Are you using p3509 like custom carrier board for Orin Nano?
=> yes, for this case it’s pretty similar.
=> L4T 35.3.1
What’s your board config in use? Could you share the board config for further check?
=> It’s the io-expander, irq should report when the downstream gpio input gets low.
Please also share the full dmesg for further check.
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6289-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Sun Mar 19 07:55:28 PDT 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: TechNexion TEK6040-ORIN with NVIDIA Orin Nano 8 GB
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x15f4fae98 SMBIOS=0xffff0000 SMBIOS 3.0=0x1412d0000 MEMATTR=0x13fb39018 ESRT=0x13fc2c818 RNG=0x164536c98 MEMRESERVE=0x13fb3bf18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x000000013fc2c818 to 0x000000013fc2c850.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000154400000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000016fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000013bffffff]
[ 0.000000] node 0: [mem 0x000000013c000000-0x000000013e1bffff]
[ 0.000000] node 0: [mem 0x000000013e1c0000-0x000000013facffff]
[ 0.000000] node 0: [mem 0x000000013fad0000-0x000000013fafffff]
[ 0.000000] node 0: [mem 0x000000013fb00000-0x000000013fb3ffff]
[ 0.000000] node 0: [mem 0x000000013fb40000-0x000000013fbdffff]
[ 0.000000] node 0: [mem 0x000000013fbe0000-0x000000013fbeffff]
[ 0.000000] node 0: [mem 0x000000013fbf0000-0x000000013fc0ffff]
[ 0.000000] node 0: [mem 0x000000013fc10000-0x0000000140d27fff]
[ 0.000000] node 0: [mem 0x0000000140d28000-0x0000000140e88fff]
[ 0.000000] node 0: [mem 0x0000000140e89000-0x00000001412bffff]
[ 0.000000] node 0: [mem 0x00000001412c0000-0x00000001412dffff]
[ 0.000000] node 0: [mem 0x00000001412e0000-0x000000014160ffff]
[ 0.000000] node 0: [mem 0x0000000141610000-0x000000014165ffff]
[ 0.000000] node 0: [mem 0x0000000141660000-0x000000014181ffff]
[ 0.000000] node 0: [mem 0x0000000141820000-0x00000001419fffff]
[ 0.000000] node 0: [mem 0x0000000141a00000-0x0000000141a8ffff]
[ 0.000000] node 0: [mem 0x0000000141a90000-0x0000000141c6ffff]
[ 0.000000] node 0: [mem 0x0000000141c70000-0x0000000141ccffff]
[ 0.000000] node 0: [mem 0x0000000141cd0000-0x0000000141dbffff]
[ 0.000000] node 0: [mem 0x0000000141dc0000-0x0000000141deffff]
[ 0.000000] node 0: [mem 0x0000000141df0000-0x0000000141dfffff]
[ 0.000000] node 0: [mem 0x0000000141e00000-0x0000000141eaffff]
[ 0.000000] node 0: [mem 0x0000000141eb0000-0x0000000141f4ffff]
[ 0.000000] node 0: [mem 0x0000000141f50000-0x000000014204ffff]
[ 0.000000] node 0: [mem 0x0000000142050000-0x00000001420effff]
[ 0.000000] node 0: [mem 0x00000001420f0000-0x00000001421effff]
[ 0.000000] node 0: [mem 0x00000001421f0000-0x000000014228ffff]
[ 0.000000] node 0: [mem 0x0000000142290000-0x0000000142b5ffff]
[ 0.000000] node 0: [mem 0x0000000142b60000-0x0000000142d3ffff]
[ 0.000000] node 0: [mem 0x0000000142d40000-0x00000001644effff]
[ 0.000000] node 0: [mem 0x00000001644f0000-0x000000016453ffff]
[ 0.000000] node 0: [mem 0x0000000164540000-0x0000000167ffffff]
[ 0.000000] node 0: [mem 0x0000000168200000-0x000000016860ffff]
[ 0.000000] node 0: [mem 0x000000016e000000-0x000000016fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000016fffffff]
[ 0.000000] On node 0, zone Normal: 496 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 944144
[ 0.000000] Kernel command line: root=PARTUUID=d525442a-0937-48f9-83f2-7b14640e3d17 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000e8680000-0x00000000f8680000] (256MB)
[ 0.000000] Memory: 3115052K/3838016K available (18496K kernel code, 3168K rwdata, 7172K rodata, 3968K init, 1418K bss, 460820K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000639] Console: colour dummy device 80x25
[ 0.000682] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000690] pid_max: default: 32768 minimum: 301
[ 0.000751] LSM: Security Framework initializing
[ 0.000774] Yama: becoming mindful.
[ 0.000793] SELinux: Initializing.
[ 0.000852] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000862] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001906] rcu: Hierarchical SRCU implementation.
