I compiled the Basic Flavor Root File System with orin Nano development board according to the tutorial, but there was an error when burning. How can
I followed the tutorial on the [Root File System — NVIDIA Jetson Linux Developer Guide 1 documentation]website to build the root file system. Since I am using Ubuntu20.04 for PC, I followed the “Execute the Script on a Non-Ubuntu 22.04 Host” tutorial to build the filesystem on the virtual machine. And unpack the built file in ~/nvidia/Linux_for_Tegra/rootfs path. To burn, run the following command:
sudo ./apply_binaries.sh
sudo ./tools/l4t_create_default_user.sh -u ys -p 123456
sudo ./tools/l4t_flash_prerequisites.sh
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1   -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml"   --showlogs --network usb0 jetson-orin-nano-devkit internal
execute“sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit internal”
An error occurred while burning:
in flash
Writing gpt_secondary_3_0.bin (parittion: secondary_gpt) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/gpt_secondary_3_0.bin
Writing /mnt/internal/gpt_secondary_3_0.bin (16896 bytes) into  /dev/mtd0:67091968
Copied 16896 bytes from /mnt/internal/gpt_secondary_3_0.bin to address 0x03ffbe00 in flash
[ 201]: l4t_flash_from_kernel: Successfully flash the qspi
[ 201]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
[ 201]: l4t_flash_from_kernel: Failed to write to APP
[ 201]: l4t_flash_from_kernel: Error flashing external device
Flash failure
Either the device cannot mount the NFS server on the host or a flash command has failed. Debug log saved to /tmp/tmp.kHbJzqLBZ3. You can access the target's terminal through "sshpass -p root ssh root@fc00:1:1:0::2"
Cleaning up...
Error message printed from the device’s serial port:
[  397.378307] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
Then I forcibly restarted the device and printed the following message
[    5.375883] hid-generic 0003:413C:2113.0003: input,hidraw2: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-3610000.usb-2.3/input1
[    8.118660] tegra194-pcie 14100000.pcie: Adding to iommu group 3
[    8.120434] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    8.120455] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    8.120462] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    8.120466] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    8.120795] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    8.120798] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.151471] tegra-xudc 3550000.usb: Adding to iommu group 4
[    8.227754] tegra194-pcie 14100000.pcie: Link up
[    8.229234] tegra194-pcie 14100000.pcie: Link up
[    8.229302] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    8.229308] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    8.229312] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    8.229315] pci_bus 0001:00: root bus resource [bus 00-ff]
[    8.229317] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    8.229373] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    8.229546] pci 0001:00:00.0: PME# supported from D0 D3hot
[    8.233426] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    8.233601] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    8.233804] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    8.234889] pci 0001:01:00.0: supports D1 D2
[    8.234897] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    8.247157] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    8.247162] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    8.247166] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    8.247271] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    8.247302] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    8.247306] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    8.247311] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    8.247422] pcieport 0001:00:00.0: Adding to iommu group 3
[    8.247527] pcieport 0001:00:00.0: PME: Signaling with IRQ 191
[    8.248139] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[    8.249109] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[    8.251756] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    8.251779] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    8.251786] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    8.251791] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    8.252391] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    8.252395] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.359749] tegra194-pcie 14160000.pcie: Link up
[    8.360465] tegra194-pcie 14160000.pcie: Link up
[    8.360529] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    8.360533] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    8.360536] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    8.360539] pci_bus 0004:00: root bus resource [bus 00-ff]
[    8.360541] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    8.360582] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    8.360732] pci 0004:00:00.0: PME# supported from D0 D3hot
[    8.364408] pci 0004:01:00.0: [10ec:5765] type 00 class 0x010802
[    8.364611] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    8.364856] pci 0004:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[    8.379153] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    8.379162] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    8.379251] pci 0004:01:00.0: BAR 5: assigned [mem 0x2428004000-0x2428005fff]
[    8.379278] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    8.379283] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    8.379445] pcieport 0004:00:00.0: Adding to iommu group 5
[    8.379562] pcieport 0004:00:00.0: PME: Signaling with IRQ 193
[    8.379703] pcieport 0004:00:00.0: AER: enabled with IRQ 193
[    8.379932] nvme 0004:01:00.0: Adding to iommu group 5
[    8.380139] nvme nvme0: pci function 0004:01:00.0
[    8.380201] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    8.380837] tegra194-pcie 141e0000.pcie: Adding to iommu group 6
[    8.382100] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[    8.382115] tegra194-pcie 141e0000.pcie:      MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[    8.382123] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    8.382127] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    8.382447] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[    8.382449] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.530167] nvme nvme0: allocated 64 MiB host memory buffer.
