Help, I bricked my AGX orin 64G
I tried to install the KDE desktop. Now it will not boot. Help
The GUI might be failed, but it isn’t really possible to “brick” a Jetson (most “bricked” systems have a BIOS, and the BIOS itself is corrupt, but Jetsons don’t have a BIOS…the same function runs on a host PC during flash and thus cannot fail).
Incidentally, if this used wired ethernet, then networking should still be up. Do you have ssh access?
Also, serial console would work even if the GUI fails. Serial console is by far the best tool you have. Can you get a serial console boot log? If so, then you could also log in via this and try to change packages.
Note that if KDE fails (or anything X server fails), then usually you can use the key binding CTRL-ALT-F3 to get to a regular console for repair login. Note that a server usually runs on the first binding, ALT-F1, and that consoles would be on CTRL-ALT-F2 through CTRL-ALT-F6, but on some systems it isALT-F2, and so I suggest CTRL-ALT-F3 to find a console since it is rare this runs the GUI.
I do not see my AGX orin
vance@Minis-Vance-KDE:~$ lsusb
Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 010 Device 004: ID 0781:55ae SanDisk Corp. Extreme 55AE
Bus 010 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 012 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 011 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 004: ID 0e8d:0608 MediaTek Inc. Wireless_Device
Bus 005 Device 005: ID 2563:0311 ShenZhen ShanWan Technology Co., Ltd. 2.4G Wireless Mouse
Bus 005 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 005 Device 002: ID 0c45:7605 Microdia Das Keyboard
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
How do I restore it back to factory settings?
You would only see your jetson as a usb device if it is in recovery mode.
You may just use SDKM on Linux host for reflashing your Jetson device.
Yes, I just discovered that. Thanks
Bus 001 Device 002: ID 0955:7023 NVIDIA Corp. APX
Can you send me a link to the serial settings, instructions and commands on how to restore the factory settings. This seems really basic, but I can’t find anything on the NVIDIA developers website.
I tried to install SDK manager on my host system but could not complete it. How do I link my AGX Orin as the target OS? I am a newbie to NVIDIA SDKs.
  1. How do I burn a bootable recovery system on to an SDcard and boot it up to restore it back to factory settings?
  2. Where can I down load the sdcard image?
  3. How do I force the AGX Orid to boot on the sdcard?
The ESC key does not enter the boot options. Any idea when this will be fixed?
Can someone please update these instructions to include ubuntu 22.04.1 LTS.
https://developer.download.nvidia.com/embedded/L4T/r35_Release_v1.0/README.txt?t=eyJscyI6ImdzZW8iLCJsc2QiOiJodHRwczovL3d3dy5nb29nbGUuY29tLyJ9
Ok. Can you point me to the instructions on how to do that? Thanks
This is my first Development project and have little idea what you are asking me.
The ESC key has no effect on the boot. Can you point me to something describing how to login with a serial console?
For JetPack 4.x or earlier (which is a frontend flashing L4T R32.x or earlier) the host PC should be Ubuntu 18.04. For JetPack 5.x or newer (which is what all Orins use, so this applies to you) the host PC can be either Ubuntu 18.04 or Ubuntu 20.04. Ubuntu 22.04 is not supported. You will find docs mentioning SDK Manager (which is a download helper for JetPack) works with Ubuntu 22.04, but it does not make it obvious that SDKM supports other NVIDIA hardware beyond Jetsons, and that Ubuntu 22.04 is not compatible with JetPack 5.x. Confusing eh? Summary:
  • L4T is “Linux for Tegra”, which is just Ubuntu plus NVIDIA drivers. This is what gets flashed.
  • JetPack is a GUI frontend for flashing (you can also use command line and skip JetPack; this increases the range of working host Linux distributions).
  • A typical command line flash, from the “Linux_for_Tegra/” directory is this (not guaranteed to work except on Ubuntu 18.04 and 20.04, but it might work even on Fedora):
    sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
    (this assumes an Orin dev kit)
  • SDKM is the network part of JetPack and login to this aids automatic download and install of components on the host PC.
Thank You Linuxdev. Turns out the microusb cable I was using only had wires for charging, I was able to log in through the terminal. I will install Ubuntu 20.04 onto my host and try again.
