Jetson UEFI firmware (version 3.1-32827747 built on 2023-03-19T14:56:32+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Recovery Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
��[ 0.000000] Booting Linux on physical CPU 0x0000010200 [0x410fd421]
[ 0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6289-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Sun Mar 19 07:55:28 PDT 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin NX Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x25f4fae98 SMBIOS=0xffff0000 SMBIOS 3.0=0x2412f0000 MEMATTR=0x2408a3018 ESRT=0x240ec4598 RNG=0x264536c18 MEMRESERVE=0x240e8ef18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000240ec4598 to 0x0000000240ec45d0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000254400000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000026fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000023bffffff]
[ 0.000000] node 0: [mem 0x000000023c000000-0x000000023e1bffff]
[ 0.000000] node 0: [mem 0x000000023e1c0000-0x00000002407cffff]
[ 0.000000] node 0: [mem 0x00000002407d0000-0x000000024089ffff]
[ 0.000000] node 0: [mem 0x00000002408a0000-0x0000000240d27fff]
[ 0.000000] node 0: [mem 0x0000000240d28000-0x0000000240e88fff]
[ 0.000000] node 0: [mem 0x0000000240e89000-0x0000000240e9ffff]
[ 0.000000] node 0: [mem 0x0000000240ea0000-0x0000000240ebffff]
[ 0.000000] node 0: [mem 0x0000000240ec0000-0x00000002412dffff]
[ 0.000000] node 0: [mem 0x00000002412e0000-0x00000002412fffff]
[ 0.000000] node 0: [mem 0x0000000241300000-0x000000024160ffff]
[ 0.000000] node 0: [mem 0x0000000241610000-0x000000024165ffff]
[ 0.000000] node 0: [mem 0x0000000241660000-0x000000024181ffff]
[ 0.000000] node 0: [mem 0x0000000241820000-0x00000002419fffff]
[ 0.000000] node 0: [mem 0x0000000241a00000-0x0000000241a8ffff]
[ 0.000000] node 0: [mem 0x0000000241a90000-0x0000000241c6ffff]
[ 0.000000] node 0: [mem 0x0000000241c70000-0x0000000241ccffff]
[ 0.000000] node 0: [mem 0x0000000241cd0000-0x0000000241dbffff]
[ 0.000000] node 0: [mem 0x0000000241dc0000-0x0000000241deffff]
[ 0.000000] node 0: [mem 0x0000000241df0000-0x0000000241dfffff]
[ 0.000000] node 0: [mem 0x0000000241e00000-0x0000000241eaffff]
[ 0.000000] node 0: [mem 0x0000000241eb0000-0x0000000241f4ffff]
[ 0.000000] node 0: [mem 0x0000000241f50000-0x000000024204ffff]
[ 0.000000] node 0: [mem 0x0000000242050000-0x00000002420effff]
[ 0.000000] node 0: [mem 0x00000002420f0000-0x00000002421effff]
[ 0.000000] node 0: [mem 0x00000002421f0000-0x000000024228ffff]
[ 0.000000] node 0: [mem 0x0000000242290000-0x0000000242b5ffff]
[ 0.000000] node 0: [mem 0x0000000242b60000-0x0000000242d3ffff]
[ 0.000000] node 0: [mem 0x0000000242d40000-0x00000002644effff]
[ 0.000000] node 0: [mem 0x00000002644f0000-0x000000026453ffff]
[ 0.000000] node 0: [mem 0x0000000264540000-0x0000000267ffffff]
[ 0.000000] node 0: [mem 0x0000000268200000-0x000000026860ffff]
[ 0.000000] node 0: [mem 0x000000026e000000-0x000000026fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000026fffffff]
[ 0.000000] On node 0, zone Normal: 496 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1976336
[ 0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 7234020K/8032320K available (18496K kernel code, 3168K rwdata, 7172K rodata, 3968K init, 1418K bss, 536156K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 10200 region 0:0x000000000f500000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000646] Console: colour dummy device 80x25
[ 0.000689] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000697] pid_max: default: 32768 minimum: 301
[ 0.000757] LSM: Security Framework initializing
[ 0.000776] Yama: becoming mindful.
[ 0.000794] SELinux: Initializing.
[ 0.000856] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000869] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001570] /cpus/cpu-map: empty cluster
[ 0.001874] rcu: Hierarchical SRCU implementation.
