Hey, im trying to create a custom rootfs. Here are the steps i’ve tried.
- Download L4T 36.2 BSP
- Under tools/samplefs, run
./nv_build_samplefs.sh --abi aarch64 --distro ubuntu --flavor basic --version jammy - Run
./tools/l4t_create_default_user.sh -u ubuntu -p ubuntu -a - Run
sudo ./apply_binaries.sh(i’ve skipped some packages here because they had some problem installing)
But after flashing it, I never get the login prompt – it seems like the kernel just hangs
logs:
Jetson System firmware version 36.2.0-gcid-34956989 date 2023-11-30T18:35:35+00:
00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
��debugfs initialized
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.122-tegra (buildbrain@mobile-u64-6517-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Thu Nov 30 10:30:37 PST 2023 ()
[ 0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x10281ff318 SMBIOS=0xffff0000 SMBIOS 3.0=0x1027c20000 MEMATTR=0x10218bf018 ESRT=0x1021862918 RNG=0x1015830018 MEMRESERVE=0x1016308c18
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x0000001021862918 to 0x0000001021862950.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000ff5000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x1022d20800-0x1022d22fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000001018c48fff]
[ 0.000000] node 0: [mem 0x0000001018c49000-0x0000001018ddbfff]
[ 0.000000] node 0: [mem 0x0000001018ddc000-0x00000010262bffff]
[ 0.000000] node 0: [mem 0x00000010262c0000-0x00000010281fffff]
[ 0.000000] node 0: [mem 0x0000001028200000-0x000000102c5fffff]
[ 0.000000] node 0: [mem 0x000000102c600000-0x000000102c7fffff]
[ 0.000000] node 0: [mem 0x000000102c800000-0x000000102cd6ffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] On node 0, zone Normal: 21136 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80344 r8192 d30248 u118784
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
��[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
��[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16187504
[ 0.000000] Policy zone: Normal
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
��[ 0.000000] Kernel command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x102C610000 bl_prof_ro_ptr=65536@0x102C600000
[ 0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x102C610000 bl_prof_ro_ptr=65536@0x102C600000", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla1_core
��[ 0.000000] Memory: 63806480K/65779136K available (19712K kernel code, 4056K rwdata, 9960K rodata, 7680K init, 528K bss, 1448368K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla1_core
��[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay i��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla1_falcon
��s 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla1_falcon
��[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_core
��[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000573] Console: colour dummy device 80x25
[ 0.000595] printk: console [tty0] enabled
[ 0.000720] Calibrating delay ��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_core
��loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000739] pid_max: default: 32768 minimum: 301
[ 0.000808] LSM: Security Framework initializing
[ 0.000861] Yama: becoming mindful.
[ 0.000896] SELinux: Initializing.
[ 0.001275] Mount-cache has��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_falcon
��h table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001502] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.004969] rcu: Hierarchical SRCU implementation.
[ 0.009237] Tegra Revision: A01 SKU: 208 CPU Process: 0 SoC Process: 0
[ 0.00962��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_falcon
��4] Remapping and enabling EFI services.
[ 0.010867] smp: Bringing up secondary CPUs ...
[ 0.011740] Detected PIPT I-cache on CPU1
[ 0.011853] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.011943] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.012705] Detected PIPT I-cache on CPU2
[ 0.012719] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.012742] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.013404] Detected PIPT I-cache on CPU3
[ 0.013416] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.013438] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.016139] Detected PIPT I-cache on CPU4
[ 0.016166] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.016203] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.016912] Detected PIPT I-cache on CPU5
[ 0.016924] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.016944] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.017617] Detected PIPT I-cache on CPU6
[ 0.017631] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.017652] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.018329] Detected PIPT I-cache on CPU7
[ 0.018342] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.018360] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.021076] Detected PIPT I-cache on CPU8
[ 0.021109] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.021144] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.021857] Detected PIPT I-cache on CPU9
[ 0.021872] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.021891] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.022595] Detected PIPT I-cache on CPU10
0.108922] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.118532] pinctrl core: initialized pinctrl subsystem
[ 0.119600] SMBIOS 3.6.0 present.
