Failed to flash JetPack 6.1 on Jetson Orin Nano Custom board
Hello. I am trying to flash the new JetPack 6.1 image on a DSBOARD-ORNX carrier board.
I am following the instructions on this website DSBOARD-ORNX Overview and Connector Definitions but obviously I’m using the BSP for JetPack 6.1 (not mentioned in guide).
I’ve made it to the flashing step and ran this command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
The board fails to boot up again after pre-flashing setup occures and eventually the program times out waiting for it.
I hooked up a serial reader to the debug pins and got the following as the last output from the board’s debug:
  Jetson System firmware version 36.4.0-gcid-37537400 date 2024-09-13T04:02:39+00:
00
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
......EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
��debugfs initialized
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.148-tegra (ubuntu@ubuntu-desktop) (aarch64-buildroot-linux-)
[    0.000000] Machine model: Orin Nano 8GB for DSBOARD-ORNX-LAN
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: TPMFinalLog=0x22c5b0000 SMBIOS=0xffff0000 SMBIOS 3.0=0x23b3a0000 MEMATTR=
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000261000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000277ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x271302800-0x271304fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000277ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000bdffffff]
[    0.000000]   node   0: [mem 0x00000000c2000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000022c3cdfff]
[    0.000000]   node   0: [mem 0x000000022c3ce000-0x000000022c5bffff]
[    0.000000]   node   0: [mem 0x000000022c5c0000-0x0000000��WARNING: clock_disable: clk_powk
��22c5cafff]
[    0.000000]   node   0: [mem 0x000000022c5cb000-0x000000022c5cbfff]
[    0.000000]   node   0: [mem 0x000000022c5cc000-0x0000000239aaffff]
[    0.000000]   node   0: [mem 0x0000000239ab0000-0x000000023b9effff]
[    0.000000]   node   0: [mem 0x000000023b9f0000-0x0000000271dfffff]
[    0.000000]   node   0: [mem 0x0000000271e00000-0x0000000271ffffff]
[    0.000000]   node   0: [mem 0x0000000272000000-0x000000027259ffff]
[    0.000000]   node   0: [mem 0x0000000272f00000-0x0000000272ffffff]
[    0.000000]   node   0: [mem 0x0000000276000000-0x0000000277ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000277ffffff]
[    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algmod /lib/mod  0
erface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit manag_remot
        e_a  0ss0000] CPUena rem4
mod  0.000000] CPU features: detected: Spectre-BHB
   ules/5.15.14[  .008-tegra/kernel/CPUver fehy/tegra/ernel page tgra-p2u.ksolation forced ONR
[    0.000000] CPU features: detected: Kernel page modtabib/le modlatule (Ks/5.15)
.14  08-t000a/kalternernvers/p: pci/conhinernllecodr/dwc/[  pci.000] Buiegr1 za194.kliso  mo
ity grouping on.  Total pages: 2001056
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=tt
[    0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x271E10000 bl.
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 7489720K/8133248K available (19456K kernel code, 4064K rwdata, 10056K )
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046,s
[    0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000377] Console: colour dummy device 80x25
[    0.000438] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.)
[    0.000444] pid_max: default: 32768 minimum: 301
[    0.000482] LSM: Security Framework initializing
[    0.000507] Yama: becoming mindful.
[    0.000525] SELinux:  Initializing.
[    0.000606] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.000621] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.001723] rcu: Hierarchical SRCU implementation.
[    0.003856] Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[    0.004168] Remapping and enabling EFI services.
[    0.004973] smp: Bringing up secondary CPUs ...
[    0.005461] Detected PIPT I-cache on CPU1
[    0.005503] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.005534] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.005984] Detected PIPT I-cache on CPU2
[    0.005995] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.006010] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.006423] Detected PIPT I-cache on CPU3
[    0.006433] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.006446] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.008903] Detected PIPT I-cache on CPU4
[    0.008932] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[    0.008961] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.009459] Detected PIPT I-cache on CPU5
[    0.009472] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[    0.009487] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.009545] smp: Brought up 1 node, 6 CPUs
[    0.009549] SMP: Total of 6 processors activated.