[    8.562823] nvme nvme0: 6/0/0 default/read/poll queues
[    8.587855] nvme nvme0: Ignoring bogus Namespace Identifiers
[    8.596189]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    8.713933] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    8.719461] Rootfs mounted over PARTUUID=49e69760-c67f-4215-b70e-800e11076fae
[    8.728518] Switching from initrd to actual rootfs
[    8.731631] Kernel panic - not syncing:
[    8.731635] Attempted to kill init! exitcode=0x00007f00
[    8.731641] CPU: 2 PID: 1 Comm: chroot Not tainted 5.15.136-tegra #1
[    8.731645] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[    8.731648] Call trace:
[    8.731649]  dump_backtrace+0x0/0x1d0
[    8.731663]  show_stack+0x34/0x50
[    8.731667]  dump_stack_lvl+0x68/0x8c
[    8.731674]  dump_stack+0x18/0x3c
[    8.731676]  panic+0xc4/0x398
[    8.731679]  do_exit+0xa1c/0xa50
[    8.731683]  do_group_exit+0x44/0xb0
[    8.731686]  __arm64_sys_exit_group+0x2c/0x30
[    8.731689]  invoke_syscall+0x5c/0x150
[    8.731694]  el0_svc_common.constprop.0+0x64/0x120
[    8.731698]  do_el0_svc+0x74/0xb0
[    8.731701]  el0_svc+0x28/0x90
[    8.731703]  el0t_64_sync_handler+0xac/0x130
[    8.731705]  el0t_64_sync+0x1a4/0x1a8
Excuse me, how should I solve the above problems, how to successfully burn Basic Flavor Root File System
Can anyone help me?
Hi 56101855,
Are you using the devkit or custom board for Orin Nano?
Could you try using the following command to flash your board instead?
$ sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
Does it work with the default desktop rootfs?
Can you please put the full log here?
▒▒Jetson System firmware version 36.3.0-gcid-36191598 date 2024-05-06T16:58:59+00:
00
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
L4TLauncher: Attempting Direct Boot
OpenAndReadUntrustedFileToBuffer: Failed to open boot\extlinux\extlinux.conf: No
t Found
ProcessExtLinuxConfig:sds Failed to Authenticate boot\extlinux\extlinux.conf (No
t Found)
L4TLauncher: Unable to process extlinux config: Not Found
L4TLauncher: Attempting Kernel Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
▒▒debugfs initialized
▒▒I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
▒▒[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.136-tegra (buildbrain@mobile-u64-6367-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon May 6 09:56:39 PDT 2024 ()
[    0.000000] Machine model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x16d84f198 SMBIOS=0xffff0000 SMBIOS 3.0=0x16d220000 MEMATTR=0x167795018 ESRT=0x167796998 RNG=0x15add0018 MEMRESERVE=0x15b919c18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] esrt: Reserving ESRT space from 0x0000000167796998 to 0x00000001677969d0.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000014a000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000177ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x171aff800-0x171b01fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000177ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000bdffffff]
[    0.000000]   node   0: [mem 0x00000000c2000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000015e259fff]
[    0.000000]   node   0: [mem 0x000000015e25a000-0x000000015e42bfff]
[    0.000000]   node   0: [mem 0x000000015e42c000-0x000000016b90ffff]
[    0.000000]   node   0: [mem 0x000000016b910000-0x000000016d84ffff]
[    0.000000]   node   0: [mem 0x000000016d850000-0x0000000171dfffff]
[    0.000000]   node   0: [mem 0x0000000171e00000-0x0000000171ffffff]
[    0.000000]   node   0: [mem 0x0000000172000000-0x000000017259ffff]
[    0.000000]   node   0: [mem 0x0000000172f00000-0x0000000172ffffff]
[    0.000000]   node   0: [mem 0x0000000176000000-0x0000000177ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000177ffffff]
[    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 968864
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=PARTUUID=43f345bd-5160-47b8-8dd2-4ad0d97748b3 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0  bl_prof_dataptr=2031616@0x171E10000 bl_prof_ro_ptr=65536@0x171E00000
[    0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x171E10000 bl_prof_ro_ptr=65536@0x171E00000", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 3407544K/3938944K available (19712K kernel code, 4056K rwdata, 9968K rodata, 7680K init, 529K bss, 269256K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000000] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000364] Console: colour dummy device 80x25
[    0.000375] printk: console [tty0] enabled
[    0.000437] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000446] pid_max: default: 32768 minimum: 301
[    0.000484] LSM: Security Framework initializing
[    0.000509] Yama: becoming mindful.
