ttyTHS1 (UART1, 40-pin header pins 8/10) TX pad does not drive on JetPack 7 / L4T R39.2 — Orin Nano Super devkit
Summary
On a Jetson Orin Nano Developer Kit (Super), freshly on L4T R39.2 / JetPack 7, I cannot get the 40-pin header UART (UART1 / /dev/ttyTHS1, pins 8/10) to transmit or receive. The controller probes cleanly, the pinmux reports function uarta at the register level, and the device-tree pad config is correct — but the TX pad (PR.02 / pin 8) never drives (measures ~0.3 V on a meter instead of idling at 3.3 V), and a TX↔RX hardware loopback returns no data at any baud.
This looks distinct from the known JetPack 6.2.2 DMA issue (Solved: UART/Serial Port not working after upgrading to JetPack 6.2.2) — I applied that fix (forced PIO) and the behavior is unchanged.
Question: Is ttyTHS1 on the 40-pin header functional on R39.2 for this board, and is there an additional pad/prod-setting required that jetson-io does not apply on R39?
Environment
# /etc/nv_tegra_release
# R39 (release), REVISION: 2.0, GCID: 45755727, BOARD: generic, EABI: aarch64, DATE: Mon Jun  1 09:28:48 PM UTC 2026
# KERNEL_VARIANT: oot
Model:  NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
Kernel: Linux 6.8.12-1021-tegra #1 SMP PREEMPT aarch64
TNSPEC: 3767-300-0005-T.1-1-1-jetson-orin-nano-devkit-super
Board:  p3768-0000 + p3767-0005 (Orin Nano 8GB Super)
Console is on ttyTCU0 (USB-C debug). The 40-pin header UART is free (nvgetty inactive, nothing holds /dev/ttyTHS1).
Goal
Use the 40-pin header UART (pins 8 = UART1_TX, 10 = UART1_RX) as /dev/ttyTHS1 to talk to an external 3.3 V TTL device.
Steps taken
  1. Enabled uarta on the 40-pin header via jetson-io.
    sudo /opt/nvidia/jetson-io/jetson-io.py → Configure 40-pin Header → set pins 8/10 to uarta → Save and reboot. This created /boot/jetson-io-hdr40-user-custom.dtbo and a JetsonIO entry in extlinux.conf (FDT + OVERLAYS), set as DEFAULT.
    (Note: the headless config-by-function.py -o dt uarta route wrote a modified DTB but did not wire it into the boot chain — only the interactive tool added the OVERLAYS line. Possibly worth documenting.)
  2. Applied the known JetPack 6.2.2 DMA workaround (remove dmas/dma-names from serial@3100000 to force PIO). Confirmed in dmesg the UART now runs in PIO mode. No change to the symptom.
  3. Noticed jetson-io set nvidia,gpio-mode = <0x01> on both UART pins in the generated overlay — a property no other pin in the live tree carries. I rebuilt the overlay with gpio-mode = <0x00>. No change to the symptom.
Current state — everything checks out, pad still dead
dmesg — controller probes cleanly in PIO mode:
serial-tegra 3100000.serial: Adding to iommu group 1
serial-tegra 3100000.serial: RX in PIO mode
serial-tegra 3100000.serial: TX in PIO mode
3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 133, base_baud = 0) is a TEGRA_UART
Pinmux register state (/sys/kernel/debug/pinctrl/*/pinmux-pins):
pin 110 (UART1_TX_PR2): 2430000.pinmux (GPIO UNCLAIMED) (HOG) function uarta group uart1_tx_pr2
pin 111 (UART1_RX_PR3): 2430000.pinmux (GPIO UNCLAIMED) (HOG) function uarta group uart1_rx_pr3
Live device-tree pad config (dtc -I fs -O dts /proc/device-tree):
hdr40-pin8 {                       hdr40-pin10 {
    nvidia,tristate = <0x00>;          nvidia,tristate = <0x01>;
    nvidia,function = "uarta";         nvidia,function = "uarta";
    nvidia,enable-input = <0x00>;      nvidia,enable-input = <0x01>;
    nvidia,pins = "uart1_tx_pr2";      nvidia,pins = "uart1_rx_pr3";
    nvidia,gpio-mode = <0x00>;         nvidia,gpio-mode = <0x00>;
TX: drive enabled, input disabled. RX: input enabled, output tristated. Both function uarta. This is correct.
