Nothing but issues with new Jetson Nano 4GB
Jetson Nano 4GB - B01 (2 camera ports)
Power via barrel plug and jumper is set
SD card flashed from another Ubuntu machine. (461)
After a while I finally got to a point where it takes me through the initial set-up.
To get here I plugged in a USB-debugger onto the serial interface facing sideways under the SD-card slot.
Connected using minicom from my Ubuntu machine. A promt asked me finish the set-up using the USB connection.
So plugged in a micro-USB and configured minicom to use /dev/ttyACM0
All easy so far., just took a while to get here. Then the usual setup, until I was able to log-in.
sudo apt update
sudo apt upgrade.
This is where it started with the issues, that I just can’t solve.
I had the issue a few days ago and haven’t been able to solve it so far and feel I have spent enough time fiddling with this.
The issue seems to be with the package “nvidia-l4t-kernel”
however, I’m unable to remove the package from the apt list, once I ran
sudo apt update.
And from there I can only
sudo apt upgrade, but that constantly fails with the below error trace:
Preparing to unpack .../7-nvidia-l4t-kernel_4.9.299-tegra-32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-kernel (4.9.299-tegra-32.7.3-20221122092935) ...
Setting up nvidia-l4t-tools (32.7.3-20221122092935) ...
Setting up nvidia-l4t-kernel (4.9.299-tegra-32.7.3-20221122092935) ...
Using the existing boot entry 'primary'
3448-300-0000--1--jetson-nano-devkit-
Setting up nvidia-l4t-jetson-io (32.7.3-20221122092935) ...
Setting up nvidia-l4t-kernel-dtbs (4.9.299-tegra-32.7.3-20221122092935) ...
Setting up nvidia-l4t-bootloader (32.7.3-20221122092935) ...
Starting bootloader post-install procedure.
ERROR. Procedure for bootloader update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-bootloader (--configure):
 installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
Setting up nvidia-l4t-xusb-firmware (32.7.3-20221122092935) ...
Starting xusb firmware post-install procedure.
ERROR. Procedure for xusb firmware update FAILED.
dpkg: error processing package nvidia-l4t-xusb-firmware (--configure):
 installed nvidia-l4t-xusb-firmware package post-installation s+-----------------------------+ exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-i|                             |
 nvidia-l4t-initrd depends on nvidia-l4t-xusb-firmware (= 32.7.|  Cannot open /dev/ttyACM0!  |
  Package nvidia-l4t-xusb-firmware is not configured yet.      |                             |
dpkg: error processing package nvidia-l4t-initrd (--configure):
 dependency problems - leaving unconfigured
Setting up nvidia-l4t-kernel-headers (4.9.299-tegra-32.7.3-20221122092935) ...
No apport report written because the error message indicates its a followup error from a previous failure.
        Processing triggers for nvidia-l4t-kernel (4.9.29.
Errors were encountered while processing:
 nvidia-l4t-initrd
E: Sub-process /usr/bin/dpkg returned an error code (1)
Here the log output, I had to trim it a bit due to length limitation on posts
administrator@ROSdev:~$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following NEW packages will be installed:
  python3-click python3-colorama
The following packages have been kept back:
  tensorrt
The following packages will be upgraded:
  apport apport-gtk bash bind9-host binutils binutils-aarch64-linux-gnu binutils-common bluez bluez-obexd ca-certificates chromium-browser
  chromium-browser-l10n chromium-codecs-ffmpeg-extra containerd cron dbus dbus-user-session dbus-x11 dirmngr distro-info-data dnsmasq-base docker.io dpkg
  dpkg-dev e2fsprogs ffmpeg fonts-opensymbol ghostscript ghostscript-x gir1.2-notify-0.7 git git-man gnupg gnupg-l10n gnupg-utils gpg gpg-agent
  gpg-wks-client gpg-wks-server gpgconf gpgsm gpgv grub-common gstreamer1.0-gtk3 gstreamer1.0-plugins-good gstreamer1.0-pulseaudio gzip imagemagick
  imagemagick-6-common imagemagick-6.q16 isc-dhcp-client isc-dhcp-common isc-dhcp-server keyutils klibc-utils libasn1-8-heimdal libavcodec57 libavdevice57
  libavfilter6 libavformat57 libavresample3 libavutil55 libbind9-160 libbinutils libbluetooth3 libc-bin libc-dev-bin libc6 libc6-dbg libc6-dev libcom-err2
  libcups2 libcupsimage2 libcurl3-gnutls libcurl4 libdbus-1-3 libdns-export1100 libdns1100 libdpkg-perl libevdev2 libexempi3 libexpat1 libexpat1-dev
  libext2fs2 libflac8 libfreerdp-client2-2 libfreerdp2-2 libfreetype6 libfribidi0 libgmp10 libgnutls30 libgs9 libgs9-common libgssapi3-heimdal
  libgstreamer-plugins-good1.0-0 libhcrypto4-heimdal libheimbase1-heimdal libheimntlm0-heimdal libhttp-daemon-perl libhx509-5-heimdal libice-dev libice6
  libinput-bin libinput10 libirs-export160 libisc-export169 libisc169 libisccc160 libisccfg-export160 libisccfg160 libjbig0 libjpeg-turbo-progs
  libjpeg-turbo8 libkeyutils1 libklibc libkrb5-26-heimdal libksba8 libldap-2.4-2 libldap-common liblouis-data liblouis14 liblwres160 liblzma5
  libmagickcore-6.q16-3 libmagickcore-6.q16-3-extra libmagickwand-6.q16-3 libmysqlclient20 libnotify-bin libnotify4 libnss-myhostname libnss-systemd
  libnss3 libntfs-3g88 libnvinfer-dev libnvinfer8 libpam-systemd libpcre16-3 libpcre3 libpcre3-dev libpcre32-3 libpcrecpp0v5 libperl5.26 libpixman-1-0
  libpoppler-glib8 libpoppler73 libpostproc54 libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib libpython3.6 libpython3.6-minimal
  libpython3.6-stdlib libraw16 libreoffice-avmedia-backend-gstreamer libreoffice-base-core libreoffice-calc libreoffice-common libreoffice-core
  libreoffice-draw libreoffice-gnome libreoffice-gtk3 libreoffice-impress libreoffice-math libreoffice-ogltrans libreoffice-pdfimport
  libreoffice-style-breeze libreoffice-style-galaxy libreoffice-style-tango libreoffice-writer libroken18-heimdal libsasl2-2 libsasl2-modules
  libsasl2-modules-db libsdl1.2debian libsensors4 libsepol1 libsmbclient libsnmp-base libsnmp30 libspeex1 libspeexdsp1 libsqlite3-0 libss2 libssl1.0.0
  libssl1.1 libswresample2 libswscale4 libsystemd0 libtiff5 libudev1 libwayland-bin libwayland-client0 libwayland-cursor0 libwayland-dev libwayland-egl1
  libwayland-server0 libwbclient0 libwind0-heimdal libwinpr2-2 libxml2 libxml2-dev libxslt1.1 linux-firmware linux-libc-dev locales login
  multiarch-support networkd-dispatcher ntfs-3g nvidia-l4t-3d-core nvidia-l4t-apt-source nvidia-l4t-camera nvidia-l4t-configs nvidia-l4t-core
  nvidia-l4t-cuda nvidia-l4t-firmware nvidia-l4t-gputools nvidia-l4t-graphics-demos nvidia-l4t-gstreamer nvidia-l4t-init nvidia-l4t-jetson-multimedia-api
  nvidia-l4t-libvulkan nvidia-l4t-multimedia nvidia-l4t-multimedia-utils nvidia-l4t-oem-config nvidia-l4t-wayland nvidia-l4t-weston nvidia-l4t-x11
  openssh-client openssh-server openssh-sftp-server openssl passwd perl perl-base perl-modules-5.26 poppler-utils python-pil python2.7 python2.7-dev
  python2.7-minimal python3-apport python3-jwt python3-louis python3-mako python3-problem-report python3-uno python3.6 python3.6-minimal rsync rsyslog
  runc samba-libs snapd systemd systemd-sysv tar thunderbird thunderbird-gnome-support tzdata ubuntu-drivers-common udev uno-libs3 unzip ure vim
  vim-common vim-runtime wireless-regdb xserver-common xserver-xephyr xserver-xorg-core xserver-xorg-legacy xwayland xxd xz-utils zlib1g zlib1g-dev
279 upgraded, 2 newly installed, 0 to remove and 1 not upgraded.
3 not fully installed or removed.
Need to get 812 MB of archives.
After this operation, 15.2 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Fetched 812 MB in 3min 45s (3,605 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 179742 files and directories currently installed.)
Preparing to unpack .../libc6-dbg_2.27-3ubuntu1.6_arm64.deb ...
Unpacking libc6-dbg:arm64 (2.27-3ubuntu1.6) over (2.27-3ubuntu1.4) ...
Preparing to unpack .../libc6-dev_2.27-3ubuntu1.6_arm64.deb ...
Unpacking libc6-dev:arm64 (2.27-3ubuntu1.6) over (2.27-3ubuntu1.4) ...
Preparing to unpack .../libc-dev-bin_2.27-3ubuntu1.6_arm64.deb ...
Unpacking libc-dev-bin (2.27-3ubuntu1.6) over (2.27-3ubuntu1.4) ...
Preparing to unpack .../linux-libc-dev_4.15.0-200.211_arm64.deb ...
Unpacking linux-libc-dev:arm64 (4.15.0-200.211) over (4.15.0-166.174) ...
Preparing to unpack .../libc6_2.27-3ubuntu1.6_arm64.deb ...
Unpacking libc6:arm64 (2.27-3ubuntu1.6) over (2.27-3ubuntu1.4) ...
Setting up libc6:arm64 (2.27-3ubuntu1.6) ...
Preparing to unpack .../00-nvidia-l4t-gstreamer_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-gstreamer (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../01-nvidia-l4t-jetson-multimedia-api_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-jetson-multimedia-api (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../02-nvidia-l4t-camera_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-camera (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../03-nvidia-l4t-multimedia_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-multimedia (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../04-nvidia-l4t-cuda_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-cuda (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../05-nvidia-l4t-graphics-demos_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-graphics-demos (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../06-nvidia-l4t-3d-core_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-3d-core (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../07-nvidia-l4t-libvulkan_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-libvulkan (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../08-libexpat1-dev_2.2.5-3ubuntu0.9_arm64.deb ...
Unpacking libexpat1-dev:arm64 (2.2.5-3ubuntu0.9) over (2.2.5-3ubuntu0.4) ...
Preparing to unpack .../09-libexpat1_2.2.5-3ubuntu0.9_arm64.deb ...
Unpacking libexpat1:arm64 (2.2.5-3ubuntu0.9) over (2.2.5-3ubuntu0.4) ...
Preparing to unpack .../10-libpcre3-dev_2%3a8.39-9ubuntu0.1_arm64.deb ...
Unpacking libpcre3-dev:arm64 (2:8.39-9ubuntu0.1) over (2:8.39-9) ...
Preparing to unpack .../11-libpcre16-3_2%3a8.39-9ubuntu0.1_arm64.deb ...
Unpacking libpcre16-3:arm64 (2:8.39-9ubuntu0.1) over (2:8.39-9) ...
Preparing to unpack .../12-libpcre32-3_2%3a8.39-9ubuntu0.1_arm64.deb ...
Unpacking libpcre32-3:arm64 (2:8.39-9ubuntu0.1) over (2:8.39-9) ...
Preparing to unpack .../13-libpcrecpp0v5_2%3a8.39-9ubuntu0.1_arm64.deb ...
Unpacking libpcrecpp0v5:arm64 (2:8.39-9ubuntu0.1) over (2:8.39-9) ...
Preparing to unpack .../14-libpcre3_2%3a8.39-9ubuntu0.1_arm64.deb ...
Unpacking libpcre3:arm64 (2:8.39-9ubuntu0.1) over (2:8.39-9) ...
Setting up libpcre3:arm64 (2:8.39-9ubuntu0.1) ...
(Reading database ... 179745 files and directories currently installed.)
Preparing to unpack .../0-libwayland-dev_1.16.0-1ubuntu1.1~18.04.4_arm64.deb ...
Unpacking libwayland-dev:arm64 (1.16.0-1ubuntu1.1~18.04.4) over (1.16.0-1ubuntu1.1~18.04.3) ...
Preparing to unpack .../1-libwayland-server0_1.16.0-1ubuntu1.1~18.04.4_arm64.deb ...
Unpacking libwayland-server0:arm64 (1.16.0-1ubuntu1.1~18.04.4) over (1.16.0-1ubuntu1.1~18.04.3) ...
Preparing to unpack .../2-libwayland-cursor0_1.16.0-1ubuntu1.1~18.04.4_arm64.deb ...
Unpacking libwayland-cursor0:arm64 (1.16.0-1ubuntu1.1~18.04.4) over (1.16.0-1ubuntu1.1~18.04.3) ...
Preparing to unpack .../3-libwayland-egl1_1.16.0-1ubuntu1.1~18.04.4_arm64.deb ...
