Hi Nvidia,
I’m using the sdmmc3 for sd card on my custom board, the device tree is added:
sdhci@3400000 {
status = "disabled";
sdhci@3440000 {
mmc-ocr-mask = <0x0>;
cd-gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(Q, 2) 0>;
nvidia,cd-wakeup-capable;
status = "okay";
Now the sd card detection and hotplugging are working.
I write/read sd card after mounting sd card:
nvidia@nvidia-desktop:~$ df -Th
Filesystem Type Size Used Avail Use% Mounted on
/dev/mmcblk0p1 ext4 14G 12G 2.0G 86% /
none devtmpfs 3.5G 0 3.5G 0% /dev
tmpfs tmpfs 3.8G 4.0K 3.8G 1% /dev/shm
tmpfs tmpfs 3.8G 21M 3.8G 1% /run
tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs tmpfs 3.8G 0 3.8G 0% /sys/fs/cgroup
tmpfs tmpfs 777M 12K 777M 1% /run/user/120
tmpfs tmpfs 777M 108K 777M 1% /run/user/1000
/dev/mmcblk1p1 ext4 59G 7.8G 48G 14% /home/nvidia/data
But sometims(not always) there is error in writing/reading sd card:
[ 261.421720] mmc1: Data CRC error
[ 261.421822] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 261.421929] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 261.422034] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003ea
[ 261.422138] sdhci: Argument: 0x00110000 | Trn mode: 0x0000002b
[ 261.422246] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 261.422353] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 261.422459] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 261.422566] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 261.422678] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 261.422782] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 261.422890] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 261.422996] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 261.423454] sdhci: Host ctl2: 0x00003000
[ 261.423742] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 261.424245] sdhci: ===========================================
[ 261.426787] mmcblk1: error -84 transferring data, sector 1114112, nr 1024, cmd response 0x900, card status 0xc00
[ 261.927252] mmc1: Data CRC error
[ 261.927353] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 261.927461] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 261.927571] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000185
[ 261.927680] sdhci: Argument: 0x00113800 | Trn mode: 0x0000002b
[ 261.927783] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 261.927887] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 261.927995] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 261.928099] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 261.928202] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 261.928304] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 261.928409] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 261.928514] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 261.928976] sdhci: Host ctl2: 0x00003000
[ 261.929274] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe470
[ 261.929795] sdhci: ===========================================
[ 261.933385] mmcblk1: error -84 transferring data, sector 1128448, nr 1024, cmd response 0x900, card status 0xc00
[ 262.022546] mmc1: Data CRC error
[ 262.022643] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 262.022750] sdhci: Sys addr: 0x00000185 | Version: 0x00000505
[ 262.022854] sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000017e
[ 262.022960] sdhci: Argument: 0x00113a7b | Trn mode: 0x0000002b
[ 262.023066] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 262.023171] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 262.023278] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 262.023382] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 262.023487] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 262.023594] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 262.023699] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 262.023803] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 262.024216] sdhci: Host ctl2: 0x00003000
[ 262.024530] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 262.025035] sdhci: ===========================================
[ 262.034838] mmcblk1: error -84 transferring data, sector 1129083, nr 389, cmd response 0x900, card status 0xc00
[ 262.039956] mmc1: Data CRC error
[ 262.040272] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 262.046135] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 262.051739] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003bb
[ 262.057601] sdhci: Argument: 0x00113c00 | Trn mode: 0x0000002b
[ 262.063721] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 262.069584] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 262.075445] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 262.081308] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 262.087087] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 262.093208] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 262.098988] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 262.105196] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 262.111056] sdhci: Host ctl2: 0x00003000
[ 262.114824] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 262.121224] sdhci: ===========================================
[ 262.130255] mmcblk1: error -84 transferring data, sector 1129472, nr 1024, cmd response 0x900, card status 0xc00
[ 262.137614] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 402653184 size 8388608 starting)
[ 262.614860] mmc1: Data CRC error
[ 262.614958] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 262.615068] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 262.615171] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003d9
[ 262.615277] sdhci: Argument: 0x00118000 | Trn mode: 0x0000002b
[ 262.615381] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 262.615494] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 262.615597] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 262.615704] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 262.615813] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 262.615919] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 262.616025] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 262.616133] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 262.616576] sdhci: Host ctl2: 0x00003000
[ 262.616875] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 262.617396] sdhci: ===========================================
[ 262.625617] mmcblk1: error -84 transferring data, sector 1146880, nr 1024, cmd response 0x900, card status 0xc00
[ 262.709953] mmc1: Data CRC error
[ 262.710049] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 262.710160] sdhci: Sys addr: 0x000003da | Version: 0x00000505
[ 262.710264] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003d0
[ 262.710369] sdhci: Argument: 0x00118026 | Trn mode: 0x0000002b