[ 0.001999] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.002396] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0003-tek-orin-a1.dts
[ 0.002400] DTB Build time: Oct 3 2023 18:26:11
[ 0.003625] Tegra Revision: A01 SKU: 0xd6 CPU Process: 0 SoC Process: 0
[ 0.003793] Remapping and enabling EFI services.
[ 0.005009] smp: Bringing up secondary CPUs ...
[ 0.033712] Detected PIPT I-cache on CPU1
[ 0.033749] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.033788] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.062441] Detected PIPT I-cache on CPU2
[ 0.062452] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.062467] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.091074] Detected PIPT I-cache on CPU3
[ 0.091084] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.091099] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.122361] Detected PIPT I-cache on CPU4
[ 0.122387] GICv3: CPU4: found redistributor 20200 region 0:0x000000000f580000
[ 0.122417] CPU4: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.151719] Detected PIPT I-cache on CPU5
[ 0.151731] GICv3: CPU5: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.151747] CPU5: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.151813] smp: Brought up 1 node, 6 CPUs
[ 0.151827] SMP: Total of 6 processors activated.
[ 0.151831] CPU features: detected: Privileged Access Never
[ 0.151832] CPU features: detected: LSE atomic instructions
[ 0.151834] CPU features: detected: User Access Override
[ 0.151836] CPU features: detected: 32-bit EL0 Support
[ 0.151839] CPU features: detected: Common not Private translations
[ 0.151841] CPU features: detected: RAS Extension Support
[ 0.151842] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.151845] CPU features: detected: CRC32 instructions
[ 0.151847] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.189040] CPU: All CPU(s) started at EL2
[ 0.190803] devtmpfs: initialized
[ 0.206830] Registered cp15_barrier emulation handler
[ 0.206839] Registered setend emulation handler
[ 0.206845] KASLR enabled
[ 0.206972] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.206984] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.208958] pinctrl core: initialized pinctrl subsystem
[ 0.209516] SMBIOS 3.0.0 present.
[ 0.209525] DMI: Unknown NVIDIA Orin Nano Developer Kit/NVIDIA Orin Nano Developer Kit, BIOS 3.1-32827747 03/19/2023
[ 0.209827] NET: Registered protocol family 16
[ 0.210732] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.210770] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.210800] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.210831] audit: initializing netlink subsys (disabled)
[ 0.210932] audit: type=2000 audit(0.208:1): state=initialized audit_enabled=0 res=1
[ 0.211125] thermal_sys: Registered thermal governor 'step_wise'
[ 0.211128] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.211131] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.212004] cpuidle: using governor menu
[ 0.212137] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.212211] ASID allocator initialised with 32768 entries
[ 0.212317] Serial: AMBA PL011 UART driver
[ 0.214228] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.214262] Tegra reboot handler registered.
[ 0.235516] mc: mapped MMIO address: 0xffff800010630000 -> 0x2c10000
[ 0.235529] mc: mapped MMIO address: 0xffff800010650000 -> 0x2c20000
[ 0.235537] mc: mapped MMIO address: 0xffff800010670000 -> 0x2c30000
[ 0.235545] mc: mapped MMIO address: 0xffff800010690000 -> 0x2c40000
[ 0.235552] mc: mapped MMIO address: 0xffff8000106b0000 -> 0x2c50000
[ 0.235558] mc: mapped MMIO address: 0xffff8000106d0000 -> 0x2b80000
[ 0.235566] mc: mapped MMIO address: 0xffff8000106f0000 -> 0x2b90000
[ 0.235572] mc: mapped MMIO address: 0xffff800010710000 -> 0x2ba0000
[ 0.235579] mc: mapped MMIO address: 0xffff800010730000 -> 0x2bb0000
[ 0.235586] mc: mapped MMIO address: 0xffff800010750000 -> 0x1700000
[ 0.235592] mc: mapped MMIO address: 0xffff800010770000 -> 0x1710000
[ 0.235599] mc: mapped MMIO address: 0xffff800010790000 -> 0x1720000
[ 0.235605] mc: mapped MMIO address: 0xffff8000107b0000 -> 0x1730000
[ 0.235612] mc: mapped MMIO address: 0xffff8000107d0000 -> 0x1740000
[ 0.235619] mc: mapped MMIO address: 0xffff8000107f0000 -> 0x1750000
[ 0.235627] mc: mapped MMIO address: 0xffff800010810000 -> 0x1760000
[ 0.235633] mc: mapped MMIO address: 0xffff800010830000 -> 0x1770000
[ 0.235643] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.235671] mc-err: mcerr ops are set to t23x
[ 0.236487] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 66, base_baud = 0) is a SBSA
[ 1.383612] printk: console [ttyAMA0] enabled
[ 1.392580] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.399288] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.405988] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.412686] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.421488] ACPI: Interpreter disabled.
