JP6 DP Flash BSP will fail on use Kernel compile by myself
Hi all
Jetpack Version: JP6.0 DP
Platform: Orin NX 16G
Hardware: Devkit / custom Board
If we just change device tree to flash R36.2.0 BSP to Orin NX platform , that will flash BSP successful.
But because we has some function need to enable with Kernel by modify defconfig and compile myself.
However when we follow below website , “chapter. Building the Jetson Linux Kernel” and “chapter. Building the NVIDIA Out-of-Tree Modules” compile Kernel , kernel module and install. when flash BSP will fail…
https://docs.nvidia.com/jetson/archives/r36.2/DeveloperGuide/SD/Kernel/KernelCustomization.html
BSP folder error message like below information:
Waiting for target to boot-up…
Waiting for device to expose ssh …RTNETLINK answers: File exists
Waiting for device to expose ssh …Run command: flash on fc00:1:1:0::2
SSH ready
blockdev: cannot open /dev/mmcblk3boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/internal/flash.idx
Number of lines is 61
max_index=60
[ 0]: l4t_flash_from_kernel: Successfully create gpt for emmc
[ 0]: l4t_flash_from_kernel: Starting to create gpt for external device
Active index file is /mnt/external/flash.idx
Number of lines is 18
max_index=17
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed--0, e950cb9e43ce26615e2b09267d7836d077e6eaf5
Writing primary_gpt partition with gpt_primary_9_0.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/mnt/external/gpt_primary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0210133 s, 804 kB/s
Writing primary_gpt partition done
Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 114903984 blocks) or continue with the current setting?
Writing secondary_gpt partition with gpt_secondary_9_0.bin
dd if=/mnt/external/gpt_secondary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=61203267072 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.021869 s, 773 kB/s
Writing secondary_gpt partition done
Fix/Ignore? Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 114903984 blocks) or continue with the current setting?
Fix
Model: M.2 (P42) 3TE6 (nvme)
Disk /dev/nvme0n1: 120GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
2 20.5kB 134MB 134MB A_kernel msftdata
3 134MB 135MB 786kB A_kernel-dtb msftdata
4 135MB 168MB 33.2MB A_reserved_on_user msftdata
5 168MB 302MB 134MB B_kernel msftdata
6 302MB 303MB 786kB B_kernel-dtb msftdata
7 303MB 336MB 33.2MB B_reserved_on_user msftdata
8 336MB 420MB 83.9MB recovery msftdata
9 420MB 421MB 524kB recovery-dtb msftdata
10 421MB 488MB 67.1MB fat32 esp boot, esp
11 488MB 572MB 83.9MB recovery_alt msftdata
12 572MB 572MB 524kB recovery-dtb_alt msftdata
13 572MB 639MB 67.1MB esp_alt msftdata
14 639MB 1059MB 419MB UDA msftdata
15 1059MB 1562MB 503MB reserved msftdata
1 1562MB 61.2GB 59.6GB ext4 APP msftdata
[ 1]: l4t_flash_from_kernel: Expanding last partition to fill the storage device
[ 1]: l4t_flash_from_kernel: Successfully create gpt for external device
Flash index file is /mnt/internal/flash.idx
max_index=60
[ 1]: l4t_flash_from_kernel: Starting to flash to qspi
mtd_debug: error!: open()
QSPI storage size: bytes.
max_index=60
Writing br_bct_BR.bct (parittion: BCT) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/br_bct_BR.bct
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:0
[ 1]: l4t_flash_from_kernel: Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:0 failed
[ 1]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
Flash failure
Cleaning up…
Debug Port Message:
Jetson System firmware version 36.2.0-gcid-34956989 date 2023-11-30T18:35:35+00:
00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
▒▒debugfs initialized
▒▒I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
▒▒[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.122-tegra (root@jack-HP-Z2-G9-Workstation) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Fri Dec 15 10:51:55 CST 2023 ()
[ 0.000000] Machine model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: SMBIOS=0xffff0000 SMBIOS 3.0=0x43b660000 MEMATTR=0x43597d018 RNG=0x427870018 MEMRESERVE=0x429e33f18
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000461000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000477ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x460312800-0x460314fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000477ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000bdffffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000fdfdffff]
[ 0.000000] node 0: [mem 0x00000000fdfe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000042c673fff]
[ 0.000000] node 0: [mem 0x000000042c674000-0x000000042c85bfff]
[ 0.000000] node 0: [mem 0x000000042c85c000-0x0000000439d3ffff]
[ 0.000000] node 0: [mem 0x0000000439d40000-0x000000043bc7ffff]
[ 0.000000] node 0: [mem 0x000000043bc80000-0x0000000471dfffff]
[ 0.000000] node 0: [mem 0x0000000471e00000-0x0000000471ffffff]
[ 0.000000] node 0: [mem 0x0000000472000000-0x000000047259ffff]
[ 0.000000] node 0: [mem 0x0000000476000000-0x0000000477ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000477ffffff]
[ 0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 14944 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80344 r8192 d30248 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.00mod /lib/modCPUuleress/5.122-tcteegrSpextra/driv4
ers.00/net/ethe ferneealres/r8168: dcte.kod:
Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4065184
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00pro ERROR: coul[ 0d n.00ot ins0] Unknowertn kel ‘r8’:man Invalid d larg paumeetent"mminit_loglevel=4 fbcon=map:0 bl_prof_ble_reaptmot031e_ass@0x471E10000 blmotof_e accero_ss536@0x471E00000", will be passed to user smod /lib/module 0.15000.12egra/ktry cael/drish vertable ents/ptegra/phys: -te7152 (graord194er:-p2, 1u.k721ytes, linear)
[ 0.000000] Inode-cache hash table entries: 1insmod /lib/576modrdes/5r: .1588608 bytegra/k lineadri
s/p[ ci/contro 0r/dwc/000mempci auinie-tt: stack:4.ko , h
eap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000f9fe0000-0x00000000fdfe0000] (64MB)
[ 0.000000] Memory: 15691736K/16520832K available (18880K kernel code, 4048K rwdata, 9928K rodata, 7616K init, 520K bss, 566952K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000000] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000308] Console: colour dummy device 80x25
[ 0.000349] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000353] pid_max: default: 32768 minimum: 301
[ 0.000376] LSM: Security Framework initializing
[ 0.000391] Yama: becoming mindful.
