Orin Nano Jetpack 6.0 UART1 issue
Continuing the discussion from Orin Nano - Using UARTD or E or F:
We require UART0 and UART1 to be used as general purpose UARTs.
We were able to use UART0 using the device node /dev/ttyTHS1.
But we weren’t able to connect with UART1.
Output of the command sudo dmesg | grep tty is given below:
[sudo] password for mtx003:
[ 0.000000] Kernel command line: root=PARTUUID=4842dbf5-9a9b-45b9-9905-ef6688e1c949 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000
[ 0.000381] printk: console [tty0] enabled
[ 0.072504] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[ 0.184522] printk: console [ttyTCU0] enabled
[ 3.333123] printk: console [tty0]: printing thread started
[ 3.334720] printk: console [ttyTCU0]: printing thread started
[ 3.457601] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 3.458309] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[ 8.999080] systemd[1]: Created slice Slice /system/serial-getty.
/dev/ttyTHS0 which maps to UART1 has not been enabled by the kernel device tree.
How to do this?
Jetpack details:
Package: nvidia-jetpack
Source: nvidia-jetpack (6.0)
Version: 6.0+b106
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-jetpack-runtime (= 6.0+b106), nvidia-jetpack-dev (= 6.0+b106)
Homepage: Jetson - Embedded AI Computing Platform | NVIDIA Developer
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_6.0+b106_arm64.deb
SHA256: 561d38f76683ff865e57b2af41e303be7e590926251890550d2652bdc51401f8
SHA1: ef3fca0c1b5c780b2bad1bafae6437753bd0a93f
MD5sum: 95de21b4fce939dee11c6df1f2db0fa5
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Version: 6.0+b87
Architecture: arm64
Installed-Size: 194
Depends: nvidia-jetpack-runtime (= 6.0+b87), nvidia-jetpack-dev (= 6.0+b87)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_6.0+b87_arm64.deb
SHA256: 70be95162aad864ee0b0cd24ac8e4fa4f131aa97b32ffa2de551f1f8f56bc14e
SHA1: 36926a991855b9feeb12072694005c3e7e7b3836
MD5sum: 050cb1fd604a16200d26841f8a59a038
Any help is welcome.
Thank you
Hi mhnrshd93,
It seems you are using custom carrier board(from previous topic)
Please share the result of the following commands on your board.
$ cat /etc/nv_tegra_release
$ cat /etc/nv_boot_control.conf
Please refer to the following UART mapping in JP6.
UART0 => UART2(PX04, PX05, PX06, PX07): uartb@3110000 (NA) - Unused => To M.2 Key E
UART1 => UART1(PR02, PR03, PR04, PR05): uarta@3100000 (serial1) - /dev/ttyTHS1 => General UART
UART2 => UART3(PCC05, PCC06): NA - /dev/ttyTCU0 => Debug
May I know which UART interface do you mean? (i.e. which pins you are connecting with)
Yes we are using a custom carrier board.
But at the moment we are testing jetpack6.0 in devkit itself before migrating to our carrier board.
The command outputs are here:
R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
TNSPEC 3767-300-0005-K.2-1-1-jetson-orin-nano-devkit-
COMPATIBLE_SPEC 3767–0005–1–jetson-orin-nano-devkit-
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
As per the UART mapping you have given,
UART1 is working for us.
We require UART0 which is /dev/ttyTHS0 to be enabled.
Could please help with this.
Thank you
Do you mean the following one?
If so, please enable the node serial@3110000 in device tree.
Please also note that /dev/ttyTHS0 is not enabled by default.
You also have to modify the following line in device tree.
        aliases {
                rtc1 = "/bus@0/rtc@c2a0000";
                nvdla0 = "/bus@0/host1x@13e00000/nvdla0@15880000";
                nvdla1 = "/bus@0/host1x@13e00000/nvdla1@158c0000";
                tegra-camera-rtcpu = "/rtcpu@bc00000";
                serial1 = "/bus@0/serial@3100000";
                serial2 = "/bus@0/serial@3140000";
+               serial3 = "/bus@0/serial@3110000";
and the /dev/ttyTHS3 should be available for UART0 (0x3110000)
kernel_tegra234-p3768-0000+p3767-0005-nv.txt (238.4 KB)
The modified dtb file is attached here.
It is not showing /dev/ttyTHS3.
