串口收发问题
我使用 Jetson Orin Nano模组,定制的底板,串口不能正常使用
UART0和UART1是对应的/dev/ttyTHS1和/dev/ttyTHS2吗?
我往/dev/ttyTHS1接口发数据时,用示波器测量UART0_TXD引脚没有电平变化
是不是要使用串口还需要修改什么配置?
Hi qiaowei,
You can refer to Jetson/L4T/peripheral/ - eLinux.org for the mapping.
Please share dmesg for further check.
我使用 Loopback test ,不能正常收发,是需要外部TX和RX也接线吗?
下面是dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.136-tegra (root@ubuntu) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #4 SMP PREEMPT Thu May 23 14:11:11 CST 2024 ()
[    0.000000] Machine model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x26d84f198 SMBIOS=0xffff0000 SMBIOS 3.0=0x26d220000 MEMATTR=0x2671fb018 ESRT=0x26702c798 RNG=0x25ac90018 MEMRESERVE=0x25b98ec18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] esrt: Reserving ESRT space from 0x000000026702c798 to 0x000000026702c7d0.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000024a000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000277ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x2712fa800-0x2712fcfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000277ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000bdffffff]
[    0.000000]   node   0: [mem 0x00000000c2000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000025e1cefff]
[    0.000000]   node   0: [mem 0x000000025e1cf000-0x000000025e42bfff]
[    0.000000]   node   0: [mem 0x000000025e42c000-0x000000026b90ffff]
[    0.000000]   node   0: [mem 0x000000026b910000-0x000000026d84ffff]
[    0.000000]   node   0: [mem 0x000000026d850000-0x0000000271dfffff]
[    0.000000]   node   0: [mem 0x0000000271e00000-0x0000000271ffffff]
[    0.000000]   node   0: [mem 0x0000000272000000-0x000000027259ffff]
[    0.000000]   node   0: [mem 0x0000000272f00000-0x0000000272ffffff]
[    0.000000]   node   0: [mem 0x0000000276000000-0x0000000277ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000277ffffff]
[    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] pcpu-alloc: s80408 r8192 d30184 u118784 alloc=29*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2001056
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=PARTUUID=366fa3cc-0dd6-4b46-90e4-9887b30999bc rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000
[    0.000000] Unknown kernel command line parameters "mminit_loglevel=4 fbcon=map:0 bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000f8120000-0x00000000fc120000] (64MB)
[    0.000000] Memory: 7520736K/8133248K available (18880K kernel code, 4048K rwdata, 9936K rodata, 7616K init, 521K bss, 350368K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000369] Console: colour dummy device 80x25
[    0.000378] printk: console [tty0] enabled
[    0.000439] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000448] pid_max: default: 32768 minimum: 301
[    0.000488] LSM: Security Framework initializing
[    0.000515] Yama: becoming mindful.
[    0.000534] SELinux:  Initializing.
[    0.000604] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.000617] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.001711] rcu: Hierarchical SRCU implementation.
[    0.003968] Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[    0.004236] Remapping and enabling EFI services.
[    0.005036] smp: Bringing up secondary CPUs ...
[    0.005543] Detected PIPT I-cache on CPU1
[    0.005584] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.005622] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.006070] Detected PIPT I-cache on CPU2
[    0.006081] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.006096] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.006509] Detected PIPT I-cache on CPU3
[    0.006519] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.006532] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.008989] Detected PIPT I-cache on CPU4
[    0.009018] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[    0.009046] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.009547] Detected PIPT I-cache on CPU5
[    0.009560] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[    0.009576] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.009634] smp: Brought up 1 node, 6 CPUs
[    0.009639] SMP: Total of 6 processors activated.
[    0.009642] CPU features: detected: 32-bit EL0 Support
[    0.009644] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.009646] CPU features: detected: Common not Private translations
[    0.009647] CPU features: detected: CRC32 instructions
[    0.009648] CPU features: detected: Data cache clean to Point of Persistence
[    0.009650] CPU features: detected: Generic authentication (architected algorithm)
[    0.009651] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.009652] CPU features: detected: LSE atomic instructions
[    0.009654] CPU features: detected: Privileged Access Never
[    0.009655] CPU features: detected: RAS Extension Support
[    0.009657] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.024796] spectre-bhb mitigation disabled by command line option
[    0.047609] CPU: All CPU(s) started at EL2
[    0.050801] devtmpfs: initialized
[    0.071194] KASLR enabled
[    0.071410] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.071437] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.076560] pinctrl core: initialized pinctrl subsystem
[    0.077641] SMBIOS 3.6.0 present.
[    0.077656] DMI: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.3.0-gcid-36106755 04/25/2024
[    0.078270] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.080264] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.080398] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.080486] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.080602] audit: initializing netlink subsys (disabled)
[    0.080767] audit: type=2000 audit(0.076:1): state=initialized audit_enabled=0 res=1
[    0.082620] thermal_sys: Registered thermal governor 'step_wise'
[    0.082625] thermal_sys: Registered thermal governor 'user_space'
[    0.082626] thermal_sys: Registered thermal governor 'power_allocator'
[    0.086533] cpuidle: using governor menu
[    0.086828] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.086941] ASID allocator initialised with 32768 entries
[    0.088946] Serial: AMBA PL011 UART driver
[    0.100917] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[    0.113141] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.123446] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.123453] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.123454] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.123456] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.124320] cryptd: max_cpu_qlen set to 1000
[    0.126098] ACPI: Interpreter disabled.
[    0.127631] VDD_1V8_AO: supplied by VDD_5V0_SYS
[    0.127810] VDD_3V3_AO: supplied by VDD_5V0_SYS
[    0.128206] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[    0.128640] iommu: Default domain type: Translated
[    0.128646] iommu: DMA domain TLB invalidation policy: strict mode
[    0.128998] SCSI subsystem initialized
[    0.129090] libata version 3.00 loaded.
[    0.129280] vgaarb: loaded
[    0.129514] usbcore: registered new interface driver usbfs
[    0.129541] usbcore: registered new interface driver hub
[    0.129559] usbcore: registered new device driver usb
[    0.130047] pps_core: LinuxPPS API ver. 1 registered
[    0.130052] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.130064] PTP clock support registered
[    0.130159] EDAC MC: Ver: 3.0.0
[    0.131606] Registered efivars operations
[    0.132378] FPGA manager framework
[    0.132460] Advanced Linux Sound Architecture Driver Initialized.