[    0.009552] CPU features: detected: 32-bit EL0 Support
[    0.009554] CPU features: detected: Data cache clean to the PoU not required for I/D cohere
[    0.009556] CPU features: detected: Common not Private translations
[    0.009558] CPU features: detected: CRC32 instructions
[    0.009559] CPU features: detected: Data cache clean to Point of Persistence
[    0.009560] CPU features: detected: Generic authentication (architected algorithm)
[    0.009561] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.009562] CPU features: detected: LSE atomic instructions
[    0.009564] CPU features: detected: Privileged Access Never
[    0.009565] CPU features: detected: RAS Extension Support
[    0.009568] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.041326] CPU: All CPU(s) started at EL2
[    0.044061] devtmpfs: initialized
[    0.063804] KASLR enabled
[    0.063999] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76s
[    0.064029] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.069129] pinctrl core: initialized pinctrl subsystem
[    0.070152] SMBIOS 3.6.0 present.
[    0.070163] DMI: NVIDIA Orin Nano 8GB for DSBOARD-ORNX-LAN/Jetson, BIOS 36.4.0-gcid-3753744
[    0.070732] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.072568] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.072693] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.072782] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.072890] audit: initializing netlink subsys (disabled)
[    0.073044] audit: type=2000 audit(0.072:1): state=initialized audit_enabled=0 res=1
[    0.074953] thermal_sys: Registered thermal governor 'step_wise'
[    0.074956] thermal_sys: Registered thermal governor 'user_space'
[    0.074957] thermal_sys: Registered thermal governor 'power_allocator'
[    0.078825] cpuidle: using governor menu
[    0.079084] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.079178] ASID allocator initialised with 32768 entries
[    0.081322] Serial: AMBA PL011 UART driver
[    0.091950] tegra-mc 2c00000.memory-controller: unknown: write @0x00000000500604c0: Securi)
[    0.092864] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[    0.105487] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-contror
[    0.115666] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.115673] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.115675] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.115676] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.116655] cryptd: max_cpu_qlen set to 1000
[    0.118506] ACPI: Interpreter disabled.
[    0.119969] VDD_1V8_AO: supplied by VDD_5V0_SYS
[    0.120181] VDD_3V3_AO: supplied by VDD_5V0_SYS
[    0.120441] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[    0.120966] iommu: Default domain type: Translated
[    0.120974] iommu: DMA domain TLB invalidation policy: strict mode
[    0.121302] SCSI subsystem initialized
[    0.121545] vgaarb: loaded
[    0.121762] usbcore: registered new interface driver usbfs
[    0.121799] usbcore: registered new interface driver hub
[    0.121816] usbcore: registered new device driver usb
[    0.122275] pps_core: LinuxPPS API ver. 1 registered
[    0.122283] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti>
[    0.122297] PTP clock support registered
[    0.122401] EDAC MC: Ver: 3.0.0
[    0.123690] Registered efivars operations
[    0.124307] FPGA manager framework
[    0.124399] Advanced Linux Sound Architecture Driver Initialized.
[    0.124980] Bluetooth: Core ver 2.22
[    0.125014] NET: Registered PF_BLUETOOTH protocol family
[    0.125019] Bluetooth: HCI device and connection manager initialized
[    0.125029] Bluetooth: HCI socket layer initialized
[    0.125036] Bluetooth: L2CAP socket layer initialized
[    0.125052] Bluetooth: SCO socket layer initialized
[    0.125490] clocksource: Switched to clocksource arch_sys_counter
[    0.161038] VFS: Disk quotas dquot_6.6.0
[    0.161114] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.161356] pnp: PnP ACPI: disabled
[    0.164620] NET: Registered PF_INET protocol family
[    0.164941] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.166820] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, line)
[    0.166919] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.166931] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.167040] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.168392] TCP: Hash tables configured (established 65536 bind 65536)
[    0.168527] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.168559] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.168729] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.169153] RPC: Registered named UNIX socket transport module.
[    0.169158] RPC: Registered udp transport module.
[    0.169158] RPC: Registered tcp transport module.
[    0.169160] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.169175] PCI: CLS 0 bytes, default 64
[    0.169389] Unpacking initramfs...
[    0.178795] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.179151] kvm [1]: IPA Size Limit: 48 bits
[    0.179190] kvm [1]: GICv3: no GICV resource entry
[    0.179197] kvm [1]: disabling GICv2 emulation
[    0.179226] kvm [1]: GIC system register CPU interface enabled
[    0.179317] kvm [1]: vgic interrupt IRQ9
[    0.179500] kvm [1]: VHE mode initialized successfully
[    0.182695] Initialise system trusted keyrings
[    0.182738] Key type blacklist registered
[    0.182871] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[    0.186126] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.186550] NFS: Registering the id_resolver key type
[    0.186586] Key type id_resolver registered
[    0.186587] Key type id_legacy registered
[    0.186634] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.186651] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.186676] ntfs: driver 2.1.32 [Flags: R/O].
