Okay. I started with release 32.4.4:
/etc/lsb-release
# cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.5 LTS"
uname -a
# uname -a
Linux localhost 4.9.140-tegra #1 SMP PREEMPT Tue Oct 27 21:02:46 PDT 2020 aarch64 aarch64 aarch64 GNU/Linux
dmesg |grep -i eqos
# dmesg |grep -i eqos
[ 1.068305] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 1.071639] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8d 80 d5
dpkg -l |grep -i l4t
# dpkg -l |grep -i l4t
ii nvidia-l4t-apt-source 32.4.4-20201016123640 arm64 NVIDIA L4T apt source list debian package
ii nvidia-l4t-bootloader 32.4.4-20201027211332 arm64 NVIDIA Bootloader Package
ii nvidia-l4t-configs 32.4.4-20201016123640 arm64 NVIDIA configs debian package
ii nvidia-l4t-core 32.4.4-20201016123640 arm64 NVIDIA Core Package
ii nvidia-l4t-firmware 32.4.4-20201027211332 arm64 NVIDIA Firmware Package
ii nvidia-l4t-init 32.4.4-20201027211332 arm64 NVIDIA Init debian package
ii nvidia-l4t-initrd 32.4.4-20201016123640 arm64 NVIDIA initrd debian package
ii nvidia-l4t-kernel 4.9.140-tegra-32.4.4-20201027211332 arm64 NVIDIA Kernel Package
ii nvidia-l4t-kernel-dtbs 4.9.140-tegra-32.4.4-20201027211332 arm64 NVIDIA Kernel DTB Package
ii nvidia-l4t-tools 32.4.4-20201027211332 arm64 NVIDIA Public Test Tools Package
ii nvidia-l4t-xusb-firmware 32.4.4-20201016123640 arm64 NVIDIA USB Firmware Package
cat /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
# cat /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
deb https://repo.download.nvidia.com/jetson/common r32.4 main
deb https://repo.download.nvidia.com/jetson/t186 r32.4 main
Then, I change r32.4 to r32.5 in the nvidia-l4t-apt-source.list, run apt update and apt dist-upgrade
apt list --upgradable
# apt list --upgradable
Listing... Done
jetson-gpio-common/stable 2.0.16 arm64 [upgradable from: 2.0.11]
nvidia-l4t-apt-source/stable 32.5.1-20210219084708 arm64 [upgradable from: 32.4.4-20201016123640]
nvidia-l4t-bootloader/stable 32.5.1-20210614115015 arm64 [upgradable from: 32.4.4-20201027211332]
nvidia-l4t-configs/stable 32.5.1-20210219084708 arm64 [upgradable from: 32.4.4-20201016123640]
nvidia-l4t-core/stable 32.5.1-20210519111140 arm64 [upgradable from: 32.4.4-20201016123640]
nvidia-l4t-firmware/stable 32.5.1-20210519111140 arm64 [upgradable from: 32.4.4-20201027211332]
nvidia-l4t-init/stable 32.5.1-20210519111140 arm64 [upgradable from: 32.4.4-20201027211332]
nvidia-l4t-initrd/stable 32.5.1-20210614115015 arm64 [upgradable from: 32.4.4-20201016123640]
nvidia-l4t-kernel/stable 4.9.201-tegra-32.5.1-20210505093723 arm64 [upgradable from: 4.9.140-tegra-32.4.4-20201027211332]
nvidia-l4t-kernel-dtbs/stable 4.9.201-tegra-32.5.1-20210505093723 arm64 [upgradable from: 4.9.140-tegra-32.4.4-20201027211332]
nvidia-l4t-tools/stable 32.5.1-20210614115015 arm64 [upgradable from: 32.4.4-20201027211332]
nvidia-l4t-xusb-firmware/stable 32.5.1-20210614115015 arm64 [upgradable from: 32.4.4-20201016123640]
python-jetson-gpio/stable 2.0.16 arm64 [upgradable from: 2.0.11]
python3-jetson-gpio/stable 2.0.16 arm64 [upgradable from: 2.0.11]
u-boot-tools/bionic-updates 2020.10+dfsg-1ubuntu0~18.04.2 arm64 [upgradable from: 2019.07+dfsg-1ubuntu4~18.04.1]
After device reboot, I see error from eqos module in dmesg:
dmesg |grep -i eqos
[ 1.035969] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 1.038732] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 1.038819] eqos 2490000.ether_qos: invalid settings : rx-frames must be enabled along with use_riwt in DT
