How can I boot from usb on xavier nx?
I am using jetpack 4.6.1.
Jetson Nano succeeded in booting from the USB external storage device.
Xavier seems to have a different bootloader.
After specifying setvar boot-order usb, booting from usb does not work.
Can you explain how to boot xavier nx to usb external storage device?
[0002.417] I> Hit any key to stop autoboot:     4
TEGRA194 # printvar boot-order
I> boot-dev-order :-
I> 1.sd
I> 2.usb
I> 3.nvme
I> 4.emmc
I> 5.net
TEGRA194 # setvar boot-order usb
I> 1.usb
TEGRA194 # help
command list:
help - print command description/usage
? - alias for 'help'
echo - echo args to console
exit - exit shell
sf - spi flash test
history - command history
setvar - set a variable with user specified value
printvar - print value of specified variable
boot - kernel boot
mmu - info about mmu
TEGRA194 # echo boot-order
boot-order
TEGRA194 # boot
I> found decompressor handler: lz4-legacy
I> decompressing BMP blob ...
I> Kernel type = Normal
I> ########## USB (0) boot ##########
W> No valid slot number is found in scratch register
W> Return default slot: _a
I> Validate XUSB-FW ...
I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x30000
I> Encryption fuse is not ON
Thank you.
I tried booting with rsync on the usb stick (16GB), but it failed. The log is as below.
TEGRA194 # boot
I> USB Firmware Version: 60.09 release
I> regulator of usb2-0 already enabled
I> regulator of usb2-1 already enabled
I> regulator of usb2-2 already enabled
I> USB 2.0 port 2 new high-speed USB device detected
W> WARNING: event and command not matching, cmd_trb_ptr = 0xa4ad9000, cmd_ring.dma = 0xa4ad90c0
I> Start to enumerate device
I>
I> Enumerated USB Device 0781:5567
I>
I> Max LUN = 0
I> Vendor Identification   :  SanDisk
I> Product Identification  :  Cruzer Blade
I> Product Revision Level  :  1.00
I> READ CAPACITY - last LBA = 30595072, 14939MB
I> -0 params source =
I> Found 1 partitions in USB_MS (instance 0)
I> Look for boot partition
I> Fallback: assuming 0th partition is boot partition
I> Detect filesystem
I> Loading kernel-bootctrl from partition
I> Loading partition kernel-bootctrl at 0xa4b50000 from device(0x1)
W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
I> Loading extlinux.conf ...
I> Loading extlinux.conf binary from rootfs ...
I> rootfs path: /usb/boot/extlinux/extlinux.conf
I> ext4_read_data_from_extent:298: Total file read should not be larger than file stat size
E> file /usb/boot/extlinux/extlinux.conf read failed!!
W> Failed to load extlinux.conf binary from rootfs (err=202113305)
E> Failed to find/load /boot/extlinux/extlinux.conf
I> Loading kernel ...
I> No kernel binary path
I> Continue to load from partition ...
I> A/B: bin_type (37) slot 0
I> Loading kernel from partition
I> Loading partition kernel at 0xa4b50000 from device(0x1)
I> Validate kernel ...
I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
I> Checking boot.img header magic ... I> [OK]
I> Loading kernel-dtb ...
I> No kernel-dtb binary path
I> A/B: bin_type (38) slot 0
I> Loading kernel-dtb from partition
I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
I> Validate kernel-dtb ...
I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
I> Kernel hdr @0xa4b50000
I> Kernel dtb @0x90000000
I> decompressor handler not found
I> Copying kernel image (34484232 bytes) from 0xa4b50800 to 0x80080000 ... I> Done
I> Move ramdisk (len: 7238366) from 0xa6c34000 to 0x92000000
I> Updated bpmp info to DTB
I> Ramdisk: Base: 0x92000000; Size: 0x6e72de
I> Updated initrd info to DTB
W> WARN: Fail to override "console=none" in commandline
I> Active rootfs suffix:
E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
I> Active slot suffix:
I> add_boot_slot_suffix: slot_suffix =
I> Linux Cmdline: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0  video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06b3000 lut_mem=0x2008@0xa06b0000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
I> Updated bootarg info to DTB
W> MAC addr invalid!
E> Failed to get WIFI MAC address
E> Failed to get Bluetooth MAC address
I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:5f:96:62
W> "plugin-manager" doesn't exist, creating
I> Adding /chosen/plugin-manager/cvm
W> "chip-id" doesn't exist, creating
I> Adding /chosen/plugin-manager/chip-id
W> "configs" doesn't exist, creating
I> Adding /chosen/plugin-manager/configs
W> "ids" doesn't exist, creating
I> Adding /chosen/plugin-manager/ids
W> "odm-data" doesn't exist, creating
I> Adding /chosen/plugin-manager/odm-data
W> "memory" doesn't exist, creating
I> [0] START: 0x80000000, END: 0xac000000
I> [1] START: 0xac004000, END: 0xf0ad0000
I> [2] START: 0xf0adc000, END: 0xf0ae0000
I> dram_block larger than 80000000
I> [3] START: 0x100000000, END: 0x480000000
I> added [base:0x80000000, size:0x2c000000] to /memory
I> added [base:0xac200000, size:0x44800000] to /memory
I> added [base:0x100000000, size:0x380000000] to /memory
I> Updated memory info to DTB
E> add_disp_param: failed to get display params for du=1
W> "reset" doesn't exist, creating
I> Adding ecid(00000001642db1c110000000100082c0) to DT
I> NVG: Logical CPU: 0; MPIDR: 0x80000000
I> NVG: Logical CPU: 1; MPIDR: 0x80000001
I> NVG: Logical CPU: 2; MPIDR: 0x80000100
I> NVG: Logical CPU: 3; MPIDR: 0x80000101
I> NVG: Logical CPU: 4; MPIDR: 0x80000200
I> NVG: Logical CPU: 5; MPIDR: 0x80000201
I> Deleted cpu@6 node in DT
I> Deleted cpu@7 node in DT
I> Deleted cluster3 node in FDT
I> Update arm-pmu in FDT
I> - update property: interrupts
I> - update property: interrupt-affinity
W> "misc-data" doesn't exist, creating
I> Boot-device: QSPI
W> Unknown boot device
I> Add storage-qspi to plugin-manager/misc-data
W> Unknown storage device
I> Add serial number:1420122068674 as DT property
I> Plugin-manager override starting
I> node /plugin-manager/fragment-pcie-c5-rp matches
I> node /plugin-manager/fragement-tegra-wdt-en matches
I> Disable plugin-manager status in FDT
I> Plugin-manager override finished successfully
I> tegrabl_load_kernel_and_dtb: Done
I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5374-d5000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Sun Apr 17 02:37:44 PDT 2022
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44800000
[    0.000000] OF: fdt: - 100000000 ,  380000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] Found tegra_fbmem: 00800000@a06b3000
[    0.000000] Found lut_mem: 00002008@a06b0000
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[    0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 4063749
[    0.000000] Kernel command line: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0  video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06b3000 lut_mem=0x2008@0xa06b0000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29972(91%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.000000] Memory: 15427660K/16513012K available (15358K kernel code, 2956K rwdata, 6696K rodata, 8640K init, 612K bss, 331688K reserved, 753664K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f80000   ( 15360 KB)
[    0.000000]     .rodata : 0xffffff8008f80000 - 0xffffff8009610000   (  6720 KB)
[    0.000000]       .init : 0xffffff8009610000 - 0xffffff8009e80000   (  8640 KB)
[    0.000000]       .data : 0xffffff8009e80000 - 0xffffff800a163008   (  2957 KB)
[    0.000000]        .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4   (   613 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf10000000   (   256 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc400000000   ( 16384 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.008857] Console: colour dummy device 80x25
[    0.012431] console [tty0] enabled
[    0.016118] bootconsole [tegra_comb_uart0] disabled
[    0.020849] kmemleak: Kernel memory leak detector disabled
[    0.020883] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.020920] pid_max: default: 32768 minimum: 301
[    0.022005] Security Framework initialized
[    0.022562] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.022589] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.024367] ftrace: allocating 47098 entries in 184 pages
[    0.427878] sched-energy: Sched-energy-costs installed from DT
[    0.427914] ASID allocator initialised with 65536 entries
[    0.462017] tegra-id: chipid=21917.