[    0.133432] clocksource: Switched to clocksource arch_sys_counter
[    0.169176] VFS: Disk quotas dquot_6.6.0
[    0.169257] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.169524] pnp: PnP ACPI: disabled
[    0.173068] NET: Registered PF_INET protocol family
[    0.173357] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.175107] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.175131] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.175149] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.175249] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.176615] TCP: Hash tables configured (established 65536 bind 65536)
[    0.176797] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.176828] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.177025] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.177501] RPC: Registered named UNIX socket transport module.
[    0.177506] RPC: Registered udp transport module.
[    0.177507] RPC: Registered tcp transport module.
[    0.177509] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.177528] PCI: CLS 0 bytes, default 64
[    0.177779] Unpacking initramfs...
[    0.186753] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.187101] kvm [1]: IPA Size Limit: 48 bits
[    0.187137] kvm [1]: GICv3: no GICV resource entry
[    0.187146] kvm [1]: disabling GICv2 emulation
[    0.187172] kvm [1]: GIC system register CPU interface enabled
[    0.187242] kvm [1]: vgic interrupt IRQ9
[    0.187385] kvm [1]: VHE mode initialized successfully
[    0.191121] Initialise system trusted keyrings
[    0.191326] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[    0.194537] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.195016] NFS: Registering the id_resolver key type
[    0.195049] Key type id_resolver registered
[    0.195052] Key type id_legacy registered
[    0.195106] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.195126] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.195147] ntfs: driver 2.1.32 [Flags: R/O].
[    0.195368] 9p: Installing v9fs 9p2000 file system support
[    0.210804] Key type asymmetric registered
[    0.210812] Asymmetric key parser 'x509' registered
[    0.210886] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.210898] io scheduler mq-deadline registered
[    0.210909] io scheduler kyber registered
[    0.222582] EINJ: ACPI disabled.
[    0.236112] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.238063] SuperH (H)SCI(F) driver initialized
[    0.238437] msm_serial: driver initialized
[    0.239138] printk: console [ttyTCU0] enabled
[    0.240132] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.240138] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.240146] arm-smmu 8000000.iommu: 	stage 1 translation
[    0.240149] arm-smmu 8000000.iommu: 	stage 2 translation
[    0.240151] arm-smmu 8000000.iommu: 	nested translation
[    0.240155] arm-smmu 8000000.iommu: 	stream matching with 128 register groups
[    0.240161] arm-smmu 8000000.iommu: 	128 context banks (0 stage-2 only)
[    0.240173] arm-smmu 8000000.iommu: 	Supported page sizes: 0x61311000
[    0.240175] arm-smmu 8000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.240176] arm-smmu 8000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.241239] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.241243] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.241248] arm-smmu 10000000.iommu: 	stage 1 translation
[    0.241250] arm-smmu 10000000.iommu: 	stage 2 translation
[    0.241252] arm-smmu 10000000.iommu: 	nested translation
[    0.241255] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    0.241259] arm-smmu 10000000.iommu: 	128 context banks (0 stage-2 only)
[    0.241267] arm-smmu 10000000.iommu: 	Supported page sizes: 0x61311000
[    0.241268] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.241270] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.241725] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.241728] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.241730] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.241731] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.241734] arm-smmu 12000000.iommu: 	nested translation
[    0.241735] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    0.241738] arm-smmu 12000000.iommu: 	128 context banks (0 stage-2 only)
[    0.241742] arm-smmu 12000000.iommu: 	Supported page sizes: 0x61311000
[    0.241743] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.241745] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.249551] loop: module loaded
[    0.250522] megasas: 07.717.02.00-rc1
[    0.254878] tun: Universal TUN/TAP device driver, 1.6
[    0.255503] thunder_xcv, ver 1.0
[    0.255529] thunder_bgx, ver 1.0
[    0.255562] nicpf, ver 1.0
[    0.256448] hclge is initializing
[    0.256487] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.256493] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.256543] e1000: Intel(R) PRO/1000 Network Driver
[    0.256549] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.256576] e1000e: Intel(R) PRO/1000 Network Driver
[    0.256579] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.256604] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.256609] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.256628] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.256632] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.256852] sky2: driver version 1.30
[    0.257586] VFIO - User Level meta-driver version: 0.3
[    0.259282] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.259292] ehci-pci: EHCI PCI platform driver
[    0.259320] ehci-platform: EHCI generic platform driver
[    0.259405] ehci-orion: EHCI orion driver
[    0.259472] ehci-exynos: EHCI Exynos driver
[    0.259526] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.259557] ohci-pci: OHCI PCI platform driver
[    0.259582] ohci-platform: OHCI generic platform driver
[    0.259668] ohci-exynos: OHCI Exynos driver
[    0.260140] usbcore: registered new interface driver usb-storage
[    0.262148] i2c_dev: i2c /dev entries driver
[    0.263543] pps pps0: new PPS source ktimer
[    0.263556] pps pps0: ktimer PPS source registered
[    0.263565] pps_ldisc: PPS line discipline registered
[    0.265823] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.267814] sdhci: Secure Digital Host Controller Interface driver
[    0.267820] sdhci: Copyright(c) Pierre Ossman
[    0.268302] Synopsys Designware Multimedia Card Interface Driver
[    0.268955] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.270187] ledtrig-cpu: registered to indicate activity on CPUs
[    0.271184] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.271661] tegra-bpmp bpmp: Adding to iommu group 0
[    0.272961] tegra-bpmp bpmp: firmware: 4f590cddd4eeb67cd15b-3b0e1a33cf8
[    0.443546] Freeing initrd memory: 13128K
[    3.508715] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    3.508754] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    3.508758] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    3.509023] hid: raw HID events driver (C) Jiri Kosina
[    3.509233] usbcore: registered new interface driver usbhid
[    3.509239] usbhid: USB HID core driver
[    3.514692] optee: probing for conduit method.
