I’m on Ubuntu 20.04 and ran SDK Manager to flash Jetpack 5.1.4 but am unable to flash my Orin NX 16GB on the devkit.
06:06:51 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
06:06:52 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
06:06:54 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
06:06:55 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
06:06:56 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
06:06:57 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up...
06:07:09 INFO: Flash Jetson Linux - flash: Waiting for device to expose ssh ...RTNETLINK answers: File exists
06:07:09 INFO: Flash Jetson Linux - flash: RTNETLINK answers: File exists
06:07:09 INFO: Flash Jetson Linux - flash: Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
06:07:18 INFO: Flash Jetson Linux - flash: SSH is not ready
06:07:18 INFO: Flash Jetson Linux - flash: Cleaning up...
It keeps claiming SSH is not ready but I am able to ping fc00:1:1:0::2
PING fc00:1:1:0::2(fc00:1:1::2) 56 data bytes
64 bytes from fc00:1:1::2: icmp_seq=1 ttl=64 time=0.346 ms
64 bytes from fc00:1:1::2: icmp_seq=2 ttl=64 time=0.341 ms
64 bytes from fc00:1:1::2: icmp_seq=3 ttl=64 time=0.371 ms
and ifconfig
has an entry for usb0
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::2 prefixlen 128 scopeid 0x20<link>
inet6 fc00:1:1::1 prefixlen 64 scopeid 0x0<global>
inet6 fe80::1cbe:deff:fe8f:8141 prefixlen 64 scopeid 0x20<link>
ether 1e:be:de:8f:81:41 txqueuelen 1000 (Ethernet)
RX packets 26 bytes 1884 (1.8 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 31 bytes 4945 (4.9 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Any idea what I should try next to get my Orin NX flashed?
serial console:
Jetson UEFI firmware (version 6.0-37391689 built on 2024-08-28T08:47:11+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
......EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.216-tegra (buildbrain@mobile-u64-6429-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Wed Aug 28 01:46:00 PDT 2024
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin NX Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: SMBIOS=0xffff0000 SMBIOS 3.0=0x43bb60000 MEMATTR=0x4363c0018 RNG=0x4293d0018 MEMRESERVE=0x42a934f18
[ 0.000000] random: crng init done
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000045e800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000473ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000042caf4fff]
[ 0.000000] node 0: [mem 0x000000042caf5000-0x000000042cd1bfff]
[ 0.000000] node 0: [mem 0x000000042cd1c000-0x000000043a1fffff]
[ 0.000000] node 0: [mem 0x000000043a200000-0x000000043c13ffff]
[ 0.000000] node 0: [mem 0x000000043c140000-0x000000046eb0ffff]
[ 0.000000] node 0: [mem 0x000000046eb10000-0x000000046eb1ffff]
[ 0.000000] node 0: [mem 0x0000000472000000-0x0000000473ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000473ffffff]
[ 0.000000] On node 0, zone Normal: 224 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90392 r8192 d32488 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4066848
[ 0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 kernel.hung_task_panic=0
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 15587444K/16526464K available (18560K kernel code, 3170K rwdata, 7240K rodata, 3968K init, 1415K bss, 676876K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000684] Console: colour dummy device 80x25
[ 0.000724] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000733] pid_max: default: 32768 minimum: 301
[ 0.000784] LSM: Security Framework initializing
[ 0.000804] Yama: becoming mindful.
[ 0.000821] SELinux: Initializing.
[ 0.000882] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000907] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.001938] rcu: Hierarchical SRCU implementation.
[ 0.002013] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.002429] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0000-p3768-0000-a0.dts
[ 0.002434] DTB Build time: Aug 28 2024 01:58:07
[ 0.003699] Tegra Revision: A01 SKU: 0xd3 CPU Process: 0 SoC Process: 0
[ 0.003904] Remapping and enabling EFI services.
[ 0.004750] smp: Bringing up secondary CPUs ...
[ 0.033445] Detected PIPT I-cache on CPU1
[ 0.033480] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.033505] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.062135] Detected PIPT I-cache on CPU2
[ 0.062146] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.062160] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.090762] Detected PIPT I-cache on CPU3
[ 0.090770] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.090785] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.121440] Detected PIPT I-cache on CPU4
[ 0.121459] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.121485] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.150144] Detected PIPT I-cache on CPU5
[ 0.150154] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.150168] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.178790] Detected PIPT I-cache on CPU6
[ 0.178799] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.178814] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.207437] Detected PIPT I-cache on CPU7
[ 0.207447] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.207462] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.207518] smp: Brought up 1 node, 8 CPUs
[ 0.207531] SMP: Total of 8 processors activated.
