Jetson orin nano HDMI output error
jetson linux 36.3 + jetson orin nano + HDMI output:
flash with p3768-0000-p3767-0000-a0-nvme.conf +
PINMUX_CONFIG=“tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi”;
PMC_CONFIG=“tegra234-mb1-bct-padvoltage-p3767-hdmi-a03.dtsi”;
OVERLAY_DTB_FILE+=“,tegra234-dcb-p3767-0000-hdmi.dtbo”;
DCE_OVERLAY_DTB_FILE=“tegra234-dcb-p3767-0000-hdmi.dtbo”;
sudo xrandr
xrandr:Failed to get size of gamma for output default
other case :
jetson linux 36.3 + jetson orin nx + HDMI output: OK
jetson linux 36.3 + jetson orin nano + DP output: OK
log:
tson System firmware version 36.3.0-gcid-36191598 date 2024-05-06T16:58:59+00:
00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
bugfs initialized
TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.136-tegra (kevinguan@via-OMEN-by-HP-Laptop-17-ck1xxx) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #9 SMP PREEMPT Wed Nov 13 11:20:24 CST 2024 ()
[ 0.000000] Machine model: NVIDIA Jetson Orin Nano Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x26d85f198 SMBIOS=0xffff0000 SMBIOS 3.0=0x26d230000 MEMATTR=0x2676c8018 ESRT=0x266a15918 RNG=0x25ad90018 MEMRESERVE=0x25ba24c18
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x0000000266a15918 to 0x0000000266a15950.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000024a000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000277ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x271309800-0x27130bfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000277ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000bdffffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000025e274fff]
[ 0.000000] node 0: [mem 0x000000025e275000-0x000000025e43bfff]
[ 0.000000] node 0: [mem 0x000000025e43c000-0x000000026b91ffff]
[ 0.000000] node 0: [mem 0x000000026b920000-0x000000026d85ffff]
[ 0.000000] node 0: [mem 0x000000026d860000-0x0000000271dfffff]
[ 0.000000] node 0: [mem 0x0000000271e00000-0x0000000271ffffff]
[ 0.000000] node 0: [mem 0x0000000272000000-0x000000027259ffff]
[ 0.000000] node 0: [mem 0x0000000272f00000-0x0000000272ffffff]
[ 0.000000] node 0: [mem 0x0000000276000000-0x0000000277ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000277ffffff]
[ 0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80344 r8192 d30248 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2001056
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=PARTUUID=8759ddf6-2e43-423e-8c53-e3ab5e04164b rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/fiRNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
ware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000
[ 0.000000] Unknown kernel command line parameters “mminit_loglevel=4 fbcon=map:0 bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000”, will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 7521676K/8133248K available (18944K kernel code, 4052K rwdata, 9948K rodata, 7616K init, 521K bss, 349428K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000358] Console: colour dummy device 80x25
[ 0.000368] printk: console [tty0] enabled
[ 0.000429] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000436] pid_max: default: 32768 minimum: 301
[ 0.000471] LSM: Security Framework initializing
[ 0.000495] Yama: becoming mindful.
[ 0.000515] SELinux: Initializing.
[ 0.000584] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000597] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001713] rcu: Hierarchical SRCU implementation.
[ 0.003864] Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[ 0.004174] Remapping and enabling EFI services.
[ 0.004975] smp: Bringing up secondary CPUs …
[ 0.005480] Detected PIPT I-cache on CPU1
[ 0.005525] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.005560] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.006008] Detected PIPT I-cache on CPU2
[ 0.006020] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006035] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006444] Detected PIPT I-cache on CPU3
[ 0.006454] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006467] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.008922] Detected PIPT I-cache on CPU4
[ 0.008952] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[ 0.008980] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.009466] Detected PIPT I-cache on CPU5
[ 0.009479] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[ 0.009495] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.009553] smp: Brought up 1 node, 6 CPUs
[ 0.009558] SMP: Total of 6 processors activated.