[ 262.710475] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 262.710581] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 262.710688] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 262.710791] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 262.710897] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 262.711007] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 262.711111] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 262.711217] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 262.711632] sdhci: Host ctl2: 0x00003000
[ 262.711930] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 262.712453] sdhci: ===========================================
[ 262.716112] mmcblk1: error -84 transferring data, sector 1146918, nr 986, cmd response 0x900, card status 0xc00
[ 262.727171] mmc1: Data CRC error
[ 262.727620] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 262.733483] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 262.739344] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fd
[ 262.745464] sdhci: Argument: 0x00118400 | Trn mode: 0x0000002b
[ 262.751069] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 262.757189] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 262.763050] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 262.768657] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 262.774951] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 262.780814] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 262.786851] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 262.792543] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 262.798405] sdhci: Host ctl2: 0x00003000
[ 262.802429] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 262.808572] sdhci: ===========================================
[ 262.815719] mmcblk1: error -84 transferring data, sector 1147904, nr 1024, cmd response 0x900, card status 0xc00
[ 262.826922] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 419430400 size 8388608 starting)
[ 262.841998] mmc1: Data CRC error
[ 262.842091] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 262.846970] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 262.853089] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fb
[ 262.858952] sdhci: Argument: 0x00118800 | Trn mode: 0x0000002b
[ 262.864556] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 262.870851] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 262.876891] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 262.882752] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 262.888789] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 262.894826] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 262.900607] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 262.906470] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 262.912330] sdhci: Host ctl2: 0x00003000
[ 262.916355] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 262.922755] sdhci: ===========================================
[ 262.930331] mmcblk1: error -84 transferring data, sector 1148928, nr 1024, cmd response 0x900, card status 0xc00
[ 262.940120] mmc1: Data CRC error
[ 262.941903] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 262.947765] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 262.953630] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fd
[ 262.959489] sdhci: Argument: 0x00118c00 | Trn mode: 0x0000002b
[ 262.965353] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 262.971214] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 262.976818] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 262.982940] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 262.988976] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 262.994838] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 263.000619] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 263.006657] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 263.012775] sdhci: Host ctl2: 0x00003000
[ 263.016542] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 263.022943] sdhci: ===========================================
[ 263.035948] mmcblk1: error -84 transferring data, sector 1149952, nr 1024, cmd response 0x900, card status 0xc00
[ 263.039366] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 419430400 size 8388608 starting)
[ 263.056589] mmc1: Data CRC error
[ 263.056679] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 263.061342] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 263.067202] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fb
[ 263.073064] sdhci: Argument: 0x00119000 | Trn mode: 0x0000002b
[ 263.078942] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 263.084706] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 263.091000] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 263.096863] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 263.102646] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 263.108939] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 263.114977] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 263.120580] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 263.126701] sdhci: Host ctl2: 0x00003000
[ 263.130208] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 263.136868] sdhci: ===========================================
[ 263.144655] mmcblk1: error -84 transferring data, sector 1150976, nr 1024, cmd response 0x900, card status 0xc00
[ 263.158661] mmc1: Data CRC error
[ 263.158754] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 263.161877] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 263.167482] sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000037e
[ 263.173601] sdhci: Argument: 0x00119400 | Trn mode: 0x0000002b
[ 263.179207] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 263.185327] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 263.191189] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 263.196793] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 263.203090] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 263.208695] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 263.214989] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 263.221027] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 263.226632] sdhci: Host ctl2: 0x00003000
[ 263.230656] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe430
[ 263.237055] sdhci: ===========================================
[ 263.243899] mmcblk1: error -84 transferring data, sector 1152000, nr 1024, cmd response 0x900, card status 0xc00
[ 263.252964] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 419430400 size 8388608 starting)
[ 263.270739] mmc1: Data CRC error
[ 263.270834] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 263.275452] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 263.281058] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fc
[ 263.287177] sdhci: Argument: 0x00119800 | Trn mode: 0x0000002b
[ 263.293040] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 263.298819] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 263.305115] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 263.310720] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 263.316755] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 263.322793] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 263.328832] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 263.334964] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 263.340554] sdhci: Host ctl2: 0x00003000
