Hi @AastaLLL ,
I inserted nvidia-p2p.ko first, and it does get rid of symbol errors, but according to dmesg the module verification fails and it does not show up in “Kernel driver in use:”
Note: Similar to this post, I’m attempting to use Xilinx VCK190 FPGA not HTG-K800 but the Internal Xilinx IP is the same.
user@ubuntu:~/Downloads/jetson-rdma-picoevb-master/kernel-module$ sudo apt install build-essential bc
Reading package lists... Done
Building dependency tree
Reading state information... Done
bc is already the newest version (1.07.1-2build1).
build-essential is already the newest version (12.8ubuntu1.1).
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin
dctrl-tools dpkg-repack gdal-data gir1.2-timezonemap-1.0 gir1.2-xkl-1.0
grub-common libaec0 libarmadillo9 libarpack2 libavcodec-dev libavformat-dev
libavresample-dev libavresample4 libavutil-dev libcfitsio8 libcharls2
libdap25 libdapclient6v5 libdc1394-22-dev libdebian-installer4 libepsilon1
libexif-dev libfreexl1 libfyba0 libgdal26 libgdcm-dev libgdcm3.0
libgeos-3.8.0 libgeos-c1v5 libgeotiff5 libgl2ps1.4 libgphoto2-dev
libhdf4-0-alt libhdf5-103 libhdf5-openmpi-103 libilmbase-dev libjbig-dev
libjpeg-dev libjpeg-turbo8-dev libjpeg8-dev libkmlbase1 libkmldom1
libkmlengine1 liblept5 liblzma-dev libminizip1 libnetcdf-c++4 libnetcdf15
libodbc1 libogdi4.1 libopencv-calib3d4.2 libopencv-contrib4.2
libopencv-dnn4.2 libopencv-features2d4.2 libopencv-flann4.2
libopencv-highgui4.2 libopencv-imgcodecs4.2 libopencv-imgproc4.2
libopencv-ml4.2 libopencv-objdetect4.2 libopencv-photo4.2 libopencv-shape4.2
libopencv-stitching4.2 libopencv-superres4.2 libopencv-video4.2
libopencv-videoio4.2 libopencv-videostab4.2 libopencv-viz4.2
libopencv4.2-java libopencv4.2-jni libopenexr-dev libpng-dev libpq5
libproj15 libqhull7 libraw1394-dev libsocket++1 libspatialite7 libsuperlu5
libswresample-dev libswscale-dev libsz2 libtesseract4 libtiff-dev libtiffxx5
libtimezonemap-data libtimezonemap1 liburiparser1 libvtk6.3 libxerces-c3.2
odbcinst odbcinst1debian2 os-prober proj-data python3-icu python3-pam rdate
tasksel tasksel-data
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 276 not upgraded.
user@ubuntu:~/Downloads/jetson-rdma-picoevb-master/kernel-module$ ./build-for-jetson-drive-igpu-native.sh
make -C "/lib/modules/5.10.120-tegra/build" "M=$PWD" "modules"
make[1]: Entering directory '/usr/src/linux-headers-5.10.120-tegra-ubuntu20.04_aarch64/kernel-5.10'
CC [M] /home/user/Downloads/jetson-rdma-picoevb-master/kernel-module/picoevb-rdma.o
MODPOST /home/user/Downloads/jetson-rdma-picoevb-master/kernel-module/Module.symvers
CC [M] /home/user/Downloads/jetson-rdma-picoevb-master/kernel-module/picoevb-rdma.mod.o
LD [M] /home/user/Downloads/jetson-rdma-picoevb-master/kernel-module/picoevb-rdma.ko
make[1]: Leaving directory '/usr/src/linux-headers-5.10.120-tegra-ubuntu20.04_aarch64/kernel-5.10'
user@ubuntu:~/Downloads/jetson-rdma-picoevb-master/kernel-module$ sudo insmod /lib/modules/5.10.120-tegra/kernel/drivers/nv-p2p/nvidia-p2p.ko
user@ubuntu:~/Downloads/jetson-rdma-picoevb-master/kernel-module$ sudo insmod ./picoevb-rdma.ko
user@ubuntu:~/Downloads/jetson-rdma-picoevb-master/kernel-module$ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.120-tegra (buildbrain@mobile-u64-6422-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Aug 1 12:32:50 PDT 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x82531df98 SMBIOS=0xffff0000 SMBIOS 3.0=0x805260000 MEMATTR=0x806822018 ESRT=0x805162818 RNG=0x806d2f198 MEMRESERVE=0x806824f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000805162818 to 0x0000000805162850.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000818c00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000833ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000804674fff]
[ 0.000000] node 0: [mem 0x0000000804675000-0x0000000804a4efff]
[ 0.000000] node 0: [mem 0x0000000804a4f000-0x0000000804dfffff]
[ 0.000000] node 0: [mem 0x0000000804e00000-0x0000000804e0ffff]
[ 0.000000] node 0: [mem 0x0000000804e10000-0x00000008051bffff]
[ 0.000000] node 0: [mem 0x00000008051c0000-0x000000080526ffff]
[ 0.000000] node 0: [mem 0x0000000805270000-0x00000008066dffff]
[ 0.000000] node 0: [mem 0x00000008066e0000-0x000000080677ffff]
[ 0.000000] node 0: [mem 0x0000000806780000-0x00000008067dffff]
[ 0.000000] node 0: [mem 0x00000008067e0000-0x000000080680ffff]
[ 0.000000] node 0: [mem 0x0000000806810000-0x000000080683ffff]
[ 0.000000] node 0: [mem 0x0000000806840000-0x000000080685ffff]
[ 0.000000] node 0: [mem 0x0000000806860000-0x000000080693ffff]
[ 0.000000] node 0: [mem 0x0000000806940000-0x000000080695ffff]
[ 0.000000] node 0: [mem 0x0000000806960000-0x000000080698ffff]
[ 0.000000] node 0: [mem 0x0000000806990000-0x0000000806b6ffff]
[ 0.000000] node 0: [mem 0x0000000806b70000-0x0000000806c3ffff]
[ 0.000000] node 0: [mem 0x0000000806c40000-0x0000000806cdffff]
[ 0.000000] node 0: [mem 0x0000000806ce0000-0x0000000806d1ffff]
[ 0.000000] node 0: [mem 0x0000000806d20000-0x0000000806faffff]
[ 0.000000] node 0: [mem 0x0000000806fb0000-0x00000008070affff]
[ 0.000000] node 0: [mem 0x00000008070b0000-0x000000080714ffff]
[ 0.000000] node 0: [mem 0x0000000807150000-0x000000080719ffff]
[ 0.000000] node 0: [mem 0x00000008071a0000-0x000000080723ffff]
[ 0.000000] node 0: [mem 0x0000000807240000-0x000000080775ffff]
[ 0.000000] node 0: [mem 0x0000000807760000-0x000000080793ffff]
[ 0.000000] node 0: [mem 0x0000000807940000-0x0000000828faffff]
[ 0.000000] node 0: [mem 0x0000000828fb0000-0x0000000828ffffff]
[ 0.000000] node 0: [mem 0x0000000829000000-0x000000082d1fffff]
[ 0.000000] node 0: [mem 0x000000082d210000-0x000000082d21ffff]
[ 0.000000] node 0: [mem 0x0000000832000000-0x0000000833ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000833ffffff]
[ 0.000000] On node 0 totalpages: 8057360
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 118016 pages used for memmap
[ 0.000000] Normal zone: 7533072 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] pcpu-alloc: s90328 r8192 d32552 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7931152
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb nv-auto-config
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 31051584K/32229440K available (18560K kernel code, 3166K rwdata, 7196K rodata, 3968K init, 1416K bss, 915712K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000756] Console: colour dummy device 80x25
[ 0.000937] printk: console [tty0] enabled
[ 0.000981] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000993] pid_max: default: 32768 minimum: 301
[ 0.001099] LSM: Security Framework initializing
[ 0.001132] Yama: becoming mindful.