What does this mean when flashing Jetson from SDK Manager?
Default ip is not avaliable. Please make sure the default ip is shown in ip addr, or use a customer ip instead.
Is there another server I can use to download the SDK Manager components? After one hour, CUDA failed.
I finally got the SDK to start the flash process, but the modules will not download. Here is the flash log errors…
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.0626 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.0718 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.0722 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.0829 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.0832 ] adding BCH for mb2_t234_aligned.bin
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.0888 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1047 ] adding BCH for mb2_t234_aligned.bin
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1196 ] Assuming zero filled SBK key
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1633 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1644 ] WARNING: boot chain is not completed. set to 0
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1695 ] Assuming zero filled SBK key
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1754 ] Offset :4608 Len :3584
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1800 ] MB1-BCT version: 0.9
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1818 ] Added Platform Config 9 data with size :- 80
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1865 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1887 ] Assuming zero filled SBK key
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1923 ] MB1-BCT version: 0.9
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1939 ] Added Platform Config 9 data with size :- 80
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.1981 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
20:15:24 INFO: Flash Jetson AGX Orin - flash: [ 0.2005 ] Assuming zero filled SBK key
20:15:25 INFO: Flash Jetson AGX Orin - flash: [ 0.2081 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
20:15:25 INFO: Flash Jetson AGX Orin - flash: [ 0.2086 ] BR_CID: 0x80012344705DD5C728000000050102C0
20:15:25 INFO: Flash Jetson AGX Orin - flash: [ 0.7346 ] Sending bct_br
20:15:30 ERROR: Flash Jetson AGX Orin - flash: [ 1.2574 ] ERROR: might be timeout in USB write.
20:15:30 INFO: Flash Jetson AGX Orin - flash: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
20:15:30 INFO: Flash Jetson AGX Orin - flash: Reading board information failed.
20:15:30 ERROR: Flash Jetson AGX Orin - flash: — Error: Reading board information failed.
20:15:30 ERROR: Flash Jetson AGX Orin - flash: command terminated with error
20:15:30 SUMMARY: DateTime Target Setup - target: Depends on failed component
Hurray, I was finally able to flash my AGX Orin 32GB platform back to the factory install. I followed the instructions here > https://developer.download.nvidia.com/embedded/L4T/r35_Release_v1.0/README.txt?t=eyJscyI6ImdzZW8iLCJsc2QiOiJodHRwczovL3d3dy5nb29nbGUuY29tLyJ9
and used the following command to start the process >
sudo ./nvautoflash.sh jetson-agx-orin-devkit-as-jao-32gb
Can someone please update and correct these instructions so the poor Newbies like myself don’t waste days trying to figure this out. Thank You for the helping me and posting these mostly correct old instructions.
I am still unable to install SDKM, it appears that the server is down.
For those trying to reinstall SDKmanager on kubuntu 20.04, try the following:
$ uname -a
Linux vance-UM690 5.15.0-58-generic #64~20.04.1-Ubuntu SMP Fri Jan 6 16:42:31 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
$ sdkmanager --cli uninstall --logintype devzone --product Jetson --version 5.0.2 --targetos Linux --host --target JETSON_AGX_ORIN_TARGETS
No update is available.
Authenticating with NVIDIA server…
Login succeeded.
Loading user information…
User information loaded successfully.
Loading server data…
Server data loaded successfully.
Session initialized…
===== UNINSTALLATION COMPLETED SUCCESSFULLY. =====
- CUDA on Host: Uninstalled
- CUDA Cross Compile Package on Host: Uninstalled
- NvSci: Uninstalled
- VPI on Host: Uninstalled
- Nsight Systems: Uninstalled
- Nsight Graphics: Uninstalled
- Nsight Compute: Uninstalled
- CUPTI: Uninstalled
- Compute Sanitizer: Uninstalled
- Drivers for Jetson: Uninstalled
- File System and OS: Uninstalled
===== Uninstallation completed successfully - Total 11 components =====
===== 11 succeeded, 0 failed, 0 up-to-date, 0 skipped =====
Download the latest version of SDKmanager here> Download and Run SDK Manager :: NVIDIA SDK Manager Documentation
And follow and installation instructions.
Note: check the box - Download now, install later.
