I am using L4T 36.4.3 DP trying to setup a minimal rootfs to run docker containers only. (that will be using the GPU, networking via ethernet) AGX Orin
My goal
- Create a basic flavor root file system (Root File System — NVIDIA Jetson Linux Developer Guide 1 documentation)
- Install NVIDIA docker
- My application is already containerized and I don’t need a GUI etc or any other SDKs
My assumed deployment process:
- Create the basic FS with
sudo ./nv_build_samplefs.sh --abi aarch64 --distro ubuntu --flavor basic --version jammy - Extract the FS to rootfs folder with
sudo tar -jxpf SAMPLE_FS_HERE -C ROOTFS_PATH - Run
apply_binaries.sh - Flash with
sudo ./nvsdkmanager_flash.sh - Create a default user with
l4t_create_default_user.sh - Boot the JETSON and install the docker runtime with:
sudo apt update
sudo apt install nvidia-container
sudo systemctl restart docker
sudo usermod -aG docker $USER
newgrp docker
- Run my containers
The Issue
The issue is that when I go to apply_binaries.sh it is complaining about dependencies for multiple l4t packages. I can do this entire process with the Desktop FS but issues when doing minimal. Confusing as on the docs it states:
The basic root file system is the smallest root file system that is used for NVIDIA Jetson develop kits and contains the dependencies for BSP and NVIDIA Docker. End users can install NVIDIA Docker to run the NVIDIA container and launch CUDA applications.
I have read Basic and minimal rootfs make apply_binaries.sh fail (L4T 36.2 DP) In that thread the solution was to remove some Linux_for_Tegra/nv_tegra/l4t_deb_packages/ but exactly what packages do I remove?
Can I please get a list of what I can remove that will allow apply_binaries.sh to run but not stop me from running my containers with the Jetson networked on ethernet. (this should be added to the docs)
There also seems to be essential packages missing from nvubuntu-jammy-minimal-aarch64-packages too:
nvme-cli - nvidia-l4t-init needs it
efibootmgr - nvidia-l4t-init needs it
Below is the log from apply_binaries.sh:
Selecting previously unselected package nvidia-l4t-core.
(Reading database ... 58646 files and directories currently installed.)
Preparing to unpack .../nvidia-l4t-core_36.4.3-20250107174145_arm64.deb ...
Pre-installing... skip compatibility checking.
Unpacking nvidia-l4t-core (36.4.3-20250107174145) ...
Setting up nvidia-l4t-core (36.4.3-20250107174145) ...
Processing triggers for libc-bin (2.35-0ubuntu3.8) ...
Selecting previously unselected package jetson-gpio-common.
(Reading database ... 58705 files and directories currently installed.)
Preparing to unpack .../jetson-gpio-common_2.1.7ubuntu1_arm64.deb ...
Unpacking jetson-gpio-common (2.1.7ubuntu1) ...
Selecting previously unselected package python3-jetson-gpio.
Preparing to unpack .../python3-jetson-gpio_2.1.7ubuntu1_arm64.deb ...
Unpacking python3-jetson-gpio (2.1.7ubuntu1) ...
Selecting previously unselected package python-jetson-gpio.
Preparing to unpack .../python-jetson-gpio_2.1.7ubuntu1_arm64.deb ...
Unpacking python-jetson-gpio (2.1.7ubuntu1) ...
Selecting previously unselected package nvidia-l4t-3d-core.
Preparing to unpack .../nvidia-l4t-3d-core_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-3d-core (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-apt-source.
Preparing to unpack .../nvidia-l4t-apt-source_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-apt-source (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-camera.
Preparing to unpack .../nvidia-l4t-camera_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-camera (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-configs.
Preparing to unpack .../nvidia-l4t-configs_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-configs (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-cuda.
Preparing to unpack .../nvidia-l4t-cuda_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-cuda (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-cuda-utils.
Preparing to unpack .../nvidia-l4t-cuda-utils_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-cuda-utils (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-firmware.
Preparing to unpack .../nvidia-l4t-firmware_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-firmware (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-gbm.