[ 0.119615] DMI: Unknown NVIDIA Jetson AGX Orin Developer Kit/NVIDIA Jetson AGX Orin Developer Kit, BIOS 36.2.0-gcid-34956989 11/30/2023
[ 0.120220] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.122850] DMA: preallocated 8192 KiB GFP_KERNEL pool for atomic allocations
[ 0.123547] DMA: preallocated 8192 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.124217] DMA: preallocated 8192 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.124281] audit: initializing netlink subsys (disabled)
[ 0.124440] audit: type=2000 audit(0.120:1): state=initialized audit_enabled=0 res=1
[ 0.126373] thermal_sys: Registered thermal governor 'step_wise'
[ 0.126378] thermal_sys: Registered thermal governor 'user_space'
[ 0.126378] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.131398] cpuidle: using governor menu
[ 0.131591] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.131749] ASID allocator initialised with 32768 entries
[ 0.133980] Serial: AMBA PL011 UART driver
[ 0.135408] printk: console [ramoops-1] enabled
[ 0.135412] pstore: Registered ramoops as persistent store backend
[ 0.135415] ramoops: using 0x200000@0x102cdf0000, ecc: 0
[ 0.145771] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 118, base_baud = 0) is a SBSA
[ 0.145808] printk: console [ttyAMA0] enabled
[ 0.157329] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.166713] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.166725] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.166729] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.166731] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.167771] cryptd: max_cpu_qlen set to 1000
[ 0.169527] ACPI: Interpreter disabled.
[ 0.171455] iommu: Default domain type: Translated
[ 0.171460] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.171796] SCSI subsystem initialized
[ 0.171975] vgaarb: loaded
[ 0.172131] usbcore: registered new interface driver usbfs
[ 0.172156] usbcore: registered new interface driver hub
[ 0.172175] usbcore: registered new device driver usb
[ 0.172600] pps_core: LinuxPPS API ver. 1 registered
[ 0.172605] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.172616] PTP clock support registered
[ 0.172688] EDAC MC: Ver: 3.0.0
[ 0.174121] Registered efivars operations
[ 0.174789] FPGA manager framework
[ 0.174865] Advanced Linux Sound Architecture Driver Initialized.
[ 0.175802] clocksource: Switched to clocksource arch_sys_counter
[ 0.213937] VFS: Disk quotas dquot_6.6.0
[ 0.214012] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.214262] pnp: PnP ACPI: disabled
[ 0.217658] NET: Registered PF_INET protocol family
[ 0.218195] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.220657] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.220720] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.220765] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.221167] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.222506] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.222776] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.222908] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.223253] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.223766] RPC: Registered named UNIX socket transport module.
[ 0.223771] RPC: Registered udp transport module.
[ 0.223771] RPC: Registered tcp transport module.
[ 0.223774] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.223811] PCI: CLS 0 bytes, default 64
[ 0.224088] Unpacking initramfs...
[ 0.232955] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.233378] kvm [1]: IPA Size Limit: 48 bits
[ 0.233419] kvm [1]: GICv3: no GICV resource entry
[ 0.233429] kvm [1]: disabling GICv2 emulation
[ 0.233455] kvm [1]: GIC system register CPU interface enabled
[ 0.233587] kvm [1]: vgic interrupt IRQ9
[ 0.233804] kvm [1]: VHE mode initialized successfully
[ 0.236917] Initialise system trusted keyrings
[ 0.237029] workingset: timestamp_bits=42 max_order=24 bucket_order=0
[ 0.240948] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.241356] NFS: Registering the id_resolver key type
[ 0.241383] Key type id_resolver registered
[ 0.241385] Key type id_legacy registered
[ 0.241434] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.241452] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.241477] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.241673] 9p: Installing v9fs 9p2000 file system support
[ 0.253509] NET: Registered PF_ALG protocol family
[ 0.253523] Key type asymmetric registered
[ 0.253529] Asymmetric key parser 'x509' registered
[ 0.253610] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.253617] io scheduler mq-deadline registered
[ 0.253628] io scheduler kyber registered
[ 0.264098] EINJ: ACPI disabled.