These are the commands used:
1. Decompile dtb to dts
$ dtc -I dtb -O dts -o temp.dts kernel_tegra234-p3768-0000+p3767-0005-nv.dtb
2. Modify the contents I shared in previous response
3. Assemble dts back to dtb
$ dtc -I dts -O dtb -o kernel_tegra234-p3768-0000+p3767-0005-nv.dtb temp.dts
Also you say that /dev/ttyTHS0 is enabled by default.
But I dont have that.
I only have /dev/ttyTHS1 and /dev/ttyTHS2.
Screenshot is attached.
Could you check and recommend any changes.
Thank you
You can share the content of dts instead of the dtb binary here.
Could you also share the /boot/extlinux/extlinux.conf for further check?
It’s my typo.
/dev/ttyTHS0 is NOT enabled by default.
kernel_tegra234-p3768-0000+p3767-0005-nv_dts.txt (310.1 KB)
The dts file is attached.
cat /boot/extlinux/extlinux.conf
Command output:
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} root=PARTUUID=4842dbf5-9a9b-45b9-9905-ef6688e1c949 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 nv-auto-config
When testing a custom kernel, it is recommended that you create a backup of
the original kernel and add a new entry to this file so that the device can
fallback to the original kernel. To do this:
1, Make a backup of the original kernel
sudo cp /boot/Image /boot/Image.backup
2, Copy your custom kernel into /boot/Image
3, Uncomment below menu setting lines for the original kernel
4, Reboot
LABEL backup
MENU LABEL backup kernel
LINUX /boot/Image.backup
INITRD /boot/initrd
APPEND ${cbootargs}
Also where should the dtb file be copied?
/boot/dtb/kernel_XXX.dtb
or
/boot/kernel_XXX.dtb
Thank you
This one, but it seems not specified in your /boot/extlinux/extlinux.conf so that it will load the dtb from UEFI binary.
Please modify the following line in your extlinux.conf.
LABEL primary
+    FDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0005-nv.dtb
      LINUX /boot/Image
      INITRD /boot/initrd
After applying the above change, please run the following command to check if it has been applied correctly.
$ cat /proc/device-tree/bus@0/serial@3110000/status
Or you can check dmesg for details.
Hi, it didn’t work. something else happened. Please see the dmesg out.
TIMEOUT 30
DEFAULT primary
LABEL primary
LINUX /boot/Image
INITRD /boot/initrd
4, Reboot
LABEL backup
INITRD /boot/initrd
APPEND ${cbootargs}
okay
[ 0.000390] printk: console [tty0] enabled
[ 0.072624] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[ 0.182263] printk: console [ttyTCU0] enabled
[ 3.327597] printk: console [tty0]: printing thread started
[ 3.328770] printk: console [ttyTCU0]: printing thread started
[ 3.464896] 3110000.serial: ttyS3 at MMIO 0x3110000 (irq = 198, base_baud = 4250000) is a Tegra
[ 3.465509] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 3.465938] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[ 13.023033] systemd[1]: Created slice Slice /system/serial-getty.
You can see that ttyS3 just got mapped to 0x3110000.
Could you check please.
My doubt in dts file are these:
1.
serial@3110000 {
compatible = “nvidia,tegra234-uart\0nvidia,tegra20-uart”;
serial@3140000 {
compatible = “nvidia,tegra194-hsuart”;
serial@3100000 {
Are these values correct?
symbols {
uarta = /bus@0/serial@3100000;
uarte = /bus@0/serial@3140000;
There is no entry for serial@3110000.
Is that correct?
Thank you
From your dmesg, it seems serial@3110000 has been enabled and you can use it through /dev/ttyS3.
If you want it to be ttyTHS3, you can modify the following line in device tree.
serial@3110000 {
-    compatible = "nvidia,tegra234-uart\0nvidia,tegra20-uart";
+    compatible = "nvidia,tegra194-hsuart";
You can also add the following line for serial@3110000
symbols {
+ uartb = /bus@0/serial@3110000;
It has issues:. ttyS3 doesn’t get enabled.
[ 0.000379] printk: console [tty0] enabled
[ 0.072609] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[ 0.195431] printk: console [ttyTCU0] enabled
[ 3.395488] printk: console [tty0]: printing thread started
[ 3.396677] printk: console [ttyTCU0]: printing thread started
[ 3.488996] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 3.490211] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[ 13.063678] systemd[1]: Created slice Slice /system/serial-getty.