[    0.462042] tegra-id: opt_subrevision=1.
[    0.462079] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[    0.462125] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[    0.462172] DTB Build time: Apr 17 2022 02:42:31
[    0.510462] CPU1: Booted secondary processor [4e0f0040]
[    0.542300] CPU2: Booted secondary processor [4e0f0040]
[    0.574404] CPU3: Booted secondary processor [4e0f0040]
[    0.606681] CPU4: Booted secondary processor [4e0f0040]
[    0.638805] CPU5: Booted secondary processor [4e0f0040]
[    0.639002] Brought up 6 CPUs
[    0.639143] SMP: Total of 6 processors activated.
[    0.639170] CPU features: detected feature: Privileged Access Never
[    0.639223] CPU features: detected feature: LSE atomic instructions
[    0.639263] CPU features: detected feature: User Access Override
[    0.639289] CPU features: detected feature: 32-bit EL0 Support
[    0.640821] CPU: All CPU(s) started at EL2
[    0.640891] alternatives: patching kernel code
[    0.648042] devtmpfs: initialized
[    0.686653] Initilizing CustomIPI irq domain
[    0.686927] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.686978] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.699647] pinctrl core: initialized pinctrl subsystem
[    0.699887] OS set in device tree is not L4T.
[    0.700184] regulator-dummy: no parameters
[    0.700482] Initializing plugin-manager
[    0.700551] Plugin module not found
[    0.700600] Plugin-manager status disabled
[    0.702138] NET: Registered protocol family 16
[    0.707984] pstore: using zlib compression
[    0.708800] console [pstore-1] enabled
[    0.708823] pstore: Registered ramoops as persistent store backend
[    0.708848] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[    0.729710] cpuidle: using governor menu
[    0.731074] bpmp: waiting for handshake
[    0.731128] bpmp: handshake completed
[    0.731162] bpmp: synchronizing channels
[    0.731186] bpmp: channels synchronized
[    0.731228] bpmp: mail init ok
[    0.733950] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[    0.734156] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[    0.734196] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[    0.734219] t19x-arm-smmu 12000000.iommu:    stage 1 translation
[    0.734243] t19x-arm-smmu 12000000.iommu:    stage 2 translation
[    0.734286] t19x-arm-smmu 12000000.iommu:    nested translation
[    0.734313] t19x-arm-smmu 12000000.iommu:    stream matching with 128 register groups, mask 0x7f80
[    0.734363] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.734407] t19x-arm-smmu 12000000.iommu:    64 context banks (0 stage-2 only)
[    0.734433] t19x-arm-smmu 12000000.iommu:    Stage-1: 39-bit VA -> 48-bit IPA
[    0.734460] t19x-arm-smmu 12000000.iommu:    Stage-2: 39-bit IPA -> 48-bit PA
[    0.737762] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e84000)
[    0.737822] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.740829] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.742407] tegra_aon_clk_init: ok
[    0.742448] Registering BPMP clocks...
[    0.742584] tegra_bpmp_clk_init: clock init ok (400 clks)
[    0.743315] Serial: AMBA PL011 UART driver
[    0.743506] tegra_powergate_init: DONE
[    0.743547] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[    0.743592] DTB Build time: Apr 17 2022 02:42:31
[    0.746758] Tegra reboot handler registered.
[    0.754100] iommu: Adding device 14160000.pcie to group 0
[    0.754797] iommu: Adding device 141a0000.pcie to group 1
[    0.756125] iommu: Adding device 2490000.ether_qos to group 2
[    0.756616] iommu: Adding device 3100000.serial to group 3
[    0.757132] iommu: Adding device 3110000.serial to group 4
[    0.757541] iommu: Adding device 3140000.serial to group 5
[    0.758182] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.758398] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    0.758446] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[    0.758466] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[    0.758485] tegra-pmc: ### PMC reset status reg: 0x0
[    0.758544] tegra-pmc: PMC Prod config success
[    0.758745] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.758796] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.759153] iommu: Adding device 3460000.sdhci to group 6
[    0.759685] iommu: Adding device 3400000.sdhci to group 7
[    0.760188] iommu: Adding device 3210000.spi to group 8
[    0.760837] iommu: Adding device 3230000.spi to group 9
[    0.761299] iommu: Adding device 3270000.spi to group 10
[    0.762383] iommu: Adding device 3160000.i2c to group 11
[    0.762805] iommu: Adding device c240000.i2c to group 12
[    0.763387] iommu: Adding device 3180000.i2c to group 13
[    0.763796] iommu: Adding device 3190000.i2c to group 14
[    0.764304] iommu: Adding device 31b0000.i2c to group 15
[    0.764699] iommu: Adding device 31c0000.i2c to group 16
[    0.765129] iommu: Adding device c250000.i2c to group 17
[    0.765541] iommu: Adding device 31e0000.i2c to group 18
[    0.766086] iommu: Adding device sound to group 19
[    0.766652] iommu: Adding device 3510000.hda to group 20
[    0.767429] iommu: Adding device bc00000.rtcpu to group 21
[    0.769308] iommu: Adding device 13e10000.host1x to group 22
[    0.769718] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[    0.770130] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[    0.770670] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[    0.771096] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[    0.771578] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[    0.772107] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[    0.772657] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[    0.773051] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[    0.773712] iommu: Adding device 15340000.vic to group 31
[    0.774255] iommu: Adding device 15380000.nvjpg to group 32
[    0.774556] iommu: Adding device 15500000.tsec to group 33
[    0.774962] iommu: Adding device 15100000.tsecb to group 34
[    0.775292] iommu: Adding device 15480000.nvdec to group 35
[    0.775589] iommu: Adding device 15140000.nvdec1 to group 36
[    0.775898] iommu: Adding device 154c0000.nvenc to group 37
[    0.776180] iommu: Adding device 15a80000.nvenc1 to group 38
[    0.776612] iommu: Adding device 15880000.nvdla0 to group 39
[    0.777025] iommu: Adding device 158c0000.nvdla1 to group 40
[    0.777602] iommu: Adding device 15200000.nvdisplay to group 41
[    0.777792] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06b3000(800000)
[    0.777837] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06b0000(3000)
[    0.781825] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[    0.781938] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[    0.782493] iommu: Adding device 15210000.nvdisplay to group 42
[    0.782577] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[    0.784174] iommu: Adding device 15c10000.vi to group 43
[    0.784375] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[    0.784887] iommu: Adding device 14800000.isp to group 44
[    0.785806] iommu: Adding device 16000000.pva0 to group 45
[    0.786410] iommu: Adding device 16800000.pva1 to group 46
[    0.786825] iommu: Adding device 15810000.se to group 47
[    0.787257] iommu: Adding device 15820000.se to group 48
[    0.787586] iommu: Adding device 15830000.se to group 49
[    0.787862] iommu: Adding device 15840000.se to group 50
[    0.788138] iommu: Adding device c1a0000.aon to group 51
[    0.789740] iommu: Adding device d000000.bpmp to group 52
[    0.790124] bpmp: ping status is 0
[    0.790260] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[    0.793381] bpmp d000000.bpmp: probe ok
[    0.795028] tegra-reset 0.bpmp_reset: registered 190 resets.
