Jetpack 6.0 restore have some fault
我使用的是orin nx的devkit,在构建jetpack6.0时,我想保存我的镜像,通过backup的方式将镜像保存下来在restore时出现了错误。
我尝试过换一个核心板和ssd,构建过程也是按照Kernel Customization — NVIDIA Jetson Linux Developer Guide 1 documentation 完成的,始终无法成功restore。
我是在系统工作正常的情况下开始的backup,随后再restore,便出现了上面的错误。
我的命令
sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -b jetson-orin-nano-devkit
sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -r jetson-orin-nano-devkit
这是我的开机log,似乎过了一会开始重启,随后重复这个过程
Jetson System firmware version 36.3.0-gcid-36191598 date 2024-05-06T16:58:59+00:
00
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
      L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
��debugfs initialized
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.136-tegra (zme@zme-System-Product-Name) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #2 SMP PREEMPT Fri Jun 28 14:57:12 CST 2024 ()
[    0.000000] Machine model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x46d82f198 SMBIOS=0xffff0000 SMBIOS 3.0=0x46d200000 MEMATTR=0x46779d018 ESRT=0x467217a18 RNG=0x45ac60018 MEMRESERVE=0x45b97ac18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] esrt: Reserving ESRT space from 0x0000000467217a18 to 0x0000000467217a50.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000044a000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000477ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x4702f0800-0x4702f2fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000477ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000bdffffff]
[    0.000000]   node   0: [mem 0x00000000c2000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000045e23afff]
[    0.00��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
��0000]   node   0: [mem 0x000000045e23b000-0x000000045e40bfff]
[    0.000000]   node   0: [mem 0x000000045e40c000-0x000000046b8effff]
[    0.000000]   node   0: [mem 0x000000046b8f0000-0x000000046d82ffff]
[    0.000000]   node   0: [mem 0x000000046d830000-0x0000000471dfffff]
[    0.000000]   node   0: [mem 0x0000000471e00000-0x0000000471ffffff]
[    0.000000]   node   0: [mem 0x0000000472000000-0x000000047259ffff]
[    0.000000]   node   0: [mem 0x0000000472f00000-0x0000000472ffffff]
[    0.000000]   node   0: [mem 0x0000000476000000-0x0000000477ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000477ffffff]
[    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4065440
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000
[    0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 15749220K/16521856K available (19136K kernel code, 4054K rwdata, 10084K rodata, 7744K init, 529K bss, 510492K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000000] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000343] Console: colour dummy device 80x25
[    0.000350] printk: console [tty0] enabled
[    0.000393] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000398] pid_max: default: 32768 minimum: 301
[    0.000427] LSM: Security Framework initializing
[    0.000442] Yama: becoming mindful.
[    0.000452] SELinux:  Initializing.
[    0.000514] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.000532] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.001391] rcu: Hierarchical SRCU implementation.
[    0.003837] Tegra Revision: A01 SKU: 211 CPU Process: 0 SoC Process: 0
[    0.004151] Remapping and enabling EFI services.
[    0.004894] smp: Bringing up secondary CPUs ...
[    0.005250] Detected PIPT I-cache on CPU1
[    0.005277] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.005300] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.005641] Detected PIPT I-cache on CPU2
[    0.005654] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.005667] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.005976] Detected PIPT I-cache on CPU3
[    0.005985] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.005997] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.008280] Detected PIPT I-cache on CPU4
[    0.008302] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.008324] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.008680] Detected PIPT I-cache on CPU5
[    0.008690] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.008701] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.009020] Detected PIPT I-cache on CPU6
[    0.009030] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.009041] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.009367] Detected PIPT I-cache on CPU7
[    0.009377] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.009390] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.009435] smp: Brought up 1 node, 8 CPUs
[    0.009438] SMP: Total of 8 processors activated.