[ 0.001154] SELinux: Initializing.
[ 0.001265] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001314] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.003224] rcu: Hierarchical SRCU implementation.
[ 0.003334] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.004114] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0004-p3737-0000.dts
[ 0.004125] DTB Build time: Aug 1 2023 12:44:17
[ 0.005751] Tegra Revision: A01 SKU: 0xd2 CPU Process: 0 SoC Process: 0
[ 0.006082] Remapping and enabling EFI services.
[ 0.006618] smp: Bringing up secondary CPUs ...
[ 0.035348] Detected PIPT I-cache on CPU1
[ 0.035385] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.035424] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.064096] Detected PIPT I-cache on CPU2
[ 0.064106] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.064121] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.092734] Detected PIPT I-cache on CPU3
[ 0.092743] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.092756] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.123436] Detected PIPT I-cache on CPU4
[ 0.123457] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.123482] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.152158] Detected PIPT I-cache on CPU5
[ 0.152168] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.152183] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.180820] Detected PIPT I-cache on CPU6
[ 0.180830] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.180845] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.209479] Detected PIPT I-cache on CPU7
[ 0.209489] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.209504] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.209562] smp: Brought up 1 node, 8 CPUs
[ 0.209607] SMP: Total of 8 processors activated.
[ 0.209612] CPU features: detected: Privileged Access Never
[ 0.209615] CPU features: detected: LSE atomic instructions
[ 0.209617] CPU features: detected: User Access Override
[ 0.209620] CPU features: detected: 32-bit EL0 Support
[ 0.209623] CPU features: detected: Common not Private translations
[ 0.209626] CPU features: detected: RAS Extension Support
[ 0.209628] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.209632] CPU features: detected: CRC32 instructions
[ 0.209635] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.226853] spectre-bhb mitigation disabled by command line option
[ 0.226855] spectre-bhb mitigation disabled by command line option
[ 0.226857] spectre-bhb mitigation disabled by command line option
[ 0.226858] spectre-bhb mitigation disabled by command line option
[ 0.226861] spectre-bhb mitigation disabled by command line option
[ 0.226862] spectre-bhb mitigation disabled by command line option
[ 0.226867] spectre-bhb mitigation disabled by command line option
[ 0.226869] spectre-bhb mitigation disabled by command line option
[ 0.242640] CPU: All CPU(s) started at EL2
[ 0.245026] devtmpfs: initialized
[ 0.266338] Registered cp15_barrier emulation handler
[ 0.266353] Registered setend emulation handler
[ 0.266360] KASLR enabled
[ 0.266484] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.266499] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.268144] pinctrl core: initialized pinctrl subsystem
[ 0.268615] SMBIOS 3.0.0 present.
[ 0.268624] DMI: Unknown Jetson AGX Orin Developer Kit/Jetson AGX Orin Developer Kit, BIOS 4.1-33958178 08/01/2023
[ 0.268958] NET: Registered protocol family 16
[ 0.269616] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.269818] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.270016] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.270044] audit: initializing netlink subsys (disabled)
[ 0.270133] audit: type=2000 audit(0.268:1): state=initialized audit_enabled=0 res=1
[ 0.270335] thermal_sys: Registered thermal governor 'step_wise'
[ 0.270337] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.270342] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.272749] cpuidle: using governor menu
[ 0.272865] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.272945] ASID allocator initialised with 32768 entries
[ 0.273045] Serial: AMBA PL011 UART driver
[ 0.275024] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.275047] Tegra reboot handler registered.
[ 0.294581] mc: mapped MMIO address: 0xffff800011110000 -> 0x2c10000
[ 0.294593] mc: mapped MMIO address: 0xffff800011130000 -> 0x2c20000
[ 0.294601] mc: mapped MMIO address: 0xffff800011150000 -> 0x2c30000
[ 0.294609] mc: mapped MMIO address: 0xffff800011170000 -> 0x2c40000
[ 0.294621] mc: mapped MMIO address: 0xffff800011190000 -> 0x2c50000
[ 0.294629] mc: mapped MMIO address: 0xffff8000111b0000 -> 0x2b80000
[ 0.294636] mc: mapped MMIO address: 0xffff8000111d0000 -> 0x2b90000
[ 0.294645] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2ba0000
[ 0.294654] mc: mapped MMIO address: 0xffff800011210000 -> 0x2bb0000
[ 0.294661] mc: mapped MMIO address: 0xffff800011230000 -> 0x1700000
[ 0.294668] mc: mapped MMIO address: 0xffff800011250000 -> 0x1710000
[ 0.294674] mc: mapped MMIO address: 0xffff800011270000 -> 0x1720000
[ 0.294681] mc: mapped MMIO address: 0xffff800011290000 -> 0x1730000
[ 0.294689] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x1740000
[ 0.294701] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x1750000
[ 0.294708] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x1760000
[ 0.294715] mc: mapped MMIO address: 0xffff800011310000 -> 0x1770000
[ 0.294724] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.294771] mc-err: mcerr ops are set to t23x
[ 0.295502] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 80, base_baud = 0) is a SBSA
[ 1.500777] printk: console [ttyAMA0] enabled
[ 1.509448] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.516158] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.522857] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.529556] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.538354] ACPI: Interpreter disabled.
[ 1.543386] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.548237] vbusA-cvb: supplied by vdd-5v-sys
[ 1.552700] vbusB-cvb: supplied by vdd-5v-sys
[ 1.557172] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.562126] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.567440] iommu: Default domain type: Translated
[ 1.572466] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.578811] SCSI subsystem initialized
[ 1.582641] usbcore: registered new interface driver usbfs
[ 1.588138] usbcore: registered new interface driver hub
[ 1.593458] usbcore: registered new device driver usb
[ 1.598822] mc: Linux media interface: v0.10
[ 1.603098] videodev: Linux video capture interface: v2.00
[ 1.608732] pps_core: LinuxPPS API ver. 1 registered
[ 1.613696] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.622832] PTP clock support registered
[ 1.626990] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.634173] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.641883] Registered efivars operations
[ 1.646464] FPGA manager framework
[ 1.649913] Advanced Linux Sound Architecture Driver Initialized.
