AGX Orin developer kit wont boot
After trying to install cuda on agx orin developer kit something went wront and now it wont boot normaly. During the process of installing cuda i see message in terminal that if next boot fail i can revert to backup file initrd to boot, but I can’t find how to do that.
All I can do now is to enter setup menu when pressing ESC during boot.
I can use sdk manager to reflash jetson but that’s last option for me.
I tried this
but it was already on Normal
Hi deki4679,
Could you share the full log at this moment?
Please share the full steps how you install CUDA on AGX Orin devkit.
Jetpack is 5.1.3
Here is log from minicom
Jetson UEFI firmware (version 5.0-35550185 built on 2024-02-20T04:21:22+00:00)
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
**  WARNING: Test Key is used.  **
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
��[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.192-tegra (buildbrain@mobile-u64-6376-d8000) (aarch64-buildroot-linux-gnu-gcc.br4
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: Jetson AGX Orin Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x824621f18 SMBIOS=0xffff0000 SMBIOS 3.0=0x828640000 MEMATTR=0x822df0018 ESRT=0x822df28
[    0.000000] random: crng init done
[    0.000000] esrt: Reserving ESRT space from 0x0000000822df2818 to 0x0000000822df2850.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000806400000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000833ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000008193b1fff]
[    0.000000]   node   0: [mem 0x00000008193b2000-0x00000008197abfff]
[    0.000000]   node   0: [mem 0x00000008197ac000-0x0000000826c8ffff]
[    0.000000]   node   0: [mem 0x0000000826c90000-0x0000000828bcffff]
[    0.000000]   node   0: [mem 0x0000000828bd0000-0x000000082d2fffff]
[    0.000000]   node   0: [mem 0x000000082d310000-0x000000082d31ffff]
[    0.000000]   node   0: [mem 0x0000000832000000-0x0000000833ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000833ffffff]
[    0.000000] On node 0, zone Normal: 16 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 224 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90392 r8192 d32488 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 7931408
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyT
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[    0.000000] Memory: 31030508K/32230464K available (18560K kernel code, 3168K rwdata, 7196K rodata, 3968K init, )
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 8815904s
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000704] Console: colour dummy device 80x25
[    0.000848] printk: console [tty0] enabled
[    0.000888] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=1250)
[    0.000899] pid_max: default: 32768 minimum: 301
[    0.000958] LSM: Security Framework initializing
[    0.000981] Yama: becoming mindful.
[    0.000999] SELinux:  Initializing.
[    0.001086] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.001133] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.003232] rcu: Hierarchical SRCU implementation.
[    0.003325] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.004127] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../.s
[    0.004138] DTB Build time: Jun 13 2024 20:20:58
[    0.005642] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[    0.005940] Remapping and enabling EFI services.
[    0.006874] smp: Bringing up secondary CPUs ...
[    0.035585] Detected PIPT I-cache on CPU1
[    0.035621] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.035655] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.064309] Detected PIPT I-cache on CPU2
[    0.064320] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.064334] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.092930] Detected PIPT I-cache on CPU3
[    0.092939] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.092952] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.123614] Detected PIPT I-cache on CPU4
[    0.123634] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.123661] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.152308] Detected PIPT I-cache on CPU5
[    0.152318] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.152333] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.180948] Detected PIPT I-cache on CPU6
[    0.180958] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.180972] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.209601] Detected PIPT I-cache on CPU7
[    0.209611] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.209625] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.240293] Detected PIPT I-cache on CPU8
[    0.240316] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[    0.240342] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[    0.268992] Detected PIPT I-cache on CPU9
[    0.269003] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[    0.269017] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[    0.298249] Detected PIPT I-cache on CPU10
[    0.298259] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[    0.298273] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[    0.327504] Detected PIPT I-cache on CPU11
[    0.327515] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[    0.327530] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[    0.327587] smp: Brought up 1 node, 12 CPUs
[    0.327652] SMP: Total of 12 processors activated.
[    0.327657] CPU features: detected: Privileged Access Never
[    0.327659] CPU features: detected: LSE atomic instructions
[    0.327662] CPU features: detected: User Access Override
[    0.327665] CPU features: detected: 32-bit EL0 Support
[    0.327669] CPU features: detected: Common not Private translations
[    0.327671] CPU features: detected: RAS Extension Support
[    0.327674] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.327678] CPU features: detected: CRC32 instructions
[    0.327680] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.345182] spectre-bhb mitigation disabled by command line option
[    0.361144] CPU: All CPU(s) started at EL2
[    0.363602] devtmpfs: initialized
[    0.382135] Registered cp15_barrier emulation handler
[    0.382148] Registered setend emulation handler
[    0.382155] KASLR enabled
[    0.382287] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.382305] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.383752] pinctrl core: initialized pinctrl subsystem
[    0.384450] NET: Registered protocol family 16
[    0.385216] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.385418] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.385616] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.385642] audit: initializing netlink subsys (disabled)
[    0.385716] audit: type=2000 audit(0.384:1): state=initialized audit_enabled=0 res=1
[    0.385896] thermal_sys: Registered thermal governor 'step_wise'
[    0.385897] thermal_sys: Registered thermal governor 'power_allocator'
[    0.385902] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.388428] cpuidle: using governor menu
[    0.388550] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.388673] ASID allocator initialised with 32768 entries
[    0.388755] Serial: AMBA PL011 UART driver
[    0.390645] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.390669] Tegra reboot handler registered.
