This error appears periodically and is only visible on UART and Jetpack 6.1:
SPI-SLV: EPL Handler Failed to send SW-Error report to SMCU!, retrying..
It is not visible in dmesg and doesn’t exist on Jetpack 6.0.
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.136-tegra (buildbrain@mobile-u64-6367-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon May 6 09:56:39 PDT 2024 ()
[ 0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0xe27f7f198 TPMFinalLog=0xe18b40000 SMBIOS=0xffff0000 SMBIOS 3.0=0xe27970000 MEMATTR=0xe21935018 ESRT=0xe2195a398 TPMEventLog=0xe18b58018 RNG=0xe15540018 MEMRESERVE=0xe18b5ac18
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x0000000e2195a398 to 0x0000000e2195a3d0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000df5000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000e33ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0xe23d66800-0xe23d68fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000e33ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000e189c0fff]
[ 0.000000] node 0: [mem 0x0000000e189c1000-0x0000000e18b4ffff]
[ 0.000000] node 0: [mem 0x0000000e18b50000-0x0000000e18b5afff]
[ 0.000000] node 0: [mem 0x0000000e18b5b000-0x0000000e18b5bfff]
[ 0.000000] node 0: [mem 0x0000000e18b5c000-0x0000000e2603ffff]
[ 0.000000] node 0: [mem 0x0000000e26040000-0x0000000e27f7ffff]
[ 0.000000] node 0: [mem 0x0000000e27f80000-0x0000000e2c5fffff]
[ 0.000000] node 0: [mem 0x0000000e2c600000-0x0000000e2c7fffff]
[ 0.000000] node 0: [mem 0x0000000e2c800000-0x0000000e2cd6ffff]
[ 0.000000] node 0: [mem 0x0000000e2d700000-0x0000000e2d7fffff]
[ 0.000000] node 0: [mem 0x0000000e32000000-0x0000000e33ffffff]
[ 0.000000] mminit::pageflags_layout_widths Section 0 Node 4 Zone 2 Lastcpupid 16 Kasantag 0 Flags 24
[ 0.000000] mminit::pageflags_layout_shifts Section 21 Node 4 Zone 2 Lastcpupid 16 Kasantag 0
[ 0.000000] mminit::pageflags_layout_pgshifts Section 0 Node 60 Zone 58 Lastcpupid 42 Kasantag 0
[ 0.000000] mminit::pageflags_layout_nodezoneid Node/Zone ID: 64 -> 58
[ 0.000000] mminit::pageflags_layout_usage location: 64 -> 42 layout 42 -> 24 unused 24 -> 0 page-flags
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000e33ffffff]
[ 0.000000] mminit::memmap_init Initialising map node 0 zone 0 pfns 524288 -> 1048576
[ 0.000000] mminit::memmap_init Initialising map node 0 zone 2 pfns 1048576 -> 14893056
[ 0.000000] On node 0, zone Normal: 2448 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 18432 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[ 0.000000] pcpu-alloc: s80408 r8192 d30184 u118784 alloc=29*4096
[ 0.000000] pcpu-alloc: [0] 00 [0] 01 [0] 02 [0] 03 [0] 04 [0] 05 [0] 06 [0] 07
[ 0.000000] pcpu-alloc: [0] 08 [0] 09 [0] 10 [0] 11
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] mminit::zonelist general 0:DMA = 0:DMA
[ 0.000000] mminit::zonelist general 0:Normal = 0:Normal 0:DMA
[ 0.000000] mminit::zonelist thisnode 0:DMA = 0:DMA
[ 0.000000] mminit::zonelist thisnode 0:Normal = 0:Normal 0:DMA
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 14123376
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=PARTUUID=841be70a-7f60-4eb5-b9b0-a4679cae071f rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 quiet bl_prof_dataptr=2031616@0xE2C610000 bl_prof_ro_ptr=65536@0xE2C600000
[ 0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0xE2C610000 bl_prof_ro_ptr=65536@0xE2C600000", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 55565188K/57391552K available (19712K kernel code, 4056K rwdata, 9968K rodata, 7680K init, 529K bss, 1302076K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000380] Console: colour dummy device 80x25
[ 0.000389] printk: console [tty0] enabled
[ 0.000450] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000457] pid_max: default: 32768 minimum: 301
[ 0.000493] LSM: Security Framework initializing
[ 0.000517] Yama: becoming mindful.
[ 0.000532] SELinux: Initializing.
[ 0.000682] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000777] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.002220] rcu: Hierarchical SRCU implementation.
[ 0.004773] Tegra Revision: A01 SKU: 144 CPU Process: 0 SoC Process: 0
[ 0.005033] Remapping and enabling EFI services.
[ 0.005939] smp: Bringing up secondary CPUs ...
[ 0.006448] Detected PIPT I-cache on CPU1
[ 0.006491] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.006520] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.006968] Detected PIPT I-cache on CPU2
[ 0.006979] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006994] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.007412] Detected PIPT I-cache on CPU3
[ 0.007424] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.007437] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.009903] Detected PIPT I-cache on CPU4
[ 0.009928] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.009955] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.010417] Detected PIPT I-cache on CPU5
[ 0.010428] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.010443] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.010885] Detected PIPT I-cache on CPU6
[ 0.010896] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.010910] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.011616] Detected PIPT I-cache on CPU7
[ 0.011627] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.011642] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.014122] Detected PIPT I-cache on CPU8
[ 0.014150] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.014178] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.014649] Detected PIPT I-cache on CPU9
[ 0.014660] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.014675] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.015509] Detected PIPT I-cache on CPU10
[ 0.015521] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.015535] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.015976] Detected PIPT I-cache on CPU11
[ 0.015989] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.016004] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.016060] smp: Brought up 1 node, 12 CPUs
[ 0.016065] SMP: Total of 12 processors activated.