[ 0.009562] CPU features: detected: 32-bit EL0 Support
[ 0.009563] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.009565] CPU features: detected: Common not Private translations
[ 0.009567] CPU features: detected: CRC32 instructions
[ 0.009568] CPU features: detected: Data cache clean to Point of Persistence
[ 0.009570] CPU features: detected: Generic authentication (architected algorithm)
[ 0.009571] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.009572] CPU features: detected: LSE atomic instructions
[ 0.009573] CPU features: detected: Privileged Access Never
[ 0.009575] CPU features: detected: RAS Extension Support
[ 0.009578] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.024701] spectre-bhb mitigation disabled by command line option
[ 0.038483] CPU: All CPU(s) started at EL2
[ 0.039917] devtmpfs: initialized
[ 0.051604] KASLR enabled
[ 0.051715] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.051728] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.053873] pinctrl core: initialized pinctrl subsystem
[ 0.054429] SMBIOS 3.6.0 present.
[ 0.054441] DMI: NVIDIA NVIDIA Jetson Orin Nano Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[ 0.054742] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.056003] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.056078] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.056132] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.056165] audit: initializing netlink subsys (disabled)
[ 0.056235] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
[ 0.057231] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.057233] thermal_sys: Registered thermal governor ‘user_space’
[ 0.057234] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.059312] cpuidle: using governor menu
[ 0.059506] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.059577] ASID allocator initialised with 32768 entries
[ 0.060767] Serial: AMBA PL011 UART driver
[ 0.061635] printk: console [ramoops-1] enabled
[ 0.061638] pstore: Registered ramoops as persistent store backend
[ 0.061640] ramoops: using 0x200000@0x2725f0000, ecc: 0
[ 0.068129] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 15, base_baud = 0) is a SBSA
[ 0.081027] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.090357] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.090363] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.090366] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.090368] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.091301] cryptd: max_cpu_qlen set to 1000
[ 0.093242] ACPI: Interpreter disabled.
[ 0.094952] VDD_1V8_AO: supplied by VDD_5V0_SYS
[ 0.095134] VDD_3V3_AO: supplied by VDD_5V0_SYS
[ 0.095715] iommu: Default domain type: Translated
[ 0.095721] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.096086] SCSI subsystem initialized
[ 0.096356] vgaarb: loaded
[ 0.096572] usbcore: registered new interface driver usbfs
[ 0.096598] usbcore: registered new interface driver hub
[ 0.096615] usbcore: registered new device driver usb
[ 0.097117] pps_core: LinuxPPS API ver. 1 registered
[ 0.097122] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.097128] PTP clock support registered
[ 0.097208] EDAC MC: Ver: 3.0.0
[ 0.098589] Registered efivars operations
[ 0.099346] FPGA manager framework
[ 0.099424] Advanced Linux Sound Architecture Driver Initialized.
[ 0.100415] clocksource: Switched to clocksource arch_sys_counter
[ 0.136818] VFS: Disk quotas dquot_6.6.0
[ 0.136894] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.137125] pnp: PnP ACPI: disabled
[ 0.140461] NET: Registered PF_INET protocol family
[ 0.140790] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.142528] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.142568] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.142582] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.142678] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.144069] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.144300] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.144333] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.144562] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.145022] RPC: Registered named UNIX socket transport module.
[ 0.145025] RPC: Registered udp transport module.
[ 0.145027] RPC: Registered tcp transport module.
[ 0.145028] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.145042] PCI: CLS 0 bytes, default 64
[ 0.145342] Unpacking initramfs…
[ 0.153671] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.153979] kvm [1]: IPA Size Limit: 48 bits
[ 0.154018] kvm [1]: GICv3: no GICV resource entry
[ 0.154026] kvm [1]: disabling GICv2 emulation
[ 0.154052] kvm [1]: GIC system register CPU interface enabled
[ 0.154128] kvm [1]: vgic interrupt IRQ9
[ 0.154288] kvm [1]: VHE mode initialized successfully
[ 0.157734] Initialise system trusted keyrings
[ 0.157880] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[ 0.162261] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.162765] NFS: Registering the id_resolver key type
[ 0.162807] Key type id_resolver registered
[ 0.162809] Key type id_legacy registered
[ 0.162868] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.162884] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.162914] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.163171] 9p: Installing v9fs 9p2000 file system support
[ 0.178847] NET: Registered PF_ALG protocol family
[ 0.178873] Key type asymmetric registered
[ 0.178879] Asymmetric key parser ‘x509’ registered
[ 0.179037] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.179044] io scheduler mq-deadline registered
[ 0.179051] io scheduler kyber registered
[ 0.190609] EINJ: ACPI disabled.