[ 0.000401] SELinux: Initializing.
[ 0.000455] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000475] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.001252] rcu: Hierarchical SRCU implementation.
[ 0.003168] Tegra Revision: A01 SKU: 211 CPU Process: 0 SoC Process: 0
[ 0.003395] Remapping and enabling EFI services.
[ 0.004156] smp: Bringing up secondary CPUs …
[ 0.004501] Detected PIPT I-cache on CPU1
[ 0.004529] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.004544] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.004870] Detected PIPT I-cache on CPU2
[ 0.004881] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.004893] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.005197] Detected PIPT I-cache on CPU3
[ 0.005206] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.005217] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.007495] Detected PIPT I-cache on CPU4
[ 0.007516] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.007535] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.007886] Detected PIPT I-cache on CPU5
[ 0.007896] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.007908] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.008237] Detected PIPT I-cache on CPU6
[ 0.008247] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.008259] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.008579] Detected PIPT I-cache on CPU7
[ 0.008589] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.008601] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.008644] smp: Brought up 1 node, 8 CPUs
[ 0.008647] SMP: Total of 8 processors activated.
[ 0.008649] CPU features: detected: 32-bit EL0 Support
[ 0.008650] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.008652] CPU features: detected: Common not Private translations
[ 0.008653] CPU features: detected: CRC32 instructions
[ 0.008653] CPU features: detected: Data cache clean to Point of Persistence
[ 0.008655] CPU features: detected: Generic authentication (architected algorithm)
[ 0.008655] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.008656] CPU features: detected: LSE atomic instructions
[ 0.008657] CPU features: detected: Privileged Access Never
[ 0.008657] CPU features: detected: RAS Extension Support
[ 0.008659] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.029751] CPU: All CPU(s) started at EL2
[ 0.031431] devtmpfs: initialized
[ 0.041629] KASLR enabled
[ 0.041722] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.041734] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.043779] pinctrl core: initialized pinctrl subsystem
[ 0.044283] SMBIOS 3.6.0 present.
[ 0.044293] DMI: Unknown NVIDIA Jetson Orin NX Engineering Reference Developer Kit/NVIDIA Jetson Orin NX Engineering Reference Developer Kit, BI
[ 0.044584] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.045679] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.045781] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.045877] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.045901] audit: initializing netlink subsys (disabled)
[ 0.045976] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
[ 0.046832] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.046835] thermal_sys: Registered thermal governor ‘user_space’
[ 0.046836] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.048645] cpuidle: using governor menu
[ 0.048749] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.048825] ASID allocator initialised with 32768 entries
[ 0.049794] Serial: AMBA PL011 UART driver
[ 0.050405] printk: console [ramoops-1] enabled
[ 0.050407] pstore: Registered ramoops as persistent store backend
[ 0.050408] ramoops: using 0x200000@0x4725f0000, ecc: 0
[ 0.057094] tegra-mc 2c00000.memory-controller: unknown: write @0x00000000500605d0: Security violation (TrustZone violation)
[ 0.057569] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 116, base_baud = 0) is a SBSA
[ 0.065461] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.071765] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.071769] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.071771] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.071773] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.072334] cryptd: max_cpu_qlen set to 1000
[ 0.073371] ACPI: Interpreter disabled.
[ 0.074195] VDD_1V8_AO: supplied by VDD_5V0_SYS
[ 0.074285] VDD_3V3_AO: supplied by VDD_5V0_SYS
[ 0.074465] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[ 0.074703] iommu: Default domain type: Translated
[ 0.074706] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.074851] SCSI subsystem initialized
[ 0.074949] vgaarb: loaded
[ 0.075033] usbcore: registered new interface driver usbfs
[ 0.075044] usbcore: registered new interface driver hub
[ 0.075054] usbcore: registered new device driver usb
[ 0.075359] pps_core: LinuxPPS API ver. 1 registered
[ 0.075362] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.075367] PTP clock support registered
[ 0.075411] EDAC MC: Ver: 3.0.0
[ 0.075974] Registered efivars operations
[ 0.076349] FPGA manager framework
[ 0.076412] Advanced Linux Sound Architecture Driver Initialized.
[ 0.076874] clocksource: Switched to clocksource arch_sys_counter
[ 0.094185] VFS: Disk quotas dquot_6.6.0
[ 0.094215] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.094323] pnp: PnP ACPI: disabled
[ 0.096428] NET: Registered PF_INET protocol family
[ 0.096641] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.098759] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.098778] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.098787] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.098896] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.099439] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.099523] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.099554] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.099645] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.099858] RPC: Registered named UNIX socket transport module.
[ 0.099860] RPC: Registered udp transport module.
[ 0.099860] RPC: Registered tcp transport module.
[ 0.099861] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.099868] PCI: CLS 0 bytes, default 64
[ 0.099991] Unpacking initramfs…
[ 0.105324] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.105469] kvm [1]: IPA Size Limit: 48 bits
[ 0.105487] kvm [1]: GICv3: no GICV resource entry
[ 0.105490] kvm [1]: disabling GICv2 emulation
[ 0.105504] kvm [1]: GIC system register CPU interface enabled
[ 0.105573] kvm [1]: vgic interrupt IRQ9
[ 0.105678] kvm [1]: VHE mode initialized successfully
[ 0.107465] Initialise system trusted keyrings
[ 0.107531] workingset: timestamp_bits=42 max_order=22 bucket_order=0
[ 0.109652] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.109863] NFS: Registering the id_resolver key type
[ 0.109875] Key type id_resolver registered
[ 0.109877] Key type id_legacy registered
[ 0.109902] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.109908] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.109926] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.110034] 9p: Installing v9fs 9p2000 file system support
[ 0.122041] NET: Registered PF_ALG protocol family
[ 0.122048] Key type asymmetric registered
[ 0.122050] Asymmetric key parser ‘x509’ registered
[ 0.122083] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.122087] io scheduler mq-deadline registered
[ 0.122090] io scheduler kyber registered
[ 0.128567] EINJ: ACPI disabled.