[ 1.656276] Bluetooth: Core ver 2.22
[ 1.659858] NET: Registered protocol family 31
[ 1.664300] Bluetooth: HCI device and connection manager initialized
[ 1.670656] Bluetooth: HCI socket layer initialized
[ 1.675532] Bluetooth: L2CAP socket layer initialized
[ 1.680586] Bluetooth: SCO socket layer initialized
[ 1.686102] camchar: rtcpu character device driver loaded
[ 1.691829] clocksource: Switched to clocksource arch_sys_counter
[ 1.862017] VFS: Disk quotas dquot_6.6.0
[ 1.865986] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.873371] pnp: PnP ACPI: disabled
[ 1.878800] la/ptsa driver initialized.
[ 1.882703] NET: Registered protocol family 2
[ 1.887263] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 1.897069] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 1.905821] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 1.914116] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.922024] TCP: Hash tables configured (established 262144 bind 65536)
[ 1.928739] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 1.935675] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 1.943128] NET: Registered protocol family 1
[ 1.947748] RPC: Registered named UNIX socket transport module.
[ 1.953675] RPC: Registered udp transport module.
[ 1.958378] RPC: Registered tcp transport module.
[ 1.963078] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.969525] PCI: CLS 0 bytes, default 64
[ 1.973558] Trying to unpack rootfs image as initramfs...
[ 2.107887] Freeing initrd memory: 9552K
[ 2.113789] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.121755] kvm [1]: IPA Size Limit: 48 bits
[ 2.126046] kvm [1]: GICv3: no GICV resource entry
[ 2.130836] kvm [1]: disabling GICv2 emulation
[ 2.135299] kvm [1]: GIC system register CPU interface enabled
[ 2.141203] kvm [1]: vgic interrupt IRQ9
[ 2.145239] kvm [1]: VHE mode initialized successfully
[ 2.151071] Initialise system trusted keyrings
[ 2.155623] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 2.164473] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.170649] NFS: Registering the id_resolver key type
[ 2.175725] Key type id_resolver registered
[ 2.179908] Key type id_legacy registered
[ 2.183949] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.190657] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.198064] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.214036] NET: Registered protocol family 38
[ 2.218483] Key type asymmetric registered
[ 2.222579] Asymmetric key parser 'x509' registered
[ 2.227473] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 2.234931] io scheduler mq-deadline registered
[ 2.239465] io scheduler kyber registered
[ 2.248084] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.253686] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.259272] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.264858] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.271268] efifb: probing for efifb
[ 2.274880] efifb: framebuffer at 0x839e00000, using 8640k, total 8640k
[ 2.281496] efifb: mode is 1920x1080x32, linelength=8192, pages=1
[ 2.287588] efifb: scrolling: redraw
[ 2.291160] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 2.299735] Console: switching to colour frame buffer device 240x67
[ 2.308774] fb0: EFI VGA frame buffer device
[ 2.314913] tegra_dc_assign_hw_data: no matching compatible node
[ 2.320936] tegradccommon module_init failed
[ 2.325212] tegradc module_init failed
[ 2.329245] EINJ: ACPI disabled.
[ 2.334149] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.341045] tegra-pmc: ### PMC reset source: MAINSWRST
[ 2.346194] tegra-pmc: ### PMC reset level: L1
[ 2.350643] tegra-pmc: ### PMC reset status reg: 0x2d
[ 2.357023] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 4.004852] printk: console [ttyTCU0] enabled
[ 4.013929] arm-smmu 12000000.iommu: probing hardware configuration...
[ 4.021954] arm-smmu 12000000.iommu: SMMUv2 with:
[ 4.026801] arm-smmu 12000000.iommu: stage 1 translation
[ 4.032357] arm-smmu 12000000.iommu: stage 2 translation
[ 4.037913] arm-smmu 12000000.iommu: nested translation
[ 4.043371] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.050791] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.059912] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.066618] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.073321] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.080895] arm-smmu 10000000.iommu: probing hardware configuration...
[ 4.087601] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.092430] arm-smmu 10000000.iommu: stage 1 translation
[ 4.097968] arm-smmu 10000000.iommu: stage 2 translation
[ 4.103518] arm-smmu 10000000.iommu: nested translation
[ 4.108973] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.116391] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.125399] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.132101] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.138804] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.145937] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.152559] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.157296] arm-smmu 8000000.iommu: stage 1 translation
[ 4.162754] arm-smmu 8000000.iommu: stage 2 translation
[ 4.168208] arm-smmu 8000000.iommu: nested translation
[ 4.173568] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.180900] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.189833] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.196451] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.203056] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.210392] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.220638] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.227212] tegra_profiler: auth: init
[ 4.231961] nvsciipc: loaded module
[ 4.237740] tun: Universal TUN/TAP device driver, 1.6
[ 4.243973] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.251944] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.257979] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.263622] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.270261] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.276359] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.282802] PPP generic driver version 2.4.2
[ 4.287779] PPP BSD Compression module registered
[ 4.293151] PPP Deflate Compression module registered
[ 4.298881] PPP MPPE Compression module registered
[ 4.304379] usbcore: registered new interface driver r8152
[ 4.310568] usbcore: registered new interface driver asix
[ 4.316667] usbcore: registered new interface driver ax88179_178a
[ 4.323472] usbcore: registered new interface driver cdc_ether
[ 4.330025] usbcore: registered new interface driver net1080
[ 4.336397] usbcore: registered new interface driver cdc_subset
[ 4.343019] usbcore: registered new interface driver zaurus
[ 4.349278] usbcore: registered new interface driver cdc_ncm
[ 4.355620] usbcore: registered new interface driver aqc111
[ 4.361976] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.368850] ohci-pci: OHCI PCI platform driver
[ 4.373934] ohci-platform: OHCI generic platform driver
[ 4.380123] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.386911] usbcore: registered new interface driver uas
[ 4.392914] usbcore: registered new interface driver usb-storage
[ 4.399738] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.406386] mousedev: PS/2 mouse device common for all mice
[ 4.412638] usbcore: registered new interface driver xpad
[ 4.420556] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.426545] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:25 UTC (25)
[ 4.435298] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.442233] i2c /dev entries driver
[ 4.446407] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.452740] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.458982] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.465280] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.471602] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.477806] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.484008] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.490253] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.498653] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.507809] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.517857] device-mapper: uevent: version 1.0.3
[ 4.523196] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.533560] sdhci: Secure Digital Host Controller Interface driver
[ 4.540441] sdhci: Copyright(c) Pierre Ossman
[ 4.545446] Synopsys Designware Multimedia Card Interface Driver
[ 4.552237] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.558749] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 4.559130] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[ 4.559291] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.560188] tegra-bpmp bpmp: firmware: 6969245516d6bf7e0f23-925eece486b
[ 4.561494] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.562067] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[ 4.568654] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.604695] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[ 5.779486] hid: raw HID events driver (C) Jiri Kosina
[ 5.785632] usbcore: registered new interface driver usbhid
[ 5.791932] usbhid: USB HID core driver
[ 5.797009] tegra-dce d800000.dce: Adding to iommu group 5
[ 5.804847] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 5.814322] tegra234-aon c000000.aon: Adding to iommu group 6
[ 5.821516] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 5.825453] c000000.aon:hsp: probed
[ 5.831078] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 5.844873] tegra234-aon c000000.aon: init done
[ 5.845562] tegra23x-psc e860000.psc: Adding to iommu group 7
[ 5.850159] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 5.857299] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 5.864799] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 5.871489] tegra23x-psc e860000.psc: init done
[ 5.881123] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 5.881125] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 5.881136] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 5.886692] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[ 5.895570] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 5.896071] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 5.905646] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.914526] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 5.914528] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 5.914539] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 5.976620] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 5.978669] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 5.992640] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.005021] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 6.017658] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 6.030135] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.043449] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.057032] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.070050] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (119)
[ 6.077608] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.086750] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[ 6.101121] t19x_cache tegra-cache: probed
[ 6.106315] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.119343] optee: probing for conduit method.