[ 0.001961] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.002399] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0001-p3768-0000-a0.dts
[ 0.002404] DTB Build time: Mar 19 2023 08:08:38
[ 0.003612] Tegra Revision: A01 SKU: 0xd4 CPU Process: 0 SoC Process: 0
[ 0.003772] Remapping and enabling EFI services.
[ 0.004993] smp: Bringing up secondary CPUs ...
[ 0.033695] Detected PIPT I-cache on CPU1
[ 0.033733] GICv3: CPU1: found redistributor 10300 region 0:0x000000000f520000
[ 0.033768] CPU1: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.064474] Detected PIPT I-cache on CPU2
[ 0.064496] GICv3: CPU2: found redistributor 20000 region 0:0x000000000f540000
[ 0.064524] CPU2: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.093187] Detected PIPT I-cache on CPU3
[ 0.093197] GICv3: CPU3: found redistributor 20100 region 0:0x000000000f560000
[ 0.093211] CPU3: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.122446] Detected PIPT I-cache on CPU4
[ 0.122456] GICv3: CPU4: found redistributor 20200 region 0:0x000000000f580000
[ 0.122470] CPU4: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.151707] Detected PIPT I-cache on CPU5
[ 0.151717] GICv3: CPU5: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.151731] CPU5: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.151786] smp: Brought up 1 node, 6 CPUs
[ 0.151797] SMP: Total of 6 processors activated.
[ 0.151801] CPU features: detected: Privileged Access Never
[ 0.151802] CPU features: detected: LSE atomic instructions
[ 0.151804] CPU features: detected: User Access Override
[ 0.151805] CPU features: detected: 32-bit EL0 Support
[ 0.151808] CPU features: detected: Common not Private translations
[ 0.151809] CPU features: detected: RAS Extension Support
[ 0.151810] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.151812] CPU features: detected: CRC32 instructions
[ 0.151814] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.185398] CPU: All CPU(s) started at EL2
[ 0.187094] devtmpfs: initialized
[ 0.201610] Registered cp15_barrier emulation handler
[ 0.201621] Registered setend emulation handler
[ 0.201626] KASLR enabled
[ 0.201748] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.201759] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.203351] pinctrl core: initialized pinctrl subsystem
[ 0.203873] SMBIOS 3.0.0 present.
[ 0.203882] DMI: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 3.1-32827747 03/19/2023
[ 0.204154] NET: Registered protocol family 16
[ 0.204927] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.204990] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.205045] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.205074] audit: initializing netlink subsys (disabled)
[ 0.205160] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
[ 0.205332] thermal_sys: Registered thermal governor 'step_wise'
[ 0.205334] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.205337] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.206155] cpuidle: using governor menu
[ 0.206251] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.206329] ASID allocator initialised with 32768 entries
[ 0.206423] Serial: AMBA PL011 UART driver
[ 0.208110] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.208134] Tegra reboot handler registered.
[ 0.225656] mc: mapped MMIO address: 0xffff8000107b0000 -> 0x2c10000
[ 0.225667] mc: mapped MMIO address: 0xffff8000107d0000 -> 0x2c20000
[ 0.225675] mc: mapped MMIO address: 0xffff8000107f0000 -> 0x2c30000
[ 0.225683] mc: mapped MMIO address: 0xffff800010810000 -> 0x2c40000
[ 0.225689] mc: mapped MMIO address: 0xffff800010830000 -> 0x2c50000
[ 0.225694] mc: mapped MMIO address: 0xffff800010850000 -> 0x2b80000
[ 0.225701] mc: mapped MMIO address: 0xffff800010870000 -> 0x2b90000
[ 0.225706] mc: mapped MMIO address: 0xffff800010890000 -> 0x2ba0000
[ 0.225711] mc: mapped MMIO address: 0xffff8000108b0000 -> 0x2bb0000
[ 0.225716] mc: mapped MMIO address: 0xffff8000108d0000 -> 0x1700000
[ 0.225722] mc: mapped MMIO address: 0xffff8000108f0000 -> 0x1710000
[ 0.225727] mc: mapped MMIO address: 0xffff800010910000 -> 0x1720000
[ 0.225733] mc: mapped MMIO address: 0xffff800010930000 -> 0x1730000
[ 0.225738] mc: mapped MMIO address: 0xffff800010950000 -> 0x1740000
[ 0.225745] mc: mapped MMIO address: 0xffff800010970000 -> 0x1750000
[ 0.225750] mc: mapped MMIO address: 0xffff800010990000 -> 0x1760000
[ 0.225756] mc: mapped MMIO address: 0xffff8000109b0000 -> 0x1770000
[ 0.225764] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.225791] mc-err: mcerr ops are set to t23x
[ 0.226455] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[ 0.230209] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.230214] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.230217] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.230220] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.232079] ACPI: Interpreter disabled.