serial@3100000 node (live, post DMA-removal):
serial@3100000 {
    iommus = <0x04 0x04>;
    compatible = "nvidia,tegra194-hsuart";
    status = "okay";
    reg = <0x00 0x3100000 0x00 0x10000>;
Symptom / measurements
  • Loopback test: physical jumper across pins 8↔10 (continuity verified with a meter). Writing to /dev/ttyTHS1 and reading back returns nothing at 9600 and 57600:
    import serial, time
    s = serial.Serial("/dev/ttyTHS1", 57600, timeout=1)
    s.reset_input_buffer()
    s.write(b"PING"); s.flush(); time.sleep(0.2)
    print(repr(s.read(4)))   # -> b''
  • Scope/meter on the TX pad (pin 8): while continuously streaming 0x55, pin 8 reads ~0.3 V (and pin 10, jumpered to it, the same). A live UART TX should idle at ~3.3 V and average ~1.5 V while streaming 0x55. The pad appears to be floating / not driven, despite tristate=0 and function uarta.
  • The exact same external device + a CP2102 USB-TTL adapter works perfectly, so the device and my wiring are known-good.
What I’ve ruled out
  • ❌ Wrong pin / miscount — pin 1 = 3.3 V, pin 2 = 5 V confirmed; jumper continuity on 8↔10 confirmed.
  • ❌ Pinmux not applied — pinmux-pins shows function uarta (HOG), GPIO UNCLAIMED.
  • ❌ Port held by getty/another process — nvgetty inactive, no holders of /dev/ttyTHS1.
  • ❌ DMA fault (the 6.2.2 issue) — forced PIO mode, dmesg clean, no SMMU faults; no change.
  • ❌ gpio-mode=1 — set to 0; no change.
  • ❌ Permissions — user in dialout, port opens fine.
Questions
  1. Is UART1 / ttyTHS1 on the 40-pin header (pins 8/10) functional on R39.2 / JetPack 7 for the Orin Nano Super devkit (p3768-0000 + p3767-0005)? Has it been tested on this release?
  2. With function uarta, tristate=0, gpio-mode=0, and the HOG applied, why would the TX pad (PR.02) not drive? Is there an additional pad/prod setting (drive strength, pull, schmitt, or an MB1/prod-settings pinmux entry) that jetson-io’s hdr40 overlay does not set on R39?
  3. Is jetson-io emitting nvidia,gpio-mode = <0x01> for a UART function a known bug on R39?
  4. Is the correct flashed pinmux (from the Orin Nano pinmux spreadsheet / MB1 BCT) required instead of a runtime overlay for UART1 to actually drive the pad on this release? If so, what is the recommended procedure on R39?
Happy to provide full dmesg, the generated .dtbo, or any register dumps. Thanks!
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
I could not find clear support for that in the provided Jetson Orin Nano documentation.
However, based on the information provided in the context, it seems that you have tried various steps to troubleshoot the issue with the UART1 on the 40-pin header, including enabling the UART1 through jetson-io, applying the known JetPack 6.2.2 DMA workaround, and checking the pinmux register state.
The Community Solutions provided do not directly address the issue with the TX pad not driving on the 40-pin header. However, they do provide information on how to enable UART1 on the 40-pin header, how to configure the pinmux settings, and how to troubleshoot UART issues on the Jetson Orin Nano.
To further troubleshoot the issue, you may want to try checking the device tree configuration, verifying that the UART1 is properly configured and enabled, and ensuring that there are no conflicts with other devices or pins on the 40-pin header. Additionally, you may want to try using a different UART or serial console to see if the issue is specific to the UART1 on the 40-pin header.
It is also recommended to check the NVIDIA Developer Forums and the Jetson Orin Nano documentation for any updates or known issues related to the UART1 on the 40-pin header.
Please note that the information provided is based on the context and may not be comprehensive or up-to-date. For further assistance, it is recommended to consult the official NVIDIA documentation and support resources.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
We have the steps for loopback test in
Making sure you're not a bot!
Do you mean the steps work on Orin Nano developer kit with Jetpack 6.2.2 r36.5, and fails on Jetpack 7.2 r39.2?