[ 0.277506] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.279304] SuperH (H)SCI(F) driver initialized
[ 0.279629] msm_serial: driver initialized
[ 0.280277] printk: console [ttyTCU0] enabled
[ 0.281174] arm-smmu 8000000.iommu: probing hardware configuration...
[ 0.281179] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.281185] arm-smmu 8000000.iommu: stage 1 translation
[ 0.281187] arm-smmu 8000000.iommu: stage 2 translation
[ 0.281192] arm-smmu 8000000.iommu: nested translation
[ 0.281199] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.281202] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.281219] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.281222] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.281224] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.282240] arm-smmu 10000000.iommu: probing hardware configuration...
[ 0.282244] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.282245] arm-smmu 10000000.iommu: stage 1 translation
[ 0.282248] arm-smmu 10000000.iommu: stage 2 translation
[ 0.282248] arm-smmu 10000000.iommu: nested translation
[ 0.282252] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.282254] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.282263] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.282264] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.282266] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.282631] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.282635] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.282636] arm-smmu 12000000.iommu: stage 1 translation
[ 0.282637] arm-smmu 12000000.iommu: stage 2 translation
[ 0.282639] arm-smmu 12000000.iommu: nested translation
[ 0.282642] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.282644] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.282650] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.282654] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.282655] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.293664] loop: module loaded
[ 0.294499] megasas: 07.717.02.00-rc1
[ 0.298820] tun: Universal TUN/TAP device driver, 1.6
[ 0.299430] thunder_xcv, ver 1.0
[ 0.299460] thunder_bgx, ver 1.0
[ 0.299478] nicpf, ver 1.0
[ 0.300360] hclge is initializing
[ 0.300388] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.300395] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.300435] e1000: Intel(R) PRO/1000 Network Driver
[ 0.300443] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.300473] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.300478] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.300509] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.300515] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.300530] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.300537] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.300745] sky2: driver version 1.30
[ 0.301443] VFIO - User Level meta-driver version: 0.3
[ 0.302955] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.302967] ehci-pci: EHCI PCI platform driver
[ 0.302996] ehci-platform: EHCI generic platform driver
[ 0.303076] ehci-orion: EHCI orion driver
[ 0.303150] ehci-exynos: EHCI Exynos driver
[ 0.303212] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.303241] ohci-pci: OHCI PCI platform driver
[ 0.303267] ohci-platform: OHCI generic platform driver
[ 0.303340] ohci-exynos: OHCI Exynos driver
[ 0.303782] usbcore: registered new interface driver usb-storage
[ 0.305680] i2c_dev: i2c /dev entries driver
[ 0.309059] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.311039] sdhci: Secure Digital Host Controller Interface driver
[ 0.311045] sdhci: Copyright(c) Pierre Ossman
[ 0.311507] Synopsys Designware Multimedia Card Interface Driver
[ 0.312164] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.313381] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.314340] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.314865] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.316279] tegra-bpmp bpmp: firmware: a381fb560faa591136e7-ac83764aab0
[ 0.402161] Freeing initrd memory: 10976K
[ 4.020053] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 4.020076] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 4.020080] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 4.020706] usbcore: registered new interface driver usbhid
[ 4.020711] usbhid: USB HID core driver
[ 4.025600] optee: probing for conduit method.