[ 0.232452] ddr-vddq: supplied by vdd-5v
[ 0.232619] ddr-vdd2: supplied by vdd-5v
[ 0.232713] vdd-AO-1v2: supplied by vdd-5v
[ 0.232812] vdd-3v3: supplied by vdd-5v
[ 0.233073] vdd-rtc: supplied by vdd-AO-1v2
[ 0.233173] vdd-0v95-uphy: supplied by vdd-AO-1v2
[ 0.233270] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[ 0.233486] vdd-1v8: supplied by vdd-3v3-sys
[ 0.233565] vdd-3v3-AO: supplied by vdd-5v-sys
[ 0.233653] vdd-av10-hub: supplied by vdd-5v-sys
[ 0.233743] vdd-vbus-a: supplied by vdd-5v-sys
[ 0.233826] vdd-vbus-b: supplied by vdd-5v-sys
[ 0.233924] vdd-3v3-dp: supplied by vdd-3v3-sys
[ 0.234148] iommu: Default domain type: Translated
[ 0.234182] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.234353] SCSI subsystem initialized
[ 0.234432] usbcore: registered new interface driver usbfs
[ 0.234445] usbcore: registered new interface driver hub
[ 0.234457] usbcore: registered new device driver usb
[ 0.234632] mc: Linux media interface: v0.10
[ 0.234640] videodev: Linux video capture interface: v2.00
[ 0.234778] pps_core: LinuxPPS API ver. 1 registered
[ 0.234780] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.234786] PTP clock support registered
[ 0.235022] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.235043] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 0.236334] Registered efivars operations
[ 0.236480] FPGA manager framework
[ 0.236519] Advanced Linux Sound Architecture Driver Initialized.
[ 0.236780] Bluetooth: Core ver 2.22
[ 0.236793] NET: Registered protocol family 31
[ 0.236795] Bluetooth: HCI device and connection manager initialized
[ 0.236801] Bluetooth: HCI socket layer initialized
[ 0.236805] Bluetooth: L2CAP socket layer initialized
[ 0.236812] Bluetooth: SCO socket layer initialized
[ 0.237489] camchar: rtcpu character device driver loaded
[ 0.237730] clocksource: Switched to clocksource arch_sys_counter
[ 0.391100] VFS: Disk quotas dquot_6.6.0
[ 0.391136] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.391267] pnp: PnP ACPI: disabled
[ 0.393128] la/ptsa driver initialized.
[ 0.393181] NET: Registered protocol family 2
[ 0.393305] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.394551] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.394568] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.394625] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.395131] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.395191] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.395211] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.395286] NET: Registered protocol family 1
[ 0.395475] RPC: Registered named UNIX socket transport module.
[ 0.395478] RPC: Registered udp transport module.
[ 0.395479] RPC: Registered tcp transport module.
[ 0.395481] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.395488] PCI: CLS 0 bytes, default 64
[ 0.395593] Trying to unpack rootfs image as initramfs...
[ 0.568340] Freeing initrd memory: 12692K
[ 0.569895] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.570024] kvm [1]: IPA Size Limit: 48 bits
[ 0.570043] kvm [1]: GICv3: no GICV resource entry
[ 0.570048] kvm [1]: disabling GICv2 emulation
[ 0.570065] kvm [1]: GIC system register CPU interface enabled
[ 0.570121] kvm [1]: vgic interrupt IRQ9
[ 0.570218] kvm [1]: VHE mode initialized successfully
[ 0.570772] Initialise system trusted keyrings
[ 0.570882] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.573042] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.573329] NFS: Registering the id_resolver key type
[ 0.573344] Key type id_resolver registered
[ 0.573347] Key type id_legacy registered
[ 0.573380] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.573387] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.573398] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.585339] NET: Registered protocol family 38
[ 0.585345] Key type asymmetric registered
[ 0.585349] Asymmetric key parser 'x509' registered
[ 0.585365] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.585409] io scheduler mq-deadline registered
[ 0.585412] io scheduler kyber registered
[ 0.588905] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.588927] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.588943] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 0.591194] tegra_dc_assign_hw_data: no matching compatible node
[ 0.591198] tegradccommon module_init failed
[ 0.591201] tegradc module_init failed
[ 0.591451] EINJ: ACPI disabled.