[    0.000526] SELinux:  Initializing.
[    0.000598] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.000607] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.001727] rcu: Hierarchical SRCU implementation.
[    0.003947] Tegra Revision: A01 SKU: 214 CPU Process: 0 SoC Process: 0
[    0.004213] Remapping and enabling EFI services.
[    0.005000] smp: Bringing up secondary CPUs ...
[    0.005486] Detected PIPT I-cache on CPU1
[    0.005528] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.005558] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.006003] Detected PIPT I-cache on CPU2
[    0.006015] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.006030] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.006441] Detected PIPT I-cache on CPU3
[    0.006451] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.006464] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.008916] Detected PIPT I-cache on CPU4
[    0.008944] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[    0.008974] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.009473] Detected PIPT I-cache on CPU5
[    0.009486] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[    0.009502] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.009563] smp: Brought up 1 node, 6 CPUs
[    0.009568] SMP: Total of 6 processors activated.
[    0.009570] CPU features: detected: 32-bit EL0 Support
[    0.009572] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.009574] CPU features: detected: Common not Private translations
[    0.009575] CPU features: detected: CRC32 instructions
[    0.009576] CPU features: detected: Data cache clean to Point of Persistence
[    0.009577] CPU features: detected: Generic authentication (architected algorithm)
[    0.009578] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.009579] CPU features: detected: LSE atomic instructions
[    0.009580] CPU features: detected: Privileged Access Never
[    0.009581] CPU features: detected: RAS Extension Support
[    0.009584] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.024930] spectre-bhb mitigation disabled by command line option
[    0.038797] CPU: All CPU(s) started at EL2
[    0.040119] devtmpfs: initialized
[    0.052094] KASLR enabled
[    0.052209] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.052223] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.054511] pinctrl core: initialized pinctrl subsystem
[    0.055077] SMBIOS 3.6.0 present.
[    0.055087] DMI: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[    0.055399] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.056619] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.056664] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.056693] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.056724] audit: initializing netlink subsys (disabled)
[    0.056791] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
[    0.057759] thermal_sys: Registered thermal governor 'step_wise'
[    0.057761] thermal_sys: Registered thermal governor 'user_space'
[    0.057763] thermal_sys: Registered thermal governor 'power_allocator'
[    0.059739] cpuidle: using governor menu
[    0.059880] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.059953] ASID allocator initialised with 32768 entries
[    0.061141] Serial: AMBA PL011 UART driver
[    0.071307] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[    0.080420] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.087911] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.087915] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.087917] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.087918] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.088417] cryptd: max_cpu_qlen set to 1000
[    0.089423] ACPI: Interpreter disabled.
[    0.090455] VDD_1V8_AO: supplied by VDD_5V0_SYS
[    0.090558] VDD_3V3_AO: supplied by VDD_5V0_SYS
[    0.090785] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[    0.091063] iommu: Default domain type: Translated
[    0.091066] iommu: DMA domain TLB invalidation policy: strict mode
[    0.091247] SCSI subsystem initialized
[    0.091372] vgaarb: loaded
[    0.091469] usbcore: registered new interface driver usbfs
[    0.091482] usbcore: registered new interface driver hub
[    0.091492] usbcore: registered new device driver usb
[    0.091868] pps_core: LinuxPPS API ver. 1 registered
[    0.091870] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.091876] PTP clock support registered
[    0.091934] EDAC MC: Ver: 3.0.0
[    0.092581] Registered efivars operations
[    0.093048] FPGA manager framework
[    0.093104] Advanced Linux Sound Architecture Driver Initialized.