[    0.409228] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2c10000
[    0.409246] mc: mapped MMIO address: 0xffff800011210000 -> 0x2c20000
[    0.409253] mc: mapped MMIO address: 0xffff800011230000 -> 0x2c30000
[    0.409260] mc: mapped MMIO address: 0xffff800011250000 -> 0x2c40000
[    0.409267] mc: mapped MMIO address: 0xffff800011270000 -> 0x2c50000
[    0.409274] mc: mapped MMIO address: 0xffff800011290000 -> 0x2b80000
[    0.409281] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x2b90000
[    0.409287] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x2ba0000
[    0.409294] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x2bb0000
[    0.409300] mc: mapped MMIO address: 0xffff800011310000 -> 0x1700000
[    0.409307] mc: mapped MMIO address: 0xffff800011330000 -> 0x1710000
[    0.409313] mc: mapped MMIO address: 0xffff800011350000 -> 0x1720000
[    0.409320] mc: mapped MMIO address: 0xffff800011370000 -> 0x1730000
[    0.409326] mc: mapped MMIO address: 0xffff800011390000 -> 0x1740000
[    0.409332] mc: mapped MMIO address: 0xffff8000113b0000 -> 0x1750000
[    0.409339] mc: mapped MMIO address: 0xffff8000113d0000 -> 0x1760000
[    0.409346] mc: mapped MMIO address: 0xffff8000113f0000 -> 0x1770000
[    0.409355] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.409394] mc-err: mcerr ops are set to t23x
[    0.410040] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 80, base_baud = 0) is a SBSA
[    1.492422] printk: console [ttyAMA0] enabled
[    1.500768] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    1.507483] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    1.514186] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    1.520886] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.529412] ACPI: Interpreter disabled.
[    1.534443] vdd-av1v1-hub: supplied by vdd-5v-sys
[    1.539351] vbusA-cvb: supplied by vdd-5v-sys
[    1.543815] vbusB-cvb: supplied by vdd-5v-sys
[    1.548299] vdd-usbc1-vbus: supplied by vdd-5v-sys
[    1.553203] vdd-usbc2-vbus: supplied by vdd-5v-sys
[    1.558434] iommu: Default domain type: Translated
[    1.563351] eventlib_kernel: keventlib is initialized, test id: 0
[    1.569614] SCSI subsystem initialized
[    1.573423] usbcore: registered new interface driver usbfs
[    1.578927] usbcore: registered new interface driver hub
[    1.584248] usbcore: registered new device driver usb
[    1.589489] mc: Linux media interface: v0.10
[    1.593769] videodev: Linux video capture interface: v2.00
[    1.599402] pps_core: LinuxPPS API ver. 1 registered
[    1.604366] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.613503] PTP clock support registered
[    1.617652] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    1.624810] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    1.632474] Registered efivars operations
[    1.637055] FPGA manager framework
[    1.640498] Advanced Linux Sound Architecture Driver Initialized.
[    1.646851] Bluetooth: Core ver 2.22
[    1.650433] NET: Registered protocol family 31
[    1.654877] Bluetooth: HCI device and connection manager initialized
[    1.661235] Bluetooth: HCI socket layer initialized
[    1.666112] Bluetooth: L2CAP socket layer initialized
[    1.671169] Bluetooth: SCO socket layer initialized
[    1.676547] camchar: rtcpu character device driver loaded
[    1.682196] clocksource: Switched to clocksource arch_sys_counter
[    1.851425] VFS: Disk quotas dquot_6.6.0
[    1.855399] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.862887] pnp: PnP ACPI: disabled
[    1.868300] la/ptsa driver initialized.
[    1.872195] NET: Registered protocol family 2
[    1.876759] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    1.886534] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    1.895283] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    1.903580] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    1.911477] TCP: Hash tables configured (established 262144 bind 65536)
[    1.918180] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    1.925110] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    1.932548] NET: Registered protocol family 1
[    1.937175] RPC: Registered named UNIX socket transport module.
[    1.943106] RPC: Registered udp transport module.
[    1.947811] RPC: Registered tcp transport module.
[    1.952513] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.958964] PCI: CLS 0 bytes, default 64
[    1.963022] Trying to unpack rootfs image as initramfs...