[ 1.425797] ddr-vddq: supplied by vdd-5v
[ 1.429949] ddr-vdd2: supplied by vdd-5v
[ 1.434008] vdd-AO-1v2: supplied by vdd-5v
[ 1.438256] vdd-3v3: supplied by vdd-5v
[ 1.442297] vdd-rtc: supplied by vdd-AO-1v2
[ 1.446605] vdd-0v95-uphy: supplied by vdd-AO-1v2
[ 1.451443] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[ 1.456435] vdd-1v8: supplied by vdd-3v3-sys
[ 1.460833] vdd-3v3-AO: supplied by vdd-5v-sys
[ 1.465398] vdd-av10-hub: supplied by vdd-5v-sys
[ 1.470151] vdd-vbus-a: supplied by vdd-5v-sys
[ 1.474711] vdd-vbus-b: supplied by vdd-5v-sys
[ 1.479280] vdd-3v3-dp: supplied by vdd-3v3-sys
[ 1.484101] iommu: Default domain type: Translated
[ 1.489023] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.495328] SCSI subsystem initialized
[ 1.499161] usbcore: registered new interface driver usbfs
[ 1.504658] usbcore: registered new interface driver hub
[ 1.509978] usbcore: registered new device driver usb
[ 1.515247] mc: Linux media interface: v0.10
[ 1.519528] videodev: Linux video capture interface: v2.00
[ 1.525195] pps_core: LinuxPPS API ver. 1 registered
[ 1.530159] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.539295] PTP clock support registered
[ 1.543474] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.550631] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.558341] Registered efivars operations
[ 1.562865] FPGA manager framework
[ 1.566314] Advanced Linux Sound Architecture Driver Initialized.
[ 1.572695] Bluetooth: Core ver 2.22
[ 1.576278] NET: Registered protocol family 31
[ 1.580720] Bluetooth: HCI device and connection manager initialized
[ 1.587076] Bluetooth: HCI socket layer initialized
[ 1.591956] Bluetooth: L2CAP socket layer initialized
[ 1.597012] Bluetooth: SCO socket layer initialized
[ 1.602440] camchar: rtcpu character device driver loaded
[ 1.608086] clocksource: Switched to clocksource arch_sys_counter
[ 1.809734] VFS: Disk quotas dquot_6.6.0
[ 1.813698] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.820743] pnp: PnP ACPI: disabled
[ 1.826455] la/ptsa driver initialized.
[ 1.830356] NET: Registered protocol family 2
[ 1.834809] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 1.843095] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 1.851638] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 1.859594] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 1.867171] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.873778] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 1.880493] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 1.887713] NET: Registered protocol family 1
[ 1.892290] RPC: Registered named UNIX socket transport module.
[ 1.898214] RPC: Registered udp transport module.
[ 1.902924] RPC: Registered tcp transport module.
[ 1.907626] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.914071] PCI: CLS 0 bytes, default 64
[ 1.918093] Trying to unpack rootfs image as initramfs...
[ 2.078564] Freeing initrd memory: 9120K
[ 2.084691] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.092641] kvm [1]: IPA Size Limit: 48 bits
[ 2.096931] kvm [1]: GICv3: no GICV resource entry
[ 2.101720] kvm [1]: disabling GICv2 emulation
[ 2.106178] kvm [1]: GIC system register CPU interface enabled
[ 2.112073] kvm [1]: vgic interrupt IRQ9
[ 2.116130] kvm [1]: VHE mode initialized successfully
[ 2.121930] Initialise system trusted keyrings
[ 2.126462] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 2.135462] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.141630] NFS: Registering the id_resolver key type
[ 2.146698] Key type id_resolver registered
[ 2.150879] Key type id_legacy registered
[ 2.154927] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.161636] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.169040] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.188115] NET: Registered protocol family 38
[ 2.192563] Key type asymmetric registered
[ 2.196658] Asymmetric key parser 'x509' registered
[ 2.201556] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.209017] io scheduler mq-deadline registered
[ 2.213550] io scheduler kyber registered
[ 2.221955] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.227554] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.233145] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.238733] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[ 2.245208] efifb: probing for efifb
[ 2.248814] efifb: framebuffer at 0x13c000000, using 8640k, total 8640k
[ 2.255430] efifb: mode is 1920x1080x32, linelength=8192, pages=1
[ 2.261525] efifb: scrolling: redraw
[ 2.265098] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 2.274474] Console: switching to colour frame buffer device 240x67
[ 2.284253] fb0: EFI VGA frame buffer device
[ 2.290373] tegra_dc_assign_hw_data: no matching compatible node
[ 2.296386] tegradccommon module_init failed
[ 2.300654] tegradc module_init failed
[ 2.304685] EINJ: ACPI disabled.
[ 2.309682] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.316565] tegra-pmc: ### PMC reset source: MAINSWRST
[ 2.321704] tegra-pmc: ### PMC reset level: L1
[ 2.326143] tegra-pmc: ### PMC reset status reg: 0x2d
[ 2.332615] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 3.771323] random: fast init done
[ 3.957337] printk: console [ttyTCU0] enabled
[ 3.962420] arm-smmu 12000000.iommu: probing hardware configuration...
