I met a issue when running sudo ./apply_binaries.sh in latest JetPack_4.4_DP_Linux_DP_JETSON_XAVIER_NX
This command report error as below:
~/nvidia_NX_440_DP/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_XAVIER_NX/Linux_for_Tegra$ sudo ./apply_binaries.sh
Using rootfs directory of: /home/yy/nvidia_NX_440_DP/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_XAVIER_NX/Linux_for_Tegra/rootfs
/home/yy/nvidia_NX_440_DP/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_XAVIER_NX/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
Root file system directory is /home/yy/nvidia_NX_440_DP/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_XAVIER_NX/Linux_for_Tegra/rootfs
Copying public debian packages to rootfs
Start L4T BSP package installation
QEMU binary is not available, looking for QEMU from host system
Found /usr/bin/qemu-aarch64-static
Installing QEMU binary in rootfs
~/nvidia_NX_440_DP/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_XAVIER_NX/Linux_for_Tegra/rootfs ~/nvidia_NX_440_DP/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_XAVIER_NX/Linux_for_Tegra
Installing BSP Debian packages in /home/yy/nvidia_NX_440_DP/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_XAVIER_NX/Linux_for_Tegra/rootfs
(Reading database … 123395 files and directories currently installed.)
Preparing to unpack …/nvidia-l4t-core_32.4.2-20200408182620_arm64.deb …
Pre-installing… skip compatibility checking.
Unpacking nvidia-l4t-core (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Setting up nvidia-l4t-core (32.4.2-20200408182620) …
Preparing to unpack …/jetson-gpio-common_2.0.8_arm64.deb …
Unpacking jetson-gpio-common (2.0.8) over (2.0.8) …
Preparing to unpack …/python3-jetson-gpio_2.0.8_arm64.deb …
qemu: Unsupported syscall: 278
Fatal Python error: failed to get random numbers to initialize Python
qemu: uncaught target signal 6 (Aborted) - core dumped
Aborted (core dumped)
dpkg: warning: old python3-jetson-gpio package pre-removal script subprocess returned error exit status 134
dpkg: trying script from the new package instead …
dpkg: error processing archive /opt/nvidia/l4t-packages/standalone/python3-jetson-gpio_2.0.8_arm64.deb (–install):
new python3-jetson-gpio package pre-removal script subprocess returned error exit status 134
Preparing to unpack …/python-jetson-gpio_2.0.8_arm64.deb …
Unpacking python-jetson-gpio (2.0.8) over (2.0.8) …
Preparing to unpack …/nvidia-l4t-3d-core_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-3d-core (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-apt-source_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-apt-source (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-camera_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-camera (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-configs_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-configs (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-cuda_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-cuda (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-firmware_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-firmware (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-graphics-demos_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-graphics-demos (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-gstreamer_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-gstreamer (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-init_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-init (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-initrd_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-initrd (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-jetson-io_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-jetson-io (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-multimedia_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-multimedia (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-multimedia-utils_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-multimedia-utils (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-oem-config_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-oem-config (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-tools_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-tools (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-wayland_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-wayland (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-weston_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-weston (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-x11_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-x11 (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-xusb-firmware_32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-xusb-firmware (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-kernel_4.9.140-tegra-32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-kernel (4.9.140-tegra-32.4.2-20200408182620) over (4.9.140-tegra-32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-kernel-dtbs_4.9.140-tegra-32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-kernel-dtbs (4.9.140-tegra-32.4.2-20200408182620) over (4.9.140-tegra-32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-kernel-headers_4.9.140-tegra-32.4.2-20200408182620_arm64.deb …
Unpacking nvidia-l4t-kernel-headers (4.9.140-tegra-32.4.2-20200408182620) over (4.9.140-tegra-32.4.2-20200408182620) …
Preparing to unpack …/nvidia-l4t-bootloader_32.4.2-20200408182620_arm64.deb …
Pre-installing bootloader package, skip flashing
Unpacking nvidia-l4t-bootloader (32.4.2-20200408182620) over (32.4.2-20200408182620) …
Setting up jetson-gpio-common (2.0.8) …
Setting up python-jetson-gpio (2.0.8) …
Setting up nvidia-l4t-apt-source (32.4.2-20200408182620) …
Pre-installing… skip changing source list.