[ 0.207535] CPU features: detected: Privileged Access Never
[ 0.207536] CPU features: detected: LSE atomic instructions
[ 0.207538] CPU features: detected: User Access Override
[ 0.207539] CPU features: detected: 32-bit EL0 Support
[ 0.207542] CPU features: detected: Common not Private translations
[ 0.207543] CPU features: detected: RAS Extension Support
[ 0.207545] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.207547] CPU features: detected: CRC32 instructions
[ 0.207548] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.241120] CPU: All CPU(s) started at EL2
[ 0.243012] devtmpfs: initialized
[ 0.257652] KASLR enabled
[ 0.257765] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.257775] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.259475] pinctrl core: initialized pinctrl subsystem
[ 0.259944] SMBIOS 3.0.0 present.
[ 0.259951] DMI: NVIDIA NVIDIA Orin NX Developer Kit/Jetson, BIOS 6.0-37391689 08/28/2024
[ 0.260227] NET: Registered protocol family 16
[ 0.260837] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.260944] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.261046] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.261073] audit: initializing netlink subsys (disabled)
[ 0.261153] audit: type=2000 audit(0.260:1): state=initialized audit_enabled=0 res=1
[ 0.261328] thermal_sys: Registered thermal governor 'step_wise'
[ 0.261329] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.261332] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.262130] cpuidle: using governor menu
[ 0.262217] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.262302] ASID allocator initialised with 32768 entries
[ 0.262379] Serial: AMBA PL011 UART driver
[ 0.264129] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.264151] Tegra reboot handler registered.
[ 0.282071] mc: mapped MMIO address: 0xffff800010b10000 -> 0x2c10000
[ 0.282082] mc: mapped MMIO address: 0xffff800010b30000 -> 0x2c20000
[ 0.282087] mc: mapped MMIO address: 0xffff800010b50000 -> 0x2c30000
[ 0.282093] mc: mapped MMIO address: 0xffff800010b70000 -> 0x2c40000
[ 0.282098] mc: mapped MMIO address: 0xffff800010b90000 -> 0x2c50000
[ 0.282103] mc: mapped MMIO address: 0xffff800010bb0000 -> 0x2b80000
[ 0.282108] mc: mapped MMIO address: 0xffff800010bd0000 -> 0x2b90000
[ 0.282114] mc: mapped MMIO address: 0xffff800010bf0000 -> 0x2ba0000
[ 0.282122] mc: mapped MMIO address: 0xffff800010c10000 -> 0x2bb0000
[ 0.282128] mc: mapped MMIO address: 0xffff800010c30000 -> 0x1700000
[ 0.282133] mc: mapped MMIO address: 0xffff800010c50000 -> 0x1710000
[ 0.282138] mc: mapped MMIO address: 0xffff800010c70000 -> 0x1720000
[ 0.282143] mc: mapped MMIO address: 0xffff800010c90000 -> 0x1730000
[ 0.282151] mc: mapped MMIO address: 0xffff800010cb0000 -> 0x1740000
[ 0.282156] mc: mapped MMIO address: 0xffff800010cd0000 -> 0x1750000
[ 0.282161] mc: mapped MMIO address: 0xffff800010cf0000 -> 0x1760000
[ 0.282165] mc: mapped MMIO address: 0xffff800010d10000 -> 0x1770000
[ 0.282173] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.282205] mc-err: mcerr ops are set to t23x
[ 0.282872] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[ 0.286768] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.286772] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.286774] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.286775] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.288495] ACPI: Interpreter disabled.