Unpacking libwayland-egl1:arm64 (1.16.0-1ubuntu1.1~18.04.4) over (1.16.0-1ubuntu1.1~18.04.3) ...
Preparing to unpack .../4-libxml2-dev_2.9.4+dfsg1-6.1ubuntu1.8_arm64.deb ...
Unpacking libxml2-dev:arm64 (2.9.4+dfsg1-6.1ubuntu1.8) over (2.9.4+dfsg1-6.1ubuntu1.4) ...
Preparing to unpack .../5-zlib1g-dev_1%3a1.2.11.dfsg-0ubuntu2.2_arm64.deb ...
Unpacking zlib1g-dev:arm64 (1:1.2.11.dfsg-0ubuntu2.2) over (1:1.2.11.dfsg-0ubuntu2) ...
Preparing to unpack .../6-zlib1g_1%3a1.2.11.dfsg-0ubuntu2.2_arm64.deb ...
Unpacking zlib1g:arm64 (1:1.2.11.dfsg-0ubuntu2.2) over (1:1.2.11.dfsg-0ubuntu2) ...
Setting up zlib1g:arm64 (1:1.2.11.dfsg-0ubuntu2.2) ...
Preparing to unpack .../liblzma5_5.2.2-1.3ubuntu0.1_arm64.deb ...
Unpacking liblzma5:arm64 (5.2.2-1.3ubuntu0.1) over (5.2.2-1.3) ...
Setting up liblzma5:arm64 (5.2.2-1.3ubuntu0.1) ...
Preparing to unpack .../00-libxml2_2.9.4+dfsg1-6.1ubuntu1.8_arm64.deb ...
Unpacking libxml2:arm64 (2.9.4+dfsg1-6.1ubuntu1.8) over (2.9.4+dfsg1-6.1ubuntu1.4) ...
Preparing to unpack .../01-libwayland-bin_1.16.0-1ubuntu1.1~18.04.4_arm64.deb ...
Unpacking libwayland-bin (1.16.0-1ubuntu1.1~18.04.4) over (1.16.0-1ubuntu1.1~18.04.3) ...
Preparing to unpack .../02-libwayland-client0_1.16.0-1ubuntu1.1~18.04.4_arm64.deb ...
Unpacking libwayland-client0:arm64 (1.16.0-1ubuntu1.1~18.04.4) over (1.16.0-1ubuntu1.1~18.04.3) ...
Preparing to unpack .../03-libevdev2_1.5.8+dfsg-1ubuntu0.2_arm64.deb ...
Unpacking libevdev2:arm64 (1.5.8+dfsg-1ubuntu0.2) over (1.5.8+dfsg-1ubuntu0.1) ...
Preparing to unpack .../04-libnss-systemd_237-3ubuntu10.56_arm64.deb ...
Unpacking libnss-systemd:arm64 (237-3ubuntu10.56) over (237-3ubuntu10.53) ...
Preparing to unpack .../05-libssl1.1_1.1.1-1ubuntu2.1~18.04.20_arm64.deb ...
Unpacking libssl1.1:arm64 (1.1.1-1ubuntu2.1~18.04.20) over (1.1.1-1ubuntu2.1~18.04.14) ...
Preparing to unpack .../06-openssl_1.1.1-1ubuntu2.1~18.04.20_arm64.deb ...
Unpacking openssl (1.1.1-1ubuntu2.1~18.04.20) over (1.1.1-1ubuntu2.1~18.04.14) ...
Preparing to unpack .../07-ca-certificates_20211016ubuntu0.18.04.1_all.deb ...
Unpacking ca-certificates (20211016ubuntu0.18.04.1) over (20210119~18.04.2) ...
Preparing to unpack .../08-openssh-sftp-server_1%3a7.6p1-4ubuntu0.7_arm64.deb ...
Unpacking openssh-sftp-server (1:7.6p1-4ubuntu0.7) over (1:7.6p1-4ubuntu0.5) ...
Preparing to unpack .../09-cron_3.0pl1-128.1ubuntu1.2_arm64.deb ...
Unpacking cron (3.0pl1-128.1ubuntu1.2) over (3.0pl1-128.1ubuntu1) ...
Preparing to unpack .../10-tar_1.29b-2ubuntu0.3_arm64.deb ...
Unpacking tar (1.29b-2ubuntu0.3) over (1.29b-2ubuntu0.2) ...
Setting up tar (1.29b-2ubuntu0.3) ...
(Reading database ... 179741 files and directories currently installed.)
Preparing to unpack .../dpkg_1.19.0.5ubuntu2.4_arm64.deb ...
Unpacking dpkg (1.19.0.5ubuntu2.4) over (1.19.0.5ubuntu2.3) ...
Setting up dpkg (1.19.0.5ubuntu2.4) ...
Preparing to unpack .../libcom-err2_1.44.1-1ubuntu1.4_arm64.deb ...
Unpacking libcom-err2:arm64 (1.44.1-1ubuntu1.4) over (1.44.1-1ubuntu1.3) ...
Setting up libcom-err2:arm64 (1.44.1-1ubuntu1.4) ...
Preparing to unpack .../libssl1.0.0_1.0.2n-1ubuntu5.10_arm64.deb ...
Unpacking libssl1.0.0:arm64 (1.0.2n-1ubuntu5.10) over (1.0.2n-1ubuntu5.7) ...
Preparing to unpack .../openssh-server_1%3a7.6p1-4ubuntu0.7_arm64.deb ...
Unpacking openssh-server (1:7.6p1-4ubuntu0.7) over (1:7.6p1-4ubuntu0.5) ...
Preparing to unpack .../git-man_1%3a2.17.1-1ubuntu0.13_all.deb ...
Unpacking git-man (1:2.17.1-1ubuntu0.13) over (1:2.17.1-1ubuntu0.9) ...
Preparing to unpack .../libgmp10_2%3a6.1.2+dfsg-2ubuntu0.1_arm64.deb ...
Unpacking libgmp10:arm64 (2:6.1.2+dfsg-2ubuntu0.1) over (2:6.1.2+dfsg-2) ...
Setting up libgmp10:arm64 (2:6.1.2+dfsg-2ubuntu0.1) ...
Preparing to unpack .../libgnutls30_3.5.18-1ubuntu1.6_arm64.deb ...
Unpacking libgnutls30:arm64 (3.5.18-1ubuntu1.6) over (3.5.18-1ubuntu1.5) ...
Setting up libgnutls30:arm64 (3.5.18-1ubuntu1.6) ...
Preparing to unpack .../00-libldap-common_2.4.45+dfsg-1ubuntu1.11_all.deb ...
Unpacking libldap-common (2.4.45+dfsg-1ubuntu1.11) over (2.4.45+dfsg-1ubuntu1.10) ...
Preparing to unpack .../01-libroken18-heimdal_7.5.0+dfsg-1ubuntu0.2_arm64.deb ...
Unpacking libroken18-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) over (7.5.0+dfsg-1) ...
Preparing to unpack .../02-libasn1-8-heimdal_7.5.0+dfsg-1ubuntu0.2_arm64.deb ...
Unpacking libasn1-8-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) over (7.5.0+dfsg-1) ...
Preparing to unpack .../03-libheimbase1-heimdal_7.5.0+dfsg-1ubuntu0.2_arm64.deb ...
Unpacking libheimbase1-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) over (7.5.0+dfsg-1) ...
Preparing to unpack .../04-libhcrypto4-heimdal_7.5.0+dfsg-1ubuntu0.2_arm64.deb ...
Unpacking libhcrypto4-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) over (7.5.0+dfsg-1) ...
Preparing to unpack .../05-libwind0-heimdal_7.5.0+dfsg-1ubuntu0.2_arm64.deb ...
Unpacking libwind0-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) over (7.5.0+dfsg-1) ...
Preparing to unpack .../06-libhx509-5-heimdal_7.5.0+dfsg-1ubuntu0.2_arm64.deb ...
Unpacking libhx509-5-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) over (7.5.0+dfsg-1) ...
Preparing to unpack .../07-libsqlite3-0_3.22.0-1ubuntu0.7_arm64.deb ...
Unpacking libsqlite3-0:arm64 (3.22.0-1ubuntu0.7) over (3.22.0-1ubuntu0.4) ...
Preparing to unpack .../08-libkrb5-26-heimdal_7.5.0+dfsg-1ubuntu0.2_arm64.deb ...
Unpacking libkrb5-26-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) over (7.5.0+dfsg-1) ...
Preparing to unpack .../09-libheimntlm0-heimdal_7.5.0+dfsg-1ubuntu0.2_arm64.deb ...
Unpacking libheimntlm0-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) over (7.5.0+dfsg-1) ...
Preparing to unpack .../10-libgssapi3-heimdal_7.5.0+dfsg-1ubuntu0.2_arm64.deb ...
Unpacking libgssapi3-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) over (7.5.0+dfsg-1) ...
Preparing to unpack .../11-libsasl2-modules-db_2.1.27~101-g0780600+dfsg-3ubuntu2.4_arm64.deb ...
Unpacking libsasl2-modules-db:arm64 (2.1.27~101-g0780600+dfsg-3ubuntu2.4) over (2.1.27~101-g0780600+dfsg-3ubuntu2.3) ...
Preparing to unpack .../12-libsasl2-2_2.1.27~101-g0780600+dfsg-3ubuntu2.4_arm64.deb ...
Unpacking libsasl2-2:arm64 (2.1.27~101-g0780600+dfsg-3ubuntu2.4) over (2.1.27~101-g0780600+dfsg-3ubuntu2.3) ...
Preparing to unpack .../13-libldap-2.4-2_2.4.45+dfsg-1ubuntu1.11_arm64.deb ...
Unpacking libldap-2.4-2:arm64 (2.4.45+dfsg-1ubuntu1.11) over (2.4.45+dfsg-1ubuntu1.10) ...
Preparing to unpack .../14-libcurl3-gnutls_7.58.0-2ubuntu3.21_arm64.deb ...
Unpacking libcurl3-gnutls:arm64 (7.58.0-2ubuntu3.21) over (7.58.0-2ubuntu3.16) ...
Preparing to unpack .../15-perl-modules-5.26_5.26.1-6ubuntu0.6_all.deb ...
Unpacking perl-modules-5.26 (5.26.1-6ubuntu0.6) over (5.26.1-6ubuntu0.5) ...
Preparing to unpack .../16-libperl5.26_5.26.1-6ubuntu0.6_arm64.deb ...
Unpacking libperl5.26:arm64 (5.26.1-6ubuntu0.6) over (5.26.1-6ubuntu0.5) ...
Preparing to unpack .../17-perl_5.26.1-6ubuntu0.6_arm64.deb ...
Unpacking perl (5.26.1-6ubuntu0.6) over (5.26.1-6ubuntu0.5) ...
Preparing to unpack .../18-perl-base_5.26.1-6ubuntu0.6_arm64.deb ...
Unpacking perl-base (5.26.1-6ubuntu0.6) over (5.26.1-6ubuntu0.5) ...
Setting up perl-base (5.26.1-6ubuntu0.6) ...
Preparing to unpack .../git_1%3a2.17.1-1ubuntu0.13_arm64.deb ...
Unpacking git (1:2.17.1-1ubuntu0.13) over (1:2.17.1-1ubuntu0.9) ...
Preparing to unpack .../passwd_1%3a4.5-1ubuntu2.5_arm64.deb ...
Unpacking passwd (1:4.5-1ubuntu2.5) over (1:4.5-1ubuntu2) ...
Setting up passwd (1:4.5-1ubuntu2.5) ...
Preparing to unpack .../00-openssh-client_1%3a7.6p1-4ubuntu0.7_arm64.deb ...
Unpacking openssh-client (1:7.6p1-4ubuntu0.7) over (1:7.6p1-4ubuntu0.5) ...
Preparing to unpack .../01-snapd_2.57.5+18.04ubuntu0.1_arm64.deb ...
Unpacking snapd (2.57.5+18.04ubuntu0.1) over (2.51.1+18.04) ...
Preparing to unpack .../02-xserver-common_2%3a1.19.6-1ubuntu4.13_all.deb ...
Unpacking xserver-common (2:1.19.6-1ubuntu4.13) over (2:1.19.6-1ubuntu4.10) ...
Preparing to unpack .../03-xserver-xorg-legacy_2%3a1.19.6-1ubuntu4.13_arm64.deb ...
Unpacking xserver-xorg-legacy (2:1.19.6-1ubuntu4.13) over (2:1.19.6-1ubuntu4.10) ...
Preparing to unpack .../04-libpixman-1-0_0.34.0-2ubuntu0.1_arm64.deb ...
Unpacking libpixman-1-0:arm64 (0.34.0-2ubuntu0.1) over (0.34.0-2) ...
Preparing to unpack .../05-xserver-xorg-core_2%3a1.19.6-1ubuntu4.13_arm64.deb ...
Unpacking xserver-xorg-core (2:1.19.6-1ubuntu4.13) over (2:1.19.6-1ubuntu4.10) ...
Preparing to unpack .../06-libnss-myhostname_237-3ubuntu10.56_arm64.deb ...
Unpacking libnss-myhostname:arm64 (237-3ubuntu10.56) over (237-3ubuntu10.53) ...
