AGX orin boot into initrd
I use board-design orin
JetPack 5.1.2
After reboot, It start into initrd
Looking at other posts, found that it is because 3 times did not wait for nv-l4t-bootloader-config to start to complete
How can I get back into the system now?
Jetson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
**  WARNING: Test Key is used.  **
      L4TLauncher: Attempting Recovery Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
??I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
??[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.120-uisee (liyanhou@uisee-System-Product-Name) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Wed Mar 27 11:07:04 CST 2024
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: Jetson AGX Orin Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x82537e518 SMBIOS=0xffff0000 SMBIOS 3.0=0x805b00000 MEMATTR=0x806887018 ESRT=0x805bdd518 RNG=0x806d8f198 MEMRESERVE=0x80688bf18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x0000000805bdd518 to 0x0000000805bdd550.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000819000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000833ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x0000000804af7fff]
[    0.000000]   node   0: [mem 0x0000000804af8000-0x0000000804e9efff]
[    0.000000]   node   0: [mem 0x0000000804e9f000-0x000000080521ffff]
[    0.000000]   node   0: [mem 0x0000000805220000-0x00000008052bffff]
[    0.000000]   node   0: [mem 0x00000008052c0000-0x0000000805aeffff]
[    0.000000]   node   0: [mem 0x0000000805af0000-0x0000000805b0ffff]
[    0.000000]   node   0: [mem 0x0000000805b10000-0x000000080676ffff]
[    0.000000]   node   0: [mem 0x0000000806770000-0x000000080680ffff]
[    0.000000]   node   0: [mem 0x0000000806810000-0x000000080683ffff]
[    0.000000]   node   0: [mem 0x0000000806840000-0x000000080686ffff]
[    0.000000]   node   0: [mem 0x0000000806870000-0x000000080689ffff]
[    0.000000]   node   0: [mem 0x00000008068a0000-0x00000008068bffff]
[    0.000000]   node   0: [mem 0x00000008068c0000-0x000000080699ffff]
[    0.000000]   node   0: [mem 0x00000008069a0000-0x00000008069bffff]
[    0.000000]   node   0: [mem 0x00000008069c0000-0x00000008069effff]
[    0.000000]   node   0: [mem 0x00000008069f0000-0x0000000806bcffff]
[    0.000000]   node   0: [mem 0x0000000806bd0000-0x0000000806c9ffff]
[    0.000000]   node   0: [mem 0x0000000806ca0000-0x0000000806d3ffff]
[    0.000000]   node   0: [mem 0x0000000806d40000-0x0000000806d7ffff]
[    0.000000]   node   0: [mem 0x0000000806d80000-0x000000080700ffff]
[    0.000000]   node   0: [mem 0x0000000807010000-0x000000080710ffff]
[    0.000000]   node   0: [mem 0x0000000807110000-0x00000008071affff]
[    0.000000]   node   0: [mem 0x00000008071b0000-0x00000008071fffff]
[    0.000000]   node   0: [mem 0x0000000807200000-0x000000080729ffff]
[    0.000000]   node   0: [mem 0x00000008072a0000-0x00000008077bffff]
[    0.000000]   node   0: [mem 0x00000008077c0000-0x000000080799ffff]
[    0.000000]   node   0: [mem 0x00000008079a0000-0x000000082900ffff]
[    0.000000]   node   0: [mem 0x0000000829010000-0x000000082905ffff]
[    0.000000]   node   0: [mem 0x0000000829060000-0x000000082d1fffff]
[    0.000000]   node   0: [mem 0x000000082d210000-0x000000082d21ffff]
[    0.000000]   node   0: [mem 0x0000000832000000-0x0000000833ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000833ffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 31 pages/cpu s89368 r8192 d29416 u126976
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 7931152
[    0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[    0.000000] Memory: 31045312K/32229440K available (18560K kernel code, 3162K rwdata, 7216K rodata, 3968K init, 1414K bss, 921984K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000677] Console: colour dummy device 80x25
[    0.000719] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000727] pid_max: default: 32768 minimum: 301
[    0.000832] LSM: Security Framework initializing
[    0.000861] Yama: becoming mindful.
[    0.000882] SELinux:  Initializing.
[    0.000993] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.001040] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.002824] rcu: Hierarchical SRCU implementation.
[    0.002929] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.003507] DTS File Name: /mnt/sda/liyanhou/JetPack-5.1.2/JetPack-5.1.2/sources/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0004-p3737-0000.dts
[    0.003513] DTB Build time: Mar 27 2024 22:57:47
[    0.004860] Tegra Revision: A01 SKU: 0xd2 CPU Process: 0 SoC Process: 0
[    0.005059] Remapping and enabling EFI services.