[    0.186920] 9p: Installing v9fs 9p2000 file system support
[    0.187573] integrity: Platform Keyring initialized
[    0.202431] Key type asymmetric registered
[    0.202440] Asymmetric key parser 'x509' registered
[    0.202521] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.202531] io scheduler mq-deadline registered
[    0.202539] io scheduler kyber registered
[    0.214232] EINJ: ACPI disabled.
[    0.226788] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.228684] SuperH (H)SCI(F) driver initialized
[    0.229068] msm_serial: driver initialized
[    0.229825] printk: console [ttyTCU0] enabled
[    0.230855] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.230862] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.230871] arm-smmu 8000000.iommu:  stage 1 translation
[    0.230876] arm-smmu 8000000.iommu:  stage 2 translation
[    0.230880] arm-smmu 8000000.iommu:  nested translation
[    0.230891] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    0.230896] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    0.230907] arm-smmu 8000000.iommu:  Supported page sizes: 0x61311000
[    0.230910] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    0.230912] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    0.231980] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.231984] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.231987] arm-smmu 10000000.iommu:         stage 1 translation
[    0.231990] arm-smmu 10000000.iommu:         stage 2 translation
[    0.231991] arm-smmu 10000000.iommu:         nested translation
[    0.231993] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    0.231998] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    0.232002] arm-smmu 10000000.iommu:         Supported page sizes: 0x61311000
[    0.232004] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.232006] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.232428] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.232433] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.232435] arm-smmu 12000000.iommu:         stage 1 translation
[    0.232436] arm-smmu 12000000.iommu:         stage 2 translation
[    0.232439] arm-smmu 12000000.iommu:         nested translation
[    0.232442] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    0.232444] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    0.232449] arm-smmu 12000000.iommu:         Supported page sizes: 0x61311000
[    0.232450] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.232452] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.240000] loop: module loaded
[    0.240995] megasas: 07.717.02.00-rc1
[    0.245545] tun: Universal TUN/TAP device driver, 1.6
[    0.246204] thunder_xcv, ver 1.0
[    0.246237] thunder_bgx, ver 1.0
[    0.246263] nicpf, ver 1.0
[    0.247188] hclge is initializing
[    0.247224] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.247230] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.247265] e1000: Intel(R) PRO/1000 Network Driver
[    0.247270] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.247307] e1000e: Intel(R) PRO/1000 Network Driver
[    0.247312] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.247337] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.247340] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.247356] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.247361] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.247599] sky2: driver version 1.30
[    0.248276] VFIO - User Level meta-driver version: 0.3
[    0.250036] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.250044] ehci-pci: EHCI PCI platform driver
[    0.250073] ehci-platform: EHCI generic platform driver
[    0.250162] ehci-orion: EHCI orion driver
[    0.250231] ehci-exynos: EHCI Exynos driver
[    0.250298] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.250325] ohci-pci: OHCI PCI platform driver
[    0.250352] ohci-platform: OHCI generic platform driver
[    0.250427] ohci-exynos: OHCI Exynos driver
[    0.250897] usbcore: registered new interface driver usb-storage
[    0.253102] i2c_dev: i2c /dev entries driver
[    0.254594] pps pps0: new PPS source ktimer
[    0.254606] pps pps0: ktimer PPS source registered
[    0.254614] pps_ldisc: PPS line discipline registered
[    0.256903] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.cm
[    0.258946] sdhci: Secure Digital Host Controller Interface driver
[    0.258951] sdhci: Copyright(c) Pierre Ossman
[    0.259460] Synopsys Designware Multimedia Card Interface Driver
[    0.260122] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.261366] ledtrig-cpu: registered to indicate activity on CPUs
[    0.262289] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.262796] tegra-bpmp bpmp: Adding to iommu group 0
[    0.264167] tegra-bpmp bpmp: firmware: e941463f35523d12ee54-da583751bbf
[    0.958270] Freeing initrd memory: 43840K
[    3.445881] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns:s
[    3.445918] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 497724s
[    3.445923] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112s
[    3.446215] hid: raw HID events driver (C) Jiri Kosina
[    3.446682] usbcore: registered new interface driver usbhid
[    3.446688] usbhid: USB HID core driver
[    3.452101] optee: probing for conduit method.