Preparing to unpack .../07-systemd-sysv_237-3ubuntu10.56_arm64.deb ...
Unpacking systemd-sysv (237-3ubuntu10.56) over (237-3ubuntu10.53) ...
Preparing to unpack .../08-libpam-systemd_237-3ubuntu10.56_arm64.deb ...
Unpacking libpam-systemd:arm64 (237-3ubuntu10.56) over (237-3ubuntu10.53) ...
Preparing to unpack .../09-bluez_5.48-0ubuntu3.9_arm64.deb ...
Unpacking bluez (5.48-0ubuntu3.9) over (5.48-0ubuntu3.7) ...
Preparing to unpack .../10-udev_237-3ubuntu10.56_arm64.deb ...
Unpacking udev (237-3ubuntu10.56) over (237-3ubuntu10.53) ...
Preparing to unpack .../11-systemd_237-3ubuntu10.56_arm64.deb ...
Unpacking systemd (237-3ubuntu10.56) over (237-3ubuntu10.53) ...
Preparing to unpack .../12-libsystemd0_237-3ubuntu10.56_arm64.deb ...
Unpacking libsystemd0:arm64 (237-3ubuntu10.56) over (237-3ubuntu10.53) ...
Setting up libsystemd0:arm64 (237-3ubuntu10.56) ...
(Reading database ... 179750 files and directories currently installed.)
Preparing to unpack .../dbus-user-session_1.12.2-1ubuntu1.4_arm64.deb ...
Unpacking dbus-user-session (1.12.2-1ubuntu1.4) over (1.12.2-1ubuntu1.2) ...
Preparing to unpack .../dbus-x11_1.12.2-1ubuntu1.4_arm64.deb ...
Unpacking dbus-x11 (1.12.2-1ubuntu1.4) over (1.12.2-1ubuntu1.2) ...
Preparing to unpack .../libdbus-1-3_1.12.2-1ubuntu1.4_arm64.deb ...
Unpacking libdbus-1-3:arm64 (1.12.2-1ubuntu1.4) over (1.12.2-1ubuntu1.2) ...
Preparing to unpack .../dbus_1.12.2-1ubuntu1.4_arm64.deb ...
Unpacking dbus (1.12.2-1ubuntu1.4) over (1.12.2-1ubuntu1.2) ...
Preparing to unpack .../libudev1_237-3ubuntu10.56_arm64.deb ...
Unpacking libudev1:arm64 (237-3ubuntu10.56) over (237-3ubuntu10.53) ...
Setting up libudev1:arm64 (237-3ubuntu10.56) ...
Preparing to unpack .../0-libinput-bin_1.10.4-1ubuntu0.18.04.3_arm64.deb ...
Unpacking libinput-bin (1.10.4-1ubuntu0.18.04.3) over (1.10.4-1ubuntu0.18.04.2) ...
Preparing to unpack .../1-libinput10_1.10.4-1ubuntu0.18.04.3_arm64.deb ...
Unpacking libinput10:arm64 (1.10.4-1ubuntu0.18.04.3) over (1.10.4-1ubuntu0.18.04.2) ...
Preparing to unpack .../2-libjpeg-turbo8_1.5.2-0ubuntu5.18.04.6_arm64.deb ...
Unpacking libjpeg-turbo8:arm64 (1.5.2-0ubuntu5.18.04.6) over (1.5.2-0ubuntu5.18.04.4) ...
Preparing to unpack .../3-nvidia-l4t-weston_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-weston (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../4-nvidia-l4t-multimedia-utils_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-multimedia-utils (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../5-nvidia-l4t-x11_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-x11 (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../6-nvidia-l4t-firmware_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-firmware (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../7-nvidia-l4t-wayland_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-wayland (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../8-nvidia-l4t-init_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-init (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../9-bash_4.4.18-2ubuntu1.3_arm64.deb ...
Unpacking bash (4.4.18-2ubuntu1.3) over (4.4.18-2ubuntu1.2) ...
Setting up bash (4.4.18-2ubuntu1.3) ...
update-alternatives: error: alternative path /usr/share/man/man7/bash-builtins.7.gz doesn't exist
(Reading database ... 179751 files and directories currently installed.)
Preparing to unpack .../libext2fs2_1.44.1-1ubuntu1.4_arm64.deb ...
Unpacking libext2fs2:arm64 (1.44.1-1ubuntu1.4) over (1.44.1-1ubuntu1.3) ...
Setting up libext2fs2:arm64 (1.44.1-1ubuntu1.4) ...
Preparing to unpack .../e2fsprogs_1.44.1-1ubuntu1.4_arm64.deb ...
Unpacking e2fsprogs (1.44.1-1ubuntu1.4) over (1.44.1-1ubuntu1.3) ...
Setting up e2fsprogs (1.44.1-1ubuntu1.4) ...
update-initramfs: deferring update (trigger activated)
Preparing to unpack .../gzip_1.6-5ubuntu1.2_arm64.deb ...
Unpacking gzip (1.6-5ubuntu1.2) over (1.6-5ubuntu1.1) ...
Setting up gzip (1.6-5ubuntu1.2) ...
Preparing to unpack .../login_1%3a4.5-1ubuntu2.5_arm64.deb ...
Unpacking login (1:4.5-1ubuntu2.5) over (1:4.5-1ubuntu2) ...
Setting up login (1:4.5-1ubuntu2.5) ...
Preparing to unpack .../locales_2.27-3ubuntu1.6_all.deb ...
Unpacking locales (2.27-3ubuntu1.6) over (2.27-3ubuntu1.4) ...
Preparing to unpack .../libc-bin_2.27-3ubuntu1.6_arm64.deb ...
Unpacking libc-bin (2.27-3ubuntu1.6) over (2.27-3ubuntu1.4) ...
Setting up libc-bin (2.27-3ubuntu1.6) ...
Preparing to unpack .../00-libpython3.6_3.6.9-1~18.04ubuntu1.9_arm64.deb ...
Unpacking libpython3.6:arm64 (3.6.9-1~18.04ubuntu1.9) over (3.6.9-1~18.04ubuntu1.6) ...
Preparing to unpack .../01-python3.6_3.6.9-1~18.04ubuntu1.9_arm64.deb ...
Unpacking python3.6 (3.6.9-1~18.04ubuntu1.9) over (3.6.9-1~18.04ubuntu1.6) ...
Preparing to unpack .../02-libpython3.6-stdlib_3.6.9-1~18.04ubuntu1.9_arm64.deb ...
Unpacking libpython3.6-stdlib:arm64 (3.6.9-1~18.04ubuntu1.9) over (3.6.9-1~18.04ubuntu1.6) ...
Preparing to unpack .../03-python3.6-minimal_3.6.9-1~18.04ubuntu1.9_arm64.deb ...
Unpacking python3.6-minimal (3.6.9-1~18.04ubuntu1.9) over (3.6.9-1~18.04ubuntu1.6) ...
Preparing to unpack .../04-libpython3.6-minimal_3.6.9-1~18.04ubuntu1.9_arm64.deb ...
Unpacking libpython3.6-minimal:arm64 (3.6.9-1~18.04ubuntu1.9) over (3.6.9-1~18.04ubuntu1.6) ...
Preparing to unpack .../05-ntfs-3g_1%3a2017.3.23-2ubuntu0.18.04.5_arm64.deb ...
Unpacking ntfs-3g (1:2017.3.23-2ubuntu0.18.04.5) over (1:2017.3.23-2ubuntu0.18.04.3) ...
Preparing to unpack .../06-libntfs-3g88_1%3a2017.3.23-2ubuntu0.18.04.5_arm64.deb ...
Unpacking libntfs-3g88 (1:2017.3.23-2ubuntu0.18.04.5) over (1:2017.3.23-2ubuntu0.18.04.3) ...
Preparing to unpack .../07-nvidia-l4t-apt-source_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-apt-source (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../08-nvidia-l4t-configs_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-configs (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../09-nvidia-l4t-oem-config_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-oem-config (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../10-chromium-browser-l10n_108.0.5359.71-0ubuntu0.18.04.5_all.deb ...
Unpacking chromium-browser-l10n (108.0.5359.71-0ubuntu0.18.04.5) over (97.0.4692.71-0ubuntu0.18.04.1) ...
Preparing to unpack .../11-libcupsimage2_2.2.7-1ubuntu2.9_arm64.deb ...
Unpacking libcupsimage2:arm64 (2.2.7-1ubuntu2.9) over (2.2.7-1ubuntu2.8) ...
Preparing to unpack .../12-libcups2_2.2.7-1ubuntu2.9_arm64.deb ...
Unpacking libcups2:arm64 (2.2.7-1ubuntu2.9) over (2.2.7-1ubuntu2.8) ...
Preparing to unpack .../13-libnss3_2%3a3.35-2ubuntu2.15_arm64.deb ...
Unpacking libnss3:arm64 (2:3.35-2ubuntu2.15) over (2:3.35-2ubuntu2.13) ...
Preparing to unpack .../14-chromium-browser_108.0.5359.71-0ubuntu0.18.04.5_arm64.deb ...
Unpacking chromium-browser (108.0.5359.71-0ubuntu0.18.04.5) over (97.0.4692.71-0ubuntu0.18.04.1) ...
Preparing to unpack .../15-chromium-codecs-ffmpeg-extra_108.0.5359.71-0ubuntu0.18.04.5_arm64.deb ...
Unpacking chromium-codecs-ffmpeg-extra (108.0.5359.71-0ubuntu0.18.04.5) over (97.0.4692.71-0ubuntu0.18.04.1) ...
Preparing to unpack .../16-imagemagick-6-common_8%3a6.9.7.4+dfsg-16ubuntu6.14_all.deb ...
Unpacking imagemagick-6-common (8:6.9.7.4+dfsg-16ubuntu6.14) over (8:6.9.7.4+dfsg-16ubuntu6.12) ...
Preparing to unpack .../17-libfreetype6_2.8.1-2ubuntu2.2_arm64.deb ...
Unpacking libfreetype6:arm64 (2.8.1-2ubuntu2.2) over (2.8.1-2ubuntu2.1) ...
Preparing to unpack .../18-libjbig0_2.1-3.1ubuntu0.18.04.1_arm64.deb ...
Unpacking libjbig0:arm64 (2.1-3.1ubuntu0.18.04.1) over (2.1-3.1build1) ...
Preparing to unpack .../19-libtiff5_4.0.9-5ubuntu0.9_arm64.deb ...
Unpacking libtiff5:arm64 (4.0.9-5ubuntu0.9) over (4.0.9-5ubuntu0.4) ...
Preparing to unpack .../20-libmagickcore-6.q16-3_8%3a6.9.7.4+dfsg-16ubuntu6.14_arm64.deb ...
Unpacking libmagickcore-6.q16-3:arm64 (8:6.9.7.4+dfsg-16ubuntu6.14) over (8:6.9.7.4+dfsg-16ubuntu6.12) ...
Preparing to unpack .../21-libmagickwand-6.q16-3_8%3a6.9.7.4+dfsg-16ubuntu6.14_arm64.deb ...
Unpacking libmagickwand-6.q16-3:arm64 (8:6.9.7.4+dfsg-16ubuntu6.14) over (8:6.9.7.4+dfsg-16ubuntu6.12) ...
Preparing to unpack .../22-libsmbclient_2%3a4.7.6+dfsg~ubuntu-0ubuntu2.29_arm64.deb ...
Unpacking libsmbclient:arm64 (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) over (2:4.7.6+dfsg~ubuntu-0ubuntu2.27) ...
Preparing to unpack .../23-python2.7-dev_2.7.17-1~18.04ubuntu1.10_arm64.deb ...
Unpacking python2.7-dev (2.7.17-1~18.04ubuntu1.10) over (2.7.17-1~18.04ubuntu1.6) ...
Preparing to unpack .../24-python2.7_2.7.17-1~18.04ubuntu1.10_arm64.deb ...
Unpacking python2.7 (2.7.17-1~18.04ubuntu1.10) over (2.7.17-1~18.04ubuntu1.6) ...
Preparing to unpack .../25-libpython2.7-dev_2.7.17-1~18.04ubuntu1.10_arm64.deb ...
Unpacking libpython2.7-dev:arm64 (2.7.17-1~18.04ubuntu1.10) over (2.7.17-1~18.04ubuntu1.6) ...
Preparing to unpack .../26-libpython2.7_2.7.17-1~18.04ubuntu1.10_arm64.deb ...
Unpacking libpython2.7:arm64 (2.7.17-1~18.04ubuntu1.10) over (2.7.17-1~18.04ubuntu1.6) ...
Preparing to unpack .../27-libpython2.7-stdlib_2.7.17-1~18.04ubuntu1.10_arm64.deb ...
Unpacking libpython2.7-stdlib:arm64 (2.7.17-1~18.04ubuntu1.10) over (2.7.17-1~18.04ubuntu1.6) ...
Preparing to unpack .../28-python2.7-minimal_2.7.17-1~18.04ubuntu1.10_arm64.deb ...
Unpacking python2.7-minimal (2.7.17-1~18.04ubuntu1.10) over (2.7.17-1~18.04ubuntu1.6) ...