[    0.009440] CPU features: detected: 32-bit EL0 Support
[    0.009441] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.009443] CPU features: detected: Common not Private translations
[    0.009444] CPU features: detected: CRC32 instructions
[    0.009445] CPU features: detected: Data cache clean to Point of Persistence
[    0.009446] CPU features: detected: Generic authentication (architected algorithm)
[    0.009447] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.009447] CPU features: detected: LSE atomic instructions
[    0.009448] CPU features: detected: Privileged Access Never
[    0.009449] CPU features: detected: RAS Extension Support
[    0.009451] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.023393] spectre-bhb mitigation disabled by command line option
[    0.037210] CPU: All CPU(s) started at EL2
[    0.039014] devtmpfs: initialized
[    0.050294] KASLR enabled
[    0.050389] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.050402] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.052468] pinctrl core: initialized pinctrl subsystem
[    0.053008] SMBIOS 3.6.0 present.
[    0.053015] DMI: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[    0.053315] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.054470] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.054582] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.054677] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.054712] audit: initializing netlink subsys (disabled)
[    0.054800] audit: type=2000 audit(0.052:1): state=initialized audit_enabled=0 res=1
[    0.055774] thermal_sys: Registered thermal governor 'step_wise'
[    0.055777] thermal_sys: Registered thermal governor 'user_space'
[    0.055778] thermal_sys: Registered thermal governor 'power_allocator'
[    0.057728] cpuidle: using governor menu
[    0.057848] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.057930] ASID allocator initialised with 32768 entries
[    0.059112] Serial: AMBA PL011 UART driver
[    0.067912] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[    0.075774] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.082609] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.082614] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.082615] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.082617] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.083151] cryptd: max_cpu_qlen set to 1000
[    0.084300] ACPI: Interpreter disabled.
[    0.085214] VDD_1V8_AO: supplied by VDD_5V0_SYS
[    0.085317] VDD_3V3_AO: supplied by VDD_5V0_SYS
[    0.085523] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[    0.085779] iommu: Default domain type: Translated
[    0.085782] iommu: DMA domain TLB invalidation policy: strict mode
[    0.085940] SCSI subsystem initialized
[    0.086044] vgaarb: loaded
[    0.086128] usbcore: registered new interface driver usbfs
[    0.086141] usbcore: registered new interface driver hub
[    0.086150] usbcore: registered new device driver usb
[    0.086485] pps_core: LinuxPPS API ver. 1 registered
[    0.086487] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.086492] PTP clock support registered
[    0.086542] EDAC MC: Ver: 3.0.0
[    0.087139] Registered efivars operations
[    0.087558] FPGA manager framework
[    0.087618] Advanced Linux Sound Architecture Driver Initialized.
[    0.088106] clocksource: Switched to clocksource arch_sys_counter
[    0.121773] VFS: Disk quotas dquot_6.6.0
[    0.121861] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.122099] pnp: PnP ACPI: disabled
[    0.125432] NET: Registered PF_INET protocol family
[    0.125970] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.128452] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.128478] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.128499] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.128674] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.130075] TCP: Hash tables configured (established 131072 bind 65536)
[    0.130272] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.130321] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.130567] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.131020] RPC: Registered named UNIX socket transport module.
[    0.131026] RPC: Registered udp transport module.
[    0.131026] RPC: Registered tcp transport module.
[    0.131027] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.131045] PCI: CLS 0 bytes, default 64
[    0.131263] Unpacking initramfs...
[    0.141147] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.141505] kvm [1]: IPA Size Limit: 48 bits
[    0.141551] kvm [1]: GICv3: no GICV resource entry
[    0.141562] kvm [1]: disabling GICv2 emulation
[    0.141585] kvm [1]: GIC system register CPU interface enabled
[    0.141677] kvm [1]: vgic interrupt IRQ9
[    0.141852] kvm [1]: VHE mode initialized successfully
[    0.145270] Initialise system trusted keyrings
[    0.145390] workingset: timestamp_bits=42 max_order=22 bucket_order=0
[    0.149223] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.149652] NFS: Registering the id_resolver key type
[    0.149683] Key type id_resolver registered
[    0.149685] Key type id_legacy registered
[    0.149738] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.149758] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.149789] ntfs: driver 2.1.32 [Flags: R/O].
[    0.150007] 9p: Installing v9fs 9p2000 file system support
[    0.161909] Key type asymmetric registered
[    0.161913] Asymmetric key parser 'x509' registered
[    0.161983] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.161990] io scheduler mq-deadline registered
[    0.161996] io scheduler kyber registered
[    0.172951] EINJ: ACPI disabled.