[    3.452161] optee: revision 4.2 (d78bc5fa)
[    3.511506] optee: dynamic shared memory is enabled
[    3.511786] optee: initialized driver
[    3.514707] usbcore: registered new interface driver snd-usb-audio
[    3.516495] NET: Registered PF_PACKET protocol family
[    3.517677] Bluetooth: RFCOMM TTY layer initialized
[    3.517689] Bluetooth: RFCOMM socket layer initialized
[    3.517712] Bluetooth: RFCOMM ver 1.11
[    3.517984] 9pnet: Installing 9P2000 support
[    3.518104] Key type dns_resolver registered
[    3.519106] printk: console [ttyTCU0]: printing thread started
[    3.519173] Loading compiled-in X.509 certificates
[    3.523287] Loaded X.509 cert 'Build time autogenerated kernel key: fd0494360c18734b320cba'
[    3.556608] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    3.558711] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    3.560841] serial-tegra 3100000.serial: RX in PIO mode
[    3.560850] serial-tegra 3100000.serial: TX in PIO mode
[    3.560974] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRT
[    3.562468] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRT
[    3.562939] serial-tegra 3110000.serial: RX in PIO mode
[    3.562945] serial-tegra 3110000.serial: TX in PIO mode
[    3.562985] 3110000.serial: ttyTHS3 at MMIO 0x3110000 (irq = 199, base_baud = 0) is a TEGRT
[    3.566532] tegra_rtc c2a0000.rtc: registered as rtc1
[    3.566547] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.567157] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    3.573660] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    3.577467] i2c i2c-2: Added multiplexed i2c bus 9
[    3.578110] i2c i2c-2: Added multiplexed i2c bus 10
[    3.578814] i2c i2c-2: Added multiplexed i2c bus 11
[    3.578996] i2c i2c-2: Added multiplexed i2c bus 12
[    3.579004] pca954x 2-0070: registered 4 multiplexed busses for I2C mux pca9544
[    3.579981] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    3.584491] tegra-i2c c240000.i2c: Adding to iommu group 1
[    3.589736] tegra-i2c c250000.i2c: Adding to iommu group 1
[    3.615522] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1525000 z
[    3.619050] irq: IRQ224: trimming hierarchy from :bus@0:pmc@c360000
[    3.620378] tegra-xusb 3610000.usb: Adding to iommu group 2
[    3.635496] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[    3.635504] tegra-xusb 3610000.usb: xHCI Host Controller
[    3.635515] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[    3.636261] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x000000
[    3.636284] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[    3.636407] tegra-xusb 3610000.usb: xHCI Host Controller
[    3.636411] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[    3.636414] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    3.636967] hub 1-0:1.0: USB hub found
[    3.636986] hub 1-0:1.0: 4 ports detected
[    3.637342] hub 2-0:1.0: USB hub found
[    3.637355] hub 2-0:1.0: 4 ports detected
[    3.638943] irq: IRQ232: trimming hierarchy from :bus@0:pmc@c360000
[    3.639004] irq: IRQ233: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    3.639052] irq: IRQ234: trimming hierarchy from :bus@0:pmc@c360000
[    3.639117] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.681515] ALSA device list:
[    3.681520]   No soundcards found.
[    3.685517] Freeing unused kernel memory: 7616K
[    3.685604] Run /init as init process
[    3.703832] Root device found: initrd
[    3.723764] r8168: loading out-of-tree module taints kernel.