[ 0.136495] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.137550] SuperH (H)SCI(F) driver initialized
[ 0.137782] msm_serial: driver initialized
[ 0.138155] printk: console [ttyTCU0] enabled
[ 0.138738] arm-smmu 8000000.iommu: probing hardware configuration…
[ 0.138741] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.138744] arm-smmu 8000000.iommu: stage 1 translation
[ 0.138745] arm-smmu 8000000.iommu: stage 2 translation
[ 0.138746] arm-smmu 8000000.iommu: nested translation
[ 0.138750] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.138752] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.138770] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.138771] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.138772] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.139519] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.139521] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.139523] arm-smmu 10000000.iommu: stage 1 translation
[ 0.139523] arm-smmu 10000000.iommu: stage 2 translation
[ 0.139524] arm-smmu 10000000.iommu: nested translation
[ 0.139526] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.139528] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.139531] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.139532] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.139533] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.139824] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.139826] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.139828] arm-smmu 12000000.iommu: stage 1 translation
[ 0.139829] arm-smmu 12000000.iommu: stage 2 translation
[ 0.139830] arm-smmu 12000000.iommu: nested translation
[ 0.139832] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.139834] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.139837] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.139838] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.139839] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.147930] loop: module loaded
[ 0.148759] megasas: 07.717.02.00-rc1
[ 0.152681] tun: Universal TUN/TAP device driver, 1.6
[ 0.153265] thunder_xcv, ver 1.0
[ 0.153296] thunder_bgx, ver 1.0
[ 0.153325] nicpf, ver 1.0
[ 0.154121] hclge is initializing
[ 0.154158] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.154166] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.154204] e1000: Intel(R) PRO/1000 Network Driver
[ 0.154211] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.154248] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.154251] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.154276] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.154281] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.154294] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.154300] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.154509] sky2: driver version 1.30
[ 0.155135] VFIO - User Level meta-driver version: 0.3
[ 0.156599] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.156610] ehci-pci: EHCI PCI platform driver
[ 0.156638] ehci-platform: EHCI generic platform driver
[ 0.156708] ehci-orion: EHCI orion driver
[ 0.156769] ehci-exynos: EHCI Exynos driver
[ 0.156840] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.156864] ohci-pci: OHCI PCI platform driver
[ 0.156917] ohci-platform: OHCI generic platform driver
[ 0.156994] ohci-exynos: OHCI Exynos driver
[ 0.157414] usbcore: registered new interface driver usb-storage
[ 0.159125] rtc-efi rtc-efi.0: registered as rtc0
[ 0.159174] rtc-efi rtc-efi.0: setting system clock to 1970-01-01T20:31:58 UTC (73918)
[ 0.159637] i2c_dev: i2c /dev entries driver
[ 0.162745] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.164578] sdhci: Secure Digital Host Controller Interface driver
[ 0.164584] sdhci: Copyright(c) Pierre Ossman
[ 0.165048] Synopsys Designware Multimedia Card Interface Driver
[ 0.165686] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.166748] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.167613] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.168094] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.169757] tegra-bpmp bpmp: firmware: e350806227175366b0bd-ac83764aab0
[ 0.681604] Freeing initrd memory: 38576K
[ 3.296912] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 3.296949] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 3.296952] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 3.297502] usbcore: registered new interface driver usbhid
[ 3.297509] usbhid: USB HID core driver
[ 3.302999] optee: probing for conduit method.
[ 3.303052] optee: revision 3.22 (1b7f2993)
[ 3.362498] optee: dynamic shared memory is enabled
[ 3.362753] optee: initialized driver
[ 3.365285] usbcore: registered new interface driver snd-usb-audio
[ 3.366931] NET: Registered PF_PACKET protocol family
[ 3.367182] 9pnet: Installing 9P2000 support
[ 3.367290] Key type dns_resolver registered
[ 3.368287] printk: console [ttyTCU0]: printing thread started
[ 3.369081] printk: console [ramoops-1]: printing thread started
[ 3.369173] Loading compiled-in X.509 certificates
[ 3.383907] Loaded X.509 cert ‘Build time autogenerated kernel key: bf53c9728f7d1de49ce8b142185151e9f9049a72’
[ 3.385885] pstore: Using crash dump compression: deflate
[ 3.428735] simple-framebuffer chosen:framebuffer: framebuffer at 0x47de00000, 0x870000 bytes
[ 3.428752] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=1920x1080x32, linelength=8192
[ 3.430277] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[ 3.430837] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 3.432248] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 3.434263] 3110000.serial: ttyS1 at MMIO 0x3110000 (irq = 197, base_baud = 4250000) is a Tegra
[ 3.434698] serial-tegra 3100000.serial: RX in PIO mode
[ 3.434705] serial-tegra 3100000.serial: TX in PIO mode
[ 3.434744] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 3.435096] serial-tegra 3140000.serial: RX in PIO mode
[ 3.435100] serial-tegra 3140000.serial: TX in PIO mode
[ 3.435131] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 198, base_baud = 0) is a TEGRA_UART
[ 3.436861] tegra_rtc c2a0000.rtc: registered as rtc1
[ 3.436876] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.437276] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 3.440165] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 3.441557] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 3.443287] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 3.445083] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 3.463555] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1989000 KHz, changing to: 1984000 KHz
[ 3.465009] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1987000 KHz, changing to: 1984000 KHz
[ 3.466437] irq: IRQ225: trimming hierarchy from :bus@0:pmc@c360000
[ 3.466697] usb-conn-gpio 3520000.padctl:ports:usb2-0:connector: repeated role: none
[ 3.467183] tegra-xusb 3610000.usb: Adding to iommu group 2
[ 3.481858] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 3.481865] tegra-xusb 3610000.usb: xHCI Host Controller
[ 3.481875] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 3.482608] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[ 3.482624] tegra-xusb 3610000.usb: irq 121, io mem 0x03610000
[ 3.482729] tegra-xusb 3610000.usb: xHCI Host Controller
[ 3.482732] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 3.482736] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.482937] hub 1-0:1.0: USB hub found
[ 3.482951] hub 1-0:1.0: 4 ports detected
[ 3.483205] hub 2-0:1.0: USB hub found
[ 3.483216] hub 2-0:1.0: 4 ports detected
[ 3.485296] irq: IRQ226: trimming hierarchy from :bus@0:pmc@c360000
[ 3.485352] irq: IRQ227: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 3.485397] irq: IRQ228: trimming hierarchy from :bus@0:pmc@c360000
[ 3.485460] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 3.520573] ALSA device list:
[ 3.520577] No soundcards found.