[    0.795516] iommu: Adding device smmu_test to group 53
[    0.796480] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c10000
[    0.796533] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c20000
[    0.796582] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c30000
[    0.796631] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2c40000
[    0.796675] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2c50000
[    0.796718] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2b80000
[    0.796761] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2b90000
[    0.796804] mc: mapped MMIO address: 0xffffff800b090000 -> 0x2ba0000
[    0.796862] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x2bb0000
[    0.796906] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1700000
[    0.797005] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1710000
[    0.797048] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1720000
[    0.797089] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1730000
[    0.797150] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1740000
[    0.797191] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1750000
[    0.797231] mc: mapped MMIO address: 0xffffff800b190000 -> 0x1760000
[    0.797309] mc: mapped MMIO address: 0xffffff800b1b0000 -> 0x1770000
[    0.797408] mc-err: mcerr ops are set to t19x
[    0.803047] iommu: Adding device 2600000.dma to group 54
[    0.807875] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[    0.809145] GPIO line 339 (wifi-enable) hogged as output/high
[    0.809213] GPIO line 412 (camera-control-output-low) hogged as output/low
[    0.809271] GPIO line 413 (camera-control-output-low) hogged as output/low
[    0.809542] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[    0.816276] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[    0.816407] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[    0.816468] GPIO line 266 (w-disable1) hogged as output/high
[    0.816530] GPIO line 264 (w-disable2) hogged as output/high
[    0.816586] GPIO line 265 (suspend-led-gpio) hogged as output/high
[    0.816854] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[    0.818887] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[    0.818916] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    0.818939] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    0.819773] iommu: Adding device 3550000.xudc to group 55
[    0.820442] iommu: Adding device 3610000.xhci to group 56
[    0.822653] arm64_ras arm64_ras: probed
[    0.823046] ras_fhi_enable: FHI 470 enabled on CPU0
[    0.823113] ras_fhi_enable: FHI 471 enabled on CPU1
[    0.823208] ras_fhi_enable: FHI 472 enabled on CPU2
[    0.823293] ras_fhi_enable: FHI 473 enabled on CPU3
[    0.823375] ras_fhi_enable: FHI 474 enabled on CPU4
[    0.823458] ras_fhi_enable: FHI 475 enabled on CPU5
[    0.823677] carmel_ras_enable: RAS enabled on cpu0
[    0.823870] carmel_ras_enable: RAS enabled on cpu1
[    0.824087] carmel_ras_enable: RAS enabled on cpu2
[    0.824298] carmel_ras_enable: RAS enabled on cpu3
[    0.824499] carmel_ras_enable: RAS enabled on cpu4
[    0.824691] carmel_ras_enable: RAS enabled on cpu5
[    0.824798] carmel_ras carmel_ras: probed
[    0.825818] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[    0.826360] tegra-cbb c600000.aon-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[    0.827219] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[    0.828048] tegra-cbb be00000.rce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[    0.828873] tegra-cbb b600000.sce-noc: noc_secure_irq = 487, noc_nonsecure_irq = 486>
[    0.829306] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[    0.830391] vdd-ac-bat: 5000 mV
[    0.830806] vdd-sdmmc1-sw: 3300 mV
[    0.831093] vdd-1v8-sd: 1800 mV
[    0.831411] vdd-3v3-cvb: 3300 mV
[    0.831722] vdd-1v8-cvb: 1800 mV
[    0.832012] vdd-epb-1v0: 1000 mV
[    0.832234] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    0.832539] avdd-cam-2v8: 2800 mV
[    0.832841] vdd-fan: 5000 mV
[    0.833142] vdd-hdmi-5v0: 5000 mV
[    0.833469] vdd_sys_en: 1200 mV
[    0.866524] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.870631] eventlib_kernel: keventlib is initialized, test id: 0
[    0.870958] SCSI subsystem initialized
[    0.871469] usbcore: registered new interface driver usbfs
[    0.871552] usbcore: registered new interface driver hub
[    0.871629] usbcore: registered new device driver usb
[    0.882875] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[    0.885662] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[    0.894704] vdd-1v0: at 1000 mV
[    0.898742] vdd-1v8-hs: at 1800 mV
[    0.902521] vdd-1v8-ls: at 1800 mV
[    0.906506] vdd-1v8-ao: at 1800 mV
[    0.910526] vddio-ddr-1v1: at 1100 mV
[    0.914299] vdd-rtc: at 800 mV
[    0.915463] spmic-ldo1: at 2375 mV
[    0.922324] vdd-ao-3v3: at 3300 mV
[    0.930375] vddio-emmc-3v3: at 3300 mV
[    0.931603] spmic-ldo4: at 1587 mV
[    0.938376] vdd-usb-3v3: at 3300 mV
[    0.946435] vddio-sdmmc1-3v3: at 3300 mV
[    0.950434] vdd-csi-1v2: at 1200 mV
[    0.951905] spmic-ldo8: at 1800 mV
[    0.956790] GPIO line 246 (gpio_default) hogged as output/high
[    0.958165] GPIO line 247 (gpio_default) hogged as output/high
[    0.958540] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[    0.958880] max77620 4-003c: max77620 probe successful
[    0.959627] media: Linux media interface: v0.10
[    0.959754] Linux video capture interface: v2.00
[    0.961349] pps_core: LinuxPPS API ver. 1 registered
[    0.961370] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.961455] PTP clock support registered
[    0.961828] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.962129] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.962198] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.964832] trusty trusty: trusty version: Built: 02:25:37 Apr 17 2022
[    0.964910] trusty trusty: selected api version: 3 (requested 3)
[    0.965772] Advanced Linux Sound Architecture Driver Initialized.
[    0.966285] Bluetooth: Core ver 2.22
[    0.966335] NET: Registered protocol family 31
[    0.966354] Bluetooth: HCI device and connection manager initialized
[    0.966381] Bluetooth: HCI socket layer initialized
[    0.966406] Bluetooth: L2CAP socket layer initialized
[    0.966506] Bluetooth: SCO socket layer initialized
[    0.971918] camchar: rtcpu character device driver loaded
[    0.972415] gpio tegra-gpio wake61 for gpio=201(Z:1)
[    0.972516] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[    0.974099] clocksource: Switched to clocksource arch_sys_counter
[    1.017160] VFS: Disk quotas dquot_6.6.0
[    1.017276] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.017628] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    1.019387] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[    1.019478] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[    1.019882] cma: enabled page replacement for spfn=c6000, epfn=f0000
[    1.019907] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    1.019942] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[    1.019971] nvmap_page_pool_init: Total RAM pages: 4045331
[    1.019991] nvmap_page_pool_init: nvmap page pool size: 505666 pages (1975 MB)
[    1.020157] nvmap_background_zero_thread: PP zeroing thread starting.