[ 0.016068] CPU features: detected: 32-bit EL0 Support
[ 0.016070] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.016072] CPU features: detected: Common not Private translations
[ 0.016073] CPU features: detected: CRC32 instructions
[ 0.016075] CPU features: detected: Data cache clean to Point of Persistence
[ 0.016077] CPU features: detected: Generic authentication (architected algorithm)
[ 0.016078] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.016079] CPU features: detected: LSE atomic instructions
[ 0.016080] CPU features: detected: Privileged Access Never
[ 0.016081] CPU features: detected: RAS Extension Support
[ 0.016084] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.031818] spectre-bhb mitigation disabled by command line option
[ 0.047401] CPU: All CPU(s) started at EL2
[ 0.050581] devtmpfs: initialized
[ 0.061568] KASLR enabled
[ 0.061654] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.061667] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.065821] pinctrl core: initialized pinctrl subsystem
[ 0.066366] SMBIOS 3.6.0 present.
[ 0.066374] DMI: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.4.0-gcid-37537400 09/13/2024
[ 0.066669] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.068244] DMA: preallocated 8192 KiB GFP_KERNEL pool for atomic allocations
[ 0.068667] DMA: preallocated 8192 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.069071] DMA: preallocated 8192 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.069105] audit: initializing netlink subsys (disabled)
[ 0.069184] audit: type=2000 audit(0.068:1): state=initialized audit_enabled=0 res=1
[ 0.070064] thermal_sys: Registered thermal governor 'step_wise'
[ 0.070066] thermal_sys: Registered thermal governor 'user_space'
[ 0.070068] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.072289] cpuidle: using governor menu
[ 0.072435] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.072553] ASID allocator initialised with 32768 entries
[ 0.073680] Serial: AMBA PL011 UART driver
[ 0.082264] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 119, base_baud = 0) is a SBSA
[ 0.082284] printk: console [ttyAMA0] enabled
[ 0.090813] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.097591] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.097596] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.097597] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.097598] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.098208] cryptd: max_cpu_qlen set to 1000
[ 0.099309] ACPI: Interpreter disabled.
[ 0.100625] iommu: Default domain type: Translated
[ 0.100628] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.100846] SCSI subsystem initialized
[ 0.100904] libata version 3.00 loaded.
[ 0.100950] vgaarb: loaded
[ 0.101045] usbcore: registered new interface driver usbfs
[ 0.101062] usbcore: registered new interface driver hub
[ 0.101073] usbcore: registered new device driver usb
[ 0.101394] pps_core: LinuxPPS API ver. 1 registered
[ 0.101397] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.101403] PTP clock support registered
[ 0.101452] EDAC MC: Ver: 3.0.0
[ 0.102022] Registered efivars operations
[ 0.102427] FPGA manager framework
[ 0.102465] Advanced Linux Sound Architecture Driver Initialized.
[ 0.102937] clocksource: Switched to clocksource arch_sys_counter
[ 0.130994] VFS: Disk quotas dquot_6.6.0
[ 0.131074] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.131312] pnp: PnP ACPI: disabled
[ 0.134622] NET: Registered PF_INET protocol family
[ 0.135140] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.137602] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.137669] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.137718] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.138239] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.139715] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.139988] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.140131] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.140535] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.141015] RPC: Registered named UNIX socket transport module.
[ 0.141019] RPC: Registered udp transport module.
[ 0.141019] RPC: Registered tcp transport module.
[ 0.141021] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.141042] PCI: CLS 0 bytes, default 64
[ 0.141325] Unpacking initramfs...
[ 0.152249] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.152687] kvm [1]: IPA Size Limit: 48 bits
[ 0.152727] kvm [1]: GICv3: no GICV resource entry
[ 0.152737] kvm [1]: disabling GICv2 emulation
[ 0.152758] kvm [1]: GIC system register CPU interface enabled
[ 0.152873] kvm [1]: vgic interrupt IRQ9
[ 0.153086] kvm [1]: VHE mode initialized successfully
[ 0.156192] Initialise system trusted keyrings
[ 0.156319] workingset: timestamp_bits=42 max_order=24 bucket_order=0
[ 0.160346] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.160817] NFS: Registering the id_resolver key type
[ 0.160845] Key type id_resolver registered
[ 0.160848] Key type id_legacy registered
[ 0.160907] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.160923] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.160952] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.161136] 9p: Installing v9fs 9p2000 file system support
[ 0.173428] Key type asymmetric registered
[ 0.173436] Asymmetric key parser 'x509' registered
[ 0.173520] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.173530] io scheduler mq-deadline registered
[ 0.173538] io scheduler kyber registered
[ 0.184480] EINJ: ACPI disabled.
[ 0.197504] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.199442] SuperH (H)SCI(F) driver initialized
[ 0.199831] msm_serial: driver initialized
[ 0.200411] printk: console [ttyTCU0] enabled
[ 0.201371] arm-smmu 8000000.iommu: probing hardware configuration...
[ 0.201377] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.201385] arm-smmu 8000000.iommu: stage 1 translation
[ 0.201388] arm-smmu 8000000.iommu: stage 2 translation
[ 0.201392] arm-smmu 8000000.iommu: nested translation
[ 0.201399] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.201404] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.201418] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.201422] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.201426] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.202434] arm-smmu 10000000.iommu: probing hardware configuration...