[ 3.525147] Freeing unused kernel memory: 7616K
[ 3.525218] Run /init as init process
[ 3.542471] Root device found: initrd
[ 3.555136] r8168: loading out-of-tree module taints kernel.
[ 3.555445] r8168: module verification failed: signature and/or required key missing - tainting kernel
[ 3.555461] r8168: disagrees about version of symbol alloc_etherdev_mqs
[ 3.555463] r8168: Unknown symbol alloc_etherdev_mqs (err -22)
[ 3.555487] r8168: disagrees about version of symbol __skb_pad
[ 3.555488] r8168: Unknown symbol __skb_pad (err -22)
[ 3.555494] r8168: disagrees about version of symbol skb_copy_bits
[ 3.555494] r8168: Unknown symbol skb_copy_bits (err -22)
[ 3.555503] r8168: disagrees about version of symbol skb_put
[ 3.555503] r8168: Unknown symbol skb_put (err -22)
[ 3.555508] r8168: disagrees about version of symbol skb_tstamp_tx
[ 3.555509] r8168: Unknown symbol skb_tstamp_tx (err -22)
[ 3.555512] r8168: disagrees about version of symbol __napi_alloc_skb
[ 3.555512] r8168: Unknown symbol __napi_alloc_skb (err -22)
[ 3.555518] r8168: disagrees about version of symbol netdev_update_features
[ 3.555518] r8168: Unknown symbol netdev_update_features (err -22)
[ 3.555523] r8168: disagrees about version of symbol consume_skb
[ 3.555523] r8168: Unknown symbol consume_skb (err -22)
[ 3.555528] r8168: disagrees about version of symbol unregister_netdev
[ 3.555529] r8168: Unknown symbol unregister_netdev (err -22)
[ 3.555561] r8168: disagrees about version of symbol __netif_napi_del
[ 3.555561] r8168: Unknown symbol __netif_napi_del (err -22)
[ 3.555567] r8168: disagrees about version of symbol netdev_err
[ 3.555568] r8168: Unknown symbol netdev_err (err -22)
[ 3.555571] r8168: disagrees about version of symbol pskb_expand_head
[ 3.555572] r8168: Unknown symbol pskb_expand_head (err -22)
[ 3.555574] r8168: disagrees about version of symbol dev_driver_string
[ 3.555575] r8168: Unknown symbol dev_driver_string (err -22)
[ 3.555581] r8168: disagrees about version of symbol eth_type_trans
[ 3.555582] r8168: Unknown symbol eth_type_trans (err -22)
[ 3.555586] r8168: disagrees about version of symbol napi_complete_done
[ 3.555587] r8168: Unknown symbol napi_complete_done (err -22)
[ 3.555591] r8168: disagrees about version of symbol skb_checksum_help
[ 3.555591] r8168: Unknown symbol skb_checksum_help (err -22)
[ 3.555597] r8168: disagrees about version of symbol __napi_schedule
[ 3.555598] r8168: Unknown symbol __napi_schedule (err -22)
[ 3.555602] r8168: disagrees about version of symbol netif_device_detach
[ 3.555602] r8168: Unknown symbol netif_device_detach (err -22)
[ 3.555605] r8168: disagrees about version of symbol _dev_info
[ 3.555606] r8168: Unknown symbol _dev_info (err -22)
[ 3.555607] r8168: disagrees about version of symbol napi_gro_receive
[ 3.555608] r8168: Unknown symbol napi_gro_receive (err -22)
[ 3.555609] r8168: disagrees about version of symbol netif_device_attach
[ 3.555610] r8168: Unknown symbol netif_device_attach (err -22)
[ 3.555619] r8168: disagrees about version of symbol _dev_err
[ 3.555620] r8168: Unknown symbol _dev_err (err -22)
[ 3.555623] r8168: disagrees about version of symbol init_net
[ 3.555623] r8168: Unknown symbol init_net (err -22)
[ 3.555631] r8168: disagrees about version of symbol netif_napi_add
[ 3.555631] r8168: Unknown symbol netif_napi_add (err -22)
[ 3.555639] r8168: disagrees about version of symbol napi_enable
[ 3.555640] r8168: Unknown symbol napi_enable (err -22)
[ 3.555643] r8168: disagrees about version of symbol register_netdev
[ 3.555644] r8168: Unknown symbol register_netdev (err -22)
[ 3.555645] r8168: disagrees about version of symbol free_netdev
[ 3.555646] r8168: Unknown symbol free_netdev (err -22)
[ 3.555651] r8168: disagrees about version of symbol netif_tx_wake_queue
[ 3.555652] r8168: Unknown symbol netif_tx_wake_queue (err -22)
[ 3.555659] r8168: disagrees about version of symbol __netdev_alloc_skb
[ 3.555660] r8168: Unknown symbol __netdev_alloc_skb (err -22)
[ 3.555669] r8168: disagrees about version of symbol __dev_kfree_skb_any
[ 3.555670] r8168: Unknown symbol __dev_kfree_skb_any (err -22)
[ 3.555673] r8168: disagrees about version of symbol netif_carrier_off
[ 3.555674] r8168: Unknown symbol netif_carrier_off (err -22)
[ 3.555677] r8168: disagrees about version of symbol netif_carrier_on
[ 3.555678] r8168: Unknown symbol netif_carrier_on (err -22)
[ 3.555686] r8168: disagrees about version of symbol napi_schedule_prep
[ 3.555687] r8168: Unknown symbol napi_schedule_prep (err -22)
[ 3.555688] r8168: disagrees about version of symbol napi_disable
[ 3.555689] r8168: Unknown symbol napi_disable (err -22)
[ 3.555691] r8168: disagrees about version of symbol _dev_printk
[ 3.555692] r8168: Unknown symbol _dev_printk (err -22)
[ 3.555694] r8168: disagrees about version of symbol __skb_gso_segment
[ 3.555695] r8168: Unknown symbol __skb_gso_segment (err -22)
[ 3.555696] r8168: disagrees about version of symbol ethtool_op_get_ts_info
[ 3.555697] r8168: Unknown symbol ethtool_op_get_ts_info (err -22)
[ 3.555699] r8168: disagrees about version of symbol netdev_info
