I am using Orin NX on my custom carrier board.I want to use UART0(PIN99,PIN101),but it seem to be missing in /dev.What should I do to get it back?
Here is the flash log.
flashlog.txt (280.4 KB)
Here is what I see in /dev.
nvidia@nvidia-desktop:~$ cd /dev/
nvidia@nvidia-desktop:/dev$ ls
autofs capture-isp-channel57 capture-vi-channel52 loop0 nvme0n1p11 tty15 ttyGS0
block capture-isp-channel58 capture-vi-channel53 loop1 …
After this post ,I try to modify the dtb files on my flash pc ,so the Orin NX UART0 can be on automaticlly.And I encountered some hitbacks .
Here is my steps.
1.Like the post ,I edited the dtb files on the flash pc.
Let me provide brief steps for this…
Please refer to the following steps in your board
1. Decompile dtb to dts
$ dtc -I dtb -O dts -o temp.dts kernel_tegra234-p3767-0004-p3768-0000-a0.dtb
2. Modify the contents I shared in previous response
3. Assemble dts back to dtb
$ dtc -I dts -O dtb -o kernel_tegra234-p3767-0004-p3768-0000-a0.dtb temp.dts
I cannot attach dtb files here. So just changed the extension to txt. The file content is exact.
temp.dts.txt (431.6 KB)
kernel_tegra234-p3767-0000-p3768-0000-a0.dtb.txt (338.7 KB)
2.I flash the Orin NX.
flash_1-1_0_20240401-223857.log (40.7 KB)
3.I cannot find ttyTHS1 in /dev.
Here is the dtb file in the Orin NX.
After I decompile it,I can see the status of serial@3110000 is still disabled.How come?
Any help is welcome.
Thank you.
How did you flash it?
Did you replace the dtb file in BSP?
I use this command to flash.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
2.I replaced the files in my fash pc in Linux_for_Tegra/rootfs/boot.
But I did not change the files in the Orin NX.
You need to replace the file under Linux_for_Tegra/kernel/dtb/, not Linux_for_Tegra/rootfs/boot/.
Your solution works. Problem solved. /dev/ttyTHS1 is showing in device nodes.
Thank you