[    1.020503] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[    1.022662] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    1.034891] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[    1.035167] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[    1.035426] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[    1.035660] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[    1.035893] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    1.037131] la/ptsa driver initialized.
[    1.037443] NET: Registered protocol family 2
[    1.037548] IP idents hash table entries: 262144 (order: 9, 2097152 bytes)
[    1.044930] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    1.045609] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    1.046249] TCP: Hash tables configured (established 131072 bind 65536)
[    1.046315] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[    1.046588] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[    1.047080] NET: Registered protocol family 1
[    1.047603] RPC: Registered named UNIX socket transport module.
[    1.047625] RPC: Registered udp transport module.
[    1.047643] RPC: Registered tcp transport module.
[    1.047661] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.047866] Trying to unpack rootfs image as initramfs...
[    1.264599] Freeing initrd memory: 7068K
[    1.279955] random: fast init done
[    1.283826] host1x 13e10000.host1x: initialized
[    1.285776] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.290560] audit: initializing netlink subsys (disabled)
[    1.290618] audit: type=2000 audit(0.900:1): initialized
[    1.291259] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[    1.299768] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.300912] ntfs: driver 2.1.32 [Flags: R/W].
[    1.301478] 9p: Installing v9fs 9p2000 file system support
[    1.306608] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.306798] io scheduler noop registered
[    1.307077] io scheduler cfq registered (default)
[    1.310503] gic 2a41000.agic-controller: GIC IRQ controller registered
[    1.342924] iommu: Adding device 2993000.adsp to group 57
[    1.452420] iommu: Adding device aconnect@2a41000:adsp_audio to group 58
[    1.453417] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    1.465823] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    1.466357] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    1.466944] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    1.467374] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    1.467763] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    1.471537] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    1.471739] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    1.474509] tsec 15500000.tsec: initialized
[    1.476184] tsec 15100000.tsecb: initialized
[    1.480335] nvdec 15480000.nvdec: initialized
[    1.483237] nvdec 15140000.nvdec1: initialized
[    1.488951] falcon 15340000.vic: initialized
[    1.490975] falcon 15380000.nvjpg: initialized
[    1.492890] falcon 154c0000.nvenc: initialized
[    1.494831] falcon 15a80000.nvenc1: initialized
[    1.497966] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    1.499681] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    1.501138] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    1.502734] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    1.504332] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    1.505976] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    1.507547] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    1.508955] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    1.512315] t194-nvcsi 15a00000.nvcsi: initialized
[    1.517559] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    1.517931] scare-pigeon 14b00000.isp-thi: initialized
[    1.523287] pva 16000000.pva0: initialized
[    1.529003] pva 16800000.pva1: initialized
[    1.533887] nvdla 15880000.nvdla0: initialized
[    1.538825] nvdla 158c0000.nvdla1: initialized
[    1.540500] tegradccommon 15200000.dc_common: host1x channel mapped
[    1.540533] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[    1.540613] tegradccommon 15200000.dc_common: dma mapping done
[    1.540826] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=78
[    1.540863] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[    1.541286] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    1.541326] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    1.541560] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    1.541582] tegra_cec 3960000.tegra_cec: probed
[    1.542445] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[    1.542526] generic_infoframe_type: 0x87
[    1.542653] tegradc 15200000.nvdisplay: DT parsed successfully
[    1.542713] tegradc 15200000.nvdisplay: Display dc.ffffff800bd50000 registered with id=0
[    1.548069] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    1.548099] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    1.548122] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    1.548356] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[    1.548381] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[    1.549348] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[    1.552113] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[    1.552146] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    1.554273] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[    1.555031] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[    1.555064] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    1.555473] kfuse 3830000.kfuse: initialized
[    1.556194] tegradc 15200000.nvdisplay: probed
[    1.561516] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.564234] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[    1.565712] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[    1.566719] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[    2.562146] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[    2.562157] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    4.034219] console [ttyTCU0] enabled
[    4.034658] [drm] Initialized
[    4.035071] Console: switching to colour frame buffer device 240x67
[    4.047133] tegradc 15200000.nvdisplay: fb registered
[    4.052408] gpio tegra-gpio wake63 for gpio=97(M:1)
[    4.057652] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    4.062874] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    4.066814] brd: module loaded
[    4.074066] Parent Clock set for DC plld2
[    4.080341] loop: module loaded
[    4.080527] tegra_profiler: version: 1.145, samples/io: 49/28
[    4.084896] tegra_profiler: auth: init
[    4.089416] THERMAL EST: found 3 subdevs
[    4.092463] THERMAL EST num_resources: 0
[    4.096650] [THERMAL EST subdev 0]
[    4.100065] [THERMAL EST subdev 1]
[    4.103471] [THERMAL EST subdev 2]
[    4.106893] THERMAL EST: Found 2 profiles, default profile is quiet
[    4.113015] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    4.122024] THERMAL EST: thz register success.
[    4.126326] THERMAL EST: end of probe, return err: 0
[    4.131748] sd: No Scsi addr parsed to reserve index
[    4.133509] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[    4.134093] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[    4.134131] tegradc 15200000.nvdisplay: hdmi: BL set VIC 0
[    4.134136] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[    4.159592] extcon-disp-state external-connection:disp-state: cable 47 state 1
[    4.159596] Extcon AUX1(HDMI) enable
[    4.159981] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[    4.160011] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[    4.160124] tegradc 15210000.nvdisplay: DT parsed successfully
[    4.160203] tegradc 15210000.nvdisplay: Display dc.ffffff800d010000 registered with id=1
[    4.160453] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[    4.160459] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[    4.169116] tegradc 15210000.nvdisplay: probed
[    4.223939] hisi_sas: driver version v1.6
[    4.223953] tegradc 15210000.nvdisplay: fb registered
[    4.227274] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    4.227280] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    4.227290] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    4.253305] tegradc 15210000.nvdisplay: blank - powerdown
[    4.258857] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[    4.267211] Extcon DP: HPD disabled
[    4.270622] hpd: hpd_switch 0
[    4.273751] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    4.280758] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    4.286725] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    4.300060] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[    4.300191] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[    4.304213] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[    4.315857] 1 ofpart partitions found on MTD device spi6.0
[    4.321354] Creating 1 MTD partitions on "spi6.0":
๏ฃท?ARNING: pll_d2 has no dyn ramp
๏ฃท?    4.326011] 0x000000000000-0x000002000000 : "Whole_flash0"
[    4.326054] tegradc 15200000.nvdisplay: blank - powerdown
[    4.328353] libphy: Fixed MDIO Bus: probed
[    4.330002] tun: Universal TUN/TAP device driver, 1.6
[    4.330006] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.330765] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    4.330769] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    4.330802] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    4.330805] igb: Copyright (c) 2007-2014 Intel Corporation.