[ 3.969119] arm-smmu 12000000.iommu: SMMUv2 with:
[ 3.973943] arm-smmu 12000000.iommu: stage 1 translation
[ 3.979478] arm-smmu 12000000.iommu: stage 2 translation
[ 3.985016] arm-smmu 12000000.iommu: nested translation
[ 3.990466] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 3.997872] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.007043] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.013744] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.020437] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.027997] arm-smmu 10000000.iommu: probing hardware configuration...
[ 4.034692] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.039519] arm-smmu 10000000.iommu: stage 1 translation
[ 4.045059] arm-smmu 10000000.iommu: stage 2 translation
[ 4.050590] arm-smmu 10000000.iommu: nested translation
[ 4.056036] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.063442] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.072694] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.079383] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.086078] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.093264] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.099868] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.104606] arm-smmu 8000000.iommu: stage 1 translation
[ 4.110057] arm-smmu 8000000.iommu: stage 2 translation
[ 4.115501] arm-smmu 8000000.iommu: nested translation
[ 4.120856] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.120860] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.123132] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.141585] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.148190] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.155496] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.165353] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.171330] tegra_profiler: auth: init
[ 4.175492] nvsciipc: loaded module
[ 4.180847] tun: Universal TUN/TAP device driver, 1.6
[ 4.186570] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.193986] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.199459] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.204555] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.210646] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.216186] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.222085] PPP generic driver version 2.4.2
[ 4.226521] PPP BSD Compression module registered
[ 4.231350] PPP Deflate Compression module registered
[ 4.236548] PPP MPPE Compression module registered
[ 4.241494] usbcore: registered new interface driver r8152
[ 4.247128] usbcore: registered new interface driver asix
[ 4.252682] usbcore: registered new interface driver ax88179_178a
[ 4.258938] usbcore: registered new interface driver cdc_ether
[ 4.264934] usbcore: registered new interface driver net1080
[ 4.270747] usbcore: registered new interface driver cdc_subset
[ 4.276834] usbcore: registered new interface driver zaurus
[ 4.282562] usbcore: registered new interface driver cdc_ncm
[ 4.288377] usbcore: registered new interface driver aqc111
[ 4.294232] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.300589] ohci-pci: OHCI PCI platform driver
[ 4.305157] ohci-platform: OHCI generic platform driver
[ 4.310890] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.317263] usbcore: registered new interface driver uas
[ 4.322738] usbcore: registered new interface driver usb-storage
[ 4.329088] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.335179] mousedev: PS/2 mouse device common for all mice
[ 4.340924] usbcore: registered new interface driver xpad
[ 4.348381] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.353853] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:27 UTC (27)
[ 4.362099] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.368502] i2c /dev entries driver
[ 4.372232] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.378032] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.383739] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.389425] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.395105] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.400786] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.406463] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.412141] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.421164] device-mapper: uevent: version 1.0.3
[ 4.426000] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.435739] sdhci: Secure Digital Host Controller Interface driver
[ 4.442080] sdhci: Copyright(c) Pierre Ossman
[ 4.446546] Synopsys Designware Multimedia Card Interface Driver
[ 4.452803] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.458977] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[ 4.459207] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.472461] tegra-bpmp bpmp: firmware: f0fadc45ec6216cb5b0b-1377b684fe5
[ 4.480581] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.486041] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 4.495055] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.500971] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��Failed to create /rm/vdd_cpu
debugfs initialized
��[ 5.623899] hid: raw HID events driver (C) Jiri Kosina
[ 5.629756] usbcore: registered new interface driver usbhid
[ 5.635484] usbhid: USB HID core driver
[ 5.639916] tegra-dce d800000.dce: Adding to iommu group 4
[ 5.646555] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 5.655142] tegra234-aon c000000.aon: Adding to iommu group 5
[ 5.661776] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 5.668710] c000000.aon:hsp: probed
[ 5.670759] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 5.683172] tegra234-aon c000000.aon: init done
[ 5.683611] tegra23x-psc e860000.psc: Adding to iommu group 6
[ 5.687855] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 5.694069] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 5.700755] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 5.707054] tegra23x-psc e860000.psc: init done
[ 5.716007] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 5.716008] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 5.716018] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 5.720844] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[ 5.729052] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 5.729181] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 5.738680] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.746591] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 5.746592] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 5.746602] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 5.755727] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 5.761201] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 5.769752] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 5.830053] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 5.841863] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 5.853780] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 5.866348] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 5.879168] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 5.891382] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (114)
[ 5.898186] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 5.906849] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=97e50cbff52bc4b542b2989187109c001c01cf77
[ 5.920512] t19x_cache tegra-cache: probed
[ 5.924955] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 5.935398] optee: probing for conduit method.