Preparing to unpack .../29-libpython2.7-minimal_2.7.17-1~18.04ubuntu1.10_arm64.deb ...
Unpacking libpython2.7-minimal:arm64 (2.7.17-1~18.04ubuntu1.10) over (2.7.17-1~18.04ubuntu1.6) ...
Preparing to unpack .../30-samba-libs_2%3a4.7.6+dfsg~ubuntu-0ubuntu2.29_arm64.deb ...
Unpacking samba-libs:arm64 (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) over (2:4.7.6+dfsg~ubuntu-0ubuntu2.27) ...
Preparing to unpack .../31-libwbclient0_2%3a4.7.6+dfsg~ubuntu-0ubuntu2.29_arm64.deb ...
Unpacking libwbclient0:arm64 (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) over (2:4.7.6+dfsg~ubuntu-0ubuntu2.27) ...
Preparing to unpack .../32-nvidia-l4t-gputools_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-gputools (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Selecting previously unselected package python3-colorama.
Preparing to unpack .../33-python3-colorama_0.3.7-1_all.deb ...
Unpacking python3-colorama (0.3.7-1) ...
Selecting previously unselected package python3-click.
Preparing to unpack .../34-python3-click_6.7-3_all.deb ...
Unpacking python3-click (6.7-3) ...
Preparing to unpack .../35-ubuntu-drivers-common_1%3a0.8.6.3~0.18.04.2_arm64.deb ...
Unpacking ubuntu-drivers-common (1:0.8.6.3~0.18.04.2) over (1:0.5.2.5) ...
Preparing to unpack .../36-libsepol1_2.7-1ubuntu0.1_arm64.deb ...
Unpacking libsepol1:arm64 (2.7-1ubuntu0.1) over (2.7-1) ...
Setting up libsepol1:arm64 (2.7-1ubuntu0.1) ...
(Reading database ... 179558 files and directories currently installed.)
Preparing to unpack .../libss2_1.44.1-1ubuntu1.4_arm64.deb ...
Unpacking libss2:arm64 (1.44.1-1ubuntu1.4) over (1.44.1-1ubuntu1.3) ...
Setting up libss2:arm64 (1.44.1-1ubuntu1.4) ...
Preparing to unpack .../00-gpg-wks-client_2.2.4-1ubuntu1.6_arm64.deb ...
Unpacking gpg-wks-client (2.2.4-1ubuntu1.6) over (2.2.4-1ubuntu1.4) ...
Preparing to unpack .../01-dirmngr_2.2.4-1ubuntu1.6_arm64.deb ...
Unpacking dirmngr (2.2.4-1ubuntu1.6) over (2.2.4-1ubuntu1.4) ...
Preparing to unpack .../02-gpg_2.2.4-1ubuntu1.6_arm64.deb ...
Unpacking gpg (2.2.4-1ubuntu1.6) over (2.2.4-1ubuntu1.4) ...
Preparing to unpack .../03-gnupg-utils_2.2.4-1ubuntu1.6_arm64.deb ...
Unpacking gnupg-utils (2.2.4-1ubuntu1.6) over (2.2.4-1ubuntu1.4) ...
Preparing to unpack .../04-gnupg-l10n_2.2.4-1ubuntu1.6_all.deb ...
Unpacking gnupg-l10n (2.2.4-1ubuntu1.6) over (2.2.4-1ubuntu1.4) ...
Preparing to unpack .../05-gpg-agent_2.2.4-1ubuntu1.6_arm64.deb ...
Unpacking gpg-agent (2.2.4-1ubuntu1.6) over (2.2.4-1ubuntu1.4) ...
Preparing to unpack .../06-gpgsm_2.2.4-1ubuntu1.6_arm64.deb ...
Unpacking gpgsm (2.2.4-1ubuntu1.6) over (2.2.4-1ubuntu1.4) ...
Preparing to unpack .../07-gpgconf_2.2.4-1ubuntu1.6_arm64.deb ...
Unpacking gpgconf (2.2.4-1ubuntu1.6) over (2.2.4-1ubuntu1.4) ...
Preparing to unpack .../08-gnupg_2.2.4-1ubuntu1.6_arm64.deb ...
Unpacking gnupg (2.2.4-1ubuntu1.6) over (2.2.4-1ubuntu1.4) ...
Preparing to unpack .../09-gpg-wks-server_2.2.4-1ubuntu1.6_arm64.deb ...
Unpacking gpg-wks-server (2.2.4-1ubuntu1.6) over (2.2.4-1ubuntu1.4) ...
Preparing to unpack .../10-libksba8_1.3.5-2ubuntu0.18.04.1_arm64.deb ...
Unpacking libksba8:arm64 (1.3.5-2ubuntu0.18.04.1) over (1.3.5-2) ...
Preparing to unpack .../11-gpgv_2.2.4-1ubuntu1.6_arm64.deb ...
Unpacking gpgv (2.2.4-1ubuntu1.6) over (2.2.4-1ubuntu1.4) ...
Setting up gpgv (2.2.4-1ubuntu1.6) ...
Preparing to unpack .../000-distro-info-data_0.37ubuntu0.15_all.deb ...
Unpacking distro-info-data (0.37ubuntu0.15) over (0.37ubuntu0.13) ...
Preparing to unpack .../001-libisc-export169_1%3a9.11.3+dfsg-1ubuntu1.18_arm64.deb ...
Unpacking libisc-export169:arm64 (1:9.11.3+dfsg-1ubuntu1.18) over (1:9.11.3+dfsg-1ubuntu1.16) ...
Preparing to unpack .../002-libdns-export1100_1%3a9.11.3+dfsg-1ubuntu1.18_arm64.deb ...
Unpacking libdns-export1100 (1:9.11.3+dfsg-1ubuntu1.18) over (1:9.11.3+dfsg-1ubuntu1.16) ...
Preparing to unpack .../003-isc-dhcp-client_4.3.5-3ubuntu7.4_arm64.deb ...
Unpacking isc-dhcp-client (4.3.5-3ubuntu7.4) over (4.3.5-3ubuntu7.3) ...
Preparing to unpack .../004-libisccfg-export160_1%3a9.11.3+dfsg-1ubuntu1.18_arm64.deb ...
Unpacking libisccfg-export160 (1:9.11.3+dfsg-1ubuntu1.18) over (1:9.11.3+dfsg-1ubuntu1.16) ...
Preparing to unpack .../005-libirs-export160_1%3a9.11.3+dfsg-1ubuntu1.18_arm64.deb ...
Unpacking libirs-export160 (1:9.11.3+dfsg-1ubuntu1.18) over (1:9.11.3+dfsg-1ubuntu1.16) ...
Preparing to unpack .../006-isc-dhcp-server_4.3.5-3ubuntu7.4_arm64.deb ...
Unpacking isc-dhcp-server (4.3.5-3ubuntu7.4) over (4.3.5-3ubuntu7.3) ...
Preparing to unpack .../007-isc-dhcp-common_4.3.5-3ubuntu7.4_arm64.deb ...
Unpacking isc-dhcp-common (4.3.5-3ubuntu7.4) over (4.3.5-3ubuntu7.3) ...
Preparing to unpack .../008-klibc-utils_2.0.4-9ubuntu2.2_arm64.deb ...
Unpacking klibc-utils (2.0.4-9ubuntu2.2) over (2.0.4-9ubuntu2) ...
Preparing to unpack .../009-libklibc_2.0.4-9ubuntu2.2_arm64.deb ...
Unpacking libklibc (2.0.4-9ubuntu2.2) over (2.0.4-9ubuntu2) ...
Preparing to unpack .../010-libfribidi0_0.19.7-2ubuntu0.1_arm64.deb ...
Unpacking libfribidi0:arm64 (0.19.7-2ubuntu0.1) over (0.19.7-2) ...
Preparing to unpack .../011-networkd-dispatcher_1.7-0ubuntu3.5_all.deb ...
Unpacking networkd-dispatcher (1.7-0ubuntu3.5) over (1.7-0ubuntu3.3) ...
Preparing to unpack .../012-rsyslog_8.32.0-1ubuntu4.2_arm64.deb ...
Unpacking rsyslog (8.32.0-1ubuntu4.2) over (8.32.0-1ubuntu4) ...
Preparing to unpack .../013-tzdata_2022g-0ubuntu0.18.04_all.deb ...
Unpacking tzdata (2022g-0ubuntu0.18.04) over (2021e-0ubuntu0.18.04) ...
Preparing to unpack .../014-vim_2%3a8.0.1453-1ubuntu1.9_arm64.deb ...
Unpacking vim (2:8.0.1453-1ubuntu1.9) over (2:8.0.1453-1ubuntu1.8) ...
Preparing to unpack .../015-vim-runtime_2%3a8.0.1453-1ubuntu1.9_all.deb ...
Unpacking vim-runtime (2:8.0.1453-1ubuntu1.9) over (2:8.0.1453-1ubuntu1.8) ...
Preparing to unpack .../016-xxd_2%3a8.0.1453-1ubuntu1.9_arm64.deb ...
Unpacking xxd (2:8.0.1453-1ubuntu1.9) over (2:8.0.1453-1ubuntu1.8) ...
Preparing to unpack .../017-vim-common_2%3a8.0.1453-1ubuntu1.9_all.deb ...
Unpacking vim-common (2:8.0.1453-1ubuntu1.9) over (2:8.0.1453-1ubuntu1.8) ...
Preparing to unpack .../018-xz-utils_5.2.2-1.3ubuntu0.1_arm64.deb ...
Unpacking xz-utils (5.2.2-1.3ubuntu0.1) over (5.2.2-1.3) ...
Preparing to unpack .../019-bind9-host_1%3a9.11.3+dfsg-1ubuntu1.18_arm64.deb ...
Unpacking bind9-host (1:9.11.3+dfsg-1ubuntu1.18) over (1:9.11.3+dfsg-1ubuntu1.16) ...
Preparing to unpack .../020-libbind9-160_1%3a9.11.3+dfsg-1ubuntu1.18_arm64.deb ...
Unpacking libbind9-160:arm64 (1:9.11.3+dfsg-1ubuntu1.18) over (1:9.11.3+dfsg-1ubuntu1.16) ...
Preparing to unpack .../021-libisccfg160_1%3a9.11.3+dfsg-1ubuntu1.18_arm64.deb ...
Unpacking libisccfg160:arm64 (1:9.11.3+dfsg-1ubuntu1.18) over (1:9.11.3+dfsg-1ubuntu1.16) ...
Preparing to unpack .../022-libisccc160_1%3a9.11.3+dfsg-1ubuntu1.18_arm64.deb ...
Unpacking libisccc160:arm64 (1:9.11.3+dfsg-1ubuntu1.18) over (1:9.11.3+dfsg-1ubuntu1.16) ...
Preparing to unpack .../023-libdns1100_1%3a9.11.3+dfsg-1ubuntu1.18_arm64.deb ...
Unpacking libdns1100:arm64 (1:9.11.3+dfsg-1ubuntu1.18) over (1:9.11.3+dfsg-1ubuntu1.16) ...
Preparing to unpack .../024-libisc169_1%3a9.11.3+dfsg-1ubuntu1.18_arm64.deb ...
Unpacking libisc169:arm64 (1:9.11.3+dfsg-1ubuntu1.18) over (1:9.11.3+dfsg-1ubuntu1.16) ...
Preparing to unpack .../025-liblwres160_1%3a9.11.3+dfsg-1ubuntu1.18_arm64.deb ...
Unpacking liblwres160:arm64 (1:9.11.3+dfsg-1ubuntu1.18) over (1:9.11.3+dfsg-1ubuntu1.16) ...
Preparing to unpack .../026-libkeyutils1_1.5.9-9.2ubuntu2.1_arm64.deb ...
Unpacking libkeyutils1:arm64 (1.5.9-9.2ubuntu2.1) over (1.5.9-9.2ubuntu2) ...
Preparing to unpack .../027-multiarch-support_2.27-3ubuntu1.6_arm64.deb ...
Unpacking multiarch-support (2.27-3ubuntu1.6) over (2.27-3ubuntu1.4) ...
Preparing to unpack .../028-nvidia-l4t-core_32.7.3-20221122092935_arm64.deb ...
Unpacking nvidia-l4t-core (32.7.3-20221122092935) over (32.7.1-20220219090432) ...
Preparing to unpack .../029-rsync_3.1.2-2.1ubuntu1.5_arm64.deb ...
Unpacking rsync (3.1.2-2.1ubuntu1.5) over (3.1.2-2.1ubuntu1.2) ...
Preparing to unpack .../030-grub-common_2.02-2ubuntu8.25_arm64.deb ...
Unpacking grub-common (2.02-2ubuntu8.25) over (2.02-2ubuntu8.23) ...
Preparing to unpack .../031-python3-problem-report_2.20.9-0ubuntu7.28_all.deb ...
Unpacking python3-problem-report (2.20.9-0ubuntu7.28) over (2.20.9-0ubuntu7.27) ...
Preparing to unpack .../032-python3-apport_2.20.9-0ubuntu7.28_all.deb ...