[    4.330834] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    4.330837] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    4.330876] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[    4.330879] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    4.367260] extcon-disp-state external-connection:disp-state: cable 47 state 0
[    4.367295] Extcon AUX1(HDMI) disable
[    4.393024] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[    4.394350] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[    4.483186] tegradc 15200000.nvdisplay: unblank
[    4.484850] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    4.485129] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    4.492491] Parent Clock set for DC plld2
[    4.497245] tegradc 15200000.nvdisplay: hdmi: tmds rate:297000K prod-setting:prod_c_hdmi_223m_300m
[    4.498666] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[    4.533400] extcon-disp-state external-connection:disp-state: cable 47 state 1
[    4.533404] Extcon AUX1(HDMI) enable
[    4.565553] tegradc 15200000.nvdisplay: sync windows ret = 242
[    4.577360] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[    4.577877] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 5f 96 62
[    4.577892] Using phyrst_lpmode = 1 from DT
[    4.578055] libphy: dwc_phy: probed
[    4.580554] PPP generic driver version 2.4.2
[    4.581106] PPP BSD Compression module registered
[    4.581111] PPP Deflate Compression module registered
[    4.581134] PPP MPPE Compression module registered
[    4.581139] NET: Registered protocol family 24
[    4.581184] usbcore: registered new interface driver r8152
[    4.581244] usbcore: registered new interface driver asix
[    4.581275] usbcore: registered new interface driver ax88179_178a
[    4.581301] usbcore: registered new interface driver cdc_ether
[    4.581355] usbcore: registered new interface driver net1080
[    4.581380] usbcore: registered new interface driver cdc_subset
[    4.581407] usbcore: registered new interface driver zaurus
[    4.581444] usbcore: registered new interface driver cdc_ncm
[    4.581938] VFIO - User Level meta-driver version: 0.3
[    4.583042] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.583061] ehci-pci: EHCI PCI platform driver
[    4.583088] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.583097] ohci-pci: OHCI PCI platform driver
[    4.583123] ohci-platform: OHCI generic platform driver
[    4.588707] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[    4.590735] tegra-xusb 3610000.xhci: extcon 0: ffffffc3ec220400 id
[    4.591587] usbcore: registered new interface driver uas
[    4.591669] usbcore: registered new interface driver usb-storage
[    4.591739] usbcore: registered new interface driver usbserial
[    4.593165] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[    4.593196] tegra-xusb 3610000.xhci: xHCI Host Controller
[    4.593212] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    4.593945] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[    4.593981] tegra-xusb 3610000.xhci: irq 465, io mem 0x03610000
[    4.594267] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.594274] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.594279] usb usb1: Product: xHCI Host Controller
[    4.594283] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[    4.594288] usb usb1: SerialNumber: 3610000.xhci
[    4.594759] hub 1-0:1.0: USB hub found
[    4.594800] hub 1-0:1.0: 4 ports detected
[    4.595242] tegra-xusb 3610000.xhci: xHCI Host Controller
[    4.595252] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    4.595260] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    4.595445] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    4.595450] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.595455] usb usb2: Product: xHCI Host Controller
[    4.595460] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[    4.595465] usb usb2: SerialNumber: 3610000.xhci
[    4.595913] hub 2-0:1.0: USB hub found
[    4.595986] hub 2-0:1.0: 4 ports detected
[    4.596799] Wake76 for irq=199
[    4.596802] Wake77 for irq=199
[    4.596804] Wake78 for irq=199
[    4.596806] Wake79 for irq=199
[    4.596809] Wake80 for irq=199
[    4.596811] Wake81 for irq=199
[    4.596813] Wake82 for irq=199
[    4.596846] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[    4.596853] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[    4.599043] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[    4.599159] tegra-xudc-new 3550000.xudc: device count: 1
[    4.600055] tegra-xudc-new 3550000.xudc: vbus state: 0
[    4.600063] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[    4.600086] tegra-xudc-new 3550000.xudc: entering ELPG
[    4.600310] tegra-xudc-new 3550000.xudc: entering ELPG done
[    4.600873] mousedev: PS/2 mouse device common for all mice
[    4.601003] usbcore: registered new interface driver xpad
[    4.698588] usb usb2: usb_suspend_both: status 0
[    4.759286] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    4.766292] Wake73 for irq=42
[    4.767598] rtc rtc1: alarm rtc device
[    4.767611] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    4.767652] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    4.767841] i2c /dev entries driver
[    4.770172] i2c i2c-2: Added multiplexed i2c bus 9
[    4.770598] i2c i2c-2: Added multiplexed i2c bus 10
[    4.770603] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    4.771374] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[    4.799562] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    4.799664] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[    4.799764] imx219 9-0010: board setup failed
[    4.799866] imx219: probe of 9-0010 failed with error -121
[    4.800250] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[    4.825092] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    4.825152] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[    4.825240] imx219 10-0010: board setup failed
[    4.825333] imx219: probe of 10-0010 failed with error -121
[    4.831231] max77620-power max20024-power: Event recorder REG_NVERC : 0x50
[    4.946128] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    5.010842] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[    5.011321] FAN dev name: pwm-fan
[    5.011372] FAN:gpio request success.
[    5.011404] FAN: can't find tach_gpio
[    5.011412] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[    5.011435] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[    5.011692] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    5.011697] pwm_fan_driver pwm-fan: tach period: 1000
[    5.069459] usb 1-2: New USB device found, idVendor=0781, idProduct=5567
[    5.069466] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.069470] usb 1-2: Product: Cruzer Blade
[    5.069475] usb 1-2: Manufacturer: SanDisk
[    5.069512] usb 1-2: SerialNumber: 4C530001101219117581
[    5.070037] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    5.070042] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[    5.070047] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[    5.070051] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[    5.070054] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    5.070058] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    5.070062] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    5.070066] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    5.070070] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    5.070075] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    5.071014] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[    5.072271] device-mapper: uevent: version 1.0.3
[    5.072764] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    5.089050] usb-storage 1-2:1.0: USB Mass Storage device detected
[    5.089516] scsi host0: usb-storage 1-2:1.0
[    5.410297] extcon-disp-state external-connection:disp-state: cable 51 state 1
[    5.414987] Extcon HDMI: HPD enabled
[    5.418978] tegradc 15200000.nvdisplay: hdmi: plugged
[    5.425115] tegra194_cpufreq_probe: platform driver Initialization: pass
[    5.429476] cpuidle: Initializing cpuidle driver
[    5.433310] sdhci: Secure Digital Host Controller Interface driver
[    5.436078] sdhci: Copyright(c) Pierre Ossman
[    5.438688] sdhci-pltfm: SDHCI platform and OF driver helper
[    5.443003] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[    5.448060] CMDQ: cmdq_platfm_init successful
[    5.451301] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    5.456362] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[    5.460997] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 247
[    5.468231] tegra-se-nvhost 15810000.se: initialized
[    5.472469] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    5.476477] tegra-se-nvhost 15820000.se: initialized
[    5.480312] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    5.485143] tegra-se-nvhost 15830000.se: initialized
[    5.488630] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    5.492501] tegra-se-nvhost 15840000.se: initialized
[    5.496050] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    5.498125] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[    5.502709] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    5.505511] hidraw: raw HID events driver (C) Jiri Kosina
[    5.510228] gpio tegra-gpio wake8 for gpio=55(G:7)
[    5.510250] usbcore: registered new interface driver usbhid
[    5.510253] usbhid: USB HID core driver
[    5.514244] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[    5.515256] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    5.515753] tegra186-aondbg aondbg: aondbg driver probe() OK
[    5.516445] denver_knobs_init:MTS_VERSION:54811859
[    5.516773] tegra19x_actmon d230000.actmon: in actmon_register()...
