call trace:
[ 25.195956] __switch_to+0x104/0x160
[ 25.195960] cpuidle_enter_state+0x1d0/0x3e0
[ 25.195962] cpuidle_enter+0x44/0x70
[ 25.195965] do_idle+0x228/0x2b0
[ 25.195967] cpu_startup_entry+0x34/0x70
[ 25.195970] secondary_start_kernel+0x14c/0x1a0
[ 25.195973] __secondary_switched+0x90/0x94
[ 25.195977] rcu: rcu_preempt kthread timer wakeup didn’t happen for 5251 jiffies! g-987 f0x0 RCU_G2
[ 25.195980] rcu: Possible timer handling issue on cpu=1 timer-softirq=50
[ 25.195982] rcu: rcu_preempt kthread starved for 5252 jiffies! g-987 f0x0 RCU_GP_WAIT_FQS(5) ->sta1
[ 25.195986] rcu: Unless rcu_preempt kthread gets sufficient CPU time, OOM is now expected beha.
[ 25.195987] rcu: RCU grace-period kthread stack dump:
[ 25.195988] task:rcu_preempt state:I stack: 0 pid: 15 ppid: 2 flags:0x00000008
[ 25.195991] Call trace:
[ 25.195991] __switch_to+0x104/0x160
[ 25.195994] __schedule+0x2e8/0x860
[ 25.196000] schedule+0x90/0x120
[ 25.196002] schedule_timeout+0xa4/0x1e0
[ 25.196005] rcu_gp_fqs_loop+0x140/0x510
[ 25.196011] rcu_gp_kthread+0x1ac/0x250
[ 25.196013] kthread+0x184/0x1a0
[ 25.196018] ret_from_fork+0x10/0x20
[ 25.196021] rcu: Stack dump where RCU GP kthread last ran:
[ 25.196022] Task dump for CPU 1:
[ 25.196022] task:swapper/1 state:R running task stack: 0 pid: 0 ppid: 1 flags8
[ 25.196025] Call trace:
[ 25.196025] __switch_to+0x104/0x160
[ 25.196028] cpuidle_enter_state+0x1d0/0x3e0
[ 25.196031] cpuidle_enter+0x44/0x70
[ 25.196033] do_idle+0x228/0x2b0
[ 25.196035] cpu_startup_entry+0x30/0x70
[ 25.196038] secondary_start_kernel+0x14c/0x1a0
[ 25.196041] __secondary_switched+0x90/0x94
[ 88.215758] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 88.215761] rcu: 1-…!: (0 ticks this GP) idle=1ca/0/0x0 softirq=60/60 fqs=1 (false positive)
[ 88.215764] (detected by 0, t=21007 jiffies, g=-987, q=7)
[ 88.215766] Task dump for CPU 1:
[ 88.215767] task:swapper/1 state:R running task stack: 0 pid: 0 ppid: 1 flags8
[ 88.215771] Call trace:
[ 88.215771] __switch_to+0x104/0x160
[ 88.215775] cpuidle_enter_state+0x1d0/0x3e0
[ 88.215779] cpuidle_enter+0x44/0x70
[ 88.215781] do_idle+0x228/0x2b0
[ 88.215784] cpu_startup_entry+0x34/0x70
[ 88.215786] secondary_start_kernel+0x14c/0x1a0
[ 88.215790] __secondary_switched+0x90/0x94
[ 88.215795] rcu: rcu_preempt kthread timer wakeup didn’t happen for 15754 jiffies! g-987 f0x0 RCU_2
[ 88.215797] rcu: Possible timer handling issue on cpu=1 timer-softirq=50
[ 88.215798] rcu: rcu_preempt kthread starved for 15755 jiffies! g-987 f0x0 RCU_GP_WAIT_FQS(5) ->st1
[ 88.215801] rcu: Unless rcu_preempt kthread gets sufficient CPU time, OOM is now expected beha.
[ 88.215802] rcu: RCU grace-period kthread stack dump:
[ 88.215803] task:rcu_preempt state:I stack: 0 pid: 15 ppid: 2 flags:0x00000008
[ 88.215805] Call trace:
[ 88.215805] __switch_to+0x104/0x160
[ 88.215809] __schedule+0x2e8/0x860
[ 88.215811] schedule+0x90/0x120
[ 88.215814] schedule_timeout+0xa4/0x1e0
[ 88.215817] rcu_gp_fqs_loop+0x140/0x510
[ 88.215820] rcu_gp_kthread+0x1ac/0x250
[ 88.215822] kthread+0x184/0x1a0
[ 88.215824] ret_from_fork+0x10/0x20
[ 88.215827] rcu: Stack dump where RCU GP kthread last ran:
[ 88.215828] Task dump for CPU 1:
[ 88.215828] task:swapper/1 state:R running task stack: 0 pid: 0 ppid: 1 flags8
[ 88.215831] Call trace:
[ 88.215832] __switch_to+0x104/0x160
[ 88.215835] cpuidle_enter_state+0x1d0/0x3e0
[ 88.215837] cpuidle_enter+0x44/0x70
[ 88.215840] do_idle+0x228/0x2b0
[ 88.215843] cpu_startup_entry+0x34/0x70
[ 88.215845] secondary_start_kernel+0x14c/0x1a0
[ 88.215848] __secondary_switched+0x90/0x94