[ 5.939998] optee: revision 3.19 (3f29c61f)
[ 5.940806] optee: dynamic shared memory is enabled
[ 5.950248] optee: initialized driver
[ 5.964973] nvpmodel: initialized successfully
[ 5.969668] tegra_hv: get_hvd: not initialized yet
[ 5.974613] user_ivc_mempool: hypervisor not present
[ 5.980540] usbcore: registered new interface driver snd-usb-audio
[ 5.987670] u32 classifier
[ 5.990456] input device check on
[ 5.994224] Actions configured
[ 5.997877] Initializing XFRM netlink socket
[ 6.002724] NET: Registered protocol family 10
[ 6.008632] Segment Routing with IPv6
[ 6.012492] NET: Registered protocol family 17
[ 6.017081] NET: Registered protocol family 15
[ 6.021704] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.035398] Bluetooth: RFCOMM socket layer initialized
[ 6.040698] Bluetooth: RFCOMM ver 1.11
[ 6.044563] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.050643] Bluetooth: HIDP socket layer initialized
[ 6.056615] 9pnet: Installing 9P2000 support
[ 6.061048] Key type dns_resolver registered
[ 6.065964] registered taskstats version 1
[ 6.070190] Loading compiled-in X.509 certificates
[ 6.087412] Loaded X.509 cert 'Build time autogenerated kernel key: e63fb224cdc2a940ac382bb67b420fcb52cc4aee'
[ 6.098209] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[ 6.111428] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.119893] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[ 6.132519] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.139441] tegra194-pcie 141e0000.pcie: Adding to iommu group 10
[ 6.151955] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 6.158906] tegra194-pcie 140a0000.pcie: Adding to iommu group 11
[ 6.171378] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 6.204740] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.215980] host1x 13e40000.host1x: Adding to iommu group 13
[ 6.244260] host1x 13e40000.host1x: initialized
[ 6.249391] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 6.257428] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.269787] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 6.277797] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.290072] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 6.298033] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.310318] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 6.318291] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.330558] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 6.338520] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.350820] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 6.358788] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.371082] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 6.379119] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.391414] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 6.399393] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.411689] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 6.419680] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 6.431961] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 6.439939] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 6.452224] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 6.460237] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 6.472514] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 6.480509] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 6.492809] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 6.500775] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 6.513057] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 6.521092] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 6.533368] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 6.541342] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.553620] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 6.561597] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.573927] falcon 15340000.vic: Adding to iommu group 30
[ 6.584944] falcon 15340000.vic: initialized
[ 6.589699] falcon 15380000.nvjpg: Adding to iommu group 31
[ 6.599169] falcon 15380000.nvjpg: initialized
[ 6.603890] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 6.613180] falcon 15540000.nvjpg1: initialized
[ 6.617991] falcon 15a50000.ofa: Adding to iommu group 33
[ 6.626322] falcon 15a50000.ofa: initialized
[ 6.630873] nvdec 15480000.nvdec: Adding to iommu group 34
[ 6.643538] nvdec 15480000.nvdec: initialized
[ 6.648194] tsec 15500000.tsec: Adding to iommu group 35
[ 6.658206] tsec 15500000.tsec: initialized
[ 6.665129] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.682121] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.699265] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 6.706700] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 6.713686] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.720056] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 6.726485] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.732697] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[ 6.740700] tegra194-isp5 14800000.isp: Adding to iommu group 36
[ 6.749126] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.758805] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 6.765170] driver not enabled, cannot register any devices
[ 6.771085] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[ 6.779273] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[ 6.787314] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.797328] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 6.804157] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 6.814143] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 6.820954] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.830952] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 6.837865] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 6.845035] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 6.852540] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.859172] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.865928] serial-tegra 3100000.serial: Adding to iommu group 2
[ 6.872524] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[ 6.882302] serial-tegra 3110000.serial: Adding to iommu group 2
[ 6.888874] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 63, base_baud = 0) is a TEGRA_UART
[ 6.898576] serial-tegra 3130000.serial: Adding to iommu group 2
[ 6.905097] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 6.914789] serial-tegra 3140000.serial: Adding to iommu group 2
[ 6.921291] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 6.947653] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 6.957418] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.963000] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 6.971677] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 6.981306] tegra-xusb 3610000.xhci: irq 220, io mem 0x03610000
[ 6.987777] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 6.996275] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.003703] usb usb1: Product: xHCI Host Controller
[ 7.008712] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 7.014977] usb usb1: SerialNumber: 3610000.xhci
[ 7.020556] hub 1-0:1.0: USB hub found