[    0.005556] smp: Bringing up secondary CPUs ...
[    0.034278] Detected PIPT I-cache on CPU1
[    0.034319] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.034357] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.063025] Detected PIPT I-cache on CPU2
[    0.063037] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.063052] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.091670] Detected PIPT I-cache on CPU3
[    0.091679] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.091693] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.122373] Detected PIPT I-cache on CPU4
[    0.122396] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.122421] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.151102] Detected PIPT I-cache on CPU5
[    0.151112] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.151128] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.179764] Detected PIPT I-cache on CPU6
[    0.179774] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.179788] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.208422] Detected PIPT I-cache on CPU7
[    0.208432] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.208447] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.208503] smp: Brought up 1 node, 8 CPUs
[    0.208517] SMP: Total of 8 processors activated.
[    0.208520] CPU features: detected: Privileged Access Never
[    0.208522] CPU features: detected: LSE atomic instructions
[    0.208523] CPU features: detected: User Access Override
[    0.208525] CPU features: detected: 32-bit EL0 Support
[    0.208527] CPU features: detected: Common not Private translations
[    0.208529] CPU features: detected: RAS Extension Support
[    0.208530] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.208532] CPU features: detected: CRC32 instructions
[    0.208533] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.244596] CPU: All CPU(s) started at EL2
[    0.247009] devtmpfs: initialized
[    0.263464] Registered cp15_barrier emulation handler
[    0.263472] Registered setend emulation handler
[    0.263477] KASLR enabled
[    0.263601] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.263614] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.265311] pinctrl core: initialized pinctrl subsystem
[    0.265768] SMBIOS 3.0.0 present.
[    0.265775] DMI: Unknown Jetson AGX Orin Developer Kit/Jetson AGX Orin Developer Kit, BIOS 4.1-33958178 08/01/2023
[    0.266106] NET: Registered protocol family 16
[    0.266949] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.267155] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.267350] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.267377] audit: initializing netlink subsys (disabled)
[    0.267480] audit: type=2000 audit(0.264:1): state=initialized audit_enabled=0 res=1
[    0.267672] thermal_sys: Registered thermal governor 'step_wise'
[    0.267674] thermal_sys: Registered thermal governor 'power_allocator'
[    0.267677] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.270050] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.270132] ASID allocator initialised with 32768 entries
[    0.270228] Serial: AMBA PL011 UART driver
[    0.271933] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.271957] Tegra reboot handler registered.
[    0.289701] mc: mapped MMIO address: 0xffff800011120000 -> 0x2c10000
[    0.289710] mc: mapped MMIO address: 0xffff800011140000 -> 0x2c20000
[    0.289716] mc: mapped MMIO address: 0xffff800011160000 -> 0x2c30000
[    0.289723] mc: mapped MMIO address: 0xffff800011180000 -> 0x2c40000
[    0.289729] mc: mapped MMIO address: 0xffff8000111a0000 -> 0x2c50000
[    0.289733] mc: mapped MMIO address: 0xffff8000111c0000 -> 0x2b80000
[    0.289739] mc: mapped MMIO address: 0xffff8000111e0000 -> 0x2b90000
[    0.289746] mc: mapped MMIO address: 0xffff800011200000 -> 0x2ba0000
[    0.289751] mc: mapped MMIO address: 0xffff800011220000 -> 0x2bb0000
[    0.289756] mc: mapped MMIO address: 0xffff800011240000 -> 0x1700000
[    0.289760] mc: mapped MMIO address: 0xffff800011260000 -> 0x1710000
[    0.289770] mc: mapped MMIO address: 0xffff800011280000 -> 0x1720000
[    0.289775] mc: mapped MMIO address: 0xffff8000112a0000 -> 0x1730000
[    0.289780] mc: mapped MMIO address: 0xffff8000112c0000 -> 0x1740000
[    0.289790] mc: mapped MMIO address: 0xffff8000112e0000 -> 0x1750000
[    0.289794] mc: mapped MMIO address: 0xffff800011300000 -> 0x1760000
[    0.289800] mc: mapped MMIO address: 0xffff800011320000 -> 0x1770000
[    0.289807] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.289847] mc-err: mcerr ops are set to t23x
[    0.290524] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 78, base_baud = 0) is a SBSA
[    0.294650] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.294655] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.294657] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.294658] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.296497] ACPI: Interpreter disabled.