Setting up nvidia-l4t-configs (32.4.2-20200408182620) …
Setting up nvidia-l4t-firmware (32.4.2-20200408182620) …
Setting up nvidia-l4t-init (32.4.2-20200408182620) …
groupadd: group ‘crypto’ already exists
groupadd: group ‘trusty’ already exists
dpkg: error processing package nvidia-l4t-init (–install):
installed nvidia-l4t-init package post-installation script subprocess returned error exit status 9
Setting up nvidia-l4t-multimedia-utils (32.4.2-20200408182620) …
Setting up nvidia-l4t-oem-config (32.4.2-20200408182620) …
Setting up nvidia-l4t-tools (32.4.2-20200408182620) …
Setting up nvidia-l4t-wayland (32.4.2-20200408182620) …
Setting up nvidia-l4t-weston (32.4.2-20200408182620) …
dpkg: dependency problems prevent configuration of nvidia-l4t-x11:
nvidia-l4t-x11 depends on nvidia-l4t-init (= 32.4.2-20200408182620); however:
Package nvidia-l4t-init is not configured yet.
dpkg: error processing package nvidia-l4t-x11 (–install):
dependency problems - leaving unconfigured
Setting up nvidia-l4t-xusb-firmware (32.4.2-20200408182620) …
Pre-installing xusb firmware package, skip flashing
Setting up nvidia-l4t-kernel (4.9.140-tegra-32.4.2-20200408182620) …
Setting up nvidia-l4t-kernel-dtbs (4.9.140-tegra-32.4.2-20200408182620) …
Setting up nvidia-l4t-kernel-headers (4.9.140-tegra-32.4.2-20200408182620) …
Unpacking kernel headers…
Setting up nvidia-l4t-bootloader (32.4.2-20200408182620) …
dpkg: dependency problems prevent configuration of nvidia-l4t-3d-core:
nvidia-l4t-3d-core depends on nvidia-l4t-init (= 32.4.2-20200408182620); however:
nvidia-l4t-3d-core depends on nvidia-l4t-x11 (= 32.4.2-20200408182620); however:
Package nvidia-l4t-x11 is not configured yet.
dpkg: error processing package nvidia-l4t-3d-core (–install):
dpkg: dependency problems prevent configuration of nvidia-l4t-camera:
nvidia-l4t-camera depends on nvidia-l4t-3d-core (= 32.4.2-20200408182620); however:
Package nvidia-l4t-3d-core is not configured yet.
dpkg: error processing package nvidia-l4t-camera (–install):
dpkg: dependency problems prevent configuration of nvidia-l4t-cuda:
nvidia-l4t-cuda depends on nvidia-l4t-3d-core (= 32.4.2-20200408182620); however:
dpkg: error processing package nvidia-l4t-cuda (–install):
dpkg: dependency problems prevent configuration of nvidia-l4t-graphics-demos:
nvidia-l4t-graphics-demos depends on nvidia-l4t-3d-core (= 32.4.2-20200408182620); however:
dpkg: error processing package nvidia-l4t-graphics-demos (–install):
dpkg: dependency problems prevent configuration of nvidia-l4t-gstreamer:
nvidia-l4t-gstreamer depends on nvidia-l4t-camera (= 32.4.2-20200408182620); however:
Package nvidia-l4t-camera is not configured yet.
nvidia-l4t-gstreamer depends on nvidia-l4t-cuda (= 32.4.2-20200408182620); however:
Package nvidia-l4t-cuda is not configured yet.
dpkg: error processing package nvidia-l4t-gstreamer (–install):
Setting up nvidia-l4t-initrd (32.4.2-20200408182620) …
Setting up nvidia-l4t-jetson-io (32.4.2-20200408182620) …
dpkg: dependency problems prevent configuration of nvidia-l4t-multimedia:
nvidia-l4t-multimedia depends on nvidia-l4t-3d-core (= 32.4.2-20200408182620); however:
nvidia-l4t-multimedia depends on nvidia-l4t-cuda (= 32.4.2-20200408182620); however:
dpkg: error processing package nvidia-l4t-multimedia (–install):
Processing triggers for nvidia-l4t-kernel (4.9.140-tegra-32.4.2-20200408182620) …
Errors were encountered while processing:
nvidia-l4t-init
nvidia-l4t-x11
nvidia-l4t-3d-core
nvidia-l4t-camera
nvidia-l4t-cuda
These errors will cause system package configuration fail when ubuntu first boot up.
In JetPack 4.4 EA. This command works fine.
Please help if you know the reason.