[    0.185260] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.187068] SuperH (H)SCI(F) driver initialized
[    0.187413] msm_serial: driver initialized
[    0.188011] printk: console [ttyTCU0] enabled
[    0.188945] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.188950] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.188959] arm-smmu 8000000.iommu:  stage 1 translation
[    0.188963] arm-smmu 8000000.iommu:  stage 2 translation
[    0.188966] arm-smmu 8000000.iommu:  nested translation
[    0.188972] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    0.188976] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    0.188997] arm-smmu 8000000.iommu:  Supported page sizes: 0x61311000
[    0.189000] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    0.189001] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    0.189989] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.189994] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.189996] arm-smmu 10000000.iommu:         stage 1 translation
[    0.189997] arm-smmu 10000000.iommu:         stage 2 translation
[    0.189998] arm-smmu 10000000.iommu:         nested translation
[    0.190003] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    0.190005] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    0.190012] arm-smmu 10000000.iommu:         Supported page sizes: 0x61311000
[    0.190013] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.190015] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.190374] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.190378] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.190379] arm-smmu 12000000.iommu:         stage 1 translation
[    0.190380] arm-smmu 12000000.iommu:         stage 2 translation
[    0.190382] arm-smmu 12000000.iommu:         nested translation
[    0.190384] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    0.190387] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    0.190396] arm-smmu 12000000.iommu:         Supported page sizes: 0x61311000
[    0.190397] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.190398] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.198904] loop: module loaded
[    0.199970] megasas: 07.717.02.00-rc1
[    0.204271] tun: Universal TUN/TAP device driver, 1.6
[    0.204859] thunder_xcv, ver 1.0
[    0.204887] thunder_bgx, ver 1.0
[    0.204917] nicpf, ver 1.0
[    0.205784] hclge is initializing
[    0.205819] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.205827] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.205871] e1000: Intel(R) PRO/1000 Network Driver
[    0.205878] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.205905] e1000e: Intel(R) PRO/1000 Network Driver
[    0.205912] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.205928] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.205934] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.205947] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.205951] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.206185] sky2: driver version 1.30
[    0.206884] VFIO - User Level meta-driver version: 0.3
[    0.208495] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.208504] ehci-pci: EHCI PCI platform driver
[    0.208535] ehci-platform: EHCI generic platform driver
[    0.208610] ehci-orion: EHCI orion driver
[    0.208675] ehci-exynos: EHCI Exynos driver
[    0.208741] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.208763] ohci-pci: OHCI PCI platform driver
[    0.208783] ohci-platform: OHCI generic platform driver
[    0.208854] ohci-exynos: OHCI Exynos driver
[    0.209306] usbcore: registered new interface driver usb-storage
[    0.211204] i2c_dev: i2c /dev entries driver
[    0.212629] pps pps0: new PPS source ktimer
[    0.212642] pps pps0: ktimer PPS source registered
[    0.212652] pps_ldisc: PPS line discipline registered
[    0.214868] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.217060] sdhci: Secure Digital Host Controller Interface driver
[    0.217067] sdhci: Copyright(c) Pierre Ossman
[    0.217541] Synopsys Designware Multimedia Card Interface Driver
[    0.218175] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.219363] ledtrig-cpu: registered to indicate activity on CPUs
[    0.220317] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.220827] tegra-bpmp bpmp: Adding to iommu group 0
[    0.222362] tegra-bpmp bpmp: firmware: 6432e47ee22b94f945d6-3b0e1a33cf8
[    0.352206] Freeing initrd memory: 13280K
[    1.659995] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    1.660014] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    1.660020] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    1.660253] hid: raw HID events driver (C) Jiri Kosina
[    1.660659] usbcore: registered new interface driver usbhid
[    1.660664] usbhid: USB HID core driver
[    1.664483] optee: probing for conduit method.