Unpacking python3-apport (2.20.9-0ubuntu7.28) over (2.20.9-0ubuntu7.27) ...
Preparing to unpack .../033-apport_2.20.9-0ubuntu7.28_all.deb ...
Unpacking apport (2.20.9-0ubuntu7.28) over (2.20.9-0ubuntu7.27) ...
Preparing to unpack .../034-apport-gtk_2.20.9-0ubuntu7.28_all.deb ...
Unpacking apport-gtk (2.20.9-0ubuntu7.28) over (2.20.9-0ubuntu7.27) ...
Preparing to unpack .../035-binutils-common_2.30-21ubuntu1~18.04.8_arm64.deb ...
Unpacking binutils-common:arm64 (2.30-21ubuntu1~18.04.8) over (2.30-21ubuntu1~18.04.7) ...
Preparing to unpack .../036-binutils_2.30-21ubuntu1~18.04.8_arm64.deb ...
Unpacking binutils (2.30-21ubuntu1~18.04.8) over (2.30-21ubuntu1~18.04.7) ...
Preparing to unpack .../037-binutils-aarch64-linux-gnu_2.30-21ubuntu1~18.04.8_arm64.deb ...
Unpacking binutils-aarch64-linux-gnu (2.30-21ubuntu1~18.04.8) over (2.30-21ubuntu1~18.04.7) ...
Preparing to unpack .../038-libbinutils_2.30-21ubuntu1~18.04.8_arm64.deb ...
Unpacking libbinutils:arm64 (2.30-21ubuntu1~18.04.8) over (2.30-21ubuntu1~18.04.7) ...
Preparing to unpack .../039-bluez-obexd_5.48-0ubuntu3.9_arm64.deb ...
Unpacking bluez-obexd (5.48-0ubuntu3.9) over (5.48-0ubuntu3.7) ...
Preparing to unpack .../040-runc_1.1.0-0ubuntu1~18.04.1_arm64.deb ...
Unpacking runc (1.1.0-0ubuntu1~18.04.1) over (1.0.1-0ubuntu2~18.04.1) ...
Preparing to unpack .../041-containerd_1.5.9-0ubuntu1~18.04.2_arm64.deb ...
Unpacking containerd (1.5.9-0ubuntu1~18.04.2) over (1.5.5-0ubuntu3~18.04.1) ...
Preparing to unpack .../042-dnsmasq-base_2.79-1ubuntu0.6_arm64.deb ...
Unpacking dnsmasq-base (2.79-1ubuntu0.6) over (2.79-1ubuntu0.5) ...
Preparing to unpack .../043-docker.io_20.10.12-0ubuntu2~18.04.1_arm64.deb ...
Unpacking docker.io (20.10.12-0ubuntu2~18.04.1) over (20.10.7-0ubuntu5~18.04.3) ...
Preparing to unpack .../044-dpkg-dev_1.19.0.5ubuntu2.4_all.deb ...
Unpacking dpkg-dev (1.19.0.5ubuntu2.4) over (1.19.0.5ubuntu2.3) ...
Preparing to unpack .../045-libdpkg-perl_1.19.0.5ubuntu2.4_all.deb ...
Unpacking libdpkg-perl (1.19.0.5ubuntu2.4) over (1.19.0.5ubuntu2.3) ...
Preparing to unpack .../046-libavutil55_7%3a3.4.11-0ubuntu0.1_arm64.deb ...
Unpacking libavutil55:arm64 (7:3.4.11-0ubuntu0.1) over (7:3.4.8-0ubuntu0.2) ...
Preparing to unpack .../047-libspeex1_1.2~rc1.2-1ubuntu2.1_arm64.deb ...
Unpacking libspeex1:arm64 (1.2~rc1.2-1ubuntu2.1) over (1.2~rc1.2-1ubuntu2) ...
Preparing to unpack .../048-libswresample2_7%3a3.4.11-0ubuntu0.1_arm64.deb ...
Unpacking libswresample2:arm64 (7:3.4.11-0ubuntu0.1) over (7:3.4.8-0ubuntu0.2) ...
Preparing to unpack .../049-libavcodec57_7%3a3.4.11-0ubuntu0.1_arm64.deb ...
Unpacking libavcodec57:arm64 (7:3.4.11-0ubuntu0.1) over (7:3.4.8-0ubuntu0.2) ...
Preparing to unpack .../050-libavformat57_7%3a3.4.11-0ubuntu0.1_arm64.deb ...
Unpacking libavformat57:arm64 (7:3.4.11-0ubuntu0.1) over (7:3.4.8-0ubuntu0.2) ...
Preparing to unpack .../051-libavresample3_7%3a3.4.11-0ubuntu0.1_arm64.deb ...
Unpacking libavresample3:arm64 (7:3.4.11-0ubuntu0.1) over (7:3.4.8-0ubuntu0.2) ...
Preparing to unpack .../052-libpostproc54_7%3a3.4.11-0ubuntu0.1_arm64.deb ...
Unpacking libpostproc54:arm64 (7:3.4.11-0ubuntu0.1) over (7:3.4.8-0ubuntu0.2) ...
Preparing to unpack .../053-libswscale4_7%3a3.4.11-0ubuntu0.1_arm64.deb ...
Unpacking libswscale4:arm64 (7:3.4.11-0ubuntu0.1) over (7:3.4.8-0ubuntu0.2) ...
Preparing to unpack .../054-libavfilter6_7%3a3.4.11-0ubuntu0.1_arm64.deb ...
Unpacking libavfilter6:arm64 (7:3.4.11-0ubuntu0.1) over (7:3.4.8-0ubuntu0.2) ...
Preparing to unpack .../055-libavdevice57_7%3a3.4.11-0ubuntu0.1_arm64.deb ...
Unpacking libavdevice57:arm64 (7:3.4.11-0ubuntu0.1) over (7:3.4.8-0ubuntu0.2) ...
Preparing to unpack .../056-ffmpeg_7%3a3.4.11-0ubuntu0.1_arm64.deb ...
Unpacking ffmpeg (7:3.4.11-0ubuntu0.1) over (7:3.4.8-0ubuntu0.2) ...
Preparing to unpack .../057-fonts-opensymbol_2%3a102.10+LibO6.0.7-0ubuntu0.18.04.12_all.deb ...
Unpacking fonts-opensymbol (2:102.10+LibO6.0.7-0ubuntu0.18.04.12) over (2:102.10+LibO6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../058-ghostscript-x_9.26~dfsg+0-0ubuntu0.18.04.17_arm64.deb ...
Unpacking ghostscript-x (9.26~dfsg+0-0ubuntu0.18.04.17) over (9.26~dfsg+0-0ubuntu0.18.04.15) ...
Preparing to unpack .../059-ghostscript_9.26~dfsg+0-0ubuntu0.18.04.17_arm64.deb ...
Unpacking ghostscript (9.26~dfsg+0-0ubuntu0.18.04.17) over (9.26~dfsg+0-0ubuntu0.18.04.15) ...
Preparing to unpack .../060-libgs9_9.26~dfsg+0-0ubuntu0.18.04.17_arm64.deb ...
Unpacking libgs9:arm64 (9.26~dfsg+0-0ubuntu0.18.04.17) over (9.26~dfsg+0-0ubuntu0.18.04.15) ...
Preparing to unpack .../061-libgs9-common_9.26~dfsg+0-0ubuntu0.18.04.17_all.deb ...
Unpacking libgs9-common (9.26~dfsg+0-0ubuntu0.18.04.17) over (9.26~dfsg+0-0ubuntu0.18.04.15) ...
Preparing to unpack .../062-libnotify4_0.7.7-3ubuntu0.18.04.1_arm64.deb ...
Unpacking libnotify4:arm64 (0.7.7-3ubuntu0.18.04.1) over (0.7.7-3) ...
Preparing to unpack .../063-gir1.2-notify-0.7_0.7.7-3ubuntu0.18.04.1_arm64.deb ...
Unpacking gir1.2-notify-0.7:arm64 (0.7.7-3ubuntu0.18.04.1) over (0.7.7-3) ...
Preparing to unpack .../064-gstreamer1.0-gtk3_1.14.5-0ubuntu1~18.04.3_arm64.deb ...
Unpacking gstreamer1.0-gtk3:arm64 (1.14.5-0ubuntu1~18.04.3) over (1.14.5-0ubuntu1~18.04.2) ...
Preparing to unpack .../065-libflac8_1.3.2-1ubuntu0.1_arm64.deb ...
Unpacking libflac8:arm64 (1.3.2-1ubuntu0.1) over (1.3.2-1) ...
Preparing to unpack .../066-gstreamer1.0-plugins-good_1.14.5-0ubuntu1~18.04.3_arm64.deb ...
Unpacking gstreamer1.0-plugins-good:arm64 (1.14.5-0ubuntu1~18.04.3) over (1.14.5-0ubuntu1~18.04.2) ...
Preparing to unpack .../067-libgstreamer-plugins-good1.0-0_1.14.5-0ubuntu1~18.04.3_arm64.deb ...
Unpacking libgstreamer-plugins-good1.0-0:arm64 (1.14.5-0ubuntu1~18.04.3) over (1.14.5-0ubuntu1~18.04.2) ...
Preparing to unpack .../068-gstreamer1.0-pulseaudio_1.14.5-0ubuntu1~18.04.3_arm64.deb ...
Unpacking gstreamer1.0-pulseaudio:arm64 (1.14.5-0ubuntu1~18.04.3) over (1.14.5-0ubuntu1~18.04.2) ...
Preparing to unpack .../069-imagemagick-6.q16_8%3a6.9.7.4+dfsg-16ubuntu6.14_arm64.deb ...
Unpacking imagemagick-6.q16 (8:6.9.7.4+dfsg-16ubuntu6.14) over (8:6.9.7.4+dfsg-16ubuntu6.12) ...
Preparing to unpack .../070-imagemagick_8%3a6.9.7.4+dfsg-16ubuntu6.14_arm64.deb ...
Unpacking imagemagick (8:6.9.7.4+dfsg-16ubuntu6.14) over (8:6.9.7.4+dfsg-16ubuntu6.12) ...
Preparing to unpack .../071-keyutils_1.5.9-9.2ubuntu2.1_arm64.deb ...
Unpacking keyutils (1.5.9-9.2ubuntu2.1) over (1.5.9-9.2ubuntu2) ...
Preparing to unpack .../072-libbluetooth3_5.48-0ubuntu3.9_arm64.deb ...
Unpacking libbluetooth3:arm64 (5.48-0ubuntu3.9) over (5.48-0ubuntu3.7) ...
Preparing to unpack .../073-libcurl4_7.58.0-2ubuntu3.21_arm64.deb ...
Unpacking libcurl4:arm64 (7.58.0-2ubuntu3.21) over (7.58.0-2ubuntu3.16) ...
Preparing to unpack .../074-libexempi3_2.4.5-2ubuntu0.1_arm64.deb ...
Unpacking libexempi3:arm64 (2.4.5-2ubuntu0.1) over (2.4.5-2) ...
Preparing to unpack .../075-libwinpr2-2_2.2.0+dfsg1-0ubuntu0.18.04.4_arm64.deb ...
Unpacking libwinpr2-2:arm64 (2.2.0+dfsg1-0ubuntu0.18.04.4) over (2.2.0+dfsg1-0ubuntu0.18.04.2) ...
Preparing to unpack .../076-libfreerdp2-2_2.2.0+dfsg1-0ubuntu0.18.04.4_arm64.deb ...
Unpacking libfreerdp2-2:arm64 (2.2.0+dfsg1-0ubuntu0.18.04.4) over (2.2.0+dfsg1-0ubuntu0.18.04.2) ...
Preparing to unpack .../077-libfreerdp-client2-2_2.2.0+dfsg1-0ubuntu0.18.04.4_arm64.deb ...
Unpacking libfreerdp-client2-2:arm64 (2.2.0+dfsg1-0ubuntu0.18.04.4) over (2.2.0+dfsg1-0ubuntu0.18.04.2) ...
Preparing to unpack .../078-libhttp-daemon-perl_6.01-1ubuntu0.1_all.deb ...
Unpacking libhttp-daemon-perl (6.01-1ubuntu0.1) over (6.01-1) ...
Preparing to unpack .../079-libice-dev_2%3a1.0.9-2ubuntu0.18.04.1_arm64.deb ...
Unpacking libice-dev:arm64 (2:1.0.9-2ubuntu0.18.04.1) over (2:1.0.9-2) ...
Preparing to unpack .../080-libice6_2%3a1.0.9-2ubuntu0.18.04.1_arm64.deb ...
Unpacking libice6:arm64 (2:1.0.9-2ubuntu0.18.04.1) over (2:1.0.9-2) ...
Preparing to unpack .../081-libjpeg-turbo-progs_1.5.2-0ubuntu5.18.04.6_arm64.deb ...
Unpacking libjpeg-turbo-progs (1.5.2-0ubuntu5.18.04.6) over (1.5.2-0ubuntu5.18.04.4) ...
Preparing to unpack .../082-liblouis-data_3.5.0-1ubuntu0.4_all.deb ...