[    2.096230] Freeing initrd memory: 9548K
[    2.102619] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    2.110546] kvm [1]: IPA Size Limit: 48 bits
[    2.114836] kvm [1]: GICv3: no GICV resource entry
[    2.119626] kvm [1]: disabling GICv2 emulation
[    2.124081] kvm [1]: GIC system register CPU interface enabled
[    2.130021] kvm [1]: vgic interrupt IRQ9
[    2.134098] kvm [1]: VHE mode initialized successfully
[    2.139986] Initialise system trusted keyrings
[    2.144514] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    2.153048] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.159170] NFS: Registering the id_resolver key type
[    2.164236] Key type id_resolver registered
[    2.168418] Key type id_legacy registered
[    2.172458] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.179165] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.186570] ntfs: driver 2.1.32 [Flags: R/W].
[    2.202439] NET: Registered protocol family 38
[    2.206887] Key type asymmetric registered
[    2.210983] Asymmetric key parser 'x509' registered
[    2.215875] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[    2.223335] io scheduler mq-deadline registered
[    2.227868] io scheduler kyber registered
[    2.236141] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    2.241746] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    2.247333] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    2.252917] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    2.259285] efifb: probing for efifb
[    2.262890] efifb: framebuffer at 0x839e00000, using 8640k, total 8640k
[    2.269510] efifb: mode is 1920x1080x32, linelength=8192, pages=1
[    2.275603] efifb: scrolling: redraw
[    2.279175] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    2.287671] Console: switching to colour frame buffer device 240x67
[    2.296665] fb0: EFI VGA frame buffer device
[    2.302758] tegra_dc_assign_hw_data: no matching compatible node
[    2.308778] tegradccommon module_init failed
[    2.313054] tegradc module_init failed
[    2.317076] EINJ: ACPI disabled.
[    2.321951] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    2.328847] tegra-pmc: ### PMC reset source: SYS_RESET_N
[    2.334170] tegra-pmc: ### PMC reset level: L0
[    2.338620] tegra-pmc: ### PMC reset status reg: 0x0
[    2.344938] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    3.868994] printk: console [ttyTCU0] enabled
[    3.878092] arm-smmu 12000000.iommu: probing hardware configuration...
[    3.886099] arm-smmu 12000000.iommu: SMMUv2 with:
[    3.890956] arm-smmu 12000000.iommu:         stage 1 translation
[    3.896523] arm-smmu 12000000.iommu:         stage 2 translation
[    3.902079] arm-smmu 12000000.iommu:         nested translation
[    3.907552] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    3.914982] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    3.923922] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    3.930636] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    3.937368] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    3.944901] arm-smmu 10000000.iommu: probing hardware configuration...
[    3.951616] arm-smmu 10000000.iommu: SMMUv2 with:
[    3.956461] arm-smmu 10000000.iommu:         stage 1 translation
[    3.962008] arm-smmu 10000000.iommu:         stage 2 translation
[    3.967550] arm-smmu 10000000.iommu:         nested translation
[    3.973016] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    3.980437] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    3.989296] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    3.996009] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    4.002706] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    4.009852] arm-smmu 8000000.iommu: probing hardware configuration...
[    4.016477] arm-smmu 8000000.iommu: SMMUv2 with:
[    4.021226] arm-smmu 8000000.iommu:  stage 1 translation
[    4.026682] arm-smmu 8000000.iommu:  stage 2 translation
[    4.032144] arm-smmu 8000000.iommu:  nested translation
[    4.037517] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    4.044858] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    4.053584] arm-smmu 8000000.iommu:  Supported page sizes: 0x00001000
[    4.060202] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    4.066826] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    4.074115] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    4.085286] tegra_profiler: version: 1.151, samples/io: 51/30
[    4.091822] tegra_profiler: auth: init
[    4.096535] nvsciipc: loaded module
[    4.102277] tun: Universal TUN/TAP device driver, 1.6
[    4.108481] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    4.116459] hns3: Copyright (c) 2017 Huawei Corporation.
[    4.122482] e1000e: Intel(R) PRO/1000 Network Driver
[    4.128137] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    4.134795] igb: Intel(R) Gigabit Ethernet Network Driver
[    4.140884] igb: Copyright (c) 2007-2014 Intel Corporation.
