[ 17.849136] CPU:0, Error: cbb-fabric@0x13a00000, irq=32
[ 17.849138] **************************************
[ 17.859485] CPU:0, Error:cbb-fabric, Errmon:2
[ 17.859491] Error Code : TIMEOUT_ERR
[ 17.859491] Overflow : Multiple TIMEOUT_ERR
[ 17.859499]
[ 17.859500] Error Code : TIMEOUT_ERR
[ 17.859501] MASTER_ID : CCPLEX
[ 17.859501] Address : 0x23de008
[ 17.859503] Cache : 0x1 – Bufferable
[ 17.859504] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 17.859505] Access_Type : Read
[ 17.859506] Access_ID : 0x10
[ 17.859506] Fabric : cbb-fabric
[ 17.859507] Slave_Id : 0x35
[ 17.859508] Burst_length : 0x0
[ 17.859508] Burst_type : 0x1
[ 17.859509] Beat_size : 0x2
[ 17.859509] VQC : 0x0
[ 17.859512] GRPSEC : 0x7e
[ 17.868020] FALCONSEC : 0x0
[ 17.868022] **************************************
[ 17.874245] WARNING: CPU: 0 PID: 729 at drivers/soc/tegra/cbb/tegra234-cbb.c:577 tegra234_cbb_isr+0x130/0x170
[ 17.944682] —[ end trace 0cb7b846446744be ]—
[ 17.959864] using random self ethernet address
[ 17.965781] using random host ethernet address
[ 18.165025] thermal thermal_zone11: failed to read out thermal zone (-61)
[ 18.758108] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[ 18.763705] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[ 20.255163] Bridge firewalling registered
Is there any application running on device?
Reproduce rate?
Which JetPack SW?
Devkit or custom carrier board?
Please don’t just copy the log to expect we can know everything.
Jetson_Linux_R35.2.1_aarch64
Jetson AGX Orin-32G
每次启动时候都会打印log:
Jetson UEFI firmware (version 2.1-32413640 built on 2023-01-24T23:12:27+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
L4TLauncher: Unable to boot via extlinux: Not Found
L4TLauncher: Attempting Kernel Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map…
ÿTC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
ÿ٠ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.104-tegra (cjx@cjx-virtual-machine) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #13 SMP PREEMPT Wed Jun 28 15:15:20 CST 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x80826aa18 SMBIOS=0xffff0000 SMBIOS 3.0=0x806c10000 MEMATTR=0x8075cd018 ESRT=0x806bc8118 RNG=0x82a9fdd18 MEMRESERVE=0x8075f3f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000806bc8118 to 0x0000000806bc8150.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000081a800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000837ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000803ffffff]
[ 0.000000] node 0: [mem 0x0000000804000000-0x00000008061bffff]
[ 0.000000] node 0: [mem 0x00000008061c0000-0x00000008066acfff]
[ 0.000000] node 0: [mem 0x00000008066ad000-0x000000080684afff]
[ 0.000000] node 0: [mem 0x000000080684b000-0x0000000806bfffff]
[ 0.000000] node 0: [mem 0x0000000806c00000-0x0000000806c1ffff]
[ 0.000000] node 0: [mem 0x0000000806c20000-0x00000008074cffff]
[ 0.000000] node 0: [mem 0x00000008074d0000-0x000000080751ffff]
[ 0.000000] node 0: [mem 0x0000000807520000-0x000000080758ffff]
[ 0.000000] node 0: [mem 0x0000000807590000-0x00000008075affff]
[ 0.000000] node 0: [mem 0x00000008075b0000-0x00000008075cffff]
[ 0.000000] node 0: [mem 0x00000008075d0000-0x00000008075effff]
[ 0.000000] node 0: [mem 0x00000008075f0000-0x00000008076affff]
[ 0.000000] node 0: [mem 0x00000008076b0000-0x000000080783ffff]
[ 0.000000] node 0: [mem 0x0000000807840000-0x000000080786ffff]
[ 0.000000] node 0: [mem 0x0000000807870000-0x00000008078bffff]
[ 0.000000] node 0: [mem 0x00000008078c0000-0x000000080792ffff]
[ 0.000000] node 0: [mem 0x0000000807930000-0x0000000807b0ffff]
[ 0.000000] node 0: [mem 0x0000000807b10000-0x0000000807b9ffff]
[ 0.000000] node 0: [mem 0x0000000807ba0000-0x0000000807cdffff]
[ 0.000000] node 0: [mem 0x0000000807ce0000-0x0000000807d1ffff]
[ 0.000000] node 0: [mem 0x0000000807d20000-0x0000000807d6ffff]
[ 0.000000] node 0: [mem 0x0000000807d70000-0x0000000807d9ffff]
[ 0.000000] node 0: [mem 0x0000000807da0000-0x0000000807daffff]
[ 0.000000] node 0: [mem 0x0000000807db0000-0x000000080838ffff]
[ 0.000000] node 0: [mem 0x0000000808390000-0x000000080842ffff]
[ 0.000000] node 0: [mem 0x0000000808430000-0x000000080852ffff]
[ 0.000000] node 0: [mem 0x0000000808530000-0x00000008085cffff]
[ 0.000000] node 0: [mem 0x00000008085d0000-0x00000008086cffff]
[ 0.000000] node 0: [mem 0x00000008086d0000-0x000000080876ffff]
[ 0.000000] node 0: [mem 0x0000000808770000-0x000000080903ffff]
[ 0.000000] node 0: [mem 0x0000000809040000-0x000000080921ffff]
[ 0.000000] node 0: [mem 0x0000000809220000-0x000000082a9affff]
[ 0.000000] node 0: [mem 0x000000082a9b0000-0x000000082a9fffff]
[ 0.000000] node 0: [mem 0x000000082aa00000-0x000000082e7fffff]
[ 0.000000] node 0: [mem 0x000000082ea00000-0x000000082eefffff]
[ 0.000000] node 0: [mem 0x0000000836000000-0x0000000837ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000837ffffff]
[ 0.000000] On node 0, zone Normal: 256 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7937792
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 31048888K/32257024K available (18496K kernel code, 3168K rwdata, 7160K rodata, 3968K init, 1110K bss, 945992K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000709] Console: colour dummy device 80x25
[ 0.000908] printk: console [tty0] enabled
[ 0.000955] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000965] pid_max: default: 32768 minimum: 301
[ 0.001036] LSM: Security Framework initializing
[ 0.001059] Yama: becoming mindful.
[ 0.001080] SELinux: Initializing.
[ 0.001169] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001218] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.003006] rcu: Hierarchical SRCU implementation.
[ 0.003104] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.003895] DTS File Name: /home/cjx/workspcace/nvidia/build_project/public_sources/Linux_for_Tegra/source/public/kernel/kernel-5.10/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0004-p3737-0000.dts
[ 0.003907] DTB Build time: Jun 29 2023 13:58:24
[ 0.005544] Tegra Revision: A01 SKU: 0xd2 CPU Process: 0 SoC Process: 0
[ 0.005864] Remapping and enabling EFI services.