[ 263.344580] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 263.350980] sdhci: ===========================================
[ 263.358566] mmcblk1: error -84 transferring data, sector 1153024, nr 1024, cmd response 0x900, card status 0xc00
[ 263.367906] mmc1: Data CRC error
[ 263.369869] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 263.375993] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 263.381595] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 263.387715] sdhci: Argument: 0x00119c00 | Trn mode: 0x0000002b
[ 263.393576] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 263.399181] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 263.405044] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 263.411165] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 263.417201] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 263.423064] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 263.428845] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 263.435140] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 263.441000] sdhci: Host ctl2: 0x00003000
[ 263.444768] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 263.451177] sdhci: ===========================================
[ 263.457858] mmcblk1: error -84 transferring data, sector 1154048, nr 1024, cmd response 0x900, card status 0xc00
[ 263.467341] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 419430400 size 8388608 starting)
[ 263.484682] mmc1: Data CRC error
[ 263.484772] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 263.489307] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 263.495168] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fb
[ 263.501288] sdhci: Argument: 0x0011a000 | Trn mode: 0x0000002b
[ 263.507151] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 263.513190] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 263.519225] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 263.525088] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 263.531125] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 263.537163] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 263.543201] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 263.549062] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 263.554925] sdhci: Host ctl2: 0x00003000
[ 263.558693] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 263.565091] sdhci: ===========================================
[ 263.576867] mmcblk1: error -84 transferring data, sector 1155072, nr 1024, cmd response 0x900, card status 0xc00
[ 263.582881] mmc1: Data CRC error
[ 263.584240] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 263.590102] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 263.595964] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fc
[ 263.601825] sdhci: Argument: 0x0011a400 | Trn mode: 0x0000002b
[ 263.607431] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 263.613551] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 263.619413] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 263.625018] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 263.631314] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 263.636918] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 263.643213] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 263.648993] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 263.655113] sdhci: Host ctl2: 0x00003000
[ 263.658623] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 263.665280] sdhci: ===========================================
[ 263.672582] mmcblk1: error -84 transferring data, sector 1156096, nr 1024, cmd response 0x900, card status 0xc00
[ 263.681418] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 419430400 size 8388608 starting)
[ 263.698142] mmc1: Data CRC error
[ 263.698215] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 263.703418] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 263.709280] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fb
[ 263.715142] sdhci: Argument: 0x0011a800 | Trn mode: 0x0000002b
[ 263.721262] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 263.727299] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 263.733338] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 263.739200] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 263.744981] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 263.751016] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 263.757054] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 263.763174] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 263.768777] sdhci: Host ctl2: 0x00003000
[ 263.772544] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 263.778945] sdhci: ===========================================
[ 263.786210] mmcblk1: error -84 transferring data, sector 1157120, nr 1024, cmd response 0x900, card status 0xc00
[ 263.797225] mmc1: Data CRC error
[ 263.798350] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 263.803956] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 263.810075] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fc
[ 263.815938] sdhci: Argument: 0x0011ac00 | Trn mode: 0x0000002b
[ 263.821542] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 263.827404] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 263.833526] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 263.839387] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 263.845425] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 263.851030] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 263.857067] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 263.863104] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 263.868965] sdhci: Host ctl2: 0x00003000
[ 263.872731] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 263.879390] sdhci: ===========================================
[ 263.891910] mmcblk1: error -84 transferring data, sector 1158144, nr 1024, cmd response 0x900, card status 0xc00
[ 263.895790] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 419430400 size 8388608 starting)
[ 263.913060] mmc1: Data CRC error
[ 263.913153] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 263.917532] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 263.923392] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fc
[ 263.929512] sdhci: Argument: 0x0011b000 | Trn mode: 0x0000002b
[ 263.935375] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 263.941413] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 263.947449] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 263.953311] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 263.959092] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 263.965387] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 263.971424] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 263.977286] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 263.982890] sdhci: Host ctl2: 0x00003000
