Can't upgrate to 6.x AGX orin
Using the SDK manager both docker container 20.04 and from ubuntu 20.04 and it will not flash the AGX Orin. Orin is detected and in recovery mode. The same behavior on two AGX orin’s. Docker container 22.04 does flash but then system is in infinite boot loop.
etson System firmware version 36.4.0-gcid-37537400 date 2024-09-13T04:02:39+00:
00
ESC   to enter Setup.
F11   to enter Boot
                   L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
��debugfs initialized
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.148-tegra (buildbrain@mobile-u64-5441-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) )
[    0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x827f4f198 TPMFinalLog=0x818b10000 SMBIOS=0xffff0000 SMBIOS 3.0=0x827940000 MEMATTR=0x821947018 ESRT=0x8207e7d18 TPMEventLog=0x818b28018 RNG=0
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] esrt: Reserving ESRT space from 0x00000008207e7d18 to 0x00000008207e7d50.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000804000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000833ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x828c75800-0x828c77fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000833ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000008189aafff]
[    0.000000]   node   0: [mem 0x00000008189ab000-0x0000000818b1ffff]
[    0.000000]   node   0: [mem 0x0000000818b20000-0x0000000818b2afff]
[    0.000000]   node   0: [mem 0x0000000818b2b000-0x0000000818b2bfff]
[    0.000000]   node   0: [mem 0x0000000818b2c000-0x000000082600ffff]
[    0.000000]   node   0: [mem 0x0000000826010000-0x0000000827f4ffff]
[    0.000000]   node   0: [mem 0x0000000827f50000-0x000000082c5fffff]
[    0.000000]   node   0: [mem 0x000000082c600000-0x000000082c7fffff]
[    0.000000]   node   0: [mem 0x000000082c800000-0x000000082cd6ffff]
[    0.000000]   node   0: [mem 0x000000082d700000-0x000000082d7fffff]
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
��[    0.000000]   node   0: [mem 0x0000000832000000-0x0000000833ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000833ffffff]
[    0.000000] On node 0, zone Normal: 2448 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 18432 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
��[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] Detected PIPT I-cache on CPU0
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
��[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 7930224
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla1_core
��[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=PARTUUID=93b56d37-d8d9-4979-b745-b73f59075f0e rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla1_core
��[    0.000000] Unknown kernel command line parameters "nv-auto-config bl_prof_dataptr=2031616@0x82C610000 bl_prof_ro_ptr=65536@0x82C600000", will be passed to user spac.
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla1_falcon
��[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 31148344K/32225728K available (20160K kernel code, 4064K rwdata, 10060K rodata, 7680K in��WARNING: clock_disable: clk_power_ungate on gated domain n
��it, 529K bss, 815240K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] ��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_core
��rcu:  RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_core
��.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deact��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_falcon
��ivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.00��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_falcon
��0000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000394] Console: colour dummy device 80x25
[    0.000403] printk: console [tty0] enabled
[    0.000466] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000474] pid_max: default: 32768 minimum: 301
[    0.000509] LSM: Security Framework initializing
[    0.000535] Yama: becoming mindful.
[    0.000552] SELinux:  Initializing.
[    0.000665] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000713] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.002156] rcu: Hierarchical SRCU implementation.
[    0.004993] Tegra Revision: A01 SKU: 208 CPU Process: 0 SoC Process: 0
[    0.005314] Remapping and enabling EFI services.
[    0.006167] smp: Bringing up secondary CPUs ...
[    0.006682] Detected PIPT I-cache on CPU1
[    0.006724] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.006766] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.007216] Detected PIPT I-cache on CPU2
[    0.007226] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.007241] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.007635] Detected PIPT I-cache on CPU3
[    0.007645] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.007657] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.010105] Detected PIPT I-cache on CPU4
[    0.010129] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.010153] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.010598] Detected PIPT I-cache on CPU5
[    0.010608] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.010620] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.011032] Detected PIPT I-cache on CPU6
[    0.011043] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.011056] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.011469] Detected PIPT I-cache on CPU7
[    0.011480] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.011494] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.013949] Detected PIPT I-cache on CPU8
[    0.013973] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[    0.013998] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[    0.014442] Detected PIPT I-cache on CPU9
[    0.014454] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[    0.014467] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[    0.014888] Detected PIPT I-cache on CPU10
[    0.014900] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[    0.014914] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[    0.015323] Detected PIPT I-cache on CPU11
[    0.015334] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[    0.015347] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[    0.015401] smp: Brought up 1 node, 12 CPUs
[    0.015406] SMP: Total of 12 processors activated.