[    3.514747] optee: revision 3.22 (e7b5ff3f)
[    3.574012] optee: dynamic shared memory is enabled
[    3.574290] optee: initialized driver
[    3.576895] usbcore: registered new interface driver snd-usb-audio
[    3.578754] NET: Registered PF_PACKET protocol family
[    3.578996] 9pnet: Installing 9P2000 support
[    3.579104] Key type dns_resolver registered
[    3.580201] printk: console [tty0]: printing thread started
[    3.580667] printk: console [ttyTCU0]: printing thread started
[    3.580747] Loading compiled-in X.509 certificates
[    3.592509] Loaded X.509 cert 'Build time autogenerated kernel key: 641353b003ab53aae4a543f44339cbad41a07a52'
[    3.618450] gpio-394 (camera-control-output-low): hogged as output/low
[    3.621349] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    3.622718] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    3.624096] serial-tegra 3100000.serial: RX in PIO mode
[    3.624101] serial-tegra 3100000.serial: TX in PIO mode
[    3.624163] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    3.624723] serial-tegra 3140000.serial: RX in PIO mode
[    3.624728] serial-tegra 3140000.serial: TX in PIO mode
[    3.624768] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[    3.626743] tegra_rtc c2a0000.rtc: registered as rtc1
[    3.626754] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.627176] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    3.629933] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    3.631366] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    3.632709] tegra-i2c c240000.i2c: Adding to iommu group 1
[    3.633860] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[    3.634352] tegra-i2c c250000.i2c: Adding to iommu group 1
[    3.636090] i2c i2c-2: Added multiplexed i2c bus 9
[    3.636321] i2c i2c-2: Added multiplexed i2c bus 10
[    3.636325] i2c-mux-gpio bus@0:cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    3.652052] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1566000 KHz, changing to: 1510400 KHz
[    3.654034] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1564000 KHz, changing to: 1510400 KHz
[    3.657618] tegra-xusb 3610000.usb: Adding to iommu group 2
[    3.674454] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[    3.674462] tegra-xusb 3610000.usb: xHCI Host Controller
[    3.674472] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[    3.675215] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[    3.675235] tegra-xusb 3610000.usb: irq 123, io mem 0x03610000
[    3.675351] tegra-xusb 3610000.usb: xHCI Host Controller
[    3.675355] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[    3.675359] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    3.675810] hub 1-0:1.0: USB hub found
[    3.675825] hub 1-0:1.0: 4 ports detected
[    3.676549] hub 2-0:1.0: USB hub found
[    3.676565] hub 2-0:1.0: 4 ports detected
[    3.679493] irq: IRQ221: trimming hierarchy from :bus@0:pmc@c360000
[    3.679560] irq: IRQ222: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    3.679611] irq: IRQ223: trimming hierarchy from :bus@0:pmc@c360000
[    3.679675] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.793833] ALSA device list:
[    3.793838]   No soundcards found.
[    3.805175] Freeing unused kernel memory: 7616K
[    3.805254] Run /init as init process
[    3.805255]   with arguments:
[    3.805256]     /init
[    3.805256]   with environment:
[    3.805257]     HOME=/
[    3.805257]     TERM=linux
[    3.805258]     mminit_loglevel=4
[    3.805259]     fbcon=map:0
[    3.805259]     bl_prof_dataptr=2031616@0x271E10000
[    3.805260]     bl_prof_ro_ptr=65536@0x271E00000
[    3.820688] Checking overlayfs setting...
[    3.831876] Overlayfs is disabled...
[    3.838012] Root device found: PARTUUID=366fa3cc-0dd6-4b46-90e4-9887b30999bc
[    4.009427] usb 1-1: new high-speed USB device number 2 using tegra-xusb
[    4.165399] usb-storage 1-1:1.0: USB Mass Storage device detected
[    4.166516] scsi host0: usb-storage 1-1:1.0
[    4.293618] usb 1-2: new high-speed USB device number 3 using tegra-xusb
[    4.451586] hub 1-2:1.0: USB hub found
[    4.452384] hub 1-2:1.0: 4 ports detected
[    4.581436] usb 1-3: new high-speed USB device number 4 using tegra-xusb
[    4.737842] hub 1-3:1.0: USB hub found
[    4.738444] hub 1-3:1.0: 4 ports detected
[    5.029425] usb 1-3.1: new high-speed USB device number 5 using tegra-xusb
[    5.182976] scsi 0:0:0:0: Direct-Access     Generic  STORAGE DEVICE   1404 PQ: 0 ANSI: 6
[    5.245448] usb 1-3.2: new full-speed USB device number 6 using tegra-xusb
[    5.419869] sd 0:0:0:0: [sda] 62333952 512-byte logical blocks: (31.9 GB/29.7 GiB)
[    5.421105] sd 0:0:0:0: [sda] Write Protect is off
[    5.421109] sd 0:0:0:0: [sda] Mode Sense: 21 00 00 00
[    5.422353] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    5.443326]  sda: sda1
[    5.446972] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    8.048404] tegra194-pcie 14100000.pcie: Adding to iommu group 3
[    8.050223] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    8.050243] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    8.050250] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    8.050255] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    8.050574] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    8.050576] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.080295] tegra-xudc 3550000.usb: Adding to iommu group 4
[    8.157431] tegra194-pcie 14100000.pcie: Link up
[    8.158912] tegra194-pcie 14100000.pcie: Link up
[    8.158977] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    8.158982] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    8.158986] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    8.158989] pci_bus 0001:00: root bus resource [bus 00-ff]
[    8.158991] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    8.159044] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    8.159215] pci 0001:00:00.0: PME# supported from D0 D3hot
[    8.163107] pci 0001:01:00.0: [10ec:b852] type 00 class 0x028000
[    8.163282] pci 0001:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    8.163286] pci 0001:01:00.0: reg 0x10: [io  size 0x0100]
[    8.163489] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x000fffff 64bit]
[    8.164559] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[    8.176777] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    8.176782] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    8.176786] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a80fffff 64bit]
[    8.176890] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    8.176922] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    8.176926] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    8.176931] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    8.177044] pcieport 0001:00:00.0: Adding to iommu group 3
[    8.177153] pcieport 0001:00:00.0: PME: Signaling with IRQ 191
[    8.178573] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[    8.179493] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[    8.183274] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    8.183303] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    8.183314] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    8.183322] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    8.183864] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    8.183869] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.289425] tegra194-pcie 14160000.pcie: Link up
[    8.290136] tegra194-pcie 14160000.pcie: Link up
[    8.290190] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    8.290194] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    8.290197] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    8.290200] pci_bus 0004:00: root bus resource [bus 00-ff]
[    8.290202] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    8.290245] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    8.290394] pci 0004:00:00.0: PME# supported from D0 D3hot
[    8.294057] pci 0004:01:00.0: [1d97:5216] type 00 class 0x010802
[    8.294251] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    8.294553] pci 0004:01:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[    8.308973] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    8.308980] pci 0004:01:00.0: BAR 6: assigned [mem 0x2428000000-0x242801ffff pref]
[    8.308984] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428020000-0x2428023fff 64bit]
[    8.309071] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    8.309076] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    8.309206] pcieport 0004:00:00.0: Adding to iommu group 5
[    8.309308] pcieport 0004:00:00.0: PME: Signaling with IRQ 193
[    8.309740] pcieport 0004:00:00.0: AER: enabled with IRQ 193
[    8.310013] nvme 0004:01:00.0: Adding to iommu group 5
[    8.310223] nvme nvme0: pci function 0004:01:00.0
[    8.310283] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    8.310891] tegra194-pcie 141e0000.pcie: Adding to iommu group 6
[    8.312131] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[    8.312147] tegra194-pcie 141e0000.pcie:      MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[    8.312154] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    8.312157] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    8.312484] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[    8.312487] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.313588] nvme nvme0: Shutdown timeout set to 8 seconds
[    8.325172] nvme nvme0: allocated 64 MiB host memory buffer.