[ 0.007019] smp: Bringing up secondary CPUs …
[ 0.035714] Detected PIPT I-cache on CPU1
[ 0.035752] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.035788] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.064427] Detected PIPT I-cache on CPU2
[ 0.064437] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.064452] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.093040] Detected PIPT I-cache on CPU3
[ 0.093050] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.093063] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.123709] Detected PIPT I-cache on CPU4
[ 0.123729] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.123755] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.152413] Detected PIPT I-cache on CPU5
[ 0.152422] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.152437] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.181054] Detected PIPT I-cache on CPU6
[ 0.181063] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.181077] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.209687] Detected PIPT I-cache on CPU7
[ 0.209697] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.209711] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.209769] smp: Brought up 1 node, 8 CPUs
[ 0.209813] SMP: Total of 8 processors activated.
[ 0.209818] CPU features: detected: Privileged Access Never
[ 0.209821] CPU features: detected: LSE atomic instructions
[ 0.209823] CPU features: detected: User Access Override
[ 0.209826] CPU features: detected: 32-bit EL0 Support
[ 0.209830] CPU features: detected: Common not Private translations
[ 0.209833] CPU features: detected: RAS Extension Support
[ 0.209835] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.209839] CPU features: detected: CRC32 instructions
[ 0.209842] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.245645] CPU: All CPU(s) started at EL2
[ 0.248042] devtmpfs: initialized
[ 0.266458] Registered cp15_barrier emulation handler
[ 0.266471] Registered setend emulation handler
[ 0.266478] KASLR enabled
[ 0.266600] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.266615] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.267978] pinctrl core: initialized pinctrl subsystem
[ 0.268532] SMBIOS 3.0.0 present.
[ 0.268544] DMI: Unknown Jetson AGX Orin/Jetson AGX Orin, BIOS 2.1-32413640 01/24/2023
[ 0.268824] NET: Registered protocol family 16
[ 0.269464] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.269666] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.269863] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.269890] audit: initializing netlink subsys (disabled)
[ 0.269968] audit: type=2000 audit(0.268:1): state=initialized audit_enabled=0 res=1
[ 0.270136] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.270138] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.270143] thermal_sys: Registered thermal governor ‘pid_thermal_gov’
[ 0.272446] cpuidle: using governor menu
[ 0.272549] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.272630] ASID allocator initialised with 32768 entries
[ 0.272720] Serial: AMBA PL011 UART driver
[ 0.274532] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.274557] Tegra reboot handler registered.
[ 0.293518] mc: mapped MMIO address: 0xffff800011110000 → 0x2c10000
[ 0.293532] mc: mapped MMIO address: 0xffff800011130000 → 0x2c20000
[ 0.293539] mc: mapped MMIO address: 0xffff800011150000 → 0x2c30000
[ 0.293546] mc: mapped MMIO address: 0xffff800011170000 → 0x2c40000
[ 0.293554] mc: mapped MMIO address: 0xffff800011190000 → 0x2c50000
[ 0.293560] mc: mapped MMIO address: 0xffff8000111b0000 → 0x2b80000
[ 0.293569] mc: mapped MMIO address: 0xffff8000111d0000 → 0x2b90000
[ 0.293575] mc: mapped MMIO address: 0xffff8000111f0000 → 0x2ba0000
[ 0.293584] mc: mapped MMIO address: 0xffff800011210000 → 0x2bb0000
[ 0.293591] mc: mapped MMIO address: 0xffff800011230000 → 0x1700000
[ 0.293597] mc: mapped MMIO address: 0xffff800011250000 → 0x1710000
[ 0.293603] mc: mapped MMIO address: 0xffff800011270000 → 0x1720000
[ 0.293611] mc: mapped MMIO address: 0xffff800011290000 → 0x1730000
[ 0.293618] mc: mapped MMIO address: 0xffff8000112b0000 → 0x1740000
[ 0.293627] mc: mapped MMIO address: 0xffff8000112d0000 → 0x1750000
[ 0.293633] mc: mapped MMIO address: 0xffff8000112f0000 → 0x1760000
[ 0.293639] mc: mapped MMIO address: 0xffff800011310000 → 0x1770000
[ 0.293653] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.293677] mc-err: mcerr ops are set to t23x
[ 0.294348] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 82, base_baud = 0) is a SBSA
[ 1.496218] printk: console [ttyAMA0] enabled
[ 1.504562] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.511277] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.517978] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.524678] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.533198] ACPI: Interpreter disabled.
[ 1.538250] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.543160] vbusA-cvb: supplied by vdd-5v-sys
[ 1.547641] vbusB-cvb: supplied by vdd-5v-sys
[ 1.552130] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.557033] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.561988] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 1.567354] iommu: Default domain type: Translated
[ 1.572271] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.578544] SCSI subsystem initialized
[ 1.582357] usbcore: registered new interface driver usbfs
[ 1.587854] usbcore: registered new interface driver hub
[ 1.593177] usbcore: registered new device driver usb
[ 1.598424] mc: Linux media interface: v0.10
[ 1.602701] videodev: Linux video capture interface: v2.00
[ 1.608346] pps_core: LinuxPPS API ver. 1 registered
[ 1.613310] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.622448] PTP clock support registered
[ 1.626572] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.633739] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.641397] Registered efivars operations
[ 1.645540] FPGA manager framework
[ 1.648961] Advanced Linux Sound Architecture Driver Initialized.
[ 1.655317] Bluetooth: Core ver 2.22
[ 1.658899] NET: Registered protocol family 31
[ 1.663344] Bluetooth: HCI device and connection manager initialized
[ 1.669703] Bluetooth: HCI socket layer initialized
[ 1.674580] Bluetooth: L2CAP socket layer initialized
[ 1.679637] Bluetooth: SCO socket layer initialized
[ 1.685008] camchar: rtcpu character device driver loaded
[ 1.690631] clocksource: Switched to clocksource arch_sys_counter
[ 1.849512] VFS: Disk quotas dquot_6.6.0
[ 1.853491] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.860526] pnp: PnP ACPI: disabled
[ 1.865861] la/ptsa driver initialized.
[ 1.869748] NET: Registered protocol family 2
[ 1.874307] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 1.884039] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 1.892787] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 1.901077] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.908976] TCP: Hash tables configured (established 262144 bind 65536)
[ 1.915685] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 1.922618] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 1.930063] NET: Registered protocol family 1
[ 1.934744] RPC: Registered named UNIX socket transport module.
[ 1.940679] RPC: Registered udp transport module.
[ 1.945383] RPC: Registered tcp transport module.