[ 0.203985] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.205922] SuperH (H)SCI(F) driver initialized
[ 0.206314] msm_serial: driver initialized
[ 0.206997] printk: console [ttyTCU0] enabled
[ 0.208036] arm-smmu 8000000.iommu: probing hardware configuration…
[ 0.208042] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.208048] arm-smmu 8000000.iommu: stage 1 translation
[ 0.208050] arm-smmu 8000000.iommu: stage 2 translation
[ 0.208052] arm-smmu 8000000.iommu: nested translation
[ 0.208059] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.208066] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.208080] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.208085] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.208089] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.209189] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.209194] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.209199] arm-smmu 10000000.iommu: stage 1 translation
[ 0.209201] arm-smmu 10000000.iommu: stage 2 translation
[ 0.209204] arm-smmu 10000000.iommu: nested translation
[ 0.209207] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.209209] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.209216] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.209217] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.209219] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.209640] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.209643] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.209645] arm-smmu 12000000.iommu: stage 1 translation
[ 0.209646] arm-smmu 12000000.iommu: stage 2 translation
[ 0.209647] arm-smmu 12000000.iommu: nested translation
[ 0.209650] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.209652] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.209658] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.209660] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.209661] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.217539] loop: module loaded
[ 0.218477] megasas: 07.717.02.00-rc1
[ 0.223015] tun: Universal TUN/TAP device driver, 1.6
[ 0.223666] thunder_xcv, ver 1.0
[ 0.223694] thunder_bgx, ver 1.0
[ 0.223714] nicpf, ver 1.0
[ 0.224636] hclge is initializing
[ 0.224670] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.224676] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.224717] e1000: Intel(R) PRO/1000 Network Driver
[ 0.224723] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.224754] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.224758] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.224790] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.224794] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.224816] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.224820] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.225043] sky2: driver version 1.30
[ 0.225791] VFIO - User Level meta-driver version: 0.3
[ 0.227600] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.227614] ehci-pci: EHCI PCI platform driver
[ 0.227639] ehci-platform: EHCI generic platform driver
[ 0.227724] ehci-orion: EHCI orion driver
[ 0.227798] ehci-exynos: EHCI Exynos driver
[ 0.227856] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.227937] ohci-pci: OHCI PCI platform driver
[ 0.227967] ohci-platform: OHCI generic platform driver
[ 0.228050] ohci-exynos: OHCI Exynos driver
[ 0.228562] usbcore: registered new interface driver usb-storage
[ 0.230523] i2c_dev: i2c /dev entries driver
[ 0.234006] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.236293] sdhci: Secure Digital Host Controller Interface driver
[ 0.236298] sdhci: Copyright(c) Pierre Ossman
[ 0.236815] Synopsys Designware Multimedia Card Interface Driver
[ 0.237526] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.238785] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.239871] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.240444] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.241827] tegra-bpmp bpmp: firmware: 4f590cddd4eeb67cd15b-3b0e1a33cf8
[ 0.404582] Freeing initrd memory: 12796K
[ 3.260495] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 3.260527] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 3.260533] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 3.261052] usbcore: registered new interface driver usbhid
[ 3.261058] usbhid: USB HID core driver
[ 3.267088] optee: probing for conduit method.