[    0.015409] CPU features: detected: 32-bit EL0 Support
[    0.015410] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.015412] CPU features: detected: Common not Private translations
[    0.015413] CPU features: detected: CRC32 instructions
[    0.015414] CPU features: detected: Data cache clean to Point of Persistence
[    0.015416] CPU features: detected: Generic authentication (architected algorithm)
[    0.015417] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.015418] CPU features: detected: LSE atomic instructions
[    0.015419] CPU features: detected: Privileged Access Never
[    0.015420] CPU features: detected: RAS Extension Support
[    0.015422] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.041014] spectre-bhb mitigation disabled by command line option
[    0.065482] CPU: All CPU(s) started at EL2
[    0.070726] devtmpfs: initialized
[    0.095131] KASLR enabled
[    0.095364] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.095398] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.100468] pinctrl core: initialized pinctrl subsystem
[    0.101514] SMBIOS 3.6.0 present.
[    0.101527] DMI: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.4.0-gcid-37537400 09/13/2024
[    0.102137] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.104379] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.104744] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.105072] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.105132] audit: initializing netlink subsys (disabled)
[    0.105305] audit: type=2000 audit(0.104:1): state=initialized audit_enabled=0 res=1
[    0.107836] thermal_sys: Registered thermal governor 'step_wise'
[    0.107840] thermal_sys: Registered thermal governor 'user_space'
[    0.107841] thermal_sys: Registered thermal governor 'power_allocator'
[    0.111969] cpuidle: using governor menu
[    0.112267] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.112450] ASID allocator initialised with 32768 entries
[    0.114398] Serial: AMBA PL011 UART driver
[    0.125656] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 118, base_baud = 0) is a SBSA
[    0.125695] printk: console [ttyAMA0] enabled
[    0.137339] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.146737] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.146746] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.146750] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.146752] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.147874] cryptd: max_cpu_qlen set to 1000
[    0.150118] ACPI: Interpreter disabled.
[    0.152147] iommu: Default domain type: Translated
[    0.152152] iommu: DMA domain TLB invalidation policy: strict mode
[    0.152573] SCSI subsystem initialized
[    0.152741] vgaarb: loaded
[    0.152947] usbcore: registered new interface driver usbfs
[    0.152972] usbcore: registered new interface driver hub
[    0.152990] usbcore: registered new device driver usb
[    0.153394] pps_core: LinuxPPS API ver. 1 registered
[    0.153399] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.153413] PTP clock support registered
[    0.153506] EDAC MC: Ver: 3.0.0
[    0.155069] Registered efivars operations
[    0.155735] FPGA manager framework
[    0.155813] Advanced Linux Sound Architecture Driver Initialized.
[    0.156418] Bluetooth: Core ver 2.22
[    0.156451] NET: Registered PF_BLUETOOTH protocol family
[    0.156453] Bluetooth: HCI device and connection manager initialized
[    0.156464] Bluetooth: HCI socket layer initialized
[    0.156470] Bluetooth: L2CAP socket layer initialized
[    0.156486] Bluetooth: SCO socket layer initialized
[    0.156946] clocksource: Switched to clocksource arch_sys_counter
[    0.192689] VFS: Disk quotas dquot_6.6.0
[    0.192757] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.192995] pnp: PnP ACPI: disabled
[    0.196145] NET: Registered PF_INET protocol family
[    0.196863] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.199220] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.199561] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.199593] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.199810] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.201144] TCP: Hash tables configured (established 262144 bind 65536)
[    0.201430] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.201499] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.201801] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.202265] RPC: Registered named UNIX socket transport module.
[    0.202270] RPC: Registered udp transport module.
[    0.202272] RPC: Registered tcp transport module.
[    0.202273] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.202288] PCI: CLS 0 bytes, default 64
[    0.202582] Unpacking initramfs...