[ 0.202438] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.202443] arm-smmu 10000000.iommu: stage 1 translation
[ 0.202445] arm-smmu 10000000.iommu: stage 2 translation
[ 0.202445] arm-smmu 10000000.iommu: nested translation
[ 0.202448] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.202450] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.202456] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.202457] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.202458] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.202837] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.202839] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.202841] arm-smmu 12000000.iommu: stage 1 translation
[ 0.202842] arm-smmu 12000000.iommu: stage 2 translation
[ 0.202842] arm-smmu 12000000.iommu: nested translation
[ 0.202845] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.202847] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.202850] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.202853] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.202854] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.213775] loop: module loaded
[ 0.214771] megasas: 07.717.02.00-rc1
[ 0.219356] tun: Universal TUN/TAP device driver, 1.6
[ 0.219973] thunder_xcv, ver 1.0
[ 0.220002] thunder_bgx, ver 1.0
[ 0.220035] nicpf, ver 1.0
[ 0.220902] hclge is initializing
[ 0.220931] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.220940] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.220981] e1000: Intel(R) PRO/1000 Network Driver
[ 0.220988] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.221013] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.221019] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.221040] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.221046] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.221062] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.221069] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.221291] sky2: driver version 1.30
[ 0.221990] VFIO - User Level meta-driver version: 0.3
[ 0.223564] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.223578] ehci-pci: EHCI PCI platform driver
[ 0.223602] ehci-platform: EHCI generic platform driver
[ 0.223697] ehci-orion: EHCI orion driver
[ 0.223767] ehci-exynos: EHCI Exynos driver
[ 0.223835] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.223864] ohci-pci: OHCI PCI platform driver
[ 0.223892] ohci-platform: OHCI generic platform driver
[ 0.223967] ohci-exynos: OHCI Exynos driver
[ 0.224411] usbcore: registered new interface driver usb-storage
[ 0.226365] i2c_dev: i2c /dev entries driver
[ 0.227793] pps pps0: new PPS source ktimer
[ 0.227801] pps pps0: ktimer PPS source registered
[ 0.227811] pps_ldisc: PPS line discipline registered
[ 0.230032] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.232019] sdhci: Secure Digital Host Controller Interface driver
[ 0.232025] sdhci: Copyright(c) Pierre Ossman
[ 0.232504] Synopsys Designware Multimedia Card Interface Driver
[ 0.233141] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.234526] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.235486] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.236048] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.238435] tegra-bpmp bpmp: firmware: ef3420a13ed0faf760cc-da583751bbf
[ 0.334218] Freeing initrd memory: 11448K
[ 2.656347] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 2.656370] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 2.656373] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 2.656618] hid: raw HID events driver (C) Jiri Kosina
[ 2.657077] usbcore: registered new interface driver usbhid
[ 2.657083] usbhid: USB HID core driver
[ 2.660987] optee: probing for conduit method.
[ 2.661044] optee: revision 4.2 (d78bc5fa)
[ 2.720207] optee: dynamic shared memory is enabled
[ 2.720472] optee: initialized driver
[ 2.723018] usbcore: registered new interface driver snd-usb-audio
[ 2.724963] NET: Registered PF_PACKET protocol family
[ 2.725230] 9pnet: Installing 9P2000 support
[ 2.725348] Key type dns_resolver registered
[ 2.726721] printk: console [tty0]: printing thread started
[ 2.727625] printk: console [ttyTCU0]: printing thread started
[ 2.728489] printk: console [ttyAMA0]: printing thread started
[ 2.728599] Loading compiled-in X.509 certificates
[ 2.740169] Loaded X.509 cert 'Build time autogenerated kernel key: dbaa37291f9eb1704a33bc5cf19ca9266fdea8e6'
[ 2.776123] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 2.777669] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 2.780516] 3140000.serial: ttyS0 at MMIO 0x3140000 (irq = 113, base_baud = 4250000) is a Tegra
[ 2.780967] serial-tegra 3100000.serial: RX in PIO mode
[ 2.780969] serial-tegra 3100000.serial: TX in PIO mode
[ 2.781010] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 2.781371] serial-tegra 3110000.serial: RX in PIO mode
[ 2.781374] serial-tegra 3110000.serial: TX in PIO mode
[ 2.781410] 3110000.serial: ttyTHS2 at MMIO 0x3110000 (irq = 209, base_baud = 0) is a TEGRA_UART
[ 2.783135] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.783142] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.783548] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 2.789466] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 2.791678] tegra-i2c 3190000.i2c: Adding to iommu group 1
[ 2.793564] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 2.795428] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[ 2.797287] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[ 2.799418] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 2.801101] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 2.829572] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1973000 KHz, changing to: 1971200 KHz
[ 2.833105] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 1969000 KHz, changing to: 1971200 KHz
[ 2.835717] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[ 2.839985] tegra-xusb 3610000.usb: Adding to iommu group 3
[ 2.840296] usb3: Requested PHY is disabled
[ 2.845682] mmc0: CQHCI version 5.10
[ 2.853688] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 2.853697] tegra-xusb 3610000.usb: xHCI Host Controller
[ 2.853709] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 2.854455] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[ 2.854476] tegra-xusb 3610000.usb: irq 128, io mem 0x03610000
[ 2.854602] tegra-xusb 3610000.usb: xHCI Host Controller
[ 2.854605] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 2.854609] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.855484] hub 1-0:1.0: USB hub found
[ 2.855501] hub 1-0:1.0: 4 ports detected
[ 2.855784] hub 2-0:1.0: USB hub found
[ 2.855795] hub 2-0:1.0: 4 ports detected
[ 2.857300] sdhci-tegra 3400000.mmc: Adding to iommu group 4
[ 2.857711] irq: IRQ235: trimming hierarchy from :bus@0:pmc@c360000
[ 2.857771] irq: IRQ236: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 2.857821] irq: IRQ237: trimming hierarchy from :bus@0:pmc@c360000
[ 2.857878] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 3.190937] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 3.318111] ALSA device list:
[ 3.318115] No soundcards found.
[ 3.322988] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 3.336206] mmc0: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[ 3.346873] hub 1-2:1.0: USB hub found
[ 3.347352] hub 1-2:1.0: 4 ports detected
[ 3.368882] irq: IRQ238: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 3.369142] mmc1: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 3.370051] Freeing unused kernel memory: 7680K
[ 3.370110] Run /init as init process
[ 3.370111] with arguments:
[ 3.370112] /init
[ 3.370112] with environment:
[ 3.370113] HOME=/
[ 3.370113] TERM=linux
[ 3.370114] bl_prof_dataptr=2031616@0xE2C610000
[ 3.370115] bl_prof_ro_ptr=65536@0xE2C600000
[ 3.378918] Checking overlayfs setting...
[ 3.388203] Overlayfs is disabled...