Preparing to unpack .../nvidia-l4t-gbm_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-gbm (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-graphics-demos.
Preparing to unpack .../nvidia-l4t-graphics-demos_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-graphics-demos (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-init.
Preparing to unpack .../nvidia-l4t-init_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-init (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-initrd.
Preparing to unpack .../nvidia-l4t-initrd_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-initrd (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-jetson-io.
Preparing to unpack .../nvidia-l4t-jetson-io_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-jetson-io (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-jetsonpower-gui-tools.
Preparing to unpack .../nvidia-l4t-jetsonpower-gui-tools_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-jetsonpower-gui-tools (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-libwayland-client0.
Preparing to unpack .../nvidia-l4t-libwayland-client0_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-libwayland-client0 (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-libwayland-cursor0.
Preparing to unpack .../nvidia-l4t-libwayland-cursor0_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-libwayland-cursor0 (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-libwayland-egl1.
Preparing to unpack .../nvidia-l4t-libwayland-egl1_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-libwayland-egl1 (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-libwayland-server0.
Preparing to unpack .../nvidia-l4t-libwayland-server0_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-libwayland-server0 (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-multimedia.
Preparing to unpack .../nvidia-l4t-multimedia_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-multimedia (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-multimedia-utils.
Preparing to unpack .../nvidia-l4t-multimedia-utils_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-multimedia-utils (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-nvfancontrol.
Preparing to unpack .../nvidia-l4t-nvfancontrol_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-nvfancontrol (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-nvml.
Preparing to unpack .../nvidia-l4t-nvml_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-nvml (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-nvpmodel.
Preparing to unpack .../nvidia-l4t-nvpmodel_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-nvpmodel (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-nvpmodel-gui-tools.
Preparing to unpack .../nvidia-l4t-nvpmodel-gui-tools_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-nvpmodel-gui-tools (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-nvsci.
Preparing to unpack .../nvidia-l4t-nvsci_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-nvsci (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-oem-config.
Preparing to unpack .../nvidia-l4t-oem-config_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-oem-config (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-openwfd.
Preparing to unpack .../nvidia-l4t-openwfd_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-openwfd (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-optee.
Preparing to unpack .../nvidia-l4t-optee_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-optee (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-pva.
Preparing to unpack .../nvidia-l4t-pva_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-pva (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-tools.
Preparing to unpack .../nvidia-l4t-tools_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-tools (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-vulkan-sc.
Preparing to unpack .../nvidia-l4t-vulkan-sc_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-vulkan-sc (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-vulkan-sc-dev.
Preparing to unpack .../nvidia-l4t-vulkan-sc-dev_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-vulkan-sc-dev (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-vulkan-sc-samples.
Preparing to unpack .../nvidia-l4t-vulkan-sc-samples_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-vulkan-sc-samples (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-vulkan-sc-sdk.
Preparing to unpack .../nvidia-l4t-vulkan-sc-sdk_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-vulkan-sc-sdk (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-wayland.
Preparing to unpack .../nvidia-l4t-wayland_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-wayland (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-weston.
Preparing to unpack .../nvidia-l4t-weston_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-weston (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-x11.
Preparing to unpack .../nvidia-l4t-x11_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-x11 (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-xusb-firmware.
Preparing to unpack .../nvidia-l4t-xusb-firmware_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-xusb-firmware (36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-display-kernel.
Preparing to unpack .../nvidia-l4t-display-kernel_5.15.148-tegra-36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-display-kernel (5.15.148-tegra-36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-kernel.
Preparing to unpack .../nvidia-l4t-kernel_5.15.148-tegra-36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-kernel (5.15.148-tegra-36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-kernel-dtbs.
Preparing to unpack .../nvidia-l4t-kernel-dtbs_5.15.148-tegra-36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-kernel-dtbs (5.15.148-tegra-36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-kernel-headers.
Preparing to unpack .../nvidia-l4t-kernel-headers_5.15.148-tegra-36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-kernel-headers (5.15.148-tegra-36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-kernel-oot-headers.