[ 0.288896] ddr-vddq: supplied by vdd-5v
[ 0.289059] ddr-vdd2: supplied by vdd-5v
[ 0.289158] vdd-AO-1v2: supplied by vdd-5v
[ 0.289256] vdd-3v3: supplied by vdd-5v
[ 0.289358] vdd-rtc: supplied by vdd-AO-1v2
[ 0.289457] vdd-0v95-uphy: supplied by vdd-AO-1v2
[ 0.289542] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[ 0.289759] vdd-1v8: supplied by vdd-3v3-sys
[ 0.289841] vdd-3v3-AO: supplied by vdd-5v-sys
[ 0.289921] vdd-av10-hub: supplied by vdd-5v-sys
[ 0.290022] vdd-vbus-a: supplied by vdd-5v-sys
[ 0.290099] vdd-vbus-b: supplied by vdd-5v-sys
[ 0.290182] vdd-3v3-dp: supplied by vdd-3v3-sys
[ 0.290470] iommu: Default domain type: Translated
[ 0.290517] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.290679] SCSI subsystem initialized
[ 0.290751] usbcore: registered new interface driver usbfs
[ 0.290764] usbcore: registered new interface driver hub
[ 0.290775] usbcore: registered new device driver usb
[ 0.290962] mc: Linux media interface: v0.10
[ 0.290971] videodev: Linux video capture interface: v2.00
[ 0.291118] pps_core: LinuxPPS API ver. 1 registered
[ 0.291121] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.291127] PTP clock support registered
[ 0.291358] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.291398] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 0.292749] Registered efivars operations
[ 0.292943] FPGA manager framework
[ 0.292997] Advanced Linux Sound Architecture Driver Initialized.
[ 0.293281] Bluetooth: Core ver 2.22
[ 0.293295] NET: Registered protocol family 31
[ 0.293297] Bluetooth: HCI device and connection manager initialized
[ 0.293302] Bluetooth: HCI socket layer initialized
[ 0.293305] Bluetooth: L2CAP socket layer initialized
[ 0.293313] Bluetooth: SCO socket layer initialized
[ 0.294055] camchar: rtcpu character device driver loaded
[ 0.294290] clocksource: Switched to clocksource arch_sys_counter
[ 0.444351] VFS: Disk quotas dquot_6.6.0
[ 0.444397] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.444687] pnp: PnP ACPI: disabled
[ 0.446450] la/ptsa driver initialized.
[ 0.446509] NET: Registered protocol family 2
[ 0.446714] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.448942] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.448969] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.449086] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.449583] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.449653] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.449683] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.449789] NET: Registered protocol family 1
[ 0.450023] RPC: Registered named UNIX socket transport module.
[ 0.450027] RPC: Registered udp transport module.
[ 0.450028] RPC: Registered tcp transport module.
[ 0.450030] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.450039] PCI: CLS 0 bytes, default 64
[ 0.450150] Trying to unpack rootfs image as initramfs...
[ 0.675725] Freeing initrd memory: 21776K
[ 0.677840] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.678006] kvm [1]: IPA Size Limit: 48 bits
[ 0.678030] kvm [1]: GICv3: no GICV resource entry
[ 0.678034] kvm [1]: disabling GICv2 emulation
[ 0.678057] kvm [1]: GIC system register CPU interface enabled
[ 0.678126] kvm [1]: vgic interrupt IRQ9
[ 0.678237] kvm [1]: VHE mode initialized successfully
[ 0.678953] Initialise system trusted keyrings
[ 0.679054] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 0.681242] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.681500] NFS: Registering the id_resolver key type
[ 0.681512] Key type id_resolver registered
[ 0.681513] Key type id_legacy registered
[ 0.681543] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.681551] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.681563] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.693446] NET: Registered protocol family 38
[ 0.693452] Key type asymmetric registered
[ 0.693456] Asymmetric key parser 'x509' registered
[ 0.693477] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 0.693531] io scheduler mq-deadline registered
[ 0.693534] io scheduler kyber registered
[ 0.697205] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.697232] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.697249] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 0.697264] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[ 0.699812] tegra_dc_assign_hw_data: no matching compatible node
[ 0.699816] tegradccommon module_init failed
[ 0.699819] tegradc module_init failed
[ 0.700073] EINJ: ACPI disabled.
[ 0.701632] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.701639] tegra-pmc: ### PMC reset source: MAINSWRST
[ 0.701644] tegra-pmc: ### PMC reset level: L1
[ 0.701646] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.702852] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.109727] printk: console [ttyTCU0] enabled
[ 2.114552] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.120395] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.124944] arm-smmu 12000000.iommu: stage 1 translation
[ 2.130290] arm-smmu 12000000.iommu: stage 2 translation
[ 2.135793] arm-smmu 12000000.iommu: nested translation
[ 2.141137] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.148133] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 2.156849] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.161270] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.167818] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.175092] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.180681] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.185404] arm-smmu 10000000.iommu: stage 1 translation
[ 2.190918] arm-smmu 10000000.iommu: stage 2 translation
[ 2.196340] arm-smmu 10000000.iommu: nested translation
[ 2.201767] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.208942] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 2.217648] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.222155] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.228718] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.235725] arm-smmu 8000000.iommu: probing hardware configuration...