[ 3.267139] optee: revision 3.22 (e7b5ff3f)
[ 3.326470] optee: dynamic shared memory is enabled
[ 3.326738] optee: initialized driver
[ 3.330100] usbcore: registered new interface driver snd-usb-audio
[ 3.332036] NET: Registered PF_PACKET protocol family
[ 3.332341] 9pnet: Installing 9P2000 support
[ 3.332470] Key type dns_resolver registered
[ 3.334082] printk: console [tty0]: printing thread started
[ 3.334623] printk: console [ttyTCU0]: printing thread started
[ 3.335483] printk: console [ramoops-1]: printing thread started
[ 3.335756] Loading compiled-in X.509 certificates
[ 3.349623] Loaded X.509 cert ‘Build time autogenerated kernel key: f3da6536cde1db8f2138a24640d62ee72191e47d’
[ 3.350767] pstore: Using crash dump compression: deflate
[ 3.376049] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[ 3.382209] amos9k gpio init
[ 3.382222] amos9k_set_gpio: gpio352 (1)
[ 3.382296] amos9k_set_gpio: gpio353 (1)
[ 3.382315] amos9k_set_gpio: gpio328 (0)
[ 3.382317] amos9k_set_gpio: unable to request gpio (-517)
[ 3.382318] amos9k_set_gpio: gpio389 (1)
[ 3.430099] simple-framebuffer chosen:framebuffer: framebuffer at 0x27de00000, 0x870000 bytes
[ 3.430112] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=1920x1080x32, linelength=8192
[ 3.432373] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[ 3.433553] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 3.435940] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 3.437519] serial-tegra 3100000.serial: RX in PIO mode
[ 3.437524] serial-tegra 3100000.serial: TX in PIO mode
[ 3.437602] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 126, base_baud = 0) is a TEGRA_UART
[ 3.439589] serial-tegra 3140000.serial: RX in PIO mode
[ 3.439599] serial-tegra 3140000.serial: TX in PIO mode
[ 3.439715] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 127, base_baud = 0) is a TEGRA_UART
[ 3.443175] tegra_rtc c2a0000.rtc: registered as rtc1
[ 3.443187] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.443686] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 3.447040] inv_mpu: inv_mpu_probe: power on here.
[ 3.447048] inv_mpu: inv_mpu_probe: power on.
[ 3.552966] inv_mpu: whoami= 68
[ 3.571413] inv_mpu: inv_mpu_initialize: initialize result is 0…
[ 3.572492] inv_mpu: wakeup_source is created successfully
[ 3.572501] inv-mpu-iio-i2c 0-0068: icm43600 ma-kernel-10.0.2 is ready to go!
[ 3.572504] inv_mpu: Data read from FIFO
[ 3.573663] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 3.580056] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 3.584899] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 3.590420] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[ 3.591163] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 3.595700] pca953x 7-0022: supply vcc not found, using dummy regulator
[ 3.595885] pca953x 7-0022: using AI
[ 3.597470] amos9k_set_gpio: gpio306 (1)
[ 3.598014] amos9k_set_gpio: gpio300 (1)
[ 3.598360] amos9k_set_gpio: gpio313 (1)
[ 3.598875] amos9k_set_gpio: gpio302 (1)
[ 3.617664] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1534000 KHz, changing to: 1510400 KHz
[ 3.620778] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1532000 KHz, changing to: 1510400 KHz
[ 3.624854] tegra-xusb 3610000.usb: Adding to iommu group 2
[ 3.639297] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 3.639304] tegra-xusb 3610000.usb: xHCI Host Controller
[ 3.639315] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 3.640063] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[ 3.640083] tegra-xusb 3610000.usb: irq 18, io mem 0x03610000
[ 3.640209] tegra-xusb 3610000.usb: xHCI Host Controller
[ 3.640213] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 3.640217] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.640663] hub 1-0:1.0: USB hub found
[ 3.640679] hub 1-0:1.0: 4 ports detected
[ 3.640974] hub 2-0:1.0: USB hub found
[ 3.640985] hub 2-0:1.0: 4 ports detected
[ 3.642054] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 3.643215] irq: IRQ224: trimming hierarchy from :bus@0:pmc@c360000
[ 3.643282] irq: IRQ225: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 3.643328] irq: IRQ226: trimming hierarchy from :bus@0:pmc@c360000
[ 3.643393] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 3.645277] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 3.689151] ALSA device list:
[ 3.689157] No soundcards found.