[ 1.054058] eqos: probe of 2490000.ether_qos failed with error -22
uname -a
# uname -a
Linux localhost 4.9.201-tegra #1 SMP PREEMPT Wed May 5 09:32:25 PDT 2021 aarch64 aarch64 aarch64 GNU/Linux
ii nvidia-l4t-apt-source 32.5.1-20210219084708 arm64 NVIDIA L4T apt source list debian package
ii nvidia-l4t-bootloader 32.5.1-20210614115015 arm64 NVIDIA Bootloader Package
ii nvidia-l4t-configs 32.5.1-20210219084708 arm64 NVIDIA configs debian package
ii nvidia-l4t-core 32.5.1-20210519111140 arm64 NVIDIA Core Package
ii nvidia-l4t-firmware 32.5.1-20210519111140 arm64 NVIDIA Firmware Package
ii nvidia-l4t-init 32.5.1-20210519111140 arm64 NVIDIA Init debian package
ii nvidia-l4t-initrd 32.5.1-20210614115015 arm64 NVIDIA initrd debian package
ii nvidia-l4t-kernel 4.9.201-tegra-32.5.1-20210505093723 arm64 NVIDIA Kernel Package
ii nvidia-l4t-kernel-dtbs 4.9.201-tegra-32.5.1-20210505093723 arm64 NVIDIA Kernel DTB Package
ii nvidia-l4t-tools 32.5.1-20210614115015 arm64 NVIDIA Public Test Tools Package
ii nvidia-l4t-xusb-firmware 32.5.1-20210614115015 arm64 NVIDIA USB Firmware Package
Dist upgrade log:
apt dist-upgrade
# apt dist-upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages will be upgraded:
jetson-gpio-common nvidia-l4t-apt-source nvidia-l4t-bootloader
nvidia-l4t-configs nvidia-l4t-core nvidia-l4t-firmware nvidia-l4t-init
nvidia-l4t-initrd nvidia-l4t-kernel nvidia-l4t-kernel-dtbs nvidia-l4t-tools
nvidia-l4t-xusb-firmware python-jetson-gpio python3-jetson-gpio u-boot-tools
15 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 106 MB of archives.
After this operation, 131 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 nvidia-l4t-core arm64 32.5.1-20210519111140 [2,790 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 u-boot-tools arm64 2020.10+dfsg-1ubuntu0~18.04.2 [139 kB]
Get:3 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 nvidia-l4t-tools arm64 32.5.1-20210614115015 [3,724 kB]
Get:4 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 nvidia-l4t-kernel-dtbs arm64 4.9.201-tegra-32.5.1-2021050509
3723 [267 kB]
Get:5 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 nvidia-l4t-kernel arm64 4.9.201-tegra-32.5.1-20210505093723
[51.3 MB]
Get:6 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 nvidia-l4t-apt-source arm64 32.5.1-20210219084708 [10.4 kB]
Get:7 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 nvidia-l4t-configs arm64 32.5.1-20210219084708 [1,440 kB]
Get:8 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 nvidia-l4t-init arm64 32.5.1-20210519111140 [66.8 kB]
Get:9 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 nvidia-l4t-firmware arm64 32.5.1-20210519111140 [1,674 kB]
Get:10 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 nvidia-l4t-xusb-firmware arm64 32.5.1-20210614115015 [151 k
B]
Get:11 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 nvidia-l4t-initrd arm64 32.5.1-20210614115015 [7,243 kB]
Get:12 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 nvidia-l4t-bootloader arm64 32.5.1-20210614115015 [37.4 MB]
Get:13 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 python3-jetson-gpio arm64 2.0.16 [19.1 kB]
Get:14 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 python-jetson-gpio arm64 2.0.16 [19.0 kB]
Get:15 https://repo.download.nvidia.com/jetson/t186 r32.5/main arm64 jetson-gpio-common arm64 2.0.16 [13.9 kB]
Fetched 106 MB in 2min 17s (774 kB/s)
(Reading database ... 23178 files and directories currently installed.)