[ 263.986915] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 263.993057] sdhci: ===========================================
[ 264.001047] mmcblk1: error -84 transferring data, sector 1159168, nr 1024, cmd response 0x900, card status 0xc00
[ 264.015077] mmc1: Data CRC error
[ 264.015163] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 264.018326] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 264.024187] sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000037e
[ 264.030049] sdhci: Argument: 0x0011b400 | Trn mode: 0x0000002b
[ 264.035912] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 264.041516] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 264.047637] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 264.053242] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 264.059537] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 264.065400] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 264.071437] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 264.077216] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 264.083079] sdhci: Host ctl2: 0x00003000
[ 264.086843] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe430
[ 264.093503] sdhci: ===========================================
[ 264.100112] mmcblk1: error -84 transferring data, sector 1160192, nr 1024, cmd response 0x900, card status 0xc00
[ 264.111614] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 419430400 size 8388608 starting)
[ 264.131343] mmc1: Data CRC error
[ 264.131420] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 264.131905] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 264.137507] sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000037e
[ 264.143368] sdhci: Argument: 0x0011b800 | Trn mode: 0x0000002b
[ 264.149230] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 264.155268] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 264.161307] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 264.167169] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 264.173464] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 264.179502] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 264.185540] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 264.191402] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 264.197263] sdhci: Host ctl2: 0x00003000
[ 264.201030] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe430
[ 264.207173] sdhci: ===========================================
[ 264.214560] mmcblk1: error -84 transferring data, sector 1161216, nr 1024, cmd response 0x900, card status 0xc00
[ 264.229753] mmc1: Data CRC error
[ 264.229846] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 264.232440] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 264.238301] sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000037e
[ 264.243907] sdhci: Argument: 0x0011bc00 | Trn mode: 0x0000002b
[ 264.249768] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 264.255633] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 264.261751] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 264.267613] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 264.273393] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 264.279256] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 264.285551] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 264.291331] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 264.297449] sdhci: Host ctl2: 0x00003000
[ 264.300959] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe430
[ 264.307619] sdhci: ===========================================
[ 264.314591] mmcblk1: error -84 transferring data, sector 1162240, nr 1024, cmd response 0x900, card status 0xc00
[ 264.325680] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 419430400 size 8388608 starting)
[ 264.340752] mmc1: Data CRC error
[ 264.340841] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 264.346013] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 264.351618] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003f9
[ 264.357736] sdhci: Argument: 0x0011c000 | Trn mode: 0x0000002b
[ 264.363342] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 264.369638] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 264.375416] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 264.381278] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 264.387316] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 264.393612] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 264.399650] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 264.405512] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 264.411116] sdhci: Host ctl2: 0x00003000
[ 264.415139] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 264.421540] sdhci: ===========================================
[ 264.428764] mmcblk1: error -84 transferring data, sector 1163264, nr 1024, cmd response 0x900, card status 0xc00
[ 264.438077] blk_update_request: 2217 callbacks suppressed
[ 264.438082] blk_update_request: I/O error, dev mmcblk1, sector 1163270
[ 264.449040] blk_update_request: I/O error, dev mmcblk1, sector 1163272
[ 264.455431] blk_update_request: I/O error, dev mmcblk1, sector 1163280
[ 264.461557] blk_update_request: I/O error, dev mmcblk1, sector 1163288
[ 264.467997] blk_update_request: I/O error, dev mmcblk1, sector 1163296
[ 264.474578] blk_update_request: I/O error, dev mmcblk1, sector 1163304
[ 264.480987] blk_update_request: I/O error, dev mmcblk1, sector 1163312
[ 264.487279] blk_update_request: I/O error, dev mmcblk1, sector 1163320
[ 264.493920] blk_update_request: I/O error, dev mmcblk1, sector 1163328
[ 264.500491] blk_update_request: I/O error, dev mmcblk1, sector 1163336
[ 264.510925] mmc1: Data CRC error
[ 264.511006] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 264.516120] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 264.522156] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 264.528451] sdhci: Argument: 0x0011c400 | Trn mode: 0x0000002b
[ 264.534489] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 264.540271] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 264.546307] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 264.552344] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 264.558640] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 264.564419] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 264.570713] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 264.576751] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 264.582354] sdhci: Host ctl2: 0x00003000
[ 264.586120] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 264.592781] sdhci: ===========================================
[ 264.599653] mmcblk1: error -84 transferring data, sector 1164288, nr 1024, cmd response 0x900, card status 0xc00
[ 264.610827] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 427819008 size 8388608 starting)
[ 264.622104] buffer_io_error: 2550 callbacks suppressed
[ 264.622110] Buffer I/O error on device mmcblk1p1, logical block 141312
[ 264.633618] Buffer I/O error on device mmcblk1p1, logical block 141313