[    4.147327] PPP generic driver version 2.4.2
[    4.152314] PPP BSD Compression module registered
[    4.157689] PPP Deflate Compression module registered
[    4.163436] PPP MPPE Compression module registered
[    4.168933] usbcore: registered new interface driver r8152
[    4.175111] usbcore: registered new interface driver asix
[    4.181209] usbcore: registered new interface driver ax88179_178a
[    4.188036] usbcore: registered new interface driver cdc_ether
[    4.194601] usbcore: registered new interface driver net1080
[    4.200968] usbcore: registered new interface driver cdc_subset
[    4.207592] usbcore: registered new interface driver zaurus
[    4.213867] usbcore: registered new interface driver cdc_ncm
[    4.220214] usbcore: registered new interface driver aqc111
[    4.226574] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.233467] ohci-pci: OHCI PCI platform driver
[    4.238553] ohci-platform: OHCI generic platform driver
[    4.244747] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    4.251547] usbcore: registered new interface driver uas
[    4.257538] usbcore: registered new interface driver usb-storage
[    4.264371] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    4.270992] mousedev: PS/2 mouse device common for all mice
[    4.277259] usbcore: registered new interface driver xpad
[    4.285153] tegra_rtc c2a0000.rtc: registered as rtc1
[    4.291141] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:23 UTC (23)
[    4.299899] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    4.306862] i2c /dev entries driver
[    4.311035] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    4.317371] tegra-i2c c240000.i2c: Adding to iommu group 2
[    4.323603] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    4.329810] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    4.336009] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    4.342204] tegra-i2c c250000.i2c: Adding to iommu group 2
[    4.348378] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    4.354610] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    4.363215] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[    4.372299] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[    4.381458] pps pps0: new PPS source ktimer
[    4.386265] pps pps0: ktimer PPS source registered
[    4.391697] pps_ldisc: PPS line discipline registered
[    4.398314] device-mapper: uevent: version 1.0.3
[    4.403655] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    4.414029] sdhci: Secure Digital Host Controller Interface driver
[    4.420932] sdhci: Copyright(c) Pierre Ossman
[    4.425941] Synopsys Designware Multimedia Card Interface Driver
[    4.432732] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.439290] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[    4.439619] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[    4.439871] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    4.441307] tegra-bpmp bpmp: firmware: a414c625926dbe27334a-fcc6f4f897a
[    4.443440] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    4.444201] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[    4.450426] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    4.484919] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��debugfs initialized
��[    5.871297] hid: raw HID events driver (C) Jiri Kosina
[    5.877624] usbcore: registered new interface driver usbhid
[    5.883932] usbhid: USB HID core driver
[    5.889286] tegra-dce d800000.dce: Adding to iommu group 5
[    5.897245] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]
[    5.906656] tegra234-aon c000000.aon: Adding to iommu group 6
[    5.913698] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    5.923401] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]
[    5.931048] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    5.931438]  c000000.aon:hsp: probed
[    5.940626] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...
[    5.953886] tegra234-aon c000000.aon: init done
[    5.954305] tegra23x-psc e860000.psc: Adding to iommu group 7
[    5.959145] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]
[    5.966354] tegra23x-psc e860000.psc: ext_cfg base:00000000012ffe38
[    5.973897] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    5.980910] tegra23x-psc e860000.psc: init done
[    5.981203] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[    5.990546] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...
[    5.996539] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    6.003392] dce: dce_start_boot_flow:173  DCE_BOOT_DONE
[    6.030409] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    6.040369] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x10
[    6.052513] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40
[    6.064423] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x30
[    6.076828] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 0
[    6.090142] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x180000
[    6.103694] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20
[    6.116819] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (119)
[    6.124358] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    6.134573] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=55ecd57df677fd722e795b49ccb281
[    6.149285] t19x_cache tegra-cache: probed
[    6.154616] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    6.173834] optee: probing for conduit method.
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[    6.179175] optee: revision 3.22 (e3b12903)
[    6.238525] optee: dynamic shared memory is enabled
[    6.249429] optee: initialized driver
[    6.269692] nvpmodel: initialized successfully
[    6.275183] tegra_hv: get_hvd: not initialized yet
[    6.280858] user_ivc_mempool: hypervisor not present
[    6.287511] usbcore: registered new interface driver snd-usb-audio
[    6.295340] u32 classifier
[    6.298886]     input device check on
[    6.303402]     Actions configured
[    6.307779] Initializing XFRM netlink socket
[    6.313331] NET: Registered protocol family 10
[    6.320555] Segment Routing with IPv6
[    6.325155] NET: Registered protocol family 17
[    6.330510] NET: Registered protocol family 15
[    6.335924] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to lo.