[    0.297678] vdd-av1v1-hub: supplied by vdd-5v-sys
[    0.297780] vbusA-cvb: supplied by vdd-5v-sys
[    0.297876] vbusB-cvb: supplied by vdd-5v-sys
[    0.297989] vdd-usbc1-vbus: supplied by vdd-5v-sys
[    0.298092] vdd-usbc2-vbus: supplied by vdd-5v-sys
[    0.298441] iommu: Default domain type: Translated
[    0.298526] eventlib_kernel: keventlib is initialized, test id: 0
[    0.298718] SCSI subsystem initialized
[    0.298790] usbcore: registered new interface driver usbfs
[    0.298800] usbcore: registered new interface driver hub
[    0.298810] usbcore: registered new device driver usb
[    0.299003] mc: Linux media interface: v0.10
[    0.299013] videodev: Linux video capture interface: v2.00
[    0.299167] pps_core: LinuxPPS API ver. 1 registered
[    0.299170] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.299185] PTP clock support registered
[    0.299422] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    0.299467] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    0.299634] Registered efivars operations
[    0.299834] FPGA manager framework
[    0.299875] Advanced Linux Sound Architecture Driver Initialized.
[    0.300148] Bluetooth: Core ver 2.22
[    0.300161] NET: Registered protocol family 31
[    0.300163] Bluetooth: HCI device and connection manager initialized
[    0.300168] Bluetooth: HCI socket layer initialized
[    0.300172] Bluetooth: L2CAP socket layer initialized
[    0.300178] Bluetooth: SCO socket layer initialized
[    0.300681] camchar: rtcpu character device driver loaded
[    0.300898] clocksource: Switched to clocksource arch_sys_counter
[    0.457870] VFS: Disk quotas dquot_6.6.0
[    0.457906] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.458219] pnp: PnP ACPI: disabled
[    0.460179] la/ptsa driver initialized.
[    0.460247] NET: Registered protocol family 2
[    0.460452] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.462652] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.462689] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.462908] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.463419] TCP: Hash tables configured (established 262144 bind 65536)
[    0.463504] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.463560] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.463705] NET: Registered protocol family 1
[    0.464000] RPC: Registered named UNIX socket transport module.
[    0.464004] RPC: Registered udp transport module.
[    0.464006] RPC: Registered tcp transport module.
[    0.464007] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.464016] PCI: CLS 0 bytes, default 64
[    0.464122] Trying to unpack rootfs image as initramfs...
[    0.695335] Freeing initrd memory: 16496K
[    0.697524] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.697709] kvm [1]: IPA Size Limit: 48 bits
[    0.697729] kvm [1]: GICv3: no GICV resource entry
[    0.697734] kvm [1]: disabling GICv2 emulation
[    0.697758] kvm [1]: GIC system register CPU interface enabled
[    0.697827] kvm [1]: vgic interrupt IRQ9
[    0.697935] kvm [1]: VHE mode initialized successfully
[    0.698624] Initialise system trusted keyrings
[    0.698728] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    0.701105] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.701439] NFS: Registering the id_resolver key type
[    0.701459] Key type id_resolver registered
[    0.701461] Key type id_legacy registered
[    0.701495] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.701503] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.701516] ntfs: driver 2.1.32 [Flags: R/W].
[    0.713167] NET: Registered protocol family 38
[    0.713172] Key type asymmetric registered
[    0.713176] Asymmetric key parser 'x509' registered
[    0.713195] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[    0.713298] io scheduler bfq registered
[    0.717675] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.717701] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.717718] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    0.717735] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    0.720280] tegra_dc_assign_hw_data: no matching compatible node
[    0.720285] tegradccommon module_init failed
[    0.720288] tegradc module_init failed
[    0.720488] EINJ: ACPI disabled.
[    0.722090] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.722097] tegra-pmc: ### PMC reset source: MAINSWRST
[    0.722101] tegra-pmc: ### PMC reset level: L1
[    0.722103] tegra-pmc: ### PMC reset status reg: 0x2d
[    0.723382] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.256660] printk: console [ttyTCU0] enabled
[    2.261464] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.267320] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.271870] arm-smmu 12000000.iommu: 	stage 1 translation
[    2.277203] arm-smmu 12000000.iommu: 	stage 2 translation
[    2.282719] arm-smmu 12000000.iommu: 	nested translation
[    2.288057] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    2.295055] arm-smmu 12000000.iommu: 	128 context banks (0 stage-2 only)
[    2.303899] arm-smmu 12000000.iommu: 	Supported page sizes: 0x00001000
[    2.308182] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    2.314745] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    2.321923] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.327607] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.332331] arm-smmu 10000000.iommu: 	stage 1 translation
[    2.337844] arm-smmu 10000000.iommu: 	stage 2 translation
[    2.343267] arm-smmu 10000000.iommu: 	nested translation
[    2.348693] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    2.355868] arm-smmu 10000000.iommu: 	128 context banks (0 stage-2 only)
[    2.364760] arm-smmu 10000000.iommu: 	Supported page sizes: 0x00001000
[    2.369082] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    2.375643] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    2.382626] arm-smmu 8000000.iommu: probing hardware configuration...