[ 3.393837] Root device found: PARTUUID=841be70a-7f60-4eb5-b9b0-a4679cae071f
[ 3.445315] mmc0: Command Queue Engine enabled
[ 3.445327] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 3.445808] mmcblk0: mmc0:0001 G1J38E 59.3 GiB
[ 3.450554] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 3.451154] mmcblk0boot0: mmc0:0001 G1J38E 31.5 MiB
[ 3.451639] mmcblk0boot1: mmc0:0001 G1J38E 31.5 MiB
[ 3.452070] mmcblk0rpmb: mmc0:0001 G1J38E 4.00 MiB, chardev (511:0)
[ 3.603660] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 3.604108] mmcblk1: mmc1:aaaa SE32G 29.7 GiB
[ 3.610744] mmcblk1: p1
[ 6.718017] tegra194-pcie 14100000.pcie: Adding to iommu group 5
[ 6.721025] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[ 6.721047] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 6.721054] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 6.721058] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 6.721375] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[ 6.721378] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 6.741653] tegra-xudc 3550000.usb: Adding to iommu group 6
[ 7.819998] tegra194-pcie 14100000.pcie: Phy link never came up
[ 8.818943] tegra194-pcie 14100000.pcie: Phy link never came up
[ 8.819040] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.819044] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.819049] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.819051] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.819053] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.819106] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.819289] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.825016] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.825156] pcieport 0001:00:00.0: Adding to iommu group 5
[ 8.825267] pcieport 0001:00:00.0: PME: Signaling with IRQ 194
[ 8.825462] pcieport 0001:00:00.0: AER: enabled with IRQ 194
[ 8.825706] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 8.825795] pci 0001:00:00.0: Removing from iommu group 5
[ 8.825807] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 8.827663] tegra194-pcie 14160000.pcie: Adding to iommu group 7
[ 8.829602] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[ 8.829625] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 8.829632] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 8.829635] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 8.829953] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[ 8.829956] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 9.935852] tegra194-pcie 14160000.pcie: Phy link never came up
[ 10.936192] tegra194-pcie 14160000.pcie: Phy link never came up
[ 10.936311] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 10.936315] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 10.936319] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.936322] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 10.936324] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 10.936381] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 10.936564] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 10.942191] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 10.942332] pcieport 0004:00:00.0: Adding to iommu group 7
[ 10.942440] pcieport 0004:00:00.0: PME: Signaling with IRQ 196
[ 10.943873] pcieport 0004:00:00.0: AER: enabled with IRQ 196
[ 10.944154] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 10.944242] pci 0004:00:00.0: Removing from iommu group 7
[ 10.944253] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 10.946147] tegra194-pcie 14180000.pcie: Adding to iommu group 8
[ 10.946907] tegra194-pcie 14180000.pcie: supply vddio-pex-ctl not found, using dummy regulator
[ 10.948003] tegra194-pcie 14180000.pcie: host bridge /bus@0/pcie@14180000 ranges:
[ 10.948017] tegra194-pcie 14180000.pcie: MEM 0x2440000000..0x2727ffffff -> 0x2440000000
[ 10.948022] tegra194-pcie 14180000.pcie: MEM 0x2728000000..0x272fffffff -> 0x0040000000
[ 10.948026] tegra194-pcie 14180000.pcie: IO 0x0038100000..0x00381fffff -> 0x0038100000
[ 10.948324] tegra194-pcie 14180000.pcie: iATU unroll: enabled
[ 10.948327] tegra194-pcie 14180000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 12.055958] tegra194-pcie 14180000.pcie: Phy link never came up
[ 13.051333] tegra194-pcie 14180000.pcie: Phy link never came up
[ 13.051444] tegra194-pcie 14180000.pcie: PCI host bridge to bus 0000:00
[ 13.051449] pci_bus 0000:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x38100000-0x381fffff])
[ 13.051452] pci_bus 0000:00: root bus resource [mem 0x2728000000-0x272fffffff] (bus address [0x40000000-0x47ffffff])
[ 13.051457] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 13.051462] pci_bus 0000:00: root bus resource [mem 0x2440000000-0x2727ffffff pref]
[ 13.051519] pci 0000:00:00.0: [10de:229c] type 01 class 0x060400
[ 13.051703] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 13.057493] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 13.057634] pcieport 0000:00:00.0: Adding to iommu group 8
[ 13.057748] pcieport 0000:00:00.0: PME: Signaling with IRQ 198
[ 13.058041] pcieport 0000:00:00.0: AER: enabled with IRQ 198
[ 13.058281] pci_bus 0000:01: busn_res: [bus 01-ff] is released
[ 13.058361] pci 0000:00:00.0: Removing from iommu group 8
[ 13.058370] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[ 13.060302] tegra194-pcie 141e0000.pcie: Adding to iommu group 9
[ 13.060745] tegra194-pcie 141e0000.pcie: supply vddio-pex-ctl not found, using dummy regulator
[ 13.062497] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[ 13.062509] tegra194-pcie 141e0000.pcie: MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[ 13.062515] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
[ 13.062518] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
[ 13.062824] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[ 13.062826] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 13.171116] tegra194-pcie 141e0000.pcie: Link up
[ 13.174242] tegra194-pcie 141e0000.pcie: Link up
[ 13.174286] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 13.174290] pci_bus 0007:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3e100000-0x3e1fffff])
[ 13.174292] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 13.174296] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 13.174297] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff pref]
[ 13.174337] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 13.174483] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 13.177457] pci 0007:01:00.0: [126f:2263] type 00 class 0x010802
[ 13.177672] pci 0007:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 13.179340] pci 0007:01:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x2 link at 0007:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 13.193516] pci 0007:00:00.0: BAR 14: assigned [mem 0x3228000000-0x32280fffff]
[ 13.193521] pci 0007:01:00.0: BAR 0: assigned [mem 0x3228000000-0x3228003fff 64bit]
[ 13.193595] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 13.193599] pci 0007:00:00.0: bridge window [mem 0x3228000000-0x32280fffff]
[ 13.193673] pcieport 0007:00:00.0: Adding to iommu group 9
[ 13.193741] pcieport 0007:00:00.0: PME: Signaling with IRQ 200
[ 13.194279] pcieport 0007:00:00.0: AER: enabled with IRQ 200
[ 13.194445] nvme 0007:01:00.0: Adding to iommu group 9
[ 13.194795] nvme nvme0: pci function 0007:01:00.0
[ 13.194895] nvme 0007:01:00.0: enabling device (0000 -> 0002)
[ 13.199265] nvme nvme0: missing or invalid SUBNQN field.