Preparing to unpack .../nvidia-l4t-core_32.5.1-20210519111140_arm64.deb ...
Unpacking nvidia-l4t-core (32.5.1-20210519111140) over (32.4.4-20201016123640) ...
Setting up nvidia-l4t-core (32.5.1-20210519111140) ...
Installing new version of config file /etc/nv_tegra_release ...
Preparing to unpack .../00-nvidia-l4t-tools_32.5.1-20210614115015_arm64.deb ...
Unpacking nvidia-l4t-tools (32.5.1-20210614115015) over (32.4.4-20201027211332) ...
Preparing to unpack .../01-nvidia-l4t-kernel-dtbs_4.9.201-tegra-32.5.1-20210505093723_arm64.deb ...
Unpacking nvidia-l4t-kernel-dtbs (4.9.201-tegra-32.5.1-20210505093723) over (4.9.140-tegra-32.4.4-20201027211332) ...
Preparing to unpack .../02-nvidia-l4t-kernel_4.9.201-tegra-32.5.1-20210505093723_arm64.deb ...
Unpacking nvidia-l4t-kernel (4.9.201-tegra-32.5.1-20210505093723) over (4.9.140-tegra-32.4.4-20201027211332) ...
Preparing to unpack .../03-nvidia-l4t-apt-source_32.5.1-20210219084708_arm64.deb ...
Unpacking nvidia-l4t-apt-source (32.5.1-20210219084708) over (32.4.4-20201016123640) ...
Preparing to unpack .../04-nvidia-l4t-configs_32.5.1-20210219084708_arm64.deb ...
Unpacking nvidia-l4t-configs (32.5.1-20210219084708) over (32.4.4-20201016123640) ...
Preparing to unpack .../05-nvidia-l4t-init_32.5.1-20210519111140_arm64.deb ...
Unpacking nvidia-l4t-init (32.5.1-20210519111140) over (32.4.4-20201027211332) ...
Preparing to unpack .../06-nvidia-l4t-firmware_32.5.1-20210519111140_arm64.deb ...
Unpacking nvidia-l4t-firmware (32.5.1-20210519111140) over (32.4.4-20201027211332) ...
Preparing to unpack .../07-nvidia-l4t-xusb-firmware_32.5.1-20210614115015_arm64.deb ...
Unpacking nvidia-l4t-xusb-firmware (32.5.1-20210614115015) over (32.4.4-20201016123640) ...
Preparing to unpack .../08-nvidia-l4t-initrd_32.5.1-20210614115015_arm64.deb ...
Unpacking nvidia-l4t-initrd (32.5.1-20210614115015) over (32.4.4-20201016123640) ...
Preparing to unpack .../09-nvidia-l4t-bootloader_32.5.1-20210614115015_arm64.deb ...
Unpacking nvidia-l4t-bootloader (32.5.1-20210614115015) over (32.4.4-20201027211332) ...
Preparing to unpack .../10-python3-jetson-gpio_2.0.16_arm64.deb ...
Unpacking python3-jetson-gpio (2.0.16) over (2.0.11) ...
Preparing to unpack .../11-python-jetson-gpio_2.0.16_arm64.deb ...
Unpacking python-jetson-gpio (2.0.16) over (2.0.11) ...
Preparing to unpack .../12-jetson-gpio-common_2.0.16_arm64.deb ...
Unpacking jetson-gpio-common (2.0.16) over (2.0.11) ...
Preparing to unpack .../13-u-boot-tools_2020.10+dfsg-1ubuntu0~18.04.2_arm64.deb ...
Unpacking u-boot-tools (2020.10+dfsg-1ubuntu0~18.04.2) over (2019.07+dfsg-1ubuntu4~18.04.1) ...
Setting up nvidia-l4t-firmware (32.5.1-20210519111140) ...