[    8.421427] tegra194-pcie 141e0000.pcie: Link up
[    8.424244] tegra194-pcie 141e0000.pcie: Link up
[    8.424340] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    8.424345] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[    8.424349] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[    8.424353] pci_bus 0007:00: root bus resource [bus 00-ff]
[    8.424356] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff pref]
[    8.424404] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    8.424557] pci 0007:00:00.0: PME# supported from D0 D3hot
[    8.428553] pci 0007:01:00.0: [10ec:8168] type 00 class 0x020000
[    8.428709] pci 0007:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    8.428889] pci 0007:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    8.429006] pci 0007:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    8.429960] pci 0007:01:00.0: supports D1 D2
[    8.429961] pci 0007:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    8.444753] pci 0007:00:00.0: BAR 14: assigned [mem 0x3228000000-0x32280fffff]
[    8.444757] pci 0007:00:00.0: BAR 13: assigned [io  0x200000-0x200fff]
[    8.444761] pci 0007:01:00.0: BAR 4: assigned [mem 0x3228000000-0x3228003fff 64bit]
[    8.444854] pci 0007:01:00.0: BAR 2: assigned [mem 0x3228004000-0x3228004fff 64bit]
[    8.444946] pci 0007:01:00.0: BAR 0: assigned [io  0x200000-0x2000ff]
[    8.444975] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    8.444978] pci 0007:00:00.0:   bridge window [io  0x200000-0x200fff]
[    8.444983] pci 0007:00:00.0:   bridge window [mem 0x3228000000-0x32280fffff]
[    8.445104] pcieport 0007:00:00.0: Adding to iommu group 6
[    8.445212] pcieport 0007:00:00.0: PME: Signaling with IRQ 195
[    8.446145] pcieport 0007:00:00.0: AER: enabled with IRQ 195
[    8.447109] tegra194-pcie 140a0000.pcie: Adding to iommu group 7
[    8.452353] nvme nvme0: 6/0/0 default/read/poll queues
[    8.454429]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[    8.553969] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ranges:
[    8.553998] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[    8.554006] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[    8.554010] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[    8.554321] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[    8.554323] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.603495] [initrd] wait_nvme_readly count: 1
[    8.606604] [initrd] first: 0, wipe: 0
[    8.665428] tegra194-pcie 140a0000.pcie: Link up
[    8.668105] tegra194-pcie 140a0000.pcie: Link up
[    8.668186] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[    8.668191] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[    8.668195] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[    8.668198] pci_bus 0008:00: root bus resource [bus 00-ff]
[    8.668200] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[    8.668247] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[    8.668406] pci 0008:00:00.0: PME# supported from D0 D3hot
[    8.672314] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[    8.672472] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    8.672657] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    8.672775] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    8.673770] pci 0008:01:00.0: supports D1 D2
[    8.673772] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    8.688866] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[    8.688872] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[    8.688876] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[    8.688971] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[    8.689065] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[    8.689093] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[    8.689096] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[    8.689101] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[    8.689238] pcieport 0008:00:00.0: Adding to iommu group 7
[    8.689344] pcieport 0008:00:00.0: PME: Signaling with IRQ 189
[    8.689767] pcieport 0008:00:00.0: AER: enabled with IRQ 189
[    8.814211] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    8.926834] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    8.940238] Rootfs mounted over PARTUUID=366fa3cc-0dd6-4b46-90e4-9887b30999bc
[    8.949308] Switching from initrd to actual rootfs
[    8.996065] systemd[1]: System time before build time, advancing clock.
[    9.040239] NET: Registered PF_INET6 protocol family
[    9.040824] Segment Routing with IPv6
[    9.040832] In-situ OAM (IOAM) with IPv6
[    9.058530] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    9.058914] systemd[1]: Detected architecture arm64.
[    9.060185] systemd[1]: Hostname set to <edge-computer>.
[    9.067539] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog
[    9.067557] systemd[1]: Set hardware watchdog to 2min.
[    9.178905] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    9.187120] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    9.234880] systemd[1]: sockets.target: Found ordering cycle on apport-forward.socket/start
[    9.234890] systemd[1]: sockets.target: Found dependency on sysinit.target/start
[    9.234893] systemd[1]: sockets.target: Found dependency on ec_init.service/start
[    9.234896] systemd[1]: sockets.target: Found dependency on basic.target/start
[    9.234899] systemd[1]: sockets.target: Found dependency on sockets.target/start
[    9.234902] systemd[1]: sockets.target: Job apport-forward.socket/start deleted to break ordering cycle starting with sockets.target/start
[    9.235265] systemd[1]: sockets.target: Found ordering cycle on snapd.socket/start
[    9.235270] systemd[1]: sockets.target: Found dependency on sysinit.target/start
[    9.235272] systemd[1]: sockets.target: Found dependency on ec_init.service/start
[    9.235274] systemd[1]: sockets.target: Found dependency on basic.target/start
[    9.235276] systemd[1]: sockets.target: Found dependency on sockets.target/start
[    9.235279] systemd[1]: sockets.target: Job snapd.socket/start deleted to break ordering cycle starting with sockets.target/start
[    9.235459] systemd[1]: ec_init.service: Found ordering cycle on sysinit.target/start
[    9.235463] systemd[1]: ec_init.service: Found dependency on ec_init.service/start
[    9.235466] systemd[1]: ec_init.service: Job ec_init.service/start deleted to break ordering cycle starting with ec_init.service/start
[    9.236292] systemd[1]: Queued start job for default target Graphical Interface.