Confirmed via your eLinux link that I’m on the documented ttyTHS1/pins 8/10; flow control is off; the TX pad measures 0.3 V and RX receives 0x00 (break), so the controller isn’t driving TX despite a clean probe. Is this functional on R39.2, or is a flashed MB1/prod pinmux required?
I can reproduce what appears to be the same issue on an Orin Nano Super Dev Kit running JetPack 7 / L4T 39.2.0.
Board identification:
cat /proc/device-tree/model
tr '\0' '\n' < /proc/device-tree/compatible
nvidia,p3768-0000+p3767-0005-super
nvidia,p3767-0005
nvidia,tegra234
Installed packages:
nvidia-l4t-core        39.2.0
nvidia-l4t-kernel      6.8.12-tegra-39.2.0
nvidia-l4t-jetson-io   39.2.0
Observed behavior:
  • UART device /dev/ttyTHS1 is present.
  • RX path appears functional.
  • TX path on the 40-pin header (pins 8/10) appears non-functional.
Testing performed:
  1. Connected an ArduPilot Cube Orange+ flight controller to the 40-pin UART.
Wiring:
Orin pin 8  -> Cube RX
Orin pin 10 <- Cube TX
Orin pin 6  -> GND
  1. MAVLink telemetry from the Cube is received correctly on /dev/ttyTHS1.
Examples:
  • Heartbeats received
  • GPS data received
  • Vehicle status received
  1. However, commands sent from the Orin do not appear to reach the Cube.
Examples:
  • MAVLink parameter requests fail
  • QGroundControl cannot download parameters over the UART link
  • MAVProxy param fetch never receives responses
  1. The exact same Cube works immediately when connected by USB (/dev/ttyACM0).
With USB:
  • QGroundControl downloads all parameters instantly
  • MAVProxy param fetch succeeds
  • Full bidirectional MAVLink communication works
  1. Loopback test on the 40-pin UART fails.
Pins 8 and 10 were shorted together and tested using both /dev/ttyTHS1 and /dev/ttyTHS2.
Example:
import serial, time
s = serial.Serial('/dev/ttyTHS1', 115200, timeout=1)
s.write(b'test\n')
s.flush()
time.sleep(0.2)
print(s.read(100))
Expected:
b'test\n'
Actual:
b''
Results were the same for:
  • ttyTHS1 @ 115200
  • ttyTHS1 @ 921600
  • ttyTHS2 @ 115200
  • ttyTHS2 @ 921600
  1. Jetson-IO appears broken for this board variant.
Commands such as:
sudo /opt/nvidia/jetson-io/config-by-function.py -l all
and
sudo /opt/nvidia/jetson-io/config-by-pin.py -p 8
fail with:
RuntimeError: No DTB found for NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super!
This suggests Jetson-IO does not recognize the p3768-0000+p3767-0005-super platform even though the matching DTB files are present under /boot.
Given that:
  • RX works
  • USB MAVLink works
  • Loopback fails
  • Jetson-IO does not support the Super board ID
it appears the issue may be related to UART pinmux / header configuration / DTB support for the Orin Nano Super on L4T 39.2.
Hi consultingfutures and mechmentz,
Could you provide the full dmesg and device tree in runtime for further check?
Have you also tried if it could work in DMA mode with dma related properties added?
ttyTHS1 / UART1 (40-pin pins 8/10) TX does not drive — root cause is pinmux not applied; how do I apply it on this SKU?
Board / versions
  • Model: NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
  • Compatible: nvidia,p3768-0000+p3767-0005-super, nvidia,p3767-0005, nvidia,tegra234
  • nvidia-l4t-core 39.2.0, nvidia-l4t-kernel 6.8.12-tegra-39.2.0, kernel 6.8.12-1021-tegra, nvidia-l4t-jetson-io 39.2.0 (JetPack 7)
Re: “have you tried DMA mode with the dma properties added?” — The PIO workaround earlier in the thread was the other reporter’s, not mine. My board runs the stock DMA config and TX still does not drive:
serial@3100000 {
dma-names = "rx", "tx"; /* both channels present */
dmas = <...>;
status = "okay";
/* no pinctrl-0 / pinctrl-names on this node */
So DMA-vs-PIO is not the variable. Full dmesg and runtime DT (dtc -I fs -O dts /proc/device-tree) attached.