[ 2.241844] arm-smmu 8000000.iommu: SMMUv2 with:
[ 2.246566] arm-smmu 8000000.iommu: stage 1 translation
[ 2.252079] arm-smmu 8000000.iommu: stage 2 translation
[ 2.257503] arm-smmu 8000000.iommu: nested translation
[ 2.262667] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 2.269842] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 2.278603] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 2.283055] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.289616] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.296913] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.305523] tegra_profiler: version: 1.151, samples/io: 51/30
[ 2.309814] tegra_profiler: auth: init
[ 2.313889] nvsciipc: loaded module
[ 2.318299] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[ 2.323314] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure has invalid entries
[ 2.330572] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure: Child has not proper setting
[ 2.338792] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[ 2.346231] tegra23x-qspi 3270000.spi: Prod settings list not found
[ 2.353061] tun: Universal TUN/TAP device driver, 1.6
[ 2.358076] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.364871] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.370405] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.375366] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.381243] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.386566] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.392314] PPP generic driver version 2.4.2
[ 2.396505] PPP BSD Compression module registered
[ 2.401186] PPP Deflate Compression module registered
[ 2.406362] PPP MPPE Compression module registered
[ 2.411354] usbcore: registered new interface driver r8152
[ 2.416676] usbcore: registered new interface driver asix
[ 2.422193] usbcore: registered new interface driver ax88179_178a
[ 2.428314] usbcore: registered new interface driver cdc_ether
[ 2.434262] usbcore: registered new interface driver net1080
[ 2.439862] usbcore: registered new interface driver cdc_subset
[ 2.445901] usbcore: registered new interface driver zaurus
[ 2.451593] usbcore: registered new interface driver cdc_ncm
[ 2.457276] usbcore: registered new interface driver aqc111
[ 2.462805] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.469002] ohci-pci: OHCI PCI platform driver
[ 2.473299] ohci-platform: OHCI generic platform driver
[ 2.478664] tegra-xusb 3610000.xhci: Adding to iommu group 1
[ 2.484623] usbcore: registered new interface driver uas
[ 2.489579] usbcore: registered new interface driver usb-storage
[ 2.495575] tegra-xudc 3550000.xudc: Adding to iommu group 2
[ 2.501298] mousedev: PS/2 mouse device common for all mice
[ 2.506744] usbcore: registered new interface driver xpad
[ 2.514089] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.517506] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:48 UTC (48)
[ 2.525297] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.531538] i2c /dev entries driver
[ 2.535096] tegra-i2c 3160000.i2c: Adding to iommu group 3
[ 2.540651] tegra-i2c c240000.i2c: Adding to iommu group 3
[ 2.546052] tegra-i2c 3180000.i2c: Adding to iommu group 3
[ 2.551464] tegra-i2c 3190000.i2c: Adding to iommu group 3
[ 2.556802] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[ 2.562318] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[ 2.567752] tegra-i2c c250000.i2c: Adding to iommu group 3
[ 2.573072] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[ 2.581022] pps pps0: new PPS source ktimer
[ 2.582664] pps pps0: ktimer PPS source registered
[ 2.587470] pps_ldisc: PPS line discipline registered
[ 2.593464] device-mapper: uevent: version 1.0.3
[ 2.597267] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.606712] sdhci: Secure Digital Host Controller Interface driver
[ 2.611969] sdhci: Copyright(c) Pierre Ossman
[ 2.616429] Synopsys Designware Multimedia Card Interface Driver
[ 2.622546] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.628656] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 2.636016] tegra-bpmp bpmp: firmware: dc3fd3cac60f9b918e11-da583751bbf
[ 2.643987] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 2.647560] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 2.659183] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 2.659364] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��debugfs initialized
��[ 4.417891] hid: raw HID events driver (C) Jiri Kosina
[ 4.418519] usbcore: registered new interface driver usbhid
[ 4.418671] usbhid: USB HID core driver
[ 4.419169] tegra-dce d800000.dce: Adding to iommu group 4
[ 4.420478] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 4.421273] tegra234-aon c000000.aon: Adding to iommu group 5
[ 4.422371] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 4.422611] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 4.422616] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 4.423070] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 4.423373] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 4.423613] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 4.423614] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 4.423628] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 4.423817] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 4.423921] c000000.aon:hsp: probed
[ 4.438487] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 4.438898] tegra234-aon c000000.aon: init done
[ 4.447321] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 4.447327] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 4.452404] tegra23x-psc e860000.psc: Adding to iommu group 6
[ 4.460415] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 4.468961] tegra23x-psc e860000.psc: ext_cfg base:0000000033ee56c4
[ 4.485724] tegra23x-psc e860000.psc: init done
[ 4.490597] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 7