[    9.238346] systemd[1]: Created slice Slice /system/modprobe.
[    9.241912] systemd[1]: Created slice Slice /system/serial-getty.
[    9.293244] systemd[1]: Created slice User and Session Slice.
[    9.293483] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    9.306317] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    9.306506] systemd[1]: Reached target Slice Units.
[    9.306574] systemd[1]: Reached target Mounting snaps.
[    9.306630] systemd[1]: Reached target Mounted snaps.
[    9.306694] systemd[1]: Reached target Swaps.
[    9.306756] systemd[1]: Reached target Local Verity Protected Volumes.
[    9.311853] systemd[1]: Listening on RPCbind Server Activation Socket.
[    9.348621] systemd[1]: Listening on Syslog Socket.
[    9.348913] systemd[1]: Listening on fsck to fsckd communication Socket.
[    9.349068] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    9.349453] systemd[1]: Listening on Journal Audit Socket.
[    9.372159] systemd[1]: Listening on Journal Socket (/dev/log).
[    9.372468] systemd[1]: Listening on Journal Socket.
[    9.372849] systemd[1]: Listening on udev Control Socket.
[    9.373058] systemd[1]: Listening on udev Kernel Socket.
[    9.374521] systemd[1]: Mounting Huge Pages File System...
[    9.400253] systemd[1]: Mounting POSIX Message Queue File System...
[    9.401679] systemd[1]: Mounting Kernel Debug File System...
[    9.412218] systemd[1]: Mounting Kernel Trace File System...
[    9.414952] systemd[1]: Starting Journal Service...
[    9.424214] systemd[1]: Starting Set the console keyboard layout...
[    9.425900] systemd[1]: Starting Create List of Static Device Nodes...
[    9.436057] systemd[1]: Starting Load Kernel Module configfs...
[    9.437777] systemd[1]: Starting Load Kernel Module drm...
[    9.447773] systemd[1]: Starting Load Kernel Module efi_pstore...
[    9.449294] systemd[1]: Starting Load Kernel Module fuse...
[    9.451002] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    9.463299] fuse: init (API version 7.34)
[    9.471015] systemd[1]: Started Nameserver information manager.
[    9.471331] systemd[1]: Reached target Preparation for Network.
[    9.471602] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    9.473882] systemd[1]: Starting Load Kernel Modules...
[    9.483160] nvsciipc: loading out-of-tree module taints kernel.
[    9.484233] nvsciipc: loaded module
[    9.497054] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    9.497734] nvmap_page_pool_init: Total RAM pages: 1950906
[    9.497738] nvmap_page_pool_init: nvmap page pool size: 243863 pages (952 MB)
[    9.497809] nvmap_background_zero_thread: PP zeroing thread starting.
[    9.507116] systemd[1]: Starting Remount Root and Kernel File Systems...
[    9.513736] tegra-host1x 13e00000.host1x: Adding to iommu group 8
[    9.514414] host1x-context host1x-ctx.0: Adding to iommu group 9
[    9.514550] host1x-context host1x-ctx.1: Adding to iommu group 10
[    9.514663] host1x-context host1x-ctx.2: Adding to iommu group 11
[    9.514776] host1x-context host1x-ctx.3: Adding to iommu group 12
[    9.514887] host1x-context host1x-ctx.4: Adding to iommu group 13
[    9.514998] host1x-context host1x-ctx.5: Adding to iommu group 14
[    9.515109] host1x-context host1x-ctx.6: Adding to iommu group 15
[    9.515220] host1x-context host1x-ctx.7: Adding to iommu group 16
[    9.515333] host1x-context host1x-ctx.8: Adding to iommu group 17
[    9.515473] host1x-context host1x-ctx.9: Adding to iommu group 18
[    9.515576] host1x-context host1x-ctx.10: Adding to iommu group 19
[    9.515686] host1x-context host1x-ctx.11: Adding to iommu group 20
[    9.515790] host1x-context host1x-ctx.12: Adding to iommu group 21
[    9.515897] host1x-context host1x-ctx.13: Adding to iommu group 22
[    9.516007] host1x-context host1x-ctx.14: Adding to iommu group 23
[    9.516118] host1x-context host1x-ctx.15: Adding to iommu group 24
[    9.523425] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-0010
[    9.523445] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-0010
[    9.523461] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with tegra-capture-vi
[    9.545570] systemd[1]: Starting Coldplug All udev Devices...
[    9.601629] systemd[1]: Started Journal Service.
[    9.650586] nvgpu: 17000000.gpu          nvgpu_nvhost_syncpt_init:122  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.716252] systemd-journald[258]: Received client request to flush runtime journal.
[    9.882114] mc: Linux media interface: v0.10
[    9.908090] tegra-soc-hwpm f100000.hwpm: Adding to iommu group 25
[    9.908768] videodev: Linux video capture interface: v2.00
[    9.914512] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.915028] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.915560] scare-pigeon 13e00000.host1x:isp-thi@14b00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.935945] Inserting ivc_ext.ko module
[   10.064235] tegra-vic 15340000.vic: Adding to iommu group 26
[   10.141848] tegra-nvdec 15480000.nvdec: Adding to iommu group 27
[   10.156600] tegra-nvjpg 15380000.nvjpg: Adding to iommu group 29
[   10.161049] tegra-nvjpg 15540000.nvjpg: Adding to iommu group 30
[   10.161843] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 28
[   10.167369] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[   10.176609] tegra-ofa 15a50000.ofa: Adding to iommu group 31
[   10.176854] using random self ethernet address
[   10.176857] using random host ethernet address
[   10.191334] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee027f size=131712
[   10.194920] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[   10.197947] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x512]=0x1900-0x1b80 TX[1x512]=0x1b80-0x1e00
[   10.199149] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1e00-0x3e80 TX[1x8192]=0x3e80-0x5f00
[   10.202846] drm drm: [drm] Cannot find any crtc or sizes
[   10.203777] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5f00-0xaf80 TX[64x320]=0xaf80-0x10000
[   10.203846] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0x10000-0x18080 TX[512x64]=0x18080-0x20100
[   10.203887] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20100-0x201c0 TX[1x64]=0x201c0-0x20280
[   10.204076] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (219)
[   10.204079] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[   10.204553] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=e2238c99959d2df9350d393f04e1f44e5bef98cb
[   10.205136] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[   10.205140] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[   10.205144] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[   10.205147] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[   10.205150] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[   10.205152] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[   10.219679] [drm] Initialized tegra 1.0.99 20120330 for drm on minor 0
[   10.221476] [RCE] TCU debug prints will be routed to traces.