[    2.388768] arm-smmu 8000000.iommu: SMMUv2 with:
[    2.393492] arm-smmu 8000000.iommu: 	stage 1 translation
[    2.399003] arm-smmu 8000000.iommu: 	stage 2 translation
[    2.404431] arm-smmu 8000000.iommu: 	nested translation
[    2.409592] arm-smmu 8000000.iommu: 	stream matching with 128 register groups
[    2.416768] arm-smmu 8000000.iommu: 	128 context banks (0 stage-2 only)
[    2.425708] arm-smmu 8000000.iommu: 	Supported page sizes: 0x00001000
[    2.429981] arm-smmu 8000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    2.436542] arm-smmu 8000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    2.443798] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    2.452795] tegra_profiler: version: 1.151, samples/io: 51/30
[    2.456749] tegra_profiler: auth: init
[    2.460807] nvsciipc: loaded module
[    2.465816] tun: Universal TUN/TAP device driver, 1.6
[    2.469737] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.476448] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.481986] e1000e: Intel(R) PRO/1000 Network Driver
[    2.486767] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.492648] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.498055] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.503905] PPP generic driver version 2.4.2
[    2.508248] PPP BSD Compression module registered
[    2.512848] PPP Deflate Compression module registered
[    2.518102] PPP MPPE Compression module registered
[    2.523103] usbcore: registered new interface driver r8152
[    2.528433] usbcore: registered new interface driver asix
[    2.533767] usbcore: registered new interface driver ax88179_178a
[    2.539887] usbcore: registered new interface driver cdc_ether
[    2.545844] usbcore: registered new interface driver net1080
[    2.551439] usbcore: registered new interface driver cdc_subset
[    2.557476] usbcore: registered new interface driver zaurus
[    2.563169] usbcore: registered new interface driver cdc_ncm
[    2.568850] usbcore: registered new interface driver qmi_wwan
[    2.574278] usbcore: registered new interface driver aqc111
[    2.580161] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.586180] ohci-pci: OHCI PCI platform driver
[    2.590475] ohci-platform: OHCI generic platform driver
[    2.596035] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    2.601778] usbcore: registered new interface driver cdc_wdm
[    2.607057] usbcore: registered new interface driver uas
[    2.612350] usbcore: registered new interface driver usb-storage
[    2.618323] usbcore: registered new interface driver option
[    2.623975] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.631087] mousedev: PS/2 mouse device common for all mice
[    2.636589] usbcore: registered new interface driver xpad
[    2.643936] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.647434] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:22 UTC (22)
[    2.655216] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.661645] i2c /dev entries driver
[    2.665238] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    2.670786] tegra-i2c c240000.i2c: Adding to iommu group 1
[    2.676083] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    2.681415] tegra-i2c 3190000.i2c: Adding to iommu group 1
[    2.686947] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[    2.692276] tegra-i2c c250000.i2c: Adding to iommu group 1
[    2.697689] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[    2.703081] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    2.710971] pps pps0: new PPS source ktimer
[    2.712605] pps pps0: ktimer PPS source registered
[    2.717427] pps_ldisc: PPS line discipline registered
[    2.722659] pps-gpio pps: failed to get GPIO from device tree
[    2.729014] device-mapper: uevent: version 1.0.3
[    2.732812] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    2.741939] sdhci: Secure Digital Host Controller Interface driver
[    2.747700] sdhci: Copyright(c) Pierre Ossman
[    2.752160] Synopsys Designware Multimedia Card Interface Driver
[    2.758274] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.764174] sdhci-tegra 3460000.sdhci: Adding to iommu group 2
[    2.764499] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[    2.764709] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    2.765515] tegra-bpmp bpmp: firmware: 6969245516d6bf7e0f23-925eece486b
[    2.766566] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    2.766872] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[    2.770219] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    2.804764] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
??debugfs initialized
??[    4.015636] hid: raw HID events driver (C) Jiri Kosina
[    4.016042] usbcore: registered new interface driver usbhid
[    4.016220] usbhid: USB HID core driver
[    4.016856] tegra-dce d800000.dce: Adding to iommu group 4
[    4.017395] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]
[    4.017809] tegra234-aon c000000.aon: Adding to iommu group 5
[    4.018578] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    4.018858] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [0]. Ignored...