[ 13.210053] nvme nvme0: allocated 64 MiB host memory buffer.
[ 13.224024] nvme nvme0: 8/0/0 default/read/poll queues
[ 13.229975] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 13.479893] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 13.483963] Rootfs mounted over PARTUUID=841be70a-7f60-4eb5-b9b0-a4679cae071f
[ 13.491429] Switching from initrd to actual rootfs
[ 13.543552] systemd[1]: System time before build time, advancing clock.
[ 13.563028] NET: Registered PF_INET6 protocol family
[ 13.563918] Segment Routing with IPv6
[ 13.563927] In-situ OAM (IOAM) with IPv6
[ 13.578136] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 13.578522] systemd[1]: Detected architecture arm64.
[ 13.579503] systemd[1]: Hostname set to <nvidia-agx-orin-industrial>.
[ 13.587216] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog
[ 13.587234] systemd[1]: Set hardware watchdog to 2min.
[ 13.735418] systemd[1]: /lib/systemd/system/snapd.service:23: Unknown key name 'RestartMode' in section 'Service', ignoring.
[ 13.743478] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 13.749797] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 13.786237] systemd[1]: Queued start job for default target Graphical Interface.
[ 13.787643] systemd[1]: Created slice Slice /system/modprobe.
[ 13.788086] systemd[1]: Created slice Slice /system/serial-getty.
[ 13.788386] systemd[1]: Created slice User and Session Slice.
[ 13.788493] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 13.788804] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 13.788914] systemd[1]: Reached target Slice Units.
[ 13.788931] systemd[1]: Reached target Mounting snaps.
[ 13.788942] systemd[1]: Reached target Mounted snaps.
[ 13.788960] systemd[1]: Reached target Swaps.
[ 13.788980] systemd[1]: Reached target Local Verity Protected Volumes.
[ 13.795585] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 13.795965] systemd[1]: Listening on Syslog Socket.
[ 13.796121] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 13.796208] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 13.796498] systemd[1]: Listening on Journal Audit Socket.
[ 13.796618] systemd[1]: Listening on Journal Socket (/dev/log).
[ 13.796774] systemd[1]: Listening on Journal Socket.
[ 13.797188] systemd[1]: Listening on udev Control Socket.
[ 13.797306] systemd[1]: Listening on udev Kernel Socket.
[ 13.798342] systemd[1]: Mounting Huge Pages File System...
[ 13.799312] systemd[1]: Mounting POSIX Message Queue File System...
[ 13.800542] systemd[1]: Mounting Kernel Debug File System...
[ 13.801563] systemd[1]: Mounting Kernel Trace File System...
[ 13.804773] systemd[1]: Starting Journal Service...
[ 13.806018] systemd[1]: Starting Set the console keyboard layout...
[ 13.807151] systemd[1]: Starting Create List of Static Device Nodes...
[ 13.808269] systemd[1]: Starting Load Kernel Module configfs...
[ 13.809555] systemd[1]: Starting Load Kernel Module drm...
[ 13.810690] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 13.812005] systemd[1]: Starting Load Kernel Module fuse...
[ 13.813221] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 13.814516] systemd[1]: Started Nameserver information manager.
[ 13.814761] systemd[1]: Reached target Preparation for Network.
[ 13.814987] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 13.817080] systemd[1]: Starting Load Kernel Modules...
[ 13.818183] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 13.818762] fuse: init (API version 7.34)
[ 13.819436] systemd[1]: Starting Coldplug All udev Devices...
[ 13.821494] systemd[1]: Mounted Huge Pages File System.
[ 13.821725] systemd[1]: Mounted POSIX Message Queue File System.
[ 13.821857] systemd[1]: Mounted Kernel Debug File System.
[ 13.822002] systemd[1]: Mounted Kernel Trace File System.
[ 13.822486] systemd[1]: Finished Create List of Static Device Nodes.
[ 13.822908] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 13.823268] systemd[1]: Finished Load Kernel Module configfs.
[ 13.823654] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 13.823980] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 13.824370] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 13.824675] systemd[1]: Finished Load Kernel Module fuse.
[ 13.825052] nvsciipc: loading out-of-tree module taints kernel.
[ 13.825119] systemd[1]: Finished NVIDIA specific first-boot udev script.
[ 13.825528] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 13.825713] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null). Quota mode: none.
[ 13.825841] systemd[1]: Finished Load Kernel Module drm.
[ 13.826211] nvsciipc: loaded module
[ 13.827262] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 13.828891] systemd[1]: Mounting FUSE Control File System...
[ 13.829915] systemd[1]: Mounting Kernel Configuration File System...
[ 13.830029] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 13.831354] systemd[1]: Starting Load/Save Random Seed...
[ 13.832014] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 13.832549] nvmap_co_device_init: vpr :dma coherent mem declare 0x0000000e49800000,914358272
[ 13.832556] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 13.832571] nvmap_page_pool_init: Total RAM pages: 14027151
[ 13.832573] nvmap_page_pool_init: nvmap page pool size: 1753393 pages (2753 MB)
[ 13.832632] nvmap_background_zero_thread: PP zeroing thread starting.
[ 13.832651] nvmap_heap_create: created heap vpr base 0x0000000e49800000 size (892928KiB)
[ 13.832678] nvmap_heap_create: fsi :dma coherent mem declare 0x0000000e2f000000,16777216
[ 13.832680] nvmap_heap_create: created heap fsi base 0x0000000e2f000000 size (16384KiB)
[ 13.832876] systemd[1]: Starting Create System Users...
[ 13.833783] systemd[1]: Mounted FUSE Control File System.
[ 13.833971] systemd[1]: Mounted Kernel Configuration File System.
[ 13.840310] tegra-host1x 13e00000.host1x: Adding to iommu group 10
[ 13.840946] systemd[1]: Finished Load/Save Random Seed.