Unpacking liblouis-data (3.5.0-1ubuntu0.4) over (3.5.0-1ubuntu0.3) ...
Preparing to unpack .../083-liblouis14_3.5.0-1ubuntu0.4_arm64.deb ...
Unpacking liblouis14:arm64 (3.5.0-1ubuntu0.4) over (3.5.0-1ubuntu0.3) ...
Preparing to unpack .../084-libmagickcore-6.q16-3-extra_8%3a6.9.7.4+dfsg-16ubuntu6.14_arm64.deb ...
Unpacking libmagickcore-6.q16-3-extra:arm64 (8:6.9.7.4+dfsg-16ubuntu6.14) over (8:6.9.7.4+dfsg-16ubuntu6.12) ...
Preparing to unpack .../085-libmysqlclient20_5.7.40-0ubuntu0.18.04.1_arm64.deb ...
Unpacking libmysqlclient20:arm64 (5.7.40-0ubuntu0.18.04.1) over (5.7.36-0ubuntu0.18.04.1) ...
Preparing to unpack .../086-libnotify-bin_0.7.7-3ubuntu0.18.04.1_arm64.deb ...
Unpacking libnotify-bin (0.7.7-3ubuntu0.18.04.1) over (0.7.7-3) ...
Preparing to unpack .../087-libnvinfer8_8.2.1-1+cuda10.2_arm64.deb ...
Unpacking libnvinfer8 (8.2.1-1+cuda10.2) over (8.2.1-1+cuda10.2) ...
Preparing to unpack .../088-libnvinfer-dev_8.2.1-1+cuda10.2_arm64.deb ...
Unpacking libnvinfer-dev (8.2.1-1+cuda10.2) over (8.2.1-1+cuda10.2) ...
Preparing to unpack .../089-poppler-utils_0.62.0-2ubuntu2.14_arm64.deb ...
Unpacking poppler-utils (0.62.0-2ubuntu2.14) over (0.62.0-2ubuntu2.12) ...
Preparing to unpack .../090-libpoppler-glib8_0.62.0-2ubuntu2.14_arm64.deb ...
Unpacking libpoppler-glib8:arm64 (0.62.0-2ubuntu2.14) over (0.62.0-2ubuntu2.12) ...
Preparing to unpack .../091-libpoppler73_0.62.0-2ubuntu2.14_arm64.deb ...
Unpacking libpoppler73:arm64 (0.62.0-2ubuntu2.14) over (0.62.0-2ubuntu2.12) ...
Preparing to unpack .../092-libraw16_0.18.8-1ubuntu0.4_arm64.deb ...
Unpacking libraw16:arm64 (0.18.8-1ubuntu0.4) over (0.18.8-1ubuntu0.3) ...
Preparing to unpack .../093-ure_6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking ure (6.0.7-0ubuntu0.18.04.12) over (6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../094-uno-libs3_6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking uno-libs3 (6.0.7-0ubuntu0.18.04.12) over (6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../095-libreoffice-calc_1%3a6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking libreoffice-calc (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../096-libreoffice-impress_1%3a6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking libreoffice-impress (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../097-libreoffice-draw_1%3a6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking libreoffice-draw (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../098-libreoffice-gnome_1%3a6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking libreoffice-gnome (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../099-libreoffice-gtk3_1%3a6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking libreoffice-gtk3 (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../100-python3-uno_1%3a6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking python3-uno (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../101-libreoffice-base-core_1%3a6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking libreoffice-base-core (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../102-libreoffice-math_1%3a6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking libreoffice-math (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../103-libreoffice-pdfimport_1%3a6.0.7-0ubuntu0.18.04.12_all.deb ...
Unpacking libreoffice-pdfimport (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../104-libreoffice-style-breeze_1%3a6.0.7-0ubuntu0.18.04.12_all.deb ...
Unpacking libreoffice-style-breeze (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../105-libreoffice-style-tango_1%3a6.0.7-0ubuntu0.18.04.12_all.deb ...
Unpacking libreoffice-style-tango (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../106-libreoffice-style-galaxy_1%3a6.0.7-0ubuntu0.18.04.12_all.deb ...
Unpacking libreoffice-style-galaxy (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../107-libreoffice-common_1%3a6.0.7-0ubuntu0.18.04.12_all.deb ...
Unpacking libreoffice-common (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../108-libreoffice-ogltrans_1%3a6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking libreoffice-ogltrans (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../109-libreoffice-avmedia-backend-gstreamer_1%3a6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking libreoffice-avmedia-backend-gstreamer (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../110-libreoffice-writer_1%3a6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking libreoffice-writer (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../111-libreoffice-core_1%3a6.0.7-0ubuntu0.18.04.12_arm64.deb ...
Unpacking libreoffice-core (1:6.0.7-0ubuntu0.18.04.12) over (1:6.0.7-0ubuntu0.18.04.10) ...
Preparing to unpack .../112-libxslt1.1_1.1.29-5ubuntu0.3_arm64.deb ...
Unpacking libxslt1.1:arm64 (1.1.29-5ubuntu0.3) over (1.1.29-5ubuntu0.2) ...
Preparing to unpack .../113-libsasl2-modules_2.1.27~101-g0780600+dfsg-3ubuntu2.4_arm64.deb ...
Unpacking libsasl2-modules:arm64 (2.1.27~101-g0780600+dfsg-3ubuntu2.4) over (2.1.27~101-g0780600+dfsg-3ubuntu2.3) ...
Preparing to unpack .../114-libsdl1.2debian_1.2.15+dfsg2-0.1ubuntu0.2_arm64.deb ...
Unpacking libsdl1.2debian:arm64 (1.2.15+dfsg2-0.1ubuntu0.2) over (1.2.15+dfsg2-0.1ubuntu0.1) ...
Preparing to unpack .../115-libsensors4_1%3a3.4.0-4ubuntu0.1_arm64.deb ...
Unpacking libsensors4:arm64 (1:3.4.0-4ubuntu0.1) over (1:3.4.0-4) ...
Preparing to unpack .../116-libsnmp-base_5.7.3+dfsg-1.8ubuntu3.7_all.deb ...
Unpacking libsnmp-base (5.7.3+dfsg-1.8ubuntu3.7) over (5.7.3+dfsg-1.8ubuntu3.6) ...
Preparing to unpack .../117-libsnmp30_5.7.3+dfsg-1.8ubuntu3.7_arm64.deb ...
Unpacking libsnmp30:arm64 (5.7.3+dfsg-1.8ubuntu3.7) over (5.7.3+dfsg-1.8ubuntu3.6) ...
Preparing to unpack .../118-libspeexdsp1_1.2~rc1.2-1ubuntu2.1_arm64.deb ...
Unpacking libspeexdsp1:arm64 (1.2~rc1.2-1ubuntu2.1) over (1.2~rc1.2-1ubuntu2) ...
Preparing to unpack .../119-linux-firmware_1.173.21_all.deb ...
Unpacking linux-firmware (1.173.21) over (1.173.20) ...
Preparing to unpack .../120-python-pil_5.1.0-1ubuntu0.8_arm64.deb ...
Unpacking python-pil:arm64 (5.1.0-1ubuntu0.8) over (5.1.0-1ubuntu0.7) ...
Preparing to unpack .../121-python3-jwt_1.5.3+ds1-1ubuntu0.1_all.deb ...
Unpacking python3-jwt (1.5.3+ds1-1ubuntu0.1) over (1.5.3+ds1-1) ...
Preparing to unpack .../122-python3-mako_1.0.7+ds1-1ubuntu0.2_all.deb ...
Unpacking python3-mako (1.0.7+ds1-1ubuntu0.2) over (1.0.7+ds1-1) ...
Preparing to unpack .../123-thunderbird_1%3a102.4.2+build2-0ubuntu0.18.04.1_arm64.deb ...
Unpacking thunderbird (1:102.4.2+build2-0ubuntu0.18.04.1) over (1:91.5.0+build1-0ubuntu0.18.04.1) ...
Preparing to unpack .../124-thunderbird-gnome-support_1%3a102.4.2+build2-0ubuntu0.18.04.1_arm64.deb ...
Unpacking thunderbird-gnome-support (1:102.4.2+build2-0ubuntu0.18.04.1) over (1:91.5.0+build1-0ubuntu0.18.04.1) ...
Preparing to unpack .../125-unzip_6.0-21ubuntu1.2_arm64.deb ...
Unpacking unzip (6.0-21ubuntu1.2) over (6.0-21ubuntu1.1) ...
Preparing to unpack .../126-wireless-regdb_2022.06.06-0ubuntu1~18.04.1_all.deb ...
Unpacking wireless-regdb (2022.06.06-0ubuntu1~18.04.1) over (2021.08.28-0ubuntu1~18.04.1) ...
Preparing to unpack .../127-xserver-xephyr_2%3a1.19.6-1ubuntu4.13_arm64.deb ...
Unpacking xserver-xephyr (2:1.19.6-1ubuntu4.13) over (2:1.19.6-1ubuntu4.10) ...
Preparing to unpack .../128-xwayland_2%3a1.19.6-1ubuntu4.13_arm64.deb ...
Unpacking xwayland (2:1.19.6-1ubuntu4.13) over (2:1.19.6-1ubuntu4.10) ...
Preparing to unpack .../129-python3-louis_3.5.0-1ubuntu0.4_all.deb ...
Unpacking python3-louis (3.5.0-1ubuntu0.4) over (3.5.0-1ubuntu0.3) ...
Setting up libgs9-common (9.26~dfsg+0-0ubuntu0.18.04.17) ...
Setting up libjpeg-turbo-progs (1.5.2-0ubuntu5.18.04.6) ...
Setting up imagemagick-6-common (8:6.9.7.4+dfsg-16ubuntu6.14) ...
Setting up libnotify4:arm64 (0.7.7-3ubuntu0.18.04.1) ...
Setting up git-man (1:2.17.1-1ubuntu0.13) ...
Setting up libwbclient0:arm64 (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) ...
Setting up gir1.2-notify-0.7:arm64 (0.7.7-3ubuntu0.18.04.1) ...
Setting up libexpat1:arm64 (2.2.5-3ubuntu0.9) ...
Setting up xserver-common (2:1.19.6-1ubuntu4.13) ...
Setting up libc6-dbg:arm64 (2.27-3ubuntu1.6) ...
Setting up libssl1.0.0:arm64 (1.0.2n-1ubuntu5.10) ...
Setting up libavutil55:arm64 (7:3.4.11-0ubuntu0.1) ...
Setting up runc (1.1.0-0ubuntu1~18.04.1) ...
Setting up libevdev2:arm64 (1.5.8+dfsg-1ubuntu0.2) ...
Setting up libnss-myhostname:arm64 (237-3ubuntu10.56) ...
Setting up xxd (2:8.0.1453-1ubuntu1.9) ...
Setting up gstreamer1.0-pulseaudio:arm64 (1.14.5-0ubuntu1~18.04.3) ...
Setting up isc-dhcp-common (4.3.5-3ubuntu7.4) ...
Setting up libjbig0:arm64 (2.1-3.1ubuntu0.18.04.1) ...
Setting up libldap-common (2.4.45+dfsg-1ubuntu1.11) ...
Setting up python3-mako (1.0.7+ds1-1ubuntu0.2) ...
Setting up gstreamer1.0-gtk3:arm64 (1.14.5-0ubuntu1~18.04.3) ...
Setting up multiarch-support (2.27-3ubuntu1.6) ...
Setting up tzdata (2022g-0ubuntu0.18.04) ...
Current default time zone: 'Pacific/Auckland'
Local time is now:      Wed Dec 21 11:37:51 NZDT 2022.
Universal Time is now:  Tue Dec 20 22:37:51 UTC 2022.
Run 'dpkg-reconfigure tzdata' if you wish to change it.
Setting up libklibc (2.0.4-9ubuntu2.2) ...
Setting up gpgconf (2.2.4-1ubuntu1.6) ...
Setting up libwayland-client0:arm64 (1.16.0-1ubuntu1.1~18.04.4) ...
Setting up libsasl2-modules-db:arm64 (2.1.27~101-g0780600+dfsg-3ubuntu2.4) ...
Setting up libbluetooth3:arm64 (5.48-0ubuntu3.9) ...
Setting up unzip (6.0-21ubuntu1.2) ...
Setting up linux-libc-dev:arm64 (4.15.0-200.211) ...
Setting up python3-colorama (0.3.7-1) ...
Setting up libsasl2-2:arm64 (2.1.27~101-g0780600+dfsg-3ubuntu2.4) ...
Setting up libflac8:arm64 (1.3.2-1ubuntu0.1) ...
Setting up gpg-agent (2.2.4-1ubuntu1.6) ...
Setting up libsdl1.2debian:arm64 (1.2.15+dfsg2-0.1ubuntu0.2) ...
Setting up distro-info-data (0.37ubuntu0.15) ...
Setting up libtiff5:arm64 (4.0.9-5ubuntu0.9) ...
Setting up wireless-regdb (2022.06.06-0ubuntu1~18.04.1) ...
Setting up libjpeg-turbo8:arm64 (1.5.2-0ubuntu5.18.04.6) ...
Setting up libroken18-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) ...