[ 264.639953] Buffer I/O error on device mmcblk1p1, logical block 141314
[ 264.646343] Buffer I/O error on device mmcblk1p1, logical block 141315
[ 264.652724] Buffer I/O error on device mmcblk1p1, logical block 141316
[ 264.659037] Buffer I/O error on device mmcblk1p1, logical block 141317
[ 264.665426] Buffer I/O error on device mmcblk1p1, logical block 141318
[ 264.671990] Buffer I/O error on device mmcblk1p1, logical block 141319
[ 264.678798] Buffer I/O error on device mmcblk1p1, logical block 141320
[ 264.685113] Buffer I/O error on device mmcblk1p1, logical block 141321
[ 264.695805] mmc1: Data CRC error
[ 264.695884] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 264.701087] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 264.706869] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 264.713162] sdhci: Argument: 0x0011c800 | Trn mode: 0x0000002b
[ 264.719199] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 264.725237] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 264.731017] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 264.737312] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 264.743350] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 264.749386] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 264.755425] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 264.761204] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 264.767066] sdhci: Host ctl2: 0x00003000
[ 264.771089] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 264.777233] sdhci: ===========================================
[ 264.788699] mmcblk1: error -84 transferring data, sector 1165312, nr 1024, cmd response 0x900, card status 0xc00
[ 264.796277] mmc1: Data CRC error
[ 264.796643] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 264.802504] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 264.808365] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 264.814228] sdhci: Argument: 0x0011cc00 | Trn mode: 0x0000002b
[ 264.822185] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 264.825695] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 264.831556] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 264.837678] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 264.843715] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 264.849318] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 264.855614] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 264.861394] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 264.867514] sdhci: Host ctl2: 0x00003000
[ 264.871021] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 264.877683] sdhci: ===========================================
[ 264.884829] mmcblk1: error -84 transferring data, sector 1166336, nr 1024, cmd response 0x900, card status 0xc00
[ 264.896299] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 427819008 size 8388608 starting)
[ 264.915382] mmc1: Data CRC error
[ 264.915476] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 264.915817] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 264.921685] sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000037f
[ 264.927801] sdhci: Argument: 0x0011d000 | Trn mode: 0x0000002b
[ 264.933664] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 264.939442] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 264.945480] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 264.951341] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 264.957640] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 264.963417] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 264.969713] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 264.975574] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 264.981179] sdhci: Host ctl2: 0x00003000
[ 264.984946] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe430
[ 264.991604] sdhci: ===========================================
[ 264.997729] mmcblk1: error -84 transferring data, sector 1167360, nr 1024, cmd response 0x900, card status 0xc00
[ 265.011252] mmc1: Data CRC error
[ 265.011326] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 265.016359] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 265.022476] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 265.028337] sdhci: Argument: 0x0011d400 | Trn mode: 0x0000002b
[ 265.033942] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 265.040062] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 265.045926] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 265.051529] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 265.057567] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 265.063689] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 265.069728] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 265.075762] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 265.081636] sdhci: Host ctl2: 0x00003000
[ 265.085390] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 265.091532] sdhci: ===========================================
[ 265.099393] mmcblk1: error -84 transferring data, sector 1168384, nr 1024, cmd response 0x900, card status 0xc00
[ 265.108376] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 427819008 size 8388608 starting)
[ 265.125689] mmc1: Data CRC error
[ 265.125767] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 265.130190] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 265.135792] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 265.141912] sdhci: Argument: 0x0011d800 | Trn mode: 0x0000002b
[ 265.147518] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 265.153811] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 265.159591] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 265.165454] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 265.171492] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 265.177787] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 265.183825] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 265.189430] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 265.195290] sdhci: Host ctl2: 0x00003000
[ 265.199056] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 265.205716] sdhci: ===========================================
[ 265.213459] mmcblk1: error -84 transferring data, sector 1169408, nr 1024, cmd response 0x900, card status 0xc00
[ 265.226279] mmc1: Data CRC error
[ 265.226373] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 265.230471] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 265.236332] sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000037f
[ 265.242450] sdhci: Argument: 0x0011dc00 | Trn mode: 0x0000002b
[ 265.248054] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 265.253916] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 265.259780] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 265.265900] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 265.271937] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 265.277541] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 265.283838] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 265.289875] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 265.295737] sdhci: Host ctl2: 0x00003000