[    0.210186] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.210572] kvm [1]: IPA Size Limit: 48 bits
[    0.210613] kvm [1]: GICv3: no GICV resource entry
[    0.210621] kvm [1]: disabling GICv2 emulation
[    0.210651] kvm [1]: GIC system register CPU interface enabled
[    0.210780] kvm [1]: vgic interrupt IRQ9
[    0.210994] kvm [1]: VHE mode initialized successfully
[    0.214405] Initialise system trusted keyrings
[    0.214456] Key type blacklist registered
[    0.214559] workingset: timestamp_bits=42 max_order=23 bucket_order=0
[    0.218503] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.218927] NFS: Registering the id_resolver key type
[    0.218972] Key type id_resolver registered
[    0.218977] Key type id_legacy registered
[    0.219027] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.219046] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.219068] ntfs: driver 2.1.32 [Flags: R/O].
[    0.219289] 9p: Installing v9fs 9p2000 file system support
[    0.219954] integrity: Platform Keyring initialized
[    0.230345] Key type asymmetric registered
[    0.230351] Asymmetric key parser 'x509' registered
[    0.230418] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.230426] io scheduler mq-deadline registered
[    0.230433] io scheduler kyber registered
[    0.241365] EINJ: ACPI disabled.
[    0.253873] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.255719] SuperH (H)SCI(F) driver initialized
[    0.256048] msm_serial: driver initialized
[    0.256718] printk: console [ttyTCU0] enabled
[    0.257614] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.257620] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.257628] arm-smmu 8000000.iommu:  stage 1 translation
[    0.257632] arm-smmu 8000000.iommu:  stage 2 translation
[    0.257635] arm-smmu 8000000.iommu:  nested translation
[    0.257644] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    0.257650] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    0.257672] arm-smmu 8000000.iommu:  Supported page sizes: 0x61311000
[    0.257677] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    0.257680] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    0.258646] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.258650] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.258652] arm-smmu 10000000.iommu:         stage 1 translation
[    0.258653] arm-smmu 10000000.iommu:         stage 2 translation
[    0.258655] arm-smmu 10000000.iommu:         nested translation
[    0.258659] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    0.258661] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    0.258665] arm-smmu 10000000.iommu:         Supported page sizes: 0x61311000
[    0.258666] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.258668] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.259004] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.259007] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.259009] arm-smmu 12000000.iommu:         stage 1 translation
[    0.259011] arm-smmu 12000000.iommu:         stage 2 translation
[    0.259011] arm-smmu 12000000.iommu:         nested translation
[    0.259014] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    0.259016] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    0.259032] arm-smmu 12000000.iommu:         Supported page sizes: 0x61311000
[    0.259034] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.259037] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.269705] loop: module loaded
[    0.270820] megasas: 07.717.02.00-rc1
[    0.275286] tun: Universal TUN/TAP device driver, 1.6
[    0.275857] thunder_xcv, ver 1.0
[    0.275887] thunder_bgx, ver 1.0
[    0.275911] nicpf, ver 1.0
[    0.276754] hclge is initializing
[    0.276785] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.276794] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.276835] e1000: Intel(R) PRO/1000 Network Driver
[    0.276842] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.276873] e1000e: Intel(R) PRO/1000 Network Driver
[    0.276880] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.276901] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.276907] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.276929] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.276954] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.277190] sky2: driver version 1.30
[    0.277891] VFIO - User Level meta-driver version: 0.3
[    0.279440] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.279450] ehci-pci: EHCI PCI platform driver
[    0.279477] ehci-platform: EHCI generic platform driver
[    0.279563] ehci-orion: EHCI orion driver
[    0.279636] ehci-exynos: EHCI Exynos driver
[    0.279697] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.279718] ohci-pci: OHCI PCI platform driver
[    0.279742] ohci-platform: OHCI generic platform driver
[    0.279812] ohci-exynos: OHCI Exynos driver
[    0.280253] usbcore: registered new interface driver usb-storage
[    0.282129] i2c_dev: i2c /dev entries driver
[    0.283464] pps pps0: new PPS source ktimer
[    0.283474] pps pps0: ktimer PPS source registered
[    0.283483] pps_ldisc: PPS line discipline registered
[    0.285643] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.287844] sdhci: Secure Digital Host Controller Interface driver
[    0.287850] sdhci: Copyright(c) Pierre Ossman
[    0.288327] Synopsys Designware Multimedia Card Interface Driver
[    0.288982] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.290223] ledtrig-cpu: registered to indicate activity on CPUs
[    0.291297] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.291883] tegra-bpmp bpmp: Adding to iommu group 0
[    0.293351] tegra-bpmp bpmp: firmware: 39f77b2baaf3f0522607-da583751bbf
[    0.450917] Freeing initrd memory: 15488K
[    4.485782] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    4.485800] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    4.485802] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    4.486004] hid: raw HID events driver (C) Jiri Kosina
[    4.486347] usbcore: registered new interface driver usbhid
[    4.486353] usbhid: USB HID core driver
[    4.491473] optee: probing for conduit method.