[ 1.950084] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.956536] PCI: CLS 0 bytes, default 64
[ 1.960595] Trying to unpack rootfs image as initramfs…
[ 2.076772] Freeing initrd memory: 8208K
[ 2.082914] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.090847] kvm [1]: IPA Size Limit: 48 bits
[ 2.095253] kvm [1]: VHE mode initialized successfully
[ 2.101052] Initialise system trusted keyrings
[ 2.105653] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 2.114197] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.120315] NFS: Registering the id_resolver key type
[ 2.125386] Key type id_resolver registered
[ 2.129568] Key type id_legacy registered
[ 2.133606] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.140312] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.147718] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.163813] NET: Registered protocol family 38
[ 2.168271] Key type asymmetric registered
[ 2.172367] Asymmetric key parser ‘x509’ registered
[ 2.177264] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.184717] io scheduler mq-deadline registered
[ 2.189251] io scheduler kyber registered
[ 2.198385] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.203989] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.209579] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.215165] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.223335] tegra_dc_assign_hw_data: no matching compatible node
[ 2.229348] tegradccommon module_init failed
[ 2.233617] tegradc module_init failed
[ 2.237627] EINJ: ACPI disabled.
[ 2.242447] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.249341] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 2.254652] tegra-pmc: ### PMC reset level: L0
[ 2.259093] tegra-pmc: ### PMC reset status reg: 0x0
[ 2.265280] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.289189] random: fast init done
[ 2.292005] printk: console [ttyTCU0] enabled
[ 3.872254] arm-smmu 12000000.iommu: probing hardware configuration…
[ 3.880281] arm-smmu 12000000.iommu: SMMUv2 with:
[ 3.885102] arm-smmu 12000000.iommu: stage 1 translation
[ 3.890634] arm-smmu 12000000.iommu: stage 2 translation
[ 3.896162] arm-smmu 12000000.iommu: nested translation
[ 3.901616] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 3.909025] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 3.917948] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 3.924642] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 3.931331] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 3.938843] arm-smmu 10000000.iommu: probing hardware configuration…
[ 3.945535] arm-smmu 10000000.iommu: SMMUv2 with:
[ 3.950361] arm-smmu 10000000.iommu: stage 1 translation
[ 3.955892] arm-smmu 10000000.iommu: stage 2 translation
[ 3.961424] arm-smmu 10000000.iommu: nested translation
[ 3.966873] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 3.974276] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 3.983150] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 3.989841] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 3.996527] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.003641] arm-smmu 8000000.iommu: probing hardware configuration…
[ 4.010242] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.014971] arm-smmu 8000000.iommu: stage 1 translation
[ 4.020412] arm-smmu 8000000.iommu: stage 2 translation
[ 4.025860] arm-smmu 8000000.iommu: nested translation
[ 4.031224] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.038544] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.047314] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.053912] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.060516] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.067805] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.077520] tegra_profiler: version: 1.150, samples/io: 50/29
[ 4.083495] tegra_profiler: auth: init
[ 4.087649] nvsciipc: loaded module
[ 4.092781] tun: Universal TUN/TAP device driver, 1.6
[ 4.098447] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.105860] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.111333] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.116425] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.122513] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.128048] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.133924] PPP generic driver version 2.4.2
[ 4.138354] PPP BSD Compression module registered
[ 4.143183] PPP Deflate Compression module registered
[ 4.148390] PPP MPPE Compression module registered
[ 4.153323] usbcore: registered new interface driver r8152
[ 4.158964] usbcore: registered new interface driver asix
[ 4.164517] usbcore: registered new interface driver ax88179_178a
[ 4.170780] usbcore: registered new interface driver cdc_ether
[ 4.176773] usbcore: registered new interface driver net1080
[ 4.182586] usbcore: registered new interface driver cdc_subset
[ 4.188662] usbcore: registered new interface driver zaurus
[ 4.194398] usbcore: registered new interface driver cdc_ncm
[ 4.200211] usbcore: registered new interface driver aqc111
[ 4.205934] GobiNet: Quectel_Linux&Android_GobiNet_Driver_V1.6.3
[ 4.212112] usbcore: registered new interface driver GobiNet
[ 4.218036] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.224380] ohci-pci: OHCI PCI platform driver
[ 4.228950] ohci-platform: OHCI generic platform driver
[ 4.234632] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.240852] usbcore: registered new interface driver uas
[ 4.246323] usbcore: registered new interface driver usb-storage
[ 4.252633] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.258719] mousedev: PS/2 mouse device common for all mice
[ 4.264464] usbcore: registered new interface driver xpad
[ 4.271845] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.277325] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:29 UTC (29)
[ 4.285548] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.291951] i2c /dev entries driver
[ 4.295582] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.301386] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.307066] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.312747] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.318422] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.324088] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.329753] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.335499] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.343277] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.351843] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.361315] device-mapper: uevent: version 1.0.3
[ 4.366141] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.375911] sdhci: Secure Digital Host Controller Interface driver
[ 4.382256] sdhci: Copyright(c) Pierre Ossman
[ 4.386724] Synopsys Designware Multimedia Card Interface Driver
[ 4.392958] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.398918] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 4.399599] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.412455] tegra-bpmp bpmp: firmware: 9a7bb16aee9be45a56e6-ccd7dae126b
[ 4.421284] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.426919] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[ 4.437640] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.443575] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
ÿᣥbugfs initialized
ÿ٠ 5.644510] hid: raw HID events driver (C) Jiri Kosina
[ 5.650071] usbcore: registered new interface driver usbhid
[ 5.655815] usbhid: USB HID core driver
[ 5.660345] tegra-dce d800000.dce: Adding to iommu group 4
[ 5.667468] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
[ 5.676081] tegra234-aon c000000.aon: Adding to iommu group 5
[ 5.682561] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 5.691672] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 5.699460] c000000.aon:hsp: probed
[ 5.703380] tegra234-aon c000000.aon: init done
[ 5.708153] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 5.708883] tegra23x-psc e860000.psc: Adding to iommu group 6
[ 5.717163] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] …
[ 5.723364] tegra23x-psc e860000.psc: ext_cfg base:(ptrval)
[ 5.731456] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 5.737900] tegra23x-psc e860000.psc: init done
[ 5.738058] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[ 5.745583] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] …
[ 5.750723] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.756974] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 5.782135] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 5.791350] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 5.802996] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 5.814487] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 5.826226] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 5.838805] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 5.851651] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 5.863724] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (121)
[ 5.870585] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 5.881926] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=10150ec03f8849d1537396903b70d4a48a255aba
[ 5.895962] t19x_cache tegra-cache: probed
[ 5.900629] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 5.915863] optee: probing for conduit method.