[ 3.555700] r8168: Unknown symbol netdev_info (err -22)
[ 3.609761] Mount initrd as rootfs and enter recovery mode
[ 3.648470] tegra194-pcie 140a0000.pcie: Adding to iommu group 3
[ 3.757352] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ranges:
[ 3.757373] tegra194-pcie 140a0000.pcie: MEM 0x3240000000…0x3527ffffff → 0x3240000000
[ 3.757379] tegra194-pcie 140a0000.pcie: MEM 0x3528000000…0x352fffffff → 0x0040000000
[ 3.757382] tegra194-pcie 140a0000.pcie: IO 0x002a100000…0x002a1fffff → 0x002a100000
[ 3.757700] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[ 3.757702] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 3.828874] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 3.864897] tegra194-pcie 140a0000.pcie: Link up
[ 3.867837] tegra194-pcie 140a0000.pcie: Link up
[ 3.867890] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 3.867894] pci_bus 0008:00: root bus resource [io 0x0000-0xfffff] (bus address [0x2a100000-0x2a1fffff])
[ 3.867898] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 3.867901] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 3.867902] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 3.867950] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 3.868107] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 3.871132] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 3.871287] pci 0008:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 3.871289] pci 0008:01:00.0: reg 0x10: [io size 0x0100]
[ 3.871469] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 3.871586] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 3.872567] pci 0008:01:00.0: supports D1 D2
[ 3.872568] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 3.887361] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 3.887365] pci 0008:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 3.887368] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 3.887460] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 3.887555] pci 0008:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 3.887582] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 3.887585] pci 0008:00:00.0: bridge window [io 0x1000-0x1fff]
[ 3.887589] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 3.887671] pcieport 0008:00:00.0: Adding to iommu group 3
[ 3.887751] pcieport 0008:00:00.0: PME: Signaling with IRQ 187
[ 3.888644] pcieport 0008:00:00.0: AER: enabled with IRQ 187
[ 3.888971] tegra194-pcie 140c0000.pcie: Adding to iommu group 4
[ 3.891733] tegra194-pcie 140c0000.pcie: host bridge /bus@0/pcie@140c0000 ranges:
[ 3.891754] tegra194-pcie 140c0000.pcie: MEM 0x3540000000…0x37ffffffff → 0x3540000000
[ 3.891761] tegra194-pcie 140c0000.pcie: MEM 0x3828000000…0x382fffffff → 0x0040000000
[ 3.891764] tegra194-pcie 140c0000.pcie: IO 0x002c100000…0x002c1fffff → 0x002c100000
[ 3.892225] tegra194-pcie 140c0000.pcie: iATU unroll: enabled
[ 3.892228] tegra194-pcie 140c0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 3.985297] hub 1-2:1.0: USB hub found
[ 3.985769] hub 1-2:1.0: 4 ports detected
[ 4.109413] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 4.138103] hub 2-1:1.0: USB hub found
[ 4.138940] hub 2-1:1.0: 4 ports detected
[ 4.256891] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 4.408795] hub 1-3:1.0: USB hub found
[ 4.409271] hub 1-3:1.0: 4 ports detected
[ 4.484875] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[ 4.603721] input: Logitech USB Keyboard as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.3/1-2.3:1.0/0003:046D:C31D.0001/input/input1
[ 4.664972] hid-generic 0003:046D:C31D.0001: input: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3610000.usb-2.3/input0
[ 4.672769] input: Logitech USB Keyboard Consumer Control as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.3/1-2.3:1.1/0003:046D:C31D.0002/input/input2
[ 4.728926] input: Logitech USB Keyboard System Control as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.3/1-2.3:1.1/0003:046D:C31D.0002/input/input3
[ 4.728949] hid-generic 0003:046D:C31D.0002: input: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3610000.usb-2.3/input1
[ 4.817054] usb 1-3.4: new full-speed USB device number 5 using tegra-xusb
[ 4.996936] tegra194-pcie 140c0000.pcie: Phy link never came up
[ 5.116876] usb 1-2.4: new low-speed USB device number 6 using tegra-xusb
[ 5.230133] input: Logitech USB Optical Mouse as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.4/1-2.4:1.0/0003:046D:C077.0003/input/input4
[ 5.230176] hid-generic 0003:046D:C077.0003: input: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-3610000.usb-2.4/input0
[ 5.992916] tegra194-pcie 140c0000.pcie: Phy link never came up
[ 5.992977] tegra194-pcie 140c0000.pcie: PCI host bridge to bus 0009:00
[ 5.992981] pci_bus 0009:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x2c100000-0x2c1fffff])
[ 5.992984] pci_bus 0009:00: root bus resource [mem 0x3828000000-0x382fffffff] (bus address [0x40000000-0x47ffffff])
[ 5.992986] pci_bus 0009:00: root bus resource [bus 00-ff]