[    4.019116] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]
[    4.019438] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    4.019710] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...
[    4.019712] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    4.019928] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]
[    4.020336]  c000000.aon:hsp: probed
[    4.020379] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    4.020920] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    4.027654] tegra234-aon c000000.aon: init done
[    4.036225] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...
[    4.036227] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    4.041476] tegra23x-psc e860000.psc: Adding to iommu group 6
[    4.049430] dce: dce_start_boot_flow:173  DCE_BOOT_DONE
[    4.057991] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[    4.074721] tegra23x-psc e860000.psc: init done
[    4.079717] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[    4.086523] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    4.097509] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    4.102776] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    4.113715] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    4.124421] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    4.135807] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    4.147557] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x1800????0-0??I/??x20??TC:??080?? Re??
??se??[  ??rve??  4??d s??.16??har??007??ed ??7] ??mem??teg??or??ra-??y i??ivc??s d??-bu??isa??s b??ble??c00??d
??x64????.rt????cpu??I/T??:iv??C:??c-b?? Dy??us:??nam??dia??ic ??g@5??sha??: d??red??iag?? m??: v??emo??er=??ry ??0 g??is ??rp=??ena??1 R??ble??X[1??d
       ??]=0????x20??I/??080??TC:??-0x?? No??201??rma??40 ??l W??TX[??orl??1x6??d ??4]=??vir??0x2??tua??014??liz??0-0??ati??x20??on ??200??su??
??ppo??[  ??rt ??  4??is??.17?? di??145??sab??7] ??led??teg??
??ra1????86-??I/??cam??TC:??-rt?? As??cpu??ync?? bc??hro??000??no??00.??us ??rtc??not??pu:??ifi?? us??cat??ing??ion?? ca??s ??m R??are??TCP?? di??U I??sab??RQ ??led??(11??
??7)
[    4.178155] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    4.186486] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    4.186490] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[    4.188317] t19x_cache tegra-cache: probed
[    4.192665] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[    4.215116] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    4.222611] optee: probing for conduit method.
[    4.225421] optee: revision 3.21 (d8269f24)
[    4.285344] optee: dynamic shared memory is enabled
[    4.285710] optee: initialized driver
[    4.298613] nvpmodel: initialized successfully
[    4.298830] tegra_hv: get_hvd: not initialized yet
[    4.298963] user_ivc_mempool: hypervisor not present
[    4.299371] usbcore: registered new interface driver snd-usb-audio
[    4.300434] u32 classifier
[    4.302663]     input device check on
[    4.306333]     Actions configured
[    4.309881] Initializing XFRM netlink socket
[    4.314432] NET: Registered protocol family 10
[    4.319411] Segment Routing with IPv6
[    4.322128] NET: Registered protocol family 17
[    4.326566] NET: Registered protocol family 15
[    4.330972] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.344026] Bluetooth: RFCOMM socket layer initialized
[    4.349227] Bluetooth: RFCOMM ver 1.11
[    4.353152] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.359009] Bluetooth: HIDP socket layer initialized
[    4.364222] 9pnet: Installing 9P2000 support
[    4.368431] Key type dns_resolver registered
[    4.373008] registered taskstats version 1
[    4.376872] Loading compiled-in X.509 certificates
[    4.389866] Loaded X.509 cert 'Build time autogenerated kernel key: ee9e76102bf33d6d33a59f1e20800692ab0cde0c'
[    4.392508] tegra194-pcie 14180000.pcie: Adding to iommu group 8
[    4.404734] tegra194-pcie 14180000.pcie: Using GICv2m MSI allocator
[    4.406438] tegra194-pcie 141e0000.pcie: Adding to iommu group 9
[    4.415992] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    4.442498] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 10
[    4.446418] host1x 13e40000.host1x: Adding to iommu group 11
[    4.465356] host1x 13e40000.host1x: initialized
[    4.465924] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 12
[    4.466433] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[    4.468086] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 13
[    4.468544] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[    4.470437] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 14
[    4.476972] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[    4.488519] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 15
[    4.494940] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    4.506300] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 16
[    4.512840] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    4.524302] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 17
[    4.530793] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    4.542342] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 18
[    4.548824] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    4.560362] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 19
[    4.566862] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    4.578413] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 20
[    4.584901] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[    4.596433] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 21
[    4.602921] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[    4.614436] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 22
[    4.620962] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[    4.632446] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 23
[    4.638990] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[    4.650494] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 24
[    4.656983] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[    4.668508] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 25
[    4.675025] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[    4.686520] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 26
