Enable UART1
Im using jetson orin nano jetpack 6 i want to enable UART1 on the 40 pin header ,How is possible ?
nvidia@ubuntu:/proc/device-tree$ ls /dev/ttyTHS*
/dev/ttyTHS1 /dev/ttyTHS2
only enable these two no found the THS0 and in the 40 pin expansion header is
                  3.3V (  1) .. (  2) 5V
                i2c8 (  3) .. (  4) 5V
                 i2c8 (  5) .. (  6) GND
              unused (  7) .. (  8) uarta
                GND (  9) .. ( 10) uarta
Hi niyas2,
Are you using the devkit or custom board for Orin Nano?
I think it has been enabled by default and you can simply use it through /dev/ttyTHS1.
Please try shorting PIN8/PIN10 of 40-pins header and run the following command to verify.
$ sudo su
# stty -F /dev/ttyTHS1 115200 raw -echo
# cat /dev/ttyTHS1 &
# echo "test" > /dev/ttyTHS1