[   10.227216] loop0: detected capacity change from 0 to 32768
[   10.474715] Mass Storage Function, version: 2009/09/11
[   10.474724] LUN: removable file: (no medium)
[   10.490814] using random self ethernet address
[   10.490821] using random host ethernet address
[   10.569646] irq: IRQ232: trimming hierarchy from :bus@0:pmc@c360000
[   10.591988] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   10.745162] usb0: HOST MAC da:af:4b:82:4f:d8
[   10.745171] usb0: MAC da:af:4b:82:4f:d9
[   10.779264] usb1: HOST MAC da:af:4b:82:4f:da
[   10.779272] usb1: MAC da:af:4b:82:4f:db
[   10.780724] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
[   10.787440] l4tbr0: port 1(usb0) entered blocking state
[   10.787460] l4tbr0: port 1(usb0) entered disabled state
[   10.821954] device usb0 entered promiscuous mode
[   10.829852] l4tbr0: port 2(usb1) entered blocking state
[   10.829875] l4tbr0: port 2(usb1) entered disabled state
[   10.866339] device usb1 entered promiscuous mode
[   10.876668] loop0: detected capacity change from 0 to 32768
[   11.263524] nv_nvsciipc_init.sh[606]: found /dev/nvsciipc
[   11.272545] nvsciipc: set_db start
[   11.272570] nvsciipc: set_db done
[   11.338065] tegra194-isp5 14800000.isp: Adding to iommu group 32
[   11.360409] tegra194-vi5 13e00000.host1x:vi0@15c00000: Adding to iommu group 33
[   11.361913] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   11.361926] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   11.424092] tegra194-vi5 13e00000.host1x:vi1@14c00000: Adding to iommu group 34
[   11.431362] (NULL device *): fops function table already registered
[   11.600454] pstore: Using crash dump compression: deflate
[   11.601676] printk: console [ramoops-1]: printing thread started
[   11.601703] printk: console [ramoops-1] enabled
[   11.601706] pstore: Registered ramoops as persistent store backend
[   11.601709] ramoops: using 0x200000@0x2725f0000, ecc: 0
[   11.826691] tegra-dce d800000.dce: Adding to iommu group 35
[   11.837118] dce: dce_ipc_channel_init:311  Invalid Channel State [0x0] for ch_type [2]
[   11.837545] dce: tegra_dce_probe:245  Found display consumer device
[   11.838053] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x5]
[   11.838061] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x5]
[   11.838325] dce: dce_admin_send_cmd_ver:456  version : [0x3] err : [0x0]
[   11.838536] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x1]
[   11.838549] dce: dce_admin_setup_clients_ipc:585  Channel Reset Complete for Type [1] ...
[   11.838553] dce: dce_admin_setup_clients_ipc:561  Get queue info failed for [2]
[   11.838756] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x2]
[   11.838763] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x2]
[   11.838766] dce: dce_admin_setup_clients_ipc:585  Channel Reset Complete for Type [3] ...
[   11.839753] dce: dce_start_boot_flow:166  DCE_BOOT_DONE
[   11.850456] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[   11.850779] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[   11.853338] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[   11.864185] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[   11.864490] nvidia: disagrees about version of symbol fget
[   11.864493] nvidia: Unknown symbol fget (err -22)
[   11.864535] nvidia: disagrees about version of symbol fd_install
[   11.864536] nvidia: Unknown symbol fd_install (err -22)
[   11.864769] nvidia: disagrees about version of symbol iterate_fd
[   11.864771] nvidia: Unknown symbol iterate_fd (err -22)
[   11.936023] spi-tegra114 3210000.spi: Adding to iommu group 1
[   11.950934] nvgpu: 17000000.gpu                  gk20a_scale_init:541  [INFO]  enabled scaling for GPU
[   11.951625] r8168 0007:01:00.0: Adding to iommu group 6
[   11.951745] r8168 Gigabit Ethernet driver 8.051.02.10m_pll-NAPI loaded
[   11.951816] r8168 0007:01:00.0: enabling device (0000 -> 0003)
[   11.953887] spi-tegra114 3230000.spi: Adding to iommu group 1
[   11.963846] at24 0-0050: 256 byte 24c02 EEPROM, read-only
[   11.974302] r8168 0007:01:00.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
[   11.974412] r8168 0007:01:00.0 (unnamed net_device) (uninitialized): Random ether addr e6:15:4e:a3:fd:d0
[   12.002176] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[   12.009028] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[   12.012866] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[   12.017253] r8168  Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[   12.017985] imx219 9-0010: board setup failed
[   12.018056] imx219: probe of 9-0010 failed with error -121
[   12.037941] r8168 0008:01:00.0: Adding to iommu group 7
[   12.038562] r8168 Gigabit Ethernet driver 8.051.02.10m_pll-NAPI loaded
[   12.038633] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[   12.045844] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[   12.056602] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[   12.062720] imx219 10-0010: board setup failed
[   12.062786] imx219: probe of 10-0010 failed with error -121
[   12.065385] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[   12.092210] r8168  Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
[   12.103840] tegra-hda 3510000.hda: Adding to iommu group 36
[   12.333927] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/3510000.hda/sound/card0/input1
[   12.357717] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/3510000.hda/sound/card0/input2
[   12.358404] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/3510000.hda/sound/card0/input3
[   12.359228] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/3510000.hda/sound/card0/input4
[   12.396637] CAN device driver interface
[   12.411332] tegra234-aon c000000.aon: Adding to iommu group 37
[   12.412031]  c000000.aon:hsp: probed
[   12.412183] tegra234-aon c000000.aon: init done
[   12.427241] TT CAN feature is not supported
[   12.427805] 	 Message RAM Configuration
               	| base addr   |0x0c312000|
               	| sidfc_flssa |0x00000000|
               	| xidfc_flesa |0x00000040|
               	| rxf0c_f0sa  |0x000000c0|
               	| rxf1c_f1sa  |0x000009c0|
               	| rxbc_rbsa   |0x000009c0|
               	| txefc_efsa  |0x000009c0|
               	| txbc_tbsa   |0x00000a40|
               	| tmc_tmsa    |0x00000ec0|
               	| mram size   |0x00001000|
[   12.429158] Release 3.2.3 from 09.06.2018
[   12.454685] gic 2a41000.interrupt-controller: GIC IRQ controller registered
[   12.454941] tegra-aconnect bus@0:aconnect@2900000: Tegra ACONNECT bus registered
[   12.455131] thermal-trip-event cpu-throttle-alert: cooling device registered.