  1.  serial@3100000 {
     	reg = <0x00 0x3100000 0x00 0x10000>;
     	interrupts = <0x00 0x70 0x04>;
     	clocks = <0x03 0x9b>;
     	resets = <0x03 0x64>;
     	status = "okay";
     	reset-names = "serial";
     	phandle = <0x1fc>;
     serial@3140000 {
     	reg = <0x00 0x3140000 0x00 0x10000>;
     	interrupts = <0x00 0x74 0x04>;
     	clocks = <0x03 0x9f>;
     	resets = <0x03 0x68>;
     	status = "okay";
     	phandle = <0x1fd>;
     serial@3110000 {
     	reg = <0x00 0x3110000 0x00 0x10000>;
     	interrupts = <0x00 0x71 0x04>;
     	clocks = <0x03 0x9c>;
     	resets = <0x03 0x65>;
     	status = "okay";
Certain entries are missing in serial@3110000 like reset-names and phandle
  1. dts file attached.
Please take a look.
Thank you
temp_dts.txt (310.1 KB)
What do you mean about “doesn’t get enabled”?
Why it appears in your previous dmesg but missing now?
You can try to add reset-names back.
Or you can rebuild the kernel image/dtb instead of modifying it through decompile dtb.
I think you misunderstand.
If I do this,
serial@3110000 {
You can verify this from the dts file I shared in my previous reply.
  1. If the above changes are not done, ttyS3 will be there in dmesg output.
    Even then, it is not working properly. I tried to send data. Rx-Tx was connected in loopback.
    I’am receiving only garbage values.
For example, If I send ‘A’ or 0x41 or 65 what I get is 0x100
If I send ‘1’ or 0x31 or 49, I get 0xC0
  1. I shall add reset-names and phandle manually in dts files.
    What should be the value in phandle for serial@3110000?
Looking forward to your reply.
Thank you
It is expected. In this way, does the /dev/ttyTHS3 show up?
If not, please share the full dmesg for further check.
Please short TXD/RXD and run the following command to verify loopback test.
$ sudo su
# stty -F /dev/ttyS3 115200 raw -echo
# cat /dev/ttyS3 &
# echo "test" > /dev/ttyS3
phandle is generated during building the dtb so that I suggested you modify it from kernel source and build kernel image/dtb manually.
$ sudo su
# cat /dev/ttyS3 &
I tried this with ttyS3. Nothing is displayed by cat.
Tried the same with the working ttyTHS1. I got the results. Loopback is working.
So ttyS3 has an issue.
  1. phandle is generated during building the dtb so that I suggested you modify it from kernel source and build kernel image/dtb manually.
    This can be difficult for us at this point.
  2. It is expected. In this way, does the /dev/ttyTHS3 show up?
    No that’s what I mentioned in the previous reply. It doesnt. Not just even ttyS3 doesnt show up in dmesg reply.
    I posted the dmesg output for your reference too.
Could you check?
Thank you
Could you get a scope and check the waveform?
I think it should be fine w/o phandle if no other nodes in device tree using it.
Please search for 3110000 in dmesg and check if there’s any spelling issue in device tree since I can’t find any message related to address 0x3110000 in your current log.
Checked the ouput of ttyS3, the signal simply toggles when there is activity.
There is no serial waveform. Its garbage.
If I send 0, then the signal remains low.
I have attached the entire dmesg output. I dont see any spelling mistakes.
Please check.
Thank you
dmesg.txt (53.9 KB)
[    3.655085] 3110000.serial: ttyS3 at MMIO 0x3110000 (irq = 198, base_baud = 4250000) is a Tegra
From your dmesg, are you using 4250000 as baudrate for serial communication?
No I’m not using that baud rate.
Our usual baud is 115200. We use that while running our UART application.
I tried ```
 Still ```
base_baud = 4250000
remains same in dmesg.
If you check the dmesg again,
base_baud is 0
How these “base_baud” values are modified?
Thank you
They are configured in driver.
Did you short them(TXD/RXD) from M.2 port?
[    3.699551] 3110000.serial: ttyTHS3 at MMIO 0x3110000 (irq = 198, base_baud = 0) is a TEGRA_UART
I could get above result in dmesg on Orin Nano devkit after configuring the device tree as following.
                serial@3110000 {
                        status = "okay";