[ 5.920456] optee: revision 3.19 (18d0f61b)
[ 5.920972] optee: dynamic shared memory is enabled
[ 5.930404] optee: initialized driver
[ 5.949185] nvpmodel: initialized successfully
[ 5.953915] tegra_hv: get_hvd: not initialized yet
[ 5.958858] user_ivc_mempool: hypervisor not present
[ 5.965116] usbcore: registered new interface driver snd-usb-audio
[ 5.972530] u32 classifier
[ 5.975316] input device check on
[ 5.979080] Actions configured
[ 5.982724] Initializing XFRM netlink socket
[ 5.987521] NET: Registered protocol family 10
[ 5.993040] Segment Routing with IPv6
[ 5.996865] NET: Registered protocol family 17
[ 6.001457] NET: Registered protocol family 15
[ 6.006073] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.019964] Bluetooth: RFCOMM socket layer initialized
[ 6.025294] Bluetooth: RFCOMM ver 1.11
[ 6.029169] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.035277] Bluetooth: HIDP socket layer initialized
[ 6.040914] 8021q: 802.1Q VLAN Support v1.8
[ 6.045480] 9pnet: Installing 9P2000 support
[ 6.049946] Key type dns_resolver registered
[ 6.055138] registered taskstats version 1
[ 6.059386] Loading compiled-in X.509 certificates
[ 6.066897] Loaded X.509 cert ‘Build time autogenerated kernel key: 9402b6235cc63f1665a56155619e16667218f3c9’
[ 6.077408] tegra194-pcie 14180000.pcie: Adding to iommu group 8
[ 6.090488] tegra194-pcie 14180000.pcie: Using GICv2m MSI allocator
[ 6.098188] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[ 6.110484] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.117325] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[ 6.129883] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.136631] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 6.148877] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.155465] tegra194-pcie 141e0000.pcie: Adding to iommu group 12
[ 6.167641] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 6.199559] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 13
[ 6.209906] host1x 13e40000.host1x: Adding to iommu group 14
[ 7.228084] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 7.246249] host1x 13e40000.host1x: initialized
[ 7.251278] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 15
[ 7.259320] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 7.271402] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 16
[ 7.279457] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 7.291496] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 17
[ 7.299488] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 7.311511] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 18
[ 7.319520] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 7.331495] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 19
[ 7.339497] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 7.351471] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 20
[ 7.359488] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 7.371504] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 21
[ 7.379516] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 7.391493] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 22
[ 7.399502] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 7.411468] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 23
[ 7.419539] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 7.431511] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 24
[ 7.439546] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 7.451521] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 25
[ 7.459519] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 7.471504] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 26
[ 7.479505] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 7.491489] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 27
[ 7.499508] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 7.511487] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 28
[ 7.519500] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 7.531455] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 29
[ 7.539452] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 7.551429] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 30
[ 7.559492] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 7.571487] falcon 15340000.vic: Adding to iommu group 31
[ 7.586462] falcon 15340000.vic: initialized
[ 7.591138] falcon 15380000.nvjpg: Adding to iommu group 32
[ 7.602002] falcon 15380000.nvjpg: initialized
[ 7.606712] falcon 15540000.nvjpg1: Adding to iommu group 33
[ 7.617295] falcon 15540000.nvjpg1: initialized
[ 7.622089] falcon 154c0000.nvenc: Adding to iommu group 34
[ 7.636056] falcon 154c0000.nvenc: initialized
[ 7.640767] falcon 15a50000.ofa: Adding to iommu group 35
[ 7.651927] falcon 15a50000.ofa: initialized
[ 7.656458] nvdec 15480000.nvdec: Adding to iommu group 36
[ 7.673827] nvdec 15480000.nvdec: initialized
[ 7.678432] tsec 15500000.tsec: Adding to iommu group 37
[ 7.692618] tsec 15500000.tsec: initialized
[ 7.699952] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.716848] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.732535] gpio-394 (camera-control-output-low): hogged as output/low
[ 7.739282] gpio-397 (camera-control-output-low): hogged as output/low
[ 7.746025] gpio-487 (camera-control-output-low): hogged as output/low
[ 7.752760] gpio-486 (camera-control-output-low): hogged as output/low
[ 7.759490] gpio-486 (GPIO15_LAN3_PWREN): hogged as output/high
[ 7.765606] gpio-444 (GPIO17_LAN4_PWREN): hogged as output/high
[ 7.771722] gpio-350 (GPIO04_miniPCIe_PWREN): hogged as output/high
[ 7.778205] gpio-449 (GPIO36_M2E_PWREN): hogged as output/high
[ 7.785255] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 7.792757] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 7.799749] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 7.806256] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 7.812747] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 7.819008] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 7.827114] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 7.835671] tegra194-isp5 14800000.isp: Adding to iommu group 38
[ 7.845305] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 7.854911] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 7.861471] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 39
[ 7.869605] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 40
[ 7.877598] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 7.887559] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 7.894352] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 7.904297] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 7.911084] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 7.921024] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 7.927851] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 41
[ 7.936516] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 7.947880] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 42
[ 7.956534] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 7.967882] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 43
[ 7.976512] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 7.987873] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 44
[ 7.996519] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 8.007883] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 45
[ 8.016560] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 8.027932] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 46
[ 8.036573] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 8.047923] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 47
[ 8.056572] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 8.067940] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 48
[ 8.076599] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 8.087960] pva 16000000.pva0: Adding to iommu group 49
[ 8.112782] pva 16000000.pva0: initialized
[ 8.127272] nvdla 15880000.nvdla0: Adding to iommu group 50
[ 8.142191] nvdla 15880000.nvdla0: initialized
[ 8.148410] nvdla 158c0000.nvdla1: Adding to iommu group 51
[ 8.162729] nvdla 158c0000.nvdla1: initialized
[ 8.168956] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 8.175976] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 8.183479] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 8.190116] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 8.196848] serial-tegra 3100000.serial: Adding to iommu group 2
[ 8.203566] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 24, base_baud = 0) is a TEGRA_UART
[ 8.212939] serial-tegra 3110000.serial: Adding to iommu group 2
[ 8.219464] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 79, base_baud = 0) is a TEGRA_UART
[ 8.229091] serial-tegra 3130000.serial: Adding to iommu group 2
[ 8.235725] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 80, base_baud = 0) is a TEGRA_UART