[ 7.024450] hub 1-0:1.0: 4 ports detected
[ 7.028861] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.034423] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.042220] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.049776] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.058283] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.065712] usb usb2: Product: xHCI Host Controller
[ 7.070718] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 7.076977] usb usb2: SerialNumber: 3610000.xhci
[ 7.082296] hub 2-0:1.0: USB hub found
[ 7.086169] hub 2-0:1.0: 4 ports detected
[ 7.095453] irq: IRQ284: trimming hierarchy from :pmc@c360000
[ 7.101470] pca953x 0-0021: supply vcc not found, using dummy regulator
[ 7.108436] pca953x 0-0021: using no AI
[ 7.114426] gpiochip2: registered GPIOs 300 to 315 on 0-0021
[ 7.122993] irq: IRQ285: trimming hierarchy from :pmc@c360000
[ 7.128950] pca953x 1-0023: supply vcc not found, using dummy regulator
[ 7.135863] pca953x 1-0023: using no AI
[ 7.142846] gpiochip3: registered GPIOs 284 to 299 on 1-0023
[ 7.161009] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.181088] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1554000 KHz, changing to: 1510400 KHz
[ 7.195336] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1543000 KHz, changing to: 1510400 KHz
[ 7.207303] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 7.214357] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.222288] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.222999] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 7.234456] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 7.243160] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 7.251890] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 7.269634] irq: IRQ286: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.277308] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 286
[ 7.288300] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 7.450470] usb 1-2: New USB device found, idVendor=0424, idProduct=2807, bcdDevice= 6.23
[ 7.458898] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.466237] usb 1-2: Product: USB2807 Hub
[ 7.470351] usb 1-2: Manufacturer: Microchip
[ 7.475608] hub 1-2:1.0: USB hub found
[ 7.479814] hub 1-2:1.0: 7 ports detected
[ 7.480557] random: crng init done
[ 7.572464] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[ 7.601954] usb 2-1: New USB device found, idVendor=0424, idProduct=5807, bcdDevice= 6.23
[ 7.610410] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.617794] usb 2-1: Product: USB5807 Hub
[ 7.621928] usb 2-1: Manufacturer: Microchip
[ 7.629839] hub 2-1:1.0: USB hub found
[ 7.634324] hub 2-1:1.0: 7 ports detected
[ 7.792094] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[ 7.903706] usb 1-2.1: New USB device found, idVendor=045b, idProduct=0209, bcdDevice= 1.00
[ 7.912307] usb 1-2.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.920739] hub 1-2.1:1.0: USB hub found
[ 7.925322] hub 1-2.1:1.0: 4 ports detected
[ 7.988664] usb 2-1.1: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[ 8.021395] usb 2-1.1: New USB device found, idVendor=045b, idProduct=0210, bcdDevice= 1.00
[ 8.029979] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.042101] hub 2-1.1:1.0: USB hub found
[ 8.046711] hub 2-1.1:1.0: 4 ports detected
[ 8.100090] usb 1-2.3: new high-speed USB device number 4 using tegra-xusb
[ 8.215985] usb 1-2.3: New USB device found, idVendor=8564, idProduct=1000, bcdDevice=11.00
[ 8.224582] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.232100] usb 1-2.3: Product: Mass Storage Device
[ 8.237110] usb 1-2.3: Manufacturer: JetFlash
[ 8.241588] usb 1-2.3: SerialNumber: 20VF8Y26AJ9QBYJZ
[ 8.248189] usb-storage 1-2.3:1.0: USB Mass Storage device detected
[ 8.255728] scsi host0: usb-storage 1-2.3:1.0
[ 8.312089] usb 1-2.1.1: new low-speed USB device number 5 using tegra-xusb
[ 8.368211] tegra194-pcie 14100000.pcie: Phy link never came up
[ 8.374483] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.381316] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.386968] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.396822] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.407682] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.415664] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.422033] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.438934] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.444371] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.453543] pcieport 0001:00:00.0: Adding to iommu group 8
[ 8.459274] usb 1-2.1.1: New USB device found, idVendor=046d, idProduct=c31d, bcdDevice=66.01
[ 8.459610] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[ 8.468044] usb 1-2.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.468046] usb 1-2.1.1: Product: USB Keyboard
[ 8.468048] usb 1-2.1.1: Manufacturer: Logitech
[ 8.491574] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[ 8.497718] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 8.503963] pci 0001:00:00.0: Removing from iommu group 8
[ 8.509569] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 8.518074] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 8.525009] input: Logitech USB Keyboard as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1.1/1-2.1.1:1.0/0003:046D:C31D.0001/input/input0
[ 8.525785] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 8.545399] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 8.554083] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 8.562796] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 8.596852] hid-generic 0003:046D:C31D.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3610000.xhci-2.1.1/input0
[ 8.617407] input: Logitech USB Keyboard Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1.1/1-2.1.1:1.1/0003:046D:C31D.0002/input/input1
[ 8.680102] tegra194-pcie 14160000.pcie: Link up
[ 8.685642] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 8.688431] input: Logitech USB Keyboard System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1.1/1-2.1.1:1.1/0003:046D:C31D.0002/input/input2
[ 8.692466] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 8.708358] hid-generic 0003:046D:C31D.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3610000.xhci-2.1.1/input1
[ 8.712578] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 8.735426] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.746268] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.754229] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.760590] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.772254] pci 0004:01:00.0: [1987:5008] type 00 class 0x010802
[ 8.778690] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 8.792685] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 8.800131] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 8.808144] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.813544] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 8.820926] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.829710] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 8.838810] pcieport 0004:00:00.0: Adding to iommu group 9