Setting up libexempi3:arm64 (2.4.5-2ubuntu0.1) ...
Setting up libnvinfer8 (8.2.1-1+cuda10.2) ...
Setting up libksba8:arm64 (1.3.5-2ubuntu0.18.04.1) ...
Setting up perl-modules-5.26 (5.26.1-6ubuntu0.6) ...
Setting up libspeex1:arm64 (1.2~rc1.2-1ubuntu2.1) ...
Setting up containerd (1.5.9-0ubuntu1~18.04.2) ...
Setting up libinput-bin (1.10.4-1ubuntu0.18.04.3) ...
Setting up libswresample2:arm64 (7:3.4.11-0ubuntu0.1) ...
Setting up libxml2:arm64 (2.9.4+dfsg1-6.1ubuntu1.8) ...
Setting up libfreetype6:arm64 (2.8.1-2ubuntu2.2) ...
Setting up gnupg-l10n (2.2.4-1ubuntu1.6) ...
Setting up libxml2-dev:arm64 (2.9.4+dfsg1-6.1ubuntu1.8) ...
Setting up rsync (3.1.2-2.1ubuntu1.5) ...
Setting up libxslt1.1:arm64 (1.1.29-5ubuntu0.3) ...
Setting up libnotify-bin (0.7.7-3ubuntu0.18.04.1) ...
Setting up liblouis-data (3.5.0-1ubuntu0.4) ...
Setting up python3-problem-report (2.20.9-0ubuntu7.28) ...
Setting up binutils-common:arm64 (2.30-21ubuntu1~18.04.8) ...
Setting up libpixman-1-0:arm64 (0.34.0-2ubuntu0.1) ...
Setting up libperl5.26:arm64 (5.26.1-6ubuntu0.6) ...
Setting up udev (237-3ubuntu10.56) ...
Setting up libswscale4:arm64 (7:3.4.11-0ubuntu0.1) ...
Setting up grub-common (2.02-2ubuntu8.25) ...
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
Setting up chromium-codecs-ffmpeg-extra (108.0.5359.71-0ubuntu0.18.04.5) ...
Setting up libssl1.1:arm64 (1.1.1-1ubuntu2.1~18.04.20) ...
Setting up xz-utils (5.2.2-1.3ubuntu0.1) ...
Setting up libheimbase1-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) ...
Setting up gpgsm (2.2.4-1ubuntu1.6) ...
Setting up liblouis14:arm64 (3.5.0-1ubuntu0.4) ...
Setting up systemd (237-3ubuntu10.56) ...
Setting up nvidia-l4t-core (32.7.3-20221122092935) ...
Configuration file '/etc/ld.so.conf.d/nvidia-tegra.conf'
 ==> Modified (by you or by a script) since installation.
 ==> Package distributor has shipped an updated version.
   What would you like to do about it ?  Your options are:
    Y or I  : install the package maintainer's version
    N or O  : keep your currently-installed version
      D     : show the differences between the versions
      Z     : start a shell to examine the situation
 The default action is to keep your current version.
*** nvidia-tegra.conf (Y/I/N/O/D/Z) [default=N] ? Y
Installing new version of config file /etc/ld.so.conf.d/nvidia-tegra.conf ...
Installing new version of config file /etc/nv_tegra_release ...
Setting up openssl (1.1.1-1ubuntu2.1~18.04.20) ...
Setting up libpostproc54:arm64 (7:3.4.11-0ubuntu0.1) ...
Setting up gnupg-utils (2.2.4-1ubuntu1.6) ...
Setting up vim-common (2:8.0.1453-1ubuntu1.9) ...
Setting up libsqlite3-0:arm64 (3.22.0-1ubuntu0.7) ...
Setting up libice6:arm64 (2:1.0.9-2ubuntu0.18.04.1) ...
Setting up libfribidi0:arm64 (0.19.7-2ubuntu0.1) ...
Setting up nvidia-l4t-gputools (32.7.3-20221122092935) ...
Setting up libsensors4:arm64 (1:3.4.0-4ubuntu0.1) ...
Setting up libpcrecpp0v5:arm64 (2:8.39-9ubuntu0.1) ...
Setting up libpcre32-3:arm64 (2:8.39-9ubuntu0.1) ...
Setting up vim-runtime (2:8.0.1453-1ubuntu1.9) ...
Setting up libmysqlclient20:arm64 (5.7.40-0ubuntu0.18.04.1) ...
Setting up libntfs-3g88 (1:2017.3.23-2ubuntu0.18.04.5) ...
Setting up libc-dev-bin (2.27-3ubuntu1.6) ...
Setting up xwayland (2:1.19.6-1ubuntu4.13) ...
Setting up libpcre16-3:arm64 (2:8.39-9ubuntu0.1) ...
Setting up libkeyutils1:arm64 (1.5.9-9.2ubuntu2.1) ...
Setting up libsasl2-modules:arm64 (2.1.27~101-g0780600+dfsg-3ubuntu2.4) ...
Setting up fonts-opensymbol (2:102.10+LibO6.0.7-0ubuntu0.18.04.12) ...
Setting up libpython2.7-minimal:arm64 (2.7.17-1~18.04ubuntu1.10) ...
Setting up uno-libs3 (6.0.7-0ubuntu0.18.04.12) ...
Setting up ca-certificates (20211016ubuntu0.18.04.1) ...
Updating certificates in /etc/ssl/certs...
rehash: warning: skipping ca-certificates.crt,it does not contain exactly one certificate or CRL
7 added, 11 removed; done.
Setting up libgstreamer-plugins-good1.0-0:arm64 (1.14.5-0ubuntu1~18.04.3) ...
Setting up nvidia-l4t-oem-config (32.7.3-20221122092935) ...
Configuration file '/etc/systemd/nv-oem-config-post.sh'
 ==> Deleted (by you or by a script) since installation.
*** nv-oem-config-post.sh (Y/I/N/O/D/Z) [default=N] ? Y
Installing new version of config file /etc/systemd/nv-oem-config-post.sh ...
Setting up openssh-client (1:7.6p1-4ubuntu0.7) ...
Setting up libc6-dev:arm64 (2.27-3ubuntu1.6) ...
Setting up cron (3.0pl1-128.1ubuntu1.2) ...
Setting up python-pil:arm64 (5.1.0-1ubuntu0.8) ...
Setting up libraw16:arm64 (0.18.8-1ubuntu0.4) ...
Setting up libwayland-cursor0:arm64 (1.16.0-1ubuntu1.1~18.04.4) ...
Setting up locales (2.27-3ubuntu1.6) ...
Generating locales (this might take a while)...
  en_AG.UTF-8... done
  en_AU.UTF-8... done
  en_BW.UTF-8... done
  en_CA.UTF-8... done
  en_DK.UTF-8... done
  en_GB.UTF-8... done
  en_HK.UTF-8... done
  en_IE.UTF-8... done
  en_IL.UTF-8... done
  en_IN.UTF-8... done
  en_NG.UTF-8... done
  en_NZ.UTF-8... done
  en_PH.UTF-8... done
  en_SG.UTF-8... done
  en_US.UTF-8... done
  en_ZA.UTF-8... done
  en_ZM.UTF-8... done
  en_ZW.UTF-8... done
Generation complete.
Setting up linux-firmware (1.173.21) ...
update-initramfs: Generating /boot/initrd.img-4.9.253-tegra
depmod: WARNING: could not open /lib/modules/4.9.253-tegra/modules.order: No such file or directory
depmod: WARNING: could not open /lib/modules/4.9.253-tegra/modules.builtin: No such file or directory
cryptsetup: WARNING: failed to detect canonical device of /dev/root
cryptsetup: WARNING: could not determine root device from /etc/fstab
Warning: couldn't identify filesystem type for fsck hook, ignoring.
I: The initramfs will attempt to resume from /dev/zram1
I: (UUID=9f6d1511-f113-47c8-b8a7-e6e8d6ac1009)
I: Set the RESUME variable to override this.
depmod: WARNING: could not open /var/tmp/mkinitramfs_keLqla/lib/modules/4.9.253-tegra/modules.order: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_keLqla/lib/modules/4.9.253-tegra/modules.builtin: No such file or directory
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/aarch64-linux-gnu_EGL.conf: No such file or directory
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/aarch64-linux-gnu_GL.conf: No such file or directory
Setting up liblwres160:arm64 (1:9.11.3+dfsg-1ubuntu1.18) ...
Setting up ure (6.0.7-0ubuntu0.18.04.12) ...
Setting up libwayland-egl1:arm64 (1.16.0-1ubuntu1.1~18.04.4) ...
Setting up python3-louis (3.5.0-1ubuntu0.4) ...
Setting up libpython2.7-stdlib:arm64 (2.7.17-1~18.04ubuntu1.10) ...
Setting up libspeexdsp1:arm64 (1.2~rc1.2-1ubuntu2.1) ...
Setting up networkd-dispatcher (1.7-0ubuntu3.5) ...
Setting up python3-jwt (1.5.3+ds1-1ubuntu0.1) ...
Setting up rsyslog (8.32.0-1ubuntu4.2) ...
The user `syslog' is already a member of `adm'.
Setting up xserver-xorg-legacy (2:1.19.6-1ubuntu4.13) ...
setting xserver-xorg-legacy/xwrapper/allowed_users from configuration file
Setting up libdbus-1-3:arm64 (1.12.2-1ubuntu1.4) ...
Setting up gpg (2.2.4-1ubuntu1.6) ...
Setting up python2.7-minimal (2.7.17-1~18.04ubuntu1.10) ...
Setting up libcups2:arm64 (2.2.7-1ubuntu2.9) ...
Setting up libwayland-server0:arm64 (1.16.0-1ubuntu1.1~18.04.4) ...
Setting up zlib1g-dev:arm64 (1:1.2.11.dfsg-0ubuntu2.2) ...
Setting up libsnmp-base (5.7.3+dfsg-1.8ubuntu3.7) ...
Setting up libwayland-bin (1.16.0-1ubuntu1.1~18.04.4) ...
Setting up libisc169:arm64 (1:9.11.3+dfsg-1ubuntu1.18) ...
Setting up libnss-systemd:arm64 (237-3ubuntu10.56) ...
Setting up libnvinfer-dev (8.2.1-1+cuda10.2) ...
Setting up libisccc160:arm64 (1:9.11.3+dfsg-1ubuntu1.18) ...
Setting up nvidia-l4t-libvulkan (32.7.3-20221122092935) ...
Setting up libpcre3-dev:arm64 (2:8.39-9ubuntu0.1) ...
Setting up klibc-utils (2.0.4-9ubuntu2.2) ...
Setting up libsnmp30:arm64 (5.7.3+dfsg-1.8ubuntu3.7) ...
Setting up libmagickcore-6.q16-3:arm64 (8:6.9.7.4+dfsg-16ubuntu6.14) ...
Setting up docker.io (20.10.12-0ubuntu2~18.04.1) ...
Setting up libavresample3:arm64 (7:3.4.11-0ubuntu0.1) ...
Setting up nvidia-l4t-multimedia-utils (32.7.3-20221122092935) ...
Setting up libwind0-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) ...
Setting up nvidia-l4t-firmware (32.7.3-20221122092935) ...
Setting up libbinutils:arm64 (2.30-21ubuntu1~18.04.8) ...
Setting up nvidia-l4t-init (32.7.3-20221122092935) ...
Installing new version of config file /etc/default/rng-tools ...
Installing new version of config file /etc/enctune.conf ...
Installing new version of config file /etc/nvidia-container-runtime/host-files-for-container.d/l4t.csv ...
Installing new version of config file /etc/systemd/nvfb.sh ...
Installing new version of config file /etc/wpa_supplicant.conf ...
Setting up libisc-export169:arm64 (1:9.11.3+dfsg-1ubuntu1.18) ...
Setting up systemd-sysv (237-3ubuntu10.56) ...
Setting up libasn1-8-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) ...
Setting up python3-click (6.7-3) ...
Setting up libavcodec57:arm64 (7:3.4.11-0ubuntu0.1) ...
Setting up libhcrypto4-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) ...
Setting up libinput10:arm64 (1.10.4-1ubuntu0.18.04.3) ...
Setting up keyutils (1.5.9-9.2ubuntu2.1) ...
Setting up python2.7 (2.7.17-1~18.04ubuntu1.10) ...
Setting up libnss3:arm64 (2:3.35-2ubuntu2.15) ...
Setting up libwinpr2-2:arm64 (2.2.0+dfsg1-0ubuntu0.18.04.4) ...
Setting up nvidia-l4t-wayland (32.7.3-20221122092935) ...
Setting up xserver-xephyr (2:1.19.6-1ubuntu4.13) ...
Setting up gpg-wks-server (2.2.4-1ubuntu1.6) ...
Setting up python3-apport (2.20.9-0ubuntu7.28) ...
Setting up nvidia-l4t-configs (32.7.3-20221122092935) ...
Setting up xserver-xorg-core (2:1.19.6-1ubuntu4.13) ...
Setting up libhx509-5-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) ...
Setting up nvidia-l4t-x11 (32.7.3-20221122092935) ...