[ 8.245378] serial-tegra 3140000.serial: Adding to iommu group 2
[ 8.251909] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 81, base_baud = 0) is a TEGRA_UART
[ 8.278573] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 8.288329] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.293908] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 8.302539] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 8.312143] tegra-xusb 3610000.xhci: irq 238, io mem 0x03610000
[ 8.318566] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.327067] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.334494] usb usb1: Product: xHCI Host Controller
[ 8.339510] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 8.345777] usb usb1: SerialNumber: 3610000.xhci
[ 8.351316] hub 1-0:1.0: USB hub found
[ 8.355203] hub 1-0:1.0: 4 ports detected
[ 8.359598] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.365159] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 8.372945] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 8.380453] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.388970] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.396402] usb usb2: Product: xHCI Host Controller
[ 8.401416] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 8.407686] usb usb2: SerialNumber: 3610000.xhci
[ 8.412928] hub 2-0:1.0: USB hub found
[ 8.416806] hub 2-0:1.0: 4 ports detected
[ 8.442158] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 8.464573] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2007000 KHz, changing to: 2035200 KHz
[ 8.477860] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2003000 KHz, changing to: 2035200 KHz
[ 8.490142] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 8.497101] tegra194-pcie 14180000.pcie: Using GICv2m MSI allocator
[ 8.504649] tegra194-pcie 14180000.pcie: host bridge /pcie@14180000 ranges:
[ 8.506291] mmc0: CQHCI version 5.10
[ 8.511820] tegra194-pcie 14180000.pcie: IO 0x0038100000…0x00381fffff → 0x0038100000
[ 8.524170] tegra194-pcie 14180000.pcie: MEM 0x2728000000…0x272fffffff → 0x0040000000
[ 8.532843] tegra194-pcie 14180000.pcie: MEM 0x2440000000…0x2727ffffff → 0x2440000000
[ 8.543329] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 8.618779] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 8.643135] mmc0: Command Queue Engine enabled
[ 8.647708] mmc0: periodic cache flush enabled
[ 8.652276] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.659322] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 8.664189] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (511:0)
[ 8.682379] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 8.774675] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[ 8.774807] random: crng init done
[ 8.783105] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 8.793943] usb 1-2: Product: USB2.0 Hub
[ 8.800024] hub 1-2:1.0: USB hub found
[ 8.804666] hub 1-2:1.0: 4 ports detected
[ 8.899362] usb 2-3: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[ 8.932555] usb 2-3: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.56
[ 8.940968] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.948317] usb 2-3: Product: USB3.1 Hub
[ 8.952344] usb 2-3: Manufacturer: GenesysLogic
[ 8.962616] hub 2-3:1.0: USB hub found
[ 8.967672] hub 2-3:1.0: 4 ports detected
[ 9.054776] usb 1-4: new full-speed USB device number 3 using tegra-xusb
[ 9.216082] usb 1-4: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[ 9.224494] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 9.290632] usb 1-2.1: new high-speed USB device number 4 using tegra-xusb
[ 9.405896] usb 1-2.1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.56
[ 9.414484] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.421998] usb 1-2.1: Product: USB2.1 Hub
[ 9.426208] usb 1-2.1: Manufacturer: GenesysLogic
[ 9.432556] hub 1-2.1:1.0: USB hub found
[ 9.437256] hub 1-2.1:1.0: 4 ports detected
[ 9.526633] usb 1-2.2: new high-speed USB device number 5 using tegra-xusb
[ 9.638424] usb 1-2.2: New USB device found, idVendor=0403, idProduct=6011, bcdDevice= 8.00
[ 9.647003] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.648062] tegra194-pcie 14180000.pcie: Phy link never came up
[ 9.654516] usb 1-2.2: Product: Quad RS232-HS
[ 9.654517] usb 1-2.2: Manufacturer: FTDI
[ 9.669264] tegra194-pcie 14180000.pcie: PCI host bridge to bus 0000:00
[ 9.676058] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 9.681692] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 9.691520] pci_bus 0000:00: root bus resource [mem 0x2728000000-0x272fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.702347] pci_bus 0000:00: root bus resource [mem 0x2440000000-0x2727ffffff pref]
[ 9.710282] pci 0000:00:00.0: [10de:229c] type 01 class 0x060400
[ 9.716616] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 9.730639] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 9.736032] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.744990] pcieport 0000:00:00.0: Adding to iommu group 8
[ 9.750898] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
[ 9.757076] pcieport 0000:00:00.0: AER: enabled with IRQ 62
[ 9.763033] pci_bus 0000:01: busn_res: [bus 01-ff] is released
[ 9.769113] pci 0000:00:00.0: Removing from iommu group 8
[ 9.774680] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[ 9.782502] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 9.789683] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 9.796852] tegra194-pcie 14100000.pcie: IO 0x0030100000…0x00301fffff → 0x0030100000
[ 9.805537] tegra194-pcie 14100000.pcie: MEM 0x20a8000000…0x20afffffff → 0x0040000000
[ 9.814218] tegra194-pcie 14100000.pcie: MEM 0x2080000000…0x20a7ffffff → 0x2080000000
[ 10.932242] tegra194-pcie 14100000.pcie: Phy link never came up
[ 10.938383] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 10.945193] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 10.950827] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 10.960943] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 10.971769] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 10.979681] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 10.986017] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 10.999824] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 11.005219] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 11.014159] pcieport 0001:00:00.0: Adding to iommu group 9
[ 11.020035] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[ 11.026194] pcieport 0001:00:00.0: AER: enabled with IRQ 64
[ 11.032678] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 11.040047] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 11.047214] tegra194-pcie 14160000.pcie: IO 0x0036100000…0x00361fffff → 0x0036100000
[ 11.055900] tegra194-pcie 14160000.pcie: MEM 0x2428000000…0x242fffffff → 0x0040000000
[ 11.064585] tegra194-pcie 14160000.pcie: MEM 0x2140000000…0x2427ffffff → 0x2140000000
[ 12.179958] tegra194-pcie 14160000.pcie: Phy link never came up
[ 12.186105] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 12.192922] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 12.198555] pci_bus 0004:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x36100000-0x361fffff])
[ 12.208664] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 12.219496] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 12.227416] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 12.233750] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 12.247498] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 12.252891] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 12.261854] pcieport 0004:00:00.0: Adding to iommu group 10
[ 12.267824] pcieport 0004:00:00.0: PME: Signaling with IRQ 66
[ 12.273983] pcieport 0004:00:00.0: AER: enabled with IRQ 66
[ 12.279924] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 12.285998] pci 0004:00:00.0: Removing from iommu group 10
[ 12.291644] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 12.299029] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 12.305845] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 12.313080] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 12.320258] tegra194-pcie 141e0000.pcie: IO 0x003e100000…0x003e1fffff → 0x003e100000
[ 12.328936] tegra194-pcie 141e0000.pcie: MEM 0x3228000000…0x322fffffff → 0x0040000000
[ 12.337619] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000…0x3227ffffff → 0x2e40000000
[ 13.456231] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 13.462393] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 13.469210] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 13.474846] pci_bus 0007:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3e100000-0x3e1fffff])
[ 13.484937] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 13.495764] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[ 13.503682] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 13.509987] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 13.523742] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 13.529131] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 13.538052] pcieport 0007:00:00.0: Adding to iommu group 12
