I’m trying to enable UART5 (/dev/ttyTHS4) on a Jetson Orin Nano 8GB using the Seeed Studio reComputer J401 carrier board, but the pinmux settings don’t seem to apply, and the port does not appear after reboot. Below is a summary of what I have done so far.
Environment
・Jetson SoC: Jetson Orin Nano 8GB
・Carrier Board: Seeed Studio reComputer J401
・JetPack / L4T: R35.5.0
・Goal: Enable /dev/ttyTHS4 (UART5) for communication
・Pins Used: Pin 31 (TX), Pin 29 (RX) on the 40-pin header (UART5 on J401)
What I’ve tried
- Created a device tree overlay
uart5-enable.dts:
/dts-v1/;
/plugin/;
compatible = “nvidia,jetson-orin-nano-devkit”;
fragment@0 {
target-path = "/serial@3140000";
__overlay__ {
status = "okay";
fragment@1 {
target-path = "/pinmux@2430000";
__overlay__ {
uart5_pinmux: uart5_pinmux {
nvidia,pins = "uart5_tx", "uart5_rx";
nvidia,function = "uart";
nvidia,pull = <0>;
nvidia,tristate = <0>;
Built it using:
dtc -I dts -O dtb -o uart5-enable.dtbo uart5-enable.dts
sudo cp uart5-enable.dtbo /boot/
- Edited `/boot/extlinux/extlinux.conf:
I added this to the APPEND line:
overlay_dtbo=uart5-enable.dtbo
(I made sure the APPEND line is a single line and syntax is valid.)
- Rebooted and checked the result:
ls /dev/ttyTHS4
→ found
sudo cat /sys/kernel/debug/pinctrl/2430000.pinmux/pinmux-pins | grep uart5
→ No output
Confirmed
・uart5-enable.dtbo exists in /boot/
・No typos or syntax errors in extlinux.conf
・No conflicting overlays
・Seeed’s documentation confirms that Pin 31 and 29 are mapped to UART5 (TX/RX)
Questions
・Is there anything additional required to enable UART5 (ttyTHS4) on Orin Nano using the J401 carrier board?
・Is placing .dtbo in /boot/ sufficient for L4T R35.5.0, or does it need to be in another directory (e.g., /boot/dtb/overlays/)?
・Are "uart5_tx" and "uart5_rx" correct for nvidia,pins when targeting UART5 on this platform?
Additional Notes
・I successfully disabled nvgetty and confirmed that ttyTHS0 works for general communication.
・I also tried a similar approach with ttyTHS3 (UART4), but the pinmux state did not change there either.
Any help or insight would be greatly appreciated.
Thank you!