[ 3.734094] irq: IRQ227: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 3.734247] mmc0: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 3.735245] Freeing unused kernel memory: 7616K
[ 3.735329] Run /init as init process
[ 3.746356] Checking overlayfs setting…
[ 3.756368] Overlayfs is disabled…
[ 3.762857] Root device found: PARTUUID=8759ddf6-2e43-423e-8c53-e3ab5e04164b
[ 3.980670] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.136536] hub 1-2:1.0: USB hub found
[ 4.137155] hub 1-2:1.0: 4 ports detected
[ 4.262768] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 4.317838] hub 2-1:1.0: USB hub found
[ 4.319166] hub 2-1:1.0: 4 ports detected
[ 4.828412] usb 1-2.4: new full-speed USB device number 3 using tegra-xusb
[ 8.027636] tegra194-pcie 14100000.pcie: Adding to iommu group 4
[ 8.030651] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[ 8.030679] tegra194-pcie 14100000.pcie: MEM 0x2080000000…0x20a7ffffff → 0x2080000000
[ 8.030687] tegra194-pcie 14100000.pcie: MEM 0x20a8000000…0x20afffffff → 0x0040000000
[ 8.030691] tegra194-pcie 14100000.pcie: IO 0x0030100000…0x00301fffff → 0x0030100000
[ 8.031007] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[ 8.031010] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 8.060070] tegra-xudc 3550000.usb: Adding to iommu group 5
[ 8.136595] tegra194-pcie 14100000.pcie: Link up
[ 8.139188] tegra194-pcie 14100000.pcie: Link up
[ 8.139248] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.139252] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.139256] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.139259] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.139261] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.139310] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.139470] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.143073] pci 0001:01:00.0: [1b4b:2b43] type 00 class 0x020000
[ 8.143275] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
[ 8.143389] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x0001ffff 64bit pref]
[ 8.143502] pci 0001:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[ 8.144416] pci 0001:01:00.0: supports D1
[ 8.144418] pci 0001:01:00.0: PME# supported from D0 D1 D3hot D3cold
[ 8.145307] pci 0001:01:00.1: [1b4b:2b44] type 00 class 0x020000
[ 8.145508] pci 0001:01:00.1: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
[ 8.145620] pci 0001:01:00.1: reg 0x18: [mem 0x00000000-0x0001ffff 64bit]
[ 8.145734] pci 0001:01:00.1: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[ 8.146525] pci 0001:01:00.1: supports D1
[ 8.146527] pci 0001:01:00.1: PME# supported from D0 D1 D3hot D3cold
[ 8.159554] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 8.159558] pci 0001:00:00.0: BAR 15: assigned [mem 0x2080000000-0x20802fffff 64bit pref]
[ 8.159562] pci 0001:01:00.0: BAR 0: assigned [mem 0x2080000000-0x20800fffff 64bit pref]
[ 8.159652] pci 0001:01:00.1: BAR 0: assigned [mem 0x2080100000-0x20801fffff 64bit pref]
[ 8.159742] pci 0001:01:00.0: BAR 2: assigned [mem 0x2080200000-0x208021ffff 64bit pref]
[ 8.159831] pci 0001:01:00.1: BAR 2: assigned [mem 0x20a8000000-0x20a801ffff 64bit]
[ 8.159920] pci 0001:01:00.0: BAR 4: assigned [mem 0x2080220000-0x2080223fff 64bit pref]
[ 8.160009] pci 0001:01:00.1: BAR 4: assigned [mem 0x2080224000-0x2080227fff 64bit pref]
[ 8.160097] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.160102] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 8.160105] pci 0001:00:00.0: bridge window [mem 0x2080000000-0x20802fffff 64bit pref]
[ 8.160209] pcieport 0001:00:00.0: Adding to iommu group 4
[ 8.160306] pcieport 0001:00:00.0: PME: Signaling with IRQ 22
[ 8.160628] pcieport 0001:00:00.0: AER: enabled with IRQ 22
[ 8.161467] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 8.164411] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[ 8.164433] tegra194-pcie 14160000.pcie: MEM 0x2140000000…0x2427ffffff → 0x2140000000
[ 8.164441] tegra194-pcie 14160000.pcie: MEM 0x2428000000…0x242fffffff → 0x0040000000
[ 8.164447] tegra194-pcie 14160000.pcie: IO 0x0036100000…0x00361fffff → 0x0036100000
[ 8.164769] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[ 8.164771] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 8.272410] tegra194-pcie 14160000.pcie: Link up
[ 8.273447] tegra194-pcie 14160000.pcie: Link up
[ 8.273498] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 8.273503] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 8.273506] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.273509] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 8.273511] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.273551] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.273696] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.277093] pci 0004:01:00.0: [1987:5021] type 00 class 0x010802
[ 8.277280] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 8.282360] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 8.282365] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 8.282447] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.282452] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 8.282543] pcieport 0004:00:00.0: Adding to iommu group 6