[    4.491525] optee: revision 4.2 (d78bc5fa)
[    4.551742] optee: dynamic shared memory is enabled
[    4.551994] optee: initialized driver
[    4.555288] usbcore: registered new interface driver snd-usb-audio
[    4.556905] NET: Registered PF_PACKET protocol family
[    4.558474] Bluetooth: RFCOMM TTY layer initialized
[    4.558507] Bluetooth: RFCOMM socket layer initialized
[    4.558540] Bluetooth: RFCOMM ver 1.11
[    4.558829] 9pnet: Installing 9P2000 support
[    4.558947] Key type dns_resolver registered
[    4.561437] printk: console [tty0]: printing thread started
[    4.562846] printk: console [ttyTCU0]: printing thread started
[    4.564261] printk: console [ttyAMA0]: printing thread started
[    4.564392] Loading compiled-in X.509 certificates
[    4.570015] Loaded X.509 cert 'Build time autogenerated kernel key: 6057098974cb65317d873b1c27b0a3a1aaaa62bd'
[    4.634190] gpio-394 (camera-control-output-low): hogged as output/low
[    4.634229] gpio-397 (camera-control-output-low): hogged as output/low
[    4.634255] gpio-487 (camera-control-output-low): hogged as output/low
[    4.634273] gpio-486 (camera-control-output-low): hogged as output/low
[    4.683730] simple-framebuffer chosen:framebuffer: framebuffer at 0x839e00000, 0x960000 bytes
[    4.683744] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=1920x1200x32, linelength=8192
[    4.696551] Console: switching to colour frame buffer device 240x75
[    4.699626] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[    4.700574] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    4.702365] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    4.703664] serial-tegra 3100000.serial: RX in PIO mode
[    4.703668] serial-tegra 3100000.serial: TX in PIO mode
[    4.703733] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    4.704804] serial-tegra 3110000.serial: RX in PIO mode
[    4.704810] serial-tegra 3110000.serial: TX in PIO mode
[    4.704850] 3110000.serial: ttyTHS2 at MMIO 0x3110000 (irq = 206, base_baud = 0) is a TEGRA_UART
[    4.708105] tegra_rtc c2a0000.rtc: registered as rtc1
[    4.708114] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    4.708587] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    4.713182] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    4.716236] tegra-i2c 3190000.i2c: Adding to iommu group 1
[    4.719720] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    4.722964] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[    4.726158] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[    4.729749] tegra-i2c c240000.i2c: Adding to iommu group 1
[    4.733416] tegra-i2c c250000.i2c: Adding to iommu group 1
[    4.766716] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[    4.769462] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[    4.772251] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[    4.773263] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[    4.774626] irq: IRQ233: trimming hierarchy from :bus@0:pmc@c360000
[    4.774684] irq: IRQ234: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    4.774730] irq: IRQ235: trimming hierarchy from :bus@0:pmc@c360000
[    4.774783] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    5.231019] ALSA device list:
[    5.231025]   No soundcards found.
[    5.231301] sdhci-tegra 3400000.mmc: Got CD GPIO
[    5.241770] mmc0: CQHCI version 5.10
[    5.276976] mmc0: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[    5.277922] irq: IRQ236: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    5.278230] mmc1: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[    5.279329] Freeing unused kernel memory: 7680K
[    5.279493] Run /init as init process
[    5.290877] Checking overlayfs setting...
[    5.301425] Overlayfs is disabled...