[    1.664536] optee: revision 3.22 (e7b5ff3f)
[    1.723979] optee: dynamic shared memory is enabled
[    1.724231] optee: initialized driver
[    1.726935] usbcore: registered new interface driver snd-usb-audio
[    1.728785] NET: Registered PF_PACKET protocol family
[    1.729046] 9pnet: Installing 9P2000 support
[    1.729159] Key type dns_resolver registered
[    1.730194] printk: console [tty0]: printing thread started
[    1.730775] printk: console [ttyTCU0]: printing thread started
[    1.730856] Loading compiled-in X.509 certificates
[    1.744242] Loaded X.509 cert 'Build time autogenerated kernel key: 34e020a07fd3e8030698ac9129966716c518e023'
[    1.773687] gpio-394 (camera-control-output-low): hogged as output/low
[    1.779674] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    1.781887] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    1.784247] serial-tegra 3100000.serial: RX in PIO mode
[    1.784254] serial-tegra 3100000.serial: TX in PIO mode
[    1.784387] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    1.786394] serial-tegra 3140000.serial: RX in PIO mode
[    1.786402] serial-tegra 3140000.serial: TX in PIO mode
[    1.786517] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[    1.791959] tegra_rtc c2a0000.rtc: registered as rtc1
[    1.791977] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    1.792710] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    1.799357] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    1.802070] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    1.804352] tegra-i2c c240000.i2c: Adding to iommu group 1
[    1.806474] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[    1.806980] tegra-i2c c250000.i2c: Adding to iommu group 1
[    1.810577] i2c i2c-2: Added multiplexed i2c bus 9
[    1.810796] i2c i2c-2: Added multiplexed i2c bus 10
[    1.810801] i2c-mux-gpio bus@0:cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    1.828116] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1974000 KHz, changing to: 1984000 KHz
[    1.830207] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1976000 KHz, changing to: 1984000 KHz
[    1.832806] tegra-xusb 3610000.usb: Adding to iommu group 2
[    1.847331] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[    1.847338] tegra-xusb 3610000.usb: xHCI Host Controller
[    1.847347] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[    1.848081] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[    1.848109] tegra-xusb 3610000.usb: irq 123, io mem 0x03610000
[    1.848219] tegra-xusb 3610000.usb: xHCI Host Controller
[    1.848222] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[    1.848225] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    1.848651] hub 1-0:1.0: USB hub found
[    1.848665] hub 1-0:1.0: 4 ports detected
[    1.848924] hub 2-0:1.0: USB hub found
[    1.848937] hub 2-0:1.0: 4 ports detected
[    1.850894] irq: IRQ221: trimming hierarchy from :bus@0:pmc@c360000
[    1.850956] irq: IRQ222: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    1.851006] irq: IRQ223: trimming hierarchy from :bus@0:pmc@c360000
[    1.851071] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    1.894006] ALSA device list:
[    1.894010]   No soundcards found.
[    1.906317] Freeing unused kernel memory: 7744K
[    1.906391] Run /init as init process
[    1.917446] Checking overlayfs setting...
[    1.926008] Overlayfs is disabled...
[    1.931543] Root device found: nvme0n1p1
[    2.008138] usb usb2-port2: config error
[    2.192278] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    2.363981] hub 1-2:1.0: USB hub found
[    2.365530] hub 1-2:1.0: 4 ports detected
[    2.496278] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    5.319805] tegra194-pcie 14100000.pcie: Adding to iommu group 3
[    5.323246] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    5.323275] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    5.323282] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    5.323285] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    5.323612] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    5.323614] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    5.349673] tegra-xudc 3550000.usb: Adding to iommu group 4
[    5.428116] tegra194-pcie 14100000.pcie: Link up
[    5.429595] tegra194-pcie 14100000.pcie: Link up
[    5.429655] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    5.429660] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    5.429663] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    5.429666] pci_bus 0001:00: root bus resource [bus 00-ff]
[    5.429667] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    5.429718] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    5.429889] pci 0001:00:00.0: PME# supported from D0 D3hot
[    5.433325] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    5.433497] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    5.433697] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    5.434723] pci 0001:01:00.0: supports D1 D2
[    5.434725] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    5.447008] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    5.447011] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    5.447014] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    5.447117] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    5.447148] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    5.447151] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    5.447155] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    5.447255] pcieport 0001:00:00.0: Adding to iommu group 3
[    5.447351] pcieport 0001:00:00.0: PME: Signaling with IRQ 191