Preparing to unpack .../nvidia-l4t-kernel-oot-headers_5.15.148-tegra-36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-kernel-oot-headers (5.15.148-tegra-36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-kernel-oot-modules.
Preparing to unpack .../nvidia-l4t-kernel-oot-modules_5.15.148-tegra-36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-kernel-oot-modules (5.15.148-tegra-36.4.3-20250107174145) ...
Selecting previously unselected package nvidia-l4t-bootloader.
Preparing to unpack .../nvidia-l4t-bootloader_36.4.3-20250107174145_arm64.deb ...
Unpacking nvidia-l4t-bootloader (36.4.3-20250107174145) ...
Setting up jetson-gpio-common (2.1.7ubuntu1) ...
Setting up python3-jetson-gpio (2.1.7ubuntu1) ...
Setting up python-jetson-gpio (2.1.7ubuntu1) ...
Setting up nvidia-l4t-apt-source (36.4.3-20250107174145) ...
Pre-installing... skip changing source list.
Setting up nvidia-l4t-configs (36.4.3-20250107174145) ...
Setting up nvidia-l4t-cuda (36.4.3-20250107174145) ...
Setting up nvidia-l4t-cuda-utils (36.4.3-20250107174145) ...
Setting up nvidia-l4t-firmware (36.4.3-20250107174145) ...
dpkg: dependency problems prevent configuration of nvidia-l4t-init:
nvidia-l4t-init depends on efibootmgr; however:
Package efibootmgr is not installed.
nvidia-l4t-init depends on nvme-cli; however:
Package nvme-cli is not installed.
dpkg: error processing package nvidia-l4t-init (--install):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-l4t-jetsonpower-gui-tools:
nvidia-l4t-jetsonpower-gui-tools depends on nvidia-l4t-init (= 36.4.3-20250107174145); however:
Package nvidia-l4t-init is not configured yet.
dpkg: error processing package nvidia-l4t-jetsonpower-gui-tools (--install):
Setting up nvidia-l4t-libwayland-client0 (36.4.3-20250107174145) ...
Setting up nvidia-l4t-libwayland-cursor0 (36.4.3-20250107174145) ...
Setting up nvidia-l4t-libwayland-egl1 (36.4.3-20250107174145) ...
Setting up nvidia-l4t-libwayland-server0 (36.4.3-20250107174145) ...
Setting up nvidia-l4t-multimedia-utils (36.4.3-20250107174145) ...
dpkg: dependency problems prevent configuration of nvidia-l4t-nvfancontrol:
nvidia-l4t-nvfancontrol depends on nvidia-l4t-init (= 36.4.3-20250107174145); however:
dpkg: error processing package nvidia-l4t-nvfancontrol (--install):
Setting up nvidia-l4t-nvml (36.4.3-20250107174145) ...
dpkg: dependency problems prevent configuration of nvidia-l4t-nvpmodel:
nvidia-l4t-nvpmodel depends on nvidia-l4t-init (= 36.4.3-20250107174145); however:
dpkg: error processing package nvidia-l4t-nvpmodel (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-nvpmodel-gui-tools:
nvidia-l4t-nvpmodel-gui-tools depends on nvidia-l4t-init (= 36.4.3-20250107174145); however:
nvidia-l4t-nvpmodel-gui-tools depends on nvidia-l4t-nvpmodel (= 36.4.3-20250107174145); however:
Package nvidia-l4t-nvpmodel is not configured yet.
dpkg: error processing package nvidia-l4t-nvpmodel-gui-tools (--install):
Setting up nvidia-l4t-nvsci (36.4.3-20250107174145) ...
Setting up nvidia-l4t-oem-config (36.4.3-20250107174145) ...
Setting up nvidia-l4t-openwfd (36.4.3-20250107174145) ...
Setting up nvidia-l4t-optee (36.4.3-20250107174145) ...
Setting up nvidia-l4t-pva (36.4.3-20250107174145) ...
Setting up nvidia-l4t-tools (36.4.3-20250107174145) ...
Setting up nvidia-l4t-vulkan-sc (36.4.3-20250107174145) ...
Setting up nvidia-l4t-vulkan-sc-dev (36.4.3-20250107174145) ...