Setting up thunderbird (1:102.4.2+build2-0ubuntu0.18.04.1) ...
Setting up perl (5.26.1-6ubuntu0.6) ...
Setting up libpython3.6-minimal:arm64 (3.6.9-1~18.04ubuntu1.9) ...
Setting up libpoppler73:arm64 (0.62.0-2ubuntu2.14) ...
Setting up libcupsimage2:arm64 (2.2.7-1ubuntu2.9) ...
Setting up ubuntu-drivers-common (1:0.8.6.3~0.18.04.2) ...
Setting up openssh-sftp-server (1:7.6p1-4ubuntu0.7) ...
Setting up libice-dev:arm64 (2:1.0.9-2ubuntu0.18.04.1) ...
Setting up binutils-aarch64-linux-gnu (2.30-21ubuntu1~18.04.8) ...
Setting up nvidia-l4t-apt-source (32.7.3-20221122092935) ...
Setting up thunderbird-gnome-support (1:102.4.2+build2-0ubuntu0.18.04.1) ...
Setting up bluez-obexd (5.48-0ubuntu3.9) ...
Setting up ntfs-3g (1:2017.3.23-2ubuntu0.18.04.5) ...
Setting up libpython2.7:arm64 (2.7.17-1~18.04ubuntu1.10) ...
Setting up libdns-export1100 (1:9.11.3+dfsg-1ubuntu1.18) ...
Setting up libmagickwand-6.q16-3:arm64 (8:6.9.7.4+dfsg-16ubuntu6.14) ...
Setting up apport (2.20.9-0ubuntu7.28) ...
Installing new version of config file /etc/init.d/apport ...
apport-autoreport.service is a disabled or a static unit, not starting it.
Setting up dnsmasq-base (2.79-1ubuntu0.6) ...
Setting up libexpat1-dev:arm64 (2.2.5-3ubuntu0.9) ...
Setting up libpython2.7-dev:arm64 (2.7.17-1~18.04ubuntu1.10) ...
Setting up binutils (2.30-21ubuntu1~18.04.8) ...
Setting up gstreamer1.0-plugins-good:arm64 (1.14.5-0ubuntu1~18.04.3) ...
Setting up libkrb5-26-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) ...
Setting up dbus (1.12.2-1ubuntu1.4) ...
A reboot is required to replace the running dbus-daemon.
Please reboot the system when convenient.
Setting up libwayland-dev:arm64 (1.16.0-1ubuntu1.1~18.04.4) ...
Setting up libdns1100:arm64 (1:9.11.3+dfsg-1ubuntu1.18) ...
Setting up bluez (5.48-0ubuntu3.9) ...
Setting up libgs9:arm64 (9.26~dfsg+0-0ubuntu0.18.04.17) ...
Setting up libavformat57:arm64 (7:3.4.11-0ubuntu0.1) ...
Setting up nvidia-l4t-weston (32.7.3-20221122092935) ...
Setting up python2.7-dev (2.7.17-1~18.04ubuntu1.10) ...
Setting up libheimntlm0-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) ...
Setting up libpython3.6-stdlib:arm64 (3.6.9-1~18.04ubuntu1.9) ...
Setting up nvidia-l4t-bootloader (32.7.3-20221122092935) ...
3448-300-0000--1--jetson-nano-devkit-
Starting bootloader post-install procedure.
ERROR. Procedure for bootloader update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-bootloader (--configure):
 installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
Setting up chromium-browser (108.0.5359.71-0ubuntu0.18.04.5) ...
Setting up nvidia-l4t-xusb-firmware (32.7.3-20221122092935) ...
Starting xusb firmware post-install procedure.
ERROR. Procedure for xusb firmware update FAILED.
dpkg: error processing package nvidia-l4t-xusb-firmware (--configure):
 installed nvidia-l4t-xusb-firmware package post-installation script subprocess returned error exit status 1
Setting up libpoppler-glib8:arm64 (0.62.0-2ubuntu2.14) ...
Setting up libpam-systemd:arm64 (237-3ubuntu10.56) ...
Setting up poppler-utils (0.62.0-2ubuntu2.14) ...
dpkg: dependency problems prevent configuration of nvidia-l4t-initrd:
 nvidia-l4t-initrd depends on nvidia-l4t-xusb-firmware (= 32.7.3-20221122092935); however:
  Package nvidia-l4t-xusb-firmware is not configured yet.
dpkg: error processing package nvidia-l4t-initrd (--configure):
 dependency problems - leaving unconfigured
Setting up nvidia-l4t-3d-core (32.7.3-20221122092935) ...
No apport report written because the error message indicates its a followup error from a previous failure.
        Setting up libfreerdp2-2:arm64 (2.2.0+dfsg1-0ubunt
u0.18.04.4) ...
Setting up libavfilter6:arm64 (7:3.4.11-0ubuntu0.1) ...
Setting up libisccfg-export160 (1:9.11.3+dfsg-1ubuntu1.18) ...
Setting up dbus-x11 (1.12.2-1ubuntu1.4) ...
Setting up libdpkg-perl (1.19.0.5ubuntu2.4) ...
Setting up python3.6-minimal (3.6.9-1~18.04ubuntu1.9) ...
Setting up imagemagick-6.q16 (8:6.9.7.4+dfsg-16ubuntu6.14) ...
Setting up apport-gtk (2.20.9-0ubuntu7.28) ...
Setting up libhttp-daemon-perl (6.01-1ubuntu0.1) ...
Setting up ghostscript (9.26~dfsg+0-0ubuntu0.18.04.17) ...
Setting up chromium-browser-l10n (108.0.5359.71-0ubuntu0.18.04.5) ...
Setting up dbus-user-session (1.12.2-1ubuntu1.4) ...
Setting up nvidia-l4t-cuda (32.7.3-20221122092935) ...
Setting up isc-dhcp-client (4.3.5-3ubuntu7.4) ...
Setting up libisccfg160:arm64 (1:9.11.3+dfsg-1ubuntu1.18) ...
Setting up nvidia-l4t-multimedia (32.7.3-20221122092935) ...
Setting up snapd (2.57.5+18.04ubuntu0.1) ...
Installing new version of config file /etc/apparmor.d/usr.lib.snapd.snap-confine.real ...
Created symlink /etc/systemd/system/multi-user.target.wants/snapd.aa-prompt-listener.service → /lib/systemd/system/snapd.aa-prompt-listener.service.
snapd.failure.service is a disabled or a static unit not running, not starting it.
snapd.snap-repair.service is a disabled or a static unit not running, not starting it.
Setting up dpkg-dev (1.19.0.5ubuntu2.4) ...
Setting up openssh-server (1:7.6p1-4ubuntu0.7) ...
Setting up libfreerdp-client2-2:arm64 (2.2.0+dfsg1-0ubuntu0.18.04.4) ...
Setting up libmagickcore-6.q16-3-extra:arm64 (8:6.9.7.4+dfsg-16ubuntu6.14) ...
Setting up nvidia-l4t-camera (32.7.3-20221122092935) ...
Setting up imagemagick (8:6.9.7.4+dfsg-16ubuntu6.14) ...
Setting up libirs-export160 (1:9.11.3+dfsg-1ubuntu1.18) ...
Setting up isc-dhcp-server (4.3.5-3ubuntu7.4) ...
isc-dhcp-server6.service is a disabled or a static unit, not starting it.
Setting up libgssapi3-heimdal:arm64 (7.5.0+dfsg-1ubuntu0.2) ...
Setting up ghostscript-x (9.26~dfsg+0-0ubuntu0.18.04.17) ...
Setting up libpython3.6:arm64 (3.6.9-1~18.04ubuntu1.9) ...
Setting up libavdevice57:arm64 (7:3.4.11-0ubuntu0.1) ...
Setting up nvidia-l4t-graphics-demos (32.7.3-20221122092935) ...
Setting up python3.6 (3.6.9-1~18.04ubuntu1.9) ...
Setting up vim (2:8.0.1453-1ubuntu1.9) ...
Setting up libbind9-160:arm64 (1:9.11.3+dfsg-1ubuntu1.18) ...
Setting up nvidia-l4t-gstreamer (32.7.3-20221122092935) ...
Setting up nvidia-l4t-jetson-multimedia-api (32.7.3-20221122092935) ...
Setting up libldap-2.4-2:arm64 (2.4.45+dfsg-1ubuntu1.11) ...
Setting up ffmpeg (7:3.4.11-0ubuntu0.1) ...
Setting up dirmngr (2.2.4-1ubuntu1.6) ...
Setting up bind9-host (1:9.11.3+dfsg-1ubuntu1.18) ...
Setting up samba-libs:arm64 (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) ...
Setting up libcurl3-gnutls:arm64 (7.58.0-2ubuntu3.21) ...
Setting up libcurl4:arm64 (7.58.0-2ubuntu3.21) ...
Setting up gpg-wks-client (2.2.4-1ubuntu1.6) ...
Setting up libsmbclient:arm64 (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) ...
Setting up git (1:2.17.1-1ubuntu0.13) ...
Setting up gnupg (2.2.4-1ubuntu1.6) ...
Setting up libreoffice-style-galaxy (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-style-tango (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-common (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-core (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up python3-uno (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-gtk3 (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-style-breeze (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-gnome (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-pdfimport (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-draw (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-avmedia-backend-gstreamer (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-impress (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-math (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-base-core (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-calc (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-ogltrans (1:6.0.7-0ubuntu0.18.04.12) ...
Setting up libreoffice-writer (1:6.0.7-0ubuntu0.18.04.12) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) ...
Processing triggers for menu (2.1.47ubuntu2.1) ...
Processing triggers for initramfs-tools (0.130ubuntu3.13) ...
depmod: WARNING: could not open /var/tmp/mkinitramfs_zS9G3r/lib/modules/4.9.253-tegra/modules.order: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_zS9G3r/lib/modules/4.9.253-tegra/modules.builtin: No such file or directory
Processing triggers for gnome-icon-theme (3.12.0-3) ...
Processing triggers for bamfdaemon (0.5.3+18.04.20180207.2-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for libc-bin (2.27-3ubuntu1.6) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for shared-mime-info (1.9-2) ...
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for fontconfig (2.12.6-0ubuntu2) ...
Processing triggers for ca-certificates (20211016ubuntu0.18.04.1) ...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
Processing triggers for systemd (237-3ubuntu10.56) ...
Errors were encountered while processing:
 nvidia-l4t-initrd
E: Sub-process /usr/bin/dpkg returned an error code (1)
administrator@ROSdev:~$
You may try:
sudo apt update
sudo apt dist-upgrade
sudo dpkg --configure -a
sudo apt --fix-broken install
sudo apt auto remove
sudo reboot
# After reboot/log in
sudo apt-get clean
If not enough, you you may also try:
sudo dpkg-reconfigure nvidia-l4t-bootloader
If it doesn’t help, you may also post the output of:
cat /etc/nv_boot_control.conf
Hi and thank you @Honey_Patouceul for the suggestions
Unfortunately, the problem persists :-/ keeping me from installing anything else, and updating etc.
This seems to be due some post-install scripts that get triggered from the messed up package “nvidia-l4t-kernel”.
Here some debug output (might have to do it in several posts:
Output:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages will be REMOVED:
  nvidia-container-csv-tensorrt
The following packages will be upgraded:
  tensorrt
1 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
3 not fully installed or removed.
Need to get 2,320 B of archives.
After this operation, 53.2 kB disk space will be freed.
Do you want to continue? [Y/n] y
Get:1 https://repo.download.nvidia.com/jetson/common r32.7/main arm64 tensorrt arm64 8.2.1.9-1+cuda10.2 [2,320 B]
Fetched 2,320 B in 2s (947 B/s)
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 179565 files and directories currently installed.)
Removing nvidia-container-csv-tensorrt (8.2.1.8-1+cuda10.2) ...
(Reading database ... 179562 files and directories currently installed.)
Preparing to unpack .../tensorrt_8.2.1.9-1+cuda10.2_arm64.deb ...
Unpacking tensorrt (8.2.1.9-1+cuda10.2) over (8.2.1.8-1+cuda10.2) ...
Setting up tensorrt (8.2.1.9-1+cuda10.2) ...
 nvidia-l4t-initrd
sudo apt autoremove
Output:
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
After this operation, 0 B of additional disk space will be used.
 nvidia-l4t-initrd
Output:
/usr/sbin/dpkg-reconfigure: nvidia-l4t-bootloader is broken or not fully installed
Output:
TNSPEC 3448-402-0000-A.0-1-0-jetson-nano-qspi-sd-mmcblk0p1
COMPATIBLE_SPEC 3448-300-0000–1–jetson-nano-devkit-
TEGRA_CHIPID 0x21
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
I’m really not sure what else I can try. I’m sure everyone understands frustration, especially when finally having a few days off over Christmas, hoping to work on a project and then nothing but issues.
Therefore I’m very very grateful for anyone being so kind and taking a few minutes to provide some help! Hopefully this can help others with the same issue and that I can myself be helpful in the community one day!
check:
Thank you @mhd0425
This did the trick (-:
Merry Christmas to all of you guys!
With some luck I won’t be back here to bother anyone!
Happy holidays!