[ 6.124692] optee: revision 3.21 (d8269f24)
[ 6.183479] optee: dynamic shared memory is enabled
[ 6.194406] optee: initialized driver
[ 6.214889] nvpmodel: initialized successfully
[ 6.220318] tegra_hv: get_hvd: not initialized yet
[ 6.226017] user_ivc_mempool: hypervisor not present
[ 6.232708] usbcore: registered new interface driver snd-usb-audio
[ 6.240764] u32 classifier
[ 6.244321] input device check on
[ 6.248870] Actions configured
[ 6.253279] Initializing XFRM netlink socket
[ 6.258922] NET: Registered protocol family 10
[ 6.265946] Segment Routing with IPv6
[ 6.270544] NET: Registered protocol family 17
[ 6.275911] NET: Registered protocol family 15
[ 6.281305] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.296327] Bluetooth: RFCOMM socket layer initialized
[ 6.302431] Bluetooth: RFCOMM ver 1.11
[ 6.307086] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.313974] Bluetooth: HIDP socket layer initialized
[ 6.320779] 9pnet: Installing 9P2000 support
[ 6.326180] Key type dns_resolver registered
[ 6.332677] registered taskstats version 1
[ 6.337692] Loading compiled-in X.509 certificates
[ 6.355163] Loaded X.509 cert 'Build time autogenerated kernel key: d94b64a20d69a5a32183bad4f211c4cae67041a9'
[ 6.366793] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[ 6.380704] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.389766] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[ 6.403457] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.411186] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 6.424241] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.431541] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 6.457053] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.472549] simple-framebuffer chosen:framebuffer: framebuffer at 0x839e00000, 0x870000 bytes, mapped to 0x(____ptrval____)
[ 6.484823] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=1920x1080x32, linelength=8192
[ 6.495193] checking generic (839e00000 870000) vs hw (839e00000 870000)
[ 6.495197] fb0: switching to simple from EFI VGA
[ 6.501890] Console: switching to colour dummy device 80x25
[ 6.510781] Console: switching to colour frame buffer device 240x67
[ 6.519974] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[ 6.527560] host1x 13e40000.host1x: Adding to iommu group 13
[ 6.555029] host1x 13e40000.host1x: initialized
[ 6.560171] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 6.568300] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.580334] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 6.588382] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.600388] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 6.608406] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.620420] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 6.628430] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.640445] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 6.648490] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.660460] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 6.668484] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.680502] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 6.688540] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.700528] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 6.708584] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.720636] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 6.728712] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 6.740751] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 6.748768] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 6.760753] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 6.768785] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 6.780753] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 6.788785] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 6.800790] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 6.808816] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 6.820812] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 6.828849] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 6.840845] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 6.848892] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.860915] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 6.868960] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.880994] falcon 15340000.vic: Adding to iommu group 30
[ 6.891352] falcon 15340000.vic: initialized
[ 6.896106] falcon 15380000.nvjpg: Adding to iommu group 31
[ 6.905049] falcon 15380000.nvjpg: initialized
[ 6.909774] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 6.918664] falcon 15540000.nvjpg1: initialized
[ 6.923484] falcon 154c0000.nvenc: Adding to iommu group 33
[ 6.933772] falcon 154c0000.nvenc: initialized
[ 6.939204] falcon 15a50000.ofa: Adding to iommu group 34
[ 6.948045] falcon 15a50000.ofa: initialized
[ 6.953292] nvdec 15480000.nvdec: Adding to iommu group 35
[ 6.965397] nvdec 15480000.nvdec: initialized
[ 6.970712] tsec 15500000.tsec: Adding to iommu group 36
[ 6.980859] tsec 15500000.tsec: initialized
[ 6.988440] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.006875] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.025286] gpio-394 (camera-control-output-low): hogged as output/low
[ 7.032767] gpio-397 (camera-control-output-low): hogged as output/low
[ 7.040232] gpio-487 (camera-control-output-low): hogged as output/low
[ 7.047673] gpio-486 (camera-control-output-low): hogged as output/low
[ 7.055798] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 7.063615] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 7.071281] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 7.078495] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 7.085600] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 7.092487] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 7.101089] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 7.110337] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 7.120333] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 7.130321] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 7.137593] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 7.146365] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 7.155000] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 7.165320] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 7.172801] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 7.183060] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 7.190543] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 7.200832] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 7.208325] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 7.217675] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 7.229726] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 7.239041] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 7.251093] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 7.260422] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 7.272484] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 7.281842] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 7.293882] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[ 7.303209] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 7.315231] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[ 7.324557] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 7.336611] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[ 7.345946] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 7.357984] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[ 7.367298] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 7.379347] pva 16000000.pva0: Adding to iommu group 48
[ 7.403666] pva 16000000.pva0: initialized
[ 7.416783] nvdla 15880000.nvdla0: Adding to iommu group 49
[ 7.431465] nvdla 15880000.nvdla0: initialized
[ 7.438427] nvdla 158c0000.nvdla1: Adding to iommu group 50
[ 7.452588] nvdla 158c0000.nvdla1: initialized
[ 7.459537] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 7.467330] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 7.475494] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 7.482792] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 7.490193] serial-tegra 3100000.serial: Adding to iommu group 2
[ 7.497459] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 26, base_baud = 0) is a TEGRA_UART
[ 7.507537] serial-tegra 3110000.serial: Adding to iommu group 2
[ 7.514826] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 78, base_baud = 0) is a TEGRA_UART