Root cause — the 40-pin UART1 pads are never muxed to the UART:
  • serial@3100000 has no pinctrl-0/pinctrl-names, so the kernel never applies a UART pinmux; pads stay at the MB1 BCT default.
  • In 2430000.pinmux:
pin 110 (UART1_TX_PR2): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 111 (UART1_RX_PR3): (MUX UNCLAIMED) (GPIO UNCLAIMED)
Nothing muxes header pin 8 to the uarta TX function — consistent with TX not driving.
  • jetson-io can’t configure this board: config-by-function.py/config-by-pin.py fail with RuntimeError: No DTB found for NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super!
  • NVIDIA’s own /boot/tegra234-p3767-0000+p3509-a02-hdr40.dtbo lists this board in its compatible and would set pin8 = uart1_tx_pr2 → uarta, pin10 = uart1_rx_pr3 → uarta — but it is not being applied (below).
What I tried to apply the hdr40 pinmux, and the results:
  1. Runtime configfs overlay — unavailable; /sys/kernel/config/device-tree does not exist (OF-configfs not in this kernel).
  2. extlinux OVERLAYS= with the stock hdr40 .dtbo (compatible matches this board) — ignored; after reboot pads still UNCLAIMED, no pinctrl-0. A custom overlay was also ignored. OVERLAYS does not appear to be honored by the UEFI launcher on R39.2.
  3. extlinux FDT= (hdr40 merged into the active kernel-dtb via fdtoverlay) — prevented boot: UEFI loaded it (EFI stub: Using DTB from configuration table) but the kernel hung right after Exiting boot services…, apparently because the runtime fixups UEFI applies to the partition DTB are not applied to a user FDT. Recovery required restoring extlinux.conf from another machine.
Question: On this SKU running R39.2 / JetPack 7, what is the supported way to apply the 40-pin pinmux (hdr40 content, pin 8/10 → uarta) when jetson-io doesn’t support the board, there’s no configfs overlay interface, OVERLAYS isn’t applied, and a custom FDT breaks boot? Is the intended path a host-side reflash (regenerating the pinmux BCT from the Orin Nano pinmux spreadsheet, or enabling hdr40 in the flashing config so it’s baked into the kernel-dtb partition)? If so, the exact file/procedure for R39.2 would help. And is the jetson-io “No DTB found …Super” failure a known defect for this variant?
In your case, please check if removing the DMA related properties could get serial interface working with PIO mode.
I would suggest using pinmux spreadsheet to configure the pinmux dtsi to be loaded in MB1.
Jetson-IO should work with the devkit configured with super mode board configuration.
Thanks — that matches what I found directly on the board: no pinctrl-0/pinctrl-names on serial@3100000, and pinmux-pins shows UART1_TX_PR2 (MUX UNCLAIMED). To close the loop on DMA: my board runs the stock DMA config (dmas/dma-names present, no PIO workaround) and TX still doesn’t drive, so the issue is purely the unclaimed pad mux, not DMA/PIO.
I also confirmed that on this UEFI / L4T R39.2 SKU I can’t fix it on-device: extlinux OVERLAYS is silently ignored (even NVIDIA’s own tegra234-p3767-0000+p3509-a02-hdr40.dtbo, whose compatible lists p3768-0000+p3767-0005-super), and merging into the boot DTB via FDT bricks the boot. So I’m ready to do it host-side.
One question: you mention Jetson-IO should work “with the devkit configured with super mode board configuration” — for me Jetson-IO fails with No DTB found for …Engineering Reference Developer Kit Super. What is that super-mode board configuration, and how do I apply it (is it a specific flash config/BSP step)? If Jetson-IO can then configure pin 8, that’s preferable to a manual pinmux BCT. Otherwise I’ll generate the pinmux dtsi from the spreadsheet and flash MB1 from a host.
May I know how you flashed your devkit with super mode enabled?
You can refer to Quick Start — NVIDIA Jetson Linux Developer Guide for the steps to setup/flash the devkit.
Jetson Orin Nano Developer Kit with Super Configuration (NVMe):
$ sudo ./l4t_initrd_flash.sh --erase-all jetson-orin-nano-devkit-super internal
Okay, please also check if updating the pinmux dtsi could help for your case.