[ 13.841180] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 13.841719] host1x-context host1x-ctx.0: Adding to iommu group 11
[ 13.841937] host1x-context host1x-ctx.1: Adding to iommu group 12
[ 13.842104] host1x-context host1x-ctx.2: Adding to iommu group 13
[ 13.842279] host1x-context host1x-ctx.3: Adding to iommu group 14
[ 13.842540] host1x-context host1x-ctx.4: Adding to iommu group 15
[ 13.842710] host1x-context host1x-ctx.5: Adding to iommu group 16
[ 13.842889] host1x-context host1x-ctx.6: Adding to iommu group 17
[ 13.843103] host1x-context host1x-ctx.7: Adding to iommu group 18
[ 13.843324] host1x-context host1x-ctx.8: Adding to iommu group 19
[ 13.843502] host1x-context host1x-ctx.9: Adding to iommu group 20
[ 13.843675] host1x-context host1x-ctx.10: Adding to iommu group 21
[ 13.843864] host1x-context host1x-ctx.11: Adding to iommu group 22
[ 13.844046] host1x-context host1x-ctx.12: Adding to iommu group 23
[ 13.844279] host1x-context host1x-ctx.13: Adding to iommu group 24
[ 13.844467] host1x-context host1x-ctx.14: Adding to iommu group 25
[ 13.844633] host1x-context host1x-ctx.15: Adding to iommu group 26
[ 13.847093] systemd[1]: Finished Create System Users.
[ 13.848741] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 13.857495] systemd[1]: Finished Set the console keyboard layout.
[ 13.861687] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 13.861839] systemd[1]: Reached target Preparation for Local File Systems.
[ 13.861866] systemd[1]: Reached target Local File Systems.
[ 13.861939] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[ 13.863265] systemd[1]: Starting Enable support for additional executable binary formats...
[ 13.864389] systemd[1]: Starting Set console font and keymap...
[ 13.865519] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[ 13.865551] systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
[ 13.867299] systemd[1]: Starting Set Up Additional Binary Formats...
[ 13.867363] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 13.867412] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 13.869206] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 13.869592] systemd[1]: Started Journal Service.
[ 13.880384] systemd-journald[348]: Received client request to flush runtime journal.
[ 13.899102] nvgpu: 17000000.gpu nvgpu_nvhost_syncpt_init:122 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 13.991930] mc: Linux media interface: v0.10
[ 13.996615] tsec 15500000.tsec: Adding to iommu group 27
[ 13.996998] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: Adding to iommu group 28
[ 13.998118] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 13.998367] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: Adding to iommu group 29
[ 14.003409] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 14.005326] scare-pigeon 13e00000.host1x:isp-thi@14b00000: Adding to iommu group 30
[ 14.007445] videodev: Linux video capture interface: v2.00
[ 14.010505] tegra-soc-hwpm f100000.hwpm: Adding to iommu group 31
[ 14.011609] scare-pigeon 13e00000.host1x:isp-thi@14b00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 14.018492] tegra-se 15820000.se: Adding to iommu group 32
[ 14.026638] tegra-se 15840000.se: Adding to iommu group 33
[ 14.027943] tegra-se 15820000.se: registered AES algorithms
[ 14.029180] tegra-se 15840000.se: registered HASH algorithms
[ 14.030541] nvdla 15880000.nvdla0: Adding to iommu group 34
[ 14.030616] pva 16000000.pva0: Adding to iommu group 35
[ 14.048091] nvdla 15880000.nvdla0: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 14.048325] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 36
[ 14.048688] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 14.050653] nvdla 158c0000.nvdla1: Adding to iommu group 37
[ 14.055277] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 38
[ 14.055853] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 14.056562] nvdla 158c0000.nvdla1: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 14.059527] Inserting ivc_ext.ko module
[ 14.063609] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 39
[ 14.063823] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 14.072026] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 40
[ 14.072189] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 14.072222] tegra-vic 15340000.vic: Adding to iommu group 41
[ 14.072896] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 42
[ 14.073012] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 14.073426] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 43
[ 14.073525] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 14.073804] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 44
[ 14.073899] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 14.074159] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 45
[ 14.074256] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 14.074274] pva 16000000.pva0: pdata->version is HW_GEN2
[ 14.093129] pva 16000000.pva0: Completed nvhost_client_device_init
[ 14.094020] pva 16000000.pva0: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 14.104609] tsec 15500000.tsec: tsec fw req success in 100 ms
[ 14.106803] tsec 15500000.tsec: RISC-V boot using kernel allocated Mem
[ 14.110281] tegra-nvdec 15480000.nvdec: Adding to iommu group 46
[ 14.113334] tsec 15500000.tsec: RISC-V boot success
[ 14.119397] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 47
[ 14.127244] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 14.136927] tegra-nvenc 154c0000.nvenc: Adding to iommu group 48
[ 14.144404] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee027f size=131712
[ 14.144577] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 14.144624] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x512]=0x1900-0x1b80 TX[1x512]=0x1b80-0x1e00
[ 14.144663] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1e00-0x3e80 TX[1x8192]=0x3e80-0x5f00
[ 14.144702] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5f00-0xaf80 TX[64x320]=0xaf80-0x10000
[ 14.144727] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0x10000-0x18080 TX[512x64]=0x18080-0x20100
[ 14.144814] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20100-0x201c0 TX[1x64]=0x201c0-0x20280
[ 14.145062] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (233)
[ 14.145065] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 14.145372] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=e2238c99959d2df9350d393f04e1f44e5bef98cb
[ 14.145505] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[ 14.145507] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[ 14.145508] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[ 14.145510] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[ 14.145511] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[ 14.145512] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[ 14.151834] tegra-nvjpg 15380000.nvjpg: Adding to iommu group 49
[ 14.186992] [RCE] TCU debug prints will be routed to traces.