[    6.351211] Bluetooth: RFCOMM socket layer initialized
[    6.357332] Bluetooth: RFCOMM ver 1.11
[    6.361993] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    6.368880] Bluetooth: HIDP socket layer initialized
[    6.375561] 9pnet: Installing 9P2000 support
[    6.380803] Key type dns_resolver registered
[    6.387226] registered taskstats version 1
[    6.392243] Loading compiled-in X.509 certificates
[    6.409462] Loaded X.509 cert 'Build time autogenerated kernel key: 116c9301190b8359d61b88147c57efebef8c95a0'
[    6.421067] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[    6.434744] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    6.443485] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[    6.456837] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    6.464506] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[    6.477390] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    6.508346] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[    6.522534] simple-framebuffer chosen:framebuffer: framebuffer at 0x839e00000, 0x870000 bytes, mapped to 0x00001
[    6.534794] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=1920x1080x32, linelength=8192
[    6.545180] fb0: switching to simple from EFI VGA
[    6.551811] Console: switching to colour dummy device 80x25
[    6.560690] Console: switching to colour frame buffer device 240x67
[    6.569871] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[    6.577418] host1x 13e40000.host1x: Adding to iommu group 13
[    6.606464] host1x 13e40000.host1x: initialized
[    6.611514] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[    6.619641] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x00000000120000)
[    6.640503] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[    6.648574] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x00000000120000)
[    6.669428] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[    6.677496] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x00000000120000)
[    6.698345] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[    6.706424] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x00000000120000)
[    6.727249] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[    6.735327] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x00000000120000)
[    6.756182] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[    6.764318] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x00000000120000)
[    6.785146] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[    6.793211] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x00000000120000)
[    6.814051] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[    6.822149] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x00000000120000)
[    6.843006] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[    6.851136] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x00000000080000)
[    6.871954] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[    6.880012] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x00000000080000)
[    6.900835] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[    6.908928] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x00000000080000)
[    6.929726] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[    6.937797] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x00000000080000)
[    6.958634] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[    6.966750] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x00000000080000)
[    6.987573] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[    6.995648] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x00000000080000)
[    7.016451] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[    7.024528] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x00000000080000)
[    7.045372] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[    7.053449] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x00000000080000)
[    7.074324] falcon 15340000.vic: Adding to iommu group 30
[    7.085229] falcon 15340000.vic: initialized
[    7.089980] falcon 15380000.nvjpg: Adding to iommu group 31
[    7.099397] falcon 15380000.nvjpg: initialized
[    7.104120] falcon 15540000.nvjpg1: Adding to iommu group 32
[    7.112818] falcon 15540000.nvjpg1: initialized
[    7.117636] falcon 154c0000.nvenc: Adding to iommu group 33
[    7.128622] falcon 154c0000.nvenc: initialized
[    7.134039] falcon 15a50000.ofa: Adding to iommu group 34
[    7.143923] falcon 15a50000.ofa: initialized
[    7.149171] nvdec 15480000.nvdec: Adding to iommu group 35
[    7.161980] nvdec 15480000.nvdec: initialized
[    7.167278] tsec 15500000.tsec: Adding to iommu group 36
[    7.178103] tsec 15500000.tsec: initialized
[    7.185691] gic 2a41000.agic-controller: GIC IRQ controller registered
[    7.203711] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    7.221869] gpio-394 (camera-control-output-low): hogged as output/low
[    7.229323] gpio-397 (camera-control-output-low): hogged as output/low
[    7.236781] gpio-487 (camera-control-output-low): hogged as output/low
[    7.244220] gpio-486 (camera-control-output-low): hogged as output/low
[    7.252586] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    7.260879] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    7.268541] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    7.276306] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    7.284436] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    7.291726] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    7.300835] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[    7.310051] tegra194-isp5 14800000.isp: Adding to iommu group 37
[    7.319996] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    7.330289] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    7.337546] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[    7.346486] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[    7.355241] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[    7.365861] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    7.373343] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[    7.383940] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    7.391411] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    7.402007] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    7.409491] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[    7.418873] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000)
[    7.430925] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[    7.440277] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000)
[    7.452322] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[    7.461696] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000)
[    7.473736] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[    7.483121] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000)
[    7.495162] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[    7.504494] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000)
[    7.516519] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[    7.525877] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000)
[    7.537915] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[    7.547270] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000)