[    5.307916] Root device found: PARTUUID=93b56d37-d8d9-4979-b745-b73f59075f0e
[    5.387722] mmc0: Command Queue Engine enabled
[    5.387734] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    5.388181] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[    5.392998]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    5.397175] mmcblk0boot0: mmc0:0001 G1M15M 31.5 MiB
[    5.397617] mmcblk0boot1: mmc0:0001 G1M15M 31.5 MiB
[    5.398382] mmcblk0rpmb: mmc0:0001 G1M15M 4.00 MiB, chardev (511:0)
[    8.366415] tegra194-pcie 14100000.pcie: Adding to iommu group 4
[    8.369302] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    8.369329] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    8.369336] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    8.369341] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    8.369818] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    8.369822] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.449395] irq: IRQ237: trimming hierarchy from :bus@0:pmc@c360000
[    8.476958] tegra194-pcie 14100000.pcie: Link up
[    8.478529] tegra194-pcie 14100000.pcie: Link up
[    8.478599] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    8.478603] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    8.478608] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    8.478611] pci_bus 0001:00: root bus resource [bus 00-ff]
[    8.478612] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    8.478663] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    8.478827] pci 0001:00:00.0: PME# supported from D0 D3hot
[    8.482342] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    8.482512] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    8.482711] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    8.483757] pci 0001:01:00.0: supports D1 D2
[    8.483758] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    8.495955] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    8.495959] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    8.495962] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    8.496103] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    8.496134] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    8.496137] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    8.496141] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    8.496247] pcieport 0001:00:00.0: Adding to iommu group 4
[    8.496345] pcieport 0001:00:00.0: PME: Signaling with IRQ 200
[    8.496869] pcieport 0001:00:00.0: AER: enabled with IRQ 200
[    8.497665] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[    8.500209] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    8.500225] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    8.500233] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    8.500238] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    8.500722] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    8.500727] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    9.089154] EXT4-fs (mmcblk0p1): recovery complete
[    9.089656] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    9.096658] Rootfs mounted over PARTUUID=93b56d37-d8d9-4979-b745-b73f59075f0e
[    9.104722] Switching from initrd to actual rootfs
[    9.188226] systemd[1]: System time before build time, advancing clock.
[    9.214329] NET: Registered PF_INET6 protocol family
[    9.215372] Segment Routing with IPv6
[    9.215379] In-situ OAM (IOAM) with IPv6
[    9.241468] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CU)
[    9.241842] systemd[1]: Detected architecture arm64.
[    9.286365] systemd[1]: Hostname set to <localhost.localdomain>.
[    9.302814] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog
[    9.302831] systemd[1]: Set hardware watchdog to 2min.
[    9.510058] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit.
[    9.537049] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your u.
[    9.608948] tegra194-pcie 14160000.pcie: Phy link never came up
[    9.609572] systemd[1]: Queued start job for default target OEM Configuration.
[    9.610968] systemd[1]: Created slice Slice /system/modprobe.
[    9.612502] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    9.636787] systemd[1]: Reached target Slice Units.
[    9.655039] systemd[1]: Reached target Swaps.
[    9.656085] systemd[1]: Reached target Local Verity Protected Volumes.
[    9.676574] systemd[1]: Listening on RPCbind Server Activation Socket.
[    9.685838] systemd[1]: Listening on fsck to fsckd communication Socket.
[    9.686950] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    9.688228] systemd[1]: Listening on Journal Audit Socket.
[    9.712112] systemd[1]: Listening on Journal Socket (/dev/log).
[    9.720553] systemd[1]: Listening on Journal Socket.
[    9.728362] systemd[1]: Listening on udev Control Socket.
[    9.736145] systemd[1]: Listening on udev Kernel Socket.
[    9.744767] systemd[1]: Mounting Huge Pages File System...
[    9.753577] systemd[1]: Mounting POSIX Message Queue File System...
[    9.755484] systemd[1]: Mounting Kernel Debug File System...
[    9.757472] systemd[1]: Mounting Kernel Trace File System...
[    9.782084] systemd[1]: Starting Journal Service...
[    9.784429] systemd[1]: Starting Set the console keyboard layout...
[    9.800821] systemd[1]: Starting Create List of Static Device Nodes...
[    9.810774] systemd[1]: Starting Load Kernel Module configfs...
[    9.812765] systemd[1]: Starting Load Kernel Module efi_pstore...
[    9.829348] systemd[1]: Starting Load Kernel Module fuse...
[    9.831355] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    9.833437] systemd[1]: Started Nameserver information manager.
[    9.855344] fuse: init (API version 7.34)
[    9.855784] systemd[1]: Reached target Preparation for Network.
[    9.856771] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    9.863386] systemd[1]: Starting Load Kernel Modules...
[    9.872360] nvsciipc: loading out-of-tree module taints kernel.