[ 14.202917] tegra-nvjpg 15540000.nvjpg: Adding to iommu group 50
[ 14.224880] tegra-ofa 15a50000.ofa: Adding to iommu group 51
[ 14.230108] drm drm: [drm] Cannot find any crtc or sizes
[ 14.241311] [drm] Initialized tegra 1.0.99 20120330 for drm on minor 0
[ 14.435606] tegra194-isp5 14800000.isp: Adding to iommu group 30
[ 14.435875] tegra194-vi5 13e00000.host1x:vi0@15c00000: Adding to iommu group 28
[ 14.436007] driver not enabled, cannot register any devices
[ 14.441401] driver not enabled, cannot register any devices
[ 14.441709] driver not enabled, cannot register any devices
[ 14.443669] tegra194-vi5 13e00000.host1x:vi1@14c00000: Adding to iommu group 29
[ 14.444150] (NULL device *): fops function table already registered
[ 14.445840] driver not enabled, cannot register any devices
[ 14.523094] tegra-dce d800000.dce: Adding to iommu group 52
[ 14.525671] dce: dce_ipc_channel_init:311 Invalid Channel State [0x0] for ch_type [2]
[ 14.525983] dce: tegra_dce_probe:245 Found display consumer device
[ 14.526424] dce: dce_mailbox_set_full_interrupt:157 Intr bit set multiple times for MB : [0x5]
[ 14.526431] dce: dce_mailbox_set_full_interrupt:157 Intr bit set multiple times for MB : [0x5]
[ 14.526685] dce: dce_admin_send_cmd_ver:456 version : [0x3] err : [0x0]
[ 14.526888] dce: dce_mailbox_set_full_interrupt:157 Intr bit set multiple times for MB : [0x1]
[ 14.526894] dce: dce_mailbox_set_full_interrupt:157 Intr bit set multiple times for MB : [0x1]
[ 14.526896] dce: dce_admin_setup_clients_ipc:585 Channel Reset Complete for Type [1] ...
[ 14.526898] dce: dce_admin_setup_clients_ipc:561 Get queue info failed for [2]
[ 14.527095] dce: dce_mailbox_set_full_interrupt:157 Intr bit set multiple times for MB : [0x2]
[ 14.527103] dce: dce_mailbox_set_full_interrupt:157 Intr bit set multiple times for MB : [0x2]
[ 14.527107] dce: dce_admin_setup_clients_ipc:585 Channel Reset Complete for Type [3] ...
[ 14.527326] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 14.527622] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[ 14.527913] nvvrs11 4-0020: NVVRS11 Vendor ID: 0x11
[ 14.528089] dce: dce_start_boot_flow:166 DCE_BOOT_DONE
[ 14.528175] nvvrs11 4-0020: NVVRS11 Model Rev: 0xC1
[ 14.528176] nvvrs11 4-0020: NVVRS11 probe successful
[ 14.528280] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[ 14.528559] nvvrs11 4-0022: NVVRS11 Vendor ID: 0x11
[ 14.528823] nvvrs11 4-0022: NVVRS11 Model Rev: 0xC1
[ 14.528824] nvvrs11 4-0022: NVVRS11 probe successful
[ 14.547749] spi-tegra114 3210000.spi: Adding to iommu group 1
[ 14.580231] nv_platform 13800000.display: Adding to iommu group 53
[ 14.580245] nvpps c6a0000.nvpps: nvpps_probe
[ 14.580359] nvpps c6a0000.nvpps: primary-emac found ethernet@6800000
[ 14.580378] nvpps c6a0000.nvpps: primary emac base address 0x6810000
[ 14.580383] nvpps c6a0000.nvpps: using ptp notifier method on emac ethernet@6800000
[ 14.580385] nvpps c6a0000.nvpps: tsc_res_ns(32)
[ 14.580396] nvpps c6a0000.nvpps: PPS GPIO not provided in DT, only Timer mode available
[ 14.583390] nvpps c6a0000.nvpps: nvpps cdev(489:0)
[ 14.583424] nvpps c6a0000.nvpps: TSC config ptx 0x113
[ 14.587481] at24 0-0050: 256 byte 24c02 EEPROM, read-only
[ 14.587933] at24 0-0056: 256 byte 24c02 EEPROM, read-only
[ 14.588112] platform 13800000.display:nvdisplay-niso: Adding to iommu group 54
[ 14.593246] nvethernet 2310000.ethernet: Adding to iommu group 55
[ 14.593943] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[ 14.593947] nvethernet 2310000.ethernet: failed to read MDIO address
[ 14.593951] nvethernet 2310000.ethernet: setting to default DMA bit mask
[ 14.606741] spi-tegra114 3230000.spi: Adding to iommu group 1
[ 14.668573] tegra-hda 3510000.hda: Adding to iommu group 56
[ 14.760885] CAN device driver interface
[ 14.770211] thermal-trip-event cpu-throttle-alert: cooling device registered.
[ 14.770532] gic 2a41000.interrupt-controller: GIC IRQ controller registered
[ 14.771271] tegra-aconnect bus@0:aconnect@2900000: Tegra ACONNECT bus registered
[ 14.774141] thermal-trip-event gpu-throttle-alert: cooling device registered.
[ 14.785117] thermal-trip-event cv0-throttle-alert: cooling device registered.
[ 14.785732] TT CAN feature is not supported
[ 14.786405] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x000009c0|
| rxbc_rbsa |0x000009c0|
| txefc_efsa |0x000009c0|
| txbc_tbsa |0x00000a40|
| tmc_tmsa |0x00000ec0|
| mram size |0x00001000|
[ 14.787790] Release 3.2.3 from 09.06.2018
[ 14.790029] thermal-trip-event cv1-throttle-alert: cooling device registered.
[ 14.794178] thermal-trip-event cv2-throttle-alert: cooling device registered.
[ 14.794368] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 14.798744] thermal-trip-event soc0-throttle-alert: cooling device registered.
[ 14.803992] thermal-trip-event soc1-throttle-alert: cooling device registered.
[ 14.804219] net can0: mttcan device registered (regs=0000000002e27b34, irq=214)
[ 14.808686] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/3510000.hda/sound/card0/input1
[ 14.808973] thermal-trip-event soc2-throttle-alert: cooling device registered.
[ 14.811514] using random self ethernet address
[ 14.811520] using random host ethernet address
[ 14.826673] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/3510000.hda/sound/card0/input2
[ 14.827488] thermal-trip-event hot-surface-alert: cooling device registered.