[    5.517311] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[    5.517708] t19x_cache tegra-cache: probed
[    5.519766] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[    5.519772] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[    5.520303] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[    5.520688] PLL_AON clock registered
[    5.521794] Clocks initialized successfully
[    5.523509] nvpmodel: initialized successfully
[    5.597929] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[    5.598608] trusty-virtio trusty:virtio: initializing
[    5.598820] trusty_ipc virtio0: vring0: va(pa)  ffffffc3d9654000(0) qsz 32 notifyid 1
[    5.598828] trusty_ipc virtio0: vring1: va(pa)  ffffffc3d9656000(0) qsz 32 notifyid 2
[    5.598997] trusty-virtio trusty:virtio: initializing done
[    5.599133] trusty_ipc virtio0: is online
[    5.599708] tegra-hda 3510000.hda: Override SDO lines to 4
[    5.600170] usbcore: registered new interface driver snd-usb-audio
[    5.630198] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    5.630385] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    5.630595] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[    5.630737] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[    5.695839] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[    5.703793] OPE platform probe
[    5.706689] OPE platform probe successful
[    5.717315] mmc0: periodic cache flush enabled
[    5.720047] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    5.723243] mmcblk0: mmc0:0001 HAG4a2 14.7 GiB
[    5.726201] mmcblk0boot0: mmc0:0001 HAG4a2 partition 1 8.00 MiB
[    5.729149] mmcblk0boot1: mmc0:0001 HAG4a2 partition 2 8.00 MiB
[    5.732152] mmcblk0rpmb: mmc0:0001 HAG4a2 partition 3 4.00 MiB
[    5.739627]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[    5.788845] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    5.791870] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    5.794675] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    5.797448] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    5.800210] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    5.802982] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    5.805726] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    5.808500] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    5.811713] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    5.815044] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    5.817849] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    5.820693] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    5.823467] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    5.826222] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    5.828954] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    5.831689] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    5.834421] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    5.837185] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[    5.840741] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[    5.846776] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[    5.881670] u32 classifier
[    5.884394]     Actions configured
[    5.887030] Initializing XFRM netlink socket
[    5.890196] NET: Registered protocol family 10
[    5.893494] NET: Registered protocol family 17
[    5.896053] NET: Registered protocol family 15
[    5.898645] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    5.901412] Bluetooth: RFCOMM socket layer initialized
[    5.904060] Bluetooth: RFCOMM ver 1.11
[    5.906616] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.909202] Bluetooth: HIDP socket layer initialized
[    5.911825] 9pnet: Installing 9P2000 support
[    5.914447] Key type dns_resolver registered
[    5.918202] Registered cp15_barrier emulation handler
[    5.923208] Registered setend emulation handler
[    5.929579] registered taskstats version 1
[    5.932813] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[    5.940167] OF: PCI: host bridge /pcie@14160000 ranges:
[    5.944036] OF: PCI:    IO 0x36100000..0x361fffff -> 0x36100000
[    5.949804] OF: PCI:   MEM 0x1740000000..0x17ffffffff -> 0x40000000
[    5.956280] OF: PCI:   MEM 0x1400000000..0x173fffffff -> 0x1400000000
[    6.114826] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Blade     1.00 PQ: 0 ANSI: 6
[    6.118342] sd 0:0:0:0: [sda] 30595072 512-byte logical blocks: (15.7 GB/14.6 GiB)
[    6.122609] sd 0:0:0:0: [sda] Write Protect is off
[    6.125758] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    6.144359]  sda: sda1
[    6.148921] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    6.479442] tegra-pcie-dw 14160000.pcie: link is down
[    6.482390] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[    6.485033] pci_bus 0004:00: root bus resource [bus 00-ff]
[    6.487702] pci_bus 0004:00: root bus resource [io  0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[    6.490372] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[    6.493074] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[    6.496151] iommu: Adding device 0004:00:00.0 to group 59
[    6.499045] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    6.501671] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    6.504583] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[    6.507750] iommu: Removing device 0004:00:00.0 from group 59
[    6.512194] tegra-pcie-dw 14160000.pcie: PCIe link is not up...!
[    6.515667] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[    6.518635] tegra-pcie-dw 141a0000.pcie: Failed to get 3V slot regulator: -19
[    6.521315] tegra-pcie-dw 141a0000.pcie: Failed to get 12V slot regulator: -19
[    6.630436] OF: PCI: host bridge /pcie@141a0000 ranges:
[    6.633214] OF: PCI:    IO 0x3a100000..0x3a1fffff -> 0x3a100000
[    6.635949] OF: PCI:   MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[    6.638698] OF: PCI:   MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    6.750161] tegra-pcie-dw 141a0000.pcie: link is up
[    6.753216] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[    6.756017] pci_bus 0005:00: root bus resource [bus 00-ff]
[    6.758733] pci_bus 0005:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[    6.761519] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    6.764336] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    6.767465] iommu: Adding device 0005:00:00.0 to group 59
[    6.771895] iommu: Adding device 0005:01:00.0 to group 60
[    6.787110] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[    6.789865] pci 0005:00:00.0: BAR 13: assigned [io  0x100000-0x100fff]
[    6.792583] pci 0005:01:00.0: BAR 4: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[    6.795386] pci 0005:01:00.0: BAR 2: assigned [mem 0x1f40004000-0x1f40004fff 64bit]
[    6.798169] pci 0005:01:00.0: BAR 0: assigned [io  0x100000-0x1000ff]
[    6.800847] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    6.803483] pci 0005:00:00.0:   bridge window [io  0x100000-0x100fff]
[    6.806137] pci 0005:00:00.0:   bridge window [mem 0x1f40000000-0x1f400fffff]
[    6.808837] pci 0005:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    6.811651] pci 0005:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    6.814611] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[    6.817259] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[    6.820421] r8168 0005:01:00.0: enabling device (0000 -> 0003)
[    6.823168] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[    6.840135] r8168 0005:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[    6.843003] r8168 0005:01:00.0 (unnamed net_device) (uninitialized): bad mac address at /chosen/nvidia,ethernet-mac: missing.
[    6.845838] r8168 0005:01:00.0 (unnamed net_device) (uninitialized): Assigning random ethernet address 8a:ac:cb:f5:1d:e6
[    6.849431] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    6.860363] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
[    6.860363]  This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[    6.860363]  This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    6.901659] tegra-cbb 14040000.cv-noc: noc_secure_irq = 91, noc_nonsecure_irq = 90>
[    6.909129] tegra194-isp5 14800000.isp: initialized
[    6.919063] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[    6.924700] tegra194-vi5 15c10000.vi: initialized
[    6.932260] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[    6.935269] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[    6.938365] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[    6.945469] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[    6.948341] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[    6.955098] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[    6.963887] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[    6.972011] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[    6.980718] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[    6.993388] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[    6.997460] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[    7.006111] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[    7.016166] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[    7.023633] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[    7.033494] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[    7.043857] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[    7.052237] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[    7.060952] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[    7.069940] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[    7.078466] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
๏ฃท?ARNING: at platform/drivers/pg/pg-gpu-t194.c:185
WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
๏ฃท?    7.164598] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[    7.167696] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    7.171835] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[    7.174805] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[    7.178047] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[    7.180967] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[    7.184068] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (66)
[    7.186837] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    7.190718] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=4c29076f2400b1aca1797dafeba3d8643d889753
[    7.194028] Wake83 for irq=211
[    7.196872] gpio tegra-gpio wake67 for gpio=48(G:0)
[    7.199746] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[    7.202650] input: gpio-keys as /devices/gpio-keys/input/input4
[    7.239654] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-02 22:09:47 UTC (946850987)
[    7.243123] mmcblk mmc0:0001: Card claimed for testing.