[ 8.282621] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[ 8.283278] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[ 8.283517] nvme 0004:01:00.0: Adding to iommu group 6
[ 8.284164] nvme nvme0: pci function 0004:01:00.0
[ 8.284415] nvme 0004:01:00.0: enabling device (0000 → 0002)
[ 8.284830] tegra194-pcie 141e0000.pcie: Adding to iommu group 7
[ 8.287560] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[ 8.287583] tegra194-pcie 141e0000.pcie: MEM 0x3000000000…0x3227ffffff → 0x3000000000
[ 8.287594] tegra194-pcie 141e0000.pcie: MEM 0x3228000000…0x322fffffff → 0x0040000000
[ 8.287598] tegra194-pcie 141e0000.pcie: IO 0x003e100000…0x003e1fffff → 0x003e100000
[ 8.288231] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[ 8.288235] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 8.302482] nvme nvme0: allocated 64 MiB host memory buffer.
[ 8.308252] nvme nvme0: 6/0/0 default/read/poll queues
[ 8.310215] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 8.396593] tegra194-pcie 141e0000.pcie: Link up
[ 8.399344] tegra194-pcie 141e0000.pcie: Link up
[ 8.399409] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 8.399414] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[ 8.399418] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.399422] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 8.399424] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff pref]
[ 8.399473] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 8.399625] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 8.403170] pci 0007:01:00.0: [10ec:8168] type 00 class 0x020000
[ 8.403326] pci 0007:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 8.403506] pci 0007:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 8.403623] pci 0007:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 8.404574] pci 0007:01:00.0: supports D1 D2
[ 8.404576] pci 0007:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.419505] pci 0007:00:00.0: BAR 14: assigned [mem 0x3228000000-0x32280fffff]
[ 8.419509] pci 0007:00:00.0: BAR 13: assigned [io 0x200000-0x200fff]
[ 8.419513] pci 0007:01:00.0: BAR 4: assigned [mem 0x3228000000-0x3228003fff 64bit]
[ 8.419606] pci 0007:01:00.0: BAR 2: assigned [mem 0x3228004000-0x3228004fff 64bit]
[ 8.419697] pci 0007:01:00.0: BAR 0: assigned [io 0x200000-0x2000ff]
[ 8.419725] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 8.419727] pci 0007:00:00.0: bridge window [io 0x200000-0x200fff]
[ 8.419732] pci 0007:00:00.0: bridge window [mem 0x3228000000-0x32280fffff]
[ 8.419827] pcieport 0007:00:00.0: Adding to iommu group 7
[ 8.419924] pcieport 0007:00:00.0: PME: Signaling with IRQ 26
[ 8.420235] pcieport 0007:00:00.0: AER: enabled with IRQ 26
[ 8.421055] tegra194-pcie 140a0000.pcie: Adding to iommu group 8
[ 8.529715] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ranges:
[ 8.529740] tegra194-pcie 140a0000.pcie: MEM 0x3240000000…0x3527ffffff → 0x3240000000
[ 8.529751] tegra194-pcie 140a0000.pcie: MEM 0x3528000000…0x352fffffff → 0x0040000000
[ 8.529758] tegra194-pcie 140a0000.pcie: IO 0x002a100000…0x002a1fffff → 0x002a100000
[ 8.530260] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[ 8.530264] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 8.599902] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 8.632759] Rootfs mounted over PARTUUID=8759ddf6-2e43-423e-8c53-e3ab5e04164b
[ 8.636587] tegra194-pcie 140a0000.pcie: Link up
[ 8.639118] tegra194-pcie 140a0000.pcie: Link up
[ 8.639184] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 8.639188] pci_bus 0008:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[ 8.639192] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.639196] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 8.639198] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 8.639245] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.639400] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 8.640872] Switching from initrd to actual rootfs
[ 8.642926] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 8.643084] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 8.643266] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 8.643384] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 8.644368] pci 0008:01:00.0: supports D1 D2
[ 8.644370] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.659502] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 8.659506] pci 0008:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 8.659513] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 8.659607] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 8.659700] pci 0008:01:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
[ 8.659730] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 8.659733] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 8.659737] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 8.659835] pcieport 0008:00:00.0: Adding to iommu group 8
[ 8.659927] pcieport 0008:00:00.0: PME: Signaling with IRQ 20
[ 8.660512] pcieport 0008:00:00.0: AER: enabled with IRQ 20
[ 8.708701] systemd[1]: System time before build time, advancing clock.