[ 13.544025] pcieport 0007:00:00.0: PME: Signaling with IRQ 70
[ 13.550187] pcieport 0007:00:00.0: AER: enabled with IRQ 70
[ 13.556111] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 13.562185] pci 0007:00:00.0: Removing from iommu group 12
[ 13.567834] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 13.574857] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 13.579864] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 13.584800] vdd-dp: supplied by vdd-3v3-sys
[ 13.589239] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 13.596709] tegra194-isp5 14800000.isp: initialized
[ 13.606252] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 13.612689] (NULL device *): fops function table already registered
[ 13.620560] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 13.627364] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 13.740347] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 13.747507] tegra194-pcie 141a0000.pcie: IO 0x003a100000…0x003a1fffff → 0x003a100000
[ 13.756189] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000…0x2b2fffffff → 0x0040000000
[ 13.764864] tegra194-pcie 141a0000.pcie: MEM 0x2740000000…0x2b27ffffff → 0x2740000000
[ 13.878773] tegra194-pcie 141a0000.pcie: Link up
[ 13.886455] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 13.893254] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 13.898890] pci_bus 0005:00: root bus resource [io 0x400000-0x4fffff] (bus address [0x3a100000-0x3a1fffff])
[ 13.908989] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 13.919818] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 13.927731] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 13.934043] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 13.944266] pci 0005:01:00.0: [8086:2723] type 00 class 0x028000
[ 13.950639] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 13.958685] pci 0005:01:00.0: PME# supported from D0 D3hot D3cold
[ 13.969373] pci 0005:00:00.0: BAR 14: assigned [mem 0x2b28000000-0x2b280fffff]
[ 13.976804] pci 0005:01:00.0: BAR 0: assigned [mem 0x2b28000000-0x2b28003fff 64bit]
[ 13.984771] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 13.990138] pci 0005:00:00.0: bridge window [mem 0x2b28000000-0x2b280fffff]
[ 13.997489] pci 0005:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 14.006238] pci 0005:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 14.015174] pcieport 0005:00:00.0: Adding to iommu group 11
[ 14.021151] pcieport 0005:00:00.0: PME: Signaling with IRQ 68
[ 14.027307] pcieport 0005:00:00.0: AER: enabled with IRQ 68
[ 14.033891] nvethernet 2310000.ethernet: Adding to iommu group 52
[ 14.040301] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[ 14.048461] nvethernet 2310000.ethernet: failed to read MDIO address
[ 14.055010] nvethernet 2310000.ethernet: setting to default DMA bit mask
[ 14.061898] nvethernet 2310000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 14.070751] nvethernet 2310000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 14.080312] nvethernet 2310000.ethernet: failed to get phy reset gpio error: -2
[ 14.090723] nvethernet 2310000.ethernet: Ethernet MAC index missing
[ 14.097199] nvethernet 2310000.ethernet: Ethernet MAC address: 48:b0:2d:94:6a:73
[ 14.105230] nvethernet 2310000.ethernet: Macsec not enabled
[ 14.110967] nvethernet 2310000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 14.119540] nvethernet 2310000.ethernet: eth0 (HW ver: 53) created with 8 DMA channels
[ 14.128157] irq: IRQ306: trimming hierarchy from :pmc@c360000
[ 14.134129] irq: IRQ307: trimming hierarchy from :interrupt-controller@f400000-1
[ 14.141795] irq: IRQ308: trimming hierarchy from :pmc@c360000
[ 14.147754] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 14.155144] tegra-se-nvhost 15810000.se: Adding to iommu group 53
[ 14.161725] tegra-se-nvhost 15810000.se: initialized
[ 14.177634] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 14.183997] tegra-se-nvhost 15820000.se: Adding to iommu group 54
[ 14.190555] tegra-se-nvhost 15820000.se: initialized
[ 14.196521] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 14.202892] tegra-se-nvhost 15840000.se: Adding to iommu group 55
[ 14.209405] tegra-se-nvhost 15840000.se: initialized
[ 14.215561] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 14.222425] tegra_actmon d230000.actmon: in actmon_register()…
[ 14.228767] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 14.234804] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 14.243173] hvc_sysfs: hypervisor is not present
ÿᖁRNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
ÿ٠ 14.376815] ALSA device list:
[ 14.379867] No soundcards found.
[ 14.383933] Freeing unused kernel memory: 3968K
[ 14.388631] Run /init as init process
[ 14.403954] Root device found: mmcblk0p1
[ 14.408465] Found dev node: /dev/mmcblk0p1
[ 14.589543] EXT4-fs (mmcblk0p1): 3 orphan inodes deleted
[ 14.595017] EXT4-fs (mmcblk0p1): recovery complete
[ 14.604236] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 14.613524] Rootfs mounted over mmcblk0p1
[ 14.634463] Switching from initrd to actual rootfs
[ 14.769640] systemd[1]: System time before build time, advancing clock.
[ 14.799537] x_tables: module verification failed: signature and/or required key missing - tainting kernel
[ 14.837119] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 14.860783] systemd[1]: Detected architecture arm64.
[ 14.902739] systemd[1]: Set hostname to .
[ 14.930245] systemd-rc-local-generator[256]: /etc/rc.local is not marked executable, skipping.
[ 15.104168] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 15.117185] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 15.126882] systemd[1]: Created slice system-modprobe.slice.
[ 15.133197] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 15.140040] systemd[1]: Created slice User and Session Slice.
[ 15.146071] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 15.154142] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 15.163916] systemd[1]: Reached target User and Group Name Lookups.
[ 15.170435] systemd[1]: Reached target Slices.
[ 15.175060] systemd[1]: Reached target Swap.
[ 15.179712] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 15.186590] systemd[1]: Listening on Syslog Socket.
[ 15.191756] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 15.198756] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 15.205689] systemd[1]: Listening on Journal Audit Socket.
[ 15.211470] systemd[1]: Listening on Journal Socket (/dev/log).
[ 15.217727] systemd[1]: Listening on Journal Socket.
[ 15.222985] systemd[1]: Listening on udev Control Socket.
[ 15.228642] systemd[1]: Listening on udev Kernel Socket.
[ 15.235268] systemd[1]: Mounting Huge Pages File System…
[ 15.242036] systemd[1]: Mounting POSIX Message Queue File System…
[ 15.249537] systemd[1]: Mounting RPC Pipe File System…
[ 15.256055] systemd[1]: Mounting Kernel Debug File System…
[ 15.262879] systemd[1]: Mounting Kernel Trace File System…
[ 15.270013] systemd[1]: Starting Journal Service…
[ 15.276304] systemd[1]: Starting Set the console keyboard layout…
[ 15.283813] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 15.293599] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[ 15.300610] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 15.310031] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 15.317482] systemd[1]: Starting Load Kernel Module pstore_blk…
[ 15.325147] systemd[1]: Starting Load Kernel Module pstore_zone…
[ 15.332796] systemd[1]: Starting Load Kernel Module ramoops…
[ 15.340063] systemd[1]: Starting NVIDIA specific first-boot udev script…
[ 15.348304] systemd[1]: Started Nameserver information manager.
[ 15.354698] systemd[1]: Reached target Network (Pre).
[ 15.360774] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 15.370115] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 15.387390] systemd[1]: Starting Load Kernel Modules…
[ 15.393804] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 15.401815] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 15.401834] systemd[1]: Starting udev Coldplug all Devices…
[ 15.402115] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 15.408729] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000000833000000,16777216
[ 15.429667] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 15.437927] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000849800000,914358272
[ 15.437928] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 15.437935] nvmap_page_pool_init: Total RAM pages: 7830802
[ 15.461493] nvmap_page_pool_init: nvmap page pool size: 978850 pages (3823 MB)
[ 15.461537] nvmap_background_zero_thread: PP zeroing thread starting.