[    4.693052] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[    4.704570] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 27
[    4.711066] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[    4.722622] falcon 15340000.vic: Adding to iommu group 28
[    4.731581] falcon 15340000.vic: initialized
[    4.732039] falcon 15380000.nvjpg: Adding to iommu group 29
[    4.739306] falcon 15380000.nvjpg: initialized
[    4.741536] falcon 15540000.nvjpg1: Adding to iommu group 30
[    4.749585] falcon 15540000.nvjpg1: initialized
[    4.751942] falcon 154c0000.nvenc: Adding to iommu group 31
[    4.761546] falcon 154c0000.nvenc: initialized
[    4.762175] falcon 15a50000.ofa: Adding to iommu group 32
[    4.770906] falcon 15a50000.ofa: initialized
[    4.772063] nvdec 15480000.nvdec: Adding to iommu group 33
[    4.783042] nvdec 15480000.nvdec: initialized
[    4.783286] tsec 15500000.tsec: Adding to iommu group 34
[    4.791551] tsec 15500000.tsec: initialized
[    4.793933] gic 2a41000.agic-controller: GIC IRQ controller registered
[    4.807877] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    4.816340] gpio-390 (camera-control-output-low): hogged as output/high
[    4.816553] gpio-397 (camera-control-output-low): hogged as output/high
[    4.818826] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    4.824797] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    4.831237] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    4.837595] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    4.843078] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    4.848543] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    4.855618] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[    4.862182] tegra194-isp5 14800000.isp: Adding to iommu group 35
[    4.871246] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    4.877007] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    4.883050] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    4.891971] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    4.901132] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 36
[    4.908592] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 37
[    4.915782] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[    4.924568] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    4.930914] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[    4.940370] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    4.946899] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    4.956293] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    4.962686] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 38
[    4.971065] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[    4.981936] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 39
[    4.990470] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[    5.001175] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 40
[    5.009513] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[    5.020424] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 41
[    5.028810] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[    5.039507] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 42
[    5.048029] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[    5.058748] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 43
[    5.067258] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[    5.077990] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 44
[    5.086536] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[    5.097243] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 45
[    5.105784] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[    5.116501] pva 16000000.pva0: Adding to iommu group 46
[    5.140254] pva 16000000.pva0: initialized
[    5.145506] nvdla 15880000.nvdla0: Adding to iommu group 47
[    5.153629] nvdla 15880000.nvdla0: initialized
[    5.155571] nvdla 158c0000.nvdla1: Adding to iommu group 48
[    5.162543] nvdla 158c0000.nvdla1: initialized
[    5.164458] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 1
[    5.165453] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    5.165895] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    5.166062] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    5.172273] serial-tegra 3100000.serial: Adding to iommu group 1
[    5.178649] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 26, base_baud = 0) is a TEGRA_UART
[    5.187539] serial-tegra 3110000.serial: Adding to iommu group 1
[    5.193300] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 75, base_baud = 0) is a TEGRA_UART
[    5.202083] serial-tegra 3130000.serial: Adding to iommu group 1
[    5.208077] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 76, base_baud = 0) is a TEGRA_UART
[    5.216840] serial-tegra 3140000.serial: Adding to iommu group 1
[    5.222946] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 77, base_baud = 0) is a TEGRA_UART
[    5.232295]  usb2: Requested PHY is disabled
[    5.250820] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[    5.251073] tegra-xusb 3610000.xhci: xHCI Host Controller
[    5.251239] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    5.259185] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    5.267813] tegra-xusb 3610000.xhci: irq 233, io mem 0x03610000
[    5.274060] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    5.282043] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.289215] usb usb1: Product: xHCI Host Controller
[    5.294204] usb usb1: Manufacturer: Linux 5.10.120-uisee xhci-hcd
[    5.300326] usb usb1: SerialNumber: 3610000.xhci
[    5.305254] hub 1-0:1.0: USB hub found
[    5.308838] hub 1-0:1.0: 4 ports detected
[    5.313117] tegra-xusb 3610000.xhci: xHCI Host Controller
[    5.318277] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    5.325886] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    5.333294] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    5.341470] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.348715] usb usb2: Product: xHCI Host Controller
[    5.353702] usb usb2: Manufacturer: Linux 5.10.120-uisee xhci-hcd
[    5.359913] usb usb2: SerialNumber: 3610000.xhci
[    5.364740] hub 2-0:1.0: USB hub found
[    5.368344] hub 2-0:1.0: 4 ports detected
[    5.380360] ov490_power_get, unimplement function...