[    3.724167] r8168: module verification failed: signature and/or required key missing - tail
[    3.726371] Mount initrd as rootfs and enter recovery mode
[    3.767387] tegra194-pcie 140a0000.pcie: Adding to iommu group 3
[    3.874182] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ranges:
[    3.874215] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x324000000
[    3.874223] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x004000000
[    3.874227] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a10000
[    3.874567] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[    3.874570] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    3.969677] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    3.981482] tegra194-pcie 140a0000.pcie: Link up
[    3.983239] tegra194-pcie 140a0000.pcie: Link up
[    3.983318] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[    3.983323] pci_bus 0008:00: root bus resource [io  0x0000-0xfffff] (bus address [0x2a1000)
[    3.983327] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus addres)
[    3.983331] pci_bus 0008:00: root bus resource [bus 00-ff]
[    3.983333] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[    3.983386] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[    3.983546] pci 0008:00:00.0: PME# supported from D0 D3hot
[    3.987478] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[    3.987637] pci 0008:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    3.987640] pci 0008:01:00.0: reg 0x10: [io  size 0x0100]
[    3.987822] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    3.987940] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    3.988930] pci 0008:01:00.0: supports D1 D2
[    3.988932] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    4.004599] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[    4.004603] pci 0008:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    4.004607] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[    4.004700] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[    4.004794] pci 0008:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    4.004823] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[    4.004826] pci 0008:00:00.0:   bridge window [io  0x1000-0x1fff]
[    4.004831] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[    4.004935] pcieport 0008:00:00.0: Adding to iommu group 3
[    4.005031] pcieport 0008:00:00.0: PME: Signaling with IRQ 189
[    4.005631] pcieport 0008:00:00.0: AER: enabled with IRQ 189
[    4.005821] r8168 0008:01:00.0: Adding to iommu group 3
[    4.005879] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded
[    4.005945] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[    4.022199] r8168: This product is covered by one or more of the following patents: US6,57.
[    4.024269] r8168  Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
[    4.024269]  This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http
[    4.024269]  This is free software, and you are welcome to redistribute it under certain c
[    4.024433] tegra194-pcie 140c0000.pcie: Adding to iommu group 4
[    4.026223] tegra194-pcie 140c0000.pcie: host bridge /bus@0/pcie@140c0000 ranges:
[    4.026238] tegra194-pcie 140c0000.pcie:      MEM 0x3540000000..0x37ffffffff -> 0x354000000
[    4.026244] tegra194-pcie 140c0000.pcie:      MEM 0x3828000000..0x382fffffff -> 0x004000000
[    4.026248] tegra194-pcie 140c0000.pcie:       IO 0x002c100000..0x002c1fffff -> 0x002c10000
[    4.026521] tegra194-pcie 140c0000.pcie: iATU unroll: enabled
[    4.026523] tegra194-pcie 140c0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    4.128441] hub 1-2:1.0: USB hub found
[    4.129155] hub 1-2:1.0: 5 ports detected
[    4.245929] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[    4.279975] hub 2-1:1.0: USB hub found
[    4.281689] hub 2-1:1.0: 4 ports detected
[    4.397480] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[    4.553785] hub 1-3:1.0: USB hub found
[    4.554385] hub 1-3:1.0: 4 ports detected
[    4.677766] usb 2-2: new SuperSpeed USB device number 3 using tegra-xusb
[    4.711083] hub 2-2:1.0: USB hub found
[    4.712410] hub 2-2:1.0: 4 ports detected
[    4.781480] usb 1-2.2: new low-speed USB device number 4 using tegra-xusb
[    4.895770] input: USB Keyboard as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.2/1-2.1
[    4.954169] hid-generic 0003:0C45:7603.0001: input,hidraw0: USB HID v1.11 Keyboard [USB Ke0
[    4.973614] input: USB Keyboard Consumer Control as /devices/platform/bus@0/3610000.usb/us2
[    4.985482] usb 1-3.1: new high-speed USB device number 5 using tegra-xusb
[    5.033751] input: USB Keyboard System Control as /devices/platform/bus@0/3610000.usb/usb13
[    5.034119] input: USB Keyboard as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.2/1-2.5
[    5.034813] hid-generic 0003:0C45:7603.0002: input,hidraw1: USB HID v1.11 Keyboard [USB Ke1
[    5.126599] tegra194-pcie 140c0000.pcie: Phy link never came up
[    5.213477] usb 1-2.3: new low-speed USB device number 6 using tegra-xusb
[    5.226514] usb 1-3.1: 4:1: cannot get freq at ep 0x84
[    5.326810] input: Logitech USB Optical Mouse as /devices/platform/bus@0/3610000.usb/usb1/6
[    5.327452] hid-generic 0003:046D:C077.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech 0
[    5.405480] usb 1-2.4: new full-speed USB device number 7 using tegra-xusb
[    5.609479] usb 1-3.2: new full-speed USB device number 8 using tegra-xusb
[    5.853489] usb 1-3.4: new high-speed USB device number 9 using tegra-xusb
[    6.094765] usb 1-3.4: 4:1: cannot get freq at ep 0x84
[    6.128456] tegra194-pcie 140c0000.pcie: Phy link never came up
[    6.128525] tegra194-pcie 140c0000.pcie: PCI host bridge to bus 0009:00
[    6.128531] pci_bus 0009:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x2c1)
[    6.128534] pci_bus 0009:00: root bus resource [mem 0x3828000000-0x382fffffff] (bus addres)
[    6.128539] pci_bus 0009:00: root bus resource [bus 00-ff]
[    6.128540] pci_bus 0009:00: root bus resource [mem 0x3540000000-0x37ffffffff pref]