[ 7.524785] serial-tegra 3130000.serial: Adding to iommu group 2
[ 7.531991] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 79, base_baud = 0) is a TEGRA_UART
[ 7.557871] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 7.568321] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.574593] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.583936] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 7.594251] tegra-xusb 3610000.xhci: irq 236, io mem 0x03610000
[ 7.601396] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.610623] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.618783] usb usb1: Product: xHCI Host Controller
[ 7.624518] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.631521] usb usb1: SerialNumber: 3610000.xhci
[ 7.637364] hub 1-0:1.0: USB hub found
[ 7.641983] hub 1-0:1.0: 4 ports detected
[ 7.647054] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.653327] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.661845] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.670108] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.679358] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.687527] usb usb2: Product: xHCI Host Controller
[ 7.693288] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.700310] usb usb2: SerialNumber: 3610000.xhci
[ 7.705945] hub 2-0:1.0: USB hub found
[ 7.710595] hub 2-0:1.0: 4 ports detected
[ 7.736926] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.763050] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2021000 KHz, changing to: 2035200 KHz
[ 7.776678] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 7.789326] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[ 7.797574] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.803514] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.806138] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 7.807671] mmc0: CQHCI version 5.10
[ 7.820083] irq: IRQ303: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.822615] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 7.830976] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[ 7.835593] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 7.840335] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 7.865602] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 7.903831] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 7.924662] mmc0: Command Queue Engine enabled
[ 7.929953] mmc0: periodic cache flush enabled
[ 7.935229] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 7.942834] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 7.948276] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[ 7.965467] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 7.979983] tegra194-pcie 14100000.pcie: Link up
[ 7.986382] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 7.993907] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.000254] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.010816] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.022362] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.030996] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.038041] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.049360] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 8.056417] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 8.063047] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.072157] pci 0001:01:00.0: supports D1 D2
[ 8.075960] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 8.077255] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.086392] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.098720] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 8.101995] usb 1-3: Product: Bluetooth Radio
[ 8.101997] usb 1-3: Manufacturer: Realtek
[ 8.110164] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 8.115371] usb 1-3: SerialNumber: 00e04c000001
[ 8.132764] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.141462] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 8.148471] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.154545] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 8.161514] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 8.169556] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 8.178996] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 8.188669] pcieport 0001:00:00.0: Adding to iommu group 9
[ 8.195278] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[ 8.200703] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 8.202111] pcieport 0001:00:00.0: AER: enabled with IRQ 64
[ 8.217630] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 8.226801] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 8.234659] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 8.244026] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 8.246124] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 8.253388] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 8.271938] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.279979] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 8.285421] usb 2-3: Manufacturer: Generic
[ 8.299344] hub 2-3:1.0: USB hub found
[ 8.305577] hub 2-3:1.0: 4 ports detected
[ 8.363833] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 8.540908] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 8.550016] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.558055] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 8.563487] usb 1-4: Manufacturer: Generic
[ 8.570461] hub 1-4:1.0: USB hub found
[ 8.576301] hub 1-4:1.0: 4 ports detected
[ 9.025688] usb 2-3.1: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[ 9.067858] usb 2-3.1: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 0.01
[ 9.077138] usb 2-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.085333] usb 2-3.1: Product: USB3.2 Hub
[ 9.090234] usb 2-3.1: Manufacturer: Generic
[ 9.102357] hub 2-3.1:1.0: USB hub found
[ 9.108669] hub 2-3.1:1.0: 4 ports detected
[ 9.279830] usb 1-4.1: new high-speed USB device number 4 using tegra-xusb
[ 9.361286] tegra194-pcie 14160000.pcie: Phy link never came up
[ 9.368080] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 9.375534] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 9.381806] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 9.381807] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.381810] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 9.409608] usb 1-4.1: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 0.01
[ 9.412625] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 9.421823] usb 1-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.428830] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 9.436847] usb 1-4.1: Product: USB2.1 Hub
[ 9.447993] usb 1-4.1: Manufacturer: Generic
[ 9.451716] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 9.456151] hub 1-4.1:1.0: USB hub found
[ 9.459089] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.466903] hub 1-4.1:1.0: 4 ports detected
[ 9.473383] pcieport 0004:00:00.0: Adding to iommu group 10
[ 9.484666] pcieport 0004:00:00.0: PME: Signaling with IRQ 66
[ 9.491480] pcieport 0004:00:00.0: AER: enabled with IRQ 66
[ 9.498084] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 9.504827] pci 0004:00:00.0: Removing from iommu group 10
[ 9.511121] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 9.519100] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 9.524642] usb 2-3.1.1: new SuperSpeed Gen 1 USB device number 4 using tegra-xusb
[ 9.526207] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 9.534725] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 9.540404] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 9.545964] vdd-dp: supplied by vdd-3v3-sys
[ 9.551051] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 9.556744] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 9.564217] tegra194-isp5 14800000.isp: initialized
[ 9.564727] usb 2-3.1.1: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 0.02
[ 9.571778] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 9.579265] usb 2-3.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.579266] usb 2-3.1.1: Product: USB3.2 Hub
[ 9.579266] usb 2-3.1.1: Manufacturer: Generic
[ 9.589328] hub 2-3.1.1:1.0: USB hub found
[ 9.594711] (NULL device *): fops function table already registered
[ 9.602188] hub 2-3.1.1:1.0: 4 ports detected