[    5.380572] ov490 2-004d: tegracam sensor driver:ov490_v2.0.6
[    5.382850] ov490_power_on, unimplement function...
[    5.387739] ov490_power_off, unimplement function...
[    5.392794] tegra-camrtc-capture-vi tegra-capture-vi: subdev ov490 2-004d bound
[    5.400627] v4l2 channel.c:1255 tegra_channel_s_ctrl : update_ts_vi is 0
[    5.407334] ov490_power_get, unimplement function...
[    5.411768] ov490 2-0040: tegracam sensor driver:ov490_v2.0.6
[    5.417404] ov490_power_on, unimplement function...
[    5.422304] ov490_power_off, unimplement function...
[    5.427129] tegra-camrtc-capture-vi tegra-capture-vi: subdev ov490 2-0040 bound
[    5.434800] v4l2 channel.c:1255 tegra_channel_s_ctrl : update_ts_vi is 0
[    5.450565] irq: IRQ300: trimming hierarchy from :pmc@c360000
[    5.450795] pps pps1: new PPS source pps.-1
[    5.450951] pps pps1: Registered IRQ 300 as PPS source
[    5.456328] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[    5.479680] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[    5.482051] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1962000 KHz, changing to: 2035200 KHz
[    5.487666] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[    5.495919] tegra194-pcie 14180000.pcie: Using GICv2m MSI allocator
[    5.496648] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    5.499845] tegra194-pcie 14180000.pcie: host bridge /pcie@14180000 ranges:
[    5.502624] mmc0: CQHCI version 5.10
[    5.512917] irq: IRQ301: trimming hierarchy from :interrupt-controller@f400000-1
[    5.514796] tegra194-pcie 14180000.pcie:       IO 0x0038100000..0x00381fffff -> 0x0038100000
[    5.522437] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 301
[    5.530411] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    5.530981] tegra194-pcie 14180000.pcie:      MEM 0x2728000000..0x272fffffff -> 0x0040000000
[    5.553293] tegra194-pcie 14180000.pcie:      MEM 0x2440000000..0x2727ffffff -> 0x2440000000
[    5.616216] mmc0: Command Queue Engine enabled
[    5.616329] mmc0: periodic cache flush enabled
[    5.616443] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    5.616794] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[    5.616986] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[    5.619909]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[    6.668937] tegra194-pcie 14180000.pcie: Phy link never came up
[    6.669024] random: crng init done
[    6.669178] tegra194-pcie 14180000.pcie: PCI host bridge to bus 0000:00
[    6.669415] pci_bus 0000:00: root bus resource [bus 00-ff]
[    6.669570] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[    6.669846] pci_bus 0000:00: root bus resource [mem 0x2728000000-0x272fffffff] (bus address [0x40000000-0x47ffffff])
[    6.670154] pci_bus 0000:00: root bus resource [mem 0x2440000000-0x2727ffffff pref]
[    6.670426] pci 0000:00:00.0: [10de:229c] type 01 class 0x060400
[    6.670758] pci 0000:00:00.0: PME# supported from D0 D3hot
[    6.678115] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    6.678275] pci 0000:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    6.678739] pcieport 0000:00:00.0: Adding to iommu group 8
[    6.679070] pcieport 0000:00:00.0: PME: Signaling with IRQ 64
[    6.679302] pcieport 0000:00:00.0: AER: enabled with IRQ 64
[    6.679657] pci_bus 0000:01: busn_res: [bus 01-ff] is released
[    6.679884] pci 0000:00:00.0: Removing from iommu group 8
[    6.680506] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[    6.687985] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    6.693572] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[    6.699586] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    6.708248] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    6.716903] tegra194-pcie 141e0000.pcie:      MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[    7.427681] tegra-xusb 3610000.xhci: entering ELPG done
[    7.832932] tegra194-pcie 141e0000.pcie: Phy link never came up
[    7.833154] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    7.833335] pci_bus 0007:00: root bus resource [bus 00-ff]
[    7.833498] pci_bus 0007:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x3e100000-0x3e1fffff])
[    7.833788] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[    7.834096] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[    7.834358] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    7.834667] pci 0007:00:00.0: PME# supported from D0 D3hot
[    7.841437] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    7.841577] pci 0007:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    7.842015] pcieport 0007:00:00.0: Adding to iommu group 9
[    7.842332] pcieport 0007:00:00.0: PME: Signaling with IRQ 66
[    7.842557] pcieport 0007:00:00.0: AER: enabled with IRQ 66