[ 15.461629] misc nvmap: created heap vpr base 0x0000000849800000 size (892928KiB)
[ 15.464611] misc nvmap: created heap fsi base 0x0000000833000000 size (16384KiB)
[ 15.492517] systemd[1]: Started Journal Service.
[ 15.526292] systemd-journald[269]: Received client request to flush runtime journal.
[ 15.551246] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 15.551246]
[ 15.830165] using random self ethernet address
[ 15.834763] using random host ethernet address
[ 15.929163] rt5640 8-001c: Device with ID register 0xffff11a1 is not rt5640/39
[ 15.955442] nvidia: loading out-of-tree module taints kernel.
[ 16.156188] ucsi_ccg 1-0008: i2c_transfer failed -121
[ 16.161736] ucsi_ccg 1-0008: ucsi_ccg_init failed - -121
[ 16.185112] ucsi_ccg: probe of 1-0008 failed with error -121
[ 16.361703] iwlwifi 0005:01:00.0: api flags index 2 larger than supported by driver
[ 16.614807] CPU:0, Error: cbb-fabric@0x13a00000, irq=32
[ 16.620188] **************************************
[ 16.620189] CPU:0, Error:cbb-fabric, Errmon:2
[ 16.620195] Error Code : TIMEOUT_ERR
[ 16.620196] Overflow : Multiple TIMEOUT_ERR
[ 16.620206]
[ 16.620212] Error Code : TIMEOUT_ERR
[ 16.620215] MASTER_ID : CCPLEX
[ 16.620218] Address : 0x23de008
[ 16.620221] Cache : 0x1 – Bufferable
[ 16.620225] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 16.620227] Access_Type : Read
[ 16.620230] Access_ID : 0x13
[ 16.620232] Fabric : cbb-fabric
[ 16.620235] Slave_Id : 0x35
[ 16.620237] Burst_length : 0x0
[ 16.620240] Burst_type : 0x1
[ 16.620242] Beat_size : 0x2
[ 16.620245] VQC : 0x0
[ 16.620248] GRPSEC : 0x7e
[ 16.620251] FALCONSEC : 0x0
[ 16.620254] **************************************
[ 16.629681] WARNING: CPU: 0 PID: 0 at drivers/soc/tegra/cbb/tegra234-cbb.c:577 tegra234_cbb_isr+0x130/0x170
[ 16.710103] —[ end trace 6ffbf31ee4861e09 ]—
[ 16.791608] thermal thermal_zone11: failed to read out thermal zone (-61)
[ 16.813542] using random self ethernet address
[ 16.818251] using random host ethernet address
[ 17.531875] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[ 17.537449] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[ 19.517533] Bridge firewalling registered
Ubuntu 20.04.5 LTS sirun ttyTCU0
Is it devkit or custom carrier board?
方便给我解释一下这是什么类型的故障吗?我这边应该怎么解决上报的这个故障。
From the log, it looks related specific kind of etherent switch which we don’t have experience, please contact with vendor if they can provide more information.
This register is MACSEC_TX_MTU_LEN_0
您的意思是交换机芯片KSZ9893引起了该错误吗?你可以具体描述一下该错误是什么吗?我不太了解该错误具体是什么。
不太確定 我們這邊對KSZ9893沒有經驗.
error log大致上只有寫說是timeout error. 看起來是嘗試讀寫register的時候沒有回應
因為跟MACSEC_TX_MTU_LEN_0有關, 所以應該是下面這個driver裡面的macsec_update_mtu()造成的
kernel/nvidia/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/macsec.c
試試看加上這個patch有沒有影響
diff --git a/drivers/net/ethernet/nvidia/nvethernet/macsec.c b/drivers/net/ethernet/nvidia/nvethernet/macsec.c
index 9bbf907..77673ed 100644
--- a/drivers/net/ethernet/nvidia/nvethernet/macsec.c
+++ b/drivers/net/ethernet/nvidia/nvethernet/macsec.c
@@ -1463,6 +1463,7 @@
macsec_release_platform_res(macsec_pdata);
init_err:
devm_kfree(dev, pdata->macsec_pdata);
+ pdata->macsec_pdata = NULL;
exit:
PRINT_EXIT();
return ret;
好的,谢谢您的帮助,我按照您的方法测试一下。
我tiania添加之后还是会出现如下所示:
当我修改设备树屏蔽掉:nvidia,max-platform-mtu = <16383>;
之后上面的问题就不会出现,但是会出现新的问题如下所示:
所以woyg我应该设置nvidia,max-platform-mtu 多少可以解决上面的问题。
您好,我这边发现应该是nvidia,max-platform-mtu = <16383>;会出现该错误,该错误会影响RGMII和SWITCH使用吗?
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
虚拟的网口lan1和lan2网线直连笔记本电脑互相ping没有问题。
当ssh连接或者iperf3测试网速时会出现如下内核崩溃的错误。
1 我们自己做的板子,使用的交换机芯片KSZ9893.
2 Jetson_Linux_R35.2.1_aarch64
3 每次都会出现。
4 相关设备树配置如下:
chosen {
nvidia,ether-mac0 = “48:B0:2D:5D:16:18”;
nvidia,ether-mac = “48:B0:2D:5D:16:18”;
eth0:
ethernet@2310000 { nvidia,pause_frames = <0>; phy_mode = “rgmii”; status = “okay”; nvidia,max-platform-mtu = <16383>; fixed-link { speed = <1000>; full-duplex; }; }; spi1: spi@c260000 { status = “okay”; spi-max-frequency = <25000000>; ksz9893: ksz9893@0 {
compatible = “microchip,ksz9893”; spi-max-frequency = <10000000>; //spi-max-frequency = <44000000>; reg = <0x0>; phy_mode = “rgmii-txid”; interrupt-parent = <&tegra_main_gpio>; interrupts = <TEGRA234_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>; status = “okay”; ports
{ #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; label = “lan1”; }; port@1 { reg = <1>; label = “lan2”; }; port@2 { reg = <2>; lable = “cpu”; ethernet = <ð0>; fixed-link { speed = <1000>; full-duplex; }; }; }; }; };
log.log (430.7 KB)
Hello is there any solution to this problem ?
I think we are facing quite the same issue on agx orin 32G with jetpack 6.0 r36.3.0
On our custom board we are using the marvell switch mv88e6321 so we are also in fixed-link
The issue seems to has nothing to do with the switch as I removed the switch driver and we are still facing the problem.