[    9.879469] nvsciipc: loaded module
[    9.887075] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    9.887636] nvmap_co_device_init: vpr :dma coherent mem declare 0x0000000849800000,914358272
[    9.887642] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    9.887652] nvmap_page_pool_init: Total RAM pages: 7858414
[    9.887653] nvmap_page_pool_init: nvmap page pool size: 982301 pages (3837 MB)
[    9.887719] nvmap_background_zero_thread: PP zeroing thread starting.
[    9.887743] nvmap_heap_create: created heap vpr base 0x0000000849800000 size (892928KiB)
[    9.887767] nvmap_heap_create: fsi :dma coherent mem declare 0x000000082f000000,16777216
[    9.887768] nvmap_heap_create: created heap fsi base 0x000000082f000000 size (16384KiB)
[    9.898213] tegra-host1x 13e00000.host1x: Adding to iommu group 6
[    9.899535] host1x-context host1x-ctx.0: Adding to iommu group 7
[    9.899673] host1x-context host1x-ctx.1: Adding to iommu group 8
[    9.899793] host1x-context host1x-ctx.2: Adding to iommu group 9
[    9.899913] host1x-context host1x-ctx.3: Adding to iommu group 10
[    9.900030] host1x-context host1x-ctx.4: Adding to iommu group 11
[    9.900146] host1x-context host1x-ctx.5: Adding to iommu group 12
[    9.900266] host1x-context host1x-ctx.6: Adding to iommu group 13
[    9.900379] host1x-context host1x-ctx.7: Adding to iommu group 14
[    9.900503] host1x-context host1x-ctx.8: Adding to iommu group 15
[    9.900624] host1x-context host1x-ctx.9: Adding to iommu group 16
[    9.900737] host1x-context host1x-ctx.10: Adding to iommu group 17
[    9.900850] host1x-context host1x-ctx.11: Adding to iommu group 18
[    9.900988] host1x-context host1x-ctx.12: Adding to iommu group 19
[    9.901121] host1x-context host1x-ctx.13: Adding to iommu group 20
[    9.901241] host1x-context host1x-ctx.14: Adding to iommu group 21
[    9.901370] host1x-context host1x-ctx.15: Adding to iommu group 22
[    9.907394] systemd[1]: Starting Remount Root and Kernel File Systems...
[    9.915193] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null). Quota mode: none.
[    9.993707] systemd[1]: Starting Coldplug All udev Devices...
[    9.999495] nvgpu: 17000000.gpu          nvgpu_nvhost_syncpt_init:122  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.999495]
[   10.051898] systemd[1]: Started Journal Service.
[   10.173552] systemd-journald[303]: Received client request to flush runtime journal.
[   10.564214] CPU:0, Error: cbb-fabric@0x13a00000, irq=190
[   10.564221] **************************************
[   10.564222] CPU:0, Error:cbb-fabric, Errmon:2
[   10.564228]    Error Code            : TIMEOUT_ERR
[   10.564237]
[   10.564238]    Error Code            : TIMEOUT_ERR
[   10.564239]    MASTER_ID             : CCPLEX
[   10.564241]    Address               : 0x1550265c
[   10.564242]    Cache                 : 0x1 -- Bufferable
[   10.564244]    Protection            : 0x2 -- Unprivileged, Non-Secure, Data Access
[   10.564247]    Access_Type           : Read
[   10.564248]    Access_ID             : 0x11
[   10.564249]    Fabric                : cbb-fabric
[   10.564251]    Slave_Id              : 0x3
[   10.564252]    Burst_length          : 0x0
[   10.564253]    Burst_type            : 0x1
[   10.564254]    Beat_size             : 0x2
[   10.564255]    VQC                   : 0x0
[   10.564256]    GRPSEC                : 0x7e
[   10.564257]    FALCONSEC             : 0x0
[   10.564261]    HOST1X_SLV_TIMEOUT_STATUS : 0x1
[   10.564263]  **************************************
[   10.564287] WARNING: CPU: 0 PID: 0 at drivers/soc/tegra/cbb/tegra234-cbb.c:608 tegra234_cbb_isr+0x14c/0x180
[   10.564423] ---[ end trace 5b84ad954a29233e ]---
[   10.865955] CPU:0, Error: cbb-fabric@0x13a00000, irq=190
[   10.865957] **************************************
[   10.865958] CPU:0, Error:cbb-fabric, Errmon:2
[   10.865963]    Error Code            : TIMEOUT_ERR
[   10.865964]    Overflow              : Multiple TIMEOUT_ERR
[   10.865972]