Setting up nvidia-l4t-vulkan-sc-sdk (36.4.3-20250107174145) ...
Setting up nvidia-l4t-wayland (36.4.3-20250107174145) ...
dpkg: dependency problems prevent configuration of nvidia-l4t-weston:
nvidia-l4t-weston depends on libseat1; however:
Package libseat1 is not installed.
dpkg: error processing package nvidia-l4t-weston (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-x11:
nvidia-l4t-x11 depends on nvidia-l4t-init (= 36.4.3-20250107174145); however:
dpkg: error processing package nvidia-l4t-x11 (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-xusb-firmware:
nvidia-l4t-xusb-firmware depends on nvidia-l4t-init (>> 36.4-0); however:
nvidia-l4t-xusb-firmware depends on nvidia-l4t-init (<< 36.5-0); however:
dpkg: error processing package nvidia-l4t-xusb-firmware (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel:
nvidia-l4t-kernel depends on nvidia-l4t-init (>> 36.4-0); however:
nvidia-l4t-kernel depends on nvidia-l4t-init (<< 36.5-0); however:
dpkg: error processing package nvidia-l4t-kernel (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.3-20250107174145); however:
Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-dtbs (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.3-20250107174145); however:
dpkg: error processing package nvidia-l4t-kernel-headers (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-oot-headers:
nvidia-l4t-kernel-oot-headers depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.3-20250107174145); however:
dpkg: error processing package nvidia-l4t-kernel-oot-headers (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-oot-modules:
nvidia-l4t-kernel-oot-modules depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.3-20250107174145); however:
dpkg: error processing package nvidia-l4t-kernel-oot-modules (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-bootloader:
nvidia-l4t-bootloader depends on nvidia-l4t-init (>> 36.4-0); however:
nvidia-l4t-bootloader depends on nvidia-l4t-init (<< 36.5-0); however:
dpkg: error processing package nvidia-l4t-bootloader (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-3d-core:
nvidia-l4t-3d-core depends on nvidia-l4t-init (= 36.4.3-20250107174145); however:
nvidia-l4t-3d-core depends on nvidia-l4t-x11 (= 36.4.3-20250107174145); however:
Package nvidia-l4t-x11 is not configured yet.
dpkg: error processing package nvidia-l4t-3d-core (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-gbm:
nvidia-l4t-gbm depends on nvidia-l4t-3d-core (= 36.4.3-20250107174145); however:
Package nvidia-l4t-3d-core is not configured yet.
dpkg: error processing package nvidia-l4t-gbm (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-graphics-demos:
nvidia-l4t-graphics-demos depends on nvidia-l4t-3d-core (= 36.4.3-20250107174145); however:
nvidia-l4t-graphics-demos depends on nvidia-l4t-weston (= 36.4.3-20250107174145); however:
Package nvidia-l4t-weston is not configured yet.
dpkg: error processing package nvidia-l4t-graphics-demos (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-initrd:
nvidia-l4t-initrd depends on nvidia-l4t-xusb-firmware (= 36.4.3-20250107174145); however:
Package nvidia-l4t-xusb-firmware is not configured yet.
dpkg: error processing package nvidia-l4t-initrd (--install):
dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-io:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (>> 5.15.148-tegra-36.4-0); however:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (<< 5.15.148-tegra-36.5-0); however:
dpkg: error processing package nvidia-l4t-jetson-io (--install):
Setting up nvidia-l4t-multimedia (36.4.3-20250107174145) ...
Setting up nvidia-l4t-vulkan-sc-samples (36.4.3-20250107174145) ...
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.3-20250107174145); however:
dpkg: error processing package nvidia-l4t-display-kernel (--install):
Setting up nvidia-l4t-camera (36.4.3-20250107174145) ...
Errors were encountered while processing:
nvidia-l4t-init
nvidia-l4t-nvpmodel
nvidia-l4t-weston
nvidia-l4t-x11
nvidia-l4t-kernel
nvidia-l4t-3d-core
nvidia-l4t-gbm
nvidia-l4t-initrd