[ 4.497627] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.508824] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.513774] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.524732] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.535609] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.546784] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.558571] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x1����800��I/T��0-0��C: ��x20��Res��080��erv��
��ed��[ �� sh�� 4��are��.57��d m��106��emo��2] ��ry��teg�� is��ra-�� di��ivc��sab��-bu��led��s b��
��c00����000��I/��.rt��TC:��cpu�� Dy��:iv��nam��c-b��ic��us:�� sh��dia��are��g@5��d m��: d��em��1 R���ry ��: v��is��er=�� en��0 g��abl��rp=��ed
��X[1����x64��I/T��]=0��C: ��x20��Nor��080��mal��-0x�� Wo��201��rl��40 ��d v��TX[��irt��1x6��ual��4]=��iza��0x2��tio��014��n ��0-0��sup��x20��por��200��t i��
��290�� ��dis�� 4��abl��.58��ed
��9] ����teg��I/T��ra1��C: ��86-��Asy��cam��nch��-rt��ron��cpu��ou�� bc��s n��000��oti���U I��ic��rtc��ati��pu:��ons�� us�� a��ing��re �� ca��dis��m R��abl��TCP��ed
��RQ (113)
[ 4.589150] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.597413] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=23d74756c4720b2703c3fdde572be7d2b5d3d3ab
[ 4.597427] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 4.610123] t19x_cache tegra-cache: probed
[ 4.614958] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 4.626086] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 4.636133] optee: probing for conduit method.
[ 4.636267] optee: revision 3.22 (eb8130c7)
[ 4.695526] optee: dynamic shared memory is enabled
[ 4.695862] optee: initialized driver
[ 4.709207] nvpmodel: initialized successfully
[ 4.709414] tegra_hv: get_hvd: not initialized yet
[ 4.709547] user_ivc_mempool: hypervisor not present
[ 4.709983] usbcore: registered new interface driver snd-usb-audio
[ 4.711184] u32 classifier
[ 4.713306] input device check on
[ 4.716812] Actions configured
[ 4.720353] Initializing XFRM netlink socket
[ 4.725148] NET: Registered protocol family 10
[ 4.730597] Segment Routing with IPv6
[ 4.732780] NET: Registered protocol family 17
[ 4.737221] NET: Registered protocol family 15
[ 4.741618] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.755696] Bluetooth: RFCOMM socket layer initialized
[ 4.759941] Bluetooth: RFCOMM ver 1.11
[ 4.763817] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.769666] Bluetooth: HIDP socket layer initialized
[ 4.775900] 9pnet: Installing 9P2000 support
[ 4.779111] Key type dns_resolver registered
[ 4.784400] registered taskstats version 1
[ 4.787531] Loading compiled-in X.509 certificates
[ 4.803388] Loaded X.509 cert 'Build time autogenerated kernel key: 8bf422cbdacfe43c83374f4270ed8f21e8dceb0f'
[ 4.804145] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[ 4.814918] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 4.816084] tegra194-pcie 14160000.pcie: Adding to iommu group 9
[ 4.826701] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 4.827242] tegra194-pcie 141e0000.pcie: Adding to iommu group 10
[ 4.838639] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 4.839473] tegra194-pcie 140a0000.pcie: Adding to iommu group 11
[ 4.851029] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 4.878413] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 4.881218] host1x 13e40000.host1x: Adding to iommu group 13
[ 4.903593] host1x 13e40000.host1x: initialized
[ 4.904151] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 4.904634] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 4.905210] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 4.905598] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 4.906169] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 4.912416] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 4.922974] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 4.930443] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 4.940753] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 4.948309] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 4.958791] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 4.966295] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 4.976800] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 4.984327] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 4.994863] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 5.002349] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 5.012866] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 5.020395] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 5.030907] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 5.038393] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 5.048902] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 5.056411] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 5.066938] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 5.074478] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 5.084966] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 5.092479] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 5.102986] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 5.110511] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 5.121028] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 5.128524] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 5.139019] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 5.146542] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 5.157122] falcon 15340000.vic: Adding to iommu group 30
[ 5.168057] falcon 15340000.vic: initialized
[ 5.168514] falcon 15380000.nvjpg: Adding to iommu group 31
[ 5.175946] falcon 15380000.nvjpg: initialized
[ 5.177017] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 5.185932] falcon 15540000.nvjpg1: initialized
[ 5.187440] falcon 154c0000.nvenc: Adding to iommu group 33
[ 5.197816] falcon 154c0000.nvenc: initialized
[ 5.198076] falcon 15a50000.ofa: Adding to iommu group 34
[ 5.206411] falcon 15a50000.ofa: initialized