[ 9.605762] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 9.629482] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 9.629529] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 9.644153] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[ 9.749412] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 9.757235] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 9.763833] usb 1-4.1.1: new high-speed USB device number 5 using tegra-xusb
[ 9.766593] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 9.783827] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[ 9.889179] usb 1-4.1.1: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 0.02
[ 9.898591] usb 1-4.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.899978] tegra194-pcie 141a0000.pcie: Link up
[ 9.906942] usb 1-4.1.1: Product: USB2.1 Hub
[ 9.906945] usb 1-4.1.1: Manufacturer: Generic
[ 9.913371] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 9.918155] random: crng init done
[ 9.922624] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 9.922626] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 9.922628] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.922629] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 9.922668] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 9.922677] hub 1-4.1.1:1.0: USB hub found
[ 9.930139] hub 1-4.1.1:1.0: 4 ports detected
[ 9.934389] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 9.999289] pci 0005:01:00.0: [10ee:b03f] type 00 class 0x058000
[ 10.006280] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x0000ffff 64bit]
[ 10.013973] pci 0005:01:00.0: reg 0x18: [mem 0x00000000-0x0001ffff]
[ 10.022133] pci 0005:01:00.0: supports D1
[ 10.026904] pci 0005:01:00.0: PME# supported from D0 D1 D3hot D3cold
[ 10.038791] pci 0005:00:00.0: BAR 14: assigned [mem 0x2b28000000-0x2b280fffff]
[ 10.046884] pci 0005:01:00.0: BAR 2: assigned [mem 0x2b28000000-0x2b2801ffff]
[ 10.054908] pci 0005:01:00.0: BAR 0: assigned [mem 0x2b28020000-0x2b2802ffff 64bit]
[ 10.063508] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 10.069525] pci 0005:00:00.0: bridge window [mem 0x2b28000000-0x2b280fffff]
[ 10.077521] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.086901] pci 0005:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 10.096488] pcieport 0005:00:00.0: Adding to iommu group 11
[ 10.103100] pcieport 0005:00:00.0: PME: Signaling with IRQ 68
[ 10.109889] pcieport 0005:00:00.0: AER: enabled with IRQ 68
[ 10.117297] nvethernet 6810000.ethernet: Adding to iommu group 51
[ 10.124573] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 10.133379] nvethernet 6810000.ethernet: failed to read MDIO address
[ 10.140561] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 10.148103] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 10.235828] usb 1-4.1.1.2: new full-speed USB device number 6 using tegra-xusb
[ 10.358921] usb 1-4.1.1.2: New USB device found, idVendor=413c, idProduct=2101, bcdDevice= 2.01
[ 10.368505] usb 1-4.1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.377015] usb 1-4.1.1.2: Product: Dell Smart Card Reader Keyboard
[ 10.384096] usb 1-4.1.1.2: Manufacturer: Dell
[ 10.394882] input: Dell Dell Smart Card Reader Keyboard as /devices/platform/3610000.xhci/usb1/1-4/1-4.1/1-4.1.1/1-4.1.1.2/1-4.1.1.2:1.0/0003:413C:2101.0001/input/input0
[ 10.468279] hid-generic 0003:413C:2101.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell Dell Smart Card Reader Keyboard] on usb-3610000.xhci-4.1.1.2/input0
[ 10.539774] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:94:80:7b
[ 10.548467] -->macsec_probe()
[ 10.548489] nvethernet 6810000.ethernet: macsec param in DT is missing or disabled
[ 10.556946] <--macsec_probe()
[ 10.556948] nvethernet 6810000.ethernet: Macsec not supported/Not enabled in DT
[ 10.563977] usb 1-4.1.1.3: new low-speed USB device number 7 using tegra-xusb
[ 10.567090] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 10.582732] irq: IRQ305: trimming hierarchy from :pmc@c360000
[ 10.589436] irq: IRQ306: trimming hierarchy from :interrupt-controller@f400000-1
[ 10.597843] irq: IRQ307: trimming hierarchy from :pmc@c360000
[ 10.604502] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 10.612443] tegra-se-nvhost 15810000.se: Adding to iommu group 52
[ 10.619708] tegra-se-nvhost 15810000.se: initialized
[ 10.636194] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 10.643246] tegra-se-nvhost 15820000.se: Adding to iommu group 53
[ 10.650464] tegra-se-nvhost 15820000.se: initialized
[ 10.658566] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 10.665646] tegra-se-nvhost 15840000.se: Adding to iommu group 54
[ 10.673165] tegra-se-nvhost 15840000.se: initialized
[ 10.682935] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 10.683896] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 10.690561] tegra_actmon d230000.actmon: in actmon_register()...
[ 10.705760] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 10.713475] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 10.722570] hvc_sysfs: hypervisor is not present
[ 10.724423] usb 1-4.1.1.3: New USB device found, idVendor=0461, idProduct=4d51, bcdDevice= 7.17
[ 10.737596] usb 1-4.1.1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 10.746116] usb 1-4.1.1.3: Product: DELL Laser Mouse
[ 10.757310] input: DELL Laser Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.1/1-4.1.1/1-4.1.1.3/1-4.1.1.3:1.0/0003:0461:4D51.0002/input/input2
[ 10.771863] hid-generic 0003:0461:4D51.0002: input,hidraw1: USB HID v1.11 Mouse [DELL Laser Mouse] on usb-3610000.xhci-4.1.1.3/input0
[ 10.854876] ALSA device list:
[ 10.858657] No soundcards found.
[ 10.863446] Freeing unused kernel memory: 3968K
[ 10.868834] Run /init as init process
[ 10.873275] with arguments:
[ 10.873276] /init
[ 10.873277] nv-auto-config
[ 10.873278] with environment:
[ 10.873278] HOME=/
[ 10.873279] TERM=linux
[ 10.873280] mminit_loglevel=4
[ 10.884908] Root device found: mmcblk0p1
[ 10.895243] Found dev node: /dev/mmcblk0p1
[ 10.926262] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.945078] Rootfs mounted over mmcblk0p1
[ 10.960826] Switching from initrd to actual rootfs
[ 11.092961] systemd[1]: System time before build time, advancing clock.
[ 11.140968] systemd[1]: systemd 245.4-4ubuntu3.21 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 11.166147] systemd[1]: Detected architecture arm64.
[ 11.213598] systemd[1]: Set hostname to <ubuntu>.
[ 11.398611] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 11.412477] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 11.422980] systemd[1]: Created slice system-modprobe.slice.
[ 11.430918] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 11.439369] systemd[1]: Created slice User and Session Slice.
[ 11.447042] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.456806] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.468303] systemd[1]: Reached target User and Group Name Lookups.
[ 11.476519] systemd[1]: Reached target Slices.
[ 11.482832] systemd[1]: Reached target Mounting snaps.
[ 11.489814] systemd[1]: Reached target Mounted snaps.
[ 11.496677] systemd[1]: Reached target Swap.
[ 11.502935] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 11.511402] systemd[1]: Listening on Syslog Socket.
[ 11.518184] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 11.526817] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 11.535408] systemd[1]: Listening on Journal Audit Socket.
[ 11.542855] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.550782] systemd[1]: Listening on Journal Socket.
[ 11.557734] systemd[1]: Listening on udev Control Socket.
[ 11.565102] systemd[1]: Listening on udev Kernel Socket.
[ 11.573433] systemd[1]: Mounting Huge Pages File System...
[ 11.581840] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.590960] systemd[1]: Mounting RPC Pipe File System...
[ 11.599118] systemd[1]: Mounting Kernel Debug File System...
[ 11.607645] systemd[1]: Mounting Kernel Trace File System...
[ 11.616458] systemd[1]: Starting Journal Service...
[ 11.624449] systemd[1]: Starting Set the console keyboard layout...
[ 11.633628] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 11.645161] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 11.653838] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 11.654801] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 11.672513] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 11.681401] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 11.690347] systemd[1]: Starting Load Kernel Module ramoops...
[ 11.699048] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 11.708883] systemd[1]: Started Nameserver information manager.
[ 11.716787] systemd[1]: Reached target Network (Pre).