[   12.471314] irq: IRQ238: trimming hierarchy from :bus@0:pmc@c360000
[   12.471676] net can0: mttcan device registered (regs=00000000d9451119, irq=201)
[   12.471961] fusb301 1-0025: failed to read device id, err : 0xffffff87
[   12.471968] fusb301 1-0025: fusb301 not support
[   12.471973] fusb301: probe of 1-0025 failed with error -22
[   12.498295] thermal-trip-event gpu-throttle-alert: cooling device registered.
[   12.500803] thermal-trip-event cv0-throttle-alert: cooling device registered.
[   12.502603] thermal-trip-event cv1-throttle-alert: cooling device registered.
[   12.514357] thermal-trip-event cv2-throttle-alert: cooling device registered.
[   12.545485] thermal-trip-event soc0-throttle-alert: cooling device registered.
[   12.559930] thermal-trip-event soc1-throttle-alert: cooling device registered.
[   12.581117] thermal-trip-event soc2-throttle-alert: cooling device registered.
[   12.615453] thermal-trip-event hot-surface-alert: cooling device registered.
[   12.647553] usbcore: registered new interface driver option
[   12.647582] usbserial: USB Serial support registered for GSM modem (1-port)
[   12.647686] option 1-3.1:1.0: GSM modem (1-port) converter detected
[   12.651828] usb 1-3.1: GSM modem (1-port) converter now attached to ttyUSB0
[   12.651923] option 1-3.1:1.1: GSM modem (1-port) converter detected
[   12.652074] usb 1-3.1: GSM modem (1-port) converter now attached to ttyUSB1
[   12.652122] option 1-3.1:1.2: GSM modem (1-port) converter detected
[   12.652199] usb 1-3.1: GSM modem (1-port) converter now attached to ttyUSB2
[   12.652252] option 1-3.1:1.3: GSM modem (1-port) converter detected
[   12.652325] usb 1-3.1: GSM modem (1-port) converter now attached to ttyUSB3
[   12.675540] Bluetooth: Core ver 2.22
[   12.675611] NET: Registered PF_BLUETOOTH protocol family
[   12.675614] Bluetooth: HCI device and connection manager initialized
[   12.675626] Bluetooth: HCI socket layer initialized
[   12.675631] Bluetooth: L2CAP socket layer initialized
[   12.675639] Bluetooth: SCO socket layer initialized
[   12.706727] usbcore: registered new interface driver btusb
[   12.722838] Bluetooth: hci0: RTL: examining hci_ver=0b hci_rev=000b lmp_ver=0b lmp_subver=8852
[   12.741704] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.6fd4e69.20220818-105856
[   12.741715] rtk_btcoex: rtk_btcoex_init: version: 1.2
[   12.741717] rtk_btcoex: create workqueue
[   12.741873] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[   12.741954] usbcore: registered new interface driver rtk_btusb
[   12.904841] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[   12.906388] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 1970-01-01T00:00:42 UTC (42)
[   12.910040] r8168 0007:01:00.0 eth2: renamed from eth0
[   12.930887] Bluetooth: hci0: RTL: examining hci_ver=0b hci_rev=000b lmp_ver=0b lmp_subver=8852
[   12.930922] Bluetooth: hci0: RTL: unknown IC info, lmp subver 8852, hci rev 000b, hci ver 000b
[   12.930926] Bluetooth: hci0: RTL: assuming no firmware upload needed
[   12.938271] tegra-adma 2930000.dma-controller: Tegra210 ADMA driver registered 32 channels
[   12.960401] eth2: 0xffff80000b3dd000, c6:91:c8:ba:ba:8e, IRQ 235
[   13.031980] eth1: 0xffff80000b47d000, 48:b0:2d:eb:5a:8e, IRQ 236
[   13.179100] tegra210-admaif 290f000.admaif: Adding to iommu group 38
[   14.156693] zram: Added device: zram0
[   14.170068] zram: Added device: zram1
[   14.170412] zram: Added device: zram2
[   14.173607] NET: Registered PF_ALG protocol family
[   14.173793] zram: Added device: zram3
[   14.195177] zram: Added device: zram4
[   14.196232] zram: Added device: zram5
[   14.224625] zram0: detected capacity change from 0 to 1300608
[   14.233889] Adding 650300k swap on /dev/zram0.  Priority:5 extents:1 across:650300k SS
[   14.235490] zram1: detected capacity change from 0 to 1300608
[   14.245075] Adding 650300k swap on /dev/zram1.  Priority:5 extents:1 across:650300k SS
[   14.248588] zram2: detected capacity change from 0 to 1300608
[   14.256863] Adding 650300k swap on /dev/zram2.  Priority:5 extents:1 across:650300k SS
[   14.258379] zram3: detected capacity change from 0 to 1300608
[   14.265748] Adding 650300k swap on /dev/zram3.  Priority:5 extents:1 across:650300k SS
[   14.267828] zram4: detected capacity change from 0 to 1300608
[   14.275134] Adding 650300k swap on /dev/zram4.  Priority:5 extents:1 across:650300k SS
[   14.277068] zram5: detected capacity change from 0 to 1300608
[   14.284974] Adding 650300k swap on /dev/zram5.  Priority:5 extents:1 across:650300k SS
[   16.061290] overlayfs: filesystem on '/var/lib/docker/check-overlayfs-support540963987/upper' not supported as upperdir