[ 5.207568] nvdec 15480000.nvdec: Adding to iommu group 35
[ 5.220394] nvdec 15480000.nvdec: initialized
[ 5.220651] tsec 15500000.tsec: Adding to iommu group 36
[ 5.228056] tsec 15500000.tsec: initialized
[ 5.230884] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 5.242801] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 5.254361] gpio-397 (camera-control-output-low): hogged as output/low
[ 5.254572] gpio-486 (camera-control-output-low): hogged as output/low
[ 5.255524] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 5.259728] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 5.266213] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 5.272555] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 5.278105] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 5.283563] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[ 5.291305] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 5.297789] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 5.303716] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 5.309799] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 5.318901] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 5.328249] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 5.335811] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 5.342891] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: Adding to iommu group 38
[ 5.350473] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 5.356718] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: Adding to iommu group 39
[ 5.364704] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 5.371152] scare-pigeon 13e40000.host1x:isp-thi@14b00000: Adding to iommu group 37
[ 5.379064] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 5.385276] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 5.393617] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 5.404307] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 5.412799] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 5.423557] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 5.431878] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 5.442819] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 5.451130] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 5.461878] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[ 5.470371] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 5.481150] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[ 5.489648] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 5.500377] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[ 5.508912] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 5.519625] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[ 5.528122] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 5.538889] pva 16000000.pva0: Adding to iommu group 48
[ 5.549653] pva 16000000.pva0: initialized
[ 5.556792] nvdla 15880000.nvdla0: Adding to iommu group 49
[ 5.562321] nvdla 15880000.nvdla0: initialized
[ 5.563149] nvdla 158c0000.nvdla1: Adding to iommu group 50
[ 5.569445] nvdla 158c0000.nvdla1: initialized
[ 5.570250] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[ 5.575464] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 5.581759] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 5.588051] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 5.594643] serial-tegra 3100000.serial: Adding to iommu group 3
[ 5.600882] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[ 5.610219] serial-tegra 3130000.serial: Adding to iommu group 3
[ 5.615775] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[ 5.624809] serial-tegra 3140000.serial: Adding to iommu group 3
[ 5.630445] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 5.639632] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure has invalid entries
[ 5.646503] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure: Child has not proper setting
[ 5.654813] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[ 5.662252] tegra23x-qspi 3270000.spi: Prod settings list not found
[ 5.693644] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 5.693892] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.694062] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 5.695137] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 5.700529] tegra-xusb 3610000.xhci: irq 230, io mem 0x03610000
[ 5.706593] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.711867] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 5.719302] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 5.726710] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.734784] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.742134] usb usb1: Product: xHCI Host Controller
[ 5.746947] usb usb1: Manufacturer: Linux 5.10.216-tegra xhci-hcd
[ 5.753157] usb usb1: SerialNumber: 3610000.xhci
[ 5.758653] hub 1-0:1.0: USB hub found
[ 5.761849] hub 1-0:1.0: 4 ports detected
[ 5.766331] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.774250] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.781507] usb usb2: Product: xHCI Host Controller
[ 5.786503] usb usb2: Manufacturer: Linux 5.10.216-tegra xhci-hcd
[ 5.792717] usb usb2: SerialNumber: 3610000.xhci
[ 5.797961] hub 2-0:1.0: USB hub found
[ 5.801301] hub 2-0:1.0: 4 ports detected
[ 5.828458] i2c i2c-2: Added multiplexed i2c bus 9
[ 5.829270] i2c i2c-2: Added multiplexed i2c bus 10
[ 5.829399] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 5.829875] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 5.843869] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1980000 KHz, changing to: 1984000 KHz
[ 5.846411] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[ 5.847902] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 5.854195] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 5.860192] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 5.868577] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 5.876884] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 5.990447] tegra194-pcie 14100000.pcie: Link up