[    0.093588] clocksource: Switched to clocksource arch_sys_counter
[    0.112907] VFS: Disk quotas dquot_6.6.0
[    0.112942] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.113058] pnp: PnP ACPI: disabled
[    0.115203] NET: Registered PF_INET protocol family
[    0.115303] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.116136] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.116147] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.116152] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.116190] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.116464] TCP: Hash tables configured (established 32768 bind 32768)
[    0.116541] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.116555] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.116633] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.116821] RPC: Registered named UNIX socket transport module.
[    0.116824] RPC: Registered udp transport module.
[    0.116824] RPC: Registered tcp transport module.
[    0.116825] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.116832] PCI: CLS 0 bytes, default 64
[    0.116964] Unpacking initramfs...
[    0.126249] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.126412] kvm [1]: IPA Size Limit: 48 bits
[    0.126430] kvm [1]: GICv3: no GICV resource entry
[    0.126433] kvm [1]: disabling GICv2 emulation
[    0.126446] kvm [1]: GIC system register CPU interface enabled
[    0.126503] kvm [1]: vgic interrupt IRQ9
[    0.126600] kvm [1]: VHE mode initialized successfully
[    0.128582] Initialise system trusted keyrings
[    0.128651] workingset: timestamp_bits=42 max_order=20 bucket_order=0
[    0.131034] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.131316] NFS: Registering the id_resolver key type
[    0.131335] Key type id_resolver registered
[    0.131336] Key type id_legacy registered
[    0.131370] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.131379] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.131391] ntfs: driver 2.1.32 [Flags: R/O].
[    0.131518] 9p: Installing v9fs 9p2000 file system support
[    0.146091] Key type asymmetric registered
[    0.146095] Asymmetric key parser 'x509' registered
[    0.146133] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.146137] io scheduler mq-deadline registered
[    0.146140] io scheduler kyber registered
[    0.153765] EINJ: ACPI disabled.
[    0.162838] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.164039] SuperH (H)SCI(F) driver initialized
[    0.164323] msm_serial: driver initialized
[    0.164770] printk: console [ttyTCU0] enabled
[    0.165490] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.165493] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.165496] arm-smmu 8000000.iommu:  stage 1 translation
[    0.165499] arm-smmu 8000000.iommu:  stage 2 translation
[    0.165501] arm-smmu 8000000.iommu:  nested translation
[    0.165505] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    0.165509] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    0.165516] arm-smmu 8000000.iommu:  Supported page sizes: 0x61311000
[    0.165518] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    0.165520] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    0.166338] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.166340] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.166342] arm-smmu 10000000.iommu:         stage 1 translation
[    0.166343] arm-smmu 10000000.iommu:         stage 2 translation
[    0.166344] arm-smmu 10000000.iommu:         nested translation
[    0.166345] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    0.166348] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    0.166352] arm-smmu 10000000.iommu:         Supported page sizes: 0x61311000
[    0.166353] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.166355] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.166699] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.166702] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.166704] arm-smmu 12000000.iommu:         stage 1 translation
[    0.166705] arm-smmu 12000000.iommu:         stage 2 translation
[    0.166706] arm-smmu 12000000.iommu:         nested translation
[    0.166708] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    0.166710] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    0.166717] arm-smmu 12000000.iommu:         Supported page sizes: 0x61311000
[    0.166718] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.166719] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.171171] loop: module loaded
[    0.171704] megasas: 07.717.02.00-rc1
[    0.174733] tun: Universal TUN/TAP device driver, 1.6
[    0.175171] thunder_xcv, ver 1.0
[    0.175189] thunder_bgx, ver 1.0
[    0.175202] nicpf, ver 1.0
[    0.175853] hclge is initializing
[    0.175868] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.175872] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.175894] e1000: Intel(R) PRO/1000 Network Driver
[    0.175897] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.175915] e1000e: Intel(R) PRO/1000 Network Driver
[    0.175917] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.175932] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.175934] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.175946] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.175949] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.176109] sky2: driver version 1.30