[ 11.725846] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 11.736011] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 11.753959] systemd[1]: Starting Load Kernel Modules...
[ 11.761892] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.770088] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 11.770579] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 11.784427] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000000838e00000,16777216
[ 11.785516] systemd[1]: Starting udev Coldplug all Devices...
[ 11.794779] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 11.810458] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000849800000,914358272
[ 11.820883] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 11.820890] nvmap_page_pool_init: Total RAM pages: 7831812
[ 11.836317] nvmap_page_pool_init: nvmap page pool size: 978976 pages (3824 MB)
[ 11.836350] nvmap_background_zero_thread: PP zeroing thread starting.
[ 11.836444] misc nvmap: created heap vpr base 0x0000000849800000 size (892928KiB)
[ 11.839442] misc nvmap: created heap fsi base 0x0000000838e00000 size (16384KiB)
[ 11.871518] systemd[1]: Started Journal Service.
[ 11.896142] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 11.930482] systemd-journald[277]: Received client request to flush runtime journal.
[ 12.214701] using random self ethernet address
[ 12.221415] using random host ethernet address
[ 12.340622] spi-tegra114 3210000.spi: Adding to iommu group 2
[ 12.345866] spi-tegra114 3230000.spi: Adding to iommu group 2
[ 12.364250] nvidia: loading out-of-tree module taints kernel.
[ 12.372123] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 12.376521] nv_platform 13800000.display: Adding to iommu group 55
[ 12.377914] platform 13800000.display:nvdisplay-niso: Adding to iommu group 56
[ 12.378602] cpu-throttle-alert cooling device registered.
[ 12.378686] gpu-throttle-alert cooling device registered.
[ 12.378745] cv0-throttle-alert cooling device registered.
[ 12.378805] cv1-throttle-alert cooling device registered.
[ 12.378856] cv2-throttle-alert cooling device registered.
[ 12.378913] soc0-throttle-alert cooling device registered.
[ 12.378960] soc1-throttle-alert cooling device registered.
[ 12.379032] soc2-throttle-alert cooling device registered.
[ 12.379135] hot-surface-alert cooling device registered.
[ 12.380608] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 35.4.1 Release Build (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:45:41 PDT 2023
[ 12.381551] irq: IRQ308: trimming hierarchy from :pmc@c360000
[ 12.442331] nvvrs11 4-0020: NVVRS11 Vendor ID: 0x11
[ 12.442646] nvvrs11 4-0020: NVVRS11 Model Rev: 0x81
[ 12.442650] nvvrs11 4-0020: NVVRS11 probe successful
[ 12.442909] irq: IRQ309: trimming hierarchy from :pmc@c360000
[ 12.442916] nct1008_nct72 4-004c: starting parse dt
[ 12.442971] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 12.442973] nct1008_nct72 4-004c: success parsing dt
[ 12.443023] nvvrs11 4-0022: NVVRS11 Vendor ID: 0x11
[ 12.443045] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 12.443273] nvvrs11 4-0022: NVVRS11 Model Rev: 0x81
[ 12.443275] nvvrs11 4-0022: NVVRS11 probe successful
[ 12.444892] tegra-hda 3510000.hda: Adding to iommu group 57
[ 12.479329] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 12.479950] nct1008_nct72 4-004c: EXT shutdown limit 107
[ 12.483102] nvadsp 2993000.adsp: Adding to iommu group 58
[ 12.483219] nvadsp 2993000.adsp: in probe()...
[ 12.483781] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 12.516349] nct1008_nct72 4-004c: initial LOC temp: 33000
[ 12.516829] nct1008_nct72 4-004c: initial EXT temp: 34750
[ 12.517764] nct1008_nct72 4-004c: hi_b:-4, lo_b:0
[ 12.518510] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 12.532601] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input3
[ 12.532765] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input4
[ 12.532854] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input5
[ 12.532989] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input6
[ 12.561030] irq: IRQ311: trimming hierarchy from :pmc@c360000
[ 12.572320] loop: module loaded
[ 12.576606] tegra-asoc: sound: Adding to iommu group 58
[ 12.591435] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 12.599667] ucsi_ccg 1-0008: Port-0: no role switch found
[ 12.607624] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 58
[ 12.607645] tegra210_adsp_audio_probe: platform probe started
[ 12.608595] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 12.609128] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 12.609358] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 12.609610] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 12.609845] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 12.610067] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 12.610070] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 12.610071] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 12.610122] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 12.623319] cdi_tsc c6a0000.tsc_sig_gen: CDI TSC probing...
[ 12.623389] cdi_tsc_probe: Initializing the driver
[ 12.624016] cdi_tsc_probe: Successfully initialized the tsc char driver
[ 12.666902] usbcore: registered new interface driver btusb
[ 12.677674] rtl88x2ce 0001:01:00.0: Adding to iommu group 9
[ 12.677987] rtl88x2ce 0001:01:00.0: enabling device (0000 -> 0003)
[ 12.680908] cryptd: max_cpu_qlen set to 1000
[ 12.683856] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 12.692056] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 12.700485] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 12.700490] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 12.700491] rtk_btcoex: create workqueue
[ 12.700563] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 12.700605] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 12.700606] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 12.700607] rtk_btusb: patch_add
[ 12.700609] rtk_btusb: auto suspend is disabled
[ 12.700611] rtk_btusb: pid = 0x3549
[ 12.700612] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 12.700618] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 12.702153] rtk_btusb: btusb_probe: done
[ 12.702202] rtk_btusb: btusb_open start
[ 12.702205] rtk_btusb: btusb_open hdev->promisc ==0
[ 12.702206] rtk_btusb: download_patch start
[ 12.702208] rtk_btusb: chip type value: 0x73
[ 12.702211] rtk_btusb: HCI reset.
[ 12.703281] usbcore: registered new interface driver rtk_btusb
[ 12.713093] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 12.713100] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 12.713102] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 12.713104] rtk_btusb: load_firmware start
[ 12.713105] rtk_btusb: lmp_version = 0x8822
[ 12.713107] rtk_btusb: config filename rtl8822cu_config
[ 12.720649] rtk_btusb: no bdaddr file /opt/bdaddr
[ 12.720656] rtk_btusb: 55 ab 23 87 00 00
[ 12.720664] rtk_btusb: Config file length 6, new length 6
[ 12.720666] rtk_btusb: fw name is rtl8822cu_fw
[ 12.724256] rtk_btusb: This is not 8723a, use new patch style!