[ 5.992987] pci_bus 0009:00: root bus resource [mem 0x3540000000-0x37ffffffff pref]
[ 5.993027] pci 0009:00:00.0: [10de:229c] type 01 class 0x060400
[ 5.993179] pci 0009:00:00.0: PME# supported from D0 D3hot
[ 5.998143] pci 0009:00:00.0: PCI bridge to [bus 01-ff]
[ 5.998238] pcieport 0009:00:00.0: Adding to iommu group 4
[ 5.998325] pcieport 0009:00:00.0: PME: Signaling with IRQ 189
[ 5.999355] pcieport 0009:00:00.0: AER: enabled with IRQ 189
[ 5.999623] pci_bus 0009:01: busn_res: [bus 01-ff] is released
[ 5.999707] pci 0009:00:00.0: Removing from iommu group 4
[ 5.999717] pci_bus 0009:00: busn_res: [bus 00-ff] is released
[ 6.000594] tegra194-pcie 14100000.pcie: Adding to iommu group 5
[ 6.001984] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[ 6.001996] tegra194-pcie 14100000.pcie: MEM 0x2080000000…0x20a7ffffff → 0x2080000000
[ 6.002001] tegra194-pcie 14100000.pcie: MEM 0x20a8000000…0x20afffffff → 0x0040000000
[ 6.002004] tegra194-pcie 14100000.pcie: IO 0x0030100000…0x00301fffff → 0x0030100000
[ 6.002271] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[ 6.002273] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 7.105936] tegra194-pcie 14100000.pcie: Phy link never came up
[ 8.107700] tegra194-pcie 14100000.pcie: Phy link never came up
[ 8.107740] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.107743] pci_bus 0001:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x30100000-0x301fffff])
[ 8.107746] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.107749] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.107750] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.107796] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.107961] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.112840] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.112924] pcieport 0001:00:00.0: Adding to iommu group 5
[ 8.113001] pcieport 0001:00:00.0: PME: Signaling with IRQ 191
[ 8.114620] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[ 8.114890] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 8.114964] pci 0001:00:00.0: Removing from iommu group 5
[ 8.114972] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 8.116023] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 8.118181] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[ 8.118193] tegra194-pcie 14160000.pcie: MEM 0x2140000000…0x2427ffffff → 0x2140000000
[ 8.118198] tegra194-pcie 14160000.pcie: MEM 0x2428000000…0x242fffffff → 0x0040000000
[ 8.118201] tegra194-pcie 14160000.pcie: IO 0x0036100000…0x00361fffff → 0x0036100000
[ 8.118490] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[ 8.118492] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 8.225053] tegra194-pcie 14160000.pcie: Link up
[ 8.226396] tegra194-pcie 14160000.pcie: Link up
[ 8.226436] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 8.226439] pci_bus 0004:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x36100000-0x361fffff])
[ 8.226442] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.226444] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 8.226445] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.226485] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.226628] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.229454] pci 0004:01:00.0: [1bc0:1002] type 00 class 0x010802
[ 8.229660] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 8.230893] pci 0004:01:00.0: PME# supported from D0 D3hot
[ 8.231523] pci 0004:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0004:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 8.233996] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 8.234002] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 8.234085] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.234089] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 8.234160] pcieport 0004:00:00.0: Adding to iommu group 6
[ 8.234232] pcieport 0004:00:00.0: PME: Signaling with IRQ 193
[ 8.235671] pcieport 0004:00:00.0: AER: enabled with IRQ 193
[ 8.235939] tegra194-pcie 141e0000.pcie: Adding to iommu group 7
[ 8.239010] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[ 8.239034] tegra194-pcie 141e0000.pcie: MEM 0x3000000000…0x3227ffffff → 0x3000000000
[ 8.239043] tegra194-pcie 141e0000.pcie: MEM 0x3228000000…0x322fffffff → 0x0040000000
[ 8.239048] tegra194-pcie 141e0000.pcie: IO 0x003e100000…0x003e1fffff → 0x003e100000
[ 8.239510] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[ 8.239513] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 8.344878] tegra194-pcie 141e0000.pcie: Link up
[ 8.347077] tegra194-pcie 141e0000.pcie: Link up
[ 8.347136] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 8.347139] pci_bus 0007:00: root bus resource [io 0x400000-0x4fffff] (bus address [0x3e100000-0x3e1fffff])
[ 8.347142] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.347145] pci_bus 0007:00: root bus rmodurc /le [ule 00.15-ff.122-tegra/k 8ernel/714drivers/nvme/host/007nvm:00e-core.ko bus resource [mem 0x3000000000-0x3227ffffff pref]
[ 8.347185] pci 0007:00:00.mod /l[10ib/de:229s/5typ.15e 0lass 02-tegra/k0
ern[ drivers/n732vme/host/07:e.k00.o PME