[    0.176647] VFIO - User Level meta-driver version: 0.3
[    0.177776] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.177781] ehci-pci: EHCI PCI platform driver
[    0.177797] ehci-platform: EHCI generic platform driver
[    0.177862] ehci-orion: EHCI orion driver
[    0.177912] ehci-exynos: EHCI Exynos driver
[    0.177961] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.177971] ohci-pci: OHCI PCI platform driver
[    0.177986] ohci-platform: OHCI generic platform driver
[    0.178045] ohci-exynos: OHCI Exynos driver
[    0.178398] usbcore: registered new interface driver usb-storage
[    0.179853] i2c_dev: i2c /dev entries driver
[    0.180925] pps pps0: new PPS source ktimer
[    0.180930] pps pps0: ktimer PPS source registered
[    0.180935] pps_ldisc: PPS line discipline registered
[    0.182681] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.183829] sdhci: Secure Digital Host Controller Interface driver
[    0.183831] sdhci: Copyright(c) Pierre Ossman
[    0.184226] Synopsys Designware Multimedia Card Interface Driver
[    0.184759] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.185718] ledtrig-cpu: registered to indicate activity on CPUs
[    0.186367] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.186631] tegra-bpmp bpmp: Adding to iommu group 0
[    0.187451] tegra-bpmp bpmp: firmware: 4f590cddd4eeb67cd15b-3b0e1a33cf8
[    0.317547] Freeing initrd memory: 11444K
[    3.208595] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    3.208612] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    3.208619] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    3.208873] hid: raw HID events driver (C) Jiri Kosina
[    3.209265] usbcore: registered new interface driver usbhid
[    3.209272] usbhid: USB HID core driver
[    3.214388] optee: probing for conduit method.
[    3.214448] optee: revision 3.22 (e7b5ff3f)
[    3.273898] optee: dynamic shared memory is enabled
[    3.274158] optee: initialized driver
[    3.277704] usbcore: registered new interface driver snd-usb-audio
[    3.279425] NET: Registered PF_PACKET protocol family
[    3.279641] 9pnet: Installing 9P2000 support
[    3.279759] Key type dns_resolver registered
[    3.281398] printk: console [tty0]: printing thread started
[    3.282282] printk: console [ttyTCU0]: printing thread started
[    3.282443] Loading compiled-in X.509 certificates
[    3.296192] Loaded X.509 cert 'Build time autogenerated kernel key: dbaa37291f9eb1704a33bc5cf19ca9266fdea8e6'
[    3.324574] gpio-394 (camera-control-output-low): hogged as output/low
[    3.364437] simple-framebuffer chosen:framebuffer: framebuffer at 0x17de00000, 0x960000 bytes
[    3.364457] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=1920x1200x32, linelength=8192
[    3.372462] Console: switching to colour frame buffer device 240x75
[    3.376644] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[    3.377532] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    3.379068] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    3.380265] serial-tegra 3100000.serial: RX in PIO mode
[    3.380273] serial-tegra 3100000.serial: TX in PIO mode
[    3.380346] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    3.381530] serial-tegra 3140000.serial: RX in PIO mode
[    3.381535] serial-tegra 3140000.serial: TX in PIO mode
[    3.381573] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[    3.384742] tegra_rtc c2a0000.rtc: registered as rtc1
[    3.384752] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.385329] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    3.389421] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    3.392536] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    3.395465] tegra-i2c c240000.i2c: Adding to iommu group 1
[    3.398167] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[    3.398743] tegra-i2c c250000.i2c: Adding to iommu group 1
[    3.401805] i2c i2c-2: Added multiplexed i2c bus 9
[    3.402076] i2c i2c-2: Added multiplexed i2c bus 10
[    3.402080] i2c-mux-gpio bus@0:cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    3.419163] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1572000 KHz, changing to: 1510400 KHz
[    3.421556] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1573000 KHz, changing to: 1510400 KHz
[    3.424141] tegra-xusb 3610000.usb: Adding to iommu group 2
[    3.440696] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[    3.440704] tegra-xusb 3610000.usb: xHCI Host Controller
[    3.440714] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[    3.441453] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[    3.441474] tegra-xusb 3610000.usb: irq 123, io mem 0x03610000
[    3.441596] tegra-xusb 3610000.usb: xHCI Host Controller
[    3.441601] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[    3.441605] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    3.441842] hub 1-0:1.0: USB hub found
[    3.441858] hub 1-0:1.0: 4 ports detected
[    3.442166] hub 2-0:1.0: USB hub found
[    3.442178] hub 2-0:1.0: 4 ports detected
[    3.444372] irq: IRQ221: trimming hierarchy from :bus@0:pmc@c360000
[    3.444431] irq: IRQ222: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    3.444476] irq: IRQ223: trimming hierarchy from :bus@0:pmc@c360000
[    3.444556] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.475761] ALSA device list:
[    3.475766]   No soundcards found.