[    6.128588] pci 0009:00:00.0: [10de:229c] type 01 class 0x060400
[    6.128742] pci 0009:00:00.0: PME# supported from D0 D3hot
[    6.135258] pci 0009:00:00.0: PCI bridge to [bus 01-ff]
[    6.135367] pcieport 0009:00:00.0: Adding to iommu group 4
[    6.135460] pcieport 0009:00:00.0: PME: Signaling with IRQ 191
[    6.136853] pcieport 0009:00:00.0: AER: enabled with IRQ 191
[    6.137140] pci_bus 0009:01: busn_res: [bus 01-ff] is released
[    6.137236] pci 0009:00:00.0: Removing from iommu group 4
[    6.137248] pci_bus 0009:00: busn_res: [bus 00-ff] is released
[    6.138225] tegra194-pcie 14100000.pcie: Adding to iommu group 5
[    6.140438] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    6.140451] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x208000000
[    6.140457] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x004000000
[    6.140461] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x003010000
[    6.140734] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    6.140736] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    6.245671] tegra194-pcie 14100000.pcie: Link up
[    6.249799] tegra194-pcie 14100000.pcie: Link up
[    6.249872] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    6.249876] pci_bus 0001:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x301)
[    6.249880] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus addres)
[    6.249883] pci_bus 0001:00: root bus resource [bus 00-ff]
[    6.249884] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    6.249935] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    6.250110] pci 0001:00:00.0: PME# supported from D0 D3hot
[    6.253650] pci 0001:01:00.0: [8086:24f3] type 00 class 0x028000
[    6.253888] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[    6.255135] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[    6.268654] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    6.268659] pci 0001:01:00.0: BAR 0: assigned [mem 0x20a8000000-0x20a8001fff 64bit]
[    6.268763] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    6.268769] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    6.268859] pcieport 0001:00:00.0: Adding to iommu group 5
[    6.268949] pcieport 0001:00:00.0: PME: Signaling with IRQ 193
[    6.269712] pcieport 0001:00:00.0: AER: enabled with IRQ 193
[    6.269982] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[    6.274659] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    6.274685] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x214000000
[    6.274692] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x004000000
[    6.274696] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x003610000
[    6.275412] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    6.275417] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    6.381723] tegra194-pcie 14160000.pcie: Link up
[    6.383244] tegra194-pcie 14160000.pcie: Link up
[    6.383315] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    6.383319] pci_bus 0004:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x361)
[    6.383323] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus addres)
[    6.383326] pci_bus 0004:00: root bus resource [bus 00-ff]
[    6.383328] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    6.383370] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    6.383521] pci 0004:00:00.0: PME# supported from D0 D3hot
[    6.387010] pci 0004:01:00.0: [15b7:5017] type 00 class 0x010802
[    6.387204] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    6.388972] pci 0004:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PC)
[    6.400608] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    6.400614] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    6.400699] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    6.400704] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    6.400803] pcieport 0004:00:00.0: Adding to iommu group 6
[    6.400892] pcieport 0004:00:00.0: PME: Signaling with IRQ 195
[    6.402434] pcieport 0004:00:00.0: AER: enabled with IRQ 195
[    6.402745] tegra194-pcie 141e0000.pcie: Adding to iommu group 7
[    6.407135] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[    6.407161] tegra194-pcie 141e0000.pcie:      MEM 0x3000000000..0x3227ffffff -> 0x300000000
[    6.407169] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x004000000
[    6.407173] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e10000
[    6.407884] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[    6.407889] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    7.515532] tegra194-pcie 141e0000.pcie: Phy link never came up
[    8.517396] tegra194-pcie 141e0000.pcie: Phy link never came up
[    8.517489] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    8.517493] pci_bus 0007:00: root bus resource [io  0x400000-0x4fffff] (bus address [0x3e1)
[    8.517496] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus addres)
[    8.517501] pci_bus 0007:00: root bus resource [bus 00-ff]
[    8.517503] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff pref]
[    8.517544] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    8.517694] pci 0007:00:00.0: PME# supported from D0 D3hot
[    8.523855] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    8.523952] pcieport 0007:00:00.0: Adding to iommu group 7
[    8.524040] pcieport 0007:00:00.0: PME: Signaling with IRQ 197
[    8.524626] pcieport 0007:00:00.0: AER: enabled with IRQ 197
[    8.524954] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[    8.525037] pci 0007:00:00.0: Removing from iommu group 7
[    8.525048] pci_bus 0007:00: busn_res: [bus 00-ff] is released
insmod /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme-core.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme.ko
[    8.540580] nvme 0004:01:00.0: Adding to iommu group 6
[    8.540791] nvme nvme0: pci function 0004:01:00.0
[    8.541022] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    8.569098] nvme nvme0: allocated 128 MiB host memory buffer.