[    7.842888] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[    7.843107] pci 0007:00:00.0: Removing from iommu group 9
[    7.843245] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[    7.848176] vdd-dp: supplied by vdd-3v3-sys
[    7.851606] vdd-3v3-sd: supplied by vdd-3v3-sys
[    7.856251] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[    7.862427] tegra194-isp5 14800000.isp: initialized
[    7.868238] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[    7.872576] (NULL device *): fops function table already registered
[    7.879604] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[    7.885458] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    7.885656] nvethernet 2310000.ethernet: Adding to iommu group 49
[    7.896162] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[    7.900925] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 301
[    7.904010] nvethernet 2310000.ethernet: failed to read MDIO address
[    7.916600] nvethernet 2310000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
[    7.927099] nvethernet 2310000.ethernet: setting to default DMA bit mask
[    7.933857] nvethernet 2310000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[    7.942674] nvethernet 2310000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[    7.959961] nvethernet 2310000.ethernet: Ethernet MAC index missing
[    7.960152] nvethernet 2310000.ethernet: Ethernet MAC address: 48:b0:2d:ac:16:68
[    7.965386] nvethernet 2310000.ethernet: macsec param in DT is missing or disabled
[    7.972513] nvethernet 2310000.ethernet: Macsec not supported/Not enabled in DT
[    7.981052] nvethernet 2310000.ethernet: eth0 (HW ver: 53) created with 8 DMA channels
[    7.988214] irq: IRQ303: trimming hierarchy from :pmc@c360000
[    7.993400] irq: IRQ304: trimming hierarchy from :interrupt-controller@f400000-1
[    8.000952] irq: IRQ305: trimming hierarchy from :pmc@c360000
[    8.006687] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    8.013934] tegra-se-nvhost 15810000.se: Adding to iommu group 50
[    8.020077] tegra-se-nvhost 15810000.se: initialized
[    8.035150] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    8.035402] tegra-se-nvhost 15820000.se: A??WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
??dding to iommu group 51
[    8.037448] tegra-se-nvhost 15820000.se: initialized
[    8.043027] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    8.048585] tegra-se-nvhost 15840000.se: Adding to iommu group 52
[    8.054838] tegra-se-nvhost 15840000.se: initialized
[    8.060606] teg??WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
??ra-se-nvhost 15840000.se: tegra_se_probe: complete
[    8.066417] tegra_actmon d230000.actmon: in actmon_register()...
[    8.071907] tegra_actmon d230000.actmon: bwmgr_disable = 1
[    8.077627] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    8.085481] hvc_sysfs: hypervi??WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
??sor is not present
[    8.218001] ALSA device list:
[    8.218100]   No soundcards found.
[    8.218833] Freeing unused kernel memory: 3968K
[    8.219015] Run /init as init process
[    8.230531] Root device found: initrd
modprobe: FATAL: Module r8168 not found in directory /lib/modules/5.10.120-uisee
[    8.232537] Mount initrd as rootfs and enter recovery mode
Finding OTA work dir on external storage devices
Checking whether device /dev/mmcblk?p1 exist
Looking for OTA work directory on the device(s): /dev/mmcblk0p1
Checking whether device /dev/sd?1 exist
Device /dev/sd?1 does not exist
Checking whether device /dev/nvme?n1p1 exist
Device /dev/nvme?n1p1 does not exist
Finding OTA work dir on internal storage device
mount /dev/mmcblk0p1 /mnt
[    8.269661] EXT4-fs (mmcblk0p1): recovery complete
[    8.269806] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
is_boot_only_partition /mnt
OTA work directory /mnt/ota_work is not found on /dev/mmcblk0p1
OTA work directory is not found on internal and external storage devices
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.0# [    8.953918] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[    9.504896] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[    9.505197] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[    9.505478] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[    9.505763] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[   39.900920] vdd-12v-sys: disabling
[   39.901028] vdd-1v8-sys: disabling
[   39.901135] vdd-3v3-ftdi: disabling
[   39.901244] vdd-12v-pcie: disabling
Press ESC to enter UEFI Menu, then choose Device Manager → NVIDIA Configuration → L4T Configuration → OS chain A status → (The value is Unbootable if UEFI attemps recovery kernel) choose Normal → Save and exit, reboot, UEFI will try Direct Boot.