[ 12.724262] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 12.726071] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 12.726078] rtk_btusb: load_firmware: New gEVersion 3
[ 12.726081] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 12.726083] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 12.726084] rtk_btusb: fw_version = 0x9a8cbc9
[ 12.726085] rtk_btusb: number_of_total_patch = 3
[ 12.726086] rtk_btusb: chipID 4
[ 12.726087] rtk_btusb: patch_length 0x8590
[ 12.726088] rtk_btusb: start_offset 0x00005d00
[ 12.726089] rtk_btusb: Svn version: 1940234490
[ 12.726090] rtk_btusb: Coexistence: BTCOEX_20210106-2020
[ 12.726091] rtk_btusb: buf_len = 0x8596
[ 12.726101] rtk_btusb: fw: exists, config file: exists
[ 12.726102] rtk_btusb: load_firmware done
[ 12.726114] rtk_btusb: download_data start
[ 12.899085] rtk_btusb: download_data done
[ 12.899091] rtk_btusb: HCI reset.
[ 12.910068] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[ 12.910074] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[ 12.910076] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 12.910084] rtk_btusb: Rtk patch end 0
[ 12.910087] rtk_btusb: btusb_open set HCI_RUNNING
[ 12.910108] rtk_btcoex: Open BTCOEX
[ 12.910110] rtk_btusb: btusb_open end
[ 12.912044] tegra210-adsp tegra210-adsp: Loaded app wire
[ 12.912050] tegra210-adsp tegra210-adsp: Loaded app apm
[ 12.912052] tegra210-adsp tegra210-adsp: Loaded app adma
[ 12.912054] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 12.912058] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 0000000068b37f53
[ 12.912085] rtk_btcoex: BTCOEX hci_rev 0x09a8
[ 12.912087] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[ 12.914877] Mass Storage Function, version: 2009/09/11
[ 12.914885] LUN: removable file: (no medium)
[ 12.917621] using random self ethernet address
[ 12.923186] using random host ethernet address
[ 12.938055] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 12.941108] rtk_btusb: btusb_notify: hci0 evt 3
[ 12.945689] rndis0: HOST MAC fe:1c:1f:a3:d4:08
[ 12.945694] rndis0: MAC fe:1c:1f:a3:d4:09
[ 12.946183] usb0: HOST MAC fe:1c:1f:a3:d4:0a
[ 12.946187] usb0: MAC fe:1c:1f:a3:d4:0b
[ 12.947012] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[ 12.950035] l4tbr0: port 1(rndis0) entered blocking state
[ 12.950047] l4tbr0: port 1(rndis0) entered disabled state
[ 12.950192] device rndis0 entered promiscuous mode
[ 12.956833] input: NVIDIA Jetson AGX Orin APE Headset Jack as /devices/platform/sound/sound/card1/input7
[ 12.968384] l4tbr0: port 2(usb0) entered blocking state
[ 12.968397] l4tbr0: port 2(usb0) entered disabled state
[ 12.968570] device usb0 entered promiscuous mode
[ 13.945141] pstore: Using crash dump compression: deflate
[ 13.945194] printk: console [ramoops-1] enabled
[ 13.945196] pstore: Registered ramoops as persistent store backend
[ 13.945198] ramoops: using 0x200000@0x82d270000, ecc: 0
[ 13.962201] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.962216] Bluetooth: BNEP socket layer initialized
[ 14.234098] nvgpu: 17000000.ga10b gk20a_scale_init:541 [INFO] enabled scaling for GPU
[ 14.838006] irq: IRQ313: trimming hierarchy from :interrupt-controller@f400000-1
[ 14.838571] hwmon hwmon6: temp1_input not attached to any thermal zone
[ 15.137121] Aquantia AQR113C 6810000.ethernet:00: No AQR phy_mode setting in DT
[ 15.457396] zram: Added device: zram0
[ 15.458672] zram: Added device: zram1
[ 15.458903] zram: Added device: zram2
[ 15.459080] zram: Added device: zram3
[ 15.459284] zram: Added device: zram4
[ 15.459438] zram: Added device: zram5
[ 15.459585] zram: Added device: zram6
[ 15.459705] zram: Added device: zram7
[ 15.523593] zram0: detected capacity change from 0 to 2004946944
[ 15.611974] Adding 1957952k swap on /dev/zram0. Priority:5 extents:1 across:1957952k SS
[ 15.615403] zram1: detected capacity change from 0 to 2004946944
[ 15.644004] Adding 1957952k swap on /dev/zram1. Priority:5 extents:1 across:1957952k SS
[ 15.646974] zram2: detected capacity change from 0 to 2004946944
[ 15.687896] Adding 1957952k swap on /dev/zram2. Priority:5 extents:1 across:1957952k SS
[ 15.689927] zram3: detected capacity change from 0 to 2004946944
[ 15.732011] Adding 1957952k swap on /dev/zram3. Priority:5 extents:1 across:1957952k SS
[ 15.734065] zram4: detected capacity change from 0 to 2004946944
[ 15.783916] Adding 1957952k swap on /dev/zram4. Priority:5 extents:1 across:1957952k SS
[ 15.785870] zram5: detected capacity change from 0 to 2004946944
[ 15.823994] Adding 1957952k swap on /dev/zram5. Priority:5 extents:1 across:1957952k SS
[ 15.826060] zram6: detected capacity change from 0 to 2004946944
[ 15.867933] Adding 1957952k swap on /dev/zram6. Priority:5 extents:1 across:1957952k SS
[ 15.869971] zram7: detected capacity change from 0 to 2004946944
[ 15.920028] Adding 1957952k swap on /dev/zram7. Priority:5 extents:1 across:1957952k SS
[ 16.206959] Bridge firewalling registered
[ 16.452877] fuse: init (API version 7.32)
[ 16.735304] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 35.4.1 Release Build (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:45:42 PDT 2023
[ 23.241690] nvethernet 6810000.ethernet: [xpcs_lane_bring_up][477][type:0x4][loga-0x0] PCS block lock SUCCESS
[ 23.241764] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 23.242247] nvethernet 6810000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 24.466145] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[ 42.431881] vdd-12v-sys: disabling
[ 42.431898] vdd-3v3-ftdi: disabling
[ 226.002525] picoevb_rdma: module verification failed: signature and/or required key missing - tainting kernel
user@ubuntu:~/Downloads/jetson-rdma-picoevb-master/kernel-module$ lspci -v
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 64
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: 00001000-00001fff [size=4K]
Memory behind bridge: 40000000-400fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Capabilities: <access denied>
Kernel driver in use: pcieport
0001:01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
Subsystem: AzureWave RTL8822CE 802.11ac PCIe Wireless Network Adapter
Flags: bus master, fast devsel, latency 0, IRQ 312
I/O ports at 1000 [size=256]
Memory at 20a8000000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: rtl88x2ce
Kernel modules: rtl8822ce
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 229a (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 68
I/O behind bridge: [disabled]
0005:01:00.0 Memory controller: Xilinx Corporation Device b03f
Subsystem: Xilinx Corporation Device 0007
Flags: fast devsel
Memory at 2b28020000 (64-bit, non-prefetchable) [disabled] [size=64K]
Memory at 2b28000000 (32-bit, non-prefetchable) [disabled] [size=128K]