[ 8.350111] pci 0007:01:00.0: [8086:1533] type 00 class 0x020000
[ 8.350268] pci 0007:01:00.0: reg 0x10: [mem 0x00000000-0x0007ffff]
[ 8.350400] pci 0007:01:00.0: reg 0x18: [io 0x0000-0x001f]
ins 8.35ib/modulepcis/507:00.0: reg 0x2-t1c: [mernem el/0000-0x00003verfff]
/te 8.35/te1397] pcigra 00mp-07:00.0: PME# sl.kuppo ed
from D0 D3hot D3cold
[ 8.363221] pci 0007:00:00.0: BAR 14: assigned [mem 0x322800ins0-0x32 /l280ib/modules/5.15.12[ egr.36322el/dri 0007:s/hwmo00.n/p0: wm-BARfan.ko 13 ssigne
d [io 0x400000-0x400fff]
[ 8.36ins3227] pciules/507:.15.1200.0: a/kernel/driversigs/u [msb/get0x3228/libcompo000-0xsit322807
ffff]
[ 8.363255] pci 0007:01:00.0: BAR 3: assigned [mem 0x3228ins000mod-0x322808ule3fff]
2-tegra/kern3282] ver 00s/usb/01:00.typec/typ 2:sigko [i 0x400000-0x40001f]
[ 8.363310] pci 0007:00:00.0: insmod /lib/e tulebuss/5-ff.12]
2-t[ egra/k.36ernpci 00dri07:00:00.0: ec/ucsridi/typec_udowcsi o 0x400000-0x400fff]
csi 8.363316] inspci /l 0007:mod00.ule bs/5ge .15win.12egr [mernel/0x3vers/u000-0xsb/ec/32280fi/uf]
udcg.k[ 8.363396] pcieport 0007:00:00.0: Adding to mod /lmu groules/5.15 82-t347egra/kpcirt 0007:00:0el/dri: Ps/usb/gnagetg w/ud IRc/tQ 1a-x95
8.364495] pcieport 0007:00:00.0: AER: enabled with IRQ 195
o [ 8lib/mod4] s/5 00.15.1207:00.egrAdda/kern toel/mmunet/ip grv6/ipv6.k 7
4808] igb 0007:01:00.0: enabling device (0000 → 0002)
[ 8.396377] pps pps0: new PPS source ptp0
[ 8.396962] igb 0007:01:00.0: added PHC on eth0
[ 8.396965] igb 0007:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 8.396967] igb 0007:01:00.0: eth0: (PCIe:2.5Gb/s:Width x1) c4:98:94:60:1d:d9
[ 8.39706mod /l 0007:ule00…15.12ethegrPBA Noa/extr003rivers/st
8agi.39platfo706rm/igbtegra/01:gte00.gra194Usie.kMSIo interrupts. 4 rx queue(s), 4 tx queue(s)
[ 8.425606] nvme 0004:01:00.0: Adding to iommu group 6
[ 8.425954] nvme nvme0: pci function 0004:01:00.0
[ 8.426293] nvme 0004:01:00.0: enabling device (0000 → 0002)
[ 8.432106] nvme nvme0: 8/0/0 default/read/poll queuesmodprobe: ERROR: coul529d ninsert nvn1:vet p2 p3hernet’: Inv p6d a p8 p9 p10 prgu11 ment p1
14 p15
el/ 8ver237sb/NETec/egisturedsb1 PF_IN protocol familyra/k grern 8
[ 8.572967] Segment Routinsmodth /l6
module[ s/5.57.154] .12In-sita/extrAM (IOAM)a/dth ersIPv/platf[ /te.58/mc600e/ta-mce.ko 94_gte
isagrees about version of symbol dev_set_name
[ 8.586013] tegra194_gte: Unknown symbol dev_set_name (err -22)
[ 8.586028] tegra194_gte: disagrees about version of symbol device_initialize
[ 8.586030] tegra194_gte: Uprobe:ownmbo ER: coulce_initiad nlizerrot ert ‘tegra_mce’ 8: Invalid603gumentteg
94_gte: disagrees about version of symbol fd_install
[ 8.586032] tegra194_gte: Unknown symbol fd_install (err -22)
[ 8.586048] tegra194_gte: disagrees about version of symbol get_device
[ 8.586049] tegra194_gte: Unknown symbol get_device (err -22)
[ 8.586064] tegra194_gte: disagrees about version of symbol put_device
[ 8.586064] tegra194_gte: Unknown symbol put_device (err -22)
[ 8.586072] tegra194_gte: disagrees about version of symbol _dev_err
.15.122-t 8.586075] riverstegra1pi-tegra210-: dd.kgreo’:abovalid versioumen of symbol device_add
[ 8.586075] tegra194_gte: Unknown symbol device_add (err -22)
[ 8.586095] tegra194_gte: disagrees about version of symbol device_del
[ 8.586096] tegra194_gte: Unknown symbol device_del (err -22)
[ 8.586099] tegra194_gte: disagrees about version of symbol _dev_warn
[ 8.586100] tegra194_gte: Unknown symbol _dev_warn (err -22)
[ 8.641351] tegra_mce: disagrees about version of symbol _dev_err
[ 8.641356] tegra_mce: Unknown symbol _dev_err (err -22)
[ 8.670700] spi_tegra210_quad: disagrees about version of symbol dev_driver_string
[ 8.670705] spi_tegra210_quad: Unknown symbol dev_driver_string (err -22)
[ 8.670720] spi_tegra210_quad: disagrees about version of symbol device_property_read_u32_array
[ 8.670721] spi_tegra210_quad: Unknown symbol device_property_read_u32_array (err -22)
[ 8.670723] spi_tegra210_quad: disagrees about version of symbol _dev_info
[ 8.670724] spi_tegra210_quad: Unknown symbol _dev_info (err -22)
[ 8.670725] spi_tegra210_quad: disagrees about version of symbol _dev_err
[ 8.670726] spi_tegra210_quad: Unknown symbol _dev_err (err -22)
[ 8.670737] spi_tegra210_quad: disagrees about version of symbol _dev_warn
[ 8.670739] spi_tegra210_quad: Unknown symbol _dev_warn (err -22)
[ 8.670740] spi_tegra210_quad: disagrees about version of symbol device_get_match_data
[ 8.670741] spi_tegra210_quad: Unknown symbol device_get_match_data (err -22)
[ 8.685216] spi_tegra210_quad: disagrees about version of symbol dev_driver_string
[ 8.685218] spi_tegra210_quad: Unknown symbol dev_driver_string (err -22)
[ 8.685229] spi_tegra210_quad: disagrees about version of symbol device_property_read_u32_array
[ 8.685231] spi_tegra210_quad: Unknown symbol device_property_read_u32_array (err -22)
[ 8.685232] spi_tegra210_quad: disagrees about version of symbol _dev_info
[ 8.685233] spi_tegra210_quad: Unknown symbol _dev_info (err -22)
[ 8.685234] spi_tegra210_quad: disagrees about version of symbol _dev_err