[ 0.592826] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.592833] tegra-pmc: ### PMC reset source: MAINSWRST
[ 0.592835] tegra-pmc: ### PMC reset level: L1
[ 0.592837] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.594044] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.600237] random: fast init done
[ 0.600433] printk: console [ttyTCU0] enabled
[ 2.160573] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.166394] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.170930] arm-smmu 12000000.iommu: stage 1 translation
[ 2.176267] arm-smmu 12000000.iommu: stage 2 translation
[ 2.181776] arm-smmu 12000000.iommu: nested translation
[ 2.186940] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.194116] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 2.202818] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.207241] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.213625] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.220990] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.226667] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.231390] arm-smmu 10000000.iommu: stage 1 translation
[ 2.236900] arm-smmu 10000000.iommu: stage 2 translation
[ 2.242326] arm-smmu 10000000.iommu: nested translation
[ 2.247754] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.254928] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 2.263714] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.268139] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.274701] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.281691] arm-smmu 8000000.iommu: probing hardware configuration...
[ 2.287827] arm-smmu 8000000.iommu: SMMUv2 with:
[ 2.292550] arm-smmu 8000000.iommu: stage 1 translation
[ 2.298063] arm-smmu 8000000.iommu: stage 2 translation
[ 2.303487] arm-smmu 8000000.iommu: nested translation
[ 2.308651] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 2.315828] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 2.324541] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 2.329040] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.335600] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.342810] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.351222] tegra_profiler: version: 1.151, samples/io: 51/30
[ 2.355811] tegra_profiler: auth: init
[ 2.359865] nvsciipc: loaded module
[ 2.364786] tun: Universal TUN/TAP device driver, 1.6
[ 2.368752] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.375507] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.381044] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.385827] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.391708] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.397115] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.402948] PPP generic driver version 2.4.2
[ 2.407316] PPP BSD Compression module registered
[ 2.411907] PPP Deflate Compression module registered
[ 2.417171] PPP MPPE Compression module registered
[ 2.422159] usbcore: registered new interface driver r8152
[ 2.427488] usbcore: registered new interface driver asix
[ 2.432825] usbcore: registered new interface driver ax88179_178a
[ 2.438949] usbcore: registered new interface driver cdc_ether
[ 2.444895] usbcore: registered new interface driver net1080
[ 2.450498] usbcore: registered new interface driver cdc_subset
[ 2.456532] usbcore: registered new interface driver zaurus
[ 2.462225] usbcore: registered new interface driver cdc_ncm
[ 2.467908] usbcore: registered new interface driver aqc111
[ 2.473433] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.479636] ohci-pci: OHCI PCI platform driver
[ 2.483930] ohci-platform: OHCI generic platform driver
[ 2.489278] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 2.495252] usbcore: registered new interface driver uas
[ 2.500212] usbcore: registered new interface driver usb-storage
[ 2.506196] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 2.511905] mousedev: PS/2 mouse device common for all mice
[ 2.517362] usbcore: registered new interface driver xpad
[ 2.524612] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.528119] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:22 UTC (22)
[ 2.535919] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.542142] i2c /dev entries driver
[ 2.545701] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 2.551263] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 2.556680] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 2.562097] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 2.567435] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 2.572946] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 2.578385] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 2.583712] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 2.592829] device-mapper: uevent: version 1.0.3
[ 2.593741] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.603125] sdhci: Secure Digital Host Controller Interface driver
[ 2.608349] sdhci: Copyright(c) Pierre Ossman
[ 2.612627] Synopsys Designware Multimedia Card Interface Driver
[ 2.618741] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.624757] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[ 2.624906] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 2.637729] tegra-bpmp bpmp: firmware: 463f4d5b75234b74bb7f-1377b684fe5
[ 2.645846] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 2.649779] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 2.662994] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 2.663175] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��Failed to create /rm/vdd_cpu
debugfs initialized
��[ 4.516006] hid: raw HID events driver (C) Jiri Kosina
[ 4.516662] usbcore: registered new interface driver usbhid
[ 4.516819] usbhid: USB HID core driver
[ 4.517352] tegra-dce d800000.dce: Adding to iommu group 4
[ 4.518710] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 4.519360] tegra234-aon c000000.aon: Adding to iommu group 5
[ 4.520385] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 4.520623] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 4.520627] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 4.521085] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 4.521382] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 4.521617] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 4.521619] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 4.521840] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 4.522062] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 4.524640] c000000.aon:hsp: probed
[ 4.536611] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 4.541956] tegra234-aon c000000.aon: init done
[ 4.545435] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 4.545436] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 4.545446] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 4.550533] tegra23x-psc e860000.psc: Adding to iommu group 6
[ 4.558537] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 4.567138] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 4.592508] tegra23x-psc e860000.psc: init done
[ 4.597496] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[ 4.604364] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.615040] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.620390] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.631534] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.642354] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.653456] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.665262] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 4.677773] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.689674] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (113)
[ 4.695856] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.704205] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=97e50cbff52bc4b542b2989187109c001c01cf77
[ 4.716882] t19x_cache tegra-cache: probed
[ 4.719223] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 4.730164] optee: probing for conduit method.