[ 4.025654] optee: revision 3.22 (1b7f2993)
[ 4.084778] optee: dynamic shared memory is enabled
[ 4.085041] optee: initialized driver
[ 4.087115] usbcore: registered new interface driver snd-usb-audio
[ 4.088601] NET: Registered PF_PACKET protocol family
[ 4.088821] 9pnet: Installing 9P2000 support
[ 4.088922] Key type dns_resolver registered
[ 4.090252] printk: console [tty0]: printing thread started
[ 4.091243] printk: console [ttyTCU0]: printing thread started
[ 4.092171] printk: console [ttyAMA0]: printing thread started
[ 4.093584] printk: console [ramoops-1]: printing thread started
[ 4.093692] Loading compiled-in X.509 certificates
[ 4.107530] Loaded X.509 cert 'Build time autogenerated kernel key: 6df01ab60d1edfd9b484fde1a886c193293a8ad8'
[ 4.180710] pstore: Using crash dump compression: deflate
[ 4.208959] gpio-394 (camera-control-output-low): hogged as output/low
[ 4.208984] gpio-397 (camera-control-output-low): hogged as output/low
[ 4.209008] gpio-487 (camera-control-output-low): hogged as output/low
[ 4.209023] gpio-486 (camera-control-output-low): hogged as output/low
[ 4.213862] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 4.221545] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 4.226032] serial-tegra 3100000.serial: RX in PIO mode
[ 4.226039] serial-tegra 3100000.serial: TX in PIO mode
[ 4.229506] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 4.230673] serial-tegra 3110000.serial: RX in PIO mode
[ 4.230679] serial-tegra 3110000.serial: TX in PIO mode
[ 4.230783] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 206, base_baud = 0) is a TEGRA_UART
[ 4.236890] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.236901] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.237303] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 4.246261] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 4.260198] tegra-i2c 3190000.i2c: Adding to iommu group 1
[ 4.268184] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 4.274561] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[ 4.279322] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[ 4.283981] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 4.287438] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 4.315702] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2006000 KHz, changing to: 2035200 KHz
[ 4.318375] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[ 4.320694] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 4.323350] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[ 4.324139] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 4.325662] irq: IRQ233: trimming hierarchy from :bus@0:pmc@c360000
[ 4.325727] irq: IRQ234: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 4.325768] irq: IRQ235: trimming hierarchy from :bus@0:pmc@c360000
[ 4.325826] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.859011] ALSA device list:
[ 4.859016] No soundcards found.
[ 4.859323] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 4.870819] mmc3: CQHCI version 5.10
[ 4.905649] mmc3: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[ 4.909333] irq: IRQ236: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 4.910091] mmc4: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 4.911107] Freeing unused kernel memory: 7680K
[ 4.911286] Run /init as init process
[ 4.923512] Checking overlayfs setting...
[ 4.933016] Overlayfs is disabled...
[ 4.939289] Root device found: nvme0n1p1
[ 5.015961] mmc3: Command Queue Engine enabled
[ 5.015969] mmc3: new HS400 Enhanced strobe MMC card at address 0001
[ 5.016473] mmcblk3: mmc3:0001 G1M15M 59.3 GiB
[ 5.021324] mmcblk3: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 5.026234] mmcblk3boot0: mmc3:0001 G1M15M 31.5 MiB
[ 5.026897] mmcblk3boot1: mmc3:0001 G1M15M 31.5 MiB
[ 5.027305] mmcblk3rpmb: mmc3:0001 G1M15M 4.00 MiB, chardev (511:0)
[ 7.962998] tegra194-pcie 14100000.pcie: Adding to iommu group 4
[ 7.966660] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[ 7.966682] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 7.966688] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 7.966692] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 7.967177] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[ 7.967180] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 8.034098] irq: IRQ237: trimming hierarchy from :bus@0:pmc@c360000
[ 8.075800] tegra194-pcie 14100000.pcie: Link up
[ 8.077390] tegra194-pcie 14100000.pcie: Link up
[ 8.077467] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.077471] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.077475] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.077478] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.077480] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.077532] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.077699] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.081303] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 8.081476] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 8.081677] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.082734] pci 0001:01:00.0: supports D1 D2
[ 8.082736] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.094694] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 8.094699] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 8.094702] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.094805] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 8.094837] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.094840] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 8.094845] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 8.094955] pcieport 0001:00:00.0: Adding to iommu group 4