[    5.447456] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[    5.448319] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[    5.451023] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    5.451044] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    5.451050] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    5.451054] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    5.451559] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    5.451563] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    5.556282] tegra194-pcie 14160000.pcie: Link up
[    5.559002] tegra194-pcie 14160000.pcie: Link up
[    5.559055] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    5.559059] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    5.559061] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    5.559063] pci_bus 0004:00: root bus resource [bus 00-ff]
[    5.559065] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    5.559105] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    5.559253] pci 0004:00:00.0: PME# supported from D0 D3hot
[    5.562431] pci 0004:01:00.0: [126f:2263] type 00 class 0x010802
[    5.562626] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    5.578965] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    5.578970] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    5.579057] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    5.579061] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    5.579157] pcieport 0004:00:00.0: Adding to iommu group 5
[    5.579247] pcieport 0004:00:00.0: PME: Signaling with IRQ 193
[    5.579383] pcieport 0004:00:00.0: AER: enabled with IRQ 193
[    5.579560] nvme 0004:01:00.0: Adding to iommu group 5
[    5.580255] nvme nvme0: pci function 0004:01:00.0
[    5.580313] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    5.580944] tegra194-pcie 141e0000.pcie: Adding to iommu group 6
[    5.583724] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[    5.583750] tegra194-pcie 141e0000.pcie:      MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[    5.583756] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    5.583759] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    5.584267] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[    5.584272] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    5.584713] nvme nvme0: missing or invalid SUBNQN field.
[    5.595272] nvme nvme0: allocated 64 MiB host memory buffer.
[    5.608917] nvme nvme0: 8/0/0 default/read/poll queues
[    5.614577]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    5.774096] Found dev node: /dev/nvme0n1p1
[    5.782776] JBD2: journal transaction 10 on nvme0n1p1-8 is corrupt.
[    5.782783] EXT4-fs (nvme0n1p1): error loading journal
[    5.783384] ERROR: nvme0n1p1 mount fail...
[    5.785297] ttyTCU0: Press [ENTER] to start bash in 30 seconds...
[    6.100342] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[    6.100368] usb usb2-port2: config error
[    6.693377] tegra194-pcie 141e0000.pcie: Phy link never came up
[    7.695182] tegra194-pcie 141e0000.pcie: Phy link never came up
[    7.695281] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    7.695286] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[    7.695288] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[    7.695291] pci_bus 0007:00: root bus resource [bus 00-ff]
[    7.695293] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff pref]
[    7.695342] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    7.695498] pci 0007:00:00.0: PME# supported from D0 D3hot
[    7.701508] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    7.701631] pcieport 0007:00:00.0: Adding to iommu group 6
[    7.701731] pcieport 0007:00:00.0: PME: Signaling with IRQ 195
[    7.702271] pcieport 0007:00:00.0: AER: enabled with IRQ 195
[    7.702552] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[    7.702634] pci 0007:00:00.0: Removing from iommu group 6
[    7.702644] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[    7.704171] tegra194-pcie 140a0000.pcie: Adding to iommu group 7
[    7.813968] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ranges:
[    7.813991] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[    7.814000] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[    7.814005] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[    7.814472] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[    7.814474] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    7.920281] tegra194-pcie 140a0000.pcie: Link up
[    7.922902] tegra194-pcie 140a0000.pcie: Link up
[    7.922948] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[    7.922951] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[    7.922953] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[    7.922956] pci_bus 0008:00: root bus resource [bus 00-ff]
[    7.922957] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[    7.923001] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[    7.923154] pci 0008:00:00.0: PME# supported from D0 D3hot
[    7.926383] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[    7.926538] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    7.926718] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    7.926834] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    7.927803] pci 0008:01:00.0: supports D1 D2
[    7.927805] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    7.942969] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[    7.942973] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[    7.942976] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[    7.943069] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[    7.943161] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[    7.943188] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[    7.943191] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[    7.943195] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[    7.943272] pcieport 0008:00:00.0: Adding to iommu group 7
[    7.943348] pcieport 0008:00:00.0: PME: Signaling with IRQ 189
[    7.943460] pcieport 0008:00:00.0: AER: enabled with IRQ 189
[    8.785807] ttyTCU0: Press [ENTER] to start bash in 27 seconds...