[ 4.730303] optee: revision 3.19 (3f29c61f)
[ 4.731057] optee: dynamic shared memory is enabled
[ 4.738745] optee: initialized driver
[ 4.753456] nvpmodel: initialized successfully
[ 4.753669] tegra_hv: get_hvd: not initialized yet
[ 4.753815] user_ivc_mempool: hypervisor not present
[ 4.757316] usbcore: registered new interface driver snd-usb-audio
[ 4.763462] u32 classifier
[ 4.765581] input device check on
[ 4.769255] Actions configured
[ 4.772635] Initializing XFRM netlink socket
[ 4.777400] NET: Registered protocol family 10
[ 4.782794] Segment Routing with IPv6
[ 4.784967] NET: Registered protocol family 17
[ 4.789320] NET: Registered protocol family 15
[ 4.793744] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.807516] Bluetooth: RFCOMM socket layer initialized
[ 4.811976] Bluetooth: RFCOMM ver 1.11
[ 4.815910] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.821760] Bluetooth: HIDP socket layer initialized
[ 4.827292] 9pnet: Installing 9P2000 support
[ 4.831198] Key type dns_resolver registered
[ 4.835874] registered taskstats version 1
[ 4.839622] Loading compiled-in X.509 certificates
[ 4.854429] Loaded X.509 cert 'Build time autogenerated kernel key: e63fb224cdc2a940ac382bb67b420fcb52cc4aee'
[ 4.855089] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[ 4.867142] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 4.868168] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[ 4.879085] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 4.879774] tegra194-pcie 141e0000.pcie: Adding to iommu group 10
[ 4.890896] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 4.891437] tegra194-pcie 140a0000.pcie: Adding to iommu group 11
[ 4.903188] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 4.929524] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 4.933108] host1x 13e40000.host1x: Adding to iommu group 13
[ 4.958554] host1x 13e40000.host1x: initialized
[ 4.959126] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 4.959579] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 4.961181] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 4.961568] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 4.963160] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 4.964487] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 4.976120] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 4.982512] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 4.993897] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 5.000369] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 5.011932] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 5.018397] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 5.029941] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 5.036432] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 5.047984] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 5.054425] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 5.066013] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 5.072501] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 5.084004] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 5.090493] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 5.102063] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 5.108514] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 5.120085] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 5.126559] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 5.138090] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 5.144578] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 5.156113] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 5.162585] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 5.174141] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 5.180603] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 5.192173] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 5.198630] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 5.210250] falcon 15340000.vic: Adding to iommu group 30
[ 5.219513] falcon 15340000.vic: initialized
[ 5.219957] falcon 15380000.nvjpg: Adding to iommu group 31
[ 5.228179] falcon 15380000.nvjpg: initialized
[ 5.229102] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 5.237789] falcon 15540000.nvjpg1: initialized
[ 5.239523] falcon 154c0000.nvenc: Adding to iommu group 33
[ 5.249234] falcon 154c0000.nvenc: initialized
[ 5.249776] falcon 15a50000.ofa: Adding to iommu group 34
[ 5.257903] falcon 15a50000.ofa: initialized
[ 5.259658] nvdec 15480000.nvdec: Adding to iommu group 35
[ 5.271614] nvdec 15480000.nvdec: initialized
[ 5.271873] tsec 15500000.tsec: Adding to iommu group 36
[ 5.280100] tsec 15500000.tsec: initialized
[ 5.283187] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 5.295806] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 5.304237] gpio-397 (camera-control-output-low): hogged as output/low
[ 5.304448] gpio-486 (camera-control-output-low): hogged as output/low
[ 5.306072] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 5.311864] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 5.318319] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 5.324622] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 5.330210] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 5.337291] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 5.343781] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 5.350424] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 5.356304] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 5.365228] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 5.374570] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 5.382318] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 5.389402] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 5.398559] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 5.404515] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 5.414371] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 5.420522] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 5.430291] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 5.436283] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 5.444646] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 5.455530] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 5.464029] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 5.474785] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 5.483144] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 5.494025] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 5.502341] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 5.513095] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[ 5.521601] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 5.532360] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[ 5.540844] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 5.551585] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[ 5.560095] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 5.570860] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[ 5.579335] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 5.590111] pva 16000000.pva0: Adding to iommu group 48