[    8.570616] nvme nvme0: 6/0/0 default/read/poll queues
[    8.576111]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
insmod /lib/modules/5.15.148-tegra/kernel/drivers/thermal/tegra/tegra-bpmp-thermal.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/pwm/pwm-tegra.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/hwmon/pwm-fan.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/libcomposite.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/typec.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/ucsi/typec_ucsi.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/ucsi/ucsi_ccg.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/udc/tegra-xudc.ko
[    8.627134] tegra-xudc 3550000.usb: Adding to iommu group 8
insmod /lib/modules/5.15.148-tegra/kernel/net/ipv6/ipv6.ko
[    8.665994] NET: Registered PF_INins pr /lib/col familuley
s/5.15.14[  8-tegra/u.66664pdates/drmenivet Rrs/nvpps/ winvpps.ko th IPv6
[    8.666647] In-situ OAM (IOAM) with IPv6
insmod /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.
insmod /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/stusb160x.ko
insmod /lib/modules/5.15.148-tegra/updates/drivers/platform/tegra/mce/tegra-mce.ko
insmod /lib/modules/5.15.148-tegra/updates/drivers/spi/spi-tegra210-quad.ko
[    8.690457] tegra-qspi 3270000.spi: Adding to iommu group 9
[    8.690997] tegra-qspi 3270000.spi: Prod config not found for QSPI: -19
[    8.692140] spi-nor spi0.0: mx25u51279g (65536 Kbytes)
[    9.713596] using random self ethernet address
[    9.713601] using random host ethernet address
[    9.741877] usb0: HOST MAC 36:a6:c6:f4:1b:f6
[    9.741885] usb0: MAC ea:f5:8a:39:93:df
[    9.741915] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
I’m not sure why this error is occuring or what I can do to fix it. Any help would be appreciated.
I don’t know if the explanation would work here so I just try to make it simpler
  1. If you are using a custom board, then please get the corresponding image from the vendor for their board. NVIDIA sdkmanager and BSP by default only guarantees to work with NV devkit. The only situation that NVIDIA sdkmanager can work is if the vendor claims their board can work fine with custom board.
  2. What I saw here is just another usb device mode issue which is very common on custom board. This must have correct configuration based on hardware design to make it work. As neither you nor me is the board vendor, we don’t know the exact schematic in their design. Thus, you should report this issue to the vendor first.
Interesting. The guide I linked in my question was made by the vendor. So I guess I assumed that if it wasn’t working, it means that I missed something.
I’ll see If I can report this to the vendor then.
Where was the whole package that you ran initrd_flash coming from? Is it provided by the vendor? or you get it from NVIDIA website?
The vendor provided it on this repo: GitHub - forecr/dsboard_ornx_lan_orin_bsp: Jetson Orin NX & Orin Nano BSP Packages for DSBOARD-ORNX-LAN
Did this board ever get flashed with any of these package ? I mean other version of jetpack.
Yes, it was flashed with JetPack 5.1.1 previously. It is what currently runs on this board I’m trying to flash.
Could you try with jetpack6.0?
Somehow we managed to accidentally fry the recover usb port. So we’ll have to order replacement boards.
I will definitely try flashing jetpack6.0 once we get them though and let you know if it works.
Hey!! So I’m back!
I did try the same flashing process with JetPack6.0 and the same problem occurred.
jetson_orin_flash_logs.txt (83.1 KB)
Here are the debug logs again for attempting the 6.0 flash if that helps.
Situation is still same. Usb device mode has some issue. My comment is still same as the beginning.
For anyone looking for the solution to this, forecr updated their BSP files and released and updated flashing guide. It can be found here.