[ 8.762113] NET: Registered PF_INET6 protocol family
[ 8.762941] Segment Routing with IPv6
[ 8.762950] In-situ OAM (IOAM) with IPv6
[ 8.792538] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 8.792923] systemd[1]: Detected architecture arm64.
[ 8.899269] systemd[1]: Hostname set to <localhost.localdomain>.
[ 8.920607] systemd[1]: Using hardware watchdog ‘NVIDIA Tegra186 WDT’, version 0, device /dev/watchdog
[ 8.920625] systemd[1]: Set hardware watchdog to 2min.
[ 9.096644] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 9.104243] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 9.143711] systemd[1]: Queued start job for default target OEM Configuration.
[ 9.145448] systemd[1]: Created slice Slice /system/modprobe.
[ 9.146005] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 9.146153] systemd[1]: Reached target Slice Units.
[ 9.146232] systemd[1]: Reached target Swaps.
[ 9.146301] systemd[1]: Reached target Local Verity Protected Volumes.
[ 9.151390] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 9.151738] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 9.151902] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 9.152255] systemd[1]: Listening on Journal Audit Socket.
[ 9.152510] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.152779] systemd[1]: Listening on Journal Socket.
[ 9.154314] systemd[1]: Listening on udev Control Socket.
[ 9.154525] systemd[1]: Listening on udev Kernel Socket.
[ 9.155784] systemd[1]: Mounting Huge Pages File System…
[ 9.157033] systemd[1]: Mounting POSIX Message Queue File System…
[ 9.170185] systemd[1]: Mounting Kernel Debug File System…
[ 9.171357] systemd[1]: Mounting Kernel Trace File System…
[ 9.173624] systemd[1]: Starting Journal Service…
[ 9.186824] systemd[1]: Starting Set the console keyboard layout…
[ 9.188493] systemd[1]: Starting Create List of Static Device Nodes…
[ 9.199851] systemd[1]: Starting Load Kernel Module configfs…
[ 9.201564] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 9.212243] systemd[1]: Starting Load Kernel Module fuse…
[ 9.213663] systemd[1]: Starting NVIDIA specific first-boot udev script…
[ 9.225318] systemd[1]: Started Nameserver information manager.
[ 9.225497] fuse: init (API version 7.34)
[ 9.225639] systemd[1]: Reached target Preparation for Network.
[ 9.225811] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 9.228087] systemd[1]: Starting Load Kernel Modules…
[ 9.229799] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 9.237330] nvsciipc: loading out-of-tree module taints kernel.
[ 9.237600] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null). Quota mode: none.
[ 9.239070] nvsciipc: loaded module
[ 9.252602] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 9.253153] nvmap_page_pool_init: Total RAM pages: 1951058
[ 9.253156] nvmap_page_pool_init: nvmap page pool size: 243882 pages (952 MB)
[ 9.253240] nvmap_background_zero_thread: PP zeroing thread starting.