[   10.172335] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[   10.172359] usb usb2-port2: config error
[   11.786194] ttyTCU0: Press [ENTER] to start bash in 24 seconds...
[   14.244333] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[   14.244357] usb usb2-port2: config error
[   14.786546] ttyTCU0: Press [ENTER] to start bash in 21 seconds...
[   17.786893] ttyTCU0: Press [ENTER] to start bash in 18 seconds...
[   18.316334] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[   18.316358] usb usb2-port2: config error
[   20.787233] ttyTCU0: Press [ENTER] to start bash in 15 seconds...
[   22.388334] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[   22.388358] usb usb2-port2: config error
[   23.787409] ttyTCU0: Press [ENTER] to start bash in 12 seconds...
[   26.460334] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[   26.460358] usb usb2-port2: config error
[   26.787754] ttyTCU0: Press [ENTER] to start bash in 9 seconds...
[   29.788096] ttyTCU0: Press [ENTER] to start bash in 6 seconds...
[   30.532335] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[   30.532358] usb usb2-port2: config error
[   32.788457] ttyTCU0: Press [ENTER] to start bash in 3 seconds...
[   34.604348] usb usb2-port2: config error
[   34.720161] usb usb2-port2: config error
[   35.790707] No ttyAMA0 is found
[   35.790749] Rebooting system...
[   35.792648] sysrq: Resetting
[   35.792674] ------------[ cut here ]------------
[   35.792675] Voluntary context switch within RCU read-side critical section!
[   35.792682] WARNING: CPU: 4 PID: 209 at kernel/rcu/tree_plugin.h:316 rcu_note_context_switch+0x41c/0x500
[   35.792696] Modules linked in: pwm_fan pwm_tegra tegra_bpmp_thermal tegra_xudc ucsi_ccg typec_ucsi typec nvme nvme_core phy_tegra194_p2u pcie_tegra194
[   35.792710] CPU: 4 PID: 209 Comm: reboot Not tainted 5.15.136-tegra #2
[   35.792713] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[   35.792715] pstate: 604000c9 (nZCv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[   35.792718] pc : rcu_note_context_switch+0x41c/0x500
[   35.792720] lr : rcu_note_context_switch+0x41c/0x500
[   35.792722] sp : ffff8000090bba40
[   35.792723] x29: ffff8000090bba40 x28: ffff000080860000 x27: ffffcb8cb7545000
[   35.792726] x26: 0000000000000000 x25: 6faccb8cb5fb39a0 x24: ffff000080860000
[   35.792728] x23: ffffcb8cb6b4b008 x22: 0000000000000000 x21: ffff000080860000
[   35.792730] x20: ffff0003f0277680 x19: ffff0003f0278480 x18: 0000000000000000
[   35.792732] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[   35.792��
[0000.063] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0000.068] I> t234-A01-0-Silicon (0x12347) Prod
[0000.072] I> Boot-mode : Coldboot
[0000.075] I> Entry timestamp: 0x00000000
[0000.079] I> last_boot_error: 0x0
[0000.082] I> BR-BCT: preprod_dev_sign: 0
[0000.086] I> rst_source: 0xb, rst_level: 0x1
[0000.090] I> Task: SE error check
[0000.093] I> Task: Bootchain select WAR set
[0000.097] I> Task: Enable SLCG
[0000.100] I> Task: CRC check
[0000.103] I> Task: Initialize MB2 params
[0000.107] I> MB2-params @ 0x40060000
[0000.111] I> Task: Crypto init
[0000.114] I> Task: Perform MB1 KAT tests
[0000.118] I> Task: NVRNG health check
[0000.121] I> NVRNG: Health check success
[0000.125] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.131] I> Task: Enabling and initialization of Bandwidth limiter
[0000.137] I> No request to configure MBWT settings for any PC!