[ 5.992784] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 5.992983] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 5.993143] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 5.993399] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 5.993673] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 5.993927] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 5.994245] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 5.998628] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 5.998937] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 5.999281] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.000559] pci 0001:01:00.0: supports D1 D2
[ 6.000667] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 6.005025] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 6.005206] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 6.005364] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.006671] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 6.012726] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 6.017948] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 6.022295] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 6.024249] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 6.038260] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 6.046627] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 6.055291] pcieport 0001:00:00.0: Adding to iommu group 8
[ 6.060686] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[ 6.066416] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[ 6.072704] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.079061] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 6.084978] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 6.093461] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 6.102034] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 6.202164] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489, bcdDevice= 1.40
[ 6.202424] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.202634] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 6.202767] usb 1-2: Manufacturer: Generic
[ 6.205113] hub 1-2:1.0: USB hub found
[ 6.206498] hub 1-2:1.0: 4 ports detected
[ 6.218523] tegra194-pcie 14160000.pcie: Link up
[ 6.221141] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 6.221328] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 6.221471] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 6.221727] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 6.222014] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 6.222257] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 6.222572] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 6.226672] pci 0004:01:00.0: [144d:a809] type 00 class 0x010802
[ 6.226998] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 6.232429] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 6.232613] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 6.232899] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 6.233024] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 6.239384] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.247918] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 6.256579] pcieport 0004:00:00.0: Adding to iommu group 9
[ 6.262046] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[ 6.267895] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[ 6.273700] nvme 0004:01:00.0: Adding to iommu group 9
[ 6.279078] nvme nvme0: pci function 0004:01:00.0
[ 6.283467] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 6.284049] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[ 6.295122] nvme nvme0: Shutdown timeout set to 8 seconds
[ 6.296146] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[ 6.307626] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
[ 6.316115] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
[ 6.316973] nvme nvme0: allocated 64 MiB host memory buffer.
[ 6.324596] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[ 6.339959] usb 2-1: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 6.386724] usb 2-1: New USB device found, idVendor=0bda, idProduct=0489, bcdDevice= 1.40
[ 6.386951] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.387142] usb 2-1: Product: 4-Port USB 3.0 Hub
[ 6.387270] usb 2-1: Manufacturer: Generic
[ 6.398612] hub 2-1:1.0: USB hub found
[ 6.400910] hub 2-1:1.0: 4 ports detected
[ 6.411154] nvme nvme0: 8/0/0 default/read/poll queues
[ 6.506455] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 6.659400] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 6.659640] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.659844] usb 1-3: Product: Bluetooth Radio
[ 6.659964] usb 1-3: Manufacturer: Realtek
[ 6.660089] usb 1-3: SerialNumber: 00e04c000001
[ 7.432085] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 7.432332] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 7.432529] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 7.432693] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[ 7.432977] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 7.433284] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[ 7.433553] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 7.433867] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 7.441212] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 7.441356] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.441846] pcieport 0007:00:00.0: Adding to iommu group 10
[ 7.442193] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[ 7.442744] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[ 7.443264] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 7.443505] pci 0007:00:00.0: Removing from iommu group 10
[ 7.443643] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[ 7.448227] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 7.453193] vdd-3v3-sd: supplied by vdd-3v3
[ 7.459055] tegra194-isp5 14800000.isp: initialized