[ 14.838342] nvethernet 2310000.ethernet: Ethernet MAC address: 48:b0:2d:ef:07:00
[ 14.839157] -->macsec_probe()
[ 14.839192] -->macsec_get_platform_res()
[ 14.839257] <--macsec_get_platform_res()
[ 14.839258] -->macsec_enable_car()
[ 14.839693] <--macsec_enable_car()
[ 14.839714] <--macsec_probe()
[ 14.839717] nvethernet 2310000.ethernet: Macsec not enabled
[ 14.839719] nvethernet 2310000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 14.842483] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/3510000.hda/sound/card0/input3
[ 14.846899] nvethernet 2310000.ethernet: eth0 (HW ver: 53) created with 8 DMA channels
[ 14.874819] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/3510000.hda/sound/card0/input4
[ 14.891723] loop0: detected capacity change from 0 to 32768
[ 15.068370] Mass Storage Function, version: 2009/09/11
[ 15.068378] LUN: removable file: (no medium)
[ 15.102268] using random self ethernet address
[ 15.102277] using random host ethernet address
[ 15.116496] loop0: detected capacity change from 0 to 8
[ 15.123231] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 15.128050] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 2024-11-18T13:15:53 UTC (1731935753)
[ 15.173271] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 15.220667] platform 2901000.i2s: Fixing up cyclic dependency with 8-001c
[ 15.254553] usb0: HOST MAC ca:66:65:57:a7:ec
[ 15.254563] usb0: MAC ca:66:65:57:a7:ed
[ 15.267552] usb1: HOST MAC ca:66:65:57:a7:ee
[ 15.267567] usb1: MAC ca:66:65:57:a7:ef
[ 15.270194] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
[ 15.280382] l4tbr0: port 1(usb0) entered blocking state
[ 15.280402] l4tbr0: port 1(usb0) entered disabled state
[ 15.281360] device usb0 entered promiscuous mode
[ 15.290394] l4tbr0: port 2(usb1) entered blocking state
[ 15.290412] l4tbr0: port 2(usb1) entered disabled state
[ 15.295662] device usb1 entered promiscuous mode
[ 15.303930] loop0: detected capacity change from 0 to 32768
[ 15.332722] tegra-adma 2930000.dma-controller: Tegra210 ADMA driver registered 32 channels
[ 15.332914] irq: IRQ296: trimming hierarchy from :bus@0:pmc@c360000
[ 15.334315] rt5640 8-001c: Device with ID register 0xffff0000 is not rt5640/39
[ 15.385632] nv_nvsciipc_init.sh[935]: found /dev/nvsciipc
[ 15.394997] nvsciipc: set_db start
[ 15.395026] nvsciipc: set_db done
[ 15.486716] tegra210-admaif 290f000.admaif: Adding to iommu group 57
[ 15.638966] pstore: Using crash dump compression: deflate
[ 15.639102] printk: console [ramoops-1]: printing thread started
[ 15.639133] printk: console [ramoops-1] enabled
[ 15.639135] pstore: Registered ramoops as persistent store backend
[ 15.639137] ramoops: using 0x200000@0xe2cdf0000, ecc: 0
[ 15.743543] IRQ239: set affinity failed(-22).
[ 15.743668] psci: CPU8 killed (polled 0 ms)
[ 15.873118] IRQ239: set affinity failed(-22).
[ 15.873321] psci: CPU9 killed (polled 0 ms)
[ 15.979850] IRQ239: set affinity failed(-22).
[ 15.980032] psci: CPU10 killed (polled 0 ms)
[ 16.016082] irq: IRQ297: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 16.016714] hwmon hwmon6: temp1_input not attached to any thermal zone
[ 16.064725] IRQ239: set affinity failed(-22).
[ 16.066069] psci: CPU11 killed (polled 0 ms)
[ 16.330848] nvgpu: 17000000.gpu gk20a_scale_init:541 [INFO] enabled scaling for GPU
[ 17.587504] zram: Added device: zram0
[ 17.588285] zram: Added device: zram1
[ 17.589516] zram: Added device: zram2
[ 17.591785] zram: Added device: zram3
[ 17.594582] zram: Added device: zram4
[ 17.597560] zram: Added device: zram5
[ 17.597890] zram: Added device: zram6
[ 17.598088] zram: Added device: zram7
[ 17.621599] zram0: detected capacity change from 0 to 7013576
[ 17.630104] Adding 3506784k swap on /dev/zram0. Priority:5 extents:1 across:3506784k SS
[ 17.636669] zram1: detected capacity change from 0 to 7013576
[ 17.644228] Adding 3506784k swap on /dev/zram1. Priority:5 extents:1 across:3506784k SS
[ 17.648525] zram2: detected capacity change from 0 to 7013576
[ 17.656086] Adding 3506784k swap on /dev/zram2. Priority:5 extents:1 across:3506784k SS
[ 17.660936] zram3: detected capacity change from 0 to 7013576
[ 17.668290] Adding 3506784k swap on /dev/zram3. Priority:5 extents:1 across:3506784k SS
[ 17.672703] zram4: detected capacity change from 0 to 7013576
[ 17.679815] Adding 3506784k swap on /dev/zram4. Priority:5 extents:1 across:3506784k SS
[ 17.684246] zram5: detected capacity change from 0 to 7013576
[ 17.691247] Adding 3506784k swap on /dev/zram5. Priority:5 extents:1 across:3506784k SS
[ 17.695683] zram6: detected capacity change from 0 to 7013576
[ 17.703134] Adding 3506784k swap on /dev/zram6. Priority:5 extents:1 across:3506784k SS
[ 17.707553] zram7: detected capacity change from 0 to 7013576
[ 17.715821] Adding 3506784k swap on /dev/zram7. Priority:5 extents:1 across:3506784k SS
[ 18.310567] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 540.3.0 Release Build (buildbrain@mobile-u64-6367-d8000) Mon May 6 10:21:06 PDT 2024
[ 18.724304] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 19.043651] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 19.045753] nvethernet 2310000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 21.995588] rfkill: input handler disabled
[ 22.023248] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: errors=remount-ro. Quota mode: none.
[ 23.136797] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 23.643213] loop1: detected capacity change from 0 to 8
[ 31.361851] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[ 33.759065] VDD_3V3_PCIE: disabling
[ 39.379142] loop1: detected capacity change from 0 to 8