[    7.559309] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[    7.568646] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000)
[    7.580694] pva 16000000.pva0: Adding to iommu group 48
[    7.606137] pva 16000000.pva0: initialized
[    7.637753] nvdla 15880000.nvdla0: Adding to iommu group 49
[    7.652752] nvdla 15880000.nvdla0: initialized
[    7.668534] nvdla 158c0000.nvdla1: Adding to iommu group 50
[    7.683353] nvdla 158c0000.nvdla1: initialized
[    7.699144] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[    7.706956] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    7.715162] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    7.722454] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    7.729849] serial-tegra 3100000.serial: Adding to iommu group 2
[    7.737106] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 26, base_baud = 0) is a TEGRA_UART
[    7.747509] serial-tegra 3110000.serial: Adding to iommu group 2
[    7.754749] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 78, base_baud = 0) is a TEGRA_UART
[    7.765050] serial-tegra 3130000.serial: Adding to iommu group 2
[    7.772202] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 79, base_baud = 0) is a TEGRA_UART
[    7.799534] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[    7.809987] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.816251] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    7.825583] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    7.835893] tegra-xusb 3610000.xhci: irq 236, io mem 0x03610000
[    7.842886] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.849147] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    7.857643] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    7.865964] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    7.875187] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.883339] usb usb1: Product: xHCI Host Controller
[    7.889071] usb usb1: Manufacturer: Linux 5.10.192-tegra xhci-hcd
[    7.896052] usb usb1: SerialNumber: 3610000.xhci
[    7.902210] hub 1-0:1.0: USB hub found
[    7.906819] hub 1-0:1.0: 4 ports detected
[    7.911963] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    7.921211] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.929385] usb usb2: Product: xHCI Host Controller
[    7.935143] usb usb2: Manufacturer: Linux 5.10.192-tegra xhci-hcd
[    7.942143] usb usb2: SerialNumber: 3610000.xhci
[    7.948127] hub 2-0:1.0: USB hub found
[    7.952750] hub 2-0:1.0: 4 ports detected
[    7.976239] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[    8.002075] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2008000 KHz, changing to: 203z
[    8.015648] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2011000 KHz, changing to: 203z
[    8.028913] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2010000 KHz, changing to: 203z
[    8.041493] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[    8.050677] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    8.052151] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    8.058934] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    8.059403] mmc0: CQHCI version 5.10
[    8.072280] irq: IRQ303: trimming hierarchy from :interrupt-controller@f400000-1
[    8.075750] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    8.084148] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[    8.086518] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    8.093539] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    8.118864] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    8.170593] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[    8.182003] mmc0: Command Queue Engine enabled
[    8.187272] mmc0: periodic cache flush enabled
[    8.192530] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    8.200249] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[    8.205660] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[    8.222809]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    8.234344] tegra194-pcie 14100000.pcie: Link up
[    8.240733] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    8.248238] pci_bus 0001:00: root bus resource [bus 00-ff]
[    8.254563] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    8.265103] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47fff)
[    8.276630] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    8.285242] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    8.292256] pci 0001:00:00.0: PME# supported from D0 D3hot
[    8.303644] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    8.310663] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    8.317269] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    8.326391] pci 0001:01:00.0: supports D1 D2
[    8.331469] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    8.338356] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[    8.343581] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    8.348075] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    8.356204] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    8.364260] usb 1-3: Product: Bluetooth Radio
[    8.371335] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    8.376511] usb 1-3: Manufacturer: Realtek
[    8.376512] usb 1-3: SerialNumber: 00e04c000001
[    8.395440] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    8.402428] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    8.408471] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    8.415412] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    8.423436] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    8.432854] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    8.442479] pcieport 0001:00:00.0: Adding to iommu group 9
[    8.449049] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[    8.456135] pcieport 0001:00:00.0: AER: enabled with IRQ 64
[    8.463099] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[    8.463336] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    8.479781] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    8.487607] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    8.496949] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    8.506284] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    8.511092] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[    8.524733] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.532729] usb 2-3: Product: 4-Port USB 3.0 Hub
[    8.538128] usb 2-3: Manufacturer: Generic
[    8.555424] hub 2-3:1.0: USB hub found
[    8.562278] hub 2-3:1.0: 4 ports detected
[    8.626346] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[    8.804544] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[    8.813621] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.821626] usb 1-4: Product: 4-Port USB 2.0 Hub
[    8.827012] usb 1-4: Manufacturer: Generic
[    8.834982] hub 1-4:1.0: USB hub found
[    8.841186] hub 1-4:1.0: 4 ports detected
[    9.570347] usb 1-4.1: new low-speed USB device number 4 using tegra-xusb
[    9.615260] tegra194-pcie 14160000.pcie: Phy link never came up
[    9.622048] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    9.629499] pci_bus 0004:00: root bus resource [bus 00-ff]