[ 8.844088] usb 1-2.1.2: new low-speed USB device number 6 using tegra-xusb
[ 8.844778] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[ 8.857717] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[ 8.864000] nvme 0004:01:00.0: Adding to iommu group 9
[ 8.870150] nvme nvme0: pci function 0004:01:00.0
[ 8.875066] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 8.876054] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 8.888970] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 8.896177] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
[ 8.904956] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
[ 8.913685] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[ 8.927327] nvme nvme0: 6/0/0 default/read/poll queues
[ 8.936916] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 8.999324] usb 1-2.1.2: New USB device found, idVendor=0461, idProduct=4de2, bcdDevice= 2.00
[ 9.008099] usb 1-2.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 9.015790] usb 1-2.1.2: Product: USB Optical Mouse
[ 9.025710] input: USB Optical Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1.2/1-2.1.2:1.0/0003:0461:4DE2.0003/input/input3
[ 9.038623] hid-generic 0003:0461:4DE2.0003: input,hidraw2: USB HID v1.11 Mouse [USB Optical Mouse] on usb-3610000.xhci-2.1.2/input0
[ 9.461653] scsi 0:0:0:0: Direct-Access JetFlash Transcend 16GB 1100 PQ: 0 ANSI: 6
[ 9.473201] sd 0:0:0:0: [sda] 30197760 512-byte logical blocks: (15.5 GB/14.4 GiB)
[ 9.482362] sd 0:0:0:0: [sda] Write Protect is off
[ 9.488952] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 9.505671] sda: sda1
[ 9.511128] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 10.028115] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 10.034350] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 10.041184] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 10.046835] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[ 10.056961] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.067794] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[ 10.075745] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 10.082120] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 10.099100] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 10.104523] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.113710] pcieport 0007:00:00.0: Adding to iommu group 10
[ 10.119779] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[ 10.126054] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[ 10.132185] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 10.138348] pci 0007:00:00.0: Removing from iommu group 10
[ 10.144040] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 10.152338] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 10.159279] vdd-3v3-sd: supplied by vdd-3v3
[ 10.165828] tegra194-isp5 14800000.isp: initialized
[ 10.170891] driver not enabled, cannot register any devices
[ 10.179765] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 10.186145] driver not enabled, cannot register any devices
[ 10.192047] (NULL device *): fops function table already registered
[ 10.199609] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 10.206015] driver not enabled, cannot register any devices
[ 10.212782] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 10.212805] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 10.219824] irq: IRQ294: trimming hierarchy from :interrupt-controller@f400000-1
[ 10.244338] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 286
[ 10.340702] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[ 10.347907] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff -> 0x002a100000
[ 10.356627] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff -> 0x0040000000
[ 10.365322] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[ 10.480086] tegra194-pcie 140a0000.pcie: Link up
[ 10.486154] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 10.492998] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 10.498644] pci_bus 0008:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[ 10.508762] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.519591] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 10.527542] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 10.533926] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 10.545333] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 10.551703] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 10.557657] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 10.564797] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 10.572986] pci 0008:01:00.0: supports D1 D2
[ 10.577397] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 10.589949] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 10.597392] pci 0008:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 10.604145] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 10.612155] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 10.620171] pci 0008:01:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
[ 10.626831] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 10.632244] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 10.638878] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 10.646269] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 10.655025] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 10.664108] pcieport 0008:00:00.0: Adding to iommu group 11
[ 10.670210] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[ 10.676510] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[ 10.684431] irq: IRQ296: trimming hierarchy from :pmc@c360000
[ 10.690448] irq: IRQ297: trimming hierarchy from :interrupt-controller@f400000-1
[ 10.698421] input: gpio-keys as /devices/platform/gpio-keys/input/input4
[ 10.706767] tegra-se-nvhost 15810000.se: Adding to iommu group 39
[ 10.713532] tegra-se-nvhost 15810000.se: initialized
[ 10.726965] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 10.733386] tegra-se-nvhost 15820000.se: Adding to iommu group 40
[ 10.740030] tegra-se-nvhost 15820000.se: initialized
[ 10.746483] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 10.752909] tegra-se-nvhost 15840000.se: Adding to iommu group 41
[ 10.759517] tegra-se-nvhost 15840000.se: initialized
[ 10.766260] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 10.773270] tegra_actmon d230000.actmon: in actmon_register()...
[ 10.779635] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 10.786027] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 10.794552] hvc_sysfs: hypervisor is not present
[ 10.837177] ALSA device list:
[ 10.840246] No soundcards found.
[ 10.844623] Freeing unused kernel memory: 3968K
[ 10.849392] Run /init as init process
[ 10.870425] Root device found: PARTUUID=d525442a-0937-48f9-83f2-7b14640e3d17
[ 11.306812] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 11.327175] EXT4-fs (nvme0n1p1): 4 orphan inodes deleted
[ 11.332650] EXT4-fs (nvme0n1p1): recovery complete
[ 11.342793] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.354661] Rootfs mounted over PARTUUID=d525442a-0937-48f9-83f2-7b14640e3d17
[ 11.376494] Switching from initrd to actual rootfs
[ 11.469741] systemd[1]: System time before build time, advancing clock.