[ 265.299243] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe430
[ 265.305648] sdhci: ===========================================
[ 265.312189] mmcblk1: error -84 transferring data, sector 1170432, nr 1024, cmd response 0x900, card status 0xc00
[ 265.323690] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 427819008 size 8388608 starting)
[ 265.339511] mmc1: Data CRC error
[ 265.339606] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 265.344304] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 265.350163] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 265.355767] sdhci: Argument: 0x0011e000 | Trn mode: 0x0000002b
[ 265.361888] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 265.367669] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 265.373704] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 265.379824] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 265.385865] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 265.391901] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 265.397681] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 265.403800] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 265.409664] sdhci: Host ctl2: 0x00003000
[ 265.413428] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 265.419572] sdhci: ===========================================
[ 265.427585] mmcblk1: error -84 transferring data, sector 1171456, nr 1024, cmd response 0x900, card status 0xc00
[ 265.449026] mmc1: Data CRC error
[ 265.449118] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 265.449228] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 265.450702] sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000037f
[ 265.456563] sdhci: Argument: 0x0011e400 | Trn mode: 0x0000002b
[ 265.462426] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 265.468290] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 265.473893] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 265.480014] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 265.485794] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 265.491914] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 265.497951] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 265.503730] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 265.509592] sdhci: Host ctl2: 0x00003000
[ 265.513358] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe430
[ 265.520019] sdhci: ===========================================
[ 265.526476] mmcblk1: error -84 transferring data, sector 1172480, nr 1024, cmd response 0x900, card status 0xc00
[ 265.538349] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 427819008 size 8388608 starting)
[ 265.553828] mmc1: Data CRC error
[ 265.553908] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 265.558416] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 265.564275] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 265.570138] sdhci: Argument: 0x0011e800 | Trn mode: 0x0000002b
[ 265.575742] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 265.582040] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 265.588075] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 265.593938] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 265.599976] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 265.606014] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 265.611794] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 265.617913] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 265.623774] sdhci: Host ctl2: 0x00003000
[ 265.627282] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 265.633685] sdhci: ===========================================
[ 265.641688] mmcblk1: error -84 transferring data, sector 1173504, nr 1024, cmd response 0x900, card status 0xc00
[ 265.654564] mmc1: Data CRC error
[ 265.654658] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 265.658695] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 265.664813] sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000037f
[ 265.670417] sdhci: Argument: 0x0011ec00 | Trn mode: 0x0000002b
[ 265.676279] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 265.682399] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 265.688262] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 265.693867] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 265.700163] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 265.705766] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 265.712062] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 265.717842] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 265.723961] sdhci: Host ctl2: 0x00003000
[ 265.727469] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe430
[ 265.733872] sdhci: ===========================================
[ 265.740088] mmcblk1: error -84 transferring data, sector 1174528, nr 1024, cmd response 0x900, card status 0xc00
[ 265.752196] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 427819008 size 8388608 starting)
[ 265.767917] mmc1: Data CRC error
[ 265.768009] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 265.772526] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 265.778387] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 265.784248] sdhci: Argument: 0x0011f000 | Trn mode: 0x0000002b
[ 265.790112] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 265.795892] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 265.802189] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 265.807791] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 265.814087] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 265.819867] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 265.825905] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 265.831766] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 265.837886] sdhci: Host ctl2: 0x00003000
[ 265.841654] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 265.848053] sdhci: ===========================================
[ 265.855784] mmcblk1: error -84 transferring data, sector 1175552, nr 1024, cmd response 0x900, card status 0xc00
[ 265.865113] mmc1: Data CRC error
[ 265.867201] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 265.873063] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 265.878668] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 265.884529] sdhci: Argument: 0x0011f400 | Trn mode: 0x0000002b
[ 265.890651] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 265.896512] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 265.902374] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 265.908238] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 265.914275] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 265.920137] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 265.926175] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 265.931954] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 265.938074] sdhci: Host ctl2: 0x00003000
[ 265.941839] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 265.948241] sdhci: ===========================================