[ 9.268244] systemd[1]: Starting Coldplug All udev Devices…
[ 9.269547] tegra-host1x 13e00000.host1x: Adding to iommu group 9
[ 9.270212] host1x-context host1x-ctx.0: Adding to iommu group 10
[ 9.270346] host1x-context host1x-ctx.1: Adding to iommu group 11
[ 9.270462] host1x-context host1x-ctx.2: Adding to iommu group 12
[ 9.270578] host1x-context host1x-ctx.3: Adding to iommu group 13
[ 9.270688] host1x-context host1x-ctx.4: Adding to iommu group 14
[ 9.270795] host1x-context host1x-ctx.5: Adding to iommu group 15
[ 9.270904] host1x-context host1x-ctx.6: Adding to iommu group 16
[ 9.271018] host1x-context host1x-ctx.7: Adding to iommu group 17
[ 9.271132] host1x-context host1x-ctx.8: Adding to iommu group 18
[ 9.271249] host1x-context host1x-ctx.9: Adding to iommu group 19
[ 9.271360] host1x-context host1x-ctx.10: Adding to iommu group 20
[ 9.271477] host1x-context host1x-ctx.11: Adding to iommu group 21
[ 9.271593] host1x-context host1x-ctx.12: Adding to iommu group 22
[ 9.271699] host1x-context host1x-ctx.13: Adding to iommu group 23
[ 9.271808] host1x-context host1x-ctx.14: Adding to iommu group 24
[ 9.271918] host1x-context host1x-ctx.15: Adding to iommu group 25
[ 9.304744] systemd[1]: Started Journal Service.
[ 9.407831] nvgpu: 17000000.gpu nvgpu_nvhost_syncpt_init:122 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 9.407831]
[ 9.451947] systemd-journald[241]: Received client request to flush runtime journal.
U debug prints will be routed to traces.
9.855708] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[ 9.855712] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[ 9.855714] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[ 9.855717] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[ 9.855720] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[ 9.855723] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[ 9.934400] tegra-nvenc 154c0000.nvenc: deferred probe timeout, ignoring dependency
[ 9.934403] tegra-nvenc: probe of 154c0000.nvenc failed with error -110
[ 10.240507] using random self ethernet address
[ 10.240517] using random host ethernet address
[ 10.664279] (NULL device *): fops function table already registered
[ 10.672343] using random self ethernet address
[ 10.672350] using random host ethernet address
arting RmBootstrap
Registered event_type:[0] for dce_core_ipc_type:[1]
Registered event_type:[1] for dce_core_ipc_type:[3]
dce_ipc State Initialized
RmBootstrap completed successfully
11.325236] fusb301 1-0025: failed to read device id, err : 0xffffff87
[ 11.325247] fusb301 1-0025: fusb301 not support
[ 11.325255] fusb301: probe of 1-0025 failed with error -22
[ 11.864434] CustomLED 0x804
[ 11.942619] CustomLED 0x84
[ 18.457520] Please complete system configuration setup on desktop to proceed…
[ 112.339284] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 112.344315] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
Ubuntu 22.04.4 LTS via-desktop ttyTCU0
via-desktop login: [ 115.451491] using random self ethernet address
[ 115.451500] using random host ethernet address
[ 115.642178] using random self ethernet address
[ 115.642187] using random host ethernet address
please share the result of /var/log/xorg.0.log when this error happened.
Also, please do not run xrandr with sudo/root.
Xorg.0.log (17.5 KB)
Did you add the hotplug gpio into the kernel dtb?
Have not modified any kernel dtb about hotplug gpio , but the orin nx is OK.
Should I add the hotplug gpio into the kernel dtb? And how to ?
Something like this one.
And please do full flash after modification.
The original source code of 36.3 has hotplug gpio in dtsi file . So it is not necessary to add the hotplug gpio into the kernel dtb manually.
source/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-p3768-0000+p3767-xxxx-nv-common.dtsi
display@13800000 {
/* os_gpio_hotplug_a is used for hotplug */
os_gpio_hotplug_a = <&gpio TEGRA234_MAIN_GPIO(M, 0) GPIO_ACTIVE_HIGH>;
status = “okay”;
I dump the dtb file , Both NX and Nano dtb have os_gpio_hotplug_a
any suggestion?
Do you have other monitor to test? Especially Orin Nano does not support 4k@60 monitor.
Also, what is the flash command you are using here? I don’t think p3768-0000-p3767-0000-a0-nvme.conf should be in use.