[    7.285926] bpmp: mounted debugfs mirror
[    7.295384] ALSA device list:
[    7.298240]   #0: tegra-hda-xnx at 0x3518000 irq 65
[    7.301057]   #1: jetson-xaviernx-ape
[    7.305981] Freeing unused kernel memory: 8640K
[    7.347402] Root device found: mmcblk0p1
[    7.352611] Found dev node: /dev/mmcblk0p1
[    7.380149] EXT4-fs (mmcblk0p1): recovery complete
[    7.383270] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    7.388925] Rootfs mounted over mmcblk0p1
[    7.416819] Switching from initrd to actual rootfs
[    7.508199] systemd[1]: System time before build time, advancing clock.
[    7.532530] ip_tables: (C) 2000-2006 Netfilter Core Team
[    7.539430] cgroup: cgroup2: unknown option "nsdelegate"
[    7.550292] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    7.554626] systemd[1]: Detected architecture arm64.
[    7.577406] systemd[1]: Set hostname to <manager-desktop>.
[    7.666480] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    7.670323] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    7.827244] random: systemd: uninitialized urandom read (16 bytes read)
[    7.831313] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.839020] random: systemd: uninitialized urandom read (16 bytes read)
[    7.845100] systemd[1]: Created slice User and Session Slice.
[    7.852236] random: systemd: uninitialized urandom read (16 bytes read)
[    7.855813] systemd[1]: Reached target Swap.
[    7.866363] systemd[1]: Reached target User and Group Name Lookups.
[    7.874805] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.987915] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    8.027057] nvgpu: 17000000.gv11b          nvgpu_nvhost_syncpt_init:291  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[    8.027057]
๏ฃท?    9.157961] using random self ethernet address
[    9.157965] using random host ethernet address
[    9.502558] random: crng init done
[    9.506712] random: 7 urandom warning(s) missed due to ratelimiting
[    9.788338] using random self ethernet address
[    9.792740] using random host ethernet address
[   10.375686] CPU4: shutdown
[   10.455970] CPU5: shutdown
[   11.466911] Bridge firewalling registered
Ubuntu 18.04.6 LTS manager-desktop ttyTCU0
manager-desktop login:
Could you tell me how to resolve this issue?
Thank you.
Please apply the cboot patch to your cboot.
https://elinux.org/Jetson/L4T/r32.7.x_patches
Hello, @WayneWWW
Cboot ์†Œ์Šค์ฝ”๋“œ๋Š” ์•„๋ž˜์—์„œ ๋ฐ›์„ ์ˆ˜ ์žˆ๋Š”๋ฐ์š”.
ํŒŒ์ผ์„ ์—ด์–ด์„œ ํŒจ์น˜๋‚ด์šฉ์„ ์ ์šฉํ•˜๊ณ  ๋นŒ๋“œํ•œ ํ›„ ํ•ด๋‹น๋‚ด์šฉ์„ Jetson Xavier NX emmc๋ชจ๋“ˆ์— ์ ์šฉํ•˜๋Š” ๋ฐฉ๋ฒ•์„ ๋ชจ๋ฅด๊ฒ ์Šต๋‹ˆ๋‹ค. Jetson Linux Developer Guide์—์„œ๋„ ํ•ด๋‹น ๋‚ด์šฉ์„ ๊ฒ€์ƒ‰ํ•ด๋ดค๋Š”๋ฐ ๋ชป์ฐพ๊ฒ ๋”๋ผ๊ณ ์š”.
๋ฐฉ๋ฒ•์„ ์•Œ๋ ค์ค„ ์ˆ˜ ์žˆ๋‚˜์š”?
๊ฐ์‚ฌํ•ฉ๋‹ˆ๋‹ค.
There is a readme file inside the cboot source.
Hello, @WayneWWW
make๋ฅผ ์‹œ๋„ํ•ด๋ดค๋Š”๋ฐ ์ข…๋ฃŒ๋  ๋•Œ ์˜ค๋ฅ˜ ๋ฉ”์‹œ์ง€๊ฐ€ ๋‚˜์˜ต๋‹ˆ๋‹ค.
๊ทธ๋Ÿฐ๋ฐ cboot/out/build-t194 ๋””๋ ‰ํ† ๋ฆฌ์— ๋“ค์–ด๊ฐ€๋ณด๋ฉด ์•„๋ž˜์™€ ๊ฐ™์ด ๊ฒฐ๊ณผ๋ฌผ์€ ์žˆ๋„ค์š”.
๋นŒ๋“œ์— ์„ฑ๊ณตํ•œ๊ฑด๊ฐ€์š”?
(base) aiserver@aiserver-H110-D3:/media/aiserver/data/manage_jetpack_version/cboot/out/build-t194$ ls
bootloader build_config.h lk.bin lk.elf lk.elf.map system-onesegment.ld
(base) aiserver@aiserver-H110-D3:/media/aiserver/data/manage_jetpack_version/cboot$ make -C ./bootloader/partner/t18x/cboot PROJECT=t194 TOOLCHAIN_PREFIX="${CROSS_COMPILE}" DEBUG=2 BUILDROOT="${PWD}"/out NV_TARGET_BOARD=t194ref NV_BUILD_SYSTEM_TYPE=l4t NOECHO=@
make: Entering directory '/media/aiserver/data/manage_jetpack_version/cboot/bootloader/partner/t18x/cboot'
LKROOT=. LKINC=". " make -rR -f ./engine.mk -I.
make[1]: Entering directory '/media/aiserver/data/manage_jetpack_version/cboot/bootloader/partner/t18x/cboot'
PROJECT = t194
PLATFORM = t194
TARGET = t194
TEGRA_TOP = /media/aiserver/data/manage_jetpack_version/cboot
TOOLCHAIN_PREFIX = /home/aiserver/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
์˜ค๋ฅ˜๋ฉ”์‹œ์ง€๋Š” ์•„๋ž˜์™€ ๊ฐ™์Šต๋‹ˆ๋‹ค.