[ 8.095055] pcieport 0001:00:00.0: PME: Signaling with IRQ 199
[ 8.095651] pcieport 0001:00:00.0: AER: enabled with IRQ 199
[ 8.096501] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[ 8.118684] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[ 8.118704] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 8.118711] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 8.118714] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 8.124145] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[ 8.124149] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 8.232339] tegra194-pcie 14160000.pcie: Link up
[ 8.242095] tegra194-pcie 14160000.pcie: Link up
[ 8.242125] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 8.242128] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 8.242131] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.242133] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 8.242135] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.242175] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.242316] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.245653] pci 0004:01:00.0: [144d:a80c] type 00 class 0x010802
[ 8.245834] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 8.258713] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 8.258719] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 8.258798] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.258802] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 8.258892] pcieport 0004:00:00.0: Adding to iommu group 5
[ 8.258970] pcieport 0004:00:00.0: PME: Signaling with IRQ 201
[ 8.259428] pcieport 0004:00:00.0: AER: enabled with IRQ 201
[ 8.259630] nvme 0004:01:00.0: Adding to iommu group 5
[ 8.259976] nvme nvme0: pci function 0004:01:00.0
[ 8.260196] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 8.260531] tegra194-pcie 141a0000.pcie: Adding to iommu group 6
[ 8.263885] nvme nvme0: Shutdown timeout set to 10 seconds
[ 8.266391] nvme nvme0: 12/0/0 default/read/poll queues
[ 8.268799] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 8.288878] Found dev node: /dev/nvme0n1p1
[ 8.350252] EXT4-fs (nvme0n1p1): recovery complete
[ 8.358976] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 8.360844] Rootfs mounted over nvme0n1p1
[ 8.366617] Switching from initrd to actual rootfs
[ 8.368306] tegra194-pcie 141a0000.pcie: host bridge /bus@0/pcie@141a0000 ranges:
[ 8.368319] tegra194-pcie 141a0000.pcie: MEM 0x2800000000..0x2b27ffffff -> 0x2800000000
[ 8.368325] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 8.368330] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 8.368650] tegra194-pcie 141a0000.pcie: iATU unroll: enabled
[ 8.368652] tegra194-pcie 141a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 8.425405] systemd[1]: System time before build time, advancing clock.
[ 8.451552] NET: Registered PF_INET6 protocol family
[ 8.452413] Segment Routing with IPv6
[ 8.452418] In-situ OAM (IOAM) with IPv6
[ 8.484479] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 8.484807] systemd[1]: Detected architecture arm64.
[ 8.616018] pcieport 0004:00:00.0: AER: Corrected error received: 0004:00:00.0
[ 8.616028] pcieport 0004:00:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 8.616030] pcieport 0004:00:00.0: device [10de:229c] error status/mask=00000001/0000e000
[ 8.616032] pcieport 0004:00:00.0: [ 0] RxErr (First)
[ 8.623843] systemd[1]: Hostname set to <tegra-ubuntu>.
[ 8.647467] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog
[ 8.647482] systemd[1]: Set hardware watchdog to 2min.
[ 8.764146] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 8.792222] systemd[1]: Queued start job for default target Graphical Interface.
[ 8.793212] systemd[1]: Created slice Slice /system/getty.
[ 8.793680] systemd[1]: Created slice Slice /system/modprobe.
[ 8.794052] systemd[1]: Created slice Slice /system/serial-getty.
[ 8.794324] systemd[1]: Created slice User and Session Slice.
[ 8.794461] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 8.794570] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.794826] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.794914] systemd[1]: Reached target Local Encrypted Volumes.
[ 8.794989] systemd[1]: Reached target Remote File Systems.
[ 8.795034] systemd[1]: Reached target Slice Units.
[ 8.795082] systemd[1]: Reached target Swaps.
[ 8.795134] systemd[1]: Reached target Local Verity Protected Volumes.
[ 8.795310] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 8.795415] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 8.795933] systemd[1]: Listening on Journal Audit Socket.
[ 8.856203] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.908411] systemd[1]: Listening on Journal Socket.
[ 8.920775] systemd[1]: Listening on Network Service Netlink Socket.
[ 8.920952] systemd[1]: Listening on udev Control Socket.
[ 8.921085] systemd[1]: Listening on udev Kernel Socket.
[ 8.921966] systemd[1]: Mounting Huge Pages File System...
[ 8.922854] systemd[1]: Mounting POSIX Message Queue File System...
[ 8.923706] systemd[1]: Mounting Kernel Debug File System...
[ 8.924693] systemd[1]: Mounting Kernel Trace File System...
[ 8.969765] systemd[1]: Starting Journal Service...
[ 8.970789] systemd[1]: Starting Create List of Static Device Nodes...