[ 5.600816] pva 16000000.pva0: initialized
[ 5.609367] nvdla 15880000.nvdla0: Adding to iommu group 49
[ 5.614986] nvdla 15880000.nvdla0: initialized
[ 5.616975] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 5.618151] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 5.623011] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 5.629038] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 5.635812] serial-tegra 3100000.serial: Adding to iommu group 2
[ 5.642122] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[ 5.651260] serial-tegra 3130000.serial: Adding to iommu group 2
[ 5.656774] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[ 5.666082] serial-tegra 3140000.serial: Adding to iommu group 2
[ 5.671616] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 5.698380] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 5.698639] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.698813] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 5.703478] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 5.712118] tegra-xusb 3610000.xhci: irq 229, io mem 0x03610000
[ 5.718340] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.726333] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.733507] usb usb1: Product: xHCI Host Controller
[ 5.738494] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 5.744793] usb usb1: SerialNumber: 3610000.xhci
[ 5.750109] hub 1-0:1.0: USB hub found
[ 5.753306] hub 1-0:1.0: 4 ports detected
[ 5.757541] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.762743] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 5.770351] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 5.777811] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.785922] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.793184] usb usb2: Product: xHCI Host Controller
[ 5.798169] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 5.804384] usb usb2: SerialNumber: 3610000.xhci
[ 5.809602] hub 2-0:1.0: USB hub found
[ 5.812796] hub 2-0:1.0: 4 ports detected
[ 5.836165] i2c i2c-2: Added multiplexed i2c bus 9
[ 5.836585] i2c i2c-2: Added multiplexed i2c bus 10
[ 5.836716] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 5.837144] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 5.854279] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1996000 KHz, changing to: 1971200 KHz
[ 5.857064] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1996000 KHz, changing to: 1971200 KHz
[ 5.864175] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 5.870119] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 5.876412] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 5.877246] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 5.886906] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 5.895320] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 5.903961] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 5.921579] irq: IRQ293: trimming hierarchy from :interrupt-controller@f400000-1
[ 5.921816] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 293
[ 6.037887] usb 1-3: new high-speed USB device number 2 using tegra-xusb
[ 6.189559] usb 1-3: New USB device found, idVendor=1a40, idProduct=0201, bcdDevice= 1.00
[ 6.189812] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 6.190026] usb 1-3: Product: USB 2.0 Hub [MTT]
[ 6.191710] hub 1-3:1.0: USB hub found
[ 6.192148] hub 1-3:1.0: 7 ports detected
[ 7.013916] tegra194-pcie 14100000.pcie: Phy link never came up
[ 7.014186] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 7.014385] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 7.014556] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 7.014837] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 7.015137] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 7.015412] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 7.015735] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 7.023120] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 7.023278] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.023752] pcieport 0001:00:00.0: Adding to iommu group 8
[ 7.024090] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[ 7.024707] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[ 7.025100] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 7.025336] pci 0001:00:00.0: Removing from iommu group 8
[ 7.025476] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 7.029679] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 7.035405] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 7.041168] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 7.049832] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 7.058479] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 7.173885] tegra194-pcie 14160000.pcie: Link up
[ 7.175108] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 7.175297] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 7.175441] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 7.175699] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 7.175973] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 7.176218] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 7.176525] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 7.180538] pci 0004:01:00.0: [1f40:1f40] type 00 class 0x010802
[ 7.180876] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 7.186031] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 7.186221] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 7.186510] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 7.186645] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 7.186839] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.187706] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 7.196368] pcieport 0004:00:00.0: Adding to iommu group 9
[ 7.201845] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[ 7.207896] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[ 7.213503] nvme 0004:01:00.0: Adding to iommu group 9
[ 7.218873] nvme nvme0: pci function 0004:01:00.0
[ 7.223409] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 7.223871] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 7.236280] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 7.242087] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
[ 7.248031] nvme nvme0: allocated 64 MiB host memory buffer.