[   16.094581] Bridge firewalling registered
[   16.269926] nvidia: disagrees about version of symbol fget
[   16.269937] nvidia: Unknown symbol fget (err -22)
[   16.269977] nvidia: disagrees about version of symbol fd_install
[   16.269979] nvidia: Unknown symbol fd_install (err -22)
[   16.270216] nvidia: disagrees about version of symbol iterate_fd
[   16.270218] nvidia: Unknown symbol iterate_fd (err -22)
[   17.196223] r8168: eth1: link up
[   17.196345] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   27.393555] nvidia: disagrees about version of symbol fget
[   27.393566] nvidia: Unknown symbol fget (err -22)
[   27.393612] nvidia: disagrees about version of symbol fd_install
[   27.393613] nvidia: Unknown symbol fd_install (err -22)
[   27.393875] nvidia: disagrees about version of symbol iterate_fd
[   27.393877] nvidia: Unknown symbol iterate_fd (err -22)
[   27.571479] nvidia: disagrees about version of symbol fget
[   27.571490] nvidia: Unknown symbol fget (err -22)
[   27.571531] nvidia: disagrees about version of symbol fd_install
[   27.571533] nvidia: Unknown symbol fd_install (err -22)
[   27.571792] nvidia: disagrees about version of symbol iterate_fd
[   27.571794] nvidia: Unknown symbol iterate_fd (err -22)
[   27.737530] nvidia: disagrees about version of symbol fget
[   27.737540] nvidia: Unknown symbol fget (err -22)
[   27.737581] nvidia: disagrees about version of symbol fd_install
[   27.737582] nvidia: Unknown symbol fd_install (err -22)
[   27.737823] nvidia: disagrees about version of symbol iterate_fd
[   27.737825] nvidia: Unknown symbol iterate_fd (err -22)
[   27.898083] nvidia: disagrees about version of symbol fget
[   27.898095] nvidia: Unknown symbol fget (err -22)
[   27.898134] nvidia: disagrees about version of symbol fd_install
[   27.898135] nvidia: Unknown symbol fd_install (err -22)
[   27.898372] nvidia: disagrees about version of symbol iterate_fd
[   27.898373] nvidia: Unknown symbol iterate_fd (err -22)
[   28.083790] nvidia: disagrees about version of symbol fget
[   28.083801] nvidia: Unknown symbol fget (err -22)
[   28.083843] nvidia: disagrees about version of symbol fd_install
[   28.083845] nvidia: Unknown symbol fd_install (err -22)
[   28.084084] nvidia: disagrees about version of symbol iterate_fd
[   28.084085] nvidia: Unknown symbol iterate_fd (err -22)
我把这4个引脚:UART0_RTS,UART0_CTS,UART1_RTS,UART1_CTS 在设备树中改成普通IO了,有影响吗?
It seems you are using Jetpack6.0GA(R36.3).
It is UART1 from 40-pin expansion header.
Yes, you need to short TX/RX externally for loopback test.
(i.e. PIN8(UART1_TX) and PIN10(UART1_RX) on 40-pin expansion header)
Do you mean the pinmux spreadsheet? If so, you should configure them as UART instead of GPIO.
You can refer to the following:
是的,我是用pinmux spreadsheet配置的,我们的定制载板已经把这4个引脚UART0_RTS,UART0_CTS,UART1_RTS,UART1_CTS做为其他GPIO使用了,串口只使用UART0_TXD,UART0_TXD,UART1_TXD,UART1_RXD这4个引脚可以吗?RTS和CTS是硬件流控功能,我不需要使用硬件流控应该怎么配置?
Okay, 如果你不需要使用RTS/CTS,那應該維持預設的設定就可以了
記得使用串口應用開啟UART時要關閉HW flow control
請問你把TX/RX從外部short後,UART loopback test可以成功嗎?
请问如何关闭HW flow control?
TX/RX从外部短接后还是不行,不确定是不是HW flow control没有关闭的原因
是通过stty命令就可以关闭吗?我是这样操作的:
下面是pinmux的配置
這根據你使用的Serial application
你現在是short 40-pins expansion header 上的PIN8和PIN10嗎?
請測試以下command:
$ sudo su
# stty -F /dev/ttyTHS1 115200 raw -echo
# cat /dev/ttyTHS1 &
# echo "Hello World" > /dev/ttyTHS1
我在DevKit上面测试UART1通了,UART1对应的设备是/dev/ttyTHS1,那UART0是/dev/ttyTHS2吗?因为没有/dev/ttyTHS0这个节点
我的定制载板还需要使用UART0,我把UART0的RX和TX短接,然后使用这个命令测试不通
不是。
UART0對應的是uartb@3110000,它在M.2 Key E
從你的log看起來目前device tree裡這個node還沒開啟
我的载板上UART0没有用于M.2 Key E,请问怎么开启UART0,我在设备树文件中没有找到uartb@3110000
是这个吗?我看到已经是开启了
我指的是在devkit上面從M.2 Key E接出來,你要根據自己的載板去找從module出來的訊號接到哪
你圖中的是serial@3100000, 不是serial@3110000
我在设备树中添加了uartb:
然后也启用了:
但是我查看状态还是禁用的:
Could you share the steps how you modify device tree?
Do you recompile the kernel image and dtb and reflash the board to apply the change?
我找到原因了,是在tegra234-soc-overlay.dtsi文件中覆盖了我的修改
Cool, can the loopback test working with UART0 on your board?
环回测试成功了,UART0对应的设备是/dev/ttyS0
感谢支持
這決定於你compatible那邊怎麼設定的,8250是另個serial driver
现在虽然环回测试成功了,但是时钟不对,19200波特率时,每个bit长度应为为52us;UART1就是这样的。
而UART0在19200波特率时,每个bit长度实测为0.5us。
我看到Linux_for_Tegra\source\hardware\nvidia\t23x\nv-public\nv-soc\tegra234-soc-overlay.dtsi里面是这样定义的,请问在怎么改UART0的时钟?
serial@3110000 {
			compatible = "nvidia,tegra234-uart", "nvidia,tegra20-uart";
			reg = <0x0 0x03110000 0x0 0x10000>;
			interrupts = <GIC_SPI TEGRA234_IRQ_UARTB IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&bpmp TEGRA234_CLK_UARTB>;
			resets = <&bpmp TEGRA234_RESET_UARTB>;
			status = "disabled";