[ 8.971785] systemd[1]: Starting Load Kernel Module configfs...
[ 8.972851] systemd[1]: Starting Load Kernel Module drm...
[ 8.997280] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 8.998227] systemd[1]: Starting Load Kernel Module fuse...
[ 8.998335] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[ 8.999144] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 9.000116] systemd[1]: Started Nameserver information manager.
[ 9.007321] fuse: init (API version 7.34)
[ 9.041361] systemd[1]: Reached target Preparation for Network.
[ 9.041486] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 9.042978] systemd[1]: Starting Load Kernel Modules...
[ 9.043888] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 9.048814] nvsciipc: loading out-of-tree module taints kernel.
[ 9.050165] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null). Quota mode: none.
[ 9.051163] nvsciipc: loaded module
[ 9.061620] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 9.062038] nvmap_co_device_init: vpr :dma coherent mem declare 0x0000001049800000,914358272
[ 9.062043] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 9.062054] nvmap_page_pool_init: Total RAM pages: 16087356
[ 9.062055] nvmap_page_pool_init: nvmap page pool size: 2010919 pages (3759 MB)
[ 9.062256] nvmap_background_zero_thread: PP zeroing thread starting.
[ 9.062270] nvmap_heap_create: created heap vpr base 0x0000001049800000 size (892928KiB)
[ 9.062295] nvmap_heap_create: fsi :dma coherent mem declare 0x000000102f000000,16777216
[ 9.062297] nvmap_heap_create: created heap fsi base 0x000000102f000000 size (16384KiB)
[ 9.073792] tegra-host1x 13e00000.host1x: Adding to iommu group 7
[ 9.075020] host1x-context host1x-ctx.0: Adding to iommu group 8
[ 9.075140] host1x-context host1x-ctx.1: Adding to iommu group 9
[ 9.075246] host1x-context host1x-ctx.2: Adding to iommu group 10
[ 9.075352] host1x-context host1x-ctx.3: Adding to iommu group 11
[ 9.075458] host1x-context host1x-ctx.4: Adding to iommu group 12
[ 9.075581] host1x-context host1x-ctx.5: Adding to iommu group 13
[ 9.075684] host1x-context host1x-ctx.6: Adding to iommu group 14
[ 9.075851] host1x-context host1x-ctx.7: Adding to iommu group 15
[ 9.075970] host1x-context host1x-ctx.8: Adding to iommu group 16
[ 9.076097] host1x-context host1x-ctx.9: Adding to iommu group 17
[ 9.076217] host1x-context host1x-ctx.10: Adding to iommu group 18
[ 9.076342] host1x-context host1x-ctx.11: Adding to iommu group 19
[ 9.076469] host1x-context host1x-ctx.12: Adding to iommu group 20
[ 9.076601] host1x-context host1x-ctx.13: Adding to iommu group 21
[ 9.076717] host1x-context host1x-ctx.14: Adding to iommu group 22
[ 9.076832] host1x-context host1x-ctx.15: Adding to iommu group 23
[ 9.088499] systemd[1]: Starting Coldplug All udev Devices...
[ 9.136770] nvgpu: 17000000.gpu nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 9.136770]
[ 9.147370] systemd[1]: Started Journal Service.
[ 9.323622] systemd-journald[281]: Received client request to flush runtime journal.
��TCU debug prints will be routed to traces.
��[ 9.524273] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[ 9.524275] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[ 9.524276] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[ 9.524277] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[ 9.524278] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[ 9.524278] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[ 9.857103] (NULL device *): fops function table already registered
[ 10.018215] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 10.022397] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 10.022474] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 10.022479] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[ 10.091925] tegra194_gte: module verification failed: signature and/or required key missing - tainting kernel
��Starting RmBootstrap
Registered event_type:[0] for dce_core_ipc_type:[1]
Registered event_type:[1] for dce_core_ipc_type:[3]
dce_ipc State Initialized
RmBootstrap completed successfully
��[ 10.556392] using random self ethernet address
[ 10.556400] using random host ethernet address
[ 10.701462] using random self ethernet address
Any help is highly appreciated
