The Jetson I am using:
Jetson Orin NX Engineering Reference Developer Kit - Jetpack 6.0 [L4T 36.3.0]
699-level Part Number: 699-13767-0005-300 M.1
P-Number: p3767-0005
Module: NVIDIA Jetson Orin Nano (Developer kit)
SoC: tegra234
I am trying to write to UART0 (UARTB β M2 key WI-FI slot) but I think its disabled by default. Here are the UART devices I can see after bootup:
As I have already flashed I wanted to try enabling UART0 in the dts file that the extlinux.conf points to:
/boot/dtb/tegra234-p3768-0000+p3767-0005-nv.dts
I converted my dtb to a dts and it was disabled so I changed it to:
I then compiled it back to dtb and rebooted but I still cant se a new /dev/THS device, I still only see:
No new device at MMIO 0x3110000
Does anyone know what I am doing wrong?
Hi matt.read,
Are you using the Orin Nano devkit board or the custom carrier board from ConnectTech?
Please check if thereβs FDT
entry in /boot/extlinux/extlinux.conf .
If not, it would load DTB from partition rather than rootfs.
Hi @KevinFFF , I am on the Orin Nano devkit board (p3768-0000).
I have now tried to do this pre-flash and have edited the dtb file in Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0005-nv.dtb
I then compiled it back to dtb and flashed my devkit with:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 --erase-all -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
After the Orin Nano booted up I checked my extlinux.conf file and it was missing the FDT
entry so it will be using the DTB from partition like you mentioned in your previous post. I then added the FDT
entry line manually and rebooted:
After reboot I still didnβt see a new TEGRA_UART@0x3110000
Maybe Im missing something from my dtb?
Do I need to add a serial3 = β/bus@0/serial@3110000β;
And a uartb = β/bus@0/serial@3110000β;
just an update I have changed serial@3110000 to:
And also included:
uartb = "/bus@0/serial@3110000";
and after a reboot I now see a THS3:
It all works now
system
Closed
November 5, 2024, 6:16am
7