[    9.635770] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    9.646518] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47fff)
[    9.657978] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    9.666524] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    9.673480] pci 0004:00:00.0: PME# supported from D0 D3hot
[    9.688002] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    9.694022] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    9.696320] usb 1-4.1: New USB device found, idVendor=03f0, idProduct=0024, bcdDevice= 1.30
[    9.703624] pcieport 0004:00:00.0: Adding to iommu group 10
[    9.712542] usb 1-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    9.712543] usb 1-4.1: Product: HP Basic USB Keyboard
[    9.712544] usb 1-4.1: Manufacturer: CHICONY
[    9.721654] input: CHICONY HP Basic USB Keyboard as /devices/platform/3610000.xhci/usb1/1-4/1-4.1/1-4.1:1.0/0000
[    9.727322] pcieport 0004:00:00.0: PME: Signaling with IRQ 66
[    9.758370] pcieport 0004:00:00.0: AER: enabled with IRQ 66
[    9.765242] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    9.771973] pci 0004:00:00.0: Removing from iommu group 10
[    9.778263] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    9.786318] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    9.790714] hid-generic 0003:03F0:0024.0001: input,hidraw0: USB HID v1.11 Keyboard [CHICONY HP Basic USB Keyboa0
[    9.807564] vdd-3v3-pcie: supplied by vdd-3v3-sys
[    9.813258] avdd-cam-2v8: supplied by vdd-3v3-sys
[    9.818848] vdd-dp: supplied by vdd-3v3-sys
[    9.823957] vdd-3v3-sd: supplied by vdd-3v3-sys
[    9.829684] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[    9.837677] tegra194-isp5 14800000.isp: initialized
[    9.846768] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[    9.853864] (NULL device *): fops function table already registered
[    9.861754] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[    9.869242] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    9.874861] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    9.886208] usb 1-4.2: new full-speed USB device number 5 using tegra-xusb
[    9.886219] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[    9.991225] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    9.999056] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[   10.008399] tegra194-pcie 141a0000.pcie:      MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[   10.017737] tegra194-pcie 141a0000.pcie:      MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[   10.019819] usb 1-4.2: New USB device found, idVendor=09da, idProduct=3519, bcdDevice= 1.00
[   10.036321] usb 1-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   10.044490] usb 1-4.2: Product: A4Tech OpticalMouse
[   10.050168] usb 1-4.2: Manufacturer: PixArt
[   10.059451] input: PixArt A4Tech OpticalMouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.2/1-4.2:1.0/0003:01
[   10.073644] hid-generic 0003:09DA:3519.0002: input,hidraw1: USB HID v1.11 Mouse [PixArt A4Tech OpticalMouse] on0
[   10.090007] input: PixArt A4Tech OpticalMouse Keyboard as /devices/platform/3610000.xhci/usb1/1-4/1-4.2/1-4.2:13
[   10.162420] input: PixArt A4Tech OpticalMouse Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.24
[   10.177613] hid-generic 0003:09DA:3519.0003: input,hiddev96,hidraw2: USB HID v1.11 Keyboard [PixArt A4Tech Opti1
[   10.949516] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[   11.136001] tegra194-pcie 141a0000.pcie: Phy link never came up
[   11.142887] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[   11.150445] pci_bus 0005:00: root bus resource [bus 00-ff]
[   11.156818] pci_bus 0005:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[   11.167657] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47fff)
[   11.179238] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[   11.187908] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[   11.194978] pci 0005:00:00.0: PME# supported from D0 D3hot
[   11.209997] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[   11.216149] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[   11.225842] pcieport 0005:00:00.0: Adding to iommu group 11
[   11.232583] pcieport 0005:00:00.0: PME: Signaling with IRQ 68
[   11.239513] pcieport 0005:00:00.0: AER: enabled with IRQ 68
[   11.246211] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[   11.253044] pci 0005:00:00.0: Removing from iommu group 11
[   11.259449] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[   11.267784] nvethernet 6810000.ethernet: Adding to iommu group 51
[   11.276113] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[   11.285023] nvethernet 6810000.ethernet: failed to read MDIO address
[   11.292306] nvethernet 6810000.ethernet: setting to default DMA bit mask
[   11.299966] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[   11.691707] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:a5:31:66
[   11.700444] nvethernet 6810000.ethernet: macsec param in DT is missing or disabled
[   11.708967] nvethernet 6810000.ethernet: Macsec not supported/Not enabled in DT
[   11.719238] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[   11.728715] irq: IRQ305: trimming hierarchy from :pmc@c360000
[   11.735431] irq: IRQ306: trimming hierarchy from :interrupt-controller@f400000-1
[   11.743840] irq: IRQ307: trimming hierarchy from :pmc@c360000
[   11.750521] input: gpio-keys as /devices/platform/gpio-keys/input/input5
[   11.758712] tegra-se-nvhost 15810000.se: Adding to iommu group 52
[   11.766022] tegra-se-nvhost 15810000.se: initialized
[   11.782575] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[   11.789637] tegra-se-nvhost 15820000.se: Adding to iommu group 53
[   11.796889] tegra-se-nvhost 15820000.se: initialized
[   11.803786] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[   11.810838] tegra-se-nvhost 15840000.se: Adding to iommu group 54
[   11.818030] tegra-se-nvhost 15840000.se: initialized
[   11.827054] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[   11.834596] tegra_actmon d230000.actmon: in actmon_register()...
[   11.841581] tegra_actmon d230000.actmon: bwmgr_disable = 1
[   11.848257] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[   11.857302] hvc_sysfs: hypervisor is not present
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
��[   11.985673] ALSA device list:
[   11.989405]   No soundcards found.
[   11.994133] Freeing unused kernel memory: 3968K
[   11.999494] Run /init as init process
[   12.015623] Root device found: mmcblk0p1
[   12.025803] Found dev node: /dev/mmcblk0p1
[   12.205416] EXT4-fs (mmcblk0p1): 3 orphan inodes deleted
[   12.211599] EXT4-fs (mmcblk0p1): recovery complete
[   12.229180] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[   12.240574] Rootfs mounted over mmcblk0p1
[   12.255923] Switching from initrd to actual rootfs
[   12.382338] systemd[1]: System time before build time, advancing clock.
[   12.441724] systemd[1]: systemd 245.4-4ubuntu3.23 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR )
[   12.466791] systemd[1]: Detected architecture arm64.
[   12.512144] systemd[1]: Set hostname to <ubuntu>.
[   12.702383] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not su.
[   12.716140] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[   12.726547] systemd[1]: Created slice system-modprobe.slice.