[ 8.685235] spi_tegra210_quad: Unknown symbol _dev_err (err -22)
[ 8.685244] spi_tegra210_quad: disagrees about version of symbol _dev_warn
[ 8.685244] spi_tegra210_quad: Unknown symbol _dev_warn (err -22)
[ 8.685246] spi_tegra210_quad: disagrees about version of symbol device_get_match_data
[ 8.685247] spi_tegra210_quad: Unknown symbol device_get_match_data (err -22)
[ 69.809972] using random self ethernet address
[ 69.809980] using random host ethernet address
Add /dev/nvme0n1
[ 69.817139] Mass Storage Function, version: 2009/09/11
[ 69.817144] LUN: removable file: (no medium)
[ 69.818275] LUN: removable file: (no medium)
[ 69.819269] LUN: removable file: (no medium)
[ 69.820266] LUN: removable file: (no medium)
[ 69.822650] usb0: HOST MAC be:bd:0a:f7:ce:29
[ 69.822655] usb0: MAC 62:36:8b:d8:32:83
[ 69.824789] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.1# [ 70.263965] tegra-xudc 3550000.usb: EP 5 (type: intr, dir: in) enabled
[ 70.263987] tegra-xudc 3550000.usb: EP 3 (type: bulk, dir: in) enabled
[ 70.263999] tegra-xudc 3550000.usb: EP 2 (type: bulk, dir: out) enabled
[ 70.264109] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 70.264269] tegra-xudc 3550000.usb: EP 7 (type: bulk, dir: in) enabled
[ 70.264285] tegra-xudc 3550000.usb: EP 4 (type: bulk, dir: out) enabled
bash-5.1#
bash-5.1#
bash-5.1#
bash-5.1# cd /dev/
bash-5.1# ls
autofs loop6 ptmx tty0 tty32 tty56 ttyp6
bus loop7 ptp0 tty1 tty33 tty57 ttyp7
console mapper pts tty10 tty34 tty58 ttyp8
cpu_dma_latency mem ptyp0 tty11 tty35 tty59 ttyp9
efi_capsule_loader net ptyp1 tty12 tty36 tty6 ttypa
fb0 ng0n1 ptyp2 tty13 tty37 tty60 ttypb
full null ptyp3 tty14 tty38 tty61 ttypc
gpiochip0 nvme0 ptyp4 tty15 tty39 tty62 ttypd
gpiochip1 nvme0n1 ptyp5 tty16 tty4 tty63 ttype
hwrng nvme0n1p1 ptyp6 tty17 tty40 tty7 ttypf
i2c-0 nvme0n1p10 ptyp7 tty18 tty41 tty8 urandom
i2c-1 nvme0n1p11 ptyp8 tty19 tty42 tty9 vcs
i2c-2 nvme0n1p12 ptyp9 tty2 tty43 ttyAMA0 vcs1
i2c-4 nvme0n1p13 ptypa tty20 tty44 ttyS0 vcsa
i2c-5 nvme0n1p14 ptypb tty21 tty45 ttyS1 vcsa1
i2c-7 nvme0n1p15 ptypc tty22 tty46 ttyS2 vcsu
input nvme0n1p2 ptypd tty23 tty47 ttyS3 vcsu1
kmsg nvme0n1p3 ptype tty24 tty48 ttyTCU0 vfio
kvm nvme0n1p4 ptypf tty25 tty49 ttyTHS0 vga_arbiter
loop-control nvme0n1p5 random tty26 tty5 ttyTHS2 watchdog
loop0 nvme0n1p6 rtc0 tty27 tty50 ttyp0 watchdog0
loop1 nvme0n1p7 rtc1 tty28 tty51 ttyp1 zero
loop2 nvme0n1p8 snd tty29 tty52 ttyp2
loop3 nvme0n1p9 tee0 tty3 tty53 ttyp3
loop4 port teepriv0 tty30 tty54 ttyp4
loop5 pps0 tty tty31 tty55 ttyp5
bash-5.1# [ 146.401813] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
[ 147.423249] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
[ 148.447846] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
[ 149.471851] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
[ 150.495813] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
[ 151.519870] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
[ 152.543761] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
[ 153.567831] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
bash-5.1# [ 154.591826] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
bash-5.1#
bash-5.1#
bash-5.1# [ 155.615841] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
ls[ 156.639805] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
bash-5.1# [ 157.663744] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
bash-5.1#
bash-5.1#
bash-5.1#
bash-5.1# [ 158.687840] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
ls
bash-5.1# [ 159.711831] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
[ 160.735841] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
[ 161.759869] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
[ 162.783851] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
[ 163.807842] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
[ 164.831510] NFS: state manager: check lease failed on NFSv4 server fc00:1:1:0::1 with error 13
These error like kernel module symbol error , We source code download from JP6.0 DP download site,I don’t why has that symbol error.
If we not change kernel Image and kernel module that error not happen.
We can’t change JP6.0 DP kernel Image now , has any one can help me this issue?
Attachment file is Devkit not change kernel image , and changed Kernel Image on custom board BSP flash log and debug port log.
jp6_flash_customBoard.log (287.9 KB)
jp6_flash_devkit.log (329.3 KB)
Debug_JP6_customBoard.log (53.3 KB)
Debug_JP6_Devkit.log (27.2 KB)
Best Regards
Jack Lan
try to clean up the format first…
Not a good idea to directly copy and paste the whole log.
Hi all
Sorry I find method how to fix this issue , Please cloes this topic
Hi Jack_lan
You mention that you have solved the problem, but can you tell us exactly how?
Hi koudaj
On JP4 and JP5 modify Kernel config just add Config on Kernel source arch/arm64/configs/defconfig , but after JP6 not suggest this method.
You necessary use kernel menuconfig modify kernel config and copy .confg replace arch/arm64/configs/ rename to new defconfig.
that is work on JP6!
Best Regards
Jack Lan