[0000.143] I> Task: Secure debug controls
[0000.147] I> Task: strap war set
[0000.150] I> Task: Initialize SOC Therm
[0000.153] I> Task: Program NV master stream id
[0000.158] I> Task: Verify boot mode
[0000.163] I> Task: Alias fuses
[0000.167] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.174] I> Task: Print SKU type
[0000.177] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0000.183] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0000.187] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0000.191] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.195] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.200] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.204] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.209] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.213] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.217] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.221] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.225] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.229] I> FUSE_SKU_INFO_0 = 0xd3
[0000.233] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.237] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.241] I> SKU: Prod
[0000.243] I> Task: Boost clocks
[0000.246] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.251] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.256] I> BPMP NAFLL lock success.
[0000.260] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.264] I> Initializing PLLC2 for AXI_CBB.
[0000.269] I> AXI_CBB : src = 35, divisor = 0
[0000.273] I> Task: Voltage monitor
[0000.276] I> VMON: Vmon re-calibration and fine tuning done
[0000.281] I> Task: UPHY init
[0000.286] I> HSIO UPHY init done
[0000.289] W> Skipping GBE UPHY config
[0000.293] I> Task: Boot device init
[0000.296] I> Boot_device: QSPI_FLASH instance: 0
[0000.301] I> Qspi clock source : pllc_out0
[0000.305] I> QSPI Flash: Macronix 64MB
[0000.309] I> QSPI-0l initialized successfully
[0000.313] I> Task: TSC init
[0000.316] I> Task: Load membct
[0000.318] I> RAM_CODE 0x4000001
[0000.321] I> Loading MEMBCT
[0000.324] I> Slot: 0
[0000.326] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.332] I> Binary name: MEM-BCT-0
[0000.335] I> Size of crypto header is 8192
[0000.339] I> Size of crypto header is 8192
[0000.343] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.349] I> BCH of MEM-BCT-0 read from storage
[0000.353] I> BCH address is : 0x40050000
[0000.357] I> MEM-BCT-0 header integrity check is success
[0000.363] I> Binary magic in BCH component 0 is MEM0
[0000.367] I> component binary type is 0
[0000.371] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.378] I> MEM-BCT-0 binary is read from storage
[0000.383] I> MEM-BCT-0 binary integrity check is success
[0000.388] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
所以你是用-r指令復原的時候就失敗?
有復原時候的log嗎?
你在現在這個狀態下完整重燒是可以用的?
還有你確定這塊是DevKit嗎
我指的DevKit是Orin NX module加上Orin Nano DevKit
这个我可以确定,我在jetpack5.1.2上是可以成功restore的。
是的,使用-r选项恢复系统就会起不来,我重新烧录是可以正常启动的。log一会我抓取一个传上来。
  1. 我使用下载命令下载
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p "-c ./bootloader/generic/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit nvme0n1p1
log:
log_orinminimal_download.log (321.9 KB)
  1. 正常启动后开始backup
    使用命令
log:
log_orinminimal_backup.log (160.0 KB)
  1. backup后reboot orin nx,随后开始restore
    使用命令
log:
log_orinminimal_restore.log (134.1 KB)
  1. 等待片刻后的重启设备
    log:
    log_orinminimal_restore_boot.log (71.1 KB)
nvbackup_partitions.sh這個script現在的版本有個bug
(在Linux_for_Tegra/tools/backup_restore/裡面)
原本ext4的partition應該用tar備份的 但是因為blkid讀錯資料 變成即使有幾十GB也是用dd備份
備份時間會變得非常長 我不確定這樣會不會讓還原回去的內容有問題
麻煩加上以下的patch再重新備份/還原一次
isext4() {
	if [ "$#" -ne 1 ]; then
		print_message "isext4 function need 1 parameter that is the name of the storage device"
		return 1;
	fi
	local result
	- result="$( blkid "/dev/${1}" | awk '{ print $3 }' | sed -n 's|TYPE="\(.*\)"|\1|p' )"
	+ result="$( blkid -o value -s TYPE "/dev/${1}" )"
	if [ "${result}" = "ext4" ]; then
		echo "true"
	else
		echo "false"
	fi
Yes, I found that the speed was very slow before, but now the backup speed is very fast.
I changed the script and tried again, and the restore was successful.
Thanks !!!
这是成功情况的log
log_orinminimal_backup.log (106.3 KB)
log_orinminimal_restore.log (104.9 KB)
那你現在開機開得起來嗎?
现在开机没问题了