[    3.485644] Freeing unused kernel memory: 7680K
[    3.485731] Run /init as init process
[    3.499276] Checking overlayfs setting...
[    3.510773] Overlayfs is disabled...
[    3.517229] Root device found: PARTUUID=43f345bd-5160-47b8-8dd2-4ad0d97748b3
[    3.781596] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    3.954530] hub 1-2:1.0: USB hub found
[    3.955833] hub 1-2:1.0: 4 ports detected
[    4.071006] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[    4.123400] hub 2-1:1.0: USB hub found
[    4.125732] hub 2-1:1.0: 4 ports detected
[    4.229593] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    4.665593] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[    4.788333] input: Dell KB216 Wired Keyboard as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.3/1-2.3:1.0/0003:413C:2113.0001/input/input1
[    4.845765] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-3610000.usb-2.3/input0
[    4.852347] input: Dell KB216 Wired Keyboard System Control as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.3/1-2.3:1.1/0003:413C:2113.0002/input/input2
[    4.909977] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.3/1-2.3:1.1/0003:413C:2113.0002/input/input3
[    4.910051] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-3610000.usb-2.3/input1
[    4.989777] usb 1-2.4: new low-speed USB device number 5 using tegra-xusb
[    5.104488] input: PixArt Lenovo USB Optical Mouse as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.4/1-2.4:1.0/0003:17EF:608D.0003/input/input4
[    5.104555] hid-generic 0003:17EF:608D.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-3610000.usb-2.4/input0
[    7.848447] tegra194-pcie 14100000.pcie: Adding to iommu group 3
[    7.850266] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    7.850289] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    7.850297] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    7.850301] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    7.850624] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    7.850627] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    7.885064] tegra-xudc 3550000.usb: Adding to iommu group 4
[    7.957779] tegra194-pcie 14100000.pcie: Link up
[    7.960568] tegra194-pcie 14100000.pcie: Link up
[    7.960630] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    7.960635] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    7.960639] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    7.960642] pci_bus 0001:00: root bus resource [bus 00-ff]
[    7.960643] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    7.960695] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    7.960865] pci 0001:00:00.0: PME# supported from D0 D3hot
[    7.964679] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    7.964854] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    7.965057] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    7.966125] pci 0001:01:00.0: supports D1 D2
[    7.966127] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    7.980959] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    7.980964] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    7.980967] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    7.981071] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    7.981103] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    7.981106] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    7.981110] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    7.981226] pcieport 0001:00:00.0: Adding to iommu group 3
[    7.981322] pcieport 0001:00:00.0: PME: Signaling with IRQ 191
[    7.982023] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[    7.982862] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[    7.985614] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    7.985630] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    7.985636] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    7.985641] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    7.986304] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    7.986306] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.093860] tegra194-pcie 14160000.pcie: Link up
[    8.094896] tegra194-pcie 14160000.pcie: Link up
[    8.094962] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    8.094967] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    8.094970] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    8.094973] pci_bus 0004:00: root bus resource [bus 00-ff]
[    8.094974] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    8.095016] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    8.095166] pci 0004:00:00.0: PME# supported from D0 D3hot
[    8.098867] pci 0004:01:00.0: [10ec:5765] type 00 class 0x010802
[    8.099064] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    8.099307] pci 0004:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[    8.112910] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    8.112916] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    8.113004] pci 0004:01:00.0: BAR 5: assigned [mem 0x2428004000-0x2428005fff]
[    8.113031] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    8.113036] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    8.113136] pcieport 0004:00:00.0: Adding to iommu group 5
[    8.113223] pcieport 0004:00:00.0: PME: Signaling with IRQ 193
[    8.114098] pcieport 0004:00:00.0: AER: enabled with IRQ 193
[    8.114396] nvme 0004:01:00.0: Adding to iommu group 5
[    8.114623] nvme nvme0: pci function 0004:01:00.0
[    8.114857] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    8.115257] tegra194-pcie 141e0000.pcie: Adding to iommu group 6
[    8.116504] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[    8.116519] tegra194-pcie 141e0000.pcie:      MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[    8.116527] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    8.116531] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    8.116845] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[    8.116847] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.265500] nvme nvme0: allocated 64 MiB host memory buffer.