[   12.734212] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   12.742436] systemd[1]: Created slice User and Session Slice.
[   12.749834] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   12.759263] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   12.770461] systemd[1]: Reached target User and Group Name Lookups.
[   12.778396] systemd[1]: Reached target Slices.
[   12.784445] systemd[1]: Reached target Mounting snaps.
[   12.791224] systemd[1]: Reached target Mounted snaps.
[   12.797908] systemd[1]: Reached target Swap.
[   12.804010] systemd[1]: Listening on RPCbind Server Activation Socket.
[   12.812315] systemd[1]: Listening on Syslog Socket.
[   12.818949] systemd[1]: Listening on fsck to fsckd communication Socket.
[   12.827433] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   12.835876] systemd[1]: Listening on Journal Audit Socket.
[   12.843132] systemd[1]: Listening on Journal Socket (/dev/log).
[   12.850878] systemd[1]: Listening on Journal Socket.
[   12.857667] systemd[1]: Listening on udev Control Socket.
[   12.864893] systemd[1]: Listening on udev Kernel Socket.
[   12.873072] systemd[1]: Mounting Huge Pages File System...
[   12.881371] systemd[1]: Mounting POSIX Message Queue File System...
[   12.890388] systemd[1]: Mounting RPC Pipe File System...
[   12.898549] systemd[1]: Mounting Kernel Debug File System...
[   12.907033] systemd[1]: Mounting Kernel Trace File System...
[   12.915759] systemd[1]: Starting Journal Service...
[   12.923625] systemd[1]: Starting Set the console keyboard layout...
[   12.932782] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   12.944298] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   12.952921] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[   12.953782] systemd[1]: Starting Load Kernel Module efi_pstore...
[   12.971335] systemd[1]: Starting Load Kernel Module pstore_blk...
[   12.980164] systemd[1]: Starting Load Kernel Module pstore_zone...
[   12.989108] systemd[1]: Starting Load Kernel Module ramoops...
[   12.997886] systemd[1]: Starting NVIDIA specific first-boot udev script...
[   13.007626] systemd[1]: Started Nameserver information manager.
[   13.015462] systemd[1]: Reached target Network (Pre).
[   13.022979] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   13.033117] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   13.051132] systemd[1]: Starting Load Kernel Modules...
[   13.059022] systemd[1]: Starting Remount Root and Kernel File Systems...
[   13.067216] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[   13.067782] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   13.081452] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000000838e00000,16777216
[   13.082661] systemd[1]: Starting udev Coldplug all Devices...
[   13.091792] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[   13.107471] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000849800000,914358272
[   13.107473] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[   13.126894] nvmap_page_pool_init: Total RAM pages: 7826542
[   13.126896] nvmap_page_pool_init: nvmap page pool size: 978317 pages (3821 MB)
[   13.127096] nvmap_background_zero_thread: PP zeroing thread starting.
[   13.127192] misc nvmap: created heap vpr base 0x0000000849800000 size (892928KiB)
[   13.130179] misc nvmap: created heap fsi base 0x0000000838e00000 size (16384KiB)
[   13.168164] systemd[1]: Started Journal Service.
[   13.187789] nvgpu: 17000000.ga10b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 sync0
[   13.187789]
[   13.225560] systemd-journald[304]: Received client request to flush runtime journal.
[   13.326112] nvidia: loading out-of-tree module taints kernel.
[   13.337256] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[   13.355977] nvidia-nvlink: Nvlink Core is being initialized, major device number 502
[   13.364695] NVRM: No NVIDIA GPU found.
[   13.367140] nvidia-nvlink: Unregistered Nvlink Core, major device number 502
[   13.637025] using random self ethernet address
[   13.642709] using random host ethernet address
[   13.848475] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[   13.939549] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[   13.948313] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[   14.280044] using random self ethernet address
[   14.285232] using random host ethernet address
[   16.460460] CPU8: shutdown
[   16.595692] CPU9: shutdown
[   16.699403] CPU10: shutdown
[   16.776378] IRQ 124: no longer affine to CPU11
[   16.781552] CPU11: shutdown
[   19.557760] Bridge firewalling registered
[   19.932654] NVRM: No NVIDIA GPU found.
[   20.134000] NVRM: No NVIDIA GPU found.
Ubuntu 20.04.6 LTS ubuntu ttyTCU0
Using minicom I can log in to ubuntu on jetson nad since before boot when all goes wrong I had a message that I can boot from backup if boot fails how can I delete initrd currently used and revert to old using minicom?
I reflashed jetson and now it is booting fine
Help me now in installing nvidia drivers, cuda and all the rest that i need to install in order to have cuda available.
When i now run nvcc -V i have cuda-11.4
Please use sudo apt update && sudo apt install nvidia-jetpack to install jetpack compoments, which includes cuda tools.
I did that but nvidia driver still not installed since i dont have nvidia-smi command
It seems you could boot up the board successfully now.
Please file another topic for SDK component installed issue.