[ 11.541508] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 11.565316] systemd[1]: Detected architecture arm64.
[ 11.612504] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 11.840992] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 11.854005] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 11.863875] systemd[1]: Created slice system-modprobe.slice.
[ 11.884440] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 11.904414] systemd[1]: Created slice User and Session Slice.
[ 11.924207] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.948444] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.972186] systemd[1]: Reached target User and Group Name Lookups.
[ 11.992129] systemd[1]: Reached target Slices.
[ 12.008121] systemd[1]: Reached target Mounting snaps.
[ 12.028120] systemd[1]: Reached target Mounted snaps.
[ 12.048431] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 12.069264] systemd[1]: Listening on Syslog Socket.
[ 12.088244] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 12.112194] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 12.136384] systemd[1]: Listening on Journal Audit Socket.
[ 12.160245] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.184266] systemd[1]: Listening on Journal Socket.
[ 12.204282] systemd[1]: Listening on udev Control Socket.
[ 12.228205] systemd[1]: Listening on udev Kernel Socket.
[ 12.253553] systemd[1]: Mounting Huge Pages File System...
[ 12.277464] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.305323] systemd[1]: Mounting RPC Pipe File System...
[ 12.329402] systemd[1]: Mounting Kernel Debug File System...
[ 12.349362] systemd[1]: Mounting Kernel Trace File System...
[ 12.369729] systemd[1]: Starting Journal Service...
[ 12.389736] systemd[1]: Starting Set the console keyboard layout...
[ 12.413773] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 12.445740] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 12.468183] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 12.478147] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 12.501546] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 12.525395] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 12.549830] systemd[1]: Starting Load Kernel Module ramoops...
[ 12.569429] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 12.593414] systemd[1]: Started Nameserver information manager.
[ 12.616333] systemd[1]: Reached target Network (Pre).
[ 12.641933] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 12.651301] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 12.663386] systemd[1]: Starting Load Kernel Modules...
[ 12.681083] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 12.688639] nvmap_page_pool_init: Total RAM pages: 847571
[ 12.694209] nvmap_page_pool_init: nvmap page pool size: 105946 pages (413 MB)
[ 12.701661] nvmap_background_zero_thread: PP zeroing thread starting.
[ 12.710054] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.722064] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[ 12.733796] systemd[1]: Starting udev Coldplug all Devices...
[ 12.748722] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 12.748722]
[ 12.766371] systemd[1]: Started Journal Service.
[ 13.076105] Adding 4194300k swap on /swapfile. Priority:-2 extents:5 across:4997116k SS
[ 13.102905] systemd-journald[246]: Received client request to flush runtime journal.
[ 13.876195] nvidia: loading out-of-tree module taints kernel.
[ 14.048249] fusb301 1-0025: failed to read device id, err : 0xffffff87
[ 14.054984] fusb301 1-0025: fusb301 not support
[ 14.060649] fusb301: probe of 1-0025 failed with error -22
[ 14.804725] using random self ethernet address
[ 14.812292] using random host ethernet address
[ 15.289185] using random self ethernet address
[ 15.293781] using random host ethernet address
Ubuntu 20.04.5 LTS tegra-ubuntu ttyTCU0
tegra-ubuntu login: ubuntu (automatic login)
Welcome to Ubuntu 20.04.5 LTS (GNU/Linux 5.10.104-tegra aarch64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
* Introducing Expanded Security Maintenance for Applications.
Receive updates to over 25,000 software packages with your
Ubuntu Pro subscription. Free for personal use.
https://ubuntu.com/pro
Expanded Security Maintenance for Applications is not enabled.
264 updates can be applied immediately.
215 of these updates are standard security updates.
To see these additional updates run: apt list --upgradable
29 additional security updates can be applied with ESM Apps.
Learn more about enabling ESM Apps service at https://ubuntu.com/esm
Last login: Tue Oct 3 10:31:47 UTC 2023 on ttyAMA0
ubuntu@tegra-ubuntu:~$ sudo su
[sudo] password for ubuntu:
root@tegra-ubuntu:/home/ubuntu# [ 23.924348] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 27.820322] irq 284: nobody cared (try booting with the "irqpoll" option)
[ 27.827460] handlers:
[ 27.829791] [<0000000076722159>] irq_default_primary_handler threaded [<00000000b32e8071>] pca953x_irq_handler
[ 27.840067] Disabling IRQ #284
[ 66.309219] irq 285: nobody cared (try booting with the "irqpoll" option)
[ 66.316411] handlers:
[ 66.318750] [<0000000076722159>] irq_default_primary_handler threaded [<00000000b32e8071>] pca953x_irq_handler
[ 66.329059] Disabling IRQ #285