[   10.865972]    Error Code            : TIMEOUT_ERR
[   10.865973]    MASTER_ID             : CCPLEX
[   10.865974]    Address               : 0x15502388
[   10.865975]    Cache                 : 0x1 -- Bufferable
[   10.865976]    Protection            : 0x2 -- Unprivileged, Non-Secure, Data Access
[   10.865977]    Access_Type           : Read
[   10.865977]    Access_ID             : 0x11
[   10.865978]    Fabric                : cbb-fabric
[   10.865978]    Slave_Id              : 0x3
[   10.865979]    Burst_length          : 0x0
[   10.865979]    Burst_type            : 0x1
[   10.865980]    Beat_size             : 0x2
[   10.865980]    VQC                   : 0x0
[   10.865981]    GRPSEC                : 0x7e
[   10.865981]    FALCONSEC             : 0x0
[   10.865983]    HOST1X_SLV_TIMEOUT_STATUS : 0x1
[   10.865985]  **************************************
[   10.866000] WARNING: CPU: 0 PID: 0 at drivers/soc/tegra/cbb/tegra234-cbb.c:608 tegra234_cbb_isr+0x14c/0x180
[   10.866098] ---[ end trace 5b84ad954a29233f ]---
Hi theokersjes,
Please provide the log as file here instead of pasting all contents for better reading.
Are you trying to flashing JP6.0 or JP6.1?
It seems there’s kernel panic in your serial console log.
Please share the full flash log for the flash failed issue.
I am now working on 6.1 .
However I have tried all 6.x version with sdkmanager in the correct ubuntu version as well as with the sdkmanager docker files. Similar behavior on all these version “infinite boot”
And then when I reach out it was because now non of these version flash the Jetson AGX Orin anymore. So I now have tried:
Tegra_Linux_Sample-Root-Filesystem_R36.4.0_aarch64.tbz2
Jetson_Linux_R36.4.0_aarch64.tbz2
with docker
nvcr.io/nvidia/jetson-linux-flash-x86 r36.3
this did flash the AGX orin again and it boots to Ubuntu 22.04 Welcome screen.
But the mouse and Keyboard are not working. I do get login prompt on the terminal see log file but no user or password is set.
Logfile6.1BootNoMouseOrKeyboard.txt (36.1 KB)
After this I tried to use sdkmanager again in 20.04 and still it will not flash from the sdkmanager. It still boots in the the 22.04 welcom screen and the log is the same with asking for localhost login and password.
with docker
nvcr.io/nvidia/jetson-linux-flash-x86 r36.4
I tried on a second Jetson AGX orin and this system is now in the same situation.
Both boot to the Ubuntu welcome screen but no mouse or keyboard to continue setup.
I need 6.x could be 6.0. should I try that?
From the log you shared, it seems it has booted from internal eMMC sucessfully.
Have you tried Flashing Support — NVIDIA Jetson Linux Developer Guide 1 documentation to pre-configure the username/password?
Yes I looked at this but cant run the command in the docker containerERROR: Cannot find the Tegra software license agreement
I can’t find a solution for this.
root@the-:/l4t/workspace/Linux_for_Tegra/tools# sudo ./l4t_create_default_user.sh -u nvidia -p banana
I started all over removing the need for the docker container.
Now I have the infinite boot again, log file attached.
  • Installed Ubuntu 22.04
  • installed SDKmanager and try to flash (does not work)
  • Jetson_Multimedia_API_R36.4.0_aarch64
  • Tegra_Linux_Sample-Root-Filesystem_R36.4.0_aarch64
  • used 4t_create_default_user.sh
  • then sudo ./apply_binaries.sh
  • then flash
(Attachment logfile_R36.4_infinit_boot is missing)
  • then flash
(attachments)
logfile_R36_4_infinit_boot.txt (35.3 KB)
Could you use the following link as BSP package instead?
https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v4.0/release/Jetson_Linux_R36.4.0_aarch64.tbz2
From the log you shared, it seems you have panic issue.
I am using the devkit AGX orin.
I am now trying the BSP provided
Theo
Same problem after flash infinite boot.
Is there anything else I can try.
We can’t reproduce the similar issue on the AGX Orin devkit with JP6.1 installed.
From your original post, you said SDK manager can’t flash the AGX Orin devkit.
Could you share the full flash log for further check?