Setting up nvidia-l4t-init (32.5.1-20210519111140) ...
Installing new version of config file /etc/nvidia-container-runtime/host-files-for-container.d/l4t.csv ...
Installing new version of config file /etc/systemd/nv.sh ...
Installing new version of config file /etc/systemd/nvfb.sh ...
Installing new version of config file /etc/systemd/nvzramconfig.sh ...
Installing new version of config file /etc/systemd/system/nv_update_verifier.service ...
Installing new version of config file /etc/udev/rules.d/99-nv-l4t-usb-host-config.rules ...
Configuration file '/etc/udev/rules.d/99-nv-ufs-mount.rules'
==> Deleted (by you or by a script) since installation.
==> Package distributor has shipped an updated version.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer's version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** 99-nv-ufs-mount.rules (Y/I/N/O/D/Z) [default=N] ?
Installing new version of config file /etc/udev/rules.d/99-tegra-devices.rules ...
Setting up nvidia-l4t-tools (32.5.1-20210614115015) ...
Installing new version of config file /etc/nvpmodel/nvpmodel_t194.conf ...
Installing new version of config file /etc/nvpmodel/nvpmodel_t194_8gb.conf ...
Installing new version of config file /etc/nvpmodel/nvpmodel_t194_p3668.conf ...
Setting up u-boot-tools (2020.10+dfsg-1ubuntu0~18.04.2) ...
Setting up nvidia-l4t-configs (32.5.1-20210219084708) ...
Installing new version of config file /etc/systemd/nvfb-early.sh ...
Setting up nvidia-l4t-apt-source (32.5.1-20210219084708) ...
Configuration file '/etc/apt/sources.list.d/nvidia-l4t-apt-source.list'
==> Modified (by you or by a script) since installation.
*** nvidia-l4t-apt-source.list (Y/I/N/O/D/Z) [default=N] ?
Setting up jetson-gpio-common (2.0.16) ...
Setting up nvidia-l4t-kernel (4.9.201-tegra-32.5.1-20210505093723) ...
Using the existing boot entry 'primary'
3310-B01---1--jetson-tx2-devkit-mmcblk0p1
Starting kernel post-install procedure.
rootfs AB is not enabled.
Reboot the target system for changes to take effect.
Setting up nvidia-l4t-kernel-dtbs (4.9.201-tegra-32.5.1-20210505093723) ...
Setting up nvidia-l4t-bootloader (32.5.1-20210614115015) ...
Starting bootloader post-install procedure.
Update bl_update_payload completed.
Updating extlinux.conf...
Root device is set in the extlinux.conf
Setting up nvidia-l4t-xusb-firmware (32.5.1-20210614115015) ...
Setting up nvidia-l4t-initrd (32.5.1-20210614115015) ...
Setting up python3-jetson-gpio (2.0.16) ...
Setting up python-jetson-gpio (2.0.16) ...
Processing triggers for nvidia-l4t-kernel (4.9.201-tegra-32.5.1-20210505093723) ...
Device boot log attached as file: boot.log (21.4 KB)
I tried to flash 32.6.1-based rootfs using two different L4T framework versions: 32.6.1 (Jetson_Linux_R32.6.1_aarch64.tbz2) and 32.4.3 (Jetson_Linux_R32.6.1_aarch64.tbz2).
In both cases I use the same rootfs: Ubuntu 18.04 based, with 32.6.1 L4T components inside.
Ethernet is working only if I flash device using 32.6.1 L4T framework version. So I suppose that it was some changes in flashing scripts, which is not ported to the deb-packages (DTB installation?).
I also tried to copy eMMC partitions related to the DTB from the working device (32.6.1 rootfs flashed by USB via 32.6.1 framework) to broken one (using dd), but after copying device got kernel cpu lockup error and starts to reboot in a loop. So, probably, eMMC partitions is not compatible between devices (?).
One more experiment: I tried to build BUP update using l4t_generate_soc_bup.sh from 32.6.1 framework, and flash it to broken device using nv_update_engine. No luck, still no Ethernet.
Does this information enough, or I should provide more?