[ 7.250567] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
[ 7.250570] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[ 7.287265] nvme nvme0: 6/0/0 default/read/poll queues
[ 7.293543] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 8.073542] tegra-xusb 3610000.xhci: entering ELPG done
[ 8.345915] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 8.346160] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 8.346359] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 8.346521] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[ 8.346805] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.347100] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[ 8.347375] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 8.347689] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 8.354823] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 8.354978] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.355456] pcieport 0007:00:00.0: Adding to iommu group 10
[ 8.355792] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[ 8.356451] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[ 8.356841] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 8.357086] pci 0007:00:00.0: Removing from iommu group 10
[ 8.357234] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 8.361975] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 8.367088] vdd-3v3-sd: supplied by vdd-3v3
[ 8.373166] tegra194-isp5 14800000.isp: initialized
[ 8.379989] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 8.382173] (NULL device *): fops function table already registered
[ 8.389763] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 8.395321] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 8.395333] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.401023] irq: IRQ301: trimming hierarchy from :interrupt-controller@f400000-1
[ 8.425945] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 293
[ 8.518214] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[ 8.518430] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff -> 0x002a100000
[ 8.518670] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff -> 0x0040000000
[ 8.518906] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[ 8.625731] tegra194-pcie 140a0000.pcie: Link up
[ 8.627116] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 8.627300] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 8.627452] pci_bus 0008:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[ 8.627724] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.628017] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 8.628260] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.628574] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 8.632679] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 8.632976] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 8.633307] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 8.633588] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 8.634785] pci 0008:01:00.0: supports D1 D2
[ 8.634895] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.639156] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 8.639343] pci 0008:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 8.640800] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 8.648594] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 8.656464] pci 0008:01:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
[ 8.662965] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 8.668191] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 8.674578] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 8.681938] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 8.690475] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 8.699135] pcieport 0008:00:00.0: Adding to iommu group 11
[ 8.704797] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[ 8.710866] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[ 8.717435] irq: IRQ303: trimming hierarchy from :pmc@c360000
[ 8.721811] irq: IRQ304: trimming hierarchy from :interrupt-controller@f400000-1
[ 8.729173] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 8.736708] tegra-se-nvhost 15810000.se: Adding to iommu group 50
[ 8.742457] tegra-se-nvhost 15810000.se: initialized
[ 8.756219] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 8.756487] tegra-se-nvhost 15820000.se: Adding to iommu group 51
[ 8.759638] tegra-se-nvhost 15820000.se: initialized
[ 8.763313] random: crng init done
[ 8.766847] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 8.773832] tegra-se-nvhost 15840000.se: Adding to iommu group 52
[ 8.780291] tegra-se-nvhost 15840000.se: initialized
[ 8.788275] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 8.791684] tegra_actmon d230000.actmon: in actmon_register()...
[ 8.797146] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 8.802940] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 8.810512] hvc_sysfs: hypervisor is not present
[ 8.850912] ALSA device list:
[ 8.850994] No soundcards found.
[ 8.851781] Freeing unused kernel memory: 3968K
[ 8.851935] Run /init as init process
[ 8.864494] Root device found: initrd
[ 8.864958] Mount initrd as rootfs and enter recovery mode
Finding OTA work dir on external storage devices
Checking whether device /dev/mmcblk?p1 exist
Device /dev/mmcblk?p1 does not exist
Checking whether device /dev/sd?1 exist
Device /dev/sd?1 does not exist
Checking whether device /dev/nvme?n1p1 exist
Looking for OTA work directory on the device(s): /dev/nvme0n1p1
[ 8.884294] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
OTA work directory /mnt/ota_work is not found on /dev/nvme0n1p1
Finding OTA work dir on internal storage device
mount: /mnt: special device /dev/mmcblk0p1 does not exist.
Failed to mount /dev/mmcblk0p1 to /mnt
OTA work directory is not found on internal and external storage devices
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.0# [ 9.474030] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
Here is the log. It’s jp5.1.1
I just reboot the machine.