[    8.301256] nvme nvme0: 6/0/0 default/read/poll queues
[    8.324425] nvme nvme0: Ignoring bogus Namespace Identifiers
[    8.334568]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    8.449817] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    8.454698] Rootfs mounted over PARTUUID=43f345bd-5160-47b8-8dd2-4ad0d97748b3
[    8.465093] Switching from initrd to actual rootfs
[    8.468619] Kernel panic - not syncing:
[    8.468623] Attempted to kill init! exitcode=0x00007f00
[    8.468628] CPU: 1 PID: 1 Comm: chroot Not tainted 5.15.136-tegra #1
[    8.468633] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[    8.468636] Call trace:
[    8.468637]  dump_backtrace+0x0/0x1d0
[    8.468653]  show_stack+0x34/0x50
[    8.468658]  dump_stack_lvl+0x68/0x8c
[    8.468667]  dump_stack+0x18/0x3c
[    8.468672]  panic+0xc4/0x398
[    8.468676]  do_exit+0xa1c/0xa50
[    8.468681]  do_group_exit+0x44/0xb0
[    8.468684]  __arm64_sys_exit_group+0x2c/0x30
[    8.468688]  invoke_syscall+0x5c/0x150
[    8.468692]  el0_svc_common.constprop.0+0x64/0x120
[    8.468695]  do_el0_svc+0x74/0xb0
[    8.468699]  el0_svc+0x28/0x90
[    8.468701]  el0t_64_sync_handler+0xac/0x130
[    8.468703]  el0t_64_sync+0x1a4/0x1a8
burn.txt (306.7 KB)
I burn the process
According to the command you said, the result is the same。
Using the default desktop and mini rootfs is fine.
tar -x -I 'zstd -T0' -pf /mnt/external/system.img  --checkpoint=10000 --warning=no-timestamp --numeric-owner --xattrs --xattrs-include=*  -C  /tmp/ci-JPsARjRNnu
tar (child): zstd -T0: Cannot exec: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
It seems you hit the same issue as the following thread, please check if it could help for your case.
Jetson Orin Nano devkit flash failing - #3 by DaveYYY
Hello, I refer to the example you gave.
Execute the operation grep -nr ‘zstd’
The problem is still solved.
1722480002534
Do you mean that you can flash the board successfully now?
failure
Please add zstd into Linux_for_Tegra/tools/samplefs/nvubuntu-jammy-basic-aarch64-packages and build the sample rootfs again.
You need to do this…
Sorry! I’m a newbie.
I didn’t quite understand the "Linux_for_Tegra/tools/samplefs/nvubuntu-jammy-basic-aarch64-packages. "Operate there.
zynq@ubuntu:~/nvidia/Linux_for_Tegra/tools/samplefs$ sudo docker run --privileged -it --rm -v ~/nvidia/Linux_for_Tegra:/l4t ubuntu:22.04
root@eedc8d0f5df7:/#
root@eedc8d0f5df7:/# cd /l4t/tools/samplefs/
root@eedc8d0f5df7:/l4t/tools/samplefs# Linux_for_Tegra/tools/samplefs/nvubuntu-jammy-basic-aarch64-packages
bash: Linux_for_Tegra/tools/samplefs/nvubuntu-jammy-basic-aarch64-packages: No such file or directory
root@eedc8d0f5df7:/l4t/tools/samplefs# sudo ./nv_build_samplefs.sh --abi aarch64 --distro ubuntu --flavor basic --version jammy
Excuse me, I am operating in the wrong way, how should I operate?
please add zstd into Linux_for_Tegra/tools/samplefs/nvubuntu-jammy-basic-aarch64-packages and build the sample rootfs again.
I don’t quite get the meaning。
do you have <Linux_for_Tegra>/tools/samplefs/nvubuntu-jammy-basic-aarch64-packages on your host?
Thanks, problem solved install zstd
