Download and unpack L4T R32.4.4 (Tegra186_Linux_R32.4.4_aarch64.tbz2)
Download and unpack sample rootfs (Tegra_Linux_Sample-Root-Filesystem_R32.4.4_aarch64.tbz2) to the rootfs folder inside Linux_for_Tegra directory using sudo
Run (with sudo/root) apply_binaries.sh inside Linux_for_Tegra directory
Run (with sudo/root) ./flash.sh -S 15032385536 -R rootfs jetson-tx2 mmcblk0p1
Connect to /dev/ttyACM0, finish the OEM configuration
Change r32.4 to r32.6 in /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
Run apt-get update && apt-get dist-upgrade
Reboot
Following error appear in dmesg: [ 1.118088] eqos 2490000.ether_qos: invalid settings : rx-frames must be enabled along with use_riwt in DT. Main ethernet port become non-working. U-boot version is also remain the same: U-Boot 2016.07-g7a7e3f476e (Oct 16 2020 - 12:15:13 -0700)
If I run flash.sh script without specifying -S option (/flash.sh -R rootfs jetson-tx2 mmcblk0p1) then eqos module was OK after reboot and ethernet port is in working state
Thanks for reporting this.
I believe your test means there is something wrong with bootloader update, which also includes dtb update, when -S is specified. Thus, kernel dtb and your bootloader(uboot/cboot) still remains in jp4.4 version. But the kernel is being changed to 4.6.
We have confirmed the cause of this issue. In brief, since you have used the “-S” in your flash.sh, this is kind of customization which affects the partition layout.
And since “apt-get upgrade” only installs “default layout” (it is not possible for a general package to know your customization), it turns out failing.
For your case, to update bootloader, you can only use BUP update method mentioned here.
1. Download the r32.6.1 BSP packages
2. Use this package to generate the BUP, just running "sudo ./l4t_generate_soc_bup.sh -p "-S 15032385536" t19x"
3. Copy the BUP to the target device.
4. use nv_update_engine to install it directly.
Thank you for information, should I install BUP before or after dist-upgrade?
And If I need to add some custom changes to U-Boot (I need to enable the bootcounter in U-boot) and change the ODMDATA=, then It will be enough to put compiled u-boot.bin binaries into the Linux_for_Tegra/bootloader/t186ref/p2771-0000/500/ and change ODMDATA in p2771-0000.conf.common before generating the BUP?
One more question: it’s possible to flash BUP when running from SATA drive? If rootfs is located on external SATA, then nv_update_engine can’t enable A/B redundancy which is required to update BUP
For your ODMDATA and uboot, you need to create BUP (offline mode) on your host side and again put it to your device side.
Are you talking about rootfs A/B or even the bootloader A/B is not able to run/update?
Note about -b "jetson-tx2-devkit" parameter. Without it, nv_update_engine is flashing my board as P3636-0001 (Jetson TX2 NX) instead of P2771-0000-500 (Jetson TX2): I see Model: NVIDIA P3636-0001 messages during U-boot load. Look’s like a bug?
So, the fix for DT is:
On host machine:
(Optionally) apply custom changes: change ODMDATA, put u-boot binaries into Linux_for_Tegra/bootloader/t186ref/p2771-0000/500/
Run BUP generator in Linux_for_Tegra directory: sudo ./l4t_generate_soc_bup.sh -p "-S 15032385536" -b "jetson-tx2-devkit" t18x
Copy bl_update_payload to the device /opt/ota_package directory
On device:
Run apt dist-upgrade
Don’t reboot device
Enable A/B: nv_update_engine -e
Update BUP: nv_update_engine -i
Reboot
Even bootloader A/B can’t be enabled if system is booted from SATA (rootfs is placed on /dev/sda3 and root=/dev/sda3 added to extlinux.conf)
# findmnt /
TARGET SOURCE FSTYPE OPTIONS
/ /dev/sda3 ext4 rw,relatime,data=ordered
# nv_update_engine -i
Nvidia A/B-Redundancy Update tool Version 2.1
null input file!
Init SMD partition failed!
null input file!
null input file!
null input file!
A/B has been disabled. Need to enable A/B.
Error: installing bootloader updates failed: -22
# nv_update_engine -e
null input file!
null input file!
null input file!
enabling A/B redundancy
null input file!
Enable A/B command failed. It could be due to A/B being enabled already.
Error: Enable A/B redundancy failed!
What if you use single spec method to create BUP? Will you see this model in uboot?
Yeah, If i use sudo ./l4t_generate_soc_bup.sh -p "-S 15032385536" t18x, without -b flag, then after BUP update I see P3636-0001 in U-boot instead of P2771-0000-500. And my board is definitely TX2, not TX2 NX.
If run from eMMC, with -S in flash.sh, then apt dist-upgrade can’t update bootloader and DT. Custom BUP can be flashed using nv_update_engine and device become fully operational
If run from SATA, with -S in flash.sh, then apt dist-upgrade can’t update bootloader and DT too, but custom BUP can’t be flashed, because nv_update_engine can’t enable A/B which is required to flash BUP
Note than it both cases (rootfs on eMMC and rootfs on SATA), flashing procedure is completely same: ./flash.sh -S 15032385536 -R rootfs jetson-tx2 mmcblk0p1. I just copy rootfs from eMMC to SATA and point extlinux to it using root=