[ 7.467621] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 7.468339] (NULL device *): fops function table already registered
[ 7.475553] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 7.481281] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[ 7.487113] irq: IRQ303: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.603361] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[ 7.603592] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff -> 0x002a100000
[ 7.603854] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff -> 0x0040000000
[ 7.604105] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[ 7.710448] tegra194-pcie 140a0000.pcie: Link up
[ 7.713656] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 7.713857] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 7.714013] pci_bus 0008:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[ 7.714294] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 7.714588] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 7.714841] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 7.715144] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 7.719393] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 7.719680] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 7.719996] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 7.720273] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 7.721461] pci 0008:01:00.0: supports D1 D2
[ 7.721582] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 7.725926] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 7.726113] pci 0008:00:00.0: BAR 13: assigned [io 0x300000-0x300fff]
[ 7.726273] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 7.733312] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 7.741183] pci 0008:01:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
[ 7.747684] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 7.752907] pci 0008:00:00.0: bridge window [io 0x300000-0x300fff]
[ 7.759296] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 7.766656] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 7.775195] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 7.783867] pcieport 0008:00:00.0: Adding to iommu group 11
[ 7.789514] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[ 7.795367] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[ 7.802177] irq: IRQ305: trimming hierarchy from :pmc@c360000
[ 7.806544] irq: IRQ306: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.813876] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 7.821322] tegra-se-nvhost 15810000.se: Adding to iommu group 51
[ 7.827197] tegra-se-nvhost 15810000.se: initialized
[ 7.840548] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 7.840815] tegra-se-nvhost 15820000.se: Adding to iommu group 52
[ 7.844374] tegra-se-nvhost 15820000.se: initialized
[ 7.851471] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 7.855135] tegra-se-nvhost 15840000.se: Adding to iommu group 53
[ 7.861605] tegra-se-nvhost 15840000.se: initialized
[ 7.869034] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 7.872991] tegra_actmon d230000.actmon: in actmon_register()...
[ 7.878637] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 7.884194] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 7.892040] hvc_sysfs: hypervisor is not present
[ 7.896440] clk: Disabling unused clocks
[ 7.935394] ALSA device list:
[ 7.935478] No soundcards found.
[ 7.936238] Freeing unused kernel memory: 3968K
[ 7.936386] Run /init as init process
[ 7.949260] Root device found: initrd
insmod /lib/modules/5.10.216-tegra/kernel/drivers/net/ethernet/realtek/r8168/r8168.ko
[ 7.955707] r8168 0008:01:00.0: Adding to iommu group 11
[ 7.956066] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded
[ 7.956305] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[ 7.974372] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 7.976710] r8168 Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
[ 7.976710] This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[ 7.976710] This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 7.986217] Mount initrd as rootfs and enter recovery mode
enable_remote_access
enable remote access
insmod /lib/modules/5.10.216-tegra/kernel/drivers/mtd/mtd.ko
insmod /lib/modules/5.10.216-tegra/kernel/drivers/mtd/devices/qspi_mtd.ko
[ 8.010270] qspi_mtd spi6.0: MX25U51279G (65536 Kbytes)
[ 8.012524] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 8.027977] 1 fixed-partitions partitions found on MTD device spi6.0
[ 8.030551] Creating 1 MTD partitions on "spi6.0":
[ 8.035546] 0x000000000000-0x000004000000 : "Whole_flash0"
insmod /lib/modules/5.10.216-tegra/kernel/drivers/spi/spi-tegra210-qspi.ko
insmod /lib/modules/5.10.216-tegra/kernel/drivers/hwmon/pwm-fan.ko
[ 8.065343] using random self ethernet address
[ 8.065470] using random host ethernet address
[ 8.068169] Mass Storage Function, version: 2009/09/11
[ 8.068310] LUN: removable file: (no medium)
[ 8.073461] LUN: removable file: (no medium)
[ 8.077829] LUN: removable file: (no medium)
[ 8.082418] LUN: removable file: (no medium)
Add /dev/nvme0n1
[ 8.089368] rndis0: HOST MAC c6:b0:f2:6f:6b:af
[ 8.092081] rndis0: MAC 9e:96:72:19:e7:19
[ 8.097412] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.0# [ 8.628146] tegra-xudc 3550000.xudc: EP 5 (type: intr, dir: in) enabled
[ 8.628343] tegra-xudc 3550000.xudc: EP 3 (type: bulk, dir: in) enabled
[ 8.628540] tegra-xudc 3550000.xudc: EP 2 (type: bulk, dir: out) enabled
[ 8.628789] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 8.628903] tegra-xudc 3550000.xudc: EP 7 (type: bulk, dir: in) enabled
[ 8.629183] tegra-xudc 3550000.xudc: EP 4 (type: bulk, dir: out) enabled
[ 9.690294] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 9.690571] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 9.690856] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 9.691151] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