[ 265.955002] mmcblk1: error -84 transferring data, sector 1176576, nr 1024, cmd response 0x900, card status 0xc00
[ 265.966320] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 427819008 size 8388608 starting)
[ 265.981723] mmc1: Data CRC error
[ 265.981816] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 265.986381] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 265.992501] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 265.998104] sdhci: Argument: 0x0011f800 | Trn mode: 0x0000002b
[ 266.003966] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 266.010004] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 266.016042] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 266.022162] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 266.027942] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 266.034236] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 266.040276] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 266.046138] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 266.051741] sdhci: Host ctl2: 0x00003000
[ 266.055764] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 266.061908] sdhci: ===========================================
[ 266.069879] mmcblk1: error -84 transferring data, sector 1177600, nr 1024, cmd response 0x900, card status 0xc00
[ 266.079491] mmc1: Data CRC error
[ 266.081312] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 266.087175] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 266.093037] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 266.098900] sdhci: Argument: 0x0011fc00 | Trn mode: 0x0000002b
[ 266.104763] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 266.110367] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 266.116229] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 266.122350] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 266.128129] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 266.133991] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 266.140030] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 266.146325] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 266.151931] sdhci: Host ctl2: 0x00003000
[ 266.155953] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 266.162353] sdhci: ===========================================
[ 266.168753] mmcblk1: error -84 transferring data, sector 1178624, nr 1024, cmd response 0x900, card status 0xc00
[ 266.180515] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 427819008 size 8388608 starting)
[ 266.195611] mmc1: Data CRC error
[ 266.195704] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 266.200495] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 266.206355] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 266.212475] sdhci: Argument: 0x00120000 | Trn mode: 0x0000002b
[ 266.218338] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 266.224117] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 266.230412] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 266.236274] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 266.242312] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 266.248091] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 266.254386] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 266.260249] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 266.265854] sdhci: Host ctl2: 0x00003000
[ 266.269879] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 266.276278] sdhci: ===========================================
[ 266.284048] mmcblk1: error -84 transferring data, sector 1179648, nr 1024, cmd response 0x900, card status 0xc00
[ 266.294627] mmc1: Data CRC error
[ 266.295167] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 266.301289] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 266.307151] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 266.313012] sdhci: Argument: 0x00120400 | Trn mode: 0x0000002b
[ 266.318875] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 266.324479] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 266.330600] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 266.336463] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 266.342499] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 266.348104] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 266.354399] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 266.360179] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 266.366299] sdhci: Host ctl2: 0x00003000
[ 266.370065] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 266.376465] sdhci: ===========================================
[ 266.388653] mmcblk1: error -84 transferring data, sector 1180672, nr 1024, cmd response 0x900, card status 0xc00
[ 266.393129] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:313: I/O error -5 writing to inode 12 (offset 436207616 size 8388608 starting)
[ 266.410025] mmc1: Data CRC error
[ 266.410107] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 266.414606] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 266.420725] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003fe
[ 266.426589] sdhci: Argument: 0x00120800 | Trn mode: 0x0000002b
[ 266.432192] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 266.438229] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 266.444525] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 266.450387] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 266.456425] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 266.462461] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 266.468500] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 266.474363] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 266.480224] sdhci: Host ctl2: 0x00003000
[ 266.483990] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 266.490392] sdhci: ===========================================
[ 266.497861] mmcblk1: error -84 transferring data, sector 1181696, nr 1024, cmd response 0x900, card status 0xc00
[ 266.508330] mmc1: Data timeout error
[ 266.509803] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 266.515405] sdhci: Sys addr: 0x00000400 | Version: 0x00000505
[ 266.521526] sdhci: Blk size: 0x00007200 | Blk cnt: 0x000003ff
[ 266.527129] sdhci: Argument: 0x00120c00 | Trn mode: 0x0000002b
[ 266.533250] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 266.539113] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 266.544975] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 266.550837] sdhci: Timeout: 0x0000000d | Int stat: 0x00000000
[ 266.556618] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02fc008b
[ 266.562738] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 266.568517] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 266.574811] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 266.580503] sdhci: Host ctl2: 0x00003000
[ 266.584269] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe420
[ 266.590928] sdhci: ===========================================
Only power off or replug sd card can solve the above problem(reboot can’t).