Here are the logs after I did :
ifconfig eth0 down
ifconfig eth0 mtu 1500
[ 1742.882987] nvethernet 2310000.ethernet eth0: Link is Down
[ 1749.108342] nvethernet 2310000.ethernet eth0: Macsec: Reduced MTU: 1466 Max: 16383
[ 1749.108585] CPU:0, Error: cbb-fabric@0x13a00000, irq=182
[ 1749.108600] **************************************
[ 1749.108602] CPU:0, Error:cbb-fabric, Errmon:2
[ 1749.108609] Error Code : TIMEOUT_ERR
[ 1749.108612] Overflow : Multiple TIMEOUT_ERR
[ 1749.108623] Error Code : TIMEOUT_ERR
[ 1749.108625] MASTER_ID : CCPLEX
[ 1749.108627] Address : 0x23de008
[ 1749.108630] Cache : 0x1 – Bufferable
[ 1749.108634] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 1749.108637] Access_Type : Read
[ 1749.108639] Access_ID : 0x12
[ 1749.108641] Fabric : cbb-fabric
[ 1749.108643] Slave_Id : 0x35
[ 1749.108645] Burst_length : 0x0
[ 1749.108647] Burst_type : 0x1
[ 1749.108649] Beat_size : 0x2
[ 1749.108651] VQC : 0x0
[ 1749.108652] GRPSEC : 0x7e
[ 1749.108654] FALCONSEC : 0x0
[ 1749.108659] AXI2APB_35_BLOCK_TMO_STATUS : 0x1
[ 1749.108663] AXI2APB_35_BLOCK0_TMO : 0x200
[ 1749.108667] **************************************
[ 1749.108714] ------------[ cut here ]------------
[ 1749.108716] WARNING: CPU: 0 PID: 0 at /drivers/soc/tegra/cbb/tegra234-cbb.c:608 tegra234_cbb_isr+0x14c/0x1a0
[ 1749.108741] Modules linked in: bluetooth ecdh_generic ecc nex_evpu_video(O) videobuf2_vmalloc libqdma(O) videobuf2_dma_sg videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc nvvrs_pseq_rtc(O) snd_hda_codec_hdmi tegra_camera_platform(O) tegra234_oc_event(O) tegra23x_perf_uncore(O) mttcan(O) tegra_mce(O) nvpmodel_clk_cap(O) snd_hda_tegra snd_hda_codec can_dev nvethernet(O) thermal_trip_event(O) tegra_cactmon_mc_all(O) snd_hda_core qdma_pf(O) tegra234_aon(O) at24 pwm_tegra_tachometer(O) spi_tegra114 i2c_nvvrs11(O) pwm_tegra lm90 tegra_bpmp_thermal nvidia_vrs_pseq(O) nvpps(O) host1x_fence(O) mc_hwpm(O) cfg80211 rfkill tegra_se(O) nvhost_nvdla(O) nvhost_pva(O) crypto_engine pwm_fan nvidia_drm(O) governor_userspace tegra_drm(O) tegra_wmark(O) nvhwpm(O) cec nvidia_modeset(O) nvidia(O) tegra_dce(O) tsecriscv(O) drm_kms_helper host1x_nvhost(O) nvgpu(O) governor_pod_scaling(O) nvmap(O) nvsciipc(O) host1x(O) mc_utils(O) ina3221 drm nvme nvme_core tegra_xudc pcie_tegra194 phy_tegra194_p2u
[ 1749.108871] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G O 5.15.136-l4t-r36.3-1009.9+g46cdb595bebc #1
[ 1749.108878] Hardware name: NVIDIA Nexvision Evpu Orin/Jetson, BIOS v36.3.0 02/09/2024
[ 1749.108882] pstate: 604000c9 (nZCv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=–)
[ 1749.108888] pc : tegra234_cbb_isr+0x14c/0x1a0
[ 1749.108893] lr : tegra234_cbb_isr+0x124/0x1a0
[ 1749.108898] sp : ffff800008003e60
[ 1749.108900] x29: ffff800008003e60 x28: ffffcfcff86b3480 x27: 0000000000000001
[ 1749.108907] x26: 00000000000000c0 x25: ffffcfcff7c752f8 x24: ffffcfcff8b4f548
[ 1749.108913] x23: ffffcfcff800b008 x22: 00000000000000b6 x21: ffffcfcff898eba8
[ 1749.108918] x20: ffffcfcff898ec68 x19: 0000000000000000 x18: 00000000fffffffd
[ 1749.108924] x17: ffff3037b0bc9000 x16: ffff800008000000 x15: ffff800008003670
[ 1749.108930] x14: 0000000000000001 x13: 2a2a2a2a2a2a2a2a x12: 2a2a2a2a2a2a2a2a
[ 1749.108935] x11: 2a2a2a2a2a2a2a2a x10: 2a2a2a2a2a2a2a2a x9 : 2a2a2a2a2a2a2a2a
[ 1749.108941] x8 : 2a2a2a2a2a2a2a2a x7 : 0000000000000000 x6 : 2a2a2a2a2a2a2a09
[ 1749.108946] x5 : ffff0007a8bd69f0 x4 : 00000000fffff37a x3 : 0000000000000000
[ 1749.108951] x2 : ffffcfcff60e1798 x1 : ffffcfcff86b3480 x0 : 0000000100010001
[ 1749.108957] Call trace:
[ 1749.108960] tegra234_cbb_isr+0x14c/0x1a0
[ 1749.108966] __handle_irq_event_percpu+0x68/0x260
[ 1749.108973] handle_irq_event+0x74/0x110
[ 1749.108977] handle_fasteoi_irq+0xb0/0x1a0
[ 1749.108983] handle_domain_irq+0x74/0xac
[ 1749.108991] gic_handle_irq+0x68/0x150
[ 1749.109001] call_on_irq_stack+0x20/0x50
[ 1749.109008] do_interrupt_handler+0x70/0x80
[ 1749.109013] el1_interrupt+0x30/0x80
[ 1749.109023] el1h_64_irq_handler+0x18/0x2c
[ 1749.109030] el1h_64_irq+0x7c/0x80
[ 1749.109034] cpuidle_enter_state+0xc0/0x3f4
[ 1749.109044] cpuidle_enter+0x44/0x60
[ 1749.109051] do_idle+0x224/0x2b0
[ 1749.109058] cpu_startup_entry+0x34/0x70
[ 1749.109063] rest_init+0xf0/0x100
[ 1749.109071] arch_call_rest_init+0x1c/0x28
[ 1749.109081] start_kernel+0x6c0/0x704
[ 1749.109087] __primary_switched+0xbc/0xc4
[ 1749.109094] —[ end trace d1d1ef2f94fbefb3 ]—
Do you have any idea on how to fix this issue ?
Thank you,
Walid
dmesg.txt (77.3 KB)
Hello, you can find here more logs, it looks like it is related to macsec_update_mtu.
Thank you,
Walid
dmesg5.1.2.txt (74.8 KB)
Here is the log for jetpack 5.1.2, We are not facing this issue. It looks like macsec is disabled. We are using the same node for ethernet in device tree as in jetpack 6.0.
Thanks,
Walid
Hi @utilisateur1559
Please help to open a new topic for your own issue. Thanks