   1749      32       0    1781     6f5 /media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/bootloader/partner/t19x/common/lib/tegrabl_auth.mod.o
   1357       0       8    1365     555 /media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/bootloader/partner/t19x/common/lib/tegrabl_brbct.mod.o
   1299       0       8    1307     51b /media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/bootloader/partner/t19x/common/lib/tegrabl_brbit.mod.o
    319       0       0     319     13f /media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/bootloader/partner/t19x/common/soc/t194/ccplex_cache.mod.o
    226       0       0     226      e2 /media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/bootloader/partner/t19x/common/soc/t194/ccplex_nvg.mod.o
   3392       0       9    3401     d49 /media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/bootloader/partner/t19x/common/soc/t194/misc.mod.o
    349       0       0     349     15d /media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/bootloader/partner/t19x/common/soc/t194/qual_engine.mod.o
     52       0       0      52      34 app/kernel_boot/../../../../common/lib/linuxboot/../../../t19x/common/lib/linuxboot/t194/prebuilt/vpr.mod.o
  52882    2664    1503   57049    ded9 platform/t194/../../../../t19x/common/drivers/se/prebuilt/se.mod.o
   2280       0       0    2280     8e8 platform/t194/../../../../t19x/common/soc/t194/qual_engine/prebuilt/qual_engine_priv.o
 582149   20698  164047  766894   bb3ae (TOTALS)
generating image: /media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/lk.bin
   text    data     bss     dec     hex filename
 449383   17568  162752  629703   99bc7 /media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/lk.elf
Appending version string: t194-d5107ac2 to /media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/lk.bin
  File "./scripts/add_version_info.py", line 43, in <module>
    f.write(struct.pack('%ds' % (length), version_string))
struct.error: argument for 's' must be a bytes object
make/build.mk:4: recipe for target '/media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/lk.bin' failed
make[1]: *** [/media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/lk.bin] Error 1
make[1]: Leaving directory '/media/aiserver/data/manage_jetpack_version/cboot/bootloader/partner/t18x/cboot'
makefile:13: recipe for target '_top' failed
make: *** [_top] Error 2
make: Leaving directory '/media/aiserver/data/manage_jetpack_version/cboot/bootloader/partner/t18x/cboot'
๊ณ ๋ง™์Šต๋‹ˆ๋‹ค.
What is the python version in use?
์•ˆ๋…•ํ•˜์„ธ์š”? @WayneWWW
์„ค์น˜๋œ ํŒŒ์ด์ฌ ๋ฒ„์ „์€ ์•„๋ž˜์™€ ๊ฐ™์Šต๋‹ˆ๋‹ค.
(base) aiserver@aiserver-H110-D3:/media/aiserver/data/manage_jetpack_version/cboot$ python
python python2.7-config python3 python3.6m python3.8-config python3m-config
python2 python2-config python3.6 python3.6m-config python3-config python-config
python2.7 python2-qr python3.6-config python3.8 python3m
Cboot readme์—์„œ ๋‹ค์Œ ๋ฌธ๊ตฌ๋ฅผ ๋ดค๋Š”๋ฐ์š”.
  • Python2 must be available.
ํŒŒ์ด์ฌ ๊ฒฝ๋กœ๋„ ์ง€์ •ํ•ด์ค˜์•ผํ•˜๋‚˜์š”?
๊ณ ๋ง™์Šต๋‹ˆ๋‹ค.
Just run โ€œpythonโ€ and share the version you see.
Python 3.8.5 (default, Sep 4 2020, 07:30:14)
[GCC 7.3.0] :: Anaconda, Inc. on linux
Type โ€œhelpโ€, โ€œcopyrightโ€, โ€œcreditsโ€ or โ€œlicenseโ€ for more information
Then it is python3โ€ฆ please use python2 as default python first.
ํŒŒ์ด์ฌ ๋ฒ„์ „ ๋ณ€๊ฒฝํ–ˆ์Šต๋‹ˆ๋‹ค.
Python 2.7.17 (default, Mar 18 2022, 13:21:42)
[GCC 7.5.0] on linux2
Type "help", "copyright", "credits" or "license" for more information.
๋‹น์‹ ์ด ์•Œ๋ ค์ค€ ํŒจ์น˜๋‚ด์šฉ๋Œ€๋กœ ext4.c๋ฅผ ์ˆ˜์ •ํ•˜๊ณ  ๋นŒ๋“œํ•˜๋Š”๋ฐ ์•„๋ž˜์™€ ๊ฐ™์€ ์˜ค๋ฅ˜๊ฐ€ ๋‚˜์˜ต๋‹ˆ๋‹ค.
/media/aiserver/data/manage_jetpack_version/cboot/bootloader/partner/common/lib/fs/ext4/ext4.c: In function โ€˜ext4_read_data_from_extentโ€™:
/media/aiserver/data/manage_jetpack_version/cboot/bootloader/partner/common/lib/fs/ext4/ext4.c:262:9: error: โ€˜lenโ€™ undeclared (first use in this function)
     if (len != 0UL) {
/media/aiserver/data/manage_jetpack_version/cboot/bootloader/partner/common/lib/fs/ext4/ext4.c:262:9: note: each undeclared identifier is reported only once for each function it appears in
make/compile.mk:43: recipe for target '/media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/bootloader/partner/common/lib/fs/ext4/ext4.o' failed
make[1]: *** [/media/aiserver/data/manage_jetpack_version/cboot/out/build-t194/bootloader/partner/common/lib/fs/ext4/ext4.o] Error 1
๊ณ ๋ง™์Šต๋‹ˆ๋‹ค.
This issue is on rel-32.7.2. So you need to use 32.7.2 cboot to build. 32.7.1 does not have this issue.
์ด๊ฑฐ ๋ฐ›์•„์„œ ๋นŒ๋“œํ•˜๋ฉด ๋ฌธ์ œ ์—†๋Š”๊ฑฐ์ฃ ?
๋นŒ๋“œ๋Š” ๋๊ณ  Linux_for_Tegra/bootloader ๋ฐ‘์— cboot๋ฐ”์ด๋„ˆ๋ฆฌ๋ฅผ ์œ„์น˜์‹œ์ผฐ๋Š”๋ฐ
์ ์šฉํ•˜๋Š” ๋ฐฉ๋ฒ•์„ ์•Œ๋ ค์ค„ ์ˆ˜ ์žˆ๋‚˜์š”?
๊ณ ๋ง™์Šต๋‹ˆ๋‹ค.
Please refer to L4T doc - Jetson Xavier NX / AGX Xavier / TX2 Update and Redundancy: NVIDIA Jetson Linux Driver Package Software Features : Bootloader | NVIDIA Docs
์•ˆ๋…•ํ•˜์„ธ์š”?
[0002.434] I> Using default boot order
[0002.437] I> boot-dev-order :-
[0002.440] I> 1.sd
[0002.442] I> 2.usb
[0002.444] I> 3.nvme
[0002.446] I> 4.emmc
[0002.448] I> 5.net
[0002.450] I> Hit any key to stop autoboot: 4 3
TEGRA194 # printvar boot-order
I> 1.sd
I> 2.usb
I> 3.nvme
I> 4.emmc
I> 5.net
TEGRA194 # setvar boot-order usb
ํŒจ์น˜๋‚ด์šฉ ๋ฐ˜์˜ํ›„ usb์ €์žฅ์žฅ์น˜๋กœ ๋ถ€ํŒ…์—๋Š” ์„ฑ๊ณตํ–ˆ์Šต๋‹ˆ๋‹ค.
cboot์—์„œ ์˜๊ตฌ์ ์œผ๋กœ ๋ถ€ํŒ…์ˆœ์„œ๋ฅผ usb๋กœ ๋ฐ”๊พธ๋Š” ๋ฐฉ๋ฒ•์„ ์•Œ๋ ค์ค„ ์ˆ˜ ์žˆ๋‚˜์š”?
๊ณ ๋ง™์Šต๋‹ˆ๋‹ค.
It seems you found the answer already, see Cboot ์†Œ์Šค์—์„œ ๋ถ€ํŒ… ์ˆœ์„œ ๋ณ€๊ฒฝํ•˜๋ ค๋ฉด ์–ด๋–ป๊ฒŒ ํ•ด์•ผํ•˜๋‚˜์š”? - #2 by forumuser
